[GRASS-SVN] r33217 - grass/trunk/imagery/i.atcorr
Tue Sep 2 06:28:04 EDT 2008
Author: martinl
Date: 2008-09-02 06:28:01 -0400 (Tue, 02 Sep 2008)
New Revision: 33217
   grass/trunk/imagery/i.atcorr/6s.cpp
   grass/trunk/imagery/i.atcorr/Abstra.cpp
   grass/trunk/imagery/i.atcorr/AerosolConcentration.cpp
   grass/trunk/imagery/i.atcorr/AerosolModel.cpp
   grass/trunk/imagery/i.atcorr/Altitude.cpp
   grass/trunk/imagery/i.atcorr/AtmosModel.cpp
   grass/trunk/imagery/i.atcorr/GeomCond.cpp
   grass/trunk/imagery/i.atcorr/Interp.cpp
   grass/trunk/imagery/i.atcorr/Iwave.cpp
   grass/trunk/imagery/i.atcorr/Transform.cpp
   grass/trunk/imagery/i.atcorr/common.cpp
   grass/trunk/imagery/i.atcorr/computations.cpp
   grass/trunk/imagery/i.atcorr/gauss.cpp
   grass/trunk/imagery/i.atcorr/main.cpp
i.atcorr: use same indentation rules for all files
(merge from devbr6, r33216)
Modified: grass/trunk/imagery/i.atcorr/6s.cpp
--- grass/trunk/imagery/i.atcorr/6s.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/6s.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -19,7 +19,7 @@
 extern void specinterp(const float wl, float& tamoy, float& tamoyp, float& pizmoy, float& pizmoyp,
                        const AerosolConcentration &aerocon, const Altitude &alt);
 extern void enviro (const float difr, const float difa, const float r, const float palt,
-			        const float xmuv, float& fra, float& fae, float& fr);
+		    const float xmuv, float& fra, float& fae, float& fr);
 void printOutput(); // forward declare this function so that it can be used in init_6S
@@ -38,38 +38,38 @@
 static AtmosModel original_atms;
 int init_6S(char* icnd_name)
-	/* (atmospheric conditions input text file) */
+    /* (atmospheric conditions input text file) */
     ifstream inText;
-	inText.open(icnd_name);
-	if(!inText.is_open()) {
+    inText.open(icnd_name);
+    if(!inText.is_open()) {
         fprintf(stderr, "Unable to open %s\n", icnd_name);
-		return -1;
+	return -1;
-	/* redirect cin to the input text file */
-	cin.rdbuf(inText.rdbuf());
+    /* redirect cin to the input text file */
+    cin.rdbuf(inText.rdbuf());
-	/* read the input geometrical conditions */
-	geom = GeomCond::Parse();
+    /* read the input geometrical conditions */
+    geom = GeomCond::Parse();
-	/* read atmospheric model */
-	original_atms = AtmosModel::Parse();
+    /* read atmospheric model */
+    original_atms = AtmosModel::Parse();
     atms = original_atms; /* making a copy */
-	/* read aerosol model */
-	aero = AerosolModel::Parse(geom.xmud);
+    /* read aerosol model */
+    aero = AerosolModel::Parse(geom.xmud);
     /* read aerosol concentration */
     aerocon = AerosolConcentration::Parse(aero.iaer, atms);
-	/* read altitude */
-	alt = Altitude::Parse();
+    /* read altitude */
+    alt = Altitude::Parse();
     alt.init(atms, aerocon);
-	/* read iwave stuff */
-	iwave = IWave::Parse();
+    /* read iwave stuff */
+    iwave = IWave::Parse();
-	/**********************************************************************c
+    /**********************************************************************c
 	c here, we first compute an equivalent wavelenght which is the input   c
 	c value for monochromatic conditions or the integrated value for a     c
 	c filter function (call equivwl) then, the atmospheric properties are  c
@@ -85,13 +85,13 @@
 	c directional reflectances                                             c
 	c**********************************************************************/
-	float wlmoy;
-	if(iwave.iwave != -1) wlmoy = iwave.equivwl();
-	else wlmoy = iwave.wl;
+    float wlmoy;
+    if(iwave.iwave != -1) wlmoy = iwave.equivwl();
+    else wlmoy = iwave.wl;
-	discom(geom, atms, aero, aerocon, alt, iwave);
-	float tamoy, tamoyp, pizmoy, pizmoyp;
-	if(aero.iaer != 0) specinterp(wlmoy, tamoy, tamoyp, pizmoy, pizmoyp, aerocon, alt);
+    discom(geom, atms, aero, aerocon, alt, iwave);
+    float tamoy, tamoyp, pizmoy, pizmoyp;
+    if(aero.iaer != 0) specinterp(wlmoy, tamoy, tamoyp, pizmoy, pizmoyp, aerocon, alt);
     printOutput();
     fflush(stderr);
@@ -107,13 +107,13 @@
     alt.set_height(height);
-	float wlmoy;
+    float wlmoy;
 /* Only update those objects that are affected by a visibility change */
@@ -123,13 +123,13 @@
     aerocon.set_visibility(vis, atms);
-	float wlmoy;
+    float wlmoy;
 /* Only update those objects that are affected by a height change */
@@ -139,190 +139,190 @@
-	float wlmoy;
+    float wlmoy;
 void printOutput()
-	static const string head(" 6s version 4.2b ");
+    static const string head(" 6s version 4.2b ");
-	cout << endl << endl << endl;
-	Output::Begin(); Output::Repeat(30,'*'); Output::Print(head); Output::Repeat(30,'*'); Output::End();
+    cout << endl << endl << endl;
+    Output::Begin(); Output::Repeat(30,'*'); Output::Print(head); Output::Repeat(30,'*'); Output::End();
-	/* ---- geometrical conditions ---- */
-	geom.print();
+    /* ---- geometrical conditions ---- */
+    geom.print();
-	/* --- atmospheric model ---- */
-	atms.print();
+    /* --- atmospheric model ---- */
+    atms.print();
-	/* --- aerosols model (type) ---- */
-	aero.print();
+    /* --- aerosols model (type) ---- */
+    aero.print();
     /* --- aerosols model (concentration) ---- */
     aerocon.print();
-	/* --- spectral condition ---- */
-	iwave.print();
+    /* --- spectral condition ---- */
+    iwave.print();
-	/* --- ground reflectance (type and spectral variation) ---- */
+    /* --- ground reflectance (type and spectral variation) ---- */
-	Output::Ln();
-	Output::WriteLn(22," target type  ");
-	Output::WriteLn(22," -----------  ");
-	Output::WriteLn(10," homogeneous ground ");
+    Output::Ln();
+    Output::WriteLn(22," target type  ");
+    Output::WriteLn(22," -----------  ");
+    Output::WriteLn(10," homogeneous ground ");
-	/* 12x a39 f6.3 */
-	static const string reflec[8] = {
-		string(" user defined spectral reflectance     "),
-		string(" monochromatic reflectance "),
-		string(" constant reflectance over the spectra "),
-		string(" spectral vegetation ground reflectance"),
-		string(" spectral clear water reflectance      "),
-		string(" spectral dry sand ground reflectance  "),
-		string(" spectral lake water reflectance       "),
-		string(" spectral volcanic debris reflectance  ")
+    /* 12x a39 f6.3 */
+    static const string reflec[8] = {
+	string(" user defined spectral reflectance     "),
+	string(" monochromatic reflectance "),
+	string(" constant reflectance over the spectra "),
+	string(" spectral vegetation ground reflectance"),
+	string(" spectral clear water reflectance      "),
+	string(" spectral dry sand ground reflectance  "),
+	string(" spectral lake water reflectance       "),
+	string(" spectral volcanic debris reflectance  ")
     float rocave = 0;       /* block of code in Fortran will always compute 0 */
-	ostringstream s;
-	s.setf(ios::fixed, ios::floatfield);
-	s << setprecision(3);
-	s << reflec[2] << setw(9) << rocave << ends;
-	Output::WriteLn(12, s.str());
+    ostringstream s;
+    s.setf(ios::fixed, ios::floatfield);
+    s << setprecision(3);
+    s << reflec[2] << setw(9) << rocave << ends;
+    Output::WriteLn(12, s.str());
-	/* --- pressure at ground level (174) and altitude (175) ---- */
-	Output::Ln();
-	Output::WriteLn(22," target elevation description ");
-	Output::WriteLn(22," ---------------------------- ");
+    /* --- pressure at ground level (174) and altitude (175) ---- */
+    Output::Ln();
+    Output::WriteLn(22," target elevation description ");
+    Output::WriteLn(22," ---------------------------- ");
-	ostringstream s1;
-	s1.setf(ios::fixed, ios::floatfield);
-	s1 << setprecision(2);
-	s1 << " ground pressure  [mb]     " << setw(9) << atms.p[0] << ends;
-	Output::WriteLn(10,s1.str());
+    ostringstream s1;
+    s1.setf(ios::fixed, ios::floatfield);
+    s1 << setprecision(2);
+    s1 << " ground pressure  [mb]     " << setw(9) << atms.p[0] << ends;
+    Output::WriteLn(10,s1.str());
-	ostringstream s2;
-	s2.setf(ios::fixed, ios::floatfield);
-	s2 << setprecision(3);
-	s2 << " ground altitude  [km]    " << setw(9) << alt.xps << ends;
-	Output::WriteLn(10,s2.str());
+    ostringstream s2;
+    s2.setf(ios::fixed, ios::floatfield);
+    s2 << setprecision(3);
+    s2 << " ground altitude  [km]    " << setw(9) << alt.xps << ends;
+    Output::WriteLn(10,s2.str());
-	if( alt.xps > 0 )
-		Output::WriteLn(15," gaseous content at target level: ");
+    if( alt.xps > 0 )
+	Output::WriteLn(15," gaseous content at target level: ");
-		ostringstream s;
-		s << " uh2o=" << setw(9) << atms.uw << " g/cm2      "
-		  << "  uo3=" << setw(9) << atms.uo3 << " cm-atm" << ends;
-		Output::WriteLn(15,s.str());
+	ostringstream s;
+	s << " uh2o=" << setw(9) << atms.uw << " g/cm2      "
+	  << "  uo3=" << setw(9) << atms.uo3 << " cm-atm" << ends;
+	Output::WriteLn(15,s.str());
-	alt.print();
+    alt.print();
-	/* ---- atmospheric correction  ---- */
-	Output::Ln();
-	Output::WriteLn(23," atmospheric correction activated ");
-	Output::WriteLn(23," -------------------------------- ");
+    /* ---- atmospheric correction  ---- */
+    Output::Ln();
+    Output::WriteLn(23," atmospheric correction activated ");
+    Output::WriteLn(23," -------------------------------- ");
 TransformInput compute()
-	const float accu3 = 1e-07;
+    const float accu3 = 1e-07;
 /* ---- initilialization	 very liberal :) */
-	int i, j;
+    int i, j;
-	float fr = 0;
-	float rad = 0;
-	float sb = 0;
-	float seb = 0;
-	float refet = 0;
-	float refet1 = 0;
-	float refet2 = 0;
-	float refet3 = 0;
-	float alumet = 0;
-	float tgasm = 0;
-	float rog = 0;
-	float dgasm = 0;
-	float ugasm = 0;
-	float sdwava = 0;
-	float sdozon = 0;
-	float sddica = 0;
-	float sdoxyg = 0;
-	float sdniox = 0;
-	float sdmoca = 0;
-	float sdmeth = 0;
+    float fr = 0;
+    float rad = 0;
+    float sb = 0;
+    float seb = 0;
+    float refet = 0;
+    float refet1 = 0;
+    float refet2 = 0;
+    float refet3 = 0;
+    float alumet = 0;
+    float tgasm = 0;
+    float rog = 0;
+    float dgasm = 0;
+    float ugasm = 0;
+    float sdwava = 0;
+    float sdozon = 0;
+    float sddica = 0;
+    float sdoxyg = 0;
+    float sdniox = 0;
+    float sdmoca = 0;
+    float sdmeth = 0;
-	float suwava = 0;
-	float suozon = 0;
-	float sudica = 0;
-	float suoxyg = 0;
-	float suniox = 0;
-	float sumoca = 0;
-	float sumeth = 0;
-	float stwava = 0;
-	float stozon = 0;
-	float stdica = 0;
-	float stoxyg = 0;
-	float stniox = 0;
-	float stmoca = 0;
-	float stmeth = 0;
-	float sodray = 0;
-	float sodrayp = 0;
-	float sodaer = 0;
-	float sodaerp = 0;
-	float sodtot = 0;
-	float sodtotp = 0;
-	float fophsr = 0;
-	float fophsa = 0;
-	float sroray = 0;
-	float sroaer = 0;
-	float srotot = 0;
-	float ssdaer = 0;
-	float sdtotr = 0;
-	float sdtota = 0;
-	float sdtott = 0;
-	float sutotr = 0;
-	float sutota = 0;
-	float sutott = 0;
-	float sasr = 0;
-	float sasa = 0;
-	float sast = 0;
+    float suwava = 0;
+    float suozon = 0;
+    float sudica = 0;
+    float suoxyg = 0;
+    float suniox = 0;
+    float sumoca = 0;
+    float sumeth = 0;
+    float stwava = 0;
+    float stozon = 0;
+    float stdica = 0;
+    float stoxyg = 0;
+    float stniox = 0;
+    float stmoca = 0;
+    float stmeth = 0;
+    float sodray = 0;
+    float sodrayp = 0;
+    float sodaer = 0;
+    float sodaerp = 0;
+    float sodtot = 0;
+    float sodtotp = 0;
+    float fophsr = 0;
+    float fophsa = 0;
+    float sroray = 0;
+    float sroaer = 0;
+    float srotot = 0;
+    float ssdaer = 0;
+    float sdtotr = 0;
+    float sdtota = 0;
+    float sdtott = 0;
+    float sutotr = 0;
+    float sutota = 0;
+    float sutott = 0;
+    float sasr = 0;
+    float sasa = 0;
+    float sast = 0;
-	float ani[2][3];
-	float aini[2][3];
-	float anr[2][3];
-	float ainr[2][3];
+    float ani[2][3];
+    float aini[2][3];
+    float anr[2][3];
+    float ainr[2][3];
-	for(i = 0; i < 2; i++)
-		for(j = 0; j < 3; j++)
-			ani[i][j] = 0;
-			aini[i][j] = 0;
-			anr[i][j] = 0;
-			ainr[i][j] = 0;
-	/* ---- spectral loop ---- */
-    if (iwave.iwave == -2)
+    for(i = 0; i < 2; i++)
+	for(j = 0; j < 3; j++)
-		Output::WriteLn(1,"wave   total  total  total  total  atm.   swl    step   sbor   dsol   toar ");
-		Output::WriteLn(1,"       gas    scat   scat   spheri intr   ");
-		Output::WriteLn(1,"       trans  down   up     albedo refl   ");
+	    ani[i][j] = 0;
+	    aini[i][j] = 0;
+	    anr[i][j] = 0;
+	    ainr[i][j] = 0;
-	int l;
-	for(l = iwave.iinf; l <= iwave.isup; l++)
+    /* ---- spectral loop ---- */
+    if (iwave.iwave == -2)
+	Output::WriteLn(1,"wave   total  total  total  total  atm.   swl    step   sbor   dsol   toar ");
+	Output::WriteLn(1,"       gas    scat   scat   spheri intr   ");
+	Output::WriteLn(1,"       trans  down   up     albedo refl   ");
+    int l;
+    for(l = iwave.iinf; l <= iwave.isup; l++)
         float sbor = iwave.ffu.s[l];
         if(l == iwave.iinf || l == iwave.isup) sbor *= 0.5f;
@@ -332,16 +332,16 @@
         float roe = 0; /* roel[l]; */
         float wl = 0.25f + l * step;
-		AbstraStruct as;
-		float uwus, uo3us;		/* initialized in abstra */
+	AbstraStruct as;
+	float uwus, uo3us;		/* initialized in abstra */
-		abstra(atms, alt, wl, (float)geom.xmus, (float)geom.xmuv, atms.uw / 2.0f, atms.uo3,
-			   uwus, uo3us, alt.puw / 2.0f, alt.puo3, alt.puwus, alt.puo3us, as);
+	abstra(atms, alt, wl, (float)geom.xmus, (float)geom.xmuv, atms.uw / 2.0f, atms.uo3,
+	       uwus, uo3us, alt.puw / 2.0f, alt.puo3, alt.puwus, alt.puo3us, as);
-		float attwava = as.ttwava;
+	float attwava = as.ttwava;
-		abstra(atms, alt, wl, (float)geom.xmus, (float)geom.xmuv, atms.uw, atms.uo3,
-			   uwus, uo3us, alt.puw, alt.puo3, alt.puwus, alt.puo3us, as);
+	abstra(atms, alt, wl, (float)geom.xmus, (float)geom.xmuv, atms.uw, atms.uo3,
+	       uwus, uo3us, alt.puw, alt.puo3, alt.puwus, alt.puo3us, as);
         if (as.dtwava < accu3) as.dtwava = 0;
         if (as.dtozon < accu3) as.dtozon = 0;
@@ -366,9 +366,9 @@
         swl = swl * geom.dsol;
         float coef = sbor * step * swl;
-		InterpStruct is;
-		memset(&is, 0, sizeof(is));
-		interp(aero.iaer, alt.idatmp, wl, aerocon.taer55, alt.taer55p, (float)geom.xmud, is);
+	InterpStruct is;
+	memset(&is, 0, sizeof(is));
+	interp(aero.iaer, alt.idatmp, wl, aerocon.taer55, alt.taer55p, (float)geom.xmud, is);
         float dgtot = as.dtwava * as.dtozon * as.dtdica * as.dtoxyg * as.dtniox * as.dtmeth * as.dtmoca;
@@ -380,12 +380,12 @@
         float edifa = (float)(is.utota - exp(-is.taerp / geom.xmuv));
-		float fra, fae;
-		enviro(edifr, edifa, rad, alt.palt, (float)geom.xmuv, fra, fae, fr);
+	float fra, fae;
+	enviro(edifr, edifa, rad, alt.palt, (float)geom.xmuv, fra, fae, fr);
-		float avr = roc * fr + (1 - fr) * roe;
-		float rsurf = (float)(roc * is.dtott * exp(-(is.trayp + is.taerp) / geom.xmuv) / (1 - avr * is.astot)
-					+ avr * is.dtott * (is.utott - exp(-(is.trayp + is.taerp) / geom.xmuv)) / (1 - avr * is.astot));
+	float avr = roc * fr + (1 - fr) * roe;
+	float rsurf = (float)(roc * is.dtott * exp(-(is.trayp + is.taerp) / geom.xmuv) / (1 - avr * is.astot)
+			      + avr * is.dtott * (is.utott - exp(-(is.trayp + is.taerp) / geom.xmuv)) / (1 - avr * is.astot));
         float ratm1 = (is.romix - is.rorayl) * tgtot + is.rorayl * tgp1;
         float ratm3 = is.romix * tgp1;
         float ratm2 = (is.romix - is.rorayl) * tgp2 + is.rorayl * tgp1;
@@ -393,24 +393,24 @@
         float romeas2 = ratm2 + rsurf * tgtot;
         float romeas3 = ratm3 + rsurf * tgtot;
-		/* computing integrated values over the spectral band */
+	/* computing integrated values over the spectral band */
-			Output::Begin();
-			ostringstream s;
-			s.precision(4);
-			s	<< setw(10) << wl << " "
-				<< setw(10) << tgtot << " "
-				<< setw(10) << is.dtott << " "
-				<< setw(10) << is.utott << " "
-				<< setw(10) << is.astot << " "
-				<< setw(10) << ratm2 << " "
-				<< setprecision(1) << setw(7) << swl << " "
-				<< setprecision(4) << setw(10) << step << " "
-				<< setw(10) << sbor << " "
-				<< setw(10) << geom.dsol << " "
-				<< setw(10) << romeas2;
+	    Output::Begin();
+	    ostringstream s;
+	    s.precision(4);
+	    s	<< setw(10) << wl << " "
+		<< setw(10) << tgtot << " "
+		<< setw(10) << is.dtott << " "
+		<< setw(10) << is.utott << " "
+		<< setw(10) << is.astot << " "
+		<< setw(10) << ratm2 << " "
+		<< setprecision(1) << setw(7) << swl << " "
+		<< setprecision(4) << setw(10) << step << " "
+		<< setw(10) << sbor << " "
+		<< setw(10) << geom.dsol << " "
+		<< setw(10) << romeas2;
@@ -469,7 +469,7 @@
         sb = sb + sbor * step;
         seb = seb + coef;
-		/* output at the ground level. */
+	/* output at the ground level. */
         float tdir = (float)exp(-(is.tray + is.taer) / geom.xmus);
         float tdif = is.dtott - tdir;
         float etn = is.dtott * dgtot / (1 - avr * is.astot);
@@ -481,16 +481,16 @@
         float ee0 = (float)(geom.xmus * swl * dgtot * avr * is.astot * is.dtott / (1 - avr * is.astot));
         if (etn > accu3)
-           ani[0][0] = esn / etn;
-           ani[0][1] = ea0n / etn;
-           ani[0][2] = ee0n / etn;
+	    ani[0][0] = esn / etn;
+	    ani[0][1] = ea0n / etn;
+	    ani[0][2] = ee0n / etn;
         else
-           ani[0][0] = 0;
-           ani[0][1] = 0;
-           ani[0][2] = 0;
+	    ani[0][0] = 0;
+	    ani[0][1] = 0;
+	    ani[0][2] = 0;
         ani[1][0] = es;
@@ -498,13 +498,13 @@
         ani[1][2] = ee0;
-          aini[0][j] = aini[0][j] + ani[0][j] * coef;
-          aini[1][j] = aini[1][j] + ani[1][j] * sbor * step;
+	    aini[0][j] = aini[0][j] + ani[0][j] * coef;
+	    aini[1][j] = aini[1][j] + ani[1][j] * sbor * step;
-		/* output at satellite level */
+	/* output at satellite level */
         float tmdir = (float)exp(-(is.tray + is.taer) / geom.xmuv);
         float tmdif = is.utott - tmdir;
         float xla0n = ratm2;
@@ -520,78 +520,78 @@
         anr[1][1] = xle;
         anr[1][2] = xlt;
-          ainr[0][j] = ainr[0][j] + anr[0][j] * coef;
-          ainr[1][j] = ainr[1][j] + anr[1][j] * sbor * step;
+	    ainr[0][j] = ainr[0][j] + anr[0][j] * coef;
+	    ainr[1][j] = ainr[1][j] + anr[1][j] * sbor * step;
-	/* ---- integrated values of apparent reflectance, radiance          ----*/
-	/* ---- and gaseous transmittances (total,downward,separately gases) ----*/
+    /* ---- integrated values of apparent reflectance, radiance          ----*/
+    /* ---- and gaseous transmittances (total,downward,separately gases) ----*/
     refet = refet / seb;
-	refet1 = refet1 / seb;
-	refet2 = refet2 / seb;
-	refet3 = refet3 / seb;
-	tgasm = tgasm / seb;
-	dgasm = dgasm / seb;
-	ugasm = ugasm / seb;
-	sasa = sasa / seb;
-	sasr = sasr / seb;
-	sast = sast / seb;
-	sdniox = sdniox / seb;
-	sdmoca = sdmoca / seb;
-	sdmeth = sdmeth / seb;
-	sdwava = sdwava / seb;
-	sdozon = sdozon / seb;
-	sddica = sddica / seb;
-	suniox = suniox / seb;
-	sumoca = sumoca / seb;
-	sumeth = sumeth / seb;
-	suwava = suwava / seb;
-	suozon = suozon / seb;
-	sudica = sudica / seb;
-	suoxyg = suoxyg / seb;
-	sdoxyg = sdoxyg / seb;
-	stniox = stniox / seb;
-	stmoca = stmoca / seb;
-	stmeth = stmeth / seb;
-	stwava = stwava / seb;
-	stozon = stozon / seb;
-	stdica = stdica / seb;
-	stoxyg = stoxyg / seb;
-	sdtotr = sdtotr / seb;
-	sdtota = sdtota / seb;
-	sdtott = sdtott / seb;
+    refet1 = refet1 / seb;
+    refet2 = refet2 / seb;
+    refet3 = refet3 / seb;
+    tgasm = tgasm / seb;
+    dgasm = dgasm / seb;
+    ugasm = ugasm / seb;
+    sasa = sasa / seb;
+    sasr = sasr / seb;
+    sast = sast / seb;
+    sdniox = sdniox / seb;
+    sdmoca = sdmoca / seb;
+    sdmeth = sdmeth / seb;
+    sdwava = sdwava / seb;
+    sdozon = sdozon / seb;
+    sddica = sddica / seb;
+    suniox = suniox / seb;
+    sumoca = sumoca / seb;
+    sumeth = sumeth / seb;
+    suwava = suwava / seb;
+    suozon = suozon / seb;
+    sudica = sudica / seb;
+    suoxyg = suoxyg / seb;
+    sdoxyg = sdoxyg / seb;
+    stniox = stniox / seb;
+    stmoca = stmoca / seb;
+    stmeth = stmeth / seb;
+    stwava = stwava / seb;
+    stozon = stozon / seb;
+    stdica = stdica / seb;
+    stoxyg = stoxyg / seb;
+    sdtotr = sdtotr / seb;
+    sdtota = sdtota / seb;
+    sdtott = sdtott / seb;
-	sutotr = sutotr / seb;
-	sutota = sutota / seb;
-	sutott = sutott / seb;
-	rog = rog / seb;
-	sroray = sroray / seb;
-	sroaer = sroaer / seb;
-	srotot = srotot / seb;
-	alumet = alumet / sb;
-	float pizera = 0.0f;
-	if(aero.iaer != 0) pizera = ssdaer / sodaer;
-	sodray = sodray / seb;
-	sodaer = sodaer / seb;
-	sodtot = sodtot / seb;
-	sodrayp = sodrayp / seb;
-	sodaerp = sodaerp / seb;
-	sodtotp = sodtotp / seb;
-	fophsa = fophsa / seb;
-	fophsr = fophsr / seb;
+    sutotr = sutotr / seb;
+    sutota = sutota / seb;
+    sutott = sutott / seb;
+    rog = rog / seb;
+    sroray = sroray / seb;
+    sroaer = sroaer / seb;
+    srotot = srotot / seb;
+    alumet = alumet / sb;
+    float pizera = 0.0f;
+    if(aero.iaer != 0) pizera = ssdaer / sodaer;
+    sodray = sodray / seb;
+    sodaer = sodaer / seb;
+    sodtot = sodtot / seb;
+    sodrayp = sodrayp / seb;
+    sodaerp = sodaerp / seb;
+    sodtotp = sodtotp / seb;
+    fophsa = fophsa / seb;
+    fophsr = fophsr / seb;
         aini[0][j] = aini[0][j] / seb;
         ainr[0][j] = ainr[0][j] / seb;
         aini[1][j] = aini[1][j] / sb;
         ainr[1][j] = ainr[1][j] / sb;
     /* Prepare data for final dn transformation */
     TransformInput ti;
Modified: grass/trunk/imagery/i.atcorr/Abstra.cpp
--- grass/trunk/imagery/i.atcorr/Abstra.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/Abstra.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -11,336 +11,336 @@
-  static const float acr[2048] = { .011482f, .13183f,
-    -.0038755f, 3.4491e-6f, -.0069899f, 9.3146e-6f, 15300.f, 15310.f,
-    .0015124f, .19547f, .0028474f, -4.7616e-6f, .0017802f, -1.079e-5f,
-    15310.f, 15320.f, .0092482f, .16207f, -.0025675f, 1.271e-5f, -.0027267f,
-    6.2076e-6f, 15320.f, 15330.f, .0104f, .25148f, .0028271f, -1.6657e-5f,
-    .0013667f, -1.7862e-5f, 15330.f, 15340.f, .036425f, .35831f, -.0010013f,
-    -1.0673e-6f, -.0025219f, -1.7475e-6f, 15340.f, 15350.f, .0050755f,
-    .12303f, -.0018115f, 9.8037e-7f, -.0034793f, 8.572e-7f, 15350.f,
-    15360.f, .0040405f, .079669f, -.0035356f, 4.2888e-6f, -.0049964f,
-    5.6042e-6f, 15360.f, 15370.f, .0012748f, .10104f, .0012869f,
-    -4.1165e-6f, -2.5366e-4f, -8.5685e-6f, 15370.f, 15380.f, .004332f,
-    .087049f, -.0037819f, 4.8177e-6f, -.0066616f, 9.4206e-6f, 15380.f,
-    15390.f, .018759f, .14839f, -.0050183f, 8.8733e-6f, -.0069647f,
-    1.2888e-5f, 15390.f, 15400.f, .013161f, .13948f, -.0039758f, 3.962e-6f,
-    -.006383f, 8.2226e-6f, 15400.f, 15410.f, .014766f, .30841f, -.0025568f,
-    -1.0002e-6f, -.0049777f, 2.925e-6f, 15410.f, 15420.f, .021082f, .15162f,
-    -.0015321f, -5.6826e-6f, -.0038546f, -1.6492e-6f, 15420.f, 15430.f,
-    .020195f, .19485f, -2.7645e-4f, -9.8888e-6f, -.0024022f, -6.5352e-6f,
-    15430.f, 15440.f, .011166f, .18799f, .0030297f, -2.1309e-5f, 4.9231e-4f,
-    -1.6445e-5f, 15440.f, 15450.f, .011405f, .30263f, .0033723f,
-    -1.9312e-5f, .0012213f, -1.8339e-5f, 15450.f, 15460.f, .0081879f,
-    .2948f, .0056918f, -2.2518e-5f, .0049723f, -2.6308e-5f, 15460.f,
-    15470.f, .0086587f, .31194f, .0049388f, -2.4988e-5f, .0025729f,
-    -2.3785e-5f, 15470.f, 15480.f, .0029624f, .25004f, .0021191f,
-    1.2889e-5f, .0021547f, -5.0741e-6f, 15480.f, 15490.f, .0010355f, .1518f,
-    .010772f, -5.3973e-5f, .0081789f, -4.9803e-5f, 15490.f, 15500.f,
-    .0019209f, .15869f, .0035388f, -1.5675e-6f, .0030429f, -1.3275e-5f,
-    15500.f, 15510.f, .0021168f, .22695f, .0033055f, -7.1274e-7f, .0018066f,
-    -1.051e-5f, 15510.f, 15520.f, 3.63e-4f, .041337f, .004643f, -3.0966e-5f,
-    .0016831f, -2.5006e-5f, 15520.f, 15530.f, 6.422e-4f, .040141f,
-    .0011384f, -1.6948e-5f, -.0017809f, -1.1069e-5f, 15530.f, 15540.f,
-    .0017361f, .12935f, 7.0897e-6f, -1.1804e-5f, -.0029721f, -5.606e-6f,
-    15540.f, 15550.f, 3.6772e-4f, .069843f, .0015876f, -1.7017e-5f,
-    -.0014188f, -1.1298e-5f, 15550.f, 15560.f, 8.1562e-4f, .085732f,
-    .0028597f, -2.3409e-5f, -8.1651e-5f, -1.7172e-5f, 15560.f, 15570.f,
-    4.1832e-5f, .037286f, .0071945f, -4.1172e-5f, .0048022f, -3.6355e-5f,
-    15570.f, 15580.f, 2.89e-4f, .059772f, .00431f, -2.7519e-5f, .0025363f,
-    -2.6086e-5f, 15580.f, 15590.f, 3.4153e-4f, .068927f, .0058634f,
-    -2.8708e-5f, .002971f, -2.6151e-5f, 15590.f, 15600.f, 6.3462e-4f,
-    .10803f, .0062584f, -1.912e-5f, .0049128f, -2.4384e-5f, 15600.f,
-    15610.f, 3.9706e-4f, .12303f, .0073825f, -2.4245e-5f, .0050938f,
-    -2.795e-5f, 15610.f, 15620.f, 1.1711e-4f, .063154f, .0049218f,
-    -2.6583e-5f, .0021634f, -2.368e-5f, 15620.f, 15630.f, 2.8022e-4f,
-    .091171f, .011895f, -5.9964e-5f, .0091244f, -5.4363e-5f, 15630.f,
-    15640.f, 4.8561e-4f, .17953f, .0048672f, -2.2506e-5f, .0012405f,
-    -1.7834e-5f, 15640.f, 15650.f, 3.295e-4f, .13103f, .0079212f,
-    -3.1361e-5f, .0048579f, -3.0501e-5f, 15650.f, 15660.f, 6.2254e-4f,
-    .13066f, .0068683f, -3.4929e-5f, .0042198f, -3.0853e-5f, 15660.f,
-    15670.f, 3.4175e-4f, .0686f, .0071102f, -4.0828e-5f, .0041954f,
-    -3.4941e-5f, 15670.f, 15680.f, 6.7893e-4f, .25103f, .002638f,
-    -1.0784e-5f, -1.9402e-4f, -1.0493e-5f, 15680.f, 15690.f, .0022454f,
-    .2126f, .0045521f, -3.0054e-5f, .0018943f, -2.5356e-5f, 15690.f,
-    15700.f, 2.2324e-4f, .16386f, 9.9924e-5f, -4.6542e-6f, -.0032498f,
-    -4.4042e-7f, 15700.f, 15710.f, .0011732f, .071121f, .0017438f,
-    -1.9369e-5f, -.0010378f, -1.3774e-5f, 15710.f, 15720.f, .0011939f,
-    .22194f, .0022505f, -2.0274e-5f, -3.0389e-4f, -1.5915e-5f, 15720.f,
-    15730.f, .0011335f, .1131f, 6.5038e-4f, -1.4226e-5f, -.0023716f,
-    -8.4484e-6f, 15730.f, 15740.f, .0013693f, .066759f, -4.9503e-4f,
-    -1.0274e-5f, -.0033442f, -4.9491e-6f, 15740.f, 15750.f, .0022675f,
-    .11019f, -.0015659f, -6.0385e-6f, -.0042073f, -9.9453e-7f, 15750.f,
-    15760.f, .0021492f, .11169f, -.0025591f, -1.868e-6f, -.0052151f,
-    2.9531e-6f, 15760.f, 15770.f, 5.2724e-4f, .079449f, -.0015077f,
-    3.7703e-7f, -.0037765f, 1.0136e-6f, 15770.f, 15780.f, .0017852f,
-    .092282f, -.0042337f, 4.5463e-6f, -.0075615f, 1.1296e-5f, 15780.f,
-    15790.f, 5.7289e-4f, .18138f, .001042f, 1.1358e-7f, -.0010771f,
-    -3.8585e-6f, 15790.f, 15800.f, .0024903f, .21722f, 6.1161e-4f,
-    2.0815e-6f, -6.5545e-4f, -6.5063e-6f, 15800.f, 15810.f, .0033934f,
-    .23501f, 3.4083e-4f, -1.2029e-5f, -.0027676f, -5.6508e-6f, 15810.f,
-    15820.f, .0043759f, .14995f, -.003628f, 2.8054e-6f, -.0061589f,
-    7.1308e-6f, 15820.f, 15830.f, 9.6328e-4f, .12298f, -.0027284f,
-    2.0822e-6f, -.0051044f, 4.1652e-6f, 15830.f, 15840.f, 6.1564e-4f,
-    .047547f, -.0041578f, 4.2375e-6f, -.007361f, 1.0687e-5f, 15840.f,
-    15850.f, 1.445e-4f, .047164f, -.0026523f, -1.7845e-6f, -.0054095f,
-    3.7673e-6f, 15850.f, 15860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15860.f,
-    15870.f, .0027617f, .080618f, -.0054341f, 9.35e-6f, -.0086841f,
-    1.5797e-5f, 15870.f, 15880.f, .0038448f, .0889f, -.0045065f, 5.7229e-6f,
-    -.0074065f, 1.161e-5f, 15880.f, 15890.f, .002669f, .12359f, -.003403f,
-    1.5184e-6f, -.0062551f, 6.94e-6f, 15890.f, 15900.f, .0035205f, .15929f,
-    -.0029195f, -6.0033e-7f, -.0055137f, 4.5063e-6f, 15900.f, 15910.f,
-    .0033857f, .15288f, -5.5305e-4f, -1.0049e-5f, -.0030402f, -5.3251e-6f,
-    15910.f, 15920.f, .0055123f, .20681f, 6.3027e-5f, -1.1203e-5f,
-    -.0021942f, -7.6854e-6f, 15920.f, 15930.f, .0025555f, .15612f,
-    .0036149f, -2.367e-5f, 8.1154e-4f, -1.8842e-5f, 15930.f, 15940.f,
-    6.0708e-4f, .15267f, .0069583f, -2.3922e-5f, .0059157f, -3.3379e-5f,
-    15940.f, 15950.f, .0013307f, .12652f, .005072f, -3.1273e-5f, .0029461f,
-    -2.8552e-5f, 15950.f, 15960.f, 1.9184e-4f, .031816f, .010823f,
-    -5.5684e-5f, .0080654f, -5.0132e-5f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f,
-      15990.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    1.6e4f, 16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16030.f,
-    16040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f,
-      16070.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16080.f, 16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16110.f,
-    16120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f,
-      16150.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16160.f, 16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16190.f,
-    16200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f,
-      16230.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16240.f, 16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16270.f,
-    16280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f,
-      16310.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16320.f, 16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16350.f,
-    16360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f,
-      16390.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16400.f, 16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16430.f,
-    16440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f,
-      16470.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16480.f, 16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16510.f,
-    16520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f,
-      16550.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16560.f, 16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16590.f,
-    16600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f,
-      16630.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16640.f, 16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16670.f,
-    16680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16690.f, 16700.f, 9.3657e-4f, .16814f, .0071611f, -3.2337e-5f,
-    .0051118f, -3.429e-5f, 16700.f, 16710.f, .002716f, .13632f, .0024507f,
-    -1.7614e-5f, 6.4545e-4f, -1.7104e-5f, 16710.f, 16720.f, .01021f,
-    .33525f, .0035136f, -2.0013e-5f, .0012395f, -1.7557e-5f, 16720.f,
-    16730.f, .0056241f, .14518f, .0025514f, -6.0743e-6f, 4.0412e-4f,
-    -9.6804e-6f, 16730.f, 16740.f, .0090151f, .16435f, 5.9525e-4f,
-    -7.4453e-6f, -7.7433e-4f, -8.1348e-6f, 16740.f, 16750.f, .017084f,
-    .37569f, .0017092f, -1.0104e-5f, 5.4764e-5f, -1.1565e-5f, 16750.f,
-    16760.f, .004068f, .16946f, .0051318f, -1.2576e-5f, .0021847f,
-    -1.7187e-5f, 16760.f, 16770.f, .014025f, .25075f, -4.9903e-4f,
-    -3.9474e-6f, -.0024356f, -2.4014e-6f, 16770.f, 16780.f, .0084391f,
-    .29482f, .00143f, -1.4909e-5f, -5.8149e-4f, -1.2205e-5f, 16780.f,
-    16790.f, .0042603f, .15728f, -.0017076f, 1.1819e-5f, -.0025115f,
-    1.7886e-6f, 16790.f, 16800.f, .016111f, .35565f, 9.8453e-4f,
-    -1.0561e-5f, -.0015547f, -8.0917e-6f, 16800.f, 16810.f, .032806f,
-    .40538f, 3.2361e-4f, -7.1099e-6f, -.0017591f, -6.4585e-6f, 16810.f,
-    16820.f, .039593f, .37366f, -.0017738f, -3.6504e-6f, -.0044894f,
-    1.5591e-6f, 16820.f, 16830.f, .0041709f, .15463f, -.001046f,
-    -1.7983e-6f, -.0027043f, -2.9685e-6f, 16830.f, 16840.f, .0035117f,
-    .15272f, -.0028931f, 3.0829e-6f, -.0046348f, 4.9372e-6f, 16840.f,
-    16850.f, .014133f, .12212f, -.0040965f, 4.1489e-6f, -.0071928f,
-    1.0033e-5f, 16850.f, 16860.f, .0077536f, .19684f, -.0044631f,
-    8.2821e-6f, -.0062227f, 1.0476e-5f, 16860.f, 16870.f, .025192f, .3428f,
-    -.003503f, 5.8569e-6f, -.0052023f, 7.3334e-6f, 16870.f, 16880.f,
-    .030248f, .27295f, -.0026774f, 1.2042e-6f, -.0042996f, 2.2385e-6f,
-    16880.f, 16890.f, .012936f, .30454f, -.0022564f, -1.1282e-6f,
-    -.0042435f, 1.4398e-6f, 16890.f, 16900.f, .011031f, .24979f, -.0032635f,
-    5.324e-6f, -.0041759f, 4.4122e-6f, 16900.f, 16910.f, .014293f, .29998f,
-    -3.4569e-4f, -9.0328e-6f, -.0021933f, -6.7146e-6f, 16910.f, 16920.f,
-    .0091809f, .29615f, .0023482f, -1.7235e-5f, -5.9956e-4f, -1.1968e-5f,
-    16920.f, 16930.f, .008126f, .323f, 1.1339e-4f, -9.8017e-7f, -.0013639f,
-    -4.0912e-6f, 16930.f, 16940.f, .040319f, .36952f, -.0034585f,
-    7.4285e-6f, -.0043038f, 5.2677e-6f, 16940.f, 16950.f, .013921f, .36738f,
-    -7.7085e-4f, 4.5894e-7f, -.0026272f, -1.4583e-6f, 16950.f, 16960.f,
-    .014345f, .25675f, -.0022235f, 1.8237e-6f, -.0031796f, 3.5185e-6f,
-    16960.f, 16970.f, .016501f, .22846f, -7.3791e-4f, -8.1276e-6f,
-    -.0030972f, -3.4017e-6f, 16970.f, 16980.f, .019984f, .24072f,
-    4.6284e-4f, -1.157e-5f, -.0016535f, -8.0246e-6f, 16980.f, 16990.f,
-    .014605f, .42551f, .0042003f, -2.4403e-5f, .0012313f, -1.961e-5f,
-    16990.f, 1.7e4f, .0056604f, .31925f, .0037029f, -1.1447e-5f, .0028937f,
-    -1.9869e-5f, 1.7e4f, 17010.f, .0063352f, .35092f, .0026893f,
-    -1.5677e-5f, 5.5216e-4f, -1.3231e-5f, 17010.f, 17020.f, .003844f,
-    .22874f, -1.2718e-4f, -9.3893e-8f, -.0018171f, -1.6527e-7f, 17020.f,
-    17030.f, .0013581f, .13591f, .0068077f, -3.5228e-5f, .0039267f,
-    -3.0049e-5f, 17030.f, 17040.f, .0018736f, .25317f, .004094f, -1.115e-5f,
-    .0020737f, -1.6908e-5f, 17040.f, 17050.f, .0012084f, .1688f, -.0010058f,
-    -7.8902e-7f, -.0025863f, -1.1192e-6f, 17050.f, 17060.f, .0010487f,
-    .069135f, .006375f, -3.3619e-5f, .0036725f, -3.0416e-5f, 17060.f,
-    17070.f, 5.0984e-4f, .11462f, .0031391f, -2.153e-5f, 4.5939e-4f,
-    -1.7989e-5f, 17070.f, 17080.f, 8.4428e-4f, .14457f, -5.8124e-4f,
-    -7.7648e-6f, -.0029191f, -4.3661e-6f, 17080.f, 17090.f, 3.0536e-4f,
-    .074835f, 1.5726e-4f, -1.2441e-5f, -.0024876f, -7.6201e-6f, 17090.f,
-    17100.f, 5.526e-4f, .12225f, .0040329f, -2.6244e-5f, .0012152f,
-    -2.1176e-5f, 17100.f, 17110.f, 3.7571e-4f, .06606f, .004893f,
-    -1.7932e-5f, .0027254f, -2.1243e-5f, 17110.f, 17120.f, 3.8817e-4f,
-    .096834f, .0050965f, -2.8072e-5f, .0025414f, -2.5439e-5f, 17120.f,
-    17130.f, 4.3455e-4f, .10332f, .0037899f, -2.5805e-5f, .0011068f,
-    -2.147e-5f, 17130.f, 17140.f, 2.797e-4f, .13222f, .0049706f,
-    -1.1993e-5f, .0022042f, -1.6597e-5f, 17140.f, 17150.f, 3.5542e-4f,
-    .094199f, .0069032f, -3.8399e-5f, .0042436f, -3.3972e-5f, 17150.f,
-    17160.f, 1.4332e-4f, .10096f, .0080342f, -4.4157e-5f, .0052994f,
-    -3.893e-5f, 17160.f, 17170.f, 1.131e-4f, .07032f, .0094132f,
-    -1.9979e-5f, .0084399f, -3.3269e-5f, 17170.f, 17180.f, 1.097e-4f,
-    .073653f, .0070015f, -3.1921e-5f, .0041785f, -3.033e-5f, 17180.f,
-    17190.f, 1.9539e-4f, .11002f, .0025848f, -2.1294e-5f, 1.5132e-4f,
-    -1.7461e-5f, 17190.f, 17200.f, 2.2464e-5f, .040498f, .0015081f,
-    -1.8426e-5f, -8.0302e-4f, -1.3773e-5f, 17200.f, 17210.f, 1.1068e-4f,
-    .041949f, .0011384f, -1.6948e-5f, -.001862f, -1.0906e-5f, 17210.f,
-    17220.f, 2.6372e-4f, .1423f, .0074076f, -9.6003e-7f, .004947f,
-    -1.6056e-5f, 17220.f, 17230.f, 1.6225e-4f, .064754f, 9.1255e-4f,
-    4.5791e-6f, 2.8912e-5f, -2.743e-6f, 17230.f, 17240.f, 3.4492e-4f,
-    .13306f, -.0022341f, -3.1568e-6f, -.0051367f, 2.5216e-6f, 17240.f,
-    17250.f, 2.9083e-4f, .1273f, .014643f, -7.0324e-5f, .011799f,
-    -6.4717e-5f, 17250.f, 17260.f, 7.9159e-5f, .084959f, .0033618f,
-    1.0957e-5f, -1.9083e-6f, 1.5045e-6f, 17260.f, 17270.f, 3.991e-4f,
-    .1611f, .0052228f, -6.6224e-6f, .003315f, -1.7428e-5f, 17270.f, 17280.f,
-    3.6117e-4f, .14552f, .0053239f, -2.7921e-6f, .0027764f, -1.3072e-5f,
-    17280.f, 17290.f, 5.6601e-4f, .2023f, .0081509f, -3.975e-5f, .0051039f,
-    -3.5401e-5f, 17290.f, 17300.f, 5.522e-4f, .27444f, .0022665f,
-    -4.1297e-6f, 6.9271e-4f, -1.2175e-5f, 17300.f, 17310.f, .0012177f,
-    .31594f, .0026446f, -1.1117e-5f, -.0010442f, -7.3851e-6f, 17310.f,
-    17320.f, .0012068f, .36919f, .0046393f, -2.5102e-5f, .001937f,
-    -2.1181e-5f, 17320.f, 17330.f, 8.1484e-4f, .12504f, .0033991f,
-    -2.4509e-5f, -1.7719e-4f, -1.657e-5f, 17330.f, 17340.f, .0010075f,
-    .10415f, .0045176f, -3.0424e-5f, .0016795f, -2.4622e-5f, 17340.f,
-    17350.f, .0014383f, .23566f, .0013476f, -1.0965e-5f, -.0023371f,
-    -4.3633e-6f, 17350.f, 17360.f, 7.8276e-4f, .2229f, -.0015478f,
-    -1.8316e-6f, -.0039408f, 4.9016e-7f, 17360.f, 17370.f, .0023195f,
-    .1644f, .0012573f, -1.668e-5f, -.0019183f, -9.5692e-6f, 17370.f,
-    17380.f, 7.0669e-4f, .18348f, -.001353f, -5.5696e-6f, -.0046409f,
-    1.1901e-6f, 17380.f, 17390.f, .0026577f, .24613f, -3.4475e-4f,
-    -9.149e-6f, -.0027647f, -4.4906e-6f, 17390.f, 17400.f, .0014266f,
-    .18058f, -1.7564e-4f, -3.1091e-6f, -.0023868f, -2.4568e-6f, 17400.f,
-    17410.f, .0013368f, .089183f, -7.5731e-4f, -3.0495e-6f, -.0013138f,
-    -5.5029e-6f, 17410.f, 17420.f, .0031555f, .29805f, -.0014978f,
-    -6.4349e-7f, -.0036817f, 1.3405e-6f, 17420.f, 17430.f, .0015803f,
-    .20706f, .0027308f, -1.4728e-5f, 2.1412e-4f, -1.4434e-5f, 17430.f,
-    17440.f, .0025444f, .19283f, -.0026123f, 3.7928e-6f, -.0040723f,
-    3.3236e-6f, 17440.f, 17450.f, .0028951f, .14488f, 8.2222e-4f,
-    -1.4617e-5f, -.0020986f, -8.6758e-6f, 17450.f, 17460.f, 9.9222e-4f,
-    .058296f, -6.973e-4f, -8.8805e-6f, -.0030012f, -5.1319e-6f, 17460.f,
-    17470.f, .0049761f, .23841f, -.0034073f, 2.1975e-6f, -.00609f,
-    6.7461e-6f, 17470.f, 17480.f, .0024737f, .16103f, -.0033546f,
-    5.2399e-6f, -.0050448f, 4.9288e-6f, 17480.f, 17490.f, 6.5774e-4f,
-    .076908f, -.0048253f, 7.2725e-6f, -.0072344f, 1.1372e-5f, 17490.f,
-    17500.f, 8.5946e-4f, .1372f, -.0034619f, 3.8209e-6f, -.0055141f,
-    6.4456e-6f, 17500.f, 17510.f, 1.3088e-4f, .077214f, 1.0378e-4f,
-    -6.7806e-6f, -.0024574f, -4.3444e-6f, 17510.f, 17520.f, 7.2177e-4f,
-    .12037f, -.0032371f, 3.8429e-6f, -.005706f, 6.3102e-6f, 17520.f,
-    17530.f, .0025932f, .057507f, -.0053841f, 9.3892e-6f, -.0080102f,
-    1.4171e-5f, 17530.f, 17540.f, .0064329f, .34361f, -.0033999f,
-    4.1519e-6f, -.0047285f, 4.1554e-6f, 17540.f, 17550.f, .0020356f,
-    .18182f, -.0031524f, 9.2073e-7f, -.0056549f, 4.9733e-6f, 17550.f,
-    17560.f, .0065331f, .22623f, -.0015636f, -4.1008e-6f, -.0032357f,
-    -2.3034e-6f, 17560.f, 17570.f, .0059972f, .29545f, -6.0272e-4f,
-    -7.9159e-6f, -.0032228f, -3.1603e-6f, 17570.f, 17580.f, .0040039f,
-    .3136f, .0032065f, -2.0617e-5f, 6.7568e-4f, -1.7932e-5f, 17580.f,
-    17590.f, .0016959f, .28903f, .005156f, -1.9347e-5f, .0033983f,
-    -2.1801e-5f, 17590.f, 17600.f, 7.0732e-4f, .16014f, .0010501f,
-    -1.4628e-5f, -.0015478f, -9.7179e-6f, 17600.f, 17610.f, .0012558f,
-    .1798f, .0044641f, -2.5933e-5f, .0019766f, -2.2898e-5f, 17610.f,
-    17620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17620.f, 17630.f, 5.944e-5f,
-    .033158f, .0060208f, -3.6477e-5f, .0032636f, -3.0925e-5f, 17630.f,
-    17640.f, 1.6627e-4f, .041123f, -.0027846f, -1.2553e-6f, -.0055418f,
-    4.2965e-6f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17650.f,
-    17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17680.f,
-      17690.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f, 17720.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17730.f,
-    17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17760.f,
-      17770.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f, 17800.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17810.f,
-    17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17840.f,
-      17850.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
+    static const float acr[2048] = { .011482f, .13183f,
+				     -.0038755f, 3.4491e-6f, -.0069899f, 9.3146e-6f, 15300.f, 15310.f,
+				     .0015124f, .19547f, .0028474f, -4.7616e-6f, .0017802f, -1.079e-5f,
+				     15310.f, 15320.f, .0092482f, .16207f, -.0025675f, 1.271e-5f, -.0027267f,
+				     6.2076e-6f, 15320.f, 15330.f, .0104f, .25148f, .0028271f, -1.6657e-5f,
+				     .0013667f, -1.7862e-5f, 15330.f, 15340.f, .036425f, .35831f, -.0010013f,
+				     -1.0673e-6f, -.0025219f, -1.7475e-6f, 15340.f, 15350.f, .0050755f,
+				     .12303f, -.0018115f, 9.8037e-7f, -.0034793f, 8.572e-7f, 15350.f,
+				     15360.f, .0040405f, .079669f, -.0035356f, 4.2888e-6f, -.0049964f,
+				     5.6042e-6f, 15360.f, 15370.f, .0012748f, .10104f, .0012869f,
+				     -4.1165e-6f, -2.5366e-4f, -8.5685e-6f, 15370.f, 15380.f, .004332f,
+				     .087049f, -.0037819f, 4.8177e-6f, -.0066616f, 9.4206e-6f, 15380.f,
+				     15390.f, .018759f, .14839f, -.0050183f, 8.8733e-6f, -.0069647f,
+				     1.2888e-5f, 15390.f, 15400.f, .013161f, .13948f, -.0039758f, 3.962e-6f,
+				     -.006383f, 8.2226e-6f, 15400.f, 15410.f, .014766f, .30841f, -.0025568f,
+				     -1.0002e-6f, -.0049777f, 2.925e-6f, 15410.f, 15420.f, .021082f, .15162f,
+				     -.0015321f, -5.6826e-6f, -.0038546f, -1.6492e-6f, 15420.f, 15430.f,
+				     .020195f, .19485f, -2.7645e-4f, -9.8888e-6f, -.0024022f, -6.5352e-6f,
+				     15430.f, 15440.f, .011166f, .18799f, .0030297f, -2.1309e-5f, 4.9231e-4f,
+				     -1.6445e-5f, 15440.f, 15450.f, .011405f, .30263f, .0033723f,
+				     -1.9312e-5f, .0012213f, -1.8339e-5f, 15450.f, 15460.f, .0081879f,
+				     .2948f, .0056918f, -2.2518e-5f, .0049723f, -2.6308e-5f, 15460.f,
+				     15470.f, .0086587f, .31194f, .0049388f, -2.4988e-5f, .0025729f,
+				     -2.3785e-5f, 15470.f, 15480.f, .0029624f, .25004f, .0021191f,
+				     1.2889e-5f, .0021547f, -5.0741e-6f, 15480.f, 15490.f, .0010355f, .1518f,
+				     .010772f, -5.3973e-5f, .0081789f, -4.9803e-5f, 15490.f, 15500.f,
+				     .0019209f, .15869f, .0035388f, -1.5675e-6f, .0030429f, -1.3275e-5f,
+				     15500.f, 15510.f, .0021168f, .22695f, .0033055f, -7.1274e-7f, .0018066f,
+				     -1.051e-5f, 15510.f, 15520.f, 3.63e-4f, .041337f, .004643f, -3.0966e-5f,
+				     .0016831f, -2.5006e-5f, 15520.f, 15530.f, 6.422e-4f, .040141f,
+				     .0011384f, -1.6948e-5f, -.0017809f, -1.1069e-5f, 15530.f, 15540.f,
+				     .0017361f, .12935f, 7.0897e-6f, -1.1804e-5f, -.0029721f, -5.606e-6f,
+				     15540.f, 15550.f, 3.6772e-4f, .069843f, .0015876f, -1.7017e-5f,
+				     -.0014188f, -1.1298e-5f, 15550.f, 15560.f, 8.1562e-4f, .085732f,
+				     .0028597f, -2.3409e-5f, -8.1651e-5f, -1.7172e-5f, 15560.f, 15570.f,
+				     4.1832e-5f, .037286f, .0071945f, -4.1172e-5f, .0048022f, -3.6355e-5f,
+				     15570.f, 15580.f, 2.89e-4f, .059772f, .00431f, -2.7519e-5f, .0025363f,
+				     -2.6086e-5f, 15580.f, 15590.f, 3.4153e-4f, .068927f, .0058634f,
+				     -2.8708e-5f, .002971f, -2.6151e-5f, 15590.f, 15600.f, 6.3462e-4f,
+				     .10803f, .0062584f, -1.912e-5f, .0049128f, -2.4384e-5f, 15600.f,
+				     15610.f, 3.9706e-4f, .12303f, .0073825f, -2.4245e-5f, .0050938f,
+				     -2.795e-5f, 15610.f, 15620.f, 1.1711e-4f, .063154f, .0049218f,
+				     -2.6583e-5f, .0021634f, -2.368e-5f, 15620.f, 15630.f, 2.8022e-4f,
+				     .091171f, .011895f, -5.9964e-5f, .0091244f, -5.4363e-5f, 15630.f,
+				     15640.f, 4.8561e-4f, .17953f, .0048672f, -2.2506e-5f, .0012405f,
+				     -1.7834e-5f, 15640.f, 15650.f, 3.295e-4f, .13103f, .0079212f,
+				     -3.1361e-5f, .0048579f, -3.0501e-5f, 15650.f, 15660.f, 6.2254e-4f,
+				     .13066f, .0068683f, -3.4929e-5f, .0042198f, -3.0853e-5f, 15660.f,
+				     15670.f, 3.4175e-4f, .0686f, .0071102f, -4.0828e-5f, .0041954f,
+				     -3.4941e-5f, 15670.f, 15680.f, 6.7893e-4f, .25103f, .002638f,
+				     -1.0784e-5f, -1.9402e-4f, -1.0493e-5f, 15680.f, 15690.f, .0022454f,
+				     .2126f, .0045521f, -3.0054e-5f, .0018943f, -2.5356e-5f, 15690.f,
+				     15700.f, 2.2324e-4f, .16386f, 9.9924e-5f, -4.6542e-6f, -.0032498f,
+				     -4.4042e-7f, 15700.f, 15710.f, .0011732f, .071121f, .0017438f,
+				     -1.9369e-5f, -.0010378f, -1.3774e-5f, 15710.f, 15720.f, .0011939f,
+				     .22194f, .0022505f, -2.0274e-5f, -3.0389e-4f, -1.5915e-5f, 15720.f,
+				     15730.f, .0011335f, .1131f, 6.5038e-4f, -1.4226e-5f, -.0023716f,
+				     -8.4484e-6f, 15730.f, 15740.f, .0013693f, .066759f, -4.9503e-4f,
+				     -1.0274e-5f, -.0033442f, -4.9491e-6f, 15740.f, 15750.f, .0022675f,
+				     .11019f, -.0015659f, -6.0385e-6f, -.0042073f, -9.9453e-7f, 15750.f,
+				     15760.f, .0021492f, .11169f, -.0025591f, -1.868e-6f, -.0052151f,
+				     2.9531e-6f, 15760.f, 15770.f, 5.2724e-4f, .079449f, -.0015077f,
+				     3.7703e-7f, -.0037765f, 1.0136e-6f, 15770.f, 15780.f, .0017852f,
+				     .092282f, -.0042337f, 4.5463e-6f, -.0075615f, 1.1296e-5f, 15780.f,
+				     15790.f, 5.7289e-4f, .18138f, .001042f, 1.1358e-7f, -.0010771f,
+				     -3.8585e-6f, 15790.f, 15800.f, .0024903f, .21722f, 6.1161e-4f,
+				     2.0815e-6f, -6.5545e-4f, -6.5063e-6f, 15800.f, 15810.f, .0033934f,
+				     .23501f, 3.4083e-4f, -1.2029e-5f, -.0027676f, -5.6508e-6f, 15810.f,
+				     15820.f, .0043759f, .14995f, -.003628f, 2.8054e-6f, -.0061589f,
+				     7.1308e-6f, 15820.f, 15830.f, 9.6328e-4f, .12298f, -.0027284f,
+				     2.0822e-6f, -.0051044f, 4.1652e-6f, 15830.f, 15840.f, 6.1564e-4f,
+				     .047547f, -.0041578f, 4.2375e-6f, -.007361f, 1.0687e-5f, 15840.f,
+				     15850.f, 1.445e-4f, .047164f, -.0026523f, -1.7845e-6f, -.0054095f,
+				     3.7673e-6f, 15850.f, 15860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15860.f,
+				     15870.f, .0027617f, .080618f, -.0054341f, 9.35e-6f, -.0086841f,
+				     1.5797e-5f, 15870.f, 15880.f, .0038448f, .0889f, -.0045065f, 5.7229e-6f,
+				     -.0074065f, 1.161e-5f, 15880.f, 15890.f, .002669f, .12359f, -.003403f,
+				     1.5184e-6f, -.0062551f, 6.94e-6f, 15890.f, 15900.f, .0035205f, .15929f,
+				     -.0029195f, -6.0033e-7f, -.0055137f, 4.5063e-6f, 15900.f, 15910.f,
+				     .0033857f, .15288f, -5.5305e-4f, -1.0049e-5f, -.0030402f, -5.3251e-6f,
+				     15910.f, 15920.f, .0055123f, .20681f, 6.3027e-5f, -1.1203e-5f,
+				     -.0021942f, -7.6854e-6f, 15920.f, 15930.f, .0025555f, .15612f,
+				     .0036149f, -2.367e-5f, 8.1154e-4f, -1.8842e-5f, 15930.f, 15940.f,
+				     6.0708e-4f, .15267f, .0069583f, -2.3922e-5f, .0059157f, -3.3379e-5f,
+				     15940.f, 15950.f, .0013307f, .12652f, .005072f, -3.1273e-5f, .0029461f,
+				     -2.8552e-5f, 15950.f, 15960.f, 1.9184e-4f, .031816f, .010823f,
+				     -5.5684e-5f, .0080654f, -5.0132e-5f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f,
+				     15990.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     1.6e4f, 16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16030.f,
+				     16040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f,
+				     16070.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16080.f, 16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16110.f,
+				     16120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f,
+				     16150.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16160.f, 16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16190.f,
+				     16200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f,
+				     16230.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16240.f, 16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16270.f,
+				     16280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f,
+				     16310.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16320.f, 16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16350.f,
+				     16360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f,
+				     16390.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16400.f, 16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16430.f,
+				     16440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f,
+				     16470.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16480.f, 16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16510.f,
+				     16520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f,
+				     16550.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16560.f, 16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16590.f,
+				     16600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f,
+				     16630.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16640.f, 16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16670.f,
+				     16680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16690.f, 16700.f, 9.3657e-4f, .16814f, .0071611f, -3.2337e-5f,
+				     .0051118f, -3.429e-5f, 16700.f, 16710.f, .002716f, .13632f, .0024507f,
+				     -1.7614e-5f, 6.4545e-4f, -1.7104e-5f, 16710.f, 16720.f, .01021f,
+				     .33525f, .0035136f, -2.0013e-5f, .0012395f, -1.7557e-5f, 16720.f,
+				     16730.f, .0056241f, .14518f, .0025514f, -6.0743e-6f, 4.0412e-4f,
+				     -9.6804e-6f, 16730.f, 16740.f, .0090151f, .16435f, 5.9525e-4f,
+				     -7.4453e-6f, -7.7433e-4f, -8.1348e-6f, 16740.f, 16750.f, .017084f,
+				     .37569f, .0017092f, -1.0104e-5f, 5.4764e-5f, -1.1565e-5f, 16750.f,
+				     16760.f, .004068f, .16946f, .0051318f, -1.2576e-5f, .0021847f,
+				     -1.7187e-5f, 16760.f, 16770.f, .014025f, .25075f, -4.9903e-4f,
+				     -3.9474e-6f, -.0024356f, -2.4014e-6f, 16770.f, 16780.f, .0084391f,
+				     .29482f, .00143f, -1.4909e-5f, -5.8149e-4f, -1.2205e-5f, 16780.f,
+				     16790.f, .0042603f, .15728f, -.0017076f, 1.1819e-5f, -.0025115f,
+				     1.7886e-6f, 16790.f, 16800.f, .016111f, .35565f, 9.8453e-4f,
+				     -1.0561e-5f, -.0015547f, -8.0917e-6f, 16800.f, 16810.f, .032806f,
+				     .40538f, 3.2361e-4f, -7.1099e-6f, -.0017591f, -6.4585e-6f, 16810.f,
+				     16820.f, .039593f, .37366f, -.0017738f, -3.6504e-6f, -.0044894f,
+				     1.5591e-6f, 16820.f, 16830.f, .0041709f, .15463f, -.001046f,
+				     -1.7983e-6f, -.0027043f, -2.9685e-6f, 16830.f, 16840.f, .0035117f,
+				     .15272f, -.0028931f, 3.0829e-6f, -.0046348f, 4.9372e-6f, 16840.f,
+				     16850.f, .014133f, .12212f, -.0040965f, 4.1489e-6f, -.0071928f,
+				     1.0033e-5f, 16850.f, 16860.f, .0077536f, .19684f, -.0044631f,
+				     8.2821e-6f, -.0062227f, 1.0476e-5f, 16860.f, 16870.f, .025192f, .3428f,
+				     -.003503f, 5.8569e-6f, -.0052023f, 7.3334e-6f, 16870.f, 16880.f,
+				     .030248f, .27295f, -.0026774f, 1.2042e-6f, -.0042996f, 2.2385e-6f,
+				     16880.f, 16890.f, .012936f, .30454f, -.0022564f, -1.1282e-6f,
+				     -.0042435f, 1.4398e-6f, 16890.f, 16900.f, .011031f, .24979f, -.0032635f,
+				     5.324e-6f, -.0041759f, 4.4122e-6f, 16900.f, 16910.f, .014293f, .29998f,
+				     -3.4569e-4f, -9.0328e-6f, -.0021933f, -6.7146e-6f, 16910.f, 16920.f,
+				     .0091809f, .29615f, .0023482f, -1.7235e-5f, -5.9956e-4f, -1.1968e-5f,
+				     16920.f, 16930.f, .008126f, .323f, 1.1339e-4f, -9.8017e-7f, -.0013639f,
+				     -4.0912e-6f, 16930.f, 16940.f, .040319f, .36952f, -.0034585f,
+				     7.4285e-6f, -.0043038f, 5.2677e-6f, 16940.f, 16950.f, .013921f, .36738f,
+				     -7.7085e-4f, 4.5894e-7f, -.0026272f, -1.4583e-6f, 16950.f, 16960.f,
+				     .014345f, .25675f, -.0022235f, 1.8237e-6f, -.0031796f, 3.5185e-6f,
+				     16960.f, 16970.f, .016501f, .22846f, -7.3791e-4f, -8.1276e-6f,
+				     -.0030972f, -3.4017e-6f, 16970.f, 16980.f, .019984f, .24072f,
+				     4.6284e-4f, -1.157e-5f, -.0016535f, -8.0246e-6f, 16980.f, 16990.f,
+				     .014605f, .42551f, .0042003f, -2.4403e-5f, .0012313f, -1.961e-5f,
+				     16990.f, 1.7e4f, .0056604f, .31925f, .0037029f, -1.1447e-5f, .0028937f,
+				     -1.9869e-5f, 1.7e4f, 17010.f, .0063352f, .35092f, .0026893f,
+				     -1.5677e-5f, 5.5216e-4f, -1.3231e-5f, 17010.f, 17020.f, .003844f,
+				     .22874f, -1.2718e-4f, -9.3893e-8f, -.0018171f, -1.6527e-7f, 17020.f,
+				     17030.f, .0013581f, .13591f, .0068077f, -3.5228e-5f, .0039267f,
+				     -3.0049e-5f, 17030.f, 17040.f, .0018736f, .25317f, .004094f, -1.115e-5f,
+				     .0020737f, -1.6908e-5f, 17040.f, 17050.f, .0012084f, .1688f, -.0010058f,
+				     -7.8902e-7f, -.0025863f, -1.1192e-6f, 17050.f, 17060.f, .0010487f,
+				     .069135f, .006375f, -3.3619e-5f, .0036725f, -3.0416e-5f, 17060.f,
+				     17070.f, 5.0984e-4f, .11462f, .0031391f, -2.153e-5f, 4.5939e-4f,
+				     -1.7989e-5f, 17070.f, 17080.f, 8.4428e-4f, .14457f, -5.8124e-4f,
+				     -7.7648e-6f, -.0029191f, -4.3661e-6f, 17080.f, 17090.f, 3.0536e-4f,
+				     .074835f, 1.5726e-4f, -1.2441e-5f, -.0024876f, -7.6201e-6f, 17090.f,
+				     17100.f, 5.526e-4f, .12225f, .0040329f, -2.6244e-5f, .0012152f,
+				     -2.1176e-5f, 17100.f, 17110.f, 3.7571e-4f, .06606f, .004893f,
+				     -1.7932e-5f, .0027254f, -2.1243e-5f, 17110.f, 17120.f, 3.8817e-4f,
+				     .096834f, .0050965f, -2.8072e-5f, .0025414f, -2.5439e-5f, 17120.f,
+				     17130.f, 4.3455e-4f, .10332f, .0037899f, -2.5805e-5f, .0011068f,
+				     -2.147e-5f, 17130.f, 17140.f, 2.797e-4f, .13222f, .0049706f,
+				     -1.1993e-5f, .0022042f, -1.6597e-5f, 17140.f, 17150.f, 3.5542e-4f,
+				     .094199f, .0069032f, -3.8399e-5f, .0042436f, -3.3972e-5f, 17150.f,
+				     17160.f, 1.4332e-4f, .10096f, .0080342f, -4.4157e-5f, .0052994f,
+				     -3.893e-5f, 17160.f, 17170.f, 1.131e-4f, .07032f, .0094132f,
+				     -1.9979e-5f, .0084399f, -3.3269e-5f, 17170.f, 17180.f, 1.097e-4f,
+				     .073653f, .0070015f, -3.1921e-5f, .0041785f, -3.033e-5f, 17180.f,
+				     17190.f, 1.9539e-4f, .11002f, .0025848f, -2.1294e-5f, 1.5132e-4f,
+				     -1.7461e-5f, 17190.f, 17200.f, 2.2464e-5f, .040498f, .0015081f,
+				     -1.8426e-5f, -8.0302e-4f, -1.3773e-5f, 17200.f, 17210.f, 1.1068e-4f,
+				     .041949f, .0011384f, -1.6948e-5f, -.001862f, -1.0906e-5f, 17210.f,
+				     17220.f, 2.6372e-4f, .1423f, .0074076f, -9.6003e-7f, .004947f,
+				     -1.6056e-5f, 17220.f, 17230.f, 1.6225e-4f, .064754f, 9.1255e-4f,
+				     4.5791e-6f, 2.8912e-5f, -2.743e-6f, 17230.f, 17240.f, 3.4492e-4f,
+				     .13306f, -.0022341f, -3.1568e-6f, -.0051367f, 2.5216e-6f, 17240.f,
+				     17250.f, 2.9083e-4f, .1273f, .014643f, -7.0324e-5f, .011799f,
+				     -6.4717e-5f, 17250.f, 17260.f, 7.9159e-5f, .084959f, .0033618f,
+				     1.0957e-5f, -1.9083e-6f, 1.5045e-6f, 17260.f, 17270.f, 3.991e-4f,
+				     .1611f, .0052228f, -6.6224e-6f, .003315f, -1.7428e-5f, 17270.f, 17280.f,
+				     3.6117e-4f, .14552f, .0053239f, -2.7921e-6f, .0027764f, -1.3072e-5f,
+				     17280.f, 17290.f, 5.6601e-4f, .2023f, .0081509f, -3.975e-5f, .0051039f,
+				     -3.5401e-5f, 17290.f, 17300.f, 5.522e-4f, .27444f, .0022665f,
+				     -4.1297e-6f, 6.9271e-4f, -1.2175e-5f, 17300.f, 17310.f, .0012177f,
+				     .31594f, .0026446f, -1.1117e-5f, -.0010442f, -7.3851e-6f, 17310.f,
+				     17320.f, .0012068f, .36919f, .0046393f, -2.5102e-5f, .001937f,
+				     -2.1181e-5f, 17320.f, 17330.f, 8.1484e-4f, .12504f, .0033991f,
+				     -2.4509e-5f, -1.7719e-4f, -1.657e-5f, 17330.f, 17340.f, .0010075f,
+				     .10415f, .0045176f, -3.0424e-5f, .0016795f, -2.4622e-5f, 17340.f,
+				     17350.f, .0014383f, .23566f, .0013476f, -1.0965e-5f, -.0023371f,
+				     -4.3633e-6f, 17350.f, 17360.f, 7.8276e-4f, .2229f, -.0015478f,
+				     -1.8316e-6f, -.0039408f, 4.9016e-7f, 17360.f, 17370.f, .0023195f,
+				     .1644f, .0012573f, -1.668e-5f, -.0019183f, -9.5692e-6f, 17370.f,
+				     17380.f, 7.0669e-4f, .18348f, -.001353f, -5.5696e-6f, -.0046409f,
+				     1.1901e-6f, 17380.f, 17390.f, .0026577f, .24613f, -3.4475e-4f,
+				     -9.149e-6f, -.0027647f, -4.4906e-6f, 17390.f, 17400.f, .0014266f,
+				     .18058f, -1.7564e-4f, -3.1091e-6f, -.0023868f, -2.4568e-6f, 17400.f,
+				     17410.f, .0013368f, .089183f, -7.5731e-4f, -3.0495e-6f, -.0013138f,
+				     -5.5029e-6f, 17410.f, 17420.f, .0031555f, .29805f, -.0014978f,
+				     -6.4349e-7f, -.0036817f, 1.3405e-6f, 17420.f, 17430.f, .0015803f,
+				     .20706f, .0027308f, -1.4728e-5f, 2.1412e-4f, -1.4434e-5f, 17430.f,
+				     17440.f, .0025444f, .19283f, -.0026123f, 3.7928e-6f, -.0040723f,
+				     3.3236e-6f, 17440.f, 17450.f, .0028951f, .14488f, 8.2222e-4f,
+				     -1.4617e-5f, -.0020986f, -8.6758e-6f, 17450.f, 17460.f, 9.9222e-4f,
+				     .058296f, -6.973e-4f, -8.8805e-6f, -.0030012f, -5.1319e-6f, 17460.f,
+				     17470.f, .0049761f, .23841f, -.0034073f, 2.1975e-6f, -.00609f,
+				     6.7461e-6f, 17470.f, 17480.f, .0024737f, .16103f, -.0033546f,
+				     5.2399e-6f, -.0050448f, 4.9288e-6f, 17480.f, 17490.f, 6.5774e-4f,
+				     .076908f, -.0048253f, 7.2725e-6f, -.0072344f, 1.1372e-5f, 17490.f,
+				     17500.f, 8.5946e-4f, .1372f, -.0034619f, 3.8209e-6f, -.0055141f,
+				     6.4456e-6f, 17500.f, 17510.f, 1.3088e-4f, .077214f, 1.0378e-4f,
+				     -6.7806e-6f, -.0024574f, -4.3444e-6f, 17510.f, 17520.f, 7.2177e-4f,
+				     .12037f, -.0032371f, 3.8429e-6f, -.005706f, 6.3102e-6f, 17520.f,
+				     17530.f, .0025932f, .057507f, -.0053841f, 9.3892e-6f, -.0080102f,
+				     1.4171e-5f, 17530.f, 17540.f, .0064329f, .34361f, -.0033999f,
+				     4.1519e-6f, -.0047285f, 4.1554e-6f, 17540.f, 17550.f, .0020356f,
+				     .18182f, -.0031524f, 9.2073e-7f, -.0056549f, 4.9733e-6f, 17550.f,
+				     17560.f, .0065331f, .22623f, -.0015636f, -4.1008e-6f, -.0032357f,
+				     -2.3034e-6f, 17560.f, 17570.f, .0059972f, .29545f, -6.0272e-4f,
+				     -7.9159e-6f, -.0032228f, -3.1603e-6f, 17570.f, 17580.f, .0040039f,
+				     .3136f, .0032065f, -2.0617e-5f, 6.7568e-4f, -1.7932e-5f, 17580.f,
+				     17590.f, .0016959f, .28903f, .005156f, -1.9347e-5f, .0033983f,
+				     -2.1801e-5f, 17590.f, 17600.f, 7.0732e-4f, .16014f, .0010501f,
+				     -1.4628e-5f, -.0015478f, -9.7179e-6f, 17600.f, 17610.f, .0012558f,
+				     .1798f, .0044641f, -2.5933e-5f, .0019766f, -2.2898e-5f, 17610.f,
+				     17620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17620.f, 17630.f, 5.944e-5f,
+				     .033158f, .0060208f, -3.6477e-5f, .0032636f, -3.0925e-5f, 17630.f,
+				     17640.f, 1.6627e-4f, .041123f, -.0027846f, -1.2553e-6f, -.0055418f,
+				     4.2965e-6f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17650.f,
+				     17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17680.f,
+				     17690.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f, 17720.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17730.f,
+				     17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17760.f,
+				     17770.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f, 17800.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17810.f,
+				     17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17840.f,
+				     17850.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
-	/* WATER VAPOR (15300 - 17860 CM-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* WATER VAPOR (15300 - 17860 CM-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* wava6 */
 void
@@ -348,332 +348,332 @@
-  static const float acr[2048] = { 4.6416e-4f, .04653f,
-    .011484f, -5.0228e-5f, .0057564f, -2.8823e-5f, 12740.f, 12750.f,
-    2.6026e-5f, .069686f, .0050381f, -3.0969e-5f, .0023565f, -2.6498e-5f,
-    12750.f, 12760.f, 2.1016e-4f, .078469f, -.0024738f, -2.0423e-6f,
-    -.0056905f, 4.9529e-6f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    12770.f, 12780.f, 6.0427e-5f, .037767f, 5.4219e-4f, -1.4563e-5f,
-    -.002215f, -9.0107e-6f, 12780.f, 12790.f, 2.496e-5f, .041123f,
-    -.0026523f, -1.7845e-6f, -.0054095f, 3.7673e-6f, 12790.f, 12800.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 12800.f, 12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    12810.f, 12820.f, 6.3228e-5f, .037767f, -6.7259e-4f, -9.7034e-6f,
-    -.0034298f, -4.1516e-6f, 12820.f, 12830.f, 7.0635e-5f, .034814f,
-    .0017376f, -1.9344e-5f, -.0010196f, -1.3792e-5f, 12830.f, 12840.f,
-    3.5776e-5f, .068419f, .0046121f, -2.7372e-5f, .0015491f, -2.2291e-5f,
-    12840.f, 12850.f, 8.2613e-5f, .072444f, .0029409f, -2.2687e-5f,
-    1.2304e-4f, -1.7626e-5f, 12850.f, 12860.f, 1.3149e-5f, .034814f,
-    .0017682f, -1.9467e-5f, -9.8895e-4f, -1.3915e-5f, 12860.f, 12870.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 1.0952e-5f, .034814f,
-      .0039164f,
-    -2.8059e-5f, .0011592f, -2.2508e-5f, 12880.f, 12890.f, 1.1287e-5f,
-    .037767f, .0031085f, -2.4828e-5f, 3.5131e-4f, -1.9276e-5f, 12890.f,
-    12900.f, 1.2534e-5f, .034814f, .006137f, -3.6942e-5f, .0033798f,
-    -3.139e-5f, 12900.f, 12910.f, 1.9577e-5f, .031771f, .0046608f,
-    -3.1037e-5f, .0019036f, -2.5485e-5f, 12910.f, 12920.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 12920.f, 12930.f, 9.153e-6f, .028818f, .0079937f, -4.4369e-5f,
-    .0052366f, -3.8817e-5f, 12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    12940.f, 12950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12960.f, 12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+    static const float acr[2048] = { 4.6416e-4f, .04653f,
+				     .011484f, -5.0228e-5f, .0057564f, -2.8823e-5f, 12740.f, 12750.f,
+				     2.6026e-5f, .069686f, .0050381f, -3.0969e-5f, .0023565f, -2.6498e-5f,
+				     12750.f, 12760.f, 2.1016e-4f, .078469f, -.0024738f, -2.0423e-6f,
+				     -.0056905f, 4.9529e-6f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12770.f, 12780.f, 6.0427e-5f, .037767f, 5.4219e-4f, -1.4563e-5f,
+				     -.002215f, -9.0107e-6f, 12780.f, 12790.f, 2.496e-5f, .041123f,
+				     -.0026523f, -1.7845e-6f, -.0054095f, 3.7673e-6f, 12790.f, 12800.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 12800.f, 12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12810.f, 12820.f, 6.3228e-5f, .037767f, -6.7259e-4f, -9.7034e-6f,
+				     -.0034298f, -4.1516e-6f, 12820.f, 12830.f, 7.0635e-5f, .034814f,
+				     .0017376f, -1.9344e-5f, -.0010196f, -1.3792e-5f, 12830.f, 12840.f,
+				     3.5776e-5f, .068419f, .0046121f, -2.7372e-5f, .0015491f, -2.2291e-5f,
+				     12840.f, 12850.f, 8.2613e-5f, .072444f, .0029409f, -2.2687e-5f,
+				     1.2304e-4f, -1.7626e-5f, 12850.f, 12860.f, 1.3149e-5f, .034814f,
+				     .0017682f, -1.9467e-5f, -9.8895e-4f, -1.3915e-5f, 12860.f, 12870.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 1.0952e-5f, .034814f,
+				     .0039164f,
+				     -2.8059e-5f, .0011592f, -2.2508e-5f, 12880.f, 12890.f, 1.1287e-5f,
+				     .037767f, .0031085f, -2.4828e-5f, 3.5131e-4f, -1.9276e-5f, 12890.f,
+				     12900.f, 1.2534e-5f, .034814f, .006137f, -3.6942e-5f, .0033798f,
+				     -3.139e-5f, 12900.f, 12910.f, 1.9577e-5f, .031771f, .0046608f,
+				     -3.1037e-5f, .0019036f, -2.5485e-5f, 12910.f, 12920.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 12920.f, 12930.f, 9.153e-6f, .028818f, .0079937f, -4.4369e-5f,
+				     .0052366f, -3.8817e-5f, 12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12940.f, 12950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12960.f, 12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12970.f,
-    12980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12990.f, 1.3e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    13020.f, 13030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13040.f, 13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13050.f,
-    13060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13070.f, 13080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f,
-      13090.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13100.f, 13110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13120.f, 13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13130.f,
-    13140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13150.f, 13160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f,
-      13170.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13180.f, 13190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13200.f, 13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13210.f,
-    13220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13230.f, 13240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f,
-      13250.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13260.f, 13270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13280.f, 13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13290.f,
-    13300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13310.f, 13320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f,
-      13330.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13340.f, 13350.f, 3.4847e-5f, .04882f, .025041f, -1.1142e-4f, .022291f,
-    -1.0647e-4f, 13350.f, 13360.f, 6.4041e-5f, .10448f, .01454f,
-    -4.7733e-5f, .013707f, -6.0524e-5f, 13360.f, 13370.f, 4.8972e-5f,
-    .061588f, .015816f, -3.1234e-5f, .012279f, -4.4662e-5f, 13370.f,
-    13380.f, 3.4101e-4f, .20633f, .0080284f, -9.6908e-6f, .0076822f,
-    -2.8886e-5f, 13380.f, 13390.f, 1.6731e-5f, .03468f, .029361f,
-    -1.2984e-4f, .026604f, -1.2428e-4f, 13390.f, 13400.f, 3.9582e-4f,
-    .10507f, .018729f, -6.1046e-5f, .015312f, -6.0499e-5f, 13400.f, 13410.f,
-    5.7395e-4f, .20422f, .012292f, -3.0378e-5f, .010954f, -4.4352e-5f,
-    13410.f, 13420.f, 1.6304e-4f, .075327f, .024345f, -1.0453e-4f, .022312f,
-    -1.0356e-4f, 13420.f, 13430.f, .0014276f, .27047f, .017891f,
-    -7.3505e-5f, .016458f, -7.1692e-5f, 13430.f, 13440.f, 3.2739e-4f,
-    .19765f, .021521f, -5.2027e-5f, .020205f, -6.8454e-5f, 13440.f, 13450.f,
-    8.4176e-4f, .22651f, .014704f, -5.7138e-5f, .012449f, -5.5586e-5f,
-    13450.f, 13460.f, .003321f, .26989f, .014889f, -6.1022e-5f, .014319f,
-    -6.4594e-5f, 13460.f, 13470.f, .0020184f, .15068f, .014242f,
-    -5.0382e-5f, .014352f, -5.2958e-5f, 13470.f, 13480.f, .0034847f,
-    .23656f, .01296f, -5.4713e-5f, .011654f, -5.3532e-5f, 13480.f, 13490.f,
-    .0051848f, .22152f, .01005f, -4.214e-5f, .010802f, -4.9706e-5f, 13490.f,
-    13500.f, .002246f, .20257f, .011509f, -1.145e-6f, .012567f, -2.9901e-5f,
-    13500.f, 13510.f, .01207f, .22916f, .0070442f, -3.1499e-5f, .0063368f,
-    -3.3814e-5f, 13510.f, 13520.f, .011903f, .21411f, .006383f, -2.2698e-5f,
-    .0062241f, -2.6759e-5f, 13520.f, 13530.f, .009548f, .21575f, .0044827f,
-    -1.1921e-5f, .0055699f, -2.5927e-5f, 13530.f, 13540.f, .011523f,
-    .40682f, .0091253f, -1.9397e-5f, .0079449f, -3.2998e-5f, 13540.f,
-    13550.f, .0084497f, .29293f, .0047841f, -1.1629e-5f, .0057988f,
-    -2.5164e-5f, 13550.f, 13560.f, .026919f, .27673f, .0019766f,
-    -3.7751e-6f, .0016743f, -8.638e-6f, 13560.f, 13570.f, .021945f, .3387f,
-    .005114f, 3.7089e-6f, .0063004f, -2.3091e-5f, 13570.f, 13580.f,
-    .021982f, .18246f, 3.6494e-4f, 1.1207e-6f, -3.7751e-4f, -1.4267e-6f,
-    13580.f, 13590.f, .010404f, .21217f, .0039463f, 5.5125e-6f, .0030886f,
-    -1.2313e-5f, 13590.f, 13600.f, .022785f, .35675f, .0080322f, -4.828e-6f,
-    .0057084f, -1.9313e-5f, 13600.f, 13610.f, .021944f, .17661f, .0028308f,
-    8.2581e-6f, .0014574f, -4.9721e-6f, 13610.f, 13620.f, .015009f, .16917f,
-    .001106f, 1.4866e-5f, .001036f, -3.5775e-6f, 13620.f, 13630.f, .028056f,
-    .27826f, .010985f, -5.284e-5f, .0083121f, -4.5055e-5f, 13630.f, 13640.f,
-    .017905f, .21652f, .0091202f, -4.3033e-5f, .0064523f, -3.6725e-5f,
-    13640.f, 13650.f, .040842f, .16141f, .002459f, -4.3246e-6f, 2.4001e-4f,
-    -1.8088e-6f, 13650.f, 13660.f, .064344f, .36355f, .002624f, -5.0938e-6f,
-    8.4629e-4f, -7.2912e-6f, 13660.f, 13670.f, .098009f, .46873f, .003736f,
-    -2.2472e-5f, .0012376f, -1.8409e-5f, 13670.f, 13680.f, .10223f, .26441f,
-    .0043146f, -2.6517e-5f, .003082f, -2.1843e-5f, 13680.f, 13690.f,
-    .051383f, .36953f, .0029461f, -4.1201e-6f, .001609f, -1.0556e-5f,
-    13690.f, 13700.f, .079035f, .41629f, .0039863f, -1.0096e-5f, .0020593f,
-    -1.5846e-5f, 13700.f, 13710.f, .17862f, .23727f, 7.0664e-4f,
-    -1.3429e-5f, -.0024735f, -6.33e-6f, 13710.f, 13720.f, .023457f, .12905f,
-    -.0022038f, -1.2856e-6f, -.0036094f, 1.0306e-6f, 13720.f, 13730.f,
-    .1498f, .27847f, -7.0337e-4f, -8.8658e-6f, -.0037774f, -2.5192e-6f,
-    13730.f, 13740.f, .15951f, .19705f, -.0012269f, -5.7441e-6f, -.0026138f,
-    -3.9795e-6f, 13740.f, 13750.f, .030444f, .2508f, .001339f, -3.667e-6f,
-    .0013056f, -7.9865e-6f, 13750.f, 13760.f, .091463f, .42355f, .0015252f,
-    -5.082e-6f, 1.0296e-4f, -1.0731e-5f, 13760.f, 13770.f, .055724f,
-    .23315f, 5.0264e-4f, -5.1006e-7f, -.0018097f, -3.8866e-6f, 13770.f,
-    13780.f, .20577f, .30719f, -.0013969f, 1.9333e-6f, -.0029895f,
-    -5.1114e-7f, 13780.f, 13790.f, .076501f, .36547f, .0034715f,
-    -2.4093e-5f, .0010916f, -1.9569e-5f, 13790.f, 13800.f, .26798f, .22416f,
-    -.0016316f, -1.9581e-6f, -.0041508f, 1.1385e-6f, 13800.f, 13810.f,
-    .20338f, .16881f, -.0022177f, -1.1382e-6f, -.0032452f, -1.5814e-7f,
-    13810.f, 13820.f, .12951f, .12548f, -.0038707f, 6.337e-6f, -.0045229f,
-    6.1639e-6f, 13820.f, 13830.f, .088731f, .17991f, -.0038169f, 7.3459e-6f,
-    -.0042642f, 6.6757e-6f, 13830.f, 13840.f, .0067788f, .12625f, .0098132f,
-    -4.8875e-5f, .007723f, -4.7347e-5f, 13840.f, 13850.f, .010502f, .21694f,
-    8.6711e-4f, 4.6135e-6f, .0011488f, -8.9674e-6f, 13850.f, 13860.f,
-    .04906f, .16058f, -.0030216f, 1.0044e-5f, -.0024328f, 6.7471e-6f,
-    13860.f, 13870.f, .24278f, .15261f, -.0051224f, 8.9719e-6f, -.0065887f,
-    1.2603e-5f, 13870.f, 13880.f, .27304f, .29617f, -.003541f, 3.4588e-6f,
-    -.0050128f, 8.099e-6f, 13880.f, 13890.f, .13252f, .25864f, -.0015695f,
-    -2.898e-6f, -.002959f, -3.2727e-6f, 13890.f, 13900.f, .27275f, .14969f,
-    -.0015578f, -4.3912e-6f, -.0023477f, -2.7675e-6f, 13900.f, 13910.f,
-    .28731f, .24848f, -2.6722e-4f, -9.0595e-6f, -.002097f, -6.6308e-6f,
-    13910.f, 13920.f, .20952f, .31628f, .0028828f, -2.1023e-5f, 9.3184e-4f,
-    -1.7842e-5f, 13920.f, 13930.f, .12621f, .34509f, .0047187f, -2.6132e-5f,
-    .0021269f, -2.2662e-5f, 13930.f, 13940.f, .082581f, .35712f, .0065235f,
-    -2.9651e-5f, .0046608f, -2.9306e-5f, 13940.f, 13950.f, .02215f, .56251f,
-    .011273f, -2.023e-5f, .0098905f, -3.5866e-5f, 13950.f, 13960.f,
-    .013395f, .23595f, .0075697f, -1.1677e-5f, .0047404f, -1.3519e-5f,
-    13960.f, 13970.f, .0097251f, .389f, .0045853f, -4.4223e-6f, .0013332f,
-    -8.8812e-6f, 13970.f, 13980.f, .01416f, .3192f, .0014413f, 7.7474e-7f,
-    .0010611f, -6.6038e-6f, 13980.f, 13990.f, .0064431f, .38168f, .0021106f,
-    -5.5268e-6f, 6.2478e-4f, -4.2781e-6f, 13990.f, 1.4e4f, .0074763f,
-    .21449f, 8.6863e-6f, -4.7583e-6f, -.0024648f, -3.1646e-6f, 1.4e4f,
-    14010.f, .0044339f, .31044f, .0062951f, -8.282e-6f, .00239f,
-    -1.0886e-5f, 14010.f, 14020.f, .0063698f, .37192f, .0035714f,
-    -7.0127e-6f, .0022531f, -1.3753e-5f, 14020.f, 14030.f, .0030618f,
-    .32199f, .0067837f, -4.6145e-6f, .0056415f, -1.9199e-5f, 14030.f,
-    14040.f, .0045836f, .19592f, .0034269f, -6.7013e-6f, .0015603f,
-    -2.0576e-6f, 14040.f, 14050.f, .0028921f, .26752f, .0054727f,
-    -8.232e-6f, .0034172f, -1.6235e-5f, 14050.f, 14060.f, .0083604f, .491f,
-    .0036871f, -2.6932e-6f, .0022258f, -1.2432e-5f, 14060.f, 14070.f,
-    .0048958f, .40049f, .0028518f, -8.9707e-6f, 7.3805e-4f, -1.0552e-5f,
-    14070.f, 14080.f, .0060175f, .66182f, .0036922f, -1.2082e-5f, .002131f,
-    -1.7251e-5f, 14080.f, 14090.f, .0051267f, .30376f, .012373f,
-    -5.2388e-5f, .0092416f, -4.9701e-5f, 14090.f, 14100.f, .0051874f,
-    .37923f, .0085604f, -3.2476e-5f, .0048279f, -2.831e-5f, 14100.f,
-    14110.f, .0037549f, .24752f, .0026234f, 1.353e-6f, 1.7089e-4f,
-    -5.9579e-6f, 14110.f, 14120.f, .008547f, .48393f, .0055118f,
-    -1.2616e-5f, .0021682f, -1.5595e-5f, 14120.f, 14130.f, .007167f,
-    .42356f, .0073835f, -3.8638e-5f, .0043338f, -3.2395e-5f, 14130.f,
-    14140.f, .0084611f, .31558f, .0047305f, -1.7484e-5f, .0013223f,
-    -1.1411e-5f, 14140.f, 14150.f, .0086532f, .27748f, .005894f, -3.133e-5f,
-    .0032608f, -2.6952e-5f, 14150.f, 14160.f, .012236f, .32519f, .0020656f,
-    -1.1881e-5f, -4.5247e-4f, -1.1093e-5f, 14160.f, 14170.f, .019531f,
-    .25874f, .0039764f, -2.6715e-5f, .0012538f, -1.9528e-5f, 14170.f,
-    14180.f, .0057931f, .18836f, .0039509f, -2.0877e-5f, .001896f,
-    -1.8677e-5f, 14180.f, 14190.f, .0065709f, .31403f, .0030661f,
-    -6.3795e-6f, .0013225f, -1.1966e-5f, 14190.f, 14200.f, .026818f,
-    .21236f, .0016226f, -1.6759e-5f, -4.3884e-4f, -1.1258e-5f, 14200.f,
-    14210.f, .0015917f, .17083f, .0098825f, -2.9767e-5f, .0059285f,
-    -2.8608e-5f, 14210.f, 14220.f, .036373f, .30478f, 9.7187e-4f,
-    -8.1756e-6f, 8.1092e-5f, -1.0434e-5f, 14220.f, 14230.f, .018351f,
-    .085618f, -.0015427f, -3.9022e-6f, -.0026215f, 7.5823e-7f, 14230.f,
-    14240.f, .027421f, .1672f, -.0016048f, 1.04e-6f, -.0021918f,
-    -7.3937e-7f, 14240.f, 14250.f, .019137f, .34394f, .0054701f,
-    -3.1082e-5f, .0021305f, -2.3894e-5f, 14250.f, 14260.f, .011742f,
-    .24754f, -.0015398f, 1.4005e-6f, -.0032941f, 1.7021e-7f, 14260.f,
-    14270.f, .030406f, .25107f, -.0021777f, 1.1738e-6f, -.0042308f,
-    1.983e-6f, 14270.f, 14280.f, .02572f, .17272f, .0014929f, -1.7124e-5f,
-    -2.0245e-4f, -1.5475e-5f, 14280.f, 14290.f, .023411f, .14155f,
-    -.0036159f, 5.4534e-6f, -.0056547f, 8.3323e-6f, 14290.f, 14300.f,
-    .050436f, .17597f, -.0035358f, 2.7001e-6f, -.005998f, 7.9894e-6f,
-    14300.f, 14310.f, .010835f, .16074f, -.0023328f, 3.6258e-6f, -.0036191f,
-    6.6611e-7f, 14310.f, 14320.f, .0097229f, .1372f, -.0026043f, 3.3682e-6f,
-    -.0039301f, 2.3934e-6f, 14320.f, 14330.f, .0041727f, .26898f,
-    8.9506e-4f, -3.3799e-6f, -8.0987e-4f, -7.4366e-6f, 14330.f, 14340.f,
-    .0028313f, .11399f, -.0023514f, 1.9057e-8f, -.0043191f, 3.2086e-6f,
-    14340.f, 14350.f, .0094087f, .13847f, -.0033995f, 5.3082e-6f,
-    -.0048841f, 7.2565e-6f, 14350.f, 14360.f, .045453f, .1618f, -.0049821f,
-    9.5517e-6f, -.0062627f, 1.3183e-5f, 14360.f, 14370.f, .05478f, .246f,
-    -.003323f, 3.3083e-6f, -.0044595f, 4.3249e-6f, 14370.f, 14380.f,
-    .057794f, .29926f, -.0018524f, -2.6891e-6f, -.0034713f, -1.4711e-6f,
-    14380.f, 14390.f, .017789f, .040974f, -5.5041e-4f, -9.0402e-6f,
-    -.0019035f, -4.1538e-6f, 14390.f, 14400.f, .066509f, .31802f,
-    1.7874e-4f, -1.0469e-5f, -.0014428f, -9.3839e-6f, 14400.f, 14410.f,
-    .033243f, .21287f, .0023294f, -1.8667e-5f, -4.0745e-4f, -1.2383e-5f,
-    14410.f, 14420.f, .030315f, .32935f, .005459f, -3.1244e-5f, .0033095f,
-    -2.8644e-5f, 14420.f, 14430.f, .011921f, .16637f, .0064852f,
-    -3.2883e-5f, .0040894f, -2.982e-5f, 14430.f, 14440.f, .0035817f,
-    .24062f, .010713f, -2.2991e-5f, .0076719f, -3.0879e-5f, 14440.f,
-    14450.f, .0020434f, .09533f, .0074555f, -4.0758e-5f, .003952f,
-    -3.2281e-5f, 14450.f, 14460.f, .0019531f, .057626f, .013393f,
-    -6.572e-5f, .010648f, -6.0338e-5f, 14460.f, 14470.f, .0015972f,
+				     12970.f,
+				     12980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12990.f, 1.3e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13020.f, 13030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13040.f, 13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13050.f,
+				     13060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13070.f, 13080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f,
+				     13090.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13100.f, 13110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13120.f, 13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13130.f,
+				     13140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13150.f, 13160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f,
+				     13170.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13180.f, 13190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13200.f, 13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13210.f,
+				     13220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13230.f, 13240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f,
+				     13250.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13260.f, 13270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13280.f, 13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13290.f,
+				     13300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13310.f, 13320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f,
+				     13330.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13340.f, 13350.f, 3.4847e-5f, .04882f, .025041f, -1.1142e-4f, .022291f,
+				     -1.0647e-4f, 13350.f, 13360.f, 6.4041e-5f, .10448f, .01454f,
+				     -4.7733e-5f, .013707f, -6.0524e-5f, 13360.f, 13370.f, 4.8972e-5f,
+				     .061588f, .015816f, -3.1234e-5f, .012279f, -4.4662e-5f, 13370.f,
+				     13380.f, 3.4101e-4f, .20633f, .0080284f, -9.6908e-6f, .0076822f,
+				     -2.8886e-5f, 13380.f, 13390.f, 1.6731e-5f, .03468f, .029361f,
+				     -1.2984e-4f, .026604f, -1.2428e-4f, 13390.f, 13400.f, 3.9582e-4f,
+				     .10507f, .018729f, -6.1046e-5f, .015312f, -6.0499e-5f, 13400.f, 13410.f,
+				     5.7395e-4f, .20422f, .012292f, -3.0378e-5f, .010954f, -4.4352e-5f,
+				     13410.f, 13420.f, 1.6304e-4f, .075327f, .024345f, -1.0453e-4f, .022312f,
+				     -1.0356e-4f, 13420.f, 13430.f, .0014276f, .27047f, .017891f,
+				     -7.3505e-5f, .016458f, -7.1692e-5f, 13430.f, 13440.f, 3.2739e-4f,
+				     .19765f, .021521f, -5.2027e-5f, .020205f, -6.8454e-5f, 13440.f, 13450.f,
+				     8.4176e-4f, .22651f, .014704f, -5.7138e-5f, .012449f, -5.5586e-5f,
+				     13450.f, 13460.f, .003321f, .26989f, .014889f, -6.1022e-5f, .014319f,
+				     -6.4594e-5f, 13460.f, 13470.f, .0020184f, .15068f, .014242f,
+				     -5.0382e-5f, .014352f, -5.2958e-5f, 13470.f, 13480.f, .0034847f,
+				     .23656f, .01296f, -5.4713e-5f, .011654f, -5.3532e-5f, 13480.f, 13490.f,
+				     .0051848f, .22152f, .01005f, -4.214e-5f, .010802f, -4.9706e-5f, 13490.f,
+				     13500.f, .002246f, .20257f, .011509f, -1.145e-6f, .012567f, -2.9901e-5f,
+				     13500.f, 13510.f, .01207f, .22916f, .0070442f, -3.1499e-5f, .0063368f,
+				     -3.3814e-5f, 13510.f, 13520.f, .011903f, .21411f, .006383f, -2.2698e-5f,
+				     .0062241f, -2.6759e-5f, 13520.f, 13530.f, .009548f, .21575f, .0044827f,
+				     -1.1921e-5f, .0055699f, -2.5927e-5f, 13530.f, 13540.f, .011523f,
+				     .40682f, .0091253f, -1.9397e-5f, .0079449f, -3.2998e-5f, 13540.f,
+				     13550.f, .0084497f, .29293f, .0047841f, -1.1629e-5f, .0057988f,
+				     -2.5164e-5f, 13550.f, 13560.f, .026919f, .27673f, .0019766f,
+				     -3.7751e-6f, .0016743f, -8.638e-6f, 13560.f, 13570.f, .021945f, .3387f,
+				     .005114f, 3.7089e-6f, .0063004f, -2.3091e-5f, 13570.f, 13580.f,
+				     .021982f, .18246f, 3.6494e-4f, 1.1207e-6f, -3.7751e-4f, -1.4267e-6f,
+				     13580.f, 13590.f, .010404f, .21217f, .0039463f, 5.5125e-6f, .0030886f,
+				     -1.2313e-5f, 13590.f, 13600.f, .022785f, .35675f, .0080322f, -4.828e-6f,
+				     .0057084f, -1.9313e-5f, 13600.f, 13610.f, .021944f, .17661f, .0028308f,
+				     8.2581e-6f, .0014574f, -4.9721e-6f, 13610.f, 13620.f, .015009f, .16917f,
+				     .001106f, 1.4866e-5f, .001036f, -3.5775e-6f, 13620.f, 13630.f, .028056f,
+				     .27826f, .010985f, -5.284e-5f, .0083121f, -4.5055e-5f, 13630.f, 13640.f,
+				     .017905f, .21652f, .0091202f, -4.3033e-5f, .0064523f, -3.6725e-5f,
+				     13640.f, 13650.f, .040842f, .16141f, .002459f, -4.3246e-6f, 2.4001e-4f,
+				     -1.8088e-6f, 13650.f, 13660.f, .064344f, .36355f, .002624f, -5.0938e-6f,
+				     8.4629e-4f, -7.2912e-6f, 13660.f, 13670.f, .098009f, .46873f, .003736f,
+				     -2.2472e-5f, .0012376f, -1.8409e-5f, 13670.f, 13680.f, .10223f, .26441f,
+				     .0043146f, -2.6517e-5f, .003082f, -2.1843e-5f, 13680.f, 13690.f,
+				     .051383f, .36953f, .0029461f, -4.1201e-6f, .001609f, -1.0556e-5f,
+				     13690.f, 13700.f, .079035f, .41629f, .0039863f, -1.0096e-5f, .0020593f,
+				     -1.5846e-5f, 13700.f, 13710.f, .17862f, .23727f, 7.0664e-4f,
+				     -1.3429e-5f, -.0024735f, -6.33e-6f, 13710.f, 13720.f, .023457f, .12905f,
+				     -.0022038f, -1.2856e-6f, -.0036094f, 1.0306e-6f, 13720.f, 13730.f,
+				     .1498f, .27847f, -7.0337e-4f, -8.8658e-6f, -.0037774f, -2.5192e-6f,
+				     13730.f, 13740.f, .15951f, .19705f, -.0012269f, -5.7441e-6f, -.0026138f,
+				     -3.9795e-6f, 13740.f, 13750.f, .030444f, .2508f, .001339f, -3.667e-6f,
+				     .0013056f, -7.9865e-6f, 13750.f, 13760.f, .091463f, .42355f, .0015252f,
+				     -5.082e-6f, 1.0296e-4f, -1.0731e-5f, 13760.f, 13770.f, .055724f,
+				     .23315f, 5.0264e-4f, -5.1006e-7f, -.0018097f, -3.8866e-6f, 13770.f,
+				     13780.f, .20577f, .30719f, -.0013969f, 1.9333e-6f, -.0029895f,
+				     -5.1114e-7f, 13780.f, 13790.f, .076501f, .36547f, .0034715f,
+				     -2.4093e-5f, .0010916f, -1.9569e-5f, 13790.f, 13800.f, .26798f, .22416f,
+				     -.0016316f, -1.9581e-6f, -.0041508f, 1.1385e-6f, 13800.f, 13810.f,
+				     .20338f, .16881f, -.0022177f, -1.1382e-6f, -.0032452f, -1.5814e-7f,
+				     13810.f, 13820.f, .12951f, .12548f, -.0038707f, 6.337e-6f, -.0045229f,
+				     6.1639e-6f, 13820.f, 13830.f, .088731f, .17991f, -.0038169f, 7.3459e-6f,
+				     -.0042642f, 6.6757e-6f, 13830.f, 13840.f, .0067788f, .12625f, .0098132f,
+				     -4.8875e-5f, .007723f, -4.7347e-5f, 13840.f, 13850.f, .010502f, .21694f,
+				     8.6711e-4f, 4.6135e-6f, .0011488f, -8.9674e-6f, 13850.f, 13860.f,
+				     .04906f, .16058f, -.0030216f, 1.0044e-5f, -.0024328f, 6.7471e-6f,
+				     13860.f, 13870.f, .24278f, .15261f, -.0051224f, 8.9719e-6f, -.0065887f,
+				     1.2603e-5f, 13870.f, 13880.f, .27304f, .29617f, -.003541f, 3.4588e-6f,
+				     -.0050128f, 8.099e-6f, 13880.f, 13890.f, .13252f, .25864f, -.0015695f,
+				     -2.898e-6f, -.002959f, -3.2727e-6f, 13890.f, 13900.f, .27275f, .14969f,
+				     -.0015578f, -4.3912e-6f, -.0023477f, -2.7675e-6f, 13900.f, 13910.f,
+				     .28731f, .24848f, -2.6722e-4f, -9.0595e-6f, -.002097f, -6.6308e-6f,
+				     13910.f, 13920.f, .20952f, .31628f, .0028828f, -2.1023e-5f, 9.3184e-4f,
+				     -1.7842e-5f, 13920.f, 13930.f, .12621f, .34509f, .0047187f, -2.6132e-5f,
+				     .0021269f, -2.2662e-5f, 13930.f, 13940.f, .082581f, .35712f, .0065235f,
+				     -2.9651e-5f, .0046608f, -2.9306e-5f, 13940.f, 13950.f, .02215f, .56251f,
+				     .011273f, -2.023e-5f, .0098905f, -3.5866e-5f, 13950.f, 13960.f,
+				     .013395f, .23595f, .0075697f, -1.1677e-5f, .0047404f, -1.3519e-5f,
+				     13960.f, 13970.f, .0097251f, .389f, .0045853f, -4.4223e-6f, .0013332f,
+				     -8.8812e-6f, 13970.f, 13980.f, .01416f, .3192f, .0014413f, 7.7474e-7f,
+				     .0010611f, -6.6038e-6f, 13980.f, 13990.f, .0064431f, .38168f, .0021106f,
+				     -5.5268e-6f, 6.2478e-4f, -4.2781e-6f, 13990.f, 1.4e4f, .0074763f,
+				     .21449f, 8.6863e-6f, -4.7583e-6f, -.0024648f, -3.1646e-6f, 1.4e4f,
+				     14010.f, .0044339f, .31044f, .0062951f, -8.282e-6f, .00239f,
+				     -1.0886e-5f, 14010.f, 14020.f, .0063698f, .37192f, .0035714f,
+				     -7.0127e-6f, .0022531f, -1.3753e-5f, 14020.f, 14030.f, .0030618f,
+				     .32199f, .0067837f, -4.6145e-6f, .0056415f, -1.9199e-5f, 14030.f,
+				     14040.f, .0045836f, .19592f, .0034269f, -6.7013e-6f, .0015603f,
+				     -2.0576e-6f, 14040.f, 14050.f, .0028921f, .26752f, .0054727f,
+				     -8.232e-6f, .0034172f, -1.6235e-5f, 14050.f, 14060.f, .0083604f, .491f,
+				     .0036871f, -2.6932e-6f, .0022258f, -1.2432e-5f, 14060.f, 14070.f,
+				     .0048958f, .40049f, .0028518f, -8.9707e-6f, 7.3805e-4f, -1.0552e-5f,
+				     14070.f, 14080.f, .0060175f, .66182f, .0036922f, -1.2082e-5f, .002131f,
+				     -1.7251e-5f, 14080.f, 14090.f, .0051267f, .30376f, .012373f,
+				     -5.2388e-5f, .0092416f, -4.9701e-5f, 14090.f, 14100.f, .0051874f,
+				     .37923f, .0085604f, -3.2476e-5f, .0048279f, -2.831e-5f, 14100.f,
+				     14110.f, .0037549f, .24752f, .0026234f, 1.353e-6f, 1.7089e-4f,
+				     -5.9579e-6f, 14110.f, 14120.f, .008547f, .48393f, .0055118f,
+				     -1.2616e-5f, .0021682f, -1.5595e-5f, 14120.f, 14130.f, .007167f,
+				     .42356f, .0073835f, -3.8638e-5f, .0043338f, -3.2395e-5f, 14130.f,
+				     14140.f, .0084611f, .31558f, .0047305f, -1.7484e-5f, .0013223f,
+				     -1.1411e-5f, 14140.f, 14150.f, .0086532f, .27748f, .005894f, -3.133e-5f,
+				     .0032608f, -2.6952e-5f, 14150.f, 14160.f, .012236f, .32519f, .0020656f,
+				     -1.1881e-5f, -4.5247e-4f, -1.1093e-5f, 14160.f, 14170.f, .019531f,
+				     .25874f, .0039764f, -2.6715e-5f, .0012538f, -1.9528e-5f, 14170.f,
+				     14180.f, .0057931f, .18836f, .0039509f, -2.0877e-5f, .001896f,
+				     -1.8677e-5f, 14180.f, 14190.f, .0065709f, .31403f, .0030661f,
+				     -6.3795e-6f, .0013225f, -1.1966e-5f, 14190.f, 14200.f, .026818f,
+				     .21236f, .0016226f, -1.6759e-5f, -4.3884e-4f, -1.1258e-5f, 14200.f,
+				     14210.f, .0015917f, .17083f, .0098825f, -2.9767e-5f, .0059285f,
+				     -2.8608e-5f, 14210.f, 14220.f, .036373f, .30478f, 9.7187e-4f,
+				     -8.1756e-6f, 8.1092e-5f, -1.0434e-5f, 14220.f, 14230.f, .018351f,
+				     .085618f, -.0015427f, -3.9022e-6f, -.0026215f, 7.5823e-7f, 14230.f,
+				     14240.f, .027421f, .1672f, -.0016048f, 1.04e-6f, -.0021918f,
+				     -7.3937e-7f, 14240.f, 14250.f, .019137f, .34394f, .0054701f,
+				     -3.1082e-5f, .0021305f, -2.3894e-5f, 14250.f, 14260.f, .011742f,
+				     .24754f, -.0015398f, 1.4005e-6f, -.0032941f, 1.7021e-7f, 14260.f,
+				     14270.f, .030406f, .25107f, -.0021777f, 1.1738e-6f, -.0042308f,
+				     1.983e-6f, 14270.f, 14280.f, .02572f, .17272f, .0014929f, -1.7124e-5f,
+				     -2.0245e-4f, -1.5475e-5f, 14280.f, 14290.f, .023411f, .14155f,
+				     -.0036159f, 5.4534e-6f, -.0056547f, 8.3323e-6f, 14290.f, 14300.f,
+				     .050436f, .17597f, -.0035358f, 2.7001e-6f, -.005998f, 7.9894e-6f,
+				     14300.f, 14310.f, .010835f, .16074f, -.0023328f, 3.6258e-6f, -.0036191f,
+				     6.6611e-7f, 14310.f, 14320.f, .0097229f, .1372f, -.0026043f, 3.3682e-6f,
+				     -.0039301f, 2.3934e-6f, 14320.f, 14330.f, .0041727f, .26898f,
+				     8.9506e-4f, -3.3799e-6f, -8.0987e-4f, -7.4366e-6f, 14330.f, 14340.f,
+				     .0028313f, .11399f, -.0023514f, 1.9057e-8f, -.0043191f, 3.2086e-6f,
+				     14340.f, 14350.f, .0094087f, .13847f, -.0033995f, 5.3082e-6f,
+				     -.0048841f, 7.2565e-6f, 14350.f, 14360.f, .045453f, .1618f, -.0049821f,
+				     9.5517e-6f, -.0062627f, 1.3183e-5f, 14360.f, 14370.f, .05478f, .246f,
+				     -.003323f, 3.3083e-6f, -.0044595f, 4.3249e-6f, 14370.f, 14380.f,
+				     .057794f, .29926f, -.0018524f, -2.6891e-6f, -.0034713f, -1.4711e-6f,
+				     14380.f, 14390.f, .017789f, .040974f, -5.5041e-4f, -9.0402e-6f,
+				     -.0019035f, -4.1538e-6f, 14390.f, 14400.f, .066509f, .31802f,
+				     1.7874e-4f, -1.0469e-5f, -.0014428f, -9.3839e-6f, 14400.f, 14410.f,
+				     .033243f, .21287f, .0023294f, -1.8667e-5f, -4.0745e-4f, -1.2383e-5f,
+				     14410.f, 14420.f, .030315f, .32935f, .005459f, -3.1244e-5f, .0033095f,
+				     -2.8644e-5f, 14420.f, 14430.f, .011921f, .16637f, .0064852f,
+				     -3.2883e-5f, .0040894f, -2.982e-5f, 14430.f, 14440.f, .0035817f,
+				     .24062f, .010713f, -2.2991e-5f, .0076719f, -3.0879e-5f, 14440.f,
+				     14450.f, .0020434f, .09533f, .0074555f, -4.0758e-5f, .003952f,
+				     -3.2281e-5f, 14450.f, 14460.f, .0019531f, .057626f, .013393f,
+				     -6.572e-5f, .010648f, -6.0338e-5f, 14460.f, 14470.f, .0015972f,
-    .063531f, -.0028566f, -9.3552e-7f, -.0057668f, 5.2381e-6f, 14470.f,
-    14480.f, 6.208e-4f, .14581f, -.0038143f, 3.5516e-6f, -.006417f,
-    7.6586e-6f, 14480.f, 14490.f, 2.573e-4f, .034903f, .0017376f,
-    -1.9344e-5f, -.0010196f, -1.3792e-5f, 14490.f, 14500.f, 5.8326e-4f,
-    .07101f, .0037987f, -2.7471e-5f, .0011761f, -2.2502e-5f, 14500.f,
-    14510.f, 1.981e-4f, .037767f, 5.4219e-4f, -1.4563e-5f, -.002215f,
-    -9.0107e-6f, 14510.f, 14520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f,
-    14530.f, 6.1723e-4f, .05996f, .0029608f, -2.3205e-5f, -5.41e-4f,
-    -1.4715e-5f, 14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f,
-    14550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 8.7384e-4f,
-    .20577f, .001467f, -1.2035e-5f, -.0013037f, -8.5219e-6f, 14560.f,
-    14570.f, 3.6981e-4f, .15319f, .0026086f, 5.1176e-7f, -9.4964e-4f,
-    -4.1621e-6f, 14570.f, 14580.f, 5.3062e-4f, .2039f, -9.2668e-4f,
-    -1.7265e-6f, -.0025209f, -3.9176e-6f, 14580.f, 14590.f, 2.3625e-4f,
-    .10952f, 3.608e-5f, -6.6963e-7f, -.0029777f, -5.5782e-7f, 14590.f,
-    14600.f, 2.5529e-4f, .085175f, .0086357f, -4.5158e-5f, .0055824f,
-    -3.9246e-5f, 14600.f, 14610.f, 3.5469e-4f, .17005f, 5.5905e-4f,
-    3.4517e-6f, -.0012201f, -2.0532e-6f, 14610.f, 14620.f, 1.4962e-4f,
-    .070668f, 3.6006e-4f, -1.3091e-5f, -.002318f, -8.0334e-6f, 14620.f,
-    14630.f, 1.6283e-4f, .043851f, -.0019069f, -4.7662e-6f, -.0047857f,
-    1.0305e-6f, 14630.f, 14640.f, 3.4849e-4f, .091227f, 1.957e-4f,
-    -6.7027e-6f, -.0019067f, -6.8831e-6f, 14640.f, 14650.f, 2.4098e-4f,
-    .073915f, 5.8149e-4f, 2.017e-6f, -.0021878f, -6.9336e-7f, 14650.f,
-    14660.f, 1.8929e-4f, .040095f, -9.767e-4f, -8.487e-6f, -.003815f,
-    -2.7719e-6f, 14660.f, 14670.f, 2.8551e-4f, .089939f, 9.0134e-4f,
-    -1.5963e-5f, -.0017529f, -1.0799e-5f, 14670.f, 14680.f, 1.3624e-4f,
-    .063104f, .0051307f, -3.2797e-5f, .002189f, -2.6775e-5f, 14680.f,
-    14690.f, 9.1275e-5f, .031681f, .0031085f, -2.4828e-5f, 3.5131e-4f,
-    -1.9276e-5f, 14690.f, 14700.f, 8.8122e-5f, .040141f, .0011384f,
-    -1.6948e-5f, -.0017809f, -1.1069e-5f, 14700.f, 14710.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14720.f,
-    14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
-      14760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14800.f,
-    14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
-      14840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14880.f,
-    14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
-      14920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14960.f,
-    14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15040.f,
-    15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
-      15080.f,
-    7.1934e-4f, .12682f, .0061012f, 1.5559e-5f, .0027848f, -4.5145e-6f,
-    15080.f, 15090.f, 4.9571e-4f, .13321f, .0050157f, 1.7658e-5f, .0024032f,
-    -4.0605e-6f, 15090.f, 15100.f, 2.2621e-4f, .12674f, .016133f,
-    -6.1229e-5f, .013281f, -6.2746e-5f, 15100.f, 15110.f, 8.5668e-4f,
-    .12425f, .016195f, -7.6668e-5f, .013811f, -7.25e-5f, 15110.f, 15120.f,
-    5.5721e-4f, .11061f, .0048501f, 3.2762e-5f, .0041846f, 4.2515e-7f,
-    15120.f, 15130.f, .0010214f, .16075f, .0077437f, -9.7938e-6f, .0033244f,
-    -1.335e-5f, 15130.f, 15140.f, .0037351f, .23141f, .0075468f,
-    -1.8073e-5f, .0038208f, -1.7101e-5f, 15140.f, 15150.f, 6.9279e-4f,
-    .16527f, .0092564f, -2.4217e-5f, .0059447f, -2.8136e-5f, 15150.f,
-    15160.f, .0020924f, .19937f, .0067646f, -1.9228e-5f, .0021429f,
-    -1.4011e-5f, 15160.f, 15170.f, .0029213f, .11019f, .0078105f,
-    -4.068e-5f, .0061601f, -3.7164e-5f, 15170.f, 15180.f, .0040031f, .2888f,
-    .0050758f, -1.9158e-5f, .0019869f, -1.728e-5f, 15180.f, 15190.f,
-    .0024252f, .15747f, .0044234f, -2.0027e-5f, 3.4479e-4f, -1.2338e-5f,
-    15190.f, 15200.f, .0087795f, .14543f, .0042621f, -2.7308e-5f,
-    7.3031e-4f, -1.681e-5f, 15200.f, 15210.f, .0095997f, .374f, .0046013f,
-    -2.8568e-5f, .002061f, -2.4098e-5f, 15210.f, 15220.f, 9.5938e-4f,
-    .22877f, .0032518f, -1.2364e-5f, .00118f, -1.6396e-5f, 15220.f, 15230.f,
-    .0089911f, .27602f, .0015486f, -1.7622e-5f, -7.0027e-4f, -1.3639e-5f,
-    15230.f, 15240.f, .0070384f, .19525f, .0017332f, -1.8418e-5f,
-    -.0010753f, -1.2514e-5f, 15240.f, 15250.f, .012889f, .20893f,
-    5.2643e-4f, -8.5726e-6f, -8.0955e-4f, -8.4315e-6f, 15250.f, 15260.f,
-    .01071f, .10552f, -.0015016f, -6.0962e-6f, -.0038322f, -1.9428e-6f,
-    15260.f, 15270.f, .011725f, .11142f, -.0024386f, -2.089e-6f, -.0045783f,
-    1.5311e-6f, 15270.f, 15280.f, .0036695f, .13405f, -.0019794f,
-    1.4362e-7f, -.0035859f, 2.0003e-6f, 15280.f, 15290.f, .0038912f,
-    .14992f, -3.0601e-5f, 8.2096e-6f, -1.4088e-4f, -1.393e-6f, 15290.f,
-    15300.f
+				     .063531f, -.0028566f, -9.3552e-7f, -.0057668f, 5.2381e-6f, 14470.f,
+				     14480.f, 6.208e-4f, .14581f, -.0038143f, 3.5516e-6f, -.006417f,
+				     7.6586e-6f, 14480.f, 14490.f, 2.573e-4f, .034903f, .0017376f,
+				     -1.9344e-5f, -.0010196f, -1.3792e-5f, 14490.f, 14500.f, 5.8326e-4f,
+				     .07101f, .0037987f, -2.7471e-5f, .0011761f, -2.2502e-5f, 14500.f,
+				     14510.f, 1.981e-4f, .037767f, 5.4219e-4f, -1.4563e-5f, -.002215f,
+				     -9.0107e-6f, 14510.f, 14520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f,
+				     14530.f, 6.1723e-4f, .05996f, .0029608f, -2.3205e-5f, -5.41e-4f,
+				     -1.4715e-5f, 14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f,
+				     14550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 8.7384e-4f,
+				     .20577f, .001467f, -1.2035e-5f, -.0013037f, -8.5219e-6f, 14560.f,
+				     14570.f, 3.6981e-4f, .15319f, .0026086f, 5.1176e-7f, -9.4964e-4f,
+				     -4.1621e-6f, 14570.f, 14580.f, 5.3062e-4f, .2039f, -9.2668e-4f,
+				     -1.7265e-6f, -.0025209f, -3.9176e-6f, 14580.f, 14590.f, 2.3625e-4f,
+				     .10952f, 3.608e-5f, -6.6963e-7f, -.0029777f, -5.5782e-7f, 14590.f,
+				     14600.f, 2.5529e-4f, .085175f, .0086357f, -4.5158e-5f, .0055824f,
+				     -3.9246e-5f, 14600.f, 14610.f, 3.5469e-4f, .17005f, 5.5905e-4f,
+				     3.4517e-6f, -.0012201f, -2.0532e-6f, 14610.f, 14620.f, 1.4962e-4f,
+				     .070668f, 3.6006e-4f, -1.3091e-5f, -.002318f, -8.0334e-6f, 14620.f,
+				     14630.f, 1.6283e-4f, .043851f, -.0019069f, -4.7662e-6f, -.0047857f,
+				     1.0305e-6f, 14630.f, 14640.f, 3.4849e-4f, .091227f, 1.957e-4f,
+				     -6.7027e-6f, -.0019067f, -6.8831e-6f, 14640.f, 14650.f, 2.4098e-4f,
+				     .073915f, 5.8149e-4f, 2.017e-6f, -.0021878f, -6.9336e-7f, 14650.f,
+				     14660.f, 1.8929e-4f, .040095f, -9.767e-4f, -8.487e-6f, -.003815f,
+				     -2.7719e-6f, 14660.f, 14670.f, 2.8551e-4f, .089939f, 9.0134e-4f,
+				     -1.5963e-5f, -.0017529f, -1.0799e-5f, 14670.f, 14680.f, 1.3624e-4f,
+				     .063104f, .0051307f, -3.2797e-5f, .002189f, -2.6775e-5f, 14680.f,
+				     14690.f, 9.1275e-5f, .031681f, .0031085f, -2.4828e-5f, 3.5131e-4f,
+				     -1.9276e-5f, 14690.f, 14700.f, 8.8122e-5f, .040141f, .0011384f,
+				     -1.6948e-5f, -.0017809f, -1.1069e-5f, 14700.f, 14710.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14720.f,
+				     14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
+				     14760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14800.f,
+				     14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
+				     14840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14880.f,
+				     14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
+				     14920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14960.f,
+				     14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15040.f,
+				     15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
+				     15080.f,
+				     7.1934e-4f, .12682f, .0061012f, 1.5559e-5f, .0027848f, -4.5145e-6f,
+				     15080.f, 15090.f, 4.9571e-4f, .13321f, .0050157f, 1.7658e-5f, .0024032f,
+				     -4.0605e-6f, 15090.f, 15100.f, 2.2621e-4f, .12674f, .016133f,
+				     -6.1229e-5f, .013281f, -6.2746e-5f, 15100.f, 15110.f, 8.5668e-4f,
+				     .12425f, .016195f, -7.6668e-5f, .013811f, -7.25e-5f, 15110.f, 15120.f,
+				     5.5721e-4f, .11061f, .0048501f, 3.2762e-5f, .0041846f, 4.2515e-7f,
+				     15120.f, 15130.f, .0010214f, .16075f, .0077437f, -9.7938e-6f, .0033244f,
+				     -1.335e-5f, 15130.f, 15140.f, .0037351f, .23141f, .0075468f,
+				     -1.8073e-5f, .0038208f, -1.7101e-5f, 15140.f, 15150.f, 6.9279e-4f,
+				     .16527f, .0092564f, -2.4217e-5f, .0059447f, -2.8136e-5f, 15150.f,
+				     15160.f, .0020924f, .19937f, .0067646f, -1.9228e-5f, .0021429f,
+				     -1.4011e-5f, 15160.f, 15170.f, .0029213f, .11019f, .0078105f,
+				     -4.068e-5f, .0061601f, -3.7164e-5f, 15170.f, 15180.f, .0040031f, .2888f,
+				     .0050758f, -1.9158e-5f, .0019869f, -1.728e-5f, 15180.f, 15190.f,
+				     .0024252f, .15747f, .0044234f, -2.0027e-5f, 3.4479e-4f, -1.2338e-5f,
+				     15190.f, 15200.f, .0087795f, .14543f, .0042621f, -2.7308e-5f,
+				     7.3031e-4f, -1.681e-5f, 15200.f, 15210.f, .0095997f, .374f, .0046013f,
+				     -2.8568e-5f, .002061f, -2.4098e-5f, 15210.f, 15220.f, 9.5938e-4f,
+				     .22877f, .0032518f, -1.2364e-5f, .00118f, -1.6396e-5f, 15220.f, 15230.f,
+				     .0089911f, .27602f, .0015486f, -1.7622e-5f, -7.0027e-4f, -1.3639e-5f,
+				     15230.f, 15240.f, .0070384f, .19525f, .0017332f, -1.8418e-5f,
+				     -.0010753f, -1.2514e-5f, 15240.f, 15250.f, .012889f, .20893f,
+				     5.2643e-4f, -8.5726e-6f, -8.0955e-4f, -8.4315e-6f, 15250.f, 15260.f,
+				     .01071f, .10552f, -.0015016f, -6.0962e-6f, -.0038322f, -1.9428e-6f,
+				     15260.f, 15270.f, .011725f, .11142f, -.0024386f, -2.089e-6f, -.0045783f,
+				     1.5311e-6f, 15270.f, 15280.f, .0036695f, .13405f, -.0019794f,
+				     1.4362e-7f, -.0035859f, 2.0003e-6f, 15280.f, 15290.f, .0038912f,
+				     .14992f, -3.0601e-5f, 8.2096e-6f, -1.4088e-4f, -1.393e-6f, 15290.f,
+				     15300.f
-	/*  WATER VAPOR (12740 - 15280 CM-1) */
+    /*  WATER VAPOR (12740 - 15280 CM-1) */
 }	/* wava5 */
 void
@@ -681,329 +681,329 @@
-  static const float acr[2048] = { .037011f, .34865f,
-    .0071795f, -2.429e-5f, .0061217f, -2.5788e-5f, 10180.f, 10190.f,
-    .096531f, .1963f, .0044353f, -2.7769e-5f, .0020496f, -1.902e-5f,
-    10190.f, 10200.f, .11553f, .22356f, .0057418f, -2.861e-5f, .005252f,
-    -3.0274e-5f, 10200.f, 10210.f, .17877f, .25357f, .0036991f, -1.9865e-5f,
-    .0035644f, -1.5681e-5f, 10210.f, 10220.f, .094449f, .35387f, .0021016f,
-    -1.5037e-5f, 5.8316e-4f, -1.1084e-5f, 10220.f, 10230.f, .079869f,
-    .2603f, .0051322f, -2.0923e-5f, .0039204f, -2.2157e-5f, 10230.f,
-    10240.f, .30687f, .32758f, 6.3705e-4f, -9.1396e-6f, 2.5647e-4f,
-    -3.6374e-6f, 10240.f, 10250.f, .15358f, .13982f, -8.3666e-4f,
-    3.3048e-6f, .0027185f, 1.2493e-5f, 10250.f, 10260.f, .38232f, .35543f,
-    -.0010313f, -1.8768e-6f, -.0016001f, 3.8356e-7f, 10260.f, 10270.f,
-    .0562f, .34487f, .0036934f, 7.3751e-6f, .0070064f, -1.2975e-5f, 10270.f,
-    10280.f, .11137f, .21188f, -.0024327f, 1.6553e-5f, -3.0535e-4f,
-    1.9603e-5f, 10280.f, 10290.f, .16704f, .162f, -.0028871f, 9.8108e-6f,
-    -4.298e-4f, 1.7309e-5f, 10290.f, 10300.f, .15496f, .19365f, -.0025906f,
-    1.7434e-5f, -3.5463e-4f, 8.1537e-6f, 10300.f, 10310.f, .050239f,
-    .44504f, .0082014f, 4.7362e-5f, .0097304f, -1.0209e-5f, 10310.f,
-    10320.f, .21509f, .29651f, -.0021764f, 2.0847e-5f, -2.3124e-4f,
-    1.0958e-5f, 10320.f, 10330.f, .15838f, .17695f, -.0019477f, 2.8641e-6f,
-    -.0031011f, 6.2742e-6f, 10330.f, 10340.f, .45807f, .42831f, -4.7039e-5f,
-    1.6616e-5f, .001452f, 6.4036e-6f, 10340.f, 10350.f, .14196f, .4315f,
-    .0032845f, 1.8573e-5f, .0044632f, -3.8921e-6f, 10350.f, 10360.f,
-    .46768f, .4897f, .0030587f, -9.9296e-6f, .0017377f, -1.2227e-5f,
-    10360.f, 10370.f, .49107f, .45881f, .0017676f, 2.3059e-5f, .0037946f,
-    -7.9699e-6f, 10370.f, 10380.f, .40709f, .39513f, .0024501f, 3.4328e-6f,
-    .0033911f, -1.6475e-5f, 10380.f, 10390.f, .53368f, .30449f, .002764f,
-    1.6491e-5f, .0031852f, -7.9335e-6f, 10390.f, 10400.f, .50598f, .38596f,
-    .0011335f, 7.9179e-6f, .0016436f, -4.2442e-6f, 10400.f, 10410.f,
-    .36712f, .58535f, .0035486f, -2.5563e-6f, .0025513f, -1.2028e-5f,
-    10410.f, 10420.f, .98775f, .50104f, .0056199f, -1.6902e-5f, .0043563f,
-    -2.6045e-5f, 10420.f, 10430.f, .76493f, .41145f, .0027287f, -1.2684e-5f,
-    9.6642e-4f, -1.2013e-5f, 10430.f, 10440.f, .4518f, .45681f, .0055394f,
-    -1.8929e-5f, .0049043f, -2.5553e-5f, 10440.f, 10450.f, .93845f, .25977f,
-    .0063165f, -3.3633e-5f, .0030572f, -2.3591e-5f, 10450.f, 10460.f,
-    1.0799f, .52983f, .0049753f, -2.2413e-5f, .0037285f, -1.9018e-5f,
-    10460.f, 10470.f, 1.9954f, .24666f, .0043881f, -2.9035e-5f, .0020409f,
-    -2.1664e-5f, 10470.f, 10480.f, .53954f, .3608f, .0038367f, -2.492e-5f,
-    .0016345f, -2.0659e-5f, 10480.f, 10490.f, 1.9042f, .28357f, .0020331f,
-    -1.9809e-5f, 1.178e-4f, -1.5063e-5f, 10490.f, 10500.f, 1.3639f, .41799f,
-    .0017903f, -1.4939e-5f, 7.7921e-4f, -1.3895e-5f, 10500.f, 10510.f,
-    .27245f, .53566f, .0028306f, -2.1067e-6f, .0041171f, -1.2108e-5f,
-    10510.f, 10520.f, 4.225f, .34405f, -9.2601e-4f, -5.8016e-6f, -.0020236f,
-    -9.379e-7f, 10520.f, 10530.f, .41591f, .38497f, .004158f, 5.6585e-6f,
-    .0031671f, -1.1552e-5f, 10530.f, 10540.f, 2.4868f, .21796f, -.0020342f,
-    2.1116e-6f, -.0020977f, 3.2759e-6f, 10540.f, 10550.f, .9442f, .51349f,
-    .0018825f, 2.2079e-6f, .0015856f, -8.8233e-6f, 10550.f, 10560.f, 2.139f,
-    .25647f, -.0019634f, 7.9808e-6f, -.0024854f, 4.6652e-6f, 10560.f,
-    10570.f, 1.3917f, .33676f, .0035449f, -2.0344e-5f, 3.2271e-4f,
-    -1.2565e-5f, 10570.f, 10580.f, 5.9303f, .30084f, 1.3471e-4f,
-    -5.1658e-6f, -.0018823f, -4.8751e-6f, 10580.f, 10590.f, 1.0087f,
-    .13259f, -.0014095f, -4.7735e-6f, -.0024541f, 2.6832e-6f, 10590.f,
-    10600.f, 4.3983f, .19046f, -.0034725f, 2.4224e-6f, -.0053127f,
-    7.1676e-6f, 10600.f, 10610.f, .96572f, .30982f, -.0027372f, 6.8946e-6f,
-    -.0023672f, 8.3925e-6f, 10610.f, 10620.f, .91323f, .32206f, -.0024872f,
-    3.2962e-6f, -.0026005f, 2.0821e-6f, 10620.f, 10630.f, .64383f, .32142f,
-    -.0040036f, 1.1751e-5f, -.0046913f, 1.096e-5f, 10630.f, 10640.f,
-    .20419f, .32226f, -.0010057f, 3.7593e-7f, -.0012761f, -1.9796e-6f,
-    10640.f, 10650.f, 3.2582f, .41089f, -.0042525f, 1.1056e-5f, -.003553f,
-    1.043e-5f, 10650.f, 10660.f, 4.0011f, .26987f, -.0041265f, 6.8604e-6f,
-    -.0047731f, 8.9525e-6f, 10660.f, 10670.f, 2.3087f, .2861f, -.0029291f,
-    1.5494e-6f, -.0036647f, 3.1219e-6f, 10670.f, 10680.f, 5.0379f, .43636f,
-    -4.8143e-4f, 6.8393e-6f, -.0011602f, 8.769e-7f, 10680.f, 10690.f,
-    3.4572f, .24029f, -3.8723e-4f, -8.7391e-6f, -4.4231e-4f, -7.617e-6f,
-    10690.f, 10700.f, 3.4164f, .31894f, 5.1822e-4f, -9.7127e-6f,
-    -8.7127e-5f, -1.1526e-5f, 10700.f, 10710.f, 1.9975f, .24091f, .0020391f,
-    -1.8108e-5f, 8.1249e-4f, -1.3281e-5f, 10710.f, 10720.f, 1.8993f,
-    .38637f, .0046303f, -2.5016e-5f, .0035053f, -2.2372e-5f, 10720.f,
-    10730.f, 1.958f, .33984f, .0057686f, -3.2398e-5f, .0041169f, -2.863e-5f,
-    10730.f, 10740.f, .56316f, .41883f, .011363f, -4.522e-5f, .0082366f,
-    -3.7842e-5f, 10740.f, 10750.f, .35401f, .69851f, .010496f, -2.1851e-5f,
-    .0066866f, -2.4626e-5f, 10750.f, 10760.f, .19707f, .69982f, .010773f,
-    -9.278e-6f, .0083529f, -1.8664e-5f, 10760.f, 10770.f, .2189f, .61722f,
-    .0026481f, 1.4368e-5f, .0037728f, -1.6702e-7f, 10770.f, 10780.f,
+    static const float acr[2048] = { .037011f, .34865f,
+				     .0071795f, -2.429e-5f, .0061217f, -2.5788e-5f, 10180.f, 10190.f,
+				     .096531f, .1963f, .0044353f, -2.7769e-5f, .0020496f, -1.902e-5f,
+				     10190.f, 10200.f, .11553f, .22356f, .0057418f, -2.861e-5f, .005252f,
+				     -3.0274e-5f, 10200.f, 10210.f, .17877f, .25357f, .0036991f, -1.9865e-5f,
+				     .0035644f, -1.5681e-5f, 10210.f, 10220.f, .094449f, .35387f, .0021016f,
+				     -1.5037e-5f, 5.8316e-4f, -1.1084e-5f, 10220.f, 10230.f, .079869f,
+				     .2603f, .0051322f, -2.0923e-5f, .0039204f, -2.2157e-5f, 10230.f,
+				     10240.f, .30687f, .32758f, 6.3705e-4f, -9.1396e-6f, 2.5647e-4f,
+				     -3.6374e-6f, 10240.f, 10250.f, .15358f, .13982f, -8.3666e-4f,
+				     3.3048e-6f, .0027185f, 1.2493e-5f, 10250.f, 10260.f, .38232f, .35543f,
+				     -.0010313f, -1.8768e-6f, -.0016001f, 3.8356e-7f, 10260.f, 10270.f,
+				     .0562f, .34487f, .0036934f, 7.3751e-6f, .0070064f, -1.2975e-5f, 10270.f,
+				     10280.f, .11137f, .21188f, -.0024327f, 1.6553e-5f, -3.0535e-4f,
+				     1.9603e-5f, 10280.f, 10290.f, .16704f, .162f, -.0028871f, 9.8108e-6f,
+				     -4.298e-4f, 1.7309e-5f, 10290.f, 10300.f, .15496f, .19365f, -.0025906f,
+				     1.7434e-5f, -3.5463e-4f, 8.1537e-6f, 10300.f, 10310.f, .050239f,
+				     .44504f, .0082014f, 4.7362e-5f, .0097304f, -1.0209e-5f, 10310.f,
+				     10320.f, .21509f, .29651f, -.0021764f, 2.0847e-5f, -2.3124e-4f,
+				     1.0958e-5f, 10320.f, 10330.f, .15838f, .17695f, -.0019477f, 2.8641e-6f,
+				     -.0031011f, 6.2742e-6f, 10330.f, 10340.f, .45807f, .42831f, -4.7039e-5f,
+				     1.6616e-5f, .001452f, 6.4036e-6f, 10340.f, 10350.f, .14196f, .4315f,
+				     .0032845f, 1.8573e-5f, .0044632f, -3.8921e-6f, 10350.f, 10360.f,
+				     .46768f, .4897f, .0030587f, -9.9296e-6f, .0017377f, -1.2227e-5f,
+				     10360.f, 10370.f, .49107f, .45881f, .0017676f, 2.3059e-5f, .0037946f,
+				     -7.9699e-6f, 10370.f, 10380.f, .40709f, .39513f, .0024501f, 3.4328e-6f,
+				     .0033911f, -1.6475e-5f, 10380.f, 10390.f, .53368f, .30449f, .002764f,
+				     1.6491e-5f, .0031852f, -7.9335e-6f, 10390.f, 10400.f, .50598f, .38596f,
+				     .0011335f, 7.9179e-6f, .0016436f, -4.2442e-6f, 10400.f, 10410.f,
+				     .36712f, .58535f, .0035486f, -2.5563e-6f, .0025513f, -1.2028e-5f,
+				     10410.f, 10420.f, .98775f, .50104f, .0056199f, -1.6902e-5f, .0043563f,
+				     -2.6045e-5f, 10420.f, 10430.f, .76493f, .41145f, .0027287f, -1.2684e-5f,
+				     9.6642e-4f, -1.2013e-5f, 10430.f, 10440.f, .4518f, .45681f, .0055394f,
+				     -1.8929e-5f, .0049043f, -2.5553e-5f, 10440.f, 10450.f, .93845f, .25977f,
+				     .0063165f, -3.3633e-5f, .0030572f, -2.3591e-5f, 10450.f, 10460.f,
+				     1.0799f, .52983f, .0049753f, -2.2413e-5f, .0037285f, -1.9018e-5f,
+				     10460.f, 10470.f, 1.9954f, .24666f, .0043881f, -2.9035e-5f, .0020409f,
+				     -2.1664e-5f, 10470.f, 10480.f, .53954f, .3608f, .0038367f, -2.492e-5f,
+				     .0016345f, -2.0659e-5f, 10480.f, 10490.f, 1.9042f, .28357f, .0020331f,
+				     -1.9809e-5f, 1.178e-4f, -1.5063e-5f, 10490.f, 10500.f, 1.3639f, .41799f,
+				     .0017903f, -1.4939e-5f, 7.7921e-4f, -1.3895e-5f, 10500.f, 10510.f,
+				     .27245f, .53566f, .0028306f, -2.1067e-6f, .0041171f, -1.2108e-5f,
+				     10510.f, 10520.f, 4.225f, .34405f, -9.2601e-4f, -5.8016e-6f, -.0020236f,
+				     -9.379e-7f, 10520.f, 10530.f, .41591f, .38497f, .004158f, 5.6585e-6f,
+				     .0031671f, -1.1552e-5f, 10530.f, 10540.f, 2.4868f, .21796f, -.0020342f,
+				     2.1116e-6f, -.0020977f, 3.2759e-6f, 10540.f, 10550.f, .9442f, .51349f,
+				     .0018825f, 2.2079e-6f, .0015856f, -8.8233e-6f, 10550.f, 10560.f, 2.139f,
+				     .25647f, -.0019634f, 7.9808e-6f, -.0024854f, 4.6652e-6f, 10560.f,
+				     10570.f, 1.3917f, .33676f, .0035449f, -2.0344e-5f, 3.2271e-4f,
+				     -1.2565e-5f, 10570.f, 10580.f, 5.9303f, .30084f, 1.3471e-4f,
+				     -5.1658e-6f, -.0018823f, -4.8751e-6f, 10580.f, 10590.f, 1.0087f,
+				     .13259f, -.0014095f, -4.7735e-6f, -.0024541f, 2.6832e-6f, 10590.f,
+				     10600.f, 4.3983f, .19046f, -.0034725f, 2.4224e-6f, -.0053127f,
+				     7.1676e-6f, 10600.f, 10610.f, .96572f, .30982f, -.0027372f, 6.8946e-6f,
+				     -.0023672f, 8.3925e-6f, 10610.f, 10620.f, .91323f, .32206f, -.0024872f,
+				     3.2962e-6f, -.0026005f, 2.0821e-6f, 10620.f, 10630.f, .64383f, .32142f,
+				     -.0040036f, 1.1751e-5f, -.0046913f, 1.096e-5f, 10630.f, 10640.f,
+				     .20419f, .32226f, -.0010057f, 3.7593e-7f, -.0012761f, -1.9796e-6f,
+				     10640.f, 10650.f, 3.2582f, .41089f, -.0042525f, 1.1056e-5f, -.003553f,
+				     1.043e-5f, 10650.f, 10660.f, 4.0011f, .26987f, -.0041265f, 6.8604e-6f,
+				     -.0047731f, 8.9525e-6f, 10660.f, 10670.f, 2.3087f, .2861f, -.0029291f,
+				     1.5494e-6f, -.0036647f, 3.1219e-6f, 10670.f, 10680.f, 5.0379f, .43636f,
+				     -4.8143e-4f, 6.8393e-6f, -.0011602f, 8.769e-7f, 10680.f, 10690.f,
+				     3.4572f, .24029f, -3.8723e-4f, -8.7391e-6f, -4.4231e-4f, -7.617e-6f,
+				     10690.f, 10700.f, 3.4164f, .31894f, 5.1822e-4f, -9.7127e-6f,
+				     -8.7127e-5f, -1.1526e-5f, 10700.f, 10710.f, 1.9975f, .24091f, .0020391f,
+				     -1.8108e-5f, 8.1249e-4f, -1.3281e-5f, 10710.f, 10720.f, 1.8993f,
+				     .38637f, .0046303f, -2.5016e-5f, .0035053f, -2.2372e-5f, 10720.f,
+				     10730.f, 1.958f, .33984f, .0057686f, -3.2398e-5f, .0041169f, -2.863e-5f,
+				     10730.f, 10740.f, .56316f, .41883f, .011363f, -4.522e-5f, .0082366f,
+				     -3.7842e-5f, 10740.f, 10750.f, .35401f, .69851f, .010496f, -2.1851e-5f,
+				     .0066866f, -2.4626e-5f, 10750.f, 10760.f, .19707f, .69982f, .010773f,
+				     -9.278e-6f, .0083529f, -1.8664e-5f, 10760.f, 10770.f, .2189f, .61722f,
+				     .0026481f, 1.4368e-5f, .0037728f, -1.6702e-7f, 10770.f, 10780.f,
-    .055267f, .6593f, .007075f, 3.4583e-6f, .0056327f, -1.8713e-5f, 10780.f,
-    10790.f, .082626f, .56771f, .0014488f, 9.0784e-6f, .0015016f,
-    -4.5502e-6f, 10790.f, 10800.f, .070929f, .31037f, 3.4662e-6f,
-    4.3968e-6f, -6.1123e-4f, -1.1496e-7f, 10800.f, 10810.f, .097418f,
-    .44409f, -3.1642e-4f, 5.1491e-6f, -.0010289f, -1.8238e-6f, 10810.f,
-    10820.f, .084947f, .43514f, .0039381f, -1.2895e-6f, .0026186f,
-    -1.3069e-5f, 10820.f, 10830.f, .05826f, .18252f, .0019735f, -6.3696e-6f,
-    -5.8857e-4f, -5.1048e-6f, 10830.f, 10840.f, .11036f, .40791f, .0027504f,
-    5.4669e-6f, .0010814f, -7.3999e-6f, 10840.f, 10850.f, .063822f, .3839f,
-    .0050367f, -2.0231e-5f, .0028937f, -1.8685e-5f, 10850.f, 10860.f,
-    .010028f, .29145f, .0059963f, -2.3315e-5f, .0034252f, -2.032e-5f,
-    10860.f, 10870.f, .12414f, .24481f, .0065529f, -3.7402e-5f, .0035139f,
-    -3.0249e-5f, 10870.f, 10880.f, .14508f, .36269f, -3.4622e-4f,
-    7.2138e-6f, -3.3853e-4f, 7.4773e-7f, 10880.f, 10890.f, .32952f, .51235f,
-    .001156f, -9.9464e-6f, -.0017097f, -6.9684e-6f, 10890.f, 10900.f,
-    .081689f, .43746f, .002472f, -8.5593e-6f, 8.107e-4f, -1.0007e-5f,
-    10900.f, 10910.f, .36297f, .47635f, -7.551e-4f, 3.2155e-6f, -.001416f,
-    1.3385e-6f, 10910.f, 10920.f, .21833f, .56037f, .0015815f, -1.3282e-5f,
-    2.7446e-4f, -1.2751e-5f, 10920.f, 10930.f, .062283f, .46899f, .003716f,
-    9.7049e-7f, .0030288f, -1.3634e-5f, 10930.f, 10940.f, .49012f, .36842f,
-    -8.7423e-4f, -6.7163e-6f, -.0022164f, -2.6838e-6f, 10940.f, 10950.f,
-    .14742f, .42276f, .0021422f, 5.937e-6f, 8.8387e-4f, -6.8671e-6f,
-    10950.f, 10960.f, .281f, .22881f, -.0022496f, -9.4548e-7f, -.0031883f,
-    4.4808e-7f, 10960.f, 10970.f, .22513f, .41493f, .0036269f, -1.6185e-5f,
-    .0017037f, -1.7793e-5f, 10970.f, 10980.f, .21994f, .21688f, -.0036261f,
-    5.7974e-6f, -.0041527f, 8.0739e-6f, 10980.f, 10990.f, .14084f, .33322f,
-    1.3752e-4f, -6.2038e-6f, -.0011146f, -6.0724e-6f, 10990.f, 1.1e4f,
-    .323f, .17636f, -.0013536f, -5.8665e-7f, -.0024854f, -3.0662e-7f,
-    1.1e4f, 11010.f, .4018f, .22575f, -.0022932f, -2.3319e-6f, -.0044015f,
-    2.451e-6f, 11010.f, 11020.f, .40187f, .17827f, -.0028707f, 1.5665e-6f,
-    -.0044357f, 3.1485e-6f, 11020.f, 11030.f, .096411f, .21466f, -.0022778f,
-    4.124e-6f, -.0027585f, 2.0224e-6f, 11030.f, 11040.f, .096343f, .15703f,
-    -.0022356f, 1.5369e-6f, -.0030654f, -3.2505e-7f, 11040.f, 11050.f,
-    .079848f, .17965f, -.0020125f, 9.6504e-6f, -.00326f, 5.3659e-6f,
-    11050.f, 11060.f, .062139f, .10557f, -.0040683f, 9.3909e-6f, -.0047053f,
-    1.0347e-5f, 11060.f, 11070.f, .25071f, .1119f, -.0048932f, 9.8071e-6f,
-    -.0052555f, 9.7232e-6f, 11070.f, 11080.f, .50363f, .18561f, -.0040852f,
-    4.7194e-6f, -.0061085f, 9.9471e-6f, 11080.f, 11090.f, .23621f, .35575f,
-    -6.9998e-4f, -3.8983e-7f, -7.4838e-4f, -6.3021e-6f, 11090.f, 11100.f,
-    .41715f, .20786f, -.0026671f, -8.5957e-7f, -.0044855f, 3.6346e-6f,
-    11100.f, 11110.f, .35497f, .15568f, -2.0655e-4f, -1.0414e-5f,
-    -.0019241f, -7.491e-6f, 11110.f, 11120.f, .36391f, .22115f, 8.0888e-5f,
-    -8.0079e-6f, -7.2043e-4f, -8.8371e-6f, 11120.f, 11130.f, .239f, .19893f,
-    .0017314f, -1.745e-5f, -7.2547e-4f, -1.0781e-5f, 11130.f, 11140.f,
-    .18535f, .23329f, .0044356f, -2.4159e-5f, .002562f, -2.1329e-5f,
-    11140.f, 11150.f, .18058f, .20287f, .0053731f, -2.948e-5f, .0026609f,
-    -2.2876e-5f, 11150.f, 11160.f, .086563f, .18472f, .0071342f,
-    -3.4497e-5f, .0062094f, -3.7103e-5f, 11160.f, 11170.f, .040545f,
-    .27173f, .012595f, -5.3501e-5f, .0098569f, -5.1164e-5f, 11170.f,
-    11180.f, .015934f, .21414f, .021094f, -9.1779e-5f, .018771f,
-    -8.8619e-5f, 11180.f, 11190.f, .032149f, .20819f, .0053736f, 4.7418e-6f,
-    .0028308f, -3.9739e-6f, 11190.f, 11200.f, .0033026f, .1125f, -.0049337f,
-    8.3861e-6f, -.0074414f, 1.2308e-5f, 11200.f, 11210.f, .0069621f,
-    .11936f, .002482f, 1.4188e-5f, .0041457f, -7.6324e-6f, 11210.f, 11220.f,
-    .0018624f, .073437f, .0037334f, 6.4996e-5f, .0021277f, 2.507e-5f,
-    11220.f, 11230.f, .0056133f, .14671f, 5.7744e-4f, -1.0633e-5f,
-    -.0020996f, -6.969e-6f, 11230.f, 11240.f, 5.9301e-4f, .13188f,
-    .0043109f, -2.7217e-5f, .0014102f, -2.1872e-5f, 11240.f, 11250.f,
-    .0062071f, .08021f, .0031276f, -2.2059e-5f, 6.1977e-4f, -1.6464e-5f,
-    11250.f, 11260.f, 7.0445e-4f, .090176f, .006354f, -1.7728e-5f,
-    .0035488f, -2.1566e-5f, 11260.f, 11270.f, .0024343f, .082442f,
-    -1.2318e-4f, -1.1355e-5f, -.0023203f, -8.0507e-6f, 11270.f, 11280.f,
-    .0053124f, .10493f, .002512f, -2.1412e-5f, -2.5472e-4f, -1.6312e-5f,
-    11280.f, 11290.f, .0010156f, .075674f, .0067257f, -3.904e-5f, .0037539f,
-    -3.2659e-5f, 11290.f, 11300.f, 4.5845e-4f, .031771f, .0083901f,
-    -4.5954e-5f, .005633f, -4.0402e-5f, 11300.f, 11310.f, .0013128f, .1362f,
-    .0032287f, -2.4445e-5f, 6.7354e-4f, -2.006e-5f, 11310.f, 11320.f,
-    9.1527e-4f, .043387f, .013028f, -6.4031e-5f, .010684f, -6.015e-5f,
-    11320.f, 11330.f, .0016381f, .11364f, .0082323f, -4.1843e-5f, .0046964f,
-    -3.5054e-5f, 11330.f, 11340.f, 8.2138e-4f, .051673f, .0074756f,
-    -4.1981e-5f, .0051092f, -3.7995e-5f, 11340.f, 11350.f, 8.2766e-4f,
-    .072646f, .0053277f, -3.266e-5f, .0034473f, -3.0783e-5f, 11350.f,
-    11360.f, 2.9086e-4f, .031771f, .0094981f, -5.0386e-5f, .0067409f,
-    -4.4834e-5f, 11360.f, 11370.f, 2.1807e-4f, .058942f, .015709f,
-    -5.9258e-5f, .013592f, -6.3956e-5f, 11370.f, 11380.f, 6.2704e-4f,
-    .12257f, .010699f, -4.9284e-5f, .0095849f, -5.3234e-5f, 11380.f,
-    11390.f, 1.0702e-4f, .028818f, .0079994f, -4.4391e-5f, .0052422f,
-    -3.8839e-5f, 11390.f, 11400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f,
-    11410.f, 2.2042e-4f, .065689f, .016094f, -7.5895e-5f, .013589f,
-    -7.1741e-5f, 11410.f, 11420.f, 8.1809e-5f, .030563f, .019812f,
-    -9.1641e-5f, .017055f, -8.6089e-5f, 11420.f, 11430.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11440.f,
-      11450.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f, 11480.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11490.f,
-    11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11510.f, 11520.f, 6.8748e-6f, .028818f, .014135f, -6.8935e-5f,
-    .011378f, -6.3383e-5f, 11520.f, 11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    11530.f, 11540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11540.f, 11550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11550.f, 11560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11560.f,
-    11570.f, 1.1592e-5f, .037767f, .0031085f, -2.4828e-5f, 3.5131e-4f,
-    -1.9276e-5f, 11570.f, 11580.f, 1.2377e-4f, .091349f, .012838f,
-    -3.6325e-5f, .0084626f, -3.8447e-5f, 11580.f, 11590.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11600.f,
-      11610.f,
-    2.7776e-4f, .099768f, .016197f, -7.1636e-5f, .012877f, -6.2598e-5f,
-    11610.f, 11620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11620.f, 11630.f,
-    6.0387e-4f, .079303f, .011427f, -5.6399e-5f, .0076314f, -4.5247e-5f,
-    11630.f, 11640.f, 8.3575e-5f, .082334f, .015996f, -7.3351e-5f, .013978f,
-    -7.131e-5f, 11640.f, 11650.f, 2.7734e-4f, .028818f, .012698f,
-    -6.3185e-5f, .0099405f, -5.7633e-5f, 11650.f, 11660.f, .0013776f,
-    .1275f, .0089606f, -4.0931e-5f, .006208f, -3.6077e-5f, 11660.f, 11670.f,
-    4.5458e-4f, .05909f, .0073062f, -4.1015e-5f, .0053622f, -3.8549e-5f,
-    11670.f, 11680.f, .0019815f, .15477f, .006225f, -3.2087e-5f, .0049876f,
-    -3.2313e-5f, 11680.f, 11690.f, 9.9572e-4f, .08831f, .0056347f,
-    -2.7093e-5f, .0037058f, -2.8108e-5f, 11690.f, 11700.f, .0025341f,
-    .10399f, .0032192f, -2.1942e-5f, .0010784f, -1.8674e-5f, 11700.f,
-    11710.f, .001691f, .18929f, .0042421f, -2.4597e-5f, .0031654f,
-    -2.3807e-5f, 11710.f, 11720.f, .001706f, .12598f, 6.5013e-4f,
-    -1.3447e-5f, -.0021977f, -8.4803e-6f, 11720.f, 11730.f, .0032703f,
-    .1478f, .0014549f, -1.0754e-5f, 3.5403e-4f, -1.3234e-5f, 11730.f,
-    11740.f, .0055601f, .15726f, -.0020459f, -2.8933e-6f, -.0040613f,
-    2.3816e-6f, 11740.f, 11750.f, .0023988f, .10521f, -8.9604e-5f,
-    -8.9256e-6f, -.0019341f, -4.1252e-6f, 11750.f, 11760.f, .0021014f,
-    .20346f, .001557f, -3.876e-7f, 4.2674e-4f, -7.4882e-6f, 11760.f,
-    11770.f, .0044559f, .17649f, -.0026665f, 2.6782e-6f, -.0043678f,
-    1.1412e-5f, 11770.f, 11780.f, .0024355f, .1438f, -.0030347f, 1.3498e-5f,
-    -.0029099f, 8.3348e-6f, 11780.f, 11790.f, .0012088f, .14652f, .0043364f,
-    -2.3499e-5f, .004136f, -2.5136e-5f, 11790.f, 11800.f, 3.5615e-4f,
-    .076935f, -4.1654e-4f, 1.6868e-5f, -3.6975e-4f, 6.6392e-6f, 11800.f,
-    11810.f, .0033205f, .14642f, -.0022883f, 1.5563e-5f, -.0011424f,
-    6.601e-6f, 11810.f, 11820.f, 9.6482e-4f, .11674f, -.0020293f,
-    3.3475e-5f, .0018153f, 1.8034e-5f, 11820.f, 11830.f, .0025468f, .23891f,
-    -3.7386e-4f, 2.5112e-5f, -7.037e-4f, 1.2657e-5f, 11830.f, 11840.f,
-    .003978f, .19525f, .0017761f, 1.7009e-5f, .0028654f, 9.7695e-7f,
-    11840.f, 11850.f, .009308f, .22287f, -.0028141f, 6.1915e-6f, -.0035846f,
-    9.0001e-6f, 11850.f, 11860.f, .0011913f, .14817f, .0011043f, 4.7279e-5f,
-    .0021704f, 1.6632e-5f, 11860.f, 11870.f, .010095f, .3319f, -3.025e-4f,
-    2.7919e-5f, 4.6706e-4f, 1.3481e-5f, 11870.f, 11880.f, .0094837f,
-    .29542f, .0041573f, -4.5489e-6f, .0046629f, -1.3608e-5f, 11880.f,
-    11890.f, .0057807f, .16128f, .0022948f, 3.093e-5f, .0032856f,
-    7.3247e-6f, 11890.f, 11900.f, .0090317f, .33992f, .0064901f, 1.3104e-5f,
-    .0058385f, -1.237e-5f, 11900.f, 11910.f, .0034946f, .17472f, 9.0274e-4f,
-    9.569e-6f, 7.5517e-4f, 7.6716e-7f, 11910.f, 11920.f, .010712f, .34337f,
-    .0057845f, 3.273e-6f, .0051567f, -1.5291e-5f, 11920.f, 11930.f,
-    .018599f, .48317f, .010589f, -3.4336e-5f, .0073964f, -3.6504e-5f,
-    11930.f, 11940.f, .011137f, .31418f, .0088066f, -1.9115e-5f, .0066643f,
-    -2.5755e-5f, 11940.f, 11950.f, .014277f, .15769f, .010665f, -4.2217e-5f,
-    .0066305f, -3.2258e-5f, 11950.f, 11960.f, .027875f, .26865f, .010692f,
-    -4.8825e-5f, .007738f, -4.3664e-5f, 11960.f, 11970.f, .012682f, .20777f,
-    .010603f, -4.8734e-5f, .0081358f, -4.1884e-5f, 11970.f, 11980.f,
-    .036127f, .20496f, .0077739f, -4.0475e-5f, .0055098f, -3.2025e-5f,
-    11980.f, 11990.f, .026197f, .26047f, .0093353f, -4.7349e-5f, .0069758f,
-    -4.2653e-5f, 11990.f, 1.2e4f, .031642f, .28308f, .0072441f, -3.3775e-5f,
-    .0041744f, -2.7701e-5f, 1.2e4f, 12010.f, .13538f, .163f, .0042895f,
-    -2.9341e-5f, .001443f, -2.3228e-5f, 12010.f, 12020.f, .04616f, .26257f,
-    .0059122f, -3.4545e-5f, .0033253f, -2.959e-5f, 12020.f, 12030.f,
-    .098778f, .16239f, .0019096f, -1.947e-5f, 1.9375e-4f, -1.6507e-5f,
-    12030.f, 12040.f, .04218f, .15687f, .0011607f, -1.5189e-5f, 3.26e-4f,
-    -1.0808e-5f, 12040.f, 12050.f, .081749f, .1447f, .0019087f, -1.8894e-5f,
-    4.6347e-5f, -1.5861e-5f, 12050.f, 12060.f, .14244f, .15544f,
-    -4.8204e-4f, -1.0055e-5f, -.0030791f, -4.5136e-6f, 12060.f, 12070.f,
-    .15967f, .14014f, -.0015241f, -6.1008e-6f, -.0038422f, -1.2202e-6f,
-    12070.f, 12080.f, .14263f, .16924f, -.0025815f, -1.3799e-6f, -.0046065f,
-    2.7252e-6f, 12080.f, 12090.f, .028755f, .09297f, -.0034559f, 3.6475e-6f,
-    -.0038455f, 8.6258e-6f, 12090.f, 12100.f, .13867f, .13244f, -.0035649f,
-    5.23e-6f, -.0053551f, 8.6133e-6f, 12100.f, 12110.f, .022667f, .083805f,
-    -.00172f, -3.4708e-6f, -.0030806f, 3.0367e-6f, 12110.f, 12120.f,
-    .092398f, .11619f, -.0042643f, 1.2112e-5f, -.0033307f, 1.1625e-5f,
-    12120.f, 12130.f, .036116f, .2779f, .0029762f, 1.3854e-6f, .0042021f,
-    -1.2139e-5f, 12130.f, 12140.f, .44373f, .46666f, 3.1523e-4f,
-    -3.0509e-6f, -2.0293e-4f, -7.5095e-6f, 12140.f, 12150.f, .27187f,
-    .27772f, -.0011411f, 1.4254e-6f, -.001681f, -8.1908e-7f, 12150.f,
-    12160.f, .051449f, .10126f, -.0037317f, 6.5728e-6f, -.0032342f,
-    1.2751e-5f, 12160.f, 12170.f, .038984f, .17694f, -.0039312f, 1.3072e-5f,
-    -.0033739f, 1.401e-5f, 12170.f, 12180.f, .0044227f, .11724f, .0062039f,
-    -3.2339e-5f, .0022912f, -2.0596e-5f, 12180.f, 12190.f, .18992f, .14819f,
-    -.0050473f, 8.811e-6f, -.0068829f, 1.2852e-5f, 12190.f, 12200.f,
-    .25583f, .13027f, -.0044286f, 5.7917e-6f, -.0063447f, 9.414e-6f,
-    12200.f, 12210.f, .13625f, .18565f, -.0034046f, 2.2857e-6f, -.0050965f,
-    6.4148e-6f, 12210.f, 12220.f, .29053f, .22511f, -.0027471f, -8.8244e-7f,
-    -.0045852f, 2.3044e-6f, 12220.f, 12230.f, .19038f, .14946f, -6.8588e-4f,
-    -9.3784e-6f, -.0027488f, -5.0351e-6f, 12230.f, 12240.f, .33873f,
-    .28292f, -1.0104e-4f, -1.0239e-5f, -.0013958f, -9.0346e-6f, 12240.f,
-    12250.f, .1325f, .17121f, .0024653f, -1.9723e-5f, 1.8597e-4f,
-    -1.4634e-5f, 12250.f, 12260.f, .12157f, .37106f, .0037908f, -2.2351e-5f,
-    .0010325f, -1.6657e-5f, 12260.f, 12270.f, .07651f, .16258f, .0034104f,
-    -2.3774e-5f, .0018529f, -2.1863e-5f, 12270.f, 12280.f, .07529f, .33562f,
-    .0076059f, -3.4182e-5f, .0052641f, -3.0402e-5f, 12280.f, 12290.f,
-    .060409f, .25407f, .0068386f, -2.9386e-5f, .0061709f, -2.8132e-5f,
-    12290.f, 12300.f, .027161f, .42647f, .0097512f, -3.3363e-5f, .0063871f,
-    -3.1407e-5f, 12300.f, 12310.f, .009111f, .28999f, .010916f, -3.5531e-5f,
-    .0085325f, -3.6715e-5f, 12310.f, 12320.f, .019913f, .33483f, .0088198f,
-    -1.1414e-5f, .0072926f, -2.8077e-5f, 12320.f, 12330.f, .0081899f,
-    .31312f, .014481f, -5.2817e-5f, .010281f, -4.4189e-5f, 12330.f, 12340.f,
-    .0047198f, .32687f, .0079614f, 6.2153e-6f, .0072159f, -1.9264e-5f,
-    12340.f, 12350.f, .011347f, .34063f, .002382f, 2.8934e-5f, .0025122f,
-    2.6528e-6f, 12350.f, 12360.f, .0035162f, .2474f, .0064215f, -4.522e-6f,
-    .0068198f, -2.2326e-5f, 12360.f, 12370.f, .0045582f, .33334f, .0040843f,
-    -6.8827e-6f, .0026935f, -1.6936e-5f, 12370.f, 12380.f, .0025789f,
-    .33203f, .004947f, -1.6065e-5f, .003438f, -2.2968e-5f, 12380.f, 12390.f,
-    .0045336f, .2043f, .0047629f, -2.7839e-5f, .0025633f, -2.4703e-5f,
-    12390.f, 12400.f, .0030244f, .20516f, .0081732f, -4.1804e-5f, .0046359f,
-    -2.9989e-5f, 12400.f, 12410.f, .0041242f, .23106f, .0057501f,
-    -3.1437e-5f, .0034257f, -2.8835e-5f, 12410.f, 12420.f, .010287f,
-    .33673f, .0041222f, -2.574e-5f, .0014121f, -2.0905e-5f, 12420.f,
-    12430.f, .0052103f, .19644f, .0037193f, -2.6341e-5f, 9.394e-4f,
-    -2.0581e-5f, 12430.f, 12440.f, 2.2877e-4f, .12174f, .0092724f,
-    -4.5126e-5f, .0056853f, -3.7747e-5f, 12440.f, 12450.f, .015209f,
-    .45993f, .0011296f, -1.4042e-5f, -.0011241f, -1.1493e-5f, 12450.f,
-    12460.f, .005545f, .1911f, .0015443f, -1.3043e-5f, -3.2861e-4f,
-    -1.1764e-5f, 12460.f, 12470.f, .011275f, .1922f, 7.547e-5f, -1.0276e-5f,
-    -.0020095f, -7.6051e-6f, 12470.f, 12480.f, .014331f, .19322f,
-    -.0010929f, -7.1557e-6f, -.0030976f, -4.5871e-6f, 12480.f, 12490.f,
-    .013106f, .20676f, -.0021472f, -1.689e-6f, -.00333f, -4.7675e-7f,
-    12490.f, 12500.f, .0031859f, .26518f, .0018883f, -3.7481e-6f,
-    4.5064e-5f, -1.1501e-5f, 12500.f, 12510.f, .0066833f, .21228f,
-    -.0021409f, 4.8505e-6f, -.0028895f, 4.0738e-6f, 12510.f, 12520.f,
-    .011966f, .28263f, -.0013922f, 6.3802e-6f, -7.3809e-4f, -1.1743e-6f,
-    12520.f, 12530.f, .0040664f, .24183f, .0035636f, -2.8875e-6f, .0022372f,
-    -1.6411e-5f, 12530.f, 12540.f, .014346f, .3851f, 2.0035e-4f, 3.7739e-6f,
-    -6.1012e-5f, -7.988e-6f, 12540.f, 12550.f, .031841f, .37389f,
-    -.0014467f, -2.5515e-6f, -.0036219f, -9.456e-7f, 12550.f, 12560.f,
-    .014117f, .15375f, -.0027582f, 1.5847e-6f, -.0042341f, 5.2506e-6f,
-    12560.f, 12570.f, .0069458f, .17261f, -.0018858f, -1.3771e-6f,
-    -.0038705f, 1.8317e-6f, 12570.f, 12580.f, .0034163f, .16476f,
-    -.0038874f, 8.9594e-6f, -.004751f, 6.5193e-6f, 12580.f, 12590.f,
-    .0010085f, .13402f, 8.9094e-4f, -6.018e-6f, -6.4581e-6f, -9.4409e-6f,
-    12590.f, 12600.f, .017942f, .20327f, -.0039862f, 7.5053e-6f, -.0052785f,
-    7.3576e-6f, 12600.f, 12610.f, .0080749f, .061138f, -.0049341f,
-    7.5781e-6f, -.0072374f, 1.1499e-5f, 12610.f, 12620.f, .022511f, .21226f,
-    -.0034799f, 3.196e-6f, -.0050773f, 6.2716e-6f, 12620.f, 12630.f,
-    .0091364f, .16111f, -.0029375f, 2.6306e-7f, -.0049473f, 4.3965e-6f,
-    12630.f, 12640.f, .014688f, .1553f, -.0020029f, -2.3192e-6f, -.0029945f,
-    -2.1575e-6f, 12640.f, 12650.f, .016309f, .20204f, 1.6988e-6f,
-    -1.109e-5f, -.0014702f, -9.9629e-6f, 12650.f, 12660.f, .028046f,
-    .24162f, 2.1643e-4f, -1.1209e-5f, -.0017491f, -8.904e-6f, 12660.f,
-    12670.f, .011289f, .29319f, .0034128f, -2.3021e-5f, .0010846f,
-    -1.8419e-5f, 12670.f, 12680.f, .0049531f, .14498f, .0053073f,
-    -2.8791e-5f, .0032927f, -2.5157e-5f, 12680.f, 12690.f, .0072485f,
-    .17855f, .0056992f, -3.2465e-5f, .0041153f, -3.2129e-5f, 12690.f,
-    12700.f, .0061604f, .2478f, .0073217f, -3.1129e-5f, .0058029f,
-    -3.2007e-5f, 12700.f, 12710.f, .0013393f, .12405f, .012672f,
-    -4.8102e-5f, .0088276f, -3.9342e-5f, 12710.f, 12720.f, .0010615f,
-    .14687f, .012203f, -5.0558e-5f, .01058f, -5.4423e-5f, 12720.f, 12730.f,
-    4.7236e-4f, .080989f, .0036212f, 3.4855e-5f, .0023529f, 7.9526e-6f,
-    12730.f, 12740.f
+				     .055267f, .6593f, .007075f, 3.4583e-6f, .0056327f, -1.8713e-5f, 10780.f,
+				     10790.f, .082626f, .56771f, .0014488f, 9.0784e-6f, .0015016f,
+				     -4.5502e-6f, 10790.f, 10800.f, .070929f, .31037f, 3.4662e-6f,
+				     4.3968e-6f, -6.1123e-4f, -1.1496e-7f, 10800.f, 10810.f, .097418f,
+				     .44409f, -3.1642e-4f, 5.1491e-6f, -.0010289f, -1.8238e-6f, 10810.f,
+				     10820.f, .084947f, .43514f, .0039381f, -1.2895e-6f, .0026186f,
+				     -1.3069e-5f, 10820.f, 10830.f, .05826f, .18252f, .0019735f, -6.3696e-6f,
+				     -5.8857e-4f, -5.1048e-6f, 10830.f, 10840.f, .11036f, .40791f, .0027504f,
+				     5.4669e-6f, .0010814f, -7.3999e-6f, 10840.f, 10850.f, .063822f, .3839f,
+				     .0050367f, -2.0231e-5f, .0028937f, -1.8685e-5f, 10850.f, 10860.f,
+				     .010028f, .29145f, .0059963f, -2.3315e-5f, .0034252f, -2.032e-5f,
+				     10860.f, 10870.f, .12414f, .24481f, .0065529f, -3.7402e-5f, .0035139f,
+				     -3.0249e-5f, 10870.f, 10880.f, .14508f, .36269f, -3.4622e-4f,
+				     7.2138e-6f, -3.3853e-4f, 7.4773e-7f, 10880.f, 10890.f, .32952f, .51235f,
+				     .001156f, -9.9464e-6f, -.0017097f, -6.9684e-6f, 10890.f, 10900.f,
+				     .081689f, .43746f, .002472f, -8.5593e-6f, 8.107e-4f, -1.0007e-5f,
+				     10900.f, 10910.f, .36297f, .47635f, -7.551e-4f, 3.2155e-6f, -.001416f,
+				     1.3385e-6f, 10910.f, 10920.f, .21833f, .56037f, .0015815f, -1.3282e-5f,
+				     2.7446e-4f, -1.2751e-5f, 10920.f, 10930.f, .062283f, .46899f, .003716f,
+				     9.7049e-7f, .0030288f, -1.3634e-5f, 10930.f, 10940.f, .49012f, .36842f,
+				     -8.7423e-4f, -6.7163e-6f, -.0022164f, -2.6838e-6f, 10940.f, 10950.f,
+				     .14742f, .42276f, .0021422f, 5.937e-6f, 8.8387e-4f, -6.8671e-6f,
+				     10950.f, 10960.f, .281f, .22881f, -.0022496f, -9.4548e-7f, -.0031883f,
+				     4.4808e-7f, 10960.f, 10970.f, .22513f, .41493f, .0036269f, -1.6185e-5f,
+				     .0017037f, -1.7793e-5f, 10970.f, 10980.f, .21994f, .21688f, -.0036261f,
+				     5.7974e-6f, -.0041527f, 8.0739e-6f, 10980.f, 10990.f, .14084f, .33322f,
+				     1.3752e-4f, -6.2038e-6f, -.0011146f, -6.0724e-6f, 10990.f, 1.1e4f,
+				     .323f, .17636f, -.0013536f, -5.8665e-7f, -.0024854f, -3.0662e-7f,
+				     1.1e4f, 11010.f, .4018f, .22575f, -.0022932f, -2.3319e-6f, -.0044015f,
+				     2.451e-6f, 11010.f, 11020.f, .40187f, .17827f, -.0028707f, 1.5665e-6f,
+				     -.0044357f, 3.1485e-6f, 11020.f, 11030.f, .096411f, .21466f, -.0022778f,
+				     4.124e-6f, -.0027585f, 2.0224e-6f, 11030.f, 11040.f, .096343f, .15703f,
+				     -.0022356f, 1.5369e-6f, -.0030654f, -3.2505e-7f, 11040.f, 11050.f,
+				     .079848f, .17965f, -.0020125f, 9.6504e-6f, -.00326f, 5.3659e-6f,
+				     11050.f, 11060.f, .062139f, .10557f, -.0040683f, 9.3909e-6f, -.0047053f,
+				     1.0347e-5f, 11060.f, 11070.f, .25071f, .1119f, -.0048932f, 9.8071e-6f,
+				     -.0052555f, 9.7232e-6f, 11070.f, 11080.f, .50363f, .18561f, -.0040852f,
+				     4.7194e-6f, -.0061085f, 9.9471e-6f, 11080.f, 11090.f, .23621f, .35575f,
+				     -6.9998e-4f, -3.8983e-7f, -7.4838e-4f, -6.3021e-6f, 11090.f, 11100.f,
+				     .41715f, .20786f, -.0026671f, -8.5957e-7f, -.0044855f, 3.6346e-6f,
+				     11100.f, 11110.f, .35497f, .15568f, -2.0655e-4f, -1.0414e-5f,
+				     -.0019241f, -7.491e-6f, 11110.f, 11120.f, .36391f, .22115f, 8.0888e-5f,
+				     -8.0079e-6f, -7.2043e-4f, -8.8371e-6f, 11120.f, 11130.f, .239f, .19893f,
+				     .0017314f, -1.745e-5f, -7.2547e-4f, -1.0781e-5f, 11130.f, 11140.f,
+				     .18535f, .23329f, .0044356f, -2.4159e-5f, .002562f, -2.1329e-5f,
+				     11140.f, 11150.f, .18058f, .20287f, .0053731f, -2.948e-5f, .0026609f,
+				     -2.2876e-5f, 11150.f, 11160.f, .086563f, .18472f, .0071342f,
+				     -3.4497e-5f, .0062094f, -3.7103e-5f, 11160.f, 11170.f, .040545f,
+				     .27173f, .012595f, -5.3501e-5f, .0098569f, -5.1164e-5f, 11170.f,
+				     11180.f, .015934f, .21414f, .021094f, -9.1779e-5f, .018771f,
+				     -8.8619e-5f, 11180.f, 11190.f, .032149f, .20819f, .0053736f, 4.7418e-6f,
+				     .0028308f, -3.9739e-6f, 11190.f, 11200.f, .0033026f, .1125f, -.0049337f,
+				     8.3861e-6f, -.0074414f, 1.2308e-5f, 11200.f, 11210.f, .0069621f,
+				     .11936f, .002482f, 1.4188e-5f, .0041457f, -7.6324e-6f, 11210.f, 11220.f,
+				     .0018624f, .073437f, .0037334f, 6.4996e-5f, .0021277f, 2.507e-5f,
+				     11220.f, 11230.f, .0056133f, .14671f, 5.7744e-4f, -1.0633e-5f,
+				     -.0020996f, -6.969e-6f, 11230.f, 11240.f, 5.9301e-4f, .13188f,
+				     .0043109f, -2.7217e-5f, .0014102f, -2.1872e-5f, 11240.f, 11250.f,
+				     .0062071f, .08021f, .0031276f, -2.2059e-5f, 6.1977e-4f, -1.6464e-5f,
+				     11250.f, 11260.f, 7.0445e-4f, .090176f, .006354f, -1.7728e-5f,
+				     .0035488f, -2.1566e-5f, 11260.f, 11270.f, .0024343f, .082442f,
+				     -1.2318e-4f, -1.1355e-5f, -.0023203f, -8.0507e-6f, 11270.f, 11280.f,
+				     .0053124f, .10493f, .002512f, -2.1412e-5f, -2.5472e-4f, -1.6312e-5f,
+				     11280.f, 11290.f, .0010156f, .075674f, .0067257f, -3.904e-5f, .0037539f,
+				     -3.2659e-5f, 11290.f, 11300.f, 4.5845e-4f, .031771f, .0083901f,
+				     -4.5954e-5f, .005633f, -4.0402e-5f, 11300.f, 11310.f, .0013128f, .1362f,
+				     .0032287f, -2.4445e-5f, 6.7354e-4f, -2.006e-5f, 11310.f, 11320.f,
+				     9.1527e-4f, .043387f, .013028f, -6.4031e-5f, .010684f, -6.015e-5f,
+				     11320.f, 11330.f, .0016381f, .11364f, .0082323f, -4.1843e-5f, .0046964f,
+				     -3.5054e-5f, 11330.f, 11340.f, 8.2138e-4f, .051673f, .0074756f,
+				     -4.1981e-5f, .0051092f, -3.7995e-5f, 11340.f, 11350.f, 8.2766e-4f,
+				     .072646f, .0053277f, -3.266e-5f, .0034473f, -3.0783e-5f, 11350.f,
+				     11360.f, 2.9086e-4f, .031771f, .0094981f, -5.0386e-5f, .0067409f,
+				     -4.4834e-5f, 11360.f, 11370.f, 2.1807e-4f, .058942f, .015709f,
+				     -5.9258e-5f, .013592f, -6.3956e-5f, 11370.f, 11380.f, 6.2704e-4f,
+				     .12257f, .010699f, -4.9284e-5f, .0095849f, -5.3234e-5f, 11380.f,
+				     11390.f, 1.0702e-4f, .028818f, .0079994f, -4.4391e-5f, .0052422f,
+				     -3.8839e-5f, 11390.f, 11400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f,
+				     11410.f, 2.2042e-4f, .065689f, .016094f, -7.5895e-5f, .013589f,
+				     -7.1741e-5f, 11410.f, 11420.f, 8.1809e-5f, .030563f, .019812f,
+				     -9.1641e-5f, .017055f, -8.6089e-5f, 11420.f, 11430.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11440.f,
+				     11450.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f, 11480.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11490.f,
+				     11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11510.f, 11520.f, 6.8748e-6f, .028818f, .014135f, -6.8935e-5f,
+				     .011378f, -6.3383e-5f, 11520.f, 11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11530.f, 11540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11540.f, 11550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11550.f, 11560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11560.f,
+				     11570.f, 1.1592e-5f, .037767f, .0031085f, -2.4828e-5f, 3.5131e-4f,
+				     -1.9276e-5f, 11570.f, 11580.f, 1.2377e-4f, .091349f, .012838f,
+				     -3.6325e-5f, .0084626f, -3.8447e-5f, 11580.f, 11590.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11600.f,
+				     11610.f,
+				     2.7776e-4f, .099768f, .016197f, -7.1636e-5f, .012877f, -6.2598e-5f,
+				     11610.f, 11620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11620.f, 11630.f,
+				     6.0387e-4f, .079303f, .011427f, -5.6399e-5f, .0076314f, -4.5247e-5f,
+				     11630.f, 11640.f, 8.3575e-5f, .082334f, .015996f, -7.3351e-5f, .013978f,
+				     -7.131e-5f, 11640.f, 11650.f, 2.7734e-4f, .028818f, .012698f,
+				     -6.3185e-5f, .0099405f, -5.7633e-5f, 11650.f, 11660.f, .0013776f,
+				     .1275f, .0089606f, -4.0931e-5f, .006208f, -3.6077e-5f, 11660.f, 11670.f,
+				     4.5458e-4f, .05909f, .0073062f, -4.1015e-5f, .0053622f, -3.8549e-5f,
+				     11670.f, 11680.f, .0019815f, .15477f, .006225f, -3.2087e-5f, .0049876f,
+				     -3.2313e-5f, 11680.f, 11690.f, 9.9572e-4f, .08831f, .0056347f,
+				     -2.7093e-5f, .0037058f, -2.8108e-5f, 11690.f, 11700.f, .0025341f,
+				     .10399f, .0032192f, -2.1942e-5f, .0010784f, -1.8674e-5f, 11700.f,
+				     11710.f, .001691f, .18929f, .0042421f, -2.4597e-5f, .0031654f,
+				     -2.3807e-5f, 11710.f, 11720.f, .001706f, .12598f, 6.5013e-4f,
+				     -1.3447e-5f, -.0021977f, -8.4803e-6f, 11720.f, 11730.f, .0032703f,
+				     .1478f, .0014549f, -1.0754e-5f, 3.5403e-4f, -1.3234e-5f, 11730.f,
+				     11740.f, .0055601f, .15726f, -.0020459f, -2.8933e-6f, -.0040613f,
+				     2.3816e-6f, 11740.f, 11750.f, .0023988f, .10521f, -8.9604e-5f,
+				     -8.9256e-6f, -.0019341f, -4.1252e-6f, 11750.f, 11760.f, .0021014f,
+				     .20346f, .001557f, -3.876e-7f, 4.2674e-4f, -7.4882e-6f, 11760.f,
+				     11770.f, .0044559f, .17649f, -.0026665f, 2.6782e-6f, -.0043678f,
+				     1.1412e-5f, 11770.f, 11780.f, .0024355f, .1438f, -.0030347f, 1.3498e-5f,
+				     -.0029099f, 8.3348e-6f, 11780.f, 11790.f, .0012088f, .14652f, .0043364f,
+				     -2.3499e-5f, .004136f, -2.5136e-5f, 11790.f, 11800.f, 3.5615e-4f,
+				     .076935f, -4.1654e-4f, 1.6868e-5f, -3.6975e-4f, 6.6392e-6f, 11800.f,
+				     11810.f, .0033205f, .14642f, -.0022883f, 1.5563e-5f, -.0011424f,
+				     6.601e-6f, 11810.f, 11820.f, 9.6482e-4f, .11674f, -.0020293f,
+				     3.3475e-5f, .0018153f, 1.8034e-5f, 11820.f, 11830.f, .0025468f, .23891f,
+				     -3.7386e-4f, 2.5112e-5f, -7.037e-4f, 1.2657e-5f, 11830.f, 11840.f,
+				     .003978f, .19525f, .0017761f, 1.7009e-5f, .0028654f, 9.7695e-7f,
+				     11840.f, 11850.f, .009308f, .22287f, -.0028141f, 6.1915e-6f, -.0035846f,
+				     9.0001e-6f, 11850.f, 11860.f, .0011913f, .14817f, .0011043f, 4.7279e-5f,
+				     .0021704f, 1.6632e-5f, 11860.f, 11870.f, .010095f, .3319f, -3.025e-4f,
+				     2.7919e-5f, 4.6706e-4f, 1.3481e-5f, 11870.f, 11880.f, .0094837f,
+				     .29542f, .0041573f, -4.5489e-6f, .0046629f, -1.3608e-5f, 11880.f,
+				     11890.f, .0057807f, .16128f, .0022948f, 3.093e-5f, .0032856f,
+				     7.3247e-6f, 11890.f, 11900.f, .0090317f, .33992f, .0064901f, 1.3104e-5f,
+				     .0058385f, -1.237e-5f, 11900.f, 11910.f, .0034946f, .17472f, 9.0274e-4f,
+				     9.569e-6f, 7.5517e-4f, 7.6716e-7f, 11910.f, 11920.f, .010712f, .34337f,
+				     .0057845f, 3.273e-6f, .0051567f, -1.5291e-5f, 11920.f, 11930.f,
+				     .018599f, .48317f, .010589f, -3.4336e-5f, .0073964f, -3.6504e-5f,
+				     11930.f, 11940.f, .011137f, .31418f, .0088066f, -1.9115e-5f, .0066643f,
+				     -2.5755e-5f, 11940.f, 11950.f, .014277f, .15769f, .010665f, -4.2217e-5f,
+				     .0066305f, -3.2258e-5f, 11950.f, 11960.f, .027875f, .26865f, .010692f,
+				     -4.8825e-5f, .007738f, -4.3664e-5f, 11960.f, 11970.f, .012682f, .20777f,
+				     .010603f, -4.8734e-5f, .0081358f, -4.1884e-5f, 11970.f, 11980.f,
+				     .036127f, .20496f, .0077739f, -4.0475e-5f, .0055098f, -3.2025e-5f,
+				     11980.f, 11990.f, .026197f, .26047f, .0093353f, -4.7349e-5f, .0069758f,
+				     -4.2653e-5f, 11990.f, 1.2e4f, .031642f, .28308f, .0072441f, -3.3775e-5f,
+				     .0041744f, -2.7701e-5f, 1.2e4f, 12010.f, .13538f, .163f, .0042895f,
+				     -2.9341e-5f, .001443f, -2.3228e-5f, 12010.f, 12020.f, .04616f, .26257f,
+				     .0059122f, -3.4545e-5f, .0033253f, -2.959e-5f, 12020.f, 12030.f,
+				     .098778f, .16239f, .0019096f, -1.947e-5f, 1.9375e-4f, -1.6507e-5f,
+				     12030.f, 12040.f, .04218f, .15687f, .0011607f, -1.5189e-5f, 3.26e-4f,
+				     -1.0808e-5f, 12040.f, 12050.f, .081749f, .1447f, .0019087f, -1.8894e-5f,
+				     4.6347e-5f, -1.5861e-5f, 12050.f, 12060.f, .14244f, .15544f,
+				     -4.8204e-4f, -1.0055e-5f, -.0030791f, -4.5136e-6f, 12060.f, 12070.f,
+				     .15967f, .14014f, -.0015241f, -6.1008e-6f, -.0038422f, -1.2202e-6f,
+				     12070.f, 12080.f, .14263f, .16924f, -.0025815f, -1.3799e-6f, -.0046065f,
+				     2.7252e-6f, 12080.f, 12090.f, .028755f, .09297f, -.0034559f, 3.6475e-6f,
+				     -.0038455f, 8.6258e-6f, 12090.f, 12100.f, .13867f, .13244f, -.0035649f,
+				     5.23e-6f, -.0053551f, 8.6133e-6f, 12100.f, 12110.f, .022667f, .083805f,
+				     -.00172f, -3.4708e-6f, -.0030806f, 3.0367e-6f, 12110.f, 12120.f,
+				     .092398f, .11619f, -.0042643f, 1.2112e-5f, -.0033307f, 1.1625e-5f,
+				     12120.f, 12130.f, .036116f, .2779f, .0029762f, 1.3854e-6f, .0042021f,
+				     -1.2139e-5f, 12130.f, 12140.f, .44373f, .46666f, 3.1523e-4f,
+				     -3.0509e-6f, -2.0293e-4f, -7.5095e-6f, 12140.f, 12150.f, .27187f,
+				     .27772f, -.0011411f, 1.4254e-6f, -.001681f, -8.1908e-7f, 12150.f,
+				     12160.f, .051449f, .10126f, -.0037317f, 6.5728e-6f, -.0032342f,
+				     1.2751e-5f, 12160.f, 12170.f, .038984f, .17694f, -.0039312f, 1.3072e-5f,
+				     -.0033739f, 1.401e-5f, 12170.f, 12180.f, .0044227f, .11724f, .0062039f,
+				     -3.2339e-5f, .0022912f, -2.0596e-5f, 12180.f, 12190.f, .18992f, .14819f,
+				     -.0050473f, 8.811e-6f, -.0068829f, 1.2852e-5f, 12190.f, 12200.f,
+				     .25583f, .13027f, -.0044286f, 5.7917e-6f, -.0063447f, 9.414e-6f,
+				     12200.f, 12210.f, .13625f, .18565f, -.0034046f, 2.2857e-6f, -.0050965f,
+				     6.4148e-6f, 12210.f, 12220.f, .29053f, .22511f, -.0027471f, -8.8244e-7f,
+				     -.0045852f, 2.3044e-6f, 12220.f, 12230.f, .19038f, .14946f, -6.8588e-4f,
+				     -9.3784e-6f, -.0027488f, -5.0351e-6f, 12230.f, 12240.f, .33873f,
+				     .28292f, -1.0104e-4f, -1.0239e-5f, -.0013958f, -9.0346e-6f, 12240.f,
+				     12250.f, .1325f, .17121f, .0024653f, -1.9723e-5f, 1.8597e-4f,
+				     -1.4634e-5f, 12250.f, 12260.f, .12157f, .37106f, .0037908f, -2.2351e-5f,
+				     .0010325f, -1.6657e-5f, 12260.f, 12270.f, .07651f, .16258f, .0034104f,
+				     -2.3774e-5f, .0018529f, -2.1863e-5f, 12270.f, 12280.f, .07529f, .33562f,
+				     .0076059f, -3.4182e-5f, .0052641f, -3.0402e-5f, 12280.f, 12290.f,
+				     .060409f, .25407f, .0068386f, -2.9386e-5f, .0061709f, -2.8132e-5f,
+				     12290.f, 12300.f, .027161f, .42647f, .0097512f, -3.3363e-5f, .0063871f,
+				     -3.1407e-5f, 12300.f, 12310.f, .009111f, .28999f, .010916f, -3.5531e-5f,
+				     .0085325f, -3.6715e-5f, 12310.f, 12320.f, .019913f, .33483f, .0088198f,
+				     -1.1414e-5f, .0072926f, -2.8077e-5f, 12320.f, 12330.f, .0081899f,
+				     .31312f, .014481f, -5.2817e-5f, .010281f, -4.4189e-5f, 12330.f, 12340.f,
+				     .0047198f, .32687f, .0079614f, 6.2153e-6f, .0072159f, -1.9264e-5f,
+				     12340.f, 12350.f, .011347f, .34063f, .002382f, 2.8934e-5f, .0025122f,
+				     2.6528e-6f, 12350.f, 12360.f, .0035162f, .2474f, .0064215f, -4.522e-6f,
+				     .0068198f, -2.2326e-5f, 12360.f, 12370.f, .0045582f, .33334f, .0040843f,
+				     -6.8827e-6f, .0026935f, -1.6936e-5f, 12370.f, 12380.f, .0025789f,
+				     .33203f, .004947f, -1.6065e-5f, .003438f, -2.2968e-5f, 12380.f, 12390.f,
+				     .0045336f, .2043f, .0047629f, -2.7839e-5f, .0025633f, -2.4703e-5f,
+				     12390.f, 12400.f, .0030244f, .20516f, .0081732f, -4.1804e-5f, .0046359f,
+				     -2.9989e-5f, 12400.f, 12410.f, .0041242f, .23106f, .0057501f,
+				     -3.1437e-5f, .0034257f, -2.8835e-5f, 12410.f, 12420.f, .010287f,
+				     .33673f, .0041222f, -2.574e-5f, .0014121f, -2.0905e-5f, 12420.f,
+				     12430.f, .0052103f, .19644f, .0037193f, -2.6341e-5f, 9.394e-4f,
+				     -2.0581e-5f, 12430.f, 12440.f, 2.2877e-4f, .12174f, .0092724f,
+				     -4.5126e-5f, .0056853f, -3.7747e-5f, 12440.f, 12450.f, .015209f,
+				     .45993f, .0011296f, -1.4042e-5f, -.0011241f, -1.1493e-5f, 12450.f,
+				     12460.f, .005545f, .1911f, .0015443f, -1.3043e-5f, -3.2861e-4f,
+				     -1.1764e-5f, 12460.f, 12470.f, .011275f, .1922f, 7.547e-5f, -1.0276e-5f,
+				     -.0020095f, -7.6051e-6f, 12470.f, 12480.f, .014331f, .19322f,
+				     -.0010929f, -7.1557e-6f, -.0030976f, -4.5871e-6f, 12480.f, 12490.f,
+				     .013106f, .20676f, -.0021472f, -1.689e-6f, -.00333f, -4.7675e-7f,
+				     12490.f, 12500.f, .0031859f, .26518f, .0018883f, -3.7481e-6f,
+				     4.5064e-5f, -1.1501e-5f, 12500.f, 12510.f, .0066833f, .21228f,
+				     -.0021409f, 4.8505e-6f, -.0028895f, 4.0738e-6f, 12510.f, 12520.f,
+				     .011966f, .28263f, -.0013922f, 6.3802e-6f, -7.3809e-4f, -1.1743e-6f,
+				     12520.f, 12530.f, .0040664f, .24183f, .0035636f, -2.8875e-6f, .0022372f,
+				     -1.6411e-5f, 12530.f, 12540.f, .014346f, .3851f, 2.0035e-4f, 3.7739e-6f,
+				     -6.1012e-5f, -7.988e-6f, 12540.f, 12550.f, .031841f, .37389f,
+				     -.0014467f, -2.5515e-6f, -.0036219f, -9.456e-7f, 12550.f, 12560.f,
+				     .014117f, .15375f, -.0027582f, 1.5847e-6f, -.0042341f, 5.2506e-6f,
+				     12560.f, 12570.f, .0069458f, .17261f, -.0018858f, -1.3771e-6f,
+				     -.0038705f, 1.8317e-6f, 12570.f, 12580.f, .0034163f, .16476f,
+				     -.0038874f, 8.9594e-6f, -.004751f, 6.5193e-6f, 12580.f, 12590.f,
+				     .0010085f, .13402f, 8.9094e-4f, -6.018e-6f, -6.4581e-6f, -9.4409e-6f,
+				     12590.f, 12600.f, .017942f, .20327f, -.0039862f, 7.5053e-6f, -.0052785f,
+				     7.3576e-6f, 12600.f, 12610.f, .0080749f, .061138f, -.0049341f,
+				     7.5781e-6f, -.0072374f, 1.1499e-5f, 12610.f, 12620.f, .022511f, .21226f,
+				     -.0034799f, 3.196e-6f, -.0050773f, 6.2716e-6f, 12620.f, 12630.f,
+				     .0091364f, .16111f, -.0029375f, 2.6306e-7f, -.0049473f, 4.3965e-6f,
+				     12630.f, 12640.f, .014688f, .1553f, -.0020029f, -2.3192e-6f, -.0029945f,
+				     -2.1575e-6f, 12640.f, 12650.f, .016309f, .20204f, 1.6988e-6f,
+				     -1.109e-5f, -.0014702f, -9.9629e-6f, 12650.f, 12660.f, .028046f,
+				     .24162f, 2.1643e-4f, -1.1209e-5f, -.0017491f, -8.904e-6f, 12660.f,
+				     12670.f, .011289f, .29319f, .0034128f, -2.3021e-5f, .0010846f,
+				     -1.8419e-5f, 12670.f, 12680.f, .0049531f, .14498f, .0053073f,
+				     -2.8791e-5f, .0032927f, -2.5157e-5f, 12680.f, 12690.f, .0072485f,
+				     .17855f, .0056992f, -3.2465e-5f, .0041153f, -3.2129e-5f, 12690.f,
+				     12700.f, .0061604f, .2478f, .0073217f, -3.1129e-5f, .0058029f,
+				     -3.2007e-5f, 12700.f, 12710.f, .0013393f, .12405f, .012672f,
+				     -4.8102e-5f, .0088276f, -3.9342e-5f, 12710.f, 12720.f, .0010615f,
+				     .14687f, .012203f, -5.0558e-5f, .01058f, -5.4423e-5f, 12720.f, 12730.f,
+				     4.7236e-4f, .080989f, .0036212f, 3.4855e-5f, .0023529f, 7.9526e-6f,
+				     12730.f, 12740.f
-	/* WATER VAPOR (10180 - 12720 CM-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* WATER VAPOR (10180 - 12720 CM-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* wava4 */
 void
@@ -1011,313 +1011,313 @@
-  static const float acr[2048] = { .092641f, .26739f,
-    .0074828f, -3.6295e-5f, .0065918f, -3.6255e-5f, 7620.f, 7630.f, .24311f,
-    .19859f, .0029686f, -1.983e-5f, .0023399f, -1.6807e-5f, 7630.f, 7640.f,
-    .12025f, .11463f, .005982f, -3.2695e-5f, .00555f, -2.817e-5f, 7640.f,
-    7650.f, .13658f, .26836f, .0072502f, -2.1381e-5f, .0073061f,
-    -3.0405e-5f, 7650.f, 7660.f, .10472f, .25523f, .0079597f, -3.2676e-5f,
-    .0058214f, -3.1308e-5f, 7660.f, 7670.f, .099714f, .25003f, .012338f,
-    -5.6896e-5f, .010569f, -5.1734e-5f, 7670.f, 7680.f, .058366f, .22207f,
-    .011694f, -5.1427e-5f, .011909f, -4.905e-5f, 7680.f, 7690.f, .035387f,
-    .17329f, .016862f, -7.5246e-5f, .013502f, -6.3311e-5f, 7690.f, 7700.f,
-    .036568f, .21034f, .0081374f, -2.4226e-5f, .0063861f, -2.5253e-5f,
-    7700.f, 7710.f, .027597f, .33962f, .017925f, -6.8929e-5f, .015283f,
-    -6.6807e-5f, 7710.f, 7720.f, .010316f, .41286f, .019917f, -4.8503e-5f,
-    .017007f, -5.8717e-5f, 7720.f, 7730.f, .0081553f, .2556f, .021997f,
-    -8.8437e-5f, .020546f, -8.5162e-5f, 7730.f, 7740.f, .015975f, .21315f,
-    .0071481f, 3.1142e-6f, .010474f, -1.3461e-5f, 7740.f, 7750.f, .013868f,
-    .24329f, .0094502f, -1.8614e-5f, .010702f, -3.4118e-5f, 7750.f, 7760.f,
-    .0077141f, .22964f, .011399f, -1.0108e-5f, .012776f, -3.7304e-5f,
-    7760.f, 7770.f, .0021739f, .34321f, .019734f, -5.1909e-5f, .019414f,
-    -7.3442e-5f, 7770.f, 7780.f, .004572f, .18176f, .010354f, -1.7399e-5f,
-    .010948f, -3.5358e-5f, 7780.f, 7790.f, .0011295f, .18695f, .014646f,
-    4.036e-5f, .015891f, -2.0174e-5f, 7790.f, 7800.f, .0033023f, .15293f,
-    .013409f, -5.3371e-5f, .011569f, -4.7548e-5f, 7800.f, 7810.f, .0052016f,
-    .24404f, .012628f, -3.6541e-5f, .01295f, -3.8949e-5f, 7810.f, 7820.f,
-    1.133e-4f, .081552f, .01837f, -7.7312e-5f, .014695f, -7.0503e-5f,
-    7820.f, 7830.f, .0054995f, .14297f, .0065566f, -2.675e-5f, .0045262f,
-    -2.0113e-5f, 7830.f, 7840.f, 3.1204e-4f, .10156f, .0088239f,
-    -3.8012e-5f, .0082963f, -3.4068e-5f, 7840.f, 7850.f, .0019523f, .20697f,
-    .02048f, -6.0781e-5f, .018775f, -6.9708e-5f, 7850.f, 7860.f, .0024757f,
-    .09698f, .011294f, -4.651e-5f, .0098378f, -4.2459e-5f, 7860.f, 7870.f,
-    2.7171e-4f, .14226f, .017805f, -6.9496e-5f, .015097f, -7.0161e-5f,
-    7870.f, 7880.f, .0012276f, .10591f, .014194f, -5.4065e-5f, .010612f,
-    -5.2507e-5f, 7880.f, 7890.f, 4.1923e-4f, .13358f, .01696f, -4.4025e-5f,
-    .015096f, -5.8421e-5f, 7890.f, 7900.f, 3.3444e-4f, .13345f, .011391f,
-    -1.184e-6f, .012153f, -2.3277e-5f, 7900.f, 7910.f, .0013058f, .21624f,
-    .016927f, -6.9213e-5f, .013941f, -6.3876e-5f, 7910.f, 7920.f,
-    1.1995e-4f, .075585f, .013632f, -4.0157e-5f, .013768f, -5.0661e-5f,
-    7920.f, 7930.f, .0011716f, .18257f, .013971f, -5.1254e-5f, .012846f,
-    -5.6651e-5f, 7930.f, 7940.f, 5.052e-4f, .076356f, .012922f, -2.0119e-5f,
-    .013988f, -4.2851e-5f, 7940.f, 7950.f, 2.4426e-4f, .1253f, .010339f,
-    -4.3784e-6f, .010719f, -3.665e-5f, 7950.f, 7960.f, 5.414e-4f, .072313f,
-    .019259f, -8.565e-5f, .01592f, -7.9109e-5f, 7960.f, 7970.f, 7.6374e-4f,
-    .068718f, .018517f, -6.7616e-5f, .016394f, -7.3663e-5f, 7970.f, 7980.f,
-    2.5606e-4f, .077067f, .016494f, -7.5101e-5f, .01272f, -6.6656e-5f,
-    7980.f, 7990.f, 1.5654e-4f, .11158f, .010695f, -4.0866e-5f, .0081416f,
-    -4.363e-5f, 7990.f, 8e3f, 4.1929e-5f, .090036f, .024363f, -1.0641e-4f,
-    .021621f, -1.0231e-4f, 8e3f, 8010.f, 7.3175e-4f, .10587f, .016949f,
-    -6.039e-5f, .015862f, -7.1742e-5f, 8010.f, 8020.f, 8.008e-5f, .030563f,
-    .019843f, -9.1766e-5f, .017086f, -8.6214e-5f, 8020.f, 8030.f,
-    2.4279e-5f, .056812f, .022624f, -9.9621e-5f, .020301f, -9.7332e-5f,
-    8030.f, 8040.f, 1.8866e-5f, .052834f, .012394f, -4.4016e-5f, .0093994f,
-    -4.6495e-5f, 8040.f, 8050.f, 9.7669e-4f, .089736f, .0062407f,
-    -2.5133e-5f, .005852f, -2.556e-5f, 8050.f, 8060.f, .0011471f, .029409f,
-    .02069f, -9.511e-5f, .018237f, -9.0575e-5f, 8060.f, 8070.f, 7.7566e-4f,
-    .12509f, .012079f, -5.088e-5f, .010725f, -5.2092e-5f, 8070.f, 8080.f,
-    .003103f, .073291f, .016462f, -7.3991e-5f, .015208f, -6.8516e-5f,
-    8080.f, 8090.f, .001251f, .11933f, .014229f, -6.2251e-5f, .011779f,
-    -6.099e-5f, 8090.f, 8100.f, .001499f, .13662f, .0065894f, -8.557e-6f,
-    .0083512f, -1.9086e-5f, 8100.f, 8110.f, .0020532f, .10298f, .015994f,
-    -6.5137e-5f, .014131f, -6.2564e-5f, 8110.f, 8120.f, .0017448f, .067598f,
-    .014749f, -6.293e-5f, .013541f, -5.9773e-5f, 8120.f, 8130.f, .0015039f,
-    .12946f, .018816f, -5.0022e-5f, .017492f, -5.9638e-5f, 8130.f, 8140.f,
-    .0046638f, .1035f, .0062829f, -3.4218e-5f, .0036814f, -2.5761e-5f,
-    8140.f, 8150.f, .0010319f, .066367f, .0071775f, -2.8782e-5f, .010631f,
-    -2.023e-5f, 8150.f, 8160.f, .0046436f, .096269f, .015527f, -6.1225e-5f,
-    .015071f, -6.3728e-5f, 8160.f, 8170.f, .0057048f, .15352f, .0032127f,
-    -1.6432e-5f, .0035091f, -1.2277e-5f, 8170.f, 8180.f, .011525f, .15916f,
-    .0083892f, -1.0637e-5f, .0067801f, -2.5386e-5f, 8180.f, 8190.f,
-    .0074791f, .18295f, .0048041f, -2.0748e-5f, .0044988f, -1.7162e-5f,
-    8190.f, 8200.f, .011502f, .15897f, .0099626f, -1.7036e-5f, .010154f,
-    -3.5251e-5f, 8200.f, 8210.f, .032694f, .12981f, .0016557f, 1.4661e-5f,
-    .0035153f, 1.0696e-6f, 8210.f, 8220.f, .007492f, .12913f, .0071536f,
-    -2.9018e-5f, .0069835f, -3.3541e-5f, 8220.f, 8230.f, .047072f, .21294f,
-    .0094858f, -4.2608e-5f, .0075764f, -3.9014e-5f, 8230.f, 8240.f,
-    .017525f, .16065f, .0024969f, -1.0727e-6f, .0020059f, -5.349e-6f,
-    8240.f, 8250.f, .057547f, .16256f, .0053651f, -3.1796e-5f, .0032968f,
-    -2.8841e-5f, 8250.f, 8260.f, .043086f, .11299f, .0044958f, -2.4017e-5f,
-    .0036046f, -2.0674e-5f, 8260.f, 8270.f, .10051f, .15621f, .0034824f,
-    -2.1289e-5f, .0019497f, -2.0952e-5f, 8270.f, 8280.f, .073404f, .16218f,
-    .0017977f, -1.3976e-5f, 1.5476e-4f, -6.5472e-6f, 8280.f, 8290.f,
-    .08523f, .11256f, 2.9553e-4f, -9.9833e-6f, -1.2813e-4f, -4.6912e-6f,
-    8290.f, 8300.f, .1818f, .19506f, -.0018708f, -2.1763e-6f, -.0027279f,
-    2.3065e-6f, 8300.f, 8310.f, .030278f, .1674f, .0055443f, -2.3707e-5f,
-    .0051615f, -2.3428e-5f, 8310.f, 8320.f, .11462f, .20492f, -.0010659f,
-    -9.4245e-7f, -.0022118f, 4.2668e-6f, 8320.f, 8330.f, .099231f, .19833f,
-    -3.5775e-4f, -3.838e-6f, -.0025607f, -3.6304e-7f, 8330.f, 8340.f,
-    .099199f, .18538f, -.0023017f, 6.6528e-6f, -.0023339f, 6.1821e-6f,
-    8340.f, 8350.f, .059379f, .077001f, -.004912f, 1.4256e-5f, -.0025954f,
-    3.0037e-5f, 8350.f, 8360.f, .044008f, .20401f, .0014099f, -5.1535e-6f,
-    .0019118f, -1.6011e-6f, 8360.f, 8370.f, .090539f, .08076f, -.0035383f,
-    1.3223e-5f, -.0028138f, 1.3001e-5f, 8370.f, 8380.f, .014326f, .1809f,
-    .0059988f, 7.331e-7f, .0076689f, -1.7035e-5f, 8380.f, 8390.f, .046664f,
-    .1734f, -8.7294e-4f, 1.0561e-5f, 3.1024e-4f, 2.7678e-6f, 8390.f, 8400.f,
-    .10171f, .16186f, -.0017894f, -2.8284e-6f, -.0040067f, -1.4559e-7f,
-    8400.f, 8410.f, .30821f, .25107f, -.0032854f, 5.8502e-6f, -.0036961f,
-    9.3802e-6f, 8410.f, 8420.f, .063199f, .24205f, -.0011158f, 3.7207e-6f,
-    -.0013624f, 5.0058e-6f, 8420.f, 8430.f, .099053f, .16171f, -.0031354f,
-    1.4107e-5f, -4.1612e-4f, 9.0938e-6f, 8430.f, 8440.f, .18961f, .16575f,
-    -.0036207f, 4.9966e-6f, -.0041916f, 8.2034e-6f, 8440.f, 8450.f, .17725f,
-    .21239f, -7.7569e-4f, -2.0023e-6f, -4.9558e-4f, -5.1555e-6f, 8450.f,
-    8460.f, .27753f, .33354f, 9.0668e-4f, -7.5987e-6f, 1.7804e-4f,
-    -6.4173e-6f, 8460.f, 8470.f, .14123f, .13127f, -1.2234e-4f, -8.3078e-6f,
-    -4.417e-4f, -4.4651e-6f, 8470.f, 8480.f, .093615f, .12378f, -.0022473f,
-    6.446e-6f, -.0023144f, 2.1685e-5f, 8480.f, 8490.f, .20449f, .23918f,
-    .0011176f, -3.6761e-6f, .0018f, -5.0232e-6f, 8490.f, 8500.f, .089489f,
-    .16701f, .0039531f, -6.6471e-6f, .0051864f, 4.9471e-6f, 8500.f, 8510.f,
-    .23406f, .40842f, .0043192f, -1.5846e-5f, .0044314f, -2.3087e-5f,
-    8510.f, 8520.f, .14482f, .32325f, .0041937f, 5.6608e-6f, .0044945f,
-    3.2348e-7f, 8520.f, 8530.f, .064432f, .26897f, .0065578f, -1.2568e-5f,
-    .007607f, -2.0405e-5f, 8530.f, 8540.f, .057924f, .33321f, .0091543f,
-    9.8398e-6f, .0086335f, -1.8156e-5f, 8540.f, 8550.f, .10794f, .40047f,
-    .010231f, 1.2947e-5f, .010777f, -2.3286e-5f, 8550.f, 8560.f, .081479f,
-    .27006f, .010378f, -1.4458e-5f, .0096133f, -3.1676e-5f, 8560.f, 8570.f,
-    .21551f, .37486f, .015271f, -4.3087e-5f, .011958f, -4.878e-5f, 8570.f,
-    8580.f, .1197f, .42176f, .011436f, -2.7559e-5f, .012343f, -4.8358e-5f,
-    8580.f, 8590.f, .1194f, .26383f, .017025f, -6.3908e-5f, .012895f,
-    -5.3752e-5f, 8590.f, 8600.f, .35022f, .24839f, .015312f, -6.7204e-5f,
-    .011349f, -5.723e-5f, 8600.f, 8610.f, .43429f, .32749f, .014111f,
-    -6.1858e-5f, .0111f, -5.2145e-5f, 8610.f, 8620.f, .649f, .17775f,
-    .012005f, -5.7105e-5f, .0091759f, -4.5878e-5f, 8620.f, 8630.f, .62583f,
-    .2559f, .011761f, -5.603e-5f, .0090211f, -4.8934e-5f, 8630.f, 8640.f,
-    .3575f, .36475f, .010308f, -4.3411e-5f, .0088328f, -3.9083e-5f, 8640.f,
-    8650.f, 1.1133f, .13506f, .0080358f, -4.3334e-5f, .0068137f,
-    -3.9624e-5f, 8650.f, 8660.f, 1.3387f, .31665f, .0078192f, -3.8805e-5f,
-    .0049558f, -3.3187e-5f, 8660.f, 8670.f, 2.7498f, .16946f, .0049939f,
-    -3.0487e-5f, .0031261f, -2.5786e-5f, 8670.f, 8680.f, 2.4398f, .19531f,
-    .0044402f, -2.9193e-5f, .0022819f, -2.5054e-5f, 8680.f, 8690.f, 3.0993f,
-    .19328f, .0022645f, -1.9507e-5f, 5.743e-4f, -1.6236e-5f, 8690.f, 8700.f,
-    1.2713f, .17117f, .0010656f, -1.5353e-5f, -6.2313e-4f, -8.8734e-6f,
-    8700.f, 8710.f, 3.1649f, .17696f, .0010942f, -1.5108e-5f, -8.8648e-4f,
-    -8.7401e-6f, 8710.f, 8720.f, 3.1075f, .11851f, -9.4639e-5f, -9.2083e-6f,
-    -3.6777e-4f, -6.4753e-6f, 8720.f, 8730.f, 7.0407f, .19201f, -.0021209f,
-    -3.6303e-6f, -.0046941f, 1.0611e-6f, 8730.f, 8740.f, 1.2454f, .17319f,
-    -.0019955f, -1.4314e-6f, -.0021532f, -5.8242e-7f, 8740.f, 8750.f,
-    .83443f, .1489f, -.0031702f, 3.926e-6f, -.0022958f, 3.8306e-6f, 8750.f,
-    8760.f, 3.6918f, .11215f, -.0041869f, 4.6517e-6f, -.0065413f,
-    1.1815e-5f, 8760.f, 8770.f, .93114f, .16247f, 8.6756e-4f, -4.9431e-6f,
-    6.7174e-4f, -4.722e-6f, 8770.f, 8780.f, 2.5247f, .085808f, -.004835f,
-    9.227e-6f, -.0060959f, 1.2095e-5f, 8780.f, 8790.f, .53387f, .20115f,
-    -.0016551f, 7.1592e-6f, -5.3003e-4f, 9.888e-7f, 8790.f, 8800.f, 6.6475f,
-    .28681f, -.0018744f, 3.5629e-6f, -.0015672f, 2.949e-6f, 8800.f, 8810.f,
-    13.449f, .46562f, .0010817f, -8.1158e-6f, 4.4146e-4f, -9.6568e-6f,
-    8810.f, 8820.f, 2.3072f, .29228f, .0018897f, 4.5344e-6f, .0023839f,
-    -8.7201e-6f, 8820.f, 8830.f, .38221f, .2037f, 4.9695e-4f, 6.5162e-6f,
-    .0021768f, 3.2622e-6f, 8830.f, 8840.f, 1.1249f, .14056f, -.0038223f,
-    1.6534e-5f, 2.8673e-4f, 1.9579e-5f, 8840.f, 8850.f, 4.8272f, .098788f,
-    -.005013f, 9.0675e-6f, -.005665f, 1.3142e-5f, 8850.f, 8860.f, 7.562f,
-    .14568f, -.0043638f, 5.3176e-6f, -.0063322f, 1.074e-5f, 8860.f, 8870.f,
-    2.4448f, .13155f, -.002417f, -2.7983e-7f, -.0034547f, 3.4138e-6f,
-    8870.f, 8880.f, 8.0582f, .19292f, -.0028534f, -8.0358e-7f, -.0051566f,
-    3.9531e-6f, 8880.f, 8890.f, 5.7451f, .18168f, -5.0148e-4f, -9.5111e-6f,
-    -.0019306f, -6.0172e-6f, 8890.f, 8900.f, 7.0547f, .19464f, -.0010049f,
-    -7.4656e-6f, -.0025268f, -4.3122e-6f, 8900.f, 8910.f, 5.4039f, .15719f,
-    .0016933f, -1.8412e-5f, 5.6219e-4f, -1.6145e-5f, 8910.f, 8920.f,
-    3.5653f, .19909f, .0033052f, -2.2923e-5f, 5.191e-4f, -1.4385e-5f,
-    8920.f, 8930.f, 2.9405f, .30828f, .0050674f, -2.9116e-5f, .0027789f,
-    -2.3443e-5f, 8930.f, 8940.f, 1.9927f, .15337f, .0040525f, -2.4922e-5f,
-    .0021726f, -1.8937e-5f, 8940.f, 8950.f, 3.1994f, .39446f, .0066249f,
-    -3.4407e-5f, .0041704f, -2.98e-5f, 8950.f, 8960.f, 1.0124f, .3051f,
-    .0095861f, -4.26e-5f, .007142f, -3.9564e-5f, 8960.f, 8970.f, .55494f,
-    .31765f, .012349f, -5.0981e-5f, .0084323f, -3.9712e-5f, 8970.f, 8980.f,
-    .62962f, .34745f, .0068325f, -6.7823e-6f, .006612f, -2.2655e-5f, 8980.f,
-    8990.f, .39155f, .17506f, .014525f, -6.4228e-5f, .012836f, -5.854e-5f,
-    8990.f, 9e3f, .29338f, .19531f, .014921f, -5.7995e-5f, .012214f,
-    -4.6413e-5f, 9e3f, 9010.f, .117f, .34769f, .013815f, -1.4315e-5f,
-    .011336f, -3.2553e-5f, 9010.f, 9020.f, .16223f, .35064f, .0089364f,
-    2.1825e-5f, .010979f, -2.503e-5f, 9020.f, 9030.f, .021742f, .25837f,
-    .021279f, -6.9818e-5f, .017662f, -6.8568e-5f, 9030.f, 9040.f, .056078f,
-    .27822f, .012493f, 1.8431e-5f, .013824f, -2.7676e-5f, 9040.f, 9050.f,
-    .050045f, .24927f, .0025877f, 4.5316e-5f, .0058234f, 9.7906e-6f, 9050.f,
-    9060.f, .074041f, .1688f, .0031016f, -1.2901e-5f, .0031503f,
-    -9.5272e-6f, 9060.f, 9070.f, .035788f, .25671f, .0055742f, -3.3952e-6f,
-    .0067343f, -9.7505e-6f, 9070.f, 9080.f, .057922f, .23584f, .0022587f,
-    -9.2537e-6f, .0015239f, -7.0447e-6f, 9080.f, 9090.f, .033597f, .22977f,
-    .0030824f, -1.1293e-5f, .0033924f, -5.6695e-6f, 9090.f, 9100.f,
-    .070807f, .38398f, .0033167f, -8.2422e-6f, .002352f, -1.7904e-5f,
-    9100.f, 9110.f, .007025f, .18707f, .008814f, -2.739e-5f, .008404f,
-    -2.9932e-5f, 9110.f, 9120.f, .069936f, .25325f, .0019174f, -1.1175e-5f,
-    .001279f, -1.4168e-5f, 9120.f, 9130.f, .052387f, .30346f, 9.3076e-4f,
-    5.2452e-6f, .0021985f, -1.2943e-5f, 9130.f, 9140.f, .015639f, .086845f,
-    .0072697f, -3.4455e-5f, .0051914f, -3.2991e-5f, 9140.f, 9150.f,
-    .091802f, .17031f, -5.4142e-4f, 2.9713e-6f, -.0010743f, -2.3472e-6f,
-    9150.f, 9160.f, .011168f, .099076f, .005622f, -3.0231e-5f, .0047197f,
-    -2.3663e-5f, 9160.f, 9170.f, .048371f, .1417f, -5.9903e-4f, -4.5058e-6f,
-    -.0011328f, 9.448e-7f, 9170.f, 9180.f, .018874f, .15366f, .0042614f,
-    -2.6279e-5f, 8.9656e-4f, -2.0193e-5f, 9180.f, 9190.f, .016112f, .12245f,
-    .0061155f, -3.4764e-5f, .0039418f, -3.163e-5f, 9190.f, 9200.f, .065149f,
-    .14651f, .0013623f, -1.4483e-5f, 1.0964e-5f, -1.1796e-5f, 9200.f,
-    9210.f, .011149f, .21185f, .0041991f, -1.3718e-5f, .0030892f,
-    -2.0781e-5f, 9210.f, 9220.f, .031171f, .12753f, .0045967f, -2.5041e-5f,
-    .0038974f, -2.7102e-5f, 9220.f, 9230.f, 4.0823e-4f, .030563f, .0247f,
-    -1.1119e-4f, .021942f, -1.0564e-4f, 9230.f, 9240.f, .012977f, .16914f,
-    .0055548f, -2.5826e-5f, .0033619f, -2.2004e-5f, 9240.f, 9250.f,
-    .020816f, .10896f, .0066122f, -3.4731e-5f, .0052212f, -3.4187e-5f,
-    9250.f, 9260.f, .0030262f, .11279f, .010901f, -5.2842e-5f, .0086449f,
-    -4.5417e-5f, 9260.f, 9270.f, .0033673f, .11423f, .010899f, -3.4157e-5f,
-    .0080866f, -3.8803e-5f, 9270.f, 9280.f, .017536f, .16659f, .0083759f,
-    -4.46e-5f, .005112f, -3.6571e-5f, 9280.f, 9290.f, 8.1624e-4f, .16081f,
-    .015916f, -6.3848e-5f, .013156f, -6.3084e-5f, 9290.f, 9300.f, .011313f,
-    .13057f, .011852f, -5.8953e-5f, .0088407f, -5.1297e-5f, 9300.f, 9310.f,
-    .0015081f, .069261f, .0041982f, -7.5358e-6f, .0057185f, -1.6686e-5f,
-    9310.f, 9320.f, .0045702f, .1342f, .013143f, -5.4394e-5f, .01017f,
-    -5.2848e-5f, 9320.f, 9330.f, 7.5901e-4f, .16485f, .017789f, -4.1657e-5f,
-    .014232f, -5.1704e-5f, 9330.f, 9340.f, .0023315f, .14437f, .015924f,
-    -7.3095e-5f, .012997f, -6.7546e-5f, 9340.f, 9350.f, .0024761f, .13342f,
-    .017367f, -6.5679e-5f, .014468f, -6.2866e-5f, 9350.f, 9360.f, .0011255f,
-    .11586f, .016217f, -5.9242e-5f, .013009f, -5.7135e-5f, 9360.f, 9370.f,
-    4.6631e-4f, .031553f, .0231f, -1.0479e-4f, .020342f, -9.924e-5f, 9370.f,
-    9380.f, 5.8334e-4f, .14333f, .014779f, -4.7773e-5f, .011406f,
-    -5.2169e-5f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9390.f, 9400.f,
-    4.6492e-4f, .064777f, .012413f, -2.9282e-5f, .013774f, -4.9601e-5f,
-    9400.f, 9410.f, 4.0085e-4f, .030483f, .010823f, -5.5684e-5f, .0080667f,
-    -5.0135e-5f, 9410.f, 9420.f, 6.5363e-5f, .053752f, .0231f, -1.0479e-4f,
-    .020342f, -9.924e-5f, 9420.f, 9430.f, 2.4119e-5f, .027609f, .03515f,
-    -1.5299e-4f, .032393f, -1.4744e-4f, 9430.f, 9440.f, 1.3718e-4f, .04682f,
-    .01614f, -5.2767e-5f, .016119f, -6.7234e-5f, 9440.f, 9450.f, 5.534e-5f,
-    .046161f, .016226f, -4.5595e-5f, .015446f, -5.9474e-5f, 9450.f, 9460.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9460.f, 9470.f, 5.7428e-5f, .063455f,
-    .017377f, -4.729e-5f, .016614f, -6.2421e-5f, 9470.f, 9480.f, 3.8406e-5f,
-    .031771f, .0046608f, -3.1037e-5f, .0019036f, -2.5485e-5f, 9480.f,
-    9490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9500.f, 9510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9520.f, 9530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f,
-    9540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9550.f, 9560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9570.f, 9580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f,
-    9590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9590.f, 9600.f, 2.4903e-5f,
-      .024969f,
-    .025759f, -1.1543e-4f, .023002f, -1.0988e-4f, 9600.f, 9610.f,
-    4.8976e-5f, .034814f, .004643f, -3.0966e-5f, .0018858f, -2.5414e-5f,
-    9610.f, 9620.f, 6.6257e-5f, .052528f, .020662f, -9.5042e-5f, .017905f,
-    -8.949e-5f, 9620.f, 9630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f,
+    static const float acr[2048] = { .092641f, .26739f,
+				     .0074828f, -3.6295e-5f, .0065918f, -3.6255e-5f, 7620.f, 7630.f, .24311f,
+				     .19859f, .0029686f, -1.983e-5f, .0023399f, -1.6807e-5f, 7630.f, 7640.f,
+				     .12025f, .11463f, .005982f, -3.2695e-5f, .00555f, -2.817e-5f, 7640.f,
+				     7650.f, .13658f, .26836f, .0072502f, -2.1381e-5f, .0073061f,
+				     -3.0405e-5f, 7650.f, 7660.f, .10472f, .25523f, .0079597f, -3.2676e-5f,
+				     .0058214f, -3.1308e-5f, 7660.f, 7670.f, .099714f, .25003f, .012338f,
+				     -5.6896e-5f, .010569f, -5.1734e-5f, 7670.f, 7680.f, .058366f, .22207f,
+				     .011694f, -5.1427e-5f, .011909f, -4.905e-5f, 7680.f, 7690.f, .035387f,
+				     .17329f, .016862f, -7.5246e-5f, .013502f, -6.3311e-5f, 7690.f, 7700.f,
+				     .036568f, .21034f, .0081374f, -2.4226e-5f, .0063861f, -2.5253e-5f,
+				     7700.f, 7710.f, .027597f, .33962f, .017925f, -6.8929e-5f, .015283f,
+				     -6.6807e-5f, 7710.f, 7720.f, .010316f, .41286f, .019917f, -4.8503e-5f,
+				     .017007f, -5.8717e-5f, 7720.f, 7730.f, .0081553f, .2556f, .021997f,
+				     -8.8437e-5f, .020546f, -8.5162e-5f, 7730.f, 7740.f, .015975f, .21315f,
+				     .0071481f, 3.1142e-6f, .010474f, -1.3461e-5f, 7740.f, 7750.f, .013868f,
+				     .24329f, .0094502f, -1.8614e-5f, .010702f, -3.4118e-5f, 7750.f, 7760.f,
+				     .0077141f, .22964f, .011399f, -1.0108e-5f, .012776f, -3.7304e-5f,
+				     7760.f, 7770.f, .0021739f, .34321f, .019734f, -5.1909e-5f, .019414f,
+				     -7.3442e-5f, 7770.f, 7780.f, .004572f, .18176f, .010354f, -1.7399e-5f,
+				     .010948f, -3.5358e-5f, 7780.f, 7790.f, .0011295f, .18695f, .014646f,
+				     4.036e-5f, .015891f, -2.0174e-5f, 7790.f, 7800.f, .0033023f, .15293f,
+				     .013409f, -5.3371e-5f, .011569f, -4.7548e-5f, 7800.f, 7810.f, .0052016f,
+				     .24404f, .012628f, -3.6541e-5f, .01295f, -3.8949e-5f, 7810.f, 7820.f,
+				     1.133e-4f, .081552f, .01837f, -7.7312e-5f, .014695f, -7.0503e-5f,
+				     7820.f, 7830.f, .0054995f, .14297f, .0065566f, -2.675e-5f, .0045262f,
+				     -2.0113e-5f, 7830.f, 7840.f, 3.1204e-4f, .10156f, .0088239f,
+				     -3.8012e-5f, .0082963f, -3.4068e-5f, 7840.f, 7850.f, .0019523f, .20697f,
+				     .02048f, -6.0781e-5f, .018775f, -6.9708e-5f, 7850.f, 7860.f, .0024757f,
+				     .09698f, .011294f, -4.651e-5f, .0098378f, -4.2459e-5f, 7860.f, 7870.f,
+				     2.7171e-4f, .14226f, .017805f, -6.9496e-5f, .015097f, -7.0161e-5f,
+				     7870.f, 7880.f, .0012276f, .10591f, .014194f, -5.4065e-5f, .010612f,
+				     -5.2507e-5f, 7880.f, 7890.f, 4.1923e-4f, .13358f, .01696f, -4.4025e-5f,
+				     .015096f, -5.8421e-5f, 7890.f, 7900.f, 3.3444e-4f, .13345f, .011391f,
+				     -1.184e-6f, .012153f, -2.3277e-5f, 7900.f, 7910.f, .0013058f, .21624f,
+				     .016927f, -6.9213e-5f, .013941f, -6.3876e-5f, 7910.f, 7920.f,
+				     1.1995e-4f, .075585f, .013632f, -4.0157e-5f, .013768f, -5.0661e-5f,
+				     7920.f, 7930.f, .0011716f, .18257f, .013971f, -5.1254e-5f, .012846f,
+				     -5.6651e-5f, 7930.f, 7940.f, 5.052e-4f, .076356f, .012922f, -2.0119e-5f,
+				     .013988f, -4.2851e-5f, 7940.f, 7950.f, 2.4426e-4f, .1253f, .010339f,
+				     -4.3784e-6f, .010719f, -3.665e-5f, 7950.f, 7960.f, 5.414e-4f, .072313f,
+				     .019259f, -8.565e-5f, .01592f, -7.9109e-5f, 7960.f, 7970.f, 7.6374e-4f,
+				     .068718f, .018517f, -6.7616e-5f, .016394f, -7.3663e-5f, 7970.f, 7980.f,
+				     2.5606e-4f, .077067f, .016494f, -7.5101e-5f, .01272f, -6.6656e-5f,
+				     7980.f, 7990.f, 1.5654e-4f, .11158f, .010695f, -4.0866e-5f, .0081416f,
+				     -4.363e-5f, 7990.f, 8e3f, 4.1929e-5f, .090036f, .024363f, -1.0641e-4f,
+				     .021621f, -1.0231e-4f, 8e3f, 8010.f, 7.3175e-4f, .10587f, .016949f,
+				     -6.039e-5f, .015862f, -7.1742e-5f, 8010.f, 8020.f, 8.008e-5f, .030563f,
+				     .019843f, -9.1766e-5f, .017086f, -8.6214e-5f, 8020.f, 8030.f,
+				     2.4279e-5f, .056812f, .022624f, -9.9621e-5f, .020301f, -9.7332e-5f,
+				     8030.f, 8040.f, 1.8866e-5f, .052834f, .012394f, -4.4016e-5f, .0093994f,
+				     -4.6495e-5f, 8040.f, 8050.f, 9.7669e-4f, .089736f, .0062407f,
+				     -2.5133e-5f, .005852f, -2.556e-5f, 8050.f, 8060.f, .0011471f, .029409f,
+				     .02069f, -9.511e-5f, .018237f, -9.0575e-5f, 8060.f, 8070.f, 7.7566e-4f,
+				     .12509f, .012079f, -5.088e-5f, .010725f, -5.2092e-5f, 8070.f, 8080.f,
+				     .003103f, .073291f, .016462f, -7.3991e-5f, .015208f, -6.8516e-5f,
+				     8080.f, 8090.f, .001251f, .11933f, .014229f, -6.2251e-5f, .011779f,
+				     -6.099e-5f, 8090.f, 8100.f, .001499f, .13662f, .0065894f, -8.557e-6f,
+				     .0083512f, -1.9086e-5f, 8100.f, 8110.f, .0020532f, .10298f, .015994f,
+				     -6.5137e-5f, .014131f, -6.2564e-5f, 8110.f, 8120.f, .0017448f, .067598f,
+				     .014749f, -6.293e-5f, .013541f, -5.9773e-5f, 8120.f, 8130.f, .0015039f,
+				     .12946f, .018816f, -5.0022e-5f, .017492f, -5.9638e-5f, 8130.f, 8140.f,
+				     .0046638f, .1035f, .0062829f, -3.4218e-5f, .0036814f, -2.5761e-5f,
+				     8140.f, 8150.f, .0010319f, .066367f, .0071775f, -2.8782e-5f, .010631f,
+				     -2.023e-5f, 8150.f, 8160.f, .0046436f, .096269f, .015527f, -6.1225e-5f,
+				     .015071f, -6.3728e-5f, 8160.f, 8170.f, .0057048f, .15352f, .0032127f,
+				     -1.6432e-5f, .0035091f, -1.2277e-5f, 8170.f, 8180.f, .011525f, .15916f,
+				     .0083892f, -1.0637e-5f, .0067801f, -2.5386e-5f, 8180.f, 8190.f,
+				     .0074791f, .18295f, .0048041f, -2.0748e-5f, .0044988f, -1.7162e-5f,
+				     8190.f, 8200.f, .011502f, .15897f, .0099626f, -1.7036e-5f, .010154f,
+				     -3.5251e-5f, 8200.f, 8210.f, .032694f, .12981f, .0016557f, 1.4661e-5f,
+				     .0035153f, 1.0696e-6f, 8210.f, 8220.f, .007492f, .12913f, .0071536f,
+				     -2.9018e-5f, .0069835f, -3.3541e-5f, 8220.f, 8230.f, .047072f, .21294f,
+				     .0094858f, -4.2608e-5f, .0075764f, -3.9014e-5f, 8230.f, 8240.f,
+				     .017525f, .16065f, .0024969f, -1.0727e-6f, .0020059f, -5.349e-6f,
+				     8240.f, 8250.f, .057547f, .16256f, .0053651f, -3.1796e-5f, .0032968f,
+				     -2.8841e-5f, 8250.f, 8260.f, .043086f, .11299f, .0044958f, -2.4017e-5f,
+				     .0036046f, -2.0674e-5f, 8260.f, 8270.f, .10051f, .15621f, .0034824f,
+				     -2.1289e-5f, .0019497f, -2.0952e-5f, 8270.f, 8280.f, .073404f, .16218f,
+				     .0017977f, -1.3976e-5f, 1.5476e-4f, -6.5472e-6f, 8280.f, 8290.f,
+				     .08523f, .11256f, 2.9553e-4f, -9.9833e-6f, -1.2813e-4f, -4.6912e-6f,
+				     8290.f, 8300.f, .1818f, .19506f, -.0018708f, -2.1763e-6f, -.0027279f,
+				     2.3065e-6f, 8300.f, 8310.f, .030278f, .1674f, .0055443f, -2.3707e-5f,
+				     .0051615f, -2.3428e-5f, 8310.f, 8320.f, .11462f, .20492f, -.0010659f,
+				     -9.4245e-7f, -.0022118f, 4.2668e-6f, 8320.f, 8330.f, .099231f, .19833f,
+				     -3.5775e-4f, -3.838e-6f, -.0025607f, -3.6304e-7f, 8330.f, 8340.f,
+				     .099199f, .18538f, -.0023017f, 6.6528e-6f, -.0023339f, 6.1821e-6f,
+				     8340.f, 8350.f, .059379f, .077001f, -.004912f, 1.4256e-5f, -.0025954f,
+				     3.0037e-5f, 8350.f, 8360.f, .044008f, .20401f, .0014099f, -5.1535e-6f,
+				     .0019118f, -1.6011e-6f, 8360.f, 8370.f, .090539f, .08076f, -.0035383f,
+				     1.3223e-5f, -.0028138f, 1.3001e-5f, 8370.f, 8380.f, .014326f, .1809f,
+				     .0059988f, 7.331e-7f, .0076689f, -1.7035e-5f, 8380.f, 8390.f, .046664f,
+				     .1734f, -8.7294e-4f, 1.0561e-5f, 3.1024e-4f, 2.7678e-6f, 8390.f, 8400.f,
+				     .10171f, .16186f, -.0017894f, -2.8284e-6f, -.0040067f, -1.4559e-7f,
+				     8400.f, 8410.f, .30821f, .25107f, -.0032854f, 5.8502e-6f, -.0036961f,
+				     9.3802e-6f, 8410.f, 8420.f, .063199f, .24205f, -.0011158f, 3.7207e-6f,
+				     -.0013624f, 5.0058e-6f, 8420.f, 8430.f, .099053f, .16171f, -.0031354f,
+				     1.4107e-5f, -4.1612e-4f, 9.0938e-6f, 8430.f, 8440.f, .18961f, .16575f,
+				     -.0036207f, 4.9966e-6f, -.0041916f, 8.2034e-6f, 8440.f, 8450.f, .17725f,
+				     .21239f, -7.7569e-4f, -2.0023e-6f, -4.9558e-4f, -5.1555e-6f, 8450.f,
+				     8460.f, .27753f, .33354f, 9.0668e-4f, -7.5987e-6f, 1.7804e-4f,
+				     -6.4173e-6f, 8460.f, 8470.f, .14123f, .13127f, -1.2234e-4f, -8.3078e-6f,
+				     -4.417e-4f, -4.4651e-6f, 8470.f, 8480.f, .093615f, .12378f, -.0022473f,
+				     6.446e-6f, -.0023144f, 2.1685e-5f, 8480.f, 8490.f, .20449f, .23918f,
+				     .0011176f, -3.6761e-6f, .0018f, -5.0232e-6f, 8490.f, 8500.f, .089489f,
+				     .16701f, .0039531f, -6.6471e-6f, .0051864f, 4.9471e-6f, 8500.f, 8510.f,
+				     .23406f, .40842f, .0043192f, -1.5846e-5f, .0044314f, -2.3087e-5f,
+				     8510.f, 8520.f, .14482f, .32325f, .0041937f, 5.6608e-6f, .0044945f,
+				     3.2348e-7f, 8520.f, 8530.f, .064432f, .26897f, .0065578f, -1.2568e-5f,
+				     .007607f, -2.0405e-5f, 8530.f, 8540.f, .057924f, .33321f, .0091543f,
+				     9.8398e-6f, .0086335f, -1.8156e-5f, 8540.f, 8550.f, .10794f, .40047f,
+				     .010231f, 1.2947e-5f, .010777f, -2.3286e-5f, 8550.f, 8560.f, .081479f,
+				     .27006f, .010378f, -1.4458e-5f, .0096133f, -3.1676e-5f, 8560.f, 8570.f,
+				     .21551f, .37486f, .015271f, -4.3087e-5f, .011958f, -4.878e-5f, 8570.f,
+				     8580.f, .1197f, .42176f, .011436f, -2.7559e-5f, .012343f, -4.8358e-5f,
+				     8580.f, 8590.f, .1194f, .26383f, .017025f, -6.3908e-5f, .012895f,
+				     -5.3752e-5f, 8590.f, 8600.f, .35022f, .24839f, .015312f, -6.7204e-5f,
+				     .011349f, -5.723e-5f, 8600.f, 8610.f, .43429f, .32749f, .014111f,
+				     -6.1858e-5f, .0111f, -5.2145e-5f, 8610.f, 8620.f, .649f, .17775f,
+				     .012005f, -5.7105e-5f, .0091759f, -4.5878e-5f, 8620.f, 8630.f, .62583f,
+				     .2559f, .011761f, -5.603e-5f, .0090211f, -4.8934e-5f, 8630.f, 8640.f,
+				     .3575f, .36475f, .010308f, -4.3411e-5f, .0088328f, -3.9083e-5f, 8640.f,
+				     8650.f, 1.1133f, .13506f, .0080358f, -4.3334e-5f, .0068137f,
+				     -3.9624e-5f, 8650.f, 8660.f, 1.3387f, .31665f, .0078192f, -3.8805e-5f,
+				     .0049558f, -3.3187e-5f, 8660.f, 8670.f, 2.7498f, .16946f, .0049939f,
+				     -3.0487e-5f, .0031261f, -2.5786e-5f, 8670.f, 8680.f, 2.4398f, .19531f,
+				     .0044402f, -2.9193e-5f, .0022819f, -2.5054e-5f, 8680.f, 8690.f, 3.0993f,
+				     .19328f, .0022645f, -1.9507e-5f, 5.743e-4f, -1.6236e-5f, 8690.f, 8700.f,
+				     1.2713f, .17117f, .0010656f, -1.5353e-5f, -6.2313e-4f, -8.8734e-6f,
+				     8700.f, 8710.f, 3.1649f, .17696f, .0010942f, -1.5108e-5f, -8.8648e-4f,
+				     -8.7401e-6f, 8710.f, 8720.f, 3.1075f, .11851f, -9.4639e-5f, -9.2083e-6f,
+				     -3.6777e-4f, -6.4753e-6f, 8720.f, 8730.f, 7.0407f, .19201f, -.0021209f,
+				     -3.6303e-6f, -.0046941f, 1.0611e-6f, 8730.f, 8740.f, 1.2454f, .17319f,
+				     -.0019955f, -1.4314e-6f, -.0021532f, -5.8242e-7f, 8740.f, 8750.f,
+				     .83443f, .1489f, -.0031702f, 3.926e-6f, -.0022958f, 3.8306e-6f, 8750.f,
+				     8760.f, 3.6918f, .11215f, -.0041869f, 4.6517e-6f, -.0065413f,
+				     1.1815e-5f, 8760.f, 8770.f, .93114f, .16247f, 8.6756e-4f, -4.9431e-6f,
+				     6.7174e-4f, -4.722e-6f, 8770.f, 8780.f, 2.5247f, .085808f, -.004835f,
+				     9.227e-6f, -.0060959f, 1.2095e-5f, 8780.f, 8790.f, .53387f, .20115f,
+				     -.0016551f, 7.1592e-6f, -5.3003e-4f, 9.888e-7f, 8790.f, 8800.f, 6.6475f,
+				     .28681f, -.0018744f, 3.5629e-6f, -.0015672f, 2.949e-6f, 8800.f, 8810.f,
+				     13.449f, .46562f, .0010817f, -8.1158e-6f, 4.4146e-4f, -9.6568e-6f,
+				     8810.f, 8820.f, 2.3072f, .29228f, .0018897f, 4.5344e-6f, .0023839f,
+				     -8.7201e-6f, 8820.f, 8830.f, .38221f, .2037f, 4.9695e-4f, 6.5162e-6f,
+				     .0021768f, 3.2622e-6f, 8830.f, 8840.f, 1.1249f, .14056f, -.0038223f,
+				     1.6534e-5f, 2.8673e-4f, 1.9579e-5f, 8840.f, 8850.f, 4.8272f, .098788f,
+				     -.005013f, 9.0675e-6f, -.005665f, 1.3142e-5f, 8850.f, 8860.f, 7.562f,
+				     .14568f, -.0043638f, 5.3176e-6f, -.0063322f, 1.074e-5f, 8860.f, 8870.f,
+				     2.4448f, .13155f, -.002417f, -2.7983e-7f, -.0034547f, 3.4138e-6f,
+				     8870.f, 8880.f, 8.0582f, .19292f, -.0028534f, -8.0358e-7f, -.0051566f,
+				     3.9531e-6f, 8880.f, 8890.f, 5.7451f, .18168f, -5.0148e-4f, -9.5111e-6f,
+				     -.0019306f, -6.0172e-6f, 8890.f, 8900.f, 7.0547f, .19464f, -.0010049f,
+				     -7.4656e-6f, -.0025268f, -4.3122e-6f, 8900.f, 8910.f, 5.4039f, .15719f,
+				     .0016933f, -1.8412e-5f, 5.6219e-4f, -1.6145e-5f, 8910.f, 8920.f,
+				     3.5653f, .19909f, .0033052f, -2.2923e-5f, 5.191e-4f, -1.4385e-5f,
+				     8920.f, 8930.f, 2.9405f, .30828f, .0050674f, -2.9116e-5f, .0027789f,
+				     -2.3443e-5f, 8930.f, 8940.f, 1.9927f, .15337f, .0040525f, -2.4922e-5f,
+				     .0021726f, -1.8937e-5f, 8940.f, 8950.f, 3.1994f, .39446f, .0066249f,
+				     -3.4407e-5f, .0041704f, -2.98e-5f, 8950.f, 8960.f, 1.0124f, .3051f,
+				     .0095861f, -4.26e-5f, .007142f, -3.9564e-5f, 8960.f, 8970.f, .55494f,
+				     .31765f, .012349f, -5.0981e-5f, .0084323f, -3.9712e-5f, 8970.f, 8980.f,
+				     .62962f, .34745f, .0068325f, -6.7823e-6f, .006612f, -2.2655e-5f, 8980.f,
+				     8990.f, .39155f, .17506f, .014525f, -6.4228e-5f, .012836f, -5.854e-5f,
+				     8990.f, 9e3f, .29338f, .19531f, .014921f, -5.7995e-5f, .012214f,
+				     -4.6413e-5f, 9e3f, 9010.f, .117f, .34769f, .013815f, -1.4315e-5f,
+				     .011336f, -3.2553e-5f, 9010.f, 9020.f, .16223f, .35064f, .0089364f,
+				     2.1825e-5f, .010979f, -2.503e-5f, 9020.f, 9030.f, .021742f, .25837f,
+				     .021279f, -6.9818e-5f, .017662f, -6.8568e-5f, 9030.f, 9040.f, .056078f,
+				     .27822f, .012493f, 1.8431e-5f, .013824f, -2.7676e-5f, 9040.f, 9050.f,
+				     .050045f, .24927f, .0025877f, 4.5316e-5f, .0058234f, 9.7906e-6f, 9050.f,
+				     9060.f, .074041f, .1688f, .0031016f, -1.2901e-5f, .0031503f,
+				     -9.5272e-6f, 9060.f, 9070.f, .035788f, .25671f, .0055742f, -3.3952e-6f,
+				     .0067343f, -9.7505e-6f, 9070.f, 9080.f, .057922f, .23584f, .0022587f,
+				     -9.2537e-6f, .0015239f, -7.0447e-6f, 9080.f, 9090.f, .033597f, .22977f,
+				     .0030824f, -1.1293e-5f, .0033924f, -5.6695e-6f, 9090.f, 9100.f,
+				     .070807f, .38398f, .0033167f, -8.2422e-6f, .002352f, -1.7904e-5f,
+				     9100.f, 9110.f, .007025f, .18707f, .008814f, -2.739e-5f, .008404f,
+				     -2.9932e-5f, 9110.f, 9120.f, .069936f, .25325f, .0019174f, -1.1175e-5f,
+				     .001279f, -1.4168e-5f, 9120.f, 9130.f, .052387f, .30346f, 9.3076e-4f,
+				     5.2452e-6f, .0021985f, -1.2943e-5f, 9130.f, 9140.f, .015639f, .086845f,
+				     .0072697f, -3.4455e-5f, .0051914f, -3.2991e-5f, 9140.f, 9150.f,
+				     .091802f, .17031f, -5.4142e-4f, 2.9713e-6f, -.0010743f, -2.3472e-6f,
+				     9150.f, 9160.f, .011168f, .099076f, .005622f, -3.0231e-5f, .0047197f,
+				     -2.3663e-5f, 9160.f, 9170.f, .048371f, .1417f, -5.9903e-4f, -4.5058e-6f,
+				     -.0011328f, 9.448e-7f, 9170.f, 9180.f, .018874f, .15366f, .0042614f,
+				     -2.6279e-5f, 8.9656e-4f, -2.0193e-5f, 9180.f, 9190.f, .016112f, .12245f,
+				     .0061155f, -3.4764e-5f, .0039418f, -3.163e-5f, 9190.f, 9200.f, .065149f,
+				     .14651f, .0013623f, -1.4483e-5f, 1.0964e-5f, -1.1796e-5f, 9200.f,
+				     9210.f, .011149f, .21185f, .0041991f, -1.3718e-5f, .0030892f,
+				     -2.0781e-5f, 9210.f, 9220.f, .031171f, .12753f, .0045967f, -2.5041e-5f,
+				     .0038974f, -2.7102e-5f, 9220.f, 9230.f, 4.0823e-4f, .030563f, .0247f,
+				     -1.1119e-4f, .021942f, -1.0564e-4f, 9230.f, 9240.f, .012977f, .16914f,
+				     .0055548f, -2.5826e-5f, .0033619f, -2.2004e-5f, 9240.f, 9250.f,
+				     .020816f, .10896f, .0066122f, -3.4731e-5f, .0052212f, -3.4187e-5f,
+				     9250.f, 9260.f, .0030262f, .11279f, .010901f, -5.2842e-5f, .0086449f,
+				     -4.5417e-5f, 9260.f, 9270.f, .0033673f, .11423f, .010899f, -3.4157e-5f,
+				     .0080866f, -3.8803e-5f, 9270.f, 9280.f, .017536f, .16659f, .0083759f,
+				     -4.46e-5f, .005112f, -3.6571e-5f, 9280.f, 9290.f, 8.1624e-4f, .16081f,
+				     .015916f, -6.3848e-5f, .013156f, -6.3084e-5f, 9290.f, 9300.f, .011313f,
+				     .13057f, .011852f, -5.8953e-5f, .0088407f, -5.1297e-5f, 9300.f, 9310.f,
+				     .0015081f, .069261f, .0041982f, -7.5358e-6f, .0057185f, -1.6686e-5f,
+				     9310.f, 9320.f, .0045702f, .1342f, .013143f, -5.4394e-5f, .01017f,
+				     -5.2848e-5f, 9320.f, 9330.f, 7.5901e-4f, .16485f, .017789f, -4.1657e-5f,
+				     .014232f, -5.1704e-5f, 9330.f, 9340.f, .0023315f, .14437f, .015924f,
+				     -7.3095e-5f, .012997f, -6.7546e-5f, 9340.f, 9350.f, .0024761f, .13342f,
+				     .017367f, -6.5679e-5f, .014468f, -6.2866e-5f, 9350.f, 9360.f, .0011255f,
+				     .11586f, .016217f, -5.9242e-5f, .013009f, -5.7135e-5f, 9360.f, 9370.f,
+				     4.6631e-4f, .031553f, .0231f, -1.0479e-4f, .020342f, -9.924e-5f, 9370.f,
+				     9380.f, 5.8334e-4f, .14333f, .014779f, -4.7773e-5f, .011406f,
+				     -5.2169e-5f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9390.f, 9400.f,
+				     4.6492e-4f, .064777f, .012413f, -2.9282e-5f, .013774f, -4.9601e-5f,
+				     9400.f, 9410.f, 4.0085e-4f, .030483f, .010823f, -5.5684e-5f, .0080667f,
+				     -5.0135e-5f, 9410.f, 9420.f, 6.5363e-5f, .053752f, .0231f, -1.0479e-4f,
+				     .020342f, -9.924e-5f, 9420.f, 9430.f, 2.4119e-5f, .027609f, .03515f,
+				     -1.5299e-4f, .032393f, -1.4744e-4f, 9430.f, 9440.f, 1.3718e-4f, .04682f,
+				     .01614f, -5.2767e-5f, .016119f, -6.7234e-5f, 9440.f, 9450.f, 5.534e-5f,
+				     .046161f, .016226f, -4.5595e-5f, .015446f, -5.9474e-5f, 9450.f, 9460.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9460.f, 9470.f, 5.7428e-5f, .063455f,
+				     .017377f, -4.729e-5f, .016614f, -6.2421e-5f, 9470.f, 9480.f, 3.8406e-5f,
+				     .031771f, .0046608f, -3.1037e-5f, .0019036f, -2.5485e-5f, 9480.f,
+				     9490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9500.f, 9510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9520.f, 9530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f,
+				     9540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9550.f, 9560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9570.f, 9580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f,
+				     9590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9590.f, 9600.f, 2.4903e-5f,
+				     .024969f,
+				     .025759f, -1.1543e-4f, .023002f, -1.0988e-4f, 9600.f, 9610.f,
+				     4.8976e-5f, .034814f, .004643f, -3.0966e-5f, .0018858f, -2.5414e-5f,
+				     9610.f, 9620.f, 6.6257e-5f, .052528f, .020662f, -9.5042e-5f, .017905f,
+				     -8.949e-5f, 9620.f, 9630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9640.f, 9650.f, 1.9405e-4f, .0908f,
-      .012893f,
-    -4.7907e-5f, .008999f, -4.3597e-5f, 9650.f, 9660.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 9660.f, 9670.f, 3.5455e-4f, .062906f, .01178f, -5.9514e-5f,
-    .0090225f, -5.3961e-5f, 9670.f, 9680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    9680.f, 9690.f, 7.3346e-4f, .095357f, .0080776f, -3.5126e-5f, .0063761f,
-    -3.2075e-5f, 9690.f, 9700.f, 2.6888e-4f, .062321f, .01172f, -5.6759e-5f,
-    .0098726f, -5.5238e-5f, 9700.f, 9710.f, 4.8999e-4f, .10498f, .0062757f,
-    -3.2864e-5f, .0049464f, -3.2626e-5f, 9710.f, 9720.f, .0010507f,
-    .071841f, .0058574f, -3.2015e-5f, .0039666f, -3.1106e-5f, 9720.f,
-    9730.f, .0025494f, .10376f, .0030444f, -2.0413e-5f, .0012384f,
-    -1.8532e-5f, 9730.f, 9740.f, .0013019f, .13387f, .0019451f, -1.3612e-5f,
-    -8.9213e-6f, -1.3158e-5f, 9740.f, 9750.f, 6.2353e-4f, .078233f,
-    7.0756e-4f, -1.519e-5f, -.0020739f, -9.6993e-6f, 9750.f, 9760.f,
-    .0056535f, .1971f, 1.6071e-4f, -5.7489e-6f, -.0014878f, -4.8238e-6f,
-    9760.f, 9770.f, .001909f, .041123f, -.0019069f, -4.7662e-6f, -.004664f,
-    7.8558e-7f, 9770.f, 9780.f, .0017619f, .13162f, -.0022639f, 7.7041e-7f,
-    -.0049756f, 4.3744e-6f, 9780.f, 9790.f, 5.7144e-4f, .099432f, .0040501f,
-    -1.5471e-5f, .0018591f, -1.7658e-5f, 9790.f, 9800.f, .0038209f, .13329f,
-    -.0046298f, 6.3691e-6f, -.0077028f, 1.2343e-5f, 9800.f, 9810.f,
-    .0017147f, .079407f, 4.5502e-4f, -1.3444e-5f, -.0030355f, -5.7728e-6f,
-    9810.f, 9820.f, .0012145f, .072418f, 2.5064e-4f, -5.9535e-6f,
-    3.3766e-6f, -6.2695e-6f, 9820.f, 9830.f, .0011057f, .13614f, .0018444f,
-    -3.817e-6f, -6.6263e-4f, -6.1358e-6f, 9830.f, 9840.f, .0021971f,
-    .053016f, -.0048189f, 9.7527e-6f, -.0060279f, 1.7406e-5f, 9840.f,
-    9850.f, .0019933f, .17956f, -.0010152f, 7.3537e-6f, -.0033437f,
-    4.3246e-6f, 9850.f, 9860.f, 8.7206e-4f, .047547f, -.0041578f,
-    4.2375e-6f, -.007361f, 1.0687e-5f, 9860.f, 9870.f, .0029909f, .069285f,
-    -.0047147f, 1.0991e-5f, -.0056075f, 1.5292e-5f, 9870.f, 9880.f,
-    .001506f, .17429f, .003529f, -1.5241e-5f, 9.8555e-4f, -1.3485e-5f,
-    9880.f, 9890.f, .0024655f, .15187f, -9.6328e-4f, 3.0116e-6f, -.002379f,
-    6.199e-6f, 9890.f, 9900.f, .0081762f, .23349f, -.0033911f, 1.8786e-6f,
-    -.0060119f, 6.563e-6f, 9900.f, 9910.f, .0035952f, .09571f, -.002565f,
-    6.9268e-6f, -.0025302f, 8.7846e-6f, 9910.f, 9920.f, .004102f, .16571f,
-    -8.2348e-4f, 4.4729e-6f, 5.0555e-5f, -1.3431e-6f, 9920.f, 9930.f,
-    .0015616f, .12559f, -.001712f, 9.5737e-7f, -.002329f, 2.8914e-6f,
-    9930.f, 9940.f, .0029147f, .1397f, .0017969f, -5.9773e-6f, .0040034f,
-    -1.6529e-5f, 9940.f, 9950.f, .0021013f, .0985f, .0026194f, -1.629e-5f,
-    .0026829f, -1.8333e-5f, 9950.f, 9960.f, .0025118f, .078548f, -.0011652f,
-    -3.1932e-6f, -.0017647f, -3.6546e-6f, 9960.f, 9970.f, .0054922f,
-    .27847f, .0022288f, -6.2983e-6f, .0011941f, -9.9545e-6f, 9970.f, 9980.f,
-    .0077074f, .24403f, .0023234f, -1.7376e-5f, 9.1247e-4f, -1.6357e-5f,
-    9980.f, 9990.f, .0015919f, .17498f, .004876f, -1.537e-5f, .0030207f,
-    -2.2305e-5f, 9990.f, 1e4f, .0023052f, .12024f, .0026434f, 3.4883e-6f,
-    .0053038f, -7.4735e-6f, 1e4f, 10010.f, 9.9075e-4f, .060379f, .0048519f,
-    -2.4596e-5f, .0039231f, -2.671e-5f, 10010.f, 10020.f, .0026106f,
-    .15994f, .0057076f, -1.5791e-5f, .0063216f, -2.8717e-5f, 10020.f,
-    10030.f, 9.0384e-4f, .21421f, .0073532f, -1.3113e-6f, .009333f,
-    -1.9232e-5f, 10030.f, 10040.f, .0020888f, .22211f, .0093854f,
-    -1.1006e-5f, .0077851f, -1.8919e-5f, 10040.f, 10050.f, .0010096f,
-    .093543f, .0051826f, -2.8108e-5f, .0041051f, -2.3759e-5f, 10050.f,
-    10060.f, .0022561f, .25885f, .013532f, -1.4879e-5f, .011628f,
-    -3.4287e-5f, 10060.f, 10070.f, .0077191f, .28721f, .0097888f,
-    -1.1073e-5f, .008539f, -2.4771e-5f, 10070.f, 10080.f, .0034195f,
-    .20647f, .0074823f, -2.1978e-5f, .007444f, -2.4751e-5f, 10080.f,
-    10090.f, .0063694f, .19871f, .011877f, -3.28e-5f, .009567f, -3.9672e-5f,
-    10090.f, 10100.f, .0063072f, .3731f, .0047744f, 2.8648e-5f, .006887f,
-    -8.4982e-6f, 10100.f, 10110.f, .0010617f, .15783f, .019027f,
-    -3.7386e-5f, .017346f, -6.0605e-5f, 10110.f, 10120.f, .016376f, .34661f,
-    .014148f, -4.8223e-5f, .010187f, -4.3401e-5f, 10120.f, 10130.f,
-    .0077156f, .39174f, .0071212f, 8.3584e-6f, .0074196f, -2.0778e-5f,
-    10130.f, 10140.f, .0081991f, .34376f, .010657f, -2.049e-5f, .009186f,
-    -3.4657e-5f, 10140.f, 10150.f, .045748f, .35631f, .011031f, -4.1938e-5f,
-    .0079877f, -3.3077e-5f, 10150.f, 10160.f, .026803f, .2161f, .011739f,
-    -5.3624e-5f, .010169f, -5.0362e-5f, 10160.f, 10170.f, .061462f, .24685f,
-    .008227f, -3.1656e-5f, .0077778f, -3.1665e-5f, 10170.f, 10180.f
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9640.f, 9650.f, 1.9405e-4f, .0908f,
+				     .012893f,
+				     -4.7907e-5f, .008999f, -4.3597e-5f, 9650.f, 9660.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 9660.f, 9670.f, 3.5455e-4f, .062906f, .01178f, -5.9514e-5f,
+				     .0090225f, -5.3961e-5f, 9670.f, 9680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     9680.f, 9690.f, 7.3346e-4f, .095357f, .0080776f, -3.5126e-5f, .0063761f,
+				     -3.2075e-5f, 9690.f, 9700.f, 2.6888e-4f, .062321f, .01172f, -5.6759e-5f,
+				     .0098726f, -5.5238e-5f, 9700.f, 9710.f, 4.8999e-4f, .10498f, .0062757f,
+				     -3.2864e-5f, .0049464f, -3.2626e-5f, 9710.f, 9720.f, .0010507f,
+				     .071841f, .0058574f, -3.2015e-5f, .0039666f, -3.1106e-5f, 9720.f,
+				     9730.f, .0025494f, .10376f, .0030444f, -2.0413e-5f, .0012384f,
+				     -1.8532e-5f, 9730.f, 9740.f, .0013019f, .13387f, .0019451f, -1.3612e-5f,
+				     -8.9213e-6f, -1.3158e-5f, 9740.f, 9750.f, 6.2353e-4f, .078233f,
+				     7.0756e-4f, -1.519e-5f, -.0020739f, -9.6993e-6f, 9750.f, 9760.f,
+				     .0056535f, .1971f, 1.6071e-4f, -5.7489e-6f, -.0014878f, -4.8238e-6f,
+				     9760.f, 9770.f, .001909f, .041123f, -.0019069f, -4.7662e-6f, -.004664f,
+				     7.8558e-7f, 9770.f, 9780.f, .0017619f, .13162f, -.0022639f, 7.7041e-7f,
+				     -.0049756f, 4.3744e-6f, 9780.f, 9790.f, 5.7144e-4f, .099432f, .0040501f,
+				     -1.5471e-5f, .0018591f, -1.7658e-5f, 9790.f, 9800.f, .0038209f, .13329f,
+				     -.0046298f, 6.3691e-6f, -.0077028f, 1.2343e-5f, 9800.f, 9810.f,
+				     .0017147f, .079407f, 4.5502e-4f, -1.3444e-5f, -.0030355f, -5.7728e-6f,
+				     9810.f, 9820.f, .0012145f, .072418f, 2.5064e-4f, -5.9535e-6f,
+				     3.3766e-6f, -6.2695e-6f, 9820.f, 9830.f, .0011057f, .13614f, .0018444f,
+				     -3.817e-6f, -6.6263e-4f, -6.1358e-6f, 9830.f, 9840.f, .0021971f,
+				     .053016f, -.0048189f, 9.7527e-6f, -.0060279f, 1.7406e-5f, 9840.f,
+				     9850.f, .0019933f, .17956f, -.0010152f, 7.3537e-6f, -.0033437f,
+				     4.3246e-6f, 9850.f, 9860.f, 8.7206e-4f, .047547f, -.0041578f,
+				     4.2375e-6f, -.007361f, 1.0687e-5f, 9860.f, 9870.f, .0029909f, .069285f,
+				     -.0047147f, 1.0991e-5f, -.0056075f, 1.5292e-5f, 9870.f, 9880.f,
+				     .001506f, .17429f, .003529f, -1.5241e-5f, 9.8555e-4f, -1.3485e-5f,
+				     9880.f, 9890.f, .0024655f, .15187f, -9.6328e-4f, 3.0116e-6f, -.002379f,
+				     6.199e-6f, 9890.f, 9900.f, .0081762f, .23349f, -.0033911f, 1.8786e-6f,
+				     -.0060119f, 6.563e-6f, 9900.f, 9910.f, .0035952f, .09571f, -.002565f,
+				     6.9268e-6f, -.0025302f, 8.7846e-6f, 9910.f, 9920.f, .004102f, .16571f,
+				     -8.2348e-4f, 4.4729e-6f, 5.0555e-5f, -1.3431e-6f, 9920.f, 9930.f,
+				     .0015616f, .12559f, -.001712f, 9.5737e-7f, -.002329f, 2.8914e-6f,
+				     9930.f, 9940.f, .0029147f, .1397f, .0017969f, -5.9773e-6f, .0040034f,
+				     -1.6529e-5f, 9940.f, 9950.f, .0021013f, .0985f, .0026194f, -1.629e-5f,
+				     .0026829f, -1.8333e-5f, 9950.f, 9960.f, .0025118f, .078548f, -.0011652f,
+				     -3.1932e-6f, -.0017647f, -3.6546e-6f, 9960.f, 9970.f, .0054922f,
+				     .27847f, .0022288f, -6.2983e-6f, .0011941f, -9.9545e-6f, 9970.f, 9980.f,
+				     .0077074f, .24403f, .0023234f, -1.7376e-5f, 9.1247e-4f, -1.6357e-5f,
+				     9980.f, 9990.f, .0015919f, .17498f, .004876f, -1.537e-5f, .0030207f,
+				     -2.2305e-5f, 9990.f, 1e4f, .0023052f, .12024f, .0026434f, 3.4883e-6f,
+				     .0053038f, -7.4735e-6f, 1e4f, 10010.f, 9.9075e-4f, .060379f, .0048519f,
+				     -2.4596e-5f, .0039231f, -2.671e-5f, 10010.f, 10020.f, .0026106f,
+				     .15994f, .0057076f, -1.5791e-5f, .0063216f, -2.8717e-5f, 10020.f,
+				     10030.f, 9.0384e-4f, .21421f, .0073532f, -1.3113e-6f, .009333f,
+				     -1.9232e-5f, 10030.f, 10040.f, .0020888f, .22211f, .0093854f,
+				     -1.1006e-5f, .0077851f, -1.8919e-5f, 10040.f, 10050.f, .0010096f,
+				     .093543f, .0051826f, -2.8108e-5f, .0041051f, -2.3759e-5f, 10050.f,
+				     10060.f, .0022561f, .25885f, .013532f, -1.4879e-5f, .011628f,
+				     -3.4287e-5f, 10060.f, 10070.f, .0077191f, .28721f, .0097888f,
+				     -1.1073e-5f, .008539f, -2.4771e-5f, 10070.f, 10080.f, .0034195f,
+				     .20647f, .0074823f, -2.1978e-5f, .007444f, -2.4751e-5f, 10080.f,
+				     10090.f, .0063694f, .19871f, .011877f, -3.28e-5f, .009567f, -3.9672e-5f,
+				     10090.f, 10100.f, .0063072f, .3731f, .0047744f, 2.8648e-5f, .006887f,
+				     -8.4982e-6f, 10100.f, 10110.f, .0010617f, .15783f, .019027f,
+				     -3.7386e-5f, .017346f, -6.0605e-5f, 10110.f, 10120.f, .016376f, .34661f,
+				     .014148f, -4.8223e-5f, .010187f, -4.3401e-5f, 10120.f, 10130.f,
+				     .0077156f, .39174f, .0071212f, 8.3584e-6f, .0074196f, -2.0778e-5f,
+				     10130.f, 10140.f, .0081991f, .34376f, .010657f, -2.049e-5f, .009186f,
+				     -3.4657e-5f, 10140.f, 10150.f, .045748f, .35631f, .011031f, -4.1938e-5f,
+				     .0079877f, -3.3077e-5f, 10150.f, 10160.f, .026803f, .2161f, .011739f,
+				     -5.3624e-5f, .010169f, -5.0362e-5f, 10160.f, 10170.f, .061462f, .24685f,
+				     .008227f, -3.1656e-5f, .0077778f, -3.1665e-5f, 10170.f, 10180.f
-	/* WATER VAPOR (7620 - 10160 CM-1) */
+    /* WATER VAPOR (7620 - 10160 CM-1) */
 }	/* wava3 */
 void
@@ -1325,315 +1325,315 @@
-  static const float acr[2048] = { .32591f, .48473f,
-    .010062f, 1.8245e-5f, .01189f, -1.2621e-5f, 5060.f, 5070.f, .73059f,
-    .13181f, .010626f, 7.3795e-6f, .011376f, -1.7764e-5f, 5070.f, 5080.f,
-    .39211f, .39522f, .01459f, -6.8376e-6f, .016326f, -3.165e-5f, 5080.f,
-    5090.f, 2.3255f, .26901f, .0092468f, 6.3821e-6f, .0083396f, -1.2628e-5f,
-    5090.f, 5100.f, 1.9706f, .34245f, .0056073f, -9.4265e-8f, .0059986f,
-    -1.0398e-5f, 5100.f, 5110.f, 2.8938f, .22738f, .022463f, -9.7912e-5f,
-    .021063f, -8.8497e-5f, 5110.f, 5120.f, 1.1454f, .40811f, .0089642f,
-    -5.1753e-6f, .0089863f, -1.9479e-5f, 5120.f, 5130.f, 2.92f, .33384f,
-    .014298f, -3.2571e-5f, .012431f, -3.5993e-5f, 5130.f, 5140.f, 6.318f,
-    .28323f, .0099085f, -1.94e-5f, .0060737f, -1.671e-5f, 5140.f, 5150.f,
-    14.918f, .41681f, .012935f, -5.2738e-5f, .010041f, -4.0263e-5f, 5150.f,
-    5160.f, 10.19f, .13237f, .011091f, -4.8728e-5f, .0081335f, -2.7045e-5f,
-    5160.f, 5170.f, 14.437f, .36156f, .0094685f, -3.4308e-5f, .0067537f,
-    -2.4477e-5f, 5170.f, 5180.f, 34.792f, .30287f, .0073719f, -3.7632e-5f,
-    .0051901f, -2.8247e-5f, 5180.f, 5190.f, 21.869f, .22075f, .0069763f,
-    -3.1715e-5f, .0041088f, -1.7042e-5f, 5190.f, 5200.f, 94.938f, .25888f,
-    .0046429f, -2.8823e-5f, .0034889f, -2.3494e-5f, 5200.f, 5210.f, 18.298f,
-    .20311f, .0050431f, -2.4681e-5f, .0028469f, -1.707e-5f, 5210.f, 5220.f,
-    69.538f, .19126f, .002196f, -2.0268e-5f, 6.875e-4f, -1.7413e-5f, 5220.f,
-    5230.f, 40.772f, .23521f, .0018896f, -1.692e-5f, 5.9126e-4f,
-    -1.3609e-5f, 5230.f, 5240.f, 131.08f, .17928f, 1.5657e-4f, -1.2114e-5f,
-    -.0017405f, -8.3108e-6f, 5240.f, 5250.f, 69.597f, .10896f, -.0015337f,
+    static const float acr[2048] = { .32591f, .48473f,
+				     .010062f, 1.8245e-5f, .01189f, -1.2621e-5f, 5060.f, 5070.f, .73059f,
+				     .13181f, .010626f, 7.3795e-6f, .011376f, -1.7764e-5f, 5070.f, 5080.f,
+				     .39211f, .39522f, .01459f, -6.8376e-6f, .016326f, -3.165e-5f, 5080.f,
+				     5090.f, 2.3255f, .26901f, .0092468f, 6.3821e-6f, .0083396f, -1.2628e-5f,
+				     5090.f, 5100.f, 1.9706f, .34245f, .0056073f, -9.4265e-8f, .0059986f,
+				     -1.0398e-5f, 5100.f, 5110.f, 2.8938f, .22738f, .022463f, -9.7912e-5f,
+				     .021063f, -8.8497e-5f, 5110.f, 5120.f, 1.1454f, .40811f, .0089642f,
+				     -5.1753e-6f, .0089863f, -1.9479e-5f, 5120.f, 5130.f, 2.92f, .33384f,
+				     .014298f, -3.2571e-5f, .012431f, -3.5993e-5f, 5130.f, 5140.f, 6.318f,
+				     .28323f, .0099085f, -1.94e-5f, .0060737f, -1.671e-5f, 5140.f, 5150.f,
+				     14.918f, .41681f, .012935f, -5.2738e-5f, .010041f, -4.0263e-5f, 5150.f,
+				     5160.f, 10.19f, .13237f, .011091f, -4.8728e-5f, .0081335f, -2.7045e-5f,
+				     5160.f, 5170.f, 14.437f, .36156f, .0094685f, -3.4308e-5f, .0067537f,
+				     -2.4477e-5f, 5170.f, 5180.f, 34.792f, .30287f, .0073719f, -3.7632e-5f,
+				     .0051901f, -2.8247e-5f, 5180.f, 5190.f, 21.869f, .22075f, .0069763f,
+				     -3.1715e-5f, .0041088f, -1.7042e-5f, 5190.f, 5200.f, 94.938f, .25888f,
+				     .0046429f, -2.8823e-5f, .0034889f, -2.3494e-5f, 5200.f, 5210.f, 18.298f,
+				     .20311f, .0050431f, -2.4681e-5f, .0028469f, -1.707e-5f, 5210.f, 5220.f,
+				     69.538f, .19126f, .002196f, -2.0268e-5f, 6.875e-4f, -1.7413e-5f, 5220.f,
+				     5230.f, 40.772f, .23521f, .0018896f, -1.692e-5f, 5.9126e-4f,
+				     -1.3609e-5f, 5230.f, 5240.f, 131.08f, .17928f, 1.5657e-4f, -1.2114e-5f,
+				     -.0017405f, -8.3108e-6f, 5240.f, 5250.f, 69.597f, .10896f, -.0015337f,
-    -4.7461e-6f, -.0027082f, -1.5598e-6f, 5250.f, 5260.f, 153.51f, .20025f,
-    -.0022803f, -2.9253e-6f, -.004398f, 2.8697e-6f, 5260.f, 5270.f, 2.6114f,
-    .24878f, -8.2927e-4f, 4.6226e-6f, -1.1922e-4f, 1.0717e-5f, 5270.f,
-    5280.f, 48.681f, .175f, -.0037857f, 4.6902e-6f, -.0036353f, 1.1426e-5f,
-    5280.f, 5290.f, 77.56f, .13557f, -.0037228f, 3.6212e-6f, -.0041326f,
-    1.5278e-5f, 5290.f, 5300.f, 60.444f, .1151f, -.0047324f, 1.0254e-5f,
-    -.0036821f, 1.4636e-5f, 5300.f, 5310.f, 15.328f, .19998f, -.0012681f,
-    2.9898e-6f, -4.683e-4f, 2.0999e-6f, 5310.f, 5320.f, 87.54f, .16972f,
-    -.0041972f, 7.1961e-6f, -.0037508f, 7.0298e-6f, 5320.f, 5330.f, 195.61f,
-    .26284f, -.0023874f, -2.1407e-7f, -.0037245f, 4.6625e-6f, 5330.f,
-    5340.f, 168.41f, .26546f, 2.4931e-4f, -9.4775e-6f, -.0016338f,
-    -6.291e-6f, 5340.f, 5350.f, 93.921f, .31129f, .0028343f, -7.1173e-6f,
-    .0026325f, -1.1816e-5f, 5350.f, 5360.f, 25.579f, .36877f, .0072262f,
-    -1.5821e-5f, .0060257f, -2.1996e-5f, 5360.f, 5370.f, 137.79f, .17089f,
-    -.004665f, 1.3962e-5f, -.002641f, 1.792e-5f, 5370.f, 5380.f, 84.199f,
-    .12293f, -.0039643f, 9.7938e-6f, -.0017023f, 1.5901e-5f, 5380.f, 5390.f,
-    140.72f, .10478f, -.0041237f, 5.0169e-6f, -.0043789f, 1.7244e-5f,
-    5390.f, 5400.f, 56.622f, .23084f, -.0025409f, -2.9811e-7f, -.0027639f,
-    7.6091e-6f, 5400.f, 5410.f, 185.34f, .21363f, -.0028691f, -4.4392e-7f,
-    -.0042358f, 6.6265e-6f, 5410.f, 5420.f, 96.955f, .12223f, -5.2081e-4f,
-    -9.6057e-6f, -.0016418f, -1.9789e-6f, 5420.f, 5430.f, 117.89f, .13571f,
-    -.0014763f, -5.7081e-6f, -.0024763f, -1.7817e-7f, 5430.f, 5440.f,
-    191.02f, .24199f, 6.976e-4f, -1.4228e-5f, -.001445f, -7.5253e-6f,
-    5440.f, 5450.f, 22.138f, .14268f, .0012465f, -1.3898e-5f, .00202f,
-    -8.418e-6f, 5450.f, 5460.f, 95.115f, .24823f, .0035551f, -2.5604e-5f,
