[GRASS-SVN] r34016 - grass/trunk/raster/r.out.gdal
svn_grass at osgeo.org
Mon Oct 27 00:08:58 EDT 2008
Author: hamish
Date: 2008-10-27 00:08:58 -0400 (Mon, 27 Oct 2008)
New Revision: 34016
Added:
grass/trunk/raster/r.out.gdal/export_band.c
grass/trunk/raster/r.out.gdal/local_proto.h
grass/trunk/raster/r.out.gdal/main.c
grass/trunk/raster/r.out.gdal/r.out.gdal.html
cleanups in pursuit of bug #73 in collaboration with Markus Metz
(merge from devbr6)
* rename & move export band to its own file
* flag to disable writing long (UInt16) color tables
* add type length defines (needs competion & review)
* add some TODO comments where future work is required
* help page cleanups
Copied: grass/trunk/raster/r.out.gdal/export_band.c (from rev 34015, grass/branches/develbranch_6/raster/r.out.gdal/export_band.c)
--- grass/trunk/raster/r.out.gdal/export_band.c (rev 0)
+++ grass/trunk/raster/r.out.gdal/export_band.c 2008-10-27 04:08:58 UTC (rev 34016)
@@ -0,0 +1,301 @@
+* MODULE: r.out.gdal
+* AUTHOR(S): Vytautas Vebra <olivership at gmail.com>
+* PURPOSE: Exports GRASS raster to GDAL suported formats;
+* based on GDAL library.
+* COPYRIGHT: (C) 2006-2008 by the GRASS Development Team
+* This program is free software under the GNU General Public
+* License (>=v2). Read the file COPYING that comes with GRASS
+* for details.
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "cpl_string.h"
+#include "gdal.h"
+#include "local_proto.h"
+int export_band(GDALDatasetH hMEMDS, int band, const char *name,
+ const char *mapset, struct Cell_head *cellhead,
+ RASTER_MAP_TYPE maptype, double nodataval,
+ const char *nodatakey, int suppress_main_colortable)
+ struct Colors sGrassColors;
+ GDALColorTableH hCT;
+ int iColor;
+ int bHaveMinMax;
+ double dfCellMin;
+ double dfCellMax;
+ struct FPRange sRange;
+ int fd;
+ int cols = cellhead->cols;
+ int rows = cellhead->rows;
+ /* Open GRASS raster */
+ fd = G_open_cell_old(name, mapset);
+ if (fd < 0) {
+ G_warning(_("Unable to open raster map <%s>"), name);
+ return -1;
+ /* Get raster band */
+ GDALRasterBandH hBand = GDALGetRasterBand(hMEMDS, band);
+ if (hBand == NULL) {
+ G_warning(_("Unable to get raster band"));
+ return -1;
+ /* Get min/max values. */
+ if (G_read_fp_range(name, mapset, &sRange) == -1) {
+ bHaveMinMax = FALSE;
+ else {
+ bHaveMinMax = TRUE;
+ G_get_fp_range_min_max(&sRange, &dfCellMin, &dfCellMax);
+/* TODO: if data range exceeds export TYPE range exit with an error.
