[GRASS-SVN] r33905 - grass/branches/develbranch_6/raster/r.series
Thu Oct 16 07:12:10 EDT 2008
Author: neteler
Date: 2008-10-16 07:12:10 -0400 (Thu, 16 Oct 2008)
New Revision: 33905
   grass/branches/develbranch_6/raster/r.series/description.html
   grass/branches/develbranch_6/raster/r.series/main.c
glynn: Add range= option (merge fom trunk, r33886)
Modified: grass/branches/develbranch_6/raster/r.series/description.html
--- grass/branches/develbranch_6/raster/r.series/description.html	2008-10-16 11:11:29 UTC (rev 33904)
+++ grass/branches/develbranch_6/raster/r.series/description.html	2008-10-16 11:12:10 UTC (rev 33905)
@@ -40,9 +40,16 @@
 number of the raster map that holds the minimum/maximum value of the
 time-series. The numbering starts at <em>0</em> up to <em>n</em> for the
 first and the last raster listed in <em>input=</em>, respectively.
+<p>
+If the <em>range=</em> option is given, any values which fall outside
+that range will be treated as if they were NULL.
+The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
+values outside of this range are treated as NULL (i.e., they will be
+ignored by most aggregates, or will cause the result to be NULL if -n is given).
+The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
+<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
+negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
 <h2>EXAMPLES</h2>
 Using <em>r.series</em> with wildcards:
Modified: grass/branches/develbranch_6/raster/r.series/main.c
--- grass/branches/develbranch_6/raster/r.series/main.c	2008-10-16 11:11:29 UTC (rev 33904)
+++ grass/branches/develbranch_6/raster/r.series/main.c	2008-10-16 11:12:10 UTC (rev 33905)
@@ -104,7 +104,7 @@
     struct GModule *module;
     struct
-	struct Option *input, *output, *method;
+	struct Option *input, *output, *method, *range;
     } parm;
     struct
@@ -121,6 +121,7 @@
     DCELL *values, *values_tmp;
     int nrows, ncols;
     int row, col;
+    double lo, hi;
     G_gisinit(argv[0]);
@@ -149,6 +150,12 @@
     flag.quiet->key = 'q';
     flag.quiet->description = _("Run quietly");
+    parm.range = G_define_option();
+    parm.range->key = "range";
+    parm.range->type = TYPE_DOUBLE;
+    parm.range->key_desc = "lo,hi";
+    parm.range->description = _("Ignore values outside this range");
     flag.nulls = G_define_flag();
     flag.nulls->key = 'n';
     flag.nulls->description = _("Propagate NULLs");
@@ -163,6 +170,11 @@
 		    "in future. Please use '--quiet' instead."));
+    if (parm.range->answer) {
+	lo = atof(parm.range->answers[0]);
+	hi = atof(parm.range->answers[1]);
     /* process the input maps */
     for (i = 0; parm.input->answers[i]; i++) ;
     num_inputs = i;
@@ -237,6 +249,10 @@
 		if (G_is_d_null_value(&v))
 		    null = 1;
+		else if (parm.range->answer && (v < lo || v > hi)) {
+		    G_set_d_null_value(&v, 1);
+		    null = 1;
 		values[i] = v;
