[GRASS-SVN] r33932 - grass-addons/gipe/i.emissivity
Mon Oct 20 06:25:23 EDT 2008
Author: ychemin
Date: 2008-10-20 06:25:23 -0400 (Mon, 20 Oct 2008)
New Revision: 33932
Added:
   grass-addons/gipe/i.emissivity/i.emissivity.html
Removed:
   grass-addons/gipe/i.emissivity/description.html
   grass-addons/gipe/i.emissivity/emissivity_generic.c
   grass-addons/gipe/i.emissivity/main.c
preparing for main SVN
Deleted: grass-addons/gipe/i.emissivity/description.html
--- grass-addons/gipe/i.emissivity/description.html	2008-10-20 08:26:56 UTC (rev 33931)
+++ grass-addons/gipe/i.emissivity/description.html	2008-10-20 10:25:23 UTC (rev 33932)
@@ -1,25 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>i.emissivity</EM> calculates the emissivity in the longwave radiation spectrum, according to the semi-empirical equation related to NDVI by Caselles and Colles (1997), valid in the NDVI range of 0.16 to 0.74.
-Estimation in the 8-14 micrometers range for sparse canopy
-<H2>NOTES</H2>
-<H2>TODO</H2>
-<H2>SEE ALSO</H2>
-<em>
-<A HREF="i.eb.netrad.html">i.eb.netrad</A><br>
-</em>
-<H2>AUTHORS</H2>
-Yann Chemin, GRASS Development Team<BR>
-<p>
-<i>Last changed: $Date: 2007/03/29 22:19:55 $</i>
Modified: grass-addons/gipe/i.emissivity/emissivity_generic.c
--- grass-addons/gipe/i.emissivity/emissivity_generic.c	2008-10-20 08:26:56 UTC (rev 33931)
+++ grass-addons/gipe/i.emissivity/emissivity_generic.c	2008-10-20 10:25:23 UTC (rev 33932)
@@ -9,15 +9,12 @@
     double result;
-    if (ndvi < 0.16) {
+    if (ndvi < 0.16)
 	result = 1.0;
-    else if (ndvi > 0.74) {
+    else if (ndvi > 0.74)
 	result = 0.9;
-    else {
+    else
 	result = 1.009 + 0.047 * log(ndvi);
     return result;
Copied: grass-addons/gipe/i.emissivity/i.emissivity.html (from rev 33842, grass-addons/gipe/i.emissivity/description.html)
--- grass-addons/gipe/i.emissivity/i.emissivity.html	                        (rev 0)
+++ grass-addons/gipe/i.emissivity/i.emissivity.html	2008-10-20 10:25:23 UTC (rev 33932)
@@ -0,0 +1,25 @@
+<H2>DESCRIPTION</H2>
+<EM>i.emissivity</EM> calculates the emissivity in the longwave radiation spectrum, according to the semi-empirical equation related to NDVI by Caselles and Colles (1997), valid in the NDVI range of 0.16 to 0.74.
+Estimation in the 8-14 micrometers range for sparse canopy
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.eb.netrad.html">i.eb.netrad</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, GRASS Development Team<BR>
+<p>
+<i>Last changed: $Date: 2007/03/29 22:19:55 $</i>
Property changes on: grass-addons/gipe/i.emissivity/i.emissivity.html
___________________________________________________________________
Modified: grass-addons/gipe/i.emissivity/main.c
--- grass-addons/gipe/i.emissivity/main.c	2008-10-20 08:26:56 UTC (rev 33931)
+++ grass-addons/gipe/i.emissivity/main.c	2008-10-20 10:25:23 UTC (rev 33932)
@@ -1,4 +1,3 @@
  * MODULE:       i.emissivity
@@ -13,152 +12,102 @@
  *   	    	 for details.
