[GRASS-SVN] r33965 - grass-addons/raster/r.viewshed
svn_grass at osgeo.org
Tue Oct 21 18:44:46 EDT 2008
Author: neteler
Date: 2008-10-21 18:44:46 -0400 (Tue, 21 Oct 2008)
New Revision: 33965
grass-addons/raster/r.viewshed/main.cc
added guisections
Modified: grass-addons/raster/r.viewshed/main.cc
--- grass-addons/raster/r.viewshed/main.cc 2008-10-21 22:07:14 UTC (rev 33964)
+++ grass-addons/raster/r.viewshed/main.cc 2008-10-21 22:44:46 UTC (rev 33965)
@@ -479,13 +479,14 @@
struct Option *inputOpt;
inputOpt = G_define_standard_option(G_OPT_R_ELEV);
inputOpt->key = "input";
+ inputOpt->guisection = _("Input_options");
/* the output */
struct Option *outputOpt;
outputOpt = G_define_standard_option(G_OPT_R_OUTPUT);
- outputOpt->description = "Name of output viewshed raser map\n\t\t\tdefault format: {NODATA, -1 (invisible), vertical angle wrt viewpoint (visible)}";
+ outputOpt->description = _("Name of output viewshed raster map\n\t\tdefault format: {NODATA, -1 (invisible), vertical angle wrt viewpoint (visible)}");
+ outputOpt->guisection = _("Output_options");
/* row-column flag */
struct Flag *row_col;
row_col = G_define_flag();
@@ -524,6 +525,7 @@
viewLocOpt->key_desc = "lat,long";
viewLocOpt->description =
("Coordinates of viewing position in latitude-longitude (if -r flag is present, then coordinates are row-column)");
+ viewLocOpt->guisection = _("Input_options");
/* observer elevation */
struct Option *obsElevOpt;
@@ -534,6 +536,7 @@
obsElevOpt->key_desc = "value";
obsElevOpt->description = _("Viewing elevation above the ground");
obsElevOpt->answer = "0.0";
+ obsElevOpt->guisection = _("Input_options");
/* max distance */
struct Option *maxDistOpt;
@@ -547,8 +550,8 @@
char infdist[10];
sprintf(infdist, "%d", INFINITY_DISTANCE);
maxDistOpt->answer = infdist;
+ maxDistOpt->guisection = _("Input_options");
/* memory size */
struct Option *memAmountOpt;
memAmountOpt = G_define_option();
@@ -558,7 +561,6 @@
memAmountOpt->key_desc = "value";
memAmountOpt->description = _("The amount of main memory in MB to be used");
memAmountOpt->answer = "500";
/*fill the options and flags with G_parser */
if (G_parser(argc, argv))