+ Otherwise the module doesn't know what to write for those values */
+ /* suppress useless warnings */
+ CPLPushErrorHandler(CPLQuietErrorHandler);
+ GDALSetRasterColorInterpretation(hBand, GPI_RGB);
+ CPLPopErrorHandler();
+ if (G_read_colors(name, mapset, &sGrassColors) >= 0) {
+ int maxcolor, i;
+ CELL min, max;
+ char key[200], value[200];
+ int rcount;
+ G_get_color_range(&min, &max, &sGrassColors);
+ if (bHaveMinMax) {
+ if (max < dfCellMax) {
+ maxcolor = max;
+ else {
+ maxcolor = (int)ceil(dfCellMax);
+ if (maxcolor > GRASS_MAX_COLORS) {
+ maxcolor = GRASS_MAX_COLORS;
+ G_warning("Too many values, color table cut to %d entries",
+ maxcolor);
+ else {
+ if (max < GRASS_MAX_COLORS) {
+ maxcolor = max;
+ else {
+ G_warning("Too many values, color table set to %d entries",
+ maxcolor);
+ rcount = G_colors_count(&sGrassColors);
+ G_debug(3, "dfCellMin: %f, dfCellMax: %f, maxcolor: %d", dfCellMin,
+ dfCellMax, maxcolor);
+ if(!suppress_main_colortable) {
+ hCT = GDALCreateColorTable(GPI_RGB);
+ for (iColor = 0; iColor <= maxcolor; iColor++) {
+ int nRed, nGreen, nBlue;
+ GDALColorEntry sColor;
+ if (G_get_color(iColor, &nRed, &nGreen, &nBlue, &sGrassColors)) {
+ sColor.c1 = nRed;
+ sColor.c2 = nGreen;
+ sColor.c3 = nBlue;
+ sColor.c4 = 255;
+ G_debug(3,
+ "G_get_color: Y, rcount %d, nRed %d, nGreen %d, nBlue %d",
+ rcount, nRed, nGreen, nBlue);
+ GDALSetColorEntry(hCT, iColor, &sColor);
+ else {
+ sColor.c1 = 0;
+ sColor.c2 = 0;
+ sColor.c3 = 0;
+ sColor.c4 = 0;
+ G_debug(3,
+ "G_get_color: N, rcount %d, nRed %d, nGreen %d, nBlue %d",
+ if (rcount > 0) {
+ /* Create metadata entries for color table rules */
+ sprintf(value, "%d", rcount);
+ GDALSetMetadataItem(hBand, "COLOR_TABLE_RULES_COUNT", value,
+ NULL);
+ /* Add the rules in reverse order */
+ for (i = rcount - 1; i >= 0; i--) {
+ DCELL val1, val2;
+ unsigned char r1, g1, b1, r2, g2, b2;
+ G_get_f_color_rule(&val1, &r1, &g1, &b1, &val2, &r2, &g2, &b2,
+ &sGrassColors, i);
+ sprintf(key, "COLOR_TABLE_RULE_RGB_%d", rcount - i - 1);
+ sprintf(value, "%e %e %d %d %d %d %d %d", val1, val2, r1, g1, b1,
+ r2, g2, b2);
+ GDALSetMetadataItem(hBand, key, value, NULL);
+ GDALSetRasterColorTable(hBand, hCT);
+ else {
+ GDALSetMetadataItem(hBand, "COLOR_TABLE_RULES_COUNT", "0", NULL);
+ /* Create GRASS raster buffer */
+ void *bufer = G_allocate_raster_buf(maptype);
+ if (bufer == NULL) {
+ G_warning(_("Unable to allocate buffer for reading raster map"));
+ return -1;
+ char *nulls = (char *)G_malloc(cols);
+ if (nulls == NULL) {
+ return -1;
+ /* Copy data form GRASS raster to memory raster */
+ int row, col;
+ int n_nulls = 0;
+ if (maptype == FCELL_TYPE) {
+ /* Source datatype understandible by GDAL */
+ GDALDataType datatype = GDT_Float32;
+ FCELL fnullval = (FCELL) nodataval;
+ for (row = 0; row < rows; row++) {
+ if (G_get_raster_row(fd, bufer, row, maptype) < 0) {
+ G_warning(_("Unable to read raster map <%s> row %d"),
+ name, row);
+ return -1;
+ G_get_null_value_row(fd, nulls, row);
+ for (col = 0; col < cols; col++)
+ if (nulls[col]) {
+ ((FCELL *) bufer)[col] = fnullval;
+ if (n_nulls == 0) {
+ GDALSetRasterNoDataValue(hBand, nodataval);
+ n_nulls++;
+ if (GDALRasterIO
+ (hBand, GF_Write, 0, row, cols, 1, bufer, cols, 1, datatype,
