[GRASS-SVN] r34121 - grass/trunk/scripts/v.out.gps
svn_grass at osgeo.org
Thu Oct 30 23:46:22 EDT 2008
Author: hamish
Date: 2008-10-30 23:46:22 -0400 (Thu, 30 Oct 2008)
New Revision: 34121
Added:
grass/trunk/scripts/v.out.gps/v.out.gps
rename from v.out.gpsbabel, part II
Copied: grass/trunk/scripts/v.out.gps/v.out.gps (from rev 34120, grass/trunk/scripts/v.out.gps/v.out.gpsbabel)
--- grass/trunk/scripts/v.out.gps/v.out.gps (rev 0)
+++ grass/trunk/scripts/v.out.gps/v.out.gps 2008-10-31 03:46:22 UTC (rev 34121)
@@ -0,0 +1,314 @@
+#!/bin/sh
+# MODULE: v.out.gps
+# PURPOSE: Exports a GRASS vector map to a GPS receiver
+# or data file using GpsBabel
+# COPYRIGHT: (c) 2008 Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# AUTHOR: Hamish Bowman, Dunedin, New Zealand
+# REQUIREMENTS:
+# - GpsBabel from http://gpsbabel.sourceforge.net
+# - cs2cs from PROJ.4 (for m.proj) http://proj.osgeo.org
+# - report supported GpsBabel formats:
+# gpsbabel -^2 | tr '\t' ';' | sort -t';' -k3
+# How to do it
+# http://www.gdal.org/ogr/drv_gpx.html
+# gpsbabel [options] -i INTYPE -f INFILE -o OUTTYPE -F OUTFILE
+#%Module
+#% description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
+#% keywords: vector, export, GPS
+#%End
+#%flag
+#% key: w
+#% description: Export as waypoints
+#%end
+#%flag
+#% key: r
+#% description: Export as routes
+#%end
+#%flag
+#% key: t
+#% description: Export as tracks
+#%end
+############ TODO:
+##%flag
+##% key: z
+##% description: Export altitude from 3D vector's z-coordinate
+##%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#% required: yes
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Feature type(s)
+#% options: point,centroid,line,boundary
+#% multiple: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Name for output file or GPS device
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% required: yes
+#%end
+#%option
+#% key: format
+#% type: string
+#% description: GpsBabel supported output format
+#% answer: gpx
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% label: Layer number
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% answer: 1
+#% required : no
+#% guisection: Subset
+#%end
+#%option
+#% key: where
+#% type: string
+#% label: WHERE conditions of SQL statement without 'where' keyword
+#% description: Example: income < 1000 and inhab >= 10000
+#% required : no
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ # save command line
+ CMDLINE="`basename $0`"
+ for arg in "$@" ; do
+ CMDLINE="$CMDLINE \"$arg\""
+ done
+ export CMDLINE
+ exec g.parser "$0" "$@"
+fi
+# set environment so that awk works properly in all languages
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
+PROG=`basename $0`
+#### check for gpsbabel
+if [ ! -x "`which gpsbabel`" ] ; then
+ g.message -e "The gpsbabel program was not found, please install it first.
+ http://gpsbabel.sourceforge.net"
+ exit 1
+fi
+#### check for cs2cs
+if [ ! -x "`which cs2cs`" ] ; then
+ g.message -e "The cs2cs program was not found, please install it first.
+ http://proj.osgeo.org"
+ exit 1
+fi
+# check if we will overwrite data
+if [ -e "$GIS_OPT_OUTPUT" ] ; then
+ if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
+ g.message -e "Output file already exists."
+ exit 1
+ fi
+fi
+#### set temporary files
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+ g.message -e "Unable to create temporary files"
+ exit 1
+fi
+cleanup()
+ g.message -d "Cleaning up ..."
+ \rm -f "$TMP" "$TMP.gpx"
+ # only try to remove map if it exists to avoid ugly warnings
+ g.findfile element=vector file="tmp_vogb_epsg4326_$$" > /dev/null
+ if [ $? -eq 0 ] ; then
+ g.remove vect="tmp_vogb_epsg4326_$$" --quiet
+ fi
+ g.findfile element=vector file="tmp_vogb_extr_$$" > /dev/null
+ g.remove vect="tmp_vogb_extr_$$" --quiet
+ fi
+#### trap ctrl-c so that we can clean up tmp
+trap 'cleanup' 2 3 15
+#### process command line arguments
+WPT=$GIS_FLAG_W ; RTE=$GIS_FLAG_R ; TRK=$GIS_FLAG_T
+if [ $WPT -eq 1 ] && ([ $RTE -eq 1 ] || [ $TRK -eq 1 ]) ; then
+ g.message -e "One feature at a time please."
