[GRASS-SVN] r33197 -
grass/branches/develbranch_6/gui/wxpython/vdigit
svn_grass at osgeo.org
Mon Sep 1 12:45:07 EDT 2008
Author: martinl
Date: 2008-09-01 12:45:04 -0400 (Mon, 01 Sep 2008)
New Revision: 33197
grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp
wxGUI/vdigit: bug fix in GetRegionSelected()"
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp 2008-09-01 16:10:39 UTC (rev 33196)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp 2008-09-01 16:45:04 UTC (rev 33197)
@@ -437,7 +437,7 @@
int type;
bool found;
- for (int line = 1; line < Vect_get_num_lines(mapInfo); line++) {
+ for (int line = 1; line <= Vect_get_num_lines(mapInfo); line++) {
type = Vect_read_line (mapInfo, NULL, cats, line);
if (!(type & (GV_POINTS | GV_LINES)))
continue;
@@ -461,7 +461,7 @@
line = list->value[i];
area = Vect_get_centroid_area(mapInfo, line);
- if (area > 0) {
+ if (area > 0 && area < Vect_get_num_areas(mapInfo)) {
if (!Vect_get_area_box(mapInfo, area, &line_box))
continue;