+ 0, 0) >= CE_Failure) {
+ G_warning(_("Unable to write GDAL raster file"));
+ return -1;
+ G_percent(row + 1, rows, 2);
+ else if (maptype == DCELL_TYPE) {
+ GDALDataType datatype = GDT_Float64;
+ DCELL dnullval = (DCELL) nodataval;
+ name, row);
+ return -1;
+ if (nulls[col]) {
+ ((DCELL *) bufer)[col] = dnullval;
+ n_nulls++;
+ if (GDALRasterIO
+ return -1;
+ else {
+ GDALDataType datatype = GDT_Int32;
+ CELL inullval = (CELL) nodataval;
+ name, row);
+ return -1;
+ if (nulls[col]) {
+ ((CELL *) bufer)[col] = inullval;
+ n_nulls++;
+ if (GDALRasterIO
+ return -1;
+ if (n_nulls > 0) { /* TODO: && nodata_param NOT specified */
+ if (maptype == CELL_TYPE)
+ G_warning(_("Input raster map contains cells with NULL-value (no-data). "
+ "The value %d was used to represent no-data values in the input map. "
+ "You can specify nodata value by %s parameter."),
+ (int)nodataval, nodatakey);
+ else
+ "The value %g was used to represent no-data values in the input map. "
+ nodataval, nodatakey);
+ return 0;
Copied: grass/trunk/raster/r.out.gdal/local_proto.h (from rev 34015, grass/branches/develbranch_6/raster/r.out.gdal/local_proto.h)
--- grass/trunk/raster/r.out.gdal/local_proto.h (rev 0)
+++ grass/trunk/raster/r.out.gdal/local_proto.h 2008-10-27 04:08:58 UTC (rev 34016)
@@ -0,0 +1,55 @@
+#ifndef __LOCAL_PROTO_H__
+#define __LOCAL_PROTO_H__
+#define GRASS_MAX_COLORS 100000 /* what is the right value? UInt16 -> 65535 ? */
+/* TODO: better- set from lesser of above and TYPE limits listed below */
+/* range limits */
+ GDAL data type minimum maximum
+ Byte 0 255
+ UInt16 0 65,535
+ Int16, CInt16 -32,768 32,767
+ UInt32 0 4,294,967,295
+ Int32, CInt32 -2,147,483,648 2,147,483,647
+ Float32, CFloat32 -3.4E38 3.4E38
+ Float64, CFloat64 -1.79E308 1.79E308
+/* TODO: for data export range checks and nodata value check
+#define TYPE_BYTE_MIN 0
+#define TYPE_BYTE_MAX 255
+#define TYPE_INT16_MIN -32768
+#define TYPE_INT16_MAX 32767
+#define TYPE_UINT16_MIN 0
+#define TYPE_UINT16_MAX 65535
+#define TYPE_UINT32_MIN 0
+#define TYPE_UINT32_MAX 4294967295 // better to use (double)(unsigned int)0xFFFFFFFFu ?
+#define TYPE_INT32_MIN -2147483648
+#define TYPE_INT32_MAX 2147483647
+#define TYPE_FLOAT32_MIN -3.4E38f
+#define TYPE_FLOAT32_MAX 3.4E38f
+#define TYPE_FLOAT64_MIN -1.79E308f
+#define TYPE_FLOAT64_MAX 1.79E308f
+ better to not define Ctypes here, rather in the code use
+ if( type == F16 || type== CF16 )
+#define TYPE_CINT16_MIN TYPE_INT16_MIN
+#define TYPE_CINT16_MAX TYPE_INT16_MAX
+#define TYPE_CINT32_MIN TYPE_INT32_MIN
+#define TYPE_CINT32_MAX TYPE_INT32_MAX
+#define TYPE_CFLOAT32_MIN TYPE_FLOAT32_MIN
+#define TYPE_CFLOAT32_MAX TYPE_FLOAT32_MAX
+#define TYPE_CFLOAT64_MIN TYPE_FLOAT64_MIN
+#define TYPE_CFLOAT64_MAX TYPE_FLOAT64_MAX
+/* export_band.c */
+int export_band(GDALDatasetH, int, const char *, const char *,
+ struct Cell_head *, RASTER_MAP_TYPE, double,
+ const char *, int);
+#endif /* __LOCAL_PROTO_H__ */
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2008-10-27 03:56:41 UTC (rev 34015)
+++ grass/trunk/raster/r.out.gdal/main.c 2008-10-27 04:08:58 UTC (rev 34016)
@@ -3,11 +3,11 @@
-* PURPOSE: exports GRASS raster to many GDAL suported formats;
-* Replace r.out.gdal.sh script based on gdal_translate
-* executable.