-    .0012041f, -1.8465e-5f, 5460.f, 5470.f, 62.976f, .15811f, .0050592f,
-    -2.9507e-5f, .0029262f, -2.138e-5f, 5470.f, 5480.f, 29.147f, .11805f,
-    .008422f, -4.2987e-5f, .0067418f, -3.6032e-5f, 5480.f, 5490.f, 51.614f,
-    .19818f, .0058436f, -3.46e-5f, .003939f, -2.8598e-5f, 5490.f, 5500.f,
-    23.266f, .1679f, .011075f, -5.348e-5f, .0084735f, -4.6037e-5f, 5500.f,
-    5510.f, 10.989f, .20302f, .0063972f, -1.4524e-5f, .0042223f,
-    -2.0806e-5f, 5510.f, 5520.f, 10.027f, .16542f, .013794f, -6.332e-5f,
-    .011093f, -5.5041e-5f, 5520.f, 5530.f, 9.3954f, .21952f, .013366f,
-    -5.7474e-5f, .0098104f, -4.6605e-5f, 5530.f, 5540.f, 4.2252f, .19874f,
-    .016633f, -7.121e-5f, .01335f, -6.0705e-5f, 5540.f, 5550.f, 6.2656f,
-    .26354f, .0098363f, -9.5486e-6f, .0079542f, -2.4062e-5f, 5550.f, 5560.f,
-    1.6378f, .16463f, .013976f, -8.3427e-6f, .012806f, -3.571e-5f, 5560.f,
-    5570.f, 1.9767f, .27227f, .014721f, -2.6094e-5f, .012774f, -4.5522e-5f,
-    5570.f, 5580.f, .586f, .20958f, .012874f, 3.9258e-5f, .011964f,
-    -1.5397e-5f, 5580.f, 5590.f, .73058f, .24104f, .02517f, -9.8784e-5f,
-    .021222f, -8.5036e-5f, 5590.f, 5600.f, 1.3668f, .20354f, .00746f,
-    -5.4501e-6f, .010036f, -2.7451e-5f, 5600.f, 5610.f, .7017f, .14013f,
-    .0054963f, 1.2171e-5f, .010386f, -5.7235e-6f, 5610.f, 5620.f, .97806f,
-    .19171f, .0021812f, 1.6431e-5f, .0066588f, 9.5186e-6f, 5620.f, 5630.f,
-    .29391f, .23855f, .0090316f, 2.3604e-5f, .012635f, -6.6897e-6f, 5630.f,
-    5640.f, .15354f, .15176f, .0057073f, 2e-5f, .014561f, -4.0698e-6f,
-    5640.f, 5650.f, .08073f, .28405f, .014753f, 3.439e-5f, .018447f,
-    -1.775e-5f, 5650.f, 5660.f, .86381f, .14813f, .0029607f, -2.0586e-5f,
-    .0028212f, -1.2594e-5f, 5660.f, 5670.f, .22599f, .16383f, .0084407f,
-    -3.2709e-5f, .011049f, -1.6279e-5f, 5670.f, 5680.f, .0030594f, .17069f,
-    .034284f, -1.0113e-4f, .035042f, -1.1247e-4f, 5680.f, 5690.f, .38291f,
-    .16459f, .0096772f, -4.3054e-5f, .0087884f, -3.2862e-5f, 5690.f, 5700.f,
-    .17817f, .065371f, .0044945f, -2.6954e-5f, .0044075f, 7.1895e-7f,
-    5700.f, 5710.f, .0073272f, .32673f, .018605f, -3.6631e-5f, .021288f,
-    -5.004e-5f, 5710.f, 5720.f, .33773f, .13375f, .0060665f, -3.0734e-5f,
-    .0046922f, -2.5584e-5f, 5720.f, 5730.f, .083205f, .058895f, .0083229f,
-    -4.2023e-5f, .0099661f, -2.959e-5f, 5730.f, 5740.f, .1796f, .1205f,
-    .0065668f, -3.475e-5f, .004411f, -2.7489e-5f, 5740.f, 5750.f, .074406f,
-    .16592f, .012426f, -4.4049e-5f, .012086f, -4.8157e-5f, 5750.f, 5760.f,
-    .029803f, .065159f, .011506f, -5.4589e-5f, .012823f, -5.1753e-5f,
-    5760.f, 5770.f, .134f, .079723f, .011174f, -5.413e-5f, .010639f,
-    -4.7462e-5f, 5770.f, 5780.f, .027397f, .11303f, .0070869f, -8.5837e-6f,
-    .0087642f, -2.4197e-5f, 5780.f, 5790.f, .04813f, .1528f, .017121f,
-    -6.8541e-5f, .016166f, -7.1739e-5f, 5790.f, 5800.f, .098878f, .11702f,
-    .011647f, -5.4757e-5f, .0095467f, -4.9145e-5f, 5800.f, 5810.f,
-    .0011937f, .11746f, .029514f, -1.178e-4f, .026592f, -1.0438e-4f, 5810.f,
-    5820.f, .021084f, .041603f, .018136f, -8.3736e-5f, .01662f, -7.5802e-5f,
-    5820.f, 5830.f, .041859f, .10038f, .011698f, -5.1084e-5f, .0091292f,
-    -3.8447e-5f, 5830.f, 5840.f, .0042835f, .054158f, .020564f, -7.9064e-5f,
-    .016849f, -6.1318e-5f, 5840.f, 5850.f, .039742f, .14212f, .015543f,
-    -6.5164e-5f, .012937f, -6.0213e-5f, 5850.f, 5860.f, .0044465f, .13575f,
-    .018218f, -6.1185e-5f, .017472f, -6.1811e-5f, 5860.f, 5870.f, .013183f,
-    .084879f, .018786f, -7.5902e-5f, .01503f, -6.7738e-5f, 5870.f, 5880.f,
-    .0036488f, .086695f, .023765f, -7.6455e-5f, .019459f, -6.0338e-5f,
-    5880.f, 5890.f, .018172f, .13595f, .016681f, -5.4016e-5f, .014894f,
-    -6.0543e-5f, 5890.f, 5900.f, .0024118f, .072933f, .025664f, -9.6848e-5f,
-    .026465f, -1.0476e-4f, 5900.f, 5910.f, .01494f, .1207f, .017582f,
-    -6.8945e-5f, .016946f, -6.9945e-5f, 5910.f, 5920.f, .0014531f, .081478f,
-    .02565f, -5.6688e-5f, .020849f, -5.2418e-5f, 5920.f, 5930.f, .004057f,
-    .064725f, .024344f, -1.0574e-4f, .021209f, -9.2148e-5f, 5930.f, 5940.f,
-    5.9362e-4f, .052682f, .023362f, -8.193e-5f, .01857f, -7.6269e-5f,
-    5940.f, 5950.f, .0021418f, .075485f, .023733f, -8.0625e-5f, .021119f,
-    -8.5514e-5f, 5950.f, 5960.f, .0033439f, .12209f, .022556f, -8.973e-5f,
-    .019031f, -8.5459e-5f, 5960.f, 5970.f, .0014641f, .13608f, .015568f,
-    3.7809e-6f, .01603f, -2.9177e-5f, 5970.f, 5980.f, 6.3999e-4f, .094011f,
-    .027455f, -3.9873e-5f, .019599f, -3.6883e-5f, 5980.f, 5990.f, .0013405f,
-    .090254f, .029576f, -1.1767e-4f, .026759f, -1.1158e-4f, 5990.f, 6e3f,
-    .0017604f, .17547f, .017851f, -6.4948e-5f, .016287f, -5.6437e-5f, 6e3f,
-    6010.f, .0011569f, .13348f, .026563f, -8.7926e-5f, .023528f,
-    -9.1174e-5f, 6010.f, 6020.f, 2.8575e-4f, .078833f, .019053f,
-    -1.8306e-5f, .018303f, -5.1186e-5f, 6020.f, 6030.f, 8.7532e-4f, .16112f,
-    .022556f, -3.3852e-5f, .021206f, -6.4336e-5f, 6030.f, 6040.f,
-    4.8531e-4f, .054398f, .022035f, -9.7698e-5f, .019943f, -8.9334e-5f,
-    6040.f, 6050.f, 4.2083e-4f, .13305f, .011783f, 6.0192e-5f, .01191f,
-    7.0965e-6f, 6050.f, 6060.f, 3.1283e-4f, .10974f, .024828f, -3.5695e-5f,
-    .021926f, -6.102e-5f, 6060.f, 6070.f, .0016917f, .14682f, .0023913f,
-    1.937e-5f, .0028143f, 1.0914e-5f, 6070.f, 6080.f, 2.4107e-4f, .056225f,
-    .019103f, -5.8306e-6f, .02305f, -4.6373e-5f, 6080.f, 6090.f, 4.4079e-4f,
-    .073062f, .0078845f, -3.8279e-5f, .0064841f, -2.5252e-5f, 6090.f,
-    6100.f, 1.7156e-4f, .08447f, .010336f, 1.0341e-4f, .0085994f,
-    4.3979e-5f, 6100.f, 6110.f, 1.5736e-4f, .047359f, .020348f, -3.159e-5f,
-    .024132f, -5.6992e-5f, 6110.f, 6120.f, .0010666f, .13835f, .0061165f,
-    -8.7157e-6f, .0071462f, -1.5e-5f, 6120.f, 6130.f, 4.1402e-5f, .071564f,
-    .014541f, -3.0661e-5f, .013703f, -3.2448e-5f, 6130.f, 6140.f,
-    1.6673e-5f, .033602f, .019118f, -8.8866e-5f, .016523f, -8.3641e-5f,
-    6140.f, 6150.f, 4.5173e-4f, .19416f, .0081406f, -4.6697e-6f, .0096975f,
-    -2.7594e-5f, 6150.f, 6160.f, 8.4192e-5f, .0848f, .0068868f, 2.0465e-5f,
-    .0065557f, -3.9158e-6f, 6160.f, 6170.f, 1.9983e-4f, .034955f, .013243f,
-    -4.8483e-5f, .014163f, -4.8663e-5f, 6170.f, 6180.f, 5.654e-4f, .092508f,
-    .0032982f, -2.8242e-7f, .0023537f, -1.1797e-5f, 6180.f, 6190.f,
-    2.6602e-4f, .14864f, -.0035881f, 8.4292e-6f, -.0064288f, 1.1323e-5f,
-    6190.f, 6200.f, 6.6332e-4f, .082351f, 4.0475e-5f, -9.1191e-6f,
-    -.0013832f, -7.433e-7f, 6200.f, 6210.f, 5.089e-4f, .13947f, .003362f,
-    -3.1112e-6f, 4.078e-4f, 8.6176e-7f, 6210.f, 6220.f, 1.2815e-4f,
-    .087906f, .012262f, -4.0572e-5f, .01202f, -4.9984e-5f, 6220.f, 6230.f,
-    1.2854e-4f, .12035f, .0025735f, -1.5152e-5f, -2.5291e-4f, -1.3133e-5f,
-    6230.f, 6240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6240.f, 6250.f, 3.8748e-4f,
-    .088892f, .0070553f, -2.9374e-5f, .0061982f, -3.1937e-5f, 6250.f,
-    6260.f, 1.6711e-4f, .096035f, .013535f, -5.983e-5f, .011956f,
-    -5.7292e-5f, 6260.f, 6270.f, 5.1664e-4f, .11783f, .0086933f,
-    -2.7481e-5f, .0070865f, -2.8728e-5f, 6270.f, 6280.f, .001613f, .21378f,
-    .0034321f, -1.5373e-5f, .0028098f, -8.7169e-6f, 6280.f, 6290.f,
-    1.104e-4f, .05027f, .011461f, -5.2791e-5f, .010667f, -5.0501e-5f,
-    6290.f, 6300.f, .0022339f, .16944f, .0043566f, -1.8834e-5f, .0025925f,
-    -1.7523e-5f, 6300.f, 6310.f, 7.0293e-4f, .10055f, .0086229f,
-    -3.5378e-5f, .0057065f, -3.2557e-5f, 6310.f, 6320.f, 2.805e-4f, .12764f,
-    .0056648f, 7.4065e-5f, .0085368f, 1.7469e-5f, 6320.f, 6330.f,
-    6.2308e-4f, .089292f, .01011f, -2.8113e-5f, .010994f, -3.9797e-5f,
-    6330.f, 6340.f, 4.9924e-4f, .15704f, .014233f, -5.3536e-5f, .011904f,
-    -5.3159e-5f, 6340.f, 6350.f, 4.5485e-4f, .2206f, .0045598f, -2.1706e-6f,
-    .0040803f, -1.9834e-5f, 6350.f, 6360.f, 4.4859e-4f, .31977f, .015688f,
-    -3.0431e-5f, .012918f, -4.8166e-5f, 6360.f, 6370.f, 2.7811e-4f, .13882f,
-    .011781f, -2.0096e-5f, .011797f, -2.376e-5f, 6370.f, 6380.f, 8.6844e-4f,
-    .2569f, .011839f, -6.454e-6f, .0097827f, -2.9934e-5f, 6380.f, 6390.f,
-    8.4205e-4f, .26741f, .010125f, -9.2493e-6f, .009507f, -2.6314e-5f,
-    6390.f, 6400.f, .0016976f, .15422f, .0095094f, 1.9053e-5f, .010682f,
-    -7.9536e-6f, 6400.f, 6410.f, 4.7975e-4f, .09426f, .011121f, -4.7922e-5f,
-    .0093837f, -4.1295e-5f, 6410.f, 6420.f, 5.2022e-4f, .16038f, .017528f,
+				     -4.7461e-6f, -.0027082f, -1.5598e-6f, 5250.f, 5260.f, 153.51f, .20025f,
+				     -.0022803f, -2.9253e-6f, -.004398f, 2.8697e-6f, 5260.f, 5270.f, 2.6114f,
+				     .24878f, -8.2927e-4f, 4.6226e-6f, -1.1922e-4f, 1.0717e-5f, 5270.f,
+				     5280.f, 48.681f, .175f, -.0037857f, 4.6902e-6f, -.0036353f, 1.1426e-5f,
+				     5280.f, 5290.f, 77.56f, .13557f, -.0037228f, 3.6212e-6f, -.0041326f,
+				     1.5278e-5f, 5290.f, 5300.f, 60.444f, .1151f, -.0047324f, 1.0254e-5f,
+				     -.0036821f, 1.4636e-5f, 5300.f, 5310.f, 15.328f, .19998f, -.0012681f,
+				     2.9898e-6f, -4.683e-4f, 2.0999e-6f, 5310.f, 5320.f, 87.54f, .16972f,
+				     -.0041972f, 7.1961e-6f, -.0037508f, 7.0298e-6f, 5320.f, 5330.f, 195.61f,
+				     .26284f, -.0023874f, -2.1407e-7f, -.0037245f, 4.6625e-6f, 5330.f,
+				     5340.f, 168.41f, .26546f, 2.4931e-4f, -9.4775e-6f, -.0016338f,
+				     -6.291e-6f, 5340.f, 5350.f, 93.921f, .31129f, .0028343f, -7.1173e-6f,
+				     .0026325f, -1.1816e-5f, 5350.f, 5360.f, 25.579f, .36877f, .0072262f,
+				     -1.5821e-5f, .0060257f, -2.1996e-5f, 5360.f, 5370.f, 137.79f, .17089f,
+				     -.004665f, 1.3962e-5f, -.002641f, 1.792e-5f, 5370.f, 5380.f, 84.199f,
+				     .12293f, -.0039643f, 9.7938e-6f, -.0017023f, 1.5901e-5f, 5380.f, 5390.f,
+				     140.72f, .10478f, -.0041237f, 5.0169e-6f, -.0043789f, 1.7244e-5f,
+				     5390.f, 5400.f, 56.622f, .23084f, -.0025409f, -2.9811e-7f, -.0027639f,
+				     7.6091e-6f, 5400.f, 5410.f, 185.34f, .21363f, -.0028691f, -4.4392e-7f,
+				     -.0042358f, 6.6265e-6f, 5410.f, 5420.f, 96.955f, .12223f, -5.2081e-4f,
+				     -9.6057e-6f, -.0016418f, -1.9789e-6f, 5420.f, 5430.f, 117.89f, .13571f,
+				     -.0014763f, -5.7081e-6f, -.0024763f, -1.7817e-7f, 5430.f, 5440.f,
+				     191.02f, .24199f, 6.976e-4f, -1.4228e-5f, -.001445f, -7.5253e-6f,
+				     5440.f, 5450.f, 22.138f, .14268f, .0012465f, -1.3898e-5f, .00202f,
+				     -8.418e-6f, 5450.f, 5460.f, 95.115f, .24823f, .0035551f, -2.5604e-5f,
+				     .0012041f, -1.8465e-5f, 5460.f, 5470.f, 62.976f, .15811f, .0050592f,
+				     -2.9507e-5f, .0029262f, -2.138e-5f, 5470.f, 5480.f, 29.147f, .11805f,
+				     .008422f, -4.2987e-5f, .0067418f, -3.6032e-5f, 5480.f, 5490.f, 51.614f,
+				     .19818f, .0058436f, -3.46e-5f, .003939f, -2.8598e-5f, 5490.f, 5500.f,
+				     23.266f, .1679f, .011075f, -5.348e-5f, .0084735f, -4.6037e-5f, 5500.f,
+				     5510.f, 10.989f, .20302f, .0063972f, -1.4524e-5f, .0042223f,
+				     -2.0806e-5f, 5510.f, 5520.f, 10.027f, .16542f, .013794f, -6.332e-5f,
+				     .011093f, -5.5041e-5f, 5520.f, 5530.f, 9.3954f, .21952f, .013366f,
+				     -5.7474e-5f, .0098104f, -4.6605e-5f, 5530.f, 5540.f, 4.2252f, .19874f,
+				     .016633f, -7.121e-5f, .01335f, -6.0705e-5f, 5540.f, 5550.f, 6.2656f,
+				     .26354f, .0098363f, -9.5486e-6f, .0079542f, -2.4062e-5f, 5550.f, 5560.f,
+				     1.6378f, .16463f, .013976f, -8.3427e-6f, .012806f, -3.571e-5f, 5560.f,
+				     5570.f, 1.9767f, .27227f, .014721f, -2.6094e-5f, .012774f, -4.5522e-5f,
+				     5570.f, 5580.f, .586f, .20958f, .012874f, 3.9258e-5f, .011964f,
+				     -1.5397e-5f, 5580.f, 5590.f, .73058f, .24104f, .02517f, -9.8784e-5f,
+				     .021222f, -8.5036e-5f, 5590.f, 5600.f, 1.3668f, .20354f, .00746f,
+				     -5.4501e-6f, .010036f, -2.7451e-5f, 5600.f, 5610.f, .7017f, .14013f,
+				     .0054963f, 1.2171e-5f, .010386f, -5.7235e-6f, 5610.f, 5620.f, .97806f,
+				     .19171f, .0021812f, 1.6431e-5f, .0066588f, 9.5186e-6f, 5620.f, 5630.f,
+				     .29391f, .23855f, .0090316f, 2.3604e-5f, .012635f, -6.6897e-6f, 5630.f,
+				     5640.f, .15354f, .15176f, .0057073f, 2e-5f, .014561f, -4.0698e-6f,
+				     5640.f, 5650.f, .08073f, .28405f, .014753f, 3.439e-5f, .018447f,
+				     -1.775e-5f, 5650.f, 5660.f, .86381f, .14813f, .0029607f, -2.0586e-5f,
+				     .0028212f, -1.2594e-5f, 5660.f, 5670.f, .22599f, .16383f, .0084407f,
+				     -3.2709e-5f, .011049f, -1.6279e-5f, 5670.f, 5680.f, .0030594f, .17069f,
+				     .034284f, -1.0113e-4f, .035042f, -1.1247e-4f, 5680.f, 5690.f, .38291f,
+				     .16459f, .0096772f, -4.3054e-5f, .0087884f, -3.2862e-5f, 5690.f, 5700.f,
+				     .17817f, .065371f, .0044945f, -2.6954e-5f, .0044075f, 7.1895e-7f,
+				     5700.f, 5710.f, .0073272f, .32673f, .018605f, -3.6631e-5f, .021288f,
+				     -5.004e-5f, 5710.f, 5720.f, .33773f, .13375f, .0060665f, -3.0734e-5f,
+				     .0046922f, -2.5584e-5f, 5720.f, 5730.f, .083205f, .058895f, .0083229f,
+				     -4.2023e-5f, .0099661f, -2.959e-5f, 5730.f, 5740.f, .1796f, .1205f,
+				     .0065668f, -3.475e-5f, .004411f, -2.7489e-5f, 5740.f, 5750.f, .074406f,
+				     .16592f, .012426f, -4.4049e-5f, .012086f, -4.8157e-5f, 5750.f, 5760.f,
+				     .029803f, .065159f, .011506f, -5.4589e-5f, .012823f, -5.1753e-5f,
+				     5760.f, 5770.f, .134f, .079723f, .011174f, -5.413e-5f, .010639f,
+				     -4.7462e-5f, 5770.f, 5780.f, .027397f, .11303f, .0070869f, -8.5837e-6f,
+				     .0087642f, -2.4197e-5f, 5780.f, 5790.f, .04813f, .1528f, .017121f,
+				     -6.8541e-5f, .016166f, -7.1739e-5f, 5790.f, 5800.f, .098878f, .11702f,
+				     .011647f, -5.4757e-5f, .0095467f, -4.9145e-5f, 5800.f, 5810.f,
+				     .0011937f, .11746f, .029514f, -1.178e-4f, .026592f, -1.0438e-4f, 5810.f,
+				     5820.f, .021084f, .041603f, .018136f, -8.3736e-5f, .01662f, -7.5802e-5f,
+				     5820.f, 5830.f, .041859f, .10038f, .011698f, -5.1084e-5f, .0091292f,
+				     -3.8447e-5f, 5830.f, 5840.f, .0042835f, .054158f, .020564f, -7.9064e-5f,
+				     .016849f, -6.1318e-5f, 5840.f, 5850.f, .039742f, .14212f, .015543f,
+				     -6.5164e-5f, .012937f, -6.0213e-5f, 5850.f, 5860.f, .0044465f, .13575f,
+				     .018218f, -6.1185e-5f, .017472f, -6.1811e-5f, 5860.f, 5870.f, .013183f,
+				     .084879f, .018786f, -7.5902e-5f, .01503f, -6.7738e-5f, 5870.f, 5880.f,
+				     .0036488f, .086695f, .023765f, -7.6455e-5f, .019459f, -6.0338e-5f,
+				     5880.f, 5890.f, .018172f, .13595f, .016681f, -5.4016e-5f, .014894f,
+				     -6.0543e-5f, 5890.f, 5900.f, .0024118f, .072933f, .025664f, -9.6848e-5f,
+				     .026465f, -1.0476e-4f, 5900.f, 5910.f, .01494f, .1207f, .017582f,
+				     -6.8945e-5f, .016946f, -6.9945e-5f, 5910.f, 5920.f, .0014531f, .081478f,
+				     .02565f, -5.6688e-5f, .020849f, -5.2418e-5f, 5920.f, 5930.f, .004057f,
+				     .064725f, .024344f, -1.0574e-4f, .021209f, -9.2148e-5f, 5930.f, 5940.f,
+				     5.9362e-4f, .052682f, .023362f, -8.193e-5f, .01857f, -7.6269e-5f,
+				     5940.f, 5950.f, .0021418f, .075485f, .023733f, -8.0625e-5f, .021119f,
+				     -8.5514e-5f, 5950.f, 5960.f, .0033439f, .12209f, .022556f, -8.973e-5f,
+				     .019031f, -8.5459e-5f, 5960.f, 5970.f, .0014641f, .13608f, .015568f,
+				     3.7809e-6f, .01603f, -2.9177e-5f, 5970.f, 5980.f, 6.3999e-4f, .094011f,
+				     .027455f, -3.9873e-5f, .019599f, -3.6883e-5f, 5980.f, 5990.f, .0013405f,
+				     .090254f, .029576f, -1.1767e-4f, .026759f, -1.1158e-4f, 5990.f, 6e3f,
+				     .0017604f, .17547f, .017851f, -6.4948e-5f, .016287f, -5.6437e-5f, 6e3f,
+				     6010.f, .0011569f, .13348f, .026563f, -8.7926e-5f, .023528f,
+				     -9.1174e-5f, 6010.f, 6020.f, 2.8575e-4f, .078833f, .019053f,
+				     -1.8306e-5f, .018303f, -5.1186e-5f, 6020.f, 6030.f, 8.7532e-4f, .16112f,
+				     .022556f, -3.3852e-5f, .021206f, -6.4336e-5f, 6030.f, 6040.f,
+				     4.8531e-4f, .054398f, .022035f, -9.7698e-5f, .019943f, -8.9334e-5f,
+				     6040.f, 6050.f, 4.2083e-4f, .13305f, .011783f, 6.0192e-5f, .01191f,
+				     7.0965e-6f, 6050.f, 6060.f, 3.1283e-4f, .10974f, .024828f, -3.5695e-5f,
+				     .021926f, -6.102e-5f, 6060.f, 6070.f, .0016917f, .14682f, .0023913f,
+				     1.937e-5f, .0028143f, 1.0914e-5f, 6070.f, 6080.f, 2.4107e-4f, .056225f,
+				     .019103f, -5.8306e-6f, .02305f, -4.6373e-5f, 6080.f, 6090.f, 4.4079e-4f,
+				     .073062f, .0078845f, -3.8279e-5f, .0064841f, -2.5252e-5f, 6090.f,
+				     6100.f, 1.7156e-4f, .08447f, .010336f, 1.0341e-4f, .0085994f,
+				     4.3979e-5f, 6100.f, 6110.f, 1.5736e-4f, .047359f, .020348f, -3.159e-5f,
+				     .024132f, -5.6992e-5f, 6110.f, 6120.f, .0010666f, .13835f, .0061165f,
+				     -8.7157e-6f, .0071462f, -1.5e-5f, 6120.f, 6130.f, 4.1402e-5f, .071564f,
+				     .014541f, -3.0661e-5f, .013703f, -3.2448e-5f, 6130.f, 6140.f,
+				     1.6673e-5f, .033602f, .019118f, -8.8866e-5f, .016523f, -8.3641e-5f,
+				     6140.f, 6150.f, 4.5173e-4f, .19416f, .0081406f, -4.6697e-6f, .0096975f,
+				     -2.7594e-5f, 6150.f, 6160.f, 8.4192e-5f, .0848f, .0068868f, 2.0465e-5f,
+				     .0065557f, -3.9158e-6f, 6160.f, 6170.f, 1.9983e-4f, .034955f, .013243f,
+				     -4.8483e-5f, .014163f, -4.8663e-5f, 6170.f, 6180.f, 5.654e-4f, .092508f,
+				     .0032982f, -2.8242e-7f, .0023537f, -1.1797e-5f, 6180.f, 6190.f,
+				     2.6602e-4f, .14864f, -.0035881f, 8.4292e-6f, -.0064288f, 1.1323e-5f,
+				     6190.f, 6200.f, 6.6332e-4f, .082351f, 4.0475e-5f, -9.1191e-6f,
+				     -.0013832f, -7.433e-7f, 6200.f, 6210.f, 5.089e-4f, .13947f, .003362f,
+				     -3.1112e-6f, 4.078e-4f, 8.6176e-7f, 6210.f, 6220.f, 1.2815e-4f,
+				     .087906f, .012262f, -4.0572e-5f, .01202f, -4.9984e-5f, 6220.f, 6230.f,
+				     1.2854e-4f, .12035f, .0025735f, -1.5152e-5f, -2.5291e-4f, -1.3133e-5f,
+				     6230.f, 6240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6240.f, 6250.f, 3.8748e-4f,
+				     .088892f, .0070553f, -2.9374e-5f, .0061982f, -3.1937e-5f, 6250.f,
+				     6260.f, 1.6711e-4f, .096035f, .013535f, -5.983e-5f, .011956f,
+				     -5.7292e-5f, 6260.f, 6270.f, 5.1664e-4f, .11783f, .0086933f,
+				     -2.7481e-5f, .0070865f, -2.8728e-5f, 6270.f, 6280.f, .001613f, .21378f,
+				     .0034321f, -1.5373e-5f, .0028098f, -8.7169e-6f, 6280.f, 6290.f,
+				     1.104e-4f, .05027f, .011461f, -5.2791e-5f, .010667f, -5.0501e-5f,
+				     6290.f, 6300.f, .0022339f, .16944f, .0043566f, -1.8834e-5f, .0025925f,
+				     -1.7523e-5f, 6300.f, 6310.f, 7.0293e-4f, .10055f, .0086229f,
+				     -3.5378e-5f, .0057065f, -3.2557e-5f, 6310.f, 6320.f, 2.805e-4f, .12764f,
+				     .0056648f, 7.4065e-5f, .0085368f, 1.7469e-5f, 6320.f, 6330.f,
+				     6.2308e-4f, .089292f, .01011f, -2.8113e-5f, .010994f, -3.9797e-5f,
+				     6330.f, 6340.f, 4.9924e-4f, .15704f, .014233f, -5.3536e-5f, .011904f,
+				     -5.3159e-5f, 6340.f, 6350.f, 4.5485e-4f, .2206f, .0045598f, -2.1706e-6f,
+				     .0040803f, -1.9834e-5f, 6350.f, 6360.f, 4.4859e-4f, .31977f, .015688f,
+				     -3.0431e-5f, .012918f, -4.8166e-5f, 6360.f, 6370.f, 2.7811e-4f, .13882f,
+				     .011781f, -2.0096e-5f, .011797f, -2.376e-5f, 6370.f, 6380.f, 8.6844e-4f,
+				     .2569f, .011839f, -6.454e-6f, .0097827f, -2.9934e-5f, 6380.f, 6390.f,
+				     8.4205e-4f, .26741f, .010125f, -9.2493e-6f, .009507f, -2.6314e-5f,
+				     6390.f, 6400.f, .0016976f, .15422f, .0095094f, 1.9053e-5f, .010682f,
+				     -7.9536e-6f, 6400.f, 6410.f, 4.7975e-4f, .09426f, .011121f, -4.7922e-5f,
+				     .0093837f, -4.1295e-5f, 6410.f, 6420.f, 5.2022e-4f, .16038f, .017528f,
-    -3.7366e-5f, .019737f, -6.1655e-5f, 6420.f, 6430.f, 8.2574e-4f, .16899f,
-    .016228f, -5.7574e-5f, .014443f, -6.2197e-5f, 6430.f, 6440.f, .0021296f,
-    .24095f, .018574f, -5.7065e-5f, .018731f, -6.6716e-5f, 6440.f, 6450.f,
-    2.6201e-4f, .11418f, .021012f, -6.7706e-5f, .019337f, -6.9411e-5f,
-    6450.f, 6460.f, .0026631f, .29606f, .0094001f, 3.2264e-5f, .0092032f,
-    -9.2228e-6f, 6460.f, 6470.f, .0025496f, .1395f, .02196f, -9.1558e-5f,
-    .019725f, -7.8434e-5f, 6470.f, 6480.f, .0030217f, .24286f, .021221f,
-    -4.9207e-5f, .017707f, -5.6279e-5f, 6480.f, 6490.f, .0025925f, .22189f,
-    .011972f, -3.5111e-5f, .011532f, -3.4767e-5f, 6490.f, 6500.f, .0036908f,
-    .17271f, .017079f, -6.2898e-5f, .018276f, -6.9468e-5f, 6500.f, 6510.f,
-    .0058412f, .27765f, .021239f, -8.2779e-5f, .019328f, -7.9739e-5f,
-    6510.f, 6520.f, .0010097f, .36424f, .014201f, 1.4574e-5f, .014137f,
-    -2.5464e-5f, 6520.f, 6530.f, .015531f, .36032f, .015962f, -5.5747e-5f,
-    .013807f, -5.4878e-5f, 6530.f, 6540.f, .021827f, .16998f, .012887f,
-    -5.3561e-5f, .013686f, -4.8168e-5f, 6540.f, 6550.f, .025524f, .44895f,
-    .014216f, -3.1158e-5f, .013867f, -4.6536e-5f, 6550.f, 6560.f, .0046252f,
-    .14687f, .017426f, -7.1751e-5f, .018048f, -6.5015e-5f, 6560.f, 6570.f,
-    .022064f, .27f, .015309f, -5.8062e-5f, .016735f, -6.1409e-5f, 6570.f,
-    6580.f, .042593f, .28026f, .015131f, -6.0674e-5f, .014017f, -5.2957e-5f,
-    6580.f, 6590.f, .039072f, .14924f, .0094106f, -4.0098e-5f, .0098574f,
-    -2.9732e-5f, 6590.f, 6600.f, .054808f, .37702f, .012248f, -2.1938e-5f,
-    .012749f, -3.4984e-5f, 6600.f, 6610.f, .036908f, .16694f, .011325f,
-    -4.1839e-5f, .012369f, -2.3977e-5f, 6610.f, 6620.f, .0049128f, .31728f,
-    .016178f, -8.7947e-6f, .019507f, -3.6007e-5f, 6620.f, 6630.f, .027419f,
-    .23237f, .022088f, -4.83e-5f, .021397f, -5.8784e-5f, 6630.f, 6640.f,
-    .09883f, .17529f, .0067054f, -2.8981e-5f, .0098183f, -2.1164e-5f,
-    6640.f, 6650.f, .097673f, .26249f, .015514f, -2.0366e-5f, .018041f,
-    -4.7825e-5f, 6650.f, 6660.f, .029234f, .39325f, .011043f, 6.9627e-6f,
-    .014995f, -2.8824e-5f, 6660.f, 6670.f, .073358f, .26517f, .022641f,
-    -9.0861e-5f, .020163f, -8.1954e-5f, 6670.f, 6680.f, .28609f, .27963f,
-    .012746f, -3.1154e-5f, .011122f, -2.9019e-5f, 6680.f, 6690.f, .15415f,
-    .42581f, .0092965f, -1.6598e-5f, .010866f, -3.0004e-5f, 6690.f, 6700.f,
-    .50854f, .25928f, .011806f, -4.9706e-5f, .01195f, -4.4564e-5f, 6700.f,
-    6710.f, .54248f, .29219f, .0086655f, -1.078e-5f, .0096072f, -2.0886e-5f,
-    6710.f, 6720.f, 1.1829f, .23177f, .0084264f, -3.6835e-5f, .0078692f,
-    -3.165e-5f, 6720.f, 6730.f, .66413f, .22652f, .0096388f, -4.5502e-5f,
-    .0094036f, -4.2748e-5f, 6730.f, 6740.f, 2.0327f, .2021f, .0051382f,
-    -2.4524e-5f, .0066314f, -1.6094e-5f, 6740.f, 6750.f, 2.8639f, .19875f,
-    .0048057f, -2.8413e-5f, .0044821f, -2.1857e-5f, 6750.f, 6760.f, 2.3946f,
-    .11681f, .0025701f, -2.0163e-5f, .0026061f, -1.6227e-5f, 6760.f, 6770.f,
-    2.3817f, .35427f, .0039392f, -1.7028e-5f, .004929f, -1.8773e-5f, 6770.f,
-    6780.f, 1.6155f, .23449f, 7.3307e-4f, -7.3637e-6f, .0016677f,
-    -2.5528e-6f, 6780.f, 6790.f, 8.3481f, .29624f, 2.1533e-4f, -8.9091e-6f,
-    -1.954e-4f, -6.9089e-6f, 6790.f, 6800.f, 3.9018f, .13513f, -.002043f,
-    4.7043e-6f, .0019385f, 1.5453e-5f, 6800.f, 6810.f, 3.3911f, .24098f,
-    -2.0667e-4f, -6.3633e-6f, -1.6731e-4f, -2.2699e-6f, 6810.f, 6820.f,
-    2.8798f, .25576f, -.0021074f, 5.4951e-6f, -.0021041f, 8.2116e-6f,
-    6820.f, 6830.f, 2.7426f, .15514f, -.0029057f, 1.2463e-5f, .0017031f,
-    1.9513e-5f, 6830.f, 6840.f, 3.2308f, .18429f, -.0036805f, 1.3879e-5f,
-    3.8114e-4f, 2.111e-5f, 6840.f, 6850.f, .82936f, .18124f, 4.1735e-4f,
-    1.4616e-6f, .0025198f, -1.3464e-6f, 6850.f, 6860.f, .35131f, .41646f,
-    .015485f, -4.647e-5f, .013388f, -3.6422e-5f, 6860.f, 6870.f, 4.6683f,
-    .15324f, -.0042182f, 9.0437e-6f, -.0013329f, 1.8577e-5f, 6870.f, 6880.f,
-    2.8455f, .17389f, -.0022094f, 1.4962e-6f, -.0015658f, 9.7344e-6f,
-    6880.f, 6890.f, 8.8724f, .42657f, -.0018169f, 8.1105e-6f, -6.5751e-4f,
-    1.2321e-5f, 6890.f, 6900.f, .81595f, .32457f, .0028256f, 1.2078e-6f,
-    .0059842f, 1.543e-6f, 6900.f, 6910.f, 12.055f, .40831f, -.0011236f,
-    2.2677e-6f, -8.159e-4f, 1.7078e-6f, 6910.f, 6920.f, 1.4005f, .42874f,
-    .0073135f, -1.6167e-5f, .0082389f, -1.8229e-5f, 6920.f, 6930.f, 9.4914f,
-    .29494f, -.0033677f, 1.1156e-5f, -.0016627f, 1.6279e-5f, 6930.f, 6940.f,
-    3.731f, .44986f, .0084547f, -3.0585e-5f, .010303f, -3.5351e-5f, 6940.f,
-    6950.f, 7.9581f, .26975f, -.0014256f, 4.1782e-6f, 1.3886e-4f,
-    7.5184e-6f, 6950.f, 6960.f, 3.409f, .33223f, -8.355e-4f, 9.9982e-6f,
-    .0032926f, 7.9289e-6f, 6960.f, 6970.f, 6.9934f, .49549f, .0034299f,
-    1.3868e-5f, .0073246f, -1.1357e-5f, 6970.f, 6980.f, 8.4288f, .29235f,
-    .0012515f, -6.6867e-6f, .0022057f, -7.2817e-6f, 6980.f, 6990.f, 3.7771f,
-    .34377f, .0066839f, 1.4877e-5f, .0099074f, -2.4726e-5f, 6990.f, 7e3f,
-    5.9358f, .4452f, .0047532f, -1.1726e-5f, .0057444f, -1.6773e-5f, 7e3f,
-    7010.f, 3.6653f, .46656f, .0075924f, -1.4859e-5f, .0085483f,
-    -2.7681e-5f, 7010.f, 7020.f, 7.623f, .59145f, .010355f, -2.3877e-5f,
-    .0084375f, -3.5191e-5f, 7020.f, 7030.f, 2.9785f, .49616f, .0095318f,
-    -2.8442e-5f, .0094393f, -3.7258e-5f, 7030.f, 7040.f, 11.489f, .4463f,
-    .012118f, -4.7464e-5f, .0089557f, -4.3911e-5f, 7040.f, 7050.f, 5.707f,
-    .30579f, .012792f, -5.848e-5f, .011943f, -4.9567e-5f, 7050.f, 7060.f,
-    4.3341f, .45254f, .0087102f, -3.6977e-5f, .0062554f, -2.9678e-5f,
-    7060.f, 7070.f, 18.415f, .27325f, .011045f, -5.5565e-5f, .0087811f,
-    -4.6635e-5f, 7070.f, 7080.f, 9.2559f, .37006f, .0093565f, -4.6638e-5f,
-    .008623f, -4.1694e-5f, 7080.f, 7090.f, 34.399f, .2696f, .0073722f,
-    -4.0297e-5f, .005669f, -3.4996e-5f, 7090.f, 7100.f, 27.357f, .28185f,
-    .0041186f, -2.4656e-5f, .0015333f, -1.4846e-5f, 7100.f, 7110.f, 59.142f,
-    .21235f, .004202f, -2.8298e-5f, .0026623f, -2.2726e-5f, 7110.f, 7120.f,
-    8.729f, .31743f, .0050667f, -2.9057e-5f, .0050497f, -2.4756e-5f, 7120.f,
-    7130.f, 66.372f, .25989f, .0021171f, -2.001e-5f, 9.8789e-4f,
-    -1.5045e-5f, 7130.f, 7140.f, 40.254f, .15248f, 6.4299e-4f, -1.3315e-5f,
-    -6.7491e-4f, -2.9781e-7f, 7140.f, 7150.f, 1.5991f, .45391f, .0083749f,
-    -1.2893e-5f, .011832f, -2.3466e-5f, 7150.f, 7160.f, 138.4f, .26185f,
-    -9.2005e-4f, -7.5058e-6f, -.0022766f, 1.2031e-6f, 7160.f, 7170.f,
-    13.476f, .27958f, 1.7108e-4f, 2.8602e-6f, .0019003f, 2.2534e-6f, 7170.f,
-    7180.f, 95.96f, .20582f, -.0022657f, 1.3812e-6f, -.0015351f, 8.8048e-6f,
-    7180.f, 7190.f, 14.69f, .24608f, 7.8336e-4f, 1.5252e-5f, .003739f,
-    -6.918e-6f, 7190.f, 7200.f, 55.288f, .25862f, -.0013454f, 9.9116e-6f,
-    -8.8298e-4f, 1.7423e-6f, 7200.f, 7210.f, 48.147f, .25568f, .0049183f,
-    -2.3894e-5f, .0037052f, -2.2724e-5f, 7210.f, 7220.f, 40.415f, .20103f,
-    -.0024259f, 7.5229e-6f, -.0017525f, 2.6464e-6f, 7220.f, 7230.f, 109.84f,
-    .33075f, 7.5622e-4f, -1.2921e-5f, -.0011898f, -5.9125e-6f, 7230.f,
-    7240.f, 130.02f, .18533f, -.0033239f, 1.8173e-6f, -.0046918f,
+				     -3.7366e-5f, .019737f, -6.1655e-5f, 6420.f, 6430.f, 8.2574e-4f, .16899f,
+				     .016228f, -5.7574e-5f, .014443f, -6.2197e-5f, 6430.f, 6440.f, .0021296f,
+				     .24095f, .018574f, -5.7065e-5f, .018731f, -6.6716e-5f, 6440.f, 6450.f,
+				     2.6201e-4f, .11418f, .021012f, -6.7706e-5f, .019337f, -6.9411e-5f,
+				     6450.f, 6460.f, .0026631f, .29606f, .0094001f, 3.2264e-5f, .0092032f,
+				     -9.2228e-6f, 6460.f, 6470.f, .0025496f, .1395f, .02196f, -9.1558e-5f,
+				     .019725f, -7.8434e-5f, 6470.f, 6480.f, .0030217f, .24286f, .021221f,
+				     -4.9207e-5f, .017707f, -5.6279e-5f, 6480.f, 6490.f, .0025925f, .22189f,
+				     .011972f, -3.5111e-5f, .011532f, -3.4767e-5f, 6490.f, 6500.f, .0036908f,
+				     .17271f, .017079f, -6.2898e-5f, .018276f, -6.9468e-5f, 6500.f, 6510.f,
+				     .0058412f, .27765f, .021239f, -8.2779e-5f, .019328f, -7.9739e-5f,
+				     6510.f, 6520.f, .0010097f, .36424f, .014201f, 1.4574e-5f, .014137f,
+				     -2.5464e-5f, 6520.f, 6530.f, .015531f, .36032f, .015962f, -5.5747e-5f,
+				     .013807f, -5.4878e-5f, 6530.f, 6540.f, .021827f, .16998f, .012887f,
+				     -5.3561e-5f, .013686f, -4.8168e-5f, 6540.f, 6550.f, .025524f, .44895f,
+				     .014216f, -3.1158e-5f, .013867f, -4.6536e-5f, 6550.f, 6560.f, .0046252f,
+				     .14687f, .017426f, -7.1751e-5f, .018048f, -6.5015e-5f, 6560.f, 6570.f,
+				     .022064f, .27f, .015309f, -5.8062e-5f, .016735f, -6.1409e-5f, 6570.f,
+				     6580.f, .042593f, .28026f, .015131f, -6.0674e-5f, .014017f, -5.2957e-5f,
+				     6580.f, 6590.f, .039072f, .14924f, .0094106f, -4.0098e-5f, .0098574f,
+				     -2.9732e-5f, 6590.f, 6600.f, .054808f, .37702f, .012248f, -2.1938e-5f,
+				     .012749f, -3.4984e-5f, 6600.f, 6610.f, .036908f, .16694f, .011325f,
+				     -4.1839e-5f, .012369f, -2.3977e-5f, 6610.f, 6620.f, .0049128f, .31728f,
+				     .016178f, -8.7947e-6f, .019507f, -3.6007e-5f, 6620.f, 6630.f, .027419f,
+				     .23237f, .022088f, -4.83e-5f, .021397f, -5.8784e-5f, 6630.f, 6640.f,
+				     .09883f, .17529f, .0067054f, -2.8981e-5f, .0098183f, -2.1164e-5f,
+				     6640.f, 6650.f, .097673f, .26249f, .015514f, -2.0366e-5f, .018041f,
+				     -4.7825e-5f, 6650.f, 6660.f, .029234f, .39325f, .011043f, 6.9627e-6f,
+				     .014995f, -2.8824e-5f, 6660.f, 6670.f, .073358f, .26517f, .022641f,
+				     -9.0861e-5f, .020163f, -8.1954e-5f, 6670.f, 6680.f, .28609f, .27963f,
+				     .012746f, -3.1154e-5f, .011122f, -2.9019e-5f, 6680.f, 6690.f, .15415f,
+				     .42581f, .0092965f, -1.6598e-5f, .010866f, -3.0004e-5f, 6690.f, 6700.f,
+				     .50854f, .25928f, .011806f, -4.9706e-5f, .01195f, -4.4564e-5f, 6700.f,
+				     6710.f, .54248f, .29219f, .0086655f, -1.078e-5f, .0096072f, -2.0886e-5f,
+				     6710.f, 6720.f, 1.1829f, .23177f, .0084264f, -3.6835e-5f, .0078692f,
+				     -3.165e-5f, 6720.f, 6730.f, .66413f, .22652f, .0096388f, -4.5502e-5f,
+				     .0094036f, -4.2748e-5f, 6730.f, 6740.f, 2.0327f, .2021f, .0051382f,
+				     -2.4524e-5f, .0066314f, -1.6094e-5f, 6740.f, 6750.f, 2.8639f, .19875f,
+				     .0048057f, -2.8413e-5f, .0044821f, -2.1857e-5f, 6750.f, 6760.f, 2.3946f,
+				     .11681f, .0025701f, -2.0163e-5f, .0026061f, -1.6227e-5f, 6760.f, 6770.f,
+				     2.3817f, .35427f, .0039392f, -1.7028e-5f, .004929f, -1.8773e-5f, 6770.f,
+				     6780.f, 1.6155f, .23449f, 7.3307e-4f, -7.3637e-6f, .0016677f,
+				     -2.5528e-6f, 6780.f, 6790.f, 8.3481f, .29624f, 2.1533e-4f, -8.9091e-6f,
+				     -1.954e-4f, -6.9089e-6f, 6790.f, 6800.f, 3.9018f, .13513f, -.002043f,
+				     4.7043e-6f, .0019385f, 1.5453e-5f, 6800.f, 6810.f, 3.3911f, .24098f,
+				     -2.0667e-4f, -6.3633e-6f, -1.6731e-4f, -2.2699e-6f, 6810.f, 6820.f,
+				     2.8798f, .25576f, -.0021074f, 5.4951e-6f, -.0021041f, 8.2116e-6f,
+				     6820.f, 6830.f, 2.7426f, .15514f, -.0029057f, 1.2463e-5f, .0017031f,
+				     1.9513e-5f, 6830.f, 6840.f, 3.2308f, .18429f, -.0036805f, 1.3879e-5f,
+				     3.8114e-4f, 2.111e-5f, 6840.f, 6850.f, .82936f, .18124f, 4.1735e-4f,
+				     1.4616e-6f, .0025198f, -1.3464e-6f, 6850.f, 6860.f, .35131f, .41646f,
+				     .015485f, -4.647e-5f, .013388f, -3.6422e-5f, 6860.f, 6870.f, 4.6683f,
+				     .15324f, -.0042182f, 9.0437e-6f, -.0013329f, 1.8577e-5f, 6870.f, 6880.f,
+				     2.8455f, .17389f, -.0022094f, 1.4962e-6f, -.0015658f, 9.7344e-6f,
+				     6880.f, 6890.f, 8.8724f, .42657f, -.0018169f, 8.1105e-6f, -6.5751e-4f,
+				     1.2321e-5f, 6890.f, 6900.f, .81595f, .32457f, .0028256f, 1.2078e-6f,
+				     .0059842f, 1.543e-6f, 6900.f, 6910.f, 12.055f, .40831f, -.0011236f,
+				     2.2677e-6f, -8.159e-4f, 1.7078e-6f, 6910.f, 6920.f, 1.4005f, .42874f,
+				     .0073135f, -1.6167e-5f, .0082389f, -1.8229e-5f, 6920.f, 6930.f, 9.4914f,
+				     .29494f, -.0033677f, 1.1156e-5f, -.0016627f, 1.6279e-5f, 6930.f, 6940.f,
+				     3.731f, .44986f, .0084547f, -3.0585e-5f, .010303f, -3.5351e-5f, 6940.f,
+				     6950.f, 7.9581f, .26975f, -.0014256f, 4.1782e-6f, 1.3886e-4f,
+				     7.5184e-6f, 6950.f, 6960.f, 3.409f, .33223f, -8.355e-4f, 9.9982e-6f,
+				     .0032926f, 7.9289e-6f, 6960.f, 6970.f, 6.9934f, .49549f, .0034299f,
+				     1.3868e-5f, .0073246f, -1.1357e-5f, 6970.f, 6980.f, 8.4288f, .29235f,
+				     .0012515f, -6.6867e-6f, .0022057f, -7.2817e-6f, 6980.f, 6990.f, 3.7771f,
+				     .34377f, .0066839f, 1.4877e-5f, .0099074f, -2.4726e-5f, 6990.f, 7e3f,
+				     5.9358f, .4452f, .0047532f, -1.1726e-5f, .0057444f, -1.6773e-5f, 7e3f,
+				     7010.f, 3.6653f, .46656f, .0075924f, -1.4859e-5f, .0085483f,
+				     -2.7681e-5f, 7010.f, 7020.f, 7.623f, .59145f, .010355f, -2.3877e-5f,
+				     .0084375f, -3.5191e-5f, 7020.f, 7030.f, 2.9785f, .49616f, .0095318f,
+				     -2.8442e-5f, .0094393f, -3.7258e-5f, 7030.f, 7040.f, 11.489f, .4463f,
+				     .012118f, -4.7464e-5f, .0089557f, -4.3911e-5f, 7040.f, 7050.f, 5.707f,
+				     .30579f, .012792f, -5.848e-5f, .011943f, -4.9567e-5f, 7050.f, 7060.f,
+				     4.3341f, .45254f, .0087102f, -3.6977e-5f, .0062554f, -2.9678e-5f,
+				     7060.f, 7070.f, 18.415f, .27325f, .011045f, -5.5565e-5f, .0087811f,
+				     -4.6635e-5f, 7070.f, 7080.f, 9.2559f, .37006f, .0093565f, -4.6638e-5f,
+				     .008623f, -4.1694e-5f, 7080.f, 7090.f, 34.399f, .2696f, .0073722f,
+				     -4.0297e-5f, .005669f, -3.4996e-5f, 7090.f, 7100.f, 27.357f, .28185f,
+				     .0041186f, -2.4656e-5f, .0015333f, -1.4846e-5f, 7100.f, 7110.f, 59.142f,
+				     .21235f, .004202f, -2.8298e-5f, .0026623f, -2.2726e-5f, 7110.f, 7120.f,
+				     8.729f, .31743f, .0050667f, -2.9057e-5f, .0050497f, -2.4756e-5f, 7120.f,
+				     7130.f, 66.372f, .25989f, .0021171f, -2.001e-5f, 9.8789e-4f,
+				     -1.5045e-5f, 7130.f, 7140.f, 40.254f, .15248f, 6.4299e-4f, -1.3315e-5f,
+				     -6.7491e-4f, -2.9781e-7f, 7140.f, 7150.f, 1.5991f, .45391f, .0083749f,
+				     -1.2893e-5f, .011832f, -2.3466e-5f, 7150.f, 7160.f, 138.4f, .26185f,
+				     -9.2005e-4f, -7.5058e-6f, -.0022766f, 1.2031e-6f, 7160.f, 7170.f,
+				     13.476f, .27958f, 1.7108e-4f, 2.8602e-6f, .0019003f, 2.2534e-6f, 7170.f,
+				     7180.f, 95.96f, .20582f, -.0022657f, 1.3812e-6f, -.0015351f, 8.8048e-6f,
+				     7180.f, 7190.f, 14.69f, .24608f, 7.8336e-4f, 1.5252e-5f, .003739f,
+				     -6.918e-6f, 7190.f, 7200.f, 55.288f, .25862f, -.0013454f, 9.9116e-6f,
+				     -8.8298e-4f, 1.7423e-6f, 7200.f, 7210.f, 48.147f, .25568f, .0049183f,
+				     -2.3894e-5f, .0037052f, -2.2724e-5f, 7210.f, 7220.f, 40.415f, .20103f,
+				     -.0024259f, 7.5229e-6f, -.0017525f, 2.6464e-6f, 7220.f, 7230.f, 109.84f,
+				     .33075f, 7.5622e-4f, -1.2921e-5f, -.0011898f, -5.9125e-6f, 7230.f,
+				     7240.f, 130.02f, .18533f, -.0033239f, 1.8173e-6f, -.0046918f,
-    8.1132e-6f, 7240.f, 7250.f, 24.491f, .30951f, -.0026793f, 5.8588e-6f,
-    -.0021237f, 4.8e-6f, 7250.f, 7260.f, 19.609f, .15703f, -.0025743f,
-    2.8622e-6f, -.0016255f, 4.4422e-6f, 7260.f, 7270.f, 17.072f, .26657f,
-    -.0029675f, 1.2335e-5f, -6.9569e-4f, 7.7744e-6f, 7270.f, 7280.f,
-    25.243f, .38981f, -.0023499f, 7.2438e-6f, -.0015088f, 4.0106e-6f,
-    7280.f, 7290.f, 139.62f, .16193f, -.0050479f, 9.269e-6f, -.0053276f,
-    1.5266e-5f, 7290.f, 7300.f, 86.705f, .11761f, -.0037859f, 4.4125e-6f,
+				     8.1132e-6f, 7240.f, 7250.f, 24.491f, .30951f, -.0026793f, 5.8588e-6f,
+				     -.0021237f, 4.8e-6f, 7250.f, 7260.f, 19.609f, .15703f, -.0025743f,
+				     2.8622e-6f, -.0016255f, 4.4422e-6f, 7260.f, 7270.f, 17.072f, .26657f,
+				     -.0029675f, 1.2335e-5f, -6.9569e-4f, 7.7744e-6f, 7270.f, 7280.f,
+				     25.243f, .38981f, -.0023499f, 7.2438e-6f, -.0015088f, 4.0106e-6f,
+				     7280.f, 7290.f, 139.62f, .16193f, -.0050479f, 9.269e-6f, -.0053276f,
+				     1.5266e-5f, 7290.f, 7300.f, 86.705f, .11761f, -.0037859f, 4.4125e-6f,
-    -.0030774f, 1.0295e-5f, 7300.f, 7310.f, 66.458f, .22506f, -.0031197f,
-    2.1671e-6f, -.003942f, 5.6842e-6f, 7310.f, 7320.f, 147.42f, .24611f,
-    -.0023854f, -1.4496e-6f, -.0034285f, 1.2805e-6f, 7320.f, 7330.f,
-    87.291f, .22526f, -1.1541e-4f, -9.6671e-6f, -9.0479e-4f, -7.8703e-6f,
-    7330.f, 7340.f, 155.36f, .27754f, -2.3889e-4f, -8.8494e-6f, -.001057f,
-    -7.3024e-6f, 7340.f, 7350.f, 60.8f, .21141f, .0022877f, -1.825e-5f,
-    .0021735f, -1.6084e-5f, 7350.f, 7360.f, 65.821f, .31454f, .0035102f,
-    -2.3014e-5f, .0021764f, -1.996e-5f, 7360.f, 7370.f, 39.314f, .19452f,
-    .0045708f, -2.8104e-5f, .0035157f, -2.3151e-5f, 7370.f, 7380.f, 33.606f,
-    .30823f, .0071777f, -3.6203e-5f, .0052193f, -2.5338e-5f, 7380.f, 7390.f,
-    28.667f, .22825f, .0067636f, -3.404e-5f, .0062429f, -3.5213e-5f, 7390.f,
-    7400.f, 9.5852f, .3028f, .012912f, -5.3899e-5f, .010209f, -4.4318e-5f,
-    7400.f, 7410.f, 7.5752f, .36859f, .010673f, -1.5633e-5f, .0094631f,
-    -3.3501e-5f, 7410.f, 7420.f, 3.3599f, .31735f, .015132f, -5.0575e-5f,
-    .013714f, -4.8842e-5f, 7420.f, 7430.f, 1.421f, .51877f, .010564f,
-    2.7798e-5f, .010716f, -1.6576e-5f, 7430.f, 7440.f, 1.3357f, .34135f,
-    .0055009f, 2.9075e-5f, .010731f, -1.4716e-5f, 7440.f, 7450.f, .90292f,
-    .35257f, .0064439f, 4.3621e-6f, .0093295f, -7.9773e-6f, 7450.f, 7460.f,
-    .47321f, .34413f, .0075753f, 3.1118e-5f, .0088184f, 2.3143e-6f, 7460.f,
-    7470.f, .14277f, .63005f, .015765f, -3.876e-5f, .014284f, -4.1344e-5f,
-    7470.f, 7480.f, .84751f, .092347f, .0044433f, -2.3373e-5f, .0065281f,
-    -2.0814e-5f, 7480.f, 7490.f, .34962f, .49346f, 3.9951e-4f, 2.823e-6f,
-    .0021242f, -6.058e-7f, 7490.f, 7500.f, .66686f, .32642f, .0015242f,
-    -8.7602e-6f, .0033093f, -6.2194e-6f, 7500.f, 7510.f, .7038f, .37824f,
-    .0040335f, -1.7144e-5f, .0058765f, -1.8563e-5f, 7510.f, 7520.f, .44176f,
-    .28314f, .0041609f, -2.1428e-5f, .0052238f, -2.1647e-5f, 7520.f, 7530.f,
-    .23859f, .25536f, .0046384f, -3.1469e-6f, .0056672f, -1.3268e-5f,
-    7530.f, 7540.f, .12451f, .19246f, .003173f, -1.645e-5f, .0046905f,
-    -1.9919e-5f, 7540.f, 7550.f, .40142f, .2566f, .0068917f, -2.2016e-5f,
-    .0042921f, -2.2533e-5f, 7550.f, 7560.f, .24593f, .28458f, 3.567e-4f,
-    -9.0627e-7f, 6.7869e-4f, -6.7459e-6f, 7560.f, 7570.f, .41189f, .23957f,
-    -2.7548e-4f, 3.566e-6f, 3.9542e-4f, -3.8485e-6f, 7570.f, 7580.f,
-    .20341f, .14662f, .0060408f, -3.5022e-5f, .0043079f, -3.1225e-5f,
-    7580.f, 7590.f, .18188f, .14279f, .0012602f, -3.0833e-6f, .0033638f,
-    -1.3417e-5f, 7590.f, 7600.f, .17978f, .35062f, .005044f, -3.1112e-6f,
-    .0036165f, -1.3022e-5f, 7600.f, 7610.f, .31504f, .16627f, .003265f,
-    -1.3345e-5f, .0040505f, -2.0124e-5f, 7610.f, 7620.f
+				     -.0030774f, 1.0295e-5f, 7300.f, 7310.f, 66.458f, .22506f, -.0031197f,
+				     2.1671e-6f, -.003942f, 5.6842e-6f, 7310.f, 7320.f, 147.42f, .24611f,
+				     -.0023854f, -1.4496e-6f, -.0034285f, 1.2805e-6f, 7320.f, 7330.f,
+				     87.291f, .22526f, -1.1541e-4f, -9.6671e-6f, -9.0479e-4f, -7.8703e-6f,
+				     7330.f, 7340.f, 155.36f, .27754f, -2.3889e-4f, -8.8494e-6f, -.001057f,
+				     -7.3024e-6f, 7340.f, 7350.f, 60.8f, .21141f, .0022877f, -1.825e-5f,
+				     .0021735f, -1.6084e-5f, 7350.f, 7360.f, 65.821f, .31454f, .0035102f,
+				     -2.3014e-5f, .0021764f, -1.996e-5f, 7360.f, 7370.f, 39.314f, .19452f,
+				     .0045708f, -2.8104e-5f, .0035157f, -2.3151e-5f, 7370.f, 7380.f, 33.606f,
+				     .30823f, .0071777f, -3.6203e-5f, .0052193f, -2.5338e-5f, 7380.f, 7390.f,
+				     28.667f, .22825f, .0067636f, -3.404e-5f, .0062429f, -3.5213e-5f, 7390.f,
+				     7400.f, 9.5852f, .3028f, .012912f, -5.3899e-5f, .010209f, -4.4318e-5f,
+				     7400.f, 7410.f, 7.5752f, .36859f, .010673f, -1.5633e-5f, .0094631f,
+				     -3.3501e-5f, 7410.f, 7420.f, 3.3599f, .31735f, .015132f, -5.0575e-5f,
+				     .013714f, -4.8842e-5f, 7420.f, 7430.f, 1.421f, .51877f, .010564f,
+				     2.7798e-5f, .010716f, -1.6576e-5f, 7430.f, 7440.f, 1.3357f, .34135f,
+				     .0055009f, 2.9075e-5f, .010731f, -1.4716e-5f, 7440.f, 7450.f, .90292f,
+				     .35257f, .0064439f, 4.3621e-6f, .0093295f, -7.9773e-6f, 7450.f, 7460.f,
+				     .47321f, .34413f, .0075753f, 3.1118e-5f, .0088184f, 2.3143e-6f, 7460.f,
+				     7470.f, .14277f, .63005f, .015765f, -3.876e-5f, .014284f, -4.1344e-5f,
+				     7470.f, 7480.f, .84751f, .092347f, .0044433f, -2.3373e-5f, .0065281f,
+				     -2.0814e-5f, 7480.f, 7490.f, .34962f, .49346f, 3.9951e-4f, 2.823e-6f,
+				     .0021242f, -6.058e-7f, 7490.f, 7500.f, .66686f, .32642f, .0015242f,
+				     -8.7602e-6f, .0033093f, -6.2194e-6f, 7500.f, 7510.f, .7038f, .37824f,
+				     .0040335f, -1.7144e-5f, .0058765f, -1.8563e-5f, 7510.f, 7520.f, .44176f,
+				     .28314f, .0041609f, -2.1428e-5f, .0052238f, -2.1647e-5f, 7520.f, 7530.f,
+				     .23859f, .25536f, .0046384f, -3.1469e-6f, .0056672f, -1.3268e-5f,
+				     7530.f, 7540.f, .12451f, .19246f, .003173f, -1.645e-5f, .0046905f,
+				     -1.9919e-5f, 7540.f, 7550.f, .40142f, .2566f, .0068917f, -2.2016e-5f,
+				     .0042921f, -2.2533e-5f, 7550.f, 7560.f, .24593f, .28458f, 3.567e-4f,
+				     -9.0627e-7f, 6.7869e-4f, -6.7459e-6f, 7560.f, 7570.f, .41189f, .23957f,
+				     -2.7548e-4f, 3.566e-6f, 3.9542e-4f, -3.8485e-6f, 7570.f, 7580.f,
+				     .20341f, .14662f, .0060408f, -3.5022e-5f, .0043079f, -3.1225e-5f,
+				     7580.f, 7590.f, .18188f, .14279f, .0012602f, -3.0833e-6f, .0033638f,
+				     -1.3417e-5f, 7590.f, 7600.f, .17978f, .35062f, .005044f, -3.1112e-6f,
+				     .0036165f, -1.3022e-5f, 7600.f, 7610.f, .31504f, .16627f, .003265f,
+				     -1.3345e-5f, .0040505f, -2.0124e-5f, 7610.f, 7620.f
-	/* WATER VAPOR (5060 - 7600 CM-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* WATER VAPOR (5060 - 7600 CM-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* wava2 */
 void
@@ -1641,314 +1641,314 @@
-  static const float acr[2048] = { 5.2155e-5f, .1088f,
-    .024708f, 5.6434e-5f, .028126f, -3.6504e-5f, 2500.f, 2510.f, 2.6024e-4f,
-    .21216f, .025876f, 3.0026e-5f, .030504f, -6.2253e-5f, 2510.f, 2520.f,
-    1.2221e-4f, .091374f, .023862f, -7.9891e-5f, .020651f, -8.5449e-5f,
-    2520.f, 2530.f, 6.8892e-5f, .12703f, .030103f, -6.0355e-5f, .031571f,
-    -9.5671e-5f, 2530.f, 2540.f, 9.5684e-5f, .11204f, .033051f, -9.6752e-5f,
-    .030485f, -1.1273e-4f, 2540.f, 2550.f, 1.0008e-4f, .092789f, .016702f,
-    4.1104e-5f, .021654f, -1.2175e-5f, 2550.f, 2560.f, 1.1515e-4f, .072392f,
-    .028437f, -8.9454e-5f, .028734f, -1.022e-4f, 2560.f, 2570.f, 1.098e-4f,
-    .093023f, .023611f, 1.0889e-5f, .02688f, -5.0398e-5f, 2570.f, 2580.f,
-    1.0952e-4f, .07579f, .029206f, -9.8206e-5f, .030307f, -1.1103e-4f,
-    2580.f, 2590.f, 1.1941e-4f, .070428f, .019144f, -2.8423e-5f, .019587f,
-    -5.4379e-5f, 2590.f, 2600.f, 8.0498e-5f, .061889f, .024778f,
-    -5.5252e-5f, .028205f, -1.2627e-4f, 2600.f, 2610.f, 7.2792e-5f,
-    .062776f, .026682f, -5.8101e-5f, .029166f, -1.1148e-4f, 2610.f, 2620.f,
-    1.6616e-4f, .015773f, .023141f, -6.0394e-5f, .024947f, -1.1178e-4f,
+    static const float acr[2048] = { 5.2155e-5f, .1088f,
+				     .024708f, 5.6434e-5f, .028126f, -3.6504e-5f, 2500.f, 2510.f, 2.6024e-4f,
+				     .21216f, .025876f, 3.0026e-5f, .030504f, -6.2253e-5f, 2510.f, 2520.f,
+				     1.2221e-4f, .091374f, .023862f, -7.9891e-5f, .020651f, -8.5449e-5f,
+				     2520.f, 2530.f, 6.8892e-5f, .12703f, .030103f, -6.0355e-5f, .031571f,
+				     -9.5671e-5f, 2530.f, 2540.f, 9.5684e-5f, .11204f, .033051f, -9.6752e-5f,
+				     .030485f, -1.1273e-4f, 2540.f, 2550.f, 1.0008e-4f, .092789f, .016702f,
+				     4.1104e-5f, .021654f, -1.2175e-5f, 2550.f, 2560.f, 1.1515e-4f, .072392f,
+				     .028437f, -8.9454e-5f, .028734f, -1.022e-4f, 2560.f, 2570.f, 1.098e-4f,
+				     .093023f, .023611f, 1.0889e-5f, .02688f, -5.0398e-5f, 2570.f, 2580.f,
+				     1.0952e-4f, .07579f, .029206f, -9.8206e-5f, .030307f, -1.1103e-4f,
+				     2580.f, 2590.f, 1.1941e-4f, .070428f, .019144f, -2.8423e-5f, .019587f,
+				     -5.4379e-5f, 2590.f, 2600.f, 8.0498e-5f, .061889f, .024778f,
+				     -5.5252e-5f, .028205f, -1.2627e-4f, 2600.f, 2610.f, 7.2792e-5f,
+				     .062776f, .026682f, -5.8101e-5f, .029166f, -1.1148e-4f, 2610.f, 2620.f,
+				     1.6616e-4f, .015773f, .023141f, -6.0394e-5f, .024947f, -1.1178e-4f,
-    2620.f, 2630.f, 1.8043e-4f, .087686f, .026248f, -3.0398e-5f, .03174f,
-    -1.367e-4f, 2630.f, 2640.f, 1.3339e-4f, .05328f, .012701f, -4.6874e-5f,
-    .012628f, -6.7487e-5f, 2640.f, 2650.f, 4.115e-5f, .0075778f, .011257f,
-    1.1038e-4f, .036362f, -1.1284e-4f, 2650.f, 2660.f, 6.1395e-5f, .026074f,
-    .016798f, 1.0755e-4f, .035481f, -1.3778e-4f, 2660.f, 2670.f, 3.5062e-4f,
-    .080662f, .021065f, -3.9968e-5f, .021602f, -8.7339e-5f, 2670.f, 2680.f,
-    2.6391e-4f, .11483f, .02727f, -4.0691e-5f, .029928f, -1.1046e-4f,
-    2680.f, 2690.f, 8.741e-4f, .06007f, .021732f, -8.76e-5f, .020645f,
-    -9.6557e-5f, 2690.f, 2700.f, 3.0675e-5f, .02297f, .0094212f, 7.8691e-6f,
-    .015402f, -7.4597e-5f, 2700.f, 2710.f, 2.1928e-4f, .13351f, .022082f,
-    -4.5472e-5f, .02546f, -9.6549e-5f, 2710.f, 2720.f, 3.4904e-4f, .095073f,
-    .013969f, 1.2276e-6f, .016415f, -6.5204e-5f, 2720.f, 2730.f, .002136f,
-    .061072f, .018908f, -7.653e-5f, .019801f, -7.7251e-5f, 2730.f, 2740.f,
-    1.3372e-4f, .10806f, .025683f, -4.923e-5f, .025729f, -8.9387e-5f,
-    2740.f, 2750.f, .0021697f, .062188f, .018593f, -8.0474e-5f, .016349f,
-    -8.1422e-5f, 2750.f, 2760.f, 4.503e-5f, .014902f, .011376f, 2.086e-4f,
-    .04688f, -1.3018e-4f, 2760.f, 2770.f, 3.9413e-4f, .075433f, .019773f,
-    3.0322e-5f, .02086f, -4.5326e-5f, 2770.f, 2780.f, .0048935f, .096746f,
-    .019042f, -7.2945e-5f, .016358f, -7.6368e-5f, 2780.f, 2790.f,
-    5.6197e-5f, .026178f, .017977f, 1.4035e-4f, .032163f, -7.1639e-5f,
-    2790.f, 2800.f, .0017459f, .049818f, .012334f, -5.2052e-5f, .013169f,
-    -4.5266e-5f, 2800.f, 2810.f, .013747f, .048325f, .012754f, -6.181e-5f,
-    .011564f, -4.9886e-5f, 2810.f, 2820.f, 8.2805e-4f, .084185f, .021588f,
-    3.0162e-6f, .021186f, -3.7441e-5f, 2820.f, 2830.f, .011866f, .034247f,
-    .0094911f, -5.0331e-5f, .0068889f, -4.5062e-5f, 2830.f, 2840.f,
-    .0053887f, .10669f, .021019f, -5.3528e-5f, .021717f, -5.4515e-5f,
-    2840.f, 2850.f, 1.0411e-4f, .11175f, .031522f, 3.5658e-5f, .036103f,
-    -8.82e-5f, 2850.f, 2860.f, .0079899f, .07314f, .02926f, -1.0778e-4f,
-    .03194f, -1.11e-4f, 2860.f, 2870.f, .024725f, .10335f, .008848f,
-    -3.2902e-5f, .010195f, -1.929e-5f, 2870.f, 2880.f, 5.7422e-4f, .18372f,
-    .046405f, -1.7178e-4f, .046094f, -1.887e-4f, 2880.f, 2890.f, .067995f,
-    .089991f, .016432f, -5.4992e-5f, .019457f, -5.5113e-5f, 2890.f, 2900.f,
-    .03635f, .17982f, .015309f, 7.9551e-7f, .018904f, -3.6064e-5f, 2900.f,
-    2910.f, .02725f, .14127f, .030783f, -1.2895e-4f, .031036f, -1.2355e-4f,
-    2910.f, 2920.f, .002652f, .19136f, .041919f, -1.6834e-4f, .042452f,
-    -1.753e-4f, 2920.f, 2930.f, .52888f, .269f, .012546f, -3.0896e-5f,
-    .013568f, -4.2996e-5f, 2930.f, 2940.f, .053771f, .17608f, .020209f,
-    -6.024e-5f, .025687f, -8.3758e-5f, 2940.f, 2950.f, .32492f, .1684f,
-    .021364f, -9.2341e-5f, .020449f, -8.8117e-5f, 2950.f, 2960.f, .61749f,
-    .1805f, .013955f, -6.0114e-5f, .014337f, -5.833e-5f, 2960.f, 2970.f,
-    1.5421f, .13158f, .0096584f, -4.1781e-5f, .0089471f, -3.729e-5f, 2970.f,
+				     2620.f, 2630.f, 1.8043e-4f, .087686f, .026248f, -3.0398e-5f, .03174f,
+				     -1.367e-4f, 2630.f, 2640.f, 1.3339e-4f, .05328f, .012701f, -4.6874e-5f,
+				     .012628f, -6.7487e-5f, 2640.f, 2650.f, 4.115e-5f, .0075778f, .011257f,
+				     1.1038e-4f, .036362f, -1.1284e-4f, 2650.f, 2660.f, 6.1395e-5f, .026074f,
+				     .016798f, 1.0755e-4f, .035481f, -1.3778e-4f, 2660.f, 2670.f, 3.5062e-4f,
+				     .080662f, .021065f, -3.9968e-5f, .021602f, -8.7339e-5f, 2670.f, 2680.f,
+				     2.6391e-4f, .11483f, .02727f, -4.0691e-5f, .029928f, -1.1046e-4f,
+				     2680.f, 2690.f, 8.741e-4f, .06007f, .021732f, -8.76e-5f, .020645f,
+				     -9.6557e-5f, 2690.f, 2700.f, 3.0675e-5f, .02297f, .0094212f, 7.8691e-6f,
+				     .015402f, -7.4597e-5f, 2700.f, 2710.f, 2.1928e-4f, .13351f, .022082f,
+				     -4.5472e-5f, .02546f, -9.6549e-5f, 2710.f, 2720.f, 3.4904e-4f, .095073f,
+				     .013969f, 1.2276e-6f, .016415f, -6.5204e-5f, 2720.f, 2730.f, .002136f,
+				     .061072f, .018908f, -7.653e-5f, .019801f, -7.7251e-5f, 2730.f, 2740.f,
+				     1.3372e-4f, .10806f, .025683f, -4.923e-5f, .025729f, -8.9387e-5f,
+				     2740.f, 2750.f, .0021697f, .062188f, .018593f, -8.0474e-5f, .016349f,
+				     -8.1422e-5f, 2750.f, 2760.f, 4.503e-5f, .014902f, .011376f, 2.086e-4f,
+				     .04688f, -1.3018e-4f, 2760.f, 2770.f, 3.9413e-4f, .075433f, .019773f,
+				     3.0322e-5f, .02086f, -4.5326e-5f, 2770.f, 2780.f, .0048935f, .096746f,
+				     .019042f, -7.2945e-5f, .016358f, -7.6368e-5f, 2780.f, 2790.f,
+				     5.6197e-5f, .026178f, .017977f, 1.4035e-4f, .032163f, -7.1639e-5f,
+				     2790.f, 2800.f, .0017459f, .049818f, .012334f, -5.2052e-5f, .013169f,
+				     -4.5266e-5f, 2800.f, 2810.f, .013747f, .048325f, .012754f, -6.181e-5f,
+				     .011564f, -4.9886e-5f, 2810.f, 2820.f, 8.2805e-4f, .084185f, .021588f,
+				     3.0162e-6f, .021186f, -3.7441e-5f, 2820.f, 2830.f, .011866f, .034247f,
+				     .0094911f, -5.0331e-5f, .0068889f, -4.5062e-5f, 2830.f, 2840.f,
+				     .0053887f, .10669f, .021019f, -5.3528e-5f, .021717f, -5.4515e-5f,
+				     2840.f, 2850.f, 1.0411e-4f, .11175f, .031522f, 3.5658e-5f, .036103f,
+				     -8.82e-5f, 2850.f, 2860.f, .0079899f, .07314f, .02926f, -1.0778e-4f,
+				     .03194f, -1.11e-4f, 2860.f, 2870.f, .024725f, .10335f, .008848f,
+				     -3.2902e-5f, .010195f, -1.929e-5f, 2870.f, 2880.f, 5.7422e-4f, .18372f,
+				     .046405f, -1.7178e-4f, .046094f, -1.887e-4f, 2880.f, 2890.f, .067995f,
+				     .089991f, .016432f, -5.4992e-5f, .019457f, -5.5113e-5f, 2890.f, 2900.f,
+				     .03635f, .17982f, .015309f, 7.9551e-7f, .018904f, -3.6064e-5f, 2900.f,
+				     2910.f, .02725f, .14127f, .030783f, -1.2895e-4f, .031036f, -1.2355e-4f,
+				     2910.f, 2920.f, .002652f, .19136f, .041919f, -1.6834e-4f, .042452f,
+				     -1.753e-4f, 2920.f, 2930.f, .52888f, .269f, .012546f, -3.0896e-5f,
+				     .013568f, -4.2996e-5f, 2930.f, 2940.f, .053771f, .17608f, .020209f,
+				     -6.024e-5f, .025687f, -8.3758e-5f, 2940.f, 2950.f, .32492f, .1684f,
+				     .021364f, -9.2341e-5f, .020449f, -8.8117e-5f, 2950.f, 2960.f, .61749f,
+				     .1805f, .013955f, -6.0114e-5f, .014337f, -5.833e-5f, 2960.f, 2970.f,
+				     1.5421f, .13158f, .0096584f, -4.1781e-5f, .0089471f, -3.729e-5f, 2970.f,
-    2980.f, 1.6668f, .2273f, .0099338f, -3.7288e-5f, .01043f, -3.702e-5f,
-    2980.f, 2990.f, 1.5158f, .13985f, .011565f, -5.1421e-5f, .011056f,
-    -4.3391e-5f, 2990.f, 3e3f, 1.6503f, .17713f, .0095447f, -3.7275e-5f,
-    .0086134f, -3.6851e-5f, 3e3f, 3010.f, 6.5433f, .21911f, .0060474f,
-    -3.289e-5f, .0053084f, -2.7435e-5f, 3010.f, 3020.f, 2.2497f, .12464f,
-    8.6253e-4f, -6.1061e-6f, .0037153f, 4.0466e-6f, 3020.f, 3030.f, 10.011f,
-    .23151f, .0027571f, -1.9224e-5f, .0021442f, -1.1081e-5f, 3030.f, 3040.f,
-    2.7015f, .12619f, .0016271f, -1.3887e-5f, .001636f, -1.9543e-8f, 3040.f,
-    3050.f, 5.2767f, .13242f, .001288f, -1.3169e-5f, .0012577f, -3.613e-6f,
-    3050.f, 3060.f, 9.1595f, .12205f, -.0012513f, -4.0326e-6f, -.0018414f,
-    2.4599e-6f, 3060.f, 3070.f, 4.6857f, .15647f, -4.3308e-5f, -6.9326e-6f,
-    -8.1377e-4f, -3.1694e-6f, 3070.f, 3080.f, 3.2521f, .14435f, .0035016f,
-    -2.0102e-5f, .0037489f, -1.4446e-5f, 3080.f, 3090.f, 8.6678f, .20679f,
-    -.0014866f, 2.2765e-6f, -.001046f, 1.7536e-6f, 3090.f, 3100.f, 9.0277f,
-    .2295f, -.0010574f, -1.1212e-6f, -6.8088e-4f, -3.9181e-8f, 3100.f,
-    3110.f, 12.148f, .38295f, 4.9769e-4f, -4.4194e-6f, 4.3116e-4f,
-    -4.0708e-6f, 3110.f, 3120.f, 9.4078f, .34012f, -3.175e-5f, 2.1043e-6f,
-    .0022348f, 1.6614e-7f, 3120.f, 3130.f, 6.1004f, .077373f, -.004677f,
-    1.1726e-5f, -5.7011e-4f, 3.3047e-5f, 3130.f, 3140.f, .64298f, .083113f,
-    -9.0344e-4f, 7.4815e-6f, .0068034f, 3.8978e-5f, 3140.f, 3150.f, .31468f,
-    .22047f, .0087793f, -1.3249e-5f, .014974f, -2.9267e-5f, 3150.f, 3160.f,
-    .84773f, .34913f, .0023565f, -7.7347e-7f, .004167f, 2.4148e-6f, 3160.f,
-    3170.f, 6.7043f, .10518f, -.0049662f, 1.3112e-5f, -9.2458e-4f,
-    3.1899e-5f, 3170.f, 3180.f, 3.3487f, .17575f, -.0036206f, 1.2779e-5f,
-    5.0643e-5f, 2.6882e-5f, 3180.f, 3190.f, 7.1051f, .15577f, -.0032039f,
-    5.7362e-6f, -.0027319f, 2.0608e-5f, 3190.f, 3200.f, 4.9187f, .094692f,
-    -.0034658f, 9.9349e-6f, 6.5696e-4f, 2.9105e-5f, 3200.f, 3210.f, 11.08f,
-    .15706f, -.0036162f, 6.4921e-6f, -.002575f, 1.9544e-5f, 3210.f, 3220.f,
-    6.4326f, .26178f, -3.2818e-4f, 3.2261e-6f, 5.6524e-4f, 5.0713e-6f,
-    3220.f, 3230.f, 4.8444f, .21447f, -.0019614f, 1.5381e-5f, .0019305f,
-    2.4092e-5f, 3230.f, 3240.f, 8.8873f, .19618f, -.0011584f, 1.5371e-6f,
-    5.7401e-4f, 5.5356e-6f, 3240.f, 3250.f, 6.7011f, .11596f, 3.1879e-4f,
-    -3.2082e-7f, .0027244f, 9.5927e-6f, 3250.f, 3260.f, 3.2951f, .21537f,
-    .0018132f, -9.3642e-6f, .0034721f, -1.0415e-5f, 3260.f, 3270.f, 11.905f,
-    .31637f, -1.7961e-5f, 7.0218e-6f, .0027392f, 8.7434e-8f, 3270.f, 3280.f,
-    4.8139f, .2732f, .0023884f, 2.6589e-5f, .0043504f, 5.7992e-6f, 3280.f,
-    3290.f, 6.9428f, .3268f, .0028073f, -7.0232e-6f, .0032805f, -8.5722e-6f,
-    3290.f, 3300.f, 5.2753f, .19806f, .0027307f, -1.4565e-6f, .0049125f,
-    -1.2966e-5f, 3300.f, 3310.f, 4.7208f, .23262f, .002983f, 2.6911e-5f,
-    .0064942f, -7.7622e-6f, 3310.f, 3320.f, 3.2466f, .37221f, .0099704f,
-    -2.8634e-5f, .011158f, -3.6092e-5f, 3320.f, 3330.f, 4.2083f, .17584f,
-    .013723f, -3.9504e-5f, .013219f, -4.4922e-5f, 3330.f, 3340.f, .78485f,
-    .29505f, .018153f, -7.6368e-5f, .018172f, -6.9561e-5f, 3340.f, 3350.f,
-    4.0763f, .2731f, .011974f, -3.8706e-5f, .010563f, -3.3592e-5f, 3350.f,
-    3360.f, 12.275f, .42572f, .0045309f, 5.9958e-6f, .0056864f, -1.5831e-5f,
-    3360.f, 3370.f, .94088f, .2913f, .012712f, -2.3725e-5f, .01375f,
-    -2.6806e-5f, 3370.f, 3380.f, 5.802f, .18758f, .0056963f, -9.9475e-6f,
-    .0091903f, -1.2922e-5f, 3380.f, 3390.f, 11.279f, .22153f, .010955f,
-    -4.55e-5f, .010347f, -3.3646e-5f, 3390.f, 3400.f, 3.0915f, .29101f,
-    .0076973f, -3.1164e-6f, .0079615f, -1.2231e-5f, 3400.f, 3410.f, 2.746f,
-    .24709f, .01353f, -3.9278e-5f, .015939f, -3.5039e-5f, 3410.f, 3420.f,
-    14.49f, .18486f, .0089652f, -3.5228e-5f, .009544f, -2.5256e-5f, 3420.f,
-    3430.f, 4.152f, .37165f, .0094576f, -9.1648e-6f, .01319f, -1.9085e-5f,
-    3430.f, 3440.f, 35.28f, .29267f, .0077335f, -3.3655e-5f, .0086235f,
-    -3.439e-5f, 3440.f, 3450.f, 1.6073f, .33722f, .016402f, 1.5852e-5f,
-    .018964f, -3.2271e-5f, 3450.f, 3460.f, 13.605f, .31569f, .0095057f,
-    -1.5485e-5f, .0094813f, -1.6751e-5f, 3460.f, 3470.f, 7.5164f, .27307f,
-    .0075889f, -4.7962e-6f, .012249f, -2.3811e-5f, 3470.f, 3480.f, 33.484f,
-    .31131f, .0077627f, -1.1503e-5f, .0094019f, -2.0136e-5f, 3480.f, 3490.f,
-    13.815f, .23917f, .010592f, -3.1935e-5f, .012433f, -3.6436e-5f, 3490.f,
-    3500.f, 61.974f, .36287f, .0075577f, 2.6848e-6f, .010181f, -2.3323e-5f,
-    3500.f, 3510.f, 14.812f, .37195f, .008261f, -1.8654e-5f, .010113f,
-    -3.1482e-5f, 3510.f, 3520.f, 83.223f, .39932f, .0076795f, 5.0656e-7f,
-    .0082892f, -2.0998e-5f, 3520.f, 3530.f, 21.464f, .29835f, .014148f,
-    -4.3852e-5f, .013193f, -5.1897e-5f, 3530.f, 3540.f, 78.956f, .41357f,
-    .012512f, -2.8052e-5f, .0093167f, -3.188e-5f, 3540.f, 3550.f, 57.829f,
-    .33002f, .0050941f, -8.3644e-6f, .0066338f, -1.927e-5f, 3550.f, 3560.f,
-    264.95f, .48627f, .0094242f, -2.4386e-5f, .0071083f, -3.052e-5f, 3560.f,
-    3570.f, 48.65f, .32647f, .003423f, -1.2164e-5f, .0023536f, -9.56e-6f,
-    3570.f, 3580.f, 278.65f, .3935f, .010521f, -4.8325e-5f, .0076691f,
-    -3.9509e-5f, 3580.f, 3590.f, 160.87f, .35038f, .0056295f, -1.9831e-5f,
-    .0040519f, -1.575e-5f, 3590.f, 3600.f, 337.87f, .23399f, .0064862f,
-    -3.0846e-5f, .0044382f, -2.4648e-5f, 3600.f, 3610.f, 576.3f, .34952f,
-    .0047866f, -2.6607e-5f, .0014788f, -1.5623e-5f, 3610.f, 3620.f, 753.87f,
-    .18159f, .0042931f, -2.8734e-5f, .0024163f, -2.2384e-5f, 3620.f, 3630.f,
-    135.67f, .19692f, .0012097f, -8.0313e-6f, -4.4021e-4f, 5.3739e-7f,
-    3630.f, 3640.f, 776.59f, .21673f, .0021798f, -2.0291e-5f, 5.0596e-4f,
-    -1.5749e-5f, 3640.f, 3650.f, 657.22f, .1435f, .001212f, -1.6829e-5f,
-    -2.0471e-4f, -9.1773e-6f, 3650.f, 3660.f, 229.37f, .088535f, -3.47e-4f,
-    -8.0698e-6f, 7.053e-4f, -5.8648e-7f, 3660.f, 3670.f, 1746.9f, .21306f,
-    -.0011718f, -7.1619e-6f, -.0032694f, -2.8781e-7f, 3670.f, 3680.f,
-    833.45f, .086211f, -.0027517f, -7.8552e-7f, -.0033472f, 1.3487e-5f,
-    3680.f, 3690.f, 324.07f, .27669f, -.0021659f, 4.4909e-7f, -.0016982f,
-    1.0818e-5f, 3690.f, 3700.f, 485.79f, .23163f, -.0033766f, 7.1088e-6f,
-    -.0016229f, 1.3215e-5f, 3700.f, 3710.f, 693.99f, .19031f, -.0023753f,
-    1.1342e-5f, 2.795e-4f, 1.1827e-5f, 3710.f, 3720.f, 309.49f, .32694f,
-    .0051146f, -3.3747e-6f, .0055153f, -1.4764e-5f, 3720.f, 3730.f, 1205.8f,
-    .33098f, 2.6244e-4f, 4.4389e-6f, 4.3858e-4f, -5.8687e-6f, 3730.f,
-    3740.f, 2387.3f, .35395f, -.0013313f, -2.6877e-6f, -.0025997f,
-    -1.5668e-6f, 3740.f, 3750.f, 1331.8f, .24255f, -.0023524f, 5.7434e-7f,
-    -.0030581f, 2.0511e-6f, 3750.f, 3760.f, 462.66f, .18423f, -.002022f,
-    1.4083e-6f, -.0011856f, 1.3407e-6f, 3760.f, 3770.f, 221.29f, .15206f,
-    -.0045078f, 1.2626e-5f, -.0025579f, 1.1787e-5f, 3770.f, 3780.f, 72.994f,
-    .26021f, -9.4598e-4f, 5.8721e-6f, .0020193f, 1.4281e-6f, 3780.f, 3790.f,
-    243.54f, .11623f, -.0039723f, 1.0003e-5f, -.0024749f, 1.1674e-5f,
-    3790.f, 3800.f, 1610.2f, .13844f, -.0050654f, 8.5459e-6f, -.0061217f,
-    1.4867e-5f, 3800.f, 3810.f, 925.09f, .095941f, -.0040019f, 4.2438e-6f,
-    -.0041671f, 1.3408e-5f, 3810.f, 3820.f, 878.65f, .19813f, -.0032809f,
-    1.3909e-6f, -.0048774f, 6.0213e-6f, 3820.f, 3830.f, 1445.5f, .15082f,
-    -.0027746f, -6.1623e-7f, -.004156f, 6.6755e-6f, 3830.f, 3840.f, 368.8f,
-    .2433f, 4.8895e-4f, -1.2565e-5f, -3.1389e-4f, -8.6255e-6f, 3840.f,
-    3850.f, 2068.8f, .2275f, -8.8059e-4f, -7.9102e-6f, -.0024751f,
-    -3.6839e-6f, 3850.f, 3860.f, 634.35f, .19602f, .0017316f, -1.7618e-5f,
-    2.7542e-4f, -9.9025e-6f, 3860.f, 3870.f, 660.01f, .16073f, .0019181f,
-    -1.8141e-5f, 8.7743e-4f, -1.3268e-5f, 3870.f, 3880.f, 596.2f, .22715f,
-    .0044999f, -2.8285e-5f, .0029743f, -2.3179e-5f, 3880.f, 3890.f, 497.07f,
-    .23257f, .0049027f, -2.8299e-5f, .0031352f, -2.2089e-5f, 3890.f, 3900.f,
-    476.01f, .20656f, .0070284f, -3.7624e-5f, .0056038f, -3.3998e-5f,
-    3900.f, 3910.f, 97.812f, .12575f, .012028f, -5.8026e-5f, .010886f,
-    -5.051e-5f, 3910.f, 3920.f, 154.07f, .2759f, .0075519f, -2.7169e-5f,
-    .0059888f, -2.6593e-5f, 3920.f, 3930.f, 75.906f, .19815f, .014672f,
-    -6.2916e-5f, .010813f, -4.7324e-5f, 3930.f, 3940.f, 91.761f, .19338f,
-    .015621f, -6.9646e-5f, .014264f, -6.8568e-5f, 3940.f, 3950.f, 23.976f,
-    .28167f, .0049108f, 1.7525e-5f, .0072419f, -1.0423e-5f, 3950.f, 3960.f,
-    14.037f, .20425f, .017638f, -2.7195e-5f, .013686f, -3.6754e-5f, 3960.f,
-    3970.f, 15.37f, .33316f, .0098866f, 2.0342e-5f, .011243f, -2.1419e-5f,
-    3970.f, 3980.f, 5.4881f, .22417f, .0075532f, 3.9091e-5f, .010416f,
-    -2.6476e-6f, 3980.f, 3990.f, 8.3126f, .20066f, .013204f, -8.1155e-7f,
-    .014493f, -3.2804e-5f, 3990.f, 4e3f, 8.7033f, .12823f, .0053683f,
-    -1.0088e-5f, .0083956f, -9.9974e-6f, 4e3f, 4010.f, 7.1987f, .21615f,
-    .0019288f, 1.9286e-5f, .006975f, 2.1036e-5f, 4010.f, 4020.f, 7.374f,
-    .10603f, .0021924f, -1.68e-5f, .0031402f, 6.6314e-10f, 4020.f, 4030.f,
-    1.2253f, .20951f, .0061999f, 3.6357e-5f, .012788f, -6.0887e-6f, 4030.f,
-    4040.f, 7.9524f, .12691f, .0039534f, -2.3885e-5f, .0036525f,
-    -1.0242e-5f, 4040.f, 4050.f, .51733f, .11847f, .011888f, -3.4371e-5f,
-    .016178f, -2.9656e-5f, 4050.f, 4060.f, 1.8317f, .094248f, .0053224f,
-    -2.5376e-5f, .005784f, -6.4186e-6f, 4060.f, 4070.f, 2.7229f, .12453f,
-    .0093697f, -3.7263e-5f, .0090599f, -2.2481e-5f, 4070.f, 4080.f, 3.4742f,
-    .19542f, .0072771f, -3.4478e-5f, .0043552f, -2.4708e-5f, 4080.f, 4090.f,
-    .08819f, .11131f, .0125f, -3.4253e-5f, .016631f, -2.1563e-5f, 4090.f,
-    4100.f, 4.472f, .16534f, .0066915f, -3.536e-5f, .0054523f, -3.2561e-5f,
-    4100.f, 4110.f, .017698f, .14435f, .0099143f, 3.28e-5f, .020212f,
-    3.5978e-6f, 4110.f, 4120.f, .49468f, .13443f, .0087298f, -3.5276e-5f,
-    .0068006f, -3.1378e-5f, 4120.f, 4130.f, 2.2881f, .15905f, .011097f,
-    -4.923e-5f, .01025f, -4.8021e-5f, 4130.f, 4140.f, .62111f, .16054f,
-    .011288f, -5.0025e-5f, .010196f, -4.7296e-5f, 4140.f, 4150.f, .60454f,
-    .14755f, .014727f, -4.9548e-5f, .014191f, -5.8716e-5f, 4150.f, 4160.f,
-    .093094f, .068954f, .004002f, -3.9015e-6f, .0055718f, -1.3126e-6f,
-    4160.f, 4170.f, .27101f, .093272f, .013113f, -5.6084e-5f, .012707f,
-    -5.2567e-5f, 4170.f, 4180.f, .5398f, .067639f, .016122f, -7.5048e-5f,
-    .013265f, -6.515e-5f, 4180.f, 4190.f, .44133f, .17104f, .016673f,
-    -7.1388e-5f, .014609f, -6.461e-5f, 4190.f, 4200.f, .36918f, .11239f,
-    .013785f, -5.548e-5f, .014404f, -5.8254e-5f, 4200.f, 4210.f, .13276f,
-    .12746f, .017403f, -5.447e-5f, .013863f, -4.8485e-5f, 4210.f, 4220.f,
-    .080464f, .086998f, .022044f, -9.2895e-5f, .019048f, -8.7985e-5f,
-    4220.f, 4230.f, .063692f, .14834f, .022806f, -8.4692e-5f, .023548f,
-    -9.253e-5f, 4230.f, 4240.f, .01811f, .12119f, .018389f, -2.2676e-6f,
-    .013683f, -2.6036e-5f, 4240.f, 4250.f, .209f, .16597f, .019432f,
-    -7.8011e-5f, .019282f, -8.4089e-5f, 4250.f, 4260.f, .049819f, .06211f,
-    .026704f, -1.1099e-4f, .025655f, -1.0067e-4f, 4260.f, 4270.f, .051444f,
-    .1311f, .014568f, -3.4291e-5f, .014016f, -4.9479e-5f, 4270.f, 4280.f,
-    .010759f, .15106f, .027993f, -1.0013e-4f, .023418f, -8.4057e-5f, 4280.f,
-    4290.f, .005931f, .085611f, .036412f, -1.5063e-4f, .034796f,
-    -1.4138e-4f, 4290.f, 4300.f, .060294f, .13145f, .023253f, -8.8313e-5f,
-    .022949f, -9.0705e-5f, 4300.f, 4310.f, .0087499f, .11428f, .024739f,
-    -5.6984e-5f, .024765f, -7.2542e-5f, 4310.f, 4320.f, .0043984f, .17658f,
-    .035844f, -1.1719e-4f, .030706f, -1.0295e-4f, 4320.f, 4330.f, .0031592f,
-    .14762f, .014237f, 6.5312e-6f, .014523f, -1.9336e-5f, 4330.f, 4340.f,
+				     2980.f, 1.6668f, .2273f, .0099338f, -3.7288e-5f, .01043f, -3.702e-5f,
+				     2980.f, 2990.f, 1.5158f, .13985f, .011565f, -5.1421e-5f, .011056f,
+				     -4.3391e-5f, 2990.f, 3e3f, 1.6503f, .17713f, .0095447f, -3.7275e-5f,
+				     .0086134f, -3.6851e-5f, 3e3f, 3010.f, 6.5433f, .21911f, .0060474f,
+				     -3.289e-5f, .0053084f, -2.7435e-5f, 3010.f, 3020.f, 2.2497f, .12464f,
+				     8.6253e-4f, -6.1061e-6f, .0037153f, 4.0466e-6f, 3020.f, 3030.f, 10.011f,
+				     .23151f, .0027571f, -1.9224e-5f, .0021442f, -1.1081e-5f, 3030.f, 3040.f,
+				     2.7015f, .12619f, .0016271f, -1.3887e-5f, .001636f, -1.9543e-8f, 3040.f,
+				     3050.f, 5.2767f, .13242f, .001288f, -1.3169e-5f, .0012577f, -3.613e-6f,
+				     3050.f, 3060.f, 9.1595f, .12205f, -.0012513f, -4.0326e-6f, -.0018414f,
+				     2.4599e-6f, 3060.f, 3070.f, 4.6857f, .15647f, -4.3308e-5f, -6.9326e-6f,
+				     -8.1377e-4f, -3.1694e-6f, 3070.f, 3080.f, 3.2521f, .14435f, .0035016f,
+				     -2.0102e-5f, .0037489f, -1.4446e-5f, 3080.f, 3090.f, 8.6678f, .20679f,
+				     -.0014866f, 2.2765e-6f, -.001046f, 1.7536e-6f, 3090.f, 3100.f, 9.0277f,
+				     .2295f, -.0010574f, -1.1212e-6f, -6.8088e-4f, -3.9181e-8f, 3100.f,
+				     3110.f, 12.148f, .38295f, 4.9769e-4f, -4.4194e-6f, 4.3116e-4f,
+				     -4.0708e-6f, 3110.f, 3120.f, 9.4078f, .34012f, -3.175e-5f, 2.1043e-6f,
+				     .0022348f, 1.6614e-7f, 3120.f, 3130.f, 6.1004f, .077373f, -.004677f,
+				     1.1726e-5f, -5.7011e-4f, 3.3047e-5f, 3130.f, 3140.f, .64298f, .083113f,
+				     -9.0344e-4f, 7.4815e-6f, .0068034f, 3.8978e-5f, 3140.f, 3150.f, .31468f,
+				     .22047f, .0087793f, -1.3249e-5f, .014974f, -2.9267e-5f, 3150.f, 3160.f,
+				     .84773f, .34913f, .0023565f, -7.7347e-7f, .004167f, 2.4148e-6f, 3160.f,
+				     3170.f, 6.7043f, .10518f, -.0049662f, 1.3112e-5f, -9.2458e-4f,
+				     3.1899e-5f, 3170.f, 3180.f, 3.3487f, .17575f, -.0036206f, 1.2779e-5f,
+				     5.0643e-5f, 2.6882e-5f, 3180.f, 3190.f, 7.1051f, .15577f, -.0032039f,
+				     5.7362e-6f, -.0027319f, 2.0608e-5f, 3190.f, 3200.f, 4.9187f, .094692f,
+				     -.0034658f, 9.9349e-6f, 6.5696e-4f, 2.9105e-5f, 3200.f, 3210.f, 11.08f,
+				     .15706f, -.0036162f, 6.4921e-6f, -.002575f, 1.9544e-5f, 3210.f, 3220.f,
+				     6.4326f, .26178f, -3.2818e-4f, 3.2261e-6f, 5.6524e-4f, 5.0713e-6f,
+				     3220.f, 3230.f, 4.8444f, .21447f, -.0019614f, 1.5381e-5f, .0019305f,
+				     2.4092e-5f, 3230.f, 3240.f, 8.8873f, .19618f, -.0011584f, 1.5371e-6f,
+				     5.7401e-4f, 5.5356e-6f, 3240.f, 3250.f, 6.7011f, .11596f, 3.1879e-4f,
+				     -3.2082e-7f, .0027244f, 9.5927e-6f, 3250.f, 3260.f, 3.2951f, .21537f,
+				     .0018132f, -9.3642e-6f, .0034721f, -1.0415e-5f, 3260.f, 3270.f, 11.905f,
+				     .31637f, -1.7961e-5f, 7.0218e-6f, .0027392f, 8.7434e-8f, 3270.f, 3280.f,
+				     4.8139f, .2732f, .0023884f, 2.6589e-5f, .0043504f, 5.7992e-6f, 3280.f,
+				     3290.f, 6.9428f, .3268f, .0028073f, -7.0232e-6f, .0032805f, -8.5722e-6f,
+				     3290.f, 3300.f, 5.2753f, .19806f, .0027307f, -1.4565e-6f, .0049125f,
+				     -1.2966e-5f, 3300.f, 3310.f, 4.7208f, .23262f, .002983f, 2.6911e-5f,
+				     .0064942f, -7.7622e-6f, 3310.f, 3320.f, 3.2466f, .37221f, .0099704f,
+				     -2.8634e-5f, .011158f, -3.6092e-5f, 3320.f, 3330.f, 4.2083f, .17584f,
+				     .013723f, -3.9504e-5f, .013219f, -4.4922e-5f, 3330.f, 3340.f, .78485f,
+				     .29505f, .018153f, -7.6368e-5f, .018172f, -6.9561e-5f, 3340.f, 3350.f,
+				     4.0763f, .2731f, .011974f, -3.8706e-5f, .010563f, -3.3592e-5f, 3350.f,
+				     3360.f, 12.275f, .42572f, .0045309f, 5.9958e-6f, .0056864f, -1.5831e-5f,
+				     3360.f, 3370.f, .94088f, .2913f, .012712f, -2.3725e-5f, .01375f,
+				     -2.6806e-5f, 3370.f, 3380.f, 5.802f, .18758f, .0056963f, -9.9475e-6f,
+				     .0091903f, -1.2922e-5f, 3380.f, 3390.f, 11.279f, .22153f, .010955f,
+				     -4.55e-5f, .010347f, -3.3646e-5f, 3390.f, 3400.f, 3.0915f, .29101f,
+				     .0076973f, -3.1164e-6f, .0079615f, -1.2231e-5f, 3400.f, 3410.f, 2.746f,
+				     .24709f, .01353f, -3.9278e-5f, .015939f, -3.5039e-5f, 3410.f, 3420.f,
+				     14.49f, .18486f, .0089652f, -3.5228e-5f, .009544f, -2.5256e-5f, 3420.f,
+				     3430.f, 4.152f, .37165f, .0094576f, -9.1648e-6f, .01319f, -1.9085e-5f,
+				     3430.f, 3440.f, 35.28f, .29267f, .0077335f, -3.3655e-5f, .0086235f,
+				     -3.439e-5f, 3440.f, 3450.f, 1.6073f, .33722f, .016402f, 1.5852e-5f,
+				     .018964f, -3.2271e-5f, 3450.f, 3460.f, 13.605f, .31569f, .0095057f,
+				     -1.5485e-5f, .0094813f, -1.6751e-5f, 3460.f, 3470.f, 7.5164f, .27307f,
+				     .0075889f, -4.7962e-6f, .012249f, -2.3811e-5f, 3470.f, 3480.f, 33.484f,
+				     .31131f, .0077627f, -1.1503e-5f, .0094019f, -2.0136e-5f, 3480.f, 3490.f,
+				     13.815f, .23917f, .010592f, -3.1935e-5f, .012433f, -3.6436e-5f, 3490.f,
+				     3500.f, 61.974f, .36287f, .0075577f, 2.6848e-6f, .010181f, -2.3323e-5f,
+				     3500.f, 3510.f, 14.812f, .37195f, .008261f, -1.8654e-5f, .010113f,
+				     -3.1482e-5f, 3510.f, 3520.f, 83.223f, .39932f, .0076795f, 5.0656e-7f,
+				     .0082892f, -2.0998e-5f, 3520.f, 3530.f, 21.464f, .29835f, .014148f,
+				     -4.3852e-5f, .013193f, -5.1897e-5f, 3530.f, 3540.f, 78.956f, .41357f,
+				     .012512f, -2.8052e-5f, .0093167f, -3.188e-5f, 3540.f, 3550.f, 57.829f,
+				     .33002f, .0050941f, -8.3644e-6f, .0066338f, -1.927e-5f, 3550.f, 3560.f,
+				     264.95f, .48627f, .0094242f, -2.4386e-5f, .0071083f, -3.052e-5f, 3560.f,
+				     3570.f, 48.65f, .32647f, .003423f, -1.2164e-5f, .0023536f, -9.56e-6f,
+				     3570.f, 3580.f, 278.65f, .3935f, .010521f, -4.8325e-5f, .0076691f,
+				     -3.9509e-5f, 3580.f, 3590.f, 160.87f, .35038f, .0056295f, -1.9831e-5f,
+				     .0040519f, -1.575e-5f, 3590.f, 3600.f, 337.87f, .23399f, .0064862f,
+				     -3.0846e-5f, .0044382f, -2.4648e-5f, 3600.f, 3610.f, 576.3f, .34952f,
+				     .0047866f, -2.6607e-5f, .0014788f, -1.5623e-5f, 3610.f, 3620.f, 753.87f,
+				     .18159f, .0042931f, -2.8734e-5f, .0024163f, -2.2384e-5f, 3620.f, 3630.f,
+				     135.67f, .19692f, .0012097f, -8.0313e-6f, -4.4021e-4f, 5.3739e-7f,
+				     3630.f, 3640.f, 776.59f, .21673f, .0021798f, -2.0291e-5f, 5.0596e-4f,
+				     -1.5749e-5f, 3640.f, 3650.f, 657.22f, .1435f, .001212f, -1.6829e-5f,
+				     -2.0471e-4f, -9.1773e-6f, 3650.f, 3660.f, 229.37f, .088535f, -3.47e-4f,
+				     -8.0698e-6f, 7.053e-4f, -5.8648e-7f, 3660.f, 3670.f, 1746.9f, .21306f,
+				     -.0011718f, -7.1619e-6f, -.0032694f, -2.8781e-7f, 3670.f, 3680.f,
+				     833.45f, .086211f, -.0027517f, -7.8552e-7f, -.0033472f, 1.3487e-5f,
+				     3680.f, 3690.f, 324.07f, .27669f, -.0021659f, 4.4909e-7f, -.0016982f,
+				     1.0818e-5f, 3690.f, 3700.f, 485.79f, .23163f, -.0033766f, 7.1088e-6f,
+				     -.0016229f, 1.3215e-5f, 3700.f, 3710.f, 693.99f, .19031f, -.0023753f,
+				     1.1342e-5f, 2.795e-4f, 1.1827e-5f, 3710.f, 3720.f, 309.49f, .32694f,
+				     .0051146f, -3.3747e-6f, .0055153f, -1.4764e-5f, 3720.f, 3730.f, 1205.8f,
+				     .33098f, 2.6244e-4f, 4.4389e-6f, 4.3858e-4f, -5.8687e-6f, 3730.f,
+				     3740.f, 2387.3f, .35395f, -.0013313f, -2.6877e-6f, -.0025997f,
+				     -1.5668e-6f, 3740.f, 3750.f, 1331.8f, .24255f, -.0023524f, 5.7434e-7f,
+				     -.0030581f, 2.0511e-6f, 3750.f, 3760.f, 462.66f, .18423f, -.002022f,
+				     1.4083e-6f, -.0011856f, 1.3407e-6f, 3760.f, 3770.f, 221.29f, .15206f,
+				     -.0045078f, 1.2626e-5f, -.0025579f, 1.1787e-5f, 3770.f, 3780.f, 72.994f,
+				     .26021f, -9.4598e-4f, 5.8721e-6f, .0020193f, 1.4281e-6f, 3780.f, 3790.f,
+				     243.54f, .11623f, -.0039723f, 1.0003e-5f, -.0024749f, 1.1674e-5f,
+				     3790.f, 3800.f, 1610.2f, .13844f, -.0050654f, 8.5459e-6f, -.0061217f,
+				     1.4867e-5f, 3800.f, 3810.f, 925.09f, .095941f, -.0040019f, 4.2438e-6f,
+				     -.0041671f, 1.3408e-5f, 3810.f, 3820.f, 878.65f, .19813f, -.0032809f,
+				     1.3909e-6f, -.0048774f, 6.0213e-6f, 3820.f, 3830.f, 1445.5f, .15082f,
+				     -.0027746f, -6.1623e-7f, -.004156f, 6.6755e-6f, 3830.f, 3840.f, 368.8f,
+				     .2433f, 4.8895e-4f, -1.2565e-5f, -3.1389e-4f, -8.6255e-6f, 3840.f,
+				     3850.f, 2068.8f, .2275f, -8.8059e-4f, -7.9102e-6f, -.0024751f,
+				     -3.6839e-6f, 3850.f, 3860.f, 634.35f, .19602f, .0017316f, -1.7618e-5f,
+				     2.7542e-4f, -9.9025e-6f, 3860.f, 3870.f, 660.01f, .16073f, .0019181f,
+				     -1.8141e-5f, 8.7743e-4f, -1.3268e-5f, 3870.f, 3880.f, 596.2f, .22715f,
+				     .0044999f, -2.8285e-5f, .0029743f, -2.3179e-5f, 3880.f, 3890.f, 497.07f,
+				     .23257f, .0049027f, -2.8299e-5f, .0031352f, -2.2089e-5f, 3890.f, 3900.f,
+				     476.01f, .20656f, .0070284f, -3.7624e-5f, .0056038f, -3.3998e-5f,
+				     3900.f, 3910.f, 97.812f, .12575f, .012028f, -5.8026e-5f, .010886f,
+				     -5.051e-5f, 3910.f, 3920.f, 154.07f, .2759f, .0075519f, -2.7169e-5f,
+				     .0059888f, -2.6593e-5f, 3920.f, 3930.f, 75.906f, .19815f, .014672f,
+				     -6.2916e-5f, .010813f, -4.7324e-5f, 3930.f, 3940.f, 91.761f, .19338f,
+				     .015621f, -6.9646e-5f, .014264f, -6.8568e-5f, 3940.f, 3950.f, 23.976f,
+				     .28167f, .0049108f, 1.7525e-5f, .0072419f, -1.0423e-5f, 3950.f, 3960.f,
+				     14.037f, .20425f, .017638f, -2.7195e-5f, .013686f, -3.6754e-5f, 3960.f,
+				     3970.f, 15.37f, .33316f, .0098866f, 2.0342e-5f, .011243f, -2.1419e-5f,
+				     3970.f, 3980.f, 5.4881f, .22417f, .0075532f, 3.9091e-5f, .010416f,
+				     -2.6476e-6f, 3980.f, 3990.f, 8.3126f, .20066f, .013204f, -8.1155e-7f,
+				     .014493f, -3.2804e-5f, 3990.f, 4e3f, 8.7033f, .12823f, .0053683f,
+				     -1.0088e-5f, .0083956f, -9.9974e-6f, 4e3f, 4010.f, 7.1987f, .21615f,
+				     .0019288f, 1.9286e-5f, .006975f, 2.1036e-5f, 4010.f, 4020.f, 7.374f,
+				     .10603f, .0021924f, -1.68e-5f, .0031402f, 6.6314e-10f, 4020.f, 4030.f,
+				     1.2253f, .20951f, .0061999f, 3.6357e-5f, .012788f, -6.0887e-6f, 4030.f,
+				     4040.f, 7.9524f, .12691f, .0039534f, -2.3885e-5f, .0036525f,
+				     -1.0242e-5f, 4040.f, 4050.f, .51733f, .11847f, .011888f, -3.4371e-5f,
+				     .016178f, -2.9656e-5f, 4050.f, 4060.f, 1.8317f, .094248f, .0053224f,
+				     -2.5376e-5f, .005784f, -6.4186e-6f, 4060.f, 4070.f, 2.7229f, .12453f,
+				     .0093697f, -3.7263e-5f, .0090599f, -2.2481e-5f, 4070.f, 4080.f, 3.4742f,
+				     .19542f, .0072771f, -3.4478e-5f, .0043552f, -2.4708e-5f, 4080.f, 4090.f,
+				     .08819f, .11131f, .0125f, -3.4253e-5f, .016631f, -2.1563e-5f, 4090.f,
+				     4100.f, 4.472f, .16534f, .0066915f, -3.536e-5f, .0054523f, -3.2561e-5f,
+				     4100.f, 4110.f, .017698f, .14435f, .0099143f, 3.28e-5f, .020212f,
+				     3.5978e-6f, 4110.f, 4120.f, .49468f, .13443f, .0087298f, -3.5276e-5f,
+				     .0068006f, -3.1378e-5f, 4120.f, 4130.f, 2.2881f, .15905f, .011097f,
+				     -4.923e-5f, .01025f, -4.8021e-5f, 4130.f, 4140.f, .62111f, .16054f,
+				     .011288f, -5.0025e-5f, .010196f, -4.7296e-5f, 4140.f, 4150.f, .60454f,
+				     .14755f, .014727f, -4.9548e-5f, .014191f, -5.8716e-5f, 4150.f, 4160.f,
+				     .093094f, .068954f, .004002f, -3.9015e-6f, .0055718f, -1.3126e-6f,
+				     4160.f, 4170.f, .27101f, .093272f, .013113f, -5.6084e-5f, .012707f,
+				     -5.2567e-5f, 4170.f, 4180.f, .5398f, .067639f, .016122f, -7.5048e-5f,
+				     .013265f, -6.515e-5f, 4180.f, 4190.f, .44133f, .17104f, .016673f,
+				     -7.1388e-5f, .014609f, -6.461e-5f, 4190.f, 4200.f, .36918f, .11239f,
+				     .013785f, -5.548e-5f, .014404f, -5.8254e-5f, 4200.f, 4210.f, .13276f,
+				     .12746f, .017403f, -5.447e-5f, .013863f, -4.8485e-5f, 4210.f, 4220.f,
+				     .080464f, .086998f, .022044f, -9.2895e-5f, .019048f, -8.7985e-5f,
+				     4220.f, 4230.f, .063692f, .14834f, .022806f, -8.4692e-5f, .023548f,
+				     -9.253e-5f, 4230.f, 4240.f, .01811f, .12119f, .018389f, -2.2676e-6f,
+				     .013683f, -2.6036e-5f, 4240.f, 4250.f, .209f, .16597f, .019432f,
+				     -7.8011e-5f, .019282f, -8.4089e-5f, 4250.f, 4260.f, .049819f, .06211f,
+				     .026704f, -1.1099e-4f, .025655f, -1.0067e-4f, 4260.f, 4270.f, .051444f,
+				     .1311f, .014568f, -3.4291e-5f, .014016f, -4.9479e-5f, 4270.f, 4280.f,
+				     .010759f, .15106f, .027993f, -1.0013e-4f, .023418f, -8.4057e-5f, 4280.f,
+				     4290.f, .005931f, .085611f, .036412f, -1.5063e-4f, .034796f,
+				     -1.4138e-4f, 4290.f, 4300.f, .060294f, .13145f, .023253f, -8.8313e-5f,
+				     .022949f, -9.0705e-5f, 4300.f, 4310.f, .0087499f, .11428f, .024739f,
+				     -5.6984e-5f, .024765f, -7.2542e-5f, 4310.f, 4320.f, .0043984f, .17658f,
+				     .035844f, -1.1719e-4f, .030706f, -1.0295e-4f, 4320.f, 4330.f, .0031592f,
+				     .14762f, .014237f, 6.5312e-6f, .014523f, -1.9336e-5f, 4330.f, 4340.f,
-    .0022605f, .13901f, .023941f, 1.0579e-5f, .023751f, -4.5551e-5f, 4340.f,
-    4350.f, 8.4338e-8f, 1.5285e-4f, .0047057f, -2.5631e-5f, .0022316f,
-    -2.3738e-5f, 4350.f, 4360.f, 9.5411e-8f, 1.1284e-4f, .0051111f,
-    -2.6317e-5f, .0030958f, -2.5483e-5f, 4360.f, 4370.f, 1.5708e-8f,
-    4.7653e-5f, .0099036f, -4.9633e-5f, .0072007f, -4.4307e-5f, 4370.f,
-    4380.f, 7.2646e-5f, .073368f, .017942f, 1.2698e-5f, .012584f,
-    -3.4551e-5f, 4380.f, 4390.f, 5.9152e-5f, .041171f, .00839f, -4.5951e-5f,
-    .0057949f, -4.0723e-5f, 4390.f, 4400.f, 9.0913e-5f, .0094376f, .037251f,
-    -1.6131e-4f, .034629f, -1.5582e-4f, 4400.f, 4410.f, 3.4561e-8f,
-    4.7569e-5f, .0015514f, -1.0274e-5f, 6.5701e-7f, -1.2526e-5f, 4410.f,
-    4420.f, 4.3107e-4f, .054262f, .024045f, -4.9839e-5f, .016547f,
-    -4.4636e-5f, 4420.f, 4430.f, 3.1142e-4f, .038963f, .014134f,
-    -6.8927e-5f, .011537f, -6.369e-5f, 4430.f, 4440.f, 1.4945e-8f,
-    7.8332e-5f, .0089337f, -4.3145e-5f, .0069004f, -4.2442e-5f, 4440.f,
-    4450.f, .0016802f, .051222f, .015502f, -2.3447e-5f, .010002f,
-    -3.2528e-5f, 4450.f, 4460.f, 1.0007e-4f, .066862f, .02459f, -9.8504e-5f,
-    .022882f, -1.0233e-4f, 4460.f, 4470.f, .0030025f, .051153f, .01923f,
-    -8.107e-5f, .015535f, -6.8267e-5f, 4470.f, 4480.f, 8.6831e-5f, .040458f,
-    .036221f, -1.5713e-4f, .03335f, -1.5083e-4f, 4480.f, 4490.f, .0080902f,
-    .1275f, .016863f, -7.6478e-5f, .01678f, -7.7918e-5f, 4490.f, 4500.f,
-    .0022317f, .15229f, .012535f, -1.3795e-5f, .010875f, -3.7123e-5f,
-    4500.f, 4510.f, .019169f, .11664f, .010716f, -5.1479e-5f, .0082124f,
-    -4.6198e-5f, 4510.f, 4520.f, .0065788f, .15986f, .012038f, -5.1957e-5f,
-    .010074f, -5.1345e-5f, 4520.f, 4530.f, .03291f, .11768f, .0084067f,
-    -4.3158e-5f, .0067305f, -4.0106e-5f, 4530.f, 4540.f, .044345f, .15763f,
-    .0035365f, -2.4308e-5f, 7.9048e-4f, -1.7012e-5f, 4540.f, 4550.f,
-    .027331f, .16819f, .0042859f, -2.1639e-5f, .0038192f, -2.5423e-5f,
-    4550.f, 4560.f, .020407f, .09609f, .001546f, -1.6323e-5f, 6.6197e-4f,
-    -9.1244e-6f, 4560.f, 4570.f, .057143f, .18848f, .0030453f, -1.8516e-5f,
-    .0016176f, -1.8614e-5f, 4570.f, 4580.f, .052929f, .13102f, -.0010515f,
-    -4.5621e-6f, -.0023271f, 2.7682e-6f, 4580.f, 4590.f, .028557f, .14681f,
-    -4.8301e-4f, -6.3151e-6f, -.0019647f, -5.3522e-6f, 4590.f, 4600.f,
-    .0046383f, .13391f, .0088609f, -2.6493e-5f, .0082741f, -3.2453e-5f,
-    4600.f, 4610.f, .02773f, .10824f, -.0034789f, 5.4132e-6f, -.0030391f,
-    8.0678e-6f, 4610.f, 4620.f, .051267f, .16778f, -.0015076f, -7.4663e-7f,
-    -.0025263f, 3.707e-6f, 4620.f, 4630.f, .0129f, .13459f, 4.1658e-4f,
-    7.4475e-7f, .0012458f, -7.7586e-6f, 4630.f, 4640.f, .044954f, .38311f,
-    -.0018643f, 4.6026e-6f, -.0027134f, 4.4958e-6f, 4640.f, 4650.f,
-    .0048639f, .10343f, .0025659f, -1.6961e-5f, .0023819f, -1.4778e-5f,
-    4650.f, 4660.f, .0012082f, .18004f, .014733f, -5.2646e-5f, .014275f,
-    -6.0508e-5f, 4660.f, 4670.f, .0013469f, .34467f, .012177f, -2.3395e-5f,
-    .010966f, -3.6299e-5f, 4670.f, 4680.f, .0068991f, .1607f, 6.4738e-4f,
-    3.7071e-6f, .0032901f, -2.0981e-6f, 4680.f, 4690.f, .027452f, .060959f,
-    -.0051851f, 1.2668e-5f, -.0041528f, 2.6305e-5f, 4690.f, 4700.f,
-    .017796f, .15523f, -.0027265f, 3.7407e-6f, -.0033733f, 1.0358e-5f,
-    4700.f, 4710.f, .011446f, .17796f, -6.8324e-4f, 6.8406e-6f, -.0010826f,
-    5.9431e-6f, 4710.f, 4720.f, .029309f, .13652f, -.0017282f, 6.762e-6f,
-    5.6764e-4f, 1.3237e-5f, 4720.f, 4730.f, .021395f, .18395f, -.0015768f,
-    1.4383e-5f, 1.5897e-4f, 8.796e-6f, 4730.f, 4740.f, .0025077f, .18622f,
-    .0042912f, -4.9559e-6f, .0045676f, -2.6247e-6f, 4740.f, 4750.f,
-    .031587f, .13943f, -.0012088f, -8.9815e-8f, -1.571e-4f, 2.0359e-5f,
-    4750.f, 4760.f, .034566f, .28253f, .0016858f, -8.995e-6f, 9.752e-4f,
-    -8.1082e-6f, 4760.f, 4770.f, .020369f, .14591f, -.0014421f, 1.9399e-5f,
-    .0039665f, 1.4338e-5f, 4770.f, 4780.f, .0081447f, .12195f, .0013964f,
-    3.2025e-5f, .0037728f, 2.0537e-5f, 4780.f, 4790.f, .019803f, .14625f,
-    9.6298e-4f, -2.9783e-6f, .0041118f, -9.7923e-7f, 4790.f, 4800.f,
-    .0052146f, .17691f, .014543f, -3.1749e-5f, .0149f, -4.4049e-5f, 4800.f,
-    4810.f, .035065f, .21617f, -.0021492f, 2.3072e-5f, .001178f, 2.4416e-5f,
-    4810.f, 4820.f, .012656f, .15792f, .0083705f, -2.1219e-5f, .0082684f,
-    -2.8775e-5f, 4820.f, 4830.f, .014126f, .4985f, .0096621f, 2.3197e-5f,
-    .011163f, -2.0765e-5f, 4830.f, 4840.f, .023704f, .35541f, .0055808f,
-    -1.0952e-6f, .0068854f, -1.3359e-5f, 4840.f, 4850.f, .032166f, .23632f,
-    -2.3289e-4f, 7.945e-6f, .0017163f, 2.8957e-6f, 4850.f, 4860.f, .026468f,
-    .24812f, .008326f, 8.9107e-6f, .010638f, -2.4848e-5f, 4860.f, 4870.f,
-    .012607f, .28278f, .014341f, -1.7161e-5f, .017744f, -4.3433e-5f, 4870.f,
-    4880.f, .0019484f, .13452f, .014299f, -5.8644e-5f, .012622f,
-    -5.8891e-5f, 4880.f, 4890.f, .019835f, .43138f, .016502f, -3.7834e-5f,
-    .015564f, -5.3844e-5f, 4890.f, 4900.f, .031673f, .23676f, .018724f,
-    -6.2795e-5f, .017963f, -6.7476e-5f, 4900.f, 4910.f, .020383f, .1686f,
-    .02082f, -9.2373e-5f, .018807f, -8.5676e-5f, 4910.f, 4920.f, .034221f,
-    .37729f, .014636f, 9.8132e-6f, .015033f, -3.2546e-5f, 4920.f, 4930.f,
-    .041381f, .17341f, .004227f, 2.6778e-5f, .0073624f, -6.193e-6f, 4930.f,
-    4940.f, .050322f, .24574f, .01506f, -6.0731e-5f, .01171f, -4.9448e-5f,
-    4940.f, 4950.f, .11355f, .43168f, .012506f, -2.3567e-5f, .010508f,
-    -3.2884e-5f, 4950.f, 4960.f, .073646f, .28063f, .01551f, -6.3821e-5f,
-    .012136f, -5.1762e-5f, 4960.f, 4970.f, .0021754f, .2329f, .025115f,
-    1.3402e-6f, .023138f, -4.9298e-5f, 4970.f, 4980.f, .20462f, .37006f,
-    .013871f, -5.7344e-5f, .011137f, -4.9726e-5f, 4980.f, 4990.f, .15479f,
-    .14505f, .012101f, -5.5517e-5f, .011913f, -3.8561e-5f, 4990.f, 5e3f,
-    .1627f, .14157f, .012656f, -4.9554e-5f, .01273f, -4.7918e-5f, 5e3f,
-    5010.f, .20283f, .16538f, .0098358f, -4.1905e-5f, .0091599f,
-    -3.3109e-5f, 5010.f, 5020.f, .32847f, .20501f, .010455f, -3.0987e-5f,
-    .011634f, -2.2216e-5f, 5020.f, 5030.f, .4088f, .1568f, .0097922f,
-    -4.2397e-5f, .0098076f, -3.8651e-5f, 5030.f, 5040.f, .27012f, .21951f,
-    .012867f, -1.8768e-6f, .012462f, -2.155e-5f, 5040.f, 5050.f, .5761f,
-    .16605f, .0061804f, -3.0533e-5f, .0069772f, -1.7735e-5f, 5050.f, 5060.f
+				     .0022605f, .13901f, .023941f, 1.0579e-5f, .023751f, -4.5551e-5f, 4340.f,
+				     4350.f, 8.4338e-8f, 1.5285e-4f, .0047057f, -2.5631e-5f, .0022316f,
+				     -2.3738e-5f, 4350.f, 4360.f, 9.5411e-8f, 1.1284e-4f, .0051111f,
+				     -2.6317e-5f, .0030958f, -2.5483e-5f, 4360.f, 4370.f, 1.5708e-8f,
+				     4.7653e-5f, .0099036f, -4.9633e-5f, .0072007f, -4.4307e-5f, 4370.f,
+				     4380.f, 7.2646e-5f, .073368f, .017942f, 1.2698e-5f, .012584f,
+				     -3.4551e-5f, 4380.f, 4390.f, 5.9152e-5f, .041171f, .00839f, -4.5951e-5f,
+				     .0057949f, -4.0723e-5f, 4390.f, 4400.f, 9.0913e-5f, .0094376f, .037251f,
+				     -1.6131e-4f, .034629f, -1.5582e-4f, 4400.f, 4410.f, 3.4561e-8f,
+				     4.7569e-5f, .0015514f, -1.0274e-5f, 6.5701e-7f, -1.2526e-5f, 4410.f,
+				     4420.f, 4.3107e-4f, .054262f, .024045f, -4.9839e-5f, .016547f,
+				     -4.4636e-5f, 4420.f, 4430.f, 3.1142e-4f, .038963f, .014134f,
+				     -6.8927e-5f, .011537f, -6.369e-5f, 4430.f, 4440.f, 1.4945e-8f,
+				     7.8332e-5f, .0089337f, -4.3145e-5f, .0069004f, -4.2442e-5f, 4440.f,
+				     4450.f, .0016802f, .051222f, .015502f, -2.3447e-5f, .010002f,
+				     -3.2528e-5f, 4450.f, 4460.f, 1.0007e-4f, .066862f, .02459f, -9.8504e-5f,
+				     .022882f, -1.0233e-4f, 4460.f, 4470.f, .0030025f, .051153f, .01923f,
+				     -8.107e-5f, .015535f, -6.8267e-5f, 4470.f, 4480.f, 8.6831e-5f, .040458f,
+				     .036221f, -1.5713e-4f, .03335f, -1.5083e-4f, 4480.f, 4490.f, .0080902f,
+				     .1275f, .016863f, -7.6478e-5f, .01678f, -7.7918e-5f, 4490.f, 4500.f,
+				     .0022317f, .15229f, .012535f, -1.3795e-5f, .010875f, -3.7123e-5f,
+				     4500.f, 4510.f, .019169f, .11664f, .010716f, -5.1479e-5f, .0082124f,
+				     -4.6198e-5f, 4510.f, 4520.f, .0065788f, .15986f, .012038f, -5.1957e-5f,
+				     .010074f, -5.1345e-5f, 4520.f, 4530.f, .03291f, .11768f, .0084067f,
+				     -4.3158e-5f, .0067305f, -4.0106e-5f, 4530.f, 4540.f, .044345f, .15763f,
+				     .0035365f, -2.4308e-5f, 7.9048e-4f, -1.7012e-5f, 4540.f, 4550.f,
+				     .027331f, .16819f, .0042859f, -2.1639e-5f, .0038192f, -2.5423e-5f,
+				     4550.f, 4560.f, .020407f, .09609f, .001546f, -1.6323e-5f, 6.6197e-4f,
+				     -9.1244e-6f, 4560.f, 4570.f, .057143f, .18848f, .0030453f, -1.8516e-5f,
+				     .0016176f, -1.8614e-5f, 4570.f, 4580.f, .052929f, .13102f, -.0010515f,
+				     -4.5621e-6f, -.0023271f, 2.7682e-6f, 4580.f, 4590.f, .028557f, .14681f,
+				     -4.8301e-4f, -6.3151e-6f, -.0019647f, -5.3522e-6f, 4590.f, 4600.f,
+				     .0046383f, .13391f, .0088609f, -2.6493e-5f, .0082741f, -3.2453e-5f,
+				     4600.f, 4610.f, .02773f, .10824f, -.0034789f, 5.4132e-6f, -.0030391f,
+				     8.0678e-6f, 4610.f, 4620.f, .051267f, .16778f, -.0015076f, -7.4663e-7f,
+				     -.0025263f, 3.707e-6f, 4620.f, 4630.f, .0129f, .13459f, 4.1658e-4f,
+				     7.4475e-7f, .0012458f, -7.7586e-6f, 4630.f, 4640.f, .044954f, .38311f,
+				     -.0018643f, 4.6026e-6f, -.0027134f, 4.4958e-6f, 4640.f, 4650.f,
+				     .0048639f, .10343f, .0025659f, -1.6961e-5f, .0023819f, -1.4778e-5f,
+				     4650.f, 4660.f, .0012082f, .18004f, .014733f, -5.2646e-5f, .014275f,
+				     -6.0508e-5f, 4660.f, 4670.f, .0013469f, .34467f, .012177f, -2.3395e-5f,
+				     .010966f, -3.6299e-5f, 4670.f, 4680.f, .0068991f, .1607f, 6.4738e-4f,
+				     3.7071e-6f, .0032901f, -2.0981e-6f, 4680.f, 4690.f, .027452f, .060959f,
+				     -.0051851f, 1.2668e-5f, -.0041528f, 2.6305e-5f, 4690.f, 4700.f,
+				     .017796f, .15523f, -.0027265f, 3.7407e-6f, -.0033733f, 1.0358e-5f,
+				     4700.f, 4710.f, .011446f, .17796f, -6.8324e-4f, 6.8406e-6f, -.0010826f,
+				     5.9431e-6f, 4710.f, 4720.f, .029309f, .13652f, -.0017282f, 6.762e-6f,
+				     5.6764e-4f, 1.3237e-5f, 4720.f, 4730.f, .021395f, .18395f, -.0015768f,
+				     1.4383e-5f, 1.5897e-4f, 8.796e-6f, 4730.f, 4740.f, .0025077f, .18622f,
+				     .0042912f, -4.9559e-6f, .0045676f, -2.6247e-6f, 4740.f, 4750.f,
+				     .031587f, .13943f, -.0012088f, -8.9815e-8f, -1.571e-4f, 2.0359e-5f,
+				     4750.f, 4760.f, .034566f, .28253f, .0016858f, -8.995e-6f, 9.752e-4f,
+				     -8.1082e-6f, 4760.f, 4770.f, .020369f, .14591f, -.0014421f, 1.9399e-5f,
+				     .0039665f, 1.4338e-5f, 4770.f, 4780.f, .0081447f, .12195f, .0013964f,
+				     3.2025e-5f, .0037728f, 2.0537e-5f, 4780.f, 4790.f, .019803f, .14625f,
+				     9.6298e-4f, -2.9783e-6f, .0041118f, -9.7923e-7f, 4790.f, 4800.f,
+				     .0052146f, .17691f, .014543f, -3.1749e-5f, .0149f, -4.4049e-5f, 4800.f,
+				     4810.f, .035065f, .21617f, -.0021492f, 2.3072e-5f, .001178f, 2.4416e-5f,
+				     4810.f, 4820.f, .012656f, .15792f, .0083705f, -2.1219e-5f, .0082684f,
+				     -2.8775e-5f, 4820.f, 4830.f, .014126f, .4985f, .0096621f, 2.3197e-5f,
+				     .011163f, -2.0765e-5f, 4830.f, 4840.f, .023704f, .35541f, .0055808f,
+				     -1.0952e-6f, .0068854f, -1.3359e-5f, 4840.f, 4850.f, .032166f, .23632f,
+				     -2.3289e-4f, 7.945e-6f, .0017163f, 2.8957e-6f, 4850.f, 4860.f, .026468f,
+				     .24812f, .008326f, 8.9107e-6f, .010638f, -2.4848e-5f, 4860.f, 4870.f,
+				     .012607f, .28278f, .014341f, -1.7161e-5f, .017744f, -4.3433e-5f, 4870.f,
+				     4880.f, .0019484f, .13452f, .014299f, -5.8644e-5f, .012622f,
+				     -5.8891e-5f, 4880.f, 4890.f, .019835f, .43138f, .016502f, -3.7834e-5f,
+				     .015564f, -5.3844e-5f, 4890.f, 4900.f, .031673f, .23676f, .018724f,
+				     -6.2795e-5f, .017963f, -6.7476e-5f, 4900.f, 4910.f, .020383f, .1686f,
+				     .02082f, -9.2373e-5f, .018807f, -8.5676e-5f, 4910.f, 4920.f, .034221f,
+				     .37729f, .014636f, 9.8132e-6f, .015033f, -3.2546e-5f, 4920.f, 4930.f,
+				     .041381f, .17341f, .004227f, 2.6778e-5f, .0073624f, -6.193e-6f, 4930.f,
+				     4940.f, .050322f, .24574f, .01506f, -6.0731e-5f, .01171f, -4.9448e-5f,
+				     4940.f, 4950.f, .11355f, .43168f, .012506f, -2.3567e-5f, .010508f,
+				     -3.2884e-5f, 4950.f, 4960.f, .073646f, .28063f, .01551f, -6.3821e-5f,
+				     .012136f, -5.1762e-5f, 4960.f, 4970.f, .0021754f, .2329f, .025115f,
+				     1.3402e-6f, .023138f, -4.9298e-5f, 4970.f, 4980.f, .20462f, .37006f,
+				     .013871f, -5.7344e-5f, .011137f, -4.9726e-5f, 4980.f, 4990.f, .15479f,
+				     .14505f, .012101f, -5.5517e-5f, .011913f, -3.8561e-5f, 4990.f, 5e3f,
+				     .1627f, .14157f, .012656f, -4.9554e-5f, .01273f, -4.7918e-5f, 5e3f,
+				     5010.f, .20283f, .16538f, .0098358f, -4.1905e-5f, .0091599f,
+				     -3.3109e-5f, 5010.f, 5020.f, .32847f, .20501f, .010455f, -3.0987e-5f,
+				     .011634f, -2.2216e-5f, 5020.f, 5030.f, .4088f, .1568f, .0097922f,
+				     -4.2397e-5f, .0098076f, -3.8651e-5f, 5030.f, 5040.f, .27012f, .21951f,
+				     .012867f, -1.8768e-6f, .012462f, -2.155e-5f, 5040.f, 5050.f, .5761f,
+				     .16605f, .0061804f, -3.0533e-5f, .0069772f, -1.7735e-5f, 5050.f, 5060.f
-	/* WATER VAPOR (2500 - 5040 CM-1) */
+    /* WATER VAPOR (2500 - 5040 CM-1) */
 }	/* wava1 */
@@ -1956,303 +1956,303 @@
-  static const float acr[2048] = { 4.1135e-5f, .13491f,
-    .019511f, -8.8592e-5f, .017169f, -8.6383e-5f, 7620.f, 7630.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7640.f,
-    7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f, 7660.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7670.f, 7680.f,
-    6.9843e-6f, .05869f, .017996f, -8.495e-5f, .014986f, -7.9255e-5f,
-    7680.f, 7690.f, 4.4856e-5f, .1161f, .012313f, -6.1208e-5f, .0094917f,
-    -5.6817e-5f, 7690.f, 7700.f, 2.1119e-4f, .14823f, .0058288f,
+    static const float acr[2048] = { 4.1135e-5f, .13491f,
+				     .019511f, -8.8592e-5f, .017169f, -8.6383e-5f, 7620.f, 7630.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7640.f,
+				     7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f, 7660.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7670.f, 7680.f,
+				     6.9843e-6f, .05869f, .017996f, -8.495e-5f, .014986f, -7.9255e-5f,
+				     7680.f, 7690.f, 4.4856e-5f, .1161f, .012313f, -6.1208e-5f, .0094917f,
+				     -5.6817e-5f, 7690.f, 7700.f, 2.1119e-4f, .14823f, .0058288f,
-    -3.5255e-5f, .0029752f, -3.0772e-5f, 7700.f, 7710.f, 6.8368e-4f,
-    .18822f, 2.1812e-4f, -1.3229e-5f, -.0027425f, -8.0771e-6f, 7710.f,
-    7720.f, 8.0401e-4f, .20648f, -.0032887f, 5.0708e-8f, -.0062117f,
-    5.94e-6f, 7720.f, 7730.f, 3.6897e-4f, .20612f, -.0045166f, 4.7173e-6f,
-    -.0074494f, 1.0697e-5f, 7730.f, 7740.f, .0011094f, .31021f, -.0022536f,
-    -1.0224e-6f, -.0033444f, 2.1129e-6f, 7740.f, 7750.f, 6.5848e-4f,
-    .26193f, .0027594f, -2.1278e-5f, 2.5217e-4f, -1.8776e-5f, 7750.f,
-    7760.f, 7.3155e-5f, .30739f, .013041f, -6.319e-5f, .010499f,
-    -6.0136e-5f, 7760.f, 7770.f, 1.9363e-5f, .19417f, .014647f, -7.1772e-5f,
-    .011659f, -6.5892e-5f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      7780.f,
-    7790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7800.f, 7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f,
-    7840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7850.f, 7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f,
-    7890.f, 3.719e-5f, .1891f, 3.2484e-4f, -1.3576e-5f, -.0026862f,
-    -8.2867e-6f, 7890.f, 7900.f, 9.4656e-5f, .363f, -.0020395f, -4.2752e-6f,
-    -.0049939f, 1.2049e-6f, 7900.f, 7910.f, 7.3888e-5f, .33612f, -.0027854f,
-    -1.4358e-6f, -.005628f, 3.7427e-6f, 7910.f, 7920.f, 3.5986e-5f, .14439f,
-    -.0040916f, 3.0556e-6f, -.0070423f, 9.0581e-6f, 7920.f, 7930.f,
-    7.729e-5f, .22754f, -.0015562f, -6.2734e-6f, -.0044592f, -1.0627e-6f,
-    7930.f, 7940.f, 1.8388e-5f, .092491f, .0027526f, -2.4014e-5f,
-    -3.4204e-4f, -1.8092e-5f, 7940.f, 7950.f, 1.9936e-7f, .0010968f,
-    .001703f, -2.0156e-5f, -.0013872f, -1.4222e-5f, 7950.f, 7960.f,
-    4.9455e-7f, .0019615f, -.0015846f, -6.8674e-6f, -.004292f, -1.7132e-6f,
-    7960.f, 7970.f, 2.7828e-7f, .0013177f, -.0036989f, 1.1926e-6f,
-    -.0065515f, 6.9563e-6f, 7970.f, 7980.f, 3.8372e-7f, .0017475f,
-    -.0038411f, 1.7875e-6f, -.0067043f, 7.5942e-6f, 7980.f, 7990.f,
-    7.3276e-7f, .003011f, -6.7794e-4f, -9.4857e-6f, -.0034111f,
-    -5.1641e-6f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f, 8010.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      8020.f,
-    8030.f, 3.7029e-8f, 3.6096e-4f, .012109f, -6.2089e-5f, .0089059f,
-    -5.5639e-5f, 8030.f, 8040.f, 2.1335e-7f, .0010751f, .0088149f,
-    -4.8284e-5f, .0057133f, -4.2623e-5f, 8040.f, 8050.f, 4.6462e-7f,
-    .001086f, .0049284f, -3.291e-5f, .0017555f, -2.6942e-5f, 8050.f, 8060.f,
-    1.5991e-6f, .0018385f, 6.4633e-4f, -1.5477e-5f, -.0022392f,
-    -1.0372e-5f, 8060.f, 8070.f, 1.7752e-6f, .0016397f, -.0024966f,
-    -3.4666e-6f, -.0051909f, 1.8847e-6f, 8070.f, 8080.f, 2.4423e-5f,
-    .26254f, .02579f, -7.7107e-5f, .025403f, -1.1405e-4f, 8080.f, 8090.f,
-    6.1857e-5f, .23309f, .021977f, -7.7807e-5f, .020482f, -9.5402e-5f,
-    8090.f, 8100.f, 1.3473e-4f, .23293f, .019374f, -8.4779e-5f, .016814f,
-    -8.2971e-5f, 8100.f, 8110.f, 3.3293e-4f, .42794f, .016857f, -7.4779e-5f,
-    .01563f, -7.4735e-5f, 8110.f, 8120.f, 4.5545e-4f, .42084f, .014131f,
-    -6.4833e-5f, .011587f, -6.2246e-5f, 8120.f, 8130.f, 3.9267e-4f, .4459f,
-    .01422f, -6.6328e-5f, .010179f, -5.8346e-5f, 8130.f, 8140.f, .0014095f,
-    .66221f, .012879f, -6.3481e-5f, .010259f, -5.9679e-5f, 8140.f, 8150.f,
-    .0025744f, .34109f, .0081434f, -3.5365e-5f, .010242f, -4.4763e-5f,
-    8150.f, 8160.f, .0053482f, .12345f, .0021618f, -2.1398e-5f, -8.9174e-4f,
-    -1.5761e-5f, 8160.f, 8170.f, .0085974f, .12902f, -.0011939f, -8.269e-6f,
-    -.0041809f, -2.5012e-6f, 8170.f, 8180.f, .011093f, .20887f, -.0036354f,
-    1.357e-6f, -.006594f, 7.4093e-6f, 8180.f, 8190.f, .0090124f, .22951f,
-    -.0041975f, 3.4952e-6f, -.0071581f, 9.6182e-6f, 8190.f, 8200.f,
-    .022977f, .54634f, 5.4679e-4f, -7.4452e-6f, 3.2715e-5f, -7.7515e-6f,
-    8200.f, 8210.f, 4.0967e-5f, .33171f, .029828f, -1.2884e-4f, .027502f,
-    -1.2751e-4f, 8210.f, 8220.f, 1.3117e-4f, .36661f, .024705f, -1.0516e-4f,
-    .023688f, -1.1029e-4f, 8220.f, 8230.f, 4.1427e-4f, .33236f, .018964f,
-    -8.1986e-5f, .018612f, -8.8547e-5f, 8230.f, 8240.f, .0011268f, .30228f,
-    .013786f, -6.0455e-5f, .014251f, -6.6968e-5f, 8240.f, 8250.f, .0038631f,
-    .3115f, .0080823f, -3.8679e-5f, .0084273f, -4.2578e-5f, 8250.f, 8260.f,
-    .0060039f, .26991f, .0040499f, -2.3093e-5f, .0051036f, -2.751e-5f,
-    8260.f, 8270.f, .014968f, .24443f, -6.0624e-4f, -8.9134e-6f, -.0014888f,
-    -7.5779e-6f, 8270.f, 8280.f, .015831f, .42226f, -.0020274f, 6.2203e-6f,
-    -1.636e-4f, -2.1524e-6f, 8280.f, 8290.f, .0086272f, .42161f, -.0028717f,
-    1.6391e-5f, 5.8996e-4f, 1.5552e-5f, 8290.f, 8300.f, .038978f, .60506f,
-    -1.8963e-4f, -4.6658e-6f, -.0011243f, -4.8784e-6f, 8300.f, 8310.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      8320.f,
-    8330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8340.f, 8350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f, 8360.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8370.f,
-    8380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8390.f, 8400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f, 8410.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8420.f,
-    8430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8440.f, 8450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f, 8460.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8470.f,
-    8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f, 8510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8520.f,
-    8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f, 8560.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8570.f,
-    8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f, 8610.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8620.f,
-    8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f, 8660.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8670.f,
-    8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f, 8710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8720.f,
-    8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f, 8760.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8770.f,
-    8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f, 8810.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8820.f,
-    8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f, 8860.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8870.f,
-    8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f, 8910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8920.f,
-    8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f, 8960.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8970.f,
-    8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9020.f,
-      9030.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
-      9080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
-      9130.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
-      9180.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
-      9230.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
-      9280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
-      9330.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 9.9593e-6f, .060237f,
-    .0097616f, -5.2148e-5f, .0066534f, -4.6124e-5f, 9340.f, 9350.f,
-    4.3567e-5f, .12051f, .0054505f, -3.4277e-5f, .0024633f, -2.9032e-5f,
-    9350.f, 9360.f, 8.8924e-5f, .12477f, .0012273f, -1.774e-5f, -.0018429f,
-    -1.1984e-5f, 9360.f, 9370.f, 1.5573e-4f, .16489f, -.0021342f,
-    -4.4631e-6f, -.005046f, 1.1731e-6f, 9370.f, 9380.f, 9.4382e-5f, .17579f,
-    -.0041243f, 3.1944e-6f, -.0071235f, 9.3601e-6f, 9380.f, 9390.f,
-    2.1829e-4f, .27491f, -.0034678f, 8.2722e-7f, -.0064858f, 7.0242e-6f,
-    9390.f, 9400.f, 2.27e-4f, .36616f, .0019245f, -1.579e-5f, -1.5673e-4f,
-    -1.5436e-5f, 9400.f, 9410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9410.f, 9420.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f, 9430.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9440.f, 9450.f, 4.0618e-5f,
-    .33672f, .016922f, -7.9759e-5f, .013854f, -7.4271e-5f, 9450.f, 9460.f,
-    8.026e-5f, .35567f, .013366f, -6.6285e-5f, .010448f, -6.0815e-5f,
-    9460.f, 9470.f, 1.7445e-4f, .15326f, .0081302f, -4.4538e-5f, .0056112f,
-    -4.1022e-5f, 9470.f, 9480.f, 3.3041e-4f, .26053f, .0049592f, -2.831e-5f,
-    .0049032f, -3.3415e-5f, 9480.f, 9490.f, 8.9723e-4f, .1582f, -1.1481e-4f,
-    -1.225e-5f, -.0031268f, -6.7086e-6f, 9490.f, 9500.f, 8.7248e-4f,
-    .13522f, -.0029599f, -1.3666e-6f, -.005813f, 4.3278e-6f, 9500.f, 9510.f,
-    5.7391e-4f, .20153f, -.0043771f, 4.1806e-6f, -.0073125f, 1.0212e-5f,
-    9510.f, 9520.f, .002106f, .33852f, -.0026269f, -1.9082e-6f, -.0056393f,
-    3.824e-6f, 9520.f, 9530.f, 8.7766e-4f, .35363f, .0044041f, -2.4109e-5f,
-    .0031707f, -2.6057e-5f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
-      9580.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
-      9630.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
-      9680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
-      9730.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
-      9780.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
-      9830.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
-      9880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
-      9930.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
-      9980.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
-      10030.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f, 10060.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10070.f,
-    10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10100.f,
-      10110.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f, 10140.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10150.f,
-    10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10170.f, 10180.f
+				     -3.5255e-5f, .0029752f, -3.0772e-5f, 7700.f, 7710.f, 6.8368e-4f,
+				     .18822f, 2.1812e-4f, -1.3229e-5f, -.0027425f, -8.0771e-6f, 7710.f,
+				     7720.f, 8.0401e-4f, .20648f, -.0032887f, 5.0708e-8f, -.0062117f,
+				     5.94e-6f, 7720.f, 7730.f, 3.6897e-4f, .20612f, -.0045166f, 4.7173e-6f,
+				     -.0074494f, 1.0697e-5f, 7730.f, 7740.f, .0011094f, .31021f, -.0022536f,
+				     -1.0224e-6f, -.0033444f, 2.1129e-6f, 7740.f, 7750.f, 6.5848e-4f,
+				     .26193f, .0027594f, -2.1278e-5f, 2.5217e-4f, -1.8776e-5f, 7750.f,
+				     7760.f, 7.3155e-5f, .30739f, .013041f, -6.319e-5f, .010499f,
+				     -6.0136e-5f, 7760.f, 7770.f, 1.9363e-5f, .19417f, .014647f, -7.1772e-5f,
+				     .011659f, -6.5892e-5f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     7780.f,
+				     7790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7800.f, 7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f,
+				     7840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7850.f, 7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f,
+				     7890.f, 3.719e-5f, .1891f, 3.2484e-4f, -1.3576e-5f, -.0026862f,
+				     -8.2867e-6f, 7890.f, 7900.f, 9.4656e-5f, .363f, -.0020395f, -4.2752e-6f,
+				     -.0049939f, 1.2049e-6f, 7900.f, 7910.f, 7.3888e-5f, .33612f, -.0027854f,
+				     -1.4358e-6f, -.005628f, 3.7427e-6f, 7910.f, 7920.f, 3.5986e-5f, .14439f,
+				     -.0040916f, 3.0556e-6f, -.0070423f, 9.0581e-6f, 7920.f, 7930.f,
+				     7.729e-5f, .22754f, -.0015562f, -6.2734e-6f, -.0044592f, -1.0627e-6f,
+				     7930.f, 7940.f, 1.8388e-5f, .092491f, .0027526f, -2.4014e-5f,
+				     -3.4204e-4f, -1.8092e-5f, 7940.f, 7950.f, 1.9936e-7f, .0010968f,
+				     .001703f, -2.0156e-5f, -.0013872f, -1.4222e-5f, 7950.f, 7960.f,
+				     4.9455e-7f, .0019615f, -.0015846f, -6.8674e-6f, -.004292f, -1.7132e-6f,
+				     7960.f, 7970.f, 2.7828e-7f, .0013177f, -.0036989f, 1.1926e-6f,
+				     -.0065515f, 6.9563e-6f, 7970.f, 7980.f, 3.8372e-7f, .0017475f,
+				     -.0038411f, 1.7875e-6f, -.0067043f, 7.5942e-6f, 7980.f, 7990.f,
+				     7.3276e-7f, .003011f, -6.7794e-4f, -9.4857e-6f, -.0034111f,
+				     -5.1641e-6f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f, 8010.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     8020.f,
+				     8030.f, 3.7029e-8f, 3.6096e-4f, .012109f, -6.2089e-5f, .0089059f,
+				     -5.5639e-5f, 8030.f, 8040.f, 2.1335e-7f, .0010751f, .0088149f,
+				     -4.8284e-5f, .0057133f, -4.2623e-5f, 8040.f, 8050.f, 4.6462e-7f,
+				     .001086f, .0049284f, -3.291e-5f, .0017555f, -2.6942e-5f, 8050.f, 8060.f,
+				     1.5991e-6f, .0018385f, 6.4633e-4f, -1.5477e-5f, -.0022392f,
+				     -1.0372e-5f, 8060.f, 8070.f, 1.7752e-6f, .0016397f, -.0024966f,
+				     -3.4666e-6f, -.0051909f, 1.8847e-6f, 8070.f, 8080.f, 2.4423e-5f,
+				     .26254f, .02579f, -7.7107e-5f, .025403f, -1.1405e-4f, 8080.f, 8090.f,
+				     6.1857e-5f, .23309f, .021977f, -7.7807e-5f, .020482f, -9.5402e-5f,
+				     8090.f, 8100.f, 1.3473e-4f, .23293f, .019374f, -8.4779e-5f, .016814f,
+				     -8.2971e-5f, 8100.f, 8110.f, 3.3293e-4f, .42794f, .016857f, -7.4779e-5f,
+				     .01563f, -7.4735e-5f, 8110.f, 8120.f, 4.5545e-4f, .42084f, .014131f,
+				     -6.4833e-5f, .011587f, -6.2246e-5f, 8120.f, 8130.f, 3.9267e-4f, .4459f,
+				     .01422f, -6.6328e-5f, .010179f, -5.8346e-5f, 8130.f, 8140.f, .0014095f,
+				     .66221f, .012879f, -6.3481e-5f, .010259f, -5.9679e-5f, 8140.f, 8150.f,
+				     .0025744f, .34109f, .0081434f, -3.5365e-5f, .010242f, -4.4763e-5f,
+				     8150.f, 8160.f, .0053482f, .12345f, .0021618f, -2.1398e-5f, -8.9174e-4f,
+				     -1.5761e-5f, 8160.f, 8170.f, .0085974f, .12902f, -.0011939f, -8.269e-6f,
+				     -.0041809f, -2.5012e-6f, 8170.f, 8180.f, .011093f, .20887f, -.0036354f,
+				     1.357e-6f, -.006594f, 7.4093e-6f, 8180.f, 8190.f, .0090124f, .22951f,
+				     -.0041975f, 3.4952e-6f, -.0071581f, 9.6182e-6f, 8190.f, 8200.f,
+				     .022977f, .54634f, 5.4679e-4f, -7.4452e-6f, 3.2715e-5f, -7.7515e-6f,
+				     8200.f, 8210.f, 4.0967e-5f, .33171f, .029828f, -1.2884e-4f, .027502f,
+				     -1.2751e-4f, 8210.f, 8220.f, 1.3117e-4f, .36661f, .024705f, -1.0516e-4f,
+				     .023688f, -1.1029e-4f, 8220.f, 8230.f, 4.1427e-4f, .33236f, .018964f,
+				     -8.1986e-5f, .018612f, -8.8547e-5f, 8230.f, 8240.f, .0011268f, .30228f,
+				     .013786f, -6.0455e-5f, .014251f, -6.6968e-5f, 8240.f, 8250.f, .0038631f,
+				     .3115f, .0080823f, -3.8679e-5f, .0084273f, -4.2578e-5f, 8250.f, 8260.f,
+				     .0060039f, .26991f, .0040499f, -2.3093e-5f, .0051036f, -2.751e-5f,
+				     8260.f, 8270.f, .014968f, .24443f, -6.0624e-4f, -8.9134e-6f, -.0014888f,
+				     -7.5779e-6f, 8270.f, 8280.f, .015831f, .42226f, -.0020274f, 6.2203e-6f,
+				     -1.636e-4f, -2.1524e-6f, 8280.f, 8290.f, .0086272f, .42161f, -.0028717f,
+				     1.6391e-5f, 5.8996e-4f, 1.5552e-5f, 8290.f, 8300.f, .038978f, .60506f,
+				     -1.8963e-4f, -4.6658e-6f, -.0011243f, -4.8784e-6f, 8300.f, 8310.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     8320.f,
+				     8330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8340.f, 8350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f, 8360.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8370.f,
+				     8380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8390.f, 8400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f, 8410.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8420.f,
+				     8430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8440.f, 8450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f, 8460.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8470.f,
+				     8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f, 8510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8520.f,
+				     8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f, 8560.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8570.f,
+				     8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f, 8610.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8620.f,
+				     8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f, 8660.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8670.f,
+				     8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f, 8710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8720.f,
+				     8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f, 8760.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8770.f,
+				     8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f, 8810.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8820.f,
+				     8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f, 8860.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8870.f,
+				     8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f, 8910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8920.f,
+				     8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f, 8960.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8970.f,
+				     8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9020.f,
+				     9030.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
+				     9080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
+				     9130.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
+				     9180.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
+				     9230.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
+				     9280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
+				     9330.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 9.9593e-6f, .060237f,
+				     .0097616f, -5.2148e-5f, .0066534f, -4.6124e-5f, 9340.f, 9350.f,
+				     4.3567e-5f, .12051f, .0054505f, -3.4277e-5f, .0024633f, -2.9032e-5f,
+				     9350.f, 9360.f, 8.8924e-5f, .12477f, .0012273f, -1.774e-5f, -.0018429f,
+				     -1.1984e-5f, 9360.f, 9370.f, 1.5573e-4f, .16489f, -.0021342f,
+				     -4.4631e-6f, -.005046f, 1.1731e-6f, 9370.f, 9380.f, 9.4382e-5f, .17579f,
+				     -.0041243f, 3.1944e-6f, -.0071235f, 9.3601e-6f, 9380.f, 9390.f,
+				     2.1829e-4f, .27491f, -.0034678f, 8.2722e-7f, -.0064858f, 7.0242e-6f,
+				     9390.f, 9400.f, 2.27e-4f, .36616f, .0019245f, -1.579e-5f, -1.5673e-4f,
+				     -1.5436e-5f, 9400.f, 9410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9410.f, 9420.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f, 9430.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9440.f, 9450.f, 4.0618e-5f,
+				     .33672f, .016922f, -7.9759e-5f, .013854f, -7.4271e-5f, 9450.f, 9460.f,
+				     8.026e-5f, .35567f, .013366f, -6.6285e-5f, .010448f, -6.0815e-5f,
+				     9460.f, 9470.f, 1.7445e-4f, .15326f, .0081302f, -4.4538e-5f, .0056112f,
+				     -4.1022e-5f, 9470.f, 9480.f, 3.3041e-4f, .26053f, .0049592f, -2.831e-5f,
+				     .0049032f, -3.3415e-5f, 9480.f, 9490.f, 8.9723e-4f, .1582f, -1.1481e-4f,
+				     -1.225e-5f, -.0031268f, -6.7086e-6f, 9490.f, 9500.f, 8.7248e-4f,
+				     .13522f, -.0029599f, -1.3666e-6f, -.005813f, 4.3278e-6f, 9500.f, 9510.f,
+				     5.7391e-4f, .20153f, -.0043771f, 4.1806e-6f, -.0073125f, 1.0212e-5f,
+				     9510.f, 9520.f, .002106f, .33852f, -.0026269f, -1.9082e-6f, -.0056393f,
+				     3.824e-6f, 9520.f, 9530.f, 8.7766e-4f, .35363f, .0044041f, -2.4109e-5f,
+				     .0031707f, -2.6057e-5f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
+				     9580.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
+				     9630.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
+				     9680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
+				     9730.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
+				     9780.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
+				     9830.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
+				     9880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
+				     9930.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
+				     9980.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
+				     10030.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f, 10060.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10070.f,
+				     10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10100.f,
+				     10110.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f, 10140.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10150.f,
+				     10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10170.f, 10180.f
-	/* carbon dioxide (7620 - 10170 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* carbon dioxide (7620 - 10170 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* dica3 */
@@ -2260,305 +2260,305 @@
-  static const float acr[2048] = { .37011f, .18132f,
-    .0098385f, -4.992e-5f, .0096965f, -3.9497e-5f, 5060.f, 5070.f, 1.7202f,
-    .2316f, .0029954f, -2.2435e-5f, .0029757f, -9.2488e-6f, 5070.f, 5080.f,
-    3.3606f, .25416f, -.0016977f, -4.0846e-6f, -.0013656f, 1.1658e-5f,
-    5080.f, 5090.f, 1.8282f, .30223f, -.0032772f, 9.4805e-6f, -5.335e-4f,
-    2.1209e-5f, 5090.f, 5100.f, 2.9024f, .38026f, -.0030989f, 7.2616e-6f,
-    -.001377f, 1.615e-5f, 5100.f, 5110.f, 4.2563f, .41711f, -1.4453e-4f,
-    -8.0697e-6f, 4.2978e-4f, -2.7285e-6f, 5110.f, 5120.f, 1.1106f, .56558f,
-    .0071956f, -3.6594e-5f, .0079066f, -3.7847e-5f, 5120.f, 5130.f, .30634f,
-    .97715f, .015099f, -6.7211e-5f, .015152f, -6.5294e-5f, 5130.f, 5140.f,
-    .11213f, .77801f, .019757f, -8.6279e-5f, .020188f, -8.4289e-5f, 5140.f,
-    5150.f, .014584f, 1.0474f, .030585f, -1.2981e-4f, .030136f, -1.2999e-4f,
-    5150.f, 5160.f, .001482f, .96349f, .039762f, -1.6303e-4f, .039329f,
-    -1.6879e-4f, 5160.f, 5170.f, 7.185e-5f, .75521f, .050597f, -1.9183e-4f,
-    .049189f, -2.096e-4f, 5170.f, 5180.f, 2.9909e-5f, .14908f, .03608f,
-    -1.1815e-4f, .034793f, -1.453e-4f, 5180.f, 5190.f, 1.2504e-4f, .18326f,
-    .032726f, -1.4282e-4f, .029813f, -1.3805e-4f, 5190.f, 5200.f,
-    2.1512e-4f, .19978f, .02843f, -1.2662e-4f, .025525f, -1.2103e-4f,
-    5200.f, 5210.f, 9.6169e-5f, .20142f, .026447f, -1.1912e-4f, .023511f,
-    -1.1308e-4f, 5210.f, 5220.f, 1.9738e-4f, .21048f, .02716f, -1.2182e-4f,
-    .024213f, -1.1582e-4f, 5220.f, 5230.f, 2.6384e-4f, .44256f, .028679f,
-    -1.144e-4f, .024161f, -1.056e-4f, 5230.f, 5240.f, 3.6492e-4f, .82665f,
-    .01703f, -5.0383e-5f, .015395f, -5.7885e-5f, 5240.f, 5250.f, 1.5039e-4f,
-    .27488f, .013098f, -6.1988e-5f, .010623f, -5.4594e-5f, 5250.f, 5260.f,
-    2.4449e-4f, .45805f, .01877f, -8.2525e-5f, .016371f, -8.1515e-5f,
-    5260.f, 5270.f, 6.037e-5f, .43685f, .016157f, -6.0387e-5f, .013838f,
-    -6.3959e-5f, 5270.f, 5280.f, 4.5624e-4f, 1.0732f, .012236f, -4.3571e-5f,
-    .011139f, -5.5369e-5f, 5280.f, 5290.f, 9.4288e-4f, .71418f, .0033079f,
-    -9.3343e-6f, .0045345f, -2.5858e-5f, 5290.f, 5300.f, .0024083f, .75842f,
-    .0033829f, 4.6857e-7f, .0043964f, -1.9712e-5f, 5300.f, 5310.f, .011861f,
-    .7448f, -.0016809f, -1.8723e-6f, -.0036883f, 4.435e-6f, 5310.f, 5320.f,
-    .005669f, .26992f, -.0026897f, -1.9753e-6f, -.0056893f, 3.9128e-6f,
-    5320.f, 5330.f, .0043472f, .36618f, .0037666f, -2.1625e-5f, .0021182f,
-    -2.2907e-5f, 5330.f, 5340.f, 6.5931e-5f, .17111f, .021978f, -9.6238e-5f,
-    .020336f, -9.699e-5f, 5340.f, 5350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      5350.f,
-    5360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5360.f, 5370.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5370.f, 5380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5380.f, 5390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5390.f, 5400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5400.f,
-    5410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5410.f, 5420.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5420.f, 5430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5430.f, 5440.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5440.f, 5450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5450.f,
-    5460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5460.f, 5470.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5470.f, 5480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5480.f, 5490.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5490.f, 5500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5500.f,
-    5510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5510.f, 5520.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5520.f, 5530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5530.f, 5540.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5540.f, 5550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5550.f,
-    5560.f, 6.8899e-6f, .12901f, .032092f, -1.4141e-4f, .029106f,
-    -1.3565e-4f, 5560.f, 5570.f, 5.4438e-6f, .10241f, .030061f, -1.3353e-4f,
-    .027225f, -1.2783e-4f, 5570.f, 5580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      5580.f,
-    5590.f, 1.3218e-5f, .23142f, .031168f, -1.3734e-4f, .028262f,
-    -1.3193e-4f, 5590.f, 5600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5600.f, 5610.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5610.f, 5620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    5620.f, 5630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5630.f, 5640.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 5640.f, 5650.f, 3.3959e-6f, .061663f, .034194f,
-    -1.4999e-4f, .031058f, -1.438e-4f, 5650.f, 5660.f, 1.0828e-5f, .12604f,
-    .03117f, -1.3759e-4f, .028105f, -1.3178e-4f, 5660.f, 5670.f, 1.7083e-5f,
-    .16767f, .028148f, -1.2567e-4f, .025263f, -1.1999e-4f, 5670.f, 5680.f,
-    4.9699e-6f, .072931f, .026646f, -1.1993e-4f, .02372f, -1.1402e-4f,
-    5680.f, 5690.f, 3.2495e-5f, .33854f, .028198f, -1.2521e-4f, .025185f,
-    -1.1947e-4f, 5690.f, 5700.f, 8.5544e-6f, .12346f, .03299f, -1.4471e-4f,
-    .029937f, -1.3907e-4f, 5700.f, 5710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      5710.f,
-    5720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5720.f, 5730.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5730.f, 5740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5740.f, 5750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5750.f, 5760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5760.f,
-    5770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5770.f, 5780.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5780.f, 5790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5790.f, 5800.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5800.f, 5810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5810.f,
-    5820.f, 1.0801e-7f, 6.4763e-4f, .00504f, -3.331e-5f, .0018319f,
-    -2.715e-5f, 5820.f, 5830.f, 3.6558e-7f, .0011712f, .0012766f,
-    -1.7918e-5f, -.0017271f, -1.2476e-5f, 5830.f, 5840.f, 6.5048e-7f,
-    .0015865f, -.0022804f, -3.9603e-6f, -.0050092f, 1.3558e-6f, 5840.f,
-    5850.f, 2.8928e-7f, .0011091f, -.0041564f, 3.1815e-6f, -.0071328f,
-    9.2288e-6f, 5850.f, 5860.f, 8.7451e-7f, .0023908f, -.003329f,
-    2.1406e-7f, -.0062303f, 6.1286e-6f, 5860.f, 5870.f, 6.7089e-7f,
-    .0021602f, .0012514f, -1.6242e-5f, -.0014507f, -1.275e-5f, 5870.f,
-    5880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5880.f, 5890.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5890.f, 5900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5900.f, 5910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5910.f, 5920.f, 1.7501e-8f, 1.3034e-4f, .0051578f,
-    -3.4109e-5f, .0018735f, -2.7495e-5f, 5920.f, 5930.f, 6.9507e-7f,
-    .0034287f, 4.4624e-4f, -1.3702e-5f, -.0024553f, -8.9919e-6f, 5930.f,
-    5940.f, 7.8354e-7f, .0027679f, -.002211f, -4.0762e-6f, -.0050605f,
-    1.5266e-6f, 5940.f, 5950.f, 1.7028e-5f, .28847f, .029444f, -1.0994e-4f,
-    .027638f, -1.257e-4f, 5950.f, 5960.f, 1.43e-5f, .23307f, .025314f,
-    -6.3115e-5f, .025428f, -1.0758e-4f, 5960.f, 5970.f, 2.9931e-5f, .32693f,
-    .031262f, -1.0549e-4f, .030096f, -1.315e-4f, 5970.f, 5980.f, 1.6591e-4f,
-    .85547f, .027749f, -1.2007e-4f, .025471f, -1.1947e-4f, 5980.f, 5990.f,
-    4.2245e-4f, .43143f, .020385f, -9.2124e-5f, .018281f, -8.9908e-5f,
-    5990.f, 6e3f, 9.3274e-4f, .46433f, .015249f, -7.1885e-5f, .01312f,
-    -6.839e-5f, 6e3f, 6010.f, 7.0225e-4f, .54757f, .013086f, -5.8065e-5f,
-    .011855f, -5.6321e-5f, 6010.f, 6020.f, 6.928e-4f, .65125f, .013222f,
-    -5.6472e-5f, .011874f, -5.5027e-5f, 6020.f, 6030.f, .0015664f, .5897f,
-    .015019f, -7.1875e-5f, .012178f, -6.7231e-5f, 6030.f, 6040.f, .0038079f,
-    .38374f, .0089238f, -3.815e-5f, .0095406f, -4.6524e-5f, 6040.f, 6050.f,
-    .011401f, .22142f, .0011962f, -1.4969e-5f, 5.0672e-4f, -5.0173e-6f,
-    6050.f, 6060.f, .015986f, .20314f, -.0028719f, -1.5218e-6f, -.0057785f,
-    4.2132e-6f, 6060.f, 6070.f, .0065575f, .20869f, -.0045237f, 4.7582e-6f,
-    -.0074277f, 1.0726e-5f, 6070.f, 6080.f, .016542f, .20732f, -.0033062f,
-    1.2692e-7f, -.0062117f, 5.9729e-6f, 6080.f, 6090.f, .0148f, .21832f,
-    5.2489e-4f, -1.4021e-5f, -.002348f, -9.405e-6f, 6090.f, 6100.f,
-    .0037777f, .221f, .0079105f, -4.1125e-5f, .0056565f, -3.9694e-5f,
-    6100.f, 6110.f, 2.3785e-4f, .20223f, .019267f, -7.498e-5f, .018479f,
-    -8.4052e-5f, 6110.f, 6120.f, 8.7992e-6f, .013627f, .0023267f,
-    9.2669e-5f, .014502f, 8.1104e-5f, 6120.f, 6130.f, 4.6902e-5f, .41886f,
-    .0248f, 7.0996e-5f, .036122f, -1.3184e-4f, 6130.f, 6140.f, 1.7614e-4f,
-    .70325f, .034157f, -1.2548e-4f, .032692f, -1.4479e-4f, 6140.f, 6150.f,
-    5.1423e-4f, .765f, .030511f, -1.3248e-4f, .028126f, -1.2927e-4f, 6150.f,
-    6160.f, .0016425f, .80783f, .024399f, -1.0406e-4f, .023798f,
-    -1.0618e-4f, 6160.f, 6170.f, .0047297f, .7047f, .018441f, -8.1354e-5f,
-    .017633f, -8.284e-5f, 6170.f, 6180.f, .012112f, .7774f, .014404f,
-    -6.4815e-5f, .014093f, -6.4401e-5f, 6180.f, 6190.f, .029946f, .46202f,
-    .0077033f, -3.8421e-5f, .0091624f, -3.7333e-5f, 6190.f, 6200.f,
-    .084779f, .36412f, .0025097f, -1.7677e-5f, .0033111f, -1.9653e-5f,
-    6200.f, 6210.f, .14928f, .35083f, -.0016626f, 6.5627e-7f, -1.0556e-5f,
-    3.0708e-6f, 6210.f, 6220.f, .055916f, .2564f, -.0037859f, 9.6465e-6f,
-    -4.846e-4f, 2.9685e-5f, 6220.f, 6230.f, .14147f, .24788f, -.0037163f,
-    1.7896e-6f, -.006379f, 1.0289e-5f, 6230.f, 6240.f, .16605f, .27773f,
-    3.1594e-4f, -1.2404e-5f, -.0024142f, -8.6644e-6f, 6240.f, 6250.f,
-    .026015f, .2642f, .0096177f, -4.5715e-5f, .0081902f, -4.718e-5f, 6250.f,
-    6260.f, 3.4429e-4f, .24315f, .027429f, -1.0196e-4f, .028346f,
-    -1.1603e-4f, 6260.f, 6270.f, 4.6627e-5f, .19149f, .036426f, -1.3678e-4f,
-    .034831f, -1.5131e-4f, 6270.f, 6280.f, 2.1373e-4f, .25683f, .031955f,
-    -1.3913e-4f, .029335f, -1.3555e-4f, 6280.f, 6290.f, .0013513f, .24863f,
-    .022352f, -9.6861e-5f, .021515f, -9.9991e-5f, 6290.f, 6300.f, .0054489f,
-    .20135f, .014377f, -6.5562e-5f, .015352f, -6.4813e-5f, 6300.f, 6310.f,
-    .027679f, .22784f, .0074243f, -3.7863e-5f, .0085371f, -3.3611e-5f,
-    6310.f, 6320.f, .078593f, .25925f, .0020493f, -1.5599e-5f, .0043199f,
-    -6.7814e-6f, 6320.f, 6330.f, .14691f, .31965f, -.0018417f, -2.6752e-7f,
-    -4.3593e-4f, 7.2456e-6f, 6330.f, 6340.f, .060904f, .38372f, -.0026072f,
-    1.0806e-5f, 3.4105e-5f, 6.1858e-6f, 6340.f, 6350.f, .16958f, .41812f,
-    -.0032411f, 1.9629e-6f, -.0029726f, 8.5775e-6f, 6350.f, 6360.f, .14604f,
-    .4663f, .0014212f, -1.3457e-5f, .0019636f, -1.361e-5f, 6360.f, 6370.f,
-    .031358f, .68476f, .010997f, -4.6694e-5f, .011746f, -5.4252e-5f, 6370.f,
-    6380.f, .0010642f, .83438f, .027721f, -1.1549e-4f, .027342f,
-    -1.2081e-4f, 6380.f, 6390.f, 1.0993e-5f, .084985f, .011868f, 1.2012e-4f,
-    .014373f, 3.5831e-5f, 6390.f, 6400.f, 6.8548e-5f, .19065f, -1.396e-4f,
-    -1.1926e-5f, -.0033005f, -5.8719e-6f, 6400.f, 6410.f, 5.8606e-5f,
-    .18176f, .0053969f, -3.2912e-5f, .0024598f, -2.8413e-5f, 6410.f, 6420.f,
-    1.3107e-5f, .089518f, .011918f, -6.0253e-5f, .0088864f, -5.4787e-5f,
-    6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f, 6440.f, 1.17e-5f,
-    .080752f, .030987f, -1.3581e-4f, .028483f, -1.3216e-4f, 6440.f, 6450.f,
-    1.5147e-4f, .133f, .021388f, -9.5943e-5f, .019129f, -9.4039e-5f, 6450.f,
-    6460.f, .0010569f, .14161f, .012722f, -6.2067e-5f, .010104f,
-    -5.8766e-5f, 6460.f, 6470.f, .0062046f, .17678f, .0050148f, -3.1545e-5f,
-    .002256f, -2.7623e-5f, 6470.f, 6480.f, .012909f, .15821f, -1.1368e-4f,
-    -1.2254e-5f, -.0031262f, -6.7108e-6f, 6480.f, 6490.f, .018519f, .26278f,
-    -.0033124f, 1.2436e-6f, -.0049708f, 1.187e-5f, 6490.f, 6500.f,
-    .0094276f, .28543f, -.0037172f, 9.5584e-6f, -.0028297f, 1.7915e-5f,
-    6500.f, 6510.f, .02326f, .34557f, -.0016092f, -1.5397e-6f, -.0015497f,
-    2.6953e-6f, 6510.f, 6520.f, .011602f, .45777f, .0040857f, -2.3186e-5f,
-    .003463f, -2.4006e-5f, 6520.f, 6530.f, .0026251f, 1.0461f, .0096811f,
-    -3.5495e-5f, .0054387f, -2.7418e-5f, 6530.f, 6540.f, .0013999f, .87933f,
-    .011802f, -4.3414e-5f, .0093028f, -3.5381e-5f, 6540.f, 6550.f,
-    .0010684f, .70255f, .015871f, -6.462e-5f, .012638f, -5.6493e-5f, 6550.f,
-    6560.f, 1.6155e-4f, .42392f, .025507f, -1.1133e-4f, .023436f,
-    -1.1063e-4f, 6560.f, 6570.f, 1.8042e-5f, .32854f, .030046f, -1.3213e-4f,
-    .02717f, -1.2714e-4f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      6580.f,
-    6590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6600.f, 6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6620.f, 6630.f, 1.6128e-5f, .088896f, .01184f,
-    -5.9958e-5f, .0088458f, -5.4627e-5f, 6630.f, 6640.f, 5.7685e-5f, .1197f,
-    .0066894f, -3.9133e-5f, .0037276f, -3.4034e-5f, 6640.f, 6650.f,
-    1.6743e-4f, .15492f, .0016277f, -1.8979e-5f, -.0013919f, -1.3601e-5f,
-    6650.f, 6660.f, 2.3995e-4f, .19763f, -.0015517f, -2.5448e-6f,
-    -.0034273f, 4.3033e-7f, 6660.f, 6670.f, .0011561f, .75988f, -.001204f,
-    -2.7363e-6f, -.0037117f, -3.8924e-7f, 6670.f, 6680.f, 2.3092e-4f,
-    .26967f, -.0038326f, 2.1748e-6f, -.0067421f, 8.1124e-6f, 6680.f, 6690.f,
-    1.8913e-4f, .29419f, 2.3018e-4f, -1.1781e-5f, -.0022434f, -9.0419e-6f,
-    6690.f, 6700.f, 4.262e-6f, .033197f, .008741f, -4.0921e-5f, .0057336f,
-    -3.8266e-5f, 6700.f, 6710.f, 9.8135e-7f, .0038989f, .019411f,
-    -9.0203e-5f, .01638f, -8.4877e-5f, 6710.f, 6720.f, 2.4238e-6f,
-    .0042762f, .015022f, -7.3077e-5f, .01219f, -6.7965e-5f, 6720.f, 6730.f,
-    4.5088e-6f, .0043488f, .010996f, -5.6685e-5f, .0085436f, -5.3188e-5f,
-    6730.f, 6740.f, 1.0584e-5f, .0026967f, .0057298f, -3.4851e-5f,
-    .0039372f, -3.384e-5f, 6740.f, 6750.f, 2.4861e-5f, .0051111f, .0029099f,
-    -1.5549e-5f, .0043761f, -2.6982e-5f, 6750.f, 6760.f, 3.9077e-5f,
-    .0028826f, -.001771f, -1.6701e-6f, -.001197f, 3.3e-6f, 6760.f, 6770.f,
-    2.3656e-5f, .0021453f, -.004179f, 3.1183e-6f, -.0071966f, 9.311e-6f,
-    6770.f, 6780.f, 4.577e-5f, .0032492f, -.003795f, 1.7261e-6f, -.006782f,
-    7.9425e-6f, 6780.f, 6790.f, 6.1088e-5f, .0055679f, .001493f,
-    -1.1871e-5f, 7.2114e-4f, -1.3903e-5f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 6800.f, 6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 6820.f, 6830.f, 9.2277e-7f, .029726f, .049361f,
-    -2.108e-4f, .046239f, -2.0451e-4f, 6830.f, 6840.f, 1.4134e-5f, .25624f,
-    .046651f, -1.979e-4f, .043955f, -1.9411e-4f, 6840.f, 6850.f, 7.2012e-5f,
-    .62577f, .042787f, -1.8123e-4f, .0404f, -1.7929e-4f, 6850.f, 6860.f,
-    1.8633e-4f, .5831f, .038378f, -1.6303e-4f, .035924f, -1.6051e-4f,
-    6860.f, 6870.f, 5.7256e-4f, .7495f, .03396f, -1.4641e-4f, .03134f,
-    -1.4291e-4f, 6870.f, 6880.f, .0014919f, .79461f, .029669f, -1.2898e-4f,
-    .027598f, -1.2671e-4f, 6880.f, 6890.f, .003259f, .69112f, .02466f,
-    -1.0873e-4f, .022993f, -1.093e-4f, 6890.f, 6900.f, .0079821f, .66219f,
-    .020779f, -9.1999e-5f, .020053f, -9.48e-5f, 6900.f, 6910.f, .019955f,
-    .70298f, .016653f, -7.4032e-5f, .017622f, -7.4061e-5f, 6910.f, 6920.f,
-    .047678f, .44625f, .011512f, -5.6613e-5f, .010983f, -5.0893e-5f, 6920.f,
-    6930.f, .072667f, .31454f, .0067346f, -3.8595e-5f, .0058565f,
-    -4.0764e-5f, 6930.f, 6940.f, .21391f, .45263f, .0039143f, -1.9313e-5f,
-    .0056575f, -2.8872e-5f, 6940.f, 6950.f, .3773f, .2493f, -.0011236f,
-    -3.7053e-6f, 4.1967e-4f, 5.3393e-6f, 6950.f, 6960.f, .29585f, .17647f,
-    -.0038687f, 2.2126e-6f, -.0068173f, 8.2438e-6f, 6960.f, 6970.f, .30531f,
-    .23118f, -.004195f, 3.5322e-6f, -.0069672f, 1.113e-5f, 6970.f, 6980.f,
-    .77834f, .54008f, 5.3815e-4f, -7.5276e-6f, -1.0156e-4f, -7.935e-6f,
-    6980.f, 6990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 7e3f, 7010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f,
-    7040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7050.f, 7060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f,
-    7090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7100.f, 7110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f,
-    7140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
+    static const float acr[2048] = { .37011f, .18132f,
+				     .0098385f, -4.992e-5f, .0096965f, -3.9497e-5f, 5060.f, 5070.f, 1.7202f,
+				     .2316f, .0029954f, -2.2435e-5f, .0029757f, -9.2488e-6f, 5070.f, 5080.f,
+				     3.3606f, .25416f, -.0016977f, -4.0846e-6f, -.0013656f, 1.1658e-5f,
+				     5080.f, 5090.f, 1.8282f, .30223f, -.0032772f, 9.4805e-6f, -5.335e-4f,
+				     2.1209e-5f, 5090.f, 5100.f, 2.9024f, .38026f, -.0030989f, 7.2616e-6f,
+				     -.001377f, 1.615e-5f, 5100.f, 5110.f, 4.2563f, .41711f, -1.4453e-4f,
+				     -8.0697e-6f, 4.2978e-4f, -2.7285e-6f, 5110.f, 5120.f, 1.1106f, .56558f,
+				     .0071956f, -3.6594e-5f, .0079066f, -3.7847e-5f, 5120.f, 5130.f, .30634f,
+				     .97715f, .015099f, -6.7211e-5f, .015152f, -6.5294e-5f, 5130.f, 5140.f,
+				     .11213f, .77801f, .019757f, -8.6279e-5f, .020188f, -8.4289e-5f, 5140.f,
+				     5150.f, .014584f, 1.0474f, .030585f, -1.2981e-4f, .030136f, -1.2999e-4f,
+				     5150.f, 5160.f, .001482f, .96349f, .039762f, -1.6303e-4f, .039329f,
+				     -1.6879e-4f, 5160.f, 5170.f, 7.185e-5f, .75521f, .050597f, -1.9183e-4f,
+				     .049189f, -2.096e-4f, 5170.f, 5180.f, 2.9909e-5f, .14908f, .03608f,
+				     -1.1815e-4f, .034793f, -1.453e-4f, 5180.f, 5190.f, 1.2504e-4f, .18326f,
+				     .032726f, -1.4282e-4f, .029813f, -1.3805e-4f, 5190.f, 5200.f,
+				     2.1512e-4f, .19978f, .02843f, -1.2662e-4f, .025525f, -1.2103e-4f,
+				     5200.f, 5210.f, 9.6169e-5f, .20142f, .026447f, -1.1912e-4f, .023511f,
+				     -1.1308e-4f, 5210.f, 5220.f, 1.9738e-4f, .21048f, .02716f, -1.2182e-4f,
+				     .024213f, -1.1582e-4f, 5220.f, 5230.f, 2.6384e-4f, .44256f, .028679f,
+				     -1.144e-4f, .024161f, -1.056e-4f, 5230.f, 5240.f, 3.6492e-4f, .82665f,
+				     .01703f, -5.0383e-5f, .015395f, -5.7885e-5f, 5240.f, 5250.f, 1.5039e-4f,
+				     .27488f, .013098f, -6.1988e-5f, .010623f, -5.4594e-5f, 5250.f, 5260.f,
+				     2.4449e-4f, .45805f, .01877f, -8.2525e-5f, .016371f, -8.1515e-5f,
+				     5260.f, 5270.f, 6.037e-5f, .43685f, .016157f, -6.0387e-5f, .013838f,
+				     -6.3959e-5f, 5270.f, 5280.f, 4.5624e-4f, 1.0732f, .012236f, -4.3571e-5f,
+				     .011139f, -5.5369e-5f, 5280.f, 5290.f, 9.4288e-4f, .71418f, .0033079f,
+				     -9.3343e-6f, .0045345f, -2.5858e-5f, 5290.f, 5300.f, .0024083f, .75842f,
+				     .0033829f, 4.6857e-7f, .0043964f, -1.9712e-5f, 5300.f, 5310.f, .011861f,
+				     .7448f, -.0016809f, -1.8723e-6f, -.0036883f, 4.435e-6f, 5310.f, 5320.f,
+				     .005669f, .26992f, -.0026897f, -1.9753e-6f, -.0056893f, 3.9128e-6f,
+				     5320.f, 5330.f, .0043472f, .36618f, .0037666f, -2.1625e-5f, .0021182f,
+				     -2.2907e-5f, 5330.f, 5340.f, 6.5931e-5f, .17111f, .021978f, -9.6238e-5f,
+				     .020336f, -9.699e-5f, 5340.f, 5350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     5350.f,
+				     5360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5360.f, 5370.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5370.f, 5380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5380.f, 5390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5390.f, 5400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5400.f,
+				     5410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5410.f, 5420.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5420.f, 5430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5430.f, 5440.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5440.f, 5450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5450.f,
+				     5460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5460.f, 5470.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5470.f, 5480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5480.f, 5490.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5490.f, 5500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5500.f,
+				     5510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5510.f, 5520.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5520.f, 5530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5530.f, 5540.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5540.f, 5550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5550.f,
+				     5560.f, 6.8899e-6f, .12901f, .032092f, -1.4141e-4f, .029106f,
+				     -1.3565e-4f, 5560.f, 5570.f, 5.4438e-6f, .10241f, .030061f, -1.3353e-4f,
+				     .027225f, -1.2783e-4f, 5570.f, 5580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     5580.f,
+				     5590.f, 1.3218e-5f, .23142f, .031168f, -1.3734e-4f, .028262f,
+				     -1.3193e-4f, 5590.f, 5600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5600.f, 5610.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5610.f, 5620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     5620.f, 5630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5630.f, 5640.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 5640.f, 5650.f, 3.3959e-6f, .061663f, .034194f,
+				     -1.4999e-4f, .031058f, -1.438e-4f, 5650.f, 5660.f, 1.0828e-5f, .12604f,
+				     .03117f, -1.3759e-4f, .028105f, -1.3178e-4f, 5660.f, 5670.f, 1.7083e-5f,
+				     .16767f, .028148f, -1.2567e-4f, .025263f, -1.1999e-4f, 5670.f, 5680.f,
+				     4.9699e-6f, .072931f, .026646f, -1.1993e-4f, .02372f, -1.1402e-4f,
+				     5680.f, 5690.f, 3.2495e-5f, .33854f, .028198f, -1.2521e-4f, .025185f,
+				     -1.1947e-4f, 5690.f, 5700.f, 8.5544e-6f, .12346f, .03299f, -1.4471e-4f,
+				     .029937f, -1.3907e-4f, 5700.f, 5710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     5710.f,
+				     5720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5720.f, 5730.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5730.f, 5740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5740.f, 5750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5750.f, 5760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5760.f,
+				     5770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5770.f, 5780.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5780.f, 5790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5790.f, 5800.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5800.f, 5810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5810.f,
+				     5820.f, 1.0801e-7f, 6.4763e-4f, .00504f, -3.331e-5f, .0018319f,
+				     -2.715e-5f, 5820.f, 5830.f, 3.6558e-7f, .0011712f, .0012766f,
+				     -1.7918e-5f, -.0017271f, -1.2476e-5f, 5830.f, 5840.f, 6.5048e-7f,
+				     .0015865f, -.0022804f, -3.9603e-6f, -.0050092f, 1.3558e-6f, 5840.f,
+				     5850.f, 2.8928e-7f, .0011091f, -.0041564f, 3.1815e-6f, -.0071328f,
+				     9.2288e-6f, 5850.f, 5860.f, 8.7451e-7f, .0023908f, -.003329f,
+				     2.1406e-7f, -.0062303f, 6.1286e-6f, 5860.f, 5870.f, 6.7089e-7f,
+				     .0021602f, .0012514f, -1.6242e-5f, -.0014507f, -1.275e-5f, 5870.f,
+				     5880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5880.f, 5890.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5890.f, 5900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5900.f, 5910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5910.f, 5920.f, 1.7501e-8f, 1.3034e-4f, .0051578f,
+				     -3.4109e-5f, .0018735f, -2.7495e-5f, 5920.f, 5930.f, 6.9507e-7f,
+				     .0034287f, 4.4624e-4f, -1.3702e-5f, -.0024553f, -8.9919e-6f, 5930.f,
+				     5940.f, 7.8354e-7f, .0027679f, -.002211f, -4.0762e-6f, -.0050605f,
+				     1.5266e-6f, 5940.f, 5950.f, 1.7028e-5f, .28847f, .029444f, -1.0994e-4f,
+				     .027638f, -1.257e-4f, 5950.f, 5960.f, 1.43e-5f, .23307f, .025314f,
+				     -6.3115e-5f, .025428f, -1.0758e-4f, 5960.f, 5970.f, 2.9931e-5f, .32693f,
+				     .031262f, -1.0549e-4f, .030096f, -1.315e-4f, 5970.f, 5980.f, 1.6591e-4f,
+				     .85547f, .027749f, -1.2007e-4f, .025471f, -1.1947e-4f, 5980.f, 5990.f,
+				     4.2245e-4f, .43143f, .020385f, -9.2124e-5f, .018281f, -8.9908e-5f,
+				     5990.f, 6e3f, 9.3274e-4f, .46433f, .015249f, -7.1885e-5f, .01312f,
+				     -6.839e-5f, 6e3f, 6010.f, 7.0225e-4f, .54757f, .013086f, -5.8065e-5f,
+				     .011855f, -5.6321e-5f, 6010.f, 6020.f, 6.928e-4f, .65125f, .013222f,
+				     -5.6472e-5f, .011874f, -5.5027e-5f, 6020.f, 6030.f, .0015664f, .5897f,
+				     .015019f, -7.1875e-5f, .012178f, -6.7231e-5f, 6030.f, 6040.f, .0038079f,
+				     .38374f, .0089238f, -3.815e-5f, .0095406f, -4.6524e-5f, 6040.f, 6050.f,
+				     .011401f, .22142f, .0011962f, -1.4969e-5f, 5.0672e-4f, -5.0173e-6f,
+				     6050.f, 6060.f, .015986f, .20314f, -.0028719f, -1.5218e-6f, -.0057785f,
+				     4.2132e-6f, 6060.f, 6070.f, .0065575f, .20869f, -.0045237f, 4.7582e-6f,
+				     -.0074277f, 1.0726e-5f, 6070.f, 6080.f, .016542f, .20732f, -.0033062f,
+				     1.2692e-7f, -.0062117f, 5.9729e-6f, 6080.f, 6090.f, .0148f, .21832f,
+				     5.2489e-4f, -1.4021e-5f, -.002348f, -9.405e-6f, 6090.f, 6100.f,
+				     .0037777f, .221f, .0079105f, -4.1125e-5f, .0056565f, -3.9694e-5f,
+				     6100.f, 6110.f, 2.3785e-4f, .20223f, .019267f, -7.498e-5f, .018479f,
+				     -8.4052e-5f, 6110.f, 6120.f, 8.7992e-6f, .013627f, .0023267f,
+				     9.2669e-5f, .014502f, 8.1104e-5f, 6120.f, 6130.f, 4.6902e-5f, .41886f,
+				     .0248f, 7.0996e-5f, .036122f, -1.3184e-4f, 6130.f, 6140.f, 1.7614e-4f,
+				     .70325f, .034157f, -1.2548e-4f, .032692f, -1.4479e-4f, 6140.f, 6150.f,
+				     5.1423e-4f, .765f, .030511f, -1.3248e-4f, .028126f, -1.2927e-4f, 6150.f,
+				     6160.f, .0016425f, .80783f, .024399f, -1.0406e-4f, .023798f,
+				     -1.0618e-4f, 6160.f, 6170.f, .0047297f, .7047f, .018441f, -8.1354e-5f,
+				     .017633f, -8.284e-5f, 6170.f, 6180.f, .012112f, .7774f, .014404f,
+				     -6.4815e-5f, .014093f, -6.4401e-5f, 6180.f, 6190.f, .029946f, .46202f,
+				     .0077033f, -3.8421e-5f, .0091624f, -3.7333e-5f, 6190.f, 6200.f,
+				     .084779f, .36412f, .0025097f, -1.7677e-5f, .0033111f, -1.9653e-5f,
+				     6200.f, 6210.f, .14928f, .35083f, -.0016626f, 6.5627e-7f, -1.0556e-5f,
+				     3.0708e-6f, 6210.f, 6220.f, .055916f, .2564f, -.0037859f, 9.6465e-6f,
+				     -4.846e-4f, 2.9685e-5f, 6220.f, 6230.f, .14147f, .24788f, -.0037163f,
+				     1.7896e-6f, -.006379f, 1.0289e-5f, 6230.f, 6240.f, .16605f, .27773f,
+				     3.1594e-4f, -1.2404e-5f, -.0024142f, -8.6644e-6f, 6240.f, 6250.f,
+				     .026015f, .2642f, .0096177f, -4.5715e-5f, .0081902f, -4.718e-5f, 6250.f,
+				     6260.f, 3.4429e-4f, .24315f, .027429f, -1.0196e-4f, .028346f,
+				     -1.1603e-4f, 6260.f, 6270.f, 4.6627e-5f, .19149f, .036426f, -1.3678e-4f,
+				     .034831f, -1.5131e-4f, 6270.f, 6280.f, 2.1373e-4f, .25683f, .031955f,
+				     -1.3913e-4f, .029335f, -1.3555e-4f, 6280.f, 6290.f, .0013513f, .24863f,
+				     .022352f, -9.6861e-5f, .021515f, -9.9991e-5f, 6290.f, 6300.f, .0054489f,
+				     .20135f, .014377f, -6.5562e-5f, .015352f, -6.4813e-5f, 6300.f, 6310.f,
+				     .027679f, .22784f, .0074243f, -3.7863e-5f, .0085371f, -3.3611e-5f,
+				     6310.f, 6320.f, .078593f, .25925f, .0020493f, -1.5599e-5f, .0043199f,
+				     -6.7814e-6f, 6320.f, 6330.f, .14691f, .31965f, -.0018417f, -2.6752e-7f,
+				     -4.3593e-4f, 7.2456e-6f, 6330.f, 6340.f, .060904f, .38372f, -.0026072f,
+				     1.0806e-5f, 3.4105e-5f, 6.1858e-6f, 6340.f, 6350.f, .16958f, .41812f,
+				     -.0032411f, 1.9629e-6f, -.0029726f, 8.5775e-6f, 6350.f, 6360.f, .14604f,
+				     .4663f, .0014212f, -1.3457e-5f, .0019636f, -1.361e-5f, 6360.f, 6370.f,
+				     .031358f, .68476f, .010997f, -4.6694e-5f, .011746f, -5.4252e-5f, 6370.f,
+				     6380.f, .0010642f, .83438f, .027721f, -1.1549e-4f, .027342f,
+				     -1.2081e-4f, 6380.f, 6390.f, 1.0993e-5f, .084985f, .011868f, 1.2012e-4f,
+				     .014373f, 3.5831e-5f, 6390.f, 6400.f, 6.8548e-5f, .19065f, -1.396e-4f,
+				     -1.1926e-5f, -.0033005f, -5.8719e-6f, 6400.f, 6410.f, 5.8606e-5f,
+				     .18176f, .0053969f, -3.2912e-5f, .0024598f, -2.8413e-5f, 6410.f, 6420.f,
+				     1.3107e-5f, .089518f, .011918f, -6.0253e-5f, .0088864f, -5.4787e-5f,
+				     6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f, 6440.f, 1.17e-5f,
+				     .080752f, .030987f, -1.3581e-4f, .028483f, -1.3216e-4f, 6440.f, 6450.f,
+				     1.5147e-4f, .133f, .021388f, -9.5943e-5f, .019129f, -9.4039e-5f, 6450.f,
+				     6460.f, .0010569f, .14161f, .012722f, -6.2067e-5f, .010104f,
+				     -5.8766e-5f, 6460.f, 6470.f, .0062046f, .17678f, .0050148f, -3.1545e-5f,
+				     .002256f, -2.7623e-5f, 6470.f, 6480.f, .012909f, .15821f, -1.1368e-4f,
+				     -1.2254e-5f, -.0031262f, -6.7108e-6f, 6480.f, 6490.f, .018519f, .26278f,
+				     -.0033124f, 1.2436e-6f, -.0049708f, 1.187e-5f, 6490.f, 6500.f,
+				     .0094276f, .28543f, -.0037172f, 9.5584e-6f, -.0028297f, 1.7915e-5f,
+				     6500.f, 6510.f, .02326f, .34557f, -.0016092f, -1.5397e-6f, -.0015497f,
+				     2.6953e-6f, 6510.f, 6520.f, .011602f, .45777f, .0040857f, -2.3186e-5f,
+				     .003463f, -2.4006e-5f, 6520.f, 6530.f, .0026251f, 1.0461f, .0096811f,
+				     -3.5495e-5f, .0054387f, -2.7418e-5f, 6530.f, 6540.f, .0013999f, .87933f,
+				     .011802f, -4.3414e-5f, .0093028f, -3.5381e-5f, 6540.f, 6550.f,
+				     .0010684f, .70255f, .015871f, -6.462e-5f, .012638f, -5.6493e-5f, 6550.f,
+				     6560.f, 1.6155e-4f, .42392f, .025507f, -1.1133e-4f, .023436f,
+				     -1.1063e-4f, 6560.f, 6570.f, 1.8042e-5f, .32854f, .030046f, -1.3213e-4f,
+				     .02717f, -1.2714e-4f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     6580.f,
+				     6590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6600.f, 6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6620.f, 6630.f, 1.6128e-5f, .088896f, .01184f,
+				     -5.9958e-5f, .0088458f, -5.4627e-5f, 6630.f, 6640.f, 5.7685e-5f, .1197f,
+				     .0066894f, -3.9133e-5f, .0037276f, -3.4034e-5f, 6640.f, 6650.f,
+				     1.6743e-4f, .15492f, .0016277f, -1.8979e-5f, -.0013919f, -1.3601e-5f,
+				     6650.f, 6660.f, 2.3995e-4f, .19763f, -.0015517f, -2.5448e-6f,
+				     -.0034273f, 4.3033e-7f, 6660.f, 6670.f, .0011561f, .75988f, -.001204f,
+				     -2.7363e-6f, -.0037117f, -3.8924e-7f, 6670.f, 6680.f, 2.3092e-4f,
+				     .26967f, -.0038326f, 2.1748e-6f, -.0067421f, 8.1124e-6f, 6680.f, 6690.f,
+				     1.8913e-4f, .29419f, 2.3018e-4f, -1.1781e-5f, -.0022434f, -9.0419e-6f,
+				     6690.f, 6700.f, 4.262e-6f, .033197f, .008741f, -4.0921e-5f, .0057336f,
+				     -3.8266e-5f, 6700.f, 6710.f, 9.8135e-7f, .0038989f, .019411f,
+				     -9.0203e-5f, .01638f, -8.4877e-5f, 6710.f, 6720.f, 2.4238e-6f,
+				     .0042762f, .015022f, -7.3077e-5f, .01219f, -6.7965e-5f, 6720.f, 6730.f,
+				     4.5088e-6f, .0043488f, .010996f, -5.6685e-5f, .0085436f, -5.3188e-5f,
+				     6730.f, 6740.f, 1.0584e-5f, .0026967f, .0057298f, -3.4851e-5f,
+				     .0039372f, -3.384e-5f, 6740.f, 6750.f, 2.4861e-5f, .0051111f, .0029099f,
+				     -1.5549e-5f, .0043761f, -2.6982e-5f, 6750.f, 6760.f, 3.9077e-5f,
+				     .0028826f, -.001771f, -1.6701e-6f, -.001197f, 3.3e-6f, 6760.f, 6770.f,
+				     2.3656e-5f, .0021453f, -.004179f, 3.1183e-6f, -.0071966f, 9.311e-6f,
+				     6770.f, 6780.f, 4.577e-5f, .0032492f, -.003795f, 1.7261e-6f, -.006782f,
+				     7.9425e-6f, 6780.f, 6790.f, 6.1088e-5f, .0055679f, .001493f,
+				     -1.1871e-5f, 7.2114e-4f, -1.3903e-5f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 6800.f, 6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 6820.f, 6830.f, 9.2277e-7f, .029726f, .049361f,
+				     -2.108e-4f, .046239f, -2.0451e-4f, 6830.f, 6840.f, 1.4134e-5f, .25624f,
+				     .046651f, -1.979e-4f, .043955f, -1.9411e-4f, 6840.f, 6850.f, 7.2012e-5f,
+				     .62577f, .042787f, -1.8123e-4f, .0404f, -1.7929e-4f, 6850.f, 6860.f,
+				     1.8633e-4f, .5831f, .038378f, -1.6303e-4f, .035924f, -1.6051e-4f,
+				     6860.f, 6870.f, 5.7256e-4f, .7495f, .03396f, -1.4641e-4f, .03134f,
+				     -1.4291e-4f, 6870.f, 6880.f, .0014919f, .79461f, .029669f, -1.2898e-4f,
+				     .027598f, -1.2671e-4f, 6880.f, 6890.f, .003259f, .69112f, .02466f,
+				     -1.0873e-4f, .022993f, -1.093e-4f, 6890.f, 6900.f, .0079821f, .66219f,
+				     .020779f, -9.1999e-5f, .020053f, -9.48e-5f, 6900.f, 6910.f, .019955f,
+				     .70298f, .016653f, -7.4032e-5f, .017622f, -7.4061e-5f, 6910.f, 6920.f,
+				     .047678f, .44625f, .011512f, -5.6613e-5f, .010983f, -5.0893e-5f, 6920.f,
+				     6930.f, .072667f, .31454f, .0067346f, -3.8595e-5f, .0058565f,
+				     -4.0764e-5f, 6930.f, 6940.f, .21391f, .45263f, .0039143f, -1.9313e-5f,
+				     .0056575f, -2.8872e-5f, 6940.f, 6950.f, .3773f, .2493f, -.0011236f,
+				     -3.7053e-6f, 4.1967e-4f, 5.3393e-6f, 6950.f, 6960.f, .29585f, .17647f,
+				     -.0038687f, 2.2126e-6f, -.0068173f, 8.2438e-6f, 6960.f, 6970.f, .30531f,
+				     .23118f, -.004195f, 3.5322e-6f, -.0069672f, 1.113e-5f, 6970.f, 6980.f,
+				     .77834f, .54008f, 5.3815e-4f, -7.5276e-6f, -1.0156e-4f, -7.935e-6f,
+				     6980.f, 6990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 7e3f, 7010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f,
+				     7040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7050.f, 7060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f,
+				     7090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7100.f, 7110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f,
+				     7140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
-    0.f, 7150.f, 7160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f,
-    7190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7200.f, 7210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f,
-    7240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7240.f, 7250.f, 9.7362e-6f,
-      .061285f,
-    .004498f, -3.1185e-5f, .0013664f, -2.5022e-5f, 7250.f, 7260.f,
-    5.4706e-5f, .18852f, 2.4251e-4f, -1.332e-5f, -.0027302f, -8.1259e-6f,
-    7260.f, 7270.f, 6.1563e-5f, .20629f, -.0032814f, 2.2e-8f, -.0062079f,
-    5.925e-6f, 7270.f, 7280.f, 1.4699e-5f, .075241f, -.0044219f, 4.3348e-6f,
-    -.0074089f, 1.0364e-5f, 7280.f, 7290.f, 7.0542e-5f, .20329f, -.002882f,
-    -1.4802e-6f, -.0057837f, 4.2344e-6f, 7290.f, 7300.f, 5.4492e-5f,
-    .21457f, .0013783f, -1.721e-5f, -.0014841f, -1.2786e-5f, 7300.f, 7310.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f, 7340.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7350.f,
-      7360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f, 7390.f, 4.0391e-5f,
-    .34559f, .016271f, -7.7571e-5f, .013286f, -7.2256e-5f, 7390.f, 7400.f,
-    4.8302e-5f, .37526f, .012898f, -6.4691e-5f, .010001f, -5.8901e-5f,
-    7400.f, 7410.f, 2.6773e-5f, .14702f, .016569f, -7.6331e-5f, .013558f,
-    -7.16e-5f, 7410.f, 7420.f, 2.0816e-4f, .52374f, .010994f, -5.4458e-5f,
-    .0090105f, -5.4076e-5f, 7420.f, 7430.f, 4.8129e-4f, .23329f, .0042161f,
-    -2.5147e-5f, .0034174f, -2.5567e-5f, 7430.f, 7440.f, .0010907f, .19364f,
-    -.0012077f, -7.8171e-6f, -.0041544f, -2.4136e-6f, 7440.f, 7450.f,
-    7.8191e-4f, .2075f, -.0039131f, 2.4015e-6f, -.0069105f, 8.5956e-6f,
-    7450.f, 7460.f, 7.115e-4f, .19688f, -.0041668f, 3.3692e-6f, -.0070951f,
-    9.4003e-6f, 7460.f, 7470.f, .0014863f, .25817f, -.0012495f, -7.1361e-6f,
-    -.0041323f, -2.2309e-6f, 7470.f, 7480.f, 4.7705e-4f, .2487f, .005832f,
-    -3.2625e-5f, .0036125f, -3.1486e-5f, 7480.f, 7490.f, 2.3552e-5f,
-    .11333f, .017332f, -8.0926e-5f, .014655f, -7.7124e-5f, 7490.f, 7500.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7500.f, 7510.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7510.f, 7520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7520.f, 7530.f, 7.1378e-6f,
-    .057272f, .023828f, -1.0818e-4f, .020923f, -1.0279e-4f, 7530.f, 7540.f,
-    5.5634e-5f, .11302f, .017308f, -8.0844e-5f, .014641f, -7.7072e-5f,
-    7540.f, 7550.f, 3.874e-4f, .29038f, .010833f, -4.9887e-5f, .010414f,
-    -5.4606e-5f, 7550.f, 7560.f, 9.6863e-4f, .27281f, .0053932f,
-    -2.8655e-5f, .0052931f, -3.3358e-5f, 7560.f, 7570.f, .0023248f, .26964f,
-    4.149e-4f, -1.1296e-5f, -6.0618e-5f, -1.1765e-5f, 7570.f, 7580.f,
-    .0029909f, .2796f, -.0030237f, 8.4962e-7f, -.0041122f, 3.9569e-6f,
-    7580.f, 7590.f, .001504f, .43911f, -.0026031f, 1.2211e-5f, -.0012549f,
-    4.2399e-6f, 7590.f, 7600.f, .004448f, .35168f, -.0020068f, -1.1923e-6f,
-    -.0024644f, 4.0855e-6f, 7600.f, 7610.f, .0020548f, .3146f, .0041619f,
-    -2.4632e-5f, .0023465f, -2.5042e-5f, 7610.f, 7620.f
+				     0.f, 7150.f, 7160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f,
+				     7190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7200.f, 7210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f,
+				     7240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7240.f, 7250.f, 9.7362e-6f,
+				     .061285f,
+				     .004498f, -3.1185e-5f, .0013664f, -2.5022e-5f, 7250.f, 7260.f,
+				     5.4706e-5f, .18852f, 2.4251e-4f, -1.332e-5f, -.0027302f, -8.1259e-6f,
+				     7260.f, 7270.f, 6.1563e-5f, .20629f, -.0032814f, 2.2e-8f, -.0062079f,
+				     5.925e-6f, 7270.f, 7280.f, 1.4699e-5f, .075241f, -.0044219f, 4.3348e-6f,
+				     -.0074089f, 1.0364e-5f, 7280.f, 7290.f, 7.0542e-5f, .20329f, -.002882f,
+				     -1.4802e-6f, -.0057837f, 4.2344e-6f, 7290.f, 7300.f, 5.4492e-5f,
+				     .21457f, .0013783f, -1.721e-5f, -.0014841f, -1.2786e-5f, 7300.f, 7310.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f, 7340.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7350.f,
+				     7360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f, 7390.f, 4.0391e-5f,
+				     .34559f, .016271f, -7.7571e-5f, .013286f, -7.2256e-5f, 7390.f, 7400.f,
+				     4.8302e-5f, .37526f, .012898f, -6.4691e-5f, .010001f, -5.8901e-5f,
+				     7400.f, 7410.f, 2.6773e-5f, .14702f, .016569f, -7.6331e-5f, .013558f,
+				     -7.16e-5f, 7410.f, 7420.f, 2.0816e-4f, .52374f, .010994f, -5.4458e-5f,
+				     .0090105f, -5.4076e-5f, 7420.f, 7430.f, 4.8129e-4f, .23329f, .0042161f,
+				     -2.5147e-5f, .0034174f, -2.5567e-5f, 7430.f, 7440.f, .0010907f, .19364f,
+				     -.0012077f, -7.8171e-6f, -.0041544f, -2.4136e-6f, 7440.f, 7450.f,
+				     7.8191e-4f, .2075f, -.0039131f, 2.4015e-6f, -.0069105f, 8.5956e-6f,
+				     7450.f, 7460.f, 7.115e-4f, .19688f, -.0041668f, 3.3692e-6f, -.0070951f,
+				     9.4003e-6f, 7460.f, 7470.f, .0014863f, .25817f, -.0012495f, -7.1361e-6f,
+				     -.0041323f, -2.2309e-6f, 7470.f, 7480.f, 4.7705e-4f, .2487f, .005832f,
+				     -3.2625e-5f, .0036125f, -3.1486e-5f, 7480.f, 7490.f, 2.3552e-5f,
+				     .11333f, .017332f, -8.0926e-5f, .014655f, -7.7124e-5f, 7490.f, 7500.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7500.f, 7510.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7510.f, 7520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7520.f, 7530.f, 7.1378e-6f,
+				     .057272f, .023828f, -1.0818e-4f, .020923f, -1.0279e-4f, 7530.f, 7540.f,
+				     5.5634e-5f, .11302f, .017308f, -8.0844e-5f, .014641f, -7.7072e-5f,
+				     7540.f, 7550.f, 3.874e-4f, .29038f, .010833f, -4.9887e-5f, .010414f,
+				     -5.4606e-5f, 7550.f, 7560.f, 9.6863e-4f, .27281f, .0053932f,
+				     -2.8655e-5f, .0052931f, -3.3358e-5f, 7560.f, 7570.f, .0023248f, .26964f,
+				     4.149e-4f, -1.1296e-5f, -6.0618e-5f, -1.1765e-5f, 7570.f, 7580.f,
+				     .0029909f, .2796f, -.0030237f, 8.4962e-7f, -.0041122f, 3.9569e-6f,
+				     7580.f, 7590.f, .001504f, .43911f, -.0026031f, 1.2211e-5f, -.0012549f,
+				     4.2399e-6f, 7590.f, 7600.f, .004448f, .35168f, -.0020068f, -1.1923e-6f,
+				     -.0024644f, 4.0855e-6f, 7600.f, 7610.f, .0020548f, .3146f, .0041619f,
+				     -2.4632e-5f, .0023465f, -2.5042e-5f, 7610.f, 7620.f
-	/* carbon dioxide (5060 - 7610 cm-1) */
+    /* carbon dioxide (5060 - 7610 cm-1) */
 }	/* dica2 */
@@ -2567,308 +2567,308 @@
-  static const float acr[2048] = { 1.1446e-5f, .0020117f,
-    -.0041334f, 3.2304e-6f, -.0069982f, 9.0084e-6f, 2500.f, 2510.f,
-    1.9234e-5f, .0019311f, -.0017326f, -5.8646e-6f, -.0045311f,
-    -6.0352e-7f, 2510.f, 2520.f, 9.202e-6f, .0017952f, .0034861f,
-    -2.526e-5f, 5.8777e-4f, -2.0915e-5f, 2520.f, 2530.f, 1.6374e-6f,
-    .0018281f, .010418f, -4.3535e-5f, .0074404f, -4.1207e-5f, 2530.f,
-    2540.f, 1.9079e-7f, .0010034f, .011048f, -9.739e-6f, .010458f,
+    static const float acr[2048] = { 1.1446e-5f, .0020117f,
+				     -.0041334f, 3.2304e-6f, -.0069982f, 9.0084e-6f, 2500.f, 2510.f,
+				     1.9234e-5f, .0019311f, -.0017326f, -5.8646e-6f, -.0045311f,
+				     -6.0352e-7f, 2510.f, 2520.f, 9.202e-6f, .0017952f, .0034861f,
+				     -2.526e-5f, 5.8777e-4f, -2.0915e-5f, 2520.f, 2530.f, 1.6374e-6f,
+				     .0018281f, .010418f, -4.3535e-5f, .0074404f, -4.1207e-5f, 2530.f,
+				     2540.f, 1.9079e-7f, .0010034f, .011048f, -9.739e-6f, .010458f,
-    -3.7165e-5f, 2540.f, 2550.f, 3.4315e-9f, 2.4238e-5f, .0054443f,
-    -3.5215e-5f, .00216f, -2.8602e-5f, 2550.f, 2560.f, 8.2488e-9f,
-    1.2211e-4f, .026474f, -1.1937e-4f, .023595f, -1.1358e-4f, 2560.f,
-    2570.f, 6.4587e-7f, .0014539f, .017175f, -7.7312e-5f, .015125f,
-    -7.6621e-5f, 2570.f, 2580.f, 5.4268e-6f, .0015777f, .0078126f,
-    -4.2151e-5f, .0051843f, -3.9096e-5f, 2580.f, 2590.f, 2.0993e-5f,
-    .0024666f, .0015156f, -1.4469e-5f, .0014551f, -1.2874e-5f, 2590.f,
-    2600.f, 3.1892e-5f, .0032261f, -.0024271f, 1.4275e-6f, -.0024514f,
-    2.5977e-6f, 2600.f, 2610.f, 1.1919e-5f, .0029607f, -.0037722f,
-    7.2919e-6f, -.004064f, 7.442e-6f, 2610.f, 2620.f, 3.5396e-5f, .0031915f,
-    -.0024421f, -5.4413e-7f, -.0029857f, 7.7772e-7f, 2620.f, 2630.f,
-    2.2174e-5f, .0031839f, .002243f, -1.6625e-5f, .0017446f, -1.7477e-5f,
-    2630.f, 2640.f, 4.9654e-6f, .0031706f, .0096026f, -4.1529e-5f,
-    .0087311f, -4.451e-5f, 2640.f, 2650.f, 5.9768e-7f, .0013719f, .0076702f,
-    1.3005e-5f, .0090078f, -2.4905e-5f, 2650.f, 2660.f, 1.3394e-7f,
-    3.2465e-4f, .0037114f, -2.6108e-5f, 9.3326e-4f, -2.2404e-5f, 2660.f,
-    2670.f, 9.101e-9f, 7.1741e-5f, .010072f, -5.3553e-5f, .0068917f,
-    -4.7305e-5f, 2670.f, 2680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2680.f, 2690.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2690.f, 2700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    2700.f, 2710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2710.f, 2720.f, 3.0498e-7f,
-    .0012211f, .011385f, -5.7015e-5f, .008676f, -5.3344e-5f, 2720.f, 2730.f,
-    2.3044e-6f, .0018735f, .0031625f, -2.3857e-5f, 4.2583e-4f, -2.0332e-5f,
-    2730.f, 2740.f, 4.587e-6f, .0020082f, -.0021166f, -4.3444e-6f,
-    -.0048776f, 8.714e-7f, 2740.f, 2750.f, 1.8151e-6f, .001778f, -.0043591f,
-    3.9928e-6f, -.0074161f, 1.0271e-5f, 2750.f, 2760.f, 4.3155e-6f,
-    .0021845f, -.0035667f, 1.0325e-6f, -.0064484f, 6.9079e-6f, 2760.f,
-    2770.f, 3.5601e-6f, .0015853f, -2.4397e-4f, -1.1623e-5f, -.0030932f,
-    -6.6664e-6f, 2770.f, 2780.f, 1.4023e-6f, .0017421f, .0052527f,
-    -3.1584e-5f, .0022672f, -2.6978e-5f, 2780.f, 2790.f, 1.9517e-7f,
-    .0010843f, .011752f, -5.0614e-5f, .0090578f, -5.0929e-5f, 2790.f,
-    2800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2800.f, 2810.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2810.f, 2820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2820.f, 2830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2830.f, 2840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2840.f,
-    2850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2850.f, 2860.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2860.f, 2870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2870.f, 2880.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2880.f, 2890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2890.f,
-    2900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2900.f, 2910.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2910.f, 2920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2920.f, 2930.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2930.f, 2940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2940.f,
-    2950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2950.f, 2960.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2960.f, 2970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2970.f, 2980.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2980.f, 2990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2990.f,
-      3e3f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3e3f, 3010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    3010.f, 3020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3020.f, 3030.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3030.f, 3040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3040.f,
-      3050.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3050.f, 3060.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3060.f, 3070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3070.f, 3080.f, 3.3052e-6f,
-    .058651f, .034989f, -1.529e-4f, .031987f, -1.4721e-4f, 3080.f, 3090.f,
-    4.1503e-5f, .20207f, .026206f, -1.1436e-4f, .023672f, -1.1213e-4f,
-    3090.f, 3100.f, 8.7906e-5f, .21783f, .018422f, -8.5123e-5f, .015304f,
-    -7.985e-5f, 3100.f, 3110.f, 2.9489e-5f, .12859f, .014066f, -6.9404e-5f,
-    .011044f, -6.3254e-5f, 3110.f, 3120.f, 3.1118e-5f, .2981f, .025033f,
-    -1.1155e-4f, .022143f, -1.0719e-4f, 3120.f, 3130.f, 1.4832e-4f, .7106f,
-    .018309f, -7.0285e-5f, .015857f, -7.3742e-5f, 3130.f, 3140.f,
-    5.0912e-4f, .39631f, .016927f, -7.7076e-5f, .014306f, -7.4481e-5f,
-    3140.f, 3150.f, .0018569f, .28375f, .0076498f, -3.6249e-5f, .0067089f,
-    -3.6791e-5f, 3150.f, 3160.f, .0023217f, .3497f, .0010351f, -1.0688e-5f,
-    9.4905e-4f, -6.7349e-6f, 3160.f, 3170.f, 4.761e-4f, .41947f, .0019347f,
-    1.6317e-5f, .0033594f, -7.9441e-6f, 3170.f, 3180.f, 4.6778e-4f, .77616f,
-    7.9129e-4f, 2.3675e-5f, 9.1006e-4f, 4.8023e-6f, 3180.f, 3190.f,
-    .0030862f, .25667f, -.0014396f, -4.1338e-6f, -.0027351f, 6.4924e-6f,
-    3190.f, 3200.f, .0034062f, .18499f, .003259f, -2.4779e-5f, 2.1425e-4f,
-    -1.9664e-5f, 3200.f, 3210.f, .0014366f, .17452f, .010436f, -5.221e-5f,
-    .0077713f, -4.9107e-5f, 3210.f, 3220.f, 2.6116e-4f, .16068f, .020114f,
-    -8.9663e-5f, .017964f, -8.8666e-5f, 3220.f, 3230.f, 3.408e-5f, .26237f,
-    .031854f, -1.3724e-4f, .029565f, -1.3533e-4f, 3230.f, 3240.f,
-    3.8044e-5f, .18154f, .023462f, -1.0477e-4f, .020484f, -1.0031e-4f,
-    3240.f, 3250.f, 2.3642e-5f, .12587f, .01793f, -8.3993e-5f, .014725f,
-    -7.8063e-5f, 3250.f, 3260.f, 1.3555e-6f, .0021856f, .0043607f,
-    -2.9254e-5f, .0012372f, -2.4119e-5f, 3260.f, 3270.f, 3.5631e-4f,
-    .86373f, .015491f, -6.0741e-5f, .014051f, -6.1126e-5f, 3270.f, 3280.f,
-    3.3068e-4f, .41597f, .01708f, -4.5243e-5f, .018249f, -6.1327e-5f,
-    3280.f, 3290.f, .001398f, .43415f, .020779f, -8.71e-5f, .019046f,
-    -8.4016e-5f, 3290.f, 3300.f, .0054038f, .37316f, .013012f, -5.4513e-5f,
-    .014582f, -6.1135e-5f, 3300.f, 3310.f, .011865f, .37215f, .005333f,
-    -2.4891e-5f, .0077872f, -2.3154e-5f, 3310.f, 3320.f, .0081717f, .45864f,
-    7.0369e-4f, -2.5399e-6f, .0032045f, -2.1463e-6f, 3320.f, 3330.f,
-    .0067313f, .55963f, -.0020245f, 2.6702e-6f, -.0024299f, 1.777e-5f,
-    3330.f, 3340.f, .013254f, .74729f, -.001815f, 5.4501e-6f, .0013181f,
-    -4.3636e-7f, 3340.f, 3350.f, .036823f, .36421f, -2.01e-4f, -5.8593e-6f,
-    .0013324f, -2.3987e-6f, 3350.f, 3360.f, .035439f, .40306f, .0054434f,
-    -2.6546e-5f, .0067677f, -2.8288e-5f, 3360.f, 3370.f, .0090957f, .48115f,
-    .014512f, -6.1088e-5f, .016771f, -6.5673e-5f, 3370.f, 3380.f, .0015199f,
-    .65754f, .023451f, -8.6e-5f, .024073f, -8.9238e-5f, 3380.f, 3390.f,
-    1.3838e-4f, .96599f, .027438f, -3.7378e-5f, .026069f, -7.2896e-5f,
-    3390.f, 3400.f, 3.1321e-4f, .32432f, .014691f, -4.5546e-5f, .01786f,
-    -4.056e-5f, 3400.f, 3410.f, 9.6318e-4f, .34642f, .017708f, -6.6986e-5f,
-    .020408f, -5.3348e-5f, 3410.f, 3420.f, 6.1782e-4f, .30724f, .02599f,
-    -8.9579e-5f, .025999f, -9.8228e-5f, 3420.f, 3430.f, 4.0506e-4f, .30755f,
-    .038698f, -1.6162e-4f, .035406f, -1.5721e-4f, 3430.f, 3440.f, .0011183f,
-    .2365f, .034497f, -1.4952e-4f, .032465f, -1.4642e-4f, 3440.f, 3450.f,
-    .0018653f, .34796f, .029814f, -1.2999e-4f, .026883f, -1.245e-4f, 3450.f,
-    3460.f, .0035542f, .40556f, .017369f, -5.7102e-5f, .019546f,
-    -4.6731e-5f, 3460.f, 3470.f, .0090605f, .50199f, .012281f, 2.333e-7f,
-    .01992f, 2.7162e-5f, 3470.f, 3480.f, .008421f, .7135f, .011986f,
-    7.348e-5f, .024636f, 8.1574e-5f, 3480.f, 3490.f, .0060886f, .9612f,
-    .023574f, 1.0867e-4f, .044783f, -7.2014e-5f, 3490.f, 3500.f, .035622f,
-    1.6535f, .012077f, 1.3532e-4f, .02212f, 8.0854e-5f, 3500.f, 3510.f,
-    .078238f, 1.3688f, .016785f, 1.4511e-4f, .032327f, -1.2296e-5f, 3510.f,
-    3520.f, .17292f, 1.6314f, .028411f, -4.0866e-6f, .033279f, -8.391e-5f,
-    3520.f, 3530.f, .58094f, 1.4177f, .030478f, -9.228e-5f, .032074f,
-    -1.1676e-4f, 3530.f, 3540.f, 1.9973f, 1.0662f, .026332f, -1.0563e-4f,
-    .027668f, -1.086e-4f, 3540.f, 3550.f, 5.8904f, .85364f, .020626f,
-    -8.7922e-5f, .022034f, -8.7919e-5f, 3550.f, 3560.f, 16.608f, .82681f,
-    .016296f, -7.197e-5f, .016508f, -6.8914e-5f, 3560.f, 3570.f, 33.94f,
-    .67293f, .011756f, -5.5546e-5f, .012667f, -5.0727e-5f, 3570.f, 3580.f,
-    105.89f, .40519f, .0053354f, -3.05e-5f, .00642f, -2.7269e-5f, 3580.f,
-    3590.f, 286.58f, .37875f, 3.1591e-4f, -7.6033e-6f, .0017571f,
-    -6.9331e-6f, 3590.f, 3600.f, 258.81f, .31632f, -.0031299f, 5.3577e-6f,
-    -.0014554f, 1.6811e-5f, 3600.f, 3610.f, 153.98f, .23899f, -.0042487f,
-    5.6295e-6f, -.0038259f, 2.864e-5f, 3610.f, 3620.f, 381.54f, .2369f,
-    -.0021079f, -4.2102e-6f, -.0046108f, 4.6494e-6f, 3620.f, 3630.f,
-    189.08f, .24104f, .003487f, -2.4525e-5f, .0012111f, -1.869e-5f, 3630.f,
-    3640.f, 22.631f, .27596f, .013843f, -6.0817e-5f, .013983f, -5.5436e-5f,
-    3640.f, 3650.f, .789f, .45834f, .0288f, -9.2261e-5f, .033526f,
-    -1.1634e-4f, 3650.f, 3660.f, 3.5516f, .24747f, .021606f, -9.1483e-5f,
-    .025091f, -7.7825e-5f, 3660.f, 3670.f, 26.382f, .26344f, .013128f,
-    -5.9351e-5f, .015813f, -4.5315e-5f, 3670.f, 3680.f, 114.51f, .25517f,
-    .0061726f, -3.2903e-5f, .0088361f, -1.856e-5f, 3680.f, 3690.f, 375.87f,
-    .29958f, 6.1303e-4f, -1.0823e-5f, .0025691f, 2.5921e-6f, 3690.f, 3700.f,
-    399.12f, .32406f, -.0024055f, 3.4271e-6f, 8.3356e-4f, 1.4624e-5f,
-    3700.f, 3710.f, 209.7f, .49024f, -.0029825f, 1.1251e-5f, 9.8088e-4f,
-    1.7825e-5f, 3710.f, 3720.f, 651.86f, .43325f, -.0025584f, -7.4576e-7f,
-    -.0013717f, 1.1441e-5f, 3720.f, 3730.f, 360.94f, .49364f, .0033219f,
-    -1.9819e-5f, .0045993f, -1.8704e-5f, 3730.f, 3740.f, 57.048f, .71411f,
-    .013964f, -5.8323e-5f, .015441f, -6.5072e-5f, 3740.f, 3750.f, 1.6419f,
-    .94961f, .031167f, -1.2796e-4f, .03253f, -1.3294e-4f, 3750.f, 3760.f,
-    .0072097f, .71242f, .053044f, -2.1219e-4f, .055695f, -2.2364e-4f,
-    3760.f, 3770.f, 3.2929e-4f, .16488f, .043688f, -1.8453e-4f, .042346f,
-    -1.8165e-4f, 3770.f, 3780.f, .0014501f, .17127f, .036748f, -1.5788e-4f,
-    .035331f, -1.524e-4f, 3780.f, 3790.f, .0047585f, .19488f, .031054f,
-    -1.364e-4f, .028516f, -1.3041e-4f, 3790.f, 3800.f, .0056312f, .2178f,
-    .027563f, -1.2299e-4f, .02536f, -1.1514e-4f, 3800.f, 3810.f, .0025663f,
-    .23975f, .026455f, -1.1697e-4f, .025771f, -1.0379e-4f, 3810.f, 3820.f,
-    .0073473f, .2611f, .028264f, -1.2512e-4f, .026543f, -1.1735e-4f, 3820.f,
-    3830.f, .0041625f, .3064f, .0335f, -1.4328e-4f, .032396f, -1.4197e-4f,
-    3830.f, 3840.f, 6.2707e-4f, .49963f, .042723f, -1.7265e-4f, .041198f,
-    -1.7864e-4f, 3840.f, 3850.f, 5.2281e-5f, .443f, .041789f, -1.3546e-4f,
-    .041381f, -1.6812e-4f, 3850.f, 3860.f, 1.1349e-4f, .48522f, .040194f,
-    -1.3982e-4f, .03909f, -1.6958e-4f, 3860.f, 3870.f, 1.1733e-4f, .49615f,
-    .044541f, -1.6207e-4f, .043254f, -1.8688e-4f, 3870.f, 3880.f,
-    2.1994e-5f, .36694f, .051435f, -1.7841e-4f, .051058f, -2.162e-4f,
-    3880.f, 3890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3890.f, 3900.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3900.f, 3910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3910.f,
-      3920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3920.f, 3930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3930.f, 3940.f, 1.0712e-5f, .11242f, .038222f, -1.6405e-4f, .035612f,
-    -1.6058e-4f, 3940.f, 3950.f, 2.226e-5f, .088337f, .032098f, -1.4078e-4f,
-    .029142f, -1.356e-4f, 3950.f, 3960.f, 6.0145e-5f, .1215f, .02614f,
-    -1.1441e-4f, .023109f, -1.101e-4f, 3960.f, 3970.f, 1.1812e-4f, .5338f,
-    .023839f, -9.6178e-5f, .023506f, -1.0676e-4f, 3970.f, 3980.f, 6.12e-5f,
-    .32611f, .020895f, -7.6119e-5f, .020369f, -8.7589e-5f, 3980.f, 3990.f,
-    3.019e-4f, .84191f, .024861f, -9.352e-5f, .024385f, -1.0546e-4f, 3990.f,
-    4e3f, .0013735f, .6758f, .014099f, -6.4565e-5f, .011933f, -5.7363e-5f,
-    4e3f, 4010.f, .0017095f, .28901f, .013726f, -6.7497e-5f, .010543f,
-    -6.096e-5f, 4010.f, 4020.f, .0020687f, .45821f, .021277f, -8.6802e-5f,
-    .020845f, -9.0012e-5f, 4020.f, 4030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      4030.f,
+				     -3.7165e-5f, 2540.f, 2550.f, 3.4315e-9f, 2.4238e-5f, .0054443f,
+				     -3.5215e-5f, .00216f, -2.8602e-5f, 2550.f, 2560.f, 8.2488e-9f,
+				     1.2211e-4f, .026474f, -1.1937e-4f, .023595f, -1.1358e-4f, 2560.f,
+				     2570.f, 6.4587e-7f, .0014539f, .017175f, -7.7312e-5f, .015125f,
+				     -7.6621e-5f, 2570.f, 2580.f, 5.4268e-6f, .0015777f, .0078126f,
+				     -4.2151e-5f, .0051843f, -3.9096e-5f, 2580.f, 2590.f, 2.0993e-5f,
+				     .0024666f, .0015156f, -1.4469e-5f, .0014551f, -1.2874e-5f, 2590.f,
+				     2600.f, 3.1892e-5f, .0032261f, -.0024271f, 1.4275e-6f, -.0024514f,
+				     2.5977e-6f, 2600.f, 2610.f, 1.1919e-5f, .0029607f, -.0037722f,
+				     7.2919e-6f, -.004064f, 7.442e-6f, 2610.f, 2620.f, 3.5396e-5f, .0031915f,
+				     -.0024421f, -5.4413e-7f, -.0029857f, 7.7772e-7f, 2620.f, 2630.f,
+				     2.2174e-5f, .0031839f, .002243f, -1.6625e-5f, .0017446f, -1.7477e-5f,
+				     2630.f, 2640.f, 4.9654e-6f, .0031706f, .0096026f, -4.1529e-5f,
+				     .0087311f, -4.451e-5f, 2640.f, 2650.f, 5.9768e-7f, .0013719f, .0076702f,
+				     1.3005e-5f, .0090078f, -2.4905e-5f, 2650.f, 2660.f, 1.3394e-7f,
+				     3.2465e-4f, .0037114f, -2.6108e-5f, 9.3326e-4f, -2.2404e-5f, 2660.f,
+				     2670.f, 9.101e-9f, 7.1741e-5f, .010072f, -5.3553e-5f, .0068917f,
+				     -4.7305e-5f, 2670.f, 2680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2680.f, 2690.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2690.f, 2700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     2700.f, 2710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2710.f, 2720.f, 3.0498e-7f,
+				     .0012211f, .011385f, -5.7015e-5f, .008676f, -5.3344e-5f, 2720.f, 2730.f,
+				     2.3044e-6f, .0018735f, .0031625f, -2.3857e-5f, 4.2583e-4f, -2.0332e-5f,
+				     2730.f, 2740.f, 4.587e-6f, .0020082f, -.0021166f, -4.3444e-6f,
+				     -.0048776f, 8.714e-7f, 2740.f, 2750.f, 1.8151e-6f, .001778f, -.0043591f,
+				     3.9928e-6f, -.0074161f, 1.0271e-5f, 2750.f, 2760.f, 4.3155e-6f,
+				     .0021845f, -.0035667f, 1.0325e-6f, -.0064484f, 6.9079e-6f, 2760.f,
+				     2770.f, 3.5601e-6f, .0015853f, -2.4397e-4f, -1.1623e-5f, -.0030932f,
+				     -6.6664e-6f, 2770.f, 2780.f, 1.4023e-6f, .0017421f, .0052527f,
+				     -3.1584e-5f, .0022672f, -2.6978e-5f, 2780.f, 2790.f, 1.9517e-7f,
+				     .0010843f, .011752f, -5.0614e-5f, .0090578f, -5.0929e-5f, 2790.f,
+				     2800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2800.f, 2810.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2810.f, 2820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2820.f, 2830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2830.f, 2840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2840.f,
+				     2850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2850.f, 2860.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2860.f, 2870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2870.f, 2880.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2880.f, 2890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2890.f,
+				     2900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2900.f, 2910.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2910.f, 2920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2920.f, 2930.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2930.f, 2940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2940.f,
+				     2950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2950.f, 2960.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2960.f, 2970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2970.f, 2980.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2980.f, 2990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2990.f,
+				     3e3f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3e3f, 3010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     3010.f, 3020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3020.f, 3030.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3030.f, 3040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3040.f,
+				     3050.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3050.f, 3060.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3060.f, 3070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3070.f, 3080.f, 3.3052e-6f,
+				     .058651f, .034989f, -1.529e-4f, .031987f, -1.4721e-4f, 3080.f, 3090.f,
+				     4.1503e-5f, .20207f, .026206f, -1.1436e-4f, .023672f, -1.1213e-4f,
+				     3090.f, 3100.f, 8.7906e-5f, .21783f, .018422f, -8.5123e-5f, .015304f,
+				     -7.985e-5f, 3100.f, 3110.f, 2.9489e-5f, .12859f, .014066f, -6.9404e-5f,
+				     .011044f, -6.3254e-5f, 3110.f, 3120.f, 3.1118e-5f, .2981f, .025033f,
+				     -1.1155e-4f, .022143f, -1.0719e-4f, 3120.f, 3130.f, 1.4832e-4f, .7106f,
+				     .018309f, -7.0285e-5f, .015857f, -7.3742e-5f, 3130.f, 3140.f,
+				     5.0912e-4f, .39631f, .016927f, -7.7076e-5f, .014306f, -7.4481e-5f,
+				     3140.f, 3150.f, .0018569f, .28375f, .0076498f, -3.6249e-5f, .0067089f,
+				     -3.6791e-5f, 3150.f, 3160.f, .0023217f, .3497f, .0010351f, -1.0688e-5f,
+				     9.4905e-4f, -6.7349e-6f, 3160.f, 3170.f, 4.761e-4f, .41947f, .0019347f,
+				     1.6317e-5f, .0033594f, -7.9441e-6f, 3170.f, 3180.f, 4.6778e-4f, .77616f,
+				     7.9129e-4f, 2.3675e-5f, 9.1006e-4f, 4.8023e-6f, 3180.f, 3190.f,
+				     .0030862f, .25667f, -.0014396f, -4.1338e-6f, -.0027351f, 6.4924e-6f,
+				     3190.f, 3200.f, .0034062f, .18499f, .003259f, -2.4779e-5f, 2.1425e-4f,
+				     -1.9664e-5f, 3200.f, 3210.f, .0014366f, .17452f, .010436f, -5.221e-5f,
+				     .0077713f, -4.9107e-5f, 3210.f, 3220.f, 2.6116e-4f, .16068f, .020114f,
+				     -8.9663e-5f, .017964f, -8.8666e-5f, 3220.f, 3230.f, 3.408e-5f, .26237f,
+				     .031854f, -1.3724e-4f, .029565f, -1.3533e-4f, 3230.f, 3240.f,
+				     3.8044e-5f, .18154f, .023462f, -1.0477e-4f, .020484f, -1.0031e-4f,
+				     3240.f, 3250.f, 2.3642e-5f, .12587f, .01793f, -8.3993e-5f, .014725f,
+				     -7.8063e-5f, 3250.f, 3260.f, 1.3555e-6f, .0021856f, .0043607f,
+				     -2.9254e-5f, .0012372f, -2.4119e-5f, 3260.f, 3270.f, 3.5631e-4f,
+				     .86373f, .015491f, -6.0741e-5f, .014051f, -6.1126e-5f, 3270.f, 3280.f,
+				     3.3068e-4f, .41597f, .01708f, -4.5243e-5f, .018249f, -6.1327e-5f,
+				     3280.f, 3290.f, .001398f, .43415f, .020779f, -8.71e-5f, .019046f,
+				     -8.4016e-5f, 3290.f, 3300.f, .0054038f, .37316f, .013012f, -5.4513e-5f,
+				     .014582f, -6.1135e-5f, 3300.f, 3310.f, .011865f, .37215f, .005333f,
+				     -2.4891e-5f, .0077872f, -2.3154e-5f, 3310.f, 3320.f, .0081717f, .45864f,
+				     7.0369e-4f, -2.5399e-6f, .0032045f, -2.1463e-6f, 3320.f, 3330.f,
+				     .0067313f, .55963f, -.0020245f, 2.6702e-6f, -.0024299f, 1.777e-5f,
+				     3330.f, 3340.f, .013254f, .74729f, -.001815f, 5.4501e-6f, .0013181f,
+				     -4.3636e-7f, 3340.f, 3350.f, .036823f, .36421f, -2.01e-4f, -5.8593e-6f,
+				     .0013324f, -2.3987e-6f, 3350.f, 3360.f, .035439f, .40306f, .0054434f,
+				     -2.6546e-5f, .0067677f, -2.8288e-5f, 3360.f, 3370.f, .0090957f, .48115f,
+				     .014512f, -6.1088e-5f, .016771f, -6.5673e-5f, 3370.f, 3380.f, .0015199f,
+				     .65754f, .023451f, -8.6e-5f, .024073f, -8.9238e-5f, 3380.f, 3390.f,
+				     1.3838e-4f, .96599f, .027438f, -3.7378e-5f, .026069f, -7.2896e-5f,
+				     3390.f, 3400.f, 3.1321e-4f, .32432f, .014691f, -4.5546e-5f, .01786f,
+				     -4.056e-5f, 3400.f, 3410.f, 9.6318e-4f, .34642f, .017708f, -6.6986e-5f,
+				     .020408f, -5.3348e-5f, 3410.f, 3420.f, 6.1782e-4f, .30724f, .02599f,
+				     -8.9579e-5f, .025999f, -9.8228e-5f, 3420.f, 3430.f, 4.0506e-4f, .30755f,
+				     .038698f, -1.6162e-4f, .035406f, -1.5721e-4f, 3430.f, 3440.f, .0011183f,
+				     .2365f, .034497f, -1.4952e-4f, .032465f, -1.4642e-4f, 3440.f, 3450.f,
+				     .0018653f, .34796f, .029814f, -1.2999e-4f, .026883f, -1.245e-4f, 3450.f,
+				     3460.f, .0035542f, .40556f, .017369f, -5.7102e-5f, .019546f,
+				     -4.6731e-5f, 3460.f, 3470.f, .0090605f, .50199f, .012281f, 2.333e-7f,
+				     .01992f, 2.7162e-5f, 3470.f, 3480.f, .008421f, .7135f, .011986f,
+				     7.348e-5f, .024636f, 8.1574e-5f, 3480.f, 3490.f, .0060886f, .9612f,
+				     .023574f, 1.0867e-4f, .044783f, -7.2014e-5f, 3490.f, 3500.f, .035622f,
+				     1.6535f, .012077f, 1.3532e-4f, .02212f, 8.0854e-5f, 3500.f, 3510.f,
+				     .078238f, 1.3688f, .016785f, 1.4511e-4f, .032327f, -1.2296e-5f, 3510.f,
+				     3520.f, .17292f, 1.6314f, .028411f, -4.0866e-6f, .033279f, -8.391e-5f,
+				     3520.f, 3530.f, .58094f, 1.4177f, .030478f, -9.228e-5f, .032074f,
+				     -1.1676e-4f, 3530.f, 3540.f, 1.9973f, 1.0662f, .026332f, -1.0563e-4f,
+				     .027668f, -1.086e-4f, 3540.f, 3550.f, 5.8904f, .85364f, .020626f,
+				     -8.7922e-5f, .022034f, -8.7919e-5f, 3550.f, 3560.f, 16.608f, .82681f,
+				     .016296f, -7.197e-5f, .016508f, -6.8914e-5f, 3560.f, 3570.f, 33.94f,
+				     .67293f, .011756f, -5.5546e-5f, .012667f, -5.0727e-5f, 3570.f, 3580.f,
+				     105.89f, .40519f, .0053354f, -3.05e-5f, .00642f, -2.7269e-5f, 3580.f,
+				     3590.f, 286.58f, .37875f, 3.1591e-4f, -7.6033e-6f, .0017571f,
+				     -6.9331e-6f, 3590.f, 3600.f, 258.81f, .31632f, -.0031299f, 5.3577e-6f,
+				     -.0014554f, 1.6811e-5f, 3600.f, 3610.f, 153.98f, .23899f, -.0042487f,
+				     5.6295e-6f, -.0038259f, 2.864e-5f, 3610.f, 3620.f, 381.54f, .2369f,
+				     -.0021079f, -4.2102e-6f, -.0046108f, 4.6494e-6f, 3620.f, 3630.f,
+				     189.08f, .24104f, .003487f, -2.4525e-5f, .0012111f, -1.869e-5f, 3630.f,
+				     3640.f, 22.631f, .27596f, .013843f, -6.0817e-5f, .013983f, -5.5436e-5f,
+				     3640.f, 3650.f, .789f, .45834f, .0288f, -9.2261e-5f, .033526f,
+				     -1.1634e-4f, 3650.f, 3660.f, 3.5516f, .24747f, .021606f, -9.1483e-5f,
+				     .025091f, -7.7825e-5f, 3660.f, 3670.f, 26.382f, .26344f, .013128f,
+				     -5.9351e-5f, .015813f, -4.5315e-5f, 3670.f, 3680.f, 114.51f, .25517f,
+				     .0061726f, -3.2903e-5f, .0088361f, -1.856e-5f, 3680.f, 3690.f, 375.87f,
+				     .29958f, 6.1303e-4f, -1.0823e-5f, .0025691f, 2.5921e-6f, 3690.f, 3700.f,
+				     399.12f, .32406f, -.0024055f, 3.4271e-6f, 8.3356e-4f, 1.4624e-5f,
+				     3700.f, 3710.f, 209.7f, .49024f, -.0029825f, 1.1251e-5f, 9.8088e-4f,
+				     1.7825e-5f, 3710.f, 3720.f, 651.86f, .43325f, -.0025584f, -7.4576e-7f,
+				     -.0013717f, 1.1441e-5f, 3720.f, 3730.f, 360.94f, .49364f, .0033219f,
+				     -1.9819e-5f, .0045993f, -1.8704e-5f, 3730.f, 3740.f, 57.048f, .71411f,
+				     .013964f, -5.8323e-5f, .015441f, -6.5072e-5f, 3740.f, 3750.f, 1.6419f,
+				     .94961f, .031167f, -1.2796e-4f, .03253f, -1.3294e-4f, 3750.f, 3760.f,
+				     .0072097f, .71242f, .053044f, -2.1219e-4f, .055695f, -2.2364e-4f,
+				     3760.f, 3770.f, 3.2929e-4f, .16488f, .043688f, -1.8453e-4f, .042346f,
+				     -1.8165e-4f, 3770.f, 3780.f, .0014501f, .17127f, .036748f, -1.5788e-4f,
+				     .035331f, -1.524e-4f, 3780.f, 3790.f, .0047585f, .19488f, .031054f,
+				     -1.364e-4f, .028516f, -1.3041e-4f, 3790.f, 3800.f, .0056312f, .2178f,
+				     .027563f, -1.2299e-4f, .02536f, -1.1514e-4f, 3800.f, 3810.f, .0025663f,
+				     .23975f, .026455f, -1.1697e-4f, .025771f, -1.0379e-4f, 3810.f, 3820.f,
+				     .0073473f, .2611f, .028264f, -1.2512e-4f, .026543f, -1.1735e-4f, 3820.f,
+				     3830.f, .0041625f, .3064f, .0335f, -1.4328e-4f, .032396f, -1.4197e-4f,
+				     3830.f, 3840.f, 6.2707e-4f, .49963f, .042723f, -1.7265e-4f, .041198f,
+				     -1.7864e-4f, 3840.f, 3850.f, 5.2281e-5f, .443f, .041789f, -1.3546e-4f,
+				     .041381f, -1.6812e-4f, 3850.f, 3860.f, 1.1349e-4f, .48522f, .040194f,
+				     -1.3982e-4f, .03909f, -1.6958e-4f, 3860.f, 3870.f, 1.1733e-4f, .49615f,
+				     .044541f, -1.6207e-4f, .043254f, -1.8688e-4f, 3870.f, 3880.f,
+				     2.1994e-5f, .36694f, .051435f, -1.7841e-4f, .051058f, -2.162e-4f,
+				     3880.f, 3890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3890.f, 3900.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3900.f, 3910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3910.f,
+				     3920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3920.f, 3930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3930.f, 3940.f, 1.0712e-5f, .11242f, .038222f, -1.6405e-4f, .035612f,
+				     -1.6058e-4f, 3940.f, 3950.f, 2.226e-5f, .088337f, .032098f, -1.4078e-4f,
+				     .029142f, -1.356e-4f, 3950.f, 3960.f, 6.0145e-5f, .1215f, .02614f,
+				     -1.1441e-4f, .023109f, -1.101e-4f, 3960.f, 3970.f, 1.1812e-4f, .5338f,
+				     .023839f, -9.6178e-5f, .023506f, -1.0676e-4f, 3970.f, 3980.f, 6.12e-5f,
+				     .32611f, .020895f, -7.6119e-5f, .020369f, -8.7589e-5f, 3980.f, 3990.f,
+				     3.019e-4f, .84191f, .024861f, -9.352e-5f, .024385f, -1.0546e-4f, 3990.f,
+				     4e3f, .0013735f, .6758f, .014099f, -6.4565e-5f, .011933f, -5.7363e-5f,
+				     4e3f, 4010.f, .0017095f, .28901f, .013726f, -6.7497e-5f, .010543f,
+				     -6.096e-5f, 4010.f, 4020.f, .0020687f, .45821f, .021277f, -8.6802e-5f,
+				     .020845f, -9.0012e-5f, 4020.f, 4030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     4030.f,
-    4040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4040.f, 4050.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4050.f, 4060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4060.f, 4070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4070.f, 4080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4080.f,
-    4090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4090.f, 4100.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4100.f, 4110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4110.f, 4120.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4120.f, 4130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4130.f,
-    4140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4140.f, 4150.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4150.f, 4160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4160.f, 4170.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4170.f, 4180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4180.f,
-    4190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4190.f, 4200.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4200.f, 4210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4210.f, 4220.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4220.f, 4230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4230.f,
-    4240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4240.f, 4250.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4250.f, 4260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4260.f, 4270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4270.f, 4280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4280.f,
-    4290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4290.f, 4300.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4300.f, 4310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4310.f, 4320.f, 0.f,
-      0.f,
+				     4040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4040.f, 4050.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4050.f, 4060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4060.f, 4070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4070.f, 4080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4080.f,
+				     4090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4090.f, 4100.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4100.f, 4110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4110.f, 4120.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4120.f, 4130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4130.f,
+				     4140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4140.f, 4150.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4150.f, 4160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4160.f, 4170.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4170.f, 4180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4180.f,
+				     4190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4190.f, 4200.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4200.f, 4210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4210.f, 4220.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4220.f, 4230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4230.f,
+				     4240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4240.f, 4250.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4250.f, 4260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4260.f, 4270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4270.f, 4280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4280.f,
+				     4290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4290.f, 4300.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4300.f, 4310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4310.f, 4320.f, 0.f,
+				     0.f,
-    0.f, 0.f, 0.f, 0.f, 4320.f, 4330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4330.f,
-    4340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4340.f, 4350.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4350.f, 4360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4360.f, 4370.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4370.f, 4380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4380.f,
-    4390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4390.f, 4400.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4400.f, 4410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4410.f, 4420.f,
-      2.629e-5f,
-    .099522f, -.0026652f, -2.6042e-6f, -.0055447f, 3.2186e-6f, 4420.f,
-    4430.f, 8.0883e-5f, .18978f, 5.7466e-4f, -1.4607e-5f, -.0025665f,
-    -8.7838e-6f, 4430.f, 4440.f, 5.526e-5f, .18005f, .0065537f, -3.7323e-5f,
-    .0036814f, -3.3174e-5f, 4440.f, 4450.f, 8.255e-6f, .05991f, .012867f,
-    -6.4515e-5f, .0097575f, -5.8512e-5f, 4450.f, 4460.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 4460.f, 4470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4470.f, 4480.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 4480.f, 4490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      4490.f,
-    4500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4500.f, 4510.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4510.f, 4520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4520.f, 4530.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4530.f, 4540.f, 5.6586e-6f, .058006f, .021852f,
-    -1.003e-4f, .018901f, -9.4764e-5f, 4540.f, 4550.f, 6.0995e-5f, .17176f,
-    .013472f, -6.3857e-5f, .010919f, -6.1333e-5f, 4550.f, 4560.f,
-    1.6173e-4f, .1827f, .0055264f, -3.3401e-5f, .0025266f, -2.8677e-5f,
-    4560.f, 4570.f, 1.342e-4f, .18669f, 8.6662e-5f, -1.2871e-5f, -.0031886f,
-    -6.3395e-6f, 4570.f, 4580.f, 7.7677e-6f, .035973f, -.0017804f,
-    3.5792e-6f, -.004378f, 4.7097e-6f, 4580.f, 4590.f, 2.1446e-4f, .52918f,
-    -.0026414f, 1.9171e-8f, -.0051868f, 3.1486e-6f, 4590.f, 4600.f,
-    4.9732e-4f, .19678f, -.0015023f, -6.4944e-6f, -.0045248f, -6.0552e-7f,
-    4600.f, 4610.f, 5.7844e-4f, .21566f, .0036076f, -2.5498e-5f, 6.874e-4f,
-    -2.1166e-5f, 4610.f, 4620.f, 1.836e-4f, .19472f, .010909f, -4.5759e-5f,
-    .0094535f, -5.3705e-5f, 4620.f, 4630.f, 2.1722e-5f, .066168f, .010212f,
-    2.4083e-5f, .016411f, -6.7231e-5f, 4630.f, 4640.f, 1.5836e-5f,
-    .0025231f, -.0037387f, 1.6847e-6f, -.0066855f, 7.7758e-6f, 4640.f,
-    4650.f, 2.8194e-5f, .055835f, .011719f, 7.8341e-5f, .028162f,
-    -6.5915e-5f, 4650.f, 4660.f, 2.9246e-5f, .15846f, .033601f, -1.2318e-4f,
-    .031988f, -1.4227e-4f, 4660.f, 4670.f, 6.866e-5f, .23768f, .030956f,
-    -1.3481e-4f, .028087f, -1.3066e-4f, 4670.f, 4680.f, 2.5776e-5f, .14238f,
-    .026879f, -1.1219e-4f, .025142f, -1.1785e-4f, 4680.f, 4690.f,
-    6.7605e-5f, .28782f, .028103f, -9.7067e-5f, .028478f, -1.1197e-4f,
-    4690.f, 4700.f, 9.4449e-5f, .58934f, .03528f, -9.4266e-5f, .037047f,
-    -1.3314e-4f, 4700.f, 4710.f, 2.1985e-4f, .94207f, .026856f, 1.5457e-5f,
-    .034398f, -7.9603e-5f, 4710.f, 4720.f, 5.9268e-4f, .92654f, .019629f,
-    7.9413e-5f, .02922f, -3.244e-5f, 4720.f, 4730.f, .001207f, .99725f,
-    .019414f, 1.0014e-4f, .026778f, -2.2067e-5f, 4730.f, 4740.f, .0022806f,
-    1.2176f, .028561f, -2.1574e-5f, .030485f, -7.5567e-5f, 4740.f, 4750.f,
-    .0043327f, 1.3486f, .028595f, -6.6405e-5f, .027851f, -7.4726e-5f,
-    4750.f, 4760.f, .0077428f, 1.4486f, .030758f, -1.1612e-4f, .029991f,
-    -1.2747e-4f, 4760.f, 4770.f, .025636f, 1.0146f, .025412f, -1.0692e-4f,
-    .02508f, -1.0479e-4f, 4770.f, 4780.f, .071004f, .80049f, .019034f,
-    -8.2075e-5f, .019591f, -8.1415e-5f, 4780.f, 4790.f, .12168f, .79844f,
-    .014488f, -6.4424e-5f, .0152f, -5.8903e-5f, 4790.f, 4800.f, .076746f,
-    1.2201f, .015267f, -5.7662e-5f, .014334f, -5.5273e-5f, 4800.f, 4810.f,
-    .25656f, .72698f, .012794f, -6.0697e-5f, .011343f, -5.448e-5f, 4810.f,
-    4820.f, .71618f, .47943f, .0075299f, -3.4485e-5f, .0086269f,
-    -4.1288e-5f, 4820.f, 4830.f, 1.9439f, .28552f, 6.0337e-4f, -1.0585e-5f,
-    .0017705f, -3.3465e-6f, 4830.f, 4840.f, 2.2409f, .24124f, -.0032243f,
-    7.7209e-7f, -.0036357f, 1.7134e-5f, 4840.f, 4850.f, 1.023f, .23661f,
-    -.0044285f, 5.6593e-6f, -.0054571f, 1.8603e-5f, 4850.f, 4860.f, 2.9838f,
-    .24972f, -.0026005f, -2.2445e-6f, -.0048507f, 6.708e-6f, 4860.f, 4870.f,
-    1.7331f, .24569f, .002513f, -2.0912e-5f, 9.7879e-5f, -1.4658e-5f,
-    4870.f, 4880.f, .23009f, .24263f, .012134f, -5.5883e-5f, .011873f,
-    -4.6579e-5f, 4880.f, 4890.f, .0073766f, .50576f, .021012f, 1.3113e-5f,
-    .033128f, -7.4753e-5f, 4890.f, 4900.f, .0053301f, 1.1415f, .02315f,
-    8.1743e-5f, .032613f, -4.9011e-5f, 4900.f, 4910.f, .019881f, 1.1163f,
-    .030658f, -8.9121e-5f, .031493f, -1.049e-4f, 4910.f, 4920.f, .13274f,
-    .8018f, .023959f, -9.6864e-5f, .026465f, -1.057e-4f, 4920.f, 4930.f,
-    .54198f, .58029f, .016095f, -6.7361e-5f, .019209f, -7.4544e-5f, 4930.f,
-    4940.f, 2.3931f, .43634f, .0083244f, -3.8869e-5f, .01091f, -4.0486e-5f,
-    4940.f, 4950.f, 6.364f, .38463f, .0024225f, -1.7014e-5f, .0051156f,
-    -1.3677e-5f, 4950.f, 4960.f, 11.174f, .37051f, -.0020924f, -1.8861e-6f,
-    1.9797e-4f, 8.4038e-6f, 4960.f, 4970.f, 4.7425f, .4397f, -.0023967f,
-    1.1771e-5f, .0015888f, 1.1027e-5f, 4970.f, 4980.f, 13.215f, .42301f,
+				     0.f, 0.f, 0.f, 0.f, 4320.f, 4330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4330.f,
+				     4340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4340.f, 4350.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4350.f, 4360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4360.f, 4370.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4370.f, 4380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4380.f,
+				     4390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4390.f, 4400.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4400.f, 4410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4410.f, 4420.f,
+				     2.629e-5f,
+				     .099522f, -.0026652f, -2.6042e-6f, -.0055447f, 3.2186e-6f, 4420.f,
+				     4430.f, 8.0883e-5f, .18978f, 5.7466e-4f, -1.4607e-5f, -.0025665f,
+				     -8.7838e-6f, 4430.f, 4440.f, 5.526e-5f, .18005f, .0065537f, -3.7323e-5f,
+				     .0036814f, -3.3174e-5f, 4440.f, 4450.f, 8.255e-6f, .05991f, .012867f,
+				     -6.4515e-5f, .0097575f, -5.8512e-5f, 4450.f, 4460.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 4460.f, 4470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4470.f, 4480.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 4480.f, 4490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     4490.f,
+				     4500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4500.f, 4510.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4510.f, 4520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4520.f, 4530.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4530.f, 4540.f, 5.6586e-6f, .058006f, .021852f,
+				     -1.003e-4f, .018901f, -9.4764e-5f, 4540.f, 4550.f, 6.0995e-5f, .17176f,
+				     .013472f, -6.3857e-5f, .010919f, -6.1333e-5f, 4550.f, 4560.f,
+				     1.6173e-4f, .1827f, .0055264f, -3.3401e-5f, .0025266f, -2.8677e-5f,
+				     4560.f, 4570.f, 1.342e-4f, .18669f, 8.6662e-5f, -1.2871e-5f, -.0031886f,
+				     -6.3395e-6f, 4570.f, 4580.f, 7.7677e-6f, .035973f, -.0017804f,
+				     3.5792e-6f, -.004378f, 4.7097e-6f, 4580.f, 4590.f, 2.1446e-4f, .52918f,
+				     -.0026414f, 1.9171e-8f, -.0051868f, 3.1486e-6f, 4590.f, 4600.f,
+				     4.9732e-4f, .19678f, -.0015023f, -6.4944e-6f, -.0045248f, -6.0552e-7f,
+				     4600.f, 4610.f, 5.7844e-4f, .21566f, .0036076f, -2.5498e-5f, 6.874e-4f,
+				     -2.1166e-5f, 4610.f, 4620.f, 1.836e-4f, .19472f, .010909f, -4.5759e-5f,
+				     .0094535f, -5.3705e-5f, 4620.f, 4630.f, 2.1722e-5f, .066168f, .010212f,
+				     2.4083e-5f, .016411f, -6.7231e-5f, 4630.f, 4640.f, 1.5836e-5f,
+				     .0025231f, -.0037387f, 1.6847e-6f, -.0066855f, 7.7758e-6f, 4640.f,
+				     4650.f, 2.8194e-5f, .055835f, .011719f, 7.8341e-5f, .028162f,
+				     -6.5915e-5f, 4650.f, 4660.f, 2.9246e-5f, .15846f, .033601f, -1.2318e-4f,
+				     .031988f, -1.4227e-4f, 4660.f, 4670.f, 6.866e-5f, .23768f, .030956f,
+				     -1.3481e-4f, .028087f, -1.3066e-4f, 4670.f, 4680.f, 2.5776e-5f, .14238f,
+				     .026879f, -1.1219e-4f, .025142f, -1.1785e-4f, 4680.f, 4690.f,
+				     6.7605e-5f, .28782f, .028103f, -9.7067e-5f, .028478f, -1.1197e-4f,
+				     4690.f, 4700.f, 9.4449e-5f, .58934f, .03528f, -9.4266e-5f, .037047f,
+				     -1.3314e-4f, 4700.f, 4710.f, 2.1985e-4f, .94207f, .026856f, 1.5457e-5f,
+				     .034398f, -7.9603e-5f, 4710.f, 4720.f, 5.9268e-4f, .92654f, .019629f,
+				     7.9413e-5f, .02922f, -3.244e-5f, 4720.f, 4730.f, .001207f, .99725f,
+				     .019414f, 1.0014e-4f, .026778f, -2.2067e-5f, 4730.f, 4740.f, .0022806f,
+				     1.2176f, .028561f, -2.1574e-5f, .030485f, -7.5567e-5f, 4740.f, 4750.f,
+				     .0043327f, 1.3486f, .028595f, -6.6405e-5f, .027851f, -7.4726e-5f,
+				     4750.f, 4760.f, .0077428f, 1.4486f, .030758f, -1.1612e-4f, .029991f,
+				     -1.2747e-4f, 4760.f, 4770.f, .025636f, 1.0146f, .025412f, -1.0692e-4f,
+				     .02508f, -1.0479e-4f, 4770.f, 4780.f, .071004f, .80049f, .019034f,
+				     -8.2075e-5f, .019591f, -8.1415e-5f, 4780.f, 4790.f, .12168f, .79844f,
+				     .014488f, -6.4424e-5f, .0152f, -5.8903e-5f, 4790.f, 4800.f, .076746f,
+				     1.2201f, .015267f, -5.7662e-5f, .014334f, -5.5273e-5f, 4800.f, 4810.f,
+				     .25656f, .72698f, .012794f, -6.0697e-5f, .011343f, -5.448e-5f, 4810.f,
+				     4820.f, .71618f, .47943f, .0075299f, -3.4485e-5f, .0086269f,
+				     -4.1288e-5f, 4820.f, 4830.f, 1.9439f, .28552f, 6.0337e-4f, -1.0585e-5f,
+				     .0017705f, -3.3465e-6f, 4830.f, 4840.f, 2.2409f, .24124f, -.0032243f,
+				     7.7209e-7f, -.0036357f, 1.7134e-5f, 4840.f, 4850.f, 1.023f, .23661f,
+				     -.0044285f, 5.6593e-6f, -.0054571f, 1.8603e-5f, 4850.f, 4860.f, 2.9838f,
+				     .24972f, -.0026005f, -2.2445e-6f, -.0048507f, 6.708e-6f, 4860.f, 4870.f,
+				     1.7331f, .24569f, .002513f, -2.0912e-5f, 9.7879e-5f, -1.4658e-5f,
+				     4870.f, 4880.f, .23009f, .24263f, .012134f, -5.5883e-5f, .011873f,
+				     -4.6579e-5f, 4880.f, 4890.f, .0073766f, .50576f, .021012f, 1.3113e-5f,
+				     .033128f, -7.4753e-5f, 4890.f, 4900.f, .0053301f, 1.1415f, .02315f,
+				     8.1743e-5f, .032613f, -4.9011e-5f, 4900.f, 4910.f, .019881f, 1.1163f,
+				     .030658f, -8.9121e-5f, .031493f, -1.049e-4f, 4910.f, 4920.f, .13274f,
+				     .8018f, .023959f, -9.6864e-5f, .026465f, -1.057e-4f, 4920.f, 4930.f,
+				     .54198f, .58029f, .016095f, -6.7361e-5f, .019209f, -7.4544e-5f, 4930.f,
+				     4940.f, 2.3931f, .43634f, .0083244f, -3.8869e-5f, .01091f, -4.0486e-5f,
+				     4940.f, 4950.f, 6.364f, .38463f, .0024225f, -1.7014e-5f, .0051156f,
+				     -1.3677e-5f, 4950.f, 4960.f, 11.174f, .37051f, -.0020924f, -1.8861e-6f,
+				     1.9797e-4f, 8.4038e-6f, 4960.f, 4970.f, 4.7425f, .4397f, -.0023967f,
+				     1.1771e-5f, .0015888f, 1.1027e-5f, 4970.f, 4980.f, 13.215f, .42301f,
-    -.002886f, 4.5346e-6f, -.0018435f, 1.2941e-5f, 4980.f, 4990.f, 10.682f,
-    .28898f, 9.1279e-4f, -1.3741e-5f, 2.9048e-4f, -3.723e-6f, 4990.f, 5e3f,
-    1.9873f, .27401f, .0096347f, -4.5675e-5f, .0089294f, -4.3606e-5f, 5e3f,
-    5010.f, .025245f, .25842f, .027802f, -1.1266e-4f, .028517f, -1.1312e-4f,
-    5010.f, 5020.f, .0010773f, .39566f, .019467f, -9.0504e-6f, .021521f,
-    -4.662e-5f, 5020.f, 5030.f, .0026445f, .46517f, .022864f, -5.1981e-6f,
-    .021923f, -4.8242e-5f, 5030.f, 5040.f, .0089353f, .34218f, .025304f,
-    -8.7147e-5f, .020721f, -6.3342e-5f, 5040.f, 5050.f, .066176f, .21908f,
-    .017982f, -8.0841e-5f, .017736f, -7.414e-5f, 5050.f, 5060.f
+				     -.002886f, 4.5346e-6f, -.0018435f, 1.2941e-5f, 4980.f, 4990.f, 10.682f,
+				     .28898f, 9.1279e-4f, -1.3741e-5f, 2.9048e-4f, -3.723e-6f, 4990.f, 5e3f,
+				     1.9873f, .27401f, .0096347f, -4.5675e-5f, .0089294f, -4.3606e-5f, 5e3f,
+				     5010.f, .025245f, .25842f, .027802f, -1.1266e-4f, .028517f, -1.1312e-4f,
+				     5010.f, 5020.f, .0010773f, .39566f, .019467f, -9.0504e-6f, .021521f,
+				     -4.662e-5f, 5020.f, 5030.f, .0026445f, .46517f, .022864f, -5.1981e-6f,
+				     .021923f, -4.8242e-5f, 5030.f, 5040.f, .0089353f, .34218f, .025304f,
+				     -8.7147e-5f, .020721f, -6.3342e-5f, 5040.f, 5050.f, .066176f, .21908f,
+				     .017982f, -8.0841e-5f, .017736f, -7.414e-5f, 5050.f, 5060.f
-	/* carbon dioxide (2500 - 5050 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* carbon dioxide (2500 - 5050 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* dica1 */
@@ -2877,297 +2877,297 @@
-  static const float acr[2048] = { .062007f, 2.4365f,
-    -5.9503e-4f, -8.1198e-6f, -.0039418f, -2.4624e-6f, 2500.f, 2510.f,
-    .023839f, 2.3534f, .0037377f, -6.15e-6f, .0015592f, -1.2727e-5f, 2510.f,
-    2520.f, .0090127f, 1.2172f, -.0014733f, -4.7053e-6f, -.0042092f,
-    -1.5909e-6f, 2520.f, 2530.f, .0058863f, 1.1f, 3.3397e-4f, -1.3388e-5f,
-    -.0024956f, -9.7955e-6f, 2530.f, 2540.f, .0021326f, .57054f, .0025704f,
-    -2.3597e-5f, -2.6961e-4f, -1.9566e-5f, 2540.f, 2550.f, 2.6378e-4f,
-    .095762f, .0021816f, -2.4506e-5f, -8.9441e-4f, -1.8362e-5f, 2550.f,
-    2560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2560.f, 2570.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2570.f, 2580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2580.f, 2590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2590.f, 2600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2600.f,
-    2610.f, 1.2538e-4f, .06037f, .017057f, -8.3526e-5f, .013989f,
-    -7.7656e-5f, 2610.f, 2620.f, .0033172f, 1.2606f, .015787f, -6.9353e-5f,
-    .013123f, -6.8937e-5f, 2620.f, 2630.f, .008713f, 2.2667f, .014103f,
-    -5.7967e-5f, .011482f, -5.9919e-5f, 2630.f, 2640.f, .0172f, 3.144f,
-    .011768f, -4.8179e-5f, .0088246f, -4.9702e-5f, 2640.f, 2650.f, .034158f,
-    3.5816f, .0099884f, -4.184e-5f, .0074214f, -4.4219e-5f, 2650.f, 2660.f,
-    .058424f, 3.8732f, .0072077f, -3.3325e-5f, .004529f, -3.3709e-5f,
-    2660.f, 2670.f, .091154f, 4.3262f, .0058558f, -2.8338e-5f, .0036931f,
-    -2.8993e-5f, 2670.f, 2680.f, .14108f, 4.4142f, .0030363f, -1.8897e-5f,
-    8.3735e-4f, -1.8016e-5f, 2680.f, 2690.f, .19337f, 5.4007f, .0022914f,
-    -1.3229e-5f, 5.9045e-4f, -1.4091e-5f, 2690.f, 2700.f, .22397f, 5.654f,
-    4.0913e-4f, -5.5214e-8f, -4.337e-4f, -1.0921e-6f, 2700.f, 2710.f,
-    .25652f, 5.9001f, .0016172f, 5.8755e-6f, .0013629f, -1.6939e-6f, 2710.f,
-    2720.f, .26204f, 6.3198f, .0046886f, 1.25e-5f, .0044002f, -9.3401e-6f,
-    2720.f, 2730.f, 1.1785f, 7.1393f, .0037596f, -7.5943e-6f, .0028497f,
-    -1.6442e-5f, 2730.f, 2740.f, 1.2094f, 5.2539f, .0056671f, -2.7298e-5f,
-    .0028397f, -2.2464e-5f, 2740.f, 2750.f, 2.6976f, 4.6649f, .0025634f,
-    -2.0935e-5f, 3.1356e-4f, -1.7037e-5f, 2750.f, 2760.f, 5.2789f, 4.5914f,
-    -7.3997e-4f, -9.2529e-6f, -.0021265f, -8.3858e-6f, 2760.f, 2770.f,
-    5.611f, 6.1724f, -.0032253f, 2.5797e-6f, -.0028278f, 8.7898e-8f, 2770.f,
