[GRASS-SVN] r34076 - grass/trunk/raster/simwe/r.sim.sediment
svn_grass at osgeo.org
Wed Oct 29 16:43:43 EDT 2008
Author: helena
Date: 2008-10-29 16:43:43 -0400 (Wed, 29 Oct 2008)
New Revision: 34076
grass/trunk/raster/simwe/r.sim.sediment/main.c
site input/output commented out
Modified: grass/trunk/raster/simwe/r.sim.sediment/main.c
--- grass/trunk/raster/simwe/r.sim.sediment/main.c 2008-10-29 20:42:59 UTC (rev 34075)
+++ grass/trunk/raster/simwe/r.sim.sediment/main.c 2008-10-29 20:43:43 UTC (rev 34076)
@@ -73,7 +73,7 @@
#include <grass/Vect.h>
#include <grass/linkm.h>
#include <grass/bitmap.h>
-#include <grass/site.h>
+/*#include <grass/site.h> */
#include <grass/glocale.h>
@@ -165,13 +165,14 @@
parm.maninval->description = _("Name of the Mannings n value");
parm.maninval->guisection = _("Input_options");
- /* needs to be updated to GRASS 6 vector format !! */
+ /* needs to be updated to GRASS 6 vector format !!
parm.sfile = G_define_standard_option(G_OPT_V_INPUT);
parm.sfile->key = "vector";
parm.sfile->required = NO;
parm.sfile->description =
_("Name of the sampling locations vector points map");
parm.sfile->guisection = _("Input_options");
parm.tc = G_define_standard_option(G_OPT_R_OUTPUT);
parm.tc->key = "tc";
@@ -230,6 +231,7 @@
_("Time interval for creating output maps [minutes]");
parm.outiter->guisection = _("Parameters");
parm.density = G_define_option();
parm.density->key = "density";
parm.density->type = TYPE_INTEGER;
@@ -237,6 +239,7 @@
parm.density->required = NO;
parm.density->description = _("Density of output walkers");
parm.density->guisection = _("Parameters");
parm.diffc = G_define_option();
parm.diffc->key = "diffc";
@@ -311,12 +314,12 @@
conc = parm.conc->answer;
flux = parm.flux->answer;
erdep = parm.erdep->answer;
- sfile = parm.sfile->answer;
+/* sfile = parm.sfile->answer; */
/* sscanf(parm.nwalk->answer, "%d", &maxwa); */
sscanf(parm.niter->answer, "%d", ×ec);
sscanf(parm.outiter->answer, "%d", &iterout);
- sscanf(parm.density->answer, "%d", &ldemo);
+/* sscanf(parm.density->answer, "%d", &ldemo); */
sscanf(parm.diffc->answer, "%lf", &frac);
sscanf(parm.maninval->answer, "%lf", &manin_val);
@@ -414,11 +417,13 @@
G_fatal_error(_("Cannot write raster maps"));
if (fdwalkers != NULL)
fclose(fdwalkers);
if (sfile != NULL)
G_sites_close(fw);
/* Exit with Success */
exit(EXIT_SUCCESS);