-* COPYRIGHT: (C) 2006-2007 by the GRASS Development Team
+* Replaces r.out.gdal.sh script which used the gdal_translate
+* executable and GDAL grass-format plugin.
@@ -31,8 +31,8 @@
#include "gdal.h"
-#define GRASS_MAX_COLORS 100000 /* what is the right value ? */
void supported_formats(char **formats)
@@ -81,275 +81,7 @@
return;
-int import_band(GDALDatasetH hMEMDS, int band, const char *name,
- const char *mapset, struct Cell_head *cellhead,
- RASTER_MAP_TYPE maptype, double nodataval,
- const char *nodatakey)
- struct Colors sGrassColors;
- GDALColorTableH hCT;
- int iColor;
- int bHaveMinMax;
- double dfCellMin;
- double dfCellMax;
- struct FPRange sRange;
- int fd;
- int cols = cellhead->cols;
- int rows = cellhead->rows;
- /* Open GRASS raster */
- fd = G_open_cell_old(name, mapset);
- if (fd < 0) {
- G_warning(_("Unable to open raster map <%s>"), name);
- return -1;
- /* Get raster band */
- GDALRasterBandH hBand = GDALGetRasterBand(hMEMDS, band);
- if (hBand == NULL) {
- G_warning(_("Unable to get raster band"));
- return -1;
- /* Get min/max values. */
- if (G_read_fp_range(name, mapset, &sRange) == -1) {
- bHaveMinMax = FALSE;
- else {
- bHaveMinMax = TRUE;
- G_get_fp_range_min_max(&sRange, &dfCellMin, &dfCellMax);
- /* suppress useless warnings */
- CPLPushErrorHandler(CPLQuietErrorHandler);
- GDALSetRasterColorInterpretation(hBand, GPI_RGB);
- CPLPopErrorHandler();
- if (G_read_colors(name, mapset, &sGrassColors) >= 0) {
- int maxcolor, i;
- CELL min, max;
- char key[200], value[200];
- int rcount;
- G_get_color_range(&min, &max, &sGrassColors);
- if (bHaveMinMax) {
- if (max < dfCellMax) {
- maxcolor = max;
- else {
- maxcolor = (int)ceil(dfCellMax);
- if (maxcolor > GRASS_MAX_COLORS) {
- maxcolor = GRASS_MAX_COLORS;
- G_warning("Too many values, color table cut to %d entries",
- maxcolor);
- else {
- if (max < GRASS_MAX_COLORS) {
- maxcolor = max;
- else {
- G_warning("Too many values, color table set to %d entries",
- maxcolor);
- rcount = G_colors_count(&sGrassColors);
- G_debug(3, "dfCellMin: %f, dfCellMax: %f, maxcolor: %d", dfCellMin,
- dfCellMax, maxcolor);
- hCT = GDALCreateColorTable(GPI_RGB);
- for (iColor = 0; iColor <= maxcolor; iColor++) {
- int nRed, nGreen, nBlue;
- GDALColorEntry sColor;
- if (G_get_color(iColor, &nRed, &nGreen, &nBlue, &sGrassColors)) {
- sColor.c1 = nRed;
- sColor.c2 = nGreen;
- sColor.c3 = nBlue;
- sColor.c4 = 255;
- G_debug(3,
- "G_get_color: Y, rcount %d, nRed %d, nGreen %d, nBlue %d",
- rcount, nRed, nGreen, nBlue);
- GDALSetColorEntry(hCT, iColor, &sColor);
- else {
- sColor.c1 = 0;
- sColor.c2 = 0;
- sColor.c3 = 0;
- sColor.c4 = 0;
- G_debug(3,
- "G_get_color: N, rcount %d, nRed %d, nGreen %d, nBlue %d",
- if (rcount > 0) {
- /* Create metadata entries for color table rules */
- sprintf(value, "%d", rcount);
- GDALSetMetadataItem(hBand, "COLOR_TABLE_RULES_COUNT", value,
- NULL);
- /* Add the rules in reverse order */
- for (i = rcount - 1; i >= 0; i--) {
- DCELL val1, val2;
- unsigned char r1, g1, b1, r2, g2, b2;
- G_get_f_color_rule(&val1, &r1, &g1, &b1, &val2, &r2, &g2, &b2,
- &sGrassColors, i);
- sprintf(key, "COLOR_TABLE_RULE_RGB_%d", rcount - i - 1);
