[GRASS-SVN] r34005 - in grass/branches/develbranch_6/scripts:
d.vect.thematic db.dropcol db.droptable v.db.addcol
v.db.addtable v.db.dropcol v.db.join v.db.reconnect.all
v.db.renamecol v.db.update v.dissolve v.rast.stats v.report
svn_grass at osgeo.org
Fri Oct 24 17:39:23 EDT 2008
Author: neteler
Date: 2008-10-24 17:39:23 -0400 (Fri, 24 Oct 2008)
New Revision: 34005
grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
grass/branches/develbranch_6/scripts/db.droptable/db.droptable
grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
grass/branches/develbranch_6/scripts/v.db.join/v.db.join
grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all
grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
grass/branches/develbranch_6/scripts/v.db.update/v.db.update
grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve
grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
grass/branches/develbranch_6/scripts/v.report/v.report
fix white space bugs (merge from trunk, r34004)
Modified: grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
--- grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic 2008-10-24 21:39:23 UTC (rev 34005)
@@ -351,9 +351,9 @@
export GRASS_PNG_AUTO_WRITE
fi
-table=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $2}'`
-database=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $4}'`
-driver=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $5}'`
+table=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $2}'`
+database=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $4}'`
+driver=`v.db.connect $GIS_OPT_MAP -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $5}'`
if [ -z "$table" ]
then
@@ -366,7 +366,7 @@
# test, if the column GRASSRGB is in the table
if [ -z "`db.columns table=$table database=$database driver=$driver| grep -i grassrgb`" ] ; then
g.message message="Creating column 'grassrgb' in table '$table'"
- echo "ALTER TABLE $table ADD COLUMN grassrgb varchar(11)" | db.execute database=$database
+ echo "ALTER TABLE $table ADD COLUMN grassrgb varchar(11)" | database="${database}" driver=${driver}
fi
fi
@@ -756,7 +756,7 @@
# update color to database?
if [ $GIS_FLAG_U -eq 1 ] ; then
echo "UPDATE $table SET GRASSRGB = '$themecolor' WHERE\
- $sqlwhere" | db.execute database=$database
+ $sqlwhere" | db.execute database="${database}" driver=${driver}
fi
# Create group for GIS Manager
@@ -1057,7 +1057,7 @@
fi
Modified: grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
--- grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2008-10-24 21:39:23 UTC (rev 34005)
@@ -153,7 +153,7 @@
exit 1
fi
else
- echo "ALTER TABLE $table DROP COLUMN $col" | db.execute database=$database driver=$driver
+ echo "ALTER TABLE $table DROP COLUMN $col" | db.execute database="${database}" driver=${driver}
if [ $? -eq 1 ] ; then
g.message -e "Cannot continue (problem deleting column)."
cleanup
Modified: grass/branches/develbranch_6/scripts/db.droptable/db.droptable
--- grass/branches/develbranch_6/scripts/db.droptable/db.droptable 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/db.droptable/db.droptable 2008-10-24 21:39:23 UTC (rev 34005)
@@ -101,7 +101,7 @@
fi
-echo "DROP TABLE $table" | db.execute database=$database driver=$driver
+echo "DROP TABLE $table" | db.execute database="${database}" driver=${driver}
exit 1
Modified: grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
--- grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2008-10-24 21:39:23 UTC (rev 34005)
@@ -84,14 +84,14 @@
exit 1
fi
if [ -z "$table" ] ; then
g.message -e 'There is no table connected to this map! Run v.db.connect or v.db.addtable first.'
exit 1
fi
colnum=`echo $GIS_OPT_COLUMNS | awk -F, '{print NF}'`
@@ -105,7 +105,7 @@
exit 1
fi
- echo "ALTER TABLE $table ADD COLUMN $col" | db.execute database=$database driver=$driver
+ echo "ALTER TABLE $table ADD COLUMN $col" | db.execute database="${database}" driver=${driver}
g.message -e "Cannot continue (problem adding column)."