-    2780.f, 4.928f, 9.4156f, -.0020334f, 1.9294e-6f, -.0030249f, -1.069e-6f,
-    2780.f, 2790.f, 9.8978f, 7.256f, -.0024986f, -1.5096e-6f, -.0036608f,
-    -5.8064e-7f, 2790.f, 2800.f, 3.3206f, 9.3181f, .0047633f, -2.5074e-5f,
-    .0053638f, -3.2113e-5f, 2800.f, 2810.f, .02474f, 2.6388f, .0070889f,
-    -3.2967e-5f, .0046677f, -3.4491e-5f, 2810.f, 2820.f, .034545f, 2.9892f,
-    .0049198f, -2.638e-5f, .0026057f, -2.5038e-5f, 2820.f, 2830.f, .04698f,
-    4.234f, .0050308f, -1.5985e-5f, .0030829f, -2.1189e-5f, 2830.f, 2840.f,
-    .07243f, 5.0065f, .0059166f, -2.0703e-5f, .0028776f, -2.3414e-5f,
-    2840.f, 2850.f, .11034f, 4.0562f, .0040989f, -2.3368e-5f, 8.42e-4f,
-    -1.8356e-5f, 2850.f, 2860.f, .12579f, 3.6106f, .0011211f, -1.2332e-5f,
-    -8.604e-4f, -1.0593e-5f, 2860.f, 2870.f, .095405f, 4.2611f, .0010479f,
-    -5.3844e-6f, -6.5774e-4f, -8.3477e-6f, 2870.f, 2880.f, .092029f,
-    4.3877f, .0013349f, -8.8914e-6f, -8.978e-4f, -9.601e-6f, 2880.f, 2890.f,
-    .085314f, 2.2957f, -.0010376f, -3.9555e-7f, -.0023459f, -3.1759e-6f,
-    2890.f, 2900.f, .1913f, 2.1329f, 9.3145e-5f, -1.0935e-5f, -.0023306f,
-    -7.0411e-6f, 2900.f, 2910.f, .14327f, 3.0363f, .0049245f, -1.9969e-5f,
-    .0019913f, -1.9177e-5f, 2910.f, 2920.f, .062081f, 2.9232f, .0028349f,
-    4.5083e-6f, .0026887f, -6.9673e-6f, 2920.f, 2930.f, .054536f, 2.5833f,
-    .003389f, 5.9711e-6f, .0039633f, 1.706e-6f, 2930.f, 2940.f, .067558f,
-    4.1622f, .012948f, 1.8636e-5f, .013881f, -2.7246e-5f, 2940.f, 2950.f,
-    .10694f, 4.2481f, .019447f, -4.2948e-5f, .016908f, -6.0648e-5f, 2950.f,
-    2960.f, .23821f, 4.1323f, .020561f, -8.5072e-5f, .016888f, -7.7856e-5f,
-    2960.f, 2970.f, .64222f, 3.762f, .01732f, -8.1718e-5f, .014625f,
-    -7.652e-5f, 2970.f, 2980.f, 1.63f, 3.7899f, .013216f, -6.5623e-5f,
-    .011621f, -6.3803e-5f, 2980.f, 2990.f, 3.8611f, 4.0234f, .0091789f,
-    -4.9247e-5f, .0082148f, -4.8334e-5f, 2990.f, 3e3f, 8.4985f, 4.366f,
-    .0053518f, -3.3739e-5f, .0046322f, -3.3282e-5f, 3e3f, 3010.f, 16.437f,
-    4.6428f, .0018372f, -1.9254e-5f, .0014965f, -1.9554e-5f, 3010.f, 3020.f,
-    26.227f, 5.2685f, -.0010368f, -6.92e-6f, -.0010546f, -7.8474e-6f,
-    3020.f, 3030.f, 29.674f, 6.9683f, -.0027894f, 1.5655e-6f, -.0027673f,
-    3.4286e-7f, 3030.f, 3040.f, 24.306f, 9.5097f, -.002074f, 6.2838e-6f,
-    -.0020776f, 2.179e-6f, 3040.f, 3050.f, 63.521f, 9.8031f, -.0012075f,
+    static const float acr[2048] = { .062007f, 2.4365f,
+				     -5.9503e-4f, -8.1198e-6f, -.0039418f, -2.4624e-6f, 2500.f, 2510.f,
+				     .023839f, 2.3534f, .0037377f, -6.15e-6f, .0015592f, -1.2727e-5f, 2510.f,
+				     2520.f, .0090127f, 1.2172f, -.0014733f, -4.7053e-6f, -.0042092f,
+				     -1.5909e-6f, 2520.f, 2530.f, .0058863f, 1.1f, 3.3397e-4f, -1.3388e-5f,
+				     -.0024956f, -9.7955e-6f, 2530.f, 2540.f, .0021326f, .57054f, .0025704f,
+				     -2.3597e-5f, -2.6961e-4f, -1.9566e-5f, 2540.f, 2550.f, 2.6378e-4f,
+				     .095762f, .0021816f, -2.4506e-5f, -8.9441e-4f, -1.8362e-5f, 2550.f,
+				     2560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2560.f, 2570.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2570.f, 2580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2580.f, 2590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2590.f, 2600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2600.f,
+				     2610.f, 1.2538e-4f, .06037f, .017057f, -8.3526e-5f, .013989f,
+				     -7.7656e-5f, 2610.f, 2620.f, .0033172f, 1.2606f, .015787f, -6.9353e-5f,
+				     .013123f, -6.8937e-5f, 2620.f, 2630.f, .008713f, 2.2667f, .014103f,
+				     -5.7967e-5f, .011482f, -5.9919e-5f, 2630.f, 2640.f, .0172f, 3.144f,
+				     .011768f, -4.8179e-5f, .0088246f, -4.9702e-5f, 2640.f, 2650.f, .034158f,
+				     3.5816f, .0099884f, -4.184e-5f, .0074214f, -4.4219e-5f, 2650.f, 2660.f,
+				     .058424f, 3.8732f, .0072077f, -3.3325e-5f, .004529f, -3.3709e-5f,
+				     2660.f, 2670.f, .091154f, 4.3262f, .0058558f, -2.8338e-5f, .0036931f,
+				     -2.8993e-5f, 2670.f, 2680.f, .14108f, 4.4142f, .0030363f, -1.8897e-5f,
+				     8.3735e-4f, -1.8016e-5f, 2680.f, 2690.f, .19337f, 5.4007f, .0022914f,
+				     -1.3229e-5f, 5.9045e-4f, -1.4091e-5f, 2690.f, 2700.f, .22397f, 5.654f,
+				     4.0913e-4f, -5.5214e-8f, -4.337e-4f, -1.0921e-6f, 2700.f, 2710.f,
+				     .25652f, 5.9001f, .0016172f, 5.8755e-6f, .0013629f, -1.6939e-6f, 2710.f,
+				     2720.f, .26204f, 6.3198f, .0046886f, 1.25e-5f, .0044002f, -9.3401e-6f,
+				     2720.f, 2730.f, 1.1785f, 7.1393f, .0037596f, -7.5943e-6f, .0028497f,
+				     -1.6442e-5f, 2730.f, 2740.f, 1.2094f, 5.2539f, .0056671f, -2.7298e-5f,
+				     .0028397f, -2.2464e-5f, 2740.f, 2750.f, 2.6976f, 4.6649f, .0025634f,
+				     -2.0935e-5f, 3.1356e-4f, -1.7037e-5f, 2750.f, 2760.f, 5.2789f, 4.5914f,
+				     -7.3997e-4f, -9.2529e-6f, -.0021265f, -8.3858e-6f, 2760.f, 2770.f,
+				     5.611f, 6.1724f, -.0032253f, 2.5797e-6f, -.0028278f, 8.7898e-8f, 2770.f,
+				     2780.f, 4.928f, 9.4156f, -.0020334f, 1.9294e-6f, -.0030249f, -1.069e-6f,
+				     2780.f, 2790.f, 9.8978f, 7.256f, -.0024986f, -1.5096e-6f, -.0036608f,
+				     -5.8064e-7f, 2790.f, 2800.f, 3.3206f, 9.3181f, .0047633f, -2.5074e-5f,
+				     .0053638f, -3.2113e-5f, 2800.f, 2810.f, .02474f, 2.6388f, .0070889f,
+				     -3.2967e-5f, .0046677f, -3.4491e-5f, 2810.f, 2820.f, .034545f, 2.9892f,
+				     .0049198f, -2.638e-5f, .0026057f, -2.5038e-5f, 2820.f, 2830.f, .04698f,
+				     4.234f, .0050308f, -1.5985e-5f, .0030829f, -2.1189e-5f, 2830.f, 2840.f,
+				     .07243f, 5.0065f, .0059166f, -2.0703e-5f, .0028776f, -2.3414e-5f,
+				     2840.f, 2850.f, .11034f, 4.0562f, .0040989f, -2.3368e-5f, 8.42e-4f,
+				     -1.8356e-5f, 2850.f, 2860.f, .12579f, 3.6106f, .0011211f, -1.2332e-5f,
+				     -8.604e-4f, -1.0593e-5f, 2860.f, 2870.f, .095405f, 4.2611f, .0010479f,
+				     -5.3844e-6f, -6.5774e-4f, -8.3477e-6f, 2870.f, 2880.f, .092029f,
+				     4.3877f, .0013349f, -8.8914e-6f, -8.978e-4f, -9.601e-6f, 2880.f, 2890.f,
+				     .085314f, 2.2957f, -.0010376f, -3.9555e-7f, -.0023459f, -3.1759e-6f,
+				     2890.f, 2900.f, .1913f, 2.1329f, 9.3145e-5f, -1.0935e-5f, -.0023306f,
+				     -7.0411e-6f, 2900.f, 2910.f, .14327f, 3.0363f, .0049245f, -1.9969e-5f,
+				     .0019913f, -1.9177e-5f, 2910.f, 2920.f, .062081f, 2.9232f, .0028349f,
+				     4.5083e-6f, .0026887f, -6.9673e-6f, 2920.f, 2930.f, .054536f, 2.5833f,
+				     .003389f, 5.9711e-6f, .0039633f, 1.706e-6f, 2930.f, 2940.f, .067558f,
+				     4.1622f, .012948f, 1.8636e-5f, .013881f, -2.7246e-5f, 2940.f, 2950.f,
+				     .10694f, 4.2481f, .019447f, -4.2948e-5f, .016908f, -6.0648e-5f, 2950.f,
+				     2960.f, .23821f, 4.1323f, .020561f, -8.5072e-5f, .016888f, -7.7856e-5f,
+				     2960.f, 2970.f, .64222f, 3.762f, .01732f, -8.1718e-5f, .014625f,
+				     -7.652e-5f, 2970.f, 2980.f, 1.63f, 3.7899f, .013216f, -6.5623e-5f,
+				     .011621f, -6.3803e-5f, 2980.f, 2990.f, 3.8611f, 4.0234f, .0091789f,
+				     -4.9247e-5f, .0082148f, -4.8334e-5f, 2990.f, 3e3f, 8.4985f, 4.366f,
+				     .0053518f, -3.3739e-5f, .0046322f, -3.3282e-5f, 3e3f, 3010.f, 16.437f,
+				     4.6428f, .0018372f, -1.9254e-5f, .0014965f, -1.9554e-5f, 3010.f, 3020.f,
+				     26.227f, 5.2685f, -.0010368f, -6.92e-6f, -.0010546f, -7.8474e-6f,
+				     3020.f, 3030.f, 29.674f, 6.9683f, -.0027894f, 1.5655e-6f, -.0027673f,
+				     3.4286e-7f, 3030.f, 3040.f, 24.306f, 9.5097f, -.002074f, 6.2838e-6f,
+				     -.0020776f, 2.179e-6f, 3040.f, 3050.f, 63.521f, 9.8031f, -.0012075f,
-    -2.994e-6f, -.0022793f, -5.3779e-6f, 3050.f, 3060.f, 1.1941f, 5.4609f,
-    .0015524f, -9.5161e-6f, -9.6618e-4f, -7.6711e-6f, 3060.f, 3070.f,
-    .92867f, 5.355f, -6.2368e-4f, -3.643e-6f, -.0029524f, -1.6001e-6f,
-    3070.f, 3080.f, .67841f, 5.2135f, 5.235e-4f, 6.0726e-6f, -3.7339e-4f,
-    -2.3662e-6f, 3080.f, 3090.f, 3.1429f, 5.2297f, .0017001f, -8.0369e-6f,
-    -2.527e-4f, -9.2399e-6f, 3090.f, 3100.f, .55537f, 4.0641f, -8.4176e-4f,
-    3.74e-7f, -.0020788f, -8.3774e-7f, 3100.f, 3110.f, .62683f, 4.1264f,
-    -6.4674e-4f, -8.4882e-7f, -5.9275e-4f, -1.4998e-6f, 3110.f, 3120.f,
-    .75072f, 5.6505f, .0024151f, -8.8833e-6f, .0024005f, -1.4915e-5f,
-    3120.f, 3130.f, .63692f, 5.2929f, .0052702f, -2.0599e-5f, .0049282f,
-    -2.9353e-5f, 3130.f, 3140.f, .6931f, 5.7878f, .0069797f, -3.6776e-5f,
-    .0052917f, -3.67e-5f, 3140.f, 3150.f, 1.0593f, 5.0675f, .0040985f,
-    -2.5996e-5f, .0032401f, -2.8071e-5f, 3150.f, 3160.f, 1.7493f, 4.5943f,
-    -1.8037e-4f, -8.6286e-6f, 2.5807e-4f, -1.0009e-5f, 3160.f, 3170.f,
-    2.0855f, 5.9045f, -.0022784f, 1.4682e-6f, -.0024776f, -2.9964e-6f,
-    3170.f, 3180.f, 1.3759f, 5.4986f, -.0034094f, 2.6712e-6f, -.0053592f,
-    5.6885e-6f, 3180.f, 3190.f, 3.923f, 8.3024f, -.0018506f, -3.5742e-7f,
-    -.0024786f, -1.1732e-6f, 3190.f, 3200.f, 1.1841f, 5.1604f, .0039237f,
-    -2.2108e-5f, .0038274f, -2.7628e-5f, 3200.f, 3210.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 3210.f, 3220.f, 5.5594e-4f, .13449f, 1.458e-4f, -1.5828e-5f,
-    -.0029023f, -1.0057e-5f, 3220.f, 3230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    3230.f, 3240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3240.f, 3250.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3250.f, 3260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3260.f,
-      3270.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3270.f, 3280.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3280.f, 3290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3290.f, 3300.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3300.f, 3310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3310.f,
-      3320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3320.f, 3330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3330.f, 3340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3340.f, 3350.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3350.f, 3360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3360.f,
-      3370.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3370.f, 3380.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3380.f, 3390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3390.f, 3400.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3400.f, 3410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3410.f,
-      3420.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3420.f, 3430.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3430.f, 3440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3440.f, 3450.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3450.f, 3460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3460.f,
-      3470.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3470.f, 3480.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3480.f, 3490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3490.f, 3500.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3500.f, 3510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3510.f,
-      3520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3520.f, 3530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3530.f, 3540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3540.f, 3550.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3550.f, 3560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3560.f,
-      3570.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3570.f, 3580.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3580.f, 3590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3590.f, 3600.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3600.f, 3610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3610.f,
-      3620.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3620.f, 3630.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3630.f, 3640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3640.f, 3650.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3650.f, 3660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3660.f,
-      3670.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3670.f, 3680.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3680.f, 3690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3690.f, 3700.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3700.f, 3710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3710.f,
-      3720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3720.f, 3730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3730.f, 3740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3740.f, 3750.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3750.f, 3760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3760.f,
-      3770.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3770.f, 3780.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3780.f, 3790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3790.f, 3800.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3800.f, 3810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3810.f,
-      3820.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3820.f, 3830.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3830.f, 3840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3840.f, 3850.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3850.f, 3860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3860.f,
-      3870.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3870.f, 3880.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-      0.f,
-      3920.f,
-      0.f,
-    3930.f, 3940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3940.f, 3950.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3950.f, 3960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3960.f,
-      3970.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3970.f, 3980.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3980.f, 3990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3990.f, 4e3f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 4e3f, 4010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4010.f, 4020.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4020.f, 4030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4030.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-      0.f,
-    0.f, 4400.f, 4410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4410.f, 4420.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4420.f, 4430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4430.f,
-    4440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4440.f, 4450.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4450.f, 4460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4460.f, 4470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4470.f, 4480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4480.f,
-    4490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4490.f, 4500.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4500.f, 4510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4510.f, 4520.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4520.f, 4530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4530.f,
-    4540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4540.f, 4550.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4550.f, 4560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4560.f, 4570.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4570.f, 4580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4580.f,
-    4590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4590.f, 4600.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4600.f, 4610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4610.f, 4620.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4620.f, 4630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4630.f,
-    4640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4640.f, 4650.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4650.f, 4660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4660.f, 4670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4670.f, 4680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4680.f,
-    4690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4690.f, 4700.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4700.f, 4710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4710.f, 4720.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4720.f, 4730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4730.f,
-    4740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4740.f, 4750.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4750.f, 4760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4760.f, 4770.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4770.f, 4780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4780.f,
-    4790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4790.f, 4800.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4800.f, 4810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4810.f, 4820.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4820.f, 4830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4830.f,
-    4840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4840.f, 4850.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4850.f, 4860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4860.f, 4870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4870.f, 4880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4880.f,
-    4890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4890.f, 4900.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4900.f, 4910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4910.f, 4920.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4920.f, 4930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4930.f,
-    4940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4940.f, 4950.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4950.f, 4960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4960.f, 4970.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4970.f, 4980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4980.f,
-    4990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4990.f, 5e3f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5e3f, 5010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5010.f, 5020.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 5020.f, 5030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5030.f,
-      5040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5040.f, 5050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    5050.f, 5060.f
+				     -2.994e-6f, -.0022793f, -5.3779e-6f, 3050.f, 3060.f, 1.1941f, 5.4609f,
+				     .0015524f, -9.5161e-6f, -9.6618e-4f, -7.6711e-6f, 3060.f, 3070.f,
+				     .92867f, 5.355f, -6.2368e-4f, -3.643e-6f, -.0029524f, -1.6001e-6f,
+				     3070.f, 3080.f, .67841f, 5.2135f, 5.235e-4f, 6.0726e-6f, -3.7339e-4f,
+				     -2.3662e-6f, 3080.f, 3090.f, 3.1429f, 5.2297f, .0017001f, -8.0369e-6f,
+				     -2.527e-4f, -9.2399e-6f, 3090.f, 3100.f, .55537f, 4.0641f, -8.4176e-4f,
+				     3.74e-7f, -.0020788f, -8.3774e-7f, 3100.f, 3110.f, .62683f, 4.1264f,
+				     -6.4674e-4f, -8.4882e-7f, -5.9275e-4f, -1.4998e-6f, 3110.f, 3120.f,
+				     .75072f, 5.6505f, .0024151f, -8.8833e-6f, .0024005f, -1.4915e-5f,
+				     3120.f, 3130.f, .63692f, 5.2929f, .0052702f, -2.0599e-5f, .0049282f,
+				     -2.9353e-5f, 3130.f, 3140.f, .6931f, 5.7878f, .0069797f, -3.6776e-5f,
+				     .0052917f, -3.67e-5f, 3140.f, 3150.f, 1.0593f, 5.0675f, .0040985f,
+				     -2.5996e-5f, .0032401f, -2.8071e-5f, 3150.f, 3160.f, 1.7493f, 4.5943f,
+				     -1.8037e-4f, -8.6286e-6f, 2.5807e-4f, -1.0009e-5f, 3160.f, 3170.f,
+				     2.0855f, 5.9045f, -.0022784f, 1.4682e-6f, -.0024776f, -2.9964e-6f,
+				     3170.f, 3180.f, 1.3759f, 5.4986f, -.0034094f, 2.6712e-6f, -.0053592f,
+				     5.6885e-6f, 3180.f, 3190.f, 3.923f, 8.3024f, -.0018506f, -3.5742e-7f,
+				     -.0024786f, -1.1732e-6f, 3190.f, 3200.f, 1.1841f, 5.1604f, .0039237f,
+				     -2.2108e-5f, .0038274f, -2.7628e-5f, 3200.f, 3210.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 3210.f, 3220.f, 5.5594e-4f, .13449f, 1.458e-4f, -1.5828e-5f,
+				     -.0029023f, -1.0057e-5f, 3220.f, 3230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     3230.f, 3240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3240.f, 3250.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3250.f, 3260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3260.f,
+				     3270.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3270.f, 3280.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3280.f, 3290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3290.f, 3300.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3300.f, 3310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3310.f,
+				     3320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3320.f, 3330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3330.f, 3340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3340.f, 3350.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3350.f, 3360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3360.f,
+				     3370.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3370.f, 3380.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3380.f, 3390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3390.f, 3400.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3400.f, 3410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3410.f,
+				     3420.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3420.f, 3430.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3430.f, 3440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3440.f, 3450.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3450.f, 3460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3460.f,
+				     3470.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3470.f, 3480.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3480.f, 3490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3490.f, 3500.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3500.f, 3510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3510.f,
+				     3520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3520.f, 3530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3530.f, 3540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3540.f, 3550.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3550.f, 3560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3560.f,
+				     3570.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3570.f, 3580.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3580.f, 3590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3590.f, 3600.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3600.f, 3610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3610.f,
+				     3620.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3620.f, 3630.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3630.f, 3640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3640.f, 3650.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3650.f, 3660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3660.f,
+				     3670.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3670.f, 3680.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3680.f, 3690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3690.f, 3700.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3700.f, 3710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3710.f,
+				     3720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3720.f, 3730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3730.f, 3740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3740.f, 3750.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3750.f, 3760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3760.f,
+				     3770.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3770.f, 3780.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3780.f, 3790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3790.f, 3800.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3800.f, 3810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3810.f,
+				     3820.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3820.f, 3830.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3830.f, 3840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3840.f, 3850.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3850.f, 3860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3860.f,
+				     3870.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3870.f, 3880.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f,
+				     3920.f,
+				     0.f,
+				     3930.f, 3940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3940.f, 3950.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3950.f, 3960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3960.f,
+				     3970.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3970.f, 3980.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3980.f, 3990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3990.f, 4e3f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 4e3f, 4010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4010.f, 4020.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4020.f, 4030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4030.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f,
+				     0.f, 4400.f, 4410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4410.f, 4420.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4420.f, 4430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4430.f,
+				     4440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4440.f, 4450.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4450.f, 4460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4460.f, 4470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4470.f, 4480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4480.f,
+				     4490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4490.f, 4500.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4500.f, 4510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4510.f, 4520.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4520.f, 4530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4530.f,
+				     4540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4540.f, 4550.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4550.f, 4560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4560.f, 4570.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4570.f, 4580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4580.f,
+				     4590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4590.f, 4600.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4600.f, 4610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4610.f, 4620.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4620.f, 4630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4630.f,
+				     4640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4640.f, 4650.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4650.f, 4660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4660.f, 4670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4670.f, 4680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4680.f,
+				     4690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4690.f, 4700.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4700.f, 4710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4710.f, 4720.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4720.f, 4730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4730.f,
+				     4740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4740.f, 4750.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4750.f, 4760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4760.f, 4770.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4770.f, 4780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4780.f,
+				     4790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4790.f, 4800.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4800.f, 4810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4810.f, 4820.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4820.f, 4830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4830.f,
+				     4840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4840.f, 4850.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4850.f, 4860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4860.f, 4870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4870.f, 4880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4880.f,
+				     4890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4890.f, 4900.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4900.f, 4910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4910.f, 4920.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4920.f, 4930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4930.f,
+				     4940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4940.f, 4950.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4950.f, 4960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4960.f, 4970.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4970.f, 4980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4980.f,
+				     4990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4990.f, 5e3f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5e3f, 5010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5010.f, 5020.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 5020.f, 5030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5030.f,
+				     5040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5040.f, 5050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     5050.f, 5060.f
-	/* ozone (2500 - 5040 cm-1) */
+    /* ozone (2500 - 5040 cm-1) */
 }	/* ozon1 */
@@ -3176,330 +3176,330 @@
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15360.f,
-    15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
-      15400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15440.f,
-    15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15360.f,
+				     15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
+				     15400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15440.f,
+				     15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
-      15480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15520.f,
-    15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
-      15560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15600.f,
-    15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
-      15640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15680.f,
-    15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15700.f, 15710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15710.f,
-      15720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15720.f, 15730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15730.f, 15740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15750.f, 15760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15760.f,
-    15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15780.f, 15790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15790.f,
-      15800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15800.f, 15810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15810.f, 15820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15820.f, 15830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15830.f, 15840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15840.f,
-    15850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15850.f, 15860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15860.f, 15870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15870.f,
-      15880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15880.f, 15890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15890.f, 15900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15900.f, 15910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15910.f, 15920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15920.f,
-    15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f, 15940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15950.f,
-      15960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f, 15990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.6e4f,
-    16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16030.f,
-      16040.f,
+				     15480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15520.f,
+				     15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
+				     15560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15600.f,
+				     15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
+				     15640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15680.f,
+				     15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15700.f, 15710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15710.f,
+				     15720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15720.f, 15730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15730.f, 15740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15750.f, 15760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15760.f,
+				     15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15780.f, 15790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15790.f,
+				     15800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15800.f, 15810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15810.f, 15820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15820.f, 15830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15830.f, 15840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15840.f,
+				     15850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15850.f, 15860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15860.f, 15870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15870.f,
+				     15880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15880.f, 15890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15890.f, 15900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15900.f, 15910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15910.f, 15920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15920.f,
+				     15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f, 15940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15950.f,
+				     15960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f, 15990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.6e4f,
+				     16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16030.f,
+				     16040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f, 16070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16080.f,
-    16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16110.f,
-      16120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f, 16150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16160.f,
-    16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16190.f,
-      16200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f, 16230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16240.f,
-    16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16270.f,
-      16280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f, 16310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16320.f,
-    16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16350.f,
-      16360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f, 16390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16400.f,
-    16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16430.f,
-      16440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f, 16470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16480.f,
-    16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16510.f,
-      16520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f, 16550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16560.f,
-    16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16590.f,
-      16600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f, 16630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16640.f,
-    16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16670.f,
-      16680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16700.f, 16710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16720.f,
-    16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16730.f, 16740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16750.f,
-      16760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f, 16770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16780.f, 16790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16800.f,
-    16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16810.f, 16820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16830.f,
-      16840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f, 16850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16860.f, 16870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16880.f,
-    16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16890.f, 16900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16910.f,
-      16920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f, 16930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16940.f, 16950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16960.f,
-    16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16970.f, 16980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16990.f, 1.7e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17020.f, 17030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17040.f,
-    17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17050.f, 17060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17070.f,
-      17080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f, 17090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17100.f, 17110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17120.f,
-    17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17130.f, 17140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17150.f,
-      17160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f, 17170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17180.f, 17190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17200.f,
-    17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17210.f, 17220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17230.f,
-      17240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f, 17250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17260.f, 17270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17280.f,
-    17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17290.f, 17300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17310.f,
-      17320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f, 17330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17340.f, 17350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17360.f,
-    17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17370.f, 17380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17390.f,
-      17400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f, 17410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17420.f, 17430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17440.f,
-    17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17450.f, 17460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17470.f,
-      17480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f, 17490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17500.f, 17510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17520.f,
-    17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17530.f, 17540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17550.f,
-      17560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f, 17570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17580.f, 17590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17600.f,
-    17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17610.f, 17620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17630.f,
-      17640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17680.f,
-    17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f,
-      17720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17760.f,
-    17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f, 16070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16080.f,
+				     16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16110.f,
+				     16120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f, 16150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16160.f,
+				     16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16190.f,
+				     16200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f, 16230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16240.f,
+				     16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16270.f,
+				     16280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f, 16310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16320.f,
+				     16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16350.f,
+				     16360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f, 16390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16400.f,
+				     16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16430.f,
+				     16440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f, 16470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16480.f,
+				     16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16510.f,
+				     16520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f, 16550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16560.f,
+				     16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16590.f,
+				     16600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f, 16630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16640.f,
+				     16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16670.f,
+				     16680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16700.f, 16710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16720.f,
+				     16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16730.f, 16740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16750.f,
+				     16760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f, 16770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16780.f, 16790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16800.f,
+				     16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16810.f, 16820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16830.f,
+				     16840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f, 16850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16860.f, 16870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16880.f,
+				     16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16890.f, 16900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16910.f,
+				     16920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f, 16930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16940.f, 16950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16960.f,
+				     16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16970.f, 16980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16990.f, 1.7e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17020.f, 17030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17040.f,
+				     17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17050.f, 17060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17070.f,
+				     17080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f, 17090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17100.f, 17110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17120.f,
+				     17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17130.f, 17140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17150.f,
+				     17160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f, 17170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17180.f, 17190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17200.f,
+				     17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17210.f, 17220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17230.f,
+				     17240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f, 17250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17260.f, 17270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17280.f,
+				     17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17290.f, 17300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17310.f,
+				     17320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f, 17330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17340.f, 17350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17360.f,
+				     17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17370.f, 17380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17390.f,
+				     17400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f, 17410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17420.f, 17430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17440.f,
+				     17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17450.f, 17460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17470.f,
+				     17480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f, 17490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17500.f, 17510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17520.f,
+				     17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17530.f, 17540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17550.f,
+				     17560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f, 17570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17580.f, 17590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17600.f,
+				     17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17610.f, 17620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17630.f,
+				     17640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17680.f,
+				     17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f,
+				     17720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17760.f,
+				     17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f,
-      17800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17840.f,
-    17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
+				     0.f,
+				     0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f,
+				     17800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17840.f,
+				     17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
-	/* nitrous oxide (15300 - 17870 cm-1) */
+    /* nitrous oxide (15300 - 17870 cm-1) */
 }	/* niox6 */
 void
@@ -3507,330 +3507,330 @@
-    0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12800.f,
-    12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
-      12840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12840.f, 12850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12850.f, 12860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12860.f, 12870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12880.f,
-    12890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12890.f, 12900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12900.f, 12910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12910.f,
-      12920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12920.f, 12930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12940.f, 12950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12960.f,
-    12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12970.f, 12980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12990.f, 1.3e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13020.f, 13030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13040.f,
-    13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13050.f, 13060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13070.f,
-      13080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f, 13090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13100.f, 13110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13120.f,
-    13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13130.f, 13140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13150.f,
-      13160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f, 13170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13180.f, 13190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13200.f,
-    13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13210.f, 13220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13230.f,
-      13240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f, 13250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13260.f, 13270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12800.f,
+				     12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
+				     12840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12840.f, 12850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12850.f, 12860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12860.f, 12870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12880.f,
+				     12890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12890.f, 12900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12900.f, 12910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12910.f,
+				     12920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12920.f, 12930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12940.f, 12950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12960.f,
+				     12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12970.f, 12980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12990.f, 1.3e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13020.f, 13030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13040.f,
+				     13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13050.f, 13060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13070.f,
+				     13080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f, 13090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13100.f, 13110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13120.f,
+				     13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13130.f, 13140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13150.f,
+				     13160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f, 13170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13180.f, 13190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13200.f,
+				     13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13210.f, 13220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13230.f,
+				     13240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f, 13250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13260.f, 13270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13280.f,
-    13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13290.f, 13300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13310.f,
-      13320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f, 13330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13340.f, 13350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13360.f,
-    13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13370.f, 13380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13390.f,
-      13400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f, 13410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13420.f, 13430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13440.f,
-    13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13450.f, 13460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13470.f,
-      13480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f, 13490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13500.f, 13510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13520.f,
-    13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13530.f, 13540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13550.f,
-      13560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f, 13570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13580.f, 13590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13600.f,
-    13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13610.f, 13620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13630.f,
-      13640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f, 13650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13660.f, 13670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13680.f,
-    13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13690.f, 13700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13710.f,
-      13720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f, 13730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13740.f, 13750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13760.f,
-    13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13770.f, 13780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13790.f,
-      13800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f, 13810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13820.f, 13830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13840.f,
-    13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13850.f, 13860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13870.f,
-      13880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f, 13890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13900.f, 13910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13920.f,
-    13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13930.f, 13940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13950.f,
-      13960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f, 13970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13980.f, 13990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.4e4f,
-    14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14010.f, 14020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14030.f,
-      14040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f, 14050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14060.f, 14070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14080.f,
-    14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14090.f, 14100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14110.f,
+				     13280.f,
+				     13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13290.f, 13300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13310.f,
+				     13320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f, 13330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13340.f, 13350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13360.f,
+				     13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13370.f, 13380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13390.f,
+				     13400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f, 13410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13420.f, 13430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13440.f,
+				     13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13450.f, 13460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13470.f,
+				     13480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f, 13490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13500.f, 13510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13520.f,
+				     13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13530.f, 13540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13550.f,
+				     13560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f, 13570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13580.f, 13590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13600.f,
+				     13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13610.f, 13620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13630.f,
+				     13640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f, 13650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13660.f, 13670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13680.f,
+				     13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13690.f, 13700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13710.f,
+				     13720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f, 13730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13740.f, 13750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13760.f,
+				     13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13770.f, 13780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13790.f,
+				     13800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f, 13810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13820.f, 13830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13840.f,
+				     13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13850.f, 13860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13870.f,
+				     13880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f, 13890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13900.f, 13910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13920.f,
+				     13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13930.f, 13940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13950.f,
+				     13960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f, 13970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13980.f, 13990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.4e4f,
+				     14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14010.f, 14020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14030.f,
+				     14040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f, 14050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14060.f, 14070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14080.f,
+				     14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14090.f, 14100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14110.f,
-      14120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f, 14130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14140.f, 14150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14160.f,
-    14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14170.f, 14180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14190.f,
-      14200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f, 14210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14220.f, 14230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14240.f,
-    14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14250.f, 14260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14270.f,
-      14280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f, 14290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14300.f, 14310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14320.f,
-    14330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14330.f, 14340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14350.f,
-      14360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14360.f, 14370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14370.f, 14380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14380.f, 14390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14390.f, 14400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14400.f,
-    14410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14410.f, 14420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14420.f, 14430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14430.f,
-      14440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14440.f, 14450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14450.f, 14460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14460.f, 14470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14470.f, 14480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14480.f,
-    14490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14490.f, 14500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14500.f, 14510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14510.f,
-      14520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f, 14530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f, 14550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f, 14130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14140.f, 14150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14160.f,
+				     14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14170.f, 14180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14190.f,
+				     14200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f, 14210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14220.f, 14230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14240.f,
+				     14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14250.f, 14260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14270.f,
+				     14280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f, 14290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14300.f, 14310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14320.f,
+				     14330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14330.f, 14340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14350.f,
+				     14360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14360.f, 14370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14370.f, 14380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14380.f, 14390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14390.f, 14400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14400.f,
+				     14410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14410.f, 14420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14420.f, 14430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14430.f,
+				     14440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14440.f, 14450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14450.f, 14460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14460.f, 14470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14470.f, 14480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14480.f,
+				     14490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14490.f, 14500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14500.f, 14510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14510.f,
+				     14520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f, 14530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f, 14550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14560.f,
-    14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
-      14600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14640.f,
-    14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
-      14680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14720.f,
-    14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
-      14760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14800.f,
-    14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
-      14840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14880.f,
-    14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
-      14920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14960.f,
-    14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
+				     14560.f,
+				     14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
+				     14600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14640.f,
+				     14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
+				     14680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14720.f,
+				     14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
+				     14760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14800.f,
+				     14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
+				     14840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14880.f,
+				     14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
+				     14920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14960.f,
+				     14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15040.f,
-    15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
-      15080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15120.f,
-    15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
-      15160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15200.f,
-    15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
-      15040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15280.f,
-    15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15040.f,
+				     15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
+				     15080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15120.f,
+				     15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
+				     15160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15200.f,
+				     15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
+				     15040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15280.f,
+				     15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
-	/* nitrous oxide (12740 - 15290 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* nitrous oxide (12740 - 15290 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* niox5 */
 void
@@ -3838,331 +3838,331 @@
-    0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10240.f,
-    10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
-      10280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10320.f,
-    10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
-      10360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10400.f,
-    10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
-      10440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10480.f,
-    10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
-      10520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10560.f,
-    10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
-      10600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10640.f,
-    10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
-      10680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10720.f,
-    10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
-      10760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10800.f,
-    10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
-      10840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10880.f,
+				     0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10240.f,
+				     10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
+				     10280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10320.f,
+				     10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
+				     10360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10400.f,
+				     10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
+				     10440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10480.f,
+				     10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
+				     10520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10560.f,
+				     10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
+				     10600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10640.f,
+				     10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
+				     10680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10720.f,
+				     10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
+				     10760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10800.f,
+				     10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
+				     10840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10880.f,
-    10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
-      10920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10960.f,
-    10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11040.f,
-    11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
-      11080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11120.f,
-    11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
-      11160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11200.f,
-    11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
-      11240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
+				     10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
+				     10920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10960.f,
+				     10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11040.f,
+				     11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
+				     11080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11120.f,
+				     11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
+				     11160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11200.f,
+				     11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
+				     11240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
-    11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11280.f,
-    11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
-      11320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11360.f,
-    11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
-      11400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11440.f,
-    11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
-      11480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11490.f, 11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11510.f, 11520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11520.f,
-    11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11530.f, 11540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11540.f, 11550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11550.f,
-      11560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11560.f, 11570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11570.f, 11580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11580.f, 11590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11600.f,
-    11610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11610.f, 11620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11620.f, 11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f,
-      11640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11650.f, 11660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11680.f,
-    11690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11700.f, 11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f,
-      11720.f,
+				     11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11280.f,
+				     11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
+				     11320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11360.f,
+				     11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
+				     11400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11440.f,
+				     11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
+				     11480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11490.f, 11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11510.f, 11520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11520.f,
+				     11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11530.f, 11540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11540.f, 11550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11550.f,
+				     11560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11560.f, 11570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11570.f, 11580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11580.f, 11590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11600.f,
+				     11610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11610.f, 11620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11620.f, 11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f,
+				     11640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11650.f, 11660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11680.f,
+				     11690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11700.f, 11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f,
+				     11720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11730.f, 11740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11760.f,
-    11770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11780.f, 11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f,
-      11800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11810.f, 11820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11840.f,
-    11850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11860.f, 11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f,
-      11880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11890.f, 11900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11920.f,
-    11930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11940.f, 11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f,
-      11960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11970.f, 11980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f,
-    12010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12020.f, 12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f,
-      12040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12050.f, 12060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12080.f,
-    12090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11730.f, 11740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11760.f,
+				     11770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11780.f, 11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f,
+				     11800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11810.f, 11820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11840.f,
+				     11850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11860.f, 11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f,
+				     11880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11890.f, 11900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11920.f,
+				     11930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11940.f, 11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f,
+				     11960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11970.f, 11980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f,
+				     12010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12020.f, 12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f,
+				     12040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12050.f, 12060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12080.f,
+				     12090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12100.f, 12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f,
-      12120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12130.f, 12140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12160.f,
-    12170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12180.f, 12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f,
-      12200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12210.f, 12220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12240.f,
-    12250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12260.f, 12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f,
-      12280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12290.f, 12300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12320.f,
-    12330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12340.f, 12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f,
-      12360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12370.f, 12380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12400.f,
-    12410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12420.f, 12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f,
-      12440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12450.f, 12460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12480.f,
-    12490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12500.f, 12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f,
-      12520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12530.f, 12540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12560.f,
-    12570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12580.f, 12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f,
-      12600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12610.f, 12620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12640.f,
-    12650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12660.f, 12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f,
-      12680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12690.f, 12700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12720.f,
-    12730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
+				     0.f,
+				     0.f, 0.f, 12100.f, 12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f,
+				     12120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12130.f, 12140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12160.f,
+				     12170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12180.f, 12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f,
+				     12200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12210.f, 12220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12240.f,
+				     12250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12260.f, 12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f,
+				     12280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12290.f, 12300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12320.f,
+				     12330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12340.f, 12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f,
+				     12360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12370.f, 12380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12400.f,
+				     12410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12420.f, 12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f,
+				     12440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12450.f, 12460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12480.f,
+				     12490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12500.f, 12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f,
+				     12520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12530.f, 12540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12560.f,
+				     12570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12580.f, 12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f,
+				     12600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12610.f, 12620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12640.f,
+				     12650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12660.f, 12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f,
+				     12680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12690.f, 12700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12720.f,
+				     12730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
-	/* nitrous oxide (10180 - 12730 cm-1) */
+    /* nitrous oxide (10180 - 12730 cm-1) */
 }	/* niox4 */
 void
@@ -4170,294 +4170,294 @@
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
-    7660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f, 7690.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7690.f, 7700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7700.f,
-    7710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7710.f, 7720.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7720.f, 7730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7730.f, 7740.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7740.f, 7750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7750.f,
-    7760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7760.f, 7770.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7780.f, 7790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7800.f,
-    7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f, 7840.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7850.f,
-    7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f, 7890.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7890.f, 7900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7900.f,
-    7910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7910.f, 7920.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7920.f, 7930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7930.f, 7940.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7940.f, 7950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7950.f,
-    7960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7960.f, 7970.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7970.f, 7980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7980.f, 7990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f,
-      8010.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8020.f, 8030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8030.f, 8040.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8040.f, 8050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8050.f,
-      8060.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8060.f, 8070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8070.f, 8080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8080.f, 8090.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8090.f, 8100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8100.f,
-      8110.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8110.f, 8120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8120.f, 8130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8130.f, 8140.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8140.f, 8150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8150.f,
-      8160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8160.f, 8170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8170.f, 8180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8180.f, 8190.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8190.f, 8200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8200.f,
-      8210.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8210.f, 8220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8220.f, 8230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8230.f, 8240.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8240.f, 8250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8250.f,
-      8260.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8260.f, 8270.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8270.f, 8280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8280.f, 8290.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8290.f, 8300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8300.f,
-      8310.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8320.f, 8330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8340.f, 8350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f,
-      8360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8370.f, 8380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8390.f, 8400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f,
-      8410.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8420.f, 8430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8440.f, 8450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f,
-      8460.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8470.f, 8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f,
-      8510.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8520.f, 8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f,
-      8560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8570.f, 8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f,
-      8610.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8620.f, 8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f,
-      8660.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8670.f, 8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f,
-      8710.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8720.f, 8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f,
-      8760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8770.f, 8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f,
-      8810.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8820.f, 8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f,
-      8860.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8870.f, 8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f,
-      8910.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8920.f, 8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f,
-      8960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8970.f, 8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      9020.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
+				     7660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f, 7690.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7690.f, 7700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7700.f,
+				     7710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7710.f, 7720.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7720.f, 7730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7730.f, 7740.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7740.f, 7750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7750.f,
+				     7760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7760.f, 7770.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7780.f, 7790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7800.f,
+				     7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f, 7840.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7850.f,
+				     7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f, 7890.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7890.f, 7900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7900.f,
+				     7910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7910.f, 7920.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7920.f, 7930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7930.f, 7940.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7940.f, 7950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7950.f,
+				     7960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7960.f, 7970.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7970.f, 7980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7980.f, 7990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f,
+				     8010.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8020.f, 8030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8030.f, 8040.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8040.f, 8050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8050.f,
+				     8060.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8060.f, 8070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8070.f, 8080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8080.f, 8090.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8090.f, 8100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8100.f,
+				     8110.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8110.f, 8120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8120.f, 8130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8130.f, 8140.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8140.f, 8150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8150.f,
+				     8160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8160.f, 8170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8170.f, 8180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8180.f, 8190.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8190.f, 8200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8200.f,
+				     8210.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8210.f, 8220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8220.f, 8230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8230.f, 8240.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8240.f, 8250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8250.f,
+				     8260.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8260.f, 8270.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8270.f, 8280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8280.f, 8290.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8290.f, 8300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8300.f,
+				     8310.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8320.f, 8330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8340.f, 8350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f,
+				     8360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8370.f, 8380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8390.f, 8400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f,
+				     8410.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8420.f, 8430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8440.f, 8450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f,
+				     8460.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8470.f, 8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f,
+				     8510.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8520.f, 8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f,
+				     8560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8570.f, 8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f,
+				     8610.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8620.f, 8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f,
+				     8660.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8670.f, 8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f,
+				     8710.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8720.f, 8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f,
+				     8760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8770.f, 8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f,
+				     8810.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8820.f, 8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f,
+				     8860.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8870.f, 8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f,
+				     8910.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8920.f, 8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f,
+				     8960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8970.f, 8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     9020.f,
-    9030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
-    9080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
-    9130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
-    9180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
-    9230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
-    9280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
-    9330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9340.f, 9350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9350.f, 9360.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9360.f, 9370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9370.f,
-    9380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9390.f, 9400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9400.f, 9410.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9410.f, 9420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f,
-    9430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9440.f, 9450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9450.f, 9460.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f,
-    9480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
+				     9030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
+				     9080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
+				     9130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
+				     9180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
+				     9230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
+				     9280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
+				     9330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9340.f, 9350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9350.f, 9360.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9360.f, 9370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9370.f,
+				     9380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9390.f, 9400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9400.f, 9410.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9410.f, 9420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f,
+				     9430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9440.f, 9450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9450.f, 9460.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f,
+				     9480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
-    9530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
-    9580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
-    9630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
-    9680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
-    9730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
-    9780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
-    9830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
-    9880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
-    9930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
-    9980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
-    10030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f,
-      10060.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10070.f, 10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10100.f,
-    10110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f,
-      0.f,
+				     9530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
+				     9580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
+				     9630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
+				     9680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
+				     9730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
+				     9780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
+				     9830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
+				     9880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
+				     9930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
+				     9980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
+				     10030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f,
+				     10060.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10070.f, 10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10100.f,
+				     10110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f,
+				     0.f,
-    0.f, 0.f, 10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f,
-      10140.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10150.f, 10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10170.f, 10180.f
+				     0.f, 0.f, 10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f,
+				     10140.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10150.f, 10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10170.f, 10180.f
-	/* nitrous oxide (7620 - 10170 cm-1) */
+    /* nitrous oxide (7620 - 10170 cm-1) */
 }	/* niox3 */
 void
@@ -4465,289 +4465,289 @@
-  static const float acr[2048] = { .072211f, .24584f,
-    .0096738f, -5.1958e-5f, .0067533f, -4.7277e-5f, 5060.f, 5070.f, .21388f,
-    .25456f, .0043318f, -3.1058e-5f, .0012217f, -2.5614e-5f, 5070.f, 5080.f,
-    .57556f, .33263f, -2.6597e-4f, -1.2844e-5f, -.0033007f, -7.3238e-6f,
-    5080.f, 5090.f, .67723f, .36014f, -.0034018f, -8.0539e-7f, -.006515f,
-    5.4383e-6f, 5090.f, 5100.f, .30093f, .41799f, -.0047912f, 4.5347e-6f,
-    -.0079672f, 1.0982e-5f, 5100.f, 5110.f, 1.0645f, .53257f, -.003157f,
-    -1.4679e-6f, -.0062971f, 4.7135e-6f, 5110.f, 5120.f, .67643f, .61899f,
-    .0025029f, -2.0398e-5f, 2.0488e-4f, -1.9155e-5f, 5120.f, 5130.f,
-    .018117f, .12425f, .013386f, -6.7752e-5f, .010428f, -6.2211e-5f, 5130.f,
-    5140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5140.f, 5150.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5150.f, 5160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5160.f, 5170.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5170.f, 5180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5180.f,
-    5190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5190.f, 5200.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5200.f, 5210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5210.f, 5220.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5220.f, 5230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5230.f,
-    5240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5240.f, 5250.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5250.f, 5260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5260.f, 5270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5270.f, 5280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5280.f,
-    5290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5290.f, 5300.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5300.f, 5310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5310.f, 5320.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5320.f, 5330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5330.f,
-    5340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5340.f, 5350.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5350.f, 5360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5360.f, 5370.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5370.f, 5380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5380.f,
-    5390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5390.f, 5400.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5400.f, 5410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5410.f, 5420.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5420.f, 5430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5430.f,
-    5440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5440.f, 5450.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5450.f, 5460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5460.f, 5470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5470.f, 5480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5480.f,
-    5490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5490.f, 5500.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5500.f, 5510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5510.f, 5520.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5520.f, 5530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5530.f,
-    5540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5540.f, 5550.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5550.f, 5560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5560.f, 5570.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5570.f, 5580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5580.f,
-    5590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5590.f, 5600.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5600.f, 5610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5610.f, 5620.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5620.f, 5630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5630.f,
-    5640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5640.f, 5650.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5650.f, 5660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5660.f, 5670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5670.f, 5680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5680.f,
-    5690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5690.f, 5700.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5700.f, 5710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5710.f, 5720.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5720.f, 5730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5730.f,
-    5740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5740.f, 5750.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5750.f, 5760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5760.f, 5770.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5770.f, 5780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5780.f,
-    5790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5790.f, 5800.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5800.f, 5810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5810.f, 5820.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5820.f, 5830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5830.f,
-    5840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5840.f, 5850.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5850.f, 5860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5860.f, 5870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5870.f, 5880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5880.f,
-    5890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5890.f, 5900.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5900.f, 5910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5910.f, 5920.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5920.f, 5930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5930.f,
-    5940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5940.f, 5950.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5950.f, 5960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5960.f, 5970.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5970.f, 5980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5980.f,
-    5990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5990.f, 6e3f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6e3f, 6010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6010.f, 6020.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6020.f, 6030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6030.f,
-      6040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6040.f, 6050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6050.f, 6060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6060.f, 6070.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6070.f, 6080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6080.f,
-      6090.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6090.f, 6100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6100.f, 6110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6110.f, 6120.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6120.f, 6130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6130.f,
-      6140.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6140.f, 6150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6150.f, 6160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6160.f, 6170.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6170.f, 6180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6180.f,
-      6190.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6190.f, 6200.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6200.f, 6210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6210.f, 6220.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6220.f, 6230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6230.f,
-      6240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6240.f, 6250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6250.f, 6260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6260.f, 6270.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6270.f, 6280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6280.f,
-      6290.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6290.f, 6300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6300.f, 6310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6310.f, 6320.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6320.f, 6330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6330.f,
-      6340.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6340.f, 6350.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6350.f, 6360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6360.f, 6370.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6370.f, 6380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6380.f,
-      6390.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6390.f, 6400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6400.f, 6410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6410.f, 6420.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f,
-      6440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6440.f, 6450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6450.f, 6460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6460.f, 6470.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6470.f, 6480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6480.f,
-      6490.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6490.f, 6500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6500.f, 6510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6510.f, 6520.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6520.f, 6530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6530.f,
-      6540.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6540.f, 6550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6550.f, 6560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6560.f, 6570.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6580.f,
-      6590.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6600.f, 6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6620.f, 6630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6630.f,
-      6640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6640.f, 6650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+    static const float acr[2048] = { .072211f, .24584f,
+				     .0096738f, -5.1958e-5f, .0067533f, -4.7277e-5f, 5060.f, 5070.f, .21388f,
+				     .25456f, .0043318f, -3.1058e-5f, .0012217f, -2.5614e-5f, 5070.f, 5080.f,
+				     .57556f, .33263f, -2.6597e-4f, -1.2844e-5f, -.0033007f, -7.3238e-6f,
+				     5080.f, 5090.f, .67723f, .36014f, -.0034018f, -8.0539e-7f, -.006515f,
+				     5.4383e-6f, 5090.f, 5100.f, .30093f, .41799f, -.0047912f, 4.5347e-6f,
+				     -.0079672f, 1.0982e-5f, 5100.f, 5110.f, 1.0645f, .53257f, -.003157f,
+				     -1.4679e-6f, -.0062971f, 4.7135e-6f, 5110.f, 5120.f, .67643f, .61899f,
+				     .0025029f, -2.0398e-5f, 2.0488e-4f, -1.9155e-5f, 5120.f, 5130.f,
+				     .018117f, .12425f, .013386f, -6.7752e-5f, .010428f, -6.2211e-5f, 5130.f,
+				     5140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5140.f, 5150.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5150.f, 5160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5160.f, 5170.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5170.f, 5180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5180.f,
+				     5190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5190.f, 5200.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5200.f, 5210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5210.f, 5220.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5220.f, 5230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5230.f,
+				     5240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5240.f, 5250.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5250.f, 5260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5260.f, 5270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5270.f, 5280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5280.f,
+				     5290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5290.f, 5300.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5300.f, 5310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5310.f, 5320.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5320.f, 5330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5330.f,
+				     5340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5340.f, 5350.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5350.f, 5360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5360.f, 5370.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5370.f, 5380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5380.f,
+				     5390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5390.f, 5400.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5400.f, 5410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5410.f, 5420.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5420.f, 5430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5430.f,
+				     5440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5440.f, 5450.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5450.f, 5460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5460.f, 5470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5470.f, 5480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5480.f,
+				     5490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5490.f, 5500.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5500.f, 5510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5510.f, 5520.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5520.f, 5530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5530.f,
+				     5540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5540.f, 5550.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5550.f, 5560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5560.f, 5570.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5570.f, 5580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5580.f,
+				     5590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5590.f, 5600.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5600.f, 5610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5610.f, 5620.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5620.f, 5630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5630.f,
+				     5640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5640.f, 5650.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5650.f, 5660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5660.f, 5670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5670.f, 5680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5680.f,
+				     5690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5690.f, 5700.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5700.f, 5710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5710.f, 5720.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5720.f, 5730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5730.f,
+				     5740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5740.f, 5750.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5750.f, 5760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5760.f, 5770.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5770.f, 5780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5780.f,
+				     5790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5790.f, 5800.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5800.f, 5810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5810.f, 5820.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5820.f, 5830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5830.f,
+				     5840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5840.f, 5850.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5850.f, 5860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5860.f, 5870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5870.f, 5880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5880.f,
+				     5890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5890.f, 5900.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5900.f, 5910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5910.f, 5920.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5920.f, 5930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5930.f,
+				     5940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5940.f, 5950.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5950.f, 5960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5960.f, 5970.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5970.f, 5980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5980.f,
+				     5990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5990.f, 6e3f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6e3f, 6010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6010.f, 6020.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6020.f, 6030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6030.f,
+				     6040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6040.f, 6050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6050.f, 6060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6060.f, 6070.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6070.f, 6080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6080.f,
+				     6090.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6090.f, 6100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6100.f, 6110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6110.f, 6120.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6120.f, 6130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6130.f,
+				     6140.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6140.f, 6150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6150.f, 6160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6160.f, 6170.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6170.f, 6180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6180.f,
+				     6190.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6190.f, 6200.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6200.f, 6210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6210.f, 6220.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6220.f, 6230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6230.f,
+				     6240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6240.f, 6250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6250.f, 6260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6260.f, 6270.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6270.f, 6280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6280.f,
+				     6290.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6290.f, 6300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6300.f, 6310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6310.f, 6320.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6320.f, 6330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6330.f,
+				     6340.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6340.f, 6350.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6350.f, 6360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6360.f, 6370.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6370.f, 6380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6380.f,
+				     6390.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6390.f, 6400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6400.f, 6410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6410.f, 6420.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f,
+				     6440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6440.f, 6450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6450.f, 6460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6460.f, 6470.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6470.f, 6480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6480.f,
+				     6490.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6490.f, 6500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6500.f, 6510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6510.f, 6520.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6520.f, 6530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6530.f,
+				     6540.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6540.f, 6550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6550.f, 6560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6560.f, 6570.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6580.f,
+				     6590.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6600.f, 6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6620.f, 6630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6630.f,
+				     6640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6640.f, 6650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6650.f, 6660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6660.f, 6670.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6670.f, 6680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6680.f,
-      6690.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6690.f, 6700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6700.f, 6710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6710.f, 6720.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6720.f, 6730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6730.f,
-      6740.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6740.f, 6750.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6750.f, 6760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6760.f, 6770.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6770.f, 6780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6780.f,
-      6790.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6800.f, 6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6820.f, 6830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6830.f,
-      6840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6840.f, 6850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6850.f, 6860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6860.f, 6870.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6870.f, 6880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6880.f,
-      6890.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6890.f, 6900.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6900.f, 6910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6910.f, 6920.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6920.f, 6930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6930.f,
-      6940.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6940.f, 6950.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    6950.f, 6960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6960.f, 6970.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 6970.f, 6980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6980.f,
-      6990.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      7e3f,
-    7010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f, 7040.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7050.f,
-    7060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f, 7090.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7100.f,
-    7110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f, 7140.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7150.f,
-    7160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f, 7190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7200.f,
-    7210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f, 7240.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7240.f, 7250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7250.f,
-    7260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7260.f, 7270.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7270.f, 7280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7280.f, 7290.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7290.f, 7300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7300.f,
-    7310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f, 7340.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7350.f,
-    7360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f, 7390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7390.f, 7400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7400.f,
-    7410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7410.f, 7420.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7420.f, 7430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7430.f, 7440.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7440.f, 7450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7450.f,
-    7460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7460.f, 7470.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7470.f, 7480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7480.f, 7490.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7490.f, 7500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7500.f,
-    7510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7510.f, 7520.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7520.f, 7530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7530.f, 7540.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7540.f, 7550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7550.f,
-    7560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7560.f, 7570.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7570.f, 7580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7580.f, 7590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7590.f, 7600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7600.f,
-    7610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7610.f, 7620.f
+				     0.f,
+				     6650.f, 6660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6660.f, 6670.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6670.f, 6680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6680.f,
+				     6690.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6690.f, 6700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6700.f, 6710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6710.f, 6720.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6720.f, 6730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6730.f,
+				     6740.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6740.f, 6750.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6750.f, 6760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6760.f, 6770.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6770.f, 6780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6780.f,
+				     6790.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6800.f, 6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6820.f, 6830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6830.f,
+				     6840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6840.f, 6850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6850.f, 6860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6860.f, 6870.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6870.f, 6880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6880.f,
+				     6890.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6890.f, 6900.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6900.f, 6910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6910.f, 6920.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6920.f, 6930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6930.f,
+				     6940.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6940.f, 6950.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     6950.f, 6960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6960.f, 6970.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 6970.f, 6980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6980.f,
+				     6990.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     7e3f,
+				     7010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f, 7040.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7050.f,
+				     7060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f, 7090.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7100.f,
+				     7110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f, 7140.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7150.f,
+				     7160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f, 7190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7200.f,
+				     7210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f, 7240.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7240.f, 7250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7250.f,
+				     7260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7260.f, 7270.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7270.f, 7280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7280.f, 7290.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7290.f, 7300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7300.f,
+				     7310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f, 7340.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7350.f,
+				     7360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f, 7390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7390.f, 7400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7400.f,
+				     7410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7410.f, 7420.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7420.f, 7430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7430.f, 7440.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7440.f, 7450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7450.f,
+				     7460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7460.f, 7470.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7470.f, 7480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7480.f, 7490.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7490.f, 7500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7500.f,
+				     7510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7510.f, 7520.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7520.f, 7530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7530.f, 7540.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7540.f, 7550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7550.f,
+				     7560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7560.f, 7570.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7570.f, 7580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7580.f, 7590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7590.f, 7600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7600.f,
+				     7610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7610.f, 7620.f
-	/* nitrous oxide (5060 - 7610 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* nitrous oxide (5060 - 7610 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* niox2 */
 void
@@ -4755,301 +4755,301 @@
-  static const float acr[2048] = { 2.0198f, 1.2223f,
-    .021725f, -7.4064e-5f, .021102f, -6.8716e-5f, 2500.f, 2510.f, 5.563f,
-    .51358f, .018526f, -8.1387e-5f, .020173f, -7.5293e-5f, 2510.f, 2520.f,
-    30.587f, .41845f, .010994f, -5.2858e-5f, .012658f, -4.4443e-5f, 2520.f,
-    2530.f, 127.44f, .46867f, .0044706f, -2.7536e-5f, .0057879f,
-    -1.6691e-5f, 2530.f, 2540.f, 288.02f, .51762f, -2.6998e-4f, -8.7651e-6f,
-    .0012264f, 2.1451e-6f, 2540.f, 2550.f, 353.69f, .7476f, -.0029604f,
-    4.5093e-6f, -.0013209f, 1.2765e-5f, 2550.f, 2560.f, 185.24f, 1.0395f,
-    -.0026365f, 1.2028e-5f, 6.176e-4f, 1.0222e-5f, 2560.f, 2570.f, 464.55f,
-    .85773f, -.0024108f, -1.72e-6f, -7.7777e-4f, 5.7019e-6f, 2570.f, 2580.f,
-    293.83f, 1.0741f, .0031043f, -2.1797e-5f, .0037703f, -2.0707e-5f,
-    2580.f, 2590.f, 55.672f, 1.7813f, .013484f, -6.2711e-5f, .013188f,
-    -6.339e-5f, 2590.f, 2600.f, 6.6505f, 2.3452f, .023437f, -9.9109e-5f,
-    .023591f, -1.0503e-4f, 2600.f, 2610.f, .41623f, 2.2528f, .035914f,
-    -1.5047e-4f, .035732f, -1.5387e-4f, 2610.f, 2620.f, .01271f, 1.0271f,
-    .047982f, -1.9811e-4f, .047474f, -2.0344e-4f, 2620.f, 2630.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 2630.f, 2640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2640.f,
-    2650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2650.f, 2660.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2660.f, 2670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2670.f, 2680.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2680.f, 2690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2690.f,
-    2700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2700.f, 2710.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2710.f, 2720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2720.f, 2730.f,
-      .018198f,
-    .18592f, .025778f, -1.1646e-4f, .02282f, -1.1152e-4f, 2730.f, 2740.f,
-    .21623f, .86664f, .021368f, -9.617e-5f, .018994f, -9.4763e-5f, 2740.f,
-    2750.f, .9723f, 1.0815f, .015101f, -7.1229e-5f, .012988f, -7.0769e-5f,
-    2750.f, 2760.f, 3.1871f, 1.6537f, .0095979f, -4.1092e-5f, .0109f,
-    -5.0556e-5f, 2760.f, 2770.f, 9.1207f, 2.0456f, .0045146f, -1.7223e-5f,
-    .0068327f, -3.3329e-5f, 2770.f, 2780.f, 15.769f, 2.4147f, .00151f,
-    2.7306e-6f, .004717f, -2.1798e-5f, 2780.f, 2790.f, 63.944f, 2.2532f,
-    -9.2395e-4f, -1.4987e-6f, -.0017516f, -2.476e-6f, 2790.f, 2800.f,
-    13.465f, .81561f, -.0029579f, 7.8199e-6f, -.0016132f, 7.282e-6f, 2800.f,
-    2810.f, 15.397f, .59138f, -4.591e-4f, -9.3657e-6f, -.0015437f,
-    -2.9788e-6f, 2810.f, 2820.f, 3.8011f, .48019f, .0069255f, -3.8126e-5f,
-    .0047344f, -3.7097e-5f, 2820.f, 2830.f, .17619f, .34619f, .019824f,
-    -8.9371e-5f, .017957f, -8.9565e-5f, 2830.f, 2840.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 2840.f, 2850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2850.f, 2860.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 2860.f, 2870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      2870.f,
-    2880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2880.f, 2890.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2890.f, 2900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2900.f, 2910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2910.f, 2920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2920.f,
-    2930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2930.f, 2940.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2940.f, 2950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2950.f, 2960.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2960.f, 2970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2970.f,
-    2980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2980.f, 2990.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2990.f, 3e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3e3f, 3010.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3010.f, 3020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3020.f,
-      3030.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3030.f, 3040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3040.f, 3050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3050.f, 3060.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3060.f, 3070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3070.f,
-      3080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3080.f, 3090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3090.f, 3100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3100.f, 3110.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3110.f, 3120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3120.f,
-      3130.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3130.f, 3140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3140.f, 3150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3150.f, 3160.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3160.f, 3170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3170.f,
-      3180.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3180.f, 3190.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3190.f, 3200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3200.f, 3210.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3210.f, 3220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3220.f,
-      3230.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3230.f, 3240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3240.f, 3250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3250.f, 3260.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3260.f, 3270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3270.f,
-      3280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3280.f, 3290.f, .031935f, .33591f, .031875f,
-    -1.4104e-4f, .028977f, -1.3626e-4f, 3290.f, 3300.f, .29281f, .7467f,
-    .024844f, -1.1101e-4f, .022436f, -1.0879e-4f, 3300.f, 3310.f, 1.3054f,
-    .88331f, .018331f, -8.5898e-5f, .015557f, -8.2041e-5f, 3310.f, 3320.f,
-    4.3559f, .97784f, .012392f, -6.2543e-5f, .0096436f, -5.8644e-5f, 3320.f,
-    3330.f, 10.74f, .87778f, .0059037f, -3.4711e-5f, .0041535f, -3.5594e-5f,
-    3330.f, 3340.f, 23.794f, .67907f, 5.4208e-5f, -1.1592e-5f, -8.2054e-4f,
-    -1.2774e-5f, 3340.f, 3350.f, 27.447f, .86607f, -.0018645f, 4.7336e-6f,
-    -.001502f, -1.8166e-6f, 3350.f, 3360.f, 12.839f, .92051f, -.0018449f,
-    1.8928e-5f, -3.1436e-5f, 6.4319e-6f, 3360.f, 3370.f, 33.503f, .561f,
-    -.0027786f, -1.9224e-7f, -.0032856f, 1.1355e-5f, 3370.f, 3380.f, 20.6f,
-    .44389f, .0016967f, -1.9484e-5f, -.0011701f, -1.5371e-5f, 3380.f,
-    3390.f, 3.8609f, .51395f, .010469f, -4.8303e-5f, .010318f, -4.3382e-5f,
-    3390.f, 3400.f, .29988f, .99187f, .032066f, -1.0701e-4f, .031782f,
-    -1.3149e-4f, 3400.f, 3410.f, 1.1046f, .96114f, .03056f, -1.2026e-4f,
-    .031203f, -1.3653e-4f, 3410.f, 3420.f, 5.3792f, .96792f, .023315f,
-    -9.51e-5f, .024421f, -1.0864e-4f, 3420.f, 3430.f, 25.745f, .89943f,
-    .015618f, -6.5963e-5f, .017309f, -7.84e-5f, 3430.f, 3440.f, 90.538f,
-    .79321f, .009142f, -4.2087e-5f, .010653f, -5.0451e-5f, 3440.f, 3450.f,
-    302.63f, .81416f, .0031369f, -1.9699e-5f, .0046971f, -2.3774e-5f,
-    3450.f, 3460.f, 451.74f, .71592f, -.0010912f, -4.691e-6f, 7.436e-4f,
-    -4.31e-6f, 3460.f, 3470.f, 395.99f, .95008f, -.0034795f, 5.0213e-6f,
-    -.0012061f, 8.3238e-6f, 3470.f, 3480.f, 391.94f, 1.0413f, -.0024518f,
-    9.7005e-6f, 3.1609e-4f, 6.168e-6f, 3480.f, 3490.f, 753.96f, .84036f,
-    -9.1794e-4f, -4.5133e-6f, -2.3983e-4f, -6.0537e-7f, 3490.f, 3500.f,
-    216.44f, .71621f, .00633f, -3.2276e-5f, .0065565f, -3.1312e-5f, 3500.f,
-    3510.f, 1.8617f, .41652f, .026193f, -1.1186e-4f, .025872f, -1.1548e-4f,
-    3510.f, 3520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3520.f, 3530.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3530.f, 3540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3540.f,
-      3550.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3550.f, 3560.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3560.f, 3570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3570.f, 3580.f, .11329f,
-    .32221f, .011785f, -5.9055e-5f, .009293f, -5.6411e-5f, 3580.f, 3590.f,
-    .6324f, .37454f, .0039372f, -2.85e-5f, .0010518f, -2.435e-5f, 3590.f,
-    3600.f, 1.3646f, .37234f, -.0012358f, -8.9975e-6f, -.0042592f,
-    -3.4218e-6f, 3600.f, 3610.f, 1.1991f, .43663f, -.0040429f, 1.6771e-6f,
-    -.007273f, 8.322e-6f, 3610.f, 3620.f, .84759f, .39017f, -.0045304f,
-    3.5248e-6f, -.0077172f, 1.0072e-5f, 3620.f, 3630.f, 1.7247f, .41455f,
-    -.0023639f, -4.6172e-6f, -.0054164f, 1.1967e-6f, 3630.f, 3640.f, .9314f,
-    .40923f, .002508f, -2.2795e-5f, -3.8062e-4f, -1.8608e-5f, 3640.f,
-    3650.f, .17321f, .37301f, .010558f, -5.3495e-5f, .0082291f, -5.1685e-5f,
-    3650.f, 3660.f, .0028992f, .031363f, .018626f, -8.9141e-5f, .015463f,
-    -8.2773e-5f, 3660.f, 3670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3670.f, 3680.f,
+    static const float acr[2048] = { 2.0198f, 1.2223f,
+				     .021725f, -7.4064e-5f, .021102f, -6.8716e-5f, 2500.f, 2510.f, 5.563f,
+				     .51358f, .018526f, -8.1387e-5f, .020173f, -7.5293e-5f, 2510.f, 2520.f,
+				     30.587f, .41845f, .010994f, -5.2858e-5f, .012658f, -4.4443e-5f, 2520.f,
+				     2530.f, 127.44f, .46867f, .0044706f, -2.7536e-5f, .0057879f,
+				     -1.6691e-5f, 2530.f, 2540.f, 288.02f, .51762f, -2.6998e-4f, -8.7651e-6f,
+				     .0012264f, 2.1451e-6f, 2540.f, 2550.f, 353.69f, .7476f, -.0029604f,
+				     4.5093e-6f, -.0013209f, 1.2765e-5f, 2550.f, 2560.f, 185.24f, 1.0395f,
+				     -.0026365f, 1.2028e-5f, 6.176e-4f, 1.0222e-5f, 2560.f, 2570.f, 464.55f,
+				     .85773f, -.0024108f, -1.72e-6f, -7.7777e-4f, 5.7019e-6f, 2570.f, 2580.f,
+				     293.83f, 1.0741f, .0031043f, -2.1797e-5f, .0037703f, -2.0707e-5f,
+				     2580.f, 2590.f, 55.672f, 1.7813f, .013484f, -6.2711e-5f, .013188f,
+				     -6.339e-5f, 2590.f, 2600.f, 6.6505f, 2.3452f, .023437f, -9.9109e-5f,
+				     .023591f, -1.0503e-4f, 2600.f, 2610.f, .41623f, 2.2528f, .035914f,
+				     -1.5047e-4f, .035732f, -1.5387e-4f, 2610.f, 2620.f, .01271f, 1.0271f,
+				     .047982f, -1.9811e-4f, .047474f, -2.0344e-4f, 2620.f, 2630.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 2630.f, 2640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2640.f,
+				     2650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2650.f, 2660.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2660.f, 2670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2670.f, 2680.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2680.f, 2690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2690.f,
+				     2700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2700.f, 2710.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2710.f, 2720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2720.f, 2730.f,
+				     .018198f,
+				     .18592f, .025778f, -1.1646e-4f, .02282f, -1.1152e-4f, 2730.f, 2740.f,
+				     .21623f, .86664f, .021368f, -9.617e-5f, .018994f, -9.4763e-5f, 2740.f,
+				     2750.f, .9723f, 1.0815f, .015101f, -7.1229e-5f, .012988f, -7.0769e-5f,
+				     2750.f, 2760.f, 3.1871f, 1.6537f, .0095979f, -4.1092e-5f, .0109f,
+				     -5.0556e-5f, 2760.f, 2770.f, 9.1207f, 2.0456f, .0045146f, -1.7223e-5f,
+				     .0068327f, -3.3329e-5f, 2770.f, 2780.f, 15.769f, 2.4147f, .00151f,
+				     2.7306e-6f, .004717f, -2.1798e-5f, 2780.f, 2790.f, 63.944f, 2.2532f,
+				     -9.2395e-4f, -1.4987e-6f, -.0017516f, -2.476e-6f, 2790.f, 2800.f,
+				     13.465f, .81561f, -.0029579f, 7.8199e-6f, -.0016132f, 7.282e-6f, 2800.f,
+				     2810.f, 15.397f, .59138f, -4.591e-4f, -9.3657e-6f, -.0015437f,
+				     -2.9788e-6f, 2810.f, 2820.f, 3.8011f, .48019f, .0069255f, -3.8126e-5f,
+				     .0047344f, -3.7097e-5f, 2820.f, 2830.f, .17619f, .34619f, .019824f,
+				     -8.9371e-5f, .017957f, -8.9565e-5f, 2830.f, 2840.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 2840.f, 2850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2850.f, 2860.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 2860.f, 2870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     2870.f,
+				     2880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2880.f, 2890.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2890.f, 2900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2900.f, 2910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2910.f, 2920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2920.f,
+				     2930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2930.f, 2940.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2940.f, 2950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2950.f, 2960.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2960.f, 2970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2970.f,
+				     2980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2980.f, 2990.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2990.f, 3e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3e3f, 3010.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3010.f, 3020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3020.f,
+				     3030.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3030.f, 3040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3040.f, 3050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3050.f, 3060.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3060.f, 3070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3070.f,
+				     3080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3080.f, 3090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3090.f, 3100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3100.f, 3110.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3110.f, 3120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3120.f,
+				     3130.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3130.f, 3140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3140.f, 3150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3150.f, 3160.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3160.f, 3170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3170.f,
+				     3180.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3180.f, 3190.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3190.f, 3200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3200.f, 3210.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3210.f, 3220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3220.f,
+				     3230.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3230.f, 3240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3240.f, 3250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3250.f, 3260.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3260.f, 3270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3270.f,
+				     3280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3280.f, 3290.f, .031935f, .33591f, .031875f,
+				     -1.4104e-4f, .028977f, -1.3626e-4f, 3290.f, 3300.f, .29281f, .7467f,
+				     .024844f, -1.1101e-4f, .022436f, -1.0879e-4f, 3300.f, 3310.f, 1.3054f,
+				     .88331f, .018331f, -8.5898e-5f, .015557f, -8.2041e-5f, 3310.f, 3320.f,
+				     4.3559f, .97784f, .012392f, -6.2543e-5f, .0096436f, -5.8644e-5f, 3320.f,
+				     3330.f, 10.74f, .87778f, .0059037f, -3.4711e-5f, .0041535f, -3.5594e-5f,
+				     3330.f, 3340.f, 23.794f, .67907f, 5.4208e-5f, -1.1592e-5f, -8.2054e-4f,
+				     -1.2774e-5f, 3340.f, 3350.f, 27.447f, .86607f, -.0018645f, 4.7336e-6f,
+				     -.001502f, -1.8166e-6f, 3350.f, 3360.f, 12.839f, .92051f, -.0018449f,
+				     1.8928e-5f, -3.1436e-5f, 6.4319e-6f, 3360.f, 3370.f, 33.503f, .561f,
+				     -.0027786f, -1.9224e-7f, -.0032856f, 1.1355e-5f, 3370.f, 3380.f, 20.6f,
+				     .44389f, .0016967f, -1.9484e-5f, -.0011701f, -1.5371e-5f, 3380.f,
+				     3390.f, 3.8609f, .51395f, .010469f, -4.8303e-5f, .010318f, -4.3382e-5f,
+				     3390.f, 3400.f, .29988f, .99187f, .032066f, -1.0701e-4f, .031782f,
+				     -1.3149e-4f, 3400.f, 3410.f, 1.1046f, .96114f, .03056f, -1.2026e-4f,
+				     .031203f, -1.3653e-4f, 3410.f, 3420.f, 5.3792f, .96792f, .023315f,
+				     -9.51e-5f, .024421f, -1.0864e-4f, 3420.f, 3430.f, 25.745f, .89943f,
+				     .015618f, -6.5963e-5f, .017309f, -7.84e-5f, 3430.f, 3440.f, 90.538f,
+				     .79321f, .009142f, -4.2087e-5f, .010653f, -5.0451e-5f, 3440.f, 3450.f,
+				     302.63f, .81416f, .0031369f, -1.9699e-5f, .0046971f, -2.3774e-5f,
+				     3450.f, 3460.f, 451.74f, .71592f, -.0010912f, -4.691e-6f, 7.436e-4f,
+				     -4.31e-6f, 3460.f, 3470.f, 395.99f, .95008f, -.0034795f, 5.0213e-6f,
+				     -.0012061f, 8.3238e-6f, 3470.f, 3480.f, 391.94f, 1.0413f, -.0024518f,
+				     9.7005e-6f, 3.1609e-4f, 6.168e-6f, 3480.f, 3490.f, 753.96f, .84036f,
+				     -9.1794e-4f, -4.5133e-6f, -2.3983e-4f, -6.0537e-7f, 3490.f, 3500.f,
+				     216.44f, .71621f, .00633f, -3.2276e-5f, .0065565f, -3.1312e-5f, 3500.f,
+				     3510.f, 1.8617f, .41652f, .026193f, -1.1186e-4f, .025872f, -1.1548e-4f,
+				     3510.f, 3520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3520.f, 3530.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3530.f, 3540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3540.f,
+				     3550.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3550.f, 3560.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3560.f, 3570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3570.f, 3580.f, .11329f,
+				     .32221f, .011785f, -5.9055e-5f, .009293f, -5.6411e-5f, 3580.f, 3590.f,
+				     .6324f, .37454f, .0039372f, -2.85e-5f, .0010518f, -2.435e-5f, 3590.f,
+				     3600.f, 1.3646f, .37234f, -.0012358f, -8.9975e-6f, -.0042592f,
+				     -3.4218e-6f, 3600.f, 3610.f, 1.1991f, .43663f, -.0040429f, 1.6771e-6f,
+				     -.007273f, 8.322e-6f, 3610.f, 3620.f, .84759f, .39017f, -.0045304f,
+				     3.5248e-6f, -.0077172f, 1.0072e-5f, 3620.f, 3630.f, 1.7247f, .41455f,
+				     -.0023639f, -4.6172e-6f, -.0054164f, 1.1967e-6f, 3630.f, 3640.f, .9314f,
+				     .40923f, .002508f, -2.2795e-5f, -3.8062e-4f, -1.8608e-5f, 3640.f,
+				     3650.f, .17321f, .37301f, .010558f, -5.3495e-5f, .0082291f, -5.1685e-5f,
+				     3650.f, 3660.f, .0028992f, .031363f, .018626f, -8.9141e-5f, .015463f,
+				     -8.2773e-5f, 3660.f, 3670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3670.f, 3680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3680.f, 3690.f, .052016f, .2333f, .023008f,
-    -1.0429e-4f, .020466f, -1.014e-4f, 3690.f, 3700.f, .40077f, .43751f,
-    .015625f, -7.0109e-5f, .014974f, -7.3666e-5f, 3700.f, 3710.f, 2.1822f,
-    .57186f, .0083501f, -3.9798e-5f, .0081924f, -4.424e-5f, 3710.f, 3720.f,
-    6.6262f, .62697f, .0026483f, -1.7431e-5f, .0025461f, -2.1437e-5f,
-    3720.f, 3730.f, 11.503f, .6936f, -.001529f, -2.0568e-6f, -.0018176f,
-    -4.1926e-6f, 3730.f, 3740.f, 5.547f, .70735f, -.0036265f, 5.5723e-6f,
-    -.0039987f, 4.3869e-6f, 3740.f, 3750.f, 10.823f, .8515f, -.0028437f,
-    4.704e-6f, -.0029039f, 1.4795e-6f, 3750.f, 3760.f, 13.145f, .83989f,
-    2.3467e-4f, -7.519e-6f, 3.7066e-4f, -1.0406e-5f, 3760.f, 3770.f,
-    3.9192f, .87428f, .0073134f, -3.2311e-5f, .0084021f, -3.9596e-5f,
-    3770.f, 3780.f, .56238f, .59784f, .018114f, -8.3716e-5f, .016001f,
-    -8.226e-5f, 3780.f, 3790.f, 1.486f, .24352f, .011201f, -5.7941e-5f,
-    .0083855f, -5.3563e-5f, 3790.f, 3800.f, 5.7846f, .28312f, .0051402f,
-    -3.3968e-5f, .0020967f, -2.8941e-5f, 3800.f, 3810.f, 15.534f, .38502f,
-    2.6866e-4f, -1.3504e-5f, -.0010262f, -5.4149e-6f, 3810.f, 3820.f,
-    20.107f, .46654f, -.0028471f, 4.7046e-7f, -.0034091f, 7.0565e-6f,
-    3820.f, 3830.f, 9.6329f, .68399f, -.0033535f, 1.0816e-5f, -.0031945f,
-    9.1488e-6f, 3830.f, 3840.f, 28.782f, .76658f, -.0028915f, 1.4121e-6f,
-    -.0036898f, 2.7782e-6f, 3840.f, 3850.f, 22.068f, .72888f, .0013903f,
-    -1.6991e-5f, -3.5656e-4f, -1.6534e-5f, 3850.f, 3860.f, 4.1416f, 1.4182f,
-    .010989f, -5.3426e-5f, .0089392f, -5.1526e-5f, 3860.f, 3870.f, 1.386f,
-    1.0616f, .014465f, -7.035e-5f, .011642f, -6.6421e-5f, 3870.f, 3880.f,
-    .21981f, .827f, .023073f, -1.0318e-4f, .020793f, -1.0169e-4f, 3880.f,
-    3890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3890.f, 3900.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3900.f, 3910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3910.f, 3920.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3920.f, 3930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3930.f,
-    3940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3940.f, 3950.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3950.f, 3960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3960.f, 3970.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3970.f, 3980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3980.f,
-    3990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3990.f, 4e3f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4e3f, 4010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4010.f, 4020.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4020.f, 4030.f, .046381f, .22687f, .0024345f, -2.3816e-5f,
-    -7.0852e-4f, -1.7981e-5f, 4030.f, 4040.f, .11207f, .33988f, -.0013925f,
-    -8.515e-6f, -.0044315f, -2.7839e-6f, 4040.f, 4050.f, .26494f, .78086f,
-    7.5352e-4f, -1.0882e-5f, -.00225f, -8.0414e-6f, 4050.f, 4060.f, .52355f,
-    .95211f, -.003229f, -8.4991e-7f, -.0065316f, 5.7606e-6f, 4060.f, 4070.f,
-    .20288f, .51222f, -.0019356f, -5.8786e-6f, -.0049461f, -5.0049e-7f,
-    4070.f, 4080.f, .047528f, .22508f, .002968f, -2.5911e-5f, -1.9533e-4f,
-    -2.0081e-5f, 4080.f, 4090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4090.f, 4100.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4100.f, 4110.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4110.f, 4120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4120.f, 4130.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4130.f, 4140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4140.f,
-      4150.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4150.f, 4160.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4160.f, 4170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4170.f, 4180.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4180.f, 4190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4190.f,
-      4200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4200.f, 4210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4210.f, 4220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4220.f, 4230.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4230.f, 4240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4240.f,
-      4250.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4250.f, 4260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4260.f, 4270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4270.f, 4280.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4280.f, 4290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4290.f,
-      4300.f,
-    .010261f, .065002f, .0034485f, -2.8392e-5f, 1.7191e-4f, -2.183e-5f,
-    4300.f, 4310.f, .084185f, .33064f, 1.571e-4f, -1.4472e-5f, -.0028838f,
-    -8.9966e-6f, 4310.f, 4320.f, .11106f, .39358f, -.0032422f, -1.3748e-6f,
-    -.006363f, 4.8743e-6f, 4320.f, 4330.f, .58854f, 1.3088f, -9.7669e-4f,
-    7.0381e-7f, -.0031832f, 2.6227e-6f, 4330.f, 4340.f, .25725f, 1.0051f,
-    .006086f, 4.6822e-5f, .0059645f, 6.3569e-6f, 4340.f, 4350.f, .46043f,
-    1.0822f, .014451f, -3.4551e-5f, .010783f, -4.3114e-5f, 4350.f, 4360.f,
-    1.0879f, .79314f, .015344f, -7.4899e-5f, .012327f, -6.9661e-5f, 4360.f,
-    4370.f, 2.8336f, .83143f, .010372f, -5.4787e-5f, .0077026f, -5.1069e-5f,
-    4370.f, 4380.f, 5.6315f, .55232f, .0048246f, -3.1963e-5f, .0030343f,
-    -3.1434e-5f, 4380.f, 4390.f, 11.627f, .66242f, .0012226f, -1.4669e-5f,
-    9.6618e-4f, -1.906e-5f, 4390.f, 4400.f, 18.357f, .81274f, -.0015078f,
-    2.8307e-6f, 3.021e-4f, -3.645e-6f, 4400.f, 4410.f, 8.1517f, .53727f,
-    -.0041588f, 8.2656e-6f, -.0039017f, 1.9754e-5f, 4410.f, 4420.f, 21.947f,
-    .50379f, -.0036693f, 3.4765e-7f, -.0068581f, 6.819e-6f, 4420.f, 4430.f,
-    21.321f, .70812f, .0014866f, -1.5888e-5f, -7.1958e-4f, -1.5047e-5f,
-    4430.f, 4440.f, .76039f, .46213f, .015813f, -7.1293e-5f, .014807f,
-    -7.4172e-5f, 4440.f, 4450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4450.f, 4460.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4460.f, 4470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4470.f, 4480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4480.f, 4490.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4490.f, 4500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4500.f,
-      4510.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4510.f, 4520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4520.f, 4530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4530.f, 4540.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4540.f, 4550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4550.f,
-      4560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4560.f, 4570.f, .0027208f, .031363f,
-      .019608f,
-    -9.3071e-5f, .016446f, -8.6703e-5f, 4570.f, 4580.f, .075316f, .2673f,
-    .013852f, -6.7928e-5f, .01126f, -6.4664e-5f, 4580.f, 4590.f, .26478f,
-    .24916f, .0075261f, -4.3549e-5f, .0044923f, -3.8501e-5f, 4590.f, 4600.f,
-    .94057f, .32245f, .0019994f, -2.1568e-5f, -.0010356f, -1.639e-5f,
-    4600.f, 4610.f, 1.6283f, .34503f, -.002067f, -5.9246e-6f, -.0051076f,
-    -7.9763e-8f, 4610.f, 4620.f, 1.1361f, .39643f, -.0042841f, 2.5773e-6f,
-    -.007504f, 9.2053e-6f, 4620.f, 4630.f, 1.3595f, .42824f, -.0043267f,
-    2.7527e-6f, -.0075382f, 9.366e-6f, 4630.f, 4640.f, 2.345f, .5039f,
-    -.0013021f, -8.1896e-6f, -.0042803f, -3.1004e-6f, 4640.f, 4650.f,
-    .73444f, .57859f, .006112f, -3.3071e-5f, .0044533f, -3.3529e-5f, 4650.f,
-    4660.f, .038422f, .23935f, .02365f, -1.0589e-4f, .020573f, -1.0116e-4f,
-    4660.f, 4670.f, .16643f, .21059f, .017844f, -8.4429e-5f, .015076f,
-    -8.0351e-5f, 4670.f, 4680.f, .66361f, .33032f, .012376f, -5.9085e-5f,
-    .01164f, -5.974e-5f, 4680.f, 4690.f, 2.4086f, .4322f, .0069608f,
-    -3.6434e-5f, .0066271f, -3.8146e-5f, 4690.f, 4700.f, 5.7007f, .46363f,
-    .0024374f, -1.85e-5f, .0021804f, -2.0294e-5f, 4700.f, 4710.f, 11.243f,
-    .58097f, -.0013313f, -4.1463e-6f, -.001735f, -4.8882e-6f, 4710.f,
-    4720.f, 7.8568f, .66135f, -.0035465f, 4.3994e-6f, -.0041602f,
-    4.5248e-6f, 4720.f, 4730.f, 9.4234f, .73404f, -.0035684f, 4.612e-6f,
-    -.0040476f, 4.3652e-6f, 4730.f, 4740.f, 18.463f, 1.0659f, 1.1174e-6f,
-    -7.5689e-6f, -1.4938e-4f, -1.035e-5f, 4740.f, 4750.f, 2.9519f, .92577f,
-    .009335f, -4.0974e-5f, .010093f, -5.0109e-5f, 4750.f, 4760.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 4760.f, 4770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4770.f,
-    4780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4780.f, 4790.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4790.f, 4800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4800.f, 4810.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4810.f, 4820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4820.f,
-    4830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4830.f, 4840.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4840.f, 4850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4850.f, 4860.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4860.f, 4870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4870.f,
-    4880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4880.f, 4890.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4890.f, 4900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4900.f, 4910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4910.f, 4920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4920.f,
-    4930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4930.f, 4940.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4940.f, 4950.f, .057081f, .26504f, 2.1749e-4f, -1.4991e-5f,
-    -.0028657f, -9.2093e-6f, 4950.f, 4960.f, .089281f, .35365f, -.0029091f,
-    -2.6962e-6f, -.0059925f, 3.4121e-6f, 4960.f, 4970.f, .46911f, 1.1088f,
-    -.0015343f, -4.5097e-6f, -.0043859f, -9.5143e-7f, 4970.f, 4980.f,
-    .1858f, .71004f, 2.2264e-4f, 5.4082e-6f, -.0022981f, 3.4446e-7f, 4980.f,
-    4990.f, .30113f, .63162f, .0034248f, -2.4398e-5f, -2.019e-4f,
-    -1.8173e-5f, 4990.f, 5e3f, .54259f, .33048f, 1.4963e-4f, -1.4443e-5f,
-    -.0028875f, -8.9818e-6f, 5e3f, 5010.f, .69468f, .35696f, -.0031719f,
-    -1.6864e-6f, -.0062635f, 4.4718e-6f, 5010.f, 5020.f, .31258f, .41285f,
-    -.0047292f, 4.2957e-6f, -.0079123f, 1.0784e-5f, 5020.f, 5030.f, .9629f,
-    .50181f, -.0034905f, -3.0499e-7f, -.0066561f, 6.056e-6f, 5030.f, 5040.f,
-    .75559f, .535f, .0012181f, -1.6925e-5f, -.0015139f, -1.3577e-5f, 5040.f,
-    5050.f, .089652f, .35481f, .010413f, -5.3691e-5f, .0078717f,
-    -5.0854e-5f, 5050.f, 5060.f
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3680.f, 3690.f, .052016f, .2333f, .023008f,
+				     -1.0429e-4f, .020466f, -1.014e-4f, 3690.f, 3700.f, .40077f, .43751f,
+				     .015625f, -7.0109e-5f, .014974f, -7.3666e-5f, 3700.f, 3710.f, 2.1822f,
+				     .57186f, .0083501f, -3.9798e-5f, .0081924f, -4.424e-5f, 3710.f, 3720.f,
+				     6.6262f, .62697f, .0026483f, -1.7431e-5f, .0025461f, -2.1437e-5f,
+				     3720.f, 3730.f, 11.503f, .6936f, -.001529f, -2.0568e-6f, -.0018176f,
+				     -4.1926e-6f, 3730.f, 3740.f, 5.547f, .70735f, -.0036265f, 5.5723e-6f,
+				     -.0039987f, 4.3869e-6f, 3740.f, 3750.f, 10.823f, .8515f, -.0028437f,
+				     4.704e-6f, -.0029039f, 1.4795e-6f, 3750.f, 3760.f, 13.145f, .83989f,
+				     2.3467e-4f, -7.519e-6f, 3.7066e-4f, -1.0406e-5f, 3760.f, 3770.f,
+				     3.9192f, .87428f, .0073134f, -3.2311e-5f, .0084021f, -3.9596e-5f,
+				     3770.f, 3780.f, .56238f, .59784f, .018114f, -8.3716e-5f, .016001f,
+				     -8.226e-5f, 3780.f, 3790.f, 1.486f, .24352f, .011201f, -5.7941e-5f,
+				     .0083855f, -5.3563e-5f, 3790.f, 3800.f, 5.7846f, .28312f, .0051402f,
+				     -3.3968e-5f, .0020967f, -2.8941e-5f, 3800.f, 3810.f, 15.534f, .38502f,
+				     2.6866e-4f, -1.3504e-5f, -.0010262f, -5.4149e-6f, 3810.f, 3820.f,
+				     20.107f, .46654f, -.0028471f, 4.7046e-7f, -.0034091f, 7.0565e-6f,
+				     3820.f, 3830.f, 9.6329f, .68399f, -.0033535f, 1.0816e-5f, -.0031945f,
+				     9.1488e-6f, 3830.f, 3840.f, 28.782f, .76658f, -.0028915f, 1.4121e-6f,
+				     -.0036898f, 2.7782e-6f, 3840.f, 3850.f, 22.068f, .72888f, .0013903f,
+				     -1.6991e-5f, -3.5656e-4f, -1.6534e-5f, 3850.f, 3860.f, 4.1416f, 1.4182f,
+				     .010989f, -5.3426e-5f, .0089392f, -5.1526e-5f, 3860.f, 3870.f, 1.386f,
+				     1.0616f, .014465f, -7.035e-5f, .011642f, -6.6421e-5f, 3870.f, 3880.f,
+				     .21981f, .827f, .023073f, -1.0318e-4f, .020793f, -1.0169e-4f, 3880.f,
+				     3890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3890.f, 3900.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3900.f, 3910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3910.f, 3920.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3920.f, 3930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3930.f,
+				     3940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3940.f, 3950.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3950.f, 3960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3960.f, 3970.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3970.f, 3980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3980.f,
+				     3990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3990.f, 4e3f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4e3f, 4010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4010.f, 4020.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4020.f, 4030.f, .046381f, .22687f, .0024345f, -2.3816e-5f,
+				     -7.0852e-4f, -1.7981e-5f, 4030.f, 4040.f, .11207f, .33988f, -.0013925f,
+				     -8.515e-6f, -.0044315f, -2.7839e-6f, 4040.f, 4050.f, .26494f, .78086f,
+				     7.5352e-4f, -1.0882e-5f, -.00225f, -8.0414e-6f, 4050.f, 4060.f, .52355f,
+				     .95211f, -.003229f, -8.4991e-7f, -.0065316f, 5.7606e-6f, 4060.f, 4070.f,
+				     .20288f, .51222f, -.0019356f, -5.8786e-6f, -.0049461f, -5.0049e-7f,
+				     4070.f, 4080.f, .047528f, .22508f, .002968f, -2.5911e-5f, -1.9533e-4f,
+				     -2.0081e-5f, 4080.f, 4090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4090.f, 4100.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4100.f, 4110.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4110.f, 4120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4120.f, 4130.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4130.f, 4140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4140.f,
+				     4150.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4150.f, 4160.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4160.f, 4170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4170.f, 4180.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4180.f, 4190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4190.f,
+				     4200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4200.f, 4210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4210.f, 4220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4220.f, 4230.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4230.f, 4240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4240.f,
+				     4250.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4250.f, 4260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4260.f, 4270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4270.f, 4280.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4280.f, 4290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4290.f,
+				     4300.f,
+				     .010261f, .065002f, .0034485f, -2.8392e-5f, 1.7191e-4f, -2.183e-5f,
+				     4300.f, 4310.f, .084185f, .33064f, 1.571e-4f, -1.4472e-5f, -.0028838f,
+				     -8.9966e-6f, 4310.f, 4320.f, .11106f, .39358f, -.0032422f, -1.3748e-6f,
+				     -.006363f, 4.8743e-6f, 4320.f, 4330.f, .58854f, 1.3088f, -9.7669e-4f,
+				     7.0381e-7f, -.0031832f, 2.6227e-6f, 4330.f, 4340.f, .25725f, 1.0051f,
+				     .006086f, 4.6822e-5f, .0059645f, 6.3569e-6f, 4340.f, 4350.f, .46043f,
+				     1.0822f, .014451f, -3.4551e-5f, .010783f, -4.3114e-5f, 4350.f, 4360.f,
+				     1.0879f, .79314f, .015344f, -7.4899e-5f, .012327f, -6.9661e-5f, 4360.f,
+				     4370.f, 2.8336f, .83143f, .010372f, -5.4787e-5f, .0077026f, -5.1069e-5f,
+				     4370.f, 4380.f, 5.6315f, .55232f, .0048246f, -3.1963e-5f, .0030343f,
+				     -3.1434e-5f, 4380.f, 4390.f, 11.627f, .66242f, .0012226f, -1.4669e-5f,
+				     9.6618e-4f, -1.906e-5f, 4390.f, 4400.f, 18.357f, .81274f, -.0015078f,
+				     2.8307e-6f, 3.021e-4f, -3.645e-6f, 4400.f, 4410.f, 8.1517f, .53727f,
+				     -.0041588f, 8.2656e-6f, -.0039017f, 1.9754e-5f, 4410.f, 4420.f, 21.947f,
+				     .50379f, -.0036693f, 3.4765e-7f, -.0068581f, 6.819e-6f, 4420.f, 4430.f,
+				     21.321f, .70812f, .0014866f, -1.5888e-5f, -7.1958e-4f, -1.5047e-5f,
+				     4430.f, 4440.f, .76039f, .46213f, .015813f, -7.1293e-5f, .014807f,
+				     -7.4172e-5f, 4440.f, 4450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4450.f, 4460.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4460.f, 4470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4470.f, 4480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4480.f, 4490.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4490.f, 4500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4500.f,
+				     4510.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4510.f, 4520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4520.f, 4530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4530.f, 4540.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4540.f, 4550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4550.f,
+				     4560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4560.f, 4570.f, .0027208f, .031363f,
+				     .019608f,
+				     -9.3071e-5f, .016446f, -8.6703e-5f, 4570.f, 4580.f, .075316f, .2673f,
+				     .013852f, -6.7928e-5f, .01126f, -6.4664e-5f, 4580.f, 4590.f, .26478f,
+				     .24916f, .0075261f, -4.3549e-5f, .0044923f, -3.8501e-5f, 4590.f, 4600.f,
+				     .94057f, .32245f, .0019994f, -2.1568e-5f, -.0010356f, -1.639e-5f,
+				     4600.f, 4610.f, 1.6283f, .34503f, -.002067f, -5.9246e-6f, -.0051076f,
+				     -7.9763e-8f, 4610.f, 4620.f, 1.1361f, .39643f, -.0042841f, 2.5773e-6f,
+				     -.007504f, 9.2053e-6f, 4620.f, 4630.f, 1.3595f, .42824f, -.0043267f,
+				     2.7527e-6f, -.0075382f, 9.366e-6f, 4630.f, 4640.f, 2.345f, .5039f,
+				     -.0013021f, -8.1896e-6f, -.0042803f, -3.1004e-6f, 4640.f, 4650.f,
+				     .73444f, .57859f, .006112f, -3.3071e-5f, .0044533f, -3.3529e-5f, 4650.f,
+				     4660.f, .038422f, .23935f, .02365f, -1.0589e-4f, .020573f, -1.0116e-4f,
+				     4660.f, 4670.f, .16643f, .21059f, .017844f, -8.4429e-5f, .015076f,
+				     -8.0351e-5f, 4670.f, 4680.f, .66361f, .33032f, .012376f, -5.9085e-5f,
+				     .01164f, -5.974e-5f, 4680.f, 4690.f, 2.4086f, .4322f, .0069608f,
+				     -3.6434e-5f, .0066271f, -3.8146e-5f, 4690.f, 4700.f, 5.7007f, .46363f,
+				     .0024374f, -1.85e-5f, .0021804f, -2.0294e-5f, 4700.f, 4710.f, 11.243f,
+				     .58097f, -.0013313f, -4.1463e-6f, -.001735f, -4.8882e-6f, 4710.f,
+				     4720.f, 7.8568f, .66135f, -.0035465f, 4.3994e-6f, -.0041602f,
+				     4.5248e-6f, 4720.f, 4730.f, 9.4234f, .73404f, -.0035684f, 4.612e-6f,
+				     -.0040476f, 4.3652e-6f, 4730.f, 4740.f, 18.463f, 1.0659f, 1.1174e-6f,
+				     -7.5689e-6f, -1.4938e-4f, -1.035e-5f, 4740.f, 4750.f, 2.9519f, .92577f,
+				     .009335f, -4.0974e-5f, .010093f, -5.0109e-5f, 4750.f, 4760.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 4760.f, 4770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4770.f,
+				     4780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4780.f, 4790.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4790.f, 4800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4800.f, 4810.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4810.f, 4820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4820.f,
+				     4830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4830.f, 4840.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4840.f, 4850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4850.f, 4860.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4860.f, 4870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4870.f,
+				     4880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4880.f, 4890.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4890.f, 4900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4900.f, 4910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4910.f, 4920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4920.f,
+				     4930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4930.f, 4940.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4940.f, 4950.f, .057081f, .26504f, 2.1749e-4f, -1.4991e-5f,
+				     -.0028657f, -9.2093e-6f, 4950.f, 4960.f, .089281f, .35365f, -.0029091f,
+				     -2.6962e-6f, -.0059925f, 3.4121e-6f, 4960.f, 4970.f, .46911f, 1.1088f,
+				     -.0015343f, -4.5097e-6f, -.0043859f, -9.5143e-7f, 4970.f, 4980.f,
+				     .1858f, .71004f, 2.2264e-4f, 5.4082e-6f, -.0022981f, 3.4446e-7f, 4980.f,
+				     4990.f, .30113f, .63162f, .0034248f, -2.4398e-5f, -2.019e-4f,
+				     -1.8173e-5f, 4990.f, 5e3f, .54259f, .33048f, 1.4963e-4f, -1.4443e-5f,
+				     -.0028875f, -8.9818e-6f, 5e3f, 5010.f, .69468f, .35696f, -.0031719f,
+				     -1.6864e-6f, -.0062635f, 4.4718e-6f, 5010.f, 5020.f, .31258f, .41285f,
+				     -.0047292f, 4.2957e-6f, -.0079123f, 1.0784e-5f, 5020.f, 5030.f, .9629f,
+				     .50181f, -.0034905f, -3.0499e-7f, -.0066561f, 6.056e-6f, 5030.f, 5040.f,
+				     .75559f, .535f, .0012181f, -1.6925e-5f, -.0015139f, -1.3577e-5f, 5040.f,
+				     5050.f, .089652f, .35481f, .010413f, -5.3691e-5f, .0078717f,
+				     -5.0854e-5f, 5050.f, 5060.f
-	/* nitrous oxide (2500 - 5050 cm-1) */
+    /* nitrous oxide (2500 - 5050 cm-1) */
 }	/* niox1 */
@@ -5058,331 +5058,331 @@
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15360.f,
-    15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
-      15400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15440.f,
-    15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
-      15480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15360.f,
+				     15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
+				     15400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15440.f,
+				     15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
+				     15480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15520.f,
+				     15520.f,
-    15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
-      15560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15600.f,
-    15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
-      15640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15680.f,
-    15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15700.f, 15710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15710.f,
-      15720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15720.f, 15730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15730.f, 15740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15750.f, 15760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15760.f,
-    15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15780.f, 15790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15790.f,
-      15800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15800.f, 15810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15810.f, 15820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15820.f, 15830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15830.f, 15840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15840.f,
-    15850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15850.f, 15860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15860.f, 15870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15870.f,
-      15880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15880.f, 15890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15890.f, 15900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15900.f, 15910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15910.f, 15920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15920.f,
-    15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f, 15940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15950.f,
-      15960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f, 15990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.6e4f,
-    16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16030.f,
-      16040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f, 16070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16080.f,
-    16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16110.f,
-      16120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f, 16150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16160.f,
-    16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16190.f,
-      16200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f, 16230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16240.f,
-    16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16270.f,
-      16280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f, 16310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16320.f,
-    16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16350.f,
-      16360.f,
+				     15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
+				     15560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15600.f,
+				     15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
+				     15640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15680.f,
+				     15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15700.f, 15710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15710.f,
+				     15720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15720.f, 15730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15730.f, 15740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15750.f, 15760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15760.f,
+				     15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15780.f, 15790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15790.f,
+				     15800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15800.f, 15810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15810.f, 15820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15820.f, 15830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15830.f, 15840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15840.f,
+				     15850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15850.f, 15860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15860.f, 15870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15870.f,
+				     15880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15880.f, 15890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15890.f, 15900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15900.f, 15910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15910.f, 15920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15920.f,
+				     15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f, 15940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15950.f,
+				     15960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f, 15990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.6e4f,
+				     16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16030.f,
+				     16040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f, 16070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16080.f,
+				     16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16110.f,
+				     16120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f, 16150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16160.f,
+				     16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16190.f,
+				     16200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f, 16230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16240.f,
+				     16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16270.f,
+				     16280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f, 16310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16320.f,
+				     16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16350.f,
+				     16360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f, 16390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16400.f,
-    16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16430.f,
-      16440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f, 16470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16480.f,
-    16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16510.f,
-      16520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f, 16550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16560.f,
-    16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16590.f,
-      16600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f, 16630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16640.f,
-    16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16670.f,
-      16680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16700.f, 16710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16720.f,
-    16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16730.f, 16740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16750.f,
-      16760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f, 16770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16780.f, 16790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16800.f,
-    16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16810.f, 16820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16830.f,
-      16840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f, 16850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16860.f, 16870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16880.f,
-    16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16890.f, 16900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16910.f,
-      16920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f, 16930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16940.f, 16950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16960.f,
-    16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16970.f, 16980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16990.f, 1.7e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17020.f, 17030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17040.f,
-    17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17050.f, 17060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17070.f,
-      17080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f, 17090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17100.f, 17110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17120.f,
-    17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17130.f, 17140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17150.f,
-      17160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f, 17170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17180.f, 17190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17200.f,
-    17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17210.f, 17220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17230.f,
-      17240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f, 17250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17260.f, 17270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17280.f,
-    17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17290.f, 17300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17310.f,
-      17320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f, 17330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17340.f, 17350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17360.f,
-    17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17370.f, 17380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17390.f,
-      17400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f, 17410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17420.f, 17430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17440.f,
-    17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17450.f, 17460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17470.f,
-      17480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f, 17490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17500.f, 17510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17520.f,
-    17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17530.f, 17540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17550.f,
-      17560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f, 17570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f, 16390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16400.f,
+				     16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16430.f,
+				     16440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f, 16470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16480.f,
+				     16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16510.f,
+				     16520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f, 16550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16560.f,
+				     16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16590.f,
+				     16600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f, 16630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16640.f,
+				     16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16670.f,
+				     16680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16700.f, 16710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16720.f,
+				     16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16730.f, 16740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16750.f,
+				     16760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f, 16770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16780.f, 16790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16800.f,
+				     16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16810.f, 16820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16830.f,
+				     16840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f, 16850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16860.f, 16870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16880.f,
+				     16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16890.f, 16900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16910.f,
+				     16920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f, 16930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16940.f, 16950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16960.f,
+				     16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16970.f, 16980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16990.f, 1.7e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17020.f, 17030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17040.f,
+				     17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17050.f, 17060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17070.f,
+				     17080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f, 17090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17100.f, 17110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17120.f,
+				     17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17130.f, 17140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17150.f,
+				     17160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f, 17170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17180.f, 17190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17200.f,
+				     17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17210.f, 17220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17230.f,
+				     17240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f, 17250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17260.f, 17270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17280.f,
+				     17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17290.f, 17300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17310.f,
+				     17320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f, 17330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17340.f, 17350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17360.f,
+				     17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17370.f, 17380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17390.f,
+				     17400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f, 17410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17420.f, 17430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17440.f,
+				     17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17450.f, 17460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17470.f,
+				     17480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f, 17490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17500.f, 17510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17520.f,
+				     17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17530.f, 17540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17550.f,
+				     17560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f, 17570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17580.f, 17590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17600.f,
-    17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17610.f, 17620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17630.f,
-      17640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17680.f,
-    17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f,
-      17720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17760.f,
-    17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f,
-      17800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17840.f,
-    17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
+				     0.f,
+				     17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17580.f, 17590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17600.f,
+				     17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17610.f, 17620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17630.f,
+				     17640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17680.f,
+				     17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f,
+				     17720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17760.f,
+				     17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f,
+				     17800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17840.f,
+				     17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
-	/* methane (15300 - 17870 cm-1) */
+    /* methane (15300 - 17870 cm-1) */
 }	/* meth6 */
 void
@@ -5390,328 +5390,328 @@
-    0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12800.f,
-    12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
-      12840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12840.f, 12850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12850.f, 12860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12860.f, 12870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12880.f,
-    12890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12890.f, 12900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12900.f, 12910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12910.f,
-      12920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12920.f, 12930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12940.f, 12950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12960.f,
-    12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12970.f, 12980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12990.f, 1.3e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13020.f, 13030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13040.f,
-    13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13050.f, 13060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13070.f,
-      13080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f, 13090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13100.f, 13110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13120.f,
-    13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13130.f, 13140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13150.f,
-      13160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f, 13170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13180.f, 13190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13200.f,
-    13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13210.f, 13220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13230.f,
-      13240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f, 13250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13260.f, 13270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13280.f,
-    13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13290.f, 13300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13310.f,
-      13320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f, 13330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13340.f, 13350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13360.f,
-    13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13370.f, 13380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13390.f,
-      13400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f, 13410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13420.f, 13430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13440.f,
-    13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13450.f, 13460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13470.f,
-      13480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f, 13490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13500.f, 13510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13520.f,
-    13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13530.f, 13540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13550.f,
-      13560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f, 13570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13580.f, 13590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13600.f,
-    13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13610.f, 13620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13630.f,
-      13640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f, 13650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13660.f, 13670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13680.f,
-    13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13690.f, 13700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13710.f,
-      13720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f, 13730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13740.f, 13750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13760.f,
-    13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13770.f, 13780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13790.f,
-      13800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f, 13810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13820.f, 13830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13840.f,
-    13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13850.f, 13860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13870.f,
-      13880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f, 13890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
+				     0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12800.f,
+				     12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
+				     12840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12840.f, 12850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12850.f, 12860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12860.f, 12870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12880.f,
+				     12890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12890.f, 12900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12900.f, 12910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12910.f,
+				     12920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12920.f, 12930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12940.f, 12950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12960.f,
+				     12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12970.f, 12980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12990.f, 1.3e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13020.f, 13030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13040.f,
+				     13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13050.f, 13060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13070.f,
+				     13080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f, 13090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13100.f, 13110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13120.f,
+				     13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13130.f, 13140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13150.f,
+				     13160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f, 13170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13180.f, 13190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13200.f,
+				     13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13210.f, 13220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13230.f,
+				     13240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f, 13250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13260.f, 13270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13280.f,
+				     13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13290.f, 13300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13310.f,
+				     13320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f, 13330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13340.f, 13350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13360.f,
+				     13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13370.f, 13380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13390.f,
+				     13400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f, 13410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13420.f, 13430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13440.f,
+				     13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13450.f, 13460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13470.f,
+				     13480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f, 13490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13500.f, 13510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13520.f,
+				     13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13530.f, 13540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13550.f,
+				     13560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f, 13570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13580.f, 13590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13600.f,
+				     13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13610.f, 13620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13630.f,
+				     13640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f, 13650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13660.f, 13670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13680.f,
+				     13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13690.f, 13700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13710.f,
+				     13720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f, 13730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13740.f, 13750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13760.f,
+				     13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13770.f, 13780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13790.f,
+				     13800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f, 13810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13820.f, 13830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13840.f,
+				     13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13850.f, 13860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13870.f,
+				     13880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f, 13890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
