[GRASS-SVN] r34094 - grass-web/trunk/devel
svn_grass at osgeo.org
Thu Oct 30 10:42:22 EDT 2008
Author: neteler
Date: 2008-10-30 10:42:22 -0400 (Thu, 30 Oct 2008)
New Revision: 34094
grass-web/trunk/devel/i18n.inc
grass-web/trunk/devel/i18n.php
translation howto moved to Wiki
Modified: grass-web/trunk/devel/i18n.inc
--- grass-web/trunk/devel/i18n.inc 2008-10-30 12:43:44 UTC (rev 34093)
+++ grass-web/trunk/devel/i18n.inc 2008-10-30 14:42:22 UTC (rev 34094)
@@ -5,13 +5,10 @@
<A HREF="#statistics">i18N translation statistics/download</A>
<a name="translations"></a>
-<h3>The idea</h3>
+<h3>The idea: GRASS speaking your language</h3>
The great worldwide interest in GRASS suggests value in translating GRASS messages to
-languages other than english. The "infrastructure" to
-support single-byte as well as multi-byte character sets was implemented
-(based on <a href="http://www.foss4g.org/">the FOSS4G efforts</a>).
+languages other than english.
<P>
The GRASS Development Team is seeking translators.
Please subscribe to the dedicated mailing list at
@@ -19,15 +16,8 @@
<a href="http://lists.osgeo.org/mailman/listinfo/grass-translations">http://lists.osgeo.org/mailman/listinfo/grass-translations</a>
<p>
-Translation related issues may be discussed there (how to start a new
-translation, how to merge old G5.0 translated messages into GRASS 6 etc).
This is an opportunity for non-programmers to contribute as messages
can be easily translated. <b>No programming skills required!</b><br>
-In the links section at bottom of this page you find references to the
-'kbabel' and 'poEdit' software to easily translate the message files.
-The use of a Web based interface is under consideration.
<h3>Wanted languages</h3>
@@ -36,76 +26,18 @@
<h3>HOWTO</h3>
-We have 4 types of .po files per language (see locale/po/):
-<ul>
-<li> grasslibs_LANG.po: messages from libraries
-<li> grassmods_LANG.po: messages from commands ("modules")
-<li> grasstcl_LANG.po: messages from TclTk graphical user interface
-<li> grasswxpy_LANG.po: messages from wxgrass/wxPython graphical user interface
-</ul>
+Please refer to the
+<a href="http://grass.osgeo.org/wiki/GRASS_messages_translation">GRASS messages translation</a> page.
-Briefly, the steps to translate messages are (may be modified in future,
-more details in the README file linked below):
-<ol>
-<li>Get the latest development version from either the SVN repository or as SVN snapshot (see "Download" section)
- or download just existing .po files (see below) from SVN.
-<li>run: '<tt>cd locale</tt>' to change into the translation directory
-<li>run: '<tt>make pot</tt>' to create grass*.pot files (containing original messages)
-<li>run: '<tt>make update-po</tt>' merge new messages into existing *.po files (or create new po files)
-<li>Now translate the messages in the po/*.po files (using kbabel or other editor)
-<li>run: '<tt>make mo</tt>' create the mo files (binary translated message files)
-</ol>
-Please, click here to see details (find the README in the locale/ directory as well):
-<br>
- Translation <a href="http://trac.osgeo.org/grass/browser/grass/trunk/locale/README">README</a>
-<P>
-For terminology, please refer to the
-<a href="http://grass.osgeo.org/wiki/GRASS_Translation_Glossary">GRASS Translation Glossary</a>.
-<P>
-To change to a certain LOCALE (if the system doesn't do it for you or
-for exploring other languages), do the following steps:
-<small>
-<div class="code"><pre>
-# 1. Define/check language settings:
- echo $LANG
- echo $LANGUAGE
- echo $LC_ALL
-# 2. Change it (example for to Japanese):
-# 2.a) bash shell:
- export LANG=ja_JP
- export LANGUAGE=ja_JP
- export LC_ALL=ja_JP
-# 2.b) (t)csh shell:
- setenv LANG ja_JP
- setenv LANGUAGE ja_JP
- setenv LC_ALL ja_JP
-</pre></div>
-</small>
-Now launch GRASS 6 in this terminal. If you launch it from an icon,
-you have to change the LOCALE in the computer setup program instead.
-<h3>Download of existing .po files for modification</h3>
-<a href="http://trac.osgeo.org/grass/browser/grass/trunk/locale/po">Download current .po files</a>
-from SVN (useful if you want to partecipate without compiling GRASS). Please
-announce your efforts on the 'GRASS translations' mailing list (see above) to
-avoid that work is doubled. To start a new language, you can simply rewrite an
-existing file. Take care to rename it properly and to update the language specific
-metadata.
+<h2>Screenshots</h2>
<a name="multibyte"></a>
<h3>Multi-byte FreeType/TrueType TTF support</h3>
+The "infrastructure" to support single-byte as well as multi-byte character sets
+was implemented (based on <a href="http://web.archive.org/web/20061102075759/http://www.foss4g.org/">the FOSS4G efforts</a>).
A multilingual terminal emulator with multi-byte support is <a
-href=http://mlterm.sourceforge.net/>mlterm</a>. <br>
+href="http://mlterm.sourceforge.net/">mlterm</a>. <br>
Using this terminal, GRASS 6 is already able to display
e.g. Japanese fonts in SQL queries (here DBF file):<p>
@@ -131,19 +63,10 @@
<h3>XDRIVER TTF Support</h3>
-Recently the XDRIVER in GRASS was extended to support True/Free Type Fonts.
+The XDRIVER in GRASS supports True/Free Type Fonts.
<P>
<img src=../images/grass57_xdriver_japanese_map.png>
-<h3>Links: .po file editors</h3>
-<ul>
-<li><a href="http://i18n.kde.org/tools/kbabel/">kbabel</a>: KBabel is
- a set of tools for editing and managing gettext PO files (should come with your Linux distibution)
-<li><a href="http://www.poedit.net/download.php">poEdit</a>: poEdit is
- cross-platform gettext catalogs (.po files) editor (works also under MS-Windows)
-</ul>
<?php
include("i18n_stats.inc");
Modified: grass-web/trunk/devel/i18n.php
--- grass-web/trunk/devel/i18n.php 2008-10-30 12:43:44 UTC (rev 34093)
+++ grass-web/trunk/devel/i18n.php 2008-10-30 14:42:22 UTC (rev 34094)
@@ -81,7 +81,7 @@
</table>
<hr>
- <div align="right">© 2004-2007 GRASS Development Team<br>
+ <div align="right">© 2004-2008 GRASS Development Team<br>
<a href="../impressum.html">Imprint</a> |
<a href="../contact.php">Comments</a> about this page<br>
</div>
