[GRASS-SVN] r34002 - in grass/trunk/scripts: v.db.addtable
v.db.dropcol v.db.droptable v.db.update v.rast.stats
svn_grass at osgeo.org
Fri Oct 24 17:23:51 EDT 2008
Author: neteler
Date: 2008-10-24 17:23:51 -0400 (Fri, 24 Oct 2008)
New Revision: 34002
grass/trunk/scripts/v.db.addtable/v.db.addtable
grass/trunk/scripts/v.db.dropcol/v.db.dropcol
grass/trunk/scripts/v.db.droptable/v.db.droptable
grass/trunk/scripts/v.db.update/v.db.update
grass/trunk/scripts/v.rast.stats/v.rast.stats
fix white space bugs
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable
--- grass/trunk/scripts/v.db.addtable/v.db.addtable 2008-10-24 20:38:32 UTC (rev 34001)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable 2008-10-24 21:23:51 UTC (rev 34002)
@@ -125,13 +125,13 @@
driver=`db.connect -p | grep '^driver' | cut -d':' -f2`
else
# there is a definition for layer 1, so we check for the user defined layer
- database=`v.db.connect map="$GIS_OPT_MAP" -g | grep -w "$QUERYLAYER" | awk '{print $4}'`
+ database=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$QUERYLAYER" | awk -F ";" '{print $4}'`
if [ -z "database" ] ; then
#nothing on user defined layer, so we use the default mapset settings in this case:
database=`db.connect -p | grep '^database' | cut -d':' -f2`
else
- driver=`v.db.connect map="$GIS_OPT_MAP" -g | grep -w "$QUERYLAYER" | awk '{print $5}'`
+ driver=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$QUERYLAYER" | awk -F ";" '{print $5}'`
fi
fi
Modified: grass/trunk/scripts/v.db.dropcol/v.db.dropcol
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol 2008-10-24 20:38:32 UTC (rev 34001)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol 2008-10-24 21:23:51 UTC (rev 34002)
@@ -97,15 +97,15 @@
exit 1
fi
-table=`v.db.connect map=$GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | cut -f2 -d" "`
+table=`v.db.connect map=$GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | cut -f2 -d";"`
if [ -z "$table" ] ; then
g.message -e 'There is no table connected to the input vector map! Cannot delete any column'
cleanup
exit 1
fi
-keycol=`v.db.connect -g map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f3 -d' '`
-database=`v.db.connect -g map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f4 -d' '`
-driver=`v.db.connect -g map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f5 -d' '`
+keycol=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f3 -d';'`
+database=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f4 -d';'`
+driver=`v.db.connect -g fs=";" map=$GIS_OPT_MAP | grep -w $GIS_OPT_LAYER | cut -f5 -d';'`
col="$GIS_OPT_COLUMN"
if [ "$col" = "$keycol" ] ; then
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable
--- grass/trunk/scripts/v.db.droptable/v.db.droptable 2008-10-24 20:38:32 UTC (rev 34001)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable 2008-10-24 21:23:51 UTC (rev 34002)
@@ -78,7 +78,7 @@
g.message -e "An error occured while running v.db.connect"
exit 1
fi
- table=`v.db.connect map="$GIS_OPT_MAP" -g | grep -w "$GIS_OPT_LAYER" | awk '{print $2}'`
+ table=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
if [ -z $table ] ; then
g.message -e "No table assigned to layer <$GIS_OPT_LAYER>"
exit 1
@@ -86,7 +86,7 @@
# Removing table name connected to selected layer
else
# Removing user specified table
- existingtable=`v.db.connect map="$GIS_OPT_MAP" -g | grep -w "$GIS_OPT_LAYER" | awk '{print $2}'`
+ existingtable=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
table=$GIS_OPT_TABLE
if [ "$existingtable" != "$table" ] ; then
g.message -e "User selected table <$table> but the table <$existingtable> is linked to layer <$GIS_OPT_LAYER>"
@@ -100,8 +100,8 @@
exit 1
fi
-database=`v.db.connect map="$GIS_OPT_MAP" -g | grep -w "$GIS_OPT_LAYER" | awk '{print $4}'`
-driver=`v.db.connect map="$GIS_OPT_MAP" -g | grep -w "$GIS_OPT_LAYER" | awk '{print $5}'`
+database=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $4}'`
+driver=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $5}'`
g.message "Removing table <$table> linked to layer <$GIS_OPT_LAYER> of vector map <$GIS_OPT_MAP>"
Modified: grass/trunk/scripts/v.db.update/v.db.update
--- grass/trunk/scripts/v.db.update/v.db.update 2008-10-24 20:38:32 UTC (rev 34001)
+++ grass/trunk/scripts/v.db.update/v.db.update 2008-10-24 21:23:51 UTC (rev 34002)
@@ -96,14 +96,14 @@
exit 1
fi
-table=`v.db.connect map="$GIS_OPT_MAP" -g | grep -w "$GIS_OPT_LAYER" | awk '{print $2}'`
+table=`v.db.connect map="$GIS_OPT_MAP" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
g.message -e 'There is no table connected to this map! Run v.db.connect or v.db.addtable first.'
exit 1
fi
# checking column types
coltype=`v.info -c map="$GIS_OPT_MAP" --quiet | grep -w "$GIS_OPT_COLUMN" | cut -d'|' -f1`
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats
--- grass/trunk/scripts/v.rast.stats/v.rast.stats 2008-10-24 20:38:32 UTC (rev 34001)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats 2008-10-24 21:23:51 UTC (rev 34002)
@@ -197,7 +197,7 @@
#check if DBF driver used, in this case cut to 10 chars col names:
DBFDRIVER=0
-v.db.connect -g "$VECTOR" | grep -w "$GIS_OPT_LAYER" | cut -d' ' -f5 | grep -i dbf --quiet
+v.db.connect -g "$VECTOR" fs=";" | grep -w "$GIS_OPT_LAYER" | cut -d';' -f5 | grep -i dbf --quiet
if [ $? -eq 0 ] ; then
DBFDRIVER=1
else
@@ -205,11 +205,11 @@
DBFDRIVER=0
fi
# we need this for non-DBF driver:
-DB_SQLDRIVER=`v.db.connect -g "$VECTOR" | cut -d' ' -f5`
-DB_DATABASE="`v.db.connect -g "$VECTOR" | cut -d' ' -f4`"
+DB_SQLDRIVER=`v.db.connect -g "$VECTOR" fs=";" | cut -d';' -f5`
+DB_DATABASE="`v.db.connect -g "$VECTOR" fs=";" | cut -d';' -f4`"
#Find out which table is linked to the vector map on the given layer
-TABLE=`v.db.connect map="$VECTOR" -g | grep -w "$GIS_OPT_LAYER" | awk '{print $2}'`
+TABLE=`v.db.connect map="$VECTOR" -g fs=";" | grep -w "$GIS_OPT_LAYER" | awk -F ";" '{print $2}'`
if [ -z "$TABLE" ] ; then
exit 1