-    13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13900.f, 13910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13920.f,
-    13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13930.f, 13940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13950.f,
-      13960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f, 13970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13980.f, 13990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.4e4f,
-    14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14010.f, 14020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14030.f,
-      14040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f, 14050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14060.f, 14070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14080.f,
-    14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14090.f, 14100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14110.f,
-      14120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f, 14130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14140.f, 14150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14160.f,
-    14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14170.f, 14180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14190.f,
-      14200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f, 14210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14220.f, 14230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14240.f,
-    14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14250.f, 14260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14270.f,
-      14280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f, 14290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14300.f, 14310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14320.f,
-    14330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14330.f, 14340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14350.f,
-      14360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14360.f, 14370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14370.f, 14380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14380.f, 14390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14390.f, 14400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14400.f,
-    14410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14410.f, 14420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14420.f, 14430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14430.f,
-      14440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14440.f, 14450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14450.f, 14460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14460.f, 14470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14470.f, 14480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14480.f,
-    14490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14490.f, 14500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14500.f, 14510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14510.f,
-      14520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f, 14530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f, 14550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14560.f,
-    14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
-      14600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14640.f,
-    14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
-      14680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14720.f,
+				     13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13900.f, 13910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13920.f,
+				     13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13930.f, 13940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13950.f,
+				     13960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f, 13970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13980.f, 13990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.4e4f,
+				     14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14010.f, 14020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14030.f,
+				     14040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f, 14050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14060.f, 14070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14080.f,
+				     14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14090.f, 14100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14110.f,
+				     14120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f, 14130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14140.f, 14150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14160.f,
+				     14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14170.f, 14180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14190.f,
+				     14200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f, 14210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14220.f, 14230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14240.f,
+				     14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14250.f, 14260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14270.f,
+				     14280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f, 14290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14300.f, 14310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14320.f,
+				     14330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14330.f, 14340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14350.f,
+				     14360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14360.f, 14370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14370.f, 14380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14380.f, 14390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14390.f, 14400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14400.f,
+				     14410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14410.f, 14420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14420.f, 14430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14430.f,
+				     14440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14440.f, 14450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14450.f, 14460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14460.f, 14470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14470.f, 14480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14480.f,
+				     14490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14490.f, 14500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14500.f, 14510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14510.f,
+				     14520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f, 14530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f, 14550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14560.f,
+				     14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
+				     14600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14640.f,
+				     14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
+				     14680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14720.f,
-    14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
-      14760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14800.f,
-    14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
-      14840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14880.f,
-    14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
-      14920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14960.f,
-    14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15040.f,
-    15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
-      15080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15120.f,
-    15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
-      15160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15200.f,
-    15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
-      15240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15280.f,
-    15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
+				     14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
+				     14760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14800.f,
+				     14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
+				     14840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14880.f,
+				     14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
+				     14920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14960.f,
+				     14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15040.f,
+				     15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
+				     15080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15120.f,
+				     15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
+				     15160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15200.f,
+				     15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
+				     15240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15280.f,
+				     15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
-	/* methane (12740 - 15290 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* methane (12740 - 15290 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* meth5 */
 void
@@ -5719,329 +5719,329 @@
-    0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
-      0.f,
+				     0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
+				     0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10240.f,
-    10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
-      10280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10320.f,
-    10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
-      10360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10400.f,
-    10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
-      10440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10480.f,
-    10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
-      10520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10560.f,
-    10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
-      10600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10640.f,
-    10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
-      10680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10720.f,
-    10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
-      10760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10800.f,
-    10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
-      10840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10880.f,
-    10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
-      10920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10960.f,
-    10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11040.f,
-    11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
-      11080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11120.f,
-    11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
-      0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10240.f,
+				     10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
+				     10280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10320.f,
+				     10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
+				     10360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10400.f,
+				     10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
+				     10440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10480.f,
+				     10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
+				     10520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10560.f,
+				     10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
+				     10600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10640.f,
+				     10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
+				     10680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10720.f,
+				     10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
+				     10760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10800.f,
+				     10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
+				     10840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10880.f,
+				     10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
+				     10920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10960.f,
+				     10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11040.f,
+				     11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
+				     11080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11120.f,
+				     11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
+				     0.f,
-    0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
-      11160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11200.f,
-    11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
-      11240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11280.f,
-    11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
-      11320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11360.f,
-    11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
-      11400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11440.f,
-    11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
-      11480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11490.f, 11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11510.f, 11520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11520.f,
-    11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11530.f, 11540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11540.f, 11550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11550.f,
-      11560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11560.f, 11570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11570.f, 11580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11580.f, 11590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11600.f,
-    11610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11610.f, 11620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11620.f, 11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f,
-      11640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11650.f, 11660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11680.f,
-    11690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11700.f, 11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f,
-      11720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11730.f, 11740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11760.f,
-    11770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11780.f, 11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f,
-      11800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11810.f, 11820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11840.f,
-    11850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11860.f, 11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f,
-      11880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11890.f, 11900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11920.f,
-    11930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11940.f, 11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f,
-      11960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11970.f, 11980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f,
-    12010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12020.f, 12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f,
-      12040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12050.f, 12060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12080.f,
-    12090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12100.f, 12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f,
-      12120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12130.f, 12140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12160.f,
-    12170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12180.f, 12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f,
-      12200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12210.f, 12220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12240.f,
-    12250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12260.f, 12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f,
-      12280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12290.f, 12300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12320.f,
-    12330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12340.f, 12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f,
-      12360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12370.f, 12380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12400.f,
-    12410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12420.f, 12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f,
-      12440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12450.f, 12460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12480.f,
-    12490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12500.f, 12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f,
-      12520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12530.f, 12540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12560.f,
-    12570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12580.f, 12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f,
-      12600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12610.f, 12620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12640.f,
-    12650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12660.f, 12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f,
-      12680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12690.f, 12700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12720.f,
-    12730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
+				     0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
+				     11160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11200.f,
+				     11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
+				     11240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11280.f,
+				     11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
+				     11320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11360.f,
+				     11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
+				     11400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11440.f,
+				     11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
+				     11480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11490.f, 11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11510.f, 11520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11520.f,
+				     11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11530.f, 11540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11540.f, 11550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11550.f,
+				     11560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11560.f, 11570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11570.f, 11580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11580.f, 11590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11600.f,
+				     11610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11610.f, 11620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11620.f, 11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f,
+				     11640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11650.f, 11660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11680.f,
+				     11690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11700.f, 11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f,
+				     11720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11730.f, 11740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11760.f,
+				     11770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11780.f, 11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f,
+				     11800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11810.f, 11820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11840.f,
+				     11850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11860.f, 11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f,
+				     11880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11890.f, 11900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11920.f,
+				     11930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11940.f, 11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f,
+				     11960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11970.f, 11980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f,
+				     12010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12020.f, 12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f,
+				     12040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12050.f, 12060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12080.f,
+				     12090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12100.f, 12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f,
+				     12120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12130.f, 12140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12160.f,
+				     12170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12180.f, 12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f,
+				     12200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12210.f, 12220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12240.f,
+				     12250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12260.f, 12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f,
+				     12280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12290.f, 12300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12320.f,
+				     12330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12340.f, 12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f,
+				     12360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12370.f, 12380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12400.f,
+				     12410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12420.f, 12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f,
+				     12440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12450.f, 12460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12480.f,
+				     12490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12500.f, 12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f,
+				     12520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12530.f, 12540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12560.f,
+				     12570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12580.f, 12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f,
+				     12600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12610.f, 12620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12640.f,
+				     12650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12660.f, 12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f,
+				     12680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12690.f, 12700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12720.f,
+				     12730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
-	/* methane (10180 - 12730 cm-1) */
+    /* methane (10180 - 12730 cm-1) */
 }	/* meth4 */
 void
@@ -6049,293 +6049,293 @@
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
-    7660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f, 7690.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7690.f, 7700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7700.f,
-    7710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7710.f, 7720.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7720.f, 7730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7730.f, 7740.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7740.f, 7750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7750.f,
-    7760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7760.f, 7770.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7780.f, 7790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7800.f,
-    7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f, 7840.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7850.f,
-    7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f, 7890.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7890.f, 7900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7900.f,
-    7910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7910.f, 7920.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7920.f, 7930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7930.f, 7940.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7940.f, 7950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7950.f,
-    7960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7960.f, 7970.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7970.f, 7980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7980.f, 7990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f,
-      8010.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8020.f, 8030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8030.f, 8040.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8040.f, 8050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8050.f,
-      8060.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8060.f, 8070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8070.f, 8080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8080.f, 8090.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8090.f, 8100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8100.f,
-      8110.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8110.f, 8120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8120.f, 8130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8130.f, 8140.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8140.f, 8150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8150.f,
-      8160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8160.f, 8170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8170.f, 8180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8180.f, 8190.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8190.f, 8200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8200.f,
-      8210.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8210.f, 8220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8220.f, 8230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8230.f, 8240.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8240.f, 8250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8250.f,
-      8260.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8260.f, 8270.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8270.f, 8280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8280.f, 8290.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8290.f, 8300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8300.f,
-      8310.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8320.f, 8330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8340.f, 8350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f,
-      8360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8370.f, 8380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8390.f, 8400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f,
-      8410.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8420.f, 8430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8440.f, 8450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f,
-      8460.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8470.f, 8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f,
-      8510.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8520.f, 8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f,
-      8560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8570.f, 8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f,
-      8610.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8620.f, 8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f,
-      8660.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8670.f, 8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f,
-      8710.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8720.f, 8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f,
-      8760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8770.f, 8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f,
-      8810.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8820.f, 8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f,
-      8860.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8870.f, 8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f,
-      0.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
+				     7660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f, 7690.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7690.f, 7700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7700.f,
+				     7710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7710.f, 7720.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7720.f, 7730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7730.f, 7740.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7740.f, 7750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7750.f,
+				     7760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7760.f, 7770.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7780.f, 7790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7800.f,
+				     7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f, 7840.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7850.f,
+				     7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f, 7890.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7890.f, 7900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7900.f,
+				     7910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7910.f, 7920.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7920.f, 7930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7930.f, 7940.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7940.f, 7950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7950.f,
+				     7960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7960.f, 7970.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7970.f, 7980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7980.f, 7990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f,
+				     8010.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8020.f, 8030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8030.f, 8040.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8040.f, 8050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8050.f,
+				     8060.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8060.f, 8070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8070.f, 8080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8080.f, 8090.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8090.f, 8100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8100.f,
+				     8110.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8110.f, 8120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8120.f, 8130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8130.f, 8140.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8140.f, 8150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8150.f,
+				     8160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8160.f, 8170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8170.f, 8180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8180.f, 8190.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8190.f, 8200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8200.f,
+				     8210.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8210.f, 8220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8220.f, 8230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8230.f, 8240.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8240.f, 8250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8250.f,
+				     8260.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8260.f, 8270.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8270.f, 8280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8280.f, 8290.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8290.f, 8300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8300.f,
+				     8310.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8320.f, 8330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8340.f, 8350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f,
+				     8360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8370.f, 8380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8390.f, 8400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f,
+				     8410.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8420.f, 8430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8440.f, 8450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f,
+				     8460.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8470.f, 8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f,
+				     8510.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8520.f, 8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f,
+				     8560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8570.f, 8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f,
+				     8610.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8620.f, 8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f,
+				     8660.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8670.f, 8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f,
+				     8710.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8720.f, 8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f,
+				     8760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8770.f, 8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f,
+				     8810.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8820.f, 8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f,
+				     8860.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8870.f, 8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f,
+				     0.f,
-    0.f, 0.f, 0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f,
-      8910.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8920.f, 8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f,
-      8960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8970.f, 8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f,
-      0.f,
+				     0.f, 0.f, 0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f,
+				     8910.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8920.f, 8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f,
+				     8960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8970.f, 8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f,
+				     0.f,
-    0.f, 0.f, 0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      9020.f,
-    9030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
-    9080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
-    9130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
-    9180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
-    9230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
-    9280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
-    9330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9340.f, 9350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9350.f, 9360.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9360.f, 9370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9370.f,
-    9380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9390.f, 9400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9400.f, 9410.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9410.f, 9420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f,
-    9430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9440.f, 9450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9450.f, 9460.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f,
-    9480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
-    9530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
-    9580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
-    9630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
-    9680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
-    9730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
-    9780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
-    9830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
-    9880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
-    9930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
-    9980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
-    10030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f,
-      10060.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10070.f, 10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10100.f,
-    10110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f,
-      10140.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10150.f, 10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10170.f, 10180.f
+				     0.f, 0.f, 0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     9020.f,
+				     9030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
+				     9080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
+				     9130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
+				     9180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
+				     9230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
+				     9280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
+				     9330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9340.f, 9350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9350.f, 9360.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9360.f, 9370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9370.f,
+				     9380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9390.f, 9400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9400.f, 9410.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9410.f, 9420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f,
+				     9430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9440.f, 9450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9450.f, 9460.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f,
+				     9480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
+				     9530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
+				     9580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
+				     9630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
+				     9680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
+				     9730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
+				     9780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
+				     9830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
+				     9880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
+				     9930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
+				     9980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
+				     10030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f,
+				     10060.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10070.f, 10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10100.f,
+				     10110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f,
+				     10140.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10150.f, 10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10170.f, 10180.f
-	/* methane (7620 - 10170 cm-1) */
+    /* methane (7620 - 10170 cm-1) */
 }	/* meth3 */
 void
@@ -6343,293 +6343,293 @@
-    0.f, 5060.f, 5070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5070.f, 5080.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5080.f, 5090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5090.f,
-    5100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5100.f, 5110.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5110.f, 5120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5120.f, 5130.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5130.f, 5140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5140.f,
-    5150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5150.f, 5160.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5160.f, 5170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5170.f, 5180.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5180.f, 5190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5190.f,
-    5200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5200.f, 5210.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5210.f, 5220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5220.f, 5230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5230.f, 5240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5240.f,
-    5250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5250.f, 5260.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5260.f, 5270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5270.f, 5280.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5280.f, 5290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5290.f,
-    5300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5300.f, 5310.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5310.f, 5320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5320.f, 5330.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5330.f, 5340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5340.f,
-    5350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5350.f, 5360.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5360.f, 5370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5370.f, 5380.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5380.f, 5390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5390.f,
-    5400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5400.f, 5410.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5410.f, 5420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5420.f, 5430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5430.f, 5440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5440.f,
-    5450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5450.f, 5460.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5460.f, 5470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5470.f, 5480.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5480.f, 5490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5490.f,
-    5500.f, .50197f, .25265f, .0033519f, -2.4607e-5f, 6.8955e-4f,
-    -2.0482e-5f, 5500.f, 5510.f, 2.3899f, .60596f, 2.7671e-5f, -1.2307e-5f,
-    -.0033058f, -5.2945e-6f, 5510.f, 5520.f, 2.4379f, .30699f, -6.0867e-4f,
-    -9.0704e-6f, -.0032892f, -5.0115e-6f, 5520.f, 5530.f, 2.1592f, .38949f,
-    -.0023556f, -3.3022e-6f, -.0052838f, 2.4513e-6f, 5530.f, 5540.f,
-    2.3029f, .15736f, -.0035795f, 2.1673e-6f, -.005968f, 6.0863e-6f, 5540.f,
-    5550.f, 1.954f, .11711f, -.0044087f, 5.103e-6f, -.0068665f, 9.1701e-6f,
-    5550.f, 5560.f, 1.195f, .29396f, -.0010618f, 3.4067e-6f, -.0024231f,
-    -2.582e-6f, 5560.f, 5570.f, 4.8095f, 1.2465f, .0019344f, -1.5456e-5f,
-    -6.8788e-4f, -1.287e-5f, 5570.f, 5580.f, 11.674f, 1.5114f, -.0025504f,
-    8.25e-7f, -.0045912f, 2.2777e-6f, 5580.f, 5590.f, 2.3702f, .84024f,
-    -8.2688e-4f, 2.9123e-6f, -.0020134f, -5.0547e-6f, 5590.f, 5600.f,
-    3.4064f, 1.1326f, -.0025002f, 8.9997e-7f, -.0048837f, 2.6082e-6f,
-    5600.f, 5610.f, 1.7392f, .31991f, -.0045126f, 8.6603e-6f, -.0061278f,
-    9.3747e-6f, 5610.f, 5620.f, 4.348f, .58786f, -.0043137f, 4.6334e-6f,
-    -.0070133f, 9.529e-6f, 5620.f, 5630.f, 6.6586f, 1.8023f, -.0019866f,
-    -1.5163e-6f, -.0039533f, -8.5993e-7f, 5630.f, 5640.f, 4.3959f, .91267f,
-    -.0018359f, -2.6379e-6f, -.0045115f, 1.3137e-6f, 5640.f, 5650.f,
-    2.9732f, .90097f, -4.5783e-4f, -8.654e-6f, -.0035958f, -2.8318e-6f,
-    5650.f, 5660.f, 2.7758f, .82876f, .0019221f, -1.4165e-5f, -.0010447f,
-    -1.1375e-5f, 5660.f, 5670.f, 1.4345f, .92016f, .0046313f, -1.9911e-5f,
-    .0018272f, -2.0246e-5f, 5670.f, 5680.f, 1.0486f, .4465f, -3.8086e-4f,
-    5.6985e-6f, -.0018929f, -1.1857e-6f, 5680.f, 5690.f, .94797f, .35596f,
-    -2.2904e-4f, 8.4588e-6f, -.0016889f, -3.7956e-7f, 5690.f, 5700.f,
-    .93528f, .41431f, .00128f, -8.7918e-7f, -.0014444f, -4.7052e-6f, 5700.f,
-    5710.f, 1.6454f, .57474f, .0026463f, -1.3124e-5f, -3.7027e-4f,
-    -1.2452e-5f, 5710.f, 5720.f, 2.0351f, .34637f, .0026986f, -1.9613e-5f,
-    -4.6781e-4f, -1.4709e-5f, 5720.f, 5730.f, 2.2445f, .69714f, .0019373f,
-    -1.6752e-5f, -8.5242e-4f, -1.2956e-5f, 5730.f, 5740.f, 3.2153f, .75956f,
+				     0.f, 5060.f, 5070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5070.f, 5080.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5080.f, 5090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5090.f,
+				     5100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5100.f, 5110.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5110.f, 5120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5120.f, 5130.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5130.f, 5140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5140.f,
+				     5150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5150.f, 5160.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5160.f, 5170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5170.f, 5180.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5180.f, 5190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5190.f,
+				     5200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5200.f, 5210.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5210.f, 5220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5220.f, 5230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5230.f, 5240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5240.f,
+				     5250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5250.f, 5260.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5260.f, 5270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5270.f, 5280.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5280.f, 5290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5290.f,
+				     5300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5300.f, 5310.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5310.f, 5320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5320.f, 5330.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5330.f, 5340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5340.f,
+				     5350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5350.f, 5360.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5360.f, 5370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5370.f, 5380.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5380.f, 5390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5390.f,
+				     5400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5400.f, 5410.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5410.f, 5420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5420.f, 5430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5430.f, 5440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5440.f,
+				     5450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5450.f, 5460.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5460.f, 5470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5470.f, 5480.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5480.f, 5490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5490.f,
+				     5500.f, .50197f, .25265f, .0033519f, -2.4607e-5f, 6.8955e-4f,
+				     -2.0482e-5f, 5500.f, 5510.f, 2.3899f, .60596f, 2.7671e-5f, -1.2307e-5f,
+				     -.0033058f, -5.2945e-6f, 5510.f, 5520.f, 2.4379f, .30699f, -6.0867e-4f,
+				     -9.0704e-6f, -.0032892f, -5.0115e-6f, 5520.f, 5530.f, 2.1592f, .38949f,
+				     -.0023556f, -3.3022e-6f, -.0052838f, 2.4513e-6f, 5530.f, 5540.f,
+				     2.3029f, .15736f, -.0035795f, 2.1673e-6f, -.005968f, 6.0863e-6f, 5540.f,
+				     5550.f, 1.954f, .11711f, -.0044087f, 5.103e-6f, -.0068665f, 9.1701e-6f,
+				     5550.f, 5560.f, 1.195f, .29396f, -.0010618f, 3.4067e-6f, -.0024231f,
+				     -2.582e-6f, 5560.f, 5570.f, 4.8095f, 1.2465f, .0019344f, -1.5456e-5f,
+				     -6.8788e-4f, -1.287e-5f, 5570.f, 5580.f, 11.674f, 1.5114f, -.0025504f,
+				     8.25e-7f, -.0045912f, 2.2777e-6f, 5580.f, 5590.f, 2.3702f, .84024f,
+				     -8.2688e-4f, 2.9123e-6f, -.0020134f, -5.0547e-6f, 5590.f, 5600.f,
+				     3.4064f, 1.1326f, -.0025002f, 8.9997e-7f, -.0048837f, 2.6082e-6f,
+				     5600.f, 5610.f, 1.7392f, .31991f, -.0045126f, 8.6603e-6f, -.0061278f,
+				     9.3747e-6f, 5610.f, 5620.f, 4.348f, .58786f, -.0043137f, 4.6334e-6f,
+				     -.0070133f, 9.529e-6f, 5620.f, 5630.f, 6.6586f, 1.8023f, -.0019866f,
+				     -1.5163e-6f, -.0039533f, -8.5993e-7f, 5630.f, 5640.f, 4.3959f, .91267f,
+				     -.0018359f, -2.6379e-6f, -.0045115f, 1.3137e-6f, 5640.f, 5650.f,
+				     2.9732f, .90097f, -4.5783e-4f, -8.654e-6f, -.0035958f, -2.8318e-6f,
+				     5650.f, 5660.f, 2.7758f, .82876f, .0019221f, -1.4165e-5f, -.0010447f,
+				     -1.1375e-5f, 5660.f, 5670.f, 1.4345f, .92016f, .0046313f, -1.9911e-5f,
+				     .0018272f, -2.0246e-5f, 5670.f, 5680.f, 1.0486f, .4465f, -3.8086e-4f,
+				     5.6985e-6f, -.0018929f, -1.1857e-6f, 5680.f, 5690.f, .94797f, .35596f,
+				     -2.2904e-4f, 8.4588e-6f, -.0016889f, -3.7956e-7f, 5690.f, 5700.f,
+				     .93528f, .41431f, .00128f, -8.7918e-7f, -.0014444f, -4.7052e-6f, 5700.f,
+				     5710.f, 1.6454f, .57474f, .0026463f, -1.3124e-5f, -3.7027e-4f,
+				     -1.2452e-5f, 5710.f, 5720.f, 2.0351f, .34637f, .0026986f, -1.9613e-5f,
+				     -4.6781e-4f, -1.4709e-5f, 5720.f, 5730.f, 2.2445f, .69714f, .0019373f,
+				     -1.6752e-5f, -8.5242e-4f, -1.2956e-5f, 5730.f, 5740.f, 3.2153f, .75956f,
-    .0013362f, -1.4189e-5f, -.0010894f, -1.1571e-5f, 5740.f, 5750.f,
-    3.4596f, .73536f, .0012876f, -1.2547e-5f, -4.537e-4f, -1.2912e-5f,
-    5750.f, 5760.f, 4.9414f, 1.0526f, 6.4547e-4f, -1.0024e-5f, -9.6857e-4f,
-    -1.1592e-5f, 5760.f, 5770.f, 7.5119f, 1.41f, 2.8819e-4f, -7.444e-6f,
-    -.0012786f, -1.0307e-5f, 5770.f, 5780.f, 7.5235f, 1.323f, -4.9407e-4f,
-    -6.8773e-6f, -.002629f, -6.638e-6f, 5780.f, 5790.f, 10.241f, 1.6323f,
-    -.0013776f, -5.3214e-6f, -.0037904f, -2.3185e-6f, 5790.f, 5800.f,
-    9.1281f, .93597f, -.0035876f, 2.3809e-6f, -.0059879f, 5.9495e-6f,
-    5800.f, 5810.f, 3.9872f, .6767f, -.0044503f, 6.8501e-6f, -.0067178f,
-    9.7535e-6f, 5810.f, 5820.f, 2.9318f, .24918f, -.0051233f, 7.7265e-6f,
-    -.0076555f, 1.1663e-5f, 5820.f, 5830.f, 3.6596f, .91227f, -.0026988f,
-    2.3063e-6f, -.0047124f, 2.5366e-6f, 5830.f, 5840.f, 6.9904f, .93296f,
-    -.0037966f, 6.1051e-6f, -.0055025f, 7.3047e-6f, 5840.f, 5850.f, 12.815f,
-    1.9354f, -.0021432f, 8.1298e-7f, -.0042246f, 2.2902e-6f, 5850.f, 5860.f,
-    10.246f, 2.1238f, 4.6316e-5f, -6.0726e-6f, -.00223f, -5.3836e-6f,
-    5860.f, 5870.f, 9.5647f, 1.9821f, .0012796f, -7.4626e-6f, -9.2616e-4f,
-    -1.0886e-5f, 5870.f, 5880.f, 4.8776f, 1.7308f, .0012461f, -8.1397e-6f,
-    -5.6127e-5f, -1.3882e-5f, 5880.f, 5890.f, 5.7337f, .87446f, .0038286f,
-    -1.704e-5f, 6.941e-4f, -1.573e-5f, 5890.f, 5900.f, 7.472f, .73641f,
-    .0028865f, -2.0558e-5f, -6.6892e-4f, -1.358e-5f, 5900.f, 5910.f,
-    7.0944f, .66112f, .0024095f, -2.1458e-5f, -9.9935e-4f, -1.3636e-5f,
-    5910.f, 5920.f, 8.1168f, .58477f, .0013314f, -1.7142e-5f, -.0010021f,
-    -1.3588e-5f, 5920.f, 5930.f, 10.972f, .47138f, -3.0541e-4f, -9.6826e-6f,
-    -.0014478f, -9.657e-6f, 5930.f, 5940.f, 7.3055f, .38828f, -.0015833f,
-    -3.9472e-6f, -.0024534f, -5.2105e-6f, 5940.f, 5950.f, .18257f, .15141f,
-    .0032545f, -2.5286e-5f, 3.2305e-4f, -1.9965e-5f, 5950.f, 5960.f, 8.803f,
-    .28605f, -.0031163f, 1.3762e-6f, -.0040606f, 1.0755e-6f, 5960.f, 5970.f,
-    6.8729f, .20493f, -.0040682f, 5.468e-6f, -.004767f, 4.3804e-6f, 5970.f,
-    5980.f, 2.9955f, .47987f, -.002474f, 9.9034e-6f, -8.4087e-4f,
-    -7.5046e-6f, 5980.f, 5990.f, 14.364f, 1.4135f, .0066597f, -3.1277e-5f,
-    .0045742f, -3.1988e-5f, 5990.f, 6e3f, 65.167f, .97529f, -.0019616f,
-    -2.2633e-6f, -.0046527f, 1.0271e-6f, 6e3f, 6010.f, 3.5647f, .20344f,
-    -.0052252f, 1.0688e-5f, -.0057674f, 8.0346e-6f, 6010.f, 6020.f, 3.4141f,
-    .14357f, -.0054304f, 9.5186e-6f, -.0072736f, 1.143e-5f, 6020.f, 6030.f,
-    7.635f, .4332f, -.0031157f, 1.3276e-5f, -.001277f, 1.7678e-7f, 6030.f,
-    6040.f, 16.118f, .28374f, -.0041664f, 4.9599e-6f, -.0056931f,
-    5.7765e-6f, 6040.f, 6050.f, 19.177f, .33833f, -.0035167f, 1.7094e-6f,
-    -.0061198f, 6.6957e-6f, 6050.f, 6060.f, 16.85f, .88879f, -.002146f,
-    -3.2028e-6f, -.0042847f, 2.7277e-7f, 6060.f, 6070.f, 21.077f, .25352f,
-    -9.3983e-4f, -9.0824e-6f, -.0038178f, -2.813e-6f, 6070.f, 6080.f,
-    14.763f, .2437f, 5.8706e-4f, -1.4814e-5f, -.0030455f, -5.893e-6f,
-    6080.f, 6090.f, 12.16f, .31237f, .002521f, -2.1431e-5f, -.0011996f,
-    -1.1964e-5f, 6090.f, 6100.f, 10.601f, .42935f, .0043443f, -2.7697e-5f,
-    3.1712e-4f, -1.7641e-5f, 6100.f, 6110.f, 7.7832f, .54373f, .0057906f,
-    -2.6532e-5f, .001438f, -1.9125e-5f, 6110.f, 6120.f, 5.7902f, 1.1869f,
-    .0054008f, -1.8503e-5f, .0023381f, -2.0741e-5f, 6120.f, 6130.f, 4.0292f,
-    .58128f, .0079694f, -2.4981e-5f, .0032731f, -2.2237e-5f, 6130.f, 6140.f,
-    3.0446f, .82071f, .0077456f, -1.3929e-5f, .0053212f, -2.5965e-5f,
-    6140.f, 6150.f, 1.9431f, .98831f, .006064f, -2.2019e-5f, .0032998f,
-    -2.4905e-5f, 6150.f, 6160.f, .97862f, .77724f, .0073198f, -3.3144e-5f,
-    .0043341f, -3.23e-5f, 6160.f, 6170.f, .41035f, .31003f, .0044331f,
-    -2.7381e-5f, .0019194f, -2.471e-5f, 6170.f, 6180.f, .19122f, .12211f,
-    .0046368f, -3.0314e-5f, .0017315f, -2.5376e-5f, 6180.f, 6190.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 6190.f, 6200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6200.f,
-    6210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6210.f, 6220.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6220.f, 6230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6230.f, 6240.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6240.f, 6250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6250.f,
-    6260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6260.f, 6270.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6270.f, 6280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6280.f, 6290.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6290.f, 6300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6300.f,
-    6310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6310.f, 6320.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6320.f, 6330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6330.f, 6340.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6340.f, 6350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6350.f,
-    6360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6360.f, 6370.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6370.f, 6380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6380.f, 6390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6390.f, 6400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6400.f,
-    6410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6410.f, 6420.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f, 6440.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6440.f, 6450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6450.f,
-    6460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6460.f, 6470.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6470.f, 6480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6480.f, 6490.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6490.f, 6500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6500.f,
-    6510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6510.f, 6520.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6520.f, 6530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6530.f, 6540.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6540.f, 6550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6550.f,
-    6560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6560.f, 6570.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6580.f, 6590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6600.f,
-    6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6620.f, 6630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6630.f, 6640.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6640.f, 6650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6650.f,
-    6660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6660.f, 6670.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6670.f, 6680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6680.f, 6690.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6690.f, 6700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6700.f,
-    6710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6710.f, 6720.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6720.f, 6730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6730.f, 6740.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6740.f, 6750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6750.f,
-    6760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6760.f, 6770.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6770.f, 6780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6780.f, 6790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6800.f,
-    6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6820.f, 6830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6830.f, 6840.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6840.f, 6850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6850.f,
-    6860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6860.f, 6870.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6870.f, 6880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6880.f, 6890.f, 0.f,
-      0.f,
+				     .0013362f, -1.4189e-5f, -.0010894f, -1.1571e-5f, 5740.f, 5750.f,
+				     3.4596f, .73536f, .0012876f, -1.2547e-5f, -4.537e-4f, -1.2912e-5f,
+				     5750.f, 5760.f, 4.9414f, 1.0526f, 6.4547e-4f, -1.0024e-5f, -9.6857e-4f,
+				     -1.1592e-5f, 5760.f, 5770.f, 7.5119f, 1.41f, 2.8819e-4f, -7.444e-6f,
+				     -.0012786f, -1.0307e-5f, 5770.f, 5780.f, 7.5235f, 1.323f, -4.9407e-4f,
+				     -6.8773e-6f, -.002629f, -6.638e-6f, 5780.f, 5790.f, 10.241f, 1.6323f,
+				     -.0013776f, -5.3214e-6f, -.0037904f, -2.3185e-6f, 5790.f, 5800.f,
+				     9.1281f, .93597f, -.0035876f, 2.3809e-6f, -.0059879f, 5.9495e-6f,
+				     5800.f, 5810.f, 3.9872f, .6767f, -.0044503f, 6.8501e-6f, -.0067178f,
+				     9.7535e-6f, 5810.f, 5820.f, 2.9318f, .24918f, -.0051233f, 7.7265e-6f,
+				     -.0076555f, 1.1663e-5f, 5820.f, 5830.f, 3.6596f, .91227f, -.0026988f,
+				     2.3063e-6f, -.0047124f, 2.5366e-6f, 5830.f, 5840.f, 6.9904f, .93296f,
+				     -.0037966f, 6.1051e-6f, -.0055025f, 7.3047e-6f, 5840.f, 5850.f, 12.815f,
+				     1.9354f, -.0021432f, 8.1298e-7f, -.0042246f, 2.2902e-6f, 5850.f, 5860.f,
+				     10.246f, 2.1238f, 4.6316e-5f, -6.0726e-6f, -.00223f, -5.3836e-6f,
+				     5860.f, 5870.f, 9.5647f, 1.9821f, .0012796f, -7.4626e-6f, -9.2616e-4f,
+				     -1.0886e-5f, 5870.f, 5880.f, 4.8776f, 1.7308f, .0012461f, -8.1397e-6f,
+				     -5.6127e-5f, -1.3882e-5f, 5880.f, 5890.f, 5.7337f, .87446f, .0038286f,
+				     -1.704e-5f, 6.941e-4f, -1.573e-5f, 5890.f, 5900.f, 7.472f, .73641f,
+				     .0028865f, -2.0558e-5f, -6.6892e-4f, -1.358e-5f, 5900.f, 5910.f,
+				     7.0944f, .66112f, .0024095f, -2.1458e-5f, -9.9935e-4f, -1.3636e-5f,
+				     5910.f, 5920.f, 8.1168f, .58477f, .0013314f, -1.7142e-5f, -.0010021f,
+				     -1.3588e-5f, 5920.f, 5930.f, 10.972f, .47138f, -3.0541e-4f, -9.6826e-6f,
+				     -.0014478f, -9.657e-6f, 5930.f, 5940.f, 7.3055f, .38828f, -.0015833f,
+				     -3.9472e-6f, -.0024534f, -5.2105e-6f, 5940.f, 5950.f, .18257f, .15141f,
+				     .0032545f, -2.5286e-5f, 3.2305e-4f, -1.9965e-5f, 5950.f, 5960.f, 8.803f,
+				     .28605f, -.0031163f, 1.3762e-6f, -.0040606f, 1.0755e-6f, 5960.f, 5970.f,
+				     6.8729f, .20493f, -.0040682f, 5.468e-6f, -.004767f, 4.3804e-6f, 5970.f,
+				     5980.f, 2.9955f, .47987f, -.002474f, 9.9034e-6f, -8.4087e-4f,
+				     -7.5046e-6f, 5980.f, 5990.f, 14.364f, 1.4135f, .0066597f, -3.1277e-5f,
+				     .0045742f, -3.1988e-5f, 5990.f, 6e3f, 65.167f, .97529f, -.0019616f,
+				     -2.2633e-6f, -.0046527f, 1.0271e-6f, 6e3f, 6010.f, 3.5647f, .20344f,
+				     -.0052252f, 1.0688e-5f, -.0057674f, 8.0346e-6f, 6010.f, 6020.f, 3.4141f,
+				     .14357f, -.0054304f, 9.5186e-6f, -.0072736f, 1.143e-5f, 6020.f, 6030.f,
+				     7.635f, .4332f, -.0031157f, 1.3276e-5f, -.001277f, 1.7678e-7f, 6030.f,
+				     6040.f, 16.118f, .28374f, -.0041664f, 4.9599e-6f, -.0056931f,
+				     5.7765e-6f, 6040.f, 6050.f, 19.177f, .33833f, -.0035167f, 1.7094e-6f,
+				     -.0061198f, 6.6957e-6f, 6050.f, 6060.f, 16.85f, .88879f, -.002146f,
+				     -3.2028e-6f, -.0042847f, 2.7277e-7f, 6060.f, 6070.f, 21.077f, .25352f,
+				     -9.3983e-4f, -9.0824e-6f, -.0038178f, -2.813e-6f, 6070.f, 6080.f,
+				     14.763f, .2437f, 5.8706e-4f, -1.4814e-5f, -.0030455f, -5.893e-6f,
+				     6080.f, 6090.f, 12.16f, .31237f, .002521f, -2.1431e-5f, -.0011996f,
+				     -1.1964e-5f, 6090.f, 6100.f, 10.601f, .42935f, .0043443f, -2.7697e-5f,
+				     3.1712e-4f, -1.7641e-5f, 6100.f, 6110.f, 7.7832f, .54373f, .0057906f,
+				     -2.6532e-5f, .001438f, -1.9125e-5f, 6110.f, 6120.f, 5.7902f, 1.1869f,
+				     .0054008f, -1.8503e-5f, .0023381f, -2.0741e-5f, 6120.f, 6130.f, 4.0292f,
+				     .58128f, .0079694f, -2.4981e-5f, .0032731f, -2.2237e-5f, 6130.f, 6140.f,
+				     3.0446f, .82071f, .0077456f, -1.3929e-5f, .0053212f, -2.5965e-5f,
+				     6140.f, 6150.f, 1.9431f, .98831f, .006064f, -2.2019e-5f, .0032998f,
+				     -2.4905e-5f, 6150.f, 6160.f, .97862f, .77724f, .0073198f, -3.3144e-5f,
+				     .0043341f, -3.23e-5f, 6160.f, 6170.f, .41035f, .31003f, .0044331f,
+				     -2.7381e-5f, .0019194f, -2.471e-5f, 6170.f, 6180.f, .19122f, .12211f,
+				     .0046368f, -3.0314e-5f, .0017315f, -2.5376e-5f, 6180.f, 6190.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 6190.f, 6200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6200.f,
+				     6210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6210.f, 6220.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6220.f, 6230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6230.f, 6240.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6240.f, 6250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6250.f,
+				     6260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6260.f, 6270.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6270.f, 6280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6280.f, 6290.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6290.f, 6300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6300.f,
+				     6310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6310.f, 6320.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6320.f, 6330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6330.f, 6340.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6340.f, 6350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6350.f,
+				     6360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6360.f, 6370.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6370.f, 6380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6380.f, 6390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6390.f, 6400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6400.f,
+				     6410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6410.f, 6420.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f, 6440.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6440.f, 6450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6450.f,
+				     6460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6460.f, 6470.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6470.f, 6480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6480.f, 6490.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6490.f, 6500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6500.f,
+				     6510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6510.f, 6520.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6520.f, 6530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6530.f, 6540.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6540.f, 6550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6550.f,
+				     6560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6560.f, 6570.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6580.f, 6590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6600.f,
+				     6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6620.f, 6630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6630.f, 6640.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6640.f, 6650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6650.f,
+				     6660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6660.f, 6670.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6670.f, 6680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6680.f, 6690.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6690.f, 6700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6700.f,
+				     6710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6710.f, 6720.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6720.f, 6730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6730.f, 6740.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6740.f, 6750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6750.f,
+				     6760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6760.f, 6770.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6770.f, 6780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6780.f, 6790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6800.f,
+				     6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6820.f, 6830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6830.f, 6840.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6840.f, 6850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6850.f,
+				     6860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6860.f, 6870.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6870.f, 6880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6880.f, 6890.f, 0.f,
+				     0.f,
-    0.f, 0.f, 0.f, 0.f, 6890.f, 6900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6900.f,
-    6910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6910.f, 6920.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6920.f, 6930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6930.f, 6940.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6940.f, 6950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6950.f,
-    6960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6960.f, 6970.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6970.f, 6980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6980.f, 6990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7e3f,
-      7010.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f, 7040.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7050.f,
-      7060.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f, 7090.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7100.f,
-      7110.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f, 7140.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7150.f,
-      7160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f, 7190.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7200.f,
-      7210.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f, 7240.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7240.f, 7250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7250.f,
-      7260.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7260.f, 7270.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7270.f, 7280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7280.f, 7290.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7290.f, 7300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7300.f,
-      7310.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f, 7340.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7350.f,
-      7360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f, 7390.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7390.f, 7400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7400.f,
-      7410.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7410.f, 7420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7420.f, 7430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7430.f, 7440.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7440.f, 7450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7450.f,
-      7460.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7460.f, 7470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7470.f, 7480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7480.f, 7490.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7490.f, 7500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7500.f,
-      7510.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7510.f, 7520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7520.f, 7530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7530.f, 7540.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7540.f, 7550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7550.f,
-      7560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7560.f, 7570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7570.f, 7580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7580.f, 7590.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7590.f, 7600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7600.f,
-      7610.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7610.f, 7620.f
+				     0.f, 0.f, 0.f, 0.f, 6890.f, 6900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6900.f,
+				     6910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6910.f, 6920.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6920.f, 6930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6930.f, 6940.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6940.f, 6950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6950.f,
+				     6960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6960.f, 6970.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6970.f, 6980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6980.f, 6990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7e3f,
+				     7010.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f, 7040.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7050.f,
+				     7060.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f, 7090.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7100.f,
+				     7110.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f, 7140.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7150.f,
+				     7160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f, 7190.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7200.f,
+				     7210.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f, 7240.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7240.f, 7250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7250.f,
+				     7260.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7260.f, 7270.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7270.f, 7280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7280.f, 7290.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7290.f, 7300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7300.f,
+				     7310.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f, 7340.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7350.f,
+				     7360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f, 7390.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7390.f, 7400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7400.f,
+				     7410.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7410.f, 7420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7420.f, 7430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7430.f, 7440.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7440.f, 7450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7450.f,
+				     7460.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7460.f, 7470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7470.f, 7480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7480.f, 7490.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7490.f, 7500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7500.f,
+				     7510.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7510.f, 7520.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7520.f, 7530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7530.f, 7540.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7540.f, 7550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7550.f,
+				     7560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7560.f, 7570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7570.f, 7580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7580.f, 7590.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7590.f, 7600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7600.f,
+				     7610.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7610.f, 7620.f
-	/* methane (5060 - 7610 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* methane (5060 - 7610 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* meth2 */
 void
@@ -6637,301 +6637,301 @@
-  static const float acr[2048] = { 1.4454f, .47807f,
-    .0052823f, -3.0056e-5f, .002903f, -2.686e-5f, 2500.f, 2510.f, 8.7736f,
-    .49348f, 3.8511e-4f, -6.0533e-6f, 1.0891e-4f, -9.3895e-6f, 2510.f,
-    2520.f, 5.7188f, .51082f, 3.239e-4f, -7.2399e-6f, 1.6424e-4f,
-    -1.0608e-5f, 2520.f, 2530.f, 4.5159f, .73333f, 5.5152e-4f, -2.5526e-6f,
-    2.6319e-4f, -1.1149e-5f, 2530.f, 2540.f, 6.2089f, .57459f, -5.1671e-5f,
-    -3.2924e-6f, -.0012056f, -7.7167e-6f, 2540.f, 2550.f, 9.8841f, .5111f,
-    -.0015575f, 1.7182e-6f, -.001203f, -3.8007e-6f, 2550.f, 2560.f, 7.6169f,
-    .80719f, 1.2985e-4f, -5.7517e-6f, -.0011789f, -6.7688e-6f, 2560.f,
-    2570.f, 7.3766f, .91538f, -6.9626e-4f, -9.8403e-8f, -.0010951f,
-    -5.6422e-6f, 2570.f, 2580.f, 7.9669f, 1.0249f, -.0020553f, 6.0631e-6f,
-    -.0025043f, 1.2199e-6f, 2580.f, 2590.f, 12.942f, 1.8227f, .0016813f,
-    -1.019e-5f, 8.4177e-4f, -1.3848e-5f, 2590.f, 2600.f, 11.671f, .93909f,
-    -.0023388f, 7.1737e-6f, -.0030848f, 1.0079e-5f, 2600.f, 2610.f, 7.682f,
-    .22382f, -.0036797f, 1.7419e-5f, -.002062f, 2.0955e-5f, 2610.f, 2620.f,
-    5.628f, .56037f, -.0012398f, 1.026e-5f, -.001454f, 8.1367e-6f, 2620.f,
-    2630.f, 14.127f, 1.2843f, 7.6229e-5f, 5.7331e-6f, -6.8637e-4f,
-    -4.6206e-6f, 2630.f, 2640.f, 9.0425f, 1.3886f, .0042412f, 2.3021e-6f,
-    .0040176f, -2.0017e-5f, 2640.f, 2650.f, 10.155f, .90252f, 9.0385e-6f,
-    1.3215e-5f, -4.9853e-4f, -1.2678e-6f, 2650.f, 2660.f, 10.154f, .79137f,
-    .0031844f, -3.2869e-6f, .0011834f, -1.1313e-5f, 2660.f, 2670.f, 11.725f,
-    .70879f, -.0014287f, 1.8146e-6f, -.0025033f, -1.0406e-7f, 2670.f,
-    2680.f, 14.948f, .92692f, .0062395f, -3.3167e-5f, .0031727f,
-    -2.6064e-5f, 2680.f, 2690.f, 26.279f, .87829f, .0028361f, -1.4791e-5f,
-    .0014018f, -1.4682e-5f, 2690.f, 2700.f, 7.1745f, .92595f, .0030055f,
-    -2.7951e-6f, .0045235f, -2.2596e-5f, 2700.f, 2710.f, 27.757f, .81447f,
-    .0030565f, -1.9569e-5f, .0025866f, -2.0025e-5f, 2710.f, 2720.f, 36.518f,
-    .82512f, .0018262f, -1.5755e-5f, .0012027f, -1.7464e-5f, 2720.f, 2730.f,
-    7.1564f, .77634f, .0051047f, -2.7255e-5f, .003528f, -2.6912e-5f, 2730.f,
-    2740.f, 53.441f, .64417f, -7.6181e-5f, -1.012e-5f, -8.2299e-4f,
-    -9.7201e-6f, 2740.f, 2750.f, 38.926f, .7434f, -6.9195e-4f, -4.3135e-6f,
-    2.1091e-4f, -6.9939e-6f, 2750.f, 2760.f, 15.709f, 1.3287f, .0030102f,
-    -4.8796e-6f, .0052525f, -2.2331e-5f, 2760.f, 2770.f, 54.733f, 1.246f,
-    -.0010987f, 5.2563e-6f, .002214f, -1.2844e-5f, 2770.f, 2780.f, 47.55f,
-    1.5791f, 8.4509e-4f, -2.0192e-6f, .0011472f, -1.6086e-5f, 2780.f,
-    2790.f, 66.52f, 1.2817f, -2.9084e-4f, -6.0279e-6f, -.0013817f,
-    -7.9406e-6f, 2790.f, 2800.f, 54.178f, .80208f, -.0020375f, 1.3886e-6f,
-    -.002404f, 9.4209e-6f, 2800.f, 2810.f, 53.2f, .65974f, -7.1708e-4f,
-    8.8569e-6f, -2.5373e-4f, 1.13e-5f, 2810.f, 2820.f, 148.4f, .84587f,
-    -.0016143f, 2.0628e-6f, -9.7561e-4f, 9.6287e-6f, 2820.f, 2830.f, 45.29f,
-    1.3591f, -2.3074e-4f, 1.8732e-5f, .0020323f, 6.678e-6f, 2830.f, 2840.f,
-    32.141f, 1.1794f, 7.5732e-4f, 5.0043e-5f, .005454f, 1.3952e-6f, 2840.f,
-    2850.f, 52.919f, .85346f, .0010685f, 4.9698e-5f, .0029632f, 1.729e-5f,
-    2850.f, 2860.f, 92.855f, 1.2724f, .0034021f, 3.1892e-5f, .0020937f,
-    7.5591e-6f, 2860.f, 2870.f, 115.15f, 1.6724f, .0068873f, 1.0637e-5f,
-    .0045477f, -1.5654e-5f, 2870.f, 2880.f, 149.81f, 1.2641f, .0081325f,
-    -1.1177e-6f, .0053865f, -1.8572e-5f, 2880.f, 2890.f, 225.46f, .83931f,
-    .011197f, -4.4342e-5f, .0080886f, -3.4016e-5f, 2890.f, 2900.f, 337.19f,
-    .68846f, .0074267f, -2.7002e-5f, .0051288f, -1.7032e-5f, 2900.f, 2910.f,
-    593.38f, .59397f, .0062712f, -3.0983e-5f, .0039217f, -1.5025e-5f,
-    2910.f, 2920.f, 814.37f, .44567f, .0050972f, -3.2548e-5f, .0037255f,
-    -1.8409e-5f, 2920.f, 2930.f, 1008.f, .42373f, .002722f, -2.2438e-5f,
-    .001776f, -8.5011e-6f, 2930.f, 2940.f, 1273.8f, .39048f, 9.1833e-4f,
-    -1.5902e-5f, 3.8752e-4f, -6.11e-6f, 2940.f, 2950.f, 1822.6f, .32354f,
-    -8.3613e-4f, -9.1286e-6f, -.0012748f, 6.4576e-7f, 2950.f, 2960.f,
-    1144.9f, .28404f, -.0022237f, -3.1413e-6f, -.0015533f, 4e-6f, 2960.f,
-    2970.f, 1422.2f, .24694f, -.0034946f, 2.0028e-6f, -.0022609f,
-    9.6681e-6f, 2970.f, 2980.f, 1129.9f, .25225f, -.0043236f, 6.0179e-6f,
-    -.0023072f, 8.9383e-6f, 2980.f, 2990.f, 382.43f, .28365f, -.0047369f,
-    1.1124e-5f, .0018248f, 1.9257e-5f, 2990.f, 3e3f, 231.12f, 2.8616f,
-    .0085402f, 4.3691e-5f, .016112f, -4.2673e-5f, 3e3f, 3010.f, 12795.f,
-    1.9671f, -2.1206e-4f, -1.4984e-6f, -3.9307e-4f, -5.8544e-6f, 3010.f,
-    3020.f, 578.69f, .79629f, -.0043645f, 1.3898e-5f, 7.3408e-4f,
-    -4.5626e-6f, 3020.f, 3030.f, 434.57f, .096576f, -.0055811f, 1.294e-5f,
-    .0011172f, 2.1736e-5f, 3030.f, 3040.f, 899.49f, .11536f, -.0052201f,
-    1.0059e-5f, -.0015874f, 2.2277e-5f, 3040.f, 3050.f, 2131.4f, .12202f,
-    -.0045842f, 6.3207e-6f, -.003267f, 2.194e-5f, 3050.f, 3060.f, 2451.4f,
-    .19437f, -.0035989f, 2.0635e-6f, -.0037611f, 1.5519e-5f, 3060.f, 3070.f,
-    1860.9f, .31324f, -.0022827f, -2.6816e-6f, -.0014644f, 8.4665e-6f,
-    3070.f, 3080.f, 2857.1f, .3194f, -8.3645e-4f, -9.0192e-6f, -7.6302e-4f,
-    2.417e-6f, 3080.f, 3090.f, 1935.6f, .28235f, 9.2008e-4f, -1.5863e-5f,
-    .0010109f, -1.3517e-6f, 3090.f, 3100.f, 1498.4f, .32994f, .0028983f,
-    -2.3966e-5f, .0020895f, -9.8936e-6f, 3100.f, 3110.f, 1250.8f, .36564f,
-    .005137f, -3.2908e-5f, .0037408f, -1.8191e-5f, 3110.f, 3120.f, 818.19f,
-    .45356f, .0075913f, -4.2727e-5f, .0055871f, -2.645e-5f, 3120.f, 3130.f,
-    483.02f, .62289f, .010573f, -5.4032e-5f, .0075195f, -3.888e-5f, 3130.f,
-    3140.f, 405.16f, 1.0372f, .01439f, -6.8744e-5f, .011121f, -5.8648e-5f,
-    3140.f, 3150.f, 80.532f, .8961f, .01798f, -6.9816e-5f, .012298f,
-    -5.1675e-5f, 3150.f, 3160.f, 41.171f, .85486f, .021624f, -8.2706e-5f,
-    .015717f, -6.4082e-5f, 3160.f, 3170.f, 18.087f, .82972f, .024369f,
-    -8.2555e-5f, .018128f, -6.8246e-5f, 3170.f, 3180.f, 7.8303f, .7783f,
-    .024083f, -4.5258e-5f, .018125f, -5.3074e-5f, 3180.f, 3190.f, 5.5218f,
-    1.2503f, .023406f, -1.2671e-6f, .019648f, -4.075e-5f, 3190.f, 3200.f,
-    .69216f, .51644f, .01424f, -8.731e-6f, .01086f, -3.2732e-5f, 3200.f,
-    3210.f, .30939f, .2177f, .0082095f, -4.4565e-5f, .0058697f, -4.1343e-5f,
-    3210.f, 3220.f, .22568f, .37985f, .012091f, -6.0525e-5f, .0090838f,
-    -5.5067e-5f, 3220.f, 3230.f, .18766f, .2799f, .01283f, -6.1005e-5f,
-    .010043f, -5.7718e-5f, 3230.f, 3240.f, .063205f, .18476f, .014107f,
-    -6.7485e-5f, .011333f, -6.3191e-5f, 3240.f, 3250.f, .028821f, .059172f,
-    .014986f, -7.1903e-5f, .012123f, -6.7129e-5f, 3250.f, 3260.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 3260.f, 3270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3270.f,
-    3280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3280.f, 3290.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3290.f, 3300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3300.f, 3310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3310.f, 3320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3320.f,
-    3330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3330.f, 3340.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3340.f, 3350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3350.f, 3360.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3360.f, 3370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3370.f,
-    3380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3380.f, 3390.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3390.f, 3400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3400.f, 3410.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3410.f, 3420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3420.f,
-    3430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3430.f, 3440.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3440.f, 3450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3450.f, 3460.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3460.f, 3470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3470.f,
-    3480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3480.f, 3490.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3490.f, 3500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3500.f, 3510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3510.f, 3520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3520.f,
-    3530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3530.f, 3540.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3540.f, 3550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3550.f, 3560.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3560.f, 3570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3570.f,
-    3580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3580.f, 3590.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3590.f, 3600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3600.f, 3610.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3610.f, 3620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3620.f,
-    3630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3630.f, 3640.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3640.f, 3650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3650.f, 3660.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 3660.f, 3670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3670.f,
-    3680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3680.f, 3690.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3690.f, 3700.f, .014928f, .049339f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 3700.f, 3710.f, .086139f, .13757f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 3710.f, 3720.f, .067083f, .12495f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3720.f, 3730.f,
-    .020862f, .049275f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
-    3730.f, 3740.f, .067784f, .11899f, .0010215f, -1.7301e-5f, -.0020195f,
-    -1.1177e-5f, 3740.f, 3750.f, .15027f, .18565f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 3750.f, 3760.f, .31581f, .26221f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 3760.f, 3770.f, .48086f, .2992f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3770.f, 3780.f,
-    .59376f, .29431f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
-    3780.f, 3790.f, 1.8375f, .36994f, .0010215f, -1.7301e-5f, -.0020195f,
-    -1.1177e-5f, 3790.f, 3800.f, 2.5355f, .40322f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 3800.f, 3810.f, 2.7002f, .43597f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 3810.f, 3820.f, 6.1651f, .55369f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3820.f, 3830.f,
-    4.0461f, .57732f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
-    3830.f, 3840.f, 6.3365f, .67727f, .0010215f, -1.7301e-5f, -.0020195f,
-    -1.1177e-5f, 3840.f, 3850.f, 9.3866f, .95498f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 3850.f, 3860.f, 20.329f, 1.0079f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 3860.f, 3870.f, 3.8488f, .60704f,
-    -.0030055f, 4.6922e-6f, -.0036436f, -2.5739e-6f, 3870.f, 3880.f,
-    11.688f, .69118f, -.0033148f, 3.0917e-6f, -.0045244f, 8.2466e-7f,
-    3880.f, 3890.f, 15.787f, .75496f, -3.761e-4f, -9.5219e-6f, -.0028616f,
-    -7.036e-6f, 3890.f, 3900.f, 12.339f, 1.2573f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 3900.f, 3910.f, 4.4035f, 1.1712f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 3910.f, 3920.f, 1.452f, 1.1029f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3920.f, 3930.f,
-    .94805f, .51649f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
-    3930.f, 3940.f, 1.3512f, .57924f, .0010215f, -1.7301e-5f, -.0020195f,
-    -1.1177e-5f, 3940.f, 3950.f, 1.2982f, .5633f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 3950.f, 3960.f, 1.1898f, .7034f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 3960.f, 3970.f, 1.2669f, .70992f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3970.f, 3980.f,
+    static const float acr[2048] = { 1.4454f, .47807f,
+				     .0052823f, -3.0056e-5f, .002903f, -2.686e-5f, 2500.f, 2510.f, 8.7736f,
+				     .49348f, 3.8511e-4f, -6.0533e-6f, 1.0891e-4f, -9.3895e-6f, 2510.f,
+				     2520.f, 5.7188f, .51082f, 3.239e-4f, -7.2399e-6f, 1.6424e-4f,
+				     -1.0608e-5f, 2520.f, 2530.f, 4.5159f, .73333f, 5.5152e-4f, -2.5526e-6f,
+				     2.6319e-4f, -1.1149e-5f, 2530.f, 2540.f, 6.2089f, .57459f, -5.1671e-5f,
+				     -3.2924e-6f, -.0012056f, -7.7167e-6f, 2540.f, 2550.f, 9.8841f, .5111f,
+				     -.0015575f, 1.7182e-6f, -.001203f, -3.8007e-6f, 2550.f, 2560.f, 7.6169f,
+				     .80719f, 1.2985e-4f, -5.7517e-6f, -.0011789f, -6.7688e-6f, 2560.f,
+				     2570.f, 7.3766f, .91538f, -6.9626e-4f, -9.8403e-8f, -.0010951f,
+				     -5.6422e-6f, 2570.f, 2580.f, 7.9669f, 1.0249f, -.0020553f, 6.0631e-6f,
+				     -.0025043f, 1.2199e-6f, 2580.f, 2590.f, 12.942f, 1.8227f, .0016813f,
+				     -1.019e-5f, 8.4177e-4f, -1.3848e-5f, 2590.f, 2600.f, 11.671f, .93909f,
+				     -.0023388f, 7.1737e-6f, -.0030848f, 1.0079e-5f, 2600.f, 2610.f, 7.682f,
+				     .22382f, -.0036797f, 1.7419e-5f, -.002062f, 2.0955e-5f, 2610.f, 2620.f,
+				     5.628f, .56037f, -.0012398f, 1.026e-5f, -.001454f, 8.1367e-6f, 2620.f,
+				     2630.f, 14.127f, 1.2843f, 7.6229e-5f, 5.7331e-6f, -6.8637e-4f,
+				     -4.6206e-6f, 2630.f, 2640.f, 9.0425f, 1.3886f, .0042412f, 2.3021e-6f,
+				     .0040176f, -2.0017e-5f, 2640.f, 2650.f, 10.155f, .90252f, 9.0385e-6f,
+				     1.3215e-5f, -4.9853e-4f, -1.2678e-6f, 2650.f, 2660.f, 10.154f, .79137f,
+				     .0031844f, -3.2869e-6f, .0011834f, -1.1313e-5f, 2660.f, 2670.f, 11.725f,
+				     .70879f, -.0014287f, 1.8146e-6f, -.0025033f, -1.0406e-7f, 2670.f,
+				     2680.f, 14.948f, .92692f, .0062395f, -3.3167e-5f, .0031727f,
+				     -2.6064e-5f, 2680.f, 2690.f, 26.279f, .87829f, .0028361f, -1.4791e-5f,
+				     .0014018f, -1.4682e-5f, 2690.f, 2700.f, 7.1745f, .92595f, .0030055f,
+				     -2.7951e-6f, .0045235f, -2.2596e-5f, 2700.f, 2710.f, 27.757f, .81447f,
+				     .0030565f, -1.9569e-5f, .0025866f, -2.0025e-5f, 2710.f, 2720.f, 36.518f,
+				     .82512f, .0018262f, -1.5755e-5f, .0012027f, -1.7464e-5f, 2720.f, 2730.f,
+				     7.1564f, .77634f, .0051047f, -2.7255e-5f, .003528f, -2.6912e-5f, 2730.f,
+				     2740.f, 53.441f, .64417f, -7.6181e-5f, -1.012e-5f, -8.2299e-4f,
+				     -9.7201e-6f, 2740.f, 2750.f, 38.926f, .7434f, -6.9195e-4f, -4.3135e-6f,
+				     2.1091e-4f, -6.9939e-6f, 2750.f, 2760.f, 15.709f, 1.3287f, .0030102f,
+				     -4.8796e-6f, .0052525f, -2.2331e-5f, 2760.f, 2770.f, 54.733f, 1.246f,
+				     -.0010987f, 5.2563e-6f, .002214f, -1.2844e-5f, 2770.f, 2780.f, 47.55f,
+				     1.5791f, 8.4509e-4f, -2.0192e-6f, .0011472f, -1.6086e-5f, 2780.f,
+				     2790.f, 66.52f, 1.2817f, -2.9084e-4f, -6.0279e-6f, -.0013817f,
+				     -7.9406e-6f, 2790.f, 2800.f, 54.178f, .80208f, -.0020375f, 1.3886e-6f,
+				     -.002404f, 9.4209e-6f, 2800.f, 2810.f, 53.2f, .65974f, -7.1708e-4f,
+				     8.8569e-6f, -2.5373e-4f, 1.13e-5f, 2810.f, 2820.f, 148.4f, .84587f,
+				     -.0016143f, 2.0628e-6f, -9.7561e-4f, 9.6287e-6f, 2820.f, 2830.f, 45.29f,
+				     1.3591f, -2.3074e-4f, 1.8732e-5f, .0020323f, 6.678e-6f, 2830.f, 2840.f,
+				     32.141f, 1.1794f, 7.5732e-4f, 5.0043e-5f, .005454f, 1.3952e-6f, 2840.f,
+				     2850.f, 52.919f, .85346f, .0010685f, 4.9698e-5f, .0029632f, 1.729e-5f,
+				     2850.f, 2860.f, 92.855f, 1.2724f, .0034021f, 3.1892e-5f, .0020937f,
+				     7.5591e-6f, 2860.f, 2870.f, 115.15f, 1.6724f, .0068873f, 1.0637e-5f,
+				     .0045477f, -1.5654e-5f, 2870.f, 2880.f, 149.81f, 1.2641f, .0081325f,
+				     -1.1177e-6f, .0053865f, -1.8572e-5f, 2880.f, 2890.f, 225.46f, .83931f,
+				     .011197f, -4.4342e-5f, .0080886f, -3.4016e-5f, 2890.f, 2900.f, 337.19f,
+				     .68846f, .0074267f, -2.7002e-5f, .0051288f, -1.7032e-5f, 2900.f, 2910.f,
+				     593.38f, .59397f, .0062712f, -3.0983e-5f, .0039217f, -1.5025e-5f,
+				     2910.f, 2920.f, 814.37f, .44567f, .0050972f, -3.2548e-5f, .0037255f,
+				     -1.8409e-5f, 2920.f, 2930.f, 1008.f, .42373f, .002722f, -2.2438e-5f,
+				     .001776f, -8.5011e-6f, 2930.f, 2940.f, 1273.8f, .39048f, 9.1833e-4f,
+				     -1.5902e-5f, 3.8752e-4f, -6.11e-6f, 2940.f, 2950.f, 1822.6f, .32354f,
+				     -8.3613e-4f, -9.1286e-6f, -.0012748f, 6.4576e-7f, 2950.f, 2960.f,
+				     1144.9f, .28404f, -.0022237f, -3.1413e-6f, -.0015533f, 4e-6f, 2960.f,
+				     2970.f, 1422.2f, .24694f, -.0034946f, 2.0028e-6f, -.0022609f,
+				     9.6681e-6f, 2970.f, 2980.f, 1129.9f, .25225f, -.0043236f, 6.0179e-6f,
+				     -.0023072f, 8.9383e-6f, 2980.f, 2990.f, 382.43f, .28365f, -.0047369f,
+				     1.1124e-5f, .0018248f, 1.9257e-5f, 2990.f, 3e3f, 231.12f, 2.8616f,
+				     .0085402f, 4.3691e-5f, .016112f, -4.2673e-5f, 3e3f, 3010.f, 12795.f,
+				     1.9671f, -2.1206e-4f, -1.4984e-6f, -3.9307e-4f, -5.8544e-6f, 3010.f,
+				     3020.f, 578.69f, .79629f, -.0043645f, 1.3898e-5f, 7.3408e-4f,
+				     -4.5626e-6f, 3020.f, 3030.f, 434.57f, .096576f, -.0055811f, 1.294e-5f,
+				     .0011172f, 2.1736e-5f, 3030.f, 3040.f, 899.49f, .11536f, -.0052201f,
+				     1.0059e-5f, -.0015874f, 2.2277e-5f, 3040.f, 3050.f, 2131.4f, .12202f,
+				     -.0045842f, 6.3207e-6f, -.003267f, 2.194e-5f, 3050.f, 3060.f, 2451.4f,
+				     .19437f, -.0035989f, 2.0635e-6f, -.0037611f, 1.5519e-5f, 3060.f, 3070.f,
+				     1860.9f, .31324f, -.0022827f, -2.6816e-6f, -.0014644f, 8.4665e-6f,
+				     3070.f, 3080.f, 2857.1f, .3194f, -8.3645e-4f, -9.0192e-6f, -7.6302e-4f,
+				     2.417e-6f, 3080.f, 3090.f, 1935.6f, .28235f, 9.2008e-4f, -1.5863e-5f,
+				     .0010109f, -1.3517e-6f, 3090.f, 3100.f, 1498.4f, .32994f, .0028983f,
+				     -2.3966e-5f, .0020895f, -9.8936e-6f, 3100.f, 3110.f, 1250.8f, .36564f,
+				     .005137f, -3.2908e-5f, .0037408f, -1.8191e-5f, 3110.f, 3120.f, 818.19f,
+				     .45356f, .0075913f, -4.2727e-5f, .0055871f, -2.645e-5f, 3120.f, 3130.f,
+				     483.02f, .62289f, .010573f, -5.4032e-5f, .0075195f, -3.888e-5f, 3130.f,
+				     3140.f, 405.16f, 1.0372f, .01439f, -6.8744e-5f, .011121f, -5.8648e-5f,
+				     3140.f, 3150.f, 80.532f, .8961f, .01798f, -6.9816e-5f, .012298f,
+				     -5.1675e-5f, 3150.f, 3160.f, 41.171f, .85486f, .021624f, -8.2706e-5f,
+				     .015717f, -6.4082e-5f, 3160.f, 3170.f, 18.087f, .82972f, .024369f,
+				     -8.2555e-5f, .018128f, -6.8246e-5f, 3170.f, 3180.f, 7.8303f, .7783f,
+				     .024083f, -4.5258e-5f, .018125f, -5.3074e-5f, 3180.f, 3190.f, 5.5218f,
+				     1.2503f, .023406f, -1.2671e-6f, .019648f, -4.075e-5f, 3190.f, 3200.f,
+				     .69216f, .51644f, .01424f, -8.731e-6f, .01086f, -3.2732e-5f, 3200.f,
+				     3210.f, .30939f, .2177f, .0082095f, -4.4565e-5f, .0058697f, -4.1343e-5f,
+				     3210.f, 3220.f, .22568f, .37985f, .012091f, -6.0525e-5f, .0090838f,
+				     -5.5067e-5f, 3220.f, 3230.f, .18766f, .2799f, .01283f, -6.1005e-5f,
+				     .010043f, -5.7718e-5f, 3230.f, 3240.f, .063205f, .18476f, .014107f,
+				     -6.7485e-5f, .011333f, -6.3191e-5f, 3240.f, 3250.f, .028821f, .059172f,
+				     .014986f, -7.1903e-5f, .012123f, -6.7129e-5f, 3250.f, 3260.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 3260.f, 3270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3270.f,
+				     3280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3280.f, 3290.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3290.f, 3300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3300.f, 3310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3310.f, 3320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3320.f,
+				     3330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3330.f, 3340.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3340.f, 3350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3350.f, 3360.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3360.f, 3370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3370.f,
+				     3380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3380.f, 3390.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3390.f, 3400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3400.f, 3410.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3410.f, 3420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3420.f,
+				     3430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3430.f, 3440.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3440.f, 3450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3450.f, 3460.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3460.f, 3470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3470.f,
+				     3480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3480.f, 3490.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3490.f, 3500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3500.f, 3510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3510.f, 3520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3520.f,
+				     3530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3530.f, 3540.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3540.f, 3550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3550.f, 3560.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3560.f, 3570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3570.f,
+				     3580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3580.f, 3590.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3590.f, 3600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3600.f, 3610.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3610.f, 3620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3620.f,
+				     3630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3630.f, 3640.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3640.f, 3650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3650.f, 3660.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 3660.f, 3670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3670.f,
+				     3680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3680.f, 3690.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3690.f, 3700.f, .014928f, .049339f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 3700.f, 3710.f, .086139f, .13757f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 3710.f, 3720.f, .067083f, .12495f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3720.f, 3730.f,
+				     .020862f, .049275f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
+				     3730.f, 3740.f, .067784f, .11899f, .0010215f, -1.7301e-5f, -.0020195f,
+				     -1.1177e-5f, 3740.f, 3750.f, .15027f, .18565f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 3750.f, 3760.f, .31581f, .26221f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 3760.f, 3770.f, .48086f, .2992f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3770.f, 3780.f,
+				     .59376f, .29431f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
+				     3780.f, 3790.f, 1.8375f, .36994f, .0010215f, -1.7301e-5f, -.0020195f,
+				     -1.1177e-5f, 3790.f, 3800.f, 2.5355f, .40322f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 3800.f, 3810.f, 2.7002f, .43597f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 3810.f, 3820.f, 6.1651f, .55369f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3820.f, 3830.f,
+				     4.0461f, .57732f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
+				     3830.f, 3840.f, 6.3365f, .67727f, .0010215f, -1.7301e-5f, -.0020195f,
+				     -1.1177e-5f, 3840.f, 3850.f, 9.3866f, .95498f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 3850.f, 3860.f, 20.329f, 1.0079f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 3860.f, 3870.f, 3.8488f, .60704f,
+				     -.0030055f, 4.6922e-6f, -.0036436f, -2.5739e-6f, 3870.f, 3880.f,
+				     11.688f, .69118f, -.0033148f, 3.0917e-6f, -.0045244f, 8.2466e-7f,
+				     3880.f, 3890.f, 15.787f, .75496f, -3.761e-4f, -9.5219e-6f, -.0028616f,
+				     -7.036e-6f, 3890.f, 3900.f, 12.339f, 1.2573f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 3900.f, 3910.f, 4.4035f, 1.1712f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 3910.f, 3920.f, 1.452f, 1.1029f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3920.f, 3930.f,
+				     .94805f, .51649f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
+				     3930.f, 3940.f, 1.3512f, .57924f, .0010215f, -1.7301e-5f, -.0020195f,
+				     -1.1177e-5f, 3940.f, 3950.f, 1.2982f, .5633f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 3950.f, 3960.f, 1.1898f, .7034f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 3960.f, 3970.f, 1.2669f, .70992f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 3970.f, 3980.f,
-    1.1486f, .75703f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
-    3980.f, 3990.f, .94294f, .67691f, .0010215f, -1.7301e-5f, -.0020195f,
-    -1.1177e-5f, 3990.f, 4e3f, 1.1722f, .71803f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 4e3f, 4010.f, 1.6614f, 1.1434f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 4010.f, 4020.f, 1.3169f, .99418f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 4020.f, 4030.f,
-    1.6675f, 1.5586f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
-    4030.f, 4040.f, 2.2754f, 1.5263f, .0010215f, -1.7301e-5f, -.0020195f,
-    -1.1177e-5f, 4040.f, 4050.f, 3.3696f, 1.614f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 4050.f, 4060.f, 4.4078f, 1.7299f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 4060.f, 4070.f, 6.4093f, 1.6235f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 4070.f, 4080.f,
-    8.8553f, 1.445f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
-    4080.f, 4090.f, 8.5641f, 1.5633f, .0010215f, -1.7301e-5f, -.0020195f,
-    -1.1177e-5f, 4090.f, 4100.f, 16.356f, 1.9485f, .0010215f, -1.7301e-5f,
-    -.0020195f, -1.1177e-5f, 4100.f, 4110.f, 15.552f, 1.5099f, .0010215f,
-    -1.7301e-5f, -.0020195f, -1.1177e-5f, 4110.f, 4120.f, 23.823f, 2.7996f,
-    .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 4120.f, 4130.f,
-    18.843f, 1.4075f, .0058105f, -2.6748e-5f, 6.4011e-4f, -1.7934e-5f,
-    4130.f, 4140.f, 7.1651f, .45187f, .0070593f, -2.9644e-5f, .0039603f,
-    -2.9724e-5f, 4140.f, 4150.f, 37.171f, .44157f, .0068418f, -3.8862e-5f,
-    .0036076f, -3.2195e-5f, 4150.f, 4160.f, 38.158f, .32296f, .0043474f,
-    -2.9319e-5f, .00185f, -2.5238e-5f, 4160.f, 4170.f, 65.621f, .45796f,
-    .0022774f, -2.0417e-5f, 8.223e-5f, -1.7919e-5f, 4170.f, 4180.f, 79.347f,
-    .33603f, -8.4769e-4f, -8.4263e-6f, -.0034772f, -3.6512e-6f, 4180.f,
-    4190.f, 65.038f, .4819f, -.0014827f, -1.4444e-6f, -.0022137f,
-    -5.6866e-6f, 4190.f, 4200.f, 86.982f, .77363f, -7.1575e-4f, 2.9104e-7f,
-    -.0017062f, -5.7132e-6f, 4200.f, 4210.f, 309.82f, 1.6801f, -8.9037e-4f,
-    -1.3593e-6f, -.0021551f, -4.6701e-6f, 4210.f, 4220.f, 81.077f, .588f,
-    -.0012356f, -7.661e-7f, -.0026793f, -4.4252e-6f, 4220.f, 4230.f,
-    89.975f, .39899f, -.0039748f, 5.6557e-6f, -.0048805f, 4.5246e-6f,
-    4230.f, 4240.f, 148.96f, .80968f, -.002216f, -1.5823e-6f, -.0039631f,
-    -2.9253e-7f, 4240.f, 4250.f, 155.94f, 1.2514f, 4.5507e-4f, -8.2566e-6f,
-    -.0014417f, -8.5226e-6f, 4250.f, 4260.f, 100.6f, 1.2829f, .0020903f,
-    -1.6069e-5f, -3.6824e-4f, -1.5144e-5f, 4260.f, 4270.f, 117.04f, 1.5739f,
-    5.5952e-4f, -2.1104e-6f, -8.6496e-4f, -9.3941e-6f, 4270.f, 4280.f,
-    72.794f, 1.549f, -6.9688e-4f, -3.1516e-6f, -.0027541f, -2.9267e-6f,
-    4280.f, 4290.f, 55.269f, .72223f, -.0034302f, 5.1174e-6f, -.0052484f,
-    7.0355e-6f, 4290.f, 4300.f, 59.856f, 1.1762f, -5.5565e-4f, 2.0772e-7f,
-    -.0019773f, -5.0966e-6f, 4300.f, 4310.f, 218.17f, 2.2377f, -.0013492f,
-    -1.8427e-6f, -.0029966f, -3.2329e-6f, 4310.f, 4320.f, 10.284f, .071846f,
-    -.0057696f, 9.8901e-6f, -.0087876f, 1.5909e-5f, 4320.f, 4330.f, 96.725f,
-    .88048f, -.0045462f, 6.1508e-6f, -.0069991f, 9.6787e-6f, 4330.f, 4340.f,
-    111.26f, 1.6893f, -.002444f, 5.0136e-7f, -.0044752f, 1.1244e-6f, 4340.f,
-    4350.f, 102.83f, 1.8062f, -3.868e-4f, -5.0005e-6f, -.0021043f,
-    -6.8556e-6f, 4350.f, 4360.f, 89.61f, 1.1851f, -6.654e-4f, 2.3556e-6f,
-    -.001897f, -3.4232e-6f, 4360.f, 4370.f, 66.668f, .73012f, -.0022103f,
-    2.3323e-6f, -.0030787f, -5.6056e-7f, 4370.f, 4380.f, 81.907f, .54144f,
-    -.0025213f, -8.9597e-7f, -.0047474f, 1.5149e-6f, 4380.f, 4390.f,
-    90.229f, .49784f, -.0023921f, -1.0143e-6f, -.0043793f, 4.6547e-7f,
-    4390.f, 4400.f, 82.849f, .85204f, -1.0412e-4f, -8.1641e-6f, -.0020032f,
-    -8.0151e-6f, 4400.f, 4410.f, 44.643f, .57527f, .0023103f, -1.4133e-5f,
-    8.589e-4f, -1.8551e-5f, 4410.f, 4420.f, 69.032f, .78506f, 3.9855e-4f,
-    -1.0098e-5f, -.0010159f, -1.0449e-5f, 4420.f, 4430.f, 58.683f, .96123f,
-    .0024151f, -1.8621e-5f, 9.2225e-4f, -1.9737e-5f, 4430.f, 4440.f,
-    37.181f, 1.0126f, .0046217f, -2.9919e-5f, .0020589f, -2.6447e-5f,
-    4440.f, 4450.f, 42.607f, 1.0332f, .0047981f, -3.088e-5f, .0014909f,
-    -2.4304e-5f, 4450.f, 4460.f, 33.113f, .94984f, .0043677f, -2.6166e-5f,
-    .0012754f, -2.2104e-5f, 4460.f, 4470.f, 32.668f, .8529f, .0023495f,
-    -1.622e-5f, -4.7342e-4f, -1.3768e-5f, 4470.f, 4480.f, 23.216f, .8354f,
-    .0022982f, -7.3604e-6f, 6.8926e-4f, -1.3485e-5f, 4480.f, 4490.f,
-    13.719f, .6592f, .0014982f, -6.2753e-6f, -3.7161e-4f, -1.1492e-5f,
-    4490.f, 4500.f, 16.799f, .41229f, -7.848e-4f, 1.7545e-6f, -.001216f,
-    -7.1041e-6f, 4500.f, 4510.f, 10.085f, .14021f, -.0037976f, 6.6108e-6f,
-    -.0050669f, 6.8711e-6f, 4510.f, 4520.f, 3.1009f, .087599f, -.0043682f,
-    1.0148e-5f, -.0057555f, 1.0223e-5f, 4520.f, 4530.f, 18.983f, 1.5932f,
-    .0014519f, -9.1544e-6f, -9.7256e-4f, -1.0139e-5f, 4530.f, 4540.f,
-    63.83f, 2.0016f, -.0011189f, -2.1104e-6f, -.0028048f, -3.8802e-6f,
-    4540.f, 4550.f, 3.1441f, .067773f, -.0040447f, 1.4471e-5f, -.0037016f,
-    5.8757e-6f, 4550.f, 4560.f, 2.1782f, .029389f, -.005929f, 1.0501e-5f,
-    -.00897f, 1.6625e-5f, 4560.f, 4570.f, 4.0086f, .078646f, -.0053825f,
-    8.3305e-6f, -.0083558f, 1.4185e-5f, 4570.f, 4580.f, 1.3954f, .11032f,
-    -.0040678f, 3.1725e-6f, -.0071674f, 9.4743e-6f, 4580.f, 4590.f, 8.2827f,
-    .13524f, -.0044855f, 4.8983e-6f, -.0072447f, 9.9023e-6f, 4590.f, 4600.f,
-    8.1728f, .18866f, -.0033132f, 4.1656e-7f, -.0059898f, 5.0092e-6f,
-    4600.f, 4610.f, 6.4947f, .31086f, -.0016438f, -5.9966e-6f, -.0043498f,
-    -1.4967e-6f, 4610.f, 4620.f, 6.3479f, .34741f, 1.5663e-4f, -1.2499e-5f,
-    -.0026034f, -7.9833e-6f, 4620.f, 4630.f, 2.4602f, .20366f, .0017162f,
-    -1.8956e-5f, -9.66e-4f, -1.4741e-5f, 4630.f, 4640.f, 2.0994f, .2061f,
-    .004364f, -2.6098e-5f, .0019605f, -2.4954e-5f, 4640.f, 4650.f, 1.6635f,
-    .21606f, .0038987f, -2.7059e-5f, .001059f, -2.2496e-5f, 4650.f, 4660.f,
-    .9148f, .11908f, .0055341f, -3.5022e-5f, .002491f, -2.9056e-5f, 4660.f,
-    4670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4670.f, 4680.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4680.f, 4690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4690.f, 4700.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4700.f, 4710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4710.f,
-    4720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4720.f, 4730.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4730.f, 4740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4740.f, 4750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4750.f, 4760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4760.f,
-    4770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4770.f, 4780.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4780.f, 4790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4790.f, 4800.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4800.f, 4810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4810.f,
-    4820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4820.f, 4830.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4830.f, 4840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4840.f, 4850.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4850.f, 4860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4860.f,
-    4870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4870.f, 4880.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4880.f, 4890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4890.f, 4900.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4900.f, 4910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4910.f,
-    4920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4920.f, 4930.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4930.f, 4940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4940.f, 4950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 4950.f, 4960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4960.f,
-    4970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4970.f, 4980.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 4980.f, 4990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4990.f, 5e3f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 5e3f, 5010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5010.f, 5020.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 5020.f, 5030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      5030.f,
-    5040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5040.f, 5050.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5050.f, 5060.f
+				     1.1486f, .75703f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
+				     3980.f, 3990.f, .94294f, .67691f, .0010215f, -1.7301e-5f, -.0020195f,
+				     -1.1177e-5f, 3990.f, 4e3f, 1.1722f, .71803f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 4e3f, 4010.f, 1.6614f, 1.1434f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 4010.f, 4020.f, 1.3169f, .99418f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 4020.f, 4030.f,
+				     1.6675f, 1.5586f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
+				     4030.f, 4040.f, 2.2754f, 1.5263f, .0010215f, -1.7301e-5f, -.0020195f,
+				     -1.1177e-5f, 4040.f, 4050.f, 3.3696f, 1.614f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 4050.f, 4060.f, 4.4078f, 1.7299f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 4060.f, 4070.f, 6.4093f, 1.6235f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 4070.f, 4080.f,
+				     8.8553f, 1.445f, .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f,
+				     4080.f, 4090.f, 8.5641f, 1.5633f, .0010215f, -1.7301e-5f, -.0020195f,
+				     -1.1177e-5f, 4090.f, 4100.f, 16.356f, 1.9485f, .0010215f, -1.7301e-5f,
+				     -.0020195f, -1.1177e-5f, 4100.f, 4110.f, 15.552f, 1.5099f, .0010215f,
+				     -1.7301e-5f, -.0020195f, -1.1177e-5f, 4110.f, 4120.f, 23.823f, 2.7996f,
+				     .0010215f, -1.7301e-5f, -.0020195f, -1.1177e-5f, 4120.f, 4130.f,
+				     18.843f, 1.4075f, .0058105f, -2.6748e-5f, 6.4011e-4f, -1.7934e-5f,
+				     4130.f, 4140.f, 7.1651f, .45187f, .0070593f, -2.9644e-5f, .0039603f,
+				     -2.9724e-5f, 4140.f, 4150.f, 37.171f, .44157f, .0068418f, -3.8862e-5f,
+				     .0036076f, -3.2195e-5f, 4150.f, 4160.f, 38.158f, .32296f, .0043474f,
+				     -2.9319e-5f, .00185f, -2.5238e-5f, 4160.f, 4170.f, 65.621f, .45796f,
+				     .0022774f, -2.0417e-5f, 8.223e-5f, -1.7919e-5f, 4170.f, 4180.f, 79.347f,
+				     .33603f, -8.4769e-4f, -8.4263e-6f, -.0034772f, -3.6512e-6f, 4180.f,
+				     4190.f, 65.038f, .4819f, -.0014827f, -1.4444e-6f, -.0022137f,
+				     -5.6866e-6f, 4190.f, 4200.f, 86.982f, .77363f, -7.1575e-4f, 2.9104e-7f,
+				     -.0017062f, -5.7132e-6f, 4200.f, 4210.f, 309.82f, 1.6801f, -8.9037e-4f,
+				     -1.3593e-6f, -.0021551f, -4.6701e-6f, 4210.f, 4220.f, 81.077f, .588f,
+				     -.0012356f, -7.661e-7f, -.0026793f, -4.4252e-6f, 4220.f, 4230.f,
+				     89.975f, .39899f, -.0039748f, 5.6557e-6f, -.0048805f, 4.5246e-6f,
+				     4230.f, 4240.f, 148.96f, .80968f, -.002216f, -1.5823e-6f, -.0039631f,
+				     -2.9253e-7f, 4240.f, 4250.f, 155.94f, 1.2514f, 4.5507e-4f, -8.2566e-6f,
+				     -.0014417f, -8.5226e-6f, 4250.f, 4260.f, 100.6f, 1.2829f, .0020903f,
+				     -1.6069e-5f, -3.6824e-4f, -1.5144e-5f, 4260.f, 4270.f, 117.04f, 1.5739f,
+				     5.5952e-4f, -2.1104e-6f, -8.6496e-4f, -9.3941e-6f, 4270.f, 4280.f,
+				     72.794f, 1.549f, -6.9688e-4f, -3.1516e-6f, -.0027541f, -2.9267e-6f,
+				     4280.f, 4290.f, 55.269f, .72223f, -.0034302f, 5.1174e-6f, -.0052484f,
+				     7.0355e-6f, 4290.f, 4300.f, 59.856f, 1.1762f, -5.5565e-4f, 2.0772e-7f,
+				     -.0019773f, -5.0966e-6f, 4300.f, 4310.f, 218.17f, 2.2377f, -.0013492f,
+				     -1.8427e-6f, -.0029966f, -3.2329e-6f, 4310.f, 4320.f, 10.284f, .071846f,
+				     -.0057696f, 9.8901e-6f, -.0087876f, 1.5909e-5f, 4320.f, 4330.f, 96.725f,
+				     .88048f, -.0045462f, 6.1508e-6f, -.0069991f, 9.6787e-6f, 4330.f, 4340.f,
+				     111.26f, 1.6893f, -.002444f, 5.0136e-7f, -.0044752f, 1.1244e-6f, 4340.f,
+				     4350.f, 102.83f, 1.8062f, -3.868e-4f, -5.0005e-6f, -.0021043f,
+				     -6.8556e-6f, 4350.f, 4360.f, 89.61f, 1.1851f, -6.654e-4f, 2.3556e-6f,
+				     -.001897f, -3.4232e-6f, 4360.f, 4370.f, 66.668f, .73012f, -.0022103f,
+				     2.3323e-6f, -.0030787f, -5.6056e-7f, 4370.f, 4380.f, 81.907f, .54144f,
+				     -.0025213f, -8.9597e-7f, -.0047474f, 1.5149e-6f, 4380.f, 4390.f,
+				     90.229f, .49784f, -.0023921f, -1.0143e-6f, -.0043793f, 4.6547e-7f,
+				     4390.f, 4400.f, 82.849f, .85204f, -1.0412e-4f, -8.1641e-6f, -.0020032f,
+				     -8.0151e-6f, 4400.f, 4410.f, 44.643f, .57527f, .0023103f, -1.4133e-5f,
+				     8.589e-4f, -1.8551e-5f, 4410.f, 4420.f, 69.032f, .78506f, 3.9855e-4f,
+				     -1.0098e-5f, -.0010159f, -1.0449e-5f, 4420.f, 4430.f, 58.683f, .96123f,
+				     .0024151f, -1.8621e-5f, 9.2225e-4f, -1.9737e-5f, 4430.f, 4440.f,
+				     37.181f, 1.0126f, .0046217f, -2.9919e-5f, .0020589f, -2.6447e-5f,
+				     4440.f, 4450.f, 42.607f, 1.0332f, .0047981f, -3.088e-5f, .0014909f,
+				     -2.4304e-5f, 4450.f, 4460.f, 33.113f, .94984f, .0043677f, -2.6166e-5f,
+				     .0012754f, -2.2104e-5f, 4460.f, 4470.f, 32.668f, .8529f, .0023495f,
+				     -1.622e-5f, -4.7342e-4f, -1.3768e-5f, 4470.f, 4480.f, 23.216f, .8354f,
+				     .0022982f, -7.3604e-6f, 6.8926e-4f, -1.3485e-5f, 4480.f, 4490.f,
+				     13.719f, .6592f, .0014982f, -6.2753e-6f, -3.7161e-4f, -1.1492e-5f,
+				     4490.f, 4500.f, 16.799f, .41229f, -7.848e-4f, 1.7545e-6f, -.001216f,
+				     -7.1041e-6f, 4500.f, 4510.f, 10.085f, .14021f, -.0037976f, 6.6108e-6f,
+				     -.0050669f, 6.8711e-6f, 4510.f, 4520.f, 3.1009f, .087599f, -.0043682f,
+				     1.0148e-5f, -.0057555f, 1.0223e-5f, 4520.f, 4530.f, 18.983f, 1.5932f,
+				     .0014519f, -9.1544e-6f, -9.7256e-4f, -1.0139e-5f, 4530.f, 4540.f,
+				     63.83f, 2.0016f, -.0011189f, -2.1104e-6f, -.0028048f, -3.8802e-6f,
+				     4540.f, 4550.f, 3.1441f, .067773f, -.0040447f, 1.4471e-5f, -.0037016f,
+				     5.8757e-6f, 4550.f, 4560.f, 2.1782f, .029389f, -.005929f, 1.0501e-5f,
+				     -.00897f, 1.6625e-5f, 4560.f, 4570.f, 4.0086f, .078646f, -.0053825f,
+				     8.3305e-6f, -.0083558f, 1.4185e-5f, 4570.f, 4580.f, 1.3954f, .11032f,
+				     -.0040678f, 3.1725e-6f, -.0071674f, 9.4743e-6f, 4580.f, 4590.f, 8.2827f,
+				     .13524f, -.0044855f, 4.8983e-6f, -.0072447f, 9.9023e-6f, 4590.f, 4600.f,
+				     8.1728f, .18866f, -.0033132f, 4.1656e-7f, -.0059898f, 5.0092e-6f,
+				     4600.f, 4610.f, 6.4947f, .31086f, -.0016438f, -5.9966e-6f, -.0043498f,
+				     -1.4967e-6f, 4610.f, 4620.f, 6.3479f, .34741f, 1.5663e-4f, -1.2499e-5f,
+				     -.0026034f, -7.9833e-6f, 4620.f, 4630.f, 2.4602f, .20366f, .0017162f,
+				     -1.8956e-5f, -9.66e-4f, -1.4741e-5f, 4630.f, 4640.f, 2.0994f, .2061f,
+				     .004364f, -2.6098e-5f, .0019605f, -2.4954e-5f, 4640.f, 4650.f, 1.6635f,
+				     .21606f, .0038987f, -2.7059e-5f, .001059f, -2.2496e-5f, 4650.f, 4660.f,
+				     .9148f, .11908f, .0055341f, -3.5022e-5f, .002491f, -2.9056e-5f, 4660.f,
+				     4670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4670.f, 4680.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4680.f, 4690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4690.f, 4700.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4700.f, 4710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4710.f,
+				     4720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4720.f, 4730.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4730.f, 4740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4740.f, 4750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4750.f, 4760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4760.f,
+				     4770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4770.f, 4780.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4780.f, 4790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4790.f, 4800.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4800.f, 4810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4810.f,
+				     4820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4820.f, 4830.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4830.f, 4840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4840.f, 4850.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4850.f, 4860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4860.f,
+				     4870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4870.f, 4880.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4880.f, 4890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4890.f, 4900.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4900.f, 4910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4910.f,
+				     4920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4920.f, 4930.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4930.f, 4940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4940.f, 4950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 4950.f, 4960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4960.f,
+				     4970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4970.f, 4980.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 4980.f, 4990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4990.f, 5e3f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 5e3f, 5010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5010.f, 5020.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 5020.f, 5030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     5030.f,
+				     5040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5040.f, 5050.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5050.f, 5060.f
-	/* methane (2500 - 5050 cm-1) */
+    /* methane (2500 - 5050 cm-1) */
 }	/* meth1 */
@@ -6940,330 +6940,330 @@
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15360.f,
-    15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
-      15400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15440.f,
-    15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
-      15480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15520.f,
-    15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
-      15560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15600.f,
-    15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
-      15640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15680.f,
-    15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15700.f, 15710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15710.f,
-      15720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15720.f, 15730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15730.f, 15740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15750.f, 15760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15760.f,
-    15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15780.f, 15790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15790.f,
-      15800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15800.f, 15810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15810.f, 15820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15820.f, 15830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15830.f, 15840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15840.f,
-    15850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15850.f, 15860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15860.f, 15870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15870.f,
-      15880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15880.f, 15890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15890.f, 15900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15900.f, 15910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15910.f, 15920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15920.f,
-    15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f, 15940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15950.f,
-      15960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f, 15990.f, 0.f,
-      0.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15360.f,
+				     15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
+				     15400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15440.f,
+				     15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
+				     15480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15520.f,
+				     15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
+				     15560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15600.f,
+				     15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
+				     15640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15680.f,
+				     15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15700.f, 15710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15710.f,
+				     15720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15720.f, 15730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15730.f, 15740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15750.f, 15760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15760.f,
+				     15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15780.f, 15790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15790.f,
+				     15800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15800.f, 15810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15810.f, 15820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15820.f, 15830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15830.f, 15840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15840.f,
+				     15850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15850.f, 15860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15860.f, 15870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15870.f,
+				     15880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15880.f, 15890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15890.f, 15900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15900.f, 15910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15910.f, 15920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15920.f,
+				     15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f, 15940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15950.f,
+				     15960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f, 15970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15980.f, 15990.f, 0.f,
+				     0.f,
-    0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.6e4f,
-    16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16030.f,
-      16040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f, 16070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16080.f,
-    16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16110.f,
-      16120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f, 16150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16160.f,
-    16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16190.f,
-      16200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f, 16230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16240.f,
-    16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16270.f,
-      16280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f, 16310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16320.f,
-    16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16350.f,
-      16360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f, 16390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16400.f,
-    16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16430.f,
-      16440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f, 16470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16480.f,
-    16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16510.f,
-      16520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f, 16550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16560.f,
-    16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16590.f,
-      16600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f, 16630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16640.f,
-    16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16670.f,
-      16680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16700.f, 16710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16720.f,
-    16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16730.f, 16740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16750.f,
-      16760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f, 16770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16780.f, 16790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16800.f,
-    16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16810.f, 16820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16830.f,
-      16840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f, 16850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16860.f, 16870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16880.f,
-    16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16890.f, 16900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16910.f,
-      16920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f, 16930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16940.f, 16950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16960.f,
-    16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16970.f, 16980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16990.f, 1.7e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.6e4f,
+				     16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16010.f, 16020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16030.f,
+				     16040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f, 16050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16060.f, 16070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16080.f,
+				     16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16090.f, 16100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16110.f,
+				     16120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f, 16130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16140.f, 16150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16160.f,
+				     16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16170.f, 16180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16190.f,
+				     16200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f, 16210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16220.f, 16230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16240.f,
+				     16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16250.f, 16260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16270.f,
+				     16280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f, 16290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16300.f, 16310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16320.f,
+				     16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16330.f, 16340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16350.f,
+				     16360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f, 16370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16380.f, 16390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16400.f,
+				     16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16410.f, 16420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16430.f,
+				     16440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f, 16450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16460.f, 16470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16480.f,
+				     16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16490.f, 16500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16510.f,
+				     16520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f, 16530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16540.f, 16550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16560.f,
+				     16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16570.f, 16580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16590.f,
+				     16600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f, 16610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16620.f, 16630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16640.f,
+				     16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16650.f, 16660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16670.f,
+				     16680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f, 16690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16700.f, 16710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16720.f,
+				     16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16730.f, 16740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16750.f,
+				     16760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f, 16770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16780.f, 16790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16800.f,
+				     16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16810.f, 16820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16830.f,
+				     16840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f, 16850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16860.f, 16870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16880.f,
+				     16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16890.f, 16900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16910.f,
+				     16920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f, 16930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16940.f, 16950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16960.f,
+				     16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16970.f, 16980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16990.f, 1.7e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17020.f, 17030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17040.f,
-    17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17050.f, 17060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17070.f,
-      17080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f, 17090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17100.f, 17110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17120.f,
-    17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17130.f, 17140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17150.f,
-      17160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f, 17170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17180.f, 17190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17200.f,
-    17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17210.f, 17220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17230.f,
-      17240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f, 17250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17260.f, 17270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17280.f,
-    17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17290.f, 17300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17310.f,
-      17320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f, 17330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17340.f, 17350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17360.f,
-    17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17370.f, 17380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17390.f,
-      17400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f, 17410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17420.f, 17430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17440.f,
-    17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17450.f, 17460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17470.f,
-      17480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f, 17490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17500.f, 17510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17520.f,
-    17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17530.f, 17540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17550.f,
-      17560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f, 17570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17580.f, 17590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17600.f,
-    17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17610.f, 17620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17630.f,
-      17640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17680.f,
-    17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f,
-      17720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f,
-      0.f,
+				     0.f,
+				     17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17020.f, 17030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17040.f,
+				     17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17050.f, 17060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17070.f,
+				     17080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f, 17090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17100.f, 17110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17120.f,
+				     17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17130.f, 17140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17150.f,
+				     17160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f, 17170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17180.f, 17190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17200.f,
+				     17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17210.f, 17220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17230.f,
+				     17240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f, 17250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17260.f, 17270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17280.f,
+				     17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17290.f, 17300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17310.f,
+				     17320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f, 17330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17340.f, 17350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17360.f,
+				     17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17370.f, 17380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17390.f,
+				     17400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f, 17410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17420.f, 17430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17440.f,
+				     17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17450.f, 17460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17470.f,
+				     17480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f, 17490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17500.f, 17510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17520.f,
+				     17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17530.f, 17540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17550.f,
+				     17560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f, 17570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17580.f, 17590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17600.f,
+				     17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17610.f, 17620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17630.f,
+				     17640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f, 17650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17660.f, 17670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17680.f,
+				     17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17690.f, 17700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17710.f,
+				     17720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f, 17730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17740.f, 17750.f, 0.f,
+				     0.f,
-    0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17760.f,
-    17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f,
-      17800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17840.f,
-    17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
+				     0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17760.f,
+				     17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17770.f, 17780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17790.f,
+				     17800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f, 17810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17820.f, 17830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17840.f,
+				     17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17850.f, 17860.f
-	/* carbon monoxide (15300 - 17870 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* carbon monoxide (15300 - 17870 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* moca6 */
 void
@@ -7271,659 +7271,659 @@
-    0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12800.f,
-    12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
-      12840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12840.f, 12850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12850.f, 12860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12860.f, 12870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12880.f,
-    12890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12890.f, 12900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12900.f, 12910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12910.f,
-      12920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12920.f, 12930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12940.f, 12950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12960.f,
-    12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12970.f, 12980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12990.f, 1.3e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13020.f, 13030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13040.f,
-    13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13050.f, 13060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13070.f,
-      13080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f, 13090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13100.f, 13110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13120.f,
-    13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13130.f, 13140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13150.f,
-      13160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f, 13170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13180.f, 13190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13200.f,
-    13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13210.f, 13220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13230.f,
-      13240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f, 13250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13260.f, 13270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13280.f,
-    13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13290.f, 13300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13310.f,
-      13320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f, 13330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13340.f, 13350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13360.f,
-    13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13370.f, 13380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13390.f,
-      13400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f, 13410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13420.f, 13430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13440.f,
-    13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13450.f, 13460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13470.f,
-      13480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f, 13490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13500.f, 13510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13520.f,
-    13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13530.f, 13540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13550.f,
-      13560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f, 13570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13580.f, 13590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13600.f,
-    13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13610.f, 13620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13630.f,
-      13640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f, 13650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13660.f, 13670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13680.f,
-    13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13690.f, 13700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13710.f,
-      13720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f, 13730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13740.f, 13750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13760.f,
-    13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13770.f, 13780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13790.f,
-      13800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f, 13810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13820.f, 13830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13840.f,
-    13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13850.f, 13860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13870.f,
-      13880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f, 13890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13900.f, 13910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13920.f,
-    13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13930.f, 13940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13950.f,
-      13960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f, 13970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13980.f, 13990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.4e4f,
-    14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14010.f, 14020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14030.f,
-      14040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f, 14050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14060.f, 14070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14080.f,
-    14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14090.f, 14100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14110.f,
-      14120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f, 14130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14140.f, 14150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14160.f,
-    14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14170.f, 14180.f, 0.f, 0.f, 0.f,
+				     0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12800.f,
+				     12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
+				     12840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12840.f, 12850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12850.f, 12860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12860.f, 12870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12870.f, 12880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12880.f,
+				     12890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12890.f, 12900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12900.f, 12910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12910.f,
+				     12920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12920.f, 12930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12930.f, 12940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12940.f, 12950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12950.f, 12960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12960.f,
+				     12970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12970.f, 12980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12980.f, 12990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12990.f, 1.3e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.3e4f, 13010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13010.f, 13020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13020.f, 13030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13030.f, 13040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13040.f,
+				     13050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13050.f, 13060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13060.f, 13070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13070.f,
+				     13080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13080.f, 13090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13090.f, 13100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13100.f, 13110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13110.f, 13120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13120.f,
+				     13130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13130.f, 13140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13140.f, 13150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13150.f,
+				     13160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13160.f, 13170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13180.f, 13190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13200.f,
+				     13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13210.f, 13220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13230.f,
+				     13240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f, 13250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13260.f, 13270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13280.f,
+				     13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13290.f, 13300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13310.f,
+				     13320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f, 13330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13340.f, 13350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13360.f,
+				     13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13370.f, 13380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13390.f,
+				     13400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f, 13410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13420.f, 13430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13440.f,
+				     13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13450.f, 13460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13470.f,
+				     13480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f, 13490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13500.f, 13510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13520.f,
+				     13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13530.f, 13540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13550.f,
+				     13560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f, 13570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13580.f, 13590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13600.f,
+				     13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13610.f, 13620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13630.f,
+				     13640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f, 13650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13660.f, 13670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13680.f,
+				     13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13690.f, 13700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13710.f,
+				     13720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f, 13730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13740.f, 13750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13760.f,
+				     13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13770.f, 13780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13790.f,
+				     13800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f, 13810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13820.f, 13830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13840.f,
+				     13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13850.f, 13860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13870.f,
+				     13880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f, 13890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13900.f, 13910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13920.f,
+				     13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13930.f, 13940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13950.f,
+				     13960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f, 13970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13980.f, 13990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.4e4f,
+				     14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14010.f, 14020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14030.f,
+				     14040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f, 14050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14060.f, 14070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14080.f,
+				     14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14090.f, 14100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14110.f,
+				     14120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f, 14130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14140.f, 14150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14160.f,
+				     14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14170.f, 14180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14190.f,
-      14200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f, 14210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14220.f, 14230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14240.f,
-    14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14250.f, 14260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14270.f,
-      14280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f, 14290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14300.f, 14310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14320.f,
-    14330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14330.f, 14340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14350.f,
-      14360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14360.f, 14370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14370.f, 14380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14380.f, 14390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14390.f, 14400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14400.f,
-    14410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14410.f, 14420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14420.f, 14430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14430.f,
-      14440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14440.f, 14450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14450.f, 14460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14460.f, 14470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14470.f, 14480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14480.f,
-    14490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14490.f, 14500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14500.f, 14510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14510.f,
-      14520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f, 14530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f, 14550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14560.f,
-    14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
-      14600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14640.f,
-    14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
-      14680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14720.f,
-    14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
-      14760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14800.f,
-    14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
-      14840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14880.f,
-    14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
-      14920.f,
+				     0.f,
+				     0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14190.f,
+				     14200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f, 14210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14220.f, 14230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14240.f,
+				     14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14250.f, 14260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14270.f,
+				     14280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f, 14290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14300.f, 14310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14320.f,
+				     14330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14330.f, 14340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14350.f,
+				     14360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14360.f, 14370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14370.f, 14380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14380.f, 14390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14390.f, 14400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14400.f,
+				     14410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14410.f, 14420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14420.f, 14430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14430.f,
+				     14440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14440.f, 14450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14450.f, 14460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14460.f, 14470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14470.f, 14480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14480.f,
+				     14490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14490.f, 14500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14500.f, 14510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14510.f,
+				     14520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14520.f, 14530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14530.f, 14540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14540.f, 14550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14560.f,
+				     14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
+				     14600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14640.f,
+				     14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
+				     14680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14720.f,
+				     14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
+				     14760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14800.f,
+				     14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
+				     14840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14880.f,
+				     14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
+				     14920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14960.f,
-    14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15040.f,
-    15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
-      15080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15120.f,
-    15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
-      15160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15200.f,
-    15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
-      15240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14960.f,
+				     14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15040.f,
+				     15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
+				     15080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15120.f,
+				     15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
+				     15160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15200.f,
+				     15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
+				     15240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15280.f,
-    15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15280.f,
+				     15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
-	/* carbon monoxide (12740 - 15290 cm-1) */
+    /* carbon monoxide (12740 - 15290 cm-1) */
 }	/* moca5 */
 void moca4 (float a[8], const long int inu)
-    0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10240.f,
-    10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
-      10280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10320.f,
-    10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
-      10360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10400.f,
-    10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
-      10440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10480.f,
-    10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
-      10520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10560.f,
-    10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
-      10600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10640.f,
-    10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
-      10680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10720.f,
-    10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
-      10760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10800.f,
-    10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
-      10840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
+				     0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10240.f,
+				     10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
+				     10280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10320.f,
+				     10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
+				     10360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10400.f,
+				     10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
+				     10440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10480.f,
+				     10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
+				     10520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10560.f,
+				     10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
+				     10600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10640.f,
+				     10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
+				     10680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10720.f,
+				     10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
+				     10760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10800.f,
+				     10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
+				     10840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
-    10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10880.f,
-    10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
-      10920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10960.f,
-    10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11040.f,
-    11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
-      11080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11120.f,
-    11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
-      11160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11200.f,
-    11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
-      11240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11280.f,
-    11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
-      11320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11360.f,
-    11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
-      11400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11440.f,
-    11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
-      11480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11490.f, 11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11510.f, 11520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11520.f,
-    11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11530.f, 11540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11540.f, 11550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11550.f,
-      11560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11560.f, 11570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11570.f, 11580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11580.f, 11590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11600.f,
-    11610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11610.f, 11620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11620.f, 11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f,
-      11640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11650.f, 11660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11680.f,
+				     10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10880.f,
+				     10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
+				     10920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10960.f,
+				     10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11040.f,
+				     11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
+				     11080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11120.f,
+				     11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
+				     11160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11200.f,
+				     11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
+				     11240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11280.f,
+				     11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
+				     11320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11360.f,
+				     11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
+				     11400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11440.f,
+				     11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
+				     11480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11490.f, 11500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11500.f, 11510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11510.f, 11520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11520.f,
+				     11530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11530.f, 11540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11540.f, 11550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11550.f,
+				     11560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11560.f, 11570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11570.f, 11580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11580.f, 11590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11590.f, 11600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11600.f,
+				     11610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11610.f, 11620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11620.f, 11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f,
+				     11640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11650.f, 11660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11680.f,
-    11690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f,
-      0.f,
+				     11690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f,
+				     0.f,
-    0.f, 0.f, 11700.f, 11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f,
-      11720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11730.f, 11740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11760.f,
-    11770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11780.f, 11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f,
-      11800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11810.f, 11820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11840.f,
-    11850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11860.f, 11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f,
-      11880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11890.f, 11900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11920.f,
-    11930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11940.f, 11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f,
-      11960.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11970.f, 11980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f,
-    12010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12020.f, 12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f,
-      12040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12050.f, 12060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12080.f,
-    12090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12100.f, 12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f,
-      12120.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12130.f, 12140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12160.f,
-    12170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12180.f, 12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f,
-      12200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12210.f, 12220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12240.f,
-    12250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12260.f, 12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f,
-      12280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12290.f, 12300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12320.f,
-    12330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12340.f, 12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f,
-      12360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12370.f, 12380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12400.f,
-    12410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 11700.f, 11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f,
+				     11720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11730.f, 11740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11760.f,
+				     11770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11780.f, 11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f,
+				     11800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11810.f, 11820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11840.f,
+				     11850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11860.f, 11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f,
+				     11880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11890.f, 11900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11920.f,
+				     11930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11940.f, 11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f,
+				     11960.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11970.f, 11980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f,
+				     12010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12020.f, 12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f,
+				     12040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12050.f, 12060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12080.f,
+				     12090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12100.f, 12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f,
+				     12120.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12130.f, 12140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12160.f,
+				     12170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12180.f, 12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f,
+				     12200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12210.f, 12220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12240.f,
+				     12250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12260.f, 12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f,
+				     12280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12290.f, 12300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12320.f,
+				     12330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12340.f, 12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f,
+				     12360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12370.f, 12380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12400.f,
+				     12410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12420.f, 12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f,
-      12440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12450.f, 12460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12480.f,
-    12490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12500.f, 12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f,
-      12520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12530.f, 12540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12560.f,
-    12570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12580.f, 12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f,
-      12600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12610.f, 12620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12640.f,
-    12650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12660.f, 12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f,
-      12680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12690.f, 12700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12720.f,
-    12730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
+				     0.f,
+				     0.f, 0.f, 12420.f, 12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f,
+				     12440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12450.f, 12460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12480.f,
+				     12490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12500.f, 12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f,
+				     12520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12530.f, 12540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12560.f,
+				     12570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12580.f, 12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f,
+				     12600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12610.f, 12620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12640.f,
+				     12650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12660.f, 12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f,
+				     12680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12690.f, 12700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12720.f,
+				     12730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
-	/* carbon monoxide (10180 - 12730 cm-1) */
+    /* carbon monoxide (10180 - 12730 cm-1) */
 }	/* moca4 */
 void
@@ -7931,305 +7931,305 @@
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
-    7660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f, 7690.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7690.f, 7700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7700.f,
-    7710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7710.f, 7720.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7720.f, 7730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7730.f, 7740.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7740.f, 7750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7750.f,
-    7760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7760.f, 7770.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7780.f, 7790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7800.f,
-    7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f, 7840.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7850.f,
-    7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f, 7890.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7890.f, 7900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7900.f,
-    7910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7910.f, 7920.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7920.f, 7930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7930.f, 7940.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7940.f, 7950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7950.f,
-    7960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7960.f, 7970.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7970.f, 7980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7980.f, 7990.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f,
-      8010.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8020.f, 8030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8030.f, 8040.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8040.f, 8050.f, 1.354e-16f, .017736f, .11256f, -4.5834e-4f,
-    .10977f, -4.527e-4f, 8050.f, 8060.f, 4.1572e-16f, .017736f, .10803f,
-    -4.4019e-4f, .10523f, -4.3455e-4f, 8060.f, 8070.f, 1.2473e-15f,
-    .017736f, .10358f, -4.2239e-4f, .10078f, -4.1676e-4f, 8070.f, 8080.f,
-    3.6626e-15f, .017736f, .099217f, -4.0495e-4f, .096419f, -3.9931e-4f,
-    8080.f, 8090.f, 1.0521e-14f, .017736f, .094944f, -3.8786e-4f, .092146f,
-    -3.8222e-4f, 8090.f, 8100.f, 2.9549e-14f, .017736f, .09076f,
-    -3.7112e-4f, .087962f, -3.6548e-4f, 8100.f, 8110.f, 8.1193e-14f,
-    .017736f, .086664f, -3.5474e-4f, .083866f, -3.491e-4f, 8110.f, 8120.f,
-    2.1814e-13f, .017736f, .082657f, -3.3871e-4f, .079859f, -3.3307e-4f,
-    8120.f, 8130.f, 5.7319e-13f, .017736f, .078739f, -3.2303e-4f, .075941f,
-    -3.174e-4f, 8130.f, 8140.f, 1.4733e-12f, .017736f, .07491f, -3.0772e-4f,
-    .072112f, -3.0208e-4f, 8140.f, 8150.f, 3.7005e-12f, .017736f, .07117f,
-    -2.9276e-4f, .068372f, -2.8712e-4f, 8150.f, 8160.f, 9.0898e-12f,
-    .017736f, .067519f, -2.7816e-4f, .064721f, -2.7252e-4f, 8160.f, 8170.f,
-    2.1828e-11f, .017736f, .063958f, -2.6391e-4f, .06116f, -2.5828e-4f,
-    8170.f, 8180.f, 1.6892e-10f, .034043f, .058108f, -2.3936e-4f, .055638f,
-    -2.3553e-4f, 8180.f, 8190.f, 2.6399e-10f, .017736f, .053812f,
-    -2.2333e-4f, .051015f, -2.177e-4f, 8190.f, 8200.f, 5.7886e-10f,
-    .017736f, .050611f, -2.1052e-4f, .047813f, -2.0489e-4f, 8200.f, 8210.f,
-    1.2407e-9f, .017957f, .047499f, -1.9807e-4f, .044701f, -1.9244e-4f,
-    8210.f, 8220.f, 2.5994e-9f, .018179f, .044477f, -1.8599e-4f, .041679f,
-    -1.8035e-4f, 8220.f, 8230.f, 1.596e-8f, .036001f, .039635f, -1.6576e-4f,
-    .03707f, -1.6145e-4f, 8230.f, 8240.f, 2.0795e-8f, .018844f, .035955f,
-    -1.519e-4f, .033157f, -1.4627e-4f, 8240.f, 8250.f, 3.9708e-8f, .019066f,
-    .033295f, -1.4126e-4f, .030497f, -1.3563e-4f, 8250.f, 8260.f,
-    2.0895e-7f, .03799f, .029113f, -1.2386e-4f, .026495f, -1.1926e-4f,
-    8260.f, 8270.f, 2.3995e-7f, .019731f, .025861f, -1.1153e-4f, .023064f,
-    -1.0589e-4f, 8270.f, 8280.f, 4.1681e-7f, .019953f, .023566f,
-    -1.0234e-4f, .020768f, -9.6709e-5f, 8280.f, 8290.f, 1.8774e-6f,
-    .040651f, .020033f, -8.771e-5f, .017363f, -8.2825e-5f, 8290.f, 8300.f,
-    1.8914e-6f, .021283f, .017225f, -7.698e-5f, .014427f, -7.1347e-5f,
-    8300.f, 8310.f, 7.568e-6f, .043989f, .014172f, -6.438e-5f, .011463f,
-    -5.9288e-5f, 8310.f, 8320.f, 6.8789e-6f, .023145f, .011707f,
-    -5.4908e-5f, .0089094f, -4.9275e-5f, 8320.f, 8330.f, 2.4399e-5f,
-    .046699f, .0091256f, -4.4298e-5f, .0063969f, -3.9079e-5f, 8330.f,
-    8340.f, 4.6806e-5f, .049425f, .006215f, -3.2716e-5f, .0034666f,
-    -2.739e-5f, 8340.f, 8350.f, 8.0605e-5f, .050945f, .0036678f,
-    -2.2582e-5f, 9.0701e-4f, -1.718e-5f, 8350.f, 8360.f, 1.2377e-4f,
-    .051881f, .0014843f, -1.3895e-5f, -.0012918f, -8.4086e-6f, 8360.f,
-    8370.f, 1.6751e-4f, .053029f, -3.3537e-4f, -6.6561e-6f, -.0031202f,
-    -1.1154e-6f, 8370.f, 8380.f, 1.9593e-4f, .054802f, -.0017908f,
-    -8.6649e-7f, -.0045868f, 4.7351e-6f, 8380.f, 8390.f, 1.8975e-4f,
-    .058538f, -.0028817f, 3.4723e-6f, -.0056846f, 9.1141e-6f, 8390.f,
-    8400.f, 1.3472e-4f, .062039f, -.0036068f, 6.3564e-6f, -.006417f,
-    1.2035e-5f, 8400.f, 8410.f, 6.4957e-5f, .06993f, -.0039984f, 7.9148e-6f,
-    -.006795f, 1.3543e-5f, 8410.f, 8420.f, 3.0309e-4f, .090113f, -.0036875f,
-    6.6869e-6f, -.0065101f, 1.2442e-5f, 8420.f, 8430.f, 5.1352e-4f, .08362f,
-    -.0026038f, 2.4173e-6f, -.0054145f, 8.1551e-6f, 8430.f, 8440.f,
-    8.2971e-4f, .13049f, 5.179e-5f, -7.5797e-6f, -.0026588f, -2.2561e-6f,
-    8440.f, 8450.f, 4.4414e-4f, .14201f, .0055167f, -2.7842e-5f, .0033215f,
-    -2.3351e-5f, 8450.f, 8460.f, 8.4089e-5f, .17964f, .015226f, -6.0171e-5f,
-    .015481f, -6.3601e-5f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      8470.f,
-    8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f, 8510.f, 0.f,
-      0.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
+				     7660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7660.f, 7670.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f, 7690.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7690.f, 7700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7700.f,
+				     7710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7710.f, 7720.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7720.f, 7730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7730.f, 7740.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7740.f, 7750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7750.f,
+				     7760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7760.f, 7770.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7770.f, 7780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7780.f, 7790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7790.f, 7800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7800.f,
+				     7810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7810.f, 7820.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7820.f, 7830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7830.f, 7840.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7840.f, 7850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7850.f,
+				     7860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7860.f, 7870.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7870.f, 7880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7880.f, 7890.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7890.f, 7900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7900.f,
+				     7910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7910.f, 7920.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7920.f, 7930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7930.f, 7940.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7940.f, 7950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7950.f,
+				     7960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7960.f, 7970.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7970.f, 7980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7980.f, 7990.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7990.f, 8e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8e3f,
+				     8010.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8010.f, 8020.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8020.f, 8030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8030.f, 8040.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8040.f, 8050.f, 1.354e-16f, .017736f, .11256f, -4.5834e-4f,
+				     .10977f, -4.527e-4f, 8050.f, 8060.f, 4.1572e-16f, .017736f, .10803f,
+				     -4.4019e-4f, .10523f, -4.3455e-4f, 8060.f, 8070.f, 1.2473e-15f,
+				     .017736f, .10358f, -4.2239e-4f, .10078f, -4.1676e-4f, 8070.f, 8080.f,
+				     3.6626e-15f, .017736f, .099217f, -4.0495e-4f, .096419f, -3.9931e-4f,
+				     8080.f, 8090.f, 1.0521e-14f, .017736f, .094944f, -3.8786e-4f, .092146f,
+				     -3.8222e-4f, 8090.f, 8100.f, 2.9549e-14f, .017736f, .09076f,
+				     -3.7112e-4f, .087962f, -3.6548e-4f, 8100.f, 8110.f, 8.1193e-14f,
+				     .017736f, .086664f, -3.5474e-4f, .083866f, -3.491e-4f, 8110.f, 8120.f,
+				     2.1814e-13f, .017736f, .082657f, -3.3871e-4f, .079859f, -3.3307e-4f,
+				     8120.f, 8130.f, 5.7319e-13f, .017736f, .078739f, -3.2303e-4f, .075941f,
+				     -3.174e-4f, 8130.f, 8140.f, 1.4733e-12f, .017736f, .07491f, -3.0772e-4f,
+				     .072112f, -3.0208e-4f, 8140.f, 8150.f, 3.7005e-12f, .017736f, .07117f,
+				     -2.9276e-4f, .068372f, -2.8712e-4f, 8150.f, 8160.f, 9.0898e-12f,
+				     .017736f, .067519f, -2.7816e-4f, .064721f, -2.7252e-4f, 8160.f, 8170.f,
+				     2.1828e-11f, .017736f, .063958f, -2.6391e-4f, .06116f, -2.5828e-4f,
+				     8170.f, 8180.f, 1.6892e-10f, .034043f, .058108f, -2.3936e-4f, .055638f,
+				     -2.3553e-4f, 8180.f, 8190.f, 2.6399e-10f, .017736f, .053812f,
+				     -2.2333e-4f, .051015f, -2.177e-4f, 8190.f, 8200.f, 5.7886e-10f,
+				     .017736f, .050611f, -2.1052e-4f, .047813f, -2.0489e-4f, 8200.f, 8210.f,
+				     1.2407e-9f, .017957f, .047499f, -1.9807e-4f, .044701f, -1.9244e-4f,
+				     8210.f, 8220.f, 2.5994e-9f, .018179f, .044477f, -1.8599e-4f, .041679f,
+				     -1.8035e-4f, 8220.f, 8230.f, 1.596e-8f, .036001f, .039635f, -1.6576e-4f,
+				     .03707f, -1.6145e-4f, 8230.f, 8240.f, 2.0795e-8f, .018844f, .035955f,
+				     -1.519e-4f, .033157f, -1.4627e-4f, 8240.f, 8250.f, 3.9708e-8f, .019066f,
+				     .033295f, -1.4126e-4f, .030497f, -1.3563e-4f, 8250.f, 8260.f,
+				     2.0895e-7f, .03799f, .029113f, -1.2386e-4f, .026495f, -1.1926e-4f,
+				     8260.f, 8270.f, 2.3995e-7f, .019731f, .025861f, -1.1153e-4f, .023064f,
+				     -1.0589e-4f, 8270.f, 8280.f, 4.1681e-7f, .019953f, .023566f,
+				     -1.0234e-4f, .020768f, -9.6709e-5f, 8280.f, 8290.f, 1.8774e-6f,
+				     .040651f, .020033f, -8.771e-5f, .017363f, -8.2825e-5f, 8290.f, 8300.f,
+				     1.8914e-6f, .021283f, .017225f, -7.698e-5f, .014427f, -7.1347e-5f,
+				     8300.f, 8310.f, 7.568e-6f, .043989f, .014172f, -6.438e-5f, .011463f,
+				     -5.9288e-5f, 8310.f, 8320.f, 6.8789e-6f, .023145f, .011707f,
+				     -5.4908e-5f, .0089094f, -4.9275e-5f, 8320.f, 8330.f, 2.4399e-5f,
+				     .046699f, .0091256f, -4.4298e-5f, .0063969f, -3.9079e-5f, 8330.f,
+				     8340.f, 4.6806e-5f, .049425f, .006215f, -3.2716e-5f, .0034666f,
+				     -2.739e-5f, 8340.f, 8350.f, 8.0605e-5f, .050945f, .0036678f,
+				     -2.2582e-5f, 9.0701e-4f, -1.718e-5f, 8350.f, 8360.f, 1.2377e-4f,
+				     .051881f, .0014843f, -1.3895e-5f, -.0012918f, -8.4086e-6f, 8360.f,
+				     8370.f, 1.6751e-4f, .053029f, -3.3537e-4f, -6.6561e-6f, -.0031202f,
+				     -1.1154e-6f, 8370.f, 8380.f, 1.9593e-4f, .054802f, -.0017908f,
+				     -8.6649e-7f, -.0045868f, 4.7351e-6f, 8380.f, 8390.f, 1.8975e-4f,
+				     .058538f, -.0028817f, 3.4723e-6f, -.0056846f, 9.1141e-6f, 8390.f,
+				     8400.f, 1.3472e-4f, .062039f, -.0036068f, 6.3564e-6f, -.006417f,
+				     1.2035e-5f, 8400.f, 8410.f, 6.4957e-5f, .06993f, -.0039984f, 7.9148e-6f,
+				     -.006795f, 1.3543e-5f, 8410.f, 8420.f, 3.0309e-4f, .090113f, -.0036875f,
+				     6.6869e-6f, -.0065101f, 1.2442e-5f, 8420.f, 8430.f, 5.1352e-4f, .08362f,
+				     -.0026038f, 2.4173e-6f, -.0054145f, 8.1551e-6f, 8430.f, 8440.f,
+				     8.2971e-4f, .13049f, 5.179e-5f, -7.5797e-6f, -.0026588f, -2.2561e-6f,
+				     8440.f, 8450.f, 4.4414e-4f, .14201f, .0055167f, -2.7842e-5f, .0033215f,
+				     -2.3351e-5f, 8450.f, 8460.f, 8.4089e-5f, .17964f, .015226f, -6.0171e-5f,
+				     .015481f, -6.3601e-5f, 8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     8470.f,
+				     8480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8490.f, 8500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f, 8510.f, 0.f,
+				     0.f,
-    0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8520.f,
-    8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f, 8560.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8570.f,
-    8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f, 8610.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8620.f,
-    8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f, 8660.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8670.f,
-    8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f, 8710.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8520.f,
+				     8530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8540.f, 8550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f, 8560.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8570.f,
+				     8580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8590.f, 8600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f, 8610.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8620.f,
+				     8630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8640.f, 8650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f, 8660.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8670.f,
+				     8680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8690.f, 8700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f, 8710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8720.f,
-    8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f, 8760.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8770.f,
-    8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f, 8810.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8820.f,
-    8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f, 8860.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8870.f,
-    8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f, 8910.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8920.f,
-    8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f, 8960.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8970.f,
-    8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9020.f,
-      9030.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
-      9080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
-      9130.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
-      9180.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
-      9230.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
-      9280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
-      9330.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9340.f, 9350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9350.f, 9360.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9360.f, 9370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9370.f,
-      9380.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9390.f, 9400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9400.f, 9410.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9410.f, 9420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f,
-      9430.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9440.f, 9450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9450.f, 9460.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f,
-      9480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
-      9530.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
-      9580.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
-      9630.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
-      9680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
-      9730.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
-      9780.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
-      9830.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
-      9880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
-      9930.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
-      9980.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
-      10030.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f, 10060.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10070.f,
-    10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10100.f,
-      10110.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f, 10140.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10150.f,
-    10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10170.f, 10180.f
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8720.f,
+				     8730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8740.f, 8750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f, 8760.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8770.f,
+				     8780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8790.f, 8800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f, 8810.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8820.f,
+				     8830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8840.f, 8850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f, 8860.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8870.f,
+				     8880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8890.f, 8900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f, 8910.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8920.f,
+				     8930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8940.f, 8950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f, 8960.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8970.f,
+				     8980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 8990.f, 9e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9010.f, 9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9020.f,
+				     9030.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9040.f, 9050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9060.f, 9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f,
+				     9080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9090.f, 9100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9110.f, 9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f,
+				     9130.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9140.f, 9150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9160.f, 9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f,
+				     9180.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9190.f, 9200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9210.f, 9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f,
+				     9230.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9240.f, 9250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9260.f, 9270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9270.f,
+				     9280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9290.f, 9300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9300.f, 9310.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9310.f, 9320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9320.f,
+				     9330.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9330.f, 9340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9340.f, 9350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9350.f, 9360.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9360.f, 9370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9370.f,
+				     9380.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9380.f, 9390.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9390.f, 9400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9400.f, 9410.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9410.f, 9420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9420.f,
+				     9430.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9430.f, 9440.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9440.f, 9450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9450.f, 9460.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f,
+				     9480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
+				     9530.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
+				     9580.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
+				     9630.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
+				     9680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
+				     9730.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
+				     9780.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
+				     9830.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
+				     9880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
+				     9930.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
+				     9980.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
+				     10030.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f, 10060.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10070.f,
+				     10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10100.f,
+				     10110.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f, 10140.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10150.f,
+				     10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10170.f, 10180.f
-	/* carbon monoxide (7600 - 10170 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* carbon monoxide (7600 - 10170 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* moca3 */
 void
@@ -8237,296 +8237,296 @@
-    0.f, 5060.f, 5070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5070.f, 5080.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5080.f, 5090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5090.f,
-    5100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5100.f, 5110.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5110.f, 5120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5120.f, 5130.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5130.f, 5140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5140.f,
-    5150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5150.f, 5160.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5160.f, 5170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5170.f, 5180.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5180.f, 5190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5190.f,
-    5200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5200.f, 5210.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5210.f, 5220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5220.f, 5230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5230.f, 5240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5240.f,
-    5250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5250.f, 5260.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5260.f, 5270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5270.f, 5280.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5280.f, 5290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5290.f,
-    5300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5300.f, 5310.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5310.f, 5320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5320.f, 5330.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5330.f, 5340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5340.f,
-    5350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5350.f, 5360.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5360.f, 5370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5370.f, 5380.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5380.f, 5390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5390.f,
-    5400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5400.f, 5410.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5410.f, 5420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5420.f, 5430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5430.f, 5440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5440.f,
-    5450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5450.f, 5460.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5460.f, 5470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5470.f, 5480.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5480.f, 5490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5490.f,
