[GRASS-SVN] r33943 - in grass/trunk: general/g.gui lib/init
    svn_grass at osgeo.org
    Mon Oct 20 22:27:24 EDT 2008
Author: hamish
Date: 2008-10-20 22:27:23 -0400 (Mon, 20 Oct 2008)
New Revision: 33943
   grass/trunk/general/g.gui/g.gui.html
   grass/trunk/general/g.gui/main.c
   grass/trunk/lib/init/functions.sh
   grass/trunk/lib/init/grass7.html
   grass/trunk/lib/init/variables.html
remove references to old Tcl/Tk GUIs
Modified: grass/trunk/general/g.gui/g.gui.html
--- grass/trunk/general/g.gui/g.gui.html	2008-10-21 01:55:42 UTC (rev 33942)
+++ grass/trunk/general/g.gui/g.gui.html	2008-10-21 02:27:23 UTC (rev 33943)
@@ -5,17 +5,15 @@
 from the command line prompt.
 <p>
-Currently three different GUIs are supported:
+GRASS 7 has a new GUI based on wxWidgets, written in Python:
 <ul>
-<li><b>tcltk</b> - Current Tcl/Tk based GUI aka the <em>gis.m</em>
-    <a href="gis.m.html">GIS Manager</a></li>
-<li><b>oldtcltk</b> - Old Tcl/Tk based GUI aka the <em>d.m</em>
-    <a href="d.m.html">Display Manager</a></li>
 <li><b>wxpython</b> - New wxPython based GUI aka
     <a href="wxGUI.html">wxGUI</a></li>
 </ul>
+The old <em>gis.m</em> and <em>d.m</em> Tcl/Tk GUIs from GRASS 6 have been removed.
+<p>
 If the <b>-u</b> update flag is given or the <em>g.gisenv</em>
 <tt>GRASS_GUI</tt> variable is missing, then the <tt>GRASS_GUI</tt>
 variable is permanently changed and the selected GUI will be used
@@ -24,8 +22,7 @@
 <h2>NOTES</h2>
-Valid values for GRASS_GUI are <tt>text</tt>, <tt>tcltk</tt>,
-<tt>oldtcltk</tt>, and <tt>wxpython</tt>.
+Valid values for GRASS_GUI are <tt>text</tt> and <tt>wxpython</tt>.
 <em>g.gisenv</em> variables are stored in the user's home directory
 in a hidden file called "<TT>.grassrc7</TT>". They are not shell environment
@@ -37,9 +34,7 @@
 <em>
 <a href="wxGUI.html">wxPython based new generation GUI</a>,
-<a href="http://grass.gdf-hannover.de/wiki/WxPython-based_GUI_for_GRASS">wxGUI wiki-page</a><br>
-<a href="gis.m.html">Tcl/Tk based GIS Manager (gis.m)</a>,<br>
-<a href="d.m.html">Tcl/Tk based Display Manager (d.m)</a>,<br><br>
+<a href="http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS">wxGUI wiki-page</a><br>
 <a href="g.gisenv.html">g.gisenv</a>, <a href="variables.html">GRASS variables list</a>
 </em>
Modified: grass/trunk/general/g.gui/main.c
--- grass/trunk/general/g.gui/main.c	2008-10-21 01:55:42 UTC (rev 33942)
+++ grass/trunk/general/g.gui/main.c	2008-10-21 02:27:23 UTC (rev 33943)
@@ -42,10 +42,8 @@
     type->type = TYPE_STRING;
     type->label = _("GUI type");
     type->description = _("Default value: GRASS_GUI if defined otherwise wxpython");
-    type->descriptions = _("tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);"
-			   "oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);"
-			   "wxpython;wxPython based next generation GUI");
-    type->options = "tcltk,oldtcltk,wxpython";
+    type->descriptions = _("wxpython;wxPython based GUI");
+    type->options = "wxpython";
     rc_file = G_define_standard_option(G_OPT_F_INPUT);
     rc_file->key = "workspace";
@@ -77,29 +75,7 @@
-    if (strcmp(type->answer, "oldtcltk") == 0) {
-	sprintf(progname, "%s/etc/dm/d.m.tcl", G_gisbase());
-	if (rc_file->answer) {
-	    G_spawn(getenv("GRASS_WISH"), "d.m", progname, "-name", "d_m_tcl",
-		    rc_file->answer, NULL);
-	else {
-		    NULL);
-    else if (strcmp(type->answer, "tcltk") == 0) {
-	sprintf(progname, "%s/etc/gm/gm.tcl", G_gisbase());
-	    G_spawn(getenv("GRASS_WISH"), "gis.m", progname, "-name",
-		    "gm_tcl", rc_file->answer, NULL);
-	else {
-		    "gm_tcl", NULL);
-    else if (strcmp(type->answer, "wxpython") == 0) {
