[GRASS-SVN] r34046 - grass/branches/develbranch_6/tools
svn_grass at osgeo.org
Wed Oct 29 05:41:45 EDT 2008
Author: hamish
Date: 2008-10-29 05:41:45 -0400 (Wed, 29 Oct 2008)
New Revision: 34046
grass/branches/develbranch_6/tools/build_html_index.sh
- quote filenames
- fix table closing bug
- photo.* now use G_parser(); don't get their own section (TODO: put after imagery list)
- desc for modules that don't use G_parser().
Modified: grass/branches/develbranch_6/tools/build_html_index.sh
--- grass/branches/develbranch_6/tools/build_html_index.sh 2008-10-29 09:22:22 UTC (rev 34045)
+++ grass/branches/develbranch_6/tools/build_html_index.sh 2008-10-29 09:41:45 UTC (rev 34046)
@@ -11,8 +11,6 @@
v.topo.check \
i.ask \
i.find \
-photo.elev \
-photo.target \
helptext.html \
r.watershed.ram \
r.watershed.seg \
@@ -22,7 +20,23 @@
p.out.vrml \
r.cats"
+# these modules don't use G_parser()
+check_for_desc_override()
+ case "$BASENAME" in
+ g.parser)
+ SHORTDESC="Provides automated parser, GUI, and help support for GRASS scipts."
+ r.mapcalc)
+ SHORTDESC="Raster map calculator."
+ r.li.daemon)
+ SHORTDESC="Support module for r.li landscape index calculations."
+ esac
############# nothing to configure below ############
# regex-proof module skip list
@@ -102,6 +116,7 @@
<li><a href=\"gem/index.html\">The GRASS Extensions Manager (GEM)</a></li>
</ul>
<P>
+</td>
" >> "$1"
@@ -183,64 +198,68 @@
#get list of available GRASS modules:
CMDLIST=`ls -1 *.*.html | grep -v "$FULLINDEX" | grep -v index.html | \
- grep -v gis.m.html | grep -v "\($EXCLUDEHTML\)" | cut -d'.' -f1 | sort -u`
+ grep -v gis.m.html | grep -v "\($EXCLUDEHTML\)" | cut -d'.' -f1 | sort -u | \
+ grep -v photo`
CMDLISTNO=`echo $CMDLIST | wc -w | awk '{print $1}'`
#write main index:
echo "Generating HTML manual pages index (help system)..."
-write_html_header $FULLINDEX "GRASS GIS $GRASSVERSION Reference Manual: Full index"
-echo "<BR><h3>Full command index:</h3>" >> $FULLINDEX
-echo "<table border=0>" >> $FULLINDEX
-echo "<tr><td> d.* </td><td>display commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> db.* </td><td>database commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> g.* </td><td>general commands</td></tr>" >> $FULLINDEX
-#echo "<tr><td> g3.* </td><td>general3D commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> i.* </td><td>imagery commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> m.* </td><td>miscellaneous commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> ps.* </td><td>postscript commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> r.* </td><td>raster commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> r3.* </td><td>raster3D commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> v.* </td><td>vector commands</td></tr>" >> $FULLINDEX
-echo "<tr><td> <a href=\"gis.m.html\">gis.m</a> </td><td>GUI frontend to GIS menus and display</td></tr>" >> $FULLINDEX
-echo "<tr><td> <a href=\"nviz.html\">nviz</a> </td><td>visualization suite</td></tr>" >> $FULLINDEX