-    5500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5500.f, 5510.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5510.f, 5520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5520.f, 5530.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5530.f, 5540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5540.f,
-    5550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5550.f, 5560.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5560.f, 5570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5570.f, 5580.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5580.f, 5590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5590.f,
-    5600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5600.f, 5610.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5610.f, 5620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5620.f, 5630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5630.f, 5640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5640.f,
-    5650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5650.f, 5660.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 5660.f, 5670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5670.f, 5680.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 5680.f, 5690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5690.f,
-    5700.f, 4.6683e-26f, 3.9946e-7f, .15004f, -6.0825e-4f, .14724f,
-    -6.0261e-4f, 5700.f, 5710.f, 1.2312e-25f, 3.9946e-7f, .14595f,
-    -5.9188e-4f, .14315f, -5.8625e-4f, 5710.f, 5720.f, 1.1266e-24f,
-    7.5927e-7f, .13909f, -5.6295e-4f, .13671f, -5.5959e-4f, 5720.f, 5730.f,
-    2.0103e-24f, 3.9946e-7f, .13415f, -5.447e-4f, .13135f, -5.3906e-4f,
-    5730.f, 5740.f, 4.9063e-24f, 3.9946e-7f, .13038f, -5.2961e-4f, .12758f,
-    -5.2397e-4f, 5740.f, 5750.f, 3.9255e-23f, 7.6518e-7f, .12413f,
-    -5.0331e-4f, .12169f, -4.9966e-4f, 5750.f, 5760.f, 6.3305e-23f,
-    3.9946e-7f, .11954f, -4.8626e-4f, .11675f, -4.8063e-4f, 5760.f, 5770.f,
-    1.5847e-21f, 1.0092e-6f, .10516f, -4.1519e-4f, .10467f, -4.2332e-4f,
-    5770.f, 5780.f, 3.6811e-21f, 7.1016e-7f, .09985f, -3.9815e-4f, .098651f,
-    -4.013e-4f, 5780.f, 5790.f, 3.2319e-20f, 1.2898e-6f, .092607f,
-    -3.6764e-4f, .092132f, -3.7318e-4f, 5790.f, 5800.f, 5.6403e-20f,
+				     0.f, 5060.f, 5070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5070.f, 5080.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5080.f, 5090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5090.f,
+				     5100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5100.f, 5110.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5110.f, 5120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5120.f, 5130.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5130.f, 5140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5140.f,
+				     5150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5150.f, 5160.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5160.f, 5170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5170.f, 5180.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5180.f, 5190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5190.f,
+				     5200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5200.f, 5210.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5210.f, 5220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5220.f, 5230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5230.f, 5240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5240.f,
+				     5250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5250.f, 5260.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5260.f, 5270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5270.f, 5280.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5280.f, 5290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5290.f,
+				     5300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5300.f, 5310.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5310.f, 5320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5320.f, 5330.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5330.f, 5340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5340.f,
+				     5350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5350.f, 5360.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5360.f, 5370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5370.f, 5380.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5380.f, 5390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5390.f,
+				     5400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5400.f, 5410.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5410.f, 5420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5420.f, 5430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5430.f, 5440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5440.f,
+				     5450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5450.f, 5460.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5460.f, 5470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5470.f, 5480.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5480.f, 5490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5490.f,
+				     5500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5500.f, 5510.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5510.f, 5520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5520.f, 5530.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5530.f, 5540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5540.f,
+				     5550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5550.f, 5560.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5560.f, 5570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5570.f, 5580.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5580.f, 5590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5590.f,
+				     5600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5600.f, 5610.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5610.f, 5620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5620.f, 5630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5630.f, 5640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5640.f,
+				     5650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5650.f, 5660.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 5660.f, 5670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5670.f, 5680.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 5680.f, 5690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5690.f,
+				     5700.f, 4.6683e-26f, 3.9946e-7f, .15004f, -6.0825e-4f, .14724f,
+				     -6.0261e-4f, 5700.f, 5710.f, 1.2312e-25f, 3.9946e-7f, .14595f,
+				     -5.9188e-4f, .14315f, -5.8625e-4f, 5710.f, 5720.f, 1.1266e-24f,
+				     7.5927e-7f, .13909f, -5.6295e-4f, .13671f, -5.5959e-4f, 5720.f, 5730.f,
+				     2.0103e-24f, 3.9946e-7f, .13415f, -5.447e-4f, .13135f, -5.3906e-4f,
+				     5730.f, 5740.f, 4.9063e-24f, 3.9946e-7f, .13038f, -5.2961e-4f, .12758f,
+				     -5.2397e-4f, 5740.f, 5750.f, 3.9255e-23f, 7.6518e-7f, .12413f,
+				     -5.0331e-4f, .12169f, -4.9966e-4f, 5750.f, 5760.f, 6.3305e-23f,
+				     3.9946e-7f, .11954f, -4.8626e-4f, .11675f, -4.8063e-4f, 5760.f, 5770.f,
+				     1.5847e-21f, 1.0092e-6f, .10516f, -4.1519e-4f, .10467f, -4.2332e-4f,
+				     5770.f, 5780.f, 3.6811e-21f, 7.1016e-7f, .09985f, -3.9815e-4f, .098651f,
+				     -4.013e-4f, 5780.f, 5790.f, 3.2319e-20f, 1.2898e-6f, .092607f,
+				     -3.6764e-4f, .092132f, -3.7318e-4f, 5790.f, 5800.f, 5.6403e-20f,
-    6.4883e-7f, .087374f, -3.4877e-4f, .086636f, -3.5122e-4f, 5800.f,
-    5810.f, 1.6009e-19f, 9.5335e-7f, .0849f, -3.3381e-4f, .084844f,
-    -3.4257e-4f, 5810.f, 5820.f, 1.0493e-18f, 1.0941e-6f, .076482f,
-    -3.0762e-4f, .080072f, -2.5402e-4f, 5820.f, 5830.f, 1.8849e-18f,
-    2.3089e-6f, .073551f, -2.7995e-4f, .10134f, -1.0464e-4f, 5830.f, 5840.f,
-    1.2274e-17f, 1.8503e-6f, .065955f, -2.6262e-4f, .08719f, -6.1536e-5f,
-    5840.f, 5850.f, 1.9475e-17f, 2.1482e-6f, .062641f, -2.3947e-4f,
-    .092133f, -5.5475e-5f, 5850.f, 5860.f, 4.2834e-17f, 5.2914e-6f,
-    .060443f, -2.1227e-4f, .10022f, -9.1581e-5f, 5860.f, 5870.f,
-    2.5814e-16f, 2.709e-6f, .053613f, -2.0674e-4f, .078473f, -2.4556e-5f,
-    5870.f, 5880.f, 3.4582e-16f, 2.4018e-6f, .049817f, -1.8578e-4f,
-    .083893f, -9.9109e-6f, 5880.f, 5890.f, 1.9766e-15f, 2.6621e-6f,
-    .044522f, -1.7276e-4f, .070531f, 1.7855e-5f, 5890.f, 5900.f,
-    7.0047e-15f, 5.7066e-6f, .039496f, -1.4181e-4f, .075654f, 5.7712e-6f,
-    5900.f, 5910.f, 8.6757e-15f, 3.3052e-5f, .040851f, -4.9822e-5f,
-    .088823f, -2.0654e-4f, 5910.f, 5920.f, 4.0761e-14f, 1.4076e-5f,
-    .033721f, -8.1073e-5f, .073952f, -7.155e-5f, 5920.f, 5930.f,
-    1.1802e-13f, 1.8315e-5f, .029401f, -5.6811e-5f, .072527f, -6.1682e-5f,
-    5930.f, 5940.f, 1.2517e-13f, 3.208e-5f, .029645f, 5.2262e-6f, .075673f,
-    -1.605e-4f, 5940.f, 5950.f, 5.3299e-13f, 8.3885e-5f, .028648f,
-    5.1037e-5f, .076701f, -1.1804e-4f, 5950.f, 5960.f, 1.2176e-12f,
-    4.3932e-5f, .023072f, 3.9649e-5f, .070157f, -2.5205e-5f, 5960.f, 5970.f,
-    2.6812e-12f, 7.4724e-5f, .021392f, 7.8492e-5f, .0689f, -5.7739e-5f,
-    5970.f, 5980.f, 5.2852e-12f, 8.1623e-5f, .018441f, 9.2123e-5f, .072474f,
-    3.8196e-5f, 5980.f, 5990.f, 1.2137e-11f, 2.5414e-4f, .024162f,
-    1.7686e-4f, .065473f, -1.1219e-4f, 5990.f, 6e3f, 2.022e-11f, 1.7439e-4f,
-    .021342f, 1.7061e-4f, .061647f, -4.9481e-5f, 6e3f, 6010.f, 7.0256e-11f,
-    3.9013e-4f, .025354f, 1.739e-4f, .056294f, -1.0119e-4f, 6010.f, 6020.f,
-    9.1715e-11f, 3.8456e-4f, .027846f, 1.3835e-4f, .055857f, -8.5738e-5f,
-    6020.f, 6030.f, 3.5812e-10f, 8.9526e-4f, .036811f, -1.9691e-5f,
-    .060026f, -5.1263e-5f, 6030.f, 6040.f, 5.1951e-10f, 6.5082e-4f,
-    .034472f, -3.8106e-5f, .057771f, -1.7166e-5f, 6040.f, 6050.f,
-    2.3396e-9f, .0012585f, .037673f, -1.3867e-4f, .056388f, -3.7053e-5f,
-    6050.f, 6060.f, 3.1627e-9f, .0012183f, .033941f, -1.1427e-4f, .058265f,
-    -1.4231e-5f, 6060.f, 6070.f, 1.3747e-8f, .0010905f, .030224f,
-    -1.1494e-4f, .045888f, -1.243e-5f, 6070.f, 6080.f, 1.6746e-8f,
-    .0011055f, .0271f, -9.4052e-5f, .048795f, 1.7267e-6f, 6080.f, 6090.f,
-    6.9627e-8f, .0014531f, .023474f, -8.7211e-5f, .042687f, 2.9187e-5f,
-    6090.f, 6100.f, 1.789e-7f, .0023713f, .020122f, -5.984e-5f, .042924f,
-    9.3171e-6f, 6100.f, 6110.f, 1.6918e-7f, .002373f, .018564f, -3.2576e-5f,
-    .047913f, -5.6001e-6f, 6110.f, 6120.f, 6.1497e-7f, .0020751f, .014671f,
-    -3.6986e-5f, .03447f, 3.2655e-5f, 6120.f, 6130.f, 1.3012e-6f, .0059809f,
-    .014081f, 1.2706e-5f, .041059f, -1.4713e-5f, 6130.f, 6140.f, 2.3687e-6f,
-    .0034824f, .010334f, 1.187e-5f, .031822f, 2.134e-5f, 6140.f, 6150.f,
-    4.1168e-6f, .0049295f, .0084797f, 3.3745e-5f, .032297f, 2.8091e-5f,
-    6150.f, 6160.f, 7.275e-6f, .015527f, .012669f, 9.9217e-5f, .036777f,
-    -5.5634e-5f, 6160.f, 6170.f, 9.7222e-6f, .0091547f, .010267f,
-    9.5535e-5f, .030194f, -2.5674e-5f, 6170.f, 6180.f, 1.7703e-5f, .012682f,
-    .0090194f, 1.0461e-4f, .028528f, -8.8439e-6f, 6180.f, 6190.f,
-    3.2557e-5f, .038848f, .022453f, 5.1526e-5f, .032595f, -1.0114e-4f,
-    6190.f, 6200.f, 3.6378e-5f, .026446f, .022869f, 1.5344e-5f, .029472f,
-    -7.8062e-5f, 6200.f, 6210.f, 1.5091e-4f, .045107f, .027472f,
-    -9.5379e-5f, .027231f, -1.0428e-4f, 6210.f, 6220.f, 4.4635e-4f,
-    .044617f, .022992f, -8.3379e-5f, .022135f, -8.6546e-5f, 6220.f, 6230.f,
-    4.645e-4f, .025101f, .020065f, -7.4635e-5f, .019585f, -7.1162e-5f,
-    6230.f, 6240.f, .0018567f, .045449f, .017769f, -7.6382e-5f, .015878f,
-    -6.8709e-5f, 6240.f, 6250.f, .0042909f, .047419f, .01417f, -6.399e-5f,
-    .012295f, -5.5119e-5f, 6250.f, 6260.f, .0037371f, .024446f, .011714f,
-    -5.4834e-5f, .0096092f, -4.6244e-5f, 6260.f, 6270.f, .012658f, .047613f,
-    .0091389f, -4.4311e-5f, .006717f, -3.7584e-5f, 6270.f, 6280.f, .022981f,
-    .050782f, .0062294f, -3.2686e-5f, .0039945f, -2.4418e-5f, 6280.f,
-    6290.f, .03751f, .052128f, .0036805f, -2.2546e-5f, .0014034f,
-    -1.3971e-5f, 6290.f, 6300.f, .054636f, .053047f, .0014952f, -1.3854e-5f,
-    -7.4579e-4f, -4.3465e-6f, 6300.f, 6310.f, .070262f, .053883f,
-    -3.2751e-4f, -6.6345e-6f, -.0026603f, 2.8956e-6f, 6310.f, 6320.f,
-    .078204f, .055207f, -.0017859f, -8.6799e-7f, -.0043181f, 7.5236e-6f,
-    6320.f, 6330.f, .10057f, .088588f, -.0030519f, 4.1846e-6f, -.0057894f,
-    1.0937e-5f, 6330.f, 6340.f, .031333f, .065185f, -.0038296f, 7.2424e-6f,
-    -.006643f, 1.2937e-5f, 6340.f, 6350.f, .033845f, .06492f, -.0039811f,
-    7.8455e-6f, -.0067871f, 1.3512e-5f, 6350.f, 6360.f, .12178f, .088198f,
-    -.0034193f, 5.6304e-6f, -.0062387f, 1.1334e-5f, 6360.f, 6370.f, .15914f,
-    .081345f, -.0020733f, 3.2783e-7f, -.0048764f, 5.9258e-6f, 6370.f,
-    6380.f, .17605f, .10382f, 4.7396e-4f, -9.4825e-6f, -.0022623f,
-    -4.3366e-6f, 6380.f, 6390.f, .10257f, .11943f, .0050797f, -2.6879e-5f,
-    .002564f, -2.3075e-5f, 6390.f, 6400.f, .025341f, .11996f, .012613f,
-    -5.5092e-5f, .010613f, -5.3927e-5f, 6400.f, 6410.f, .0020638f, .13697f,
-    .024524f, -9.7954e-5f, .025258f, -9.9948e-5f, 6410.f, 6420.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f,
-    6440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6440.f, 6450.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6450.f, 6460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6460.f, 6470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6470.f, 6480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6480.f,
-    6490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6490.f, 6500.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6500.f, 6510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6510.f, 6520.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6520.f, 6530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6530.f,
-    6540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6540.f, 6550.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6550.f, 6560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6560.f, 6570.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6580.f,
-    6590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6600.f, 6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6620.f, 6630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6630.f,
-    6640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6640.f, 6650.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6650.f, 6660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6660.f, 6670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6670.f, 6680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6680.f,
-    6690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6690.f, 6700.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6700.f, 6710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6710.f, 6720.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6720.f, 6730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6730.f,
-    6740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6740.f, 6750.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6750.f, 6760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6760.f, 6770.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6770.f, 6780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6780.f,
-    6790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6800.f, 6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6820.f, 6830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6830.f,
-    6840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6840.f, 6850.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6850.f, 6860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6860.f, 6870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6870.f, 6880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6880.f,
-    6890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6890.f, 6900.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6900.f, 6910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6910.f, 6920.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6920.f, 6930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6930.f,
-    6940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6940.f, 6950.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 6950.f, 6960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6960.f, 6970.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 6970.f, 6980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6980.f,
-    6990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 7e3f, 7010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f,
-      7040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7050.f, 7060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f,
-      7090.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7100.f, 7110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f,
-      7140.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7150.f, 7160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f,
-      7190.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7200.f, 7210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f,
-      7240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7240.f, 7250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7250.f, 7260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7260.f, 7270.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7270.f, 7280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7280.f,
-      7290.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7290.f, 7300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7300.f, 7310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f,
-      7340.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7350.f, 7360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f,
-      7390.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7390.f, 7400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7400.f, 7410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7410.f, 7420.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7420.f, 7430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7430.f,
-      7440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7440.f, 7450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7450.f, 7460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7460.f, 7470.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7470.f, 7480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7480.f,
-      7490.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7490.f, 7500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7500.f, 7510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7510.f, 7520.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7520.f, 7530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7530.f,
-      7540.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7540.f, 7550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7550.f, 7560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7560.f, 7570.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 7570.f, 7580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7580.f,
-      7590.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7590.f, 7600.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    7600.f, 7610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7610.f, 7620.f
+				     6.4883e-7f, .087374f, -3.4877e-4f, .086636f, -3.5122e-4f, 5800.f,
+				     5810.f, 1.6009e-19f, 9.5335e-7f, .0849f, -3.3381e-4f, .084844f,
+				     -3.4257e-4f, 5810.f, 5820.f, 1.0493e-18f, 1.0941e-6f, .076482f,
+				     -3.0762e-4f, .080072f, -2.5402e-4f, 5820.f, 5830.f, 1.8849e-18f,
+				     2.3089e-6f, .073551f, -2.7995e-4f, .10134f, -1.0464e-4f, 5830.f, 5840.f,
+				     1.2274e-17f, 1.8503e-6f, .065955f, -2.6262e-4f, .08719f, -6.1536e-5f,
+				     5840.f, 5850.f, 1.9475e-17f, 2.1482e-6f, .062641f, -2.3947e-4f,
+				     .092133f, -5.5475e-5f, 5850.f, 5860.f, 4.2834e-17f, 5.2914e-6f,
+				     .060443f, -2.1227e-4f, .10022f, -9.1581e-5f, 5860.f, 5870.f,
+				     2.5814e-16f, 2.709e-6f, .053613f, -2.0674e-4f, .078473f, -2.4556e-5f,
+				     5870.f, 5880.f, 3.4582e-16f, 2.4018e-6f, .049817f, -1.8578e-4f,
+				     .083893f, -9.9109e-6f, 5880.f, 5890.f, 1.9766e-15f, 2.6621e-6f,
+				     .044522f, -1.7276e-4f, .070531f, 1.7855e-5f, 5890.f, 5900.f,
+				     7.0047e-15f, 5.7066e-6f, .039496f, -1.4181e-4f, .075654f, 5.7712e-6f,
+				     5900.f, 5910.f, 8.6757e-15f, 3.3052e-5f, .040851f, -4.9822e-5f,
+				     .088823f, -2.0654e-4f, 5910.f, 5920.f, 4.0761e-14f, 1.4076e-5f,
+				     .033721f, -8.1073e-5f, .073952f, -7.155e-5f, 5920.f, 5930.f,
+				     1.1802e-13f, 1.8315e-5f, .029401f, -5.6811e-5f, .072527f, -6.1682e-5f,
+				     5930.f, 5940.f, 1.2517e-13f, 3.208e-5f, .029645f, 5.2262e-6f, .075673f,
+				     -1.605e-4f, 5940.f, 5950.f, 5.3299e-13f, 8.3885e-5f, .028648f,
+				     5.1037e-5f, .076701f, -1.1804e-4f, 5950.f, 5960.f, 1.2176e-12f,
+				     4.3932e-5f, .023072f, 3.9649e-5f, .070157f, -2.5205e-5f, 5960.f, 5970.f,
+				     2.6812e-12f, 7.4724e-5f, .021392f, 7.8492e-5f, .0689f, -5.7739e-5f,
+				     5970.f, 5980.f, 5.2852e-12f, 8.1623e-5f, .018441f, 9.2123e-5f, .072474f,
+				     3.8196e-5f, 5980.f, 5990.f, 1.2137e-11f, 2.5414e-4f, .024162f,
+				     1.7686e-4f, .065473f, -1.1219e-4f, 5990.f, 6e3f, 2.022e-11f, 1.7439e-4f,
+				     .021342f, 1.7061e-4f, .061647f, -4.9481e-5f, 6e3f, 6010.f, 7.0256e-11f,
+				     3.9013e-4f, .025354f, 1.739e-4f, .056294f, -1.0119e-4f, 6010.f, 6020.f,
+				     9.1715e-11f, 3.8456e-4f, .027846f, 1.3835e-4f, .055857f, -8.5738e-5f,
+				     6020.f, 6030.f, 3.5812e-10f, 8.9526e-4f, .036811f, -1.9691e-5f,
+				     .060026f, -5.1263e-5f, 6030.f, 6040.f, 5.1951e-10f, 6.5082e-4f,
+				     .034472f, -3.8106e-5f, .057771f, -1.7166e-5f, 6040.f, 6050.f,
+				     2.3396e-9f, .0012585f, .037673f, -1.3867e-4f, .056388f, -3.7053e-5f,
+				     6050.f, 6060.f, 3.1627e-9f, .0012183f, .033941f, -1.1427e-4f, .058265f,
+				     -1.4231e-5f, 6060.f, 6070.f, 1.3747e-8f, .0010905f, .030224f,
+				     -1.1494e-4f, .045888f, -1.243e-5f, 6070.f, 6080.f, 1.6746e-8f,
+				     .0011055f, .0271f, -9.4052e-5f, .048795f, 1.7267e-6f, 6080.f, 6090.f,
+				     6.9627e-8f, .0014531f, .023474f, -8.7211e-5f, .042687f, 2.9187e-5f,
+				     6090.f, 6100.f, 1.789e-7f, .0023713f, .020122f, -5.984e-5f, .042924f,
+				     9.3171e-6f, 6100.f, 6110.f, 1.6918e-7f, .002373f, .018564f, -3.2576e-5f,
+				     .047913f, -5.6001e-6f, 6110.f, 6120.f, 6.1497e-7f, .0020751f, .014671f,
+				     -3.6986e-5f, .03447f, 3.2655e-5f, 6120.f, 6130.f, 1.3012e-6f, .0059809f,
+				     .014081f, 1.2706e-5f, .041059f, -1.4713e-5f, 6130.f, 6140.f, 2.3687e-6f,
+				     .0034824f, .010334f, 1.187e-5f, .031822f, 2.134e-5f, 6140.f, 6150.f,
+				     4.1168e-6f, .0049295f, .0084797f, 3.3745e-5f, .032297f, 2.8091e-5f,
+				     6150.f, 6160.f, 7.275e-6f, .015527f, .012669f, 9.9217e-5f, .036777f,
+				     -5.5634e-5f, 6160.f, 6170.f, 9.7222e-6f, .0091547f, .010267f,
+				     9.5535e-5f, .030194f, -2.5674e-5f, 6170.f, 6180.f, 1.7703e-5f, .012682f,
+				     .0090194f, 1.0461e-4f, .028528f, -8.8439e-6f, 6180.f, 6190.f,
+				     3.2557e-5f, .038848f, .022453f, 5.1526e-5f, .032595f, -1.0114e-4f,
+				     6190.f, 6200.f, 3.6378e-5f, .026446f, .022869f, 1.5344e-5f, .029472f,
+				     -7.8062e-5f, 6200.f, 6210.f, 1.5091e-4f, .045107f, .027472f,
+				     -9.5379e-5f, .027231f, -1.0428e-4f, 6210.f, 6220.f, 4.4635e-4f,
+				     .044617f, .022992f, -8.3379e-5f, .022135f, -8.6546e-5f, 6220.f, 6230.f,
+				     4.645e-4f, .025101f, .020065f, -7.4635e-5f, .019585f, -7.1162e-5f,
+				     6230.f, 6240.f, .0018567f, .045449f, .017769f, -7.6382e-5f, .015878f,
+				     -6.8709e-5f, 6240.f, 6250.f, .0042909f, .047419f, .01417f, -6.399e-5f,
+				     .012295f, -5.5119e-5f, 6250.f, 6260.f, .0037371f, .024446f, .011714f,
+				     -5.4834e-5f, .0096092f, -4.6244e-5f, 6260.f, 6270.f, .012658f, .047613f,
+				     .0091389f, -4.4311e-5f, .006717f, -3.7584e-5f, 6270.f, 6280.f, .022981f,
+				     .050782f, .0062294f, -3.2686e-5f, .0039945f, -2.4418e-5f, 6280.f,
+				     6290.f, .03751f, .052128f, .0036805f, -2.2546e-5f, .0014034f,
+				     -1.3971e-5f, 6290.f, 6300.f, .054636f, .053047f, .0014952f, -1.3854e-5f,
+				     -7.4579e-4f, -4.3465e-6f, 6300.f, 6310.f, .070262f, .053883f,
+				     -3.2751e-4f, -6.6345e-6f, -.0026603f, 2.8956e-6f, 6310.f, 6320.f,
+				     .078204f, .055207f, -.0017859f, -8.6799e-7f, -.0043181f, 7.5236e-6f,
+				     6320.f, 6330.f, .10057f, .088588f, -.0030519f, 4.1846e-6f, -.0057894f,
+				     1.0937e-5f, 6330.f, 6340.f, .031333f, .065185f, -.0038296f, 7.2424e-6f,
+				     -.006643f, 1.2937e-5f, 6340.f, 6350.f, .033845f, .06492f, -.0039811f,
+				     7.8455e-6f, -.0067871f, 1.3512e-5f, 6350.f, 6360.f, .12178f, .088198f,
+				     -.0034193f, 5.6304e-6f, -.0062387f, 1.1334e-5f, 6360.f, 6370.f, .15914f,
+				     .081345f, -.0020733f, 3.2783e-7f, -.0048764f, 5.9258e-6f, 6370.f,
+				     6380.f, .17605f, .10382f, 4.7396e-4f, -9.4825e-6f, -.0022623f,
+				     -4.3366e-6f, 6380.f, 6390.f, .10257f, .11943f, .0050797f, -2.6879e-5f,
+				     .002564f, -2.3075e-5f, 6390.f, 6400.f, .025341f, .11996f, .012613f,
+				     -5.5092e-5f, .010613f, -5.3927e-5f, 6400.f, 6410.f, .0020638f, .13697f,
+				     .024524f, -9.7954e-5f, .025258f, -9.9948e-5f, 6410.f, 6420.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 6420.f, 6430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6430.f,
+				     6440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6440.f, 6450.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6450.f, 6460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6460.f, 6470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6470.f, 6480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6480.f,
+				     6490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6490.f, 6500.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6500.f, 6510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6510.f, 6520.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6520.f, 6530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6530.f,
+				     6540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6540.f, 6550.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6550.f, 6560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6560.f, 6570.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6570.f, 6580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6580.f,
+				     6590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6590.f, 6600.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6600.f, 6610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6610.f, 6620.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6620.f, 6630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6630.f,
+				     6640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6640.f, 6650.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6650.f, 6660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6660.f, 6670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6670.f, 6680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6680.f,
+				     6690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6690.f, 6700.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6700.f, 6710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6710.f, 6720.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6720.f, 6730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6730.f,
+				     6740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6740.f, 6750.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6750.f, 6760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6760.f, 6770.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6770.f, 6780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6780.f,
+				     6790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6790.f, 6800.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6800.f, 6810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6810.f, 6820.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6820.f, 6830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6830.f,
+				     6840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6840.f, 6850.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6850.f, 6860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6860.f, 6870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6870.f, 6880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6880.f,
+				     6890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6890.f, 6900.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6900.f, 6910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6910.f, 6920.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6920.f, 6930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6930.f,
+				     6940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6940.f, 6950.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 6950.f, 6960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6960.f, 6970.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 6970.f, 6980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6980.f,
+				     6990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 6990.f, 7e3f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 7e3f, 7010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7010.f, 7020.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7020.f, 7030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7030.f,
+				     7040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7040.f, 7050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7050.f, 7060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7060.f, 7070.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7070.f, 7080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7080.f,
+				     7090.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7090.f, 7100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7100.f, 7110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7110.f, 7120.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7120.f, 7130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7130.f,
+				     7140.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7140.f, 7150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7150.f, 7160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7160.f, 7170.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7170.f, 7180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7180.f,
+				     7190.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7190.f, 7200.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7200.f, 7210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7210.f, 7220.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7220.f, 7230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7230.f,
+				     7240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7240.f, 7250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7250.f, 7260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7260.f, 7270.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7270.f, 7280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7280.f,
+				     7290.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7290.f, 7300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7300.f, 7310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7310.f, 7320.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7320.f, 7330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7330.f,
+				     7340.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7340.f, 7350.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7350.f, 7360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7360.f, 7370.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7370.f, 7380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7380.f,
+				     7390.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7390.f, 7400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7400.f, 7410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7410.f, 7420.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7420.f, 7430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7430.f,
+				     7440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7440.f, 7450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7450.f, 7460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7460.f, 7470.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7470.f, 7480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7480.f,
+				     7490.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7490.f, 7500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7500.f, 7510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7510.f, 7520.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7520.f, 7530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7530.f,
+				     7540.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7540.f, 7550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7550.f, 7560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7560.f, 7570.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 7570.f, 7580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7580.f,
+				     7590.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7590.f, 7600.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     7600.f, 7610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7610.f, 7620.f
-	/* carbon monoxide (5060 - 7610 cm-1) */
+    /* carbon monoxide (5060 - 7610 cm-1) */
 }	/* moca2 */
 void
@@ -8534,308 +8534,308 @@
-    0.f, 2500.f, 2510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2510.f, 2520.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2520.f, 2530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2530.f,
-    2540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2540.f, 2550.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2550.f, 2560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2560.f, 2570.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2570.f, 2580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2580.f,
-    2590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2590.f, 2600.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2600.f, 2610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2610.f, 2620.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2620.f, 2630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2630.f,
-    2640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2640.f, 2650.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2650.f, 2660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2660.f, 2670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2670.f, 2680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2680.f,
-    2690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2690.f, 2700.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2700.f, 2710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2710.f, 2720.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2720.f, 2730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2730.f,
-    2740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2740.f, 2750.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2750.f, 2760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2760.f, 2770.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2770.f, 2780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2780.f,
-    2790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2790.f, 2800.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2800.f, 2810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2810.f, 2820.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2820.f, 2830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2830.f,
-    2840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2840.f, 2850.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2850.f, 2860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2860.f, 2870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2870.f, 2880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2880.f,
-    2890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2890.f, 2900.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2900.f, 2910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2910.f, 2920.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2920.f, 2930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2930.f,
-    2940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2940.f, 2950.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 2950.f, 2960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2960.f, 2970.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 2970.f, 2980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2980.f,
-    2990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2990.f, 3e3f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 3e3f, 3010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3010.f, 3020.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3020.f, 3030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3030.f,
-      3040.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3040.f, 3050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3050.f, 3060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3060.f, 3070.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3070.f, 3080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3080.f,
-      3090.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3090.f, 3100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3100.f, 3110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3110.f, 3120.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3120.f, 3130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3130.f,
-      3140.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3140.f, 3150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3150.f, 3160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3160.f, 3170.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3170.f, 3180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3180.f,
-      3190.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3190.f, 3200.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3200.f, 3210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3210.f, 3220.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3220.f, 3230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3230.f,
-      3240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3240.f, 3250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3250.f, 3260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3260.f, 3270.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3270.f, 3280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3280.f,
-      3290.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3290.f, 3300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3300.f, 3310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3310.f, 3320.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3320.f, 3330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3330.f,
-      3340.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3340.f, 3350.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3350.f, 3360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3360.f, 3370.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3370.f, 3380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3380.f,
-      3390.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3390.f, 3400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3400.f, 3410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3410.f, 3420.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3420.f, 3430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3430.f,
-      3440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3440.f, 3450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3450.f, 3460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3460.f, 3470.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3470.f, 3480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3480.f,
-      3490.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3490.f, 3500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3500.f, 3510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3510.f, 3520.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3520.f, 3530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3530.f,
-      3540.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3540.f, 3550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3550.f, 3560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3560.f, 3570.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3570.f, 3580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3580.f,
-      3590.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3590.f, 3600.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3600.f, 3610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3610.f, 3620.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3620.f, 3630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3630.f,
-      3640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3640.f, 3650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3650.f, 3660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3660.f, 3670.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3670.f, 3680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3680.f,
-      3690.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3690.f, 3700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3700.f, 3710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3710.f, 3720.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 3720.f, 3730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3730.f,
-      3740.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3740.f, 3750.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    3750.f, 3760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3760.f, 3770.f, 2.6188e-23f,
-    7.5648e-7f, .14705f, -5.9469e-4f, .14469f, -5.9147e-4f, 3770.f, 3780.f,
-    1.7237e-22f, 7.5958e-7f, .13909f, -5.6296e-4f, .13671f, -5.596e-4f,
-    3780.f, 3790.f, 3.0601e-22f, 3.9946e-7f, .13415f, -5.447e-4f, .13135f,
-    -5.3906e-4f, 3790.f, 3800.f, 2.5148e-21f, 7.6406e-7f, .12775f,
-    -5.1775e-4f, .12533f, -5.1417e-4f, 3800.f, 3810.f, 2.5745e-19f,
-    6.6661e-7f, .10289f, -4.1172e-4f, .10359f, -4.1229e-4f, 3810.f, 3820.f,
-    2.3471e-18f, 8.5834e-7f, .095064f, -3.8496e-4f, .093786f, -3.8192e-4f,
-    3820.f, 3830.f, 4.4267e-18f, 6.1131e-7f, .090479f, -3.6372e-4f,
-    .091063f, -3.6128e-4f, 3830.f, 3840.f, 3.7544e-17f, 9.6342e-7f,
-    .083552f, -3.3748e-4f, .083109f, -3.3494e-4f, 3840.f, 3850.f,
-    6.6043e-17f, 4.5762e-6f, .080581f, -2.9237e-4f, .1186f, -1.9899e-4f,
-    3850.f, 3860.f, 5.0104e-16f, 3.0566e-6f, .073204f, -2.8334e-4f, .10085f,
-    -1.1404e-4f, 3860.f, 3870.f, 2.5102e-15f, 5.6505e-6f, .066558f,
-    -2.4745e-4f, .10411f, -1.0858e-4f, 3870.f, 3880.f, 1.179e-14f,
-    7.1883e-6f, .060355f, -2.1477e-4f, .099433f, -1.0798e-4f, 3880.f,
-    3890.f, 1.7518e-14f, 1.0491e-5f, .058888f, -1.6207e-4f, .09819f,
-    -2.0655e-4f, 3890.f, 3900.f, 1.2334e-13f, 8.2478e-5f, .061162f,
-    -4.6855e-5f, .099456f, -3.0433e-4f, 3900.f, 3910.f, 5.9987e-13f,
-    1.9476e-4f, .061687f, 1.0764e-5f, .093436f, -3.2996e-4f, 3910.f, 3920.f,
-    1.7948e-12f, 9.9622e-5f, .052116f, 1.2152e-5f, .087699f, -2.7025e-4f,
-    3920.f, 3930.f, 8.3226e-12f, 3.291e-4f, .054625f, 5.1416e-5f, .089131f,
-    -2.3629e-4f, 3930.f, 3940.f, 2.0276e-11f, 2.1725e-4f, .045681f,
-    6.3672e-5f, .093594f, -1.044e-4f, 3940.f, 3950.f, 9.452e-11f,
-    4.2081e-4f, .049658f, 5.7601e-5f, .079407f, -1.9603e-4f, 3950.f, 3960.f,
-    2.0604e-10f, 4.2113e-4f, .043092f, 7.9797e-5f, .08456f, -1.0065e-4f,
-    3960.f, 3970.f, 9.2559e-10f, 5.2769e-4f, .046842f, 2.13e-5f, .070955f,
-    -1.5981e-4f, 3970.f, 3980.f, 4.0093e-9f, .0016525f, .048905f,
-    -4.3479e-5f, .080584f, -1.3211e-4f, 3980.f, 3990.f, 7.2188e-9f,
-    .0049631f, .047903f, 3.506e-5f, .087341f, -2.2515e-4f, 3990.f, 4e3f,
-    3.5244e-8f, .0026406f, .044217f, -4.3905e-5f, .074799f, -1.3539e-4f,
-    4e3f, 4010.f, 1.4041e-7f, .0058689f, .045795f, -7.4645e-5f, .073346f,
-    -1.7741e-4f, 4010.f, 4020.f, 4.8242e-7f, .0031728f, .03946f,
-    -9.4315e-5f, .063747f, -1.0552e-4f, 4020.f, 4030.f, 1.5614e-6f,
-    .0029789f, .03481f, -9.4517e-5f, .058578f, -7.6764e-5f, 4030.f, 4040.f,
-    2.3212e-6f, .011038f, .038571f, -4.0092e-6f, .064826f, -1.8611e-4f,
-    4040.f, 4050.f, 1.0679e-5f, .014942f, .035924f, 2.0954e-7f, .05826f,
-    -1.6362e-4f, 4050.f, 4060.f, 2.5314e-5f, .0076112f, .028757f,
-    -2.7274e-6f, .050639f, -1.0468e-4f, 4060.f, 4070.f, 8.2488e-5f,
-    .019238f, .031099f, 3.2981e-5f, .049127f, -1.4923e-4f, 4070.f, 4080.f,
-    1.5838e-4f, .010696f, .024633f, 3.8132e-5f, .04326f, -9.7166e-5f,
-    4080.f, 4090.f, 5.3014e-4f, .027912f, .028944f, 3.4086e-5f, .042425f,
-    -1.3608e-4f, 4090.f, 4100.f, .0019236f, .031464f, .026171f, 2.5248e-5f,
-    .036412f, -1.1618e-4f, 4100.f, 4110.f, .002417f, .018774f, .023171f,
-    3.1047e-5f, .032949f, -9.3254e-5f, 4110.f, 4120.f, .0095957f, .039252f,
-    .027808f, -5.0845e-5f, .030866f, -1.1461e-4f, 4120.f, 4130.f, .029222f,
-    .041309f, .025476f, -7.0834e-5f, .025927f, -9.9072e-5f, 4130.f, 4140.f,
-    .080521f, .042144f, .023591f, -9.2915e-5f, .022029f, -9.0905e-5f,
-    4140.f, 4150.f, .21163f, .043454f, .019801f, -8.4058e-5f, .017719f,
-    -7.6225e-5f, 4150.f, 4160.f, .20177f, .023178f, .017214f, -7.6243e-5f,
-    .015553f, -6.4832e-5f, 4160.f, 4170.f, .7632f, .046725f, .01416f,
-    -6.3818e-5f, .012147f, -5.4565e-5f, 4170.f, 4180.f, 1.5947f, .047792f,
-    .010708f, -5.0352e-5f, .0083233f, -4.2778e-5f, 4180.f, 4190.f, 5.2669f,
-    .073957f, .0067643f, -3.4467e-5f, .004319f, -2.8069e-5f, 4190.f, 4200.f,
-    6.4202f, .051382f, .0036772f, -2.2614e-5f, 9.742e-4f, -1.6763e-5f,
-    4200.f, 4210.f, 9.2445f, .052627f, .0014938f, -1.3915e-5f, -.0010491f,
-    -6.9012e-6f, 4210.f, 4220.f, 11.75f, .05381f, -3.2681e-4f, -6.6562e-6f,
-    -.0028054f, 1.0375e-6f, 4220.f, 4230.f, 12.919f, .055506f, -.0017838f,
-    -8.5608e-7f, -.0042665f, 7.1579e-6f, 4230.f, 4240.f, 16.381f, .089081f,
-    -.003049f, 4.1985e-6f, -.0056615f, 1.1648e-5f, 4240.f, 4250.f, 5.0278f,
-    .066105f, -.0038255f, 7.3053e-6f, -.0061865f, 1.7191e-5f, 4250.f,
-    4260.f, 5.3208f, .065464f, -.0039797f, 7.8726e-6f, -.006508f,
-    1.6403e-5f, 4260.f, 4270.f, 18.844f, .088395f, -.0034205f, 5.6382e-6f,
-    -.0061631f, 1.2216e-5f, 4270.f, 4280.f, 24.188f, .081391f, -.0020758f,
-    3.3792e-7f, -.004851f, 6.276e-6f, 4280.f, 4290.f, 20.85f, .078388f,
-    7.1143e-5f, -8.1227e-6f, -.0026924f, -2.6258e-6f, 4290.f, 4300.f,
-    16.326f, .099662f, .003472f, -2.1159e-5f, 8.2032e-4f, -1.6489e-5f,
-    4300.f, 4310.f, 5.9676f, .090468f, .0087017f, -4.1571e-5f, .0061894f,
-    -3.7687e-5f, 4310.f, 4320.f, 1.4674f, .080452f, .015334f, -6.7528e-5f,
-    .012977f, -6.4486e-5f, 4320.f, 4330.f, .26137f, .087098f, .023749f,
-    -9.9448e-5f, .02192f, -9.8971e-5f, 4330.f, 4340.f, .017052f, .094008f,
-    .036064f, -1.4594e-4f, .035363f, -1.4924e-4f, 4340.f, 4350.f,
-    1.3974e-4f, .088019f, .056495f, -2.2628e-4f, .057375f, -2.2878e-4f,
-    4350.f, 4360.f, 2.5708e-10f, .017736f, .10803f, -4.4019e-4f, .10523f,
-    -4.3455e-4f, 4360.f, 4370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4370.f, 4380.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4380.f, 4390.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4390.f, 4400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4400.f, 4410.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4410.f, 4420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4420.f,
-      4430.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4430.f, 4440.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4440.f, 4450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4450.f, 4460.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4460.f, 4470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4470.f,
-      4480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4480.f, 4490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4490.f, 4500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4500.f, 4510.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4510.f, 4520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4520.f,
-      4530.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4530.f, 4540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4540.f, 4550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4550.f, 4560.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4560.f, 4570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4570.f,
-      4580.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4580.f, 4590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4590.f, 4600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4600.f, 4610.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4610.f, 4620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4620.f,
-      4630.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4630.f, 4640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4640.f, 4650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4650.f, 4660.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4660.f, 4670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4670.f,
-      4680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4680.f, 4690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4690.f, 4700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4700.f, 4710.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4710.f, 4720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4720.f,
-      4730.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4730.f, 4740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4740.f, 4750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4750.f, 4760.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4760.f, 4770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4770.f,
-      4780.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4780.f, 4790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4790.f, 4800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4800.f, 4810.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4810.f, 4820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4820.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 2500.f, 2510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2510.f, 2520.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2520.f, 2530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2530.f,
+				     2540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2540.f, 2550.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2550.f, 2560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2560.f, 2570.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2570.f, 2580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2580.f,
+				     2590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2590.f, 2600.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2600.f, 2610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2610.f, 2620.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2620.f, 2630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2630.f,
+				     2640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2640.f, 2650.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2650.f, 2660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2660.f, 2670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2670.f, 2680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2680.f,
+				     2690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2690.f, 2700.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2700.f, 2710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2710.f, 2720.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2720.f, 2730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2730.f,
+				     2740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2740.f, 2750.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2750.f, 2760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2760.f, 2770.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2770.f, 2780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2780.f,
+				     2790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2790.f, 2800.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2800.f, 2810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2810.f, 2820.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2820.f, 2830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2830.f,
+				     2840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2840.f, 2850.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2850.f, 2860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2860.f, 2870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2870.f, 2880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2880.f,
+				     2890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2890.f, 2900.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2900.f, 2910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2910.f, 2920.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2920.f, 2930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2930.f,
+				     2940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2940.f, 2950.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 2950.f, 2960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2960.f, 2970.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 2970.f, 2980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2980.f,
+				     2990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 2990.f, 3e3f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 3e3f, 3010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3010.f, 3020.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3020.f, 3030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3030.f,
+				     3040.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3040.f, 3050.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3050.f, 3060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3060.f, 3070.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3070.f, 3080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3080.f,
+				     3090.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3090.f, 3100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3100.f, 3110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3110.f, 3120.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3120.f, 3130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3130.f,
+				     3140.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3140.f, 3150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3150.f, 3160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3160.f, 3170.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3170.f, 3180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3180.f,
+				     3190.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3190.f, 3200.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3200.f, 3210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3210.f, 3220.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3220.f, 3230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3230.f,
+				     3240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3240.f, 3250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3250.f, 3260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3260.f, 3270.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3270.f, 3280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3280.f,
+				     3290.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3290.f, 3300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3300.f, 3310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3310.f, 3320.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3320.f, 3330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3330.f,
+				     3340.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3340.f, 3350.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3350.f, 3360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3360.f, 3370.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3370.f, 3380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3380.f,
+				     3390.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3390.f, 3400.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3400.f, 3410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3410.f, 3420.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3420.f, 3430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3430.f,
+				     3440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3440.f, 3450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3450.f, 3460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3460.f, 3470.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3470.f, 3480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3480.f,
+				     3490.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3490.f, 3500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3500.f, 3510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3510.f, 3520.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3520.f, 3530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3530.f,
+				     3540.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3540.f, 3550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3550.f, 3560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3560.f, 3570.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3570.f, 3580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3580.f,
+				     3590.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3590.f, 3600.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3600.f, 3610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3610.f, 3620.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3620.f, 3630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3630.f,
+				     3640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3640.f, 3650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3650.f, 3660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3660.f, 3670.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3670.f, 3680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3680.f,
+				     3690.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3690.f, 3700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3700.f, 3710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3710.f, 3720.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 3720.f, 3730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3730.f,
+				     3740.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3740.f, 3750.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     3750.f, 3760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 3760.f, 3770.f, 2.6188e-23f,
+				     7.5648e-7f, .14705f, -5.9469e-4f, .14469f, -5.9147e-4f, 3770.f, 3780.f,
+				     1.7237e-22f, 7.5958e-7f, .13909f, -5.6296e-4f, .13671f, -5.596e-4f,
+				     3780.f, 3790.f, 3.0601e-22f, 3.9946e-7f, .13415f, -5.447e-4f, .13135f,
+				     -5.3906e-4f, 3790.f, 3800.f, 2.5148e-21f, 7.6406e-7f, .12775f,
+				     -5.1775e-4f, .12533f, -5.1417e-4f, 3800.f, 3810.f, 2.5745e-19f,
+				     6.6661e-7f, .10289f, -4.1172e-4f, .10359f, -4.1229e-4f, 3810.f, 3820.f,
+				     2.3471e-18f, 8.5834e-7f, .095064f, -3.8496e-4f, .093786f, -3.8192e-4f,
+				     3820.f, 3830.f, 4.4267e-18f, 6.1131e-7f, .090479f, -3.6372e-4f,
+				     .091063f, -3.6128e-4f, 3830.f, 3840.f, 3.7544e-17f, 9.6342e-7f,
+				     .083552f, -3.3748e-4f, .083109f, -3.3494e-4f, 3840.f, 3850.f,
+				     6.6043e-17f, 4.5762e-6f, .080581f, -2.9237e-4f, .1186f, -1.9899e-4f,
+				     3850.f, 3860.f, 5.0104e-16f, 3.0566e-6f, .073204f, -2.8334e-4f, .10085f,
+				     -1.1404e-4f, 3860.f, 3870.f, 2.5102e-15f, 5.6505e-6f, .066558f,
+				     -2.4745e-4f, .10411f, -1.0858e-4f, 3870.f, 3880.f, 1.179e-14f,
+				     7.1883e-6f, .060355f, -2.1477e-4f, .099433f, -1.0798e-4f, 3880.f,
+				     3890.f, 1.7518e-14f, 1.0491e-5f, .058888f, -1.6207e-4f, .09819f,
+				     -2.0655e-4f, 3890.f, 3900.f, 1.2334e-13f, 8.2478e-5f, .061162f,
+				     -4.6855e-5f, .099456f, -3.0433e-4f, 3900.f, 3910.f, 5.9987e-13f,
+				     1.9476e-4f, .061687f, 1.0764e-5f, .093436f, -3.2996e-4f, 3910.f, 3920.f,
+				     1.7948e-12f, 9.9622e-5f, .052116f, 1.2152e-5f, .087699f, -2.7025e-4f,
+				     3920.f, 3930.f, 8.3226e-12f, 3.291e-4f, .054625f, 5.1416e-5f, .089131f,
+				     -2.3629e-4f, 3930.f, 3940.f, 2.0276e-11f, 2.1725e-4f, .045681f,
+				     6.3672e-5f, .093594f, -1.044e-4f, 3940.f, 3950.f, 9.452e-11f,
+				     4.2081e-4f, .049658f, 5.7601e-5f, .079407f, -1.9603e-4f, 3950.f, 3960.f,
+				     2.0604e-10f, 4.2113e-4f, .043092f, 7.9797e-5f, .08456f, -1.0065e-4f,
+				     3960.f, 3970.f, 9.2559e-10f, 5.2769e-4f, .046842f, 2.13e-5f, .070955f,
+				     -1.5981e-4f, 3970.f, 3980.f, 4.0093e-9f, .0016525f, .048905f,
+				     -4.3479e-5f, .080584f, -1.3211e-4f, 3980.f, 3990.f, 7.2188e-9f,
+				     .0049631f, .047903f, 3.506e-5f, .087341f, -2.2515e-4f, 3990.f, 4e3f,
+				     3.5244e-8f, .0026406f, .044217f, -4.3905e-5f, .074799f, -1.3539e-4f,
+				     4e3f, 4010.f, 1.4041e-7f, .0058689f, .045795f, -7.4645e-5f, .073346f,
+				     -1.7741e-4f, 4010.f, 4020.f, 4.8242e-7f, .0031728f, .03946f,
+				     -9.4315e-5f, .063747f, -1.0552e-4f, 4020.f, 4030.f, 1.5614e-6f,
+				     .0029789f, .03481f, -9.4517e-5f, .058578f, -7.6764e-5f, 4030.f, 4040.f,
+				     2.3212e-6f, .011038f, .038571f, -4.0092e-6f, .064826f, -1.8611e-4f,
+				     4040.f, 4050.f, 1.0679e-5f, .014942f, .035924f, 2.0954e-7f, .05826f,
+				     -1.6362e-4f, 4050.f, 4060.f, 2.5314e-5f, .0076112f, .028757f,
+				     -2.7274e-6f, .050639f, -1.0468e-4f, 4060.f, 4070.f, 8.2488e-5f,
+				     .019238f, .031099f, 3.2981e-5f, .049127f, -1.4923e-4f, 4070.f, 4080.f,
+				     1.5838e-4f, .010696f, .024633f, 3.8132e-5f, .04326f, -9.7166e-5f,
+				     4080.f, 4090.f, 5.3014e-4f, .027912f, .028944f, 3.4086e-5f, .042425f,
+				     -1.3608e-4f, 4090.f, 4100.f, .0019236f, .031464f, .026171f, 2.5248e-5f,
+				     .036412f, -1.1618e-4f, 4100.f, 4110.f, .002417f, .018774f, .023171f,
+				     3.1047e-5f, .032949f, -9.3254e-5f, 4110.f, 4120.f, .0095957f, .039252f,
+				     .027808f, -5.0845e-5f, .030866f, -1.1461e-4f, 4120.f, 4130.f, .029222f,
+				     .041309f, .025476f, -7.0834e-5f, .025927f, -9.9072e-5f, 4130.f, 4140.f,
+				     .080521f, .042144f, .023591f, -9.2915e-5f, .022029f, -9.0905e-5f,
+				     4140.f, 4150.f, .21163f, .043454f, .019801f, -8.4058e-5f, .017719f,
+				     -7.6225e-5f, 4150.f, 4160.f, .20177f, .023178f, .017214f, -7.6243e-5f,
+				     .015553f, -6.4832e-5f, 4160.f, 4170.f, .7632f, .046725f, .01416f,
+				     -6.3818e-5f, .012147f, -5.4565e-5f, 4170.f, 4180.f, 1.5947f, .047792f,
+				     .010708f, -5.0352e-5f, .0083233f, -4.2778e-5f, 4180.f, 4190.f, 5.2669f,
+				     .073957f, .0067643f, -3.4467e-5f, .004319f, -2.8069e-5f, 4190.f, 4200.f,
+				     6.4202f, .051382f, .0036772f, -2.2614e-5f, 9.742e-4f, -1.6763e-5f,
+				     4200.f, 4210.f, 9.2445f, .052627f, .0014938f, -1.3915e-5f, -.0010491f,
+				     -6.9012e-6f, 4210.f, 4220.f, 11.75f, .05381f, -3.2681e-4f, -6.6562e-6f,
+				     -.0028054f, 1.0375e-6f, 4220.f, 4230.f, 12.919f, .055506f, -.0017838f,
+				     -8.5608e-7f, -.0042665f, 7.1579e-6f, 4230.f, 4240.f, 16.381f, .089081f,
+				     -.003049f, 4.1985e-6f, -.0056615f, 1.1648e-5f, 4240.f, 4250.f, 5.0278f,
+				     .066105f, -.0038255f, 7.3053e-6f, -.0061865f, 1.7191e-5f, 4250.f,
+				     4260.f, 5.3208f, .065464f, -.0039797f, 7.8726e-6f, -.006508f,
+				     1.6403e-5f, 4260.f, 4270.f, 18.844f, .088395f, -.0034205f, 5.6382e-6f,
+				     -.0061631f, 1.2216e-5f, 4270.f, 4280.f, 24.188f, .081391f, -.0020758f,
+				     3.3792e-7f, -.004851f, 6.276e-6f, 4280.f, 4290.f, 20.85f, .078388f,
+				     7.1143e-5f, -8.1227e-6f, -.0026924f, -2.6258e-6f, 4290.f, 4300.f,
+				     16.326f, .099662f, .003472f, -2.1159e-5f, 8.2032e-4f, -1.6489e-5f,
+				     4300.f, 4310.f, 5.9676f, .090468f, .0087017f, -4.1571e-5f, .0061894f,
+				     -3.7687e-5f, 4310.f, 4320.f, 1.4674f, .080452f, .015334f, -6.7528e-5f,
+				     .012977f, -6.4486e-5f, 4320.f, 4330.f, .26137f, .087098f, .023749f,
+				     -9.9448e-5f, .02192f, -9.8971e-5f, 4330.f, 4340.f, .017052f, .094008f,
+				     .036064f, -1.4594e-4f, .035363f, -1.4924e-4f, 4340.f, 4350.f,
+				     1.3974e-4f, .088019f, .056495f, -2.2628e-4f, .057375f, -2.2878e-4f,
+				     4350.f, 4360.f, 2.5708e-10f, .017736f, .10803f, -4.4019e-4f, .10523f,
+				     -4.3455e-4f, 4360.f, 4370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4370.f, 4380.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4380.f, 4390.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4390.f, 4400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4400.f, 4410.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4410.f, 4420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4420.f,
+				     4430.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4430.f, 4440.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4440.f, 4450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4450.f, 4460.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4460.f, 4470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4470.f,
+				     4480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4480.f, 4490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4490.f, 4500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4500.f, 4510.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4510.f, 4520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4520.f,
+				     4530.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4530.f, 4540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4540.f, 4550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4550.f, 4560.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4560.f, 4570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4570.f,
+				     4580.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4580.f, 4590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4590.f, 4600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4600.f, 4610.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4610.f, 4620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4620.f,
+				     4630.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4630.f, 4640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4640.f, 4650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4650.f, 4660.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4660.f, 4670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4670.f,
+				     4680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4680.f, 4690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4690.f, 4700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4700.f, 4710.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4710.f, 4720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4720.f,
+				     4730.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4730.f, 4740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4740.f, 4750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4750.f, 4760.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4760.f, 4770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4770.f,
+				     4780.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4780.f, 4790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4790.f, 4800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4800.f, 4810.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4810.f, 4820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4820.f,
-      4830.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4830.f, 4840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4840.f, 4850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4850.f, 4860.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4860.f, 4870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4870.f,
-      4880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4880.f, 4890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4890.f, 4900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4900.f, 4910.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4910.f, 4920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4920.f,
-      4930.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4930.f, 4940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4940.f, 4950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4950.f, 4960.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 4960.f, 4970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4970.f,
-      4980.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4980.f, 4990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    4990.f, 5e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5e3f, 5010.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 5010.f, 5020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5020.f, 5030.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 5030.f, 5040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      5040.f,
-    5050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5050.f, 5060.f
+				     4830.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4830.f, 4840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4840.f, 4850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4850.f, 4860.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4860.f, 4870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4870.f,
+				     4880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4880.f, 4890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4890.f, 4900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4900.f, 4910.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4910.f, 4920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4920.f,
+				     4930.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4930.f, 4940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4940.f, 4950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4950.f, 4960.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 4960.f, 4970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4970.f,
+				     4980.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 4980.f, 4990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     4990.f, 5e3f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5e3f, 5010.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 5010.f, 5020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5020.f, 5030.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 5030.f, 5040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     5040.f,
+				     5050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 5050.f, 5060.f
-	/* carbon monoxide (2500 - 5050 cm-1) */
+    /* carbon monoxide (2500 - 5050 cm-1) */
 }	/* moca1 */
@@ -8844,658 +8844,658 @@
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15360.f,
-    15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
-      15400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15440.f,
-    15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
-      15480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15520.f,
-    15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
-      15560.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15600.f,
-    15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
-      15640.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15680.f,
-    15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15700.f, 15710.f, 1.596e-8f, .018194f, .038561f, -1.5424e-4f,
-    .036533f, -1.5016e-4f, 15710.f, 15720.f, 1.5504e-8f, .018194f, .03852f,
-    -1.5408e-4f, .036492f, -1.5e-4f, 15720.f, 15730.f, 8.6149e-8f, .036385f,
-    .03409f, -1.3636e-4f, .032063f, -1.3228e-4f, 15730.f, 15740.f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 2.2012e-7f, .036385f, .029911f,
-    -1.1964e-4f, .027883f, -1.1556e-4f, 15750.f, 15760.f, 5.2469e-7f,
-    .036384f, .026002f, -1.0401e-4f, .023974f, -9.9924e-5f, 15760.f,
-    15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 1.1652e-6f,
-    .037236f, .022365f, -8.9458e-5f, .020337f, -8.5374e-5f, 15780.f,
-    15790.f, 2.4086e-6f, .038115f, .019f, -7.5998e-5f, .016972f,
-    -7.1915e-5f, 15790.f, 15800.f, 4.63e-6f, .039407f, .015907f,
-    -6.3629e-5f, .01388f, -5.9545e-5f, 15800.f, 15810.f, 4.2478e-6f,
-    .019927f, .01311f, -5.2439e-5f, .011082f, -4.8357e-5f, 15810.f, 15820.f,
-    4.0121e-6f, .019927f, .013066f, -5.2262e-5f, .011038f, -4.818e-5f,
-    15820.f, 15830.f, 1.3653e-5f, .041148f, .010543f, -4.2171e-5f,
-    .0085153f, -3.8088e-5f, 15830.f, 15840.f, 2.0849e-5f, .04334f,
-    .0082714f, -3.3085e-5f, .0062412f, -2.8988e-5f, 15840.f, 15850.f,
-    2.9295e-5f, .044164f, .0062748f, -2.5099e-5f, .004247f, -2.1015e-5f,
-    15850.f, 15860.f, 3.768e-5f, .045464f, .0045528f, -1.8211e-5f, .002525f,
-    -1.4127e-5f, 15860.f, 15870.f, 6.8735e-5f, .070552f, .0026882f,
-    -1.0606e-5f, 6.7182e-4f, -6.6419e-6f, 15870.f, 15880.f, 6.2284e-5f,
-    .071735f, .0013301f, -5.2392e-6f, -7.0196e-4f, -1.1788e-6f, 15880.f,
-    15890.f, 3.9741e-5f, .0779f, 3.5779e-4f, -1.1367e-6f, -.0013542f,
-    4.5537e-6f, 15890.f, 15900.f, 1.6287e-5f, .058682f, 3.1178e-4f,
-    2.4589e-6f, 5.313e-4f, 1.3293e-5f, 15900.f, 15910.f, 9.9855e-5f,
-    .14228f, .0013456f, -1.6726e-6f, .0010356f, 3.4749e-6f, 15910.f,
-    15920.f, 1.9246e-4f, .31716f, .005754f, -1.6318e-5f, .0052332f,
-    -1.9378e-5f, 15920.f, 15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f,
-    15940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15950.f, 15960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f,
-      15970.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15980.f, 15990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 1.6e4f, 16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16010.f,
-    16020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16030.f, 16040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f,
-      16050.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16060.f, 16070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16080.f, 16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16090.f,
-    16100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16110.f, 16120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f,
-      16130.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16140.f, 16150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16160.f, 16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16170.f,
-    16180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16190.f, 16200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f,
-      16210.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16220.f, 16230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16240.f, 16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16250.f,
-    16260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16270.f, 16280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f,
-      16290.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16300.f, 16310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16320.f, 16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16330.f,
-    16340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16350.f, 16360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f,
-      16370.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16380.f, 16390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16400.f, 16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16410.f,
-    16420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16430.f, 16440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f,
-      16450.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16460.f, 16470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16480.f, 16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16490.f,
-    16500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16510.f, 16520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f,
-      16530.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16540.f, 16550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16560.f, 16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16570.f,
-    16580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16590.f, 16600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f,
-      16610.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16620.f, 16630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16640.f, 16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16650.f,
-    16660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16670.f, 16680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f,
-      16690.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16700.f, 16710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16720.f, 16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16730.f,
-    16740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16750.f, 16760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f,
-      16770.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16780.f, 16790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16800.f, 16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16810.f,
-    16820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16830.f, 16840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f,
-      16850.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16860.f, 16870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16880.f, 16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16890.f,
-    16900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16910.f, 16920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f,
-      16930.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    16940.f, 16950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 16960.f, 16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      16970.f,
-    16980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 16990.f, 1.7e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    17020.f, 17030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17040.f, 17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17050.f,
-    17060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17070.f, 17080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f,
-      17090.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17100.f, 17110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17120.f, 17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17130.f,
-    17140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17150.f, 17160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f,
-      17170.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17180.f, 17190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17200.f, 17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17210.f,
-    17220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17230.f, 17240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f,
-      17250.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17260.f, 17270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17280.f, 17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17290.f,
-    17300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17310.f, 17320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f,
-      17330.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17340.f, 17350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17360.f, 17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17370.f,
-    17380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17390.f, 17400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f,
-      17410.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17420.f, 17430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17440.f, 17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17450.f,
-    17460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17470.f, 17480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f,
-      17490.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17500.f, 17510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17520.f, 17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17530.f,
-    17540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17550.f, 17560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f,
-      17570.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17580.f, 17590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17600.f, 17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17610.f,
-    17620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17630.f, 17640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f,
-      17650.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17660.f, 17670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17680.f, 17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17690.f,
-    17700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17710.f, 17720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f,
-      17730.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17740.f, 17750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17760.f, 17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17770.f,
-    17780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 17790.f, 17800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f,
-      17810.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    17820.f, 17830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 17840.f, 17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      17850.f,
-    17860.f
+				     0.f, 15300.f, 15310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15310.f, 15320.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 15320.f, 15330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15330.f, 15340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15340.f, 15350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15350.f, 15360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15360.f,
+				     15370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15370.f, 15380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15380.f, 15390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15390.f,
+				     15400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15400.f, 15410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15410.f, 15420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15420.f, 15430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15430.f, 15440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15440.f,
+				     15450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15450.f, 15460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15460.f, 15470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15470.f,
+				     15480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15480.f, 15490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15490.f, 15500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15500.f, 15510.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15510.f, 15520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15520.f,
+				     15530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15530.f, 15540.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15540.f, 15550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15550.f,
+				     15560.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15560.f, 15570.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15570.f, 15580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15580.f, 15590.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15590.f, 15600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15600.f,
+				     15610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15610.f, 15620.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15620.f, 15630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15630.f,
+				     15640.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15640.f, 15650.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15650.f, 15660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15660.f, 15670.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15670.f, 15680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15680.f,
+				     15690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15690.f, 15700.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15700.f, 15710.f, 1.596e-8f, .018194f, .038561f, -1.5424e-4f,
+				     .036533f, -1.5016e-4f, 15710.f, 15720.f, 1.5504e-8f, .018194f, .03852f,
+				     -1.5408e-4f, .036492f, -1.5e-4f, 15720.f, 15730.f, 8.6149e-8f, .036385f,
+				     .03409f, -1.3636e-4f, .032063f, -1.3228e-4f, 15730.f, 15740.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 15740.f, 15750.f, 2.2012e-7f, .036385f, .029911f,
+				     -1.1964e-4f, .027883f, -1.1556e-4f, 15750.f, 15760.f, 5.2469e-7f,
+				     .036384f, .026002f, -1.0401e-4f, .023974f, -9.9924e-5f, 15760.f,
+				     15770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15770.f, 15780.f, 1.1652e-6f,
+				     .037236f, .022365f, -8.9458e-5f, .020337f, -8.5374e-5f, 15780.f,
+				     15790.f, 2.4086e-6f, .038115f, .019f, -7.5998e-5f, .016972f,
+				     -7.1915e-5f, 15790.f, 15800.f, 4.63e-6f, .039407f, .015907f,
+				     -6.3629e-5f, .01388f, -5.9545e-5f, 15800.f, 15810.f, 4.2478e-6f,
+				     .019927f, .01311f, -5.2439e-5f, .011082f, -4.8357e-5f, 15810.f, 15820.f,
+				     4.0121e-6f, .019927f, .013066f, -5.2262e-5f, .011038f, -4.818e-5f,
+				     15820.f, 15830.f, 1.3653e-5f, .041148f, .010543f, -4.2171e-5f,
+				     .0085153f, -3.8088e-5f, 15830.f, 15840.f, 2.0849e-5f, .04334f,
+				     .0082714f, -3.3085e-5f, .0062412f, -2.8988e-5f, 15840.f, 15850.f,
+				     2.9295e-5f, .044164f, .0062748f, -2.5099e-5f, .004247f, -2.1015e-5f,
+				     15850.f, 15860.f, 3.768e-5f, .045464f, .0045528f, -1.8211e-5f, .002525f,
+				     -1.4127e-5f, 15860.f, 15870.f, 6.8735e-5f, .070552f, .0026882f,
+				     -1.0606e-5f, 6.7182e-4f, -6.6419e-6f, 15870.f, 15880.f, 6.2284e-5f,
+				     .071735f, .0013301f, -5.2392e-6f, -7.0196e-4f, -1.1788e-6f, 15880.f,
+				     15890.f, 3.9741e-5f, .0779f, 3.5779e-4f, -1.1367e-6f, -.0013542f,
+				     4.5537e-6f, 15890.f, 15900.f, 1.6287e-5f, .058682f, 3.1178e-4f,
+				     2.4589e-6f, 5.313e-4f, 1.3293e-5f, 15900.f, 15910.f, 9.9855e-5f,
+				     .14228f, .0013456f, -1.6726e-6f, .0010356f, 3.4749e-6f, 15910.f,
+				     15920.f, 1.9246e-4f, .31716f, .005754f, -1.6318e-5f, .0052332f,
+				     -1.9378e-5f, 15920.f, 15930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15930.f,
+				     15940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15940.f, 15950.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15950.f, 15960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15960.f,
+				     15970.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15970.f, 15980.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15980.f, 15990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15990.f, 1.6e4f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 1.6e4f, 16010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16010.f,
+				     16020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16020.f, 16030.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16030.f, 16040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16040.f,
+				     16050.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16050.f, 16060.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16060.f, 16070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16070.f, 16080.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16080.f, 16090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16090.f,
+				     16100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16100.f, 16110.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16110.f, 16120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16120.f,
+				     16130.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16130.f, 16140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16140.f, 16150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16150.f, 16160.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16160.f, 16170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16170.f,
+				     16180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16180.f, 16190.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16190.f, 16200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16200.f,
+				     16210.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16210.f, 16220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16220.f, 16230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16230.f, 16240.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16240.f, 16250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16250.f,
+				     16260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16260.f, 16270.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16270.f, 16280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16280.f,
+				     16290.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16290.f, 16300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16300.f, 16310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16310.f, 16320.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16320.f, 16330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16330.f,
+				     16340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16340.f, 16350.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16350.f, 16360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16360.f,
+				     16370.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16370.f, 16380.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16380.f, 16390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16390.f, 16400.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16400.f, 16410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16410.f,
+				     16420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16420.f, 16430.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16430.f, 16440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16440.f,
+				     16450.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16450.f, 16460.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16460.f, 16470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16470.f, 16480.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16480.f, 16490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16490.f,
+				     16500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16500.f, 16510.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16510.f, 16520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16520.f,
+				     16530.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16530.f, 16540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16540.f, 16550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16550.f, 16560.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16560.f, 16570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16570.f,
+				     16580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16580.f, 16590.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16590.f, 16600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16600.f,
+				     16610.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16610.f, 16620.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16620.f, 16630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16630.f, 16640.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16640.f, 16650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16650.f,
+				     16660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16660.f, 16670.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16670.f, 16680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16680.f,
+				     16690.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16690.f, 16700.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16700.f, 16710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16710.f, 16720.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16720.f, 16730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16730.f,
+				     16740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16740.f, 16750.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16750.f, 16760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16760.f,
+				     16770.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16770.f, 16780.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16780.f, 16790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16790.f, 16800.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16800.f, 16810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16810.f,
+				     16820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16820.f, 16830.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16830.f, 16840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16840.f,
+				     16850.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16850.f, 16860.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16860.f, 16870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16870.f, 16880.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16880.f, 16890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16890.f,
+				     16900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16900.f, 16910.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16910.f, 16920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16920.f,
+				     16930.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16930.f, 16940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     16940.f, 16950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16950.f, 16960.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 16960.f, 16970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     16970.f,
+				     16980.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 16980.f, 16990.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 16990.f, 1.7e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.7e4f, 17010.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 17010.f, 17020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17020.f, 17030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17030.f, 17040.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17040.f, 17050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17050.f,
+				     17060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17060.f, 17070.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17070.f, 17080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17080.f,
+				     17090.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17090.f, 17100.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17100.f, 17110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17110.f, 17120.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17120.f, 17130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17130.f,
+				     17140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17140.f, 17150.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17150.f, 17160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17160.f,
+				     17170.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17170.f, 17180.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17180.f, 17190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17190.f, 17200.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17200.f, 17210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17210.f,
+				     17220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17220.f, 17230.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17230.f, 17240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17240.f,
+				     17250.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17250.f, 17260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17260.f, 17270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17270.f, 17280.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17280.f, 17290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17290.f,
+				     17300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17300.f, 17310.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17310.f, 17320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17320.f,
+				     17330.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17330.f, 17340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17340.f, 17350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17350.f, 17360.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17360.f, 17370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17370.f,
+				     17380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17380.f, 17390.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17390.f, 17400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17400.f,
+				     17410.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17410.f, 17420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17420.f, 17430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17430.f, 17440.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17440.f, 17450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17450.f,
+				     17460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17460.f, 17470.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17470.f, 17480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17480.f,
+				     17490.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17490.f, 17500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17500.f, 17510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17510.f, 17520.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17520.f, 17530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17530.f,
+				     17540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17540.f, 17550.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17550.f, 17560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17560.f,
+				     17570.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17570.f, 17580.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17580.f, 17590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17590.f, 17600.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17600.f, 17610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17610.f,
+				     17620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17620.f, 17630.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17630.f, 17640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17640.f,
+				     17650.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17650.f, 17660.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17660.f, 17670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17670.f, 17680.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17680.f, 17690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17690.f,
+				     17700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17700.f, 17710.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17710.f, 17720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17720.f,
+				     17730.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17730.f, 17740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17740.f, 17750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17750.f, 17760.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17760.f, 17770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17770.f,
+				     17780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17780.f, 17790.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 17790.f, 17800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17800.f,
+				     17810.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17810.f, 17820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     17820.f, 17830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 17830.f, 17840.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 17840.f, 17850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     17850.f,
+				     17860.f
-	/* oxygen (15300 - 17870 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* oxygen (15300 - 17870 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* oxyg6 */
 void oxyg5 (float a[8], const long int inu)
-    0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12800.f,
+				     0.f, 12740.f, 12750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12750.f, 12760.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 12760.f, 12770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12770.f, 12780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12780.f, 12790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12790.f, 12800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12800.f,
-    12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
-      12840.f,
-    1.4615e-8f, .036385f, .0669f, -2.676e-4f, .064873f, -2.6352e-4f,
-    12840.f, 12850.f, 1.7551e-8f, .018194f, .063056f, -2.5222e-4f, .061029f,
-    -2.4814e-4f, 12850.f, 12860.f, 5.5571e-8f, .034936f, .060516f,
-    -2.4079e-4f, .058832f, -2.3863e-4f, 12860.f, 12870.f, 1.1652e-7f,
-    .036823f, .057157f, -2.2751e-4f, .055426f, -2.2511e-4f, 12870.f,
+				     12810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12810.f, 12820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12820.f, 12830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12830.f,
+				     12840.f,
+				     1.4615e-8f, .036385f, .0669f, -2.676e-4f, .064873f, -2.6352e-4f,
+				     12840.f, 12850.f, 1.7551e-8f, .018194f, .063056f, -2.5222e-4f, .061029f,
+				     -2.4814e-4f, 12850.f, 12860.f, 5.5571e-8f, .034936f, .060516f,
+				     -2.4079e-4f, .058832f, -2.3863e-4f, 12860.f, 12870.f, 1.1652e-7f,
+				     .036823f, .057157f, -2.2751e-4f, .055426f, -2.2511e-4f, 12870.f,
-    12880.f, 2.2758e-7f, .037524f, .05406f, -2.1528e-4f, .052277f,
-    -2.1261e-4f, 12880.f, 12890.f, 4.1844e-7f, .044301f, .051439f,
-    -2.03e-4f, .050656f, -2.0073e-4f, 12890.f, 12900.f, 1.1196e-6f,
-    .064417f, .048398f, -1.9212e-4f, .047119f, -1.8843e-4f, 12900.f,
-    12910.f, 1.3443e-6f, .056296f, .046024f, -1.7943e-4f, .045942f,
-    -1.7773e-4f, 12910.f, 12920.f, 1.9719e-6f, .064603f, .044605f,
-    -1.7094e-4f, .044515f, -1.7298e-4f, 12920.f, 12930.f, 2.6027e-6f,
-    .060089f, .042943f, -1.6604e-4f, .04177f, -1.6646e-4f, 12930.f, 12940.f,
-    5.7954e-6f, .10762f, .040374f, -1.577e-4f, .038909f, -1.5614e-4f,
-    12940.f, 12950.f, 4.3014e-6f, .084704f, .042188f, -1.5762e-4f, .040357f,
-    -1.5977e-4f, 12950.f, 12960.f, 7.9614e-6f, .097284f, .041471f,
-    -1.6264e-4f, .038436f, -1.5588e-4f, 12960.f, 12970.f, 1.7998e-5f,
-    .071534f, .03844f, -1.5372e-4f, .036186f, -1.4871e-4f, 12970.f, 12980.f,
-    2.7733e-5f, .06553f, .0349f, -1.3823e-4f, .034326f, -1.4018e-4f,
-    12980.f, 12990.f, 8.7111e-5f, .082142f, .031863f, -1.2227e-4f, .033009f,
-    -1.3017e-4f, 12990.f, 1.3e4f, 5.9912e-5f, .064608f, .031064f,
-    -1.1475e-4f, .036751f, -1.2672e-4f, 1.3e4f, 13010.f, 2.6987e-4f,
-    .037736f, .026012f, -1.039e-4f, .024588f, -9.7152e-5f, 13010.f, 13020.f,
-    5.9914e-4f, .037261f, .022365f, -8.9458e-5f, .020337f, -8.5375e-5f,
-    13020.f, 13030.f, .0012384f, .038141f, .019f, -7.5998e-5f, .016972f,
-    -7.1916e-5f, 13030.f, 13040.f, .0023802f, .03944f, .015907f,
-    -6.3629e-5f, .01388f, -5.9546e-5f, 13040.f, 13050.f, .0078692f,
-    .059793f, .01191f, -4.6882e-5f, .010043f, -4.3832e-5f, 13050.f, 13060.f,
-    .014112f, .0632f, .0088039f, -3.4775e-5f, .0068655f, -3.1246e-5f,
-    13060.f, 13070.f, .01506f, .044198f, .0062748f, -2.5099e-5f, .0042475f,
-    -2.1017e-5f, 13070.f, 13080.f, .019365f, .045501f, .0045529f,
-    -1.8211e-5f, .0025253f, -1.4128e-5f, 13080.f, 13090.f, .035332f,
-    .070599f, .0026881f, -1.0606e-5f, 6.7201e-4f, -6.6426e-6f, 13090.f,
-    13100.f, .032021f, .071785f, .0013302f, -5.2395e-6f, -7.0181e-4f,
-    -1.1794e-6f, 13100.f, 13110.f, .020424f, .076507f, 3.4001e-4f,
-    -1.3505e-6f, -.0017047f, 2.7972e-6f, 13110.f, 13120.f, .0083211f,
-    .050488f, 6.3467e-5f, -2.5366e-7f, -.0019594f, 3.8105e-6f, 13120.f,
-    13130.f, .039472f, .095766f, 7.6617e-4f, -3.019e-6f, -.0012832f,
-    1.1287e-6f, 13130.f, 13140.f, .057473f, .11569f, .0028314f, -1.0907e-5f,
-    8.5516e-4f, -7.1029e-6f, 13140.f, 13150.f, .046463f, .16239f, .0072656f,
-    -2.6424e-5f, .0059616f, -2.4138e-5f, 13150.f, 13160.f, .0070486f,
-    .18365f, .016807f, -5.8784e-5f, .017894f, -6.4531e-5f, 13160.f, 13170.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13180.f, 13190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13200.f, 13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13210.f,
-    13220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13230.f, 13240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f,
-      13250.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13260.f, 13270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13280.f, 13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13290.f,
-    13300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13310.f, 13320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f,
-      13330.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13340.f, 13350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13360.f, 13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13370.f,
-    13380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13390.f, 13400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f,
-      13410.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13420.f, 13430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13440.f, 13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13450.f,
-    13460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13470.f, 13480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f,
-      13490.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13500.f, 13510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f,
+				     12880.f, 2.2758e-7f, .037524f, .05406f, -2.1528e-4f, .052277f,
+				     -2.1261e-4f, 12880.f, 12890.f, 4.1844e-7f, .044301f, .051439f,
+				     -2.03e-4f, .050656f, -2.0073e-4f, 12890.f, 12900.f, 1.1196e-6f,
+				     .064417f, .048398f, -1.9212e-4f, .047119f, -1.8843e-4f, 12900.f,
+				     12910.f, 1.3443e-6f, .056296f, .046024f, -1.7943e-4f, .045942f,
+				     -1.7773e-4f, 12910.f, 12920.f, 1.9719e-6f, .064603f, .044605f,
+				     -1.7094e-4f, .044515f, -1.7298e-4f, 12920.f, 12930.f, 2.6027e-6f,
+				     .060089f, .042943f, -1.6604e-4f, .04177f, -1.6646e-4f, 12930.f, 12940.f,
+				     5.7954e-6f, .10762f, .040374f, -1.577e-4f, .038909f, -1.5614e-4f,
+				     12940.f, 12950.f, 4.3014e-6f, .084704f, .042188f, -1.5762e-4f, .040357f,
+				     -1.5977e-4f, 12950.f, 12960.f, 7.9614e-6f, .097284f, .041471f,
+				     -1.6264e-4f, .038436f, -1.5588e-4f, 12960.f, 12970.f, 1.7998e-5f,
+				     .071534f, .03844f, -1.5372e-4f, .036186f, -1.4871e-4f, 12970.f, 12980.f,
+				     2.7733e-5f, .06553f, .0349f, -1.3823e-4f, .034326f, -1.4018e-4f,
+				     12980.f, 12990.f, 8.7111e-5f, .082142f, .031863f, -1.2227e-4f, .033009f,
+				     -1.3017e-4f, 12990.f, 1.3e4f, 5.9912e-5f, .064608f, .031064f,
+				     -1.1475e-4f, .036751f, -1.2672e-4f, 1.3e4f, 13010.f, 2.6987e-4f,
+				     .037736f, .026012f, -1.039e-4f, .024588f, -9.7152e-5f, 13010.f, 13020.f,
+				     5.9914e-4f, .037261f, .022365f, -8.9458e-5f, .020337f, -8.5375e-5f,
+				     13020.f, 13030.f, .0012384f, .038141f, .019f, -7.5998e-5f, .016972f,
+				     -7.1916e-5f, 13030.f, 13040.f, .0023802f, .03944f, .015907f,
+				     -6.3629e-5f, .01388f, -5.9546e-5f, 13040.f, 13050.f, .0078692f,
+				     .059793f, .01191f, -4.6882e-5f, .010043f, -4.3832e-5f, 13050.f, 13060.f,
+				     .014112f, .0632f, .0088039f, -3.4775e-5f, .0068655f, -3.1246e-5f,
+				     13060.f, 13070.f, .01506f, .044198f, .0062748f, -2.5099e-5f, .0042475f,
+				     -2.1017e-5f, 13070.f, 13080.f, .019365f, .045501f, .0045529f,
+				     -1.8211e-5f, .0025253f, -1.4128e-5f, 13080.f, 13090.f, .035332f,
+				     .070599f, .0026881f, -1.0606e-5f, 6.7201e-4f, -6.6426e-6f, 13090.f,
+				     13100.f, .032021f, .071785f, .0013302f, -5.2395e-6f, -7.0181e-4f,
+				     -1.1794e-6f, 13100.f, 13110.f, .020424f, .076507f, 3.4001e-4f,
+				     -1.3505e-6f, -.0017047f, 2.7972e-6f, 13110.f, 13120.f, .0083211f,
+				     .050488f, 6.3467e-5f, -2.5366e-7f, -.0019594f, 3.8105e-6f, 13120.f,
+				     13130.f, .039472f, .095766f, 7.6617e-4f, -3.019e-6f, -.0012832f,
+				     1.1287e-6f, 13130.f, 13140.f, .057473f, .11569f, .0028314f, -1.0907e-5f,
+				     8.5516e-4f, -7.1029e-6f, 13140.f, 13150.f, .046463f, .16239f, .0072656f,
+				     -2.6424e-5f, .0059616f, -2.4138e-5f, 13150.f, 13160.f, .0070486f,
+				     .18365f, .016807f, -5.8784e-5f, .017894f, -6.4531e-5f, 13160.f, 13170.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13170.f, 13180.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13180.f, 13190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13190.f, 13200.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13200.f, 13210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13210.f,
+				     13220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13220.f, 13230.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13230.f, 13240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13240.f,
+				     13250.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13250.f, 13260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13260.f, 13270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13270.f, 13280.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13280.f, 13290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13290.f,
+				     13300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13300.f, 13310.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13310.f, 13320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13320.f,
+				     13330.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13330.f, 13340.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13340.f, 13350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13350.f, 13360.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13360.f, 13370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13370.f,
+				     13380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13380.f, 13390.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13390.f, 13400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13400.f,
+				     13410.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13410.f, 13420.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13420.f, 13430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13430.f, 13440.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13440.f, 13450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13450.f,
+				     13460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13460.f, 13470.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13470.f, 13480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13480.f,
+				     13490.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13490.f, 13500.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13500.f, 13510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13510.f, 13520.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13520.f, 13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13530.f,
-    13540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13550.f, 13560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f,
-      13570.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13580.f, 13590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13600.f, 13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13610.f,
-    13620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13630.f, 13640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f,
-      13650.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13660.f, 13670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13680.f, 13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13690.f,
-    13700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13710.f, 13720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f,
-      13730.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13740.f, 13750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13760.f, 13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13770.f,
-    13780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13520.f, 13530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13530.f,
+				     13540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13540.f, 13550.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13550.f, 13560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13560.f,
+				     13570.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13570.f, 13580.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13580.f, 13590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13590.f, 13600.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13600.f, 13610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13610.f,
+				     13620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13620.f, 13630.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13630.f, 13640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13640.f,
+				     13650.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13650.f, 13660.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13660.f, 13670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13670.f, 13680.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13680.f, 13690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13690.f,
+				     13700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13700.f, 13710.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13710.f, 13720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13720.f,
+				     13730.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13730.f, 13740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13740.f, 13750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13750.f, 13760.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13760.f, 13770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13770.f,
+				     13780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13780.f, 13790.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13790.f, 13800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f,
-      13810.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13820.f, 13830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13840.f, 13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13850.f,
-    13860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13870.f, 13880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f,
-      13890.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13900.f, 13910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 13920.f, 13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      13930.f,
-    13940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 13950.f, 13960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f,
-      13970.f,
+				     0.f,
+				     0.f, 0.f, 13790.f, 13800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13800.f,
+				     13810.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13810.f, 13820.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13820.f, 13830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13830.f, 13840.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13840.f, 13850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13850.f,
+				     13860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13860.f, 13870.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13870.f, 13880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13880.f,
+				     13890.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13890.f, 13900.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13900.f, 13910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13910.f, 13920.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 13920.f, 13930.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     13930.f,
+				     13940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13940.f, 13950.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 13950.f, 13960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13960.f,
+				     13970.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    13980.f, 13990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f,
-    0.f, 0.f, 0.f, 0.f, 1.4e4f, 14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14010.f,
-    14020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14030.f, 14040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f,
-      14050.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14060.f, 14070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14080.f, 14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14090.f,
-    14100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14110.f, 14120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f,
-      14130.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14140.f, 14150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14160.f, 14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14170.f,
-    14180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14190.f, 14200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f,
-      14210.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14220.f, 14230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14240.f, 14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14250.f,
-    14260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14270.f, 14280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f,
-      14290.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14300.f, 14310.f, 3.2848e-8f, .036386f, .053505f, -2.1402e-4f, .051477f,
-    -2.0994e-4f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14320.f,
-    14330.f, 1.1021e-7f, .036386f, .048248f, -1.9299e-4f, .046221f,
-    -1.8891e-4f, 14330.f, 14340.f, 3.4571e-7f, .036386f, .04326f,
-    -1.7304e-4f, .041233f, -1.6896e-4f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 0.f, 14350.f, 14360.f, 1.0131e-6f, .036386f, .03854f, -1.5416e-4f,
-    .036513f, -1.5008e-4f, 14360.f, 14370.f, 2.7746e-6f, .036442f, .034089f,
-    -1.3635e-4f, .032054f, -1.3222e-4f, 14370.f, 14380.f, 3.6059e-6f,
-    .01824f, .02993f, -1.1971e-4f, .027892f, -1.1557e-4f, 14380.f, 14390.f,
-    3.4852e-6f, .018279f, .029884f, -1.1951e-4f, .027832f, -1.1527e-4f,
-    14390.f, 14400.f, 1.6898e-5f, .036461f, .026f, -1.0399e-4f, .023962f,
-    -9.9845e-5f, 14400.f, 14410.f, 3.7525e-5f, .037306f, .022363f,
-    -8.9448e-5f, .020327f, -8.5313e-5f, 14410.f, 14420.f, 7.7568e-5f,
-    .038179f, .018999f, -7.5991e-5f, .016964f, -7.1868e-5f, 14420.f,
-    14430.f, 7.644e-5f, .019568f, .015927f, -6.3702e-5f, .013885f,
-    -5.9534e-5f, 14430.f, 14440.f, 2.0947e-4f, .038957f, .014055f,
-    -5.5384e-5f, .012236f, -5.2506e-5f, 14440.f, 14450.f, 3.5608e-4f,
-    .040125f, .011458f, -4.5137e-5f, .0095851f, -4.1989e-5f, 14450.f,
-    14460.f, 5.6079e-4f, .041622f, .0091259f, -3.5944e-5f, .0072131f,
-    -3.2578e-5f, 14460.f, 14470.f, 8.1523e-4f, .043384f, .0070608f,
-    -2.7807e-5f, .0051286f, -2.4309e-5f, 14470.f, 14480.f, .0016639f,
-    .067344f, .0050076f, -1.9758e-5f, .0030273f, -1.599e-5f, 14480.f,
-    14490.f, .0014146f, .046358f, .003106f, -1.2424e-5f, .0010767f,
-    -8.3329e-6f, 14490.f, 14500.f, .0022165f, .071957f, .0016398f,
-    -6.477e-6f, -3.8835e-4f, -2.4326e-6f, 14500.f, 14510.f, .0015542f,
-    .07478f, 6.4291e-4f, -2.5306e-6f, -.0013922f, 1.5886e-6f, 14510.f,
-    14520.f, 3.1245e-4f, .026878f, 9.5018e-5f, -3.8003e-7f, -.0019316f,
-    3.6996e-6f, 14520.f, 14530.f, .0015805f, .097644f, 3.0344e-4f,
-    -1.0773e-6f, -.0013616f, 5.954e-6f, 14530.f, 14540.f, .0044256f,
-    .14544f, .0020504f, -7.4913e-6f, 6.2397e-4f, -9.5059e-7f, 14540.f,
-    14550.f, .0039335f, .29035f, .0078502f, -2.3749e-5f, .0080984f,
-    -2.7655e-5f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14560.f,
-    14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
-      14600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14640.f,
-    14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
-      14680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14720.f,
-    14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
-      14760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14800.f,
-    14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
-      14840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14880.f,
-    14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
-      14920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      14960.f,
-    14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15040.f,
-    15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
-      15080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15120.f,
-    15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
-      15160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13970.f, 13980.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     13980.f, 13990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 13990.f, 1.4e4f, 0.f, 0.f,
+				     0.f, 0.f, 0.f, 0.f, 1.4e4f, 14010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14010.f,
+				     14020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14020.f, 14030.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14030.f, 14040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14040.f,
+				     14050.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14050.f, 14060.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14060.f, 14070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14070.f, 14080.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14080.f, 14090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14090.f,
+				     14100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14100.f, 14110.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14110.f, 14120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14120.f,
+				     14130.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14130.f, 14140.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14140.f, 14150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14150.f, 14160.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14160.f, 14170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14170.f,
+				     14180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14180.f, 14190.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14190.f, 14200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14200.f,
+				     14210.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14210.f, 14220.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14220.f, 14230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14230.f, 14240.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14240.f, 14250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14250.f,
+				     14260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14260.f, 14270.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14270.f, 14280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14280.f,
+				     14290.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14290.f, 14300.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14300.f, 14310.f, 3.2848e-8f, .036386f, .053505f, -2.1402e-4f, .051477f,
+				     -2.0994e-4f, 14310.f, 14320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14320.f,
+				     14330.f, 1.1021e-7f, .036386f, .048248f, -1.9299e-4f, .046221f,
+				     -1.8891e-4f, 14330.f, 14340.f, 3.4571e-7f, .036386f, .04326f,
+				     -1.7304e-4f, .041233f, -1.6896e-4f, 14340.f, 14350.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 0.f, 14350.f, 14360.f, 1.0131e-6f, .036386f, .03854f, -1.5416e-4f,
+				     .036513f, -1.5008e-4f, 14360.f, 14370.f, 2.7746e-6f, .036442f, .034089f,
+				     -1.3635e-4f, .032054f, -1.3222e-4f, 14370.f, 14380.f, 3.6059e-6f,
+				     .01824f, .02993f, -1.1971e-4f, .027892f, -1.1557e-4f, 14380.f, 14390.f,
+				     3.4852e-6f, .018279f, .029884f, -1.1951e-4f, .027832f, -1.1527e-4f,
+				     14390.f, 14400.f, 1.6898e-5f, .036461f, .026f, -1.0399e-4f, .023962f,
+				     -9.9845e-5f, 14400.f, 14410.f, 3.7525e-5f, .037306f, .022363f,
+				     -8.9448e-5f, .020327f, -8.5313e-5f, 14410.f, 14420.f, 7.7568e-5f,
+				     .038179f, .018999f, -7.5991e-5f, .016964f, -7.1868e-5f, 14420.f,
+				     14430.f, 7.644e-5f, .019568f, .015927f, -6.3702e-5f, .013885f,
+				     -5.9534e-5f, 14430.f, 14440.f, 2.0947e-4f, .038957f, .014055f,
+				     -5.5384e-5f, .012236f, -5.2506e-5f, 14440.f, 14450.f, 3.5608e-4f,
+				     .040125f, .011458f, -4.5137e-5f, .0095851f, -4.1989e-5f, 14450.f,
+				     14460.f, 5.6079e-4f, .041622f, .0091259f, -3.5944e-5f, .0072131f,
+				     -3.2578e-5f, 14460.f, 14470.f, 8.1523e-4f, .043384f, .0070608f,
+				     -2.7807e-5f, .0051286f, -2.4309e-5f, 14470.f, 14480.f, .0016639f,
+				     .067344f, .0050076f, -1.9758e-5f, .0030273f, -1.599e-5f, 14480.f,
+				     14490.f, .0014146f, .046358f, .003106f, -1.2424e-5f, .0010767f,
+				     -8.3329e-6f, 14490.f, 14500.f, .0022165f, .071957f, .0016398f,
+				     -6.477e-6f, -3.8835e-4f, -2.4326e-6f, 14500.f, 14510.f, .0015542f,
+				     .07478f, 6.4291e-4f, -2.5306e-6f, -.0013922f, 1.5886e-6f, 14510.f,
+				     14520.f, 3.1245e-4f, .026878f, 9.5018e-5f, -3.8003e-7f, -.0019316f,
+				     3.6996e-6f, 14520.f, 14530.f, .0015805f, .097644f, 3.0344e-4f,
+				     -1.0773e-6f, -.0013616f, 5.954e-6f, 14530.f, 14540.f, .0044256f,
+				     .14544f, .0020504f, -7.4913e-6f, 6.2397e-4f, -9.5059e-7f, 14540.f,
+				     14550.f, .0039335f, .29035f, .0078502f, -2.3749e-5f, .0080984f,
+				     -2.7655e-5f, 14550.f, 14560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14560.f,
+				     14570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14570.f, 14580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14580.f, 14590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14590.f,
+				     14600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14600.f, 14610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14610.f, 14620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14620.f, 14630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14630.f, 14640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14640.f,
+				     14650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14650.f, 14660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14660.f, 14670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14670.f,
+				     14680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14680.f, 14690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14690.f, 14700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14700.f, 14710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14710.f, 14720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14720.f,
+				     14730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14730.f, 14740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14740.f, 14750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14750.f,
+				     14760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14760.f, 14770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14770.f, 14780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14780.f, 14790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14790.f, 14800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14800.f,
+				     14810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14810.f, 14820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14820.f, 14830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14830.f,
+				     14840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14840.f, 14850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14850.f, 14860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14860.f, 14870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14870.f, 14880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14880.f,
+				     14890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14890.f, 14900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14900.f, 14910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14910.f,
+				     14920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14920.f, 14930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     14930.f, 14940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14940.f, 14950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 14950.f, 14960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     14960.f,
+				     14970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14970.f, 14980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 14980.f, 14990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 14990.f, 1.5e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.5e4f, 15010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15010.f, 15020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15020.f, 15030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15030.f, 15040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15040.f,
+				     15050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15050.f, 15060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15060.f, 15070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15070.f,
+				     15080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15080.f, 15090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15090.f, 15100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15100.f, 15110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15110.f, 15120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15120.f,
+				     15130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15130.f, 15140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15140.f, 15150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15150.f,
+				     15160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15160.f, 15170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15170.f, 15180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15180.f, 15190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15190.f, 15200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15200.f,
-    15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
-      15240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      15280.f,
-    15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
+				     15200.f,
+				     15210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15210.f, 15220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 15220.f, 15230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15230.f,
+				     15240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15240.f, 15250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     15250.f, 15260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15260.f, 15270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 15270.f, 15280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     15280.f,
+				     15290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 15290.f, 15300.f
-	/* oxygen (12740 - 15290 cm-1) */
+    /* oxygen (12740 - 15290 cm-1) */
 }	/* oxyg5 */
 void
@@ -9503,1156 +9503,1156 @@
-    0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-    10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10240.f,
-    10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
-      10280.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10320.f,
-    10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
-      10360.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10400.f,
-    10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
-      10440.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10480.f,
-    10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
-      10520.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10560.f,
-    10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
-      10600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10640.f,
-    10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
-      10680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10720.f,
-    10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
-      10760.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10800.f,
-    10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
-      10840.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10880.f,
-    10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
-      10920.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10960.f,
-    10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11040.f,
-    11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
-      11080.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11120.f,
-    11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
-      11160.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11200.f,
-    11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
-      11240.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11280.f,
-    11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
-      11320.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11360.f,
-    11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
-      11400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11440.f,
-    11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
-      11480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 2.485e-8f, .039407f,
-    .053053f, -2.1221e-4f, .051025f, -2.0813e-4f, 11490.f, 11500.f,
-    1.1624e-7f, .079933f, .048686f, -1.9403e-4f, .046806f, -1.9088e-4f,
-    11500.f, 11510.f, 1.0964e-7f, .043304f, .045502f, -1.8201e-4f, .043474f,
-    -1.7792e-4f, 11510.f, 11520.f, 2.5643e-7f, .066862f, .042844f,
-    -1.7105e-4f, .040871f, -1.6735e-4f, 11520.f, 11530.f, 3.2105e-7f,
-    .068728f, .040797f, -1.6299e-4f, .038797f, -1.5911e-4f, 11530.f,
-    11540.f, 3.5585e-7f, .071858f, .038944f, -1.557e-4f, .036916f,
-    -1.5165e-4f, 11540.f, 11550.f, 2.4915e-7f, .074592f, .037957f,
-    -1.5179e-4f, .035912f, -1.4766e-4f, 11550.f, 11560.f, 4.9923e-8f,
-    .026857f, .037416f, -1.4966e-4f, .035388f, -1.4558e-4f, 11560.f,
-    11570.f, 2.5239e-7f, .096092f, .037615f, -1.5045e-4f, .035561f,
-    -1.4627e-4f, 11570.f, 11580.f, 5.8358e-7f, .11778f, .039104f,
-    -1.5615e-4f, .03708f, -1.5221e-4f, 11580.f, 11590.f, 4.8767e-7f,
-    .11043f, .041978f, -1.6721e-4f, .04006f, -1.6392e-4f, 11590.f, 11600.f,
-    2.0866e-7f, .10009f, .046771f, -1.859e-4f, .045f, -1.8335e-4f, 11600.f,
-    11610.f, 6.2339e-8f, .091546f, .052598f, -2.0809e-4f, .051104f,
-    -2.0723e-4f, 11610.f, 11620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11620.f,
-    11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f, 11640.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11650.f,
-      11660.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11680.f, 11690.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11700.f,
-    11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f, 11720.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11730.f,
-      11740.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11760.f, 11770.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11780.f,
-    11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f, 11800.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11810.f,
-      11820.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11840.f, 11850.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11860.f,
-    11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f, 11880.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11890.f,
-      11900.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11920.f, 11930.f, 0.f,
+    static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f, 10180.f, 10190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10190.f, 10200.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 10200.f, 10210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10210.f, 10220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10220.f, 10230.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10230.f, 10240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10240.f,
+				     10250.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10250.f, 10260.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10260.f, 10270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10270.f,
+				     10280.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10280.f, 10290.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10290.f, 10300.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10300.f, 10310.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10310.f, 10320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10320.f,
+				     10330.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10330.f, 10340.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10340.f, 10350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10350.f,
+				     10360.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10360.f, 10370.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10370.f, 10380.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10380.f, 10390.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10390.f, 10400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10400.f,
+				     10410.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10410.f, 10420.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10420.f, 10430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10430.f,
+				     10440.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10440.f, 10450.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10450.f, 10460.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10460.f, 10470.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10470.f, 10480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10480.f,
+				     10490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10490.f, 10500.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10500.f, 10510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10510.f,
+				     10520.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10520.f, 10530.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10530.f, 10540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10540.f, 10550.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10550.f, 10560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10560.f,
+				     10570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10570.f, 10580.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10580.f, 10590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10590.f,
+				     10600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10600.f, 10610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10610.f, 10620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10620.f, 10630.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10630.f, 10640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10640.f,
+				     10650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10650.f, 10660.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10660.f, 10670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10670.f,
+				     10680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10680.f, 10690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10690.f, 10700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10700.f, 10710.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10710.f, 10720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10720.f,
+				     10730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10730.f, 10740.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10740.f, 10750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10750.f,
+				     10760.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10760.f, 10770.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10770.f, 10780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10780.f, 10790.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10790.f, 10800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10800.f,
+				     10810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10810.f, 10820.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10820.f, 10830.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10830.f,
+				     10840.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10840.f, 10850.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10850.f, 10860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10860.f, 10870.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10870.f, 10880.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10880.f,
+				     10890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10890.f, 10900.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10900.f, 10910.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10910.f,
+				     10920.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10920.f, 10930.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10930.f, 10940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10940.f, 10950.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10950.f, 10960.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10960.f,
+				     10970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10970.f, 10980.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10980.f, 10990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10990.f, 1.1e4f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.1e4f, 11010.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11010.f, 11020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11020.f, 11030.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11030.f, 11040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11040.f,
+				     11050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11050.f, 11060.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11060.f, 11070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11070.f,
+				     11080.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11080.f, 11090.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11090.f, 11100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11100.f, 11110.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11110.f, 11120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11120.f,
+				     11130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11130.f, 11140.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11140.f, 11150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11150.f,
+				     11160.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11160.f, 11170.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11170.f, 11180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11180.f, 11190.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11190.f, 11200.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11200.f,
+				     11210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11210.f, 11220.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11220.f, 11230.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11230.f,
+				     11240.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11240.f, 11250.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11250.f, 11260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11260.f, 11270.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11270.f, 11280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11280.f,
+				     11290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11290.f, 11300.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11300.f, 11310.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11310.f,
+				     11320.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11320.f, 11330.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11330.f, 11340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11340.f, 11350.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11350.f, 11360.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11360.f,
+				     11370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11370.f, 11380.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11380.f, 11390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11390.f,
+				     11400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11400.f, 11410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11410.f, 11420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11420.f, 11430.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11430.f, 11440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11440.f,
+				     11450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11450.f, 11460.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11460.f, 11470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11470.f,
+				     11480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11480.f, 11490.f, 2.485e-8f, .039407f,
+				     .053053f, -2.1221e-4f, .051025f, -2.0813e-4f, 11490.f, 11500.f,
+				     1.1624e-7f, .079933f, .048686f, -1.9403e-4f, .046806f, -1.9088e-4f,
+				     11500.f, 11510.f, 1.0964e-7f, .043304f, .045502f, -1.8201e-4f, .043474f,
+				     -1.7792e-4f, 11510.f, 11520.f, 2.5643e-7f, .066862f, .042844f,
+				     -1.7105e-4f, .040871f, -1.6735e-4f, 11520.f, 11530.f, 3.2105e-7f,
+				     .068728f, .040797f, -1.6299e-4f, .038797f, -1.5911e-4f, 11530.f,
+				     11540.f, 3.5585e-7f, .071858f, .038944f, -1.557e-4f, .036916f,
+				     -1.5165e-4f, 11540.f, 11550.f, 2.4915e-7f, .074592f, .037957f,
+				     -1.5179e-4f, .035912f, -1.4766e-4f, 11550.f, 11560.f, 4.9923e-8f,
+				     .026857f, .037416f, -1.4966e-4f, .035388f, -1.4558e-4f, 11560.f,
+				     11570.f, 2.5239e-7f, .096092f, .037615f, -1.5045e-4f, .035561f,
+				     -1.4627e-4f, 11570.f, 11580.f, 5.8358e-7f, .11778f, .039104f,
+				     -1.5615e-4f, .03708f, -1.5221e-4f, 11580.f, 11590.f, 4.8767e-7f,
+				     .11043f, .041978f, -1.6721e-4f, .04006f, -1.6392e-4f, 11590.f, 11600.f,
+				     2.0866e-7f, .10009f, .046771f, -1.859e-4f, .045f, -1.8335e-4f, 11600.f,
+				     11610.f, 6.2339e-8f, .091546f, .052598f, -2.0809e-4f, .051104f,
+				     -2.0723e-4f, 11610.f, 11620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11620.f,
+				     11630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11630.f, 11640.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11640.f, 11650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11650.f,
+				     11660.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11660.f, 11670.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11670.f, 11680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11680.f, 11690.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11690.f, 11700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11700.f,
+				     11710.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11710.f, 11720.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11720.f, 11730.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11730.f,
+				     11740.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11740.f, 11750.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11750.f, 11760.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11760.f, 11770.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11770.f, 11780.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11780.f,
+				     11790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11790.f, 11800.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11800.f, 11810.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11810.f,
+				     11820.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11820.f, 11830.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11830.f, 11840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11840.f, 11850.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11850.f, 11860.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11860.f,
+				     11870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11870.f, 11880.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11880.f, 11890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11890.f,
+				     11900.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11900.f, 11910.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11910.f, 11920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11920.f, 11930.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      11940.f,
-    11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f, 11960.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11970.f,
-      11980.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f, 12010.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12020.f,
-    12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f, 12040.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12050.f,
-      12060.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12080.f, 12090.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12100.f,
-    12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f, 12120.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12130.f,
-      12140.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12160.f, 12170.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12180.f,
-    12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f, 12200.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12210.f,
-      12220.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12240.f, 12250.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12260.f,
-    12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f, 12280.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12290.f,
-      12300.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12320.f, 12330.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12340.f,
-    12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f, 12360.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12370.f,
-      12380.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12400.f, 12410.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12420.f,
-    12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f, 12440.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12450.f,
-      12460.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12480.f, 12490.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12500.f,
-    12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f, 12520.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12530.f,
-      12540.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12560.f, 12570.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12580.f,
-    12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f, 12600.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12610.f,
-      12620.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12640.f, 12650.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      12660.f,
-    12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f, 12680.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12690.f,
-      12700.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12720.f, 12730.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 11930.f, 11940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     11940.f,
+				     11950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11950.f, 11960.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 11960.f, 11970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11970.f,
+				     11980.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 11980.f, 11990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     11990.f, 1.2e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1.2e4f, 12010.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 12010.f, 12020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12020.f,
+				     12030.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12030.f, 12040.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12040.f, 12050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12050.f,
+				     12060.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12060.f, 12070.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12070.f, 12080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12080.f, 12090.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12090.f, 12100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12100.f,
+				     12110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12110.f, 12120.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12120.f, 12130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12130.f,
+				     12140.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12140.f, 12150.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12150.f, 12160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12160.f, 12170.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12170.f, 12180.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12180.f,
+				     12190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12190.f, 12200.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12200.f, 12210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12210.f,
+				     12220.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12220.f, 12230.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12230.f, 12240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12240.f, 12250.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12250.f, 12260.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12260.f,
+				     12270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12270.f, 12280.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12280.f, 12290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12290.f,
+				     12300.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12300.f, 12310.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12310.f, 12320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12320.f, 12330.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12330.f, 12340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12340.f,
+				     12350.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12350.f, 12360.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12360.f, 12370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12370.f,
+				     12380.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12380.f, 12390.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12390.f, 12400.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12400.f, 12410.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12410.f, 12420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12420.f,
+				     12430.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12430.f, 12440.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12440.f, 12450.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12450.f,
+				     12460.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12460.f, 12470.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12470.f, 12480.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12480.f, 12490.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12490.f, 12500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12500.f,
+				     12510.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12510.f, 12520.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12520.f, 12530.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12530.f,
+				     12540.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12540.f, 12550.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12550.f, 12560.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12560.f, 12570.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12570.f, 12580.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12580.f,
+				     12590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12590.f, 12600.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12600.f, 12610.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12610.f,
+				     12620.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12620.f, 12630.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12630.f, 12640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12640.f, 12650.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12650.f, 12660.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     12660.f,
+				     12670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12670.f, 12680.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 12680.f, 12690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12690.f,
+				     12700.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12700.f, 12710.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     12710.f, 12720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 12720.f, 12730.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 12730.f, 12740.f
-	/* oxygen (10180 - 12730 cm-1) */
+    /* oxygen (10180 - 12730 cm-1) */
 }	/* oxyg4 */
 void
 oxyg3 (float a[8], const long int inu)
-  static const float acr[2048] = { 0.f, 0.f, 0.f, 0.f, 0.f,
-    0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
-    7660.f, 5.4851e-9f, .018194f, .043239f, -1.7296e-4f, .041212f,
-    -1.6888e-4f, 7660.f, 7670.f, 1.5945e-8f, .018194f, .03852f, -1.5408e-4f,
-    .036492f, -1.5e-4f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f,
-    7690.f, 4.3251e-8f, .018194f, .034069f, -1.3628e-4f, .032042f,
-    -1.3219e-4f, 7690.f, 7700.f, 1.0929e-7f, .018194f, .029889f,
-    -1.1956e-4f, .027862f, -1.1547e-4f, 7700.f, 7710.f, 2.5722e-7f,
-    .018194f, .02598f, -1.0392e-4f, .023953f, -9.9839e-5f, 7710.f, 7720.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7720.f, 7730.f, 5.6266e-7f, .018194f,
-    .022343f, -8.9371e-5f, .020315f, -8.5289e-5f, 7730.f, 7740.f,
-    1.1425e-6f, .01906f, .018977f, -7.591e-5f, .01695f, -7.1828e-5f, 7740.f,
-    7750.f, 2.1596e-6f, .022229f, .016034f, -6.2289e-5f, .015554f,
-    -5.5716e-5f, 7750.f, 7760.f, 8.1892e-8f, .052034f, .039222f,
-    -1.5556e-4f, .037572f, -1.5339e-4f, 7760.f, 7770.f, 3.9209e-6f,
-    .032273f, .014036f, -4.6954e-5f, .015654f, -4.8384e-5f, 7770.f, 7780.f,
-    6.4421e-6f, .036427f, .011888f, -3.5835e-5f, .013496f, -4.0675e-5f,
-    7780.f, 7790.f, 1.1047e-5f, .055891f, .011375f, -2.6109e-5f, .013172f,
-    -4.0967e-5f, 7790.f, 7800.f, 1.7987e-5f, .067558f, .010748f,
-    -2.3562e-5f, .01137f, -3.8223e-5f, 7800.f, 7810.f, 9.8092e-6f, .038971f,
-    .015905f, -6.3621e-5f, .013877f, -5.9532e-5f, 7810.f, 7820.f,
-    4.4018e-5f, .082997f, .0095499f, -3.1911e-5f, .0077993f, -3.2091e-5f,
-    7820.f, 7830.f, 7.0926e-5f, .086557f, .0076614f, -2.7697e-5f, .0055197f,
-    -2.4447e-5f, 7830.f, 7840.f, 1.0119e-4f, .087824f, .0052157f,
-    -1.9889e-5f, .00297f, -1.5277e-5f, 7840.f, 7850.f, 1.2386e-4f, .090123f,
-    .0034834f, -1.2896e-5f, .0022642f, -3.5587e-6f, 7850.f, 7860.f,
-    1.3558e-4f, .14355f, .0025455f, 7.5114e-7f, .0043782f, 4.2838e-6f,
-    7860.f, 7870.f, 3.6155e-4f, .30611f, .00774f, -2.3164e-5f, .0072019f,
-    -2.6289e-5f, 7870.f, 7880.f, 7.4132e-4f, .38505f, .0019206f,
-    -6.4925e-6f, 1.9419e-5f, -3.3562e-6f, 7880.f, 7890.f, 2.6142e-4f,
-    .099139f, 5.6355e-4f, -2.1878e-6f, -.0015085f, 2.0396e-6f, 7890.f,
-    7900.f, 3.3585e-4f, .12035f, .0017877f, -6.7625e-6f, -3.0147e-4f,
-    -2.6201e-6f, 7900.f, 7910.f, 2.1797e-4f, .09124f, .0044856f,
-    -1.7351e-5f, .0025121f, -1.3772e-5f, 7910.f, 7920.f, 1.8805e-4f,
-    .12809f, .0061732f, -1.8626e-5f, .0047187f, -2.0003e-5f, 7920.f, 7930.f,
-    8.7414e-5f, .10246f, .0071283f, -9.5048e-6f, .0079366f, -2.5696e-5f,
-    7930.f, 7940.f, 5.0284e-5f, .070001f, .0058651f, -1.5881e-6f, .0099197f,
-    -1.9259e-5f, 7940.f, 7950.f, 3.4484e-5f, .036136f, .0050423f,
-    -1.3556e-5f, .0083314f, -2.9461e-6f, 7950.f, 7960.f, 2.508e-5f,
+				     0.f, 7620.f, 7630.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7630.f, 7640.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 7640.f, 7650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7650.f,
+				     7660.f, 5.4851e-9f, .018194f, .043239f, -1.7296e-4f, .041212f,
+				     -1.6888e-4f, 7660.f, 7670.f, 1.5945e-8f, .018194f, .03852f, -1.5408e-4f,
+				     .036492f, -1.5e-4f, 7670.f, 7680.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7680.f,
+				     7690.f, 4.3251e-8f, .018194f, .034069f, -1.3628e-4f, .032042f,
+				     -1.3219e-4f, 7690.f, 7700.f, 1.0929e-7f, .018194f, .029889f,
+				     -1.1956e-4f, .027862f, -1.1547e-4f, 7700.f, 7710.f, 2.5722e-7f,
+				     .018194f, .02598f, -1.0392e-4f, .023953f, -9.9839e-5f, 7710.f, 7720.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 7720.f, 7730.f, 5.6266e-7f, .018194f,
+				     .022343f, -8.9371e-5f, .020315f, -8.5289e-5f, 7730.f, 7740.f,
+				     1.1425e-6f, .01906f, .018977f, -7.591e-5f, .01695f, -7.1828e-5f, 7740.f,
+				     7750.f, 2.1596e-6f, .022229f, .016034f, -6.2289e-5f, .015554f,
+				     -5.5716e-5f, 7750.f, 7760.f, 8.1892e-8f, .052034f, .039222f,
+				     -1.5556e-4f, .037572f, -1.5339e-4f, 7760.f, 7770.f, 3.9209e-6f,
+				     .032273f, .014036f, -4.6954e-5f, .015654f, -4.8384e-5f, 7770.f, 7780.f,
+				     6.4421e-6f, .036427f, .011888f, -3.5835e-5f, .013496f, -4.0675e-5f,
+				     7780.f, 7790.f, 1.1047e-5f, .055891f, .011375f, -2.6109e-5f, .013172f,
+				     -4.0967e-5f, 7790.f, 7800.f, 1.7987e-5f, .067558f, .010748f,
+				     -2.3562e-5f, .01137f, -3.8223e-5f, 7800.f, 7810.f, 9.8092e-6f, .038971f,
+				     .015905f, -6.3621e-5f, .013877f, -5.9532e-5f, 7810.f, 7820.f,
+				     4.4018e-5f, .082997f, .0095499f, -3.1911e-5f, .0077993f, -3.2091e-5f,
+				     7820.f, 7830.f, 7.0926e-5f, .086557f, .0076614f, -2.7697e-5f, .0055197f,
+				     -2.4447e-5f, 7830.f, 7840.f, 1.0119e-4f, .087824f, .0052157f,
+				     -1.9889e-5f, .00297f, -1.5277e-5f, 7840.f, 7850.f, 1.2386e-4f, .090123f,
+				     .0034834f, -1.2896e-5f, .0022642f, -3.5587e-6f, 7850.f, 7860.f,
+				     1.3558e-4f, .14355f, .0025455f, 7.5114e-7f, .0043782f, 4.2838e-6f,
+				     7860.f, 7870.f, 3.6155e-4f, .30611f, .00774f, -2.3164e-5f, .0072019f,
+				     -2.6289e-5f, 7870.f, 7880.f, 7.4132e-4f, .38505f, .0019206f,
+				     -6.4925e-6f, 1.9419e-5f, -3.3562e-6f, 7880.f, 7890.f, 2.6142e-4f,
+				     .099139f, 5.6355e-4f, -2.1878e-6f, -.0015085f, 2.0396e-6f, 7890.f,
+				     7900.f, 3.3585e-4f, .12035f, .0017877f, -6.7625e-6f, -3.0147e-4f,
+				     -2.6201e-6f, 7900.f, 7910.f, 2.1797e-4f, .09124f, .0044856f,
+				     -1.7351e-5f, .0025121f, -1.3772e-5f, 7910.f, 7920.f, 1.8805e-4f,
+				     .12809f, .0061732f, -1.8626e-5f, .0047187f, -2.0003e-5f, 7920.f, 7930.f,
+				     8.7414e-5f, .10246f, .0071283f, -9.5048e-6f, .0079366f, -2.5696e-5f,
+				     7930.f, 7940.f, 5.0284e-5f, .070001f, .0058651f, -1.5881e-6f, .0099197f,
+				     -1.9259e-5f, 7940.f, 7950.f, 3.4484e-5f, .036136f, .0050423f,
+				     -1.3556e-5f, .0083314f, -2.9461e-6f, 7950.f, 7960.f, 2.508e-5f,
-    .023597f, .0062798f, -2.4587e-5f, .0054199f, -1.4942e-5f, 7960.f,
-    7970.f, 1.7175e-5f, .021672f, .0082429f, -3.2972e-5f, .0062159f,
-    -2.8891e-5f, 7970.f, 7980.f, 1.0919e-5f, .0208f, .010514f, -4.2054e-5f,
-    .0084864f, -3.7973e-5f, 7980.f, 7990.f, 6.453e-6f, .019927f, .013058f,
-    -5.2234e-5f, .011031f, -4.8151e-5f, 7990.f, 8e3f, 3.5484e-6f, .019493f,
-    .015877f, -6.3508e-5f, .01385f, -5.9425e-5f, 8e3f, 8010.f, 1.8178e-6f,
-    .01906f, .018969f, -7.5874e-5f, .016941f, -7.1792e-5f, 8010.f, 8020.f,
-    8.6808e-7f, .018194f, .022333f, -8.9332e-5f, .020306f, -8.525e-5f,
-    8020.f, 8030.f, 5.4731e-7f, .034766f, .027088f, -1.0685e-4f, .025457f,
-    -1.0498e-4f, 8030.f, 8040.f, 6.2423e-8f, .018194f, .034057f,
-    -1.3623e-4f, .03203f, -1.3215e-4f, 8040.f, 8050.f, 2.2644e-8f, .018194f,
-    .038506f, -1.5403e-4f, .036479f, -1.4994e-4f, 8050.f, 8060.f,
-    7.6809e-9f, .018194f, .043225f, -1.729e-4f, .041198f, -1.6882e-4f,
-    8060.f, 8070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8070.f, 8080.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8080.f, 8090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8090.f,
-      8100.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8100.f, 8110.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8110.f, 8120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8120.f, 8130.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8130.f, 8140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8140.f,
-      8150.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8150.f, 8160.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8160.f, 8170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8170.f, 8180.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8180.f, 8190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8190.f,
-      8200.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8200.f, 8210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8210.f, 8220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8220.f, 8230.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8230.f, 8240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8240.f,
-      8250.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8250.f, 8260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8260.f, 8270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8270.f, 8280.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8280.f, 8290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8290.f,
-      8300.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8300.f, 8310.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8320.f, 8330.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8340.f,
-      8350.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f, 8360.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8370.f, 8380.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8390.f,
-      8400.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f, 8410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8420.f, 8430.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8440.f,
-      8450.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f, 8460.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8470.f, 8480.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8490.f,
-      8500.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f, 8510.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8520.f, 8530.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8540.f,
-      8550.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f, 8560.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8570.f, 8580.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8590.f,
-      8600.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f, 8610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8620.f, 8630.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8640.f,
-      8650.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f, 8660.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8670.f, 8680.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8690.f,
-      8700.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f, 8710.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8720.f, 8730.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8740.f,
-      8750.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f, 8760.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8770.f, 8780.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8790.f,
-      8800.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f, 8810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8820.f, 8830.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8840.f,
-      8850.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f, 8860.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8870.f, 8880.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8890.f,
-      8900.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f, 8910.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8920.f, 8930.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8940.f,
-      8950.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f, 8960.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8970.f, 8980.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8990.f, 9e3f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      9010.f,
-    9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9020.f, 9030.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9040.f, 9050.f, 0.f,
+				     .023597f, .0062798f, -2.4587e-5f, .0054199f, -1.4942e-5f, 7960.f,
+				     7970.f, 1.7175e-5f, .021672f, .0082429f, -3.2972e-5f, .0062159f,
+				     -2.8891e-5f, 7970.f, 7980.f, 1.0919e-5f, .0208f, .010514f, -4.2054e-5f,
+				     .0084864f, -3.7973e-5f, 7980.f, 7990.f, 6.453e-6f, .019927f, .013058f,
+				     -5.2234e-5f, .011031f, -4.8151e-5f, 7990.f, 8e3f, 3.5484e-6f, .019493f,
+				     .015877f, -6.3508e-5f, .01385f, -5.9425e-5f, 8e3f, 8010.f, 1.8178e-6f,
+				     .01906f, .018969f, -7.5874e-5f, .016941f, -7.1792e-5f, 8010.f, 8020.f,
+				     8.6808e-7f, .018194f, .022333f, -8.9332e-5f, .020306f, -8.525e-5f,
+				     8020.f, 8030.f, 5.4731e-7f, .034766f, .027088f, -1.0685e-4f, .025457f,
+				     -1.0498e-4f, 8030.f, 8040.f, 6.2423e-8f, .018194f, .034057f,
+				     -1.3623e-4f, .03203f, -1.3215e-4f, 8040.f, 8050.f, 2.2644e-8f, .018194f,
+				     .038506f, -1.5403e-4f, .036479f, -1.4994e-4f, 8050.f, 8060.f,
+				     7.6809e-9f, .018194f, .043225f, -1.729e-4f, .041198f, -1.6882e-4f,
+				     8060.f, 8070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8070.f, 8080.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8080.f, 8090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8090.f,
+				     8100.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8100.f, 8110.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8110.f, 8120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8120.f, 8130.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8130.f, 8140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8140.f,
+				     8150.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8150.f, 8160.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8160.f, 8170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8170.f, 8180.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8180.f, 8190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8190.f,
+				     8200.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8200.f, 8210.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8210.f, 8220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8220.f, 8230.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8230.f, 8240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8240.f,
+				     8250.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8250.f, 8260.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8260.f, 8270.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8270.f, 8280.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8280.f, 8290.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8290.f,
+				     8300.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8300.f, 8310.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8310.f, 8320.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8320.f, 8330.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8330.f, 8340.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8340.f,
+				     8350.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8350.f, 8360.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8360.f, 8370.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8370.f, 8380.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8380.f, 8390.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8390.f,
+				     8400.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8400.f, 8410.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8410.f, 8420.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8420.f, 8430.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8430.f, 8440.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8440.f,
+				     8450.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8450.f, 8460.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8460.f, 8470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8470.f, 8480.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8480.f, 8490.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8490.f,
+				     8500.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8500.f, 8510.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8510.f, 8520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8520.f, 8530.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8530.f, 8540.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8540.f,
+				     8550.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8550.f, 8560.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8560.f, 8570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8570.f, 8580.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8580.f, 8590.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8590.f,
+				     8600.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8600.f, 8610.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8610.f, 8620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8620.f, 8630.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8630.f, 8640.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8640.f,
+				     8650.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8650.f, 8660.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8660.f, 8670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8670.f, 8680.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8680.f, 8690.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8690.f,
+				     8700.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8700.f, 8710.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8710.f, 8720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8720.f, 8730.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8730.f, 8740.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8740.f,
+				     8750.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8750.f, 8760.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8760.f, 8770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8770.f, 8780.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8780.f, 8790.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8790.f,
+				     8800.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8800.f, 8810.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8810.f, 8820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8820.f, 8830.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8830.f, 8840.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8840.f,
+				     8850.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8850.f, 8860.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8860.f, 8870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8870.f, 8880.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8880.f, 8890.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8890.f,
+				     8900.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8900.f, 8910.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8910.f, 8920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8920.f, 8930.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8930.f, 8940.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8940.f,
+				     8950.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8950.f, 8960.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     8960.f, 8970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8970.f, 8980.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 8980.f, 8990.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 8990.f, 9e3f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 9e3f, 9010.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     9010.f,
+				     9020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9020.f, 9030.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9030.f, 9040.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9040.f, 9050.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9060.f,
-    9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f, 9080.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9090.f, 9100.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9110.f,
-    9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f, 9130.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9140.f, 9150.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9160.f,
-    9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f, 9180.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9190.f, 9200.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9210.f,
-    9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f, 9230.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9240.f, 9250.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 2.9327e-8f, .020793f, .01052f,
-    -4.2079e-5f, .0084925f, -3.7997e-5f, 9260.f, 9270.f, 4.284e-8f,
-    .021659f, .0082482f, -3.2993e-5f, .0062209f, -2.8911e-5f, 9270.f,
-    9280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 1.4493e-7f,
-      .078959f,
-    .011173f, -3.6086e-5f, .0098558f, -3.9242e-5f, 9290.f, 9300.f,
-    2.5005e-7f, .083955f, .0092831f, -3.2526e-5f, .0073578f, -3.1073e-5f,
-    9300.f, 9310.f, 2.7511e-7f, .065813f, .0069254f, -2.5251e-5f, .0046721f,
-    -2.1357e-5f, 9310.f, 9320.f, 3.3929e-7f, .065167f, .0055165f,
-    -2.0774e-5f, .0031412f, -1.5731e-5f, 9320.f, 9330.f, 7.3603e-7f,
-    .092398f, .0037855f, -1.4891e-5f, .0017763f, -1.1006e-5f, 9330.f,
-    9340.f, 4.4813e-7f, .07935f, .0045127f, -2.4202e-6f, .0042176f,
-    -9.3426e-6f, 9340.f, 9350.f, 1.4773e-6f, .2629f, .0066029f, -1.8761e-5f,
-    .004739f, -1.8284e-5f, 9350.f, 9360.f, 3.6258e-6f, .35403f, .0024719f,
-    -8.6417e-6f, 5.0685e-4f, -5.3198e-6f, 9360.f, 9370.f, 1.0885e-6f,
-    .098959f, 2.798e-4f, -1.1056e-6f, -.0017654f, 3.0416e-6f, 9370.f,
-    9380.f, 1.6901e-6f, .12199f, .0012891f, -4.9557e-6f, -7.9138e-4f,
-    -7.506e-7f, 9380.f, 9390.f, 1.6816e-6f, .13899f, .0035668f, -1.2886e-5f,
-    .0015543f, -9.4945e-6f, 9390.f, 9400.f, 1.0341e-6f, .16279f, .0068719f,
-    -1.996e-5f, .0057191f, -2.3184e-5f, 9400.f, 9410.f, 3.1773e-7f, .06436f,
-    .0052558f, -2.7296e-6f, .0065364f, -1.6975e-5f, 9410.f, 9420.f,
-    2.0773e-7f, .023392f, .0030789f, -1.2316e-5f, .0010516f, -8.2335e-6f,
-    9420.f, 9430.f, 1.6613e-7f, .022959f, .0045253f, -1.8101e-5f, .0024979f,
-    -1.4019e-5f, 9430.f, 9440.f, 1.2289e-7f, .022092f, .0062467f,
-    -2.4987e-5f, .0042194f, -2.0905e-5f, 9440.f, 9450.f, 8.4168e-8f,
-    .021659f, .0082429f, -3.2972e-5f, .0062156f, -2.8889e-5f, 9450.f,
-    9460.f, 8.5119e-8f, .040142f, .011444f, -4.5054e-5f, .0095711f,
-    -4.1931e-5f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f, 9480.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
-      9530.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
-      9580.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
-      9630.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
-      9680.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
-      9730.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
-      9780.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9050.f, 9060.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9060.f,
+				     9070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9070.f, 9080.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9080.f, 9090.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9090.f, 9100.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9100.f, 9110.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9110.f,
+				     9120.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9120.f, 9130.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9130.f, 9140.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9140.f, 9150.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9150.f, 9160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9160.f,
+				     9170.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9170.f, 9180.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9180.f, 9190.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9190.f, 9200.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9200.f, 9210.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9210.f,
+				     9220.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9220.f, 9230.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 9230.f, 9240.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9240.f, 9250.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 9250.f, 9260.f, 2.9327e-8f, .020793f, .01052f,
+				     -4.2079e-5f, .0084925f, -3.7997e-5f, 9260.f, 9270.f, 4.284e-8f,
+				     .021659f, .0082482f, -3.2993e-5f, .0062209f, -2.8911e-5f, 9270.f,
+				     9280.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9280.f, 9290.f, 1.4493e-7f,
+				     .078959f,
+				     .011173f, -3.6086e-5f, .0098558f, -3.9242e-5f, 9290.f, 9300.f,
+				     2.5005e-7f, .083955f, .0092831f, -3.2526e-5f, .0073578f, -3.1073e-5f,
+				     9300.f, 9310.f, 2.7511e-7f, .065813f, .0069254f, -2.5251e-5f, .0046721f,
+				     -2.1357e-5f, 9310.f, 9320.f, 3.3929e-7f, .065167f, .0055165f,
+				     -2.0774e-5f, .0031412f, -1.5731e-5f, 9320.f, 9330.f, 7.3603e-7f,
+				     .092398f, .0037855f, -1.4891e-5f, .0017763f, -1.1006e-5f, 9330.f,
+				     9340.f, 4.4813e-7f, .07935f, .0045127f, -2.4202e-6f, .0042176f,
+				     -9.3426e-6f, 9340.f, 9350.f, 1.4773e-6f, .2629f, .0066029f, -1.8761e-5f,
+				     .004739f, -1.8284e-5f, 9350.f, 9360.f, 3.6258e-6f, .35403f, .0024719f,
+				     -8.6417e-6f, 5.0685e-4f, -5.3198e-6f, 9360.f, 9370.f, 1.0885e-6f,
+				     .098959f, 2.798e-4f, -1.1056e-6f, -.0017654f, 3.0416e-6f, 9370.f,
+				     9380.f, 1.6901e-6f, .12199f, .0012891f, -4.9557e-6f, -7.9138e-4f,
+				     -7.506e-7f, 9380.f, 9390.f, 1.6816e-6f, .13899f, .0035668f, -1.2886e-5f,
+				     .0015543f, -9.4945e-6f, 9390.f, 9400.f, 1.0341e-6f, .16279f, .0068719f,
+				     -1.996e-5f, .0057191f, -2.3184e-5f, 9400.f, 9410.f, 3.1773e-7f, .06436f,
+				     .0052558f, -2.7296e-6f, .0065364f, -1.6975e-5f, 9410.f, 9420.f,
+				     2.0773e-7f, .023392f, .0030789f, -1.2316e-5f, .0010516f, -8.2335e-6f,
+				     9420.f, 9430.f, 1.6613e-7f, .022959f, .0045253f, -1.8101e-5f, .0024979f,
+				     -1.4019e-5f, 9430.f, 9440.f, 1.2289e-7f, .022092f, .0062467f,
+				     -2.4987e-5f, .0042194f, -2.0905e-5f, 9440.f, 9450.f, 8.4168e-8f,
+				     .021659f, .0082429f, -3.2972e-5f, .0062156f, -2.8889e-5f, 9450.f,
+				     9460.f, 8.5119e-8f, .040142f, .011444f, -4.5054e-5f, .0095711f,
+				     -4.1931e-5f, 9460.f, 9470.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9470.f, 9480.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9480.f, 9490.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9490.f, 9500.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9500.f, 9510.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9510.f, 9520.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9520.f,
+				     9530.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9530.f, 9540.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9540.f, 9550.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9550.f, 9560.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9560.f, 9570.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9570.f,
+				     9580.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9580.f, 9590.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9590.f, 9600.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9600.f, 9610.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9610.f, 9620.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9620.f,
+				     9630.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9630.f, 9640.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9640.f, 9650.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9650.f, 9660.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9660.f, 9670.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9670.f,
+				     9680.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9680.f, 9690.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9690.f, 9700.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9700.f, 9710.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9710.f, 9720.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9720.f,
+				     9730.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9730.f, 9740.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9740.f, 9750.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9750.f, 9760.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9760.f, 9770.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9770.f,
+				     9780.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9780.f, 9790.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
-    9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
-      9830.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
-      9880.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
-      9930.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
-      9980.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
-      10030.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f, 10060.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10070.f,
-    10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10100.f,
-      10110.f,
-    0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      0.f,
-    10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f, 10140.f, 0.f,
-      0.f,
-    0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
-      10150.f,
-    10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f, 0.f, 0.f,
-      0.f,
-    0.f, 0.f, 10170.f, 10180.f
+				     9790.f, 9800.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9800.f, 9810.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9810.f, 9820.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9820.f,
+				     9830.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9830.f, 9840.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9840.f, 9850.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9850.f, 9860.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9860.f, 9870.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9870.f,
+				     9880.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9880.f, 9890.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9890.f, 9900.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9900.f, 9910.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9910.f, 9920.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9920.f,
+				     9930.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9930.f, 9940.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9940.f, 9950.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9950.f, 9960.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 9960.f, 9970.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9970.f,
+				     9980.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 9980.f, 9990.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     9990.f, 1e4f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 1e4f, 10010.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10010.f, 10020.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10020.f,
+				     10030.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10030.f, 10040.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10040.f, 10050.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10050.f, 10060.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10060.f, 10070.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10070.f,
+				     10080.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10080.f, 10090.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10090.f, 10100.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10100.f,
+				     10110.f,
+				     0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10110.f, 10120.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     10120.f, 10130.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10130.f, 10140.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 0.f, 0.f, 10140.f, 10150.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f,
+				     10150.f,
+				     10160.f, 0.f, 0.f, 0.f, 0.f, 0.f, 0.f, 10160.f, 10170.f, 0.f, 0.f, 0.f,
+				     0.f,
+				     0.f, 0.f, 10170.f, 10180.f
-	/* oxygen (7620 - 10170 cm-1) */
-	for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
+    /* oxygen (7620 - 10170 cm-1) */
+    for(int i = 0; i < 8; i++) a[i] = acr[i + (inu << 3) - 8];
 }	/* oxyg3 */
 void abstra (const AtmosModel& atms, const Altitude& alt,
-			 const float wl, const float xmus, const float xmuv,
-			 const float uw, const float uo3, float& uwus, float& uo3us,
-			 const float uwpl, const float uo3pl, const float uwusp,
-			 const float uo3usp, AbstraStruct& as )
+	     const float wl, const float xmus, const float xmuv,
+	     const float uw, const float uo3, float& uwus, float& uo3us,
+	     const float uwpl, const float uo3pl, const float uwusp,
+	     const float uo3usp, AbstraStruct& as )
-	// transmittance calculation for ozone, water vapor,
-	// carbon dioxyde and oxygen.
+    // transmittance calculation for ozone, water vapor,
+    // carbon dioxyde and oxygen.
-	float tnu[10][3],a[8],rm[34],r2[34],r3[34],tp[34],rat[10];
+    float tnu[10][3],a[8],rm[34],r2[34],r3[34],tp[34],rat[10];
     float rmpl[34],r2pl[34],r3pl[34],ratpl[10];
-	float dtcont,utcont,ttcont;
+    float dtcont,utcont,ttcont;
     float v,te2,phi,psi,uu,u,up,uud,uut,uuu;
     float ud,ut,upd,upt,udp,updp,udtp,updtp;
     float ds2,uupl,upl,uppl,ah2o;
     float xh,xi,xd,ako3,test1,test2,test3,udt,atest;
     float updt,tt,y,utt,uptt,tn;
-	float ds,te,roair;
-	double ptest, ptest1;
-	int iv,id,idgaz,inu = 0,n,nh;
+    float ds,te,roair;
+    double ptest, ptest1;
+    int iv,id,idgaz,inu = 0,n,nh;
-	int ivli[6] = { 2500,5060,7620,10180,12740,15300 };
-	float co3[102] = {
-		 4.50e-03, 8.00e-03, 1.07e-02, 1.10e-02, 1.27e-02, 1.71e-02,
-		 2.00e-02, 2.45e-02, 3.07e-02, 3.84e-02, 4.78e-02, 5.67e-02,
-		 6.54e-02, 7.62e-02, 9.15e-02, 1.00e-01, 1.09e-01, 1.20e-01,
-		 1.28e-01, 1.12e-01, 1.11e-01, 1.16e-01, 1.19e-01, 1.13e-01,
-		 1.03e-01, 9.24e-02, 8.28e-02, 7.57e-02, 7.07e-02, 6.58e-02,
-		 5.56e-02, 4.77e-02, 4.06e-02, 3.87e-02, 3.82e-02, 2.94e-02,
-		 2.09e-02, 1.80e-02, 1.91e-02, 1.66e-02, 1.17e-02, 7.70e-03,
-		 6.10e-03, 8.50e-03, 6.10e-03, 3.70e-03, 3.20e-03, 3.10e-03,
-		 2.55e-03, 1.98e-03, 1.40e-03, 8.25e-04, 2.50e-04, 0.      ,
-		 0.      , 0.      , 5.65e-04, 2.04e-03, 7.35e-03, 2.03e-02,
-		 4.98e-02, 1.18e-01, 2.46e-01, 5.18e-01, 1.02e+00, 1.95e+00,
-		 3.79e+00, 6.65e+00, 1.24e+01, 2.20e+01, 3.67e+01, 5.95e+01,
-		 8.50e+01, 1.26e+02, 1.68e+02, 2.06e+02, 2.42e+02, 2.71e+02,
-		 2.91e+02, 3.02e+02, 3.03e+02, 2.94e+02, 2.77e+02, 2.54e+02,
-		 2.26e+02, 1.96e+02, 1.68e+02, 1.44e+02, 1.17e+02, 9.75e+01,
-		 7.65e+01, 6.04e+01, 4.62e+01, 3.46e+01, 2.52e+01, 2.00e+01,
-		 1.57e+01, 1.20e+01, 1.00e+01, 8.80e+00, 8.30e+00, 8.60e+00
+    int ivli[6] = { 2500,5060,7620,10180,12740,15300 };
+    float co3[102] = {
+	4.50e-03, 8.00e-03, 1.07e-02, 1.10e-02, 1.27e-02, 1.71e-02,
+	2.00e-02, 2.45e-02, 3.07e-02, 3.84e-02, 4.78e-02, 5.67e-02,
+	6.54e-02, 7.62e-02, 9.15e-02, 1.00e-01, 1.09e-01, 1.20e-01,
+	1.28e-01, 1.12e-01, 1.11e-01, 1.16e-01, 1.19e-01, 1.13e-01,
+	1.03e-01, 9.24e-02, 8.28e-02, 7.57e-02, 7.07e-02, 6.58e-02,
+	5.56e-02, 4.77e-02, 4.06e-02, 3.87e-02, 3.82e-02, 2.94e-02,
+	2.09e-02, 1.80e-02, 1.91e-02, 1.66e-02, 1.17e-02, 7.70e-03,
+	6.10e-03, 8.50e-03, 6.10e-03, 3.70e-03, 3.20e-03, 3.10e-03,
+	2.55e-03, 1.98e-03, 1.40e-03, 8.25e-04, 2.50e-04, 0.      ,
+	0.      , 0.      , 5.65e-04, 2.04e-03, 7.35e-03, 2.03e-02,
+	4.98e-02, 1.18e-01, 2.46e-01, 5.18e-01, 1.02e+00, 1.95e+00,
+	3.79e+00, 6.65e+00, 1.24e+01, 2.20e+01, 3.67e+01, 5.95e+01,
+	8.50e+01, 1.26e+02, 1.68e+02, 2.06e+02, 2.42e+02, 2.71e+02,
+	2.91e+02, 3.02e+02, 3.03e+02, 2.94e+02, 2.77e+02, 2.54e+02,
+	2.26e+02, 1.96e+02, 1.68e+02, 1.44e+02, 1.17e+02, 9.75e+01,
+	7.65e+01, 6.04e+01, 4.62e+01, 3.46e+01, 2.52e+01, 2.00e+01,
+	1.57e+01, 1.20e+01, 1.00e+01, 8.80e+00, 8.30e+00, 8.60e+00
-	float cch2o[15] = {
-		0.00,0.19,0.15,0.12,0.10,
-		0.09,0.10,0.12,0.15,0.17,
-		0.20,0.24,0.28,0.33,0.00
+    float cch2o[15] = {
+	0.00,0.19,0.15,0.12,0.10,
+	0.09,0.10,0.12,0.15,0.17,
+	0.20,0.24,0.28,0.33,0.00
-	as.dtwava = 1;
-	as.utwava = 1;
-	as.ttwava = 1;
-	dtcont = 1;
-	utcont = 1;
-	ttcont = 1;
-	as.dtozon = 1;
-	as.utozon = 1;
-	as.ttozon = 1;
-	as.dtdica = 1;
-	as.utdica = 1;
-	as.ttdica = 1;
-	as.dtoxyg = 1;
+    as.dtwava = 1;
+    as.utwava = 1;
+    as.ttwava = 1;
+    dtcont = 1;
+    utcont = 1;
+    ttcont = 1;
+    as.dtozon = 1;
+    as.utozon = 1;
+    as.ttozon = 1;
+    as.dtdica = 1;
+    as.utdica = 1;
+    as.ttdica = 1;
+    as.dtoxyg = 1;
-	as.utoxyg = 1;
-	as.ttoxyg = 1;
-	as.dtniox = 1;
-	as.utniox = 1;
-	as.ttniox = 1;
-	as.dtmeth = 1;
-	as.utmeth = 1;
-	as.ttmeth = 1;
-	as.dtmoca = 1;
-	as.utmoca = 1;
-	as.ttmoca = 1;
+    as.utoxyg = 1;
+    as.ttoxyg = 1;
+    as.dtniox = 1;
+    as.utniox = 1;
+    as.ttniox = 1;
+    as.dtmeth = 1;
+    as.utmeth = 1;
+    as.ttmeth = 1;
+    as.dtmoca = 1;
+    as.utmoca = 1;
+    as.ttmoca = 1;
-	for(int i = 0 ; i < 10; i++ )
-		rat[i] = 1;
-		tnu[i][0] = 1;
-		tnu[i][1] = 1;
-		tnu[i][2] = 1;
+    for(int i = 0 ; i < 10; i++ )
+	rat[i] = 1;
+	tnu[i][0] = 1;
+	tnu[i][1] = 1;
+	tnu[i][2] = 1;
-	if (atms.idatm == 0) return;
+    if (atms.idatm == 0) return;
-	if((xmus == 0.) || (xmuv == 0.))
