[GRASS-SVN] r34078 - grass/branches/develbranch_6/scripts/d.out.file
Wed Oct 29 23:28:53 EDT 2008
Author: hamish
Date: 2008-10-29 23:28:52 -0400 (Wed, 29 Oct 2008)
New Revision: 34078
   grass/branches/develbranch_6/scripts/d.out.file/d.out.file
margin crop enabled for tif, jpg, and non-cairo bmp
Modified: grass/branches/develbranch_6/scripts/d.out.file/d.out.file
--- grass/branches/develbranch_6/scripts/d.out.file/d.out.file	2008-10-29 20:52:40 UTC (rev 34077)
+++ grass/branches/develbranch_6/scripts/d.out.file/d.out.file	2008-10-30 03:28:52 UTC (rev 34078)
@@ -360,6 +360,25 @@
 g.message "Screen export complete. (writing the file may take a small amount of time)"
+if [ $GIS_FLAG_M -eq 0 ] ; then
+   # chop off out of region borders
+   eval `g.region -g`
+   BOX_L=`echo $BOX | cut -f1 -d' '`
+   BOX_R=`echo $BOX | cut -f2 -d' '`
+   BOX_T=`echo $BOX | cut -f3 -d' '`
+   BOX_B=`echo $BOX | cut -f4 -d' '`
+   BOX_WIDTH=`echo $BOX_R $BOX_L | awk '{print $1 - $2}'`
+   BOX_HEIGHT=`echo $BOX_B $BOX_T | awk '{print $1 - $2}'`
+   CROP_PARAM="-srcwin $BOX_L $BOX_T $BOX_WIDTH $BOX_HEIGHT"
+   g.message "Image crop [$BOX_WIDTH x $BOX_HEIGHT]"
+else
+   CROP_PARAM=""
+fi
 d.mon select="$curr_mon"
 case "$GIS_OPT_FORMAT" in
@@ -388,40 +407,24 @@
    tif)
      g.message "Translating to TIFF format"
-     gdal_translate -of GTIFF -quiet "$output" "$outname"
+     gdal_translate -of GTIFF $CROP_PARAM -quiet "$output" "$outname"
      EXITCODE=$?
    jpg)
      g.message "Translating to JPEG format"
      gdal_translate -of JPEG -co QUALITY="$GIS_OPT_QUALITY" \
-	 -quiet "$output" "$outname"
+	 $CROP_PARAM -quiet "$output" "$outname"
      EXITCODE=$?
    bmp)
      g.message "Translating to BMP format"
-     gdal_translate -of BMP -quiet "$output" "$outname"
+     gdal_translate -of BMP $CROP_PARAM -quiet "$output" "$outname"
      EXITCODE=$?
    geotiff)
      g.message "Translating to GeoTIFF format"
-     if [ $GIS_FLAG_M -eq 0 ] ; then
-	# chop off out of region borders
-	eval `g.region -g`
-	BOX_L=`echo $BOX | cut -f1 -d' '`
-	BOX_R=`echo $BOX | cut -f2 -d' '`
-	BOX_T=`echo $BOX | cut -f3 -d' '`
-	BOX_B=`echo $BOX | cut -f4 -d' '`
-	BOX_WIDTH=`echo $BOX_R $BOX_L | awk '{print $1 - $2}'`
-	BOX_HEIGHT=`echo $BOX_B $BOX_T | awk '{print $1 - $2}'`
-	CROP_PARAM="-srcwin $BOX_L $BOX_T $BOX_WIDTH $BOX_HEIGHT"
-	g.message "Image crop [$BOX_WIDTH x $BOX_HEIGHT]"
-     else
-	CROP_PARAM=""
-     fi
      PROJ_WKT="`g.proj -wf`"
      CO=""
      if [ -n "$GIS_OPT_CREATEOPT" ] ; then
