[GRASS-SVN] r34021 - grass/branches/develbranch_6/lib/gis
svn_grass at osgeo.org
Mon Oct 27 11:17:52 EDT 2008
Author: marisn
Date: 2008-10-27 11:17:52 -0400 (Mon, 27 Oct 2008)
New Revision: 34021
grass/branches/develbranch_6/lib/gis/gui.tcl
Fix autogenerated modules UI issues with tabs Required and Output. Fixes glitches introduced by r31340
Modified: grass/branches/develbranch_6/lib/gis/gui.tcl
--- grass/branches/develbranch_6/lib/gis/gui.tcl 2008-10-27 13:53:49 UTC (rev 34020)
+++ grass/branches/develbranch_6/lib/gis/gui.tcl 2008-10-27 15:17:52 UTC (rev 34021)
@@ -346,7 +346,7 @@
global bgcolor
if {$guisection == {}} {set guisection {{}}}
if {[llength $guisection] == 1} {
# A frame for a toplevel section
# This uses a scrolled frame in a notebook tab
@@ -356,10 +356,10 @@
set guisection {Options}
set path $opt($dlg,path)
- if {$glabel == "Required"} {
- set optpane [$path.nb insert 0 $guisection -text $glabel]
- } else {
- set optpane [$path.nb insert end $guisection -text $glabel]
+ set optpane [$path.nb insert end $guisection -text $glabel]
+ # Word "required" in $glabel may be translated
+ if {$glabel == [G_msg "Required"]} {
+ $path.nb move $guisection 0
# Specials don't get scrolling frames:
if {$optn == -1} {
@@ -418,11 +418,7 @@
- set firstpg [$path.nb pages 0]
$path.nb raise $guisection
- #Make the first tab the active one instead of the "options" tab
- $path.nb raise $firstpg
proc layout_raise_special_frame {dlg guisection key} {
@@ -747,12 +743,18 @@
make_dialog_end $dlg $path $root
if {$n > 0} {
- layout_raise_frame $dlg $opt($dlg,1,guisection) 1
+ # Rise first page
+ $path.nb raise [$path.nb pages 0]
update
show_cmd $dlg
+ # Following commands will force redrawing of notebook
+ # It is required in case if pages where rearranged
+ $path.nb _realize
+ $path.nb _redraw
proc add_option {optn optlist} {