+    if((xmus == 0.) || (xmuv == 0.))
         fprintf(stderr, "Error on zenithal angle ( near 90 deg )\n");
-		return;
+	return;
-	/* constants determination */
-	const float p0 = 1013.25f;
-	const float g = 98.1f;
+    /* constants determination */
+    const float p0 = 1013.25f;
+    const float g = 98.1f;
-	const float t0 = 250.f;
+    const float t0 = 250.f;
-	/* volumic mass in kilogrammes per m3 */
-	ds = 0;
-	te = 0;
-	roair = 0;
-	const float air = 0.028964 / 0.0224;
-	const float roco2 = 0.044 / 0.0224;
-	const float rmo2 = 0.032 / 0.0224;
-	const float rmo3 = 0.048 / 0.0224;
-	const float rmn2o = 0.044 / 0.0224;
-	const float rmch4 = 0.016 / 0.0224;
-	const float rmco  = 0.028 / 0.0224;
+    /* volumic mass in kilogrammes per m3 */
+    ds = 0;
+    te = 0;
+    roair = 0;
+    const float air = 0.028964 / 0.0224;
+    const float roco2 = 0.044 / 0.0224;
+    const float rmo2 = 0.032 / 0.0224;
+    const float rmo3 = 0.048 / 0.0224;
+    const float rmn2o = 0.044 / 0.0224;
+    const float rmch4 = 0.016 / 0.0224;
+    const float rmco  = 0.028 / 0.0224;
-	uwus = 1.424;
-	uo3us = .344;
+    uwus = 1.424;
+    uo3us = .344;
-	if(atms.idatm == 8)
-		rat[0] = uw / uwus;
-		rat[1] = 1;
-		rat[2] = 1;
-		rat[3] = uo3 / uo3us;
-		rat[4] = 1;
-		rat[5] = 1;
-		rat[6] = 1;
-		rat[7] = uw / uwus;
-		rat[8] = uw / uwus;
-		rat[9] = uw / uwus;
+    if(atms.idatm == 8)
+	rat[0] = uw / uwus;
+	rat[1] = 1;
+	rat[2] = 1;
+	rat[3] = uo3 / uo3us;
+	rat[4] = 1;
+	rat[5] = 1;
+	rat[6] = 1;
+	rat[7] = uw / uwus;
+	rat[8] = uw / uwus;
+	rat[9] = uw / uwus;
-	v = (float)(1e+04 / wl);
-	iv = (int)(v / 5);
-	iv = iv * 5;
-	id = ((iv - 2500) / 10) / 256 + 1;
+    v = (float)(1e+04 / wl);
+    iv = (int)(v / 5);
+    iv = iv * 5;
+    id = ((iv - 2500) / 10) / 256 + 1;
-	for(idgaz = 1; idgaz <= 7; idgaz++)
+    for(idgaz = 1; idgaz <= 7; idgaz++)
+	if (id <= 6) inu = (iv - ivli[id-1]) / 10 + 1;
+	bool to270 = false;
+	switch(id)
-		if (id <= 6) inu = (iv - ivli[id-1]) / 10 + 1;
-		bool to270 = false;
-		switch(id)
-		case 1:
-				if(idgaz == 1) wava1(a,inu);
-				if(idgaz == 2) dica1(a,inu);
-				if(idgaz == 3) to270 = true;
-				if(idgaz == 4) ozon1(a,inu);
-				if(idgaz == 5) niox1(a,inu);
-				if(idgaz == 6) meth1(a,inu);
-				if(idgaz == 7) moca1(a,inu);
-				break;
-		case 2:
-				if(idgaz == 1) wava2(a,inu);
-				if(idgaz == 2) dica2(a,inu);
-				if(idgaz == 4) to270 = true;
-				if(idgaz == 5) niox2(a,inu);
-				if(idgaz == 6) meth2(a,inu);
-				if(idgaz == 7) moca2(a,inu);
-				break;
-		case 3:
-				if(idgaz == 1) wava3(a,inu);
-				if(idgaz == 2) dica3(a,inu);
-				if(idgaz == 3) oxyg3(a,inu);
-				if(idgaz == 5) niox3(a,inu);
-				if(idgaz == 6) meth3(a,inu);
-				if(idgaz == 7) moca3(a,inu);
-				break;
-		case 4:
-				if(idgaz == 1) wava4(a,inu);
-				if(idgaz == 2) to270 = true;
-				if(idgaz == 3) oxyg4(a,inu);
-				if(idgaz == 5) niox4(a,inu);
-				if(idgaz == 6) meth4(a,inu);
-				if(idgaz == 7) moca4(a,inu);
-				break;
-		case 5:
-				if(idgaz == 1) wava5(a,inu);
-				if(idgaz == 3) oxyg5(a,inu);
-				if(idgaz == 5) niox5(a,inu);
-				if(idgaz == 6) meth5(a,inu);
-				if(idgaz == 7) moca5(a,inu);
-				break;
-		case 6:
-				if(idgaz == 1) wava6(a,inu);
-				if(idgaz == 3) oxyg6(a,inu);
-				if(idgaz == 5) niox6(a,inu);
-				if(idgaz == 6) meth6(a,inu);
-				if(idgaz == 7) moca6(a,inu);
-				break;
-		default: to270 = true;
+	case 1:
+	    if(idgaz == 1) wava1(a,inu);
+	    if(idgaz == 2) dica1(a,inu);
+	    if(idgaz == 3) to270 = true;
+	    if(idgaz == 4) ozon1(a,inu);
+	    if(idgaz == 5) niox1(a,inu);
+	    if(idgaz == 6) meth1(a,inu);
+	    if(idgaz == 7) moca1(a,inu);
+	    break;
+	case 2:
+	    if(idgaz == 1) wava2(a,inu);
+	    if(idgaz == 2) dica2(a,inu);
+	    if(idgaz == 4) to270 = true;
+	    if(idgaz == 5) niox2(a,inu);
+	    if(idgaz == 6) meth2(a,inu);
+	    if(idgaz == 7) moca2(a,inu);
+	    break;
+	case 3:
+	    if(idgaz == 1) wava3(a,inu);
+	    if(idgaz == 2) dica3(a,inu);
+	    if(idgaz == 3) oxyg3(a,inu);
+	    if(idgaz == 5) niox3(a,inu);
+	    if(idgaz == 6) meth3(a,inu);
+	    if(idgaz == 7) moca3(a,inu);
+	    break;
+	case 4:
+	    if(idgaz == 1) wava4(a,inu);
+	    if(idgaz == 2) to270 = true;
+	    if(idgaz == 3) oxyg4(a,inu);
+	    if(idgaz == 5) niox4(a,inu);
+	    if(idgaz == 6) meth4(a,inu);
+	    if(idgaz == 7) moca4(a,inu);
+	    break;
+	case 5:
+	    if(idgaz == 1) wava5(a,inu);
+	    if(idgaz == 3) oxyg5(a,inu);
+	    if(idgaz == 5) niox5(a,inu);
+	    if(idgaz == 6) meth5(a,inu);
+	    if(idgaz == 7) moca5(a,inu);
+	    break;
+	case 6:
+	    if(idgaz == 1) wava6(a,inu);
+	    if(idgaz == 3) oxyg6(a,inu);
+	    if(idgaz == 5) niox6(a,inu);
+	    if(idgaz == 6) meth6(a,inu);
+	    if(idgaz == 7) moca6(a,inu);
+	    break;
+	default: to270 = true;
-		if(to270) for(int i = 0; i < 8; i++) a[i] = 0;
+	if(to270) for(int i = 0; i < 8; i++) a[i] = 0;
-		/* mixing ratio calculation for each gaseous constituents */
-		int k;
-		for(k = 0; k < 33; k++)
-			roair = air * 273.16f * atms.p[k] / (1013.25f * atms.t[k]);
-			tp[k] = (atms.t[k] + atms.t[k + 1]) / 2.f;
-			te = tp[k] - t0;
-			te2 = te * te;
-			phi = (float)exp(a[2] * te + a[3] * te2);
-			psi = (float)exp(a[4] * te + a[5] * te2);
-			if(idgaz == 1) rm[k] = atms.wh[k] / (roair * 1000);
-			if(idgaz == 2) rm[k] = 3.3e-04f * roco2 / air;
-			if(idgaz == 3) rm[k] = 0.20947f * rmo2 / air;
-			if(idgaz == 4) rm[k] = atms.wo[k] / (roair * 1000);
-			if(idgaz == 5) rm[k] = 310.e-09f * rmn2o / air;
-			if(idgaz == 6) rm[k] = 1.72e-06f * rmch4 / air;
-			if(idgaz == 7) rm[k] = 1.00e-09f * rmco  / air;
-			r2[k] = rm[k] * phi;
-			r3[k] = rm[k] * psi;
+	/* mixing ratio calculation for each gaseous constituents */
+	int k;
+	for(k = 0; k < 33; k++)
+	    roair = air * 273.16f * atms.p[k] / (1013.25f * atms.t[k]);
+	    tp[k] = (atms.t[k] + atms.t[k + 1]) / 2.f;
+	    te = tp[k] - t0;
+	    te2 = te * te;
+	    phi = (float)exp(a[2] * te + a[3] * te2);
+	    psi = (float)exp(a[4] * te + a[5] * te2);
+	    if(idgaz == 1) rm[k] = atms.wh[k] / (roair * 1000);
+	    if(idgaz == 2) rm[k] = 3.3e-04f * roco2 / air;
+	    if(idgaz == 3) rm[k] = 0.20947f * rmo2 / air;
+	    if(idgaz == 4) rm[k] = atms.wo[k] / (roair * 1000);
+	    if(idgaz == 5) rm[k] = 310.e-09f * rmn2o / air;
+	    if(idgaz == 6) rm[k] = 1.72e-06f * rmch4 / air;
+	    if(idgaz == 7) rm[k] = 1.00e-09f * rmco  / air;
+	    r2[k] = rm[k] * phi;
+	    r3[k] = rm[k] * psi;
-		uu = 0;
-		u = 0;
-		up = 0;
-		uud = 0;
-		uut = 0;
-		uuu = 0;
-		ud = 0;
-		ut = 0;
-		upd = 0;
-		upt = 0;
-		udp = 0;
-		updp = 0;
-		udtp = 0;
-		updtp = 0;
+	uu = 0;
+	u = 0;
+	up = 0;
+	uud = 0;
+	uut = 0;
+	uuu = 0;
+	ud = 0;
+	ut = 0;
+	upd = 0;
+	upt = 0;
+	udp = 0;
+	updp = 0;
+	udtp = 0;
+	updtp = 0;
-		/* pressure scale integration sigma = atms.p / p0 */
-		for(k = 1; k < 33; k++)
-			ds = (atms.p[k-1] - atms.p[k]) / atms.p[0];
-			ds2 = (atms.p[k-1] * atms.p[k-1] - atms.p[k] * atms.p[k]) / (2 * atms.p[0] * p0);
-			uu = uu + ((rm[k] + rm[k-1]) / 2) * ds * rat[idgaz-1];
-			u  = u  + ((r2[k] + r2[k-1]) / 2) * ds * rat[idgaz-1];
-			up = up + ((r3[k] + r3[k-1]) / 2) * ds2 * rat[idgaz-1];
+	/* pressure scale integration sigma = atms.p / p0 */
+	for(k = 1; k < 33; k++)
+	    ds = (atms.p[k-1] - atms.p[k]) / atms.p[0];
+	    ds2 = (atms.p[k-1] * atms.p[k-1] - atms.p[k] * atms.p[k]) / (2 * atms.p[0] * p0);
+	    uu = uu + ((rm[k] + rm[k-1]) / 2) * ds * rat[idgaz-1];
+	    u  = u  + ((r2[k] + r2[k-1]) / 2) * ds * rat[idgaz-1];
+	    up = up + ((r3[k] + r3[k-1]) / 2) * ds2 * rat[idgaz-1];
-		uu = uu * atms.p[0] * 100 / g;
-		u = u * atms.p[0] * 100 / g;
-		up = up * atms.p[0] * 100 / g;
+	uu = uu * atms.p[0] * 100 / g;
+	u = u * atms.p[0] * 100 / g;
+	up = up * atms.p[0] * 100 / g;
-		if(idgaz == 4) uu = 1000 * uu / rmo3;
-		if(idgaz == 2) uu = 1000 * uu / roco2;
-		if(idgaz == 5) uu = 1000 * uu / rmn2o;
-		if(idgaz == 6) uu = 1000 * uu / rmch4;
-		if(idgaz == 7) uu = 1000 * uu / rmco;
+	if(idgaz == 4) uu = 1000 * uu / rmo3;
+	if(idgaz == 2) uu = 1000 * uu / roco2;
+	if(idgaz == 5) uu = 1000 * uu / rmn2o;
+	if(idgaz == 6) uu = 1000 * uu / rmch4;
+	if(idgaz == 7) uu = 1000 * uu / rmco;
-		/* mixing ratio for plane calculation for each gaseous constituents */
-		if ((alt.idatmp == 0) || (alt.idatmp == 4))
-			uupl = uu;
-			upl = u;
-			uppl = up;
-		else
+	/* mixing ratio for plane calculation for each gaseous constituents */
+	if ((alt.idatmp == 0) || (alt.idatmp == 4))
+	    uupl = uu;
+	    upl = u;
+	    uppl = up;
+	else
             int k;
-				roair = air * 273.16f * alt.plane_sim.ppl[k] / (1013.25f * alt.plane_sim.tpl[k]);
-				tp[k]  =  (alt.plane_sim.tpl[k] + alt.plane_sim.tpl[k + 1]) / 2;
-				te = tp[k] - t0;
-				te2 = te * te;
-				if(idgaz == 1) rmpl[k] = alt.plane_sim.whpl[k] / (roair * 1000);
-				if(idgaz == 2) rmpl[k] = 3.3e-04f * roco2 / air;
-				if(idgaz == 3) rmpl[k] = 0.20947f * rmo2 / air;
-				if(idgaz == 4) rmpl[k] = alt.plane_sim.wopl[k] / (roair * 1000);
-				if(idgaz == 5) rmpl[k] = 310.e-09f * rmn2o / air;
-				if(idgaz ==	6) rmpl[k] = 1.72e-06f * rmch4 / air;
-				if(idgaz == 7) rmpl[k] = 1.00e-09f * rmco  / air;
-				r2pl[k] = rmpl[k] * phi;
-				r3pl[k] = rmpl[k] * psi;
+		roair = air * 273.16f * alt.plane_sim.ppl[k] / (1013.25f * alt.plane_sim.tpl[k]);
+		tp[k]  =  (alt.plane_sim.tpl[k] + alt.plane_sim.tpl[k + 1]) / 2;
+		te = tp[k] - t0;
+		te2 = te * te;
+		if(idgaz == 1) rmpl[k] = alt.plane_sim.whpl[k] / (roair * 1000);
+		if(idgaz == 2) rmpl[k] = 3.3e-04f * roco2 / air;
+		if(idgaz == 3) rmpl[k] = 0.20947f * rmo2 / air;
+		if(idgaz == 4) rmpl[k] = alt.plane_sim.wopl[k] / (roair * 1000);
+		if(idgaz == 5) rmpl[k] = 310.e-09f * rmn2o / air;
+		if(idgaz ==	6) rmpl[k] = 1.72e-06f * rmch4 / air;
+		if(idgaz == 7) rmpl[k] = 1.00e-09f * rmco  / air;
+		r2pl[k] = rmpl[k] * phi;
+		r3pl[k] = rmpl[k] * psi;
-			uupl = 0;
-			upl = 0;
-			uppl = 0;
+	    uupl = 0;
+	    upl = 0;
+	    uppl = 0;
-			/* update ratio plane */
-			for(int i = 0; i < 10; i++)	ratpl[i] = 1;
+	    /* update ratio plane */
+	    for(int i = 0; i < 10; i++)	ratpl[i] = 1;
-			if (alt.idatmp == 8)
-				ratpl[0] = uwpl / uwusp;
-				ratpl[1] = 1;
-				ratpl[2] = 1;
-				ratpl[3] = uo3pl / uo3usp;
-				ratpl[4] = 1;
-				ratpl[5] = 1;
-				ratpl[6] = 1;
-				ratpl[7] = uwpl / uwusp;
-				ratpl[8] = uwpl / uwusp;
-				ratpl[9] = uwpl / uwusp;
+	    if (alt.idatmp == 8)
+		ratpl[0] = uwpl / uwusp;
+		ratpl[1] = 1;
+		ratpl[2] = 1;
+		ratpl[3] = uo3pl / uo3usp;
+		ratpl[4] = 1;
+		ratpl[5] = 1;
+		ratpl[6] = 1;
+		ratpl[7] = uwpl / uwusp;
+		ratpl[8] = uwpl / uwusp;
+		ratpl[9] = uwpl / uwusp;
-			/* * all gases*/
+	    /* * all gases*/
-				ds = (alt.plane_sim.ppl[k-1] - alt.plane_sim.ppl[k]) / alt.plane_sim.ppl[0];
-				ds2 = (alt.plane_sim.ppl[k-1] * alt.plane_sim.ppl[k-1] -
-					  alt.plane_sim.ppl[k] * alt.plane_sim.ppl[k]) /
-					  (2 * alt.plane_sim.ppl[0] * p0);
-				uupl = uupl + ((rmpl[k] + rmpl[k-1]) / 2) * ds * ratpl[idgaz-1];
-				upl  = upl  + ((r2pl[k] + r2pl[k-1]) / 2) * ds * ratpl[idgaz-1];
-				uppl = uppl + ((r3pl[k] + r3pl[k-1]) / 2) * ds2 * ratpl[idgaz-1];
+		ds = (alt.plane_sim.ppl[k-1] - alt.plane_sim.ppl[k]) / alt.plane_sim.ppl[0];
+		ds2 = (alt.plane_sim.ppl[k-1] * alt.plane_sim.ppl[k-1] -
+		       alt.plane_sim.ppl[k] * alt.plane_sim.ppl[k]) /
+		    (2 * alt.plane_sim.ppl[0] * p0);
+		uupl = uupl + ((rmpl[k] + rmpl[k-1]) / 2) * ds * ratpl[idgaz-1];
+		upl  = upl  + ((r2pl[k] + r2pl[k-1]) / 2) * ds * ratpl[idgaz-1];
+		uppl = uppl + ((r3pl[k] + r3pl[k-1]) / 2) * ds2 * ratpl[idgaz-1];
-			uupl = uupl * alt.plane_sim.ppl[0] * 100 / g;
-			upl = upl * alt.plane_sim.ppl[0] * 100 / g;
-			uppl = uppl * alt.plane_sim.ppl[0] * 100 / g;
+	    uupl = uupl * alt.plane_sim.ppl[0] * 100 / g;
+	    upl = upl * alt.plane_sim.ppl[0] * 100 / g;
+	    uppl = uppl * alt.plane_sim.ppl[0] * 100 / g;
-			if(idgaz == 4) uupl = 1000 * uupl / rmo3;
-			if(idgaz == 2) uupl = 1000 * uupl / roco2;
-			if(idgaz == 5) uupl = 1000 * uupl / rmn2o;
-			if(idgaz == 6) uupl = 1000 * uupl / rmch4;
-			if(idgaz == 7) uupl = 1000 * uupl / rmco;
+	    if(idgaz == 4) uupl = 1000 * uupl / rmo3;
+	    if(idgaz == 2) uupl = 1000 * uupl / roco2;
+	    if(idgaz == 5) uupl = 1000 * uupl / rmn2o;
+	    if(idgaz == 6) uupl = 1000 * uupl / rmch4;
+	    if(idgaz == 7) uupl = 1000 * uupl / rmco;
-		} /* endif test atms.idatm  = 0,4 */
+	} /* endif test atms.idatm  = 0,4 */
-		/* downward path */
-		uud	= uu / xmus;
-		/* upward path */
-		uuu = uupl / xmuv;
-		/* total(down + up) path */
-		uut = uu / xmus + uupl / xmuv;
+	/* downward path */
+	uud	= uu / xmus;
+	/* upward path */
+	uuu = uupl / xmuv;
+	/* total(down + up) path */
+	uut = uu / xmus + uupl / xmuv;
-		if((idgaz == 2 && iv > 9620) || (idgaz == 3 && iv > 15920))
-			tnu[idgaz-1][0] = 1;
-			tnu[idgaz-1][1] = 1;
-			tnu[idgaz-1][2] = 1;
-			continue;
+	if((idgaz == 2 && iv > 9620) || (idgaz == 3 && iv > 15920))
+	    tnu[idgaz-1][0] = 1;
+	    tnu[idgaz-1][1] = 1;
+	    tnu[idgaz-1][2] = 1;
+	    continue;
-		if(idgaz == 1 || idgaz == 4)
-			xi = 0;
-			n = 0;
-			xd = 0;
-			if(!(iv < 2350 || iv > 3000))
+	if(idgaz == 1 || idgaz == 4)
+	    xi = 0;
+	    n = 0;
+	    xd = 0;
+	    if(!(iv < 2350 || iv > 3000))
-				xi = (v - 2350) / 50 + 1;
-				nh = (int)(xi + 1.001f);
-				xh = xi - float(nh);
-				ah2o = cch2o[nh-1] + xh * (cch2o[nh-1]-cch2o[nh-2]);
-				dtcont = (float)exp(-ah2o * uud);
-				utcont = (float)exp(-ah2o * uuu);
-				ttcont = (float)exp(-ah2o * uut);
+		xi = (v - 2350) / 50 + 1;
+		nh = (int)(xi + 1.001f);
+		xh = xi - float(nh);
+		ah2o = cch2o[nh-1] + xh * (cch2o[nh-1]-cch2o[nh-2]);
+		dtcont = (float)exp(-ah2o * uud);
+		utcont = (float)exp(-ah2o * uuu);
+		ttcont = (float)exp(-ah2o * uut);
-			if (!((idgaz == 1) || (iv < 13000)))
-				if(iv <=  23400) xi = (v - 13000) / 200 + 1;
-				else if(iv >=  27500) xi = (v - 27500) / 500 + 57;
-				else
-					tnu[3][0] = 1;
-					tnu[3][1] = 1;
-					tnu[3][2] = 1;
-					break;
+	    if (!((idgaz == 1) || (iv < 13000)))
+		if(iv <=  23400) xi = (v - 13000) / 200 + 1;
+		else if(iv >=  27500) xi = (v - 27500) / 500 + 57;
+		else
+		    tnu[3][0] = 1;
+		    tnu[3][1] = 1;
+		    tnu[3][2] = 1;
+		    break;
-				n = (int)(xi + 1.001);
-				xd = xi-float(n);
-				ako3 = co3[n-1] + xd * (co3[n-1] - co3[n-2]);
-				test1 = ako3 * uud;
-				test2 = ako3 * uuu;
-				test3 = ako3 * uut;
+		n = (int)(xi + 1.001);
+		xd = xi-float(n);
+		ako3 = co3[n-1] + xd * (co3[n-1] - co3[n-2]);
+		test1 = ako3 * uud;
+		test2 = ako3 * uuu;
+		test3 = ako3 * uut;
-				/* exponential overflow test */
+		/* exponential overflow test */
-				if(test1 > 86.0) test1 = 86.0;
-				if(test2 > 86.0) test2 = 86.0;
-				if(test3 > 86.0) test3 = 86.0;
+		if(test1 > 86.0) test1 = 86.0;
+		if(test2 > 86.0) test2 = 86.0;
+		if(test3 > 86.0) test3 = 86.0;
-				tnu[3][0] = (float)exp(-test1);
-				tnu[3][1] = (float)exp(-test2);
-				tnu[3][2] = (float)exp(-test3);
+		tnu[3][0] = (float)exp(-test1);
+		tnu[3][1] = (float)exp(-test2);
+		tnu[3][2] = (float)exp(-test3);
-				continue;
+		continue;
-		if(idgaz == 4 && iv > 3020) {
-			continue;
+	if(idgaz == 4 && iv > 3020) {
+	    continue;
-		ud = u / xmus;
-		upd = up / xmus;
-		udt = ud;
-		if(ud == 0 && upd == 0) udt = 1;
-		tn = a[1] * upd / (2 * udt);
-		atest = a[1];
-		if (a[1] == 0 && a[0] == 0.) atest = 1;
-		updt = upd;
-		if(ud == 0 && upd == 0.) updt = 1;
-		tt = 1 + 4 * (a[0] / atest) * ((ud * ud) / updt);
-		y = (float)(-tn * (sqrt(tt) - 1));
-		if(idgaz == 1) y = (float)(-a[0] * ud / sqrt(1 + (a[0] / atest) * (ud * ud / updt)));
-		tnu[idgaz-1][0] = (float)exp(y);
+	ud = u / xmus;
+	upd = up / xmus;
+	udt = ud;
+	if(ud == 0 && upd == 0) udt = 1;
+	tn = a[1] * upd / (2 * udt);
+	atest = a[1];
+	if (a[1] == 0 && a[0] == 0.) atest = 1;
+	updt = upd;
+	if(ud == 0 && upd == 0.) updt = 1;
+	tt = 1 + 4 * (a[0] / atest) * ((ud * ud) / updt);
+	y = (float)(-tn * (sqrt(tt) - 1));
+	if(idgaz == 1) y = (float)(-a[0] * ud / sqrt(1 + (a[0] / atest) * (ud * ud / updt)));
+	tnu[idgaz-1][0] = (float)exp(y);
-		/* upward path modified to take account for plane content */
-		udp = upl / xmuv;
-		updp = uppl / xmuv;
-		udtp = udp;
-		if(udp == 0 && updp == 0.) udtp = 1;
-		tn = a[1] * updp / (2 * udtp);
-		atest = a[1];
-		updtp = updp;
-		if(udp == 0 && updp == 0.) updtp = 1;
-		tt = 1 + 4 * (a[0] / atest) * ((udp * udp) / updtp);
-		if(idgaz == 1) y = (float)(-a[0] * udp / sqrt(1 + (a[0] / atest) * (udp * udp / updtp)));
-		tnu[idgaz-1][1] = (float)exp(y);
+	/* upward path modified to take account for plane content */
+	udp = upl / xmuv;
+	updp = uppl / xmuv;
+	udtp = udp;
+	if(udp == 0 && updp == 0.) udtp = 1;
+	tn = a[1] * updp / (2 * udtp);
+	atest = a[1];
+	updtp = updp;
+	if(udp == 0 && updp == 0.) updtp = 1;
+	tt = 1 + 4 * (a[0] / atest) * ((udp * udp) / updtp);
+	if(idgaz == 1) y = (float)(-a[0] * udp / sqrt(1 + (a[0] / atest) * (udp * udp / updtp)));
+	tnu[idgaz-1][1] = (float)exp(y);
-		/* total(down + up) path modified on the way up */
-		ut = u / xmus + upl / xmuv;
-		upt = up / xmus + uppl / xmuv;
-		utt = ut;
-		if(ut == 0 && upt == 0.) utt = 1;
-		tn = a[1] * upt / (2 * utt);
-		uptt = upt;
-		if(ut == 0 && upt == 0.) uptt = 1;
-		tt = 1 + 4 * (a[0] / atest) * ((ut * ut) / uptt);
-		if(idgaz == 1) y = (float)(-a[0] * ut / sqrt(1 + (a[0] / atest) * (ut * ut / uptt)));
-		tnu[idgaz-1][2] = (float)exp(y);
+	/* total(down + up) path modified on the way up */
+	ut = u / xmus + upl / xmuv;
+	upt = up / xmus + uppl / xmuv;
+	utt = ut;
+	if(ut == 0 && upt == 0.) utt = 1;
+	tn = a[1] * upt / (2 * utt);
+	uptt = upt;
+	if(ut == 0 && upt == 0.) uptt = 1;
+	tt = 1 + 4 * (a[0] / atest) * ((ut * ut) / uptt);
+	if(idgaz == 1) y = (float)(-a[0] * ut / sqrt(1 + (a[0] / atest) * (ut * ut / uptt)));
+	tnu[idgaz-1][2] = (float)exp(y);
     ptest1 = tnu[0][0] * dtcont;
-	ptest = ptest1;
-	if (ptest > 1e-10) as.dtwava = (float)ptest;
-	else as.dtwava = 0;
+    ptest = ptest1;
+    if (ptest > 1e-10) as.dtwava = (float)ptest;
+    else as.dtwava = 0;
-	ptest1 = tnu[0][1] * utcont;
-	ptest = ptest1;
+    ptest1 = tnu[0][1] * utcont;
+    ptest = ptest1;
-	if (ptest > 1e-10) as.utwava = (float)ptest;
-	else as.utwava = 0;
+    if (ptest > 1e-10) as.utwava = (float)ptest;
+    else as.utwava = 0;
-	ptest1 = tnu[0][2] * ttcont;
-	ptest = ptest1;
+    ptest1 = tnu[0][2] * ttcont;
+    ptest = ptest1;
-	if (ptest > 1e-10) as.ttwava = (float)ptest;
-	else as.ttwava = 0;
+    if (ptest > 1e-10) as.ttwava = (float)ptest;
+    else as.ttwava = 0;
-	as.dtdica = tnu[1][0];
-	as.utdica = tnu[1][1];
-	as.ttdica = tnu[1][2];
-	as.dtoxyg = tnu[2][0];
-	as.utoxyg = tnu[2][1];
-	as.ttoxyg = tnu[2][2];
-	as.dtozon = tnu[3][0];
-	as.utozon = tnu[3][1];
-	as.ttozon = tnu[3][2];
-	as.dtniox = tnu[4][0];
-	as.utniox = tnu[4][1];
-	as.ttniox = tnu[4][2];
-	as.dtmeth = tnu[5][0];
-	as.utmeth = tnu[5][1];
-	as.ttmeth = tnu[5][2];
-	as.dtmoca = tnu[6][0];
-	as.utmoca = tnu[6][1];
-	as.ttmoca = tnu[6][2];
+    as.dtdica = tnu[1][0];
+    as.utdica = tnu[1][1];
+    as.ttdica = tnu[1][2];
+    as.dtoxyg = tnu[2][0];
+    as.utoxyg = tnu[2][1];
+    as.ttoxyg = tnu[2][2];
+    as.dtozon = tnu[3][0];
+    as.utozon = tnu[3][1];
+    as.ttozon = tnu[3][2];
+    as.dtniox = tnu[4][0];
+    as.utniox = tnu[4][1];
+    as.ttniox = tnu[4][2];
+    as.dtmeth = tnu[5][0];
+    as.utmeth = tnu[5][1];
+    as.ttmeth = tnu[5][2];
+    as.dtmoca = tnu[6][0];
+    as.utmoca = tnu[6][1];
+    as.ttmoca = tnu[6][2];
-	if (alt.idatmp == 0)
-		as.ttwava = as.dtwava;
-		as.utwava = 1;
-		as.ttdica = as.dtdica;
-		as.utdica = 1;
-		as.ttoxyg = as.dtoxyg;
-		as.utoxyg = 1;
-		as.ttozon = as.dtozon;
-		as.utozon = 1;
-		as.ttniox = as.dtniox;
-		as.utniox = 1;
-		as.ttmeth = as.dtmeth;
-		as.utmeth = 1;
-		as.ttmoca = as.dtmoca;
-		as.utmoca = 1;
+    if (alt.idatmp == 0)
+	as.ttwava = as.dtwava;
+	as.utwava = 1;
+	as.ttdica = as.dtdica;
+	as.utdica = 1;
+	as.ttoxyg = as.dtoxyg;
+	as.utoxyg = 1;
+	as.ttozon = as.dtozon;
+	as.utozon = 1;
+	as.ttniox = as.dtniox;
+	as.utniox = 1;
+	as.ttmeth = as.dtmeth;
+	as.utmeth = 1;
+	as.ttmoca = as.dtmoca;
+	as.utmoca = 1;
Modified: grass/trunk/imagery/i.atcorr/AerosolConcentration.cpp
--- grass/trunk/imagery/i.atcorr/AerosolConcentration.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/AerosolConcentration.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -24,119 +24,119 @@
     iaer = _iaer;
-	taer55 = 0.f;
-	cin >> v;
+    taer55 = 0.f;
+    cin >> v;
+    cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore comments */
+    if(v == 0)
+	cin >> taer55;
-	if(v == 0)
-		cin >> taer55;
-		cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore comments */
-		v = (float)(exp(-log(taer55/2.7628f)/0.79902f));
-	else if(v > 0) oda550(v, atms);
+	v = (float)(exp(-log(taer55/2.7628f)/0.79902f));
+    else if(v > 0) oda550(v, atms);
 void AerosolConcentration::oda550(const float v, const AtmosModel& atms)
-	/* aerosol optical depth at wl=550nm */
-	/* vertical repartition of aerosol density for v=23km */
-	/*                ( in nbr of part/cm3 ) */
-	static const float an23[34] = {
-		2.828e+03,1.244e+03,5.371e+02,2.256e+02,1.192e+02,
-		8.987e+01,6.337e+01,5.890e+01,6.069e+01,5.818e+01,
-		5.675e+01,5.317e+01,5.585e+01,5.156e+01,5.048e+01,
-		4.744e+01,4.511e+01,4.458e+01,4.314e+01,3.634e+01,
-		2.667e+01,1.933e+01,1.455e+01,1.113e+01,8.826e+00,
-		7.429e+00,2.238e+00,5.890e-01,1.550e-01,4.082e-02,
-		1.078e-02,5.550e-05,1.969e-08,0.000e+00
+    /* aerosol optical depth at wl=550nm */
+    /* vertical repartition of aerosol density for v=23km */
+    /*                ( in nbr of part/cm3 ) */
+    static const float an23[34] = {
+	2.828e+03,1.244e+03,5.371e+02,2.256e+02,1.192e+02,
+	8.987e+01,6.337e+01,5.890e+01,6.069e+01,5.818e+01,
+	5.675e+01,5.317e+01,5.585e+01,5.156e+01,5.048e+01,
+	4.744e+01,4.511e+01,4.458e+01,4.314e+01,3.634e+01,
+	2.667e+01,1.933e+01,1.455e+01,1.113e+01,8.826e+00,
+	7.429e+00,2.238e+00,5.890e-01,1.550e-01,4.082e-02,
+	1.078e-02,5.550e-05,1.969e-08,0.000e+00
-	/* vertical repartition of aerosol density for v=5km */
-	static const float an5[34] = {
-		1.378e+04,5.030e+03,1.844e+03,6.731e+02,2.453e+02,
+    /* vertical repartition of aerosol density for v=5km */
+    static const float an5[34] = {
+	1.378e+04,5.030e+03,1.844e+03,6.731e+02,2.453e+02,
-	taer55 = 0;
-	if(fabs(v) <= 0) return;
-	if(iaer == 0) return;
+    taer55 = 0;
+    if(fabs(v) <= 0) return;
+    if(iaer == 0) return;
-	for(int k = 0; k < 32; k++)
-		float dz = atms.z[k+1] - atms.z[k];
-		float az = (115.f / 18.f) * (an5[k] - an23[k]);
-		float az1 = (115.f / 18.f) * (an5[k+1] - an23[k+1]);
+    for(int k = 0; k < 32; k++)
+	float dz = atms.z[k+1] - atms.z[k];
+	float az = (115.f / 18.f) * (an5[k] - an23[k]);
+	float az1 = (115.f / 18.f) * (an5[k+1] - an23[k+1]);
-		float bz = (5.f * an5[k] / 18.f) - (23.f * an23[k] / 18.f);
-		float bz1 = (5.f * an5[k+1] / 18.f) - (23.f * an23[k+1] / 18.f);
+	float bz = (5.f * an5[k] / 18.f) - (23.f * an23[k] / 18.f);
+	float bz1 = (5.f * an5[k+1] / 18.f) - (23.f * an23[k+1] / 18.f);
-		float bnz = az / v - bz;
-		float bnz1 = az1 / v - bz1;
+	float bnz = az / v - bz;
+	float bnz1 = az1 / v - bz1;
-		float ev = (float)(dz * exp((log(bnz) + log(bnz1)) / 2));
-		taer55 += ev * sigma * 1.0e-03f;
+	float ev = (float)(dz * exp((log(bnz) + log(bnz1)) / 2));
+	taer55 += ev * sigma * 1.0e-03f;
 void AerosolConcentration::print()
-	/* --- aerosol model (concentration) ---- */
+    /* --- aerosol model (concentration) ---- */
+    Output::Begin();
+    Output::End();
+    Output::Begin();
+    Output::Repeat(10, ' ');
+    Output::Print(" optical condition identity :");
+    Output::End();
+    if(fabs(v) <= xacc)
 	Output::Begin();
+	Output::Repeat(15, ' ');
+	Output::Print(" user def. opt. thick. at 550nm :");
+	ostringstream s;
+	s.setf(ios::fixed, ios::floatfield);
+	s << setprecision(4);
+	s << setw(11) << taer55 << ends;
+	Output::Print(s.str());
 	Output::End();
+    else
 	Output::Begin();
-	Output::Repeat(10, ' ');
-	Output::Print(" optical condition identity :");
+	Output::Print(" visibility :");
+	ostringstream s1;
+	s1.setf(ios::fixed, ios::floatfield);
+	s1 << setprecision(2);
+	s1 << setw(8) << v << ends;
+	Output::Print(s1.str());
+	Output::Print(" km  opt. thick. 550nm :");
+	ostringstream s2;
+	s2.setf(ios::fixed, ios::floatfield);
+	s2 << setprecision(4);
+	s2 << setw(9) << taer55 << ends;
+	Output::Print(s2.str());
 	Output::End();
-	if(fabs(v) <= xacc)
-		Output::Begin();
-		Output::Repeat(15, ' ');
-		Output::Print(" user def. opt. thick. at 550nm :");
-		ostringstream s;
-		s.setf(ios::fixed, ios::floatfield);
-		s << setprecision(4);
-		s << setw(11) << taer55 << ends;
-		Output::Print(s.str());
-		Output::End();
-	else
-		Output::Begin();
-		Output::Print(" visibility :");
-		ostringstream s1;
-		s1.setf(ios::fixed, ios::floatfield);
-		s1 << setprecision(2);
-		s1 << setw(8) << v << ends;
-		Output::Print(s1.str());
-		Output::Print(" km  opt. thick. 550nm :");
-		ostringstream s2;
-		s2.setf(ios::fixed, ios::floatfield);
-		s2 << setprecision(4);
-		s2 << setw(9) << taer55 << ends;
-		Output::Print(s2.str());
-		Output::End();
-	Output::Begin();
-	Output::End();
+    Output::Begin();
+    Output::End();
 AerosolConcentration AerosolConcentration::Parse(const long int iaer, const AtmosModel& atms)
-	AerosolConcentration aerocon;
-	aerocon.parse(iaer, atms);
-	return aerocon;
+    AerosolConcentration aerocon;
+    aerocon.parse(iaer, atms);
+    return aerocon;
Modified: grass/trunk/imagery/i.atcorr/AerosolModel.cpp
--- grass/trunk/imagery/i.atcorr/AerosolModel.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/AerosolModel.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -8,491 +8,491 @@
 /* (background desert model...) */
 void AerosolModel::bdm()
-	sixs_aerbas.ph = &sixs_aerbas.bdm_ph;
+    sixs_aerbas.ph = &sixs_aerbas.bdm_ph;
 /* (biomass burning model...) */
 void AerosolModel::bbm()
-	sixs_aerbas.ph = &sixs_aerbas.bbm_ph;
+    sixs_aerbas.ph = &sixs_aerbas.bbm_ph;
 /* (stratospherique aerosol model...) */
 void AerosolModel::stm()
-	sixs_aerbas.ph = &sixs_aerbas.stm_ph;
+    sixs_aerbas.ph = &sixs_aerbas.stm_ph;
 /* dust model */
 void AerosolModel::dust()
-	sixs_aerbas.ph = &(sixs_aerbas.dust_ph);
+    sixs_aerbas.ph = &(sixs_aerbas.dust_ph);
 /* water model */
 void AerosolModel::wate()
-	sixs_aerbas.ph = &(sixs_aerbas.wate_ph);
+    sixs_aerbas.ph = &(sixs_aerbas.wate_ph);
 /* ocean model */
 void AerosolModel::ocea()
-	sixs_aerbas.ph = &sixs_aerbas.ocea_ph;
+    sixs_aerbas.ph = &sixs_aerbas.ocea_ph;
 /* soot model */
 void AerosolModel::soot()
-	sixs_aerbas.ph = &sixs_aerbas.soot_ph;
+    sixs_aerbas.ph = &sixs_aerbas.soot_ph;
 /* (user defined model from size distribution) */
 /*	To compute, using the scattering of electromagnetic waves by a homogeneous
-	isotropic sphere, the physical properties of particles whose sizes are
-	comparable to or larger than the wavelength, and to generate mixture of
-	dry particles. */
+  isotropic sphere, the physical properties of particles whose sizes are
+  comparable to or larger than the wavelength, and to generate mixture of
+  dry particles. */
 void AerosolModel::mie(float (&ex)[4][10], float (&sc)[4][10], float (&asy)[4][10])
-	double np[4];
-	double ext[10][4];
-	double sca[10][4];
-	double p1[10][4][83];
+    double np[4];
+    double ext[10][4];
+    double sca[10][4];
+    double p1[10][4][83];
-	const double rmul = 0.99526231496887960135245539673954; /*rlogpas = 0.030;  (10**rlogpas-1.D+00)*/
+    const double rmul = 0.99526231496887960135245539673954; /*rlogpas = 0.030;  (10**rlogpas-1.D+00)*/
-	int i;
-	for(i = 0; i < mie_in.icp; i++)
+    int i;
+    for(i = 0; i < mie_in.icp; i++)
-		np[i] = 0;
-		for(int j = 0; j < 10; j++)
-			ex[i][j] = 0;
-			sc[i][j] = 0;
-			ext[j][i] = 0;
-			sca[j][i] = 0;
-			for(int k = 0; k < 83; k++) p1[j][i][k] = 0;
+	np[i] = 0;
+	for(int j = 0; j < 10; j++)
+	    ex[i][j] = 0;
+	    sc[i][j] = 0;
+	    ext[j][i] = 0;
+	    sca[j][i] = 0;
+	    for(int k = 0; k < 83; k++) p1[j][i][k] = 0;
-	double r;
-	double dr;
-	double nr = 0;
-	/* LOOPS ON THE NUMBER OF PARTICLE TYPE (4 max) */
-		r = mie_in.rmin;
-		dr = r*rmul;
+    double r;
+    double dr;
+    double nr = 0;
+    /* LOOPS ON THE NUMBER OF PARTICLE TYPE (4 max) */
+	r = mie_in.rmin;
+	dr = r*rmul;
-		/* LOOPS ON THE RADIUS OF THE PARTICLE */
-		do {
+	/* LOOPS ON THE RADIUS OF THE PARTICLE */
+	do {
-			/* call of the size distribution nr. For our computation, we need dn/dr for */
-			/* all functions except for sun-photometer inputs for which we need dV/dlog(r) */
+	    /* call of the size distribution nr. For our computation, we need dn/dr for */
+	    /* all functions except for sun-photometer inputs for which we need dV/dlog(r) */
-			switch(iaer-7)
-			case 1:
-					/* --- Mixture of particles (Log-Normal distribution functions, up to 5)*/
-					const double sqrt2PI =	2.506628274631000502415765284811;
-					const double ln10 =		2.3025850929940456840179914546844;
-					double log10_x2 = log10(mie_in.x2[i]);
-					double sq = log10(r/mie_in.x1[i])/log10_x2;
-					nr = exp(-0.5*sq*sq);
-					nr /= sqrt2PI * log10_x2 * ln10 * r;
-					break;
-			case 2:
-					/* --- Modified Gamma distribution function */
-					const double ldexp = -300.;
-					double arg=-mie_in.x2[i]*pow(r,(double)mie_in.x3[i]);
-					if(arg > ldexp) nr = pow(r,(double)mie_in.x1[i])*exp(arg);
-					else nr = 0;
-					break;
-			case 3:
-					/* --- Junge power-law function */
-					nr = pow(0.1,-(double)mie_in.x1[i]);
-					if(r > 0.1) nr = pow(r,-(double)mie_in.x1[i]);
-					break;
-			case 4:
-					/* --- from sun photometer */
-					nr = 0;
-					for(int j = 1; j < mie_in.irsunph; j++)
-						if((r-mie_in.rsunph[j]) < 0.000001)
-							nr = (r - mie_in.rsunph[j-1])/(mie_in.rsunph[j]-mie_in.rsunph[j-1]);
-							nr = mie_in.nrsunph[j-1] + nr*(mie_in.nrsunph[j] - mie_in.nrsunph[j-1]);
-							break;
+	    switch(iaer-7)
+	    case 1:
+		/* --- Mixture of particles (Log-Normal distribution functions, up to 5)*/
+		const double sqrt2PI =	2.506628274631000502415765284811;
+		const double ln10 =		2.3025850929940456840179914546844;
+		double log10_x2 = log10(mie_in.x2[i]);
+		double sq = log10(r/mie_in.x1[i])/log10_x2;
+		nr = exp(-0.5*sq*sq);
+		nr /= sqrt2PI * log10_x2 * ln10 * r;
+		break;
+	    case 2:
+		/* --- Modified Gamma distribution function */
+		const double ldexp = -300.;
+		double arg=-mie_in.x2[i]*pow(r,(double)mie_in.x3[i]);
+		if(arg > ldexp) nr = pow(r,(double)mie_in.x1[i])*exp(arg);
+		else nr = 0;
+		break;
+	    case 3:
+		/* --- Junge power-law function */
+		nr = pow(0.1,-(double)mie_in.x1[i]);
+		if(r > 0.1) nr = pow(r,-(double)mie_in.x1[i]);
+		break;
+	    case 4:
+		/* --- from sun photometer */
+		nr = 0;
+		for(int j = 1; j < mie_in.irsunph; j++)
+		    if((r-mie_in.rsunph[j]) < 0.000001)
+			nr = (r - mie_in.rsunph[j-1])/(mie_in.rsunph[j]-mie_in.rsunph[j-1]);
+			nr = mie_in.nrsunph[j-1] + nr*(mie_in.nrsunph[j] - mie_in.nrsunph[j-1]);
+			break;
-			/* The Mie's calculations have to be called several times (min=2, max=10 for
-			 each type of particle): at wavelengths bounding the range of the selected
-			 wavelengths,and at 0.550 microns to normalized the extinction coefficient
-			 (if it's not in the selected range of wavelengths). */
+	    /* The Mie's calculations have to be called several times (min=2, max=10 for
+	       each type of particle): at wavelengths bounding the range of the selected
+	       wavelengths,and at 0.550 microns to normalized the extinction coefficient
+	       (if it's not in the selected range of wavelengths). */
-			double xndpr2 = nr * dr * M_PI * (r * r);
-			/* relatif number of particle for each type of particle (has to be equal to 1) */
-			np[i]+= nr * dr;
+	    double xndpr2 = nr * dr * M_PI * (r * r);
+	    /* relatif number of particle for each type of particle (has to be equal to 1) */
+	    np[i]+= nr * dr;
-				if( (xndpr2*mie_in.cij[i]) < (1e-8 / sqrt(sixs_disc.wldis[j])) ) break;
+		if( (xndpr2*mie_in.cij[i]) < (1e-8 / sqrt(sixs_disc.wldis[j])) ) break;
-				double alpha = 2. * M_PI * r / sixs_disc.wldis[j];
-				double Qext, Qsca;
-				double p11[83];
-				exscphase(alpha, mie_in.rn[j][i], mie_in.ri[j][i], Qext, Qsca, p11);
-				ext[j][i] += xndpr2 * Qext;
-				sca[j][i] += xndpr2 * Qsca;
+		double alpha = 2. * M_PI * r / sixs_disc.wldis[j];
+		double Qext, Qsca;
+		double p11[83];
+		exscphase(alpha, mie_in.rn[j][i], mie_in.ri[j][i], Qext, Qsca, p11);
+		ext[j][i] += xndpr2 * Qext;
+		sca[j][i] += xndpr2 * Qsca;
-				/* phase function for each type of particle */
-				for(int k = 0; k < 83; k++) p1[j][i][k] += p11[k]*xndpr2;
+		/* phase function for each type of particle */
+		for(int k = 0; k < 83; k++) p1[j][i][k] += p11[k]*xndpr2;
-			r += dr;
-			dr = r * rmul;
-		} while (r < mie_in.rmax);
+	    r += dr;
+	    dr = r * rmul;
+	} while (r < mie_in.rmax);
+    /* NOW WE MIXTE THE DIFFERENT TYPES OF PARTICLE
+       computation of the scattering and extinction coefficients. We first start
+       at 0.550 micron (the extinction coefficient is normalized at 0.550 micron) */
+    int j;
+    for(j = 0; j < 10; j++)
+	for(int i = 0; i < mie_in.icp; i++)
+	    ext[j][i] /= np[i] * 1000;
+	    sca[j][i] /= np[i] * 1000;
+	    ex[0][j] += (float)(mie_in.cij[i] * ext[j][i]);
+	    sc[0][j] += (float)(mie_in.cij[i] * sca[j][i]);
+    /* computation of the phase function and the asymetry coefficient
+       of the mixture of particles */
-	/* NOW WE MIXTE THE DIFFERENT TYPES OF PARTICLE
-	 computation of the scattering and extinction coefficients. We first start
-	 at 0.550 micron (the extinction coefficient is normalized at 0.550 micron) */
-	int j;
-	for(j = 0; j < 10; j++)
-		for(int i = 0; i < mie_in.icp; i++)
-			ext[j][i] /= np[i] * 1000;
-			sca[j][i] /= np[i] * 1000;
-			ex[0][j] += (float)(mie_in.cij[i] * ext[j][i]);
-			sc[0][j] += (float)(mie_in.cij[i] * sca[j][i]);
+	double asy_n = 0;
+	double asy_d = 0;
-	/* computation of the phase function and the asymetry coefficient
-	 of the mixture of particles */
-		double asy_n = 0;
-		double asy_d = 0;
-			sixs_aerbas.usr_ph[j][k] = 0;
-				sixs_aerbas.usr_ph[j][k] += (float)(mie_in.cij[i] * p1[j][i][k] / np[i] / 1000);
+	    sixs_aerbas.usr_ph[j][k] = 0;
+		sixs_aerbas.usr_ph[j][k] += (float)(mie_in.cij[i] * p1[j][i][k] / np[i] / 1000);
-			sixs_aerbas.usr_ph[j][k] += (float)sc[0][j];
-			asy_n += sixs_sos.cgaus[k] * sixs_aerbas.usr_ph[j][k] * sixs_sos.pdgs[k] / 10.;
-			asy_d += sixs_aerbas.usr_ph[j][k] * sixs_sos.pdgs[k] / 10.;
-		asy[0][j] = (float)(asy_n / asy_d);
+	    sixs_aerbas.usr_ph[j][k] += (float)sc[0][j];
+	    asy_n += sixs_sos.cgaus[k] * sixs_aerbas.usr_ph[j][k] * sixs_sos.pdgs[k] / 10.;
+	    asy_d += sixs_aerbas.usr_ph[j][k] * sixs_sos.pdgs[k] / 10.;
-	sixs_aerbas.ph = &sixs_aerbas.usr_ph;
+	asy[0][j] = (float)(asy_n / asy_d);
+    sixs_aerbas.ph = &sixs_aerbas.usr_ph;
   Using the Mie's theory, this subroutine compute the scattering and
   extinction efficiency factors (usually written Qsca and Qext) and it also
   compute the scattering intensity efficiency
 void AerosolModel::exscphase(const double X, const double nr,
-							 const double ni, double& Qext,
-							 double& Qsca, double (&p11)[83])
+			     const double ni, double& Qext,
+			     double& Qsca, double (&p11)[83])
-	double Ren=nr/(nr*nr+ni*ni);
-	double Imn=ni/(nr*nr+ni*ni);
+    double Ren=nr/(nr*nr+ni*ni);
+    double Imn=ni/(nr*nr+ni*ni);
-	/* ---Identification of the greater order of computation (=mu)
-	    as defined by F.J. Corbato, J. Assoc. Computing Machinery, 1959,
-	    6, 366-375 */
+    /* ---Identification of the greater order of computation (=mu)
+       as defined by F.J. Corbato, J. Assoc. Computing Machinery, 1959,
+       6, 366-375 */
     int N=int(0.5*(-1+sqrt(1+4*X*X)))+1;
     if (N == 1) N = 2;
-	int mu2 = 1000000;
-	double Up = 2 * X / (2 * N + 1);
-	int mu1 = int(N + 30. * (0.1 + 0.35 * Up * (2. - Up * Up) / 2 / (1 - Up)));
-	int Np = int(X - 0.5 * sqrt(30. * 0.35 * X));
+    int mu2 = 1000000;
+    double Up = 2 * X / (2 * N + 1);
+    int mu1 = int(N + 30. * (0.1 + 0.35 * Up * (2. - Up * Up) / 2 / (1 - Up)));
+    int Np = int(X - 0.5 * sqrt(30. * 0.35 * X));
-	if(Np > N)
-		Up = 2 * X / (2 * Np + 1);
-		mu2 = int(Np + 30. * (0.1 + 0.35 * Up * (2 - Up * Up)/ 2 / (1 - Up)));
+    if(Np > N)
+	Up = 2 * X / (2 * Np + 1);
+	mu2 = int(Np + 30. * (0.1 + 0.35 * Up * (2 - Up * Up)/ 2 / (1 - Up)));
-	int mu = (mu1 < mu2) ? mu1 : mu2;	/* min(mu1, mu2) */
+    int mu = (mu1 < mu2) ? mu1 : mu2;	/* min(mu1, mu2) */
-	/* --- Identification of the transition line. Below this line the Bessel
-	     function j behaves as oscillating functions. Above the behavior
-	     becomes monotonic. We start at a order greater than this transition
-	     line (order max=mu) because a downward recursion is called for. */
+    /* --- Identification of the transition line. Below this line the Bessel
+       function j behaves as oscillating functions. Above the behavior
+       becomes monotonic. We start at a order greater than this transition
+       line (order max=mu) because a downward recursion is called for. */
-	double Rn[10001], xj[10001];
-	int k = mu + 1;
+    double Rn[10001], xj[10001];
+    int k = mu + 1;
-	Rn[mu] = 0;
-	int mub;
-	while(true)
+    Rn[mu] = 0;
+    int mub;
+    while(true)
+	k--;
+	xj[k] = 0;
+	Rn[k-1] = X / (2 * k + 1 - X * Rn[k]);
+	if ( k == 2)
-		k--;
-		xj[k] = 0;
-		Rn[k-1] = X / (2 * k + 1 - X * Rn[k]);
-		if ( k == 2)
-			xj[mu + 1] = 0;
-			xj[mu] = 1;
-			mub = mu;
-			break;
+	    xj[mu + 1] = 0;
+	    xj[mu] = 1;
+	    mub = mu;
+	    break;
-		if(Rn[k-1] > 1)
-			xj[k] = Rn[k-1];
-			xj[k-1] = 1;
-			mub = k - 1;
-			break;
+	if(Rn[k-1] > 1)
+	    xj[k] = Rn[k-1];
+	    xj[k-1] = 1;
+	    mub = k - 1;
+	    break;
-	for(k = mub; k >= 1; k--) xj[k-1] = (2 * k + 1) * xj[k] / X - xj[k+1];
-	double coxj = xj[0] - X * xj[1] * cos(X) + X * xj[0] * sin(X);
+    for(k = mub; k >= 1; k--) xj[k-1] = (2 * k + 1) * xj[k] / X - xj[k+1];
+    double coxj = xj[0] - X * xj[1] * cos(X) + X * xj[0] * sin(X);
-	/* --- Computation Dn(alpha) and Dn(alpha*m) (cf MIE's theory)
-	     downward recursion    - real and imaginary parts */
+    /* --- Computation Dn(alpha) and Dn(alpha*m) (cf MIE's theory)
+       downward recursion    - real and imaginary parts */
-	double RDnY[10001];
-	double IDnY[10001];
-	double RDnX[10001];
-	RDnY[mu] = 0;
-	IDnY[mu] = 0;
-	RDnX[mu] = 0;
+    double RDnY[10001];
+    double IDnY[10001];
+    double RDnX[10001];
+    RDnY[mu] = 0;
+    IDnY[mu] = 0;
+    RDnX[mu] = 0;
-	for(k = mu; k >= 1; k--)
-		RDnX[k-1] = k / X - 1 / (RDnX[k] + k / X);
-		double XnumRDnY = RDnY[k] + Ren * k / X;
-		double XnumIDnY = IDnY[k] + Imn * k / X;
-		double XdenDnY = XnumRDnY * XnumRDnY + XnumIDnY * XnumIDnY;
-		RDnY[k-1] = k * Ren / X - XnumRDnY / XdenDnY;
-		IDnY[k-1] = k * Imn / X + XnumIDnY / XdenDnY;
+    for(k = mu; k >= 1; k--)
+	RDnX[k-1] = k / X - 1 / (RDnX[k] + k / X);
+	double XnumRDnY = RDnY[k] + Ren * k / X;
+	double XnumIDnY = IDnY[k] + Imn * k / X;
+	double XdenDnY = XnumRDnY * XnumRDnY + XnumIDnY * XnumIDnY;
+	RDnY[k-1] = k * Ren / X - XnumRDnY / XdenDnY;
+	IDnY[k-1] = k * Imn / X + XnumIDnY / XdenDnY;
-	/* --- Initialization of the upward recursions
-	 macro to help keep indexing correct, can't be to safe */
-	#define INDEX(X) ((X)+1)
-	double xy[10002];
-	xy[INDEX(-1)] = sin(X) / X;
-	xy[INDEX(0)]  = -cos(X) / X;
+    /* --- Initialization of the upward recursions
+       macro to help keep indexing correct, can't be to safe */
+#define INDEX(X) ((X)+1)
+    double xy[10002];
+    xy[INDEX(-1)] = sin(X) / X;
+    xy[INDEX(0)]  = -cos(X) / X;
-	double RGnX[10001];
-	double IGnX[10001];
-	RGnX[0] = 0;
-	IGnX[0] = -1;
-	Qsca = 0;
-	Qext = 0;
+    double RGnX[10001];
+    double IGnX[10001];
+    RGnX[0] = 0;
+    IGnX[0] = -1;
+    Qsca = 0;
+    Qext = 0;
-	double RAn[10001];
-	double IAn[10001];
-	double RBn[10001];
-	double IBn[10001];
+    double RAn[10001];
+    double IAn[10001];
+    double RBn[10001];
+    double IBn[10001];
-	for(k = 1; k <= mu; k++)
-		if (k <= mub) xj[k] /= coxj;
-		else xj[k] = Rn[k-1] * xj[k-1];
+    for(k = 1; k <= mu; k++)
+	if (k <= mub) xj[k] /= coxj;
+	else xj[k] = Rn[k-1] * xj[k-1];
-		/* --- Computation of bessel's function y(alpha) */
-		xy[INDEX(k)] = (2 * k - 1) * xy[INDEX(k-1)] / X - xy[INDEX(k-2)];
-		double xJonH = xj[k] / ( xj[k] * xj[k] + xy[INDEX(k)] * xy[INDEX(k)] );
+	/* --- Computation of bessel's function y(alpha) */
+	xy[INDEX(k)] = (2 * k - 1) * xy[INDEX(k-1)] / X - xy[INDEX(k-2)];
+	double xJonH = xj[k] / ( xj[k] * xj[k] + xy[INDEX(k)] * xy[INDEX(k)] );
-		/*  --- Computation of Gn(alpha), Real and Imaginary part */
-		double XdenGNX = (RGnX[k-1] - k/X)*(RGnX[k-1] - k/X) + IGnX[k-1] * IGnX[k-1];
-		RGnX[k] = (k / X - RGnX[k-1])/XdenGNX - k / X;
-		IGnX[k] = IGnX[k-1] / XdenGNX;
+	/*  --- Computation of Gn(alpha), Real and Imaginary part */
+	double XdenGNX = (RGnX[k-1] - k/X)*(RGnX[k-1] - k/X) + IGnX[k-1] * IGnX[k-1];
+	RGnX[k] = (k / X - RGnX[k-1])/XdenGNX - k / X;
+	IGnX[k] = IGnX[k-1] / XdenGNX;
-		/* --- Computation of An(alpha) and Bn(alpha), Real and Imaginary part */
-		double Xnum1An = RDnY[k] - nr * RDnX[k];
-		double Xnum2An = IDnY[k] + ni * RDnX[k];
-		double Xden1An = RDnY[k] - nr * RGnX[k] - ni * IGnX[k];
-		double Xden2An = IDnY[k] + ni * RGnX[k] - nr * IGnX[k];
-		double XdenAn = Xden1An * Xden1An + Xden2An * Xden2An;
-		double RAnb = (Xnum1An * Xden1An + Xnum2An * Xden2An) / XdenAn;
-		double IAnb = (-Xnum1An * Xden2An + Xnum2An * Xden1An) / XdenAn;
-		RAn[k] = xJonH * (xj[k] * RAnb - xy[INDEX(k)] * IAnb);
-		IAn[k] = xJonH * (xy[INDEX(k)] * RAnb + xj[k] * IAnb);
+	/* --- Computation of An(alpha) and Bn(alpha), Real and Imaginary part */
+	double Xnum1An = RDnY[k] - nr * RDnX[k];
+	double Xnum2An = IDnY[k] + ni * RDnX[k];
+	double Xden1An = RDnY[k] - nr * RGnX[k] - ni * IGnX[k];
+	double Xden2An = IDnY[k] + ni * RGnX[k] - nr * IGnX[k];
+	double XdenAn = Xden1An * Xden1An + Xden2An * Xden2An;
+	double RAnb = (Xnum1An * Xden1An + Xnum2An * Xden2An) / XdenAn;
+	double IAnb = (-Xnum1An * Xden2An + Xnum2An * Xden1An) / XdenAn;
+	RAn[k] = xJonH * (xj[k] * RAnb - xy[INDEX(k)] * IAnb);
+	IAn[k] = xJonH * (xy[INDEX(k)] * RAnb + xj[k] * IAnb);
-		double Xnum1Bn = nr * RDnY[k] + ni * IDnY[k] - RDnX[k];
-		double Xnum2Bn = nr * IDnY[k] - ni * RDnY[k];
-		double Xden1Bn = nr * RDnY[k] + ni * IDnY[k] - RGnX[k];
-		double Xden2Bn = nr * IDnY[k] - ni * RDnY[k] - IGnX[k];
-		double XdenBn = Xden1Bn * Xden1Bn + Xden2Bn * Xden2Bn;
-		double RBnb = (Xnum1Bn * Xden1Bn + Xnum2Bn * Xden2Bn) / XdenBn;
-		double IBnb = (-Xnum1Bn * Xden2Bn + Xnum2Bn * Xden1Bn) / XdenBn;
-		RBn[k] = xJonH * (xj[k] * RBnb - xy[INDEX(k)] * IBnb);
-		IBn[k] = xJonH * (xy[INDEX(k)] * RBnb + xj[k] * IBnb);
+	double Xnum1Bn = nr * RDnY[k] + ni * IDnY[k] - RDnX[k];
+	double Xnum2Bn = nr * IDnY[k] - ni * RDnY[k];
+	double Xden1Bn = nr * RDnY[k] + ni * IDnY[k] - RGnX[k];
+	double Xden2Bn = nr * IDnY[k] - ni * RDnY[k] - IGnX[k];
+	double XdenBn = Xden1Bn * Xden1Bn + Xden2Bn * Xden2Bn;
+	double RBnb = (Xnum1Bn * Xden1Bn + Xnum2Bn * Xden2Bn) / XdenBn;
+	double IBnb = (-Xnum1Bn * Xden2Bn + Xnum2Bn * Xden1Bn) / XdenBn;
+	RBn[k] = xJonH * (xj[k] * RBnb - xy[INDEX(k)] * IBnb);
+	IBn[k] = xJonH * (xy[INDEX(k)] * RBnb + xj[k] * IBnb);
-		/* ---Criterion on the recursion formulas as defined by D. Deirmendjian
-		    et al., J. Opt. Soc. Am., 1961, 51, 6, 620-633 */
-		double temp = RAn[k] * RAn[k] + IAn[k] * IAn[k] + RBn[k] * RBn[k] + IBn[k] * IBn[k];
-		if((temp/k) < 1e-14)
-			mu = k;
-			break;
+	/* ---Criterion on the recursion formulas as defined by D. Deirmendjian
+	   et al., J. Opt. Soc. Am., 1961, 51, 6, 620-633 */
+	double temp = RAn[k] * RAn[k] + IAn[k] * IAn[k] + RBn[k] * RBn[k] + IBn[k] * IBn[k];
+	if((temp/k) < 1e-14)
+	    mu = k;
+	    break;
-		/* --- Computation of the scattering and extinction efficiency factor */
-		double xpond =  2 / X / X * (2 * k + 1);
-		Qsca = Qsca + xpond * temp;
-		Qext = Qext + xpond * (RAn[k] + RBn[k]);
+	/* --- Computation of the scattering and extinction efficiency factor */
+	double xpond =  2 / X / X * (2 * k + 1);
+	Qsca = Qsca + xpond * temp;
+	Qext = Qext + xpond * (RAn[k] + RBn[k]);
-	/* --- Computation of the amplitude functions S1 and S2 (cf MIE's theory)
-	     defined by PIn, TAUn, An and Bn with PIn and TAUn related to the
-	     Legendre polynomials. */
-	for(int j = 0; j < 83; j++)
-		double RS1 = 0;
-		double RS2 = 0;
-		double IS1 = 0;
-		double IS2 = 0;
-		double PIn[10001];
-		double TAUn[10001];
+    /* --- Computation of the amplitude functions S1 and S2 (cf MIE's theory)
+       defined by PIn, TAUn, An and Bn with PIn and TAUn related to the
+       Legendre polynomials. */
+    for(int j = 0; j < 83; j++)
+	double RS1 = 0;
+	double RS2 = 0;
+	double IS1 = 0;
+	double IS2 = 0;
+	double PIn[10001];
+	double TAUn[10001];
-		PIn[0] = 0;
-		PIn[1] = 0;
-		TAUn[1] = sixs_sos.cgaus[j];
+	PIn[0] = 0;
+	PIn[1] = 0;
+	TAUn[1] = sixs_sos.cgaus[j];
-		for(int k = 1; k <= mu; k++)
-			double co_n = (2 * k + 1) / k / (k + 1);
-			RS1 += co_n * (RAn[k] * PIn[k] + RBn[k] * TAUn[k]);
-			RS2 += co_n * (RAn[k] * TAUn[k] + RBn[k] * PIn[k]);
-			IS1 += co_n * (IAn[k] * PIn[k] + IBn[k] * TAUn[k]);
-			IS2 += co_n * (IAn[k] * TAUn[k] + IBn[k] * PIn[k]);
+	for(int k = 1; k <= mu; k++)
+	    double co_n = (2 * k + 1) / k / (k + 1);
+	    RS1 += co_n * (RAn[k] * PIn[k] + RBn[k] * TAUn[k]);
+	    RS2 += co_n * (RAn[k] * TAUn[k] + RBn[k] * PIn[k]);
+	    IS1 += co_n * (IAn[k] * PIn[k] + IBn[k] * TAUn[k]);
+	    IS2 += co_n * (IAn[k] * TAUn[k] + IBn[k] * PIn[k]);
-			PIn[k+1] = ((2 * k + 1) * sixs_sos.cgaus[j] * PIn[k] - (k + 1) * PIn[k-1])/k;
-			TAUn[k+1] = (k + 1) * sixs_sos.cgaus[j] * PIn[k + 1] - (k + 2) * PIn[k];
+	    PIn[k+1] = ((2 * k + 1) * sixs_sos.cgaus[j] * PIn[k] - (k + 1) * PIn[k-1])/k;
+	    TAUn[k+1] = (k + 1) * sixs_sos.cgaus[j] * PIn[k + 1] - (k + 2) * PIn[k];
-		/* --- Computation of the scattering intensity efficiency */
-		p11[j] = 2 * (RS1 *RS1 + IS1 * IS1 + RS2 * RS2 + IS2 * IS2)/X/X;
+	/* --- Computation of the scattering intensity efficiency */
+	p11[j] = 2 * (RS1 *RS1 + IS1 * IS1 + RS2 * RS2 + IS2 * IS2)/X/X;
 /* load parameters from .mie file */
 void AerosolModel::load()
-	int i;
-	ifstream in(filename.c_str());
-	cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore this line */
+    int i;
+    ifstream in(filename.c_str());
+    cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore this line */
-	in.ignore(8);
-	for(i = 0; i < 10; i++)
-		in.ignore(3);
-		in >> sixs_aer.ext[i];
-		in.ignore(6);
-		in >> sca[i];
-		in.ignore(6);
-		in >> sixs_aer.ome[i];
-		in.ignore(6);
-		in >> sixs_aer.gasym[i];
-		in.ignore(3);
-		cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore the rest */
+    in.ignore(8);
+    for(i = 0; i < 10; i++)
+	in.ignore(3);
+	in >> sixs_aer.ext[i];
+	in.ignore(6);
+	in >> sca[i];
+	in.ignore(6);
+	in >> sixs_aer.ome[i];
+	in.ignore(6);
+	in >> sixs_aer.gasym[i];
+	in.ignore(3);
+	cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore the rest */
-	/* ignore 3 lines */
+    /* ignore 3 lines */
-	for(i = 0; i < 83; i++)
+    for(i = 0; i < 83; i++)
+	in.ignore(8);
-		in.ignore(8);
-			in.ignore(1);
-			in >> sixs_sos.phasel[j][i];
+	    in.ignore(1);
+	    in >> sixs_sos.phasel[j][i];
 /* do we wish to save this? */
 void AerosolModel::save()
-	ofstream out(filename.c_str());
-	/* output header */
-	out << "   Wlgth  Nor_Ext_Co  Nor_Sca_Co  Sg_Sca_Alb  Asymm_Para  Extinct_Co  Scatter_Co" << endl;
+    ofstream out(filename.c_str());
+    /* output header */
+    out << "   Wlgth  Nor_Ext_Co  Nor_Sca_Co  Sg_Sca_Alb  Asymm_Para  Extinct_Co  Scatter_Co" << endl;
     int i;
-		out << setprecision(4); /* set the required precision */
-		out << "  " << setw(10) << sixs_disc.wldis[0]
-			<< "   " << setw(10) << sixs_aer.ext[i]
-			<< "      " << setw(10) << sca[i]
-			<< "      " << setw(10) << sixs_aer.ome[i]
-			<< "      " << setw(10) << sixs_aer.gasym[i]
-			<< "      " << setw(10) << sixs_aer.ext[i]/nis
-			<< "      " << setw(10) << sca[i]/nis << endl;
+	out << setprecision(4); /* set the required precision */
+	out << "  " << setw(10) << sixs_disc.wldis[0]
+	    << "   " << setw(10) << sixs_aer.ext[i]
+	    << "      " << setw(10) << sca[i]
+	    << "      " << setw(10) << sixs_aer.ome[i]
+	    << "      " << setw(10) << sixs_aer.gasym[i]
+	    << "      " << setw(10) << sixs_aer.ext[i]/nis
+	    << "      " << setw(10) << sca[i]/nis << endl;
-	out << endl << endl << setw(20) << " " << " Phase Function " << endl;
-	out << "   TETA ";
-	for(i = 0; i < 10; i++) out << "   " << setw(10) << sixs_disc.wldis[i] << "  ";
-	out << endl;
+    out << endl << endl << setw(20) << " " << " Phase Function " << endl;
+    out << "   TETA ";
+    for(i = 0; i < 10; i++) out << "   " << setw(10) << sixs_disc.wldis[i] << "  ";
+    out << endl;
-		out << setprecision(2);
-		out << "  " << setw(8) << (180.*acos(sixs_sos.cgaus[i])/M_PI);
+	out << setprecision(2);
+	out << "  " << setw(8) << (180.*acos(sixs_sos.cgaus[i])/M_PI);
-		out.setf(ios::scientific, ios::floatfield);
-		for(int j = 0; j < 10; j++) out << " " << setw(14) << sixs_sos.phasel[j][i];
-		out.setf(ios::fixed, ios::floatfield);
-		out << endl;
+	out.setf(ios::scientific, ios::floatfield);
+	for(int j = 0; j < 10; j++) out << " " << setw(14) << sixs_sos.phasel[j][i];
+	out.setf(ios::fixed, ios::floatfield);
+	out << endl;
-To compute the optical scattering parameters (extinction and scattering
-coefficients, single scattering albedo, phase function, assymetry factor) at the ten discrete
-wavelengths for the selected model (or created model) from:
-(1) the characteristics of the basic components of the International Radiation Commission.
-(1983).
-	 dust-like component (D.L., SUBROUTINE DUST)
-	 oceanic component (O.C., SUBROUTINE OCEA)
-	 water-soluble component (W.S., SUBROUTINE WATE)
-	 soot component (S.O., SUBROUTINE SOOT)
-(2) pre-computed caracteristics,
-now available are the desertic aerosol model corresponding to background conditions, as
-described in Shettle(1984), a stratospheric aerosol model as measured Mona Loa (Hawaii)
-during El Chichon eruption and as described by King et al. (1984), and a biomass burning
-aerosol model as deduced from measurements taken by sunphotometers in Amazonia.
-(SUBROUTINES BDM, STM and BBM)
-(3) computed using the MIE theory with inputs (size distribution, refractive indexes...) given
-by the user (see SUBROUTINES MIE and EXSCPHASE).
-These models don't correspond to a mixture of the four basic components.
+  To compute the optical scattering parameters (extinction and scattering
+  coefficients, single scattering albedo, phase function, assymetry factor) at the ten discrete
+  wavelengths for the selected model (or created model) from:
+  (1) the characteristics of the basic components of the International Radiation Commission.
+  (1983).
+  dust-like component (D.L., SUBROUTINE DUST)
+  oceanic component (O.C., SUBROUTINE OCEA)
+  water-soluble component (W.S., SUBROUTINE WATE)
+  soot component (S.O., SUBROUTINE SOOT)
+  (2) pre-computed caracteristics,
+  now available are the desertic aerosol model corresponding to background conditions, as
+  described in Shettle(1984), a stratospheric aerosol model as measured Mona Loa (Hawaii)
+  during El Chichon eruption and as described by King et al. (1984), and a biomass burning
+  aerosol model as deduced from measurements taken by sunphotometers in Amazonia.
+  (SUBROUTINES BDM, STM and BBM)
+  (3) computed using the MIE theory with inputs (size distribution, refractive indexes...) given
+  by the user (see SUBROUTINES MIE and EXSCPHASE).
+  These models don't correspond to a mixture of the four basic components.
 void AerosolModel::aeroso(const float xmud)
@@ -502,665 +502,665 @@
 /*     water-soluble = 2 */
 /*     oceanique = 3 */
 /*     soot = 4 */
-	static const double vi[4] = { 113.983516, 1.13983516e-4, 5.1444150196, 5.977353425e-5 };
-	static const double ni[4] = { 54.734, 1868550., 276.05, 1805820. };
+    static const double vi[4] = { 113.983516, 1.13983516e-4, 5.1444150196, 5.977353425e-5 };
+    static const double ni[4] = { 54.734, 1868550., 276.05, 1805820. };
-	/* i: 1=dust-like 2=water-soluble 3=oceanic 4=soot */
-	static const float s_ex[4][10] =
+    /* i: 1=dust-like 2=water-soluble 3=oceanic 4=soot */
+    static const float s_ex[4][10] =
-		{0.1796674e-01,0.1815135e-01,0.1820247e-01,0.1827016e-01,0.1842182e-01,
-		 0.1853081e-01,0.1881427e-01,0.1974608e-01,0.1910712e-01,0.1876025e-01},
-		{0.7653460e-06,0.6158538e-06,0.5793444e-06,0.5351736e-06,0.4480091e-06,
-		 0.3971033e-06,0.2900993e-06,0.1161433e-06,0.3975192e-07,0.1338443e-07},
-		{0.3499458e-02,0.3574996e-02,0.3596592e-02,0.3622467e-02,0.3676341e-02,
-		 0.3708866e-02,0.3770822e-02,0.3692255e-02,0.3267943e-02,0.2801670e-02},
-		{0.8609083e-06,0.6590103e-06,0.6145787e-06,0.5537643e-06,0.4503008e-06,
-		 0.3966041e-06,0.2965532e-06,0.1493927e-06,0.1017134e-06,0.6065031e-07}
+	    {0.1796674e-01,0.1815135e-01,0.1820247e-01,0.1827016e-01,0.1842182e-01,
+	     0.1853081e-01,0.1881427e-01,0.1974608e-01,0.1910712e-01,0.1876025e-01},
+	    {0.7653460e-06,0.6158538e-06,0.5793444e-06,0.5351736e-06,0.4480091e-06,
+	     0.3971033e-06,0.2900993e-06,0.1161433e-06,0.3975192e-07,0.1338443e-07},
+	    {0.3499458e-02,0.3574996e-02,0.3596592e-02,0.3622467e-02,0.3676341e-02,
+	     0.3708866e-02,0.3770822e-02,0.3692255e-02,0.3267943e-02,0.2801670e-02},
+	    {0.8609083e-06,0.6590103e-06,0.6145787e-06,0.5537643e-06,0.4503008e-06,
+	     0.3966041e-06,0.2965532e-06,0.1493927e-06,0.1017134e-06,0.6065031e-07}
-	static const float s_sc[4][10] =
+    static const float s_sc[4][10] =
-		{0.1126647e-01,0.1168918e-01,0.1180978e-01,0.1196792e-01,0.1232056e-01,
-		 0.1256952e-01,0.1319347e-01,0.1520712e-01,0.1531952e-01,0.1546761e-01},
-		{0.7377123e-06,0.5939413e-06,0.5587120e-06,0.5125148e-06,0.4289210e-06,
-		 0.3772760e-06,0.2648252e-06,0.9331806e-07,0.3345499e-07,0.1201109e-07},
-		{0.3499455e-02,0.3574993e-02,0.3596591e-02,0.3622465e-02,0.3676338e-02,
-		 0.3708858e-02,0.3770696e-02,0.3677038e-02,0.3233194e-02,0.2728013e-02},
-		{0.2299196e-06,0.1519321e-06,0.1350890e-06,0.1155423e-06,0.8200095e-07,
-		 0.6469735e-07,0.3610638e-07,0.6227224e-08,0.1779378e-08,0.3050002e-09}
+	    {0.1126647e-01,0.1168918e-01,0.1180978e-01,0.1196792e-01,0.1232056e-01,
+	     0.1256952e-01,0.1319347e-01,0.1520712e-01,0.1531952e-01,0.1546761e-01},
+	    {0.7377123e-06,0.5939413e-06,0.5587120e-06,0.5125148e-06,0.4289210e-06,
+	     0.3772760e-06,0.2648252e-06,0.9331806e-07,0.3345499e-07,0.1201109e-07},
+	    {0.3499455e-02,0.3574993e-02,0.3596591e-02,0.3622465e-02,0.3676338e-02,
+	     0.3708858e-02,0.3770696e-02,0.3677038e-02,0.3233194e-02,0.2728013e-02},
+	    {0.2299196e-06,0.1519321e-06,0.1350890e-06,0.1155423e-06,0.8200095e-07,
+	     0.6469735e-07,0.3610638e-07,0.6227224e-08,0.1779378e-08,0.3050002e-09}
-	static const float ex2[10] =
+    static const float ex2[10] =
-		43.83631f, 42.12415f, 41.57425f, 40.85399f, 39.1404f,
-		37.89763f, 34.67506f, 24.59f, 17.96726f, 10.57569f
+	    43.83631f, 42.12415f, 41.57425f, 40.85399f, 39.1404f,
+	    37.89763f, 34.67506f, 24.59f, 17.96726f, 10.57569f
-	static const float sc2[10] =
+    static const float sc2[10] =
-		40.28625f, 39.04473f, 38.6147f, 38.03645f, 36.61054f,
-		35.54456f, 32.69951f, 23.41019f, 17.15375f,10.09731f
+	    40.28625f, 39.04473f, 38.6147f, 38.03645f, 36.61054f,
+	    35.54456f, 32.69951f, 23.41019f, 17.15375f,10.09731f
-	static const float ex3[10] =
+    static const float ex3[10] =
-		95397.86f, 75303.6f, 70210.64f, 64218.28f, 52430.56f,
-		45577.68f, 31937.77f, 9637.68f, 3610.691f, 810.5614f
+	    95397.86f, 75303.6f, 70210.64f, 64218.28f, 52430.56f,
+	    45577.68f, 31937.77f, 9637.68f, 3610.691f, 810.5614f
-	static const float sc3[10] =
+    static const float sc3[10] =
-		92977.9f, 73397.17f, 68425.49f,	62571.8f, 51049.87f,
-		44348.77f, 31006.21f, 9202.678f, 3344.476f,	664.1915f
+	    92977.9f, 73397.17f, 68425.49f,	62571.8f, 51049.87f,
+	    44348.77f, 31006.21f, 9202.678f, 3344.476f,	664.1915f
-	static const float ex4[10] =
+    static const float ex4[10] =
-		54273040.f, 61981440.f, 63024320.f, 63489470.f, 61467600.f,
-		58179720.f, 46689090.f, 15190620.f, 5133055.f, 899859.4f
+	    54273040.f, 61981440.f, 63024320.f, 63489470.f, 61467600.f,
+	    58179720.f, 46689090.f, 15190620.f, 5133055.f, 899859.4f
-	static const float sc4[10] =
+    static const float sc4[10] =
-	static const float s_asy[4][10] =
+    static const float s_asy[4][10] =
-		{0.896,0.885,0.880,0.877,0.867,0.860,0.845,0.836,0.905,0.871},
-		{0.642,0.633,0.631,0.628,0.621,0.616,0.610,0.572,0.562,0.495},
-		{0.795,0.790,0.788,0.781,0.783,0.782,0.778,0.783,0.797,0.750},
-		{0.397,0.359,0.348,0.337,0.311,0.294,0.253,0.154,0.103,0.055}
+	    {0.896,0.885,0.880,0.877,0.867,0.860,0.845,0.836,0.905,0.871},
+	    {0.642,0.633,0.631,0.628,0.621,0.616,0.610,0.572,0.562,0.495},
+	    {0.795,0.790,0.788,0.781,0.783,0.782,0.778,0.783,0.797,0.750},
+	    {0.397,0.359,0.348,0.337,0.311,0.294,0.253,0.154,0.103,0.055}
-	static const float asy2[10] = { .718f, .712f, .71f, .708f, .704f, .702f, .696f, .68f, .668f, .649f };
+    static const float asy2[10] = { .718f, .712f, .71f, .708f, .704f, .702f, .696f, .68f, .668f, .649f };
-	static const float asy3[10] = { .704f, .69f, .686f, .68f, .667f, .659f, .637f, .541f, .437f, .241f };
-	static const float asy4[10] = { .705f, .744f, .751f, .757f, .762f, .759f, .737f, .586f, .372f, .139f };
+    static const float asy3[10] = { .704f, .69f, .686f, .68f, .667f, .659f, .637f, .541f, .437f, .241f };
+    static const float asy4[10] = { .705f, .744f, .751f, .757f, .762f, .759f, .737f, .586f, .372f, .139f };
-	/* local */
-	double coef;
-	float sigm;
-	double sumni;
-	double dd[4][10];
-	double pha[5][10][83];
+    /* local */
+    double coef;
+    float sigm;
+    double sumni;
+    double dd[4][10];
+    double pha[5][10][83];
-	float ex[4][10];
-	float sc[4][10];
-	float asy[4][10];
+    float ex[4][10];
+    float sc[4][10];
+    float asy[4][10];
-	int i;	/* crappy VS6 */
-	/* initialize ex, sc & asy */
-	for(i = 0; i < 4; i++)
-		int j;
-		for(j = 0; j < 10; j++) ex[i][j] = s_ex[i][j];
-		for(j = 0; j < 10; j++) sc[i][j] = s_sc[i][j];
-		for(j = 0; j < 10; j++) asy[i][j] = s_asy[i][j];
+    int i;	/* crappy VS6 */
+    /* initialize ex, sc & asy */
+    for(i = 0; i < 4; i++)
+	int j;
+	for(j = 0; j < 10; j++) ex[i][j] = s_ex[i][j];
+	for(j = 0; j < 10; j++) sc[i][j] = s_sc[i][j];
+	for(j = 0; j < 10; j++) asy[i][j] = s_asy[i][j];
-	/* optical properties of aerosol model computed from sra basic comp */
-	for (i = 0; i < 10; ++i)
-		if(i == 4 && iaer == 0) sixs_aer.ext[i] = 1.f;
-		else sixs_aer.ext[i] = 0.f;
-		sca[i] = 0.f;
-		sixs_aer.ome[i] = 0.f;
-		sixs_aer.gasym[i] = 0.f;
-		sixs_aer.phase[i] = 0.f;
+    /* optical properties of aerosol model computed from sra basic comp */
+    for (i = 0; i < 10; ++i)
+	if(i == 4 && iaer == 0) sixs_aer.ext[i] = 1.f;
+	else sixs_aer.ext[i] = 0.f;
+	sca[i] = 0.f;
+	sixs_aer.ome[i] = 0.f;
+	sixs_aer.gasym[i] = 0.f;
+	sixs_aer.phase[i] = 0.f;
-		for (int k = 1; k <= 83; ++k) sixs_sos.phasel[i][k] = 0.f;
+	for (int k = 1; k <= 83; ++k) sixs_sos.phasel[i][k] = 0.f;
-	/* return if iear = 0 */
+    /* return if iear = 0 */
-	/* look for an interval in cgaus */
-	long int j1 = -1;
-	for (i = 0; i < 82; ++i)
-		if (xmud >= sixs_sos.cgaus[i] && xmud < sixs_sos.cgaus[i+1])  {  j1 = i; break; }
-	if(j1 == -1) return; /* unable to find interval */
+    /* look for an interval in cgaus */
+    long int j1 = -1;
+    for (i = 0; i < 82; ++i)
+	if (xmud >= sixs_sos.cgaus[i] && xmud < sixs_sos.cgaus[i+1])  {  j1 = i; break; }
+    if(j1 == -1) return; /* unable to find interval */
-	coef = -(xmud - sixs_sos.cgaus[j1]) / (sixs_sos.cgaus[j1+1] - sixs_sos.cgaus[j1]);
+    coef = -(xmud - sixs_sos.cgaus[j1]) / (sixs_sos.cgaus[j1+1] - sixs_sos.cgaus[j1]);
-	switch(iaer)
+    switch(iaer)
+    case 12: /* read from file */
+	load();
+	    sixs_aer.phase[i] = (float)(sixs_sos.phasel[i][j1] +
+					coef*(sixs_sos.phasel[i][j1]-sixs_sos.phasel[i][j1+1]));
+	return;
+    case 5:
-	case 12: /* read from file */
-			load();
-				sixs_aer.phase[i] = (float)(sixs_sos.phasel[i][j1] +
-								coef*(sixs_sos.phasel[i][j1]-sixs_sos.phasel[i][j1+1]));
-			return;
-	case 5:
-				asy[0][i]	= asy2[i];
-				ex[0][i]	= ex2[i];
-				sc[0][i]	= sc2[i];
-			break;
-	case 6:
-				asy[0][i]	= asy3[i];
-				ex[0][i]	= ex3[i];
-				sc[0][i]	= sc3[i];
-			break;
-	case 7:
-				asy[0][i]	= asy4[i];
-				ex[0][i]	= ex4[i];
-				sc[0][i]	= sc4[i];
-			break;
-	default:;
+	    asy[0][i]	= asy2[i];
+	    ex[0][i]	= ex2[i];
+	    sc[0][i]	= sc2[i];
+	break;
+    case 6:
+	    asy[0][i]	= asy3[i];
+	    ex[0][i]	= ex3[i];
+	    sc[0][i]	= sc3[i];
+	break;
+    case 7:
+	    asy[0][i]	= asy4[i];
+	    ex[0][i]	= ex4[i];
+	    sc[0][i]	= sc4[i];
+	break;
+    default:;
-	if(iaer >= 5 && iaer <= 11)
+    if(iaer >= 5 && iaer <= 11)
+	/* calling a special aerosol model */
+	switch(iaer)
-		/* calling a special aerosol model */
+	    /* (background desert model...) */
+	case 5: bdm(); break;
+	    /* (biomass burning model...) */
+	case 6: bbm(); break;
+	    /* (stratospherique aerosol model...) */
+	case 7: stm(); break;
-		switch(iaer)
-		/* (background desert model...) */
-		case 5: bdm(); break;
-		/* (biomass burning model...) */
-		case 6: bbm(); break;
-		/* (stratospherique aerosol model...) */
-		case 7: stm(); break;
+	    /* (user defined model from size distribution) */
+	case 8:
+	case 9:
+	case 10:
+	case 11: mie (ex, sc, asy); break;
-		/* (user defined model from size distribution) */
-		case 8:
-		case 9:
-		case 10:
-		case 11: mie (ex, sc, asy); break;
+	for (int i = 0; i < 10; i++)
+	    dd[0][i] = (*sixs_aerbas.ph)[i][j1] + coef * ((*sixs_aerbas.ph)[i][j1] - (*sixs_aerbas.ph)[i][j1+1]);
+	    for(int k = 0; k < 83; k++) pha[0][i][k] = (*sixs_aerbas.ph)[i][k];
-		for (int i = 0; i < 10; i++)
-			dd[0][i] = (*sixs_aerbas.ph)[i][j1] + coef * ((*sixs_aerbas.ph)[i][j1] - (*sixs_aerbas.ph)[i][j1+1]);
-			for(int k = 0; k < 83; k++) pha[0][i][k] = (*sixs_aerbas.ph)[i][k];
+	mie_in.icp = 1;
+	mie_in.cij[0] = 1.f;
+	/* for normalization of the extinction coefficient */
+	nis = 1. / ex[0][3];
+    else {
+	/* calling each sra components */
+	mie_in.icp = 4;
+	/*  -dust */
+	dust();
+	    for(int k = 0; k < 83; k++) pha[0][i][k] = ((*sixs_aerbas.ph))[i][k];
-		mie_in.icp = 1;
-		mie_in.cij[0] = 1.f;
-		/* for normalization of the extinction coefficient */
-		nis = 1. / ex[0][3];
-	else {
-		/* calling each sra components */
-		mie_in.icp = 4;
-		/*  -dust */
-		dust();
-			for(int k = 0; k < 83; k++) pha[0][i][k] = ((*sixs_aerbas.ph))[i][k];
+	/* -water soluble */
+	wate();
+	    dd[1][i] = (*sixs_aerbas.ph)[i][j1]+coef*((*sixs_aerbas.ph)[i][j1]-(*sixs_aerbas.ph)[i][j1+1]);
+	    for(int k = 0; k < 83; k++) pha[1][i][k] = (*sixs_aerbas.ph)[i][k];
-		/* -water soluble */
-		wate();
-			dd[1][i] = (*sixs_aerbas.ph)[i][j1]+coef*((*sixs_aerbas.ph)[i][j1]-(*sixs_aerbas.ph)[i][j1+1]);
-			for(int k = 0; k < 83; k++) pha[1][i][k] = (*sixs_aerbas.ph)[i][k];
-		/* -oceanic type */
-		ocea();
-			dd[2][i] = (*sixs_aerbas.ph)[i][j1]+coef*((*sixs_aerbas.ph)[i][j1]-(*sixs_aerbas.ph)[i][j1+1]);
-			for(int k = 0; k < 83; k++) pha[2][i][k] = (*sixs_aerbas.ph)[i][k];
+	/* -oceanic type */
+	ocea();
+	    dd[2][i] = (*sixs_aerbas.ph)[i][j1]+coef*((*sixs_aerbas.ph)[i][j1]-(*sixs_aerbas.ph)[i][j1+1]);
+	    for(int k = 0; k < 83; k++) pha[2][i][k] = (*sixs_aerbas.ph)[i][k];
-		/* -soot */
-		soot();
-			dd[3][i] = (*sixs_aerbas.ph)[i][j1]+coef*((*sixs_aerbas.ph)[i][j1]-(*sixs_aerbas.ph)[i][j1+1]);
-			for(int k = 0; k < 83; k++) pha[3][i][k] = (*sixs_aerbas.ph)[i][k];
+	/* -soot */
+	soot();
+	    dd[3][i] = (*sixs_aerbas.ph)[i][j1]+coef*((*sixs_aerbas.ph)[i][j1]-(*sixs_aerbas.ph)[i][j1+1]);
+	    for(int k = 0; k < 83; k++) pha[3][i][k] = (*sixs_aerbas.ph)[i][k];
-		/* summ of the c/vi calculation */
-		sumni = 0.f;
-		sigm = 0.f;
+	/* summ of the c/vi calculation */
+	sumni = 0.f;
+	sigm = 0.f;
-		for(i = 0; i < 4; i++) sigm+=(float)(c[i]/vi[i]);
+	for(i = 0; i < 4; i++) sigm+=(float)(c[i]/vi[i]);
-		/* cij coefficients calculation */
-		for(i = 0; i < 4; i++) {
-			mie_in.cij[i] = (float)(c[i]/vi[i]/sigm);
-			sumni += mie_in.cij[i]/ni[i];
-	    nis = 1. / sumni;
+	/* cij coefficients calculation */
+	for(i = 0; i < 4; i++) {
+	    mie_in.cij[i] = (float)(c[i]/vi[i]/sigm);
+	    sumni += mie_in.cij[i]/ni[i];
+	nis = 1. / sumni;
-	/*     mixing parameters calculation */
+    /*     mixing parameters calculation */
+	for(int j = 0; j < mie_in.icp; j++)
-		for(int j = 0; j < mie_in.icp; j++)
-			sixs_aer.ext[i] +=		(float)(ex[j][i] * mie_in.cij[j]);
-			sca[i] +=				(float)(sc[j][i] * mie_in.cij[j]);
-			sixs_aer.gasym[i] +=	(float)(sc[j][i] * mie_in.cij[j] * asy[j][i]);
-			sixs_aer.phase[i] +=	(float)(sc[j][i] * mie_in.cij[j] * dd[j][i]);
+	    sixs_aer.ext[i] +=		(float)(ex[j][i] * mie_in.cij[j]);
+	    sca[i] +=				(float)(sc[j][i] * mie_in.cij[j]);
+	    sixs_aer.gasym[i] +=	(float)(sc[j][i] * mie_in.cij[j] * asy[j][i]);
+	    sixs_aer.phase[i] +=	(float)(sc[j][i] * mie_in.cij[j] * dd[j][i]);
-				sixs_sos.phasel[i][k] += (float)(sc[j][i] * mie_in.cij[j] * pha[j][i][k]);
+		sixs_sos.phasel[i][k] += (float)(sc[j][i] * mie_in.cij[j] * pha[j][i][k]);
-		sixs_aer.ome[i] = sca[i]/sixs_aer.ext[i];
-		sixs_aer.gasym[i] /= sca[i];
-		sixs_aer.phase[i] /= sca[i];
+	sixs_aer.ome[i] = sca[i]/sixs_aer.ext[i];
+	sixs_aer.gasym[i] /= sca[i];
+	sixs_aer.phase[i] /= sca[i];
-		for(int k = 0; k < 83; k++)	sixs_sos.phasel[i][k] /= sca[i];
+	for(int k = 0; k < 83; k++)	sixs_sos.phasel[i][k] /= sca[i];
-		sixs_aer.ext[i] *= (float)nis;
-		sca[i] *= (float)nis;
+	sixs_aer.ext[i] *= (float)nis;
+	sca[i] *= (float)nis;
-	if (filename.size() != 0 && iaer >= 8 && iaer <= 11) save();
+    if (filename.size() != 0 && iaer >= 8 && iaer <= 11) save();
 void AerosolModel::parse(const float xmud)
-	cin >> iaer;
+    cin >> iaer;
-	/* initialize vars; */
-	mie_in.rmin = 0.f;
-	mie_in.rmax = 0.f;
-	mie_in.icp = 1;
+    /* initialize vars; */
+    mie_in.rmin = 0.f;
+    mie_in.rmax = 0.f;
+    mie_in.icp = 1;
-	int i;
-		mie_in.cij[i] = 0.f;
+    int i;
+	mie_in.cij[i] = 0.f;
-		mie_in.x1[i] = 0.f;
-		mie_in.x2[i] = 0.f;
-		mie_in.x3[i] = 0.f;
+	mie_in.x1[i] = 0.f;
+	mie_in.x2[i] = 0.f;
+	mie_in.x3[i] = 0.f;
-			mie_in.rn[j][i] = 0.f;
-			mie_in.ri[j][i] = 0.f;
+	    mie_in.rn[j][i] = 0.f;
+	    mie_in.ri[j][i] = 0.f;
-	for(i = 0; i < 50; i++)
-		mie_in.rsunph[i]	= 0.f;
-		mie_in.nrsunph[i] = 0.f;
+    for(i = 0; i < 50; i++)
+	mie_in.rsunph[i]	= 0.f;
+	mie_in.nrsunph[i] = 0.f;
     mie_in.cij[0] = 1.00f;
-	switch (iaer)
-	case 0:
-	case 5:
-	case 6:
-	case 7: break;		/* do nothing */
+    switch (iaer)
+    case 0:
+    case 5:
+    case 6:
+    case 7: break;		/* do nothing */
-	case 1:
-			c[0]=0.70f;
-		    c[1]=0.29f;
-			c[2]=0.00f;
-		    c[3]=0.01f;
-			break;
-	case 2:
-			c[0]=0.00f;
-		    c[1]=0.05f;
-			c[2]=0.95f;
-		    c[3]=0.00f;
-			break;
-	case 3:
-			c[0]=0.17f;
-			c[1]=0.61f;
-			c[2]=0.00f;
-			c[3]=0.22f;
-			break;
-	case 4:
-			for(int i = 0; i < 4; i++) cin >> c[i];
-			break;
-	case 8:
-			cin >> mie_in.rmin;
-			cin >> mie_in.rmax;
-			cin >> mie_in.icp;
+    case 1:
+	c[0]=0.70f;
+	c[1]=0.29f;
+	c[2]=0.00f;
+	c[3]=0.01f;
+	break;
+    case 2:
+	c[0]=0.00f;
+	c[1]=0.05f;
+	c[2]=0.95f;
+	c[3]=0.00f;
+	break;
+    case 3:
+	c[0]=0.17f;
+	c[1]=0.61f;
+	c[2]=0.00f;
+	c[3]=0.22f;
+	break;
+    case 4:
+	for(int i = 0; i < 4; i++) cin >> c[i];
+	break;
+    case 8:
+	cin >> mie_in.rmin;
+	cin >> mie_in.rmax;
+	cin >> mie_in.icp;
-			if(mie_in.icp >= 4) {
-				fprintf(stderr, "mie_in.icp: %ld > 4, will cause internal buffer overflow.\n", mie_in.icp);
-				exit(-1);
+	if(mie_in.icp >= 4) {
+	    fprintf(stderr, "mie_in.icp: %ld > 4, will cause internal buffer overflow.\n", mie_in.icp);
+	    exit(-1);
-				cin >> mie_in.x1[i];
-				cin >> mie_in.x2[i];
-				cin >> mie_in.cij[i];
+	    cin >> mie_in.x1[i];
+	    cin >> mie_in.x2[i];
+	    cin >> mie_in.cij[i];
-				int j;
-				for(j = 0; j < 10; j++) cin >> mie_in.rn[j][i];
+	    int j;
+	    for(j = 0; j < 10; j++) cin >> mie_in.rn[j][i];
-				for(j = 0; j < 10; j++) cin >> mie_in.ri[j][i];
-			break;
-	case 9:
+	    for(j = 0; j < 10; j++) cin >> mie_in.ri[j][i];
+	break;
+    case 9:
-			cin >> mie_in.x1[0];
-			cin >> mie_in.x2[0];
-			cin >> mie_in.x3[0];
+	cin >> mie_in.x1[0];
+	cin >> mie_in.x2[0];
+	cin >> mie_in.x3[0];
-			int j;
-			for(j = 0; j < 10; j++) cin >> mie_in.rn[j][0];
+	int j;
+	for(j = 0; j < 10; j++) cin >> mie_in.rn[j][0];
-			for(j = 0; j < 10; j++) cin >> mie_in.ri[j][0];
+	for(j = 0; j < 10; j++) cin >> mie_in.ri[j][0];
-			break;
-	case 10:
+	break;
+    case 10:
-			int j;
+	int j;
-			break;
-	case 11:
-			cin >> mie_in.irsunph;
+	break;
+    case 11:
+	cin >> mie_in.irsunph;
-			if(mie_in.irsunph >= 50) {
-				fprintf(stderr, "mie_in.irsunph: %ld > 50, will cause internal buffer overflow.\n", mie_in.irsunph);
-				exit(-1);
+	if(mie_in.irsunph >= 50) {
+	    fprintf(stderr, "mie_in.irsunph: %ld > 50, will cause internal buffer overflow.\n", mie_in.irsunph);
+	    exit(-1);
-			int i;
-			for(i = 0; i < mie_in.irsunph; i++)
-				cin >> mie_in.rsunph[i];
-				cin >> mie_in.nrsunph[i];
+	int i;
+	for(i = 0; i < mie_in.irsunph; i++)
+	    cin >> mie_in.rsunph[i];
+	    cin >> mie_in.nrsunph[i];
-				double sq = mie_in.rsunph[i]*mie_in.rsunph[i];
-				mie_in.nrsunph[i] = (float)(mie_in.nrsunph[i]/(sq*sq)/ln10);
-			mie_in.rmin=mie_in.rsunph[0];
-			mie_in.rmax=mie_in.rsunph[mie_in.irsunph-1]+1e-07f;
+	    double sq = mie_in.rsunph[i]*mie_in.rsunph[i];
+	    mie_in.nrsunph[i] = (float)(mie_in.nrsunph[i]/(sq*sq)/ln10);
+	mie_in.rmin=mie_in.rsunph[0];
+	mie_in.rmax=mie_in.rsunph[mie_in.irsunph-1]+1e-07f;
-			for(i = 0; i < 10; i++) cin >> mie_in.rn[i][0];
+	for(i = 0; i < 10; i++) cin >> mie_in.rn[i][0];
-			for(i = 0; i < 10; i++) cin >> mie_in.ri[i][0];
-			break;
-	case 12:
-		{	/* read file name */
-			getline(cin,filename);
-			filename = filename.substr(0, filename.find(" "));
-			break;
-	default: fprintf(stderr, "Unknown aerosol model!\n");
+	for(i = 0; i < 10; i++) cin >> mie_in.ri[i][0];
+	break;
+    case 12:
+    {	/* read file name */
+	getline(cin,filename);
+	filename = filename.substr(0, filename.find(" "));
+	break;
+    default: fprintf(stderr, "Unknown aerosol model!\n");
-	if(iaer >= 8 && iaer <= 11)
+    if(iaer >= 8 && iaer <= 11)
+	cin >> iaerp;
+	if( iaerp == 1 ) /* read file name */
-		cin >> iaerp;
-		if( iaerp == 1 ) /* read file name */
-			filename += ".mie";
+	    filename += ".mie";
-	aeroso(xmud);
+    aeroso(xmud);
 /* format 132 */
 void AerosolModel::print132(string s)
-	Output::Begin();
-	Output::Print(s);
-	Output::Print(" aerosols model");
-	Output::End();
+    Output::Begin();
+    Output::Print(s);
+    Output::Print(" aerosols model");
+    Output::End();
 /* --- aerosols model ---- */
 void AerosolModel::print()
-	/* --- aerosols model (type) ---- */
+    /* --- aerosols model (type) ---- */
+    Output::Begin();
+    Output::Print(" aerosols type identity :");
+    Output::End();
+    if(iaer == 4 || (iaer >= 8 && iaer != 11))
 	Output::Begin();
-	Output::Print(" aerosols type identity :");
+	Output::Print(" user defined aerosols model ");
 	Output::End();
-	if(iaer == 4 || (iaer >= 8 && iaer != 11))
+    switch(iaer)
+    case 0:
+	Output::Begin();
+	Output::Print(" no aerosols computed   ");
+	Output::End();
+	break;
+    case 1: print132("    Continental"); break;
+    case 2: print132("       Maritime"); break;
+    case 3: print132("          Urban"); break;
+    case 4:
+	static const string desc[4] = {
+	    string(" % of dust-like"),
+	    string(" % of water-soluble"),
+	    string(" % of oceanic"),
+	    string(" % of soot")
-		Output::Begin();
-		Output::Print(" user defined aerosols model ");
-		Output::End();
+	    Output::Begin();
+	    Output::Repeat(26, ' ');
+	    ostringstream s;
+	    s << setprecision(3);
+	    s << c[i] << desc[i] << ends;
+	    Output::End();
+	break;
+    case 5: print132("       Desertic"); break;
+    case 6: print132("          Smoke"); break;
+    case 7: print132("  Stratospheric"); break;
+    case 8:
+	Output::Begin();
+	ostringstream s;
+	s << "using " << mie_in.icp << " Log-normal size-distribution(s)" << ends;
+	Output::End();
-	switch(iaer)
+	Output::Begin();
+	Output::Print("Mean radius  Stand. Dev.  Percent. dencity");
+	Output::End();
-	case 0:
-			Output::Begin();
-			Output::Print(" no aerosols computed   ");
-			Output::End();
-			break;
-	case 1: print132("    Continental"); break;
-	case 2: print132("       Maritime"); break;
-	case 3: print132("          Urban"); break;
-	case 4:
-			static const string desc[4] = {
-				string(" % of dust-like"),
-				string(" % of water-soluble"),
-				string(" % of oceanic"),
-				string(" % of soot")
+	    Output::Begin();
+	    Output::Position(41);
+	    ostringstream s1;
+	    s1 << setprecision(4);
+	    s1 << setw(10) << mie_in.x1[i] << ends;
-				Output::Begin();
-				Output::Repeat(26, ' ');
-				ostringstream s;
-				s << setprecision(3);
-				s << c[i] << desc[i] << ends;
-				Output::End();
-			break;
-	case 5: print132("       Desertic"); break;
-	case 6: print132("          Smoke"); break;
-	case 7: print132("  Stratospheric"); break;
-	case 8:
-			Output::Begin();
-			ostringstream s;
-			s << "using " << mie_in.icp << " Log-normal size-distribution(s)" << ends;
-			Output::End();
+	    Output::Position(55);
+	    ostringstream s2;
+	    s2 << setprecision(3);
+	    s2 << setw(8) << mie_in.x2[i] << ends;
-			Output::Begin();
-			Output::Print("Mean radius  Stand. Dev.  Percent. dencity");
-			Output::End();
+	    Output::Position(69);
+	    ostringstream s3;
+	    s3.setf(ios::fixed, ios::floatfield);
+	    s3 << setprecision(3);
+	    s3 << setw(11) << mie_in.cij[i] << ends;
+	    Output::Print(s3.str());
-				Output::Begin();
-				Output::Position(41);
-				ostringstream s1;
-				s1 << setprecision(4);
-				s1 << setw(10) << mie_in.x1[i] << ends;
+	    Output::End();
+	break;
+    case 9:
+	Output::Begin();
+	Output::Print("using a Modified Gamma size-distribution");
+	Output::End();
-				Output::Position(55);
-				ostringstream s2;
-				s2 << setprecision(3);
-				s2 << setw(8) << mie_in.x2[i] << ends;
+	Output::Begin();
+	Output::Repeat(19, ' ');
+	Output::Print("Alpha         b             Gamma");
+	Output::End();
-				Output::Position(69);
-				ostringstream s3;
-				s3.setf(ios::fixed, ios::floatfield);
-				s3 << setprecision(3);
-				s3 << setw(11) << mie_in.cij[i] << ends;
-				Output::Print(s3.str());
+	Output::Begin();
+	Output::Position(20);
+	ostringstream s1;
+	s1 << setprecision(3);
+	s1 << setw(9) << mie_in.x1[0] << ends;
-				Output::End();
-			break;
-	case 9:
-			Output::Begin();
-			Output::Print("using a Modified Gamma size-distribution");
-			Output::End();
+	Output::Position(31);
+	ostringstream s2;
+	s2 << setw(9) << mie_in.x2[0] << ends;
-			Output::Begin();
-			Output::Repeat(19, ' ');
-			Output::Print("Alpha         b             Gamma");
-			Output::End();
+	Output::Position(47);
+	ostringstream s3;
+	s3 << setw(9) << mie_in.x3[0] << ends;
-			Output::Begin();
-			Output::Position(20);
-			ostringstream s1;
-			s1 << setprecision(3);
-			s1 << setw(9) << mie_in.x1[0] << ends;
+	Output::End();
+	break;
+    case 10:
+	Output::Begin();
+	Output::Print("using a Power law size-distribution with alpha=");
+	ostringstream s;
+	s << setprecision(1);
+	s << setw(4) << mie_in.x1[0] << ends;
+	Output::End();
-			Output::Position(31);
-			ostringstream s2;
-			s2 << setw(9) << mie_in.x2[0] << ends;
+	break;
+    case 11: print132(" Sun Photometer"); break;
+    case 12:
+	Output::Begin();
+	Output::Print("using data from the file:");
+	Output::End();
-			Output::Position(47);
-			ostringstream s3;
-			s3 << setw(9) << mie_in.x3[0] << ends;
+	Output::Begin();
+	Output::Position(25);
+	Output::Print(filename);
+	Output::End();
-			Output::End();
-			break;
-	case 10:
-			Output::Begin();
-			Output::Print("using a Power law size-distribution with alpha=");
-			ostringstream s;
-			s << setprecision(1);
-			s << setw(4) << mie_in.x1[0] << ends;
-			Output::End();
+    if(iaer > 7 && iaerp == 1)
+	Output::Begin();
+	Output::Print(" results saved into the file:");
+	Output::End();
-			break;
-	case 11: print132(" Sun Photometer"); break;
-	case 12:
-			Output::Begin();
-			Output::Print("using data from the file:");
-			Output::End();
-			Output::Begin();
-			Output::Position(25);
-			Output::Print(filename);
-			Output::End();
-	if(iaer > 7 && iaerp == 1)
-		Output::Begin();
-		Output::Print(" results saved into the file:");
-		Output::End();
-		Output::Begin();
-		Output::End();
+	Output::Begin();
+	Output::End();
 AerosolModel AerosolModel::Parse(const float xmud)
-	AerosolModel aero;
-	aero.parse(xmud);
-	return aero;
+    AerosolModel aero;
+    aero.parse(xmud);
+    return aero;
Modified: grass/trunk/imagery/i.atcorr/Altitude.cpp
--- grass/trunk/imagery/i.atcorr/Altitude.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/Altitude.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -7,186 +7,186 @@
    is not at sea level.
-	Given the altitude of the target in kilometers as input, we transform the
-	original atmospheric profile (Pressure, Temperature, Water Vapor, Ozone)
-	so that first level of the new profile is the one at the target altitude.
-	We also compute the new integrated content in water vapor and ozone, that
-	are used as outputs or in computations when the user chooses to enter a
-	specific amount of Ozone and Water Vapor.
+   Given the altitude of the target in kilometers as input, we transform the
+   original atmospheric profile (Pressure, Temperature, Water Vapor, Ozone)
+   so that first level of the new profile is the one at the target altitude.
+   We also compute the new integrated content in water vapor and ozone, that
+   are used as outputs or in computations when the user chooses to enter a
+   specific amount of Ozone and Water Vapor.
 void Altitude::pressure(AtmosModel& atms, float& uw, float& uo3)
-	/* log linear interpolation */
-	if(xps >= 100) xps = 99.99f;
+    /* log linear interpolation */
+    if(xps >= 100) xps = 99.99f;
-	int i;
-	for(i = 0; atms.z[i] <= xps; i++);
+    int i;
+    for(i = 0; atms.z[i] <= xps; i++);
-	int isup = i;
-	int iinf = i - 1;
+    int isup = i;
+    int iinf = i - 1;
-	float xa = (float)((atms.z[isup] - atms.z[iinf]) / log(atms.p[isup] / atms.p[iinf]));
-	float xb = (float)(atms.z[isup] - xa * log(atms.p[isup]));
-	float ps = (float)exp((xps - xb) / xa);
+    float xa = (float)((atms.z[isup] - atms.z[iinf]) / log(atms.p[isup] / atms.p[iinf]));
+    float xb = (float)(atms.z[isup] - xa * log(atms.p[isup]));
+    float ps = (float)exp((xps - xb) / xa);
-	/* interpolating temperature wator vapor and ozone profile versus altitude */
-	float xalt = xps;
-	float xtemp = (atms.t[isup] - atms.t[iinf]) / (atms.z[isup] - atms.z[iinf]);
-	xtemp = xtemp * (xalt - atms.z[iinf]) + atms.t[iinf];
-	float xwo = (atms.wo[isup] - atms.wo[iinf]) / (atms.z[isup] - atms.z[iinf]);
-	xwo = xwo * (xalt - atms.z[iinf]) + atms.wo[iinf];
-	float xwh = (atms.wh[isup] - atms.wh[iinf]) / (atms.z[isup] - atms.z[iinf]);
-	xwh = xwh * (xalt - atms.z[iinf]) + atms.wh[iinf];
+    /* interpolating temperature wator vapor and ozone profile versus altitude */
+    float xalt = xps;
+    float xtemp = (atms.t[isup] - atms.t[iinf]) / (atms.z[isup] - atms.z[iinf]);
+    xtemp = xtemp * (xalt - atms.z[iinf]) + atms.t[iinf];
+    float xwo = (atms.wo[isup] - atms.wo[iinf]) / (atms.z[isup] - atms.z[iinf]);
+    xwo = xwo * (xalt - atms.z[iinf]) + atms.wo[iinf];
+    float xwh = (atms.wh[isup] - atms.wh[iinf]) / (atms.z[isup] - atms.z[iinf]);
+    xwh = xwh * (xalt - atms.z[iinf]) + atms.wh[iinf];
-	/* updating atmospheric profile
-	  1rst level: target     , complete to 34
-	  with interpolated layers */
-	atms.z[0] = xalt;
-	atms.p[0] = ps;
-	atms.t[0] = xtemp;
-	atms.wh[0] = xwh;
-	atms.wo[0] = xwo;
+    /* updating atmospheric profile
+       1rst level: target     , complete to 34
+       with interpolated layers */
+    atms.z[0] = xalt;
+    atms.p[0] = ps;
+    atms.t[0] = xtemp;
+    atms.wh[0] = xwh;
+    atms.wo[0] = xwo;
-	for (i = 1; i < 33 - iinf; ++i)
+    for (i = 1; i < 33 - iinf; ++i)
-		atms.z[i] = atms.z[i + iinf];
-		atms.p[i] = atms.p[i + iinf];
-		atms.t[i] = atms.t[i + iinf];
-		atms.wh[i] = atms.wh[i + iinf];
-		atms.wo[i] = atms.wo[i + iinf];
+	atms.z[i] = atms.z[i + iinf];
+	atms.p[i] = atms.p[i + iinf];
+	atms.t[i] = atms.t[i + iinf];
+	atms.wh[i] = atms.wh[i + iinf];
+	atms.wo[i] = atms.wo[i + iinf];
-	int l = 33 - iinf - 1;
-	for (i = l; i < 34; ++i)
+    int l = 33 - iinf - 1;
+    for (i = l; i < 34; ++i)
-      atms.z[i] = (atms.z[33] - atms.z[l]) * (i - l) / (33 - l) + atms.z[l];
-      atms.p[i] = (atms.p[33] - atms.p[l]) * (i - l) / (33 - l) + atms.p[l];
-      atms.t[i] = (atms.t[33] - atms.t[l]) * (i - l) / (33 - l) + atms.t[l];
-      atms.wh[i] = (atms.wh[33] - atms.wh[l]) * (i - l) / (33 - l) + atms.wh[l];
-      atms.wo[i] = (atms.wo[33] - atms.wo[l]) * (i - l) / (33 - l) + atms.wo[l];
+	atms.z[i] = (atms.z[33] - atms.z[l]) * (i - l) / (33 - l) + atms.z[l];
+	atms.p[i] = (atms.p[33] - atms.p[l]) * (i - l) / (33 - l) + atms.p[l];
+	atms.t[i] = (atms.t[33] - atms.t[l]) * (i - l) / (33 - l) + atms.t[l];
+	atms.wh[i] = (atms.wh[33] - atms.wh[l]) * (i - l) / (33 - l) + atms.wh[l];
+	atms.wo[i] = (atms.wo[33] - atms.wo[l]) * (i - l) / (33 - l) + atms.wo[l];
-	/* compute modified h2o and o3 integrated content */
-	uw = 0;
-	uo3 = 0;
-	const float g = 98.1f;
-	const float air = 0.028964f/0.0224f;
-	const float ro3 = 0.048f/0.0224f;
+    /* compute modified h2o and o3 integrated content */
+    uw = 0;
+    uo3 = 0;
+    const float g = 98.1f;
+    const float air = 0.028964f/0.0224f;
+    const float ro3 = 0.048f/0.0224f;
-	float rmwh[34];
-	float rmo3[34];
-	int k;
-	for (k = 0; k < 33; ++k)
+    float rmwh[34];
+    float rmo3[34];
+    int k;
+    for (k = 0; k < 33; ++k)
-		float roair = air * 273.16f * atms.p[k] / (atms.t[k] * 1013.25f);
-		rmwh[k] = atms.wh[k] / (roair * 1e3f);
-		rmo3[k] = atms.wo[k] / (roair * 1e3f);
+	float roair = air * 273.16f * atms.p[k] / (atms.t[k] * 1013.25f);
+	rmwh[k] = atms.wh[k] / (roair * 1e3f);
+	rmo3[k] = atms.wo[k] / (roair * 1e3f);
-	for (k = 1; k < 33; ++k)
+    for (k = 1; k < 33; ++k)
-		float ds = (atms.p[k - 1] - atms.p[k]) / atms.p[0];
-		uw += (rmwh[k] + rmwh[k - 1]) * ds / 2.f;
-		uo3 += (rmo3[k] + rmo3[k - 1]) * ds / 2.f;
+	float ds = (atms.p[k - 1] - atms.p[k]) / atms.p[0];
+	uw += (rmwh[k] + rmwh[k - 1]) * ds / 2.f;
+	uo3 += (rmo3[k] + rmo3[k - 1]) * ds / 2.f;
-	uw = uw * atms.p[0] * 100.f / g;
-	uo3 = uo3 * atms.p[0] * 100.f / g;
-	uo3 = uo3 * 1e3f / ro3;
+    uw = uw * atms.p[0] * 100.f / g;
+    uo3 = uo3 * atms.p[0] * 100.f / g;
+    uo3 = uo3 * 1e3f / ro3;
-Function: Update the atmospheric profile (P(z),T(z),H2O(z),O3(z)) in case the observer is on
-board an aircraft.
+  Function: Update the atmospheric profile (P(z),T(z),H2O(z),O3(z)) in case the observer is on
+  board an aircraft.
-Description: Given the altitude or pressure at aircraft level as input, the first task is to
-compute the altitude (in case the pressure has been entered) or the pressure (in case the altitude has
-been entered) at plane level. Then, a new atmospheric profile is created (Pp,Tp,H2Op,O3p) for which
-the last level is located at the plane altitude. This profile is used in the gaseous absorption
-computation (ABSTRA.f) for the path from target to sensor (upward transmission). The ozone and
-water vapor integrated content of the "plane" atmospheric profile are also an output of this
-subroutine. The last output is the proportion of molecules below plane level which is useful in
-scattering computations (OS.f,ISO.f).
+  Description: Given the altitude or pressure at aircraft level as input, the first task is to
+  compute the altitude (in case the pressure has been entered) or the pressure (in case the altitude has
+  been entered) at plane level. Then, a new atmospheric profile is created (Pp,Tp,H2Op,O3p) for which
+  the last level is located at the plane altitude. This profile is used in the gaseous absorption
+  computation (ABSTRA.f) for the path from target to sensor (upward transmission). The ozone and
+  water vapor integrated content of the "plane" atmospheric profile are also an output of this
+  subroutine. The last output is the proportion of molecules below plane level which is useful in
+  scattering computations (OS.f,ISO.f).
 void Altitude::presplane(AtmosModel& atms)
-	xpp += atms.z[0];
-	if(xpp >= 100) xpp = 1000;
+    xpp += atms.z[0];
+    if(xpp >= 100) xpp = 1000;
-	int i;
-	for(i = 0; atms.z[i] <= xpp; i++);
+    int i;
+    for(i = 0; atms.z[i] <= xpp; i++);
-	int isup = i;
-	int iinf = i-1;
+    int isup = i;
+    int iinf = i-1;
-	float ps = (float)(exp((xpp - xb) / xa));
+    float ps = (float)(exp((xpp - xb) / xa));
-	/* interpolating temperature wator vapor and ozone profile versus altitud */
-	float xalt = xpp;
-	float xtemp  = (atms.t[isup] - atms.t[iinf])/ (atms.z[isup] - atms.z[iinf]);
+    /* interpolating temperature wator vapor and ozone profile versus altitud */
+    float xalt = xpp;
+    float xtemp  = (atms.t[isup] - atms.t[iinf])/ (atms.z[isup] - atms.z[iinf]);
-	  last level: plane     , complete to 34
-	for(i = 0; i <= iinf; i++)
-		plane_sim.zpl[i] = atms.z[i];
-		plane_sim.ppl[i] = atms.p[i];
-		plane_sim.tpl[i] = atms.t[i];
-		plane_sim.whpl[i] = atms.wh[i];
-		plane_sim.wopl[i] = atms.wo[i];
+       last level: plane     , complete to 34
+    for(i = 0; i <= iinf; i++)
+	plane_sim.zpl[i] = atms.z[i];
+	plane_sim.ppl[i] = atms.p[i];
+	plane_sim.tpl[i] = atms.t[i];
+	plane_sim.whpl[i] = atms.wh[i];
+	plane_sim.wopl[i] = atms.wo[i];
-	for(i = iinf+1; i < 34; i++)
-		plane_sim.zpl[i] = xalt;
-		plane_sim.ppl[i] = ps;
-		plane_sim.tpl[i] = xtemp;
-		plane_sim.whpl[i] = xwh;
-		plane_sim.wopl[i] = xwo;
+    for(i = iinf+1; i < 34; i++)
+	plane_sim.zpl[i] = xalt;
+	plane_sim.ppl[i] = ps;
+	plane_sim.tpl[i] = xtemp;
+	plane_sim.whpl[i] = xwh;
+	plane_sim.wopl[i] = xwo;
-	 compute conversion factor for rayleigh optical thickness computation
-	 ftray=rp/rt */
-	atms.uw = 0;
-	atms.uo3 = 0;
-	float rt = 0;
-	float rp = 0;
+       compute conversion factor for rayleigh optical thickness computation
+       ftray=rp/rt */
+    atms.uw = 0;
+    atms.uo3 = 0;
+    float rt = 0;
+    float rp = 0;
-	float rmo3[34];
-	float rmwh[34];
-	int k;
-	for(k = 0; k < 33; k++)
-		float roair = (float)(air * 273.16 * plane_sim.ppl[k] / (1013.25 * plane_sim.tpl[k]));
-		rmwh[k] = atms.wh[k] / (roair * 1000);
-		rmo3[k] = atms.wo[k] / (roair * 1000);
-		rt += (atms.p[k+1] / atms.t[k+1] + atms.p[k] / atms.p[k]) * (atms.z[k+1] - atms.z[k]);
-		rp += (plane_sim.ppl[k+1] / plane_sim.tpl[k+1] + plane_sim.ppl[k] / plane_sim.tpl[k])
-			* (plane_sim.zpl[k+1] - plane_sim.zpl[k]);
+    float rmo3[34];
+    float rmwh[34];
+    int k;
+    for(k = 0; k < 33; k++)
+	float roair = (float)(air * 273.16 * plane_sim.ppl[k] / (1013.25 * plane_sim.tpl[k]));
+	rmwh[k] = atms.wh[k] / (roair * 1000);
+	rmo3[k] = atms.wo[k] / (roair * 1000);
+	rt += (atms.p[k+1] / atms.t[k+1] + atms.p[k] / atms.p[k]) * (atms.z[k+1] - atms.z[k]);
+	rp += (plane_sim.ppl[k+1] / plane_sim.tpl[k+1] + plane_sim.ppl[k] / plane_sim.tpl[k])
+	    * (plane_sim.zpl[k+1] - plane_sim.zpl[k]);
-	ftray = rp / rt;
-	for(k = 1; k < 33; k++)
-		float ds = (plane_sim.ppl[k-1] - plane_sim.ppl[k]) / plane_sim.ppl[0];
-		atms.uw += (rmwh[k] + rmwh[k-1])*ds/2;
-		atms.uo3+= (rmo3[k] + rmo3[k-1])*ds/2;
+    ftray = rp / rt;
+    for(k = 1; k < 33; k++)
+	float ds = (plane_sim.ppl[k-1] - plane_sim.ppl[k]) / plane_sim.ppl[0];
+	atms.uw += (rmwh[k] + rmwh[k-1])*ds/2;
+	atms.uo3+= (rmo3[k] + rmo3[k-1])*ds/2;
-	atms.uw *= plane_sim.ppl[0] * 100 / g;
-	atms.uo3*= plane_sim.ppl[0] * 100 / g;
-	atms.uo3*= 1000 / ro3;
+    atms.uw *= plane_sim.ppl[0] * 100 / g;
+    atms.uo3*= plane_sim.ppl[0] * 100 / g;
+    atms.uo3*= 1000 / ro3;
 void Altitude::init(AtmosModel &atms, const AerosolConcentration &aerocon)
@@ -194,145 +194,145 @@
     xps = original_xps;
     xpp = original_xpp;
-	float uwus;
-	float uo3us;
-	if(xps <= 0)
+    float uwus;
+    float uo3us;
+    if(xps <= 0)
+	xps = 0;
+	uwus = 1.424f;
+	uo3us = 0.344f;
+    else if(atms.idatm != 8) pressure(atms, atms.uw, atms.uo3);
+    else pressure(atms, uwus, uo3us);
+    if(xpp <= 0)
+	/* ground measurement option */
+	palt = 0;
+	pps = atms.p[0];
+	idatmp = 0;
+	taer55p = 0;
+	puw = 0;
+    else if(xpp >= 100)
+	/* satellite case of equivalent */
+	palt = 1000;
+	pps = 0;
+	taer55p = aerocon.taer55;
+	puw = 0;
+	ftray = 1;
+	idatmp = 4;
+    else
+	/* "real" plane case */
+	cin >> puw;
+	cin >> puo3;
+	cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore comments */
+	if ( puw < 0 )
-		xps = 0;
-		uwus = 1.424f;
-		uo3us = 0.344f;
+	    presplane(atms);
+	    idatmp = 2;
+	    if (atms.idatm == 8)
+		puwus = puw;
+		puo3us = puo3;
+		puw *= atms.uw / uwus;
+		puo3 *= atms.uo3 / uo3us;
+		idatmp = 8;
-	else if(atms.idatm != 8) pressure(atms, atms.uw, atms.uo3);
-	else pressure(atms, uwus, uo3us);
-	if(xpp <= 0)
+	else
-		/* ground measurement option */
-		palt = 0;
-		pps = atms.p[0];
-		idatmp = 0;
-		taer55p = 0;
-		puw = 0;
+	    presplane(atms);
+	    idatmp = 8;
-	else if(xpp >= 100)
+	palt = plane_sim.zpl[33] - atms.z[0];
+	pps = plane_sim.ppl[33];
+	cin >> taer55p;
+	if ((taer55p > 0) || ((aerocon.taer55 - taer55p) < 1e-03))
-		/* satellite case of equivalent */
-		palt = 1000;
-		pps = 0;
-		taer55p = aerocon.taer55;
-		puw = 0;
-		ftray = 1;
-		idatmp = 4;
+	    /* a scale heigh of 2km is assumed in case no value is given for taer55p */
+	    taer55p = (float)(aerocon.taer55 * (1 - exp(-palt / 2)));
 	else
-		/* "real" plane case */
-		cin >> puw;
-		cin >> puo3;
-		cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore comments */
-		if ( puw < 0 )
-			presplane(atms);
-			idatmp = 2;
+	    /* compute effective scale heigh */
+	    double sham = exp(-palt / 4);
+	    double sha = 1 - (taer55p / aerocon.taer55);
-			if (atms.idatm == 8)
-				puwus = puw;
-				puo3us = puo3;
-				puw *= atms.uw / uwus;
-				puo3 *= atms.uo3 / uo3us;
-				idatmp = 8;
-		else
-			presplane(atms);
-			idatmp = 8;
-		palt = plane_sim.zpl[33] - atms.z[0];
-		pps = plane_sim.ppl[33];
-		cin >> taer55p;
-		if ((taer55p > 0) || ((aerocon.taer55 - taer55p) < 1e-03))
-			/* a scale heigh of 2km is assumed in case no value is given for taer55p */
-			taer55p = (float)(aerocon.taer55 * (1 - exp(-palt / 2)));
-		else
-			/* compute effective scale heigh */
-			double sham = exp(-palt / 4);
-			double sha = 1 - (taer55p / aerocon.taer55);
-			if( sha >= sham) taer55p = (float)(aerocon.taer55 * (1 - exp(-palt / 4)));
-			else {
-				sha = -palt/log(sha);
-				taer55p = (float)(aerocon.taer55 * (1 - exp(-palt/sha)));
+	    if( sha >= sham) taer55p = (float)(aerocon.taer55 * (1 - exp(-palt / 4)));
+	    else {
+		sha = -palt/log(sha);
+		taer55p = (float)(aerocon.taer55 * (1 - exp(-palt/sha)));
 void Altitude::parse()
-	cin >> original_xps;
+    cin >> original_xps;
     original_xps = -original_xps;
-	cin >> original_xpp;
+    cin >> original_xpp;
     original_xpp = -original_xpp;
 /* --- plane simulation output if selected ---- */
 void Altitude::print()
-	if(palt < 1000)
-		Output::Ln();
-		Output::WriteLn(22," plane simulation description ");
-		Output::WriteLn(22," ---------------------------- ");
+    if(palt < 1000)
+	Output::Ln();
+	Output::WriteLn(22," plane simulation description ");
+	Output::WriteLn(22," ---------------------------- ");
-		ostringstream s1;
-		s1.setf(ios::fixed, ios::floatfield);
-		s1.precision(2);
-		s1 << " plane  pressure          [mb] " << setw(9) << pps << ends;
-		Output::WriteLn(10,s1.str());
+	ostringstream s1;
+	s1.setf(ios::fixed, ios::floatfield);
+	s1.precision(2);
+	s1 << " plane  pressure          [mb] " << setw(9) << pps << ends;
+	Output::WriteLn(10,s1.str());
-		ostringstream s2;
-		s2.setf(ios::fixed, ios::floatfield);
-		s2.precision(3);
-		s2 << " plane  altitude absolute [km] " << setw(9) << plane_sim.zpl[33] << ends;
-		Output::WriteLn(10,s2.str());
+	ostringstream s2;
+	s2.setf(ios::fixed, ios::floatfield);
+	s2.precision(3);
+	s2 << " plane  altitude absolute [km] " << setw(9) << plane_sim.zpl[33] << ends;
+	Output::WriteLn(10,s2.str());
-		Output::WriteLn(15," atmosphere under plane description: ");
+	Output::WriteLn(15," atmosphere under plane description: ");
-		ostringstream s3;
-		s3.precision(3);
-		s3 << " ozone content            " << setw(9) << puo3 << ends;
-		Output::WriteLn(15,s3.str());
+	ostringstream s3;
+	s3.precision(3);
+	s3 << " ozone content            " << setw(9) << puo3 << ends;
+	Output::WriteLn(15,s3.str());
-		ostringstream s4;
-		s4.setf(ios::fixed, ios::floatfield);
-		s4.precision(3);
-		s4 << " h2o   content            " << setw(9) << puw << ends;
-		Output::WriteLn(15,s4.str());
+	ostringstream s4;
+	s4.setf(ios::fixed, ios::floatfield);
+	s4.precision(3);
+	s4 << " h2o   content            " << setw(9) << puw << ends;
+	Output::WriteLn(15,s4.str());
-		ostringstream s5;
-		s5.setf(ios::fixed, ios::floatfield);
-		s5.precision(3);
-		s5 << "aerosol opt. thick. 550nm " << setw(9) << taer55p << ends;
-		Output::WriteLn(15,s5.str());
+	ostringstream s5;
+	s5.setf(ios::fixed, ios::floatfield);
+	s5.precision(3);
+	s5 << "aerosol opt. thick. 550nm " << setw(9) << taer55p << ends;
+	Output::WriteLn(15,s5.str());
 Altitude Altitude::Parse()
-	Altitude alt;
-	alt.parse();
-	return alt;
+    Altitude alt;
+    alt.parse();
+    return alt;
Modified: grass/trunk/imagery/i.atcorr/AtmosModel.cpp
--- grass/trunk/imagery/i.atcorr/AtmosModel.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/AtmosModel.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -3,315 +3,315 @@
 void AtmosModel::tropic()
-	static const float z1[34] =
+    static const float z1[34] =
-		0.f, 1.f, 2.f, 3.f, 4.f, 5.f, 6.f, 7.f, 8.f, 9.f, 10.f, 11.f,
-		12.f, 13.f, 14.f, 15.f, 16.f, 17.f, 18.f, 19.f, 20.f, 21.f,
-		22.f, 23.f, 24.f, 25.f, 30.f, 35.f, 40.f, 45.f, 50.f, 70.f, 100.f, 99999.f
+	    0.f, 1.f, 2.f, 3.f, 4.f, 5.f, 6.f, 7.f, 8.f, 9.f, 10.f, 11.f,
+	    12.f, 13.f, 14.f, 15.f, 16.f, 17.f, 18.f, 19.f, 20.f, 21.f,
+	    22.f, 23.f, 24.f, 25.f, 30.f, 35.f, 40.f, 45.f, 50.f, 70.f, 100.f, 99999.f
-	static const float p1[34] =
-		1013.f, 904.f, 805.f, 715.f, 633.f, 559.f, 492.f, 432.f, 378.f,
-		329.f, 286.f, 247.f, 213.f, 182.f, 156.f, 132.f, 111.f, 93.7f,
-		78.9f, 66.6f, 56.5f, 48.f, 40.9f, 35.f, 30.f, 25.7f, 12.2f, 6.f,
-		3.05f, 1.59f, .854f, .0579f, 3e-4f, 0.f
+    static const float p1[34] =
+	    1013.f, 904.f, 805.f, 715.f, 633.f, 559.f, 492.f, 432.f, 378.f,
+	    329.f, 286.f, 247.f, 213.f, 182.f, 156.f, 132.f, 111.f, 93.7f,
+	    78.9f, 66.6f, 56.5f, 48.f, 40.9f, 35.f, 30.f, 25.7f, 12.2f, 6.f,
+	    3.05f, 1.59f, .854f, .0579f, 3e-4f, 0.f
-	static const float t1[34] =
-		300.f, 294.f, 288.f, 284.f, 277.f, 270.f, 264.f, 257.f, 250.f,
-		244.f, 237.f, 230.f, 224.f, 217.f, 210.f, 204.f, 197.f, 195.f,
-		199.f, 203.f, 207.f, 211.f, 215.f, 217.f, 219.f, 221.f, 232.f,
-		243.f, 254.f, 265.f, 270.f, 219.f, 210.f, 210.f
+    static const float t1[34] =
+	    300.f, 294.f, 288.f, 284.f, 277.f, 270.f, 264.f, 257.f, 250.f,
+	    244.f, 237.f, 230.f, 224.f, 217.f, 210.f, 204.f, 197.f, 195.f,
+	    199.f, 203.f, 207.f, 211.f, 215.f, 217.f, 219.f, 221.f, 232.f,
+	    243.f, 254.f, 265.f, 270.f, 219.f, 210.f, 210.f
-	static const float wh1[34] =
-		19.f, 13.f, 9.3f, 4.7f, 2.2f, 1.5f, .85f, .47f, .25f, .12f, .05f,
+    static const float wh1[34] =
+	    19.f, 13.f, 9.3f, 4.7f, 2.2f, 1.5f, .85f, .47f, .25f, .12f, .05f,
-		.017f, .006f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f, 5e-4f,
-		4.9e-4f, 4.5e-4f, 5.1e-4f, 5.1e-4f, 5.4e-4f, 6e-4f, 6.7e-4f,
-		3.6e-4f, 1.1e-4f, 4.3e-5f, 1.9e-5f, 6.3e-6f, 1.4e-7f, 1e-9f, 0.f
+	    .017f, .006f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f, 5e-4f,
+	    4.9e-4f, 4.5e-4f, 5.1e-4f, 5.1e-4f, 5.4e-4f, 6e-4f, 6.7e-4f,
+	    3.6e-4f, 1.1e-4f, 4.3e-5f, 1.9e-5f, 6.3e-6f, 1.4e-7f, 1e-9f, 0.f
-	static const float wo1[34] =
-		5.6e-5f, 5.6e-5f, 5.4e-5f, 5.1e-5f, 4.7e-5f, 4.5e-5f,
-		4.3e-5f, 4.1e-5f, 3.9e-5f, 3.9e-5f, 3.9e-5f, 4.1e-5f, 4.3e-5f, 4.5e-5f,
+    static const float wo1[34] =
+	    5.6e-5f, 5.6e-5f, 5.4e-5f, 5.1e-5f, 4.7e-5f, 4.5e-5f,
+	    4.3e-5f, 4.1e-5f, 3.9e-5f, 3.9e-5f, 3.9e-5f, 4.1e-5f, 4.3e-5f, 4.5e-5f,
 	    4.5e-5f, 4.7e-5f, 4.7e-5f, 6.9e-5f, 9e-5f, 1.4e-4f, 1.9e-4f, 2.4e-4f,
-		2.8e-4f, 3.2e-4f, 3.4e-4f, 3.4e-4f, 2.4e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f,
-		4.3e-6f, 8.6e-8f, 4.3e-11f, 0.f
+	    2.8e-4f, 3.2e-4f, 3.4e-4f, 3.4e-4f, 2.4e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f,
+	    4.3e-6f, 8.6e-8f, 4.3e-11f, 0.f
-	/* model: tropical mc clatchey */
-	for (int i = 0; i < 34; i++)
+    /* model: tropical mc clatchey */
+    for (int i = 0; i < 34; i++)
-      z[i] = z1[i];
-      p[i] = p1[i];
-      t[i] = t1[i];
-      wh[i] = wh1[i];
-      wo[i] = wo1[i];
+	z[i] = z1[i];
+	p[i] = p1[i];
+	t[i] = t1[i];
+	wh[i] = wh1[i];
+	wo[i] = wo1[i];
 void AtmosModel::midsum()
-		12.f, 13.f, 14.f, 15.f, 16.f, 17.f, 18.f, 19.f, 20.f, 21.f, 22.f, 23.f,
-		24.f, 25.f, 30.f, 35.f, 40.f, 45.f, 50.f, 70.f, 100.f, 99999.f
+	    12.f, 13.f, 14.f, 15.f, 16.f, 17.f, 18.f, 19.f, 20.f, 21.f, 22.f, 23.f,
+	    24.f, 25.f, 30.f, 35.f, 40.f, 45.f, 50.f, 70.f, 100.f, 99999.f
-		1013.f, 902.f, 802.f, 710.f, 628.f, 554.f, 487.f, 426.f,
-		372.f, 324.f, 281.f, 243.f, 209.f, 179.f, 153.f, 130.f, 111.f, 95.f,
-		81.2f, 69.5f, 59.5f, 51.f, 43.7f, 37.6f, 32.2f, 27.7f, 13.2f, 6.52f,
-		3.33f, 1.76f, .951f, .0671f, 3e-4f, 0.f
+	    1013.f, 902.f, 802.f, 710.f, 628.f, 554.f, 487.f, 426.f,
+	    372.f, 324.f, 281.f, 243.f, 209.f, 179.f, 153.f, 130.f, 111.f, 95.f,
+	    81.2f, 69.5f, 59.5f, 51.f, 43.7f, 37.6f, 32.2f, 27.7f, 13.2f, 6.52f,
+	    3.33f, 1.76f, .951f, .0671f, 3e-4f, 0.f
-		294.f, 290.f, 285.f, 279.f, 273.f, 267.f, 261.f, 255.f,
+	    294.f, 290.f, 285.f, 279.f, 273.f, 267.f, 261.f, 255.f,
 	    248.f, 242.f, 235.f, 229.f, 222.f, 216.f, 216.f, 216.f, 216.f, 216.f,
-		216.f, 217.f, 218.f, 219.f, 220.f, 222.f, 223.f, 224.f, 234.f, 245.f, 258.f,
-		270.f, 276.f, 218.f, 210.f, 210.f
+	    216.f, 217.f, 218.f, 219.f, 220.f, 222.f, 223.f, 224.f, 234.f, 245.f, 258.f,
+	    270.f, 276.f, 218.f, 210.f, 210.f
-		14.f, 9.3f, 5.9f, 3.3f, 1.9f, 1.f, .61f, .37f, .21f, .12f,
-		.064f, .022f, .006f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f, 5e-4f,
-		4.9e-4f, 4.5e-4f, 5.1e-4f, 5.1e-4f, 5.4e-4f, 6e-4f, 6.7e-4f, 3.6e-4f,
-		1.1e-4f, 4.3e-5f, 1.9e-5f, 1.3e-6f, 1.4e-7f, 1e-9f, 0.f
+	    14.f, 9.3f, 5.9f, 3.3f, 1.9f, 1.f, .61f, .37f, .21f, .12f,
+	    .064f, .022f, .006f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f, 5e-4f,
+	    4.9e-4f, 4.5e-4f, 5.1e-4f, 5.1e-4f, 5.4e-4f, 6e-4f, 6.7e-4f, 3.6e-4f,
+	    1.1e-4f, 4.3e-5f, 1.9e-5f, 1.3e-6f, 1.4e-7f, 1e-9f, 0.f
-		6e-5f, 6e-5f, 6e-5f, 6.2e-5f, 6.4e-5f, 6.6e-5f, 6.9e-5f,
+	    6e-5f, 6e-5f, 6e-5f, 6.2e-5f, 6.4e-5f, 6.6e-5f, 6.9e-5f,
 	    7.5e-5f, 7.9e-5f, 8.6e-5f, 9e-5f, 1.1e-4f, 1.2e-4f, 1.5e-4f, 1.8e-4f,
-		1.9e-4f, 2.1e-4f, 2.4e-4f, 2.8e-4f, 3.2e-4f, 3.4e-4f, 3.6e-4f, 3.6e-4f,
-		3.4e-4f, 3.2e-4f, 3e-4f, 2e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f, 4.3e-6f,
-		8.6e-8f, 4.3e-11f, 0.f
+	    1.9e-4f, 2.1e-4f, 2.4e-4f, 2.8e-4f, 3.2e-4f, 3.4e-4f, 3.6e-4f, 3.6e-4f,
+	    3.4e-4f, 3.2e-4f, 3e-4f, 2e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f, 4.3e-6f,
+	    8.6e-8f, 4.3e-11f, 0.f
-	/* model: midlatitude summer mc clatchey */
+    /* model: midlatitude summer mc clatchey */
-      z[i] = z1[i];
-      p[i] = p1[i];
-      t[i] = t1[i];
-      wh[i] = wh1[i];
-      wo[i] = wo1[i];
+	z[i] = z1[i];
+	p[i] = p1[i];
+	t[i] = t1[i];
+	wh[i] = wh1[i];
+	wo[i] = wo1[i];
 void AtmosModel::midwin()
-		1018.f, 897.3f, 789.7f, 693.8f, 608.1f, 531.3f, 462.7f,
+	    1018.f, 897.3f, 789.7f, 693.8f, 608.1f, 531.3f, 462.7f,
 	    401.6f, 347.3f, 299.2f, 256.8f, 219.9f, 188.2f, 161.f, 137.8f, 117.8f,
-		100.7f, 86.1f, 73.5f, 62.8f, 53.7f, 45.8f, 39.1f, 33.4f, 28.6f, 24.3f,
+	    100.7f, 86.1f, 73.5f, 62.8f, 53.7f, 45.8f, 39.1f, 33.4f, 28.6f, 24.3f,
 	    11.1f, 5.18f, 2.53f, 1.29f, .682f, .0467f, 3e-4f, 0.f
-		272.2f, 268.7f, 265.2f, 261.7f, 255.7f, 249.7f, 243.7f,
+	    272.2f, 268.7f, 265.2f, 261.7f, 255.7f, 249.7f, 243.7f,
 	    237.7f, 231.7f, 225.7f, 219.7f, 219.2f, 218.7f, 218.2f, 217.7f, 217.2f,
-		216.7f, 216.2f, 215.7f, 215.2f, 215.2f, 215.2f, 215.2f, 215.2f, 215.2f,
+	    216.7f, 216.2f, 215.7f, 215.2f, 215.2f, 215.2f, 215.2f, 215.2f, 215.2f,
 	    215.2f, 217.4f, 227.8f, 243.2f, 258.5f, 265.7f, 230.7f, 210.2f, 210.f
-		3.5f, 2.5f, 1.8f, 1.2f, .66f, .38f, .21f, .085f, .035f,
+	    3.5f, 2.5f, 1.8f, 1.2f, .66f, .38f, .21f, .085f, .035f,
 	    .016f, .0075f, .0069f, .006f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f,
-		5e-4f, 4.9e-4f, 4.5e-4f, 5.1e-4f, 5.1e-4f, 5.4e-4f, 6e-4f, 6.7e-4f,
+	    5e-4f, 4.9e-4f, 4.5e-4f, 5.1e-4f, 5.1e-4f, 5.4e-4f, 6e-4f, 6.7e-4f,
-		6e-5f, 5.4e-5f, 4.9e-5f, 4.9e-5f, 4.9e-5f, 5.8e-5f,
+	    6e-5f, 5.4e-5f, 4.9e-5f, 4.9e-5f, 4.9e-5f, 5.8e-5f,
 	    6.4e-5f, 7.7e-5f, 9e-5f, 1.2e-4f, 1.6e-4f, 2.1e-4f, 2.6e-4f, 3e-4f,
-		3.2e-4f, 3.4e-4f, 3.6e-4f, 3.9e-4f, 4.1e-4f, 4.3e-4f, 4.5e-4f, 4.3e-4f,
+	    3.2e-4f, 3.4e-4f, 3.6e-4f, 3.9e-4f, 4.1e-4f, 4.3e-4f, 4.5e-4f, 4.3e-4f,
 	    4.3e-4f, 3.9e-4f, 3.6e-4f, 3.4e-4f, 1.9e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f,
-	/* model: midlatitude winter mc clatchey */
+    /* model: midlatitude winter mc clatchey */
-      z[i] = z1[i];
-      p[i] = p1[i];
-      t[i] = t1[i];
-      wh[i] = wh1[i];
-      wo[i] = wo1[i];
+	z[i] = z1[i];
+	p[i] = p1[i];
+	t[i] = t1[i];
+	wh[i] = wh1[i];
+	wo[i] = wo1[i];
 void AtmosModel::subsum()
-		1010.f, 896.f, 792.9f, 700.f, 616.f, 541.f, 473.f, 413.f,
+	    1010.f, 896.f, 792.9f, 700.f, 616.f, 541.f, 473.f, 413.f,
 	    359.f, 310.7f, 267.7f, 230.f, 197.7f, 170.f, 146.f, 125.f, 108.f, 92.8f,
-		79.8f, 68.6f, 58.9f, 50.7f, 43.6f, 37.5f, 32.27f, 27.8f, 13.4f, 6.61f,
+	    79.8f, 68.6f, 58.9f, 50.7f, 43.6f, 37.5f, 32.27f, 27.8f, 13.4f, 6.61f,
 	    3.4f, 1.81f, .987f, .0707f, 3e-4f, 0.f
-		287.f, 282.f, 276.f, 271.f, 266.f, 260.f, 253.f, 246.f,
-		239.f, 232.f, 225.f, 225.f, 225.f, 225.f, 225.f, 225.f, 225.f, 225.f,
+	    287.f, 282.f, 276.f, 271.f, 266.f, 260.f, 253.f, 246.f,
+	    239.f, 232.f, 225.f, 225.f, 225.f, 225.f, 225.f, 225.f, 225.f, 225.f,
 	    225.f, 225.f, 225.f, 225.f, 225.f, 225.f, 226.f, 228.f, 235.f, 247.f, 262.f,
-		274.f, 277.f, 216.f, 210.f, 210.f
+	    274.f, 277.f, 216.f, 210.f, 210.f
-		9.1f, 6.f, 4.2f, 2.7f, 1.7f, 1.f, .54f, .29f, .13f, .042f,
+	    9.1f, 6.f, 4.2f, 2.7f, 1.7f, 1.f, .54f, .29f, .13f, .042f,
 	    .015f, .0094f, .006f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f, 5e-4f,
-		1.1e-4f, 4.3e-5f, 1.9e-5f, 6.3e-6f, 1.4e-7f, 1e-9f, 0.f
+	    1.1e-4f, 4.3e-5f, 1.9e-5f, 6.3e-6f, 1.4e-7f, 1e-9f, 0.f
-		4.9e-5f, 5.4e-5f, 5.6e-5f, 5.8e-5f, 6e-5f, 6.4e-5f,
+	    4.9e-5f, 5.4e-5f, 5.6e-5f, 5.8e-5f, 6e-5f, 6.4e-5f,
 	    7.1e-5f, 7.5e-5f, 7.9e-5f, 1.1e-4f, 1.3e-4f, 1.8e-4f, 2.1e-4f, 2.6e-4f,
-		2.8e-4f, 3.2e-4f, 3.4e-4f, 3.9e-4f, 4.1e-4f, 4.1e-4f, 3.9e-4f, 3.6e-4f,
+	    2.8e-4f, 3.2e-4f, 3.4e-4f, 3.9e-4f, 4.1e-4f, 4.1e-4f, 3.9e-4f, 3.6e-4f,
 	    3.2e-4f, 3e-4f, 2.8e-4f, 2.6e-4f, 1.4e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f,
-	/* model: subarctique summer mc clatchey */
+    /* model: subarctique summer mc clatchey */
-      z[i] = z1[i];
-      p[i] = p1[i];
-      t[i] = t1[i];
-      wh[i] = wh1[i];
-      wo[i] = wo1[i];
+	z[i] = z1[i];
+	p[i] = p1[i];
+	t[i] = t1[i];
+	wh[i] = wh1[i];
+	wo[i] = wo1[i];
 void AtmosModel::subwin()
-		1013.f, 887.8f, 777.5f, 679.8f, 593.2f, 515.8f, 446.7f,
+	    1013.f, 887.8f, 777.5f, 679.8f, 593.2f, 515.8f, 446.7f,
 	    385.3f, 330.8f, 282.9f, 241.8f, 206.7f, 176.6f, 151.f, 129.1f, 110.3f,
-		94.31f, 80.58f, 68.82f, 58.75f, 50.14f, 42.77f, 36.47f, 31.09f, 26.49f,
-		22.56f, 10.2f, 4.701f, 2.243f, 1.113f, .5719f, .04016f, 3e-4f, 0.f
+	    94.31f, 80.58f, 68.82f, 58.75f, 50.14f, 42.77f, 36.47f, 31.09f, 26.49f,
+	    22.56f, 10.2f, 4.701f, 2.243f, 1.113f, .5719f, .04016f, 3e-4f, 0.f
-		257.1f, 259.1f, 255.9f, 252.7f, 247.7f, 240.9f, 234.1f,
+	    257.1f, 259.1f, 255.9f, 252.7f, 247.7f, 240.9f, 234.1f,
 	    227.3f, 220.6f, 217.2f, 217.2f, 217.2f, 217.2f, 217.2f, 217.2f, 217.2f,
-		216.6f, 216.f, 215.4f, 214.8f, 214.1f, 213.6f, 213.f, 212.4f, 211.8f,
-		211.2f, 216.f, 222.2f, 234.7f, 247.f, 259.3f, 245.7f, 210.f, 210.f
+	    216.6f, 216.f, 215.4f, 214.8f, 214.1f, 213.6f, 213.f, 212.4f, 211.8f,
+	    211.2f, 216.f, 222.2f, 234.7f, 247.f, 259.3f, 245.7f, 210.f, 210.f
-		1.2f, 1.2f, .94f, .68f, .41f, .2f, .098f, .054f, .011f,
-		.0084f, .0055f, .0038f, .0026f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f,
+	    1.2f, 1.2f, .94f, .68f, .41f, .2f, .098f, .054f, .011f,
+	    .0084f, .0055f, .0038f, .0026f, .0018f, .001f, 7.6e-4f, 6.4e-4f, 5.6e-4f,
-		4.1e-5f, 4.1e-5f, 4.1e-5f, 4.3e-5f, 4.5e-5f, 4.7e-5f,
-		4.9e-5f, 7.1e-5f, 9e-5f, 1.6e-4f, 2.4e-4f, 3.2e-4f, 4.3e-4f, 4.7e-4f,
-		4.9e-4f, 5.6e-4f, 6.2e-4f, 6.2e-4f, 6.2e-4f, 6e-4f, 5.6e-4f, 5.1e-4f,
-		4.7e-4f, 4.3e-4f, 3.6e-4f, 3.2e-4f, 1.5e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f,
+	    4.1e-5f, 4.1e-5f, 4.1e-5f, 4.3e-5f, 4.5e-5f, 4.7e-5f,
+	    4.9e-5f, 7.1e-5f, 9e-5f, 1.6e-4f, 2.4e-4f, 3.2e-4f, 4.3e-4f, 4.7e-4f,
+	    4.9e-4f, 5.6e-4f, 6.2e-4f, 6.2e-4f, 6.2e-4f, 6e-4f, 5.6e-4f, 5.1e-4f,
+	    4.7e-4f, 4.3e-4f, 3.6e-4f, 3.2e-4f, 1.5e-4f, 9.2e-5f, 4.1e-5f, 1.3e-5f,
-	/* model: subarctique winter mc clatchey */
+    /* model: subarctique winter mc clatchey */
-      z[i] = z1[i];
-      p[i] = p1[i];
-      t[i] = t1[i];
-      wh[i] = wh1[i];
-      wo[i] = wo1[i];
+	z[i] = z1[i];
+	p[i] = p1[i];
+	t[i] = t1[i];
+	wh[i] = wh1[i];
+	wo[i] = wo1[i];
 void AtmosModel::us62()
-		1013.f, 898.6f, 795.f, 701.2f, 616.6f, 540.5f, 472.2f,
-		411.1f, 356.5f, 308.f, 265.f, 227.f, 194.f, 165.8f, 141.7f, 121.1f,
-		103.5f, 88.5f, 75.65f, 64.67f, 55.29f, 47.29f, 40.47f, 34.67f, 29.72f, 25.49f,
-		11.97f, 5.746f, 2.871f, 1.491f, .7978f, .0552f, 3.008e-4f, 0.f
+	    1013.f, 898.6f, 795.f, 701.2f, 616.6f, 540.5f, 472.2f,
+	    411.1f, 356.5f, 308.f, 265.f, 227.f, 194.f, 165.8f, 141.7f, 121.1f,
+	    103.5f, 88.5f, 75.65f, 64.67f, 55.29f, 47.29f, 40.47f, 34.67f, 29.72f, 25.49f,
+	    11.97f, 5.746f, 2.871f, 1.491f, .7978f, .0552f, 3.008e-4f, 0.f
-		288.1f, 281.6f, 275.1f, 268.7f, 262.2f, 255.7f, 249.2f,
+	    288.1f, 281.6f, 275.1f, 268.7f, 262.2f, 255.7f, 249.2f,
 	    242.7f, 236.2f, 229.7f, 223.2f, 216.8f, 216.6f, 216.6f, 216.6f, 216.6f,
-		216.6f, 216.6f, 216.6f, 216.6f, 216.6f, 217.6f, 218.6f, 219.6f, 220.6f,
-		221.6f, 226.5f, 236.5f, 253.4f, 264.2f, 270.6f, 219.7f, 210.f, 210.f
+	    216.6f, 216.6f, 216.6f, 216.6f, 216.6f, 217.6f, 218.6f, 219.6f, 220.6f,
+	    221.6f, 226.5f, 236.5f, 253.4f, 264.2f, 270.6f, 219.7f, 210.f, 210.f
-		5.9f, 4.2f, 2.9f, 1.8f, 1.1f, .64f, .38f, .21f, .12f,
+	    5.9f, 4.2f, 2.9f, 1.8f, 1.1f, .64f, .38f, .21f, .12f,
 	    .046f, .018f, .0082f, .0037f, .0018f, 8.4e-4f, 7.2e-4f, 6.1e-4f, 5.2e-4f,
-		4.4e-4f, 4.4e-4f, 4.4e-4f, 4.8e-4f, 5.2e-4f, 5.7e-4f, 6.1e-4f, 6.6e-4f,
+	    4.4e-4f, 4.4e-4f, 4.4e-4f, 4.8e-4f, 5.2e-4f, 5.7e-4f, 6.1e-4f, 6.6e-4f,
 	    3.8e-4f, 1.6e-4f, 6.7e-5f, 3.2e-5f, 1.2e-5f, 1.5e-7f, 1e-9f, 0.f
-		5.4e-5f, 5.4e-5f, 5.4e-5f, 5e-5f, 4.6e-5f, 4.6e-5f,
-		4.5e-5f, 4.9e-5f, 5.2e-5f, 7.1e-5f, 9e-5f, 1.3e-4f, 1.6e-4f, 1.7e-4f,
-		1.9e-4f, 2.1e-4f, 2.4e-4f, 2.8e-4f, 3.2e-4f, 3.5e-4f, 3.8e-4f, 3.8e-4f,
-		3.9e-4f, 3.8e-4f, 3.6e-4f, 3.4e-4f, 2e-4f, 1.1e-4f, 4.9e-5f, 1.7e-5f,
-		4e-6f, 8.6e-8f, 4.3e-11f, 0.f
+	    5.4e-5f, 5.4e-5f, 5.4e-5f, 5e-5f, 4.6e-5f, 4.6e-5f,
+	    4.5e-5f, 4.9e-5f, 5.2e-5f, 7.1e-5f, 9e-5f, 1.3e-4f, 1.6e-4f, 1.7e-4f,
+	    1.9e-4f, 2.1e-4f, 2.4e-4f, 2.8e-4f, 3.2e-4f, 3.5e-4f, 3.8e-4f, 3.8e-4f,
+	    3.9e-4f, 3.8e-4f, 3.6e-4f, 3.4e-4f, 2e-4f, 1.1e-4f, 4.9e-5f, 1.7e-5f,
+	    4e-6f, 8.6e-8f, 4.3e-11f, 0.f
-	/* model: us standard 62 mc clatchey */
+    /* model: us standard 62 mc clatchey */
         z[i] = z1[i];
         p[i] = p1[i];
@@ -324,142 +324,142 @@
 void AtmosModel::parse()
-	cin >> idatm;
-	cin.ignore(numeric_limits<int>::max(),'\n'); /* read the rest of the scraps, like comments */
+    cin >> idatm;
+    cin.ignore(numeric_limits<int>::max(),'\n'); /* read the rest of the scraps, like comments */
-	uw = 0.;
-	uo3 = 0.;
+    uw = 0.;
+    uo3 = 0.;
-	switch(idatm)
+    switch(idatm)
+    case 0: us62();	    break;
+    case 1: tropic();	break;
+    case 2: midsum();	break;
+    case 3: midwin();	break;
+    case 4: subsum();	break;
+    case 5: subwin();	break;
+    case 6: us62();	    break;
+    case 7:
+	/* read input */
+	for(int i = 0; i < 34; i++)
-	case 0: us62();	    break;
-	case 1: tropic();	break;
-	case 2: midsum();	break;
-	case 3: midwin();	break;
-	case 4: subsum();	break;
-	case 5: subwin();	break;
-	case 6: us62();	    break;
-	case 7:
-			/* read input */
-			for(int i = 0; i < 34; i++)
-				cin >> z[i];
-				cin >> p[i];
-				cin >> t[i];
-				cin >> wh[i];
-				cin >> wo[i];
-			break;
-	case 8:
-			cin >> uw;
-			cin >> uo3;
-			us62();
-            break;
-	default: fprintf(stderr, "Unknown atmospheric model!\n");
+	    cin >> z[i];
+	    cin >> p[i];
+	    cin >> t[i];
+	    cin >> wh[i];
+	    cin >> wo[i];
+	break;
+    case 8:
+	cin >> uw;
+	cin >> uo3;
+	us62();
+	break;
+    default: fprintf(stderr, "Unknown atmospheric model!\n");
 /* --- atmospheric model ---- */
 void AtmosModel::print()
-	static const string head(" atmospheric model description  ");
-	static const string line(" -----------------------------  ");
-	Output::Begin(); Output::Repeat(22,' '); Output::Print(head); Output::End();
-	Output::Begin(); Output::Repeat(22,' '); Output::Print(line); Output::End();
+    static const string head(" atmospheric model description  ");
+    static const string line(" -----------------------------  ");
+    Output::Begin(); Output::Repeat(22,' '); Output::Print(head); Output::End();
+    Output::Begin(); Output::Repeat(22,' '); Output::Print(line); Output::End();
-	if(idatm < 7)
-		static const string atmid[7] = {
-			string("no absorption computed                             "),
-			string("tropical            (uh2o=4.12g/cm2,uo3=.247cm-atm)"),
-			string("midlatitude summer  (uh2o=2.93g/cm2,uo3=.319cm-atm)"),
-			string("midlatitude winter  (uh2o=.853g/cm2,uo3=.395cm-atm)"),
-			string("subarctic  summer   (uh2o=2.10g/cm2,uo3=.480cm-atm)"),
-			string("subarctic  winter   (uh2o=.419g/cm2,uo3=.480cm-atm)"),
-			string("us  standard 1962   (uh2o=1.42g/cm2,uo3=.344cm-atm)")
+    if(idatm < 7)
+	static const string atmid[7] = {
+	    string("no absorption computed                             "),
+	    string("tropical            (uh2o=4.12g/cm2,uo3=.247cm-atm)"),
+	    string("midlatitude summer  (uh2o=2.93g/cm2,uo3=.319cm-atm)"),
+	    string("midlatitude winter  (uh2o=.853g/cm2,uo3=.395cm-atm)"),
+	    string("subarctic  summer   (uh2o=2.10g/cm2,uo3=.480cm-atm)"),
+	    string("subarctic  winter   (uh2o=.419g/cm2,uo3=.480cm-atm)"),
+	    string("us  standard 1962   (uh2o=1.42g/cm2,uo3=.344cm-atm)")
-		Output::Begin();
-		Output::Repeat(10,' ');
-		Output::Print(" atmospheric model identity : ");
-		Output::End();
+	Output::Begin();
+	Output::Repeat(10,' ');
+	Output::Print(" atmospheric model identity : ");
+	Output::End();
-		Output::Begin();
-		Output::Repeat(15,' ');
-		Output::Print(atmid[idatm]);
-		Output::End();
-	else if(idatm == 7)
-		Output::Begin();
-		Output::End();
+	Output::Begin();
+	Output::Repeat(15,' ');
+	Output::Print(atmid[idatm]);
+	Output::End();
+    else if(idatm == 7)
+	Output::Begin();
+	Output::End();
-		Output::Begin();
-		Output::Repeat(12, ' ');
-		Output::Print(" user defined atmospheric model  ");
-		Output::End();
+	Output::Begin();
+	Output::Repeat(12, ' ');
+	Output::Print(" user defined atmospheric model  ");
+	Output::End();
-		Output::Begin();
-		Output::Print("*altitude  *pressure  *temp.     *h2o dens. *o3 dens.  ");
-		Output::End();
+	Output::Begin();
+	Output::Print("*altitude  *pressure  *temp.     *h2o dens. *o3 dens.  ");
+	Output::End();
-			Output::Begin();
-			ostringstream s;
-			s.setf(ios::fixed, ios::floatfield);
-			s << setprecision(4);
-			s << setw(9) << z[i] << "  ";
-			s << setw(9) << p[i] << "  ";
-			s << setw(9) << t[i] << "  ";
-			s << setw(9) << wh[i] << "  ";
-			s << setw(9) << wo[i] << "  ";
-			s << ends;
-			Output::Print(s.str());
-			Output::End();
+	    Output::Begin();
+	    ostringstream s;
+	    s.setf(ios::fixed, ios::floatfield);
+	    s << setprecision(4);
+	    s << setw(9) << z[i] << "  ";
+	    s << setw(9) << p[i] << "  ";
+	    s << setw(9) << t[i] << "  ";
+	    s << setw(9) << wh[i] << "  ";
+	    s << setw(9) << wo[i] << "  ";
+	    s << ends;
+	    Output::Print(s.str());
+	    Output::End();
-	else
-		Output::Begin();
-		Output::Repeat(10, ' ');
-		Output::End();
+    else
+	Output::Begin();
+	Output::Repeat(10, ' ');
+	Output::End();
-		Output::Begin();
-		ostringstream s1;
-		s1 << " user defined water content : uh2o=" << setw(9) << uw << " g/cm2 ";
-		Output::Print(s1.str());
-		Output::End();
+	Output::Begin();
+	ostringstream s1;
+	s1 << " user defined water content : uh2o=" << setw(9) << uw << " g/cm2 ";
+	Output::Print(s1.str());
+	Output::End();
-		Output::Begin();
-		ostringstream s2;
-		s2 << " user defined ozone content : uo3 =" << setw(9) << uo3 << " cm-atm";
-		Output::Print(s2.str());
-		Output::End();
+	Output::Begin();
+	ostringstream s2;
+	s2 << " user defined ozone content : uo3 =" << setw(9) << uo3 << " cm-atm";
+	Output::Print(s2.str());
+	Output::End();
-	Output::Begin(); Output::End();
+    Output::Begin(); Output::End();
 AtmosModel AtmosModel::Parse()
-	AtmosModel atms;
-	atms.parse();
-	return atms;
+    AtmosModel atms;
+    atms.parse();
+    return atms;
Modified: grass/trunk/imagery/i.atcorr/GeomCond.cpp
--- grass/trunk/imagery/i.atcorr/GeomCond.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/GeomCond.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -36,23 +36,23 @@
 /*	To take into account the variation of the solar constant as a function
-	of the Julian day.
+  of the Julian day.
-	return dsol
-	dsol is a multiplicative factor to apply to the mean value of solar constant
+  return dsol
+  dsol is a multiplicative factor to apply to the mean value of solar constant
 float GeomCond::varsol ()
 /* calculation of the variability of the solar constant during the year.
    jday is the number of the day in the month   */
-  long int j;
-  if (month <= 2) j = (month - 1) * 31 + jday;
-  else if (month > 8) j = (month - 1) * 31 - (month - 2) / 2 - 2 + jday;
-  else j = (month - 1) * 31 - (month - 1) / 2 - 2 + jday;
+    long int j;
+    if (month <= 2) j = (month - 1) * 31 + jday;
+    else if (month > 8) j = (month - 1) * 31 - (month - 2) / 2 - 2 + jday;
+    else j = (month - 1) * 31 - (month - 1) / 2 - 2 + jday;
 /* Computing 2nd power */
-  double tmp = 1.f - cos ((float) (j - 4) * 0.9856f * M_PI / 180.f) * .01673f;
-  return 1.f / (float)(tmp * tmp);
+    double tmp = 1.f - cos ((float) (j - 4) * 0.9856f * M_PI / 180.f) * .01673f;
+    return 1.f / (float)(tmp * tmp);
@@ -61,41 +61,41 @@
 /*     warning !!! */
 /*     xlon and xlat are the coordinates of the scene center. */
-	avis = 0.f;
-	phiv = 0.f;
-	possol(tu);
+    avis = 0.f;
+    phiv = 0.f;
+    possol(tu);
-To compute the solar azimuthal and zenithal angles (in degrees) for a point over
-the globe defined by its longitude and its latitude (in dec. degrees) for a day of the year (fixed by
-number of the month and number of the day in the month) at any Greenwich Meridian Time (GMT
-dec. hour).
+  To compute the solar azimuthal and zenithal angles (in degrees) for a point over
+  the globe defined by its longitude and its latitude (in dec. degrees) for a day of the year (fixed by
+  number of the month and number of the day in the month) at any Greenwich Meridian Time (GMT
+  dec. hour).
 void GeomCond::possol(float tu)
-	long int ia = 0;
-	long int nojour;
+    long int ia = 0;
+    long int nojour;
 /*     solar position (zenithal angle asol,azimuthal angle phi0 */
 /*                     in degrees) */
 /*     jday is the number of the day in the month */
-	day_number(ia, nojour);
-	pos_fft (nojour, tu);
-	if (asol > 90.f) fprintf(stderr, "The sun is not raised\n");
+    day_number(ia, nojour);
+    pos_fft (nojour, tu);
+    if (asol > 90.f) fprintf(stderr, "The sun is not raised\n");
 void GeomCond::day_number(long int ia, long int& j)
-	if (month <= 2)
-		j = (month - 1) * 31 + jday;
-		return;
+    if (month <= 2)
+	j = (month - 1) * 31 + jday;
+	return;
-	if (month > 8) j = (month - 1) * 31 - (month - 2) / 2 - 2 + jday;
+    if (month > 8) j = (month - 1) * 31 - (month - 2) / 2 - 2 + jday;
-	if (ia != 0 && ia % 4 == 0) ++j;
+    if (ia != 0 && ia % 4 == 0) ++j;
 /* returns the sign of the element */
@@ -103,112 +103,112 @@
 void GeomCond::pos_fft (long int j, float tu)
-	/* Local variables */
-	double ah, et, az, caz, xla, tet, tsm, tsv, elev, azim, delta, amuzero;
+    /* Local variables */
+    double ah, et, az, caz, xla, tet, tsm, tsv, elev, azim, delta, amuzero;
-	/*     solar position (zenithal angle asol,azimuthal angle phi0 */
-	/*                     in degrees) */
-	/*     j is the day number in the year */
+    /*     solar position (zenithal angle asol,azimuthal angle phi0 */
+    /*                     in degrees) */
+    /*     j is the day number in the year */
-	/* mean solar time (heure decimale) */
-	tsm = tu + xlon / 15.;
-	xla = xlat * M_PI / 180.;
-	tet = (float)(j) * M_PI2 / 365.;
+    /* mean solar time (heure decimale) */
+    tsm = tu + xlon / 15.;
+    xla = xlat * M_PI / 180.;
+    tet = (float)(j) * M_PI2 / 365.;
-	/* time equation (in mn.dec) */
-	et = 7.5e-5f + 0.001868f * cos (tet) - 0.032077f * sin (tet) -
-		 0.014615f * cos (tet * 2.f) - 0.040849f * sin (tet * 2.f);
+    /* time equation (in mn.dec) */
+    et = 7.5e-5f + 0.001868f * cos (tet) - 0.032077f * sin (tet) -
+	0.014615f * cos (tet * 2.f) - 0.040849f * sin (tet * 2.f);
-	et = et * 12.f * 60.f / M_PI;
+    et = et * 12.f * 60.f / M_PI;
-	/* true solar time */
-	tsv = tsm + et / 60.f;
-	tsv += -12.f;
+    /* true solar time */
+    tsv = tsm + et / 60.f;
+    tsv += -12.f;
-	/* hour angle */
-	ah = tsv * 15.f * M_PI / 180.f;
+    /* hour angle */
+    ah = tsv * 15.f * M_PI / 180.f;
-	/* solar declination   (in radian) */
-	delta = 0.006918f - 0.399912f * cos (tet) + 0.070257f * sin (tet) -
-			0.006758f * cos (tet * 2.f) + 9.07e-4f * sin (tet * 2.f) -
-			0.002697f * cos (tet * 3.f) + 0.00148f * sin (tet * 3.f);
+    /* solar declination   (in radian) */
+    delta = 0.006918f - 0.399912f * cos (tet) + 0.070257f * sin (tet) -
+	0.006758f * cos (tet * 2.f) + 9.07e-4f * sin (tet * 2.f) -
+	0.002697f * cos (tet * 3.f) + 0.00148f * sin (tet * 3.f);
-	/* elevation,azimuth */
-	amuzero = sin (xla) * sin (delta) + cos (xla) * cos (delta) * cos (ah);
-	elev = asin (amuzero);
-	az = cos (delta) * sin (ah) / cos (elev);
+    /* elevation,azimuth */
+    amuzero = sin (xla) * sin (delta) + cos (xla) * cos (delta) * cos (ah);
+    elev = asin (amuzero);
+    az = cos (delta) * sin (ah) / cos (elev);
-	if (fabs (az) - 1.f > 0.f) az = SIGN(az);
+    if (fabs (az) - 1.f > 0.f) az = SIGN(az);
-	caz = (-cos (xla) * sin (delta) + sin (xla) * cos (delta) * cos (ah)) / cos (elev);
-	azim = asin (az);
-	if (caz <= 0.f) azim = M_PI - azim;
+    caz = (-cos (xla) * sin (delta) + sin (xla) * cos (delta) * cos (ah)) / cos (elev);
+    azim = asin (az);
+    if (caz <= 0.f) azim = M_PI - azim;
-	if (caz > 0.f && az <= 0.f) azim += M_PI2;
+    if (caz > 0.f && az <= 0.f) azim += M_PI2;
-	azim += M_PI;
-	if (azim > M_PI2) azim -= M_PI2;
+    azim += M_PI;
+    if (azim > M_PI2) azim -= M_PI2;
-	elev = elev * 180. / M_PI;
+    elev = elev * 180. / M_PI;
-	/*     conversion in degrees */
-	asol = (float)(90. - elev);
-	phi0 = (float)(azim * 180. / M_PI);
+    /*     conversion in degrees */
+    asol = (float)(90. - elev);
+    phi0 = (float)(azim * 180. / M_PI);
-convert:
-1 = meteosat observation
-2 = goes east observation
-3 = goes west observation
+  convert:
+  1 = meteosat observation
+  2 = goes east observation
+  3 = goes west observation
 void GeomCond::posobs(float tu, int nc, int nl)
-	double yr, xr, alti;
+    double yr, xr, alti;
-	if(igeom == 1) /* meteosat observation */
-		yr = nl - 1250.5;
-		xr = nc - 2500.5;
-		alti = 42164.0 - 6378.155;
-	else if(igeom == 2) /* goes east observation */
-		yr = nl - 8665.5;
-		xr = nc - 6498.5;
-		alti = 42107.0 - 6378.155;
-	else /* goes west observation */
-      yr = nl - 8665.5;
-      xr = nc - 6498.5;
-      alti = 42147.0 - 6378.155;
+    if(igeom == 1) /* meteosat observation */
+	yr = nl - 1250.5;
+	xr = nc - 2500.5;
+	alti = 42164.0 - 6378.155;
+    else if(igeom == 2) /* goes east observation */
+	yr = nl - 8665.5;
+	xr = nc - 6498.5;
+	alti = 42107.0 - 6378.155;
+    else /* goes west observation */
+	yr = nl - 8665.5;
+	xr = nc - 6498.5;
+	alti = 42147.0 - 6378.155;
-	const double re = 6378.155;
+    const double re = 6378.155;
     const double aaa = 1. / 297.;
     const double rp = re / (1.f + aaa);
     const double cdr = M_PI / 180.;
     const double crd = 180. / M_PI;
-	double deltax;
-	double deltay;
+    double deltax;
+    double deltay;
-	if(igeom == 1)
-		deltax = 18.0 / 5000.0;
-		deltay = 18.0 / 2500.0;
-	else
-		deltax = 18.0 / 12997.0;
-		deltay = 20.0 / 17331.0;
+    if(igeom == 1)
+	deltax = 18.0 / 5000.0;
+	deltay = 18.0 / 2500.0;
+    else
+	deltax = 18.0 / 12997.0;
+	deltay = 20.0 / 17331.0;
-	double x = xr * deltax * cdr;
+    double x = xr * deltax * cdr;
     double y = yr * deltay * cdr;
-	double rs = re + alti;
+    double rs = re + alti;
     double tanx = tan(x);
     double tany = tan(y);
     double val1 = 1.0 + (tanx * tanx);
@@ -216,184 +216,184 @@
     double yk = rs / re;
     double cosx2 = 1. / (val1 * val2);
-	double sn, zt, xt, yt, teta, ylat, ylon;
-	if((1. / cosx2) > ((yk * yk) / (yk*yk - 1.)))
-		fprintf(stderr, "no possibility to compute lat. and long.\n");
-		return;
-	else
-      sn = (rs - (re * (sqrt((yk * yk) - (yk*yk - 1.) * (1. / cosx2))))) / (1. / cosx2);
-      zt = rs - sn;
-      xt = -(sn * tanx);
-      yt = sn * tany / cos(x);
-      teta = asin(yt / rp);
-      ylat = (atan(((tan(teta)) * rp) / re));
-      ylon = atan(xt / zt);
+    double sn, zt, xt, yt, teta, ylat, ylon;
+    if((1. / cosx2) > ((yk * yk) / (yk*yk - 1.)))
+	fprintf(stderr, "no possibility to compute lat. and long.\n");
+	return;
+    else
+	sn = (rs - (re * (sqrt((yk * yk) - (yk*yk - 1.) * (1. / cosx2))))) / (1. / cosx2);
+	zt = rs - sn;
+	xt = -(sn * tanx);
+	yt = sn * tany / cos(x);
+	teta = asin(yt / rp);
+	ylat = (atan(((tan(teta)) * rp) / re));
+	ylon = atan(xt / zt);
-	xlat = (float)(ylat * crd);
+    xlat = (float)(ylat * crd);
-	if(igeom == 1) xlon = (float)(ylon * crd);
-	else if(igeom == 2) xlon = (float)(ylon * crd - 75.);
-	else xlon = (float)(ylon * crd - 135.);
+    if(igeom == 1) xlon = (float)(ylon * crd);
+    else if(igeom == 2) xlon = (float)(ylon * crd - 75.);
+    else xlon = (float)(ylon * crd - 135.);
-	possol(tu);
+    possol(tu);
-	if(igeom == 1) ylon = xlon * M_PI / 180.;
-	else if(igeom == 2) ylon = xlon * M_PI / 180. + 75. * cdr;
-	else ylon = xlon * M_PI / 180. + 135. * cdr;
+    if(igeom == 1) ylon = xlon * M_PI / 180.;
+    else if(igeom == 2) ylon = xlon * M_PI / 180. + 75. * cdr;
+    else ylon = xlon * M_PI / 180. + 135. * cdr;
-	ylat = xlat * M_PI / 180.;
-	double gam = sqrt(((1. / cosx2) - 1.) * cosx2);
-	avis = (float)(asin((1. + alti / re) * (gam)) * 180. / M_PI);
-	phiv = (float)((atan2(tan(ylon),sin(ylat)) + M_PI) * 180. / M_PI);
+    ylat = xlat * M_PI / 180.;
+    double gam = sqrt(((1. / cosx2) - 1.) * cosx2);
+    avis = (float)(asin((1. + alti / re) * (gam)) * 180. / M_PI);
+    phiv = (float)((atan2(tan(ylon),sin(ylat)) + M_PI) * 180. / M_PI);
 void GeomCond::posnoa(float tu, int nc, float xlonan, float campm, float hna)
 /*     noaa 6 definition
-     orbite inclination ai in radians
-     hor mouv in rad/s  an
-     h/r=860/6378
-     campm allows the user to switch to pm platforms */
+       orbite inclination ai in radians
+       hor mouv in rad/s  an
+       h/r=860/6378
+       campm allows the user to switch to pm platforms */
-      const double r = 860. / 6378.155;
-      const double ai = 98.96 * M_PI / 180.;
-      const double an = 360. * M_PI / (6119. * 180.);
-      double ylonan = xlonan * M_PI / 180.;
-      double t = tu * 3600;
-      double hnam = hna;
-      hnam = hnam * 3600;
-      double u = t - hnam;
-      u = campm * u * an;
-      double delt = ((nc - (2048 + 1) / 2.) * 55.385 / ((2048. - 1) / 2.));
-      delt = campm * delt * M_PI / 180.;
-      avis = (float)asin((1 + r) * sin(delt));
-      double d = avis - delt;
-      double y = cos(d) * cos(ai) * sin(u) - sin(ai) * sin(d);
-      double z = cos(d) * sin(ai) * sin(u) + cos(ai) * sin(d);
-      double ylat = asin(z);
-      double cosy = cos(d) * cos(u) / cos(ylat);
+    const double r = 860. / 6378.155;
+    const double ai = 98.96 * M_PI / 180.;
+    const double an = 360. * M_PI / (6119. * 180.);
+    double ylonan = xlonan * M_PI / 180.;
+    double t = tu * 3600;
+    double hnam = hna;
+    hnam = hnam * 3600;
+    double u = t - hnam;
+    u = campm * u * an;
+    double delt = ((nc - (2048 + 1) / 2.) * 55.385 / ((2048. - 1) / 2.));
+    delt = campm * delt * M_PI / 180.;
+    avis = (float)asin((1 + r) * sin(delt));
+    double d = avis - delt;
+    double y = cos(d) * cos(ai) * sin(u) - sin(ai) * sin(d);
+    double z = cos(d) * sin(ai) * sin(u) + cos(ai) * sin(d);
+    double ylat = asin(z);
+    double cosy = cos(d) * cos(u) / cos(ylat);
-      double siny = y / cos(ylat);
-      double ylon = asin(siny);
-      if(cosy <= 0.)
-		if(siny > 0) ylon = M_PI - ylon;
-		if(siny <= 0) ylon = -(M_PI + ylon);
-      double ylo1 = ylon + ylonan - (t - hnam) * 2. * M_PI / 86400.;
-      xlat = (float)(ylat * 180. / M_PI);
-      xlon = (float)(ylo1 * 180. / M_PI);
+    double siny = y / cos(ylat);
+    double ylon = asin(siny);
+    if(cosy <= 0.)