exit 1
Modified: grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
--- grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable 2008-10-24 21:39:23 UTC (rev 34005)
@@ -177,7 +177,7 @@
fi
# connect the map to the DB:
-v.db.connect map="$GIS_OPT_MAP" database="$database" driver="$driver" \
+v.db.connect map="$GIS_OPT_MAP" database="${database}" driver="$driver" \
layer="$GIS_OPT_LAYER" table="$table" key=cat
# finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
Modified: grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
--- grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol 2008-10-24 21:39:23 UTC (rev 34005)
@@ -146,7 +146,7 @@
exit 1
fi
else
g.message -e 'Cannot continue (problem deleting column)'
cleanup
Modified: grass/branches/develbranch_6/scripts/v.db.join/v.db.join
--- grass/branches/develbranch_6/scripts/v.db.join/v.db.join 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.db.join/v.db.join 2008-10-24 21:39:23 UTC (rev 34005)
@@ -73,15 +73,15 @@
PROG=`basename $0`
-driver=`v.db.connect -g map="$GIS_OPT_MAP" | grep "^$GIS_OPT_LAYER " | cut -d' ' -f5`
-database=`v.db.connect -g map="$GIS_OPT_MAP" | grep "^$GIS_OPT_LAYER " | cut -d' ' -f4`
+driver=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER " | cut -d';' -f5`
+database=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER " | cut -d';' -f4`
if [ "$driver" = "dbf" ] ; then
g.message -e "JOIN is not supported for tables stored in DBF format."
exit 1
fi
-maptable=`v.db.connect -g map="$GIS_OPT_MAP" | grep "^$GIS_OPT_LAYER " | cut -d' ' -f2`
+maptable=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep "^$GIS_OPT_LAYER " | cut -d';' -f2`
if [ -z "$maptable" ] ; then
g.message 'There is no table connected to this map! Cannot join any column.'
cleanup
@@ -109,7 +109,7 @@
exit 1
fi
echo "UPDATE $maptable SET $col=(SELECT $col
- FROM $GIS_OPT_OTABLE WHERE $GIS_OPT_OTABLE.$GIS_OPT_OCOLUMN=$maptable.$GIS_OPT_COLUMN);" | db.execute driver=$driver database=$database
+ FROM $GIS_OPT_OTABLE WHERE $GIS_OPT_OTABLE.$GIS_OPT_OCOLUMN=$maptable.$GIS_OPT_COLUMN);" | db.execute database="${database}" driver=${driver}
i=`expr $i + 1`
done
Modified: grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all
--- grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.db.reconnect.all/v.db.reconnect.all 2008-10-24 21:39:23 UTC (rev 34005)
@@ -72,7 +72,7 @@
for VECT in `g.list type=vect mapset=${MAPSET} | sed 1,2d | grep -v '^-*$'`
do
g.message message="Reconnecting vector '${VECT}@${MAPSET}'"
- for LINK in `v.db.connect -g map=${VECT}@${MAPSET} | tr ' ' '|'`
+ for LINK in `v.db.connect -g fs=";" map=${VECT}@${MAPSET} | tr ';' '|'`
do
eval `echo $LINK | sed 's$\([^\|]*\)|\([^\|]*\)|\([^\|]*\)|\([^\|]*\)|\([^\|]*\)$LAYER=\1 SCHEMA_TABLE=\2 KEY=\3 DATABASE=\4 DRIVER=\5$'`
@@ -90,7 +90,7 @@
if [ "$DATABASE" = "$OLD_DATABASE" -a "$SCHEMA" = "$OLD_SCHEMA" ]
then
g.message " Reconnecting layer $LAYER"
- CMD="v.db.connect -o map=${VECT}@${MAPSET} layer=$LAYER driver=$DRIVER database=$NEW_DATABASE table=$NEW_SCHEMA_TABLE key=$KEY"
+ CMD="v.db.connect -o map=${VECT}@${MAPSET} layer=$LAYER driver=$DRIVER database=${NEW_DATABASE} table=$NEW_SCHEMA_TABLE key=$KEY"
g.message message="$CMD"
$CMD
else
Modified: grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
--- grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol 2008-10-24 21:39:23 UTC (rev 34005)
@@ -102,16 +102,16 @@
exit 1
fi
-table=`v.db.connect -g map="$GIS_OPT_MAP" | grep -w "$GIS_OPT_LAYER" | cut -f2 -d' '`
+table=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "$GIS_OPT_LAYER" | cut -f2 -d';'`