+    if (strcmp(type->answer, "wxpython") == 0) {
 	sprintf(progname, "%s/etc/wxpython/wxgui.py", G_gisbase());
 	    G_spawn("python", "wxgui", progname, "--workspace",
Modified: grass/trunk/lib/init/functions.sh
--- grass/trunk/lib/init/functions.sh	2008-10-21 01:55:42 UTC (rev 33942)
+++ grass/trunk/lib/init/functions.sh	2008-10-21 02:27:23 UTC (rev 33943)
@@ -10,7 +10,7 @@
     cat <<-EOF
 	Usage:
 	  $CMD_NAME [-h | -help | --help] [-v | --version] [-c]
-		  [-text | -gui | -tcltk | -wxpython]
+		  [-text | -gui | -wxpython]
 		  [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
 	Flags:
@@ -21,8 +21,6 @@
 	                                   and set as default
 	  -gui                           use graphical user interface ($DEFAULT_GUI by default)
 	                                   and set as default
-	  -tcltk                         use Tcl/Tk based graphical user interface
-	                                   and set as default
 	  -wxpython                      use wxPython based graphical user interface
 	                                   and set as default
@@ -34,7 +32,7 @@
 	  GISDBASE/LOCATION_NAME/MAPSET  fully qualified initial mapset directory
 	Environment variables relevant for startup:
-	  GRASS_GUI                      select GUI (text, gui, tcltk, wxpython)
+	  GRASS_GUI                      select GUI (text, gui, wxpython)
 	  GRASS_WISH                     set wish shell name to override 'wish'
 	  GRASS_HTML_BROWSER             set html web browser for help pages
 	  GRASS_ADDON_PATH               set additional path(s) to local GRASS modules
@@ -98,10 +96,10 @@
 	GRASS_GUI="$DEFAULT_GUI"
     fi
-    # d.m no longer exists
+    # gis.m, d.m no longer exist
     case "$GRASS_GUI" in
-    d.m | oldtcltk)
-	GRASS_GUI=gis.m
+    d.m | oldtcltk | gis.m)
+	GRASS_GUI="$DEFAULT_GUI"
     esac
@@ -257,26 +255,16 @@
 	if [ "$GRASS_GUI" = "wxpython" ]; then
 	    echo 'variable=True' | "$GRASS_PYTHON" >/dev/null 2>&1
 	fi
-	# Check if we need to find wish
-	if [ "$GRASS_GUI" = "tcltk" ] || \
-	    [ "$GRASS_GUI" = "gis.m" ] ; then
-	    # Check if wish is working properly
-	    echo 'exit 0' | "$GRASS_WISH" >/dev/null 2>&1
-	fi
 	# ok
 	if [ "$?" = 0 ] ; then
-	    # Set the tcltkgrass base directory
-	    TCLTKGRASSBASE="$ETC"
 	    # Set the wxpython base directory
 	    WXPYTHONGRASSBASE="$ETC/wxpython"
 	else
-	    # Wish was not found - switch to text interface mode
+	    # Python was not found - switch to text interface mode
 	    cat <<-EOF
-		WARNING: The wish command does not work as expected!
-		Please check your GRASS_WISH environment variable.
+		WARNING: The python command does not work as expected!
+		Please check your GRASS_PYTHON environment variable.
 		Use the -help option for details.
 		Switching to text based interface mode.
@@ -420,7 +408,7 @@
 	    # Check for GUI
-	    tcltk | gis.m | wxpython)
+	    wxpython)
 		gui_startup
@@ -436,18 +424,15 @@
 gui_startup()
-    if [ "$GRASS_GUI" = "tcltk" ] || [ "$GRASS_GUI" = "gis.m" ] ; then
+    if [ "$GRASS_GUI" = "wxpython" ] ; then
 		# eval `foo` will return subshell return code and not app foo return code!!!
-	eval '"$GRASS_WISH" -file "$TCLTKGRASSBASE/gis_set.tcl"'
-	thetest=$?
-    else
 	eval '"$GRASS_PYTHON" "$WXPYTHONGRASSBASE/gis_set.py"'
 	thetest=$?
     fi
     case $thetest in
 	1)
-	    # The gis_set.tcl script printed an error message so wait
+	    # The startup script printed an error message so wait
 	    # for user to read it
 	    cat <<-EOF
 		Error in GUI startup. If necessary, please
@@ -481,7 +466,7 @@
 	    exit 0
-	    echo "ERROR: Invalid return code from gis_set.tcl."
