[GRASS-SVN] r33988 - grass/branches/develbranch_6/testsuite/raster
svn_grass at osgeo.org
Thu Oct 23 04:04:27 EDT 2008
Author: neteler
Date: 2008-10-23 04:04:27 -0400 (Thu, 23 Oct 2008)
New Revision: 33988
grass/branches/develbranch_6/testsuite/raster/rhemisphere.sh
small fixes
Modified: grass/branches/develbranch_6/testsuite/raster/rhemisphere.sh
--- grass/branches/develbranch_6/testsuite/raster/rhemisphere.sh 2008-10-23 06:47:03 UTC (rev 33987)
+++ grass/branches/develbranch_6/testsuite/raster/rhemisphere.sh 2008-10-23 08:04:27 UTC (rev 33988)
@@ -1,6 +1,9 @@
#!/bin/sh
# Markus Neteler, 2006
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
# Test cases for 2D raster data
# generate a hemisphere to test slope, aspect, curvatures
@@ -9,8 +12,9 @@
RADIUS=500 # half BOXLENGTH
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program."
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
exit 1
fi
@@ -20,7 +24,7 @@
cleanup()
echo "Removing temporary map"
- g.remove rast=$TMP > /dev/null
+ g.remove --q rast=$TMP > /dev/null
@@ -40,6 +44,6 @@
r.mapcalc "hemisphere=$HEIGHT"
cleanup
+g.message "Generated raster map <hemisphere>"
+#echo "Now generate aspect + slope on <hemisphere>"
-echo "Now generate aspect + slope on <hemisphere>"
