[GRASS-SVN] r33986 - grass/branches/develbranch_6/raster/r.out.gdal
svn_grass at osgeo.org
Thu Oct 23 02:43:21 EDT 2008
Author: hamish
Date: 2008-10-23 02:43:20 -0400 (Thu, 23 Oct 2008)
New Revision: 33986
grass/branches/develbranch_6/raster/r.out.gdal/main.c
user specified nodata was being clobbered by default if type= was not given; missing space in warning msg
Modified: grass/branches/develbranch_6/raster/r.out.gdal/main.c
--- grass/branches/develbranch_6/raster/r.out.gdal/main.c 2008-10-22 21:59:36 UTC (rev 33985)
+++ grass/branches/develbranch_6/raster/r.out.gdal/main.c 2008-10-23 06:43:20 UTC (rev 33986)
@@ -334,15 +334,15 @@
- if (n_nulls > 0) {
+ if (n_nulls > 0) { /* TODO: && nodata_param NOT specified */
if (maptype == CELL_TYPE)
G_warning(_("Input raster map contains cells with NULL-value (no-data). "
- "The value %d was used to represent no-data values in the input map."
+ "The value %d was used to represent no-data values in the input map. "
"You can specify nodata value by %s parameter."),
(int)nodataval, nodatakey);
else
- "The value %g was used to represent no-data values in the input map."
+ "The value %g was used to represent no-data values in the input map. "
@@ -599,11 +599,6 @@
- /* force nodata-value if needed */
- if (nodataopt->answer) {
- nodataval = atof(nodataopt->answer);
/* If file type not set by user ... */
/* Get min/max values. */
if (G_read_fp_range(ref.file[0].name, ref.file[0].mapset, &sRange) == -1) {
@@ -645,6 +640,11 @@
+ /* force nodata-value if needed */
+ if (nodataopt->answer) {
+ nodataval = atof(nodataopt->answer);
G_debug(3, "Input map datatype=%s\n",
(maptype == CELL_TYPE ? "CELL" :
(maptype == DCELL_TYPE ? "DCELL" :