- sprintf(value, "%e %e %d %d %d %d %d %d", val1, val2, r1, g1, b1,
- r2, g2, b2);
- GDALSetMetadataItem(hBand, key, value, NULL);
- GDALSetRasterColorTable(hBand, hCT);
- else {
- GDALSetMetadataItem(hBand, "COLOR_TABLE_RULES_COUNT", "0", NULL);
- /* Create GRASS raster buffer */
- void *bufer = G_allocate_raster_buf(maptype);
- if (bufer == NULL) {
- G_warning(_("Unable to allocate buffer for reading raster map"));
- return -1;
- char *nulls = (char *)G_malloc(cols);
- if (nulls == NULL) {
- return -1;
- /* Copy data form GRASS raster to memory raster */
- int row, col;
- int n_nulls = 0;
- if (maptype == FCELL_TYPE) {
- /* Source datatype understandible by GDAL */
- GDALDataType datatype = GDT_Float32;
- FCELL fnullval = (FCELL) nodataval;
- for (row = 0; row < rows; row++) {
- if (G_get_raster_row(fd, bufer, row, maptype) < 0) {
- G_warning(_("Unable to read raster map <%s> row %d"),
- name, row);
- return -1;
- G_get_null_value_row(fd, nulls, row);
- for (col = 0; col < cols; col++)
- if (nulls[col]) {
- ((FCELL *) bufer)[col] = fnullval;
- if (n_nulls == 0) {
- GDALSetRasterNoDataValue(hBand, nodataval);
- n_nulls++;
- if (GDALRasterIO
- (hBand, GF_Write, 0, row, cols, 1, bufer, cols, 1, datatype,
- 0, 0) >= CE_Failure) {
- G_warning(_("Unable to write GDAL raster file"));
- return -1;
- G_percent(row + 1, rows, 2);
- else if (maptype == DCELL_TYPE) {
- GDALDataType datatype = GDT_Float64;
- DCELL dnullval = (DCELL) nodataval;
- name, row);
- return -1;
- if (nulls[col]) {
- ((DCELL *) bufer)[col] = dnullval;
- n_nulls++;
- if (GDALRasterIO
- return -1;
- else {
- GDALDataType datatype = GDT_Int32;
- CELL inullval = (CELL) nodataval;
- name, row);
- return -1;
- if (nulls[col]) {
- ((CELL *) bufer)[col] = inullval;
- n_nulls++;
- if (GDALRasterIO
- return -1;
- if (n_nulls > 0) { /* TODO: && nodata_param NOT specified */
- if (maptype == CELL_TYPE)
- G_warning(_("Input raster map contains cells with NULL-value (no-data). "
- "The value %d was used to represent no-data values in the input map. "
- "You can specify nodata value by %s parameter."),
- (int)nodataval, nodatakey);
- else
- "The value %g was used to represent no-data values in the input map. "
- nodataval, nodatakey);
- return 0;
static void AttachMetadata(GDALDatasetH hDS, char **papszMetadataOptions)
/* function taken from gdal_translate */
@@ -373,7 +105,7 @@
struct GModule *module;
- struct Flag *flag_l;
+ struct Flag *flag_l, *flag_c;
struct Option *input, *format, *type, *output, *createopt, *metaopt,
*nodataopt;
@@ -390,7 +122,7 @@
module = G_define_module();
module->description =
- _("Exports GRASS raster map into GDAL supported formats.");
+ _("Exports GRASS raster maps into GDAL supported formats.");
module->keywords = _("raster, export");
flag_l = G_define_flag();
@@ -398,6 +130,11 @@
flag_l->description = _("List supported output formats");
flag_l->guisection = _("Print");
+ flag_c = G_define_flag();
+ flag_c->key = 'c';
+ flag_c->label = _("Do not export long colortable");
+ flag_c->description = _("Only applicable to Byte or UInt16 data types.");
input = G_define_standard_option(G_OPT_R_INPUT);
input->required = NO;
