[GRASS-SVN] r34084 - grass/branches/develbranch_6/vector/v.select
svn_grass at osgeo.org
Thu Oct 30 00:10:50 EDT 2008
Author: hamish
Date: 2008-10-30 00:10:50 -0400 (Thu, 30 Oct 2008)
New Revision: 34084
grass/branches/develbranch_6/vector/v.select/description.html
only works on features with cat numbers
Modified: grass/branches/develbranch_6/vector/v.select/description.html
--- grass/branches/develbranch_6/vector/v.select/description.html 2008-10-30 04:04:43 UTC (rev 34083)
+++ grass/branches/develbranch_6/vector/v.select/description.html 2008-10-30 04:10:50 UTC (rev 34084)
@@ -5,6 +5,19 @@
<h2>NOTES</h2>
+Only features with category numbers will be considered. If required
+the <em>v.category</em> module can be used to add them. Typically
+boundaries do not need to be given a category number, as an area's
+attributes are inherited from the centroid. Typically points, lines, and
+centroids will always want to have a cat number.
+<p>
+e.g. take a road which separates two farms. It is ambiguous as to which
+farm an attribute that is attached to the road belongs to. The boundary
+only needs a cat number if it will hold its own attributes, such as road
+name or pavement form. A centroid in each paddock holds the information
+with respect to ownership, area, etc.
<h2>EXAMPLES</h2>
Extract forest fire points from larger fire map:
@@ -21,14 +34,18 @@
out=watrcrsl_italy op=overlap
</pre></div>
<h2>SEE ALSO</h2>
<em>
+<a HREF="v.category.html">v.category</a>,
<a HREF="v.overlay.html">v.overlay</a>,
<a HREF="sql.html">GRASS SQL interface</a></em>
<h2>AUTHORS</h2>
Radim Blazek
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