+ rm -f "${TMP}"
+ exit 1
+fi
+# logic eludes me at pressent.. [combine with above]
+if [ $RTE -eq 1 ] && [ $TRK -eq 1 ] ; then
+ rm -f "${TMP}"
+ exit 1
+fi
+if [ $WPT -eq 0 ] && [ $RTE -eq 0 ] && [ $TRK -eq 0 ] ; then
+ g.message -e "No features requested for export."
+ cleanup
+ exit 1
+fi
+# set some reasonable defaults
+if [ $WPT -eq 1 ] ; then
+ if [ -z "$GIS_OPT_TYPE" ] ; then
+ GIS_OPT_TYPE="point"
+ fi
+else
+ GIS_OPT_TYPE="line"
+ fi
+fi
+# SQL extract if needed
+if [ -n "$GIS_OPT_WHERE" ] ; then
+ v.extract in="$GIS_OPT_INPUT" out="tmp_vogb_extr_$$" \
+ type="$GIS_OPT_TYPE" layer="$GIS_OPT_LAYER" \
+ where="$GIS_OPT_WHERE" --quiet
+ if [ $? -ne 0 ] ; then
+ g.message -e "Error executing SQL query"
+ cleanup
+ exit 1
+ fi
+ eval `v.info -t map="tmp_vogb_extr_$$"`
+ if [ "$primitives" -eq 0 ] ; then
+ g.message -e "SQL query returned an empty map"
+ cleanup
+ exit 1
+ fi
+ INMAP="tmp_vogb_extr_$$"
+else
+ INMAP="$GIS_OPT_INPUT"
+fi
+#### set up projection info
+# TODO: check if we are already in ll/WGS84. If so skip m.proj step.
+# TODO: multi layer will probably fail badly due to sed 's/^ 1 /'
+# output as old GRASS 4 vector ascii and fight with dig_ascii/?
+# reproject to lat/lon WGS84
+v.out.ascii in="$INMAP" format=standard | \
+ sed -e 's/^\([PLBCFKA]\)/#\1/' -e 's/^ 1 /# 1 /' | \
+ tail -n +11 | m.proj -od --quiet | \
+ sed -e 's/\t\([-\.0-9]*\) .*/ \1/' \
+ -e 's/^\([-\.0-9]\)/ \1/' \
+ -e 's/^#//' | \
+ v.in.ascii out=tmp_vogb_epsg4326_$$ -n format=standard --quiet
+if [ $? -ne 0 ] ; then
+ g.message -e "Error reprojecting data"
+ cleanup
+ exit 1
+fi
+# export as GPX using v.out.ogr
+if [ $TRK -eq 1 ] ; then
+ LINETYPE="FORCE_GPX_TRACK=YES,"
+elif [ $RTE -eq 1 ] ; then
+ LINETYPE="FORCE_GPX_ROUTE=YES,"
+else
+ LINETYPE=""
+fi
+# TODO: cat is being reported as evelation? or is <ele>=element??
+# TODO: fix attribute output. ogr2ogr -sql to rename columns?
+# see http://www.gdal.org/ogr/drv_gpx.html
+v.out.ogr in=tmp_vogb_epsg4326_$$ dsn="$TMP.gpx" type="$GIS_OPT_TYPE" \
+ format=GPX lco="${LINETYPE}GPX_USE_EXTENSIONS=YES" --quiet
+ g.message -e "Error exporting data"
+ cleanup
+ exit 1
+fi
+if [ "$GIS_OPT_FORMAT" = gpx ] ; then
+ # short circuit, we have what we came for.
+ mv "$TMP.gpx" "$GIS_OPT_OUTPUT"
+ cleanup
+ g.message -d "Fast exit"
+ exit 0
+fi
+# run gpsbabel
+GTYPE=""
+ GTYPE="-w"
+elif [ $TRK -eq 1 ] ; then
+ GTYPE="-t"
+ GTYPE="-r"
+fi
+gpsbabel $GTYPE -i gpx -f "$TMP.gpx" \
+ -o "$GIS_OPT_FORMAT" -F "$GIS_OPT_OUTPUT"
+ g.message -e "Error running GpsBabel"
+ cleanup
+ exit 1
+fi
+cleanup
+g.message -v "Done."
+exit