+	if(siny > 0) ylon = M_PI - ylon;
+	if(siny <= 0) ylon = -(M_PI + ylon);
+    double ylo1 = ylon + ylonan - (t - hnam) * 2. * M_PI / 86400.;
+    xlat = (float)(ylat * 180. / M_PI);
+    xlon = (float)(ylo1 * 180. / M_PI);
-      possol(tu);
+    possol(tu);
-      double zlat = asin(sin(ai) * sin(u));
-      double zlon = atan2(cos(ai) * sin(u),cos(u));
-      if(nc != 1024)
-		double xnum = sin(zlon - ylon) * cos(zlat) / sin(fabs(d));
-		double xden = (sin(zlat) - sin(ylat) * cos(d)) / cos(ylat) / sin(fabs(d));
-		phiv = (float)atan2(xnum,xden);
-      else phiv = 0.;
-      phiv = (float)(phiv * 180. / M_PI);
-      avis = (float)(fabs(avis) * 180. / M_PI);
+    double zlat = asin(sin(ai) * sin(u));
+    double zlon = atan2(cos(ai) * sin(u),cos(u));
+    if(nc != 1024)
+	double xnum = sin(zlon - ylon) * cos(zlat) / sin(fabs(d));
+	double xden = (sin(zlat) - sin(ylat) * cos(d)) / cos(ylat) / sin(fabs(d));
+	phiv = (float)atan2(xnum,xden);
+    else phiv = 0.;
+    phiv = (float)(phiv * 180. / M_PI);
+    avis = (float)(fabs(avis) * 180. / M_PI);
 void GeomCond::parse()
-	cin >> igeom;
+    cin >> igeom;
-	float campm = -1.0f;	/* initialize in case igeom == 5 */
-	float tu, xlonan, hna;
-	int nc, nl;
+    float campm = -1.0f;	/* initialize in case igeom == 5 */
+    float tu, xlonan, hna;
+    int nc, nl;
-	switch(igeom)
-	case 0: /* internal format */
-			cin >> asol;
-			cin >> phi0;
-			cin >> avis;
-			cin >> phiv;
-			cin >> month;
-			cin >> jday;
-			break;
-	case 1: /* meteosat observation */
-	case 2: /* goes east observation */
-	case 3: /* goes west observation  */
-			cin >> month;
-			cin >> jday;
-			cin >> tu;
-			cin >> nc;
-			cin >> nl;
-			posobs(tu, nc, nl);
-			break;
-	case 4: campm = 1.0f;
-	case 5:
-			cin >> month;
-			cin >> jday;
-			cin >> tu;
-			cin >> nc;
-			cin >> xlonan;
-			cin >> hna;
-			posnoa(tu, nc, xlonan, campm, hna);
-			break;
-	case 6: /* hrv   ( spot )    * enter month,day,hh.ddd,long.,lat. */
-	case 7: /* tm    ( landsat ) * enter month,day,hh.ddd,long.,lat. */
-	case 8: /* etm+  ( landsat7) * enter month,day,hh.ddd,long.,lat. */
-			cin >> month;
-			cin >> jday;
-			cin >> tu;
-			cin >> xlon;
-			cin >> xlat;
-			landsat(tu);
-			break;
-	default: fprintf(stderr, "Unsupported format.\n");
+    switch(igeom)
+    case 0: /* internal format */
+	cin >> asol;
+	cin >> phi0;
+	cin >> avis;
+	cin >> phiv;
+	cin >> month;
+	cin >> jday;
+	break;
+    case 1: /* meteosat observation */
+    case 2: /* goes east observation */
+    case 3: /* goes west observation  */
+	cin >> month;
+	cin >> jday;
+	cin >> tu;
+	cin >> nc;
+	cin >> nl;
+	posobs(tu, nc, nl);
+	break;
+    case 4: campm = 1.0f;
+    case 5:
+	cin >> month;
+	cin >> jday;
+	cin >> tu;
+	cin >> nc;
+	cin >> xlonan;
+	cin >> hna;
+	posnoa(tu, nc, xlonan, campm, hna);
+	break;
+    case 6: /* hrv   ( spot )    * enter month,day,hh.ddd,long.,lat. */
+    case 7: /* tm    ( landsat ) * enter month,day,hh.ddd,long.,lat. */
+    case 8: /* etm+  ( landsat7) * enter month,day,hh.ddd,long.,lat. */
+	cin >> month;
+	cin >> jday;
+	cin >> tu;
+	cin >> xlon;
+	cin >> xlat;
+	landsat(tu);
+	break;
+    default: fprintf(stderr, "Unsupported format.\n");
-	/*                                 / scattered direction                  */
-	/*                           / adif                                       */
-	/*    incident   + + + + + + + + + + + + + + +                            */
-	/*    direction                                                           */
-	phi = (float)fabs(phiv - phi0);
-	phirad = (phi0 - phiv) * (float)M_PI / 180.f;
-	if (phirad < 0.f) phirad += (float)M_PI2;
-	if (phirad > M_PI2) phirad -= (float)M_PI2;
+    /*                                 / scattered direction                  */
+    /*                           / adif                                       */
+    /*    incident   + + + + + + + + + + + + + + +                            */
+    /*    direction                                                           */
+    phi = (float)fabs(phiv - phi0);
+    phirad = (phi0 - phiv) * (float)M_PI / 180.f;
+    if (phirad < 0.f) phirad += (float)M_PI2;
+    if (phirad > M_PI2) phirad -= (float)M_PI2;
-	xmus = (float)cos (asol * M_PI / 180.f);
-	xmuv = (float)cos (avis * M_PI / 180.f);
-	xmup = (float)cos (phirad);
-	xmud = -xmus * xmuv - (float)sqrt (1.f - xmus * xmus) * (float)sqrt (1.f - xmuv * xmuv) * xmup;
+    xmus = (float)cos (asol * M_PI / 180.f);
+    xmuv = (float)cos (avis * M_PI / 180.f);
+    xmup = (float)cos (phirad);
+    xmud = -xmus * xmuv - (float)sqrt (1.f - xmus * xmus) * (float)sqrt (1.f - xmuv * xmuv) * xmup;
-	/* test vermote bug */
-	if (xmud > 1.f)  xmud = 1.f;
-	if (xmud < -1.f) xmud = -1.f;
-	adif = (float)acos (xmud) * 180.f / (float)M_PI;
+    /* test vermote bug */
+    if (xmud > 1.f)  xmud = 1.f;
+    if (xmud < -1.f) xmud = -1.f;
+    adif = (float)acos (xmud) * 180.f / (float)M_PI;
     dsol = varsol();
@@ -401,75 +401,75 @@
 /* ---- print geometrical conditions ---- */
 void GeomCond::print()
-	static const string etiq1[9] = {
-     string(" user defined conditions     "),
-     string(" meteosat observation        "),
-     string(" goes east observation       "),
-     string(" goes west observation       "),
-     string(" avhrr (AM noaa) observation "),
-     string(" avhrr (PM noaa) observation "),
-     string(" h.r.v.   observation        "),
-     string(" t.m.     observation        "),
-     string(" etm+     observation        ")
+    static const string etiq1[9] = {
+	string(" user defined conditions     "),
+	string(" meteosat observation        "),
+	string(" goes east observation       "),
+	string(" goes west observation       "),
+	string(" avhrr (AM noaa) observation "),
+	string(" avhrr (PM noaa) observation "),
+	string(" h.r.v.   observation        "),
+	string(" t.m.     observation        "),
+	string(" etm+     observation        ")
-	static const string head(" geometrical conditions identity  ");
-	static const string line(" -------------------------------  ");
+    static const string head(" geometrical conditions identity  ");
+    static const string line(" -------------------------------  ");
-	Output::Begin(); Output::Repeat(22,' '); Output::Print(etiq1[igeom]); Output::End();
+    Output::Begin(); Output::Repeat(22,' '); Output::Print(etiq1[igeom]); Output::End();
-	Output::Begin(); Output::Repeat(2,' ');
-	ostringstream s1;
-	s1 << " month: " << month << " day: " << jday;
-	s1 << ends;
-	Output::End();
+    Output::Begin(); Output::Repeat(2,' ');
+    ostringstream s1;
+    s1 << " month: " << month << " day: " << jday;
+    s1 << ends;
+    Output::End();
-	ostringstream s2;
-	s2 << setprecision(2);
+    ostringstream s2;
+    s2 << setprecision(2);
-	s2 << " solar zenith angle:  " << setw(6) << asol << " deg ";
-	s2 << " solar azimuthal angle:      " << setw(6) << phi0 << " deg";
-	s2 << ends;
-	Output::End();
+    s2 << " solar zenith angle:  " << setw(6) << asol << " deg ";
+    s2 << " solar azimuthal angle:      " << setw(6) << phi0 << " deg";
+    s2 << ends;
+    Output::End();
-	ostringstream s3;
-	s3 << setprecision(2);
-	s3 << " view zenith angle:   " << setw(6) << avis << " deg ";
-	s3 << " view azimuthal angle:       " << setw(6) << phiv << " deg ";
-	s3 << ends;
-	Output::End();
-	ostringstream s4;
-	s4 << setprecision(2);
-	s4 << " scattering angle:    " << setw(6) << adif << " deg ";
-	s4 << " azimuthal angle difference: " << setw(6) << phi << " deg ";
-	s4 << ends;
-	Output::Print(s4.str());
-	Output::End();
+    ostringstream s3;
+    s3 << setprecision(2);
+    s3 << " view zenith angle:   " << setw(6) << avis << " deg ";
+    s3 << " view azimuthal angle:       " << setw(6) << phiv << " deg ";
+    s3 << ends;
+    Output::End();
+    ostringstream s4;
+    s4 << setprecision(2);
+    s4 << " scattering angle:    " << setw(6) << adif << " deg ";
+    s4 << " azimuthal angle difference: " << setw(6) << phi << " deg ";
+    s4 << ends;
+    Output::Print(s4.str());
+    Output::End();
 GeomCond GeomCond::Parse()
-	GeomCond geom;
-	geom.parse();
-	return geom;
+    GeomCond geom;
+    geom.parse();
+    return geom;
Modified: grass/trunk/imagery/i.atcorr/Interp.cpp
--- grass/trunk/imagery/i.atcorr/Interp.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/Interp.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -2,202 +2,202 @@
 #include "Interp.h"
 void interp (const int iaer, const int idatmp,
-			 const float wl, const float taer55,
-			 const float taer55p, const float xmud,
-			 InterpStruct& is)
+	     const float wl, const float taer55,
+	     const float taer55p, const float xmud,
+	     InterpStruct& is)
 /*     that for the atmosphere :
-     the reflectances
-                     rayleigh                             = rorayl
-                     aerosols                             = roaero
-                     mixing                               = romix
-     the downward transmittances
-                     rayleigh                             = dtotr
-                     aerosols                             = dtota
-                     total                                = dtott
-     the upward transmittances
-                     rayleigh                             = utotr
-                     aerosols                             = utota
-                     total                                = utott
-     the spherical albedos
-                     rayleigh                             = asray
-                     aerosols                             = asaer
-                     total                                = astot
-     the optical thickness of total atmosphere
-                     rayleigh                             = tray
-                     aerosols                             = taer
-     the optical thickness of the atmosphere above the plane
-                     rayleigh                             = is.trayp
-                     aerosols                             = taerp
-     the tsca of the aerosols (god dammed it)
-                     total atmosphere                     = tsca */
+       the reflectances
+       rayleigh                             = rorayl
+       aerosols                             = roaero
+       mixing                               = romix
+       the downward transmittances
+       rayleigh                             = dtotr
+       aerosols                             = dtota
+       total                                = dtott
+       the upward transmittances
+       rayleigh                             = utotr
+       aerosols                             = utota
+       total                                = utott
+       the spherical albedos
+       rayleigh                             = asray
+       aerosols                             = asaer
+       total                                = astot
+       the optical thickness of total atmosphere
+       rayleigh                             = tray
+       aerosols                             = taer
+       the optical thickness of the atmosphere above the plane
+       rayleigh                             = is.trayp
+       aerosols                             = taerp
+       the tsca of the aerosols (god dammed it)
+       total atmosphere                     = tsca */
-	int linf = 0;
-	for(int i = 0; i < 9; i++) if(wl > sixs_disc.wldis[i] && wl <= sixs_disc.wldis[i+1]) linf = i;
+    int linf = 0;
+    for(int i = 0; i < 9; i++) if(wl > sixs_disc.wldis[i] && wl <= sixs_disc.wldis[i+1]) linf = i;
     if(wl > sixs_disc.wldis[9]) linf = 8;
-	int lsup = linf + 1;
+    int lsup = linf + 1;
-	/*    interpolation in function of wavelength for scattering
-	    atmospheric functions from discrete values at sixs_disc.wldis */
+    /*    interpolation in function of wavelength for scattering
+	  atmospheric functions from discrete values at sixs_disc.wldis */
-	float alphaa = 0;
-	float betaa = 0;
-	float alphar = 0;
-	float betar = 0;
-	float alphac = 0;
-	float betac = 0;
-	is.phaa = 0;
-	is.roaero = 0;
-	is.dtota = 1;
-	is.utota = 1;
-	is.asaer = 0;
-	is.taer = 0;
-	is.taerp = 0;
-	float coef = (float)log(sixs_disc.wldis[lsup] / sixs_disc.wldis[linf]);
+    float alphaa = 0;
+    float betaa = 0;
+    float alphar = 0;
+    float betar = 0;
+    float alphac = 0;
+    float betac = 0;
+    is.phaa = 0;
+    is.roaero = 0;
+    is.dtota = 1;
+    is.utota = 1;
+    is.asaer = 0;
+    is.taer = 0;
+    is.taerp = 0;
+    float coef = (float)log(sixs_disc.wldis[lsup] / sixs_disc.wldis[linf]);
     float wlinf = sixs_disc.wldis[linf];
     if(iaer != 0)
-		alphaa = (float)(log(sixs_aer.phase[lsup] / sixs_aer.phase[linf]) / coef);
-		betaa = (float)(sixs_aer.phase[linf] / pow(wlinf,alphaa));
-		is.phaa = (float)(betaa * pow(wl,alphaa));
+	alphaa = (float)(log(sixs_aer.phase[lsup] / sixs_aer.phase[linf]) / coef);
+	betaa = (float)(sixs_aer.phase[linf] / pow(wlinf,alphaa));
+	is.phaa = (float)(betaa * pow(wl,alphaa));
-	float d2 = 2 + delta;
+    float d2 = 2 + delta;
     is.phar = (2 * (1 - delta) / d2) * .75f * (1 + xmud * xmud) + 3 * delta / d2;
-	if(idatmp == 0)
-		betar = 0;
+    if(idatmp == 0)
+	betar = 0;
         betaa = 0;
         betac = 0;
+    else
+	if(sixs_disc.roatm[0][linf] < 0.001)
+	    is.rorayl = sixs_disc.roatm[0][linf] + (sixs_disc.roatm[0][lsup] - sixs_disc.roatm[0][linf])
+		* (wl - sixs_disc.wldis[linf]) / (sixs_disc.wldis[lsup] - sixs_disc.wldis[linf]);
 	else
-		if(sixs_disc.roatm[0][linf] < 0.001)
-			is.rorayl = sixs_disc.roatm[0][linf] + (sixs_disc.roatm[0][lsup] - sixs_disc.roatm[0][linf])
-				   * (wl - sixs_disc.wldis[linf]) / (sixs_disc.wldis[lsup] - sixs_disc.wldis[linf]);
-		else
-			alphar = (float)(log(sixs_disc.roatm[0][lsup] / sixs_disc.roatm[0][linf]) / coef);
-			betar = (float)(sixs_disc.roatm[0][linf] / pow(wlinf,alphar));
-			is.rorayl = (float)(betar * pow(wl,alphar));
+	    alphar = (float)(log(sixs_disc.roatm[0][lsup] / sixs_disc.roatm[0][linf]) / coef);
+	    betar = (float)(sixs_disc.roatm[0][linf] / pow(wlinf,alphar));
+	    is.rorayl = (float)(betar * pow(wl,alphar));
-		if(sixs_disc.roatm[1][linf] < 0.001)
-			is.romix = sixs_disc.roatm[1][linf] + (sixs_disc.roatm[1][lsup] - sixs_disc.roatm[1][linf])
+	if(sixs_disc.roatm[1][linf] < 0.001)
+	    is.romix = sixs_disc.roatm[1][linf] + (sixs_disc.roatm[1][lsup] - sixs_disc.roatm[1][linf])
         else
-			alphac = (float)(log(sixs_disc.roatm[1][lsup] / sixs_disc.roatm[1][linf]) / coef);
-			betac = (float)(sixs_disc.roatm[1][linf] / pow(wlinf,alphac));
-			is.romix = (float)(betac * pow(wl,alphac));
+	    alphac = (float)(log(sixs_disc.roatm[1][lsup] / sixs_disc.roatm[1][linf]) / coef);
+	    betac = (float)(sixs_disc.roatm[1][linf] / pow(wlinf,alphac));
+	    is.romix = (float)(betac * pow(wl,alphac));
-		if(iaer != 0)
+	if(iaer != 0)
-			if(sixs_disc.roatm[2][linf] < 0.001)
-				is.roaero = sixs_disc.roatm[2][linf]+(sixs_disc.roatm[2][lsup] - sixs_disc.roatm[2][linf])
-			else
-				alphaa = (float)(log(sixs_disc.roatm[2][lsup] / sixs_disc.roatm[2][linf]) / coef);
-				betaa = (float)(sixs_disc.roatm[2][linf] / pow(wlinf,alphaa));
-				is.roaero = (float)(betaa * pow(wl,alphaa));
+	    if(sixs_disc.roatm[2][linf] < 0.001)
+		is.roaero = sixs_disc.roatm[2][linf]+(sixs_disc.roatm[2][lsup] - sixs_disc.roatm[2][linf])
+	    else
+		alphaa = (float)(log(sixs_disc.roatm[2][lsup] / sixs_disc.roatm[2][linf]) / coef);
+		betaa = (float)(sixs_disc.roatm[2][linf] / pow(wlinf,alphaa));
+		is.roaero = (float)(betaa * pow(wl,alphaa));
-	alphar = (float)(log(sixs_disc.trayl[lsup] / sixs_disc.trayl[linf]) / coef);
+    alphar = (float)(log(sixs_disc.trayl[lsup] / sixs_disc.trayl[linf]) / coef);
     betar = (float)(sixs_disc.trayl[linf] / pow(wlinf,alphar));
     is.tray = (float)(betar * pow(wl,alphar));
-	if (idatmp != 0)
-		alphar = (float)(log(sixs_disc.traypl[lsup] / sixs_disc.traypl[linf]) / coef);
+    if (idatmp != 0)
+	alphar = (float)(log(sixs_disc.traypl[lsup] / sixs_disc.traypl[linf]) / coef);
         betar = (float)(sixs_disc.traypl[linf] / pow(wlinf,alphar));
         is.trayp = (float)(betar * pow(wl,alphar));
     else is.trayp = 0;
-	if(iaer != 0)
-		alphaa = (float)(log(sixs_aer.ext[lsup] * sixs_aer.ome[lsup] / (sixs_aer.ext[linf] * sixs_aer.ome[linf])) / coef);
-		betaa = (float)(sixs_aer.ext[linf] * sixs_aer.ome[linf] / pow(wlinf,alphaa));
-		is.tsca = (float)(taer55 * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
-		alphaa = (float)(log(sixs_aer.ext[lsup] / sixs_aer.ext[linf]) / coef);
-		betaa = (float)(sixs_aer.ext[linf] / pow(wlinf,alphaa));
-		is.taerp = (float)(taer55p * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
-		is.taer = (float)(taer55 * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
+    if(iaer != 0)
+	alphaa = (float)(log(sixs_aer.ext[lsup] * sixs_aer.ome[lsup] / (sixs_aer.ext[linf] * sixs_aer.ome[linf])) / coef);
+	betaa = (float)(sixs_aer.ext[linf] * sixs_aer.ome[linf] / pow(wlinf,alphaa));
+	is.tsca = (float)(taer55 * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
+	alphaa = (float)(log(sixs_aer.ext[lsup] / sixs_aer.ext[linf]) / coef);
+	betaa = (float)(sixs_aer.ext[linf] / pow(wlinf,alphaa));
+	is.taerp = (float)(taer55p * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
+	is.taer = (float)(taer55 * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
-	float drinf = sixs_disc.dtdif[0][linf] + sixs_disc.dtdir[0][linf];
-	float drsup = sixs_disc.dtdif[0][lsup] + sixs_disc.dtdir[0][lsup];
-	alphar = (float)(log(drsup / drinf) / coef);
-	betar = (float)(drinf / pow(wlinf,alphar));
-	is.dtotr = (float)(betar * pow(wl,alphar));
-	float dtinf = sixs_disc.dtdif[1][linf] + sixs_disc.dtdir[1][linf];
-	float dtsup = sixs_disc.dtdif[1][lsup] + sixs_disc.dtdir[1][lsup];
-	alphac = (float)(log((dtsup * drinf) / (dtinf * drsup)) / coef);
-	betac = (float)((dtinf / drinf) / pow(wlinf,alphac));
-	float dtotc = (float)(betac * pow(wl,alphac));
-	float dainf = sixs_disc.dtdif[2][linf] + sixs_disc.dtdir[2][linf];
-	float dasup = sixs_disc.dtdif[2][lsup] + sixs_disc.dtdir[2][lsup];
+    float drinf = sixs_disc.dtdif[0][linf] + sixs_disc.dtdir[0][linf];
+    float drsup = sixs_disc.dtdif[0][lsup] + sixs_disc.dtdir[0][lsup];
+    alphar = (float)(log(drsup / drinf) / coef);
+    betar = (float)(drinf / pow(wlinf,alphar));
+    is.dtotr = (float)(betar * pow(wl,alphar));
+    float dtinf = sixs_disc.dtdif[1][linf] + sixs_disc.dtdir[1][linf];
+    float dtsup = sixs_disc.dtdif[1][lsup] + sixs_disc.dtdir[1][lsup];
+    alphac = (float)(log((dtsup * drinf) / (dtinf * drsup)) / coef);
+    betac = (float)((dtinf / drinf) / pow(wlinf,alphac));
+    float dtotc = (float)(betac * pow(wl,alphac));
+    float dainf = sixs_disc.dtdif[2][linf] + sixs_disc.dtdir[2][linf];
+    float dasup = sixs_disc.dtdif[2][lsup] + sixs_disc.dtdir[2][lsup];
-	if(iaer != 0)
-		alphaa = (float)(log(dasup / dainf) / coef);
-		betaa = (float)(dainf / pow(wlinf,alphaa));
-		is.dtota = (float)(betaa * pow(wl,alphaa));
+    if(iaer != 0)
+	alphaa = (float)(log(dasup / dainf) / coef);
+	betaa = (float)(dainf / pow(wlinf,alphaa));
+	is.dtota = (float)(betaa * pow(wl,alphaa));
-	is.dtott = dtotc * is.dtotr;
-	float urinf = sixs_disc.utdif[0][linf] + sixs_disc.utdir[0][linf];
-	float ursup = sixs_disc.utdif[0][lsup] + sixs_disc.utdir[0][lsup];
-	alphar = (float)(log(ursup / urinf) / coef);
-	betar = (float)(urinf / pow(wlinf,alphar));
-	is.utotr = (float)(betar * pow(wl,alphar));
-	float utinf = sixs_disc.utdif[1][linf] + sixs_disc.utdir[1][linf];
-	float utsup = sixs_disc.utdif[1][lsup] + sixs_disc.utdir[1][lsup];
-	alphac = (float)(log((utsup * urinf) / (utinf * ursup)) / coef);
-	betac = (float)((utinf / urinf) / pow(wlinf,alphac));
-	float utotc = (float)(betac * pow(wl,alphac));
-	float uainf = sixs_disc.utdif[2][linf] + sixs_disc.utdir[2][linf];
-	float uasup = sixs_disc.utdif[2][lsup] + sixs_disc.utdir[2][lsup];
-	is.utott = utotc * is.utotr;
+    is.dtott = dtotc * is.dtotr;
+    float urinf = sixs_disc.utdif[0][linf] + sixs_disc.utdir[0][linf];
+    float ursup = sixs_disc.utdif[0][lsup] + sixs_disc.utdir[0][lsup];
+    alphar = (float)(log(ursup / urinf) / coef);
+    betar = (float)(urinf / pow(wlinf,alphar));
+    is.utotr = (float)(betar * pow(wl,alphar));
+    float utinf = sixs_disc.utdif[1][linf] + sixs_disc.utdir[1][linf];
+    float utsup = sixs_disc.utdif[1][lsup] + sixs_disc.utdir[1][lsup];
+    alphac = (float)(log((utsup * urinf) / (utinf * ursup)) / coef);
+    betac = (float)((utinf / urinf) / pow(wlinf,alphac));
+    float utotc = (float)(betac * pow(wl,alphac));
+    float uainf = sixs_disc.utdif[2][linf] + sixs_disc.utdir[2][linf];
+    float uasup = sixs_disc.utdif[2][lsup] + sixs_disc.utdir[2][lsup];
+    is.utott = utotc * is.utotr;
-	if(iaer != 0)
-		alphaa = (float)(log(uasup / uainf) / coef);
-		betaa = (float)(uainf / pow(wlinf,alphaa));
-		is.utota = (float)(betaa * pow(wl,alphaa));
+    if(iaer != 0)
+	alphaa = (float)(log(uasup / uainf) / coef);
+	betaa = (float)(uainf / pow(wlinf,alphaa));
+	is.utota = (float)(betaa * pow(wl,alphaa));
-	float arinf = sixs_disc.sphal[0][linf];
-	float arsup = sixs_disc.sphal[0][lsup];
-	alphar = (float)(log(arsup / arinf) / coef);
-	betar = (float)(arinf / pow(wlinf,alphar));
-	is.asray = (float)(betar * pow(wl,alphar));
-	float atinf = sixs_disc.sphal[1][linf];
-	float atsup = sixs_disc.sphal[1][lsup];
-	alphac = (float)(log(atsup / atinf) / coef);
-	betac = (float)(atinf / pow(wlinf,alphac));
-	is.astot = (float)(betac * pow(wl,alphac));
-	float aainf = sixs_disc.sphal[2][linf];
-	float aasup = sixs_disc.sphal[2][lsup];
+    float arinf = sixs_disc.sphal[0][linf];
+    float arsup = sixs_disc.sphal[0][lsup];
+    alphar = (float)(log(arsup / arinf) / coef);
+    betar = (float)(arinf / pow(wlinf,alphar));
+    is.asray = (float)(betar * pow(wl,alphar));
+    float atinf = sixs_disc.sphal[1][linf];
+    float atsup = sixs_disc.sphal[1][lsup];
+    alphac = (float)(log(atsup / atinf) / coef);
+    betac = (float)(atinf / pow(wlinf,alphac));
+    is.astot = (float)(betac * pow(wl,alphac));
+    float aainf = sixs_disc.sphal[2][linf];
+    float aasup = sixs_disc.sphal[2][lsup];
-	if(iaer != 0)
-		alphaa = (float)(log(aasup / aainf) / coef);
-		betaa = (float)(aainf / pow(wlinf,alphaa));
-		is.asaer = (float)(betaa * pow(wl,alphaa));
+    if(iaer != 0)
+	alphaa = (float)(log(aasup / aainf) / coef);
+	betaa = (float)(aainf / pow(wlinf,alphaa));
+	is.asaer = (float)(betaa * pow(wl,alphaa));
Modified: grass/trunk/imagery/i.atcorr/Iwave.cpp
--- grass/trunk/imagery/i.atcorr/Iwave.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/Iwave.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -5,1564 +5,1564 @@
 #pragma warning(disable:4305)	/* disable warning about initialization of a float by a double */
 #endif
-    spectral band of meteosat
+  spectral band of meteosat
 void IWave::meteo()
-	static const float sr[305] = {
-	    .00,    .00,    .00,    .01,    .01,    .01,    .02,
-	    .02,    .02,    .02,    .02,    .02,    .03,    .03,
-	    .04,    .04,    .04,    .05,    .05,    .05,    .06,
-	    .06,    .07,    .07,    .07,    .08,    .08,    .09,
-	    .09,    .10,    .10,    .10,    .11,    .11,    .12,
-	    .12,    .12,    .13,    .14,    .14,    .15,    .15,
-	    .16,    .16,    .17,    .17,    .18,    .18,    .19,
-	    .20,    .20,    .21,    .21,    .22,    .23,    .24,
-	    .24,    .25,    .26,    .27,    .28,    .28,    .29,
-	    .30,    .30,    .31,    .32,    .33,    .34,    .35,
-	    .35,    .36,    .37,    .38,    .39,    .40,    .40,
-	    .41,    .42,    .43,    .44,    .45,    .46,    .48,
-	    .49,    .50,    .51,    .52,    .53,    .55,    .56,
-	    .57,    .58,    .60,    .61,    .62,    .63,    .64,
-	    .65,    .65,    .66,    .67,    .67,    .68,    .69,
-	    .69,    .70,    .71,    .71,    .72,    .73,    .73,
-	    .74,    .76,    .77,    .78,    .78,    .79,    .80,
-	    .81,    .82,    .83,    .84,    .85,    .86,    .87,
-	    .88,    .89,    .89,    .91,    .92,    .93,    .94,
-	    .95,    .96,    .96,    .97,    .98,    .98,    .99,
-	    .99,    .99,    .99,   1.00,   1.00,   1.00,   1.00,
-	   1.00,   1.00,   1.00,   1.00,   1.00,   1.00,    .99,
-	    .99,    .99,    .99,    .98,    .98,    .98,    .98,
-	    .98,    .97,    .97,    .97,    .97,    .97,    .97,
-	    .97,    .96,    .96,    .96,    .96,    .96,    .96,
-	    .96,    .96,    .96,    .96,    .95,    .95,    .95,
-	    .94,    .93,    .93,    .92,    .92,    .91,    .90,
-	    .89,    .89,    .88,    .88,    .87,    .86,    .86,
-	    .85,    .85,    .84,    .84,    .83,    .82,    .82,
-	    .81,    .80,    .80,    .79,    .79,    .78,    .77,
-	    .77,    .76,    .76,    .75,    .75,    .74,    .74,
-	    .74,    .73,    .73,    .72,    .71,    .70,    .68,
-	    .67,    .65,    .64,    .63,    .62,    .61,    .60,
-	    .59,    .58,    .57,    .56,    .55,    .54,    .53,
-	    .52,    .51,    .50,    .49,    .49,    .48,    .47,
-	    .46,    .45,    .43,    .42,    .41,    .40,    .39,
-	    .38,    .37,    .36,    .35,    .34,    .33,    .31,
-	    .30,    .29,    .28,    .28,    .27,    .25,    .24,
-	    .23,    .22,    .21,    .20,    .19,    .18,    .17,
-	    .16,    .15,    .14,    .13,    .12,    .11,    .11,
-	    .10,    .09,    .08,    .08,    .08,    .07,    .06,
-	    .06,    .05,    .05,    .05,    .04,    .04,    .03,
-	    .03,    .02,    .02,    .01,    .01,    .01,    .01,
-		.01,    .00,    .00,    .00 };
+    static const float sr[305] = {
+	.00,    .00,    .00,    .01,    .01,    .01,    .02,
+	.02,    .02,    .02,    .02,    .02,    .03,    .03,
+	.04,    .04,    .04,    .05,    .05,    .05,    .06,
+	.06,    .07,    .07,    .07,    .08,    .08,    .09,
+	.09,    .10,    .10,    .10,    .11,    .11,    .12,
+	.12,    .12,    .13,    .14,    .14,    .15,    .15,
+	.16,    .16,    .17,    .17,    .18,    .18,    .19,
+	.20,    .20,    .21,    .21,    .22,    .23,    .24,
+	.24,    .25,    .26,    .27,    .28,    .28,    .29,
+	.30,    .30,    .31,    .32,    .33,    .34,    .35,
+	.35,    .36,    .37,    .38,    .39,    .40,    .40,
+	.41,    .42,    .43,    .44,    .45,    .46,    .48,
+	.49,    .50,    .51,    .52,    .53,    .55,    .56,
+	.57,    .58,    .60,    .61,    .62,    .63,    .64,
+	.65,    .65,    .66,    .67,    .67,    .68,    .69,
+	.69,    .70,    .71,    .71,    .72,    .73,    .73,
+	.74,    .76,    .77,    .78,    .78,    .79,    .80,
+	.81,    .82,    .83,    .84,    .85,    .86,    .87,
+	.88,    .89,    .89,    .91,    .92,    .93,    .94,
+	.95,    .96,    .96,    .97,    .98,    .98,    .99,
+	.99,    .99,    .99,   1.00,   1.00,   1.00,   1.00,
+	1.00,   1.00,   1.00,   1.00,   1.00,   1.00,    .99,
+	.99,    .99,    .99,    .98,    .98,    .98,    .98,
+	.98,    .97,    .97,    .97,    .97,    .97,    .97,
+	.97,    .96,    .96,    .96,    .96,    .96,    .96,
+	.96,    .96,    .96,    .96,    .95,    .95,    .95,
+	.94,    .93,    .93,    .92,    .92,    .91,    .90,
+	.89,    .89,    .88,    .88,    .87,    .86,    .86,
+	.85,    .85,    .84,    .84,    .83,    .82,    .82,
+	.81,    .80,    .80,    .79,    .79,    .78,    .77,
+	.77,    .76,    .76,    .75,    .75,    .74,    .74,
+	.74,    .73,    .73,    .72,    .71,    .70,    .68,
+	.67,    .65,    .64,    .63,    .62,    .61,    .60,
+	.59,    .58,    .57,    .56,    .55,    .54,    .53,
+	.52,    .51,    .50,    .49,    .49,    .48,    .47,
+	.46,    .45,    .43,    .42,    .41,    .40,    .39,
+	.38,    .37,    .36,    .35,    .34,    .33,    .31,
+	.30,    .29,    .28,    .28,    .27,    .25,    .24,
+	.23,    .22,    .21,    .20,    .19,    .18,    .17,
+	.16,    .15,    .14,    .13,    .12,    .11,    .11,
+	.10,    .09,    .08,    .08,    .08,    .07,    .06,
+	.06,    .05,    .05,    .05,    .04,    .04,    .03,
+	.03,    .02,    .02,    .01,    .01,    .01,    .01,
+	.01,    .00,    .00,    .00 };
-     ffu.wlinf=0.3499999f;
-     ffu.wlsup=1.11f;
+    ffu.wlinf=0.3499999f;
+    ffu.wlsup=1.11f;
-	 int i;
-	 for(i = 0; i < 40; i++)	ffu.s[0] = 0;
-	 for(i = 0; i < 305; i++)	ffu.s[40+i] = sr[i];
-	 for(i = 345; i < 1501; i++)ffu.s[i] = 0;
+    int i;
+    for(i = 0; i < 40; i++)	ffu.s[0] = 0;
+    for(i = 0; i < 305; i++)	ffu.s[40+i] = sr[i];
+    for(i = 345; i < 1501; i++)ffu.s[i] = 0;
 void IWave::goes_east()
-	/* spectral band of goes east */
-	static const float sr[165] = {
-	    .00,    .00,    .00,    .01,    .01,    .03,    .05,
-	    .09,    .13,    .22,    .30,    .38,    .46,    .52,
-	    .58,    .63,    .68,    .70,    .73,    .75,    .77,
-	    .79,    .81,    .82,    .84,    .85,    .86,    .87,
-	    .88,    .89,    .90,    .91,    .92,    .93,    .93,
-	    .94,    .95,    .96,    .96,    .97,    .98,    .99,
-	    .99,    .99,    .98,    .98,    .97,    .97,    .96,
-	    .95,    .95,    .94,    .94,    .93,    .93,    .92,
-	    .92,    .91,    .91,    .91,    .91,    .91,    .91,
-	    .91,    .91,    .91,    .91,    .90,    .89,    .88,
-	    .88,    .86,    .84,    .83,    .81,    .79,    .77,
-	    .75,    .73,    .71,    .69,    .69,    .68,    .67,
-	    .66,    .65,    .64,    .63,    .61,    .60,    .59,
-	    .57,    .56,    .54,    .52,    .50,    .49,    .47,
-	    .46,    .44,    .43,    .41,    .40,    .38,    .36,
-	    .35,    .33,    .32,    .30,    .29,    .28,    .27,
-	    .26,    .25,    .23,    .22,    .21,    .20,    .19,
-	    .18,    .17,    .16,    .15,    .14,    .13,    .12,
-	    .11,    .10,    .10,    .09,    .08,    .08,    .07,
-	    .06,    .06,    .05,    .05,    .04,    .04,    .03,
-	    .03,    .03,    .02,    .02,    .02,    .02,    .01,
-	    .01,    .01,    .01,    .01,    .00,    .00,    .00,
-	    .00,    .00,    .00,    .00,    .00,    .00,    .00,
-	    .00,    .00,    .00,    .00 };
+    /* spectral band of goes east */
+    static const float sr[165] = {
+	.00,    .00,    .00,    .01,    .01,    .03,    .05,
+	.09,    .13,    .22,    .30,    .38,    .46,    .52,
+	.58,    .63,    .68,    .70,    .73,    .75,    .77,
+	.79,    .81,    .82,    .84,    .85,    .86,    .87,
+	.88,    .89,    .90,    .91,    .92,    .93,    .93,
+	.94,    .95,    .96,    .96,    .97,    .98,    .99,
+	.99,    .99,    .98,    .98,    .97,    .97,    .96,
+	.95,    .95,    .94,    .94,    .93,    .93,    .92,
+	.92,    .91,    .91,    .91,    .91,    .91,    .91,
+	.91,    .91,    .91,    .91,    .90,    .89,    .88,
+	.88,    .86,    .84,    .83,    .81,    .79,    .77,
+	.75,    .73,    .71,    .69,    .69,    .68,    .67,
+	.66,    .65,    .64,    .63,    .61,    .60,    .59,
+	.57,    .56,    .54,    .52,    .50,    .49,    .47,
+	.46,    .44,    .43,    .41,    .40,    .38,    .36,
+	.35,    .33,    .32,    .30,    .29,    .28,    .27,
+	.26,    .25,    .23,    .22,    .21,    .20,    .19,
+	.18,    .17,    .16,    .15,    .14,    .13,    .12,
+	.11,    .10,    .10,    .09,    .08,    .08,    .07,
+	.06,    .06,    .05,    .05,    .04,    .04,    .03,
+	.03,    .03,    .02,    .02,    .02,    .02,    .01,
+	.01,    .01,    .01,    .01,    .00,    .00,    .00,
+	.00,    .00,    .00,    .00,    .00,    .00,    .00,
+	.00,    .00,    .00,    .00 };
-	ffu.wlinf = 0.49f;
-	ffu.wlsup = 0.8999999f;
-	int i = 0;
-	for(i = 0; i < 96; i++)		ffu.s[i] = 0;
-	for(i = 0; i < 165; i++)	ffu.s[96+i] = sr[i];
-	for(i = 261; i < 1501; i++) ffu.s[i] = 0;
+    ffu.wlinf = 0.49f;
+    ffu.wlsup = 0.8999999f;
+    int i = 0;
+    for(i = 0; i < 96; i++)		ffu.s[i] = 0;
+    for(i = 0; i < 165; i++)	ffu.s[96+i] = sr[i];
+    for(i = 261; i < 1501; i++) ffu.s[i] = 0;
 void IWave::goes_west()
-	/* spectral band of goes west */
+    /* spectral band of goes west */
-	    .00,    .00,    .00,    .00,    .00,    .01,    .02,
-	    .04,    .06,    .12,    .18,    .30,    .41,    .51,
-	    .61,    .69,    .77,    .83,    .89,    .91,    .93,
-	    .94,    .96,    .96,    .97,    .98,    .99,    .99,
-	    .99,   1.00,   1.00,   1.00,   1.00,   1.00,   1.00,
-	    .99,    .99,    .99,    .98,    .98,    .97,    .97,
-	    .96,    .96,    .96,    .95,    .95,    .95,    .94,
-	    .94,    .93,    .92,    .91,    .90,    .89,    .88,
-	    .87,    .86,    .85,    .84,    .83,    .82,    .81,
-	    .80,    .80,    .79,    .78,    .77,    .76,    .75,
-	    .74,    .73,    .72,    .70,    .69,    .67,    .66,
-	    .64,    .63,    .61,    .59,    .58,    .56,    .55,
-	    .54,    .52,    .51,    .50,    .49,    .48,    .46,
-	    .45,    .44,    .43,    .41,    .40,    .38,    .37,
-	    .36,    .34,    .33,    .32,    .31,    .29,    .28,
-	    .27,    .26,    .24,    .23,    .22,    .21,    .20,
-	    .19,    .18,    .17,    .17,    .16,    .15,    .14,
-	    .14,    .13,    .12,    .12,    .11,    .10,    .09,
-	    .09,    .08,    .08,    .07,    .07,    .07,    .06,
-	    .03,    .03,    .03,    .02,    .02,    .02,    .02,
-	    .02,    .01,    .01,    .01,    .01,    .01,    .01,
-	    .01,    .00,    .00,    .00,    .00,    .00,    .00,
+	.00,    .00,    .00,    .00,    .00,    .01,    .02,
+	.04,    .06,    .12,    .18,    .30,    .41,    .51,
+	.61,    .69,    .77,    .83,    .89,    .91,    .93,
+	.94,    .96,    .96,    .97,    .98,    .99,    .99,
+	.99,   1.00,   1.00,   1.00,   1.00,   1.00,   1.00,
+	.99,    .99,    .99,    .98,    .98,    .97,    .97,
+	.96,    .96,    .96,    .95,    .95,    .95,    .94,
+	.94,    .93,    .92,    .91,    .90,    .89,    .88,
+	.87,    .86,    .85,    .84,    .83,    .82,    .81,
+	.80,    .80,    .79,    .78,    .77,    .76,    .75,
+	.74,    .73,    .72,    .70,    .69,    .67,    .66,
+	.64,    .63,    .61,    .59,    .58,    .56,    .55,
+	.54,    .52,    .51,    .50,    .49,    .48,    .46,
+	.45,    .44,    .43,    .41,    .40,    .38,    .37,
+	.36,    .34,    .33,    .32,    .31,    .29,    .28,
+	.27,    .26,    .24,    .23,    .22,    .21,    .20,
+	.19,    .18,    .17,    .17,    .16,    .15,    .14,
+	.14,    .13,    .12,    .12,    .11,    .10,    .09,
+	.09,    .08,    .08,    .07,    .07,    .07,    .06,
+	.03,    .03,    .03,    .02,    .02,    .02,    .02,
+	.02,    .01,    .01,    .01,    .01,    .01,    .01,
+	.01,    .00,    .00,    .00,    .00,    .00,    .00,
-	int i = 0;
+    int i = 0;
 void IWave::avhrr(int iwa)
-	/* 1st spectral band of avhrr  (noaa 6) */
-	static const float sr1[80] = {
-	 .0000, .0178, .0355, .0533, .0710, .1655, .2600, .3545,
-	 .4490, .5215, .5940, .6665, .7390, .7575, .7760, .7945,
-	 .8130, .8113, .8095, .8078, .8060, .8201, .8343, .8484,
-	 .8625, .8766, .8908, .9049, .9190, .9291, .9393, .9494,
-	 .9595, .9696, .9798, .9899, 1.000, .9996, .9992, .9989,
-	 .9985, .9981, .9977, .9974, .9970, .9596, .9222, .8849,
-	 .8475, .8101, .7727, .7354, .6980, .6047, .5115, .4182,
-	 .3250, .2767, .2285, .1802, .1320, .1127, .0935, .0742,
-	 .0550, .0480, .0410, .0340, .0270, .0235, .0200, .0165,
-	 .0130, .0115, .0100, .0085, .0070, .0052, .0035, .0017
+    /* 1st spectral band of avhrr  (noaa 6) */
+    static const float sr1[80] = {
+	.0000, .0178, .0355, .0533, .0710, .1655, .2600, .3545,
+	.4490, .5215, .5940, .6665, .7390, .7575, .7760, .7945,
+	.8130, .8113, .8095, .8078, .8060, .8201, .8343, .8484,
+	.8625, .8766, .8908, .9049, .9190, .9291, .9393, .9494,
+	.9595, .9696, .9798, .9899, 1.000, .9996, .9992, .9989,
+	.9985, .9981, .9977, .9974, .9970, .9596, .9222, .8849,
+	.8475, .8101, .7727, .7354, .6980, .6047, .5115, .4182,
+	.3250, .2767, .2285, .1802, .1320, .1127, .0935, .0742,
+	.0550, .0480, .0410, .0340, .0270, .0235, .0200, .0165,
+	.0130, .0115, .0100, .0085, .0070, .0052, .0035, .0017
-	/* 2nd spectral band of avhrr  (noaa 6) */
-	static const float sr2[173] = {
+    /* 2nd spectral band of avhrr  (noaa 6) */
+    static const float sr2[173] = {
-	 .0000, .0020, .0040, .0060, .0080, .0710, .1340, .1970,
-	 .2600, .3492, .4385, .5277, .6170, .6678, .7185, .7693,
-	 .8200, .8435, .8670, .8905, .9140, .9212, .9285, .9358,
-	 .9430, .9415, .9400, .9385, .9370, .9520, .9670, .9820,
-	 .9970, .9977, .9985, .9992, 1.000, .9813, .9625, .9438,
-	 .9250, .9148, .9045, .8943, .8840, .8751, .8663, .8574,
-	 .8485, .8396, .8307, .8219, .8130, .8100, .8070, .8040,
-	 .8010, .7980, .7950, .7920, .7890, .7878, .7865, .7853,
-	 .7840, .7828, .7815, .7803, .7790, .7751, .7713, .7674,
-	 .7635, .7596, .7558, .7519, .7480, .7464, .7448, .7431,
-	 .7415, .7399, .7383, .7366, .7350, .7225, .7100, .6975,
-	 .6850, .6783, .6715, .6648, .6580, .6515, .6450, .6385,
-	 .6320, .6270, .6220, .6170, .6120, .6093, .6065, .6038,
-	 .6010, .5993, .5975, .5958, .5940, .5910, .5880, .5850,
-	 .5820, .5720, .5620, .5520, .5420, .5243, .5065, .4887,
-	 .4710, .4402, .4095, .3787, .3480, .3155, .2830, .2505,
-	 .2180, .1935, .1690, .1445, .1200, .1055, .0910, .0765,
-	 .0620, .0540, .0460, .0380, .0300, .0257, .0215, .0172,
-	 .0130, .0112, .0095, .0077, .0060, .0053, .0045, .0038,
-	 .0030, .0025, .0020, .0015, .0010, .0010, .0010, .0010,
-	 .0010, .0009, .0007, .0006, .0005, .0004, .0004, .0003,
-	 .0002, .0002, .0001, .0001, .0000
+	.0000, .0020, .0040, .0060, .0080, .0710, .1340, .1970,
+	.2600, .3492, .4385, .5277, .6170, .6678, .7185, .7693,
+	.8200, .8435, .8670, .8905, .9140, .9212, .9285, .9358,
+	.9430, .9415, .9400, .9385, .9370, .9520, .9670, .9820,
+	.9970, .9977, .9985, .9992, 1.000, .9813, .9625, .9438,
+	.9250, .9148, .9045, .8943, .8840, .8751, .8663, .8574,
+	.8485, .8396, .8307, .8219, .8130, .8100, .8070, .8040,
+	.8010, .7980, .7950, .7920, .7890, .7878, .7865, .7853,
+	.7840, .7828, .7815, .7803, .7790, .7751, .7713, .7674,
+	.7635, .7596, .7558, .7519, .7480, .7464, .7448, .7431,
+	.7415, .7399, .7383, .7366, .7350, .7225, .7100, .6975,
+	.6850, .6783, .6715, .6648, .6580, .6515, .6450, .6385,
+	.6320, .6270, .6220, .6170, .6120, .6093, .6065, .6038,
+	.6010, .5993, .5975, .5958, .5940, .5910, .5880, .5850,
+	.5820, .5720, .5620, .5520, .5420, .5243, .5065, .4887,
+	.4710, .4402, .4095, .3787, .3480, .3155, .2830, .2505,
+	.2180, .1935, .1690, .1445, .1200, .1055, .0910, .0765,
+	.0620, .0540, .0460, .0380, .0300, .0257, .0215, .0172,
+	.0130, .0112, .0095, .0077, .0060, .0053, .0045, .0038,
+	.0030, .0025, .0020, .0015, .0010, .0010, .0010, .0010,
+	.0010, .0009, .0007, .0006, .0005, .0004, .0004, .0003,
+	.0002, .0002, .0001, .0001, .0000
-	/* 1st spectral band of avhrr (noaa 7) */
-	static const float sr3[121] = {
-	 .0000, .0008, .0016, .0024, .0032, .0032, .0031, .0030,
-	 .0030, .0029, .0029, .0028, .0028, .0027, .0027, .0026,
-	 .0025, .0031, .0036, .0042, .0047, .0288, .0529, .0769,
-	 .1010, .1943, .2875, .3808, .4740, .5363, .5985, .6608,
-	 .7230, .7390, .7550, .7710, .7870, .7838, .7805, .7773,
-	 .7740, .7788, .7835, .7883, .7930, .8100, .8270, .8440,
-	 .8610, .8958, .9305, .9653,1.0000, .9860, .9720, .9580,
-	 .9440, .9435, .9430, .9425, .9420, .9442, .9465, .9487,
-	 .9510, .9575, .9640, .9705, .9770, .9135, .8500, .7865,
-	 .7230, .6285, .5340, .4395, .3450, .2955, .2460, .1965,
-	 .1470, .1280, .1090, .0900, .0710, .0638, .0565, .0493,
-	 .0420, .0383, .0345, .0307, .0270, .0245, .0220, .0195,
-	 .0170, .0158, .0145, .0132, .0120, .0114, .0107, .0101,
-	 .0095, .0096, .0098, .0099, .0100, .0103, .0105, .0108,
-	 .0110, .0100, .0090, .0080, .0070, .0052, .0035, .0017,
-	 .0000
+    /* 1st spectral band of avhrr (noaa 7) */
+    static const float sr3[121] = {
+	.0000, .0008, .0016, .0024, .0032, .0032, .0031, .0030,
+	.0030, .0029, .0029, .0028, .0028, .0027, .0027, .0026,
+	.0025, .0031, .0036, .0042, .0047, .0288, .0529, .0769,
+	.1010, .1943, .2875, .3808, .4740, .5363, .5985, .6608,
+	.7230, .7390, .7550, .7710, .7870, .7838, .7805, .7773,
+	.7740, .7788, .7835, .7883, .7930, .8100, .8270, .8440,
+	.8610, .8958, .9305, .9653,1.0000, .9860, .9720, .9580,
+	.9440, .9435, .9430, .9425, .9420, .9442, .9465, .9487,
+	.9510, .9575, .9640, .9705, .9770, .9135, .8500, .7865,
+	.7230, .6285, .5340, .4395, .3450, .2955, .2460, .1965,
+	.1470, .1280, .1090, .0900, .0710, .0638, .0565, .0493,
+	.0420, .0383, .0345, .0307, .0270, .0245, .0220, .0195,
+	.0170, .0158, .0145, .0132, .0120, .0114, .0107, .0101,
+	.0095, .0096, .0098, .0099, .0100, .0103, .0105, .0108,
+	.0110, .0100, .0090, .0080, .0070, .0052, .0035, .0017,
+	.0000
-	/* 2nd spectral band of avhrr  (noaa 7) */
-	static const float sr4[213] = {
-	 .0000, .0018, .0035, .0053, .0070, .0068, .0065, .0063,
-	 .0060, .0058, .0055, .0052, .0050, .0050, .0050, .0050,
-	 .0050, .0060, .0070, .0080, .0090, .0320, .0550, .0780,
-	 .1010, .1788, .2565, .3343, .4120, .4922, .5725, .6527,
-	 .7330, .7765, .8200, .8635, .9070, .9218, .9365, .9513,
-	 .9660, .9725, .9790, .9855, .9920, .9940, .9960, .9980,
-	 1.0000, .9962,.9925, .9887, .9850, .9870, .9890, .9910,
-	 .9930, .9763, .9595, .9428, .9260, .9298, .9335, .9373,
-	 .9410, .9373, .9335, .9298, .9260, .9120, .8980, .8840,
-	 .8700, .8700, .8700, .8700, .8700, .8703, .8705, .8708,
-	 .8710, .8708, .8705, .8703, .8700, .8715, .8730, .8745,
-	 .8760, .8740, .8720, .8700, .8680, .8690, .8700, .8710,
-	 .8720, .8687, .8655, .8623, .8590, .8555, .8520, .8485,
-	 .8450, .8428, .8405, .8383, .8360, .8328, .8295, .8263,
-	 .8230, .8145, .8060, .7975, .7890, .7872, .7855, .7838,
-	 .7820, .7790, .7760, .7730, .7700, .7682, .7665, .7648,
-	 .7630, .7545, .7460, .7375, .7290, .6987, .6685, .6382,
-	 .6080, .5623, .5165, .4707, .4250, .3812, .3375, .2937/
-	 .2500, .2215, .1930, .1645, .1360, .1202, .1045, .0887,
-	 .0730, .0647, .0565, .0482, .0400, .0357, .0315, .0272,
-	 .0230, .0207, .0185, .0162, .0140, .0125, .0110, .0095,
-	 .0080, .0075, .0070, .0065, .0060, .0055, .0050, .0045,
-	 .0040, .0039, .0038, .0037, .0036, .0036, .0037, .0037,
-	 .0037, .0035, .0034, .0032, .0031, .0029, .0028, .0026,
-	 .0025, .0025, .0024, .0024, .0023, .0023, .0022, .0022,
-	 .0021, .0021, .0021, .0020, .0020, .0019, .0019, .0018,
-	 .0018, .0013, .0009, .0004, .0000
+    /* 2nd spectral band of avhrr  (noaa 7) */
+    static const float sr4[213] = {
+	.0000, .0018, .0035, .0053, .0070, .0068, .0065, .0063,
+	.0060, .0058, .0055, .0052, .0050, .0050, .0050, .0050,
+	.0050, .0060, .0070, .0080, .0090, .0320, .0550, .0780,
+	.1010, .1788, .2565, .3343, .4120, .4922, .5725, .6527,
+	.7330, .7765, .8200, .8635, .9070, .9218, .9365, .9513,
+	.9660, .9725, .9790, .9855, .9920, .9940, .9960, .9980,
+	1.0000, .9962,.9925, .9887, .9850, .9870, .9890, .9910,
+	.9930, .9763, .9595, .9428, .9260, .9298, .9335, .9373,
+	.9410, .9373, .9335, .9298, .9260, .9120, .8980, .8840,
+	.8700, .8700, .8700, .8700, .8700, .8703, .8705, .8708,
+	.8710, .8708, .8705, .8703, .8700, .8715, .8730, .8745,
+	.8760, .8740, .8720, .8700, .8680, .8690, .8700, .8710,
+	.8720, .8687, .8655, .8623, .8590, .8555, .8520, .8485,
+	.8450, .8428, .8405, .8383, .8360, .8328, .8295, .8263,
+	.8230, .8145, .8060, .7975, .7890, .7872, .7855, .7838,
+	.7820, .7790, .7760, .7730, .7700, .7682, .7665, .7648,
+	.7630, .7545, .7460, .7375, .7290, .6987, .6685, .6382,
+	.6080, .5623, .5165, .4707, .4250, .3812, .3375, .2937/
+	.2500, .2215, .1930, .1645, .1360, .1202, .1045, .0887,
+	.0730, .0647, .0565, .0482, .0400, .0357, .0315, .0272,
+	.0230, .0207, .0185, .0162, .0140, .0125, .0110, .0095,
+	.0080, .0075, .0070, .0065, .0060, .0055, .0050, .0045,
+	.0040, .0039, .0038, .0037, .0036, .0036, .0037, .0037,
+	.0037, .0035, .0034, .0032, .0031, .0029, .0028, .0026,
+	.0025, .0025, .0024, .0024, .0023, .0023, .0022, .0022,
+	.0021, .0021, .0021, .0020, .0020, .0019, .0019, .0018,
+	.0018, .0013, .0009, .0004, .0000
-	/* 1st spectral band of avhrr (noaa 8) */
-	static const float sr5[189] = {
-	 .0000, .0012, .0024, .0036, .0048, .0223, .0399, .0574,
-	 .0749, .1633, .2517, .3400, .4284, .4937, .5590, .6243,
-	 .6896, .7135, .7375, .7614, .7853, .7833, .7813, .7793,
-	 .7773, .7774, .7775, .7776, .7777, .7922, .8067, .8211,
-	 .8356, .8566, .8777, .8987, .9197, .9332, .9468, .9603,
-	 .9739, .9674, .9609, .9545, .9480, .9507, .9534, .9561,
-	 .9588, .9691, .9794, .9897,1.0000, .9692, .9385, .9077,
-	 .8770, .7775, .6779, .5784, .4789, .4108, .3428, .2747,
-	 .2067, .1782, .1497, .1213, .0928, .0820, .0712, .0604,
-	 .0496, .0425, .0355, .0284, .0214, .0208, .0202, .0196,
-	 .0190, .0167, .0145, .0122, .0100, .0095, .0090, .0085,
-	 .0080, .0083, .0086, .0089, .0092, .0094, .0097, .0100,
-	 .0103, .0100, .0096, .0093, .0090, .0086, .0083, .0079,
-	 .0076, .0082, .0087, .0093, .0099, .0104, .0110, .0115,
-	 .0121, .0114, .0108, .0101, .0094, .0088, .0081, .0075,
-	 .0068, .0074, .0079, .0085, .0091, .0097, .0102, .0108,
-	 .0114, .0115, .0115, .0116, .0117, .0118, .0119, .0119,
-	 .0120, .0136, .0152, .0167, .0183, .0204, .0224, .0245,
-	 .0265, .0295, .0324, .0354, .0384, .0419, .0453, .0488,
-	 .0522, .0514, .0507, .0499, .0491, .0467, .0443, .0420,
-	 .0396, .0348, .0299, .0251, .0203, .0183, .0164, .0144,
-	 .0125, .0118, .0110, .0103, .0095, .0083, .0071, .0060,
-	 .0048, .0041, .0035, .0028, .0022, .0022, .0021, .0021,
-	 .0021, .0016, .0010, .0005, .0000
+    /* 1st spectral band of avhrr (noaa 8) */
+    static const float sr5[189] = {
+	.0000, .0012, .0024, .0036, .0048, .0223, .0399, .0574,
+	.0749, .1633, .2517, .3400, .4284, .4937, .5590, .6243,
+	.6896, .7135, .7375, .7614, .7853, .7833, .7813, .7793,
+	.7773, .7774, .7775, .7776, .7777, .7922, .8067, .8211,
+	.8356, .8566, .8777, .8987, .9197, .9332, .9468, .9603,
+	.9739, .9674, .9609, .9545, .9480, .9507, .9534, .9561,
+	.9588, .9691, .9794, .9897,1.0000, .9692, .9385, .9077,
+	.8770, .7775, .6779, .5784, .4789, .4108, .3428, .2747,
+	.2067, .1782, .1497, .1213, .0928, .0820, .0712, .0604,
+	.0496, .0425, .0355, .0284, .0214, .0208, .0202, .0196,
+	.0190, .0167, .0145, .0122, .0100, .0095, .0090, .0085,
+	.0080, .0083, .0086, .0089, .0092, .0094, .0097, .0100,
+	.0103, .0100, .0096, .0093, .0090, .0086, .0083, .0079,
+	.0076, .0082, .0087, .0093, .0099, .0104, .0110, .0115,
+	.0121, .0114, .0108, .0101, .0094, .0088, .0081, .0075,
+	.0068, .0074, .0079, .0085, .0091, .0097, .0102, .0108,
+	.0114, .0115, .0115, .0116, .0117, .0118, .0119, .0119,
+	.0120, .0136, .0152, .0167, .0183, .0204, .0224, .0245,
+	.0265, .0295, .0324, .0354, .0384, .0419, .0453, .0488,
+	.0522, .0514, .0507, .0499, .0491, .0467, .0443, .0420,
+	.0396, .0348, .0299, .0251, .0203, .0183, .0164, .0144,
+	.0125, .0118, .0110, .0103, .0095, .0083, .0071, .0060,
+	.0048, .0041, .0035, .0028, .0022, .0022, .0021, .0021,
+	.0021, .0016, .0010, .0005, .0000
-	/*  2nd spectral band of avhrr  (noaa 8) */
-	static const float sr6[177] = {
-	 .0000, .0095, .0190, .0285, .0381, .0476, .0571, .0666,
-	 .0761, .1559, .2358, .3156, .3954, .4855, .5756, .6658,
-	 .7559, .7966, .8373, .8779, .9186, .9332, .9478, .9624,
-	 .9770, .9814, .9858, .9902, .9946, .9959, .9973, .9986,
+    /*  2nd spectral band of avhrr  (noaa 8) */
+    static const float sr6[177] = {
+	.0000, .0095, .0190, .0285, .0381, .0476, .0571, .0666,
+	.0761, .1559, .2358, .3156, .3954, .4855, .5756, .6658,
+	.7559, .7966, .8373, .8779, .9186, .9332, .9478, .9624,
+	.9770, .9814, .9858, .9902, .9946, .9959, .9973, .9986,
 	1.0000, .9965, .9930, .9896, .9861, .9796, .9731, .9666,
-	 .9601, .9518, .9435, .9351, .9268, .9171, .9073, .8976,
-	 .8879, .8791, .8703, .8615, .8527, .8439, .8351, .8263,
-	 .8175, .8140, .8104, .8068, .8033, .7997, .7962, .7926,
-	 .7891, .7871, .7850, .7830, .7810, .7790, .7769, .7749,
-	 .7729, .7711, .7694, .7677, .7659, .7642, .7624, .7607,
-	 .7589, .7558, .7528, .7497, .7466, .7436, .7405, .7375,
-	 .7344, .7282, .7220, .7158, .7096, .7034, .6972, .6910,
-	 .6848, .6781, .6713, .6646, .6579, .6511, .6444, .6376,
-	 .6309, .6265, .6221, .6177, .6133, .6088, .6044, .6000,
-	 .5956, .5888, .5820, .5752, .5684, .5616, .5548, .5480,
-	 .5412, .5159, .4906, .4653, .4400, .4147, .3894, .3641,
-	 .3388, .3061, .2734, .2408, .2081, .1851, .1621, .1392,
-	 .1162, .1023, .0884, .0745, .0606, .0532, .0458, .0384/
-	 .0310, .0271, .0231, .0192, .0153, .0134, .0115, .0096,
-	 .0077, .0071, .0065, .0059, .0053, .0046, .0040, .0034,
-	 .0028, .0026, .0024, .0023, .0021, .0019, .0017, .0016,
-	 .0014, .0012, .0010, .0009, .0007, .0005, .0003, .0002,
-	 .0000
+	.9601, .9518, .9435, .9351, .9268, .9171, .9073, .8976,
+	.8879, .8791, .8703, .8615, .8527, .8439, .8351, .8263,
+	.8175, .8140, .8104, .8068, .8033, .7997, .7962, .7926,
+	.7891, .7871, .7850, .7830, .7810, .7790, .7769, .7749,
+	.7729, .7711, .7694, .7677, .7659, .7642, .7624, .7607,
+	.7589, .7558, .7528, .7497, .7466, .7436, .7405, .7375,
+	.7344, .7282, .7220, .7158, .7096, .7034, .6972, .6910,
+	.6848, .6781, .6713, .6646, .6579, .6511, .6444, .6376,
+	.6309, .6265, .6221, .6177, .6133, .6088, .6044, .6000,
+	.5956, .5888, .5820, .5752, .5684, .5616, .5548, .5480,
+	.5412, .5159, .4906, .4653, .4400, .4147, .3894, .3641,
+	.3388, .3061, .2734, .2408, .2081, .1851, .1621, .1392,
+	.1162, .1023, .0884, .0745, .0606, .0532, .0458, .0384/
+	.0310, .0271, .0231, .0192, .0153, .0134, .0115, .0096,
+	.0077, .0071, .0065, .0059, .0053, .0046, .0040, .0034,
+	.0028, .0026, .0024, .0023, .0021, .0019, .0017, .0016,
+	.0014, .0012, .0010, .0009, .0007, .0005, .0003, .0002,
+	.0000
-	/* 1st spectral band of avhrr (noaa 9) */
-	static const float sr7[113] = {
-	 .0000, .0001, .0003, .0004, .0006, .0040, .0074, .0108,
-	 .0142, .0622, .1101, .1581, .2060, .2810, .3561, .4311,
-	 .5061, .5500, .5940, .6379, .6818, .7127, .7437, .7746,
-	 .8055, .8122, .8190, .8170, .8150, .8063, .7975, .7887,
-	 .7800, .7881, .7962, .8044, .8125, .8335, .8544, .8753,
-	 .8963, .9000, .9037, .9074, .9111, .8899, .8688, .8476,
-	 .8265, .8198, .8130, .8110, .8090, .8277, .8464, .8650,
-	 .8837, .9128, .9419, .9709,1.0000, .9678, .9356, .9035,
-	 .8713, .7712, .6711, .5711, .4710, .4067, .3424, .2782,
-	 .2139, .1849, .1559, .1269, .0979, .0861, .0743, .0625,
-	 .0507, .0454, .0400, .0347, .0294, .0266, .0238, .0210,
-	 .0182, .0170, .0157, .0145, .0133, .0124, .0115, .0107,
-	 .0098, .0092, .0086, .0080, .0074, .0071, .0069, .0066,
-	 .0063, .0062, .0061, .0061, .0060, .0045, .0030, .0015,
-	 .0000
+    /* 1st spectral band of avhrr (noaa 9) */
+    static const float sr7[113] = {
+	.0000, .0001, .0003, .0004, .0006, .0040, .0074, .0108,
+	.0142, .0622, .1101, .1581, .2060, .2810, .3561, .4311,
+	.5061, .5500, .5940, .6379, .6818, .7127, .7437, .7746,
+	.8055, .8122, .8190, .8170, .8150, .8063, .7975, .7887,
+	.7800, .7881, .7962, .8044, .8125, .8335, .8544, .8753,
+	.8963, .9000, .9037, .9074, .9111, .8899, .8688, .8476,
+	.8265, .8198, .8130, .8110, .8090, .8277, .8464, .8650,
+	.8837, .9128, .9419, .9709,1.0000, .9678, .9356, .9035,
+	.8713, .7712, .6711, .5711, .4710, .4067, .3424, .2782,
+	.2139, .1849, .1559, .1269, .0979, .0861, .0743, .0625,
+	.0507, .0454, .0400, .0347, .0294, .0266, .0238, .0210,
+	.0182, .0170, .0157, .0145, .0133, .0124, .0115, .0107,
+	.0098, .0092, .0086, .0080, .0074, .0071, .0069, .0066,
+	.0063, .0062, .0061, .0061, .0060, .0045, .0030, .0015,
+	.0000
-	/* 2nd spectral band of avhrr  (noaa 9) */
-	static const float sr8[197] = {
-	 .0000, .0011, .0022, .0033, .0044, .0207, .0369, .0532,
-	 .0694, .1410, .2127, .2843, .3559, .4388, .5217, .6047,
-	 .6876, .7304, .7731, .8159, .8586, .8782, .8977, .9173,
-	 .9369, .9491, .9614, .9736, .9859, .9894, .9930, .9965,
+    /* 2nd spectral band of avhrr  (noaa 9) */
+    static const float sr8[197] = {
+	.0000, .0011, .0022, .0033, .0044, .0207, .0369, .0532,
+	.0694, .1410, .2127, .2843, .3559, .4388, .5217, .6047,
+	.6876, .7304, .7731, .8159, .8586, .8782, .8977, .9173,
+	.9369, .9491, .9614, .9736, .9859, .9894, .9930, .9965,
 	1.0000, .9956, .9912, .9869, .9825, .9699, .9574, .9448,
-	 .9323, .9243, .9163, .9083, .9003, .8971, .8939, .8907,
-	 .8875, .8881, .8887, .8893, .8899, .8931, .8963, .8994,
-	 .9026, .9046, .9067, .9087, .9108, .9114, .9120, .9126,
-	 .9132, .9065, .8997, .8930, .8863, .8807, .8750, .8694,
-	 .8638, .8605, .8571, .8538, .8504, .8532, .8560, .8588,
-	 .8616, .8644, .8672, .8701, .8729, .8749, .8770, .8790,
-	 .8811, .8766, .8721, .8677, .8632, .8502, .8372, .8242,
-	 .8112, .7959, .7806, .7653, .7500, .7423, .7347, .7270,
-	 .7193, .7166, .7138, .7111, .7084, .7169, .7255, .7340,
-	 .7425, .7382, .7338, .7295, .7251, .6819, .6387, .5955,
-	 .5523, .4922, .4321, .3721, .3120, .2722, .2325, .1927,
-	 .1529, .1336, .1144, .0951, .0759, .0673, .0586, .0500,
-	 .0414, .0370, .0327, .0283, .0240, .0217, .0195, .0172,
-	 .0150, .0139, .0128, .0118, .0107, .0099, .0090, .0082,
-	 .0074, .0070, .0066, .0061, .0057, .0054, .0051, .0049,
-	 .0046, .0044, .0042, .0041, .0039, .0037, .0036, .0034,
-	 .0033, .0032, .0031, .0030, .0029, .0028, .0027, .0026,
-	 .0025, .0025, .0025, .0024, .0024, .0023, .0022, .0021,
-	 .0020, .0019, .0018, .0018, .0017, .0016, .0015, .0015,
-	 .0014, .0010, .0007, .0003, .0000
+	.9323, .9243, .9163, .9083, .9003, .8971, .8939, .8907,
+	.8875, .8881, .8887, .8893, .8899, .8931, .8963, .8994,
+	.9026, .9046, .9067, .9087, .9108, .9114, .9120, .9126,
+	.9132, .9065, .8997, .8930, .8863, .8807, .8750, .8694,
+	.8638, .8605, .8571, .8538, .8504, .8532, .8560, .8588,
+	.8616, .8644, .8672, .8701, .8729, .8749, .8770, .8790,
+	.8811, .8766, .8721, .8677, .8632, .8502, .8372, .8242,
+	.8112, .7959, .7806, .7653, .7500, .7423, .7347, .7270,
+	.7193, .7166, .7138, .7111, .7084, .7169, .7255, .7340,
+	.7425, .7382, .7338, .7295, .7251, .6819, .6387, .5955,
+	.5523, .4922, .4321, .3721, .3120, .2722, .2325, .1927,
+	.1529, .1336, .1144, .0951, .0759, .0673, .0586, .0500,
+	.0414, .0370, .0327, .0283, .0240, .0217, .0195, .0172,
+	.0150, .0139, .0128, .0118, .0107, .0099, .0090, .0082,
+	.0074, .0070, .0066, .0061, .0057, .0054, .0051, .0049,
+	.0046, .0044, .0042, .0041, .0039, .0037, .0036, .0034,
+	.0033, .0032, .0031, .0030, .0029, .0028, .0027, .0026,
+	.0025, .0025, .0025, .0024, .0024, .0023, .0022, .0021,
+	.0020, .0019, .0018, .0018, .0017, .0016, .0015, .0015,
+	.0014, .0010, .0007, .0003, .0000
-	/* 1st spectral band of avhrr (noaa 10) */
-	static const float sr9[101] = {
-	 .0000, .0005, .0010, .0015, .0020, .0023, .0025, .0028,
-	 .0030, .0239, .0448, .0657, .0866, .1852, .2838, .3824,
-	 .4810, .5470, .6130, .6790, .7450, .7640, .7830, .8020,
-	 .8210, .8182, .8154, .8126, .8098, .8219, .8339, .8460,
-	 .8580, .8808, .9035, .9263, .9490, .9607, .9723, .9840,
-	 .9956, .9875, .9793, .9712, .9630, .9595, .9560, .9525,
-	 .9490, .9618, .9745, .9872,1.0000, .9980, .9960, .9940,
-	 .9920, .9013, .8105, .7197, .6290, .5400, .4510, .3620,
-	 .2730, .2315, .1900, .1485, .1070, .0935, .0800, .0665,
-	 .0530, .0468, .0405, .0343, .0280, .0255, .0230, .0205,
-	 .0180, .0165, .0150, .0135, .0120, .0110, .0100, .0090,
-	 .0080, .0070, .0061, .0051, .0042, .0034, .0026, .0018,
-	 .0010, .0007, .0005, .0002, .0000
+    /* 1st spectral band of avhrr (noaa 10) */
+    static const float sr9[101] = {
+	.0000, .0005, .0010, .0015, .0020, .0023, .0025, .0028,
+	.0030, .0239, .0448, .0657, .0866, .1852, .2838, .3824,
+	.4810, .5470, .6130, .6790, .7450, .7640, .7830, .8020,
+	.8210, .8182, .8154, .8126, .8098, .8219, .8339, .8460,
+	.8580, .8808, .9035, .9263, .9490, .9607, .9723, .9840,
+	.9956, .9875, .9793, .9712, .9630, .9595, .9560, .9525,
+	.9490, .9618, .9745, .9872,1.0000, .9980, .9960, .9940,
+	.9920, .9013, .8105, .7197, .6290, .5400, .4510, .3620,
+	.2730, .2315, .1900, .1485, .1070, .0935, .0800, .0665,
+	.0530, .0468, .0405, .0343, .0280, .0255, .0230, .0205,
+	.0180, .0165, .0150, .0135, .0120, .0110, .0100, .0090,
+	.0080, .0070, .0061, .0051, .0042, .0034, .0026, .0018,
+	.0010, .0007, .0005, .0002, .0000
-	/* 2nd spectral band of avhrr  (noaa 10) */
-	static const float sr10[237] = {
-	 .0000, .0006, .0012, .0018, .0024, .0030, .0036, .0042,
-	 .0048, .0049, .0049, .0050, .0051, .0051, .0052, .0052,
-	 .0053, .0053, .0054, .0054, .0055, .0055, .0056, .0056,
-	 .0057, .0054, .0050, .0047, .0044, .0041, .0037, .0034,
-	 .0031, .0031, .0032, .0032, .0033, .0033, .0033, .0034,
-	 .0034, .0239, .0445, .0650, .0855, .1561, .2267, .2974,
-	 .3680, .4508, .5335, .6163, .6990, .7430, .7870, .8310,
-	 .8750, .8918, .9085, .9253, .9420, .9510, .9600, .9690,
-	 .9780, .9835, .9890, .9945,1.0000, .9933, .9866, .9800,
-	 .9733, .9661, .9589, .9517, .9445, .9329, .9213, .9096,
-	 .8980, .8935, .8890, .8845, .8800, .8788, .8775, .8763,
-	 .8750, .8658, .8565, .8473, .8380, .8415, .8450, .8485,
-	 .8520, .8508, .8495, .8483, .8470, .8410, .8350, .8290,
-	 .8230, .8148, .8065, .7983, .7900, .7983, .8065, .8148,
-	 .8230, .8190, .8150, .8110, .8070, .7990, .7910, .7830,
-	 .7750, .7712, .7675, .7637, .7600, .7425, .7250, .7075,
-	 .6900, .6855, .6810, .6765, .6720, .6710, .6700, .6690,
-	 .6680, .6655, .6630, .6605, .6580, .6455, .6330, .6205,
-	 .6080, .5993, .5905, .5818, .5730, .5602, .5475, .5347,
-	 .5220, .4872, .4525, .4177, .3830, .3435, .3040, .2645,
-	 .2250, .2015, .1780, .1545, .1310, .1155, .1000, .0845,
-	 .0690, .0613, .0535, .0457, .0380, .0337, .0295, .0252,
-	 .0210, .0189, .0168, .0147, .0126, .0114, .0102, .0091,
-	 .0079, .0073, .0067, .0060, .0054, .0051, .0047, .0044,
-	 .0041, .0040, .0038, .0037, .0036, .0035, .0034, .0033,
-	 .0032, .0031, .0030, .0030, .0029, .0028, .0027, .0027,
-	 .0026, .0026, .0025, .0025, .0024, .0023, .0022, .0022,
-	 .0021, .0020, .0019, .0018, .0017, .0016, .0016, .0015,
-	 .0015, .0015, .0014, .0014, .0014, .0014, .0014, .0015,
-	 .0015, .0011, .0008, .0004, .0000
+    /* 2nd spectral band of avhrr  (noaa 10) */
+    static const float sr10[237] = {
+	.0000, .0006, .0012, .0018, .0024, .0030, .0036, .0042,
+	.0048, .0049, .0049, .0050, .0051, .0051, .0052, .0052,
+	.0053, .0053, .0054, .0054, .0055, .0055, .0056, .0056,
+	.0057, .0054, .0050, .0047, .0044, .0041, .0037, .0034,
+	.0031, .0031, .0032, .0032, .0033, .0033, .0033, .0034,
+	.0034, .0239, .0445, .0650, .0855, .1561, .2267, .2974,
+	.3680, .4508, .5335, .6163, .6990, .7430, .7870, .8310,
+	.8750, .8918, .9085, .9253, .9420, .9510, .9600, .9690,
+	.9780, .9835, .9890, .9945,1.0000, .9933, .9866, .9800,
+	.9733, .9661, .9589, .9517, .9445, .9329, .9213, .9096,
+	.8980, .8935, .8890, .8845, .8800, .8788, .8775, .8763,
+	.8750, .8658, .8565, .8473, .8380, .8415, .8450, .8485,
+	.8520, .8508, .8495, .8483, .8470, .8410, .8350, .8290,
+	.8230, .8148, .8065, .7983, .7900, .7983, .8065, .8148,
+	.8230, .8190, .8150, .8110, .8070, .7990, .7910, .7830,
+	.7750, .7712, .7675, .7637, .7600, .7425, .7250, .7075,
+	.6900, .6855, .6810, .6765, .6720, .6710, .6700, .6690,
+	.6680, .6655, .6630, .6605, .6580, .6455, .6330, .6205,
+	.6080, .5993, .5905, .5818, .5730, .5602, .5475, .5347,
+	.5220, .4872, .4525, .4177, .3830, .3435, .3040, .2645,
+	.2250, .2015, .1780, .1545, .1310, .1155, .1000, .0845,
+	.0690, .0613, .0535, .0457, .0380, .0337, .0295, .0252,
+	.0210, .0189, .0168, .0147, .0126, .0114, .0102, .0091,
+	.0079, .0073, .0067, .0060, .0054, .0051, .0047, .0044,
+	.0041, .0040, .0038, .0037, .0036, .0035, .0034, .0033,
+	.0032, .0031, .0030, .0030, .0029, .0028, .0027, .0027,
+	.0026, .0026, .0025, .0025, .0024, .0023, .0022, .0022,
+	.0021, .0020, .0019, .0018, .0017, .0016, .0016, .0015,
+	.0015, .0015, .0014, .0014, .0014, .0014, .0014, .0015,
+	.0015, .0011, .0008, .0004, .0000
-	/* 1st spectral band of avhrr (noaa 11) */
-	static const float sr11[113] = {
-	 .0000, .0033, .0065, .0098, .0130, .0500, .0870, .1240,
-	 .1610, .2385, .3160, .3935, .4710, .5150, .5590, .6030,
-	 .6470, .6768, .7065, .7363, .7660, .7745, .7830, .7915,
-	 .8000, .7918, .7835, .7753, .7670, .7747, .7825, .7903,
-	 .7980, .8215, .8450, .8685, .8920, .8907, .8895, .8882,
-	 .8870, .8702, .8535, .8367, .8200, .8110, .8020, .7930,
-	 .7840, .8050, .8260, .8470, .8680, .9010, .9340, .9670,
+    /* 1st spectral band of avhrr (noaa 11) */
+    static const float sr11[113] = {
+	.0000, .0033, .0065, .0098, .0130, .0500, .0870, .1240,
+	.1610, .2385, .3160, .3935, .4710, .5150, .5590, .6030,
+	.6470, .6768, .7065, .7363, .7660, .7745, .7830, .7915,
+	.8000, .7918, .7835, .7753, .7670, .7747, .7825, .7903,
+	.7980, .8215, .8450, .8685, .8920, .8907, .8895, .8882,
+	.8870, .8702, .8535, .8367, .8200, .8110, .8020, .7930,
+	.7840, .8050, .8260, .8470, .8680, .9010, .9340, .9670,
 	1.0000, .9562, .9125, .8687, .8250, .7192, .6135, .5077,
-	 .4020, .3467, .2915, .2362, .1810, .1568, .1325, .1083,
-	 .0840, .0735, .0630, .0525, .0420, .0380, .0340, .0300,
-	 .0260, .0242, .0225, .0207, .0190, .0180, .0170, .0160,
-	 .0150, .0137, .0125, .0112, .0100, .0087, .0075, .0062,
-	 .0050, .0052, .0055, .0057, .0060, .0060, .0060, .0060,
-	 .0060, .0060, .0060, .0060, .0060, .0045, .0030, .0015,
-	 .0000
+	.4020, .3467, .2915, .2362, .1810, .1568, .1325, .1083,
+	.0840, .0735, .0630, .0525, .0420, .0380, .0340, .0300,
+	.0260, .0242, .0225, .0207, .0190, .0180, .0170, .0160,
+	.0150, .0137, .0125, .0112, .0100, .0087, .0075, .0062,
+	.0050, .0052, .0055, .0057, .0060, .0060, .0060, .0060,
+	.0060, .0060, .0060, .0060, .0060, .0045, .0030, .0015,
+	.0000
-	/* 2nd spectral band of avhrr  (noaa 11) */
-	static const float sr12[209] = {
-	 .0000, .0005, .0010, .0015, .0020, .0025, .0030, .0035,
-	 .0040, .0039, .0037, .0036, .0035, .0034, .0032, .0031,
-	 .0030, .0029, .0028, .0026, .0025, .0024, .0023, .0021,
-	 .0020, .0020, .0020, .0020, .0020, .0020, .0020, .0020,
-	 .0020, .0028, .0035, .0043, .0050, .0173, .0295, .0418,
-	 .0540, .1150, .1760, .2370, .2980, .3822, .4665, .5507,
-	 .6350, .6865, .7380, .7895, .8410, .8623, .8835, .9048,
-	 .9260, .9415, .9570, .9725, .9880, .9910, .9940, .9970,
+    /* 2nd spectral band of avhrr  (noaa 11) */
+    static const float sr12[209] = {
+	.0000, .0005, .0010, .0015, .0020, .0025, .0030, .0035,
+	.0040, .0039, .0037, .0036, .0035, .0034, .0032, .0031,
+	.0030, .0029, .0028, .0026, .0025, .0024, .0023, .0021,
+	.0020, .0020, .0020, .0020, .0020, .0020, .0020, .0020,
+	.0020, .0028, .0035, .0043, .0050, .0173, .0295, .0418,
+	.0540, .1150, .1760, .2370, .2980, .3822, .4665, .5507,
+	.6350, .6865, .7380, .7895, .8410, .8623, .8835, .9048,
+	.9260, .9415, .9570, .9725, .9880, .9910, .9940, .9970,
 	1.0000, .9925, .9850, .9775, .9700, .9600, .9500, .9400,
-	 .9300, .9193, .9085, .8978, .8870, .8770, .8670, .8570,
-	 .8470, .8478, .8485, .8493, .8500, .8518, .8535, .8553,
-	 .8570, .8602, .8635, .8668, .8700, .8673, .8645, .8618,
-	 .8590, .8505, .8420, .8335, .8250, .8183, .8115, .8047,
-	 .7980, .7983, .7985, .7988, .7990, .7935, .7880, .7825,
-	 .7770, .7835, .7900, .7965, .8030, .8075, .8120, .8165,
-	 .8210, .8108, .8005, .7903, .7800, .7767, .7735, .7703,
-	 .7670, .7473, .7275, .7077, .6880, .6755, .6630, .6505,
-	 .6380, .6350, .6320, .6290, .6260, .6345, .6430, .6515/
-	 .6600, .6695, .6790, .6885, .6980, .6790, .6600, .6410,
-	 .6220, .5645, .5070, .4495, .3920, .3420, .2920, .2420,
-	 .1920, .1667, .1415, .1162, .0910, .0795, .0680, .0565,
-	 .0450, .0411, .0372, .0334, .0295, .0256, .0217, .0179,
-	 .0140, .0129, .0117, .0106, .0095, .0084, .0072, .0061,
-	 .0050, .0048, .0045, .0043, .0040, .0038, .0035, .0033,
-	 .0030, .0029, .0027, .0026, .0025, .0024, .0022, .0021,
-	 .0020, .0017, .0015, .0012, .0010, .0007, .0005, .0002,
-	 .0000
+	.9300, .9193, .9085, .8978, .8870, .8770, .8670, .8570,
+	.8470, .8478, .8485, .8493, .8500, .8518, .8535, .8553,
+	.8570, .8602, .8635, .8668, .8700, .8673, .8645, .8618,
+	.8590, .8505, .8420, .8335, .8250, .8183, .8115, .8047,
+	.7980, .7983, .7985, .7988, .7990, .7935, .7880, .7825,
+	.7770, .7835, .7900, .7965, .8030, .8075, .8120, .8165,
+	.8210, .8108, .8005, .7903, .7800, .7767, .7735, .7703,
+	.7670, .7473, .7275, .7077, .6880, .6755, .6630, .6505,
+	.6380, .6350, .6320, .6290, .6260, .6345, .6430, .6515/
+	.6600, .6695, .6790, .6885, .6980, .6790, .6600, .6410,
+	.6220, .5645, .5070, .4495, .3920, .3420, .2920, .2420,
+	.1920, .1667, .1415, .1162, .0910, .0795, .0680, .0565,
+	.0450, .0411, .0372, .0334, .0295, .0256, .0217, .0179,
+	.0140, .0129, .0117, .0106, .0095, .0084, .0072, .0061,
+	.0050, .0048, .0045, .0043, .0040, .0038, .0035, .0033,
+	.0030, .0029, .0027, .0026, .0025, .0024, .0022, .0021,
+	.0020, .0017, .0015, .0012, .0010, .0007, .0005, .0002,
+	.0000
-	/* 1st spectral band of avhrr (noaa 12) */
-	static const float sr13[201] = {
-	 .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
-	 .0000, .0000, .0000, .0000, .0000, .0048, .0135, .0200,
-	 .0270, .1046, .2094, .3253, .4360, .5286, .6030, .6621,
-	 .7090, .7464, .7753, .7966, .8110, .8196, .8249, .8301,
+    /* 1st spectral band of avhrr (noaa 12) */
+    static const float sr13[201] = {
+	.0000, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+	.0000, .0000, .0000, .0000, .0000, .0048, .0135, .0200,
+	.0270, .1046, .2094, .3253, .4360, .5286, .6030, .6621,
+	.7090, .7464, .7753, .7966, .8110, .8196, .8249, .8301,
-	 .8380, .8507, .8668, .8837, .8990, .9109, .9198, .9265,
-	 .9320, .9371, .9419, .9466, .9510, .9552, .9587, .9612,
-	 .9620, .9610, .9593, .9582, .9590, .9625, .9673, .9715,
-	 .9730, .9707, .9666, .9635, .9640, .9701, .9799, .9908,
+	.8380, .8507, .8668, .8837, .8990, .9109, .9198, .9265,
+	.9320, .9371, .9419, .9466, .9510, .9552, .9587, .9612,
+	.9620, .9610, .9593, .9582, .9590, .9625, .9673, .9715,
+	.9730, .9707, .9666, .9635, .9640, .9701, .9799, .9908,
 	1.0000, .9805, .9590, .9407, .9180, .8357, .7325, .6205,
-	 .5120, .4170, .3365, .2692, .2140, .1695, .1343, .1066,
-	 .0850, .0679, .0546, .0442, .0360, .0294, .0240, .0196,
-	 .0160, .0130, .0105, .0089, .0080, .0080, .0083, .0085,
-	 .0080, .0064, .0041, .0018, .0000, .0000, .0000, .0000,
-	 .0000, .0024, .0056, .0087, .0110, .0118, .0117, .0112,
-	 .0110, .0117, .0130, .0145, .0160, .0171, .0178, .0184,
-	 .0190, .0197, .0205, .0213, .0220, .0226, .0229, .0228,
-	 .0220, .0205, .0187, .0170, .0160, .0159, .0160, .0157,
-	 .0140, .0106, .0063, .0023, .0000, .0001, .0018, .0038,
-	 .0050, .0044, .0027, .0009, .0000, .0006, .0023, .0040,
-	 .0050, .0046, .0032, .0015, .0000, .0000, .0000, .0000,
-	 .0000
+	.5120, .4170, .3365, .2692, .2140, .1695, .1343, .1066,
+	.0850, .0679, .0546, .0442, .0360, .0294, .0240, .0196,
+	.0160, .0130, .0105, .0089, .0080, .0080, .0083, .0085,
+	.0080, .0064, .0041, .0018, .0000, .0000, .0000, .0000,
+	.0000, .0024, .0056, .0087, .0110, .0118, .0117, .0112,
+	.0110, .0117, .0130, .0145, .0160, .0171, .0178, .0184,
+	.0190, .0197, .0205, .0213, .0220, .0226, .0229, .0228,
+	.0220, .0205, .0187, .0170, .0160, .0159, .0160, .0157,
+	.0140, .0106, .0063, .0023, .0000, .0001, .0018, .0038,
+	.0050, .0044, .0027, .0009, .0000, .0006, .0023, .0040,
+	.0050, .0046, .0032, .0015, .0000, .0000, .0000, .0000,
+	.0000
-	/* 2nd spectral band of avhrr  (noaa 12) */
-	static const float sr14[189] = {
-	 .0000, .0050, .0111, .0162, .0180, .0153, .0097, .0038,
-	 .0000, .0005, .0060, .0168, .0330, .0555, .0869, .1303,
-	 .1890, .2643, .3509, .4418, .5300, .6096, .6796, .7403,
-	 .7920, .8350, .8702, .8988, .9220, .9408, .9559, .9680,
-	 .9780, .9863, .9929, .9975,1.0000, .0115, .9987, .9958,
-	 .9920, .9876, .9821, .9748, .9650, .9522, .9370, .9203,
-	 .9030, .8858, .8694, .8543, .8410, .8299, .8207, .8129,
-	 .8060, .7997, .7943, .7902, .7880, .7879, .7893, .7916,
-	 .7940, .7959, .7971, .7972, .7960, .7935, .7900, .7860,
-	 .7820, .7783, .7747, .7704, .7650, .7582, .7506, .7433,
-	 .7370, .7326, .7299, .7288, .7290, .7303, .7323, .7350,
-	 .7380, .7411, .7441, .7468, .7490, .7504, .7510, .7505,
-	 .7490, .7463, .7421, .7365, .7290, .7197, .7086, .6960,
-	 .6820, .6670, .6518, .6371, .6240, .6131, .6043, .5973,
-	 .5920, .5881, .5857, .5849, .5860, .5889, .5929, .5969,
-	 .6000, .6011, .5986, .5905, .5750, .5508, .5186, .4792,
-	 .4340, .3842, .3326, .2822, .2360, .1964, .1633, .1357,
-	 .1130, .0943, .0789, .0664, .0560, .0473, .0400, .0339,
-	 .0290, .0250, .0217, .0191, .0170, .0152, .0137, .0123,
-	 .0110, .0098, .0086, .0077, .0070, .0066, .0063, .0059,
-	 .0050, .0035, .0019, .0005, .0000, .0006, .0019, .0033,
-	 .0040, .0036, .0025, .0011, .0000, .0000, .0000, .0000,
+    /* 2nd spectral band of avhrr  (noaa 12) */
+    static const float sr14[189] = {
+	.0000, .0050, .0111, .0162, .0180, .0153, .0097, .0038,
+	.0000, .0005, .0060, .0168, .0330, .0555, .0869, .1303,
+	.1890, .2643, .3509, .4418, .5300, .6096, .6796, .7403,
+	.7920, .8350, .8702, .8988, .9220, .9408, .9559, .9680,
+	.9780, .9863, .9929, .9975,1.0000, .0115, .9987, .9958,
+	.9920, .9876, .9821, .9748, .9650, .9522, .9370, .9203,
+	.9030, .8858, .8694, .8543, .8410, .8299, .8207, .8129,
+	.8060, .7997, .7943, .7902, .7880, .7879, .7893, .7916,
+	.7940, .7959, .7971, .7972, .7960, .7935, .7900, .7860,
+	.7820, .7783, .7747, .7704, .7650, .7582, .7506, .7433,
+	.7370, .7326, .7299, .7288, .7290, .7303, .7323, .7350,
+	.7380, .7411, .7441, .7468, .7490, .7504, .7510, .7505,
+	.7490, .7463, .7421, .7365, .7290, .7197, .7086, .6960,
+	.6820, .6670, .6518, .6371, .6240, .6131, .6043, .5973,
+	.5920, .5881, .5857, .5849, .5860, .5889, .5929, .5969,
+	.6000, .6011, .5986, .5905, .5750, .5508, .5186, .4792,
+	.4340, .3842, .3326, .2822, .2360, .1964, .1633, .1357,
+	.1130, .0943, .0789, .0664, .0560, .0473, .0400, .0339,
+	.0290, .0250, .0217, .0191, .0170, .0152, .0137, .0123,
+	.0110, .0098, .0086, .0077, .0070, .0066, .0063, .0059,
+	.0050, .0035, .0019, .0005, .0000, .0006, .0019, .0033,
+	.0040, .0036, .0025, .0011, .0000, .0000, .0000, .0000,
-	/* 1st spectral band of avhrr (noaa 14) -from NOAA/POD Guide */
-	static const float sr15[241] = {
-	 .0000, .0003, .0007, .0010, .0013, .0152, .0290, .0429,
-	 .0568, .1226, .1884, .2543, .3201, .3727, .4254, .4780,
-	 .5306, .5528, .5749, .5971, .6193, .6267, .6342, .6417,
-	 .6492, .6538, .6583, .6629, .6675, .6734, .6793, .6853,
-	 .6912, .6948, .6984, .7020, .7056, .7106, .7156, .7206,
-	 .7256, .7243, .7229, .7216, .7203, .7188, .7174, .7159,
-	 .7145, .7130, .7116, .7102, .7088, .7154, .7221, .7287,
-	 .7353, .7292, .7232, .7172, .7111, .6501, .5891, .5281,
-	 .4671, .4037, .3402, .2768, .2133, .1830, .1527, .1223,
-	 .0920, .0797, .0675, .0553, .0431, .0406, .0381, .0357,
-	 .0332, .0279, .0226, .0173, .0120, .0117, .0114, .0110,
-	 .0107, .0100, .0093, .0086, .0080, .0076, .0072, .0069,
-	 .0065, .0062, .0059, .0055, .0052, .0051, .0050, .0048,
-	 .0047, .0048, .0049, .0050, .0051, .0051, .0050, .0050,
-	 .0050, .0050, .0051, .0052, .0052, .0053, .0054, .0054,
-	 .0055, .0057, .0059, .0061, .0063, .0068, .0072, .0076,
-	 .0080, .0084, .0088, .0092, .0096, .0100, .0104, .0108,
-	 .0113, .0116, .0119, .0122, .0125, .0127, .0128, .0130,
-	 .0132, .0130, .0128, .0126, .0123, .0120, .0116, .0112,
-	 .0108, .0104, .0099, .0095, .0090, .0086, .0082, .0078,
-	 .0074, .0072, .0070, .0067, .0065, .0063, .0060, .0058,
-	 .0055, .0053, .0050, .0048, .0046, .0044, .0042, .0040,
-	 .0038, .0036, .0034, .0032, .0030, .0028, .0027, .0025,
-	 .0023, .0022, .0022, .0021, .0020, .0019, .0018, .0017,
-	 .0016, .0016, .0015, .0014, .0014, .0013, .0012, .0012,
-	 .0011, .0011, .0011, .0011, .0011, .0011, .0011, .0011,
-	 .0011, .0011, .0011, .0011, .0011, .0011, .0011, .0010,
-	 .0010, .0010, .0010, .0010, .0010, .0010, .0010, .0010,
-	 .0010
+    /* 1st spectral band of avhrr (noaa 14) -from NOAA/POD Guide */
+    static const float sr15[241] = {
+	.0000, .0003, .0007, .0010, .0013, .0152, .0290, .0429,
+	.0568, .1226, .1884, .2543, .3201, .3727, .4254, .4780,
+	.5306, .5528, .5749, .5971, .6193, .6267, .6342, .6417,
+	.6492, .6538, .6583, .6629, .6675, .6734, .6793, .6853,
+	.6912, .6948, .6984, .7020, .7056, .7106, .7156, .7206,
+	.7256, .7243, .7229, .7216, .7203, .7188, .7174, .7159,
+	.7145, .7130, .7116, .7102, .7088, .7154, .7221, .7287,
+	.7353, .7292, .7232, .7172, .7111, .6501, .5891, .5281,
+	.4671, .4037, .3402, .2768, .2133, .1830, .1527, .1223,
+	.0920, .0797, .0675, .0553, .0431, .0406, .0381, .0357,
+	.0332, .0279, .0226, .0173, .0120, .0117, .0114, .0110,
+	.0107, .0100, .0093, .0086, .0080, .0076, .0072, .0069,
+	.0065, .0062, .0059, .0055, .0052, .0051, .0050, .0048,
+	.0047, .0048, .0049, .0050, .0051, .0051, .0050, .0050,
+	.0050, .0050, .0051, .0052, .0052, .0053, .0054, .0054,
+	.0055, .0057, .0059, .0061, .0063, .0068, .0072, .0076,
+	.0080, .0084, .0088, .0092, .0096, .0100, .0104, .0108,
+	.0113, .0116, .0119, .0122, .0125, .0127, .0128, .0130,
+	.0132, .0130, .0128, .0126, .0123, .0120, .0116, .0112,
+	.0108, .0104, .0099, .0095, .0090, .0086, .0082, .0078,
+	.0074, .0072, .0070, .0067, .0065, .0063, .0060, .0058,
+	.0055, .0053, .0050, .0048, .0046, .0044, .0042, .0040,
+	.0038, .0036, .0034, .0032, .0030, .0028, .0027, .0025,
+	.0023, .0022, .0022, .0021, .0020, .0019, .0018, .0017,
+	.0016, .0016, .0015, .0014, .0014, .0013, .0012, .0012,
+	.0011, .0011, .0011, .0011, .0011, .0011, .0011, .0011,
+	.0011, .0011, .0011, .0011, .0011, .0011, .0011, .0010,
+	.0010, .0010, .0010, .0010, .0010, .0010, .0010, .0010,
+	.0010
-	/* 2nd spectral band of avhrr (noaa 14) */
-	static const float sr16[176] = {
-	 .0000,.0000,.0000,.0000,.0000,.0000,.0022,.0045,
-	 .0067,.0090,.0107,.0125,.0143,.0160,.0543,.0925,
-	 .1308,.1690,.2573,.3455,.4338,.5220,.5978,.6735,
-	 .7492,.8250,.8503,.8755,.9007,.9260,.9362,.9465,
-	 .9568,.9670,.9737,.9805,.9872,.9940,.9935,.9930,
-	 .9925,.9920,.9940,.9960,.9980,1.000,.9885,.9770,
-	 .9655,.9540,.9398,.9255,.9112,.8970,.8855,.8740,
-	 .8625,.8510,.8400,.8290,.8180,.8070,.8052,.8035,
-	 .8018,.8000,.8065,.8130,.8195,.8260,.8257,.8255,
-	 .8253,.8250,.8245,.8240,.8235,.8230,.8230,.8230,
-	 .8230,.8230,.8210,.8190,.8170,.8150,.8147,.8145,
-	 .8142,.8140,.8183,.8225,.8267,.8310,.8367,.8425,
-	 .8482,.8540,.8547,.8555,.8562,.8570,.8510,.8450,
-	 .8390,.8330,.8170,.8010,.7850,.7690,.7587,.7485,
-	 .7383,.7280,.7203,.7125,.7048,.6970,.6957,.6945,
-	 .6932,.6920,.6970,.7020,.7070,.7120,.7035,.6950,
-	 .6865,.6780,.6370,.5960,.5550,.5140,.4560,.3980,
-	 .3400,.2820,.2458,.2095,.1732,.1370,.1190,.1010,
-	 .0830,.0650,.0560,.0470,.0380,.0290,.0250,.0210,
-	 .0170,.0130,.0095,.0060,.0050,.0040,.0020,.0000,
-	 .0010,.0020,.0018,.0015,.0012,.0010,.0010,.0010,
-	 .0010,.0010,.0008,.0005,.0003,.0000,.0000,.0000
+    /* 2nd spectral band of avhrr (noaa 14) */
+    static const float sr16[176] = {
+	.0000,.0000,.0000,.0000,.0000,.0000,.0022,.0045,
+	.0067,.0090,.0107,.0125,.0143,.0160,.0543,.0925,
+	.1308,.1690,.2573,.3455,.4338,.5220,.5978,.6735,
+	.7492,.8250,.8503,.8755,.9007,.9260,.9362,.9465,
+	.9568,.9670,.9737,.9805,.9872,.9940,.9935,.9930,
+	.9925,.9920,.9940,.9960,.9980,1.000,.9885,.9770,
+	.9655,.9540,.9398,.9255,.9112,.8970,.8855,.8740,
+	.8625,.8510,.8400,.8290,.8180,.8070,.8052,.8035,
+	.8018,.8000,.8065,.8130,.8195,.8260,.8257,.8255,
+	.8253,.8250,.8245,.8240,.8235,.8230,.8230,.8230,
+	.8230,.8230,.8210,.8190,.8170,.8150,.8147,.8145,
+	.8142,.8140,.8183,.8225,.8267,.8310,.8367,.8425,
+	.8482,.8540,.8547,.8555,.8562,.8570,.8510,.8450,
+	.8390,.8330,.8170,.8010,.7850,.7690,.7587,.7485,
+	.7383,.7280,.7203,.7125,.7048,.6970,.6957,.6945,
+	.6932,.6920,.6970,.7020,.7070,.7120,.7035,.6950,
+	.6865,.6780,.6370,.5960,.5550,.5140,.4560,.3980,
+	.3400,.2820,.2458,.2095,.1732,.1370,.1190,.1010,
+	.0830,.0650,.0560,.0470,.0380,.0290,.0250,.0210,
+	.0170,.0130,.0095,.0060,.0050,.0040,.0020,.0000,
+	.0010,.0020,.0018,.0015,.0012,.0010,.0010,.0010,
+	.0010,.0010,.0008,.0005,.0003,.0000,.0000,.0000
-	static const float wli[16] = { 0.55, 0.69, 0.5, 0.64, 0.54, 0.68, 0.53, 0.68, 0.53, 0.60, 0.54, 0.60, 0.50, 0.65, 0.50, 0.68 };
-	static const float wls[16] = { 0.75, 1.12, 0.8, 1.17, 1.01, 1.12, 0.81, 1.17, 0.78, 1.19, 0.82, 1.12, 1.00, 1.12, 1.11, 1.10 };
+    static const float wli[16] = { 0.55, 0.69, 0.5, 0.64, 0.54, 0.68, 0.53, 0.68, 0.53, 0.60, 0.54, 0.60, 0.50, 0.65, 0.50, 0.68 };
+    static const float wls[16] = { 0.75, 1.12, 0.8, 1.17, 1.01, 1.12, 0.81, 1.17, 0.78, 1.19, 0.82, 1.12, 1.00, 1.12, 1.11, 1.10 };
-	ffu.wlinf = (float)wli[iwa-1];
-	ffu.wlsup = (float)wls[iwa-1];
+    ffu.wlinf = (float)wli[iwa-1];
+    ffu.wlsup = (float)wls[iwa-1];
-	int i;
-	for(i = 0; i < 1501; i++) ffu.s[i] = 0;
+    int i;
+    for(i = 0; i < 1501; i++) ffu.s[i] = 0;
-	switch(iwa)
-	case 1: for(i = 0; i < 80; i++)	 ffu.s[120+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 80; i++)	 ffu.s[120+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 173; i++) ffu.s[176+i] = sr2[i];
+    case 2: for(i = 0; i < 173; i++) ffu.s[176+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 121; i++) ffu.s[100+i] = sr3[i];
+    case 3: for(i = 0; i < 121; i++) ffu.s[100+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 213; i++) ffu.s[156+i] = sr4[i];
+    case 4: for(i = 0; i < 213; i++) ffu.s[156+i] = sr4[i];
 	break;
-	case 5: for(i = 0; i < 189; i++) ffu.s[116+i] = sr5[i];
+    case 5: for(i = 0; i < 189; i++) ffu.s[116+i] = sr5[i];
 	break;
-	case 6: for(i = 0; i < 177; i++) ffu.s[172+i] = sr6[i];
+    case 6: for(i = 0; i < 177; i++) ffu.s[172+i] = sr6[i];
 	break;
-	case 7: for(i = 0; i < 113; i++) ffu.s[112+i] = sr7[i];
+    case 7: for(i = 0; i < 113; i++) ffu.s[112+i] = sr7[i];
 	break;
-	case 8: for(i = 0; i < 197; i++) ffu.s[172+i] = sr8[i];
+    case 8: for(i = 0; i < 197; i++) ffu.s[172+i] = sr8[i];
 	break;
-	case 9: for(i = 0; i < 101; i++) ffu.s[112+i] = sr9[i];
+    case 9: for(i = 0; i < 101; i++) ffu.s[112+i] = sr9[i];
 	break;
-	case 10: for(i = 0; i < 237; i++) ffu.s[140+i] = sr10[i];
+    case 10: for(i = 0; i < 237; i++) ffu.s[140+i] = sr10[i];
 	break;
-	case 11: for(i = 0; i < 113; i++) ffu.s[116+i] = sr11[i];
+    case 11: for(i = 0; i < 113; i++) ffu.s[116+i] = sr11[i];
 	break;
-	case 12: for(i = 0; i < 209; i++) ffu.s[140+i] = sr12[i];
+    case 12: for(i = 0; i < 209; i++) ffu.s[140+i] = sr12[i];
 	break;
-	case 13: for(i = 0; i < 201; i++) ffu.s[100+i] = sr13[i];
+    case 13: for(i = 0; i < 201; i++) ffu.s[100+i] = sr13[i];
 	break;
-	case 14: for(i = 0; i < 189; i++) ffu.s[160+i] = sr14[i];
+    case 14: for(i = 0; i < 189; i++) ffu.s[160+i] = sr14[i];
 	break;
-	case 15: for(i = 0; i < 241; i++) ffu.s[100+i] = sr15[i];
+    case 15: for(i = 0; i < 241; i++) ffu.s[100+i] = sr15[i];
 	break;
-	case 16: for(i = 0; i < 176; i++) ffu.s[168+i] = sr16[i];
+    case 16: for(i = 0; i < 176; i++) ffu.s[168+i] = sr16[i];
 void IWave::hrv(int iwa)
-	/* 1st spectral band of hrv1 */
-	static const float sr1[73] = {
-       .0010, .0023, .0035, .0048, .0060, .0492, .0925, .1357,
-       .1790, .2598, .3405, .4213, .5020, .5575, .6130, .6685,
-       .7240, .7588, .7935, .8283, .8630, .8900, .9170, .9440,
-       .9710, .9782, .9855, .9927,1.0000, .9875, .9750, .9625,
-       .9500, .9255, .9010, .8765, .8520, .8225, .7930, .7635,
-       .7340, .7105, .6870, .6635, .6400, .5945, .5490, .5035,
-       .4580, .3985, .3390, .2795, .2200, .1787, .1375, .0962,
-       .0550, .0437, .0325, .0212, .0100, .0085, .0070, .0055,
-       .0040, .0035, .0030, .0025, .0020, .0015, .0010, .0005,
-       .0000
+    /* 1st spectral band of hrv1 */
+    static const float sr1[73] = {
+	.0010, .0023, .0035, .0048, .0060, .0492, .0925, .1357,
+	.1790, .2598, .3405, .4213, .5020, .5575, .6130, .6685,
+	.7240, .7588, .7935, .8283, .8630, .8900, .9170, .9440,
+	.9710, .9782, .9855, .9927,1.0000, .9875, .9750, .9625,
+	.9500, .9255, .9010, .8765, .8520, .8225, .7930, .7635,
+	.7340, .7105, .6870, .6635, .6400, .5945, .5490, .5035,
+	.4580, .3985, .3390, .2795, .2200, .1787, .1375, .0962,
+	.0550, .0437, .0325, .0212, .0100, .0085, .0070, .0055,
+	.0040, .0035, .0030, .0025, .0020, .0015, .0010, .0005,
+	.0000
     /* 2nd spectral band of hrv1 */
-	static const float sr2[49] = {
-       .0190, .0845, .1500, .2155, .2810, .3870, .4930, .5990,
-       .7050, .7663, .8275, .8888, .9500, .9557, .9615, .9672,
-       .9730, .9797, .9865, .9933,1.0000, .8445, .6890, .5335,
-       .3780, .3152, .2525, .1897, .1270, .1067, .0865, .0662,
-       .0460, .0395, .0330, .0265, .0200, .0172, .0145, .0117,
-       .0090, .0080, .0070, .0060, .0050, .0045, .0040, .0035,
-       .0030
+    static const float sr2[49] = {
+	.0190, .0845, .1500, .2155, .2810, .3870, .4930, .5990,
+	.7050, .7663, .8275, .8888, .9500, .9557, .9615, .9672,
+	.9730, .9797, .9865, .9933,1.0000, .8445, .6890, .5335,
+	.3780, .3152, .2525, .1897, .1270, .1067, .0865, .0662,
+	.0460, .0395, .0330, .0265, .0200, .0172, .0145, .0117,
+	.0090, .0080, .0070, .0060, .0050, .0045, .0040, .0035,
+	.0030
     /* 3rd spectral band of hrv1 */
-	static const float sr3[81] = {
-       .0010, .0033, .0055, .0078, .0100, .0238, .0375, .0513,
-       .0650, .0953, .1255, .1558, .1860, .2470, .3080, .3690,
-       .4300, .4918, .5535, .6153, .6770, .7222, .7675, .8127,
-       .8580, .8825, .9070, .9315, .9560, .9670, .9780, .9890,
-      1.0000, .9915, .9830, .9745, .9660, .9557, .9455, .9352,
-       .9250, .9112, .8975, .8837, .8700, .8777, .8855, .8932,
-       .9010, .8342, .7675, .7007, .6340, .5600, .4860, .4120,
-       .3380, .2875, .2370, .1865, .1360, .1130, .0900, .0670,
-       .0440, .0360, .0280, .0200, .0120, .0108, .0095, .0083,
-       .0070, .0067, .0065, .0062, .0060, .0047, .0035, .0022,
-       .0010
+    static const float sr3[81] = {
+	.0010, .0033, .0055, .0078, .0100, .0238, .0375, .0513,
+	.0650, .0953, .1255, .1558, .1860, .2470, .3080, .3690,
+	.4300, .4918, .5535, .6153, .6770, .7222, .7675, .8127,
+	.8580, .8825, .9070, .9315, .9560, .9670, .9780, .9890,
+	1.0000, .9915, .9830, .9745, .9660, .9557, .9455, .9352,
+	.9250, .9112, .8975, .8837, .8700, .8777, .8855, .8932,
+	.9010, .8342, .7675, .7007, .6340, .5600, .4860, .4120,
+	.3380, .2875, .2370, .1865, .1360, .1130, .0900, .0670,
+	.0440, .0360, .0280, .0200, .0120, .0108, .0095, .0083,
+	.0070, .0067, .0065, .0062, .0060, .0047, .0035, .0022,
+	.0010
     /* panchromatic band of hrv1 */
-	static const float sr4[129] = {
-       .0000, .0013, .0025, .0038, .0050, .0322, .0595, .0867,
-       .1140, .1723, .2305, .2888, .3470, .3748, .4025, .4303,
-       .4580, .4750, .4920, .5090, .5260, .5538, .5815, .6093,
-       .6370, .6575, .6780, .6985, .7190, .7228, .7265, .7303,
-       .7340, .7370, .7400, .7430, .7460, .7595, .7730, .7865,
-       .8000, .8163, .8325, .8488, .8650, .8767, .8885, .9003,
-       .9120, .9137, .9155, .9172, .9190, .9245, .9300, .9355,
-       .9410, .9387, .9365, .9342, .9320, .9373, .9425, .9478,
-       .9530, .9575, .9620, .9665, .9710, .9783, .9855, .9928,
-      1.0000, .9898, .9795, .9693, .9590, .9450, .9310, .9170,
-       .9030, .8780, .8530, .8280, .8030, .7770, .7510, .7250,
-       .6990, .6820, .6650, .6480, .6310, .6235, .6160, .6085,
-       .6010, .5535, .5060, .4585, .4110, .3620, .3130, .2640,
-       .2150, .1825, .1500, .1175, .0850, .0720, .0590, .0460,
-       .0330, .0282, .0235, .0187, .0140, .0120, .0100, .0080,
-       .0060, .0055, .0050, .0045, .0040, .0035, .0030, .0025,
-       .0020
+    static const float sr4[129] = {
+	.0000, .0013, .0025, .0038, .0050, .0322, .0595, .0867,
+	.1140, .1723, .2305, .2888, .3470, .3748, .4025, .4303,
+	.4580, .4750, .4920, .5090, .5260, .5538, .5815, .6093,
+	.6370, .6575, .6780, .6985, .7190, .7228, .7265, .7303,
+	.7340, .7370, .7400, .7430, .7460, .7595, .7730, .7865,
+	.8000, .8163, .8325, .8488, .8650, .8767, .8885, .9003,
+	.9120, .9137, .9155, .9172, .9190, .9245, .9300, .9355,
+	.9410, .9387, .9365, .9342, .9320, .9373, .9425, .9478,
+	.9530, .9575, .9620, .9665, .9710, .9783, .9855, .9928,
+	1.0000, .9898, .9795, .9693, .9590, .9450, .9310, .9170,
+	.9030, .8780, .8530, .8280, .8030, .7770, .7510, .7250,
+	.6990, .6820, .6650, .6480, .6310, .6235, .6160, .6085,
+	.6010, .5535, .5060, .4585, .4110, .3620, .3130, .2640,
+	.2150, .1825, .1500, .1175, .0850, .0720, .0590, .0460,
+	.0330, .0282, .0235, .0187, .0140, .0120, .0100, .0080,
+	.0060, .0055, .0050, .0045, .0040, .0035, .0030, .0025,
+	.0020
     /* 1st spectral band of hrv2 */
-	static const float sr5[73] = {
-       .0010, .0015, .0020, .0025, .0030, .0040, .0050, .0060,
-       .0070, .0850, .1630, .2410, .3190, .3918, .4645, .5373,
-       .6100, .6500, .6900, .7300, .7700, .7965, .8230, .8495,
-       .8760, .8957, .9155, .9352, .9550, .9663, .9775, .9888,
-      1.0000, .9915, .9830, .9745, .9660, .9362, .9065, .8767,
-       .8470, .8147, .7825, .7502, .7180, .6660, .6140, .5620,
-       .5100, .4638, .4175, .3713, .3250, .2737, .2225, .1712,
-       .1200, .1012, .0825, .0637, .0450, .0377, .0305, .0232,
-       .0160, .0122, .0085, .0047, .0010, .0007, .0005, .0002,
-       .0000
+    static const float sr5[73] = {
+	.0010, .0015, .0020, .0025, .0030, .0040, .0050, .0060,
+	.0070, .0850, .1630, .2410, .3190, .3918, .4645, .5373,
+	.6100, .6500, .6900, .7300, .7700, .7965, .8230, .8495,
+	.8760, .8957, .9155, .9352, .9550, .9663, .9775, .9888,
+	1.0000, .9915, .9830, .9745, .9660, .9362, .9065, .8767,
+	.8470, .8147, .7825, .7502, .7180, .6660, .6140, .5620,
+	.5100, .4638, .4175, .3713, .3250, .2737, .2225, .1712,
+	.1200, .1012, .0825, .0637, .0450, .0377, .0305, .0232,
+	.0160, .0122, .0085, .0047, .0010, .0007, .0005, .0002,
+	.0000
     /* 2nd spectral band of hrv2 */
-	static const float sr6[57] = {
-       .0040, .0045, .0050, .0055, .0060, .0115, .0170, .0225,
-       .0280, .0893, .1505, .2118, .2730, .3593, .4455, .5318,
-       .6180, .6803, .7425, .8048, .8670, .9003, .9335, .9668,
-      1.0000, .9365, .8730, .8095, .7460, .6830, .6200, .5570,
-       .4940, .4405, .3870, .3335, .2800, .2452, .2105, .1757,
-       .1410, .1222, .1035, .0847, .0660, .0575, .0490, .0405,
-       .0320, .0283, .0245, .0208, .0170, .0152, .0135, .0117,
-       .0100
+    static const float sr6[57] = {
+	.0040, .0045, .0050, .0055, .0060, .0115, .0170, .0225,
+	.0280, .0893, .1505, .2118, .2730, .3593, .4455, .5318,
+	.6180, .6803, .7425, .8048, .8670, .9003, .9335, .9668,
+	1.0000, .9365, .8730, .8095, .7460, .6830, .6200, .5570,
+	.4940, .4405, .3870, .3335, .2800, .2452, .2105, .1757,
+	.1410, .1222, .1035, .0847, .0660, .0575, .0490, .0405,
+	.0320, .0283, .0245, .0208, .0170, .0152, .0135, .0117,
+	.0100
     /* 3rd spectral band of hrv2 */
-	static const float sr7[81] = {
-       .0020, .0030, .0040, .0050, .0060, .0105, .0150, .0195,
-       .0240, .0380, .0520, .0660, .0800, .1140, .1480, .1820,
-       .2160, .2722, .3285, .3847, .4410, .5018, .5625, .6233,
-       .6840, .7298, .7755, .8213, .8670, .8920, .9170, .9420,
-       .9670, .9753, .9835, .9918,1.0000, .9967, .9935, .9902,
-       .9870, .9793, .9715, .9638, .9560, .9500, .9440, .9380,
-       .9320, .9047, .8775, .8502, .8230, .7665, .7100, .6535,
-       .5970, .5305, .4640, .3975, .3310, .2850, .2390, .1930,
-       .1470, .1250, .1030, .0810, .0590, .0497, .0405, .0312,
-       .0220, .0185, .0150, .0115, .0080, .0062, .0045, .0027,
-       .0010
+    static const float sr7[81] = {
+	.0020, .0030, .0040, .0050, .0060, .0105, .0150, .0195,
+	.0240, .0380, .0520, .0660, .0800, .1140, .1480, .1820,
+	.2160, .2722, .3285, .3847, .4410, .5018, .5625, .6233,
+	.6840, .7298, .7755, .8213, .8670, .8920, .9170, .9420,
+	.9670, .9753, .9835, .9918,1.0000, .9967, .9935, .9902,
+	.9870, .9793, .9715, .9638, .9560, .9500, .9440, .9380,
+	.9320, .9047, .8775, .8502, .8230, .7665, .7100, .6535,
+	.5970, .5305, .4640, .3975, .3310, .2850, .2390, .1930,
+	.1470, .1250, .1030, .0810, .0590, .0497, .0405, .0312,
+	.0220, .0185, .0150, .0115, .0080, .0062, .0045, .0027,
+	.0010
     /* panchromatic spectral band of hrv2 */
-	static const float sr8[129] = {
-       .0010, .0013, .0015, .0018, .0020, .0137, .0255, .0372,
-       .0490, .0898, .1305, .1713, .2120, .2468, .2815, .3163,
-       .3510, .3725, .3940, .4155, .4370, .4655, .4940, .5225,
-       .5510, .5742, .5975, .6207, .6440, .6505, .6570, .6635,
-       .6700, .6752, .6805, .6858, .6910, .7032, .7155, .7278,
-       .7400, .7530, .7660, .7790, .7920, .8027, .8135, .8242,
-       .8350, .8427, .8505, .8582, .8660, .8692, .8725, .8758,
-       .8790, .8830, .8870, .8910, .8950, .9025, .9100, .9175,
-       .9250, .9365, .9480, .9595, .9710, .9783, .9855, .9928,
-      1.0000, .9930, .9860, .9790, .9720, .9548, .9375, .9202,
-       .9030, .8802, .8575, .8347, .8120, .7945, .7770, .7595,
-       .7420, .7062, .6705, .6347, .5990, .5587, .5185, .4782,
-       .4380, .3893, .3405, .2918, .2430, .2085, .1740, .1395,
-       .1050, .0895, .0740, .0585, .0430, .0367, .0305, .0242,
-       .0180, .0155, .0130, .0105, .0080, .0070, .0060, .0050,
-       .0040, .0035, .0030, .0025, .0020, .0018, .0015, .0013,
-       .0010
+    static const float sr8[129] = {
+	.0010, .0013, .0015, .0018, .0020, .0137, .0255, .0372,
+	.0490, .0898, .1305, .1713, .2120, .2468, .2815, .3163,
+	.3510, .3725, .3940, .4155, .4370, .4655, .4940, .5225,
+	.5510, .5742, .5975, .6207, .6440, .6505, .6570, .6635,
+	.6700, .6752, .6805, .6858, .6910, .7032, .7155, .7278,
+	.7400, .7530, .7660, .7790, .7920, .8027, .8135, .8242,
+	.8350, .8427, .8505, .8582, .8660, .8692, .8725, .8758,
+	.8790, .8830, .8870, .8910, .8950, .9025, .9100, .9175,
+	.9250, .9365, .9480, .9595, .9710, .9783, .9855, .9928,
+	1.0000, .9930, .9860, .9790, .9720, .9548, .9375, .9202,
+	.9030, .8802, .8575, .8347, .8120, .7945, .7770, .7595,
+	.7420, .7062, .6705, .6347, .5990, .5587, .5185, .4782,
+	.4380, .3893, .3405, .2918, .2430, .2085, .1740, .1395,
+	.1050, .0895, .0740, .0585, .0430, .0367, .0305, .0242,
+	.0180, .0155, .0130, .0105, .0080, .0070, .0060, .0050,
+	.0040, .0035, .0030, .0025, .0020, .0018, .0015, .0013,
+	.0010
-	static const float wli[8] = { 0.4699999, 0.60, 0.73, 0.4699999, 0.4699999, 0.5899999, 0.74, 0.4699999 };
-	static const float wls[8] = { 0.6499999, 0.72, 0.93, 0.7900000, 0.6499999, 0.7300000, 0.94, 0.7900000 };
+    static const float wli[8] = { 0.4699999, 0.60, 0.73, 0.4699999, 0.4699999, 0.5899999, 0.74, 0.4699999 };
+    static const float wls[8] = { 0.6499999, 0.72, 0.93, 0.7900000, 0.6499999, 0.7300000, 0.94, 0.7900000 };
-	ffu.wlinf = wli[iwa-1];
-	ffu.wlsup = wls[iwa-1];
+    ffu.wlinf = wli[iwa-1];
+    ffu.wlsup = wls[iwa-1];
-	int i;
+    int i;
-	switch(iwa)
-	case 1: for(i = 0; i < 73; i++)	 ffu.s[88+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 73; i++)	 ffu.s[88+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 49; i++)	 ffu.s[140+i] = sr2[i];
+    case 2: for(i = 0; i < 49; i++)	 ffu.s[140+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 81; i++)	 ffu.s[192+i] = sr3[i];
+    case 3: for(i = 0; i < 81; i++)	 ffu.s[192+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 129; i++) ffu.s[88+i] = sr4[i];
+    case 4: for(i = 0; i < 129; i++) ffu.s[88+i] = sr4[i];
 	break;
-	case 5: for(i = 0; i < 73; i++)	 ffu.s[88+i] = sr5[i];
+    case 5: for(i = 0; i < 73; i++)	 ffu.s[88+i] = sr5[i];
 	break;
-	case 6: for(i = 0; i < 57; i++)	 ffu.s[136+i] = sr6[i];
+    case 6: for(i = 0; i < 57; i++)	 ffu.s[136+i] = sr6[i];
 	break;
-	case 7: for(i = 0; i < 81; i++)	 ffu.s[196+i] = sr7[i];
+    case 7: for(i = 0; i < 81; i++)	 ffu.s[196+i] = sr7[i];
 	break;
-	case 8: for(i = 0; i < 129; i++) ffu.s[88+i] = sr8[i];
+    case 8: for(i = 0; i < 129; i++) ffu.s[88+i] = sr8[i];
 	break;
 void IWave::tm(int iwa)
     /* 1st spectral band of thematic mapper */
-	static const float sr1[53] = {
-       .0030, .0085, .0140, .0255, .0370, .0500, .0630, .2010,
-       .3390, .5030, .6670, .6935, .7200, .7525, .7850, .8030,
-       .8210, .8370, .8530, .8780, .9030, .9135, .9240, .9355,
-       .9470, .9625, .9780, .9835, .9890, .9860, .9830, .9060,
-       .8290, .7815, .7340, .5265, .3190, .1995, .0800, .0630,
-       .0460, .0380, .0300, .0230, .0160, .0120, .0080, .0065,
-       .0050, .0045, .0040, .0035, .0030
+    static const float sr1[53] = {
+	.0030, .0085, .0140, .0255, .0370, .0500, .0630, .2010,
+	.3390, .5030, .6670, .6935, .7200, .7525, .7850, .8030,
+	.8210, .8370, .8530, .8780, .9030, .9135, .9240, .9355,
+	.9470, .9625, .9780, .9835, .9890, .9860, .9830, .9060,
+	.8290, .7815, .7340, .5265, .3190, .1995, .0800, .0630,
+	.0460, .0380, .0300, .0230, .0160, .0120, .0080, .0065,
+	.0050, .0045, .0040, .0035, .0030
     /* 2nd spectral band of thematic mapper */
-	static const float sr2[61] = {
-       .0010, .0055, .0100, .0165, .0230, .0305, .0380, .1010,
-       .1640, .2710, .3780, .4750, .5720, .6150, .6580, .6945,
-       .7310, .7575, .7840, .8105, .8370, .8510, .8650, .8770,
-       .8890, .8965, .9040, .9055, .9070, .9070, .9070, .9095,
-       .9120, .9310, .9500, .9685, .9870, .9951, .9980, .9705,
-       .9430, .8655, .7880, .6250, .4620, .3330, .2040, .1505,
-       .0970, .0745, .0520, .0440, .0360, .0285, .0210, .0165,
-       .0120, .0090, .0060, .0030, .0000
+    static const float sr2[61] = {
+	.0010, .0055, .0100, .0165, .0230, .0305, .0380, .1010,
+	.1640, .2710, .3780, .4750, .5720, .6150, .6580, .6945,
+	.7310, .7575, .7840, .8105, .8370, .8510, .8650, .8770,
+	.8890, .8965, .9040, .9055, .9070, .9070, .9070, .9095,
+	.9120, .9310, .9500, .9685, .9870, .9951, .9980, .9705,
+	.9430, .8655, .7880, .6250, .4620, .3330, .2040, .1505,
+	.0970, .0745, .0520, .0440, .0360, .0285, .0210, .0165,
+	.0120, .0090, .0060, .0030, .0000
     /* 3rd spectral band of thematic mapper */
-	static const float sr3[65] = {
-       .0020, .0020, .0020, .0020, .0020, .0030, .0040, .0060,
-       .0080, .0140, .0200, .0290, .0380, .0730, .1080, .2020,
-       .2960, .3840, .4720, .5245, .5770, .6625, .7480, .7830,
-       .8180, .8430, .8680, .8845, .9010, .9030, .9050, .9055,
-       .9060, .9200, .9340, .9520, .9700, .9815, .9930,1.0000,
-       .9980, .9770, .9560, .8715, .7870, .5775, .3680, .2435,
-       .1190, .0920, .0650, .0555, .0460, .0385, .0310, .0255,
-       .0200, .0160, .0120, .0090, .0060, .0055, .0050, .0040,
-       .0030
+    static const float sr3[65] = {
+	.0020, .0020, .0020, .0020, .0020, .0030, .0040, .0060,
+	.0080, .0140, .0200, .0290, .0380, .0730, .1080, .2020,
+	.2960, .3840, .4720, .5245, .5770, .6625, .7480, .7830,
+	.8180, .8430, .8680, .8845, .9010, .9030, .9050, .9055,
+	.9060, .9200, .9340, .9520, .9700, .9815, .9930,1.0000,
+	.9980, .9770, .9560, .8715, .7870, .5775, .3680, .2435,
+	.1190, .0920, .0650, .0555, .0460, .0385, .0310, .0255,
+	.0200, .0160, .0120, .0090, .0060, .0055, .0050, .0040,
+	.0030
     /* 4th spectral band of thematic mapper */
-	static const float sr4[89] = {
-       .0020, .0035, .0050, .0060, .0070, .0080, .0090, .0140,
-       .0190, .0260, .0330, .0520, .0710, .1035, .1360, .2055,
-       .2750, .3615, .4480, .5505, .6530, .7410, .8290, .8795,
-       .9300, .9520, .9740, .9870,1.0000, .9955, .9910, .9855,
-       .9800, .9685, .9570, .9465, .9360, .9260, .9160, .9165,
-       .9170, .9180, .9190, .9195, .9200, .9215, .9230, .9240,
-       .9250, .9160, .9070, .8965, .8860, .8835, .8810, .8825,
-       .8840, .8825, .8810, .8705, .8600, .8410, .8220, .8030,
-       .7840, .7715, .7590, .7370, .7150, .5905, .4660, .3385,
-       .2110, .1440, .0770, .0540, .0310, .0230, .0150, .0115,
-       .0080, .0070, .0060, .0050, .0040, .0030, .0020, .0010,
-       .0000
+    static const float sr4[89] = {
+	.0020, .0035, .0050, .0060, .0070, .0080, .0090, .0140,
+	.0190, .0260, .0330, .0520, .0710, .1035, .1360, .2055,
+	.2750, .3615, .4480, .5505, .6530, .7410, .8290, .8795,
+	.9300, .9520, .9740, .9870,1.0000, .9955, .9910, .9855,
+	.9800, .9685, .9570, .9465, .9360, .9260, .9160, .9165,
+	.9170, .9180, .9190, .9195, .9200, .9215, .9230, .9240,
+	.9250, .9160, .9070, .8965, .8860, .8835, .8810, .8825,
+	.8840, .8825, .8810, .8705, .8600, .8410, .8220, .8030,
+	.7840, .7715, .7590, .7370, .7150, .5905, .4660, .3385,
+	.2110, .1440, .0770, .0540, .0310, .0230, .0150, .0115,
+	.0080, .0070, .0060, .0050, .0040, .0030, .0020, .0010,
+	.0000
     /* 5th spectral band of thematic mapper */
-	static const float sr5[156] = {
-       .0000, .0003, .0007, .0010, .0013, .0015, .0018, .0020,
-       .0038, .0055, .0073, .0090, .0123, .0155, .0188, .0220,
-       .0393, .0565, .0738, .0910, .1410, .1910, .2410, .2910,
-       .3617, .4325, .5032, .5740, .6383, .7025, .7668, .8310,
-       .8622, .8935, .9248, .9560, .9522, .9485, .9447, .9410,
-       .9417, .9425, .9433, .9440, .9505, .9570, .9635, .9700,
-       .9738, .9775, .9813, .9850, .9833, .9815, .9797, .9780,
-       .9747, .9715, .9682, .9650, .9682, .9715, .9747, .9780,
-       .9793, .9805, .9818, .9830, .9837, .9845, .9852, .9860,
-       .9838, .9815, .9793, .9770, .9815, .9860, .9905, .9950,
-       .9963, .9975, .9988,1.0000, .9992, .9985, .9977, .9970,
-       .9912, .9855, .9797, .9740, .9697, .9655, .9613, .9570,
-       .9553, .9535, .9517, .9500, .9505, .9510, .9515, .9520,
-       .9370, .9220, .9070, .8920, .8260, .7600, .6940, .6280,
-       .5507, .4735, .3962, .3190, .2780, .2370, .1960, .1550,
-       .1340, .1130, .0920, .0710, .0643, .0575, .0508, .0440,
-       .0385, .0330, .0275, .0220, .0197, .0175, .0152, .0130,
-       .0120, .0110, .0100, .0090, .0077, .0065, .0052, .0040,
-       .0037, .0035, .0032, .0030, .0027, .0025, .0022, .0020,
-       .0015, .0010, .0005, .0000
+    static const float sr5[156] = {
+	.0000, .0003, .0007, .0010, .0013, .0015, .0018, .0020,
+	.0038, .0055, .0073, .0090, .0123, .0155, .0188, .0220,
+	.0393, .0565, .0738, .0910, .1410, .1910, .2410, .2910,
+	.3617, .4325, .5032, .5740, .6383, .7025, .7668, .8310,
+	.8622, .8935, .9248, .9560, .9522, .9485, .9447, .9410,
+	.9417, .9425, .9433, .9440, .9505, .9570, .9635, .9700,
+	.9738, .9775, .9813, .9850, .9833, .9815, .9797, .9780,
+	.9747, .9715, .9682, .9650, .9682, .9715, .9747, .9780,
+	.9793, .9805, .9818, .9830, .9837, .9845, .9852, .9860,
+	.9838, .9815, .9793, .9770, .9815, .9860, .9905, .9950,
+	.9963, .9975, .9988,1.0000, .9992, .9985, .9977, .9970,
+	.9912, .9855, .9797, .9740, .9697, .9655, .9613, .9570,
+	.9553, .9535, .9517, .9500, .9505, .9510, .9515, .9520,
+	.9370, .9220, .9070, .8920, .8260, .7600, .6940, .6280,
+	.5507, .4735, .3962, .3190, .2780, .2370, .1960, .1550,
+	.1340, .1130, .0920, .0710, .0643, .0575, .0508, .0440,
+	.0385, .0330, .0275, .0220, .0197, .0175, .0152, .0130,
+	.0120, .0110, .0100, .0090, .0077, .0065, .0052, .0040,
+	.0037, .0035, .0032, .0030, .0027, .0025, .0022, .0020,
+	.0015, .0010, .0005, .0000
     /* 7th spectral band of thematic mapper */
- 	static const float sr6[185] = {
-       .0040, .0043, .0045, .0048, .0050, .0055, .0060, .0065,
-       .0070, .0075, .0080, .0085, .0090, .0103, .0115, .0128,
-       .0140, .0153, .0165, .0178, .0190, .0233, .0275, .0318,
-       .0360, .0400, .0440, .0480, .0520, .0563, .0605, .0648,
-       .0690, .0768, .0845, .0923, .1000, .1125, .1250, .1375,
-       .1500, .1753, .2005, .2258, .2510, .2870, .3230, .3590,
-       .3950, .4313, .4675, .5038, .5400, .5788, .6175, .6563,
-       .6950, .7345, .7740, .8135, .8530, .8737, .8945, .9152,
-       .9360, .9398, .9435, .9473, .9510, .9472, .9435, .9397,
-       .9360, .9385, .9410, .9435, .9460, .9500, .9540, .9580,
-       .9620, .9693, .9765, .9838, .9910, .9930, .9950, .9970,
-       .9990,1.0000, .9988, .9975, .9960, .9952, .9945, .9937,
-       .9930, .9922, .9915, .9908, .9900, .9815, .9730, .9645,
-       .9560, .9525, .9490, .9455, .9420, .9370, .9320, .9270,
-       .9220, .9205, .9190, .9175, .9160, .9135, .9110, .9085,
-       .9060, .9020, .8980, .8940, .8900, .8730, .8560, .8390,
-       .8220, .8058, .7895, .7732, .7570, .7545, .7520, .7495,
-       .7470, .7623, .7775, .7928, .8080, .8245, .8410, .8575,
-       .8740, .8292, .7845, .7397, .6950, .6290, .5630, .4970,
-       .4310, .3747, .3185, .2622, .2060, .1735, .1410, .1085,
-       .0760, .0653, .0545, .0438, .0330, .0275, .0220, .0165,
-       .0110, .0097, .0085, .0072, .0060, .0045, .0030, .0015,
-       .0000
+    static const float sr6[185] = {
+	.0040, .0043, .0045, .0048, .0050, .0055, .0060, .0065,
+	.0070, .0075, .0080, .0085, .0090, .0103, .0115, .0128,
+	.0140, .0153, .0165, .0178, .0190, .0233, .0275, .0318,
+	.0360, .0400, .0440, .0480, .0520, .0563, .0605, .0648,
+	.0690, .0768, .0845, .0923, .1000, .1125, .1250, .1375,
+	.1500, .1753, .2005, .2258, .2510, .2870, .3230, .3590,
+	.3950, .4313, .4675, .5038, .5400, .5788, .6175, .6563,
+	.6950, .7345, .7740, .8135, .8530, .8737, .8945, .9152,
+	.9360, .9398, .9435, .9473, .9510, .9472, .9435, .9397,
+	.9360, .9385, .9410, .9435, .9460, .9500, .9540, .9580,
+	.9620, .9693, .9765, .9838, .9910, .9930, .9950, .9970,
+	.9990,1.0000, .9988, .9975, .9960, .9952, .9945, .9937,
+	.9930, .9922, .9915, .9908, .9900, .9815, .9730, .9645,
+	.9560, .9525, .9490, .9455, .9420, .9370, .9320, .9270,
+	.9220, .9205, .9190, .9175, .9160, .9135, .9110, .9085,
+	.9060, .9020, .8980, .8940, .8900, .8730, .8560, .8390,
+	.8220, .8058, .7895, .7732, .7570, .7545, .7520, .7495,
+	.7470, .7623, .7775, .7928, .8080, .8245, .8410, .8575,
+	.8740, .8292, .7845, .7397, .6950, .6290, .5630, .4970,
+	.4310, .3747, .3185, .2622, .2060, .1735, .1410, .1085,
+	.0760, .0653, .0545, .0438, .0330, .0275, .0220, .0165,
+	.0110, .0097, .0085, .0072, .0060, .0045, .0030, .0015,
+	.0000
-	static const float wli[6] = { 0.43, 0.5000000, 0.5799999, 0.73, 1.5025, 1.95 };
-	static const float wls[6] = { 0.56, 0.6499999, 0.7400000, 0.95, 1.8900, 2.41 };
+    static const float wli[6] = { 0.43, 0.5000000, 0.5799999, 0.73, 1.5025, 1.95 };
+    static const float wls[6] = { 0.56, 0.6499999, 0.7400000, 0.95, 1.8900, 2.41 };
-	int i;
+    int i;
-	switch(iwa)
-	case 1: for(i = 0; i < 53; i++)	 ffu.s[72+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 53; i++)	 ffu.s[72+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 61; i++)	 ffu.s[100+i] = sr2[i];
+    case 2: for(i = 0; i < 61; i++)	 ffu.s[100+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 65; i++)	 ffu.s[132+i] = sr3[i];
+    case 3: for(i = 0; i < 65; i++)	 ffu.s[132+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 89; i++)	 ffu.s[192+i] = sr4[i];
+    case 4: for(i = 0; i < 89; i++)	 ffu.s[192+i] = sr4[i];
 	break;
-	case 5: for(i = 0; i < 156; i++) ffu.s[501+i] = sr5[i];
+    case 5: for(i = 0; i < 156; i++) ffu.s[501+i] = sr5[i];
 	break;
-	case 6: for(i = 0; i < 185; i++) ffu.s[680+i] = sr6[i];
+    case 6: for(i = 0; i < 185; i++) ffu.s[680+i] = sr6[i];
 	break;
 void IWave::mss(int iwa)
     /* 1st spectral band of multi spectral scanner */
- 	static const float sr1[67] = {
-          .00,    .01,    .01,    .01,    .02,    .04,    .05,
-          .09,    .13,    .21,    .29,    .45,    .61,    .72,
-          .82,    .85,    .89,    .92,    .95,    .96,    .98,
-          .99,    .99,   1.00,   1.00,   1.00,   1.00,   1.00,
-         1.00,   1.00,    .99,    .99,    .98,    .98,    .98,
-          .97,    .97,    .96,    .96,    .96,    .96,    .95,
-          .95,    .93,    .91,    .89,    .87,    .85,    .82,
-          .73,    .65,    .54,    .43,    .38,    .33,    .24,
-          .15,    .11,    .08,    .06,    .04,    .03,    .03,
-          .02,    .02,    .02,    .01
+    static const float sr1[67] = {
+	.00,    .01,    .01,    .01,    .02,    .04,    .05,
+	.09,    .13,    .21,    .29,    .45,    .61,    .72,
+	.82,    .85,    .89,    .92,    .95,    .96,    .98,
+	.99,    .99,   1.00,   1.00,   1.00,   1.00,   1.00,
+	1.00,   1.00,    .99,    .99,    .98,    .98,    .98,
+	.97,    .97,    .96,    .96,    .96,    .96,    .95,
+	.95,    .93,    .91,    .89,    .87,    .85,    .82,
+	.73,    .65,    .54,    .43,    .38,    .33,    .24,
+	.15,    .11,    .08,    .06,    .04,    .03,    .03,
+	.02,    .02,    .02,    .01
     /* 2nd spectral band of multi spectral scanner */
- 	static const float sr2[69] = {
-          .01,    .01,    .01,    .01,    .01,    .01,    .02,
-          .03,    .04,    .08,    .13,    .21,    .29,    .43,
-          .57,    .69,    .80,    .86,    .92,    .94,    .96,
-          .97,    .99,    .99,   1.00,   1.00,   1.00,    .99,
-          .98,    .97,    .96,    .94,    .93,    .90,    .88,
-          .92,    .96,    .96,    .96,    .95,    .95,    .90,
-          .84,    .82,    .80,    .79,    .78,    .79,    .80,
-          .80,    .80,    .73,    .67,    .59,    .50,    .38,
-          .25,    .18,    .11,    .09,    .08,    .07,    .06,
-          .05,    .05,    .04,    .04,    .03,    .03
+    static const float sr2[69] = {
+	.01,    .01,    .01,    .01,    .01,    .01,    .02,
+	.03,    .04,    .08,    .13,    .21,    .29,    .43,
+	.57,    .69,    .80,    .86,    .92,    .94,    .96,
+	.97,    .99,    .99,   1.00,   1.00,   1.00,    .99,
+	.98,    .97,    .96,    .94,    .93,    .90,    .88,
+	.92,    .96,    .96,    .96,    .95,    .95,    .90,
+	.84,    .82,    .80,    .79,    .78,    .79,    .80,
+	.80,    .80,    .73,    .67,    .59,    .50,    .38,
+	.25,    .18,    .11,    .09,    .08,    .07,    .06,
+	.05,    .05,    .04,    .04,    .03,    .03
     /* 3rd spectral band of multi spectral scanner */
-          .01,    .01,    .01,    .02,    .02,    .02,    .02,
-          .03,    .03,    .05,    .07,    .10,    .14,    .17,
-          .20,    .31,    .41,    .48,    .56,    .66,    .75,
-          .83,    .90,    .93,    .97,    .98,    .99,   1.00,
-         1.00,   1.00,    .99,    .99,    .98,    .97,    .96,
-          .94,    .93,    .90,    .88,    .87,    .86,    .84,
-          .83,    .82,    .82,    .82,    .82,    .82,    .83,
-          .83,    .83,    .83,    .83,    .81,    .80,    .78,
-          .75,    .68,    .61,    .55,    .49,    .41,    .34,
-          .29,    .24,    .19,    .15,    .12,    .08,    .07,
-          .07,    .05,    .03,    .03,    .03,    .02,    .02,
+	.01,    .01,    .01,    .02,    .02,    .02,    .02,
+	.03,    .03,    .05,    .07,    .10,    .14,    .17,
+	.20,    .31,    .41,    .48,    .56,    .66,    .75,
+	.83,    .90,    .93,    .97,    .98,    .99,   1.00,
+	1.00,   1.00,    .99,    .99,    .98,    .97,    .96,
+	.94,    .93,    .90,    .88,    .87,    .86,    .84,
+	.83,    .82,    .82,    .82,    .82,    .82,    .83,
+	.83,    .83,    .83,    .83,    .81,    .80,    .78,
+	.75,    .68,    .61,    .55,    .49,    .41,    .34,
+	.29,    .24,    .19,    .15,    .12,    .08,    .07,
+	.07,    .05,    .03,    .03,    .03,    .02,    .02,
-	 /* 4th spectral band of multi spectral scanner */
- 	static const float sr4[127] = {
-          .01,    .02,    .02,    .04,    .06,    .14,    .21,
-          .45,    .68,    .76,    .83,    .89,    .94,    .94,
-          .94,    .94,    .95,    .95,    .96,    .97,    .98,
-         1.00,   1.00,    .99,    .98,    .97,    .96,    .95,
-          .94,    .93,    .92,    .92,    .91,    .90,    .89,
-          .88,    .87,    .86,    .86,    .85,    .83,    .82,
-          .81,    .80,    .78,    .77,    .76,    .76,    .75,
-          .74,    .72,    .70,    .69,    .68,    .66,    .64,
-          .63,    .62,    .61,    .60,    .58,    .57,    .56/
-          .55,    .55,    .54,    .52,    .51,    .50,    .49,
-          .47,    .46,    .45,    .44,    .43,    .42,    .41,
-          .40,    .39,    .39,    .38,    .37,    .36,    .35,
-          .34,    .33,    .32,    .31,    .30,    .29,    .28,
-          .27,    .26,    .25,    .24,    .23,    .22,    .21,
-          .20,    .20,    .19,    .18,    .16,    .15,    .14,
-          .13,    .12,    .12,    .11,    .10,    .08,    .07,
-          .06,    .06,    .05,    .04,    .03,    .02,    .01,
-          .01
+    /* 4th spectral band of multi spectral scanner */
+    static const float sr4[127] = {
+	.01,    .02,    .02,    .04,    .06,    .14,    .21,
+	.45,    .68,    .76,    .83,    .89,    .94,    .94,
+	.94,    .94,    .95,    .95,    .96,    .97,    .98,
+	1.00,   1.00,    .99,    .98,    .97,    .96,    .95,
+	.94,    .93,    .92,    .92,    .91,    .90,    .89,
+	.88,    .87,    .86,    .86,    .85,    .83,    .82,
+	.81,    .80,    .78,    .77,    .76,    .76,    .75,
+	.74,    .72,    .70,    .69,    .68,    .66,    .64,
+	.63,    .62,    .61,    .60,    .58,    .57,    .56/
+	.55,    .55,    .54,    .52,    .51,    .50,    .49,
+	.47,    .46,    .45,    .44,    .43,    .42,    .41,
+	.40,    .39,    .39,    .38,    .37,    .36,    .35,
+	.34,    .33,    .32,    .31,    .30,    .29,    .28,
+	.27,    .26,    .25,    .24,    .23,    .22,    .21,
+	.20,    .20,    .19,    .18,    .16,    .15,    .14,
+	.13,    .12,    .12,    .11,    .10,    .08,    .07,
+	.06,    .06,    .05,    .04,    .03,    .02,    .01,
+	.01
-	static const float wli[4] = { 0.4749999, 0.5799999, 0.6549999, 0.7849999 };
-	static const float wls[4] = { 0.6399999, 0.7500000, 0.8549998, 1.1000000 };
+    static const float wli[4] = { 0.4749999, 0.5799999, 0.6549999, 0.7849999 };
+    static const float wls[4] = { 0.6399999, 0.7500000, 0.8549998, 1.1000000 };
-	int i;
+    int i;
-	switch(iwa)
-	case 1: for(i = 0; i < 67; i++)	 ffu.s[90+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 67; i++)	 ffu.s[90+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 69; i++)	 ffu.s[132+i] = sr2[i];
+    case 2: for(i = 0; i < 69; i++)	 ffu.s[132+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 81; i++)	 ffu.s[162+i] = sr3[i];
+    case 3: for(i = 0; i < 81; i++)	 ffu.s[162+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 127; i++) ffu.s[214+i] = sr4[i];
+    case 4: for(i = 0; i < 127; i++) ffu.s[214+i] = sr4[i];
 	break;
 void IWave::mas(int iwa)
     /* first spectral band of Modis airborne simulator */
- 	static const float sr1[35] = {
-       .0244, .0338, .0536, .1052, .1941, .3166, .4797, .6893,
-       .9417,1.2218,1.4890,1.7202,1.9194,2.0812,2.1934,2.2580,
-      2.3031,2.3395,2.3620,2.3575,2.3228,2.2421,2.1129,1.9317,
-      1.7031,1.4126,1.0985, .8088, .5573, .3477, .1843, .0918,
-       .0473, .0308, .0248
+    static const float sr1[35] = {
+	.0244, .0338, .0536, .1052, .1941, .3166, .4797, .6893,
+	.9417,1.2218,1.4890,1.7202,1.9194,2.0812,2.1934,2.2580,
+	2.3031,2.3395,2.3620,2.3575,2.3228,2.2421,2.1129,1.9317,
+	1.7031,1.4126,1.0985, .8088, .5573, .3477, .1843, .0918,
+	.0473, .0308, .0248
-	 /* second spectral band of Modis airborne simulator */
- 	static const float sr2[38] = {
-       .0197, .0223, .0298, .0481, .0877, .1645, .2829, .4699,
-       .7101, .9752,1.2209,1.4459,1.6307,1.7482,1.8092,1.8370,
-      1.8465,1.8527,1.8574,1.8627,1.8703,1.8733,1.8763,1.8769,
-      1.8731,1.8599,1.8221,1.7208,1.5341,1.2689, .9810, .6911,
-       .4250, .2204, .0947, .0447, .0253, .0209
+    /* second spectral band of Modis airborne simulator */
+    static const float sr2[38] = {
+	.0197, .0223, .0298, .0481, .0877, .1645, .2829, .4699,
+	.7101, .9752,1.2209,1.4459,1.6307,1.7482,1.8092,1.8370,
+	1.8465,1.8527,1.8574,1.8627,1.8703,1.8733,1.8763,1.8769,
+	1.8731,1.8599,1.8221,1.7208,1.5341,1.2689, .9810, .6911,
+	.4250, .2204, .0947, .0447, .0253, .0209
-	 /* third spectral band of Modis airborne simulator */
- 	static const float sr3[34] = {
-       .0273, .0357, .0560, .1265, .3269, .6239, .9777,1.3481,
-      1.7037,2.0081,2.1885,2.2765,2.3178,2.3474,2.3777,2.4053,
-      2.4286,2.4487,2.4604,2.4324,2.2594,1.9695,1.6105,1.2200,
-       .8289, .4724, .2484, .1443, .0998, .0726, .0546, .0421,
-       .0333, .0270
+    /* third spectral band of Modis airborne simulator */
+    static const float sr3[34] = {
+	.0273, .0357, .0560, .1265, .3269, .6239, .9777,1.3481,
+	1.7037,2.0081,2.1885,2.2765,2.3178,2.3474,2.3777,2.4053,
+	2.4286,2.4487,2.4604,2.4324,2.2594,1.9695,1.6105,1.2200,
+	.8289, .4724, .2484, .1443, .0998, .0726, .0546, .0421,
+	.0333, .0270
-	 /* fourth spectral band of Modis airborne simulator */
- 	static const float sr4[40] = {
-       .0242, .0276, .0364, .0505, .0717, .1058, .1841, .3889,
-       .7570,1.1872,1.6245,1.9511,2.0986,2.1652,2.2058,2.2430,
-      2.2471,2.2299,2.2190,2.2052,2.1875,2.1519,2.0989,2.0314,
-      1.9292,1.7185,1.3603, .9476, .5555, .2803, .1608, .1090,
-       .0926, .0830, .0720, .0590, .0476, .0377, .0300, .0245
+    /* fourth spectral band of Modis airborne simulator */
+    static const float sr4[40] = {
+	.0242, .0276, .0364, .0505, .0717, .1058, .1841, .3889,
+	.7570,1.1872,1.6245,1.9511,2.0986,2.1652,2.2058,2.2430,
+	2.2471,2.2299,2.2190,2.2052,2.1875,2.1519,2.0989,2.0314,
+	1.9292,1.7185,1.3603, .9476, .5555, .2803, .1608, .1090,
+	.0926, .0830, .0720, .0590, .0476, .0377, .0300, .0245
-	 /* fifth spectral band of Modis airborne simulator */
+    /* fifth spectral band of Modis airborne simulator */
- 	static const float sr5[56] = {
-       .0232, .0234, .0254, .0259, .0300, .0313, .0325, .0368,
-       .0397, .0432, .0454, .0525, .0624, .0839, .1305, .2066,
-       .3012, .4087, .5292, .6814, .8961,1.1607,1.4407,1.6803,
-      1.8543,1.9683,2.0260,2.0562,2.0704,2.0550,2.0031,1.9304,
-      1.8731,1.8325,1.7974,1.7334,1.6188,1.4710,1.2919,1.0871,
-       .8785, .6871, .5194, .3728, .2565, .1667, .1099, .0720,
-       .0536, .0434, .0375, .0355, .0324, .0281, .0251, .0214
+    static const float sr5[56] = {
+	.0232, .0234, .0254, .0259, .0300, .0313, .0325, .0368,
+	.0397, .0432, .0454, .0525, .0624, .0839, .1305, .2066,
+	.3012, .4087, .5292, .6814, .8961,1.1607,1.4407,1.6803,
+	1.8543,1.9683,2.0260,2.0562,2.0704,2.0550,2.0031,1.9304,
+	1.8731,1.8325,1.7974,1.7334,1.6188,1.4710,1.2919,1.0871,
+	.8785, .6871, .5194, .3728, .2565, .1667, .1099, .0720,
+	.0536, .0434, .0375, .0355, .0324, .0281, .0251, .0214
-     /* sixth spectral band of Modis airborne simulator */
- 	static const float sr6[40] = {
-       .0229, .0271, .0404, .0690, .1237, .2051, .3206, .4619,
-       .6269, .8073,1.0025,1.2045,1.4075,1.5980,1.7690,1.9111,
-      2.0102,2.0697,2.0965,2.1009,2.0903,2.0685,2.0262,1.9608,
-      1.8675,1.7447,1.5974,1.4411,1.2742,1.0954, .9031, .7062,
-       .5164, .3475, .2148, .1205, .0665, .0376, .0254, .0211
+    /* sixth spectral band of Modis airborne simulator */
+    static const float sr6[40] = {
+	.0229, .0271, .0404, .0690, .1237, .2051, .3206, .4619,
+	.6269, .8073,1.0025,1.2045,1.4075,1.5980,1.7690,1.9111,
+	2.0102,2.0697,2.0965,2.1009,2.0903,2.0685,2.0262,1.9608,
+	1.8675,1.7447,1.5974,1.4411,1.2742,1.0954, .9031, .7062,
+	.5164, .3475, .2148, .1205, .0665, .0376, .0254, .0211
-   /* seventh spectral band of Modis airborne simulator */
- 	static const float sr7[117] = {
-       .0075, .0087, .0108, .0133, .0168, .0208, .0257, .0312,
-       .0379, .0456, .0540, .0629, .0728, .0828, .0937, .1054,
-       .1189, .1329, .1478, .1618, .1729, .1845, .1963, .2095,
-       .2206, .2326, .2448, .2578, .2714, .2864, .3033, .3192,
-       .3349, .3515, .3724, .3922, .4100, .4291, .4477, .4674,
-       .4824, .4992, .5197, .5436, .5681, .5908, .6099, .6204,
-       .6284, .6393, .6466, .6466, .6488, .6531, .6575, .6612,
-       .6572, .6566, .6577, .6602, .6649, .6595, .6568, .6522,
-       .6606, .6656, .6606, .6517, .6426, .6374, .6311, .6217,
-       .6053, .5933, .5827, .5672, .5483, .5325, .5241, .5121,
-       .5077, .4958, .4827, .4718, .4552, .4369, .4200, .4076,
-       .3921, .3730, .3550, .3397, .3224, .3045, .2849, .2622,
-       .2426, .2223, .2035, .1830, .1628, .1416, .1211, .1033,
-       .0871, .0731, .0606, .0491, .0395, .0315, .0245, .0189,
-       .0151, .0117, .0093, .0076, .0070
+    /* seventh spectral band of Modis airborne simulator */
+    static const float sr7[117] = {
+	.0075, .0087, .0108, .0133, .0168, .0208, .0257, .0312,
+	.0379, .0456, .0540, .0629, .0728, .0828, .0937, .1054,
+	.1189, .1329, .1478, .1618, .1729, .1845, .1963, .2095,
+	.2206, .2326, .2448, .2578, .2714, .2864, .3033, .3192,
+	.3349, .3515, .3724, .3922, .4100, .4291, .4477, .4674,
+	.4824, .4992, .5197, .5436, .5681, .5908, .6099, .6204,
+	.6284, .6393, .6466, .6466, .6488, .6531, .6575, .6612,
+	.6572, .6566, .6577, .6602, .6649, .6595, .6568, .6522,
+	.6606, .6656, .6606, .6517, .6426, .6374, .6311, .6217,
+	.6053, .5933, .5827, .5672, .5483, .5325, .5241, .5121,
+	.5077, .4958, .4827, .4718, .4552, .4369, .4200, .4076,
+	.3921, .3730, .3550, .3397, .3224, .3045, .2849, .2622,
+	.2426, .2223, .2035, .1830, .1628, .1416, .1211, .1033,
+	.0871, .0731, .0606, .0491, .0395, .0315, .0245, .0189,
+	.0151, .0117, .0093, .0076, .0070
-	/* third band of MODIS (469nm) soil and vegetation differences */
- 	static const float sr8[13] = {
-       .0732, .8372,3.6403,4.9195,5.0091,5.0102,5.0102,5.0099,
-      4.9670,4.0931,1.2880, .1186, .0237
+    /* third band of MODIS (469nm) soil and vegetation differences */
+    static const float sr8[13] = {
+	.0732, .8372,3.6403,4.9195,5.0091,5.0102,5.0102,5.0099,
+	4.9670,4.0931,1.2880, .1186, .0237
-	 /* fifth band of MODIS ( 1.24micron)  leaf and canopy properties */
- 	static const float sr9[25] = {
-       .0094, .0143, .0248, .0457, .0902, .1928, .4494,1.1087,
-      2.4282,3.6387,4.5556,4.9434,4.9975,4.9434,4.5556,3.6387,
-      2.4282,1.1087, .4494, .1928, .0902, .0457, .0248, .0143,
-       .0094
+    /* fifth band of MODIS ( 1.24micron)  leaf and canopy properties */
+    static const float sr9[25] = {
+	.0094, .0143, .0248, .0457, .0902, .1928, .4494,1.1087,
+	2.4282,3.6387,4.5556,4.9434,4.9975,4.9434,4.5556,3.6387,
+	2.4282,1.1087, .4494, .1928, .0902, .0457, .0248, .0143,
+	.0094
-	 /* sixth band of MODIS ( 1.64microns) snow and cloud differences */
- 	static const float sr10[27] = {
-       .0215, .0307, .0493, .0827, .1454, .2693, .5240,1.0412,
-      1.9431,2.6724,3.3494,3.8269,4.0296,4.0624,4.0296,3.8269,
-      3.3494,2.6724,1.9097,1.0412, .5240, .2693, .1454, .0827,
-       .0493, .0307, .0215
+    /* sixth band of MODIS ( 1.64microns) snow and cloud differences */
+    static const float sr10[27] = {
+	.0215, .0307, .0493, .0827, .1454, .2693, .5240,1.0412,
+	1.9431,2.6724,3.3494,3.8269,4.0296,4.0624,4.0296,3.8269,
+	3.3494,2.6724,1.9097,1.0412, .5240, .2693, .1454, .0827,
+	.0493, .0307, .0215
-	static const float wli[10] = { 0.5025, 0.6075, 0.8300, 0.9000, 1.8200, 2.0950, 3.5800, 0.4550, 1.2100, 1.6075 };
-	static const float wls[10] = { 0.5875, 0.7000, 0.9125, 0.9975, 1.9575, 2.1925, 3.8700, 0.4850, 1.2700, 1.6725 };
+    static const float wli[10] = { 0.5025, 0.6075, 0.8300, 0.9000, 1.8200, 2.0950, 3.5800, 0.4550, 1.2100, 1.6075 };
+    static const float wls[10] = { 0.5875, 0.7000, 0.9125, 0.9975, 1.9575, 2.1925, 3.8700, 0.4850, 1.2700, 1.6725 };
-	int i;
+    int i;
-	switch(iwa)
-	case 1: for(i = 0; i < 35; i++)	 ffu.s[101+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 35; i++)	 ffu.s[101+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 38; i++)	 ffu.s[143+i] = sr2[i];
+    case 2: for(i = 0; i < 38; i++)	 ffu.s[143+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 34; i++)	 ffu.s[232+i] = sr3[i];
+    case 3: for(i = 0; i < 34; i++)	 ffu.s[232+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 40; i++)	 ffu.s[260+i] = sr4[i];
+    case 4: for(i = 0; i < 40; i++)	 ffu.s[260+i] = sr4[i];
 	break;
-	case 5: for(i = 0; i < 56; i++)	 ffu.s[628+i] = sr5[i];
+    case 5: for(i = 0; i < 56; i++)	 ffu.s[628+i] = sr5[i];
 	break;
-	case 6: for(i = 0; i < 40; i++)	 ffu.s[738+i] = sr6[i];
+    case 6: for(i = 0; i < 40; i++)	 ffu.s[738+i] = sr6[i];
 	break;
-	case 7: for(i = 0; i < 117; i++) ffu.s[1332+i] = sr7[i];
+    case 7: for(i = 0; i < 117; i++) ffu.s[1332+i] = sr7[i];
 	break;
-	case 8: for(i = 0; i < 13; i++)	 ffu.s[82+i] = sr8[i];
+    case 8: for(i = 0; i < 13; i++)	 ffu.s[82+i] = sr8[i];
 	break;
-	case 9: for(i = 0; i < 25; i++)	 ffu.s[384+i] = sr9[i];
+    case 9: for(i = 0; i < 25; i++)	 ffu.s[384+i] = sr9[i];
 	break;
-	case 10: for(i = 0; i < 27; i++) ffu.s[543+i] = sr10[i];
+    case 10: for(i = 0; i < 27; i++) ffu.s[543+i] = sr10[i];
 	break;
 void IWave::modis(int iwa)
     /* band 1 of MODIS (vegetation monitoring at 250m) */
- 	static const float sr1[31] = {
-       .0000, .0000, .0101, .0984, .2914, .5020, .6564, .6881,
-       .7064, .7114, .7292, .7523, .7721, .7852, .8112, .8664,
-       .9309, .9794,1.0000, .9855, .9333, .8429, .7187, .5672,
-       .3996, .2327, .1024, .0369, .0157, .0092, .0000
+    static const float sr1[31] = {
+	.0000, .0000, .0101, .0984, .2914, .5020, .6564, .6881,
+	.7064, .7114, .7292, .7523, .7721, .7852, .8112, .8664,
+	.9309, .9794,1.0000, .9855, .9333, .8429, .7187, .5672,
+	.3996, .2327, .1024, .0369, .0157, .0092, .0000
-	 /* band 2 of MODIS (vegetation monitoring at 250m) */
- 	static const float sr2[34] = {
-       .0000, .0216, .0502, .0923, .1431, .1938, .2713, .4292,
-       .6543, .8606, .9672, .9609, .9418, .9273, .9311, .9550,
-       .9827, .9948,1.0000, .9782, .9308, .7860, .5430, .2931,
-       .1477, .0824, .0520, .0367, .0276, .0213, .0159, .0112,
-       .0076, .0000
+    /* band 2 of MODIS (vegetation monitoring at 250m) */
+    static const float sr2[34] = {
+	.0000, .0216, .0502, .0923, .1431, .1938, .2713, .4292,
+	.6543, .8606, .9672, .9609, .9418, .9273, .9311, .9550,
+	.9827, .9948,1.0000, .9782, .9308, .7860, .5430, .2931,
+	.1477, .0824, .0520, .0367, .0276, .0213, .0159, .0112,
+	.0076, .0000
-	 /* band 3 of MODIS (vegetation monitoring at 500m / MVI) */
- 	static const float sr3[14] = {
-       .0000, .0222, .2021, .7451,1.0141, .9036, .8745, .9242,
-      1.0009, .9305, .5877, .1496, .0170, .0000
+    /* band 3 of MODIS (vegetation monitoring at 500m / MVI) */
+    static const float sr3[14] = {
+	.0000, .0222, .2021, .7451,1.0141, .9036, .8745, .9242,
+	1.0009, .9305, .5877, .1496, .0170, .0000
-	 /* band 4 of MODIS (green channel at 500m ) */
- 	static const float sr4[13] = {
-       .0286, .2645, .7583, .9889,1.0002, .9750, .9726, .9878,
-       .9622, .7041, .2147, .0163, .0000
+    /* band 4 of MODIS (green channel at 500m ) */
+    static const float sr4[13] = {
+	.0286, .2645, .7583, .9889,1.0002, .9750, .9726, .9878,
+	.9622, .7041, .2147, .0163, .0000
-	 /* band 5 of MODIS (cloud channel at 500m ) */
- 	static const float sr5[23] = {
-       .0000, .0188, .0381, .0984, .1872, .3188, .4933, .6582,
-       .8046, .8877, .9564, .9973,1.0000, .9451, .8172, .6366,
-       .3949, .2260, .1218, .0623, .0253, .0173, .0000
+    /* band 5 of MODIS (cloud channel at 500m ) */
+    static const float sr5[23] = {
+	.0000, .0188, .0381, .0984, .1872, .3188, .4933, .6582,
+	.8046, .8877, .9564, .9973,1.0000, .9451, .8172, .6366,
+	.3949, .2260, .1218, .0623, .0253, .0173, .0000
-	 /* band 6 of MODIS (snow/ice channel at 500m ) */
- 	static const float sr6[27] = {
-       .0000, .0580, .0910, .1611, .2705, .4289, .6049, .7688,
-       .8948, .9729,1.0000, .9969, .9875, .9648, .9278, .8629,
-       .7530, .6041, .4342, .2748, .1614, .0911, .0508, .0299,
-       .0162, .0108, .0000
+    /* band 6 of MODIS (snow/ice channel at 500m ) */
+    static const float sr6[27] = {
+	.0000, .0580, .0910, .1611, .2705, .4289, .6049, .7688,
+	.8948, .9729,1.0000, .9969, .9875, .9648, .9278, .8629,
+	.7530, .6041, .4342, .2748, .1614, .0911, .0508, .0299,
+	.0162, .0108, .0000
-	   /* band 7 of MODIS (liquid water absorption channel at 500m ) */
- 	static const float sr7[51] = {
-       .0000, .0124, .0165, .0229, .0317, .0444, .0630, .0918,
-       .1358, .2006, .2904, .4032, .5329, .6632, .7775, .8680,
-       .9308, .9700, .9913,1.0000,1.0009, .9961, .9866, .9715,
-       .9498, .9209, .8851, .8446, .8022, .7614, .7241, .6860,
-       .6423, .5915, .5326, .4637, .3846, .3042, .2317, .1698,
-       .1195, .0814, .0553, .0381, .0266, .0189, .0137, .0097,
-       .0056, .0001, .0000
+    /* band 7 of MODIS (liquid water absorption channel at 500m ) */
+    static const float sr7[51] = {
+	.0000, .0124, .0165, .0229, .0317, .0444, .0630, .0918,
+	.1358, .2006, .2904, .4032, .5329, .6632, .7775, .8680,
+	.9308, .9700, .9913,1.0000,1.0009, .9961, .9866, .9715,
+	.9498, .9209, .8851, .8446, .8022, .7614, .7241, .6860,
+	.6423, .5915, .5326, .4637, .3846, .3042, .2317, .1698,
+	.1195, .0814, .0553, .0381, .0266, .0189, .0137, .0097,
+	.0056, .0001, .0000
-	static const float wli[7] = { 0.6100, 0.8200, 0.4500, 0.5400, 1.2150, 1.6000, 2.0575 };
-	static const float wls[7] = { 0.6850, 0.9025, 0.4825, 0.5700, 1.2700, 1.6650, 2.1825 };
+    static const float wli[7] = { 0.6100, 0.8200, 0.4500, 0.5400, 1.2150, 1.6000, 2.0575 };
+    static const float wls[7] = { 0.6850, 0.9025, 0.4825, 0.5700, 1.2700, 1.6650, 2.1825 };
-	int i;
+    int i;
-	switch(iwa)
-	case 1: for(i = 0; i < 31; i++)	 ffu.s[144+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 31; i++)	 ffu.s[144+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 34; i++)	 ffu.s[228+i] = sr2[i];
+    case 2: for(i = 0; i < 34; i++)	 ffu.s[228+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 14; i++)	 ffu.s[80+i] = sr3[i];
+    case 3: for(i = 0; i < 14; i++)	 ffu.s[80+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 13; i++)	 ffu.s[116+i] = sr4[i];
+    case 4: for(i = 0; i < 13; i++)	 ffu.s[116+i] = sr4[i];
 	break;
-	case 5: for(i = 0; i < 23; i++)	 ffu.s[386+i] = sr5[i];
+    case 5: for(i = 0; i < 23; i++)	 ffu.s[386+i] = sr5[i];
 	break;
-	case 6: for(i = 0; i < 27; i++)	 ffu.s[540+i] = sr6[i];
+    case 6: for(i = 0; i < 27; i++)	 ffu.s[540+i] = sr6[i];
 	break;
-	case 7: for(i = 0; i < 51; i++)	 ffu.s[723+i] = sr7[i];
+    case 7: for(i = 0; i < 51; i++)	 ffu.s[723+i] = sr7[i];
 	break;
 void IWave::polder(int iwa)
     /* band 1 of POLDER (443 mic, polarized channel) */
- 	static const float sr1[27] = {
-       .0003, .0042, .0028, .0036, .0060, .0134, .0430, .1284,
-       .3394, .6162, .8056, .9060, .9656, .9968, .9880, .8944,
+    static const float sr1[27] = {
+	.0003, .0042, .0028, .0036, .0060, .0134, .0430, .1284,
+	.3394, .6162, .8056, .9060, .9656, .9968, .9880, .8944,
-       .6612, .3880, .1950, .0966, .0512, .0292, .0180, .0122,
-       .0040, .0000, .0000
+	.6612, .3880, .1950, .0966, .0512, .0292, .0180, .0122,
+	.0040, .0000, .0000
-	 /* band 2 of POLDER (490 mic) */
- 	static const float sr2[46] = {
-       .0000, .0000, .0000, .0000, .0012, .0014, .0022, .0032,
-       .0060, .0116, .0252, .0666, .1932, .4896, .8104, .9414,
-       .9544, .9710, .9898, .9544, .6920, .3438, .1466, .0630,
-       .0304, .0170, .0102, .0070, .0000, .0000
+    /* band 2 of POLDER (490 mic) */
+    static const float sr2[46] = {
+	.0000, .0000, .0000, .0000, .0012, .0014, .0022, .0032,
+	.0060, .0116, .0252, .0666, .1932, .4896, .8104, .9414,
+	.9544, .9710, .9898, .9544, .6920, .3438, .1466, .0630,
+	.0304, .0170, .0102, .0070, .0000, .0000
-	 /* band 3 of POLDER (565 mic) */
- 	static const float sr3[26] = {
-       .0000, .0016, .0048, .0074, .0130, .0258, .0566, .1368,
-       .3294, .6592, .9270, .9946, .9798, .9544, .9262, .8814,
-       .7692, .5420, .2814, .1218, .0518, .0244, .0118, .0066,
-       .0038, .0000
+    /* band 3 of POLDER (565 mic) */
+    static const float sr3[26] = {
+	.0000, .0016, .0048, .0074, .0130, .0258, .0566, .1368,
+	.3294, .6592, .9270, .9946, .9798, .9544, .9262, .8814,
+	.7692, .5420, .2814, .1218, .0518, .0244, .0118, .0066,
+	.0038, .0000
-	 /* band 4 of POLDER (670 P1, polarized channel) */
- 	static const float sr4[30] = {
-       .0000, .0000, .0000, .0000, .0010, .0044, .0022, .0140,
-       .0176, .0394, .1004, .2476, .5462, .8672, .9902, .9874,
-       .9572, .9484, .9264, .8274, .5688, .2828, .1154, .0500,
-       .0224, .0186, .0160, .0072, .0000, .0000
+    /* band 4 of POLDER (670 P1, polarized channel) */
+    static const float sr4[30] = {
+	.0000, .0000, .0000, .0000, .0010, .0044, .0022, .0140,
+	.0176, .0394, .1004, .2476, .5462, .8672, .9902, .9874,
+	.9572, .9484, .9264, .8274, .5688, .2828, .1154, .0500,
+	.0224, .0186, .0160, .0072, .0000, .0000
-	 /* band 5 of POLDER (763 mic, oxygen absorption channel) */
- 	static const float sr5[15] = {
-       .0000, .0004, .0046, .0134, .0834, .4148, .8056, .9274,
-       .9880, .7488, .2416, .0416, .0094, .0008, .0000
+    /* band 5 of POLDER (763 mic, oxygen absorption channel) */
+    static const float sr5[15] = {
+	.0000, .0004, .0046, .0134, .0834, .4148, .8056, .9274,
+	.9880, .7488, .2416, .0416, .0094, .0008, .0000
-	 /* band 6 of POLDER (765 mic, oxygen absorption channel) */
- 	static const float sr6[53] = {
-       .0000, .0000, .0010, .0018, .0010, .0030, .0046, .0080,
-       .0096, .0140, .0202, .0300, .0410, .0622, .0958, .1516,
-       .2400, .3648, .5174, .6640, .7798, .8494, .8858, .9066,
-       .9202, .9374, .9516, .9692, .9886, .9932, .9650, .8684,
-       .6836, .4686, .2922, .1724, .1012, .0594, .0360, .0238,
-       .0144, .0104, .0088, .0060, .0052, .0046, .0038, .0052,
-       .0028, .0022, .0000, .0000, .0000
+    /* band 6 of POLDER (765 mic, oxygen absorption channel) */
+    static const float sr6[53] = {
+	.0000, .0000, .0010, .0018, .0010, .0030, .0046, .0080,
+	.0096, .0140, .0202, .0300, .0410, .0622, .0958, .1516,
+	.2400, .3648, .5174, .6640, .7798, .8494, .8858, .9066,
+	.9202, .9374, .9516, .9692, .9886, .9932, .9650, .8684,
+	.6836, .4686, .2922, .1724, .1012, .0594, .0360, .0238,
+	.0144, .0104, .0088, .0060, .0052, .0046, .0038, .0052,
+	.0028, .0022, .0000, .0000, .0000
-	 /* band 7 of POLDER (865 P1, polarized channel) */
- 	static const float sr7[45] = {
-       .0000, .0004, .0008, .0024, .0030, .0056, .0102, .0186,
-       .0338, .0622, .1110, .1974, .3410, .5432, .7610, .9218,
-       .9896, .9936, .9744, .9514, .9352, .9222, .9150, .9094,
-       .8954, .8592, .7766, .6354, .4604, .3006, .1838, .1082,
-       .0626, .0346, .0198, .0112, .0064, .0038, .0028, .0016,
-       .0014, .0006, .0000, .0000, .0000
+    /* band 7 of POLDER (865 P1, polarized channel) */
+    static const float sr7[45] = {
+	.0000, .0004, .0008, .0024, .0030, .0056, .0102, .0186,
+	.0338, .0622, .1110, .1974, .3410, .5432, .7610, .9218,
+	.9896, .9936, .9744, .9514, .9352, .9222, .9150, .9094,
+	.8954, .8592, .7766, .6354, .4604, .3006, .1838, .1082,
+	.0626, .0346, .0198, .0112, .0064, .0038, .0028, .0016,
+	.0014, .0006, .0000, .0000, .0000
-	 /* band 8 of POLDER (910 mic, water vapor absorption channel) */
- 	static const float sr8[31] = {
-       .0000, .0000, .0000, .0012, .0016, .0018, .0032, .0046,
-       .0082, .0158, .0354, .0876, .2242, .5142, .8436, .9848,
-       .9838, .9534, .9254, .9084, .8560, .6444, .3388, .1424,
-       .0566, .0238, .0098, .0000, .0000, .0000, .0000
+    /* band 8 of POLDER (910 mic, water vapor absorption channel) */
+    static const float sr8[31] = {
+	.0000, .0000, .0000, .0012, .0016, .0018, .0032, .0046,
+	.0082, .0158, .0354, .0876, .2242, .5142, .8436, .9848,
+	.9838, .9534, .9254, .9084, .8560, .6444, .3388, .1424,
+	.0566, .0238, .0098, .0000, .0000, .0000, .0000
-	static const float wli[8] = { 0.4125, 0.4100, 0.5325, 0.6300, 0.7450, 0.7000, 0.8100, 0.8650 };
-	static const float wls[8] = { 0.4775, 0.5225, 0.5950, 0.7025, 0.7800, 0.8300, 0.9200, 0.9400 };
+    static const float wli[8] = { 0.4125, 0.4100, 0.5325, 0.6300, 0.7450, 0.7000, 0.8100, 0.8650 };
+    static const float wls[8] = { 0.4775, 0.5225, 0.5950, 0.7025, 0.7800, 0.8300, 0.9200, 0.9400 };
-	int i;
+    int i;
-	switch(iwa)
-	case 1: for(i = 0; i < 27; i++)	 ffu.s[65+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 27; i++)	 ffu.s[65+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 46; i++)	 ffu.s[64+i] = sr2[i];
+    case 2: for(i = 0; i < 46; i++)	 ffu.s[64+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 26; i++)	 ffu.s[113+i] = sr3[i];
+    case 3: for(i = 0; i < 26; i++)	 ffu.s[113+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 30; i++)	 ffu.s[152+i] = sr4[i];
+    case 4: for(i = 0; i < 30; i++)	 ffu.s[152+i] = sr4[i];
 	break;
-	case 5: for(i = 0; i < 15; i++)	 ffu.s[198+i] = sr5[i];
+    case 5: for(i = 0; i < 15; i++)	 ffu.s[198+i] = sr5[i];
 	break;
-	case 6: for(i = 0; i < 53; i++)	 ffu.s[180+i] = sr6[i];
+    case 6: for(i = 0; i < 53; i++)	 ffu.s[180+i] = sr6[i];
 	break;
-	case 7: for(i = 0; i < 45; i++)	 ffu.s[224+i] = sr7[i];
+    case 7: for(i = 0; i < 45; i++)	 ffu.s[224+i] = sr7[i];
 	break;
-	case 8: for(i = 0; i < 31; i++)	 ffu.s[246+i] = sr8[i];
+    case 8: for(i = 0; i < 31; i++)	 ffu.s[246+i] = sr8[i];
 	break;
 void IWave::etmplus(int iwa)
     /* Spectral filter data found on the following page:
-     http://ltpwww.gsfc.nasa.gov/IAS/handbook/handbook_toc.html
+       http://ltpwww.gsfc.nasa.gov/IAS/handbook/handbook_toc.html
     /* 1st spectral band of enhanced thematic mapper plus */
-      .0160, .0710, .2870, .6665, .7920, .8570, .8390, .8060,
-      .7790, .8460, .9010, .8995, .8900, .8510, .8750, .8930,
-      .8840, .9300, .9580, .9540, .9800, .9750, .9650, .9625,
-      .9950, .9900, .9900, .9795, .9830, .9685, .9600, .7685,
-      .2930, .0545, .0090
+	.0160, .0710, .2870, .6665, .7920, .8570, .8390, .8060,
+	.7790, .8460, .9010, .8995, .8900, .8510, .8750, .8930,
+	.8840, .9300, .9580, .9540, .9800, .9750, .9650, .9625,
+	.9950, .9900, .9900, .9795, .9830, .9685, .9600, .7685,
+	.2930, .0545, .0090
-	/* 2nd spectral band of enhanced thematic mapper plus */
-	static const float sr2[50] = {
-      .0006, .0015, .0030, .0117, .0260, .0740, .1740, .3480,
-      .5520, .6960, .7590, .7845, .8220, .8695, .9050, .9285,
-      .9470, .9525, .9520, .9515, .9530, .9500, .9540, .9670,
-      .9590, .9405, .9330, .9385, .9510, .9565, .9550, .9560,
-      .9730, .9915,1.0000, .9760, .9420, .9300, .9120, .7985,
-      .5740, .3400, .1850, .1055, .0620, .0375, .0210, .0109,
-      .0048, .0021
+    /* 2nd spectral band of enhanced thematic mapper plus */
+    static const float sr2[50] = {
+	.0006, .0015, .0030, .0117, .0260, .0740, .1740, .3480,
+	.5520, .6960, .7590, .7845, .8220, .8695, .9050, .9285,
+	.9470, .9525, .9520, .9515, .9530, .9500, .9540, .9670,
+	.9590, .9405, .9330, .9385, .9510, .9565, .9550, .9560,
+	.9730, .9915,1.0000, .9760, .9420, .9300, .9120, .7985,
+	.5740, .3400, .1850, .1055, .0620, .0375, .0210, .0109,
+	.0048, .0021
-	/* 3rd spectral band of enhanced thematic mapper plus */
-	static const float sr3[36] = {
-      .0001, .0006, .0020, .0095, .0470, .1740, .4190, .7310,
-      .9210, .9425, .9370, .9365, .9490, .9645, .9730, .9705,
-      .9580, .9550, .9620, .9800, .9930, .9980,1.0000, .9955,
-      .9920, .9885, .9770, .9545, .9320, .8805, .7290, .4440,
-      .1830, .0660, .0250, .0121
+    /* 3rd spectral band of enhanced thematic mapper plus */
+    static const float sr3[36] = {
+	.0001, .0006, .0020, .0095, .0470, .1740, .4190, .7310,
+	.9210, .9425, .9370, .9365, .9490, .9645, .9730, .9705,
+	.9580, .9550, .9620, .9800, .9930, .9980,1.0000, .9955,
+	.9920, .9885, .9770, .9545, .9320, .8805, .7290, .4440,
+	.1830, .0660, .0250, .0121
     /* 4th spectral band of enhanced thematic mapper plus */
-	static const float sr4[70] = {
-      .0004, .0021, .0037, .0024, .0010, .0199, .0315, .0518,
-      .0690, .1100, .1750, .2710, .4020, .5555, .7050, .8120,
-      .8710, .8955, .9080, .9180, .9260, .9280, .9300, .9255,
-      .9250, .9280, .9230, .9165, .9080, .9035, .9090, .9240,
-      .9460, .9655, .9710, .9690, .9670, .9655, .9670, .9605,
-      .9490, .9310, .9250, .9295, .9430, .9610, .9850, .9925,
-      .9980, .9915, .9940, .9970, .9980, .9995, .9910, .9880,
-      .9690, .9265, .8680, .8175, .8190, .8800, .8540, .5725,
-      .2560, .1035, .0440, .0220, .0110, .0071
+    static const float sr4[70] = {
+	.0004, .0021, .0037, .0024, .0010, .0199, .0315, .0518,
+	.0690, .1100, .1750, .2710, .4020, .5555, .7050, .8120,
+	.8710, .8955, .9080, .9180, .9260, .9280, .9300, .9255,
+	.9250, .9280, .9230, .9165, .9080, .9035, .9090, .9240,
+	.9460, .9655, .9710, .9690, .9670, .9655, .9670, .9605,
+	.9490, .9310, .9250, .9295, .9430, .9610, .9850, .9925,
+	.9980, .9915, .9940, .9970, .9980, .9995, .9910, .9880,
+	.9690, .9265, .8680, .8175, .8190, .8800, .8540, .5725,
+	.2560, .1035, .0440, .0220, .0110, .0071
-	/* 5th spectral band of enhanced thematic mapper plus */
-	static const float sr5[116] = {
-      .0015, .0000, .0010, .0112, .0120, .0060, .0135, .0210,
-      .0400, .0530, .0760, .1028, .1480, .2052, .2740, .3660,
-      .4620, .5137, .5780, .6250, .6670, .7090, .7370, .7710,
-      .8080, .8315, .8590, .8750, .8930, .9013, .8960, .8953,
-      .8945, .8878, .8760, .8685, .8725, .8773, .8740, .8605,
-      .8680, .8785, .8990, .8940, .9000, .9020, .9190, .9248,
-      .9290, .9455, .9475, .9533, .9520, .9668, .9610, .9598,
-      .9780, .9587, .9535, .9513, .9517, .9550, .9440, .9345,
-      .9305, .9385, .9480, .9398, .9385, .9470, .9450, .9450,
-      .9553, .9648, .9690, .9733, .9910, .9960, .9975, .9945,
-     1.0000, .9913, .9865, .9885, .9895, .9875, .9810, .9812,
-      .9780, .9685, .9600, .9383, .9020, .8545, .7910, .6928,
-      .6077, .5257, .4275, .3420, .2670, .2028, .1585, .1187,
-      .0840, .0723, .0535, .0437, .0390, .0305, .0205, .0217,
-      .0110, .0100, .0060, .0020
+    /* 5th spectral band of enhanced thematic mapper plus */
+    static const float sr5[116] = {
+	.0015, .0000, .0010, .0112, .0120, .0060, .0135, .0210,
+	.0400, .0530, .0760, .1028, .1480, .2052, .2740, .3660,
+	.4620, .5137, .5780, .6250, .6670, .7090, .7370, .7710,
+	.8080, .8315, .8590, .8750, .8930, .9013, .8960, .8953,
+	.8945, .8878, .8760, .8685, .8725, .8773, .8740, .8605,
+	.8680, .8785, .8990, .8940, .9000, .9020, .9190, .9248,
+	.9290, .9455, .9475, .9533, .9520, .9668, .9610, .9598,
+	.9780, .9587, .9535, .9513, .9517, .9550, .9440, .9345,
+	.9305, .9385, .9480, .9398, .9385, .9470, .9450, .9450,
+	.9553, .9648, .9690, .9733, .9910, .9960, .9975, .9945,
+	1.0000, .9913, .9865, .9885, .9895, .9875, .9810, .9812,
+	.9780, .9685, .9600, .9383, .9020, .8545, .7910, .6928,
+	.6077, .5257, .4275, .3420, .2670, .2028, .1585, .1187,
+	.0840, .0723, .0535, .0437, .0390, .0305, .0205, .0217,
+	.0110, .0100, .0060, .0020
-	/* 7th spectral band of enhanced thematic mapper plus */
-	static const float sr6[147] = {
-      .0020, .0020, .0120, .0085, .0090, .0177, .0170, .0313,
-      .0370, .0458, .0580, .0762, .0880, .1097, .1490, .1960,
-      .2420, .3030, .3670, .4368, .5190, .6100, .6765, .7182,
-      .7560, .7738, .7840, .7755, .7890, .7817, .7780, .7665,
-      .7615, .7680, .7750, .7690, .7880, .8085, .7940, .8230,
-      .8115, .8195, .8365, .8370, .8360, .8513, .8585, .8553,
-      .8710, .8735, .8750, .8590, .8715, .8593, .8720, .8625,
-      .8650, .8680, .8765, .8730, .8690, .8760, .8680, .8793,
-      .8735, .8760, .8800, .8745, .8700, .8578, .8630, .8585,
-      .8440, .8585, .8545, .8625, .8680, .8560, .8470, .8613,
-      .8510, .8520, .8380, .8465, .8403, .8305, .8355, .8382,
-      .8220, .8380, .8385, .8425, .8535, .8623, .8730, .8680,
-      .8790, .8908, .8980, .9195, .9200, .9263, .9275, .9340,
-      .9360, .9533, .9540, .9518, .9600, .9728, .9850, .9720,
-      .9700, .9938, .9895, .9748,1.0000, .9912, .9680, .9658,
-      .9555, .9295, .9290, .9255, .9030, .9235, .9290, .9285,
-      .9200, .8533, .7750, .6587, .5315, .4035, .2750, .2175,
-      .1310, .1035, .0750, .0518, .0290, .0280, .0135, .0193,
-      .0130, .0065, .0150
+    /* 7th spectral band of enhanced thematic mapper plus */
+    static const float sr6[147] = {
+	.0020, .0020, .0120, .0085, .0090, .0177, .0170, .0313,
+	.0370, .0458, .0580, .0762, .0880, .1097, .1490, .1960,
+	.2420, .3030, .3670, .4368, .5190, .6100, .6765, .7182,
+	.7560, .7738, .7840, .7755, .7890, .7817, .7780, .7665,
+	.7615, .7680, .7750, .7690, .7880, .8085, .7940, .8230,
+	.8115, .8195, .8365, .8370, .8360, .8513, .8585, .8553,
+	.8710, .8735, .8750, .8590, .8715, .8593, .8720, .8625,
+	.8650, .8680, .8765, .8730, .8690, .8760, .8680, .8793,
+	.8735, .8760, .8800, .8745, .8700, .8578, .8630, .8585,
+	.8440, .8585, .8545, .8625, .8680, .8560, .8470, .8613,
+	.8510, .8520, .8380, .8465, .8403, .8305, .8355, .8382,
+	.8220, .8380, .8385, .8425, .8535, .8623, .8730, .8680,
+	.8790, .8908, .8980, .9195, .9200, .9263, .9275, .9340,
+	.9360, .9533, .9540, .9518, .9600, .9728, .9850, .9720,
+	.9700, .9938, .9895, .9748,1.0000, .9912, .9680, .9658,
+	.9555, .9295, .9290, .9255, .9030, .9235, .9290, .9285,
+	.9200, .8533, .7750, .6587, .5315, .4035, .2750, .2175,
+	.1310, .1035, .0750, .0518, .0290, .0280, .0135, .0193,
+	.0130, .0065, .0150
-	/* 8th spectral band of enhanced thematic mapper plus (Pan) */
-	static const float sr7[164] = {
-      .0028, .0175, .0563, .1500, .3285, .5015, .5845, .5990,
-      .6018, .6095, .6143, .6100, .6035, .6035, .6118, .6270,
-      .6385, .6445, .6438, .6320, .6260, .6245, .6320, .6420,
-      .6593, .6775, .6898, .6970, .7005, .7050, .7110, .7130,
-      .7165, .7180, .7120, .7070, .7040, .7030, .7148, .7300,
-      .7440, .7535, .7615, .7640, .7533, .7450, .7353, .7290,
-      .7285, .7310, .7328, .7340, .7435, .7495, .7540, .7580,
-      .7618, .7680, .7720, .7790, .7815, .7850, .7900, .7930,
-      .7918, .7915, .7950, .7980, .8018, .8060, .8133, .8200,
-      .8275, .8315, .8370, .8420, .8485, .8545, .8605, .8680,
-      .8723, .8795, .8853, .8920, .8945, .8960, .8945, .8940,
-      .8943, .8955, .8975, .9000, .9033, .9035, .9023, .9000,
-      .8968, .8935, .8828, .8790, .8783, .8730, .8760, .8800,
-      .8813, .8865, .8910, .8930, .9035, .9105, .9183, .9200,
-      .9175, .9160, .9183, .9180, .9168, .9155, .9173, .9270,
-      .9290, .9375, .9497, .9570, .9638, .9695, .9715, .9770,
-      .9795, .9840, .9908, .9970, .9985, .9980, .9953, .9940,
-      .9920, .9930, .9925, .9870, .9755, .9650, .9583, .9490,
-      .9348, .9240, .9133, .9070, .9053, .9085, .9193, .9400,
-      .9658, .9780, .9625, .8950, .7520, .5715, .3962, .2580,
-      .1675, .1080, .0687, .0440
+    /* 8th spectral band of enhanced thematic mapper plus (Pan) */
+    static const float sr7[164] = {
+	.0028, .0175, .0563, .1500, .3285, .5015, .5845, .5990,
+	.6018, .6095, .6143, .6100, .6035, .6035, .6118, .6270,
+	.6385, .6445, .6438, .6320, .6260, .6245, .6320, .6420,
+	.6593, .6775, .6898, .6970, .7005, .7050, .7110, .7130,
+	.7165, .7180, .7120, .7070, .7040, .7030, .7148, .7300,
+	.7440, .7535, .7615, .7640, .7533, .7450, .7353, .7290,
+	.7285, .7310, .7328, .7340, .7435, .7495, .7540, .7580,
+	.7618, .7680, .7720, .7790, .7815, .7850, .7900, .7930,
+	.7918, .7915, .7950, .7980, .8018, .8060, .8133, .8200,
+	.8275, .8315, .8370, .8420, .8485, .8545, .8605, .8680,
+	.8723, .8795, .8853, .8920, .8945, .8960, .8945, .8940,
+	.8943, .8955, .8975, .9000, .9033, .9035, .9023, .9000,
+	.8968, .8935, .8828, .8790, .8783, .8730, .8760, .8800,
+	.8813, .8865, .8910, .8930, .9035, .9105, .9183, .9200,
+	.9175, .9160, .9183, .9180, .9168, .9155, .9173, .9270,
+	.9290, .9375, .9497, .9570, .9638, .9695, .9715, .9770,
+	.9795, .9840, .9908, .9970, .9985, .9980, .9953, .9940,
+	.9920, .9930, .9925, .9870, .9755, .9650, .9583, .9490,
+	.9348, .9240, .9133, .9070, .9053, .9085, .9193, .9400,
+	.9658, .9780, .9625, .8950, .7520, .5715, .3962, .2580,
+	.1675, .1080, .0687, .0440
-	static const float wli[7] = { 0.4350, 0.5000, 0.6150, 0.7400, 1.5050, 2.0150, 0.5025 };
-	static const float wls[7] = { 0.5200, 0.6225, 0.7025, 0.9125, 1.7925, 2.3800, 0.9100 };
+    static const float wli[7] = { 0.4350, 0.5000, 0.6150, 0.7400, 1.5050, 2.0150, 0.5025 };
+    static const float wls[7] = { 0.5200, 0.6225, 0.7025, 0.9125, 1.7925, 2.3800, 0.9100 };
-	int i;
-	for(i = 0; i < 1501; i++) ffu.s[i] = 0;
+    int i;
+    for(i = 0; i < 1501; i++) ffu.s[i] = 0;
-	switch(iwa)
-	case 1: for(i = 0; i < 35; i++)	 ffu.s[74+i] = sr1[i];
+    switch(iwa)
+    case 1: for(i = 0; i < 35; i++)	 ffu.s[74+i] = sr1[i];
 	break;
-	case 2: for(i = 0; i < 50; i++)	 ffu.s[100+i] = sr2[i];
+    case 2: for(i = 0; i < 50; i++)	 ffu.s[100+i] = sr2[i];
 	break;
-	case 3: for(i = 0; i < 36; i++)	 ffu.s[146+i] = sr3[i];
+    case 3: for(i = 0; i < 36; i++)	 ffu.s[146+i] = sr3[i];
 	break;
-	case 4: for(i = 0; i < 70; i++)	 ffu.s[196+i] = sr4[i];
+    case 4: for(i = 0; i < 70; i++)	 ffu.s[196+i] = sr4[i];
 	break;
-	case 5: for(i = 0; i < 116; i++) ffu.s[502+i] = sr5[i];
+    case 5: for(i = 0; i < 116; i++) ffu.s[502+i] = sr5[i];
 	break;
-	case 6: for(i = 0; i < 147; i++) ffu.s[706+i] = sr6[i];
+    case 6: for(i = 0; i < 147; i++) ffu.s[706+i] = sr6[i];
 	break;
-	case 7: for(i = 0; i < 164; i++) ffu.s[101+i] = sr7[i];
+    case 7: for(i = 0; i < 164; i++) ffu.s[101+i] = sr7[i];
 float IWave::solirr(const float wl) const
 /*    si (in w/m2/micron) contains the values of the solar
-    irradiance between 0.25 and 4.0 microns, by step of 0.0025 m.
-    the value of the total irradiance is 1372 w/m2 on the whole
-    spectrum (1358 w/m2 between 0.25 and 4.0 microns) */
+      irradiance between 0.25 and 4.0 microns, by step of 0.0025 m.