g.message -e 'There is no table connected to the input vector map! Cannot rename any column'
cleanup
exit 1
fi
-keycol=`v.db.connect -g map="$GIS_OPT_MAP" | grep -w $GIS_OPT_LAYER | cut -f3 -d' '`
-database=`v.db.connect -g map="$GIS_OPT_MAP" | grep -w $GIS_OPT_LAYER | cut -f4 -d' '`
-driver=`v.db.connect -g map="$GIS_OPT_MAP" | grep -w $GIS_OPT_LAYER | cut -f5 -d' '`
+keycol=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w $GIS_OPT_LAYER | cut -f3 -d';'`
+database=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w $GIS_OPT_LAYER | cut -f4 -d';'`
+driver=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w $GIS_OPT_LAYER | cut -f5 -d';'`
oldcol="`echo $GIS_OPT_COLUMN | cut -d',' -f1`"
newcol="`echo $GIS_OPT_COLUMN | cut -d',' -f2`"
@@ -154,10 +154,10 @@
else
v.db.addcol map="$GIS_OPT_MAP" layer=$GIS_OPT_LAYER col="$newcol $oldcoltype" || error
fi
- echo "UPDATE $table SET $newcol=$oldcol" | db.execute database=$database driver=$driver
+ echo "UPDATE $table SET $newcol=$oldcol" | db.execute database="${database}" driver=${driver}
v.db.dropcol map="$GIS_OPT_MAP" layer=$GIS_OPT_LAYER col=$oldcol
else
- echo "ALTER TABLE $table RENAME $oldcol TO $newcol" | db.execute database=$database driver=$driver || error
+ echo "ALTER TABLE $table RENAME $oldcol TO $newcol" | db.execute database="${database}" driver=${driver} || error
fi
# cleanup
Modified: grass/branches/develbranch_6/scripts/v.db.update/v.db.update
--- grass/branches/develbranch_6/scripts/v.db.update/v.db.update 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.db.update/v.db.update 2008-10-24 21:39:23 UTC (rev 34005)
@@ -127,10 +127,10 @@
if [ -n "$GIS_OPT_WHERE" ]
then
echo "UPDATE $table SET $GIS_OPT_COLUMN=$value WHERE $GIS_OPT_WHERE" |
- db.execute database="$database" driver="$driver"
+ db.execute database="${database}" driver=${driver}
else
echo "UPDATE $table SET $GIS_OPT_COLUMN=$value" | \
fi
# write cmd history:
Modified: grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve
--- grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.dissolve/v.dissolve 2008-10-24 21:39:23 UTC (rev 34005)
@@ -102,7 +102,7 @@
exit 1
fi
- table=`v.db.connect $GIS_OPT_INPUT -g | grep -w $GIS_OPT_LAYER | awk '{print $2}'`
+ table=`v.db.connect $GIS_OPT_INPUT -g fs=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $2}'`
g.message -e 'There is no table connected to this map!'
exit 1
Modified: grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats
--- grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats 2008-10-24 21:39:23 UTC (rev 34005)
@@ -318,7 +318,7 @@
g.message -v "Updating the database ..."
-db.execute input="$SQLTMP" database="$DB_DATABASE" driver="$DB_SQLDRIVER"
+db.execute input="$SQLTMP" database="${DB_DATABASE}" driver="$DB_SQLDRIVER"
EXITCODE=$?
Modified: grass/branches/develbranch_6/scripts/v.report/v.report
--- grass/branches/develbranch_6/scripts/v.report/v.report 2008-10-24 21:38:43 UTC (rev 34004)
+++ grass/branches/develbranch_6/scripts/v.report/v.report 2008-10-24 21:39:23 UTC (rev 34005)
@@ -143,7 +143,7 @@
if [ $TABLEEXISTS -eq 1 ] ; then
v.db.select -c map="$MAP" layer="$LAYER" | sort -n -t'|' -k 1 | grep -v '^0' > "$TMP1"
if [ `wc -l "$TMP1" | awk '{print $1}'` -eq 0 ] ; then
- KEY=`v.db.connect -g map="$GIS_OPT_MAP" | grep -w "$LAYER" | cut -f3 -d" "`
+ KEY=`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "$LAYER" | cut -f3 -d';'`
g.message -e "There is a table connected to input vector map '$MAP', but\
there are no categories present in the key column '$KEY'. Consider using\
v.to.db to correct this."