+	    echo "ERROR: Invalid return code from GUI startup script."
 	    echo "Please advise GRASS developers of this error."
 	    cleanup_tmpdir
 	    exit 1
@@ -606,10 +591,7 @@
-        # Check for tcltk interface
-        tcltk | gis.m)
-            "$GISBASE/scripts/gis.m"
+        # Check for gui interface
         wxpython)
             "$GISBASE/etc/wxpython/scripts/wxgui"
@@ -664,9 +646,6 @@
 	See the licence terms with:              g.version -c
 	EOF
-    tcltk | gis.m)
-        echo "If required, restart the GUI with:       g.gui tcltk"
     wxpython)
         echo "If required, restart the GUI with:       g.gui wxpython"
@@ -769,7 +748,7 @@
     if [ "$MINGW" ] ; then
 	# "$ETC/run" doesn't work at all???
         "$SHELL"
-	rm -rf "$LOCATION/.tmp"/*  # remove gis.m session files from .tmp
+	rm -rf "$LOCATION/.tmp"/*  # remove GUI session files from .tmp
     else
     	"$ETC/run" "$SHELL"
 	EXIT_VAL=$?
Modified: grass/trunk/lib/init/grass7.html
--- grass/trunk/lib/init/grass7.html	2008-10-21 01:55:42 UTC (rev 33942)
+++ grass/trunk/lib/init/grass7.html	2008-10-21 02:27:23 UTC (rev 33943)
@@ -17,7 +17,7 @@
 <H2>SYNOPSIS</H2>
 <B>grass70</B> [<B>-</B>] [<B>-v</B>] [<B>-h | -help | --help</B>]
-    [<B>-text | -gui | -tcltk | -wxpython]</B>]
+    [<B>-text | -gui | -wxpython]</B>]
     [[[<B><GISDBASE>/</B>]<B><LOCATION_NAME>/</B>]
     	<B><MAPSET></B>]
@@ -43,7 +43,7 @@
 settings for the user interface and mapset selected.
 <P>
-If you specify a graphical user interface (Tcl/Tk or wxPython) the <EM>grass70</EM>
+If you specify a graphical user interface (wxPython) the <EM>grass70</EM>
 program will try to verify that the system you specified exists and that you
 can access it successfully. If any of these checks fail then <EM>grass70</EM>
 will automatically switch back to the text user interface mode.
@@ -67,10 +67,7 @@
 <DT><B>-text</B>
 <DD> Indicates that the text based user interface should be used
-<DT><B>-gui</B> (or <B>-tcltk</B>)
-<DD> Indicates that the old Tcl/Tk based graphical user interface should be used
-<DT><B>-wxpython</B>
+<DT><B>-gui</B> (or <B>-wxpython</B>)
 <DD> Indicates that the new Python based graphical user interface should be used
 <DT><B>-v</B> <B>--version</B>
@@ -126,9 +123,7 @@
 variable called GRASS_GUI which indicates the type of user interface for
 GRASS to use. If this variable is not set when <EM>grass70</EM> is run, then
 it will be created and then saved in the <tt>$HOME/.grassrc7</tt> file for
-the next time GRASS is run. In addition to "text", "tcltk" or "wxpython",
-the GRASS_GUI variable can be set to the name of the Tcl/Tk GUI to use, for
-example "gis.m" or "d.m".
+the next time GRASS is run. It can be set to "text" or "wxpython".
 <P>
 There is an order of precedence in the way <EM>grass70</EM> determines the user
@@ -140,15 +135,15 @@
  <DD>• Command line argument<BR>
      • Environment variable GRASS_GUI<BR>
      • Value set in <tt>$HOME/.grassrc7</tt><BR>
-     • Default value - currently gis.m
+     • Default value - wxpython
 </DL>
 <H3>Tcl/Tk and Python Environment Variables</H3>
 <P>
-If you choose to use the Tcl/Tk graphical user interface, then the following
-environment variables can be used to override your system default
-<tt>tclsh</tt> and <tt>wish</tt> commands.
+If you choose to use the wxPython interface or Tcl/Tk modules, then
+the following environment variables can be used to override your
+system default <tt>tclsh</tt>, <tt>wish</tt>, and <tt>python</tt> commands.
 <DL>
 <DT><B>GRASS_TCLSH</B>
@@ -162,20 +157,14 @@
 </DL>
-<H4>Example Use of GRASS Tcl/Tk Environment Variables</H4>
+<H4>Example Use of GRASS Python Environment Variable</H4>
 <P>
-Suppose your system has Tcl/Tk 8.3 installed and you install a personal
-version of the Tcl/Tk 8.5 binaries under <tt>$HOME/bin</tt>. You can use
-the above variables to have GRASS use the Tcl/Tk 8.5 binaries instead.
+Suppose your system has Python 2.4 installed and you install a personal
+version of the Python 2.5 binaries under <tt>$HOME/bin</tt>. You can use
+the above variables to have GRASS use the Python 2.5 binaries instead.
