[GRASS-SVN] r33186 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Sep 1 06:39:56 EDT 2008
Author: martinl
Date: 2008-09-01 06:39:54 -0400 (Mon, 01 Sep 2008)
New Revision: 33186
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: render command layer on enter
multiple commands separated by ';' can be entered, trac #268
(merge from devbr6, r33185)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-09-01 10:32:30 UTC (rev 33185)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-09-01 10:39:54 UTC (rev 33186)
@@ -134,8 +134,20 @@
# execute command
try:
- runcmd = gcmd.Command(cmd=self.cmdlist + ['--q'],
- stderr=None)
+ if self.type == 'command':
+ read = False
+ for cmd in self.cmdlist:
+ runcmd = gcmd.Command(cmd=cmd + ['--q'],
+ stderr=None)
+ if runcmd.returncode != 0:
+ break
+ if not read:
+ os.environ["GRASS_PNG_READ"] = "TRUE"
+ os.environ["GRASS_PNG_READ"] = "FALSE"
+ else:
+ runcmd = gcmd.Command(cmd=self.cmdlist + ['--q'],
+ stderr=None)
#clean up after probley
@@ -178,7 +190,13 @@
@return command list/string
if string:
- return ' '.join(self.cmdlist)
+ cmdStr = ''
+ cmdStr += ' '.join(cmd) + ';'
+ return cmdStr
+ else:
+ return ' '.join(self.cmdlist)
else:
return self.cmdlist
@@ -255,7 +273,7 @@
"""Set new command for layer"""
self.cmdlist = cmd
Debug.msg(3, "Layer.SetCmd(): cmd='%s'" % self.GetCmd(string=True))
# for re-rendering
self.force_render = True
@@ -848,6 +866,8 @@
os.environ["GRASS_RENDER_IMMEDIATE"] = "png"
else:
os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
self._renderLayers(force, mapWindow, maps, masks, opacities)
@@ -1005,10 +1025,10 @@
if kargs.has_key('type'):
layer.SetType(kargs['type']) # check type
if kargs.has_key('command'):
layer.SetCmd(kargs['command'])
if kargs.has_key('name'):
layer.SetName(kargs['name'])
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-09-01 10:32:30 UTC (rev 33185)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-09-01 10:39:54 UTC (rev 33186)
@@ -540,10 +540,11 @@
if ltype == 'command':
# generic command item
ctrl = wx.TextCtrl(self, id=wx.ID_ANY, value='',
- pos=wx.DefaultPosition, size=(250,25),
- style=wx.TE_MULTILINE|wx.TE_WORDWRAP)
+ pos=wx.DefaultPosition, size=(self.GetSize()[0]-100,25),
+ # style=wx.TE_MULTILINE|wx.TE_WORDWRAP)
+ style=wx.TE_PROCESS_ENTER | wx.TE_DONTWRAP)
ctrl.Bind(wx.EVT_TEXT_ENTER, self.OnCmdChanged)
- ctrl.Bind(wx.EVT_TEXT, self.OnCmdChanged)
+ # ctrl.Bind(wx.EVT_TEXT, self.OnCmdChanged)
elif ltype == 'group':
# group item
ctrl = None
@@ -900,9 +901,14 @@
# ignore when map layer is edited
self.Map.ChangeLayerActive(mapLayer, checked)
# update progress bar range (mapwindow statusbar)
self.mapdisplay.onRenderGauge.SetRange(len(self.Map.GetListOfLayers(l_active=True)))
+ # nviz
if self.mapdisplay.toolbars['nviz'] and \
self.GetPyData(item) is not None:
# nviz - load/unload data layer
@@ -967,6 +973,10 @@
"""Selection changed"""
oldlayer = event.GetOldItem()
layer = event.GetItem()
+ if layer == oldlayer:
+ event.Veto()
+ return
self.layer_selected = layer
try:
@@ -975,13 +985,17 @@
except:
pass
# update statusbar -> show command string
if self.GetPyData(layer) and self.GetPyData(layer)[0]['maplayer']:
cmd = self.GetPyData(layer)[0]['maplayer'].GetCmd(string=True)
if len(cmd) > 0:
self.gismgr.SetStatusText(cmd)
# update nviz tools
self.GetPyData(self.layer_selected) is not None:
@@ -1253,13 +1267,16 @@
def ChangeLayer(self, item):
"""Change layer"""
type = self.GetPyData(item)[0]['type']
+ layerName = None
if type == 'command':
win = self.FindWindowById(self.GetPyData(item)[0]['ctrl'])
if win.GetValue() != None:
- cmdlist = win.GetValue().split(' ')
+ cmd = win.GetValue().split(';')
+ cmdlist = []
+ for c in cmd:
+ cmdlist.append(c.split(' '))
opac = 1.0
chk = self.IsItemChecked(item)
hidden = not self.IsVisible(item)
@@ -1269,29 +1286,28 @@
opac = self.GetPyData(item)[0]['maplayer'].GetOpacity(float=True)
- # determine layer name
- layerName = utils.GetLayerNameFromCmd(cmdlist, fullyQualified=True)
- if not layerName:
- layerName = self.GetItemText(item)
+ # determine layer name
+ layerName = utils.GetLayerNameFromCmd(cmdlist, fullyQualified=True)
+ if not layerName:
+ layerName = self.GetItemText(item)
maplayer = self.Map.ChangeLayer(layer=self.GetPyData(item)[0]['maplayer'], type=type,
command=cmdlist, name=layerName,
l_active=chk, l_hidden=hidden, l_opacity=opac, l_render=False)
self.GetPyData(item)[0]['maplayer'] = maplayer
# if digitization tool enabled -> update list of available vector map layers
if self.mapdisplay.toolbars['vdigit']:
self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers(updateTool=True)
# redraw map if auto-rendering is enabled
self.rerender = True
self.reorder = True
#if self.mapdisplay.autoRender.GetValue():
# print "*** Change OnRender *****"
# self.mapdisplay.OnRender(None)
- # item.SetHeight(TREE_ITEM_HEIGHT)
def OnCloseWindow(self, event):
pass
# self.Map.Clean()
