[GRASS-SVN] r33188 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Sep 1 07:24:02 EDT 2008
Author: martinl
Date: 2008-09-01 07:24:02 -0400 (Mon, 01 Sep 2008)
New Revision: 33188
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: fix workspace (opacity and command layers)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-09-01 11:13:00 UTC (rev 33187)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-09-01 11:24:02 UTC (rev 33188)
@@ -205,7 +205,7 @@
cmdStr = ''
for cmd in self.cmdlist:
cmdStr += ' '.join(cmd) + ';'
- return cmdStr
+ return cmdStr.rstrip(';')
else:
return ' '.join(self.cmdlist)
else:
@@ -1030,7 +1030,7 @@
Debug.msg (3, "Map.ChangeLayer(): layer=%s" % layer.name)
if kargs.has_key('type'):
layer.SetType(kargs['type']) # check type
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2008-09-01 11:13:00 UTC (rev 33187)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2008-09-01 11:24:02 UTC (rev 33188)
@@ -235,7 +235,7 @@
"type" : self.layerType,
"name" : self.layerName,
"checked" : int(self.layerChecked),
- "opacity" : None,
+ "opacity" : 1.0,
"cmd" : None,
"group" : self.inTag['group'],
"display" : self.displayIndex,
@@ -246,7 +246,7 @@
self.layers[-1]["opacity"] = float(self.layerOpacity)
if self.cmd:
self.layers[-1]["cmd"] = self.cmd
self.layerType = self.layerName = self.Checked = \
self.Opacity = self.cmd = None
@@ -404,10 +404,10 @@
maplayer = None
checked = int(item.IsChecked())
- cmd = mapTree.GetPyData(item)[0]['cmd']
if type == 'command':
+ cmd = mapTree.GetPyData(item)[0]['maplayer'].GetCmd(string=True)
self.file.write('%s<layer type="%s" name="%s" checked="%d">\n' % \
- (' ' * self.indent, type, ' '.join(cmd), checked));
+ (' ' * self.indent, type, cmd, checked));
self.file.write('%s</layer>\n' % (' ' * self.indent));
elif type == 'group':
name = mapTree.GetItemText(item)
@@ -419,6 +419,7 @@
self.indent -= 4
self.file.write('%s</group>\n' % (' ' * self.indent));
else:
+ cmd = mapTree.GetPyData(item)[0]['maplayer'].GetCmd(string=False)
# remove 'opacity' part
if '(opacity' in name:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-09-01 11:13:00 UTC (rev 33187)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-09-01 11:24:02 UTC (rev 33188)
@@ -649,17 +649,16 @@
self.first = False
if ltype != 'group':
- if lopacity:
- opacity = int(lopacity * 100)
- else:
- opacity = 100
if lcmd and len(lcmd) > 1:
cmd = lcmd
render = False
name = utils.GetLayerNameFromCmd(lcmd)
else:
cmd = []
+ if ltype == 'command' and lname:
+ for c in lname.split(';'):
+ cmd.append(c.split(' '))
render = False
name = None
@@ -695,7 +694,7 @@
maplayer = self.Map.AddLayer(pos=pos,
type=ltype, command=self.GetPyData(layer)[0]['cmd'], name=name,
l_active=checked, l_hidden=False,
- l_opacity=opacity, l_render=render)
+ l_opacity=lopacity, l_render=render)
self.GetPyData(layer)[0]['maplayer'] = maplayer
# run properties dialog if no properties given
@@ -718,13 +717,13 @@
if lname:
if ltype == 'group':
self.SetItemText(layer, lname)
- elif ltype != 'command':
+ elif ltype == 'command':
+ ctrl.SetValue(lname)
+ else:
name = lname + ' (opacity: ' + \
str(self.GetPyData(layer)[0]['maplayer'].GetOpacity()) + '%)'
self.SetItemText(layer, name)
- else:
- ctrl.SetValue(lname)
# updated progress bar range (mapwindow statusbar)
if checked is True:
self.mapdisplay.onRenderGauge.SetRange(len(self.Map.GetListOfLayers(l_active=True)))