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
 double emissivity_generic(double ndvi);
 int main(int argc, char *argv[])
-    struct Cell_head cellhd;	/*region+header info */
-    char *mapset;		/*mapset name */
     int nrows, ncols;
     int row, col;
     struct GModule *module;
-    struct Option *input1, *output1;
-    struct Flag *flag1, *flag2;
+    struct Option *input, *output;
     struct History history;	/*metadata */
-	/* FMEO Declarations**************** */
-    char *name;			/*input raster name */
-    char *result1;		/*output raster name */
-	/*File Descriptors */
-    int infd_ndvi;
-    int outfd1;
+    char *result1;    /*output raster name */
+    int infd, outfd;    /*File Descriptors */
     char *ndvi;
     char *emissivity;
+    void *inr;
+    DCELL * outr;
-    int i = 0, j = 0;
-    void *inrast_ndvi;
-    DCELL * outrast1;
-    RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
-    RASTER_MAP_TYPE data_type_ndvi;
-	G_gisinit(argv[0]);
+    G_gisinit(argv[0]);
     module = G_define_module();
     module->keywords = _("emissivity, land flux, energy balance");
     module->description =
 	_("Emissivity from NDVI, generic method for spares land.");
-	/* Define the different options */
-	input1 = G_define_standard_option(G_OPT_R_INPUT);
-    input1->description = _("Name of the NDVI map [-]");
-    output1 = G_define_standard_option(G_OPT_R_INPUT);
-    output1->description = _("Name of the output emissivity layer");
+    /* Define the different options */
+    input = G_define_standard_option(G_OPT_R_INPUT);
+    input->description = _("Name of the NDVI map [-]");
-	if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    ndvi = input1->answer;
-    result1 = output1->answer;
+    output = G_define_standard_option(G_OPT_R_INPUT);
+    output->description = _("Name of the output emissivity layer");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
-	mapset = G_find_cell2(ndvi, "");
-    if (mapset == NULL) {
-	G_fatal_error(_("cell file [%s] not found"), ndvi);
-    data_type_ndvi = G_raster_map_type(ndvi, mapset);
-    if ((infd_ndvi = G_open_cell_old(ndvi, mapset)) < 0)
+    ndvi = input->answer;
+    result1 = output->answer;
+    if ((infd = G_open_cell_old(ndvi, "")) < 0)
 	G_fatal_error(_("Cannot open cell file [%s]"), ndvi);
-    if (G_get_cellhd(ndvi, mapset, &cellhd) < 0)
-	G_fatal_error(_("Cannot read file header of [%s])"), ndvi);
-    inrast_ndvi = G_allocate_raster_buf(data_type_ndvi);
+    inr = G_allocate_d_raster_buf();
-	G_debug(3, "number of rows %d", cellhd.rows);
     nrows = G_window_rows();
     ncols = G_window_cols();
-    outrast1 = G_allocate_raster_buf(data_type_output);
+    outr = G_allocate_d_raster_buf();
-	/* Create New raster files */
-	if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
+    /* Create New raster files */
+    if ((outfd = G_open_raster_new(result1, DCELL_TYPE)) < 0)
 	G_fatal_error(_("Could not open <%s>"), result1);
-	/* Process pixels */
-	for (row = 0; row < nrows; row++)
+    /* Process pixels */
+    for (row = 0; row < nrows; row++)
 	DCELL d;
 	DCELL d_ndvi;
 	G_percent(row, nrows, 2);
-	    /* read input maps */
-	    if (G_get_raster_row(infd_ndvi, inrast_ndvi, row, data_type_ndvi)
-		< 0)
+        /* read input maps */
+        if (G_get_raster_row(infd,inr,row,DCELL_TYPE)< 0)
 	    G_fatal_error(_("Could not read from <%s>"), ndvi);
-	    /*process the data */
-	    for (col = 0; col < ncols; col++)
-	    switch (data_type_ndvi) {
-	    case CELL_TYPE:
-		d_ndvi = (double)((CELL *) inrast_ndvi)[col];
-		break;
-	    case FCELL_TYPE:
-		d_ndvi = (double)((FCELL *) inrast_ndvi)[col];
-		break;
-	    case DCELL_TYPE:
-		d_ndvi = ((DCELL *) inrast_ndvi)[col];
-		break;
-	    if (G_is_d_null_value(&d_ndvi)) {
-		G_set_d_null_value(&outrast1[col], 1);
+        /*process the data */
+        for (col = 0; col < ncols; col++)
+            d_ndvi = ((DCELL *) inr)[col];
+	    if (G_is_d_null_value(&d_ndvi))
+		G_set_d_null_value(&outr[col], 1);
 	    else {
-		    /* calculate emissivity     */
-		    d = emissivity_generic(d_ndvi);
-		outrast1[col] = d;
+                /* calculate emissivity     */
+                d = emissivity_generic(d_ndvi);
+		outr[col] = d;
-	if (G_put_raster_row(outfd1, outrast1, data_type_output) < 0)
+	if (G_put_raster_row(outfd, outr, DCELL_TYPE) < 0)
 	    G_fatal_error(_("Cannot write to output raster file"));
-    G_free(inrast_ndvi);
-    G_close_cell(infd_ndvi);
-    G_free(outrast1);
-    G_close_cell(outfd1);
+    G_free(inr);
+    G_close_cell(infd);
+    G_free(outr);
+    G_close_cell(outfd);
     G_short_history(result1, "raster", &history);
     G_command_history(&history);
     G_write_history(result1, &history);
     exit(EXIT_SUCCESS);
