[GRASS-SVN] r33959 - grass/branches/develbranch_6/raster/r.null
svn_grass at osgeo.org
Tue Oct 21 17:54:15 EDT 2008
Author: martinl
Date: 2008-10-21 17:54:15 -0400 (Tue, 21 Oct 2008)
New Revision: 33959
grass/branches/develbranch_6/raster/r.null/null.c
r.null: header added
i18n, message standardization
Modified: grass/branches/develbranch_6/raster/r.null/null.c
--- grass/branches/develbranch_6/raster/r.null/null.c 2008-10-21 21:26:46 UTC (rev 33958)
+++ grass/branches/develbranch_6/raster/r.null/null.c 2008-10-21 21:54:15 UTC (rev 33959)
@@ -1,3 +1,16 @@
+ * MODULE: r.null
+ * AUTHOR(S): U.S.Army Construction Engineering Research Laboratory
+ * PURPOSE: Manages NULL-values of given raster map.
+ * COPYRIGHT: (C) 2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
@@ -42,15 +55,10 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("raster");
- module->description = _("Creates explicitly the NULL-value bitmap file.");
+ module->keywords = _("raster, null data");
+ module->description = _("Manages NULL-values of given raster map.");
- parms.map = G_define_option();
- parms.map->key = "map";
- parms.map->type = TYPE_STRING;
- parms.map->required = YES;
- parms.map->multiple = NO;
- parms.map->gisprompt = "old,cell,raster";
+ parms.map = G_define_standard_option(G_OPT_R_MAP);
parms.map->description = _("Raster map for which to edit null file");
parms.setnull = G_define_option();
@@ -106,43 +114,48 @@
is_reclass = (G_is_reclass(name, mapset, rname, rmapset) > 0);
if (is_reclass)
- G_fatal_error
- ("%s is a reclass of map <%s> in mapset <%s>. Consider to generate a copy with r.mapcalc. Exiting.",
- name, rname, rmapset);
+ G_fatal_error(_("Raster map <%s> is a reclass of map <%s@%s>. "
+ "Consider to generate a copy with r.mapcalc. Exiting."),
+ name, rname, rmapset);
if (strcmp(mapset, G_mapset()) != 0)
- G_fatal_error("%s is not in your mapset (%s)", name, G_mapset());
+ G_fatal_error(_("Raster map <%s> is not in your mapset <%s>"),
+ name, G_mapset());
if (parms.null->answer) {
if (sscanf(parms.null->answer, "%lf", &new_null) == 1)
change_null = 1;
else
- G_fatal_error("%s is illegal entry for null", parms.null->answer);
+ G_fatal_error(_("%s is illegal entry for null"),
+ parms.null->answer);
map_type = G_raster_map_type(name, mapset);
if (only_null && G_find_file_misc("cell_misc", "null", name, mapset))
- G_fatal_error("%s already has a null bitmap file!", name);
+ G_fatal_error(_("Raster map <%s> already has a null bitmap file"), name);
if (map_type == CELL_TYPE) {
if (only_fp)
- G_fatal_error("%s is integer!", name);
+ G_fatal_error(_("<%s> is integer raster map (CELL)"),
+ name);
if ((double)((int)new_null) != new_null) {
- G_warning("%s is an integer map! Using null=%d", name,
- (int)new_null);
+ G_warning(_("<%s> is integer raster map (CELL). Using null=%d."),
+ name, (int)new_null);
new_null = (double)((int)new_null);
else if (only_int)
- G_fatal_error("%s is floating point!", name);
+ G_fatal_error(_("<%s> is floating pointing raster map"),
+ name);
parse_vallist(parms.setnull->answers, &d_mask);
if (G_get_cellhd(name, mapset, &cellhd) < 0)
- G_fatal_error("Can't read cell header for %s", name);
+ G_fatal_error(_("Unable to read header of raster map <%s>"),
+ G_fully_qualified_name(name, mapset));
if (create) {
/* write a file of no-nulls */
@@ -153,31 +166,38 @@
null_fd = G_open_new_misc("cell_misc", "null", name);
- G_message("Writing new null file for [%s]... ", name);
+ G_verbose_message(_("Writing new null file for raster map <%s>..."),
+ name);
for (row = 0; row < cellhd.rows; row++) {
G_percent(row, cellhd.rows, 1);
if (G__write_null_bits(null_fd, null_bits, row, cellhd.cols, 0) <
0)
- G_fatal_error("Error writing null row %d", row);
+ G_fatal_error(_("Error writing null row %d"), row);
close(null_fd);
- G_message("Done");
+ G_done_msg(_("Raster map <%s> modified."), name);
exit(EXIT_SUCCESS);
if (remove) {
- G_message("Removing null file for [%s]... ", name);
+ G_verbose_message(_("Removing null file for raster map <%s>..."),
+ name);
G__file_name_misc(path, "cell_misc", "null", name, mapset);
unlink(path);
exit(EXIT_SUCCESS);
process(name, mapset, change_null, map_type);
exit(EXIT_SUCCESS);
@@ -235,9 +255,9 @@
else {
if (where)
- G_fatal_error("%s: %s: illegal value spec", where, vallist);
+ G_fatal_error(_("%s: %s: illegal value spec"), where, vallist);
else
- G_fatal_error("%s: illegal value spec", vallist);
+ G_fatal_error(_("%s: illegal value spec"), vallist);
return 0;
@@ -304,20 +324,23 @@
rast = G_allocate_raster_buf(map_type);
- G_message("Writing new data for [%s]... ", name);
+ G_verbose_message(_("Writing new data for raster map <%s>..."), name);
/* the null file is written automatically */
if (G_get_raster_row_nomask(old, rast, row, map_type) < 0) {
- G_warning("Can't read row %d", row);
+ G_warning(_("Unable to read raster map <%s> row %d"),
+ name, row);
break;
mask_raster_array(rast, cellhd.cols, change_null, map_type);
if (G_put_raster_row(new, rast, map_type) < 0) {
- G_warning("Can't write row %d", row);
+ G_warning(_("Failed writing raster map <%s> row %d"),
+ name, row);
break;
@@ -329,5 +352,6 @@
return 1;
G_close_cell(new);
return 0;