input->description = _("Name of raster map (or group) to export");
@@ -430,7 +167,7 @@
type->type = TYPE_STRING;
type->description = _("File type");
type->options =
- "Byte,Int16,UInt16,UInt32,Int32,Float32,Float64,CInt16,CInt32,CFloat32,CFloat64";
+ "Byte,Int16,UInt16,Int32,UInt32,Float32,Float64,CInt16,CInt32,CFloat32,CFloat64";
type->required = NO;
output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -442,8 +179,8 @@
createopt = G_define_option();
createopt->key = "createopt";
createopt->type = TYPE_STRING;
- createopt->description = _("Creation option to the output format driver. "
- "Multiple options may be listed.");
+ createopt->description =
+ _("Creation option(s) to pass to the output format driver");
createopt->multiple = YES;
createopt->required = NO;
@@ -463,9 +200,11 @@
nodataopt->multiple = NO;
nodataopt->required = NO;
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
#ifndef __ALLOW_DYNAMIC_OPTIONS__
/* Init GDAL */
GDALAllRegister();
@@ -476,9 +215,8 @@
exit(EXIT_SUCCESS);
- if (!input->answer) {
+ if (!input->answer)
G_fatal_error(_("Required parameter <%s> not set"), input->key);
/* Try to open input GRASS raster.. */
mapset = G_find_cell2(input->answer, "");
@@ -633,7 +371,7 @@
nodataval = (double)(short)0x8000;
else {
- datatype = GDT_Int32; /* need to furthermore fine tune this? */
+ datatype = GDT_Int32; /* need to fine tune this more? */
nodataval = (double)(int)0x80000000;
@@ -645,6 +383,11 @@
nodataval = atof(nodataopt->answer);
+/* TODO:
+ if( nodata_used && nodataval is out_of_type_range )
+ G_fatal_error(_("No-data value out of range for type %s"), type->answer);
G_debug(3, "Input map datatype=%s\n",
(maptype == CELL_TYPE ? "CELL" :
(maptype == DCELL_TYPE ? "DCELL" :
@@ -722,9 +465,9 @@
ref.file[band].mapset),
band + 1);
- if (import_band
+ if (export_band
(hCurrDS, band + 1, ref.file[band].name, ref.file[band].mapset,
- &cellhead, maptype, nodataval, nodataopt->key) < 0)
+ &cellhead, maptype, nodataval, nodataopt->key, flag_c->answer) < 0)
G_warning(_("Unable to export raster map <%s>"),
ref.file[band].name);
@@ -740,12 +483,12 @@
GDALClose(hDstDS);
if (hMEMDS)
GDALClose(hMEMDS);
CSLDestroy(papszOptions);
G_done_msg(" ");
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.out.gdal/r.out.gdal.html
--- grass/trunk/raster/r.out.gdal/r.out.gdal.html 2008-10-27 03:56:41 UTC (rev 34015)
+++ grass/trunk/raster/r.out.gdal/r.out.gdal.html 2008-10-27 04:08:58 UTC (rev 34016)
@@ -3,15 +3,24 @@
<em>r.out.gdal</em> allows a user to export a GRASS raster map layer
into any GDAL supported raster map format.
-For possible <em>metaopt</em> parameters see the 'supported formats' pages
-of GDAL.
-The <em>createopt</em> may be used to create TFW or World files ("TFW=YES",
-"WORLDFILE=ON").
+For possible <em>metaopt</em> parameters see the individual
+<a href="http://www.gdal.org/formats_list.html">supported formats</a> pages
+on the GDAL website.
+The <em>createopt</em> parameter may be used to create TFW or World files
+("TFW=YES","WORLDFILE=ON").
<p>
-<em>r.out.gdal</em> also supports the export of multiband rasters through
-a group (created e.g. with <em>i.group</em>), when the group's name is entered
-as input.
