[GRASS-SVN] r33955 - in grass/trunk: gui/wxpython/gui_modules raster/r.stats
Tue Oct 21 16:57:58 EDT 2008
Author: martinl
Date: 2008-10-21 16:57:57 -0400 (Tue, 21 Oct 2008)
New Revision: 33955
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/raster/r.stats/main.c
wxGUI: use description instead of value for checkbox
r.report: suppress "r.stats complete"
(merge from devbr6, r33954)
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2008-10-21 20:55:09 UTC (rev 33954)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2008-10-21 20:57:57 UTC (rev 33955)
@@ -753,7 +753,8 @@
                 list.append(layer)
         self.layers.Set(list)
+        self.OnSelectAll(None)
         event.Skip()
     def GetMapLayers(self):
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-10-21 20:55:09 UTC (rev 33954)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-10-21 20:57:57 UTC (rev 33955)
@@ -1006,7 +1006,8 @@
                     p['value'] = p.get('default','')
             if ( len(p.get('values', []) ) > 0):
-                valuelist=map( str, p.get('values',[]) )
+                valuelist      = map(str, p.get('values',[]))
+                valuelist_desc = map(str, p.get('values_desc',[]))
                 if p.get('multiple', 'no') == 'yes' and \
                         p.get('gisprompt',False) == False and \
@@ -1027,14 +1028,23 @@
                         # for multi checkboxes, this is an array of all wx IDs
                         # for each individual checkbox
                         p[ 'wxId' ] = []
+                    idx = 0
                     for val in valuelist:
-                        chkbox = wx.CheckBox( parent=which_panel, label = text_beautify(val) )
+                        try:
+                            label = valuelist_desc[idx]
+                        except IndexError:
+                            label = val
+                        chkbox = wx.CheckBox( parent=which_panel, label = text_beautify(label) )
                         p[ 'wxId' ].append( chkbox.GetId() )
                         if isEnabled.has_key(val):
                             chkbox.SetValue( True )
                         hSizer.Add( item=chkbox, proportion=0,
                                     flag=wx.ADJUST_MINSIZE | wx.ALL, border=1 )
                         chkbox.Bind(wx.EVT_CHECKBOX, self.OnCheckBoxMulti)
+                        idx += 1
                     which_sizer.Add( item=hSizer, proportion=0,
                                      flag=wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border=5 )
                 elif p.get('gisprompt',False) == False:
Modified: grass/trunk/raster/r.stats/main.c
--- grass/trunk/raster/r.stats/main.c	2008-10-21 20:55:09 UTC (rev 33954)
+++ grass/trunk/raster/r.stats/main.c	2008-10-21 20:57:57 UTC (rev 33955)
@@ -337,7 +337,5 @@
 	cell_stats(fd, with_percents, with_counts, with_areas, with_labels,
 		   fmt);
-    G_done_msg(" ");
     exit(EXIT_SUCCESS);
