[GRASS-SVN] r33919 - in
grass/branches/develbranch_6/imagery/i.ortho.photo: menu
photo.2target photo.camera photo.elev photo.target
svn_grass at osgeo.org
Thu Oct 16 10:18:27 EDT 2008
Author: hamish
Date: 2008-10-16 10:18:27 -0400 (Thu, 16 Oct 2008)
New Revision: 33919
grass/branches/develbranch_6/imagery/i.ortho.photo/menu/menu.c
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.camera/main.c
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.target/main.c
residual cleanup
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/menu/menu.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/menu/menu.c 2008-10-16 14:17:05 UTC (rev 33918)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/menu/menu.c 2008-10-16 14:18:27 UTC (rev 33919)
@@ -59,25 +59,25 @@
/* get and check the group reference files */
if (!I_get_group_ref(group.name, &group.group_ref)) {
- G_warning("Pre-selected group <%s> not found.", group.name);
+ G_warning(_("Pre-selected group <%s> not found"), group.name);
/* clean the wrong name in GROUPFILE */
I_put_group("");
/* ask for new group name */
- if (!I_ask_group_old
- ("Enter imagery group for ortho-rectification", group.name))
- exit(0);
+ if (!I_ask_group_old(
+ _("Enter imagery group for ortho-rectification"), group.name))
+ exit(EXIT_SUCCESS);
I_get_group_ref(group.name, &group.group_ref);
if (group.group_ref.nfiles <= 0)
- G_fatal_error("Group [%s] contains no files\n", group.name);
+ G_fatal_error(_("Group [%s] contains no files"), group.name);
I_put_group(group.name);
while (1) {
if (!I_get_group(group.name)) {
- exit(0);
/* print the screen full of options */
@@ -109,7 +109,7 @@
if (!G_gets(buf))
continue;
if (*buf == 0) /* exit */
- exit(0);
/* run the program choosen */
G_strip(buf);
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c 2008-10-16 14:17:05 UTC (rev 33918)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c 2008-10-16 14:18:27 UTC (rev 33919)
@@ -44,6 +44,9 @@
int ok;
int nfiles;
+ /* must run in a term window */
+ G_putenv("GRASS_UI_TERM", "1");
G_gisinit(argv[0]);
module = G_define_module();
@@ -61,13 +64,13 @@
map_opt = G_define_standard_option(G_OPT_R_MAP);
map_opt->required = NO;
map_opt->description = _("Name of image to be rectified which will "
- " be initially drawn on screen.");
+ "be initially drawn on screen");
target_map_opt = G_define_standard_option(G_OPT_R_MAP);
target_map_opt->key = "target";
target_map_opt->required = NO;
target_map_opt->description = _("Name of a map from target mapset which "
- " will be initially drawn on screen.");
+ "will be initially drawn on screen");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.camera/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.camera/main.c 2008-10-16 14:17:05 UTC (rev 33918)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.camera/main.c 2008-10-16 14:18:27 UTC (rev 33919)
@@ -7,9 +7,11 @@
* Roberto Flor <flor itc.it>,
* Bernhard Reiter <bernhard intevation.de>,
* Glynn Clements <glynn gclements.plus.com>
- * PURPOSE: creates or modifies entries in a camera reference file
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * Hamish Bowman
+ * PURPOSE: Creates or modifies entries in a camera reference file
+ * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c 2008-10-16 14:17:05 UTC (rev 33918)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c 2008-10-16 14:18:27 UTC (rev 33919)
@@ -7,9 +7,11 @@
- * PURPOSE: select the elevation model
+ * Hamish Bowman
+ * PURPOSE: Select the elevation model
* for details.
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.target/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.target/main.c 2008-10-16 14:17:05 UTC (rev 33918)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.target/main.c 2008-10-16 14:18:27 UTC (rev 33919)
@@ -8,7 +8,8 @@
* Hamish Bowman
- * PURPOSE: select target location and mapset
+ * PURPOSE: Select target location and mapset