-echo "<tr><td> <a href=\"wxGUI.html\">wxGUI</a> </td><td>wxPython-based GUI frontend</td></tr>" >> $FULLINDEX
-echo "<tr><td> <a href=\"xganim.html\">xganim</a> </td><td>raster map slideshow</td></tr>" >> $FULLINDEX
-echo "</table>" >> $FULLINDEX
+write_html_header "$FULLINDEX" "GRASS GIS $GRASSVERSION Reference Manual: Full index"
+echo "</tr></table>" >> "$FULLINDEX"
+echo "<BR><h3>Full command index:</h3>" >> "$FULLINDEX"
+echo "<table border=0>" >> "$FULLINDEX"
+echo "<tr><td> d.* </td><td>display commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> db.* </td><td>database commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> g.* </td><td>general commands</td></tr>" >> "$FULLINDEX"
+#echo "<tr><td> g3.* </td><td>general3D commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> i.* </td><td>imagery commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> m.* </td><td>miscellaneous commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> ps.* </td><td>postscript commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> r.* </td><td>raster commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> r3.* </td><td>raster3D commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> v.* </td><td>vector commands</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> <a href=\"gis.m.html\">gis.m</a> </td><td>GUI frontend to GIS menus and display</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> <a href=\"nviz.html\">nviz</a> </td><td>visualization suite</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> <a href=\"wxGUI.html\">wxGUI</a> </td><td>wxPython-based GUI frontend</td></tr>" >> "$FULLINDEX"
+echo "<tr><td> <a href=\"xganim.html\">xganim</a> </td><td>raster map slideshow</td></tr>" >> "$FULLINDEX"
+echo "</table>" >> "$FULLINDEX"
#generate main index of all modules:
-echo "<BR><BR>[ " >> $FULLINDEX
+echo "<BR><BR>[ " >> "$FULLINDEX"
k=0
for i in $CMDLIST
do
k=`expr $k + 1`
- echo -n "<b><a href=\"#$i\">$i.*</a></b>" >> $FULLINDEX
+ echo -n "<b><a href=\"#$i\">$i.*</a></b>" >> "$FULLINDEX"
if [ $k -lt $CMDLISTNO ] ; then
- echo -n " | " >> $FULLINDEX
+ echo -n " | " >> "$FULLINDEX"
fi
done
echo " ]
<BR>
-" >> $FULLINDEX
+" >> "$FULLINDEX"
#for all module groups:
for i in $CMDLIST
do
- echo "<a name=\"$i\"></a>" >> $FULLINDEX
- echo "<BR><BR><h3>$i.* commands:</h3>" >> $FULLINDEX
- echo "<table>" >> $FULLINDEX
+ echo "<a name=\"$i\"></a>" >> "$FULLINDEX"
+ echo "<BR><BR><h3>$i.* commands:</h3>" >> "$FULLINDEX"
+ echo "<table>" >> "$FULLINDEX"
#for all modules:
for i in `ls -1 $i.*.html | grep -v "\($EXCLUDEHTML\)"`
do
BASENAME=`basename $i .html`
SHORTDESC="`cat $i | awk '/NAME/,/SYNOPSIS/' | grep '<em>' | cut -d'-' -f2- | sed 's+^ ++g' | grep -vi 'SYNOPSIS' | head -n 1`"
- echo "<tr><td valign="top"><a href=\"$i\">$BASENAME</a></td> <td>$SHORTDESC</td></tr>" >> $FULLINDEX
+ check_for_desc_override
+ echo "<tr><td valign="top"><a href=\"$i\">$BASENAME</a></td> <td>$SHORTDESC</td></tr>" >> "$FULLINDEX"
done
- echo "</table>" >> $FULLINDEX
+ echo "</table>" >> "$FULLINDEX"
done
-write_html_footer $FULLINDEX index.html
+write_html_footer "$FULLINDEX" index.html