+<em>r.out.gdal</em> also supports the export of multiband rasters as
+a group, when the imagery group's name is entered as input.
+(created imagery groups with the <em><a href="i.group.html">i.group</a></em>
+module)
+<p>
+As with most GRASS raster modules, the current region extents and region
+resolution are used, and a MASK is respected if present.
+Use <em><a href="g.region.html">g.region</a></em>'s "align=", or "rast="
+options if you need to realign the region settings the original map's
+before export.
<h2>SUPPORTED RASTER FORMATS</h2>
The set of <a href="http://www.gdal.org/formats_list.html">supported
@@ -44,29 +53,102 @@
XPM: X11 PixMap Format
</pre>
<h2>NOTES</h2>
-When writing out GeoTIFF format for users of ESRI software or ImageMagick,
-the band interleaving should be switched to pixel interleaving using
-<em>createopt="INTERLEAVE=PIXEL"</em>.
+When writing out multi-band GeoTIFF images for users of ESRI software or
+ImageMagick, the interleaving mode should be set to "pixel" using
+<em>createopt="INTERLEAVE=PIXEL"</em>. BAND interleaving is slightly more
+efficient, but not supported by some applications.
+<!-- GDAL switched default from BAND to PIXEL interleave on 08/01/07 (r11823) -->
+This issue only arises when writing out multi-band imagery groups.
+Some software may not recognize all of the compression methods available.
+<!-- e.g. data destined for ESRI software should use COMPRESS=LZW/PACKBITS/DEFLATE ??? -->
<p>
To specify multiple options use a comma separated list
(<em>createopt="TFW=YES,COMPRESS=DEFLATE"</em>).
<p>
-Out of the GDAL data types, the closest match for GRASS CELL, FCELL and DCELL
-rasters are respectively Int32, Float32 and Float64. These are not exact
-equivalents, but they will preserve the max possible data range and number of
-decimal places for each respective GRASS raster data type. Please keep in mind, that
-not all CELL rasters will require Int32 - e.g., 0-255 CELL raster are covered
-by the Byte <em>type</em> as well. Moreover, some GDAL-supported formats do not
-support all the data types possible in GDAL and GRASS. Use
-<em><a href="r.info">r.info</a></em> to check the data type and range for your
-GRASS raster, refer to specific format documentation
-(<a href="http://www.gdal.org/">GDAL website</a>, format vendor's docs) and
-e.g. the Wikipedia article
-<em><a href="http://en.wikipedia.org/wiki/C_syntax#Typical_boundaries_of_primitive_integral_types">Typical boundaries of primitive integral types</a></em>
+Out of the GDAL data types, the closest match for GRASS CELL, FCELL and
+DCELL rasters are respectively Int32, Float32 and Float64. These are not
+exact equivalents, but they will preserve the maximum possible data range
+and number of decimal places for each respective GRASS raster data type.
+Please keep in mind that not all CELL rasters will require Int32 - e.g.,
+0-255 CELL raster are covered by the Byte <em>type</em> as well.
+Moreover, some GDAL-supported formats do not support all the data types
+possible in GDAL and GRASS. Use <em><a href="r.info">r.info</a></em> to
+check the data type and range for your GRASS raster, refer to specific
+format documentation (on the <a href="http://www.gdal.org/">GDAL website</a>),
+format vendor's documentation, and e.g. the Wikipedia article
+<em><a href="http://en.wikipedia.org/wiki/C_syntax#Typical_boundaries_of_primitive_integral_types">Typical
+ boundaries of primitive integral types</a></em>
for details.
+<h4>Ranges of GDAL data types</h4>
+<pre>
+ Byte 0 255
+ UInt16 0 65,535
+</pre>
+<p>
+Float32 precision is 7 decimal places, e.g. 1.0000001E20, so 1.000000001E20
+is truncated to 1.0000000E20.
+<p>
+Float64 precision is 16 decimal places, e.g. 1.0000000000000001E20,
+equivalent to DCELL.
+<p>
+Note that e.g. 0.0000000012345678E20 is stored as 1.2345678000000000E11,
+so Float32 would be ok.