-<P>
-<pre>
-   GRASS_TCLSH = $HOME/bin/tclsh8.5
-   GRASS_WISH  = $HOME/bin/wish8.5
-</pre>
 <H4>Example Use of the GRASS Python Environment Variable</H4>
 <P>
 <pre>
@@ -372,24 +361,18 @@
 <H2>CAVEAT</H2>
-If you start GRASS using the Tcl/Tk interface you must have a <tt>wish</tt>
+If you start GRASS using the wxPython interface you must have a <tt>python</tt>
 command in your $PATH variable. That is, the command must be named
-<tt>wish</tt> and not something like <tt>wish8.3</tt>. By default, some Tcl/Tk
-installations do not create a <tt>wish</tt> command. In these cases the system
-administrator must create an appropriate link to the actual <tt>wish</tt>
+<tt>python</tt> and not something like <tt>python2.5</tt>. Rarely some Python
+installations do not create a <tt>python</tt> command. In these cases the system
+administrator must create an appropriate link to the actual <tt>python</tt>
 program.
 <P>
-For example, suppose Tcl/Tk 8.3 programs are installed in /usr/local/bin. Then
-the system administrator should go to the /usr/local/bin directory and run the
-commands "<tt>ln -s wish8.3 wish</tt>" and "<tt>ln -s tclsh8.3 tclsh</tt>" to
-properly install Tcl/Tk for use with GRASS.
-<P>
-Furthermore, if you have more than one version of Tcl/Tk installed, make sure
+Furthermore, if you have more than one version of Python installed, make sure
 that the version you want to use with GRASS is the first version found in
 your <tt>$PATH</tt> variable. GRASS searches your <tt>$PATH</tt> variable
-until it finds the first version of <tt>wish</tt>.
+until it finds the first version of <tt>python</tt>.
 <H2>FILES</H2>
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2008-10-21 01:55:42 UTC (rev 33942)
+++ grass/trunk/lib/init/variables.html	2008-10-21 02:27:23 UTC (rev 33943)
@@ -140,9 +140,7 @@
   <dt>GRASS_GUI</dt>
   <dd>either <tt>text</tt> or <tt>gui</tt> to define non-/graphical startup.
     <br><br>
-    Can also specify the name of the GUI to use, e.g. <tt>tcltk</tt>
-    (<em><a href="gis.m.html">gis.m</a></em>), <tt>oldtcltk</tt>
-    (<em><a href="d.m.html">d.m</a></em>) or <tt>wxpython</tt>
+    Can also specify the name of the GUI to use, e.g. <tt>wxpython</tt>
     (<em><a href="wxGUI.html">wxGUI</a></em>). Also exists as a GRASS
     gisenv variable (see below). If this shell variable exists at GRASS
     startup, it will determine the GUI used. If it is not defined startup
@@ -158,7 +156,7 @@
     defines the height of GRASS monitor, see also GRASS_WIDTH.</dd>
   <dt>GRASS_HTML_BROWSER</dt>
-  <dd>[init.sh, d.m, gis.m]<br>
+  <dd>[init.sh, wxgui]<br>
     defines name of HTML browser. For most platforms this should be
     an executable in your PATH, or the full path to an executable.<br><br>
     Mac OS X runs applications differently from the CLI.
@@ -245,7 +243,7 @@
     defines the width of GRASS monitor, see also GRASS_HEIGHT.</dd>
   <dt>GRASS_WISH</dt>
-  <dd>[d.m, nviz]<br>
+  <dd>[nviz, Tcl/Tk programs]<br>
     set wish shell name to override 'wish'.</dd>
   <dt>GRASS_NO_GLX_PBUFFERS</dt>
@@ -451,7 +449,7 @@
     it causes programs to use the specified named region (created with
     e.g. <tt>g.region save=...</tt>) to be used as the current region, instead of
     the region from the WIND file.<br><br>
-    This allows programs such as gis.m to run external commands on an
+    This allows programs such as the GUI to run external commands on an
     alternate region without having to modify the WIND file then change it
     back afterwards.</dd>
 </dl>
@@ -472,10 +470,6 @@
 	g.gisenv set=DEBUG=0
     </pre></div>
-  <dt>DM_FORM_MODE</dt>
-  <dd>[d.m]<br>
-    sets default form mode (<tt>txt</tt> or <tt>gui</tt>)</dd>
   <dt>GISDBASE</dt>
   <dd>initial database</dd>
@@ -490,9 +484,7 @@
   <dt>GRASS_GUI</dt>
     <br><br> Can also specify the name of the GUI to use,
-    e.g. <tt>tcltk</tt>
+    e.g. <tt>wxpython</tt>
     (<em><a href="wxGUI.html">wxGUI</a></em>). Also exists as a shell
     environment variable. If this shell variable exists at GRASS