# done full index
#next write separate module pages:
@@ -250,47 +269,49 @@
MODCLASS=`expand_module_class_name $k`
FILENAME=$MODCLASS.html
- write_html_header $FILENAME "GRASS GIS $GRASSVERSION Reference Manual: $MODCLASS"
- echo "<b>$MODCLASS commands:</b>" >> $FILENAME
- echo "<table>" >> $FILENAME
+ write_html_header "$FILENAME" "GRASS GIS $GRASSVERSION Reference Manual: $MODCLASS"
+ echo "</tr></table>" >> "$FILENAME"
+ echo "<b>$MODCLASS commands:</b>" >> "$FILENAME"
+ echo "<table>" >> "$FILENAME"
#for all modules:
for k in `ls -1 $k.*.html | grep -v "\($EXCLUDEHTML\)"`
do
BASENAME=`basename $k .html`
SHORTDESC="`cat $k | awk '/NAME/,/SYNOPSIS/' | grep '<em>' | cut -d'-' -f2- | sed 's+^ ++g' | grep -vi 'SYNOPSIS' | head -n 1`"
- echo "<tr><td valign="top"><a href=\"$k\">$BASENAME</a></td> <td>$SHORTDESC</td></tr>" >> $FILENAME
+ echo "<tr><td valign="top"><a href=\"$k\">$BASENAME</a></td> <td>$SHORTDESC</td></tr>" >> "$FILENAME"
done
- echo "</table>" >> $FILENAME
+ echo "</table>" >> "$FILENAME"
- write_html_footer $FILENAME index.html
+ write_html_footer "$FILENAME" index.html
done
#next write main page:
FILENAME=index.html
-write_html_header $FILENAME "GRASS GIS $GRASSVERSION Reference Manual" 1
+write_html_header "$FILENAME" "GRASS GIS $GRASSVERSION Reference Manual" 1
#modules:
-echo "</td>" >> $FILENAME
-echo "<td valign=\"top\">" >> $FILENAME
-echo "<h3>Manual sections:</h3>" >> $FILENAME
-echo "<ul>" >> $FILENAME
+echo "<td valign=\"top\">" >> "$FILENAME"
+echo "<h3>Manual sections:</h3>" >> "$FILENAME"
+echo "<ul>" >> "$FILENAME"
for k in $CMDLIST
do
- echo "<li><a href=\"$MODCLASS.html\">$MODCLASS commands</a></li>" >> $FILENAME
+ echo "<li><a href=\"$MODCLASS.html\">$MODCLASS commands</a></li>" >> "$FILENAME"
done
#extra stuff for 'nviz' and 'xganim' and GUIs:
-echo "<li><a href=\"gis.m.html\">gis.m</a> and <a href=\"d.m.html\">d.m</a> GIS managers</li>" >> $FILENAME
-echo "<li><a href=\"nviz.html\">nviz</a> visualization and animation tool</li>" >> $FILENAME
-echo "<li><a href=\"wxGUI.html\">wxGUI</a> wxPython-based GUI frontend</li>" >> $FILENAME
-echo "<li><a href=\"xganim.html\">xganim</a> tool for animating a raster map series</li>" >> $FILENAME
+echo "<li><a href=\"gis.m.html\">gis.m</a> and <a href=\"d.m.html\">d.m</a> GIS managers</li>" >> "$FILENAME"
+echo "<li><a href=\"nviz.html\">nviz</a> visualization and animation tool</li>" >> "$FILENAME"
+echo "<li><a href=\"wxGUI.html\">wxGUI</a> wxPython-based GUI frontend</li>" >> "$FILENAME"
+echo "<li><a href=\"xganim.html\">xganim</a> tool for animating a raster map series</li>" >> "$FILENAME"
-echo "</ul>" >> $FILENAME
-echo "</td></tr>" >> $FILENAME
-echo "</table>" >> $FILENAME
+echo "</ul>" >> "$FILENAME"
+echo "</td></tr>" >> "$FILENAME"
+echo "</table>" >> "$FILENAME"
#insert a special comment so that GEM will know where to merge docs of extensions
echo >> "$FILENAME"
@@ -299,7 +320,7 @@
-write_html_footer $FILENAME index.html
+write_html_footer "$FILENAME" index.html
echo "Generated HTML docs in $HTMLDIR/index.html"