+<p>
+If there is a need to keep file sizes small, use the simplest data type
+covering the data range of the raster(s) to be exported, e.g., if suitable
+use Byte rather than UInt16; use Int16 rather than Int32; or use Float32
+rather than Float64. In addition, the COMPRESS <b>createopt</b> used can
+have a very large impact on the size of the output file.
+<h4>Improving GeoTIFF compatibility</h4>
+To create a highly compatibility GeoTIFF with various other GIS software
+packages, it is recommended to keep the GeoTIFF file as simple as possible.
+You will have to experiment with which options your software is compatible
+with, as this varies widely between vendors and versions. Long term, the
+less metadata you have to remove the more self-documenting (and useful)
+the dataset will be.
+<p>
+Here are some things to try:
+<ul>
+<li>Create a World file with <tt>createopt="TFW=YES"</tt>.
+<li>Do not use GeoTIFF internal compression. Other GIS software often
+supports only a subset of the available compression methods with the
+supported methods differing between GIS software packages. Unfortunately
+this means the output image can be rather huge, but the file can be
+compressed with software like <tt>zip</tt>, <tt>gnuzip</tt>, or <tt>bzip2</tt>.
+<li>Skip exporting the color table. Color tables are not always properly
+rendered and the GeoTIFF file can appear completely black. If you are lucky
+the problematic software package has a method to reset the color table.
+<li>Keep metadata simple with <tt>createopt="PROFILE=GeoTIFF"</tt> or
+<tt>createopt="PROFILE=BASELINE"</tt>. With BASELINE no GDAL or GeoTIFF
+tags will be written and a World file is required (<em>createopt="TFW=YES"</em>).
+<li>Adding overviews with <tt>gdaladdo</tt> after exporting can speed up display.
+Note that other software might create their own overviews, ignoring existing
+overviews.
+</ul>
<h2>EXAMPLES</h2>
<h4>Export the integer raster roads map to GeoTIFF format:</h4>
@@ -77,10 +159,17 @@
<h4>Export a DCELL raster map in GeoTIFF format suitable for ESRI software:</h4>
<div class="code"><pre>
-r.out.gdal in=elevation.10m out=ned_elev10m.tif type=Float64 createopt="INTERLEAVE=PIXEL,TFW=YES"
+r.out.gdal in=elevation.10m out=ned_elev10m.tif type=Float64 createopt="TFW=YES"
</pre></div>
<p>
+<h4>Export R,G,B imagery bands in GeoTIFF format suitable for ESRI software:</h4>
+<div class="code"><pre>
+i.group group=nc_landsat_rgb input=lsat7_2002_30,lsat7_2002_20,lsat7_2002_10
+r.out.gdal in=nc_landsat_rgb out=nc_landsat_rgb.tif type=Byte createopt="INTERLEAVE=PIXEL,TFW=YES"
+</pre></div>
+<p>
<h4>Export the floating point raster elevation map to ERDAS/IMG format:</h4>
r.out.gdal input=elevation.10m output=elev_dem10.img format=HFA type=Float32
@@ -99,13 +188,17 @@
<h2>GDAL RELATED ERROR MESSAGES</h2>
<ul>
-<li> "ERROR 6: SetColorInterpretation() not supported for this dataset.": This <i>may</i>
- indicate that the color table was not written properly. But usually it will be
- correct and the message can be ignored.</li>
-<li> "ERROR 6: SetNoDataValue() not supported for this dataset.": The selected output format
- does not support "no data". It is recommended to use a different output format.</li>
-<li> "Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.": The color table metadata
- are too large. It is recommended to use a different output format.</li>
+<li> "ERROR 6: SetColorInterpretation() not supported for this dataset.":
+ This <i>may</i> indicate that the color table was not written properly.
+ But usually it will be correct and the message can be ignored.</li>
+<li> "ERROR 6: SetNoDataValue() not supported for this dataset.":
+ The selected output format does not support "no data". It is recommended
+ to use a different output format if your data contains NULLs.</li>
+<li> "Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in
+ tag.": The color table metadata may be too large. It is recommended to
+ simplify or not write the color table, or use a different output format.</li>
</ul>