+      the value of the total irradiance is 1372 w/m2 on the whole
+      spectrum (1358 w/m2 between 0.25 and 4.0 microns) */
-	static const float si[1501] = {
+    static const float si[1501] = {
         69.30,  77.65,  86.00, 100.06, 114.12, 137.06, 160.00,
-       169.52, 179.04, 178.02, 177.00, 193.69, 210.38, 241.69,
-       273.00, 318.42, 363.84, 434.42, 505.00, 531.50, 558.00,
-       547.50, 537.00, 559.02, 581.03, 619.52, 658.00, 694.39,
-       730.78, 774.39, 817.99, 871.99, 925.99, 912.04, 898.09,
-       920.69, 943.29, 925.99, 908.69, 936.09, 963.49, 994.94,
-      1026.39, 980.74, 935.09,1036.29,1137.49,1163.74,1189.99,
-      1109.34,1028.69,1088.99,1149.29,1033.69, 918.09,1031.89,
-      1145.69,1035.09, 924.49,1269.29,1614.09,1631.09,1648.09,
-      1677.19,1706.29,1744.89,1783.49,1750.19,1716.89,1705.19,
-      1693.49,1597.69,1501.89,1630.99,1760.09,1775.24,1790.39,
-      1859.94,1929.49,1993.44,2057.39,2039.23,2021.08,2030.73,
-      2040.38,2026.53,2012.68,1999.53,1986.38,2002.88,2019.38,
-      2038.09,2056.79,1967.74,1878.68,1905.83,1932.98,1953.58,
-      1974.18,1935.68,1897.19,1916.78,1936.38,1937.23,1938.09,
-      1881.44,1824.79,1814.09,1803.39,1832.24,1861.09,1885.93,
-      1910.78,1904.68,1898.58,1875.73,1852.88,1865.64,1878.39,
-      1874.74,1871.09,1872.44,1873.79,1850.39,1826.99,1837.04,
-      1847.09,1841.18,1835.28,1849.48,1863.69,1851.03,1838.38,
-      1840.73,1843.08,1802.83,1762.58,1778.78,1794.99,1777.48,
-      1759.98,1764.73,1769.49,1753.48,1737.48,1713.14,1688.80,
-      1702.88,1716.97,1696.07,1675.17,1672.03,1668.89,1663.56,
-      1658.23,1647.75,1637.27,1630.02,1622.77,1606.06,1589.36,
-      1552.29,1515.22,1528.91,1542.60,1548.90,1555.21,1544.41,
-      1533.62,1525.24,1516.86,1507.92,1498.98,1484.07,1469.17,
-      1464.28,1459.39,1448.73,1438.08,1423.16,1408.24,1407.53,
-      1406.82,1397.82,1388.82,1378.51,1368.21,1352.13,1336.05,
-      1343.88,1351.71,1339.60,1327.50,1320.72,1313.94,1294.94,
-      1275.94,1280.92,1285.90,1278.04,1270.19,1263.68,1257.18,
-      1249.80,1242.41,1231.30,1220.19,1212.14,1204.10,1201.69,
-      1199.29,1194.78,1190.27,1185.47,1180.68,1174.38,1168.09,
-      1156.17,1144.26,1143.46,1142.67,1132.95,1123.23,1116.71,
-      1110.19,1110.89,1111.59,1094.80,1078.01,1077.75,1077.49,
-      1073.89,1070.29,1058.71,1047.13,1045.66,1044.20,1037.03,
-      1029.86,1010.40, 990.94, 966.91, 942.89, 972.87,1002.86,
-       978.93, 955.00, 960.95, 966.91, 983.31, 999.71, 991.91,
-       984.11, 979.05, 973.99, 968.79, 963.60, 958.23, 952.87,
-       947.93, 942.99, 937.99, 933.00, 928.00, 923.00, 918.18,
-       913.37, 908.74, 904.11, 899.05, 893.99, 889.18, 884.37,
-       879.74, 875.12, 870.24, 865.36, 860.94, 856.53, 852.02,
-       847.50, 843.00, 838.50, 833.99, 829.49, 824.98, 820.48,
-       815.99, 811.50, 806.99, 802.49, 798.17, 793.86, 789.74,
-       785.63, 781.25, 776.87, 772.92, 768.98, 764.80, 760.63,
-       756.06, 751.49, 746.99, 742.49, 738.18, 733.88, 729.76,
-       725.63, 721.24, 716.86, 712.92, 708.99, 704.81, 700.63,
-       696.25, 691.87, 687.94, 684.01, 680.01, 676.00, 671.80,
-       667.61, 663.23, 658.86, 655.32, 651.77, 649.07, 646.37,
-       643.74, 641.11, 638.05, 634.99, 632.18, 629.37, 626.74,
-       624.12, 621.06, 618.00, 615.18, 612.37, 609.92, 607.48,
-       604.79, 602.11, 599.24, 596.38, 593.93, 591.48, 588.79,
-       586.11, 583.25, 580.40, 577.94, 575.48, 572.99, 570.51,
-       568.00, 565.49, 562.98, 560.47, 557.98, 555.50, 553.01,
-       550.51, 548.00, 545.49, 542.98, 540.48, 537.98, 535.49,
-       533.19, 530.90, 528.94, 526.99, 524.80, 522.62, 520.24,
-       517.87, 515.44, 513.01, 509.59, 506.17, 502.89, 499.62,
-       496.35, 493.09, 489.81, 486.54, 483.27, 480.01, 476.73,
-       473.46, 470.19, 466.92, 463.64, 460.37, 457.10, 453.84,
-       450.57, 447.30, 444.03, 440.76, 437.48, 434.21, 430.94,
-       427.67, 424.40, 421.13, 417.86, 414.59, 411.32, 408.05,
-       404.78, 401.51, 398.24, 394.97, 391.70, 388.43, 392.57,
-       396.71, 401.92, 407.14, 405.32, 403.50, 401.67, 399.84,
-       398.02, 396.21, 394.37, 392.54, 390.72, 388.90, 387.06,
-       385.23, 383.42, 381.60, 379.77, 377.95, 376.12, 374.30,
-       372.48, 370.66, 368.82, 366.99, 365.17, 363.35, 361.52,
-       359.69, 357.87, 356.05, 354.22, 352.39, 350.57, 348.75,
-       346.92, 345.10, 343.27, 341.45, 341.84, 342.24, 342.95,
-       343.66, 342.27, 340.89, 339.49, 338.09, 336.69, 335.30,
-       333.91, 332.53, 331.13, 329.73, 328.34, 326.96, 325.56,
-       324.16, 322.77, 321.39, 319.99, 318.59, 317.20, 315.82,
-       314.42, 313.03, 311.63, 310.24, 308.85, 307.46, 306.06,
-       304.66, 303.28, 301.90, 300.50, 299.10, 297.71, 296.32,
-       294.93, 293.54, 293.41, 293.28, 293.35, 293.42, 292.26,
-       291.10, 289.97, 288.84, 287.69, 286.54, 285.39, 284.25,
-       283.10, 281.96, 280.81, 279.67, 278.52, 277.38, 276.23,
-       275.08, 273.94, 272.80, 271.65, 270.51, 269.36, 268.22,
-       267.07, 265.93, 264.78, 263.64, 262.49, 261.34, 260.20,
-       259.06, 257.91, 256.77, 255.62, 254.47, 253.33, 252.20,
-       251.16, 250.13, 249.11, 248.09, 246.97, 245.86, 244.74,
-       243.61, 242.49, 241.37, 240.24, 239.12, 238.00, 236.89,
-       235.76, 234.64, 233.51, 232.38, 231.26, 230.13, 229.01,
-       227.90, 226.77, 225.65, 224.53, 223.42, 222.29, 221.16,
-       220.04, 218.92, 217.80, 216.68, 215.55, 214.43, 213.30,
-       212.18, 211.06, 209.94, 208.82, 207.69, 206.99, 206.29,
-       205.65, 205.02, 203.98, 202.95, 201.90, 200.85, 199.81,
-       198.78, 197.74, 196.70, 195.65, 194.61, 193.57, 192.54,
-       191.50, 190.47, 189.42, 188.37, 187.33, 186.30, 185.26,
-       184.22, 183.18, 182.14, 181.10, 180.06, 179.02, 177.98,
-       176.93, 175.89, 174.86, 173.83, 172.78, 171.73, 170.70,
-       169.67, 168.62, 167.57, 167.59, 167.60, 167.76, 167.93,
-       167.09, 166.26, 165.42, 164.58, 163.75, 162.92, 162.08,
-       161.25, 160.41, 159.58, 158.74, 157.91, 157.07, 156.24,
-       155.40, 154.57, 153.73, 152.90, 152.06, 151.23, 150.39,
-       149.56, 148.72, 147.89, 147.06, 146.23, 145.39, 144.55,
-       143.71, 142.88, 142.05, 141.22, 140.38, 139.54, 138.70,
-       137.86, 137.99, 138.11, 138.36, 138.60, 137.94, 137.29,
-       136.64, 136.00, 135.35, 134.71, 134.05, 133.39, 132.74,
-       132.09, 131.45, 130.81, 130.15, 129.49, 128.84, 128.20,
-       127.55, 126.90, 126.25, 125.60, 124.94, 124.29, 123.64,
-       123.00, 122.35, 121.70, 121.05, 120.40, 119.74, 119.09,
-       118.45, 117.81, 117.15, 116.50, 115.85, 115.19, 115.25,
-       115.31, 115.46, 115.62, 115.11, 114.60, 114.09, 113.58,
-       113.06, 112.54, 112.03, 111.53, 111.01, 110.50, 109.99,
-       109.47, 108.95, 108.44, 107.93, 107.42, 106.92, 106.42,
-       105.89, 105.37, 104.85, 104.34, 103.83, 103.33, 102.81,
-       102.29, 101.79, 101.29, 100.77, 100.25,  99.74,  99.22,
+	169.52, 179.04, 178.02, 177.00, 193.69, 210.38, 241.69,
+	273.00, 318.42, 363.84, 434.42, 505.00, 531.50, 558.00,
+	547.50, 537.00, 559.02, 581.03, 619.52, 658.00, 694.39,
+	730.78, 774.39, 817.99, 871.99, 925.99, 912.04, 898.09,
+	920.69, 943.29, 925.99, 908.69, 936.09, 963.49, 994.94,
+	1026.39, 980.74, 935.09,1036.29,1137.49,1163.74,1189.99,
+	1109.34,1028.69,1088.99,1149.29,1033.69, 918.09,1031.89,
+	1145.69,1035.09, 924.49,1269.29,1614.09,1631.09,1648.09,
+	1677.19,1706.29,1744.89,1783.49,1750.19,1716.89,1705.19,
+	1693.49,1597.69,1501.89,1630.99,1760.09,1775.24,1790.39,
+	1859.94,1929.49,1993.44,2057.39,2039.23,2021.08,2030.73,
+	2040.38,2026.53,2012.68,1999.53,1986.38,2002.88,2019.38,
+	2038.09,2056.79,1967.74,1878.68,1905.83,1932.98,1953.58,
+	1974.18,1935.68,1897.19,1916.78,1936.38,1937.23,1938.09,
+	1881.44,1824.79,1814.09,1803.39,1832.24,1861.09,1885.93,
+	1910.78,1904.68,1898.58,1875.73,1852.88,1865.64,1878.39,
+	1874.74,1871.09,1872.44,1873.79,1850.39,1826.99,1837.04,
+	1847.09,1841.18,1835.28,1849.48,1863.69,1851.03,1838.38,
+	1840.73,1843.08,1802.83,1762.58,1778.78,1794.99,1777.48,
+	1759.98,1764.73,1769.49,1753.48,1737.48,1713.14,1688.80,
+	1702.88,1716.97,1696.07,1675.17,1672.03,1668.89,1663.56,
+	1658.23,1647.75,1637.27,1630.02,1622.77,1606.06,1589.36,
+	1552.29,1515.22,1528.91,1542.60,1548.90,1555.21,1544.41,
+	1533.62,1525.24,1516.86,1507.92,1498.98,1484.07,1469.17,
+	1464.28,1459.39,1448.73,1438.08,1423.16,1408.24,1407.53,
+	1406.82,1397.82,1388.82,1378.51,1368.21,1352.13,1336.05,
+	1343.88,1351.71,1339.60,1327.50,1320.72,1313.94,1294.94,
+	1275.94,1280.92,1285.90,1278.04,1270.19,1263.68,1257.18,
+	1249.80,1242.41,1231.30,1220.19,1212.14,1204.10,1201.69,
+	1199.29,1194.78,1190.27,1185.47,1180.68,1174.38,1168.09,
+	1156.17,1144.26,1143.46,1142.67,1132.95,1123.23,1116.71,
+	1110.19,1110.89,1111.59,1094.80,1078.01,1077.75,1077.49,
+	1073.89,1070.29,1058.71,1047.13,1045.66,1044.20,1037.03,
+	1029.86,1010.40, 990.94, 966.91, 942.89, 972.87,1002.86,
+	978.93, 955.00, 960.95, 966.91, 983.31, 999.71, 991.91,
+	984.11, 979.05, 973.99, 968.79, 963.60, 958.23, 952.87,
+	947.93, 942.99, 937.99, 933.00, 928.00, 923.00, 918.18,
+	913.37, 908.74, 904.11, 899.05, 893.99, 889.18, 884.37,
+	879.74, 875.12, 870.24, 865.36, 860.94, 856.53, 852.02,
+	847.50, 843.00, 838.50, 833.99, 829.49, 824.98, 820.48,
+	815.99, 811.50, 806.99, 802.49, 798.17, 793.86, 789.74,
+	785.63, 781.25, 776.87, 772.92, 768.98, 764.80, 760.63,
+	756.06, 751.49, 746.99, 742.49, 738.18, 733.88, 729.76,
+	725.63, 721.24, 716.86, 712.92, 708.99, 704.81, 700.63,
+	696.25, 691.87, 687.94, 684.01, 680.01, 676.00, 671.80,
+	667.61, 663.23, 658.86, 655.32, 651.77, 649.07, 646.37,
+	643.74, 641.11, 638.05, 634.99, 632.18, 629.37, 626.74,
+	624.12, 621.06, 618.00, 615.18, 612.37, 609.92, 607.48,
+	604.79, 602.11, 599.24, 596.38, 593.93, 591.48, 588.79,
+	586.11, 583.25, 580.40, 577.94, 575.48, 572.99, 570.51,
+	568.00, 565.49, 562.98, 560.47, 557.98, 555.50, 553.01,
+	550.51, 548.00, 545.49, 542.98, 540.48, 537.98, 535.49,
+	533.19, 530.90, 528.94, 526.99, 524.80, 522.62, 520.24,
+	517.87, 515.44, 513.01, 509.59, 506.17, 502.89, 499.62,
+	496.35, 493.09, 489.81, 486.54, 483.27, 480.01, 476.73,
+	473.46, 470.19, 466.92, 463.64, 460.37, 457.10, 453.84,
+	450.57, 447.30, 444.03, 440.76, 437.48, 434.21, 430.94,
+	427.67, 424.40, 421.13, 417.86, 414.59, 411.32, 408.05,
+	404.78, 401.51, 398.24, 394.97, 391.70, 388.43, 392.57,
+	396.71, 401.92, 407.14, 405.32, 403.50, 401.67, 399.84,
+	398.02, 396.21, 394.37, 392.54, 390.72, 388.90, 387.06,
+	385.23, 383.42, 381.60, 379.77, 377.95, 376.12, 374.30,
+	372.48, 370.66, 368.82, 366.99, 365.17, 363.35, 361.52,
+	359.69, 357.87, 356.05, 354.22, 352.39, 350.57, 348.75,
+	346.92, 345.10, 343.27, 341.45, 341.84, 342.24, 342.95,
+	343.66, 342.27, 340.89, 339.49, 338.09, 336.69, 335.30,
+	333.91, 332.53, 331.13, 329.73, 328.34, 326.96, 325.56,
+	324.16, 322.77, 321.39, 319.99, 318.59, 317.20, 315.82,
+	314.42, 313.03, 311.63, 310.24, 308.85, 307.46, 306.06,
+	304.66, 303.28, 301.90, 300.50, 299.10, 297.71, 296.32,
+	294.93, 293.54, 293.41, 293.28, 293.35, 293.42, 292.26,
+	291.10, 289.97, 288.84, 287.69, 286.54, 285.39, 284.25,
+	283.10, 281.96, 280.81, 279.67, 278.52, 277.38, 276.23,
+	275.08, 273.94, 272.80, 271.65, 270.51, 269.36, 268.22,
+	267.07, 265.93, 264.78, 263.64, 262.49, 261.34, 260.20,
+	259.06, 257.91, 256.77, 255.62, 254.47, 253.33, 252.20,
+	251.16, 250.13, 249.11, 248.09, 246.97, 245.86, 244.74,
+	243.61, 242.49, 241.37, 240.24, 239.12, 238.00, 236.89,
+	235.76, 234.64, 233.51, 232.38, 231.26, 230.13, 229.01,
+	227.90, 226.77, 225.65, 224.53, 223.42, 222.29, 221.16,
+	220.04, 218.92, 217.80, 216.68, 215.55, 214.43, 213.30,
+	212.18, 211.06, 209.94, 208.82, 207.69, 206.99, 206.29,
+	205.65, 205.02, 203.98, 202.95, 201.90, 200.85, 199.81,
+	198.78, 197.74, 196.70, 195.65, 194.61, 193.57, 192.54,
+	191.50, 190.47, 189.42, 188.37, 187.33, 186.30, 185.26,
+	184.22, 183.18, 182.14, 181.10, 180.06, 179.02, 177.98,
+	176.93, 175.89, 174.86, 173.83, 172.78, 171.73, 170.70,
+	169.67, 168.62, 167.57, 167.59, 167.60, 167.76, 167.93,
+	167.09, 166.26, 165.42, 164.58, 163.75, 162.92, 162.08,
+	161.25, 160.41, 159.58, 158.74, 157.91, 157.07, 156.24,
+	155.40, 154.57, 153.73, 152.90, 152.06, 151.23, 150.39,
+	149.56, 148.72, 147.89, 147.06, 146.23, 145.39, 144.55,
+	143.71, 142.88, 142.05, 141.22, 140.38, 139.54, 138.70,
+	137.86, 137.99, 138.11, 138.36, 138.60, 137.94, 137.29,
+	136.64, 136.00, 135.35, 134.71, 134.05, 133.39, 132.74,
+	132.09, 131.45, 130.81, 130.15, 129.49, 128.84, 128.20,
+	127.55, 126.90, 126.25, 125.60, 124.94, 124.29, 123.64,
+	123.00, 122.35, 121.70, 121.05, 120.40, 119.74, 119.09,
+	118.45, 117.81, 117.15, 116.50, 115.85, 115.19, 115.25,
+	115.31, 115.46, 115.62, 115.11, 114.60, 114.09, 113.58,
+	113.06, 112.54, 112.03, 111.53, 111.01, 110.50, 109.99,
+	109.47, 108.95, 108.44, 107.93, 107.42, 106.92, 106.42,
+	105.89, 105.37, 104.85, 104.34, 103.83, 103.33, 102.81,
+	102.29, 101.79, 101.29, 100.77, 100.25,  99.74,  99.22,
         98.71,  98.20,  97.69,  97.18,  97.12,  97.07,  97.09,
         97.11,  96.68,  96.26,  95.84,  95.42,  94.99,  94.56,
         94.14,  93.72,  93.31,  92.89,  92.46,  92.03,  91.61,
@@ -1665,209 +1665,209 @@
         10.52,  10.50,  10.47,  10.44,  10.42,  10.39,  10.37,
         10.34,  10.31,  10.28,  10.25,  10.22,  10.20,  10.17,
         10.15,  10.12,  10.10,  10.06,  10.03,  10.00,   9.98,
-         9.95,   9.92,   9.89,   9.86,   9.84,   9.82,   9.79,
-         9.75,   9.73,   9.71,   9.70,   9.70,   9.70,   9.70,
-         9.67,   9.63,   9.61,   9.59,   9.58,   9.56,   9.53,
-         9.50,   9.48,   9.45,   9.43,   9.41,   9.39,   9.36,
-         9.34,   9.32,   9.30,   9.27,   9.24,   9.22,   9.20,
-         9.18,   9.15,   9.13,   9.11,   9.08,   9.06,   9.05,
-         9.02,   8.99,   8.96,   8.94,   8.92,   8.90,   8.87,
-         8.85,   8.83,   8.81
+	9.95,   9.92,   9.89,   9.86,   9.84,   9.82,   9.79,
+	9.75,   9.73,   9.71,   9.70,   9.70,   9.70,   9.70,
+	9.67,   9.63,   9.61,   9.59,   9.58,   9.56,   9.53,
+	9.50,   9.48,   9.45,   9.43,   9.41,   9.39,   9.36,
+	9.34,   9.32,   9.30,   9.27,   9.24,   9.22,   9.20,
+	9.18,   9.15,   9.13,   9.11,   9.08,   9.06,   9.05,
+	9.02,   8.99,   8.96,   8.94,   8.92,   8.90,   8.87,
+	8.85,   8.83,   8.81
     float pas = 0.0025;
     int   iwl = (int)((wl - 0.250) / pas + 1.5);
-	if(iwl >= 0) return si[iwl-1];
+    if(iwl >= 0) return si[iwl-1];
-	cout << " wavelength  less  than  0.25  micron: " << endl << " let's take s(l)=s(0.25)" << endl;
-	return si[0];
+    cout << " wavelength  less  than  0.25  micron: " << endl << " let's take s(l)=s(0.25)" << endl;
+    return si[0];
 float IWave::equivwl() const
-	float seb = 0;
-	float wlwave = 0;
+    float seb = 0;
+    float wlwave = 0;
-	for(int i = iinf; i <= isup; i++)
-		float sbor = ffu.s[i];
-		if(i == iinf || i == isup) sbor *= 0.5;
-		float wl = (float)(0.25 + i * step);
-		float swl = solirr(wl);
-		float coef = sbor * step * swl;
-		seb += coef;
-		wlwave += wl * coef;
+    for(int i = iinf; i <= isup; i++)
+	float sbor = ffu.s[i];
+	if(i == iinf || i == isup) sbor *= 0.5;
+	float wl = (float)(0.25 + i * step);
+	float swl = solirr(wl);
+	float coef = sbor * step * swl;
+	seb += coef;
+	wlwave += wl * coef;
-	return wlwave/seb;
+    return wlwave/seb;
 void IWave::parse()
-	iinf = 0;
-	isup = 1500;
+    iinf = 0;
+    isup = 1500;
-	int i;
-	for(i = 0; i <= isup; i++) ffu.s[i] = 1;
+    int i;
+    for(i = 0; i <= isup; i++) ffu.s[i] = 1;
-	cin >> iwave;
+    cin >> iwave;
+    cin.ignore(numeric_limits<int>::max(),'\n');
+    if(iwave == 0 || iwave == -2)
+	cin >> ffu.wlinf;
+	cin >> ffu.wlsup;
-	if(iwave == 0 || iwave == -2)
+    else if(iwave < 0)	/* excludes -2 */
+	cin >> wl;
+	ffu.wlinf = wl;
+	ffu.wlsup = wl;
+    else
+	/* da big switch */
+	if(iwave == 1)
-		cin >> ffu.wlinf;
-		cin >> ffu.wlsup;
-		cin.ignore(numeric_limits<int>::max(),'\n');
-	else if(iwave < 0)	/* excludes -2 */
-		cin >> wl;
-		ffu.wlinf = wl;
-		ffu.wlsup = wl;
-	else
-		/* da big switch */
-		if(iwave == 1)
-			cin >> ffu.wlinf;
-			cin >> ffu.wlsup;
-			/* moved rest further on */
-		else if(iwave == 2)		meteo();
-		else if(iwave == 3)		goes_east();
-		else if(iwave == 4)		goes_west();
-		else if(iwave <= 16)	avhrr(iwave - 4);
-		else if(iwave <= 24)	hrv(iwave - 16);
-		else if(iwave <= 30)	tm(iwave - 24);
-		else if(iwave <= 34)	mss(iwave - 30);
-		else if(iwave <= 41)	mas(iwave - 34);
-		else if(iwave <= 48)	modis(iwave - 41);
-		else if(iwave <= 52)	avhrr(iwave - 36);
-		else if(iwave <= 60)	polder(iwave - 52);
-		else if(iwave <= 67)	etmplus(iwave - 60);
-		else fprintf(stderr, "Unsupported iwave value: %d\n", iwave);
+	    cin >> ffu.wlinf;
+	    cin >> ffu.wlsup;
+	    /* moved rest further on */
+	else if(iwave == 2)		meteo();
+	else if(iwave == 3)		goes_east();
+	else if(iwave == 4)		goes_west();
+	else if(iwave <= 16)	avhrr(iwave - 4);
+	else if(iwave <= 24)	hrv(iwave - 16);
+	else if(iwave <= 30)	tm(iwave - 24);
+	else if(iwave <= 34)	mss(iwave - 30);
+	else if(iwave <= 41)	mas(iwave - 34);
+	else if(iwave <= 48)	modis(iwave - 41);
+	else if(iwave <= 52)	avhrr(iwave - 36);
+	else if(iwave <= 60)	polder(iwave - 52);
+	else if(iwave <= 67)	etmplus(iwave - 60);
+	else fprintf(stderr, "Unsupported iwave value: %d\n", iwave);
-	iinf = (int)((ffu.wlinf - 0.25f) / 0.0025f + 1.5f) - 1;	/* remember indexing*/
-	isup = (int)((ffu.wlsup - 0.25f) / 0.0025f + 1.5f) - 1;	/*		   "*/
+    iinf = (int)((ffu.wlinf - 0.25f) / 0.0025f + 1.5f) - 1;	/* remember indexing*/
+    isup = (int)((ffu.wlsup - 0.25f) / 0.0025f + 1.5f) - 1;	/*		   "*/
-	if(iwave == 1)	/* moved here to avoid unnecessery gotos */
-		for(int i = iinf; i <= isup; i++) cin >> ffu.s[i];
+    if(iwave == 1)	/* moved here to avoid unnecessery gotos */
+	for(int i = iinf; i <= isup; i++) cin >> ffu.s[i];
 /* --- spectral condition ---- */
 void IWave::print()
-	static const string nsat[68] = {
-	 string(" constant        "), string(" user s          "),
-     string(" meteosat        "), string(" goes east       "), string(" goes west       "),
-     string(" avhrr 1 (noaa6) "), string(" avhrr 2 (noaa6) "),
-     string(" avhrr 1 (noaa7) "), string(" avhrr 2 (noaa7) "),
-     string(" avhrr 1 (noaa8) "), string(" avhrr 2 (noaa8) "),
-     string(" avhrr 1 (noaa9) "), string(" avhrr 2 (noaa9) "),
-     string(" avhrr 1 (noaa10)"), string(" avhrr 2 (noaa10)"),
-     string(" avhrr 1 (noaa11)"), string(" avhrr 2 (noaa11)"),
-     string(" hrv1 1          "), string(" hrv1 2          "), string(" hrv1 3          "),
-     string(" hrv1 pan        "),
-     string(" hrv2 1          "), string(" hrv2 2          "), string(" hrv2 3          "),
-     string(" hrv2 pan        "),
-     string("  tm  1          "), string("  tm  2          "), string("  tm  3          "),
-     string("  tm  4          "), string("  tm  5          "), string("  tm  7          "),
-     string("  mss 4          "), string("  mss 5          "),
-     string("  mss 6          "), string("  mss 7          "),
-     string("  mas 1          "), string("  mas 2          "), string("  mas 3          "),
-     string("  mas 4          "), string("  mas 5          "), string("  mas 6          "),
-     string("  mas 7          "), string("  modis 1        "), string("  modis 2        "),
-     string("  modis 3        "), string("  modis 4        "), string("  modis 5        "),
-     string("  modis 6        "), string("  modis 7        "),
-     string(" avhrr 1 (noaa12)"), string(" avhrr 2 (noaa12)"),
-     string(" avhrr 1 (noaa14)"), string(" avhrr 2 (noaa14)"),
-     string(" polder 1        "), string(" polder 2        "),
-     string(" polder 3        "), string(" polder 4        "), string(" polder 6        "),
-     string(" polder 6        "), string(" polder 7        "), string(" polder 8        "),
-     string(" etm+ 1          "), string(" etm+ 2          "), string(" etm+ 3          "),
-     string(" etm+ 4          "), string(" etm+ 5          "), string(" etm+ 7          "),
-     string(" etm+ 8          ")
+    static const string nsat[68] = {
+	string(" constant        "), string(" user s          "),
+	string(" meteosat        "), string(" goes east       "), string(" goes west       "),
+	string(" avhrr 1 (noaa6) "), string(" avhrr 2 (noaa6) "),
+	string(" avhrr 1 (noaa7) "), string(" avhrr 2 (noaa7) "),
+	string(" avhrr 1 (noaa8) "), string(" avhrr 2 (noaa8) "),
+	string(" avhrr 1 (noaa9) "), string(" avhrr 2 (noaa9) "),
+	string(" avhrr 1 (noaa10)"), string(" avhrr 2 (noaa10)"),
+	string(" avhrr 1 (noaa11)"), string(" avhrr 2 (noaa11)"),
+	string(" hrv1 1          "), string(" hrv1 2          "), string(" hrv1 3          "),
+	string(" hrv1 pan        "),
+	string(" hrv2 1          "), string(" hrv2 2          "), string(" hrv2 3          "),
+	string(" hrv2 pan        "),
+	string("  tm  1          "), string("  tm  2          "), string("  tm  3          "),
+	string("  tm  4          "), string("  tm  5          "), string("  tm  7          "),
+	string("  mss 4          "), string("  mss 5          "),
+	string("  mss 6          "), string("  mss 7          "),
+	string("  mas 1          "), string("  mas 2          "), string("  mas 3          "),
+	string("  mas 4          "), string("  mas 5          "), string("  mas 6          "),
+	string("  mas 7          "), string("  modis 1        "), string("  modis 2        "),
+	string("  modis 3        "), string("  modis 4        "), string("  modis 5        "),
+	string("  modis 6        "), string("  modis 7        "),
+	string(" avhrr 1 (noaa12)"), string(" avhrr 2 (noaa12)"),
+	string(" avhrr 1 (noaa14)"), string(" avhrr 2 (noaa14)"),
+	string(" polder 1        "), string(" polder 2        "),
+	string(" polder 3        "), string(" polder 4        "), string(" polder 6        "),
+	string(" polder 6        "), string(" polder 7        "), string(" polder 8        "),
+	string(" etm+ 1          "), string(" etm+ 2          "), string(" etm+ 3          "),
+	string(" etm+ 4          "), string(" etm+ 5          "), string(" etm+ 7          "),
+	string(" etm+ 8          ")
-	Output::Begin();
-	Output::Repeat(22, ' ');
-	Output::Print(" spectral condition  ");
+    Output::Begin();
+    Output::Repeat(22, ' ');
+    Output::Print(" spectral condition  ");
+    Output::End();
+    Output::Begin();
+    Output::Print(" ------------------  ");
+    Output::End();
+    if(iwave == -2)
+	Output::Begin();
+	Output::Repeat(10,' ');
+	Output::Print(nsat[0]);
 	Output::End();
-	Output::Begin();
-	Output::Print(" ------------------  ");
+	Output::Begin();
+	Output::Repeat(15,' ');
+	Output::Print("value of filter function :");
 	Output::End();
-	if(iwave == -2)
-		Output::Begin();
-		Output::Repeat(10,' ');
-		Output::Print(nsat[0]);
-		Output::End();
+	Output::Begin();
+	ostringstream s;
+	s.setf(ios::fixed, ios::floatfield);
+	s << setprecision(3);
+	s << " wl inf=" << setw(9) << ffu.wlinf << " mic  "
+	  << " wl sup=" << setw(9) << ffu.wlsup << " mic" << ends;
+	Output::Print(s.str());
+	Output::End();
+    else if(iwave == -1)
+	Output::Begin();
+	Output::Repeat(12,' ');
+	ostringstream s;
+	s << " monochromatic calculation at wl :" << setw(9) << ffu.wlsup << " micron" << ends;
+	Output::End();
+    else if(iwave >= 0)
+	Output::Begin();
+	Output::Print(nsat[iwave]);
+	Output::End();
-		Output::Begin();
-		Output::Repeat(15,' ');
-		Output::Print("value of filter function :");
-		Output::End();
+	Output::Begin();
+	Output::End();
-		Output::Begin();
-		ostringstream s;
-		s.setf(ios::fixed, ios::floatfield);
-		s << setprecision(3);
-		s << " wl inf=" << setw(9) << ffu.wlinf << " mic  "
-		  << " wl sup=" << setw(9) << ffu.wlsup << " mic" << ends;
-		Output::Print(s.str());
-		Output::End();
-	else if(iwave == -1)
-		Output::Begin();
-		Output::Repeat(12,' ');
-		ostringstream s;
-		s << " monochromatic calculation at wl :" << setw(9) << ffu.wlsup << " micron" << ends;
-		Output::End();
-	else if(iwave >= 0)
-		Output::Begin();
-		Output::Print(nsat[iwave]);
-		Output::End();
-		Output::Begin();
-		Output::End();
-		Output::Begin();
-		ostringstream s;
-		Output::End();
+	Output::Begin();
+	ostringstream s;
+	Output::End();
 IWave IWave::Parse()
-	IWave iwave;
-	iwave.parse();
-	return iwave;
+    IWave iwave;
+    iwave.parse();
+    return iwave;
Modified: grass/trunk/imagery/i.atcorr/Transform.cpp
--- grass/trunk/imagery/i.atcorr/Transform.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/Transform.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -3,135 +3,135 @@
 void EtmDN(int iwave, float asol, bool before, float &lmin, float &lmax)
-	if (before)		/* ETM+ digital numbers taken before July 1, 2000 */
+    if (before)		/* ETM+ digital numbers taken before July 1, 2000 */
+	switch(iwave)
-		switch(iwave)
-		case 61:
-				lmin = -6.2f;
-				lmax = 194.3f;
-				break;
+	case 61:
+	    lmin = -6.2f;
+	    lmax = 194.3f;
+	    break;
-		case 62:
-				lmin = -6.0f;
-				lmax = 202.4f;
-				break;
+	case 62:
+	    lmin = -6.0f;
+	    lmax = 202.4f;
+	    break;
-		case 63:
-				lmin = -4.5f;
-				lmax = 158.6f;
-				break;
+	case 63:
+	    lmin = -4.5f;
+	    lmax = 158.6f;
+	    break;
-		case 64:
-				if (asol < 45.)
-					lmin = -4.5f;
-					lmax = 235.0f;
-				else
-					lmin = -4.5f;
-					lmax = 157.5f;
-				break;
+	case 64:
+	    if (asol < 45.)
+		lmin = -4.5f;
+		lmax = 235.0f;
+	    else
+		lmin = -4.5f;
+		lmax = 157.5f;
+	    break;
-		case 65:
-				lmin = -1.0f;
-				lmax = 31.76f;
-				break;
+	case 65:
+	    lmin = -1.0f;
+	    lmax = 31.76f;
+	    break;
-		case 66:
-				lmin = -0.35f;
-				lmax = 10.932f;
-				break;
+	case 66:
+	    lmin = -0.35f;
+	    lmax = 10.932f;
+	    break;
-		case 67:
-				lmin = -5.0f;
-				lmax = 244.00f;
-				break;
+	case 67:
+	    lmin = -5.0f;
+	    lmax = 244.00f;
+	    break;
-	else		/* ETM+ digital numbers taken after July 1, 2000 */
+    else		/* ETM+ digital numbers taken after July 1, 2000 */
+	switch(iwave)
-		switch(iwave)
-		case 61:
-				lmin = -6.2f;
-				lmax = 191.6f;
-				break;
+	case 61:
+	    lmin = -6.2f;
+	    lmax = 191.6f;
+	    break;
-		case 62:
-				lmin = -6.4f;
-				lmax = 196.5f;
-				break;
+	case 62:
+	    lmin = -6.4f;
+	    lmax = 196.5f;
+	    break;
-		case 63:
-				lmin = -5.0f;
-				lmax = 152.9f;
-				break;
+	case 63:
+	    lmin = -5.0f;
+	    lmax = 152.9f;
+	    break;
-		case 64:
-				if (asol < 45.)
-					lmin = -5.1f;
-					lmax = 241.1f;
-				else
-					lmin = -5.1f;
-					lmax = 157.4f;
-				break;
+	case 64:
+	    if (asol < 45.)
+		lmin = -5.1f;
+		lmax = 241.1f;
+	    else
+		lmin = -5.1f;
+		lmax = 157.4f;
+	    break;
-		case 65:
-				lmin = -1.0f;
-				lmax = 31.06f;
-				break;
+	case 65:
+	    lmin = -1.0f;
+	    lmax = 31.06f;
+	    break;
-		case 66:
-				lmin = -0.35f;
-				lmax = 10.80f;
-				break;
+	case 66:
+	    lmin = -0.35f;
+	    lmax = 10.80f;
+	    break;
-		case 67:
-				lmin = -4.7f;
-				lmax = 243.1f;
-				break;
+	case 67:
+	    lmin = -4.7f;
+	    lmax = 243.1f;
+	    break;
 /* Assuming input value between 0 and 1
-if rad is true, idn should first be converted to a reflectance value
-returns adjusted value also between 0 and 1 */
+   if rad is true, idn should first be converted to a reflectance value
+   returns adjusted value also between 0 and 1 */
 float transform(const TransformInput ti, InputMask imask, float idn)
     /* convert from radiance to reflectance */
@@ -148,40 +148,40 @@
     if(imask & RADIANCE) idn += (float)M_PI * idn * 255.f * ti.sb / ti.xmus / ti.seb;
-	float rapp = idn;
+    float rapp = idn;
     float ainrpix = ti.ainr[0][0];
-	float xa = 0.0f;
-	float xb = 0.0f;
-	float xc = 0.0f;
-	float rog = rapp / ti.tgasm;
-	/* The if below was added to avoid ground reflectances lower than
-	 zero when ainr(1,1) greater than rapp/tgasm
-	 In such case either the choice of atmospheric model was not
-	 adequate for that image or the calculated apparent reflectance
-	 was too low. Run the model again for other conditions.
-	 The lines below just decrease ainr(1,1)/tgasm to avoid too
-	 bright pixels in the image. Check the output file to see if that
-	 has happened. */
+    float xa = 0.0f;
+    float xb = 0.0f;
+    float xc = 0.0f;
+    float rog = rapp / ti.tgasm;
+    /* The if below was added to avoid ground reflectances lower than
+       zero when ainr(1,1) greater than rapp/tgasm
+       In such case either the choice of atmospheric model was not
+       adequate for that image or the calculated apparent reflectance
+       was too low. Run the model again for other conditions.
+       The lines below just decrease ainr(1,1)/tgasm to avoid too
+       bright pixels in the image. Check the output file to see if that
+       has happened. */
-	float decrfact = 1.0f;
-	if (rog < (ainrpix / ti.tgasm))
+    float decrfact = 1.0f;
+    if (rog < (ainrpix / ti.tgasm))
+	do
-		do
-			decrfact = decrfact - 0.1f;
-			ainrpix = decrfact * ainrpix;
-		while(rog < (ainrpix / ti.tgasm));
+	    decrfact = decrfact - 0.1f;
+	    ainrpix = decrfact * ainrpix;
+	while(rog < (ainrpix / ti.tgasm));
-	rog = (rog - ainrpix / ti.tgasm) / ti.sutott / ti.sdtott;
-	rog = rog / (1.f + rog * ti.sast);
-	xa = (float)M_PI * ti.sb / ti.xmus / ti.seb / ti.tgasm / ti.sutott / ti.sdtott;
-	xb = ti.srotot / ti.sutott / ti.sdtott / ti.tgasm;
-	xc = ti.sast;
+    rog = (rog - ainrpix / ti.tgasm) / ti.sutott / ti.sdtott;
+    rog = rog / (1.f + rog * ti.sast);
+    xa = (float)M_PI * ti.sb / ti.xmus / ti.seb / ti.tgasm / ti.sutott / ti.sdtott;
+    xb = ti.srotot / ti.sutott / ti.sdtott / ti.tgasm;
+    xc = ti.sast;
-	if (rog > 1) rog = 1;
-	if (rog < 0) rog = 0;
+    if (rog > 1) rog = 1;
+    if (rog < 0) rog = 0;
     return rog;
Modified: grass/trunk/imagery/i.atcorr/common.cpp
--- grass/trunk/imagery/i.atcorr/common.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/common.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -7,1104 +7,1104 @@
 Sixs_trunc sixs_trunc; /* initialized in discom global routine */
 Sixs_disc sixs_disc =
-	{0}, {0}, {0}, {0}, {0}, {0},
-	{ .4f, .488f, .515f, .55f, .633f, .694f, .86f, 1.536f, 2.25f, 3.75f },/* wldis */
-	{0},
-	{0}
+    {0}, {0}, {0}, {0}, {0}, {0},
+    { .4f, .488f, .515f, .55f, .633f, .694f, .86f, 1.536f, 2.25f, 3.75f },/* wldis */
+    {0},
+    {0}
 Sixs_sos sixs_sos =
-	{0},
-		-1.f, -.9996f, -.9976f, -.9942f, -.9893f, -.9828f,
-		-.9749f, -.9655f, -.9546f, -.9422f, -.9285f, -.9133f, -.8967f,
-	    -.8787f, -.8594f, -.8388f, -.817f, -.7938f, -.7695f, -.744f,
-		-.7174f, -.6896f, -.6609f, -.6311f, -.6003f, -.5687f, -.5361f,
-	    -.5028f, -.4687f, -.4339f, -.3984f, -.3623f, -.3257f, -.2885f,
-		-.251f, -.213f, -.1747f, -.1362f, -.0974f, -.0585f, -.0195f, 0.f,
-	    .0195f, .0585f, .0974f, .1362f, .1747f, .213f, .251f, .2885f,
-		.3257f, .3623f, .3984f, .4339f, .4687f, .5028f, .5361f, .5687f,
-	    .6003f, .6311f, .6609f, .6896f, .7174f, .744f, .7695f, .7938f,
-		.817f, .8388f, .8594f, .8787f, .8967f, .9133f, .9285f, .9422f,
-	    .9546f, .9655f, .9749f, .9828f, .9893f, .9942f, .9976f, .9996f, 1.f,
-	{    0.f, .0114f, .0266f, .0418f, .0569f, .0719f, .0868f, .1016f,
-		.1162f, .1307f, .1449f, .159f, .1727f, .1863f, .1995f, .2124f,
-	    .2251f, .2373f, .2492f, .2606f, .2719f, .2826f, .2929f, .3027f,
-	    .3121f, .321f, .3294f, .3373f, .3447f, .3516f, .3579f, .3637f,
-	    .369f, .3737f, .3778f, .3813f, .3842f, .3866f, .3884f, .3896f,
-	    .3902f, 0.f, .3902f, .3896f, .3884f, .3866f, .3842f, .3813f,
-		.3778f, .3737f, .369f, .3637f, .3579f, .3516f, .3447f, .3373f,
-		.3294f, .321f, .3121f, .3027f, .2929f, .2826f, .2719f, .2606f,
-	    .2492f, .2373f, .2251f, .2124f, .1995f, .1863f, .1727f, .159f,
-		.1449f, .1307f, .1162f, .1016f, .0868f, .0719f, .0569f, .0418f,
-		.0266f, .0114f, 0.f
+    {0},
+	-1.f, -.9996f, -.9976f, -.9942f, -.9893f, -.9828f,
+	-.9749f, -.9655f, -.9546f, -.9422f, -.9285f, -.9133f, -.8967f,
+	-.8787f, -.8594f, -.8388f, -.817f, -.7938f, -.7695f, -.744f,
+	-.7174f, -.6896f, -.6609f, -.6311f, -.6003f, -.5687f, -.5361f,
+	-.5028f, -.4687f, -.4339f, -.3984f, -.3623f, -.3257f, -.2885f,
+	-.251f, -.213f, -.1747f, -.1362f, -.0974f, -.0585f, -.0195f, 0.f,
+	.0195f, .0585f, .0974f, .1362f, .1747f, .213f, .251f, .2885f,
+	.3257f, .3623f, .3984f, .4339f, .4687f, .5028f, .5361f, .5687f,
+	.6003f, .6311f, .6609f, .6896f, .7174f, .744f, .7695f, .7938f,
+	.817f, .8388f, .8594f, .8787f, .8967f, .9133f, .9285f, .9422f,
+	.9546f, .9655f, .9749f, .9828f, .9893f, .9942f, .9976f, .9996f, 1.f,
+    {    0.f, .0114f, .0266f, .0418f, .0569f, .0719f, .0868f, .1016f,
+	 .1162f, .1307f, .1449f, .159f, .1727f, .1863f, .1995f, .2124f,
+	 .2251f, .2373f, .2492f, .2606f, .2719f, .2826f, .2929f, .3027f,
+	 .3121f, .321f, .3294f, .3373f, .3447f, .3516f, .3579f, .3637f,
+	 .369f, .3737f, .3778f, .3813f, .3842f, .3866f, .3884f, .3896f,
+	 .3902f, 0.f, .3902f, .3896f, .3884f, .3866f, .3842f, .3813f,
+	 .3778f, .3737f, .369f, .3637f, .3579f, .3516f, .3447f, .3373f,
+	 .3294f, .321f, .3121f, .3027f, .2929f, .2826f, .2719f, .2606f,
+	 .2492f, .2373f, .2251f, .2124f, .1995f, .1863f, .1727f, .159f,
+	 .1449f, .1307f, .1162f, .1016f, .0868f, .0719f, .0569f, .0418f,
+	 .0266f, .0114f, 0.f
 /* only used in aerosol model */
 Sixs_aerbas sixs_aerbas =
-		/* background desert model... */
-			0.8352,0.8057,0.7377,0.6569,0.5760,0.5032,0.4427,0.3969,
+    /* background desert model... */
+	    0.8352,0.8057,0.7377,0.6569,0.5760,0.5032,0.4427,0.3969,
-			0.3646,0.3385,0.3125,0.2863,0.2611,0.2380,0.2175,0.1998,
-			0.1848,0.1722,0.1619,0.1536,0.1469,0.1416,0.1376,0.1347,
-			0.1329,0.1319,0.1319,0.1327,0.1343,0.1366,0.1397,0.1437,
-			0.1485,0.1541,0.1607,0.1682,0.1768,0.1865,0.1974,0.2097,
-			0.2235,0.2309,0.2388,0.2559,0.2749,0.2960,0.3196,0.3459,
-			0.3750,0.4073,0.4432,0.4831,0.5276,0.5774,0.6331,0.6954,
-			0.7652,0.8433,0.9308,1.0291,1.1399,1.2648,1.4060,1.5661,
-			1.7479,1.9552,2.1925,2.4657,2.7822,3.1529,3.5921,4.1201,
-			4.7671,5.5787,6.6249,8.0218,9.9742,12.864,17.461,25.540,
-			42.106,87.294,183.39
-			0.8002,0.7733,0.7063,0.6273,0.5489,0.4793,0.4227,0.3810,
-			0.3524,0.3297,0.3071,0.2839,0.2611,0.2399,0.2207,0.2039,
-			0.1895,0.1773,0.1672,0.1590,0.1523,0.1471,0.1431,0.1401,
-			0.1382,0.1373,0.1372,0.1380,0.1396,0.1419,0.1451,0.1490,
-			0.1539,0.1596,0.1663,0.1739,0.1826,0.1925,0.2036,0.2161,
-			0.2301,0.2377,0.2458,0.2632,0.2826,0.3042,0.3284,0.3553,
-			0.3852,0.4184,0.4553,0.4964,0.5424,0.5938,0.6514,0.7159,
-			0.7882,0.8693,0.9603,1.0626,1.1779,1.3081,1.4554,1.6225,
-			1.8124,2.0287,2.2763,2.5611,2.8904,3.2747,3.7281,4.2698,
-			4.9281,5.7448,6.7836,8.1481,10.017,12.714,16.878,23.920,
-			37.639,72.434,130.26
-			0.7899,0.7637,0.6974,0.6190,0.5414,0.4728,0.4173,0.3766,
-			0.3489,0.3271,0.3054,0.2830,0.2609,0.2402,0.2214,0.2048,
-			0.1906,0.1786,0.1685,0.1603,0.1537,0.1485,0.1445,0.1415,
-			0.1396,0.1387,0.1386,0.1394,0.1409,0.1433,0.1464,0.1504,
-			0.1553,0.1610,0.1677,0.1754,0.1841,0.1940,0.2052,0.2178,
+	    0.3646,0.3385,0.3125,0.2863,0.2611,0.2380,0.2175,0.1998,
+	    0.1848,0.1722,0.1619,0.1536,0.1469,0.1416,0.1376,0.1347,
+	    0.1329,0.1319,0.1319,0.1327,0.1343,0.1366,0.1397,0.1437,
+	    0.1485,0.1541,0.1607,0.1682,0.1768,0.1865,0.1974,0.2097,
+	    0.2235,0.2309,0.2388,0.2559,0.2749,0.2960,0.3196,0.3459,
+	    0.3750,0.4073,0.4432,0.4831,0.5276,0.5774,0.6331,0.6954,
+	    0.7652,0.8433,0.9308,1.0291,1.1399,1.2648,1.4060,1.5661,
+	    1.7479,1.9552,2.1925,2.4657,2.7822,3.1529,3.5921,4.1201,
+	    4.7671,5.5787,6.6249,8.0218,9.9742,12.864,17.461,25.540,
+	    42.106,87.294,183.39
+	 0.8002,0.7733,0.7063,0.6273,0.5489,0.4793,0.4227,0.3810,
+	 0.3524,0.3297,0.3071,0.2839,0.2611,0.2399,0.2207,0.2039,
+	 0.1895,0.1773,0.1672,0.1590,0.1523,0.1471,0.1431,0.1401,
+	 0.1382,0.1373,0.1372,0.1380,0.1396,0.1419,0.1451,0.1490,
+	 0.1539,0.1596,0.1663,0.1739,0.1826,0.1925,0.2036,0.2161,
+	 0.2301,0.2377,0.2458,0.2632,0.2826,0.3042,0.3284,0.3553,
+	 0.3852,0.4184,0.4553,0.4964,0.5424,0.5938,0.6514,0.7159,
+	 0.7882,0.8693,0.9603,1.0626,1.1779,1.3081,1.4554,1.6225,
+	 1.8124,2.0287,2.2763,2.5611,2.8904,3.2747,3.7281,4.2698,
+	 4.9281,5.7448,6.7836,8.1481,10.017,12.714,16.878,23.920,
+	 37.639,72.434,130.26
+	 0.7899,0.7637,0.6974,0.6190,0.5414,0.4728,0.4173,0.3766,
+	 0.3489,0.3271,0.3054,0.2830,0.2609,0.2402,0.2214,0.2048,
+	 0.1906,0.1786,0.1685,0.1603,0.1537,0.1485,0.1445,0.1415,
+	 0.1396,0.1387,0.1386,0.1394,0.1409,0.1433,0.1464,0.1504,
+	 0.1553,0.1610,0.1677,0.1754,0.1841,0.1940,0.2052,0.2178,
-			0.2319,0.2395,0.2476,0.2651,0.2846,0.3064,0.3307,0.3578,
-			0.3879,0.4214,0.4585,0.5000,0.5464,0.5982,0.6563,0.7215,
-			0.7944,0.8763,0.9682,1.0715,1.1881,1.3197,1.4685,1.6375,
-			1.8294,2.0481,2.2983,2.5859,2.9183,3.3060,3.7626,4.3073,
-			4.9677,5.7846,6.8200,8.1736,10.017,12.661,16.709,23.484,
-			36.489,68.980,119.09
-			0.7770,0.7516,0.6862,0.6087,0.5323,0.4648,0.4106,0.3713,
-			0.3447,0.3239,0.3032,0.2817,0.2604,0.2403,0.2220,0.2058,
-			0.1918,0.1800,0.1700,0.1619,0.1553,0.1501,0.1461,0.1432,
-			0.1413,0.1403,0.1402,0.1410,0.1426,0.1449,0.1481,0.1521,
-			0.1570,0.1628,0.1695,0.1772,0.1860,0.1959,0.2072,0.2199,
-			0.2340,0.2417,0.2498,0.2675,0.2871,0.3091,0.3336,0.3608,
-			0.3912,0.4250,0.4625,0.5044,0.5512,0.6036,0.6623,0.7282,
-			0.8019,0.8848,0.9777,1.0823,1.2003,1.3336,1.4844,1.6555,
-			1.8498,2.0712,2.3245,2.6155,2.9515,3.3429,3.8033,4.3511,
-			5.0134,5.8298,6.8600,8.1995,10.012,12.589,16.495,22.954,
-			35.131,65.032,107.60
-			0.7483,0.7247,0.6618,0.5867,0.5127,0.4480,0.3967,0.3601,
-			0.3357,0.3169,0.2982,0.2787,0.2590,0.2403,0.2230,0.2076,
-			0.1942,0.1827,0.1730,0.1651,0.1586,0.1535,0.1495,0.1466,
-			0.1447,0.1437,0.1437,0.1445,0.1460,0.1484,0.1516,0.1557,
-			0.1606,0.1664,0.1732,0.1810,0.1899,0.2000,0.2114,0.2242,
-			0.2386,0.2464,0.2546,0.2725,0.2925,0.3147,0.3396,0.3674,
-			0.3983,0.4327,0.4710,0.5138,0.5616,0.6151,0.6752,0.7425,
-			0.8180,0.9029,0.9982,1.1054,1.2264,1.3631,1.5178,1.6933,
-			1.8926,2.1196,2.3789,2.6765,3.0196,3.4181,3.8851,4.4383,
+	 0.2319,0.2395,0.2476,0.2651,0.2846,0.3064,0.3307,0.3578,
+	 0.3879,0.4214,0.4585,0.5000,0.5464,0.5982,0.6563,0.7215,
+	 0.7944,0.8763,0.9682,1.0715,1.1881,1.3197,1.4685,1.6375,
+	 1.8294,2.0481,2.2983,2.5859,2.9183,3.3060,3.7626,4.3073,
+	 4.9677,5.7846,6.8200,8.1736,10.017,12.661,16.709,23.484,
+	 36.489,68.980,119.09
+	 0.7770,0.7516,0.6862,0.6087,0.5323,0.4648,0.4106,0.3713,
+	 0.3447,0.3239,0.3032,0.2817,0.2604,0.2403,0.2220,0.2058,
+	 0.1918,0.1800,0.1700,0.1619,0.1553,0.1501,0.1461,0.1432,
+	 0.1413,0.1403,0.1402,0.1410,0.1426,0.1449,0.1481,0.1521,
+	 0.1570,0.1628,0.1695,0.1772,0.1860,0.1959,0.2072,0.2199,
+	 0.2340,0.2417,0.2498,0.2675,0.2871,0.3091,0.3336,0.3608,
+	 0.3912,0.4250,0.4625,0.5044,0.5512,0.6036,0.6623,0.7282,
+	 0.8019,0.8848,0.9777,1.0823,1.2003,1.3336,1.4844,1.6555,
+	 1.8498,2.0712,2.3245,2.6155,2.9515,3.3429,3.8033,4.3511,
+	 5.0134,5.8298,6.8600,8.1995,10.012,12.589,16.495,22.954,
+	 35.131,65.032,107.60
+	 0.7483,0.7247,0.6618,0.5867,0.5127,0.4480,0.3967,0.3601,
+	 0.3357,0.3169,0.2982,0.2787,0.2590,0.2403,0.2230,0.2076,
+	 0.1942,0.1827,0.1730,0.1651,0.1586,0.1535,0.1495,0.1466,
+	 0.1447,0.1437,0.1437,0.1445,0.1460,0.1484,0.1516,0.1557,
+	 0.1606,0.1664,0.1732,0.1810,0.1899,0.2000,0.2114,0.2242,
+	 0.2386,0.2464,0.2546,0.2725,0.2925,0.3147,0.3396,0.3674,
+	 0.3983,0.4327,0.4710,0.5138,0.5616,0.6151,0.6752,0.7425,
+	 0.8180,0.9029,0.9982,1.1054,1.2264,1.3631,1.5178,1.6933,
+	 1.8926,2.1196,2.3789,2.6765,3.0196,3.4181,3.8851,4.4383,
-			5.1031,5.9162,6.9324,8.2384,9.9800,12.414,16.024,21.8313,
-			32.417,57.406,86.131
-			0.7290,0.7065,0.6456,0.5721,0.5001,0.4373,0.3879,0.3528,
-			0.3298,0.3122,0.2948,0.2764,0.2579,0.2400,0.2234,0.2085,
-			0.1955,0.1843,0.1748,0.1670,0.1606,0.1555,0.1516,0.1488,
-			0.1469,0.1459,0.1459,0.1467,0.1483,0.1507,0.1539,0.1579,
-			0.1629,0.1688,0.1756,0.1835,0.1924,0.2026,0.2141,0.2270,
-			0.2415,0.2494,0.2577,0.2758,0.2959,0.3185,0.3436,0.3717,
-			0.4030,0.4378,0.4766,0.5199,0.5684,0.6227,0.6836,0.7519,
-			0.8285,0.9146,1.0114,1.1203,1.2432,1.3821,1.5392,1.7174,
-			1.9197,2.1501,2.4131,2.7146,3.0617,3.4642,3.9347,4.4902,
-			5.1552,5.9644,6.9694,8.2514,9.9446,12.284,15.706,21.119,
-			30.763,52.922,75.133
-			0.6834,0.6633,0.6079,0.5390,0.4716,0.4134,0.3682,0.3368,
-			0.3165,0.3014,0.2865,0.2708,0.2546,0.2387,0.2237,0.2101,
-			0.1980,0.1875,0.1786,0.1711,0.1650,0.1601,0.1564,0.1536,
-			0.1518,0.1509,0.1509,0.1517,0.1534,0.1558,0.1591,0.1632,
-			0.1683,0.1742,0.1812,0.1892,0.1983,0.2087,0.2204,0.2337,
-			0.2485,0.2565,0.2650,0.2835,0.3042,0.3273,0.3531,0.3819,
-			0.4140,0.4499,0.4898,0.5345,0.5844,0.6405,0.7033,0.7739,
-			0.8531,0.9420,1.0421,1.1547,1.2818,1.4253,1.5877,1.7716,
-			1.9804,2.2176,2.4880,2.7971,3.1520,3.5615,4.0374,4.5953,
-			5.2568,6.0522,7.0261,8.2465,9.8238,11.947,14.951,19.512,
-			27.207,43.691,55.647
-			0.5664,0.5524,0.5105,0.4593,0.4056,0.3604,0.3252,0.3017,
-			0.2868,0.2764,0.2666,0.2562,0.2452,0.2340,0.2231,0.2127,
-			0.2033,0.1949,0.1876,0.1814,0.1763,0.1721,0.1689,0.1665,
-			0.1651,0.1644,0.1647,0.1657,0.1675,0.1702,0.1737,0.1781,
-			0.1835,0.1898,0.1972,0.2056,0.2153,0.2264,0.2388,0.2529,
-			0.2687,0.2773,0.2864,0.3062,0.3284,0.3531,0.3808,0.4118,
-			0.4464,0.4850,0.5281,0.5763,0.6303,0.6908,0.7586,0.8347,
-			0.9201,1.0159,1.1236,1.2446,1.3810,1.5344,1.7076,1.9029,
-			2.1236,2.3730,2.6551,2.9753,3.3383,3.7523,4.2252,4.7683,
-			5.3971,6.1289,6.9937,8.0270,9.2901,10.873,12.948,15.760,
-			20.227,26.155,28.327
-			0.5017,0.4916,0.4574,0.4166,0.3755,0.3366,0.3067,0.2874,
-			0.2748,0.2660,0.2585,0.2504,0.2418,0.2329,0.2241,0.2156,
-			0.2078,0.2007,0.1945,0.1891,0.1846,0.1810,0.1781,0.1761,
-			0.1750,0.1746,0.1750,0.1762,0.1782,0.1810,0.1848,0.1894,
-			0.1950,0.2016,0.2093,0.2181,0.2283,0.2398,0.2528,0.2676,
-			0.2841,0.2931,0.3026,0.3234,0.3466,0.3726,0.4016,0.4341,
-			0.4704,0.5108,0.5560,0.6065,0.6630,0.7261,0.7970,0.8761,
-			0.9649,1.0644,1.1759,1.3009,1.4415,1.5992,1.7762,1.9755,
-			2.1997,2.4512,2.7345,3.0541,3.4136,3.8188,4.2785,4.7998,
-			5.3909,6.0685,6.8504,7.7572,8.8313,10.118,11.724,13.933,
-			16.806,19.370,20.119
-			0.4481,0.4411,0.4148,0.3788,0.3444,0.3172,0.2972,0.2822,
-			0.2711,0.2632,0.2572,0.2514,0.2450,0.2379,0.2310,0.2245,
-			0.2183,0.2126,0.2074,0.2030,0.1993,0.1963,0.1939,0.1923,
-			0.1915,0.1914,0.1920,0.1934,0.1957,0.1988,0.2027,0.2076,
-			0.2135,0.2206,0.2287,0.2381,0.2488,0.2611,0.2750,0.2906,
-			0.3082,0.3178,0.3279,0.3501,0.3748,0.4024,0.4332,0.4677,
-			0.5062,0.5491,0.5968,0.6500,0.7094,0.7758,0.8499,0.9325,
-			1.0245,1.1273,1.2424,1.3710,1.5144,1.6743,1.8527,2.0524,
-			2.2759,2.5253,2.8026,3.1112,3.4553,3.8394,4.2681,4.7465,
-			5.2801,5.8742,6.5358,7.2843,8.1602,9.2141,10.458,11.804,
-			13.032,13.853,14.061
+	 5.1031,5.9162,6.9324,8.2384,9.9800,12.414,16.024,21.8313,
+	 32.417,57.406,86.131
+	 0.7290,0.7065,0.6456,0.5721,0.5001,0.4373,0.3879,0.3528,
+	 0.3298,0.3122,0.2948,0.2764,0.2579,0.2400,0.2234,0.2085,
+	 0.1955,0.1843,0.1748,0.1670,0.1606,0.1555,0.1516,0.1488,
+	 0.1469,0.1459,0.1459,0.1467,0.1483,0.1507,0.1539,0.1579,
+	 0.1629,0.1688,0.1756,0.1835,0.1924,0.2026,0.2141,0.2270,
+	 0.2415,0.2494,0.2577,0.2758,0.2959,0.3185,0.3436,0.3717,
+	 0.4030,0.4378,0.4766,0.5199,0.5684,0.6227,0.6836,0.7519,
+	 0.8285,0.9146,1.0114,1.1203,1.2432,1.3821,1.5392,1.7174,
+	 1.9197,2.1501,2.4131,2.7146,3.0617,3.4642,3.9347,4.4902,
+	 5.1552,5.9644,6.9694,8.2514,9.9446,12.284,15.706,21.119,
+	 30.763,52.922,75.133
+	 0.6834,0.6633,0.6079,0.5390,0.4716,0.4134,0.3682,0.3368,
+	 0.3165,0.3014,0.2865,0.2708,0.2546,0.2387,0.2237,0.2101,
+	 0.1980,0.1875,0.1786,0.1711,0.1650,0.1601,0.1564,0.1536,
+	 0.1518,0.1509,0.1509,0.1517,0.1534,0.1558,0.1591,0.1632,
+	 0.1683,0.1742,0.1812,0.1892,0.1983,0.2087,0.2204,0.2337,
+	 0.2485,0.2565,0.2650,0.2835,0.3042,0.3273,0.3531,0.3819,
+	 0.4140,0.4499,0.4898,0.5345,0.5844,0.6405,0.7033,0.7739,
+	 0.8531,0.9420,1.0421,1.1547,1.2818,1.4253,1.5877,1.7716,
+	 1.9804,2.2176,2.4880,2.7971,3.1520,3.5615,4.0374,4.5953,
+	 5.2568,6.0522,7.0261,8.2465,9.8238,11.947,14.951,19.512,
+	 27.207,43.691,55.647
+	 0.5664,0.5524,0.5105,0.4593,0.4056,0.3604,0.3252,0.3017,
+	 0.2868,0.2764,0.2666,0.2562,0.2452,0.2340,0.2231,0.2127,
+	 0.2033,0.1949,0.1876,0.1814,0.1763,0.1721,0.1689,0.1665,
+	 0.1651,0.1644,0.1647,0.1657,0.1675,0.1702,0.1737,0.1781,
+	 0.1835,0.1898,0.1972,0.2056,0.2153,0.2264,0.2388,0.2529,
+	 0.2687,0.2773,0.2864,0.3062,0.3284,0.3531,0.3808,0.4118,
+	 0.4464,0.4850,0.5281,0.5763,0.6303,0.6908,0.7586,0.8347,
+	 0.9201,1.0159,1.1236,1.2446,1.3810,1.5344,1.7076,1.9029,
+	 2.1236,2.3730,2.6551,2.9753,3.3383,3.7523,4.2252,4.7683,
+	 5.3971,6.1289,6.9937,8.0270,9.2901,10.873,12.948,15.760,
+	 20.227,26.155,28.327
+	 0.5017,0.4916,0.4574,0.4166,0.3755,0.3366,0.3067,0.2874,
+	 0.2748,0.2660,0.2585,0.2504,0.2418,0.2329,0.2241,0.2156,
+	 0.2078,0.2007,0.1945,0.1891,0.1846,0.1810,0.1781,0.1761,
+	 0.1750,0.1746,0.1750,0.1762,0.1782,0.1810,0.1848,0.1894,
+	 0.1950,0.2016,0.2093,0.2181,0.2283,0.2398,0.2528,0.2676,
+	 0.2841,0.2931,0.3026,0.3234,0.3466,0.3726,0.4016,0.4341,
+	 0.4704,0.5108,0.5560,0.6065,0.6630,0.7261,0.7970,0.8761,
+	 0.9649,1.0644,1.1759,1.3009,1.4415,1.5992,1.7762,1.9755,
+	 2.1997,2.4512,2.7345,3.0541,3.4136,3.8188,4.2785,4.7998,
+	 5.3909,6.0685,6.8504,7.7572,8.8313,10.118,11.724,13.933,
+	 16.806,19.370,20.119
+	 0.4481,0.4411,0.4148,0.3788,0.3444,0.3172,0.2972,0.2822,
+	 0.2711,0.2632,0.2572,0.2514,0.2450,0.2379,0.2310,0.2245,
+	 0.2183,0.2126,0.2074,0.2030,0.1993,0.1963,0.1939,0.1923,
+	 0.1915,0.1914,0.1920,0.1934,0.1957,0.1988,0.2027,0.2076,
+	 0.2135,0.2206,0.2287,0.2381,0.2488,0.2611,0.2750,0.2906,
+	 0.3082,0.3178,0.3279,0.3501,0.3748,0.4024,0.4332,0.4677,
+	 0.5062,0.5491,0.5968,0.6500,0.7094,0.7758,0.8499,0.9325,
+	 1.0245,1.1273,1.2424,1.3710,1.5144,1.6743,1.8527,2.0524,
+	 2.2759,2.5253,2.8026,3.1112,3.4553,3.8394,4.2681,4.7465,
+	 5.2801,5.8742,6.5358,7.2843,8.1602,9.2141,10.458,11.804,
+	 13.032,13.853,14.061
-		/* biomass burning model... */
-			0.2150,0.2122,0.2027,0.1928,0.1884,0.1905,0.1952,0.1983,
-			0.1980,0.1954,0.1918,0.1874,0.1819,0.1752,0.1680,0.1612,
-			0.1553,0.1501,0.1457,0.1417,0.1382,0.1351,0.1326,0.1308,
-			0.1296,0.1292,0.1293,0.1299,0.1310,0.1328,0.1353,0.1387,
-			0.1429,0.1480,0.1539,0.1606,0.1682,0.1770,0.1870,0.1984,
-			0.2115,0.2186,0.2263,0.2432,0.2622,0.2838,0.3082,0.3358,
-			0.3671,0.4024,0.4423,0.4875,0.5386,0.5968,0.6630,0.7387,
-			0.8253,0.9247,1.0387,1.1695,1.3192,1.4909,1.6883,1.9162,
-			2.1797,2.4841,2.8350,3.2382,3.7008,4.2315,4.8393,5.5328,
-			6.3184,7.2028,8.1966,9.3190,10.591,12.016,13.541,15.036,
-			16.295,17.092,17.290
-			0.2180,0.2160,0.2091,0.2007,0.1951,0.1943,0.1972,0.2005,
-			0.2013,0.1986,0.1934,0.1874,0.1819,0.1771,0.1724,0.1673,
-			0.1619,0.1565,0.1518,0.1480,0.1449,0.1426,0.1408,0.1395,
-			0.1387,0.1383,0.1385,0.1392,0.1406,0.1427,0.1456,0.1492,
-			0.1535,0.1585,0.1644,0.1713,0.1793,0.1887,0.1995,0.2119,
-			0.2261,0.2339,0.2421,0.2601,0.2803,0.3029,0.3284,0.3571,
-			0.3896,0.4266,0.4687,0.5166,0.5710,0.6328,0.7029,0.7826,
-			0.8733,0.9769,1.0955,1.2314,1.3869,1.5649,1.7685,2.0010,
-			2.2665,2.5691,2.9134,3.3049,3.7496,4.2547,4.8268,5.4728,
-			6.1989,7.0122,7.9194,8.9236,10.016,11.166,12.309,13.350,
-			14.175,14.677,14.799
-			0.2171,0.2154,0.2091,0.2012,0.1955,0.1939,0.1960,0.1992,
-			0.2006,0.1987,0.1940,0.1879,0.1820,0.1770,0.1727,0.1684,
-			0.1638,0.1590,0.1544,0.1504,0.1473,0.1450,0.1433,0.1422,
-			0.1416,0.1414,0.1418,0.1426,0.1439,0.1459,0.1486,0.1522,
-			0.1566,0.1619,0.1681,0.1752,0.1835,0.1930,0.2039,0.2163,
-			0.2305,0.2383,0.2466,0.2650,0.2857,0.3090,0.3352,0.3647,
-			0.3981,0.4358,0.4785,0.5269,0.5816,0.6437,0.7143,0.7949,
-			0.8870,0.9923,1.1126,1.2501,1.4072,1.5866,1.7913,2.0244,
-			2.2894,2.5902,2.9315,3.3191,3.7594,4.2591,4.8242,5.4598,
-			6.1705,6.9612,7.8359,8.7939,9.8227,10.889,11.934,12.873,
-			13.609,14.053,14.161
-			0.2183,0.2168,0.2113,0.2040,0.1981,0.1956,0.1966,0.1992,
-			0.2011,0.2003,0.1965,0.1907,0.1843,0.1786,0.1740,0.1701,
-			0.1664,0.1624,0.1583,0.1543,0.1510,0.1484,0.1466,0.1454,
-			0.1448,0.1447,0.1451,0.1461,0.1476,0.1497,0.1525,0.1560,
-			0.1605,0.1660,0.1725,0.1800,0.1886,0.1984,0.2095,0.2221,
-			0.2364,0.2442,0.2526,0.2710,0.2920,0.3158,0.3429,0.3735,
-			0.4081,0.4469,0.4906,0.5399,0.5957,0.6591,0.7311,0.8132,
-			0.9068,1.0134,1.1350,1.2737,1.4317,1.6116,1.8158,2.0475,
-			2.3101,2.6080,2.9466,3.3317,3.7694,4.2645,4.8209,5.4417,
-			6.1298,6.8888,7.7208,8.6227,9.5794,10.558,11.502,12.339,
-			12.989,13.377,13.471
-			0.2249,0.2239,0.2197,0.2137,0.2078,0.2036,0.2019,0.2022,
-			0.2034,0.2038,0.2022,0.1985,0.1929,0.1865,0.1803,0.1751,
-			0.1711,0.1679,0.1651,0.1624,0.1597,0.1571,0.1549,0.1533,
-			0.1525,0.1525,0.1532,0.1545,0.1564,0.1589,0.1622,0.1662,
-			0.1710,0.1767,0.1832,0.1907,0.1995,0.2097,0.2215,0.2351,
-			0.2505,0.2589,0.2679,0.2874,0.3094,0.3341,0.3621,0.3936,
-			0.4294,0.4698,0.5157,0.5676,0.6266,0.6934,0.7691,0.8549,
-			0.9521,1.0619,1.1858,1.3254,1.4828,1.6604,1.8614,2.0895,
-			2.3492,2.6448,2.9802,3.3587,3.7823,4.2529,4.7729,5.3459,
-			5.9763,6.6683,7.4225,8.2312,9.0749,9.9191,10.715,11.405,
-			11.931,12.241,12.316
-			0.2268,0.2259,0.2225,0.2173,0.2117,0.2070,0.2041,0.2029,
+    /* biomass burning model... */
+	    0.2150,0.2122,0.2027,0.1928,0.1884,0.1905,0.1952,0.1983,
+	    0.1980,0.1954,0.1918,0.1874,0.1819,0.1752,0.1680,0.1612,
+	    0.1553,0.1501,0.1457,0.1417,0.1382,0.1351,0.1326,0.1308,
+	    0.1296,0.1292,0.1293,0.1299,0.1310,0.1328,0.1353,0.1387,
+	    0.1429,0.1480,0.1539,0.1606,0.1682,0.1770,0.1870,0.1984,
+	    0.2115,0.2186,0.2263,0.2432,0.2622,0.2838,0.3082,0.3358,
+	    0.3671,0.4024,0.4423,0.4875,0.5386,0.5968,0.6630,0.7387,
+	    0.8253,0.9247,1.0387,1.1695,1.3192,1.4909,1.6883,1.9162,
+	    2.1797,2.4841,2.8350,3.2382,3.7008,4.2315,4.8393,5.5328,
+	    6.3184,7.2028,8.1966,9.3190,10.591,12.016,13.541,15.036,
+	    16.295,17.092,17.290
+	 0.2180,0.2160,0.2091,0.2007,0.1951,0.1943,0.1972,0.2005,
+	 0.2013,0.1986,0.1934,0.1874,0.1819,0.1771,0.1724,0.1673,
+	 0.1619,0.1565,0.1518,0.1480,0.1449,0.1426,0.1408,0.1395,
+	 0.1387,0.1383,0.1385,0.1392,0.1406,0.1427,0.1456,0.1492,
+	 0.1535,0.1585,0.1644,0.1713,0.1793,0.1887,0.1995,0.2119,
+	 0.2261,0.2339,0.2421,0.2601,0.2803,0.3029,0.3284,0.3571,
+	 0.3896,0.4266,0.4687,0.5166,0.5710,0.6328,0.7029,0.7826,
+	 0.8733,0.9769,1.0955,1.2314,1.3869,1.5649,1.7685,2.0010,
+	 2.2665,2.5691,2.9134,3.3049,3.7496,4.2547,4.8268,5.4728,
+	 6.1989,7.0122,7.9194,8.9236,10.016,11.166,12.309,13.350,
+	 14.175,14.677,14.799
+	 0.2171,0.2154,0.2091,0.2012,0.1955,0.1939,0.1960,0.1992,
+	 0.2006,0.1987,0.1940,0.1879,0.1820,0.1770,0.1727,0.1684,
+	 0.1638,0.1590,0.1544,0.1504,0.1473,0.1450,0.1433,0.1422,
+	 0.1416,0.1414,0.1418,0.1426,0.1439,0.1459,0.1486,0.1522,
+	 0.1566,0.1619,0.1681,0.1752,0.1835,0.1930,0.2039,0.2163,
+	 0.2305,0.2383,0.2466,0.2650,0.2857,0.3090,0.3352,0.3647,
+	 0.3981,0.4358,0.4785,0.5269,0.5816,0.6437,0.7143,0.7949,
+	 0.8870,0.9923,1.1126,1.2501,1.4072,1.5866,1.7913,2.0244,
+	 2.2894,2.5902,2.9315,3.3191,3.7594,4.2591,4.8242,5.4598,
+	 6.1705,6.9612,7.8359,8.7939,9.8227,10.889,11.934,12.873,
+	 13.609,14.053,14.161
+	 0.2183,0.2168,0.2113,0.2040,0.1981,0.1956,0.1966,0.1992,
+	 0.2011,0.2003,0.1965,0.1907,0.1843,0.1786,0.1740,0.1701,
+	 0.1664,0.1624,0.1583,0.1543,0.1510,0.1484,0.1466,0.1454,
+	 0.1448,0.1447,0.1451,0.1461,0.1476,0.1497,0.1525,0.1560,
+	 0.1605,0.1660,0.1725,0.1800,0.1886,0.1984,0.2095,0.2221,
+	 0.2364,0.2442,0.2526,0.2710,0.2920,0.3158,0.3429,0.3735,
+	 0.4081,0.4469,0.4906,0.5399,0.5957,0.6591,0.7311,0.8132,
+	 0.9068,1.0134,1.1350,1.2737,1.4317,1.6116,1.8158,2.0475,
+	 2.3101,2.6080,2.9466,3.3317,3.7694,4.2645,4.8209,5.4417,
+	 6.1298,6.8888,7.7208,8.6227,9.5794,10.558,11.502,12.339,
+	 12.989,13.377,13.471
+	 0.2249,0.2239,0.2197,0.2137,0.2078,0.2036,0.2019,0.2022,
+	 0.2034,0.2038,0.2022,0.1985,0.1929,0.1865,0.1803,0.1751,
+	 0.1711,0.1679,0.1651,0.1624,0.1597,0.1571,0.1549,0.1533,
+	 0.1525,0.1525,0.1532,0.1545,0.1564,0.1589,0.1622,0.1662,
+	 0.1710,0.1767,0.1832,0.1907,0.1995,0.2097,0.2215,0.2351,
+	 0.2505,0.2589,0.2679,0.2874,0.3094,0.3341,0.3621,0.3936,
+	 0.4294,0.4698,0.5157,0.5676,0.6266,0.6934,0.7691,0.8549,
+	 0.9521,1.0619,1.1858,1.3254,1.4828,1.6604,1.8614,2.0895,
+	 2.3492,2.6448,2.9802,3.3587,3.7823,4.2529,4.7729,5.3459,
+	 5.9763,6.6683,7.4225,8.2312,9.0749,9.9191,10.715,11.405,
+	 11.931,12.241,12.316
+	 0.2268,0.2259,0.2225,0.2173,0.2117,0.2070,0.2041,0.2029,
-			0.2031,0.2034,0.2029,0.2008,0.1970,0.1919,0.1861,0.1806,
-			0.1758,0.1721,0.1693,0.1673,0.1655,0.1638,0.1622,0.1607,
-			0.1597,0.1593,0.1597,0.1609,0.1628,0.1654,0.1687,0.1728,
-			0.1778,0.1838,0.1908,0.1990,0.2083,0.2189,0.2309,0.2446,
-			0.2602,0.2687,0.2779,0.2981,0.3210,0.3470,0.3763,0.4093,
-			0.4464,0.4883,0.5354,0.5887,0.6488,0.7166,0.7931,0.8793,
-			0.9763,1.0854,1.2083,1.3469,1.5037,1.6817,1.8840,2.1140,
-			2.3747,2.6685,2.9974,3.3632,3.7679,4.2147,4.7080,5.2537,
-			5.8571,6.5215,7.2440,8.0132,8.8062,9.5882,10.315,10.936,
-			11.403,11.678,11.743
-			0.2427,0.2421,0.2399,0.2362,0.2317,0.2269,0.2224,0.2187,
-			0.2159,0.2139,0.2124,0.2110,0.2094,0.2072,0.2041,0.2004,
-			0.1962,0.1917,0.1875,0.1839,0.1810,0.1790,0.1779,0.1775,
-			0.1776,0.1782,0.1792,0.1805,0.1822,0.1846,0.1877,0.1917,
-			0.1968,0.2031,0.2106,0.2194,0.2295,0.2412,0.2545,0.2697,
-			0.2869,0.2963,0.3063,0.3284,0.3532,0.3812,0.4125,0.4476,
-			0.4868,0.5305,0.5793,0.6339,0.6951,0.7639,0.8414,0.9288,
-			1.0277,1.1395,1.2655,1.4074,1.5662,1.7433,1.9398,2.1574,
-			2.3979,2.6641,2.9597,3.2895,3.6589,4.0736,4.5385,5.0562,
-			5.6261,6.2424,6.8937,7.5622,8.2243,8.8516,9.4132,9.8788,
-			10.221,10.418,10.465
-			0.3408,0.3406,0.3396,0.3380,0.3356,0.3327,0.3292,0.3253,
-			0.3210,0.3165,0.3119,0.3072,0.3026,0.2981,0.2939,0.2898,
-			0.2861,0.2827,0.2797,0.2770,0.2747,0.2728,0.2712,0.2701,
-			0.2693,0.2690,0.2693,0.2700,0.2715,0.2737,0.2768,0.2808,
-			0.2861,0.2926,0.3005,0.3101,0.3214,0.3346,0.3499,0.3675,
+	 0.2031,0.2034,0.2029,0.2008,0.1970,0.1919,0.1861,0.1806,
+	 0.1758,0.1721,0.1693,0.1673,0.1655,0.1638,0.1622,0.1607,
+	 0.1597,0.1593,0.1597,0.1609,0.1628,0.1654,0.1687,0.1728,
+	 0.1778,0.1838,0.1908,0.1990,0.2083,0.2189,0.2309,0.2446,
+	 0.2602,0.2687,0.2779,0.2981,0.3210,0.3470,0.3763,0.4093,
+	 0.4464,0.4883,0.5354,0.5887,0.6488,0.7166,0.7931,0.8793,
+	 0.9763,1.0854,1.2083,1.3469,1.5037,1.6817,1.8840,2.1140,
+	 2.3747,2.6685,2.9974,3.3632,3.7679,4.2147,4.7080,5.2537,
+	 5.8571,6.5215,7.2440,8.0132,8.8062,9.5882,10.315,10.936,
+	 11.403,11.678,11.743
+	 0.2427,0.2421,0.2399,0.2362,0.2317,0.2269,0.2224,0.2187,
+	 0.2159,0.2139,0.2124,0.2110,0.2094,0.2072,0.2041,0.2004,
+	 0.1962,0.1917,0.1875,0.1839,0.1810,0.1790,0.1779,0.1775,
+	 0.1776,0.1782,0.1792,0.1805,0.1822,0.1846,0.1877,0.1917,
+	 0.1968,0.2031,0.2106,0.2194,0.2295,0.2412,0.2545,0.2697,
+	 0.2869,0.2963,0.3063,0.3284,0.3532,0.3812,0.4125,0.4476,
+	 0.4868,0.5305,0.5793,0.6339,0.6951,0.7639,0.8414,0.9288,
+	 1.0277,1.1395,1.2655,1.4074,1.5662,1.7433,1.9398,2.1574,
+	 2.3979,2.6641,2.9597,3.2895,3.6589,4.0736,4.5385,5.0562,
+	 5.6261,6.2424,6.8937,7.5622,8.2243,8.8516,9.4132,9.8788,
+	 10.221,10.418,10.465
+	 0.3408,0.3406,0.3396,0.3380,0.3356,0.3327,0.3292,0.3253,
+	 0.3210,0.3165,0.3119,0.3072,0.3026,0.2981,0.2939,0.2898,
+	 0.2861,0.2827,0.2797,0.2770,0.2747,0.2728,0.2712,0.2701,
+	 0.2693,0.2690,0.2693,0.2700,0.2715,0.2737,0.2768,0.2808,
+	 0.2861,0.2926,0.3005,0.3101,0.3214,0.3346,0.3499,0.3675,
-			0.3875,0.3984,0.4100,0.4354,0.4636,0.4951,0.5300,0.5686,
-			0.6114,0.6588,0.7114,0.7697,0.8346,0.9068,0.9874,1.0773,
-			1.1778,1.2898,1.4147,1.5535,1.7072,1.8766,2.0625,2.2649,
-			2.4840,2.7191,2.9691,3.2325,3.5070,3.7899,4.0777,4.3667,
-			4.6524,4.9302,5.1951,5.4422,5.6667,5.8638,6.0293,6.1597,
-			6.2518,6.3038,6.3160
-			0.4735,0.4733,0.4725,0.4711,0.4690,0.4664,0.4632,0.4596,
-			0.4554,0.4507,0.4457,0.4404,0.4347,0.4289,0.4229,0.4168,
-			0.4106,0.4046,0.3987,0.3930,0.3876,0.3825,0.3779,0.3738,
-			0.3704,0.3676,0.3656,0.3646,0.3645,0.3655,0.3677,0.3712,
-			0.3762,0.3827,0.3910,0.4011,0.4134,0.4278,0.4447,0.4643,
-			0.4868,0.4992,0.5124,0.5414,0.5742,0.6109,0.6519,0.6974,
-			0.7479,0.8036,0.8648,0.9317,1.0047,1.0838,1.1694,1.2615,
-			1.3601,1.4653,1.5768,1.6946,1.8182,1.9474,2.0814,2.2197,
-			2.3614,2.5057,2.6516,2.7980,2.9435,3.0870,3.2271,3.3623,
-			3.4914,3.6129,3.7254,3.8277,3.9184,3.9966,4.0611,4.1113,
-			4.1465,4.1662,4.1709
-			0.7907,0.7905,0.7895,0.7878,0.7852,0.7820,0.7780,0.7733,
-			0.7679,0.7619,0.7553,0.7481,0.7405,0.7324,0.7239,0.7151,
-			0.7061,0.6968,0.6875,0.6782,0.6690,0.6599,0.6512,0.6428,
-			0.6349,0.6276,0.6211,0.6154,0.6107,0.6071,0.6047,0.6037,
-			0.6042,0.6063,0.6102,0.6160,0.6239,0.6339,0.6462,0.6609,
-			0.6782,0.6878,0.6981,0.7207,0.7461,0.7743,0.8055,0.8396,
-			0.8768,0.9168,0.9599,1.0058,1.0545,1.1060,1.1601,1.2166,
-			1.2753,1.3362,1.3988,1.4630,1.5284,1.5948,1.6618,1.7290,
-			1.7962,1.8627,1.9284,1.9927,2.0553,2.1156,2.1734,2.2281,
+	 0.3875,0.3984,0.4100,0.4354,0.4636,0.4951,0.5300,0.5686,
+	 0.6114,0.6588,0.7114,0.7697,0.8346,0.9068,0.9874,1.0773,
+	 1.1778,1.2898,1.4147,1.5535,1.7072,1.8766,2.0625,2.2649,
+	 2.4840,2.7191,2.9691,3.2325,3.5070,3.7899,4.0777,4.3667,
+	 4.6524,4.9302,5.1951,5.4422,5.6667,5.8638,6.0293,6.1597,
+	 6.2518,6.3038,6.3160
+	 0.4735,0.4733,0.4725,0.4711,0.4690,0.4664,0.4632,0.4596,
+	 0.4554,0.4507,0.4457,0.4404,0.4347,0.4289,0.4229,0.4168,
+	 0.4106,0.4046,0.3987,0.3930,0.3876,0.3825,0.3779,0.3738,
+	 0.3704,0.3676,0.3656,0.3646,0.3645,0.3655,0.3677,0.3712,
+	 0.3762,0.3827,0.3910,0.4011,0.4134,0.4278,0.4447,0.4643,
+	 0.4868,0.4992,0.5124,0.5414,0.5742,0.6109,0.6519,0.6974,
+	 0.7479,0.8036,0.8648,0.9317,1.0047,1.0838,1.1694,1.2615,
+	 1.3601,1.4653,1.5768,1.6946,1.8182,1.9474,2.0814,2.2197,
+	 2.3614,2.5057,2.6516,2.7980,2.9435,3.0870,3.2271,3.3623,
+	 3.4914,3.6129,3.7254,3.8277,3.9184,3.9966,4.0611,4.1113,
+	 4.1465,4.1662,4.1709
+	 0.7907,0.7905,0.7895,0.7878,0.7852,0.7820,0.7780,0.7733,
+	 0.7679,0.7619,0.7553,0.7481,0.7405,0.7324,0.7239,0.7151,
+	 0.7061,0.6968,0.6875,0.6782,0.6690,0.6599,0.6512,0.6428,
+	 0.6349,0.6276,0.6211,0.6154,0.6107,0.6071,0.6047,0.6037,
+	 0.6042,0.6063,0.6102,0.6160,0.6239,0.6339,0.6462,0.6609,
+	 0.6782,0.6878,0.6981,0.7207,0.7461,0.7743,0.8055,0.8396,
+	 0.8768,0.9168,0.9599,1.0058,1.0545,1.1060,1.1601,1.2166,
+	 1.2753,1.3362,1.3988,1.4630,1.5284,1.5948,1.6618,1.7290,
+	 1.7962,1.8627,1.9284,1.9927,2.0553,2.1156,2.1734,2.2281,
-			2.2795,2.3271,2.3705,2.4095,2.4438,2.4729,2.4969,2.5154,
-			2.5283,2.5355,2.5372
+	 2.2795,2.3271,2.3705,2.4095,2.4438,2.4729,2.4969,2.5154,
+	 2.5283,2.5355,2.5372
-		/* stratospherique aerosol model...
-		  model: Stratospheric aerosol as follow king's model
-		  Journal of Climate and Applied Meteorology, Vol23, No7, pp=1121-1137, 1984 */
-			  .4482,  .4378,  .3984,  .3460,  .3030,  .2864,  .3011,  .3393,
-			  .3852,  .4224,  .4395,  .4332,  .4068,  .3674,  .3232,  .2806,
-			  .2436,  .2137,  .1909,  .1740,  .1615,  .1523,  .1453,  .1398,
-			  .1356,  .1324,  .1300,  .1284,  .1277,  .1278,  .1286,  .1303,
-			  .1328,  .1362,  .1404,  .1455,  .1515,  .1585,  .1666,  .1759,
-			  .1864,  .1922,  .1984,  .2119,  .2272,  .2444,  .2638,  .2856,
-			  .3103,  .3381,  .3696,  .4052,  .4454,  .4911,  .5429,  .6018,
-			  .6687,  .7447,  .8309,  .9284, 1.0383, 1.1614, 1.2985, 1.4500,
-			 1.6169, 1.8014, 2.0088, 2.2506, 2.5487, 2.9404, 3.4830, 4.2562,
-			 5.3583, 6.8944, 8.9537,11.5772,14.7221,18.2338,21.8390,25.1693,
-			27.8195,29.4297,29.8220
-			  .3066,  .3025,  .2862,  .2621,  .2369,  .2173,  .2078,  .2095,
-			  .2201,  .2355,  .2504,  .2607,  .2637,  .2589,  .2472,  .2305,
-			  .2114,  .1919,  .1736,  .1577,  .1445,  .1340,  .1261,  .1203,
-			  .1162,  .1134,  .1117,  .1109,  .1108,  .1113,  .1124,  .1141,
-			  .1165,  .1194,  .1230,  .1273,  .1324,  .1384,  .1452,  .1531,
-			  .1620,  .1669,  .1722,  .1838,  .1969,  .2117,  .2285,  .2475,
-			  .2691,  .2936,  .3213,  .3528,  .3886,  .4293,  .4754,  .5278,
-			  .5872,  .6543,  .7304,  .8164,  .9142, 1.0260, 1.1554, 1.3080,
-			 1.4922, 1.7208, 2.0120, 2.3907, 2.8891, 3.5464, 4.4062, 5.5124,
-			 6.9014, 8.5929,10.5796,12.8175,15.2199,17.6577,19.9678,21.9699,
-			23.4901,24.3864,24.6019
-			  .2797,  .2765,  .2636,  .2440,  .2227,  .2045,  .1934,  .1907,
-			  .1956,  .2056,  .2171,  .2266,  .2316,  .2310,  .2247,  .2138,
-			  .1998,  .1843,  .1689,  .1546,  .1422,  .1319,  .1237,  .1176,
-			  .1131,  .1101,  .1082,  .1073,  .1072,  .1077,  .1089,  .1107,
-			  .1130,  .1160,  .1196,  .1239,  .1289,  .1347,  .1413,  .1490,
-			  .1577,  .1625,  .1676,  .1789,  .1916,  .2061,  .2225,  .2410,
-			  .2621,  .2859,  .3130,  .3437,  .3785,  .4179,  .4626,  .5133,
-			  .5706,  .6356,  .7094,  .7936,  .8904, 1.0031, 1.1367, 1.2984,
-			 1.4985, 1.7518, 2.0779, 2.5018, 3.0542, 3.7695, 4.6834, 5.8280,
-			 7.2258, 8.8822,10.7776,12.8620,15.0519,17.2327,19.2671,21.0083,
-			22.3181,23.0858,23.2698
-			  .2523,  .2499,  .2401,  .2249,  .2075,  .1914,  .1795,  .1736,
-			  .1735,  .1782,  .1854,  .1928,  .1984,  .2005,  .1988,  .1932,
-			  .1846,  .1739,  .1623,  .1506,  .1398,  .1303,  .1223,  .1159,
-			  .1110,  .1076,  .1054,  .1042,  .1039,  .1044,  .1055,  .1073,
-			  .1097,  .1127,  .1163,  .1205,  .1255,  .1312,  .1378,  .1453,
-			  .1539,  .1586,  .1636,  .1746,  .1871,  .2013,  .2173,  .2354,
-			  .2559,  .2792,  .3055,  .3352,  .3689,  .4070,  .4502,  .4990,
-			  .5545,  .6178,  .6905,  .7747,  .8738,  .9921, 1.1363, 1.3153,
-			 1.5410, 1.8295, 2.2003, 2.6770, 3.2861, 4.0549, 5.0090, 6.1680,
-			 7.5404, 9.1188,10.8752,12.7575,14.6902,16.5769,18.3076,19.7692,
-			20.8579,21.4919,21.6435
-			  .2099,  .2085,  .2029,  .1937,  .1824,  .1705,  .1597,  .1512,
-			  .1457,  .1433,  .1435,  .1455,  .1484,  .1511,  .1529,  .1533,
-			  .1519,  .1489,  .1445,  .1391,  .1331,  .1270,  .1212,  .1158,
-			  .1112,  .1075,  .1048,  .1029,  .1020,  .1019,  .1027,  .1041,
-			  .1063,  .1092,  .1128,  .1170,  .1220,  .1278,  .1344,  .1419,
-			  .1505,  .1551,  .1601,  .1710,  .1833,  .1971,  .2127,  .2303,
-			  .2501,  .2724,  .2976,  .3260,  .3583,  .3950,  .4371,  .4857,
-			  .5424,  .6092,  .6892,  .7862,  .9053, 1.0531, 1.2379, 1.4701,
-			 1.7619, 2.1272, 2.5813, 3.1398, 3.8174, 4.6261, 5.5735, 6.6598,
-			 7.8763, 9.2034,10.6092,12.0501,13.4719,14.8129,16.0082,16.9948,
-			17.7172,18.1334,18.2325
-			  .1911,  .1901,  .1861,  .1793,  .1706,  .1610,  .1516,  .1432,
-			  .1365,  .1318,  .1292,  .1284,  .1289,  .1301,  .1316,  .1328,
-			  .1333,  .1330,  .1317,  .1295,  .1266,  .1232,  .1196,  .1160,
-			  .1126,  .1096,  .1072,  .1054,  .1043,  .1040,  .1044,  .1056,
-			  .1075,  .1102,  .1136,  .1177,  .1227,  .1285,  .1351,  .1427,
-			  .1513,  .1560,  .1610,  .1719,  .1842,  .1981,  .2136,  .2311,
-			  .2509,  .2732,  .2986,  .3275,  .3607,  .3992,  .4441,  .4973,
-			  .5608,  .6374,  .7309,  .8458,  .9877, 1.1636, 1.3815, 1.6506,
-			 1.9812, 2.3839, 2.8694, 3.4473, 4.1253, 4.9077, 5.7944, 6.7794,
-			 7.8497, 8.9848,10.1567,11.3301,12.4643,13.5152,14.4381,15.1909,
-			15.7373,16.0504,16.1247
-			  .1657,  .1652,  .1631,  .1595,  .1546,  .1488,  .1424,  .1358,
-			  .1294,  .1235,  .1183,  .1141,  .1107,  .1084,  .1070,  .1063,
-			  .1062,  .1066,  .1072,  .1080,  .1088,  .1096,  .1103,  .1108,
-			  .1113,  .1117,  .1121,  .1126,  .1133,  .1142,  .1155,  .1172,
-			  .1193,  .1221,  .1255,  .1296,  .1345,  .1402,  .1469,  .1547,
-			  .1636,  .1686,  .1739,  .1856,  .1991,  .2147,  .2326,  .2534,
-			  .2775,  .3058,  .3392,  .3787,  .4256,  .4818,  .5491,  .6299,
-			  .7270,  .8435,  .9830, 1.1494, 1.3469, 1.5800, 1.8530, 2.1701,
-			 2.5350, 2.9507, 3.4187, 3.9394, 4.5111, 5.1299, 5.7894, 6.4806,
-			 7.1921, 7.9098, 8.6176, 9.2978, 9.9320,10.5016,10.9891,11.3786,
-			11.6571,11.8152,11.8525
-			  .1867,  .1866,  .1860,  .1850,  .1836,  .1819,  .1797,  .1773,
-			  .1746,  .1717,  .1687,  .1655,  .1624,  .1593,  .1563,  .1535,
-			  .1509,  .1487,  .1469,  .1455,  .1447,  .1444,  .1449,  .1460,
-			  .1480,  .1509,  .1547,  .1596,  .1656,  .1729,  .1814,  .1915,
-			  .2031,  .2164,  .2315,  .2488,  .2683,  .2902,  .3149,  .3426,
-			  .3736,  .3904,  .4081,  .4466,  .4894,  .5369,  .5895,  .6476,
-			  .7117,  .7821,  .8593,  .9436, 1.0355, 1.1354, 1.2434, 1.3598,
-			 1.4848, 1.6183, 1.7604, 1.9108, 2.0693, 2.2352, 2.4081, 2.5870,
-			 2.7711, 2.9591, 3.1498, 3.3417, 3.5332, 3.7226, 3.9080, 4.0876,
-			 4.2594, 4.4215, 4.5720, 4.7090, 4.8308, 4.9359, 5.0228, 5.0905,
-			 5.1379, 5.1645, 5.1708
-			  .4829,  .4828,  .4824,  .4816,  .4804,  .4790,  .4772,  .4751,
-			  .4728,  .4701,  .4673,  .4643,  .4611,  .4578,  .4544,  .4511,
-			  .4477,  .4444,  .4413,  .4384,  .4358,  .4335,  .4317,  .4304,
-			  .4298,  .4299,  .4308,  .4327,  .4356,  .4397,  .4452,  .4520,
-			  .4605,  .4708,  .4829,  .4971,  .5135,  .5323,  .5536,  .5776,
-			  .6045,  .6190,  .6344,  .6674,  .7038,  .7435,  .7869,  .8338,
-			  .8845,  .9390,  .9973, 1.0594, 1.1253, 1.1949, 1.2682, 1.3449,
-			 1.4249, 1.5080, 1.5939, 1.6823, 1.7728, 1.8650, 1.9584, 2.0527,
-			 2.1472, 2.2414, 2.3347, 2.4266, 2.5162, 2.6031, 2.6866, 2.7660,
-			 2.8408, 2.9103, 2.9739, 3.0312, 3.0815, 3.1246, 3.1599, 3.1873,
-			 3.2064, 3.2170, 3.2195
-			 1.0488, 1.0485, 1.0470, 1.0443, 1.0405, 1.0355, 1.0295, 1.0223,
-			 1.0141, 1.0049,  .9948,  .9838,  .9719,  .9594,  .9461,  .9323,
-			  .9180,  .9032,  .8882,  .8730,  .8577,  .8425,  .8273,  .8125,
-			  .7981,  .7841,  .7709,  .7584,  .7469,  .7364,  .7271,  .7191,
-			  .7126,  .7077,  .7045,  .7031,  .7036,  .7062,  .7109,  .7179,
-			  .7271,  .7326,  .7387,  .7527,  .7692,  .7881,  .8096,  .8335,
-			  .8599,  .8886,  .9198,  .9532,  .9888, 1.0265, 1.0661, 1.1075,
-			 1.1505, 1.1949, 1.2406, 1.2872, 1.3346, 1.3825, 1.4307, 1.4789,
-			 1.5267, 1.5741, 1.6205, 1.6659, 1.7098, 1.7521, 1.7924, 1.8305,
-			 1.8661, 1.8989, 1.9289, 1.9557, 1.9792, 1.9992, 2.0156, 2.0282,
-			 2.0370, 2.0419, 2.0431
+    /* stratospherique aerosol model...
+       model: Stratospheric aerosol as follow king's model
+       Journal of Climate and Applied Meteorology, Vol23, No7, pp=1121-1137, 1984 */
+	    .4482,  .4378,  .3984,  .3460,  .3030,  .2864,  .3011,  .3393,
+	    .3852,  .4224,  .4395,  .4332,  .4068,  .3674,  .3232,  .2806,
+	    .2436,  .2137,  .1909,  .1740,  .1615,  .1523,  .1453,  .1398,
+	    .1356,  .1324,  .1300,  .1284,  .1277,  .1278,  .1286,  .1303,
+	    .1328,  .1362,  .1404,  .1455,  .1515,  .1585,  .1666,  .1759,
+	    .1864,  .1922,  .1984,  .2119,  .2272,  .2444,  .2638,  .2856,
+	    .3103,  .3381,  .3696,  .4052,  .4454,  .4911,  .5429,  .6018,
+	    .6687,  .7447,  .8309,  .9284, 1.0383, 1.1614, 1.2985, 1.4500,
+	    1.6169, 1.8014, 2.0088, 2.2506, 2.5487, 2.9404, 3.4830, 4.2562,
+	    5.3583, 6.8944, 8.9537,11.5772,14.7221,18.2338,21.8390,25.1693,
+	    27.8195,29.4297,29.8220
+	 .3066,  .3025,  .2862,  .2621,  .2369,  .2173,  .2078,  .2095,
+	 .2201,  .2355,  .2504,  .2607,  .2637,  .2589,  .2472,  .2305,
+	 .2114,  .1919,  .1736,  .1577,  .1445,  .1340,  .1261,  .1203,
+	 .1162,  .1134,  .1117,  .1109,  .1108,  .1113,  .1124,  .1141,
+	 .1165,  .1194,  .1230,  .1273,  .1324,  .1384,  .1452,  .1531,
+	 .1620,  .1669,  .1722,  .1838,  .1969,  .2117,  .2285,  .2475,
+	 .2691,  .2936,  .3213,  .3528,  .3886,  .4293,  .4754,  .5278,
+	 .5872,  .6543,  .7304,  .8164,  .9142, 1.0260, 1.1554, 1.3080,
+	 1.4922, 1.7208, 2.0120, 2.3907, 2.8891, 3.5464, 4.4062, 5.5124,
+	 6.9014, 8.5929,10.5796,12.8175,15.2199,17.6577,19.9678,21.9699,
+	 23.4901,24.3864,24.6019
+	 .2797,  .2765,  .2636,  .2440,  .2227,  .2045,  .1934,  .1907,
+	 .1956,  .2056,  .2171,  .2266,  .2316,  .2310,  .2247,  .2138,
+	 .1998,  .1843,  .1689,  .1546,  .1422,  .1319,  .1237,  .1176,
+	 .1131,  .1101,  .1082,  .1073,  .1072,  .1077,  .1089,  .1107,
+	 .1130,  .1160,  .1196,  .1239,  .1289,  .1347,  .1413,  .1490,
+	 .1577,  .1625,  .1676,  .1789,  .1916,  .2061,  .2225,  .2410,
+	 .2621,  .2859,  .3130,  .3437,  .3785,  .4179,  .4626,  .5133,
+	 .5706,  .6356,  .7094,  .7936,  .8904, 1.0031, 1.1367, 1.2984,
+	 1.4985, 1.7518, 2.0779, 2.5018, 3.0542, 3.7695, 4.6834, 5.8280,
+	 7.2258, 8.8822,10.7776,12.8620,15.0519,17.2327,19.2671,21.0083,
+	 22.3181,23.0858,23.2698
+	 .2523,  .2499,  .2401,  .2249,  .2075,  .1914,  .1795,  .1736,
+	 .1735,  .1782,  .1854,  .1928,  .1984,  .2005,  .1988,  .1932,
+	 .1846,  .1739,  .1623,  .1506,  .1398,  .1303,  .1223,  .1159,
+	 .1110,  .1076,  .1054,  .1042,  .1039,  .1044,  .1055,  .1073,
+	 .1097,  .1127,  .1163,  .1205,  .1255,  .1312,  .1378,  .1453,
+	 .1539,  .1586,  .1636,  .1746,  .1871,  .2013,  .2173,  .2354,
+	 .2559,  .2792,  .3055,  .3352,  .3689,  .4070,  .4502,  .4990,
+	 .5545,  .6178,  .6905,  .7747,  .8738,  .9921, 1.1363, 1.3153,
+	 1.5410, 1.8295, 2.2003, 2.6770, 3.2861, 4.0549, 5.0090, 6.1680,
+	 7.5404, 9.1188,10.8752,12.7575,14.6902,16.5769,18.3076,19.7692,
+	 20.8579,21.4919,21.6435
+	 .2099,  .2085,  .2029,  .1937,  .1824,  .1705,  .1597,  .1512,
+	 .1457,  .1433,  .1435,  .1455,  .1484,  .1511,  .1529,  .1533,
+	 .1519,  .1489,  .1445,  .1391,  .1331,  .1270,  .1212,  .1158,
+	 .1112,  .1075,  .1048,  .1029,  .1020,  .1019,  .1027,  .1041,
+	 .1063,  .1092,  .1128,  .1170,  .1220,  .1278,  .1344,  .1419,
+	 .1505,  .1551,  .1601,  .1710,  .1833,  .1971,  .2127,  .2303,
+	 .2501,  .2724,  .2976,  .3260,  .3583,  .3950,  .4371,  .4857,
+	 .5424,  .6092,  .6892,  .7862,  .9053, 1.0531, 1.2379, 1.4701,
+	 1.7619, 2.1272, 2.5813, 3.1398, 3.8174, 4.6261, 5.5735, 6.6598,
+	 7.8763, 9.2034,10.6092,12.0501,13.4719,14.8129,16.0082,16.9948,
+	 17.7172,18.1334,18.2325
+	 .1911,  .1901,  .1861,  .1793,  .1706,  .1610,  .1516,  .1432,
+	 .1365,  .1318,  .1292,  .1284,  .1289,  .1301,  .1316,  .1328,
+	 .1333,  .1330,  .1317,  .1295,  .1266,  .1232,  .1196,  .1160,
+	 .1126,  .1096,  .1072,  .1054,  .1043,  .1040,  .1044,  .1056,
+	 .1075,  .1102,  .1136,  .1177,  .1227,  .1285,  .1351,  .1427,
+	 .1513,  .1560,  .1610,  .1719,  .1842,  .1981,  .2136,  .2311,
+	 .2509,  .2732,  .2986,  .3275,  .3607,  .3992,  .4441,  .4973,
+	 .5608,  .6374,  .7309,  .8458,  .9877, 1.1636, 1.3815, 1.6506,
+	 1.9812, 2.3839, 2.8694, 3.4473, 4.1253, 4.9077, 5.7944, 6.7794,
+	 7.8497, 8.9848,10.1567,11.3301,12.4643,13.5152,14.4381,15.1909,
+	 15.7373,16.0504,16.1247
+	 .1657,  .1652,  .1631,  .1595,  .1546,  .1488,  .1424,  .1358,
+	 .1294,  .1235,  .1183,  .1141,  .1107,  .1084,  .1070,  .1063,
+	 .1062,  .1066,  .1072,  .1080,  .1088,  .1096,  .1103,  .1108,
+	 .1113,  .1117,  .1121,  .1126,  .1133,  .1142,  .1155,  .1172,
+	 .1193,  .1221,  .1255,  .1296,  .1345,  .1402,  .1469,  .1547,
+	 .1636,  .1686,  .1739,  .1856,  .1991,  .2147,  .2326,  .2534,
+	 .2775,  .3058,  .3392,  .3787,  .4256,  .4818,  .5491,  .6299,
+	 .7270,  .8435,  .9830, 1.1494, 1.3469, 1.5800, 1.8530, 2.1701,
+	 2.5350, 2.9507, 3.4187, 3.9394, 4.5111, 5.1299, 5.7894, 6.4806,
+	 7.1921, 7.9098, 8.6176, 9.2978, 9.9320,10.5016,10.9891,11.3786,
+	 11.6571,11.8152,11.8525
+	 .1867,  .1866,  .1860,  .1850,  .1836,  .1819,  .1797,  .1773,
+	 .1746,  .1717,  .1687,  .1655,  .1624,  .1593,  .1563,  .1535,
+	 .1509,  .1487,  .1469,  .1455,  .1447,  .1444,  .1449,  .1460,
+	 .1480,  .1509,  .1547,  .1596,  .1656,  .1729,  .1814,  .1915,
+	 .2031,  .2164,  .2315,  .2488,  .2683,  .2902,  .3149,  .3426,
+	 .3736,  .3904,  .4081,  .4466,  .4894,  .5369,  .5895,  .6476,
+	 .7117,  .7821,  .8593,  .9436, 1.0355, 1.1354, 1.2434, 1.3598,
+	 1.4848, 1.6183, 1.7604, 1.9108, 2.0693, 2.2352, 2.4081, 2.5870,
+	 2.7711, 2.9591, 3.1498, 3.3417, 3.5332, 3.7226, 3.9080, 4.0876,
+	 4.2594, 4.4215, 4.5720, 4.7090, 4.8308, 4.9359, 5.0228, 5.0905,
+	 5.1379, 5.1645, 5.1708
+	 .4829,  .4828,  .4824,  .4816,  .4804,  .4790,  .4772,  .4751,
+	 .4728,  .4701,  .4673,  .4643,  .4611,  .4578,  .4544,  .4511,
+	 .4477,  .4444,  .4413,  .4384,  .4358,  .4335,  .4317,  .4304,
+	 .4298,  .4299,  .4308,  .4327,  .4356,  .4397,  .4452,  .4520,
+	 .4605,  .4708,  .4829,  .4971,  .5135,  .5323,  .5536,  .5776,
+	 .6045,  .6190,  .6344,  .6674,  .7038,  .7435,  .7869,  .8338,
+	 .8845,  .9390,  .9973, 1.0594, 1.1253, 1.1949, 1.2682, 1.3449,
+	 1.4249, 1.5080, 1.5939, 1.6823, 1.7728, 1.8650, 1.9584, 2.0527,
+	 2.1472, 2.2414, 2.3347, 2.4266, 2.5162, 2.6031, 2.6866, 2.7660,
+	 2.8408, 2.9103, 2.9739, 3.0312, 3.0815, 3.1246, 3.1599, 3.1873,
+	 3.2064, 3.2170, 3.2195
+	 1.0488, 1.0485, 1.0470, 1.0443, 1.0405, 1.0355, 1.0295, 1.0223,
+	 1.0141, 1.0049,  .9948,  .9838,  .9719,  .9594,  .9461,  .9323,
+	 .9180,  .9032,  .8882,  .8730,  .8577,  .8425,  .8273,  .8125,
+	 .7981,  .7841,  .7709,  .7584,  .7469,  .7364,  .7271,  .7191,
+	 .7126,  .7077,  .7045,  .7031,  .7036,  .7062,  .7109,  .7179,
+	 .7271,  .7326,  .7387,  .7527,  .7692,  .7881,  .8096,  .8335,
+	 .8599,  .8886,  .9198,  .9532,  .9888, 1.0265, 1.0661, 1.1075,
+	 1.1505, 1.1949, 1.2406, 1.2872, 1.3346, 1.3825, 1.4307, 1.4789,
+	 1.5267, 1.5741, 1.6205, 1.6659, 1.7098, 1.7521, 1.7924, 1.8305,
+	 1.8661, 1.8989, 1.9289, 1.9557, 1.9792, 1.9992, 2.0156, 2.0282,
+	 2.0370, 2.0419, 2.0431
-		/* dust model */
-			0.2021E+00,0.2079E+00,0.2462E+00,0.2310E+00,0.2069E+00,0.1883E+00,
-			0.1750E+00,0.1624E+00,0.1458E+00,0.1241E+00,0.1013E+00,0.8379E-01,
-			0.7097E-01,0.6207E-01,0.5595E-01,0.5174E-01,0.4879E-01,0.4675E-01,
-			0.4531E-01,0.4435E-01,0.4373E-01,0.4337E-01,0.4324E-01,0.4330E-01,
-			0.4353E-01,0.4392E-01,0.4449E-01,0.4522E-01,0.4612E-01,0.4721E-01,
-			0.4850E-01,0.5001E-01,0.5177E-01,0.5381E-01,0.5616E-01,0.5885E-01,
-			0.6191E-01,0.6540E-01,0.6936E-01,0.7383E-01,0.7889E-01,0.8168E-01,
-			0.8459E-01,0.9096E-01,0.9808E-01,0.1060E+00,0.1148E+00,0.1246E+00,
-			0.1355E+00,0.1474E+00,0.1605E+00,0.1750E+00,0.1910E+00,0.2088E+00,
-			0.2284E+00,0.2501E+00,0.2739E+00,0.3000E+00,0.3284E+00,0.3594E+00,
-			0.3935E+00,0.4308E+00,0.4718E+00,0.5172E+00,0.5670E+00,0.6222E+00,
-			0.6840E+00,0.7528E+00,0.8308E+00,0.9217E+00,0.1029E+01,0.1159E+01,
-			0.1327E+01,0.1553E+01,0.1878E+01,0.2386E+01,0.3253E+01,0.4937E+01,
-			0.8737E+01,0.1952E+02,0.6427E+02,0.4929E+03,0.5169E+05
-			0.2467E+00,0.2483E+00,0.2871E+00,0.2722E+00,0.2454E+00,0.2231E+00,
-			0.2060E+00,0.1900E+00,0.1704E+00,0.1452E+00,0.1186E+00,0.9754E-01,
-			0.8182E-01,0.7067E-01,0.6284E-01,0.5734E-01,0.5345E-01,0.5070E-01,
-			0.4875E-01,0.4741E-01,0.4651E-01,0.4596E-01,0.4570E-01,0.4569E-01,
-			0.4589E-01,0.4631E-01,0.4693E-01,0.4776E-01,0.4879E-01,0.5005E-01,
-			0.5153E-01,0.5328E-01,0.5532E-01,0.5768E-01,0.6040E-01,0.6350E-01,
-			0.6704E-01,0.7104E-01,0.7559E-01,0.8071E-01,0.8648E-01,0.8967E-01,
-			0.9298E-01,0.1002E+00,0.1083E+00,0.1173E+00,0.1273E+00,0.1384E+00,
-			0.1507E+00,0.1641E+00,0.1790E+00,0.1954E+00,0.2134E+00,0.2335E+00,
-			0.2557E+00,0.2801E+00,0.3070E+00,0.3366E+00,0.3687E+00,0.4039E+00,
-			0.4427E+00,0.4850E+00,0.5316E+00,0.5834E+00,0.6402E+00,0.7032E+00,
-			0.7738E+00,0.8527E+00,0.9422E+00,0.1047E+01,0.1171E+01,0.1321E+01,
-			0.1516E+01,0.1780E+01,0.2160E+01,0.2753E+01,0.3768E+01,0.5728E+01,
-			0.1011E+02,0.2231E+02,0.7109E+02,0.5001E+03,0.3548E+05
-			0.2599E+00,0.2602E+00,0.2986E+00,0.2838E+00,0.2563E+00,0.2330E+00,
-			0.2148E+00,0.1978E+00,0.1774E+00,0.1513E+00,0.1237E+00,0.1017E+00,
-			0.8513E-01,0.7333E-01,0.6499E-01,0.5912E-01,0.5494E-01,0.5198E-01,
-			0.4986E-01,0.4840E-01,0.4742E-01,0.4681E-01,0.4651E-01,0.4647E-01,
-			0.4667E-01,0.4708E-01,0.4772E-01,0.4858E-01,0.4965E-01,0.5094E-01,
-			0.5249E-01,0.5430E-01,0.5642E-01,0.5887E-01,0.6169E-01,0.6491E-01,
-			0.6858E-01,0.7273E-01,0.7744E-01,0.8274E-01,0.8872E-01,0.9201E-01,
-			0.9544E-01,0.1029E+00,0.1113E+00,0.1206E+00,0.1309E+00,0.1424E+00,
-			0.1550E+00,0.1689E+00,0.1842E+00,0.2011E+00,0.2198E+00,0.2404E+00,
-			0.2633E+00,0.2886E+00,0.3163E+00,0.3468E+00,0.3800E+00,0.4164E+00,
-			0.4565E+00,0.5002E+00,0.5485E+00,0.6020E+00,0.6608E+00,0.7261E+00,
-			0.7993E+00,0.8810E+00,0.9739E+00,0.1083E+01,0.1211E+01,0.1368E+01,
-			0.1571E+01,0.1846E+01,0.2242E+01,0.2860E+01,0.3918E+01,0.5956E+01,
-			0.1050E+02,0.2307E+02,0.7281E+02,0.4999E+03,0.3196E+05
-			0.2765E+00,0.2752E+00,0.3129E+00,0.2981E+00,0.2697E+00,0.2452E+00,
-			0.2256E+00,0.2075E+00,0.1862E+00,0.1589E+00,0.1301E+00,0.1069E+00,
-			0.8939E-01,0.7677E-01,0.6780E-01,0.6145E-01,0.5690E-01,0.5366E-01,
-			0.5134E-01,0.4973E-01,0.4862E-01,0.4794E-01,0.4758E-01,0.4751E-01,
-			0.4769E-01,0.4811E-01,0.4877E-01,0.4965E-01,0.5076E-01,0.5212E-01,
-			0.5373E-01,0.5563E-01,0.5784E-01,0.6041E-01,0.6336E-01,0.6672E-01,
-			0.7055E-01,0.7488E-01,0.7979E-01,0.8532E-01,0.9155E-01,0.9497E-01,
-			0.9854E-01,0.1063E+00,0.1150E+00,0.1247E+00,0.1354E+00,0.1473E+00,
-			0.1604E+00,0.1748E+00,0.1907E+00,0.2083E+00,0.2276E+00,0.2491E+00,
-			0.2729E+00,0.2990E+00,0.3279E+00,0.3596E+00,0.3941E+00,0.4319E+00,
-			0.4735E+00,0.5191E+00,0.5693E+00,0.6251E+00,0.6864E+00,0.7545E+00,
-			0.8309E+00,0.9163E+00,0.1013E+01,0.1127E+01,0.1262E+01,0.1426E+01,
-			0.1640E+01,0.1928E+01,0.2345E+01,0.2995E+01,0.4106E+01,0.6242E+01,
-			0.1098E+02,0.2400E+02,0.7481E+02,0.4984E+03,0.2810E+05
-			0.3140E+00,0.3090E+00,0.3440E+00,0.3291E+00,0.2988E+00,0.2716E+00,
-			0.2491E+00,0.2285E+00,0.2053E+00,0.1759E+00,0.1447E+00,0.1190E+00,
-			0.9926E-01,0.8484E-01,0.7446E-01,0.6700E-01,0.6162E-01,0.5774E-01,
-			0.5493E-01,0.5295E-01,0.5158E-01,0.5070E-01,0.5021E-01,0.5005E-01,
-			0.5019E-01,0.5060E-01,0.5129E-01,0.5224E-01,0.5344E-01,0.5492E-01,
-			0.5668E-01,0.5876E-01,0.6118E-01,0.6400E-01,0.6723E-01,0.7091E-01,
-			0.7509E-01,0.7981E-01,0.8516E-01,0.9117E-01,0.9793E-01,0.1016E+00,
-			0.1055E+00,0.1140E+00,0.1234E+00,0.1338E+00,0.1454E+00,0.1582E+00,
-			0.1724E+00,0.1879E+00,0.2051E+00,0.2241E+00,0.2449E+00,0.2681E+00,
-			0.2937E+00,0.3220E+00,0.3531E+00,0.3873E+00,0.4247E+00,0.4656E+00,
-			0.5108E+00,0.5603E+00,0.6149E+00,0.6756E+00,0.7425E+00,0.8168E+00,
-			0.9003E+00,0.9939E+00,0.1101E+01,0.1226E+01,0.1374E+01,0.1557E+01,
-			0.1793E+01,0.2114E+01,0.2577E+01,0.3299E+01,0.4529E+01,0.6879E+01,
-			0.1204E+02,0.2596E+02,0.7866E+02,0.4906E+03,0.2124E+05
-			0.3397E+00,0.3323E+00,0.3646E+00,0.3493E+00,0.3179E+00,0.2889E+00,
-			0.2644E+00,0.2424E+00,0.2181E+00,0.1874E+00,0.1547E+00,0.1274E+00,
-			0.1062E+00,0.9063E-01,0.7928E-01,0.7107E-01,0.6509E-01,0.6076E-01,
-			0.5761E-01,0.5537E-01,0.5380E-01,0.5278E-01,0.5218E-01,0.5196E-01,
-			0.5206E-01,0.5246E-01,0.5317E-01,0.5415E-01,0.5542E-01,0.5697E-01,
-			0.5883E-01,0.6103E-01,0.6359E-01,0.6657E-01,0.6998E-01,0.7387E-01,
-			0.7829E-01,0.8327E-01,0.8891E-01,0.9524E-01,0.1024E+00,0.1063E+00,
-			0.1103E+00,0.1192E+00,0.1291E+00,0.1400E+00,0.1522E+00,0.1656E+00,
-			0.1805E+00,0.1968E+00,0.2148E+00,0.2346E+00,0.2565E+00,0.2807E+00,
-			0.3076E+00,0.3372E+00,0.3699E+00,0.4058E+00,0.4451E+00,0.4881E+00,
-			0.5357E+00,0.5878E+00,0.6454E+00,0.7094E+00,0.7800E+00,0.8586E+00,
-			0.9471E+00,0.1046E+01,0.1160E+01,0.1293E+01,0.1451E+01,0.1646E+01,
-			0.1899E+01,0.2242E+01,0.2738E+01,0.3509E+01,0.4820E+01,0.7310E+01,
-			0.1274E+02,0.2720E+02,0.8080E+02,0.4822E+03,0.1763E+05
-			0.3665E+00,0.3585E+00,0.3853E+00,0.3705E+00,0.3386E+00,0.3093E+00,
-			0.2869E+00,0.2705E+00,0.2507E+00,0.2187E+00,0.1832E+00,0.1512E+00,
-			0.1258E+00,0.1065E+00,0.9217E-01,0.8162E-01,0.7386E-01,0.6812E-01,
-			0.6393E-01,0.6088E-01,0.5870E-01,0.5723E-01,0.5631E-01,0.5585E-01,
-			0.5579E-01,0.5612E-01,0.5681E-01,0.5783E-01,0.5918E-01,0.6088E-01,
-			0.6291E-01,0.6532E-01,0.6815E-01,0.7143E-01,0.7521E-01,0.7951E-01,
-			0.8439E-01,0.8988E-01,0.9607E-01,0.1030E+00,0.1108E+00,0.1151E+00,
-			0.1196E+00,0.1293E+00,0.1400E+00,0.1520E+00,0.1652E+00,0.1799E+00,
-			0.1961E+00,0.2140E+00,0.2338E+00,0.2557E+00,0.2799E+00,0.3069E+00,
-			0.3367E+00,0.3696E+00,0.4060E+00,0.4461E+00,0.4901E+00,0.5388E+00,
-			0.5927E+00,0.6520E+00,0.7180E+00,0.7913E+00,0.8725E+00,0.9634E+00,
-			0.1066E+01,0.1181E+01,0.1314E+01,0.1469E+01,0.1655E+01,0.1885E+01,
-			0.2183E+01,0.2586E+01,0.3166E+01,0.4061E+01,0.5568E+01,0.8386E+01,
-			0.1440E+02,0.2992E+02,0.8452E+02,0.4537E+03,0.1132E+05
-			0.2248E+00,0.2041E+00,0.2013E+00,0.2015E+00,0.2038E+00,0.2142E+00,
-			0.2218E+00,0.2177E+00,0.2078E+00,0.1973E+00,0.1876E+00,0.1779E+00,
-			0.1666E+00,0.1530E+00,0.1377E+00,0.1221E+00,0.1078E+00,0.9531E-01,
-			0.8504E-01,0.7686E-01,0.7052E-01,0.6573E-01,0.6219E-01,0.5966E-01,
-			0.5794E-01,0.5689E-01,0.5645E-01,0.5656E-01,0.5718E-01,0.5825E-01,
-			0.5974E-01,0.6159E-01,0.6382E-01,0.6647E-01,0.6955E-01,0.7314E-01,
-			0.7723E-01,0.8187E-01,0.8711E-01,0.9302E-01,0.9976E-01,0.1035E+00,
-			0.1075E+00,0.1163E+00,0.1263E+00,0.1377E+00,0.1507E+00,0.1653E+00,
-			0.1819E+00,0.2008E+00,0.2222E+00,0.2467E+00,0.2745E+00,0.3060E+00,
-			0.3418E+00,0.3822E+00,0.4279E+00,0.4800E+00,0.5391E+00,0.6066E+00,
-			0.6838E+00,0.7715E+00,0.8718E+00,0.9864E+00,0.1117E+01,0.1268E+01,
-			0.1442E+01,0.1643E+01,0.1880E+01,0.2160E+01,0.2496E+01,0.2906E+01,
-			0.3423E+01,0.4095E+01,0.5014E+01,0.6356E+01,0.8465E+01,0.1211E+02,
-			0.1924E+02,0.3569E+02,0.8510E+02,0.3357E+03,0.3290E+04
-			0.8649E-01,0.6705E-01,0.5195E-01,0.7001E-01,0.7008E-01,0.6002E-01,
-			0.5176E-01,0.4616E-01,0.4241E-01,0.3977E-01,0.3795E-01,0.3668E-01,
-			0.3583E-01,0.3535E-01,0.3514E-01,0.3524E-01,0.3565E-01,0.3638E-01,
-			0.3751E-01,0.3892E-01,0.4055E-01,0.4217E-01,0.4354E-01,0.4447E-01,
-			0.4473E-01,0.4432E-01,0.4334E-01,0.4196E-01,0.4043E-01,0.3895E-01,
-			0.3767E-01,0.3668E-01,0.3599E-01,0.3567E-01,0.3568E-01,0.3603E-01,
-			0.3675E-01,0.3782E-01,0.3929E-01,0.4119E-01,0.4354E-01,0.4489E-01,
-			0.4638E-01,0.4977E-01,0.5377E-01,0.5848E-01,0.6402E-01,0.7052E-01,
-			0.7819E-01,0.8720E-01,0.9780E-01,0.1103E+00,0.1250E+00,0.1423E+00,
-			0.1629E+00,0.1872E+00,0.2164E+00,0.2514E+00,0.2934E+00,0.3442E+00,
-			0.4055E+00,0.4799E+00,0.5709E+00,0.6824E+00,0.8200E+00,0.9912E+00,
-			0.1205E+01,0.1474E+01,0.1814E+01,0.2247E+01,0.2801E+01,0.3520E+01,
-			0.4460E+01,0.5710E+01,0.7406E+01,0.9765E+01,0.1318E+02,0.1847E+02,
-			0.2749E+02,0.4547E+02,0.9155E+02,0.2798E+03,0.1582E+04
-			0.9344E-01,0.8261E-01,0.6680E-01,0.7550E-01,0.8962E-01,0.9095E-01,
-			0.8469E-01,0.7755E-01,0.7170E-01,0.6726E-01,0.6401E-01,0.6173E-01,
-			0.6034E-01,0.5974E-01,0.5979E-01,0.6028E-01,0.6096E-01,0.6155E-01,
-			0.6179E-01,0.6151E-01,0.6067E-01,0.5928E-01,0.5752E-01,0.5554E-01,
-			0.5354E-01,0.5165E-01,0.4997E-01,0.4858E-01,0.4752E-01,0.4683E-01,
-			0.4651E-01,0.4657E-01,0.4701E-01,0.4781E-01,0.4897E-01,0.5053E-01,
-			0.5250E-01,0.5493E-01,0.5787E-01,0.6137E-01,0.6550E-01,0.6782E-01,
-			0.7033E-01,0.7593E-01,0.8242E-01,0.8992E-01,0.9860E-01,0.1087E+00,
-			0.1203E+00,0.1339E+00,0.1497E+00,0.1682E+00,0.1896E+00,0.2147E+00,
-			0.2441E+00,0.2786E+00,0.3193E+00,0.3675E+00,0.4248E+00,0.4931E+00,
-			0.5747E+00,0.6726E+00,0.7902E+00,0.9324E+00,0.1105E+01,0.1316E+01,
-			0.1575E+01,0.1895E+01,0.2292E+01,0.2787E+01,0.3407E+01,0.4192E+01,
-			0.5195E+01,0.6498E+01,0.8221E+01,0.1057E+02,0.1389E+02,0.1886E+02,
-			0.2699E+02,0.4205E+02,0.7598E+02,0.1847E+03,0.5926E+03
+    /* dust model */
+	    0.2021E+00,0.2079E+00,0.2462E+00,0.2310E+00,0.2069E+00,0.1883E+00,
+	    0.1750E+00,0.1624E+00,0.1458E+00,0.1241E+00,0.1013E+00,0.8379E-01,
+	    0.7097E-01,0.6207E-01,0.5595E-01,0.5174E-01,0.4879E-01,0.4675E-01,
+	    0.4531E-01,0.4435E-01,0.4373E-01,0.4337E-01,0.4324E-01,0.4330E-01,
+	    0.4353E-01,0.4392E-01,0.4449E-01,0.4522E-01,0.4612E-01,0.4721E-01,
+	    0.4850E-01,0.5001E-01,0.5177E-01,0.5381E-01,0.5616E-01,0.5885E-01,
+	    0.6191E-01,0.6540E-01,0.6936E-01,0.7383E-01,0.7889E-01,0.8168E-01,
+	    0.8459E-01,0.9096E-01,0.9808E-01,0.1060E+00,0.1148E+00,0.1246E+00,
+	    0.1355E+00,0.1474E+00,0.1605E+00,0.1750E+00,0.1910E+00,0.2088E+00,
+	    0.2284E+00,0.2501E+00,0.2739E+00,0.3000E+00,0.3284E+00,0.3594E+00,
+	    0.3935E+00,0.4308E+00,0.4718E+00,0.5172E+00,0.5670E+00,0.6222E+00,
+	    0.6840E+00,0.7528E+00,0.8308E+00,0.9217E+00,0.1029E+01,0.1159E+01,
+	    0.1327E+01,0.1553E+01,0.1878E+01,0.2386E+01,0.3253E+01,0.4937E+01,
+	    0.8737E+01,0.1952E+02,0.6427E+02,0.4929E+03,0.5169E+05
+	 0.2467E+00,0.2483E+00,0.2871E+00,0.2722E+00,0.2454E+00,0.2231E+00,
+	 0.2060E+00,0.1900E+00,0.1704E+00,0.1452E+00,0.1186E+00,0.9754E-01,
+	 0.8182E-01,0.7067E-01,0.6284E-01,0.5734E-01,0.5345E-01,0.5070E-01,
+	 0.4875E-01,0.4741E-01,0.4651E-01,0.4596E-01,0.4570E-01,0.4569E-01,
+	 0.4589E-01,0.4631E-01,0.4693E-01,0.4776E-01,0.4879E-01,0.5005E-01,
+	 0.5153E-01,0.5328E-01,0.5532E-01,0.5768E-01,0.6040E-01,0.6350E-01,
+	 0.6704E-01,0.7104E-01,0.7559E-01,0.8071E-01,0.8648E-01,0.8967E-01,
+	 0.9298E-01,0.1002E+00,0.1083E+00,0.1173E+00,0.1273E+00,0.1384E+00,
+	 0.1507E+00,0.1641E+00,0.1790E+00,0.1954E+00,0.2134E+00,0.2335E+00,
+	 0.2557E+00,0.2801E+00,0.3070E+00,0.3366E+00,0.3687E+00,0.4039E+00,
+	 0.4427E+00,0.4850E+00,0.5316E+00,0.5834E+00,0.6402E+00,0.7032E+00,
+	 0.7738E+00,0.8527E+00,0.9422E+00,0.1047E+01,0.1171E+01,0.1321E+01,
+	 0.1516E+01,0.1780E+01,0.2160E+01,0.2753E+01,0.3768E+01,0.5728E+01,
+	 0.1011E+02,0.2231E+02,0.7109E+02,0.5001E+03,0.3548E+05
+	 0.2599E+00,0.2602E+00,0.2986E+00,0.2838E+00,0.2563E+00,0.2330E+00,
+	 0.2148E+00,0.1978E+00,0.1774E+00,0.1513E+00,0.1237E+00,0.1017E+00,
+	 0.8513E-01,0.7333E-01,0.6499E-01,0.5912E-01,0.5494E-01,0.5198E-01,
+	 0.4986E-01,0.4840E-01,0.4742E-01,0.4681E-01,0.4651E-01,0.4647E-01,
+	 0.4667E-01,0.4708E-01,0.4772E-01,0.4858E-01,0.4965E-01,0.5094E-01,
+	 0.5249E-01,0.5430E-01,0.5642E-01,0.5887E-01,0.6169E-01,0.6491E-01,
+	 0.6858E-01,0.7273E-01,0.7744E-01,0.8274E-01,0.8872E-01,0.9201E-01,
+	 0.9544E-01,0.1029E+00,0.1113E+00,0.1206E+00,0.1309E+00,0.1424E+00,
+	 0.1550E+00,0.1689E+00,0.1842E+00,0.2011E+00,0.2198E+00,0.2404E+00,
+	 0.2633E+00,0.2886E+00,0.3163E+00,0.3468E+00,0.3800E+00,0.4164E+00,
+	 0.4565E+00,0.5002E+00,0.5485E+00,0.6020E+00,0.6608E+00,0.7261E+00,
+	 0.7993E+00,0.8810E+00,0.9739E+00,0.1083E+01,0.1211E+01,0.1368E+01,
+	 0.1571E+01,0.1846E+01,0.2242E+01,0.2860E+01,0.3918E+01,0.5956E+01,
+	 0.1050E+02,0.2307E+02,0.7281E+02,0.4999E+03,0.3196E+05
+	 0.2765E+00,0.2752E+00,0.3129E+00,0.2981E+00,0.2697E+00,0.2452E+00,
+	 0.2256E+00,0.2075E+00,0.1862E+00,0.1589E+00,0.1301E+00,0.1069E+00,
+	 0.8939E-01,0.7677E-01,0.6780E-01,0.6145E-01,0.5690E-01,0.5366E-01,
+	 0.5134E-01,0.4973E-01,0.4862E-01,0.4794E-01,0.4758E-01,0.4751E-01,
+	 0.4769E-01,0.4811E-01,0.4877E-01,0.4965E-01,0.5076E-01,0.5212E-01,
+	 0.5373E-01,0.5563E-01,0.5784E-01,0.6041E-01,0.6336E-01,0.6672E-01,
+	 0.7055E-01,0.7488E-01,0.7979E-01,0.8532E-01,0.9155E-01,0.9497E-01,
+	 0.9854E-01,0.1063E+00,0.1150E+00,0.1247E+00,0.1354E+00,0.1473E+00,
+	 0.1604E+00,0.1748E+00,0.1907E+00,0.2083E+00,0.2276E+00,0.2491E+00,
+	 0.2729E+00,0.2990E+00,0.3279E+00,0.3596E+00,0.3941E+00,0.4319E+00,
+	 0.4735E+00,0.5191E+00,0.5693E+00,0.6251E+00,0.6864E+00,0.7545E+00,
+	 0.8309E+00,0.9163E+00,0.1013E+01,0.1127E+01,0.1262E+01,0.1426E+01,
+	 0.1640E+01,0.1928E+01,0.2345E+01,0.2995E+01,0.4106E+01,0.6242E+01,
+	 0.1098E+02,0.2400E+02,0.7481E+02,0.4984E+03,0.2810E+05
+	 0.3140E+00,0.3090E+00,0.3440E+00,0.3291E+00,0.2988E+00,0.2716E+00,
+	 0.2491E+00,0.2285E+00,0.2053E+00,0.1759E+00,0.1447E+00,0.1190E+00,
+	 0.9926E-01,0.8484E-01,0.7446E-01,0.6700E-01,0.6162E-01,0.5774E-01,
+	 0.5493E-01,0.5295E-01,0.5158E-01,0.5070E-01,0.5021E-01,0.5005E-01,
+	 0.5019E-01,0.5060E-01,0.5129E-01,0.5224E-01,0.5344E-01,0.5492E-01,
+	 0.5668E-01,0.5876E-01,0.6118E-01,0.6400E-01,0.6723E-01,0.7091E-01,
+	 0.7509E-01,0.7981E-01,0.8516E-01,0.9117E-01,0.9793E-01,0.1016E+00,
+	 0.1055E+00,0.1140E+00,0.1234E+00,0.1338E+00,0.1454E+00,0.1582E+00,
+	 0.1724E+00,0.1879E+00,0.2051E+00,0.2241E+00,0.2449E+00,0.2681E+00,
+	 0.2937E+00,0.3220E+00,0.3531E+00,0.3873E+00,0.4247E+00,0.4656E+00,
+	 0.5108E+00,0.5603E+00,0.6149E+00,0.6756E+00,0.7425E+00,0.8168E+00,
+	 0.9003E+00,0.9939E+00,0.1101E+01,0.1226E+01,0.1374E+01,0.1557E+01,
+	 0.1793E+01,0.2114E+01,0.2577E+01,0.3299E+01,0.4529E+01,0.6879E+01,
+	 0.1204E+02,0.2596E+02,0.7866E+02,0.4906E+03,0.2124E+05
+	 0.3397E+00,0.3323E+00,0.3646E+00,0.3493E+00,0.3179E+00,0.2889E+00,
+	 0.2644E+00,0.2424E+00,0.2181E+00,0.1874E+00,0.1547E+00,0.1274E+00,
+	 0.1062E+00,0.9063E-01,0.7928E-01,0.7107E-01,0.6509E-01,0.6076E-01,
+	 0.5761E-01,0.5537E-01,0.5380E-01,0.5278E-01,0.5218E-01,0.5196E-01,
+	 0.5206E-01,0.5246E-01,0.5317E-01,0.5415E-01,0.5542E-01,0.5697E-01,
+	 0.5883E-01,0.6103E-01,0.6359E-01,0.6657E-01,0.6998E-01,0.7387E-01,
+	 0.7829E-01,0.8327E-01,0.8891E-01,0.9524E-01,0.1024E+00,0.1063E+00,
+	 0.1103E+00,0.1192E+00,0.1291E+00,0.1400E+00,0.1522E+00,0.1656E+00,
+	 0.1805E+00,0.1968E+00,0.2148E+00,0.2346E+00,0.2565E+00,0.2807E+00,
+	 0.3076E+00,0.3372E+00,0.3699E+00,0.4058E+00,0.4451E+00,0.4881E+00,
+	 0.5357E+00,0.5878E+00,0.6454E+00,0.7094E+00,0.7800E+00,0.8586E+00,
+	 0.9471E+00,0.1046E+01,0.1160E+01,0.1293E+01,0.1451E+01,0.1646E+01,
+	 0.1899E+01,0.2242E+01,0.2738E+01,0.3509E+01,0.4820E+01,0.7310E+01,
+	 0.1274E+02,0.2720E+02,0.8080E+02,0.4822E+03,0.1763E+05
+	 0.3665E+00,0.3585E+00,0.3853E+00,0.3705E+00,0.3386E+00,0.3093E+00,
+	 0.2869E+00,0.2705E+00,0.2507E+00,0.2187E+00,0.1832E+00,0.1512E+00,
+	 0.1258E+00,0.1065E+00,0.9217E-01,0.8162E-01,0.7386E-01,0.6812E-01,
+	 0.6393E-01,0.6088E-01,0.5870E-01,0.5723E-01,0.5631E-01,0.5585E-01,
+	 0.5579E-01,0.5612E-01,0.5681E-01,0.5783E-01,0.5918E-01,0.6088E-01,
+	 0.6291E-01,0.6532E-01,0.6815E-01,0.7143E-01,0.7521E-01,0.7951E-01,
+	 0.8439E-01,0.8988E-01,0.9607E-01,0.1030E+00,0.1108E+00,0.1151E+00,
+	 0.1196E+00,0.1293E+00,0.1400E+00,0.1520E+00,0.1652E+00,0.1799E+00,
+	 0.1961E+00,0.2140E+00,0.2338E+00,0.2557E+00,0.2799E+00,0.3069E+00,
+	 0.3367E+00,0.3696E+00,0.4060E+00,0.4461E+00,0.4901E+00,0.5388E+00,
+	 0.5927E+00,0.6520E+00,0.7180E+00,0.7913E+00,0.8725E+00,0.9634E+00,
+	 0.1066E+01,0.1181E+01,0.1314E+01,0.1469E+01,0.1655E+01,0.1885E+01,
+	 0.2183E+01,0.2586E+01,0.3166E+01,0.4061E+01,0.5568E+01,0.8386E+01,
+	 0.1440E+02,0.2992E+02,0.8452E+02,0.4537E+03,0.1132E+05
+	 0.2248E+00,0.2041E+00,0.2013E+00,0.2015E+00,0.2038E+00,0.2142E+00,
+	 0.2218E+00,0.2177E+00,0.2078E+00,0.1973E+00,0.1876E+00,0.1779E+00,
+	 0.1666E+00,0.1530E+00,0.1377E+00,0.1221E+00,0.1078E+00,0.9531E-01,
+	 0.8504E-01,0.7686E-01,0.7052E-01,0.6573E-01,0.6219E-01,0.5966E-01,
+	 0.5794E-01,0.5689E-01,0.5645E-01,0.5656E-01,0.5718E-01,0.5825E-01,
+	 0.5974E-01,0.6159E-01,0.6382E-01,0.6647E-01,0.6955E-01,0.7314E-01,
+	 0.7723E-01,0.8187E-01,0.8711E-01,0.9302E-01,0.9976E-01,0.1035E+00,
+	 0.1075E+00,0.1163E+00,0.1263E+00,0.1377E+00,0.1507E+00,0.1653E+00,
+	 0.1819E+00,0.2008E+00,0.2222E+00,0.2467E+00,0.2745E+00,0.3060E+00,
+	 0.3418E+00,0.3822E+00,0.4279E+00,0.4800E+00,0.5391E+00,0.6066E+00,
+	 0.6838E+00,0.7715E+00,0.8718E+00,0.9864E+00,0.1117E+01,0.1268E+01,
+	 0.1442E+01,0.1643E+01,0.1880E+01,0.2160E+01,0.2496E+01,0.2906E+01,
+	 0.3423E+01,0.4095E+01,0.5014E+01,0.6356E+01,0.8465E+01,0.1211E+02,
+	 0.1924E+02,0.3569E+02,0.8510E+02,0.3357E+03,0.3290E+04
+	 0.8649E-01,0.6705E-01,0.5195E-01,0.7001E-01,0.7008E-01,0.6002E-01,
+	 0.5176E-01,0.4616E-01,0.4241E-01,0.3977E-01,0.3795E-01,0.3668E-01,
+	 0.3583E-01,0.3535E-01,0.3514E-01,0.3524E-01,0.3565E-01,0.3638E-01,
+	 0.3751E-01,0.3892E-01,0.4055E-01,0.4217E-01,0.4354E-01,0.4447E-01,
+	 0.4473E-01,0.4432E-01,0.4334E-01,0.4196E-01,0.4043E-01,0.3895E-01,
+	 0.3767E-01,0.3668E-01,0.3599E-01,0.3567E-01,0.3568E-01,0.3603E-01,
+	 0.3675E-01,0.3782E-01,0.3929E-01,0.4119E-01,0.4354E-01,0.4489E-01,
+	 0.4638E-01,0.4977E-01,0.5377E-01,0.5848E-01,0.6402E-01,0.7052E-01,
+	 0.7819E-01,0.8720E-01,0.9780E-01,0.1103E+00,0.1250E+00,0.1423E+00,
+	 0.1629E+00,0.1872E+00,0.2164E+00,0.2514E+00,0.2934E+00,0.3442E+00,
+	 0.4055E+00,0.4799E+00,0.5709E+00,0.6824E+00,0.8200E+00,0.9912E+00,
+	 0.1205E+01,0.1474E+01,0.1814E+01,0.2247E+01,0.2801E+01,0.3520E+01,
+	 0.4460E+01,0.5710E+01,0.7406E+01,0.9765E+01,0.1318E+02,0.1847E+02,
+	 0.2749E+02,0.4547E+02,0.9155E+02,0.2798E+03,0.1582E+04
+	 0.9344E-01,0.8261E-01,0.6680E-01,0.7550E-01,0.8962E-01,0.9095E-01,
+	 0.8469E-01,0.7755E-01,0.7170E-01,0.6726E-01,0.6401E-01,0.6173E-01,
+	 0.6034E-01,0.5974E-01,0.5979E-01,0.6028E-01,0.6096E-01,0.6155E-01,
+	 0.6179E-01,0.6151E-01,0.6067E-01,0.5928E-01,0.5752E-01,0.5554E-01,
+	 0.5354E-01,0.5165E-01,0.4997E-01,0.4858E-01,0.4752E-01,0.4683E-01,
+	 0.4651E-01,0.4657E-01,0.4701E-01,0.4781E-01,0.4897E-01,0.5053E-01,
+	 0.5250E-01,0.5493E-01,0.5787E-01,0.6137E-01,0.6550E-01,0.6782E-01,
+	 0.7033E-01,0.7593E-01,0.8242E-01,0.8992E-01,0.9860E-01,0.1087E+00,
+	 0.1203E+00,0.1339E+00,0.1497E+00,0.1682E+00,0.1896E+00,0.2147E+00,
+	 0.2441E+00,0.2786E+00,0.3193E+00,0.3675E+00,0.4248E+00,0.4931E+00,
+	 0.5747E+00,0.6726E+00,0.7902E+00,0.9324E+00,0.1105E+01,0.1316E+01,
+	 0.1575E+01,0.1895E+01,0.2292E+01,0.2787E+01,0.3407E+01,0.4192E+01,
+	 0.5195E+01,0.6498E+01,0.8221E+01,0.1057E+02,0.1389E+02,0.1886E+02,
+	 0.2699E+02,0.4205E+02,0.7598E+02,0.1847E+03,0.5926E+03
-		/* water model */
-			0.4115E+00,0.4045E+00,0.3805E+00,0.3495E+00,0.3192E+00,0.2943E+00,
-			0.2768E+00,0.2659E+00,0.2592E+00,0.2538E+00,0.2479E+00,0.2411E+00,
-			0.2336E+00,0.2255E+00,0.2175E+00,0.2098E+00,0.2026E+00,0.1961E+00,
-			0.1903E+00,0.1854E+00,0.1812E+00,0.1778E+00,0.1752E+00,0.1734E+00,
-			0.1723E+00,0.1719E+00,0.1724E+00,0.1736E+00,0.1756E+00,0.1784E+00,
-			0.1820E+00,0.1866E+00,0.1920E+00,0.1985E+00,0.2061E+00,0.2149E+00,
-			0.2249E+00,0.2363E+00,0.2492E+00,0.2638E+00,0.2803E+00,0.2893E+00,
-			0.2988E+00,0.3195E+00,0.3428E+00,0.3688E+00,0.3979E+00,0.4306E+00,
-			0.4671E+00,0.5079E+00,0.5537E+00,0.6048E+00,0.6622E+00,0.7264E+00,
-			0.7985E+00,0.8794E+00,0.9701E+00,0.1072E+01,0.1186E+01,0.1315E+01,
-			0.1460E+01,0.1622E+01,0.1805E+01,0.2011E+01,0.2242E+01,0.2503E+01,
-			0.2796E+01,0.3125E+01,0.3496E+01,0.3913E+01,0.4383E+01,0.4912E+01,
-			0.5510E+01,0.6185E+01,0.6951E+01,0.7825E+01,0.8828E+01,0.9991E+01,
-			0.1136E+02,0.1297E+02,0.1491E+02,0.1711E+02,0.1834E+02
-			0.3918E+00,0.3859E+00,0.3654E+00,0.3384E+00,0.3117E+00,0.2895E+00,
-			0.2736E+00,0.2635E+00,0.2571E+00,0.2522E+00,0.2470E+00,0.2411E+00,
-			0.2345E+00,0.2275E+00,0.2204E+00,0.2135E+00,0.2071E+00,0.2012E+00,
-			0.1959E+00,0.1914E+00,0.1875E+00,0.1844E+00,0.1820E+00,0.1804E+00,
-			0.1794E+00,0.1792E+00,0.1797E+00,0.1810E+00,0.1831E+00,0.1860E+00,
-			0.1898E+00,0.1945E+00,0.2001E+00,0.2068E+00,0.2146E+00,0.2236E+00,
-			0.2339E+00,0.2456E+00,0.2589E+00,0.2739E+00,0.2909E+00,0.3001E+00,
-			0.3099E+00,0.3312E+00,0.3552E+00,0.3820E+00,0.4119E+00,0.4455E+00,
-			0.4830E+00,0.5249E+00,0.5718E+00,0.6243E+00,0.6829E+00,0.7486E+00,
-			0.8221E+00,0.9045E+00,0.9968E+00,0.1100E+01,0.1216E+01,0.1346E+01,
-			0.1492E+01,0.1655E+01,0.1839E+01,0.2045E+01,0.2275E+01,0.2534E+01,
-			0.2824E+01,0.3149E+01,0.3513E+01,0.3920E+01,0.4375E+01,0.4884E+01,
-			0.5454E+01,0.6092E+01,0.6807E+01,0.7611E+01,0.8516E+01,0.9543E+01,
-			0.1071E+02,0.1205E+02,0.1357E+02,0.1518E+02,0.1599E+02
-			0.3872E+00,0.3816E+00,0.3620E+00,0.3360E+00,0.3102E+00,0.2887E+00,
-			0.2732E+00,0.2633E+00,0.2571E+00,0.2522E+00,0.2471E+00,0.2414E+00,
-			0.2350E+00,0.2283E+00,0.2214E+00,0.2148E+00,0.2085E+00,0.2028E+00,
-			0.1976E+00,0.1932E+00,0.1894E+00,0.1864E+00,0.1840E+00,0.1824E+00,
-			0.1815E+00,0.1813E+00,0.1819E+00,0.1832E+00,0.1853E+00,0.1883E+00,
-			0.1920E+00,0.1968E+00,0.2024E+00,0.2092E+00,0.2170E+00,0.2261E+00,
-			0.2364E+00,0.2483E+00,0.2617E+00,0.2768E+00,0.2939E+00,0.3032E+00,
-			0.3131E+00,0.3346E+00,0.3587E+00,0.3857E+00,0.4159E+00,0.4497E+00,
-			0.4875E+00,0.5297E+00,0.5769E+00,0.6297E+00,0.6887E+00,0.7547E+00,
-			0.8286E+00,0.9114E+00,0.1004E+01,0.1108E+01,0.1224E+01,0.1354E+01,
-			0.1500E+01,0.1664E+01,0.1847E+01,0.2053E+01,0.2284E+01,0.2542E+01,
-			0.2831E+01,0.3154E+01,0.3515E+01,0.3919E+01,0.4370E+01,0.4874E+01,
-			0.5436E+01,0.6064E+01,0.6765E+01,0.7549E+01,0.8430E+01,0.9422E+01,
-			0.1054E+02,0.1182E+02,0.1324E+02,0.1472E+02,0.1544E+02
-			0.3737E+00,0.3687E+00,0.3509E+00,0.3269E+00,0.3030E+00,0.2830E+00,
-			0.2686E+00,0.2593E+00,0.2535E+00,0.2490E+00,0.2444E+00,0.2393E+00,
-			0.2335E+00,0.2273E+00,0.2210E+00,0.2148E+00,0.2089E+00,0.2036E+00,
-			0.1987E+00,0.1945E+00,0.1910E+00,0.1881E+00,0.1859E+00,0.1844E+00,
-			0.1836E+00,0.1835E+00,0.1842E+00,0.1855E+00,0.1877E+00,0.1907E+00,
-			0.1945E+00,0.1993E+00,0.2051E+00,0.2118E+00,0.2198E+00,0.2289E+00,
-			0.2394E+00,0.2513E+00,0.2649E+00,0.2802E+00,0.2974E+00,0.3068E+00,
-			0.3168E+00,0.3385E+00,0.3628E+00,0.3901E+00,0.4206E+00,0.4547E+00,
-			0.4928E+00,0.5353E+00,0.5829E+00,0.6361E+00,0.6955E+00,0.7620E+00,
-			0.8363E+00,0.9195E+00,0.1013E+01,0.1117E+01,0.1233E+01,0.1364E+01,
-			0.1510E+01,0.1674E+01,0.1858E+01,0.2063E+01,0.2293E+01,0.2550E+01,
-			0.2838E+01,0.3160E+01,0.3518E+01,0.3919E+01,0.4365E+01,0.4863E+01,
-			0.5416E+01,0.6033E+01,0.6719E+01,0.7483E+01,0.8337E+01,0.9292E+01,
-			0.1036E+02,0.1156E+02,0.1289E+02,0.1423E+02,0.1486E+02
-			0.3651E+00,0.3607E+00,0.3449E+00,0.3233E+00,0.3016E+00,0.2832E+00,
-			0.2697E+00,0.2609E+00,0.2552E+00,0.2509E+00,0.2465E+00,0.2418E+00,
-			0.2364E+00,0.2307E+00,0.2249E+00,0.2191E+00,0.2137E+00,0.2086E+00,
-			0.2041E+00,0.2001E+00,0.1968E+00,0.1940E+00,0.1919E+00,0.1905E+00,
-			0.1898E+00,0.1897E+00,0.1904E+00,0.1919E+00,0.1941E+00,0.1971E+00,
-			0.2011E+00,0.2059E+00,0.2118E+00,0.2187E+00,0.2267E+00,0.2361E+00,
-			0.2467E+00,0.2589E+00,0.2727E+00,0.2883E+00,0.3059E+00,0.3155E+00,
-			0.3257E+00,0.3478E+00,0.3726E+00,0.4004E+00,0.4315E+00,0.4662E+00,
-			0.5050E+00,0.5483E+00,0.5967E+00,0.6507E+00,0.7110E+00,0.7783E+00,
-			0.8536E+00,0.9376E+00,0.1032E+01,0.1137E+01,0.1254E+01,0.1385E+01,
-			0.1531E+01,0.1695E+01,0.1878E+01,0.2083E+01,0.2311E+01,0.2566E+01,
-			0.2850E+01,0.3166E+01,0.3518E+01,0.3910E+01,0.4344E+01,0.4825E+01,
-			0.5358E+01,0.5947E+01,0.6597E+01,0.7314E+01,0.8106E+01,0.8978E+01,
-			0.9939E+01,0.1099E+02,0.1211E+02,0.1319E+02,0.1367E+02
-			0.3540E+00,0.3501E+00,0.3360E+00,0.3166E+00,0.2969E+00,0.2801E+00,
-			0.2677E+00,0.2594E+00,0.2541E+00,0.2500E+00,0.2461E+00,0.2417E+00,
-			0.2369E+00,0.2317E+00,0.2263E+00,0.2211E+00,0.2160E+00,0.2113E+00,
-			0.2070E+00,0.2033E+00,0.2001E+00,0.1976E+00,0.1956E+00,0.1943E+00,
-			0.1937E+00,0.1937E+00,0.1945E+00,0.1960E+00,0.1982E+00,0.2013E+00,
-			0.2053E+00,0.2102E+00,0.2162E+00,0.2232E+00,0.2313E+00,0.2408E+00,
-			0.2516E+00,0.2639E+00,0.2779E+00,0.2937E+00,0.3115E+00,0.3213E+00,
-			0.3315E+00,0.3540E+00,0.3791E+00,0.4073E+00,0.4387E+00,0.4739E+00,
-			0.5131E+00,0.5569E+00,0.6057E+00,0.6603E+00,0.7211E+00,0.7890E+00,
-			0.8647E+00,0.9493E+00,0.1044E+01,0.1149E+01,0.1267E+01,0.1398E+01,
-			0.1545E+01,0.1708E+01,0.1891E+01,0.2095E+01,0.2322E+01,0.2575E+01,
-			0.2856E+01,0.3169E+01,0.3517E+01,0.3902E+01,0.4328E+01,0.4799E+01,
-			0.5318E+01,0.5890E+01,0.6519E+01,0.7208E+01,0.7963E+01,0.8788E+01,
-			0.9685E+01,0.1065E+02,0.1166E+02,0.1261E+02,0.1301E+02
-			0.3121E+00,0.3097E+00,0.3008E+00,0.2882E+00,0.2753E+00,0.2643E+00,
-			0.2562E+00,0.2509E+00,0.2473E+00,0.2445E+00,0.2417E+00,0.2384E+00,
-			0.2348E+00,0.2307E+00,0.2265E+00,0.2223E+00,0.2182E+00,0.2144E+00,
-			0.2109E+00,0.2078E+00,0.2052E+00,0.2030E+00,0.2014E+00,0.2004E+00,
-			0.2000E+00,0.2002E+00,0.2011E+00,0.2027E+00,0.2051E+00,0.2082E+00,
-			0.2123E+00,0.2173E+00,0.2232E+00,0.2303E+00,0.2386E+00,0.2482E+00,
-			0.2591E+00,0.2717E+00,0.2859E+00,0.3019E+00,0.3201E+00,0.3300E+00,
-			0.3404E+00,0.3633E+00,0.3889E+00,0.4176E+00,0.4496E+00,0.4854E+00,
-			0.5253E+00,0.5699E+00,0.6196E+00,0.6749E+00,0.7367E+00,0.8055E+00,
-			0.8822E+00,0.9677E+00,0.1063E+01,0.1169E+01,0.1288E+01,0.1419E+01,
-			0.1566E+01,0.1730E+01,0.1912E+01,0.2115E+01,0.2341E+01,0.2591E+01,
-			0.2869E+01,0.3177E+01,0.3518E+01,0.3895E+01,0.4309E+01,0.4765E+01,
-			0.5265E+01,0.5811E+01,0.6405E+01,0.7049E+01,0.7744E+01,0.8489E+01,
-			0.9280E+01,0.1010E+02,0.1093E+02,0.1165E+02,0.1192E+02
-			0.3070E+00,0.3061E+00,0.3027E+00,0.2975E+00,0.2918E+00,0.2865E+00,
-			0.2821E+00,0.2787E+00,0.2760E+00,0.2735E+00,0.2711E+00,0.2684E+00,
-			0.2656E+00,0.2626E+00,0.2594E+00,0.2562E+00,0.2530E+00,0.2500E+00,
-			0.2471E+00,0.2446E+00,0.2423E+00,0.2404E+00,0.2390E+00,0.2380E+00,
-			0.2375E+00,0.2377E+00,0.2385E+00,0.2400E+00,0.2422E+00,0.2453E+00,
-			0.2493E+00,0.2543E+00,0.2604E+00,0.2677E+00,0.2762E+00,0.2861E+00,
-			0.2976E+00,0.3108E+00,0.3258E+00,0.3428E+00,0.3620E+00,0.3725E+00,
-			0.3836E+00,0.4079E+00,0.4351E+00,0.4655E+00,0.4993E+00,0.5371E+00,
-			0.5791E+00,0.6258E+00,0.6776E+00,0.7351E+00,0.7988E+00,0.8694E+00,
-			0.9476E+00,0.1034E+01,0.1130E+01,0.1236E+01,0.1353E+01,0.1482E+01,
-			0.1625E+01,0.1783E+01,0.1957E+01,0.2148E+01,0.2359E+01,0.2590E+01,
-			0.2844E+01,0.3121E+01,0.3424E+01,0.3754E+01,0.4112E+01,0.4498E+01,
-			0.4913E+01,0.5356E+01,0.5826E+01,0.6320E+01,0.6833E+01,0.7358E+01,
-			0.7884E+01,0.8390E+01,0.8846E+01,0.9187E+01,0.9295E+01
-			0.3321E+00,0.3315E+00,0.3294E+00,0.3266E+00,0.3238E+00,0.3214E+00,
-			0.3192E+00,0.3169E+00,0.3142E+00,0.3111E+00,0.3075E+00,0.3036E+00,
-			0.2994E+00,0.2950E+00,0.2905E+00,0.2860E+00,0.2817E+00,0.2775E+00,
-			0.2735E+00,0.2698E+00,0.2665E+00,0.2635E+00,0.2609E+00,0.2587E+00,
-			0.2571E+00,0.2561E+00,0.2556E+00,0.2558E+00,0.2568E+00,0.2586E+00,
-			0.2613E+00,0.2650E+00,0.2697E+00,0.2756E+00,0.2827E+00,0.2913E+00,
-			0.3013E+00,0.3131E+00,0.3267E+00,0.3422E+00,0.3600E+00,0.3698E+00,
-			0.3802E+00,0.4030E+00,0.4287E+00,0.4575E+00,0.4899E+00,0.5261E+00,
-			0.5665E+00,0.6115E+00,0.6617E+00,0.7175E+00,0.7795E+00,0.8484E+00,
-			0.9248E+00,0.1010E+01,0.1103E+01,0.1208E+01,0.1323E+01,0.1451E+01,
-			0.1592E+01,0.1749E+01,0.1922E+01,0.2113E+01,0.2324E+01,0.2557E+01,
-			0.2813E+01,0.3095E+01,0.3403E+01,0.3740E+01,0.4106E+01,0.4502E+01,
-			0.4928E+01,0.5383E+01,0.5863E+01,0.6364E+01,0.6878E+01,0.7395E+01,
-			0.7898E+01,0.8366E+01,0.8764E+01,0.9041E+01,0.9119E+01
-			0.4248E+00,0.4242E+00,0.4221E+00,0.4189E+00,0.4153E+00,0.4116E+00,
-			0.4081E+00,0.4045E+00,0.4006E+00,0.3964E+00,0.3918E+00,0.3869E+00,
-			0.3818E+00,0.3764E+00,0.3709E+00,0.3654E+00,0.3600E+00,0.3547E+00,
-			0.3495E+00,0.3446E+00,0.3401E+00,0.3359E+00,0.3321E+00,0.3288E+00,
-			0.3260E+00,0.3239E+00,0.3224E+00,0.3218E+00,0.3219E+00,0.3230E+00,
-			0.3251E+00,0.3282E+00,0.3326E+00,0.3383E+00,0.3455E+00,0.3542E+00,
-			0.3646E+00,0.3768E+00,0.3911E+00,0.4075E+00,0.4263E+00,0.4366E+00,
-			0.4476E+00,0.4717E+00,0.4989E+00,0.5293E+00,0.5633E+00,0.6011E+00,
-			0.6431E+00,0.6896E+00,0.7410E+00,0.7977E+00,0.8603E+00,0.9291E+00,
-			0.1005E+01,0.1088E+01,0.1179E+01,0.1278E+01,0.1387E+01,0.1506E+01,
-			0.1636E+01,0.1778E+01,0.1933E+01,0.2100E+01,0.2283E+01,0.2480E+01,
-			0.2693E+01,0.2923E+01,0.3169E+01,0.3433E+01,0.3713E+01,0.4009E+01,
-			0.4319E+01,0.4642E+01,0.4973E+01,0.5308E+01,0.5640E+01,0.5962E+01,
-			0.6262E+01,0.6528E+01,0.6740E+01,0.6876E+01,0.6911E+01
+    /* water model */
+	    0.4115E+00,0.4045E+00,0.3805E+00,0.3495E+00,0.3192E+00,0.2943E+00,
+	    0.2768E+00,0.2659E+00,0.2592E+00,0.2538E+00,0.2479E+00,0.2411E+00,
+	    0.2336E+00,0.2255E+00,0.2175E+00,0.2098E+00,0.2026E+00,0.1961E+00,
+	    0.1903E+00,0.1854E+00,0.1812E+00,0.1778E+00,0.1752E+00,0.1734E+00,
+	    0.1723E+00,0.1719E+00,0.1724E+00,0.1736E+00,0.1756E+00,0.1784E+00,
+	    0.1820E+00,0.1866E+00,0.1920E+00,0.1985E+00,0.2061E+00,0.2149E+00,
+	    0.2249E+00,0.2363E+00,0.2492E+00,0.2638E+00,0.2803E+00,0.2893E+00,
+	    0.2988E+00,0.3195E+00,0.3428E+00,0.3688E+00,0.3979E+00,0.4306E+00,
+	    0.4671E+00,0.5079E+00,0.5537E+00,0.6048E+00,0.6622E+00,0.7264E+00,
+	    0.7985E+00,0.8794E+00,0.9701E+00,0.1072E+01,0.1186E+01,0.1315E+01,
+	    0.1460E+01,0.1622E+01,0.1805E+01,0.2011E+01,0.2242E+01,0.2503E+01,
+	    0.2796E+01,0.3125E+01,0.3496E+01,0.3913E+01,0.4383E+01,0.4912E+01,
+	    0.5510E+01,0.6185E+01,0.6951E+01,0.7825E+01,0.8828E+01,0.9991E+01,
+	    0.1136E+02,0.1297E+02,0.1491E+02,0.1711E+02,0.1834E+02
+	 0.3918E+00,0.3859E+00,0.3654E+00,0.3384E+00,0.3117E+00,0.2895E+00,
+	 0.2736E+00,0.2635E+00,0.2571E+00,0.2522E+00,0.2470E+00,0.2411E+00,
+	 0.2345E+00,0.2275E+00,0.2204E+00,0.2135E+00,0.2071E+00,0.2012E+00,
+	 0.1959E+00,0.1914E+00,0.1875E+00,0.1844E+00,0.1820E+00,0.1804E+00,
+	 0.1794E+00,0.1792E+00,0.1797E+00,0.1810E+00,0.1831E+00,0.1860E+00,
+	 0.1898E+00,0.1945E+00,0.2001E+00,0.2068E+00,0.2146E+00,0.2236E+00,
+	 0.2339E+00,0.2456E+00,0.2589E+00,0.2739E+00,0.2909E+00,0.3001E+00,
+	 0.3099E+00,0.3312E+00,0.3552E+00,0.3820E+00,0.4119E+00,0.4455E+00,
+	 0.4830E+00,0.5249E+00,0.5718E+00,0.6243E+00,0.6829E+00,0.7486E+00,
+	 0.8221E+00,0.9045E+00,0.9968E+00,0.1100E+01,0.1216E+01,0.1346E+01,
+	 0.1492E+01,0.1655E+01,0.1839E+01,0.2045E+01,0.2275E+01,0.2534E+01,
+	 0.2824E+01,0.3149E+01,0.3513E+01,0.3920E+01,0.4375E+01,0.4884E+01,
+	 0.5454E+01,0.6092E+01,0.6807E+01,0.7611E+01,0.8516E+01,0.9543E+01,
+	 0.1071E+02,0.1205E+02,0.1357E+02,0.1518E+02,0.1599E+02
+	 0.3872E+00,0.3816E+00,0.3620E+00,0.3360E+00,0.3102E+00,0.2887E+00,
+	 0.2732E+00,0.2633E+00,0.2571E+00,0.2522E+00,0.2471E+00,0.2414E+00,
+	 0.2350E+00,0.2283E+00,0.2214E+00,0.2148E+00,0.2085E+00,0.2028E+00,
+	 0.1976E+00,0.1932E+00,0.1894E+00,0.1864E+00,0.1840E+00,0.1824E+00,
+	 0.1815E+00,0.1813E+00,0.1819E+00,0.1832E+00,0.1853E+00,0.1883E+00,
+	 0.1920E+00,0.1968E+00,0.2024E+00,0.2092E+00,0.2170E+00,0.2261E+00,
+	 0.2364E+00,0.2483E+00,0.2617E+00,0.2768E+00,0.2939E+00,0.3032E+00,
+	 0.3131E+00,0.3346E+00,0.3587E+00,0.3857E+00,0.4159E+00,0.4497E+00,
+	 0.4875E+00,0.5297E+00,0.5769E+00,0.6297E+00,0.6887E+00,0.7547E+00,
+	 0.8286E+00,0.9114E+00,0.1004E+01,0.1108E+01,0.1224E+01,0.1354E+01,
+	 0.1500E+01,0.1664E+01,0.1847E+01,0.2053E+01,0.2284E+01,0.2542E+01,
+	 0.2831E+01,0.3154E+01,0.3515E+01,0.3919E+01,0.4370E+01,0.4874E+01,
+	 0.5436E+01,0.6064E+01,0.6765E+01,0.7549E+01,0.8430E+01,0.9422E+01,
+	 0.1054E+02,0.1182E+02,0.1324E+02,0.1472E+02,0.1544E+02
+	 0.3737E+00,0.3687E+00,0.3509E+00,0.3269E+00,0.3030E+00,0.2830E+00,
+	 0.2686E+00,0.2593E+00,0.2535E+00,0.2490E+00,0.2444E+00,0.2393E+00,
+	 0.2335E+00,0.2273E+00,0.2210E+00,0.2148E+00,0.2089E+00,0.2036E+00,
+	 0.1987E+00,0.1945E+00,0.1910E+00,0.1881E+00,0.1859E+00,0.1844E+00,
+	 0.1836E+00,0.1835E+00,0.1842E+00,0.1855E+00,0.1877E+00,0.1907E+00,
+	 0.1945E+00,0.1993E+00,0.2051E+00,0.2118E+00,0.2198E+00,0.2289E+00,
+	 0.2394E+00,0.2513E+00,0.2649E+00,0.2802E+00,0.2974E+00,0.3068E+00,
+	 0.3168E+00,0.3385E+00,0.3628E+00,0.3901E+00,0.4206E+00,0.4547E+00,
+	 0.4928E+00,0.5353E+00,0.5829E+00,0.6361E+00,0.6955E+00,0.7620E+00,
+	 0.8363E+00,0.9195E+00,0.1013E+01,0.1117E+01,0.1233E+01,0.1364E+01,
+	 0.1510E+01,0.1674E+01,0.1858E+01,0.2063E+01,0.2293E+01,0.2550E+01,
+	 0.2838E+01,0.3160E+01,0.3518E+01,0.3919E+01,0.4365E+01,0.4863E+01,
+	 0.5416E+01,0.6033E+01,0.6719E+01,0.7483E+01,0.8337E+01,0.9292E+01,
+	 0.1036E+02,0.1156E+02,0.1289E+02,0.1423E+02,0.1486E+02
+	 0.3651E+00,0.3607E+00,0.3449E+00,0.3233E+00,0.3016E+00,0.2832E+00,
+	 0.2697E+00,0.2609E+00,0.2552E+00,0.2509E+00,0.2465E+00,0.2418E+00,
+	 0.2364E+00,0.2307E+00,0.2249E+00,0.2191E+00,0.2137E+00,0.2086E+00,
+	 0.2041E+00,0.2001E+00,0.1968E+00,0.1940E+00,0.1919E+00,0.1905E+00,
+	 0.1898E+00,0.1897E+00,0.1904E+00,0.1919E+00,0.1941E+00,0.1971E+00,
+	 0.2011E+00,0.2059E+00,0.2118E+00,0.2187E+00,0.2267E+00,0.2361E+00,
+	 0.2467E+00,0.2589E+00,0.2727E+00,0.2883E+00,0.3059E+00,0.3155E+00,
+	 0.3257E+00,0.3478E+00,0.3726E+00,0.4004E+00,0.4315E+00,0.4662E+00,
+	 0.5050E+00,0.5483E+00,0.5967E+00,0.6507E+00,0.7110E+00,0.7783E+00,
+	 0.8536E+00,0.9376E+00,0.1032E+01,0.1137E+01,0.1254E+01,0.1385E+01,
+	 0.1531E+01,0.1695E+01,0.1878E+01,0.2083E+01,0.2311E+01,0.2566E+01,
+	 0.2850E+01,0.3166E+01,0.3518E+01,0.3910E+01,0.4344E+01,0.4825E+01,
+	 0.5358E+01,0.5947E+01,0.6597E+01,0.7314E+01,0.8106E+01,0.8978E+01,
+	 0.9939E+01,0.1099E+02,0.1211E+02,0.1319E+02,0.1367E+02
+	 0.3540E+00,0.3501E+00,0.3360E+00,0.3166E+00,0.2969E+00,0.2801E+00,
+	 0.2677E+00,0.2594E+00,0.2541E+00,0.2500E+00,0.2461E+00,0.2417E+00,
+	 0.2369E+00,0.2317E+00,0.2263E+00,0.2211E+00,0.2160E+00,0.2113E+00,
+	 0.2070E+00,0.2033E+00,0.2001E+00,0.1976E+00,0.1956E+00,0.1943E+00,
+	 0.1937E+00,0.1937E+00,0.1945E+00,0.1960E+00,0.1982E+00,0.2013E+00,
+	 0.2053E+00,0.2102E+00,0.2162E+00,0.2232E+00,0.2313E+00,0.2408E+00,
+	 0.2516E+00,0.2639E+00,0.2779E+00,0.2937E+00,0.3115E+00,0.3213E+00,
+	 0.3315E+00,0.3540E+00,0.3791E+00,0.4073E+00,0.4387E+00,0.4739E+00,
+	 0.5131E+00,0.5569E+00,0.6057E+00,0.6603E+00,0.7211E+00,0.7890E+00,
+	 0.8647E+00,0.9493E+00,0.1044E+01,0.1149E+01,0.1267E+01,0.1398E+01,
+	 0.1545E+01,0.1708E+01,0.1891E+01,0.2095E+01,0.2322E+01,0.2575E+01,
+	 0.2856E+01,0.3169E+01,0.3517E+01,0.3902E+01,0.4328E+01,0.4799E+01,
+	 0.5318E+01,0.5890E+01,0.6519E+01,0.7208E+01,0.7963E+01,0.8788E+01,
+	 0.9685E+01,0.1065E+02,0.1166E+02,0.1261E+02,0.1301E+02
+	 0.3121E+00,0.3097E+00,0.3008E+00,0.2882E+00,0.2753E+00,0.2643E+00,
+	 0.2562E+00,0.2509E+00,0.2473E+00,0.2445E+00,0.2417E+00,0.2384E+00,
+	 0.2348E+00,0.2307E+00,0.2265E+00,0.2223E+00,0.2182E+00,0.2144E+00,
+	 0.2109E+00,0.2078E+00,0.2052E+00,0.2030E+00,0.2014E+00,0.2004E+00,
+	 0.2000E+00,0.2002E+00,0.2011E+00,0.2027E+00,0.2051E+00,0.2082E+00,
+	 0.2123E+00,0.2173E+00,0.2232E+00,0.2303E+00,0.2386E+00,0.2482E+00,
+	 0.2591E+00,0.2717E+00,0.2859E+00,0.3019E+00,0.3201E+00,0.3300E+00,
+	 0.3404E+00,0.3633E+00,0.3889E+00,0.4176E+00,0.4496E+00,0.4854E+00,
+	 0.5253E+00,0.5699E+00,0.6196E+00,0.6749E+00,0.7367E+00,0.8055E+00,
+	 0.8822E+00,0.9677E+00,0.1063E+01,0.1169E+01,0.1288E+01,0.1419E+01,
+	 0.1566E+01,0.1730E+01,0.1912E+01,0.2115E+01,0.2341E+01,0.2591E+01,
+	 0.2869E+01,0.3177E+01,0.3518E+01,0.3895E+01,0.4309E+01,0.4765E+01,
+	 0.5265E+01,0.5811E+01,0.6405E+01,0.7049E+01,0.7744E+01,0.8489E+01,
+	 0.9280E+01,0.1010E+02,0.1093E+02,0.1165E+02,0.1192E+02
+	 0.3070E+00,0.3061E+00,0.3027E+00,0.2975E+00,0.2918E+00,0.2865E+00,
+	 0.2821E+00,0.2787E+00,0.2760E+00,0.2735E+00,0.2711E+00,0.2684E+00,
+	 0.2656E+00,0.2626E+00,0.2594E+00,0.2562E+00,0.2530E+00,0.2500E+00,
+	 0.2471E+00,0.2446E+00,0.2423E+00,0.2404E+00,0.2390E+00,0.2380E+00,
+	 0.2375E+00,0.2377E+00,0.2385E+00,0.2400E+00,0.2422E+00,0.2453E+00,
+	 0.2493E+00,0.2543E+00,0.2604E+00,0.2677E+00,0.2762E+00,0.2861E+00,
+	 0.2976E+00,0.3108E+00,0.3258E+00,0.3428E+00,0.3620E+00,0.3725E+00,
+	 0.3836E+00,0.4079E+00,0.4351E+00,0.4655E+00,0.4993E+00,0.5371E+00,
+	 0.5791E+00,0.6258E+00,0.6776E+00,0.7351E+00,0.7988E+00,0.8694E+00,
+	 0.9476E+00,0.1034E+01,0.1130E+01,0.1236E+01,0.1353E+01,0.1482E+01,
+	 0.1625E+01,0.1783E+01,0.1957E+01,0.2148E+01,0.2359E+01,0.2590E+01,
+	 0.2844E+01,0.3121E+01,0.3424E+01,0.3754E+01,0.4112E+01,0.4498E+01,
+	 0.4913E+01,0.5356E+01,0.5826E+01,0.6320E+01,0.6833E+01,0.7358E+01,
+	 0.7884E+01,0.8390E+01,0.8846E+01,0.9187E+01,0.9295E+01
+	 0.3321E+00,0.3315E+00,0.3294E+00,0.3266E+00,0.3238E+00,0.3214E+00,
+	 0.3192E+00,0.3169E+00,0.3142E+00,0.3111E+00,0.3075E+00,0.3036E+00,
+	 0.2994E+00,0.2950E+00,0.2905E+00,0.2860E+00,0.2817E+00,0.2775E+00,
+	 0.2735E+00,0.2698E+00,0.2665E+00,0.2635E+00,0.2609E+00,0.2587E+00,
+	 0.2571E+00,0.2561E+00,0.2556E+00,0.2558E+00,0.2568E+00,0.2586E+00,
+	 0.2613E+00,0.2650E+00,0.2697E+00,0.2756E+00,0.2827E+00,0.2913E+00,
+	 0.3013E+00,0.3131E+00,0.3267E+00,0.3422E+00,0.3600E+00,0.3698E+00,
+	 0.3802E+00,0.4030E+00,0.4287E+00,0.4575E+00,0.4899E+00,0.5261E+00,
+	 0.5665E+00,0.6115E+00,0.6617E+00,0.7175E+00,0.7795E+00,0.8484E+00,
+	 0.9248E+00,0.1010E+01,0.1103E+01,0.1208E+01,0.1323E+01,0.1451E+01,
+	 0.1592E+01,0.1749E+01,0.1922E+01,0.2113E+01,0.2324E+01,0.2557E+01,
+	 0.2813E+01,0.3095E+01,0.3403E+01,0.3740E+01,0.4106E+01,0.4502E+01,
+	 0.4928E+01,0.5383E+01,0.5863E+01,0.6364E+01,0.6878E+01,0.7395E+01,
+	 0.7898E+01,0.8366E+01,0.8764E+01,0.9041E+01,0.9119E+01
+	 0.4248E+00,0.4242E+00,0.4221E+00,0.4189E+00,0.4153E+00,0.4116E+00,
+	 0.4081E+00,0.4045E+00,0.4006E+00,0.3964E+00,0.3918E+00,0.3869E+00,
+	 0.3818E+00,0.3764E+00,0.3709E+00,0.3654E+00,0.3600E+00,0.3547E+00,
+	 0.3495E+00,0.3446E+00,0.3401E+00,0.3359E+00,0.3321E+00,0.3288E+00,
+	 0.3260E+00,0.3239E+00,0.3224E+00,0.3218E+00,0.3219E+00,0.3230E+00,
+	 0.3251E+00,0.3282E+00,0.3326E+00,0.3383E+00,0.3455E+00,0.3542E+00,
+	 0.3646E+00,0.3768E+00,0.3911E+00,0.4075E+00,0.4263E+00,0.4366E+00,
+	 0.4476E+00,0.4717E+00,0.4989E+00,0.5293E+00,0.5633E+00,0.6011E+00,
+	 0.6431E+00,0.6896E+00,0.7410E+00,0.7977E+00,0.8603E+00,0.9291E+00,
+	 0.1005E+01,0.1088E+01,0.1179E+01,0.1278E+01,0.1387E+01,0.1506E+01,
+	 0.1636E+01,0.1778E+01,0.1933E+01,0.2100E+01,0.2283E+01,0.2480E+01,
+	 0.2693E+01,0.2923E+01,0.3169E+01,0.3433E+01,0.3713E+01,0.4009E+01,
+	 0.4319E+01,0.4642E+01,0.4973E+01,0.5308E+01,0.5640E+01,0.5962E+01,
+	 0.6262E+01,0.6528E+01,0.6740E+01,0.6876E+01,0.6911E+01
-		/* ocean model */
-			0.7855E+00,0.6283E+00,0.5465E+00,0.4693E+00,0.4153E+00,0.3917E+00,
-			0.3657E+00,0.3378E+00,0.3161E+00,0.3025E+00,0.2972E+00,0.2990E+00,
-			0.3055E+00,0.3118E+00,0.3059E+00,0.2715E+00,0.2118E+00,0.1585E+00,
-			0.1230E+00,0.9913E-01,0.8327E-01,0.7292E-01,0.6585E-01,0.6171E-01,
-			0.5883E-01,0.5780E-01,0.5791E-01,0.5893E-01,0.6144E-01,0.6406E-01,
-			0.6717E-01,0.6966E-01,0.7130E-01,0.7291E-01,0.7434E-01,0.7626E-01,
-			0.7847E-01,0.8190E-01,0.8583E-01,0.9044E-01,0.9709E-01,0.1006E+00,
-			0.1045E+00,0.1128E+00,0.1239E+00,0.1360E+00,0.1497E+00,0.1667E+00,
-			0.1856E+00,0.2070E+00,0.2323E+00,0.2615E+00,0.2948E+00,0.3326E+00,
-			0.3772E+00,0.4263E+00,0.4840E+00,0.5492E+00,0.6242E+00,0.7103E+00,
-			0.8075E+00,0.9192E+00,0.1046E+01,0.1190E+01,0.1354E+01,0.1541E+01,
-			0.1756E+01,0.2002E+01,0.2277E+01,0.2603E+01,0.2976E+01,0.3416E+01,
-			0.3931E+01,0.4563E+01,0.5372E+01,0.6490E+01,0.8191E+01,0.1111E+02,
-			0.1692E+02,0.3097E+02,0.7524E+02,0.2992E+03,0.1697E+04
-			0.7129E+00,0.5739E+00,0.5059E+00,0.4429E+00,0.4035E+00,0.3898E+00,
-			0.3678E+00,0.3416E+00,0.3195E+00,0.3042E+00,0.2975E+00,0.2961E+00,
-			0.2987E+00,0.2994E+00,0.2909E+00,0.2614E+00,0.2134E+00,0.1670E+00,
-			0.1336E+00,0.1100E+00,0.9363E-01,0.8252E-01,0.7480E-01,0.6967E-01,
-			0.6621E-01,0.6499E-01,0.6438E-01,0.6506E-01,0.6656E-01,0.6880E-01,
-			0.7108E-01,0.7332E-01,0.7497E-01,0.7681E-01,0.7860E-01,0.8093E-01,
-			0.8357E-01,0.8723E-01,0.9184E-01,0.9665E-01,0.1036E+00,0.1075E+00,
-			0.1112E+00,0.1200E+00,0.1316E+00,0.1436E+00,0.1580E+00,0.1748E+00,
-			0.1937E+00,0.2154E+00,0.2413E+00,0.2704E+00,0.3031E+00,0.3421E+00,
-			0.3856E+00,0.4356E+00,0.4928E+00,0.5586E+00,0.6333E+00,0.7196E+00,
-			0.8188E+00,0.9313E+00,0.1060E+01,0.1208E+01,0.1375E+01,0.1568E+01,
-			0.1791E+01,0.2047E+01,0.2340E+01,0.2679E+01,0.3075E+01,0.3547E+01,
-			0.4107E+01,0.4805E+01,0.5714E+01,0.6981E+01,0.8889E+01,0.1212E+02,
-			0.1839E+02,0.3283E+02,0.7515E+02,0.2626E+03,0.1134E+04
-			0.6966E+00,0.5607E+00,0.4902E+00,0.4336E+00,0.3978E+00,0.3866E+00,
-			0.3674E+00,0.3412E+00,0.3187E+00,0.3039E+00,0.2960E+00,0.2945E+00,
-			0.2960E+00,0.2961E+00,0.2874E+00,0.2591E+00,0.2133E+00,0.1692E+00,
-			0.1362E+00,0.1129E+00,0.9630E-01,0.8484E-01,0.7707E-01,0.7190E-01,
-			0.6854E-01,0.6653E-01,0.6597E-01,0.6668E-01,0.6812E-01,0.7009E-01,
-			0.7216E-01,0.7425E-01,0.7580E-01,0.7758E-01,0.7959E-01,0.8174E-01,
-			0.8490E-01,0.8852E-01,0.9294E-01,0.9864E-01,0.1048E+00,0.1084E+00,
-			0.1128E+00,0.1220E+00,0.1325E+00,0.1453E+00,0.1596E+00,0.1762E+00,
-			0.1959E+00,0.2177E+00,0.2428E+00,0.2725E+00,0.3055E+00,0.3440E+00,
-			0.3882E+00,0.4382E+00,0.4953E+00,0.5613E+00,0.6365E+00,0.7225E+00,
-			0.8218E+00,0.9344E+00,0.1065E+01,0.1212E+01,0.1381E+01,0.1577E+01,
-			0.1801E+01,0.2059E+01,0.2360E+01,0.2701E+01,0.3107E+01,0.3586E+01,
-			0.4166E+01,0.4885E+01,0.5821E+01,0.7115E+01,0.9088E+01,0.1241E+02,
-			0.1877E+02,0.3323E+02,0.7480E+02,0.2523E+03,0.1018E+04
-			0.6774E+00,0.5476E+00,0.4775E+00,0.4252E+00,0.3937E+00,0.3855E+00,
-			0.3684E+00,0.3432E+00,0.3209E+00,0.3059E+00,0.2974E+00,0.2950E+00,
-			0.2951E+00,0.2935E+00,0.2832E+00,0.2550E+00,0.2114E+00,0.1697E+00,
-			0.1380E+00,0.1153E+00,0.9882E-01,0.8737E-01,0.7952E-01,0.7423E-01,
-			0.7074E-01,0.6859E-01,0.6788E-01,0.6842E-01,0.6969E-01,0.7150E-01,
-			0.7349E-01,0.7557E-01,0.7720E-01,0.7911E-01,0.8125E-01,0.8356E-01,
-			0.8685E-01,0.9062E-01,0.9516E-01,0.1010E+00,0.1073E+00,0.1109E+00,
-			0.1154E+00,0.1247E+00,0.1352E+00,0.1482E+00,0.1626E+00,0.1793E+00,
-			0.1991E+00,0.2210E+00,0.2462E+00,0.2760E+00,0.3091E+00,0.3477E+00,
-			0.3920E+00,0.4422E+00,0.4994E+00,0.5656E+00,0.6410E+00,0.7275E+00,
-			0.8272E+00,0.9405E+00,0.1071E+01,0.1220E+01,0.1391E+01,0.1588E+01,
-			0.1815E+01,0.2077E+01,0.2382E+01,0.2731E+01,0.3145E+01,0.3636E+01,
-			0.4233E+01,0.4974E+01,0.5942E+01,0.7282E+01,0.9319E+01,0.1273E+02,
-			0.1919E+02,0.3364E+02,0.7414E+02,0.2397E+03,0.8914E+03
-			0.6153E+00,0.5058E+00,0.4382E+00,0.3950E+00,0.3738E+00,0.3731E+00,
-			0.3585E+00,0.3354E+00,0.3139E+00,0.2983E+00,0.2892E+00,0.2849E+00,
-			0.2832E+00,0.2800E+00,0.2703E+00,0.2469E+00,0.2112E+00,0.1741E+00,
-			0.1442E+00,0.1219E+00,0.1054E+00,0.9356E-01,0.8531E-01,0.7966E-01,
-			0.7561E-01,0.7323E-01,0.7198E-01,0.7214E-01,0.7291E-01,0.7415E-01,
-			0.7601E-01,0.7747E-01,0.7901E-01,0.8091E-01,0.8293E-01,0.8564E-01,
-			0.8906E-01,0.9289E-01,0.9788E-01,0.1033E+00,0.1102E+00,0.1141E+00,
-			0.1181E+00,0.1275E+00,0.1385E+00,0.1511E+00,0.1660E+00,0.1823E+00,
-			0.2018E+00,0.2241E+00,0.2491E+00,0.2784E+00,0.3123E+00,0.3503E+00,
-			0.3942E+00,0.4451E+00,0.5020E+00,0.5684E+00,0.6448E+00,0.7319E+00,
-			0.8325E+00,0.9481E+00,0.1081E+01,0.1234E+01,0.1409E+01,0.1612E+01,
-			0.1846E+01,0.2118E+01,0.2440E+01,0.2809E+01,0.3249E+01,0.3773E+01,
-			0.4413E+01,0.5211E+01,0.6259E+01,0.7710E+01,0.9888E+01,0.1347E+02,
-			0.2009E+02,0.3435E+02,0.7217E+02,0.2130E+03,0.6728E+03
-			0.5916E+00,0.4877E+00,0.4171E+00,0.3786E+00,0.3632E+00,0.3654E+00,
-			0.3546E+00,0.3335E+00,0.3124E+00,0.2967E+00,0.2869E+00,0.2822E+00,
-			0.2792E+00,0.2744E+00,0.2635E+00,0.2413E+00,0.2085E+00,0.1740E+00,
-			0.1459E+00,0.1244E+00,0.1084E+00,0.9682E-01,0.8822E-01,0.8243E-01,
-			0.7835E-01,0.7606E-01,0.7463E-01,0.7441E-01,0.7473E-01,0.7609E-01,
-			0.7739E-01,0.7905E-01,0.8078E-01,0.8256E-01,0.8474E-01,0.8745E-01,
-			0.9082E-01,0.9490E-01,0.9996E-01,0.1057E+00,0.1127E+00,0.1166E+00,
-			0.1207E+00,0.1301E+00,0.1412E+00,0.1539E+00,0.1686E+00,0.1858E+00,
-			0.2048E+00,0.2270E+00,0.2528E+00,0.2818E+00,0.3154E+00,0.3545E+00,
-			0.3980E+00,0.4487E+00,0.5067E+00,0.5728E+00,0.6491E+00,0.7374E+00,
-			0.8386E+00,0.9547E+00,0.1090E+01,0.1244E+01,0.1423E+01,0.1630E+01,
-			0.1870E+01,0.2149E+01,0.2477E+01,0.2862E+01,0.3316E+01,0.3862E+01,
-			0.4527E+01,0.5365E+01,0.6458E+01,0.7974E+01,0.1023E+02,0.1390E+02,
-			0.2058E+02,0.3459E+02,0.7042E+02,0.1961E+03,0.5608E+03
-			0.5164E+00,0.4330E+00,0.3650E+00,0.3341E+00,0.3313E+00,0.3413E+00,
-			0.3356E+00,0.3182E+00,0.2998E+00,0.2844E+00,0.2744E+00,0.2677E+00,
-			0.2626E+00,0.2560E+00,0.2453E+00,0.2267E+00,0.2009E+00,0.1730E+00,
-			0.1485E+00,0.1291E+00,0.1141E+00,0.1028E+00,0.9425E-01,0.8828E-01,
-			0.8375E-01,0.8105E-01,0.7927E-01,0.7843E-01,0.7860E-01,0.7925E-01,
-			0.8010E-01,0.8165E-01,0.8331E-01,0.8499E-01,0.8754E-01,0.9034E-01,
-			0.9390E-01,0.9825E-01,0.1034E+00,0.1093E+00,0.1164E+00,0.1203E+00,
-			0.1246E+00,0.1342E+00,0.1452E+00,0.1582E+00,0.1728E+00,0.1896E+00,
-			0.2094E+00,0.2310E+00,0.2569E+00,0.2863E+00,0.3195E+00,0.3587E+00,
-			0.4030E+00,0.4534E+00,0.5122E+00,0.5794E+00,0.6565E+00,0.7463E+00,
-			0.8505E+00,0.9697E+00,0.1109E+01,0.1270E+01,0.1457E+01,0.1674E+01,
-			0.1929E+01,0.2226E+01,0.2578E+01,0.2997E+01,0.3495E+01,0.4096E+01,
-			0.4831E+01,0.5758E+01,0.6967E+01,0.8629E+01,0.1105E+02,0.1487E+02,
-			0.2152E+02,0.3465E+02,0.6548E+02,0.1595E+03,0.3700E+03
-			0.3257E+00,0.2888E+00,0.2378E+00,0.2215E+00,0.2345E+00,0.2532E+00,
-			0.2578E+00,0.2504E+00,0.2390E+00,0.2282E+00,0.2194E+00,0.2123E+00,
-			0.2059E+00,0.1991E+00,0.1906E+00,0.1797E+00,0.1665E+00,0.1520E+00,
-			0.1379E+00,0.1254E+00,0.1147E+00,0.1061E+00,0.9917E-01,0.9373E-01,
-			0.8960E-01,0.8656E-01,0.8438E-01,0.8306E-01,0.8243E-01,0.8240E-01,
-			0.8294E-01,0.8394E-01,0.8543E-01,0.8740E-01,0.8990E-01,0.9302E-01,
-			0.9681E-01,0.1013E+00,0.1067E+00,0.1129E+00,0.1200E+00,0.1240E+00,
-			0.1283E+00,0.1379E+00,0.1490E+00,0.1618E+00,0.1764E+00,0.1932E+00,
-			0.2124E+00,0.2345E+00,0.2599E+00,0.2892E+00,0.3231E+00,0.3622E+00,
-			0.4072E+00,0.4593E+00,0.5195E+00,0.5895E+00,0.6711E+00,0.7664E+00,
-			0.8781E+00,0.1009E+01,0.1163E+01,0.1343E+01,0.1556E+01,0.1808E+01,
-			0.2107E+01,0.2464E+01,0.2891E+01,0.3405E+01,0.4025E+01,0.4779E+01,
-			0.5707E+01,0.6863E+01,0.8338E+01,0.1027E+02,0.1291E+02,0.1670E+02,
-			0.2248E+02,0.3211E+02,0.5001E+02,0.8772E+02,0.1334E+03
-			0.2139E+00,0.1949E+00,0.1618E+00,0.1541E+00,0.1685E+00,0.1828E+00,
-			0.1856E+00,0.1800E+00,0.1718E+00,0.1642E+00,0.1581E+00,0.1534E+00,
-			0.1495E+00,0.1460E+00,0.1421E+00,0.1375E+00,0.1318E+00,0.1252E+00,
-			0.1178E+00,0.1105E+00,0.1036E+00,0.9754E-01,0.9237E-01,0.8811E-01,
-			0.8468E-01,0.8198E-01,0.7994E-01,0.7852E-01,0.7768E-01,0.7741E-01,
-			0.7767E-01,0.7843E-01,0.7969E-01,0.8144E-01,0.8373E-01,0.8662E-01,
-			0.9014E-01,0.9438E-01,0.9939E-01,0.1052E+00,0.1120E+00,0.1158E+00,
-			0.1198E+00,0.1289E+00,0.1394E+00,0.1514E+00,0.1653E+00,0.1813E+00,
-			0.1997E+00,0.2208E+00,0.2453E+00,0.2736E+00,0.3064E+00,0.3444E+00,
-			0.3886E+00,0.4400E+00,0.5000E+00,0.5703E+00,0.6528E+00,0.7502E+00,
-			0.8652E+00,0.1001E+01,0.1163E+01,0.1355E+01,0.1584E+01,0.1859E+01,
-			0.2188E+01,0.2586E+01,0.3067E+01,0.3649E+01,0.4358E+01,0.5222E+01,
-			0.6282E+01,0.7594E+01,0.9235E+01,0.1132E+02,0.1404E+02,0.1768E+02,
-			0.2278E+02,0.3033E+02,0.4233E+02,0.6237E+02,0.7953E+02
-			0.2110E+00,0.2025E+00,0.1832E+00,0.1730E+00,0.1773E+00,0.1912E+00,
-			0.2055E+00,0.2138E+00,0.2152E+00,0.2113E+00,0.2040E+00,0.1946E+00,
-			0.1842E+00,0.1734E+00,0.1627E+00,0.1524E+00,0.1429E+00,0.1344E+00,
-			0.1268E+00,0.1203E+00,0.1149E+00,0.1104E+00,0.1068E+00,0.1040E+00,
-			0.1019E+00,0.1006E+00,0.9982E-01,0.9972E-01,0.1003E+00,0.1014E+00,
-			0.1031E+00,0.1054E+00,0.1084E+00,0.1119E+00,0.1162E+00,0.1212E+00,
-			0.1271E+00,0.1338E+00,0.1415E+00,0.1503E+00,0.1603E+00,0.1658E+00,
-			0.1717E+00,0.1847E+00,0.1995E+00,0.2163E+00,0.2354E+00,0.2571E+00,
-			0.2818E+00,0.3100E+00,0.3422E+00,0.3792E+00,0.4216E+00,0.4702E+00,
-			0.5261E+00,0.5903E+00,0.6644E+00,0.7500E+00,0.8493E+00,0.9645E+00,
-			0.1098E+01,0.1254E+01,0.1436E+01,0.1649E+01,0.1897E+01,0.2189E+01,
-			0.2531E+01,0.2934E+01,0.3408E+01,0.3968E+01,0.4630E+01,0.5415E+01,
-			0.6348E+01,0.7463E+01,0.8805E+01,0.1044E+02,0.1244E+02,0.1495E+02,
-			0.1816E+02,0.2237E+02,0.2799E+02,0.3517E+02,0.3934E+02
+    /* ocean model */
+	    0.7855E+00,0.6283E+00,0.5465E+00,0.4693E+00,0.4153E+00,0.3917E+00,
+	    0.3657E+00,0.3378E+00,0.3161E+00,0.3025E+00,0.2972E+00,0.2990E+00,
+	    0.3055E+00,0.3118E+00,0.3059E+00,0.2715E+00,0.2118E+00,0.1585E+00,
+	    0.1230E+00,0.9913E-01,0.8327E-01,0.7292E-01,0.6585E-01,0.6171E-01,
+	    0.5883E-01,0.5780E-01,0.5791E-01,0.5893E-01,0.6144E-01,0.6406E-01,
+	    0.6717E-01,0.6966E-01,0.7130E-01,0.7291E-01,0.7434E-01,0.7626E-01,
+	    0.7847E-01,0.8190E-01,0.8583E-01,0.9044E-01,0.9709E-01,0.1006E+00,
+	    0.1045E+00,0.1128E+00,0.1239E+00,0.1360E+00,0.1497E+00,0.1667E+00,
+	    0.1856E+00,0.2070E+00,0.2323E+00,0.2615E+00,0.2948E+00,0.3326E+00,
+	    0.3772E+00,0.4263E+00,0.4840E+00,0.5492E+00,0.6242E+00,0.7103E+00,
+	    0.8075E+00,0.9192E+00,0.1046E+01,0.1190E+01,0.1354E+01,0.1541E+01,
+	    0.1756E+01,0.2002E+01,0.2277E+01,0.2603E+01,0.2976E+01,0.3416E+01,
+	    0.3931E+01,0.4563E+01,0.5372E+01,0.6490E+01,0.8191E+01,0.1111E+02,
+	    0.1692E+02,0.3097E+02,0.7524E+02,0.2992E+03,0.1697E+04
+	 0.7129E+00,0.5739E+00,0.5059E+00,0.4429E+00,0.4035E+00,0.3898E+00,
+	 0.3678E+00,0.3416E+00,0.3195E+00,0.3042E+00,0.2975E+00,0.2961E+00,
+	 0.2987E+00,0.2994E+00,0.2909E+00,0.2614E+00,0.2134E+00,0.1670E+00,
+	 0.1336E+00,0.1100E+00,0.9363E-01,0.8252E-01,0.7480E-01,0.6967E-01,
+	 0.6621E-01,0.6499E-01,0.6438E-01,0.6506E-01,0.6656E-01,0.6880E-01,
+	 0.7108E-01,0.7332E-01,0.7497E-01,0.7681E-01,0.7860E-01,0.8093E-01,
+	 0.8357E-01,0.8723E-01,0.9184E-01,0.9665E-01,0.1036E+00,0.1075E+00,
+	 0.1112E+00,0.1200E+00,0.1316E+00,0.1436E+00,0.1580E+00,0.1748E+00,
+	 0.1937E+00,0.2154E+00,0.2413E+00,0.2704E+00,0.3031E+00,0.3421E+00,
+	 0.3856E+00,0.4356E+00,0.4928E+00,0.5586E+00,0.6333E+00,0.7196E+00,
+	 0.8188E+00,0.9313E+00,0.1060E+01,0.1208E+01,0.1375E+01,0.1568E+01,
+	 0.1791E+01,0.2047E+01,0.2340E+01,0.2679E+01,0.3075E+01,0.3547E+01,
+	 0.4107E+01,0.4805E+01,0.5714E+01,0.6981E+01,0.8889E+01,0.1212E+02,
+	 0.1839E+02,0.3283E+02,0.7515E+02,0.2626E+03,0.1134E+04
+	 0.6966E+00,0.5607E+00,0.4902E+00,0.4336E+00,0.3978E+00,0.3866E+00,
+	 0.3674E+00,0.3412E+00,0.3187E+00,0.3039E+00,0.2960E+00,0.2945E+00,
+	 0.2960E+00,0.2961E+00,0.2874E+00,0.2591E+00,0.2133E+00,0.1692E+00,
+	 0.1362E+00,0.1129E+00,0.9630E-01,0.8484E-01,0.7707E-01,0.7190E-01,
+	 0.6854E-01,0.6653E-01,0.6597E-01,0.6668E-01,0.6812E-01,0.7009E-01,
+	 0.7216E-01,0.7425E-01,0.7580E-01,0.7758E-01,0.7959E-01,0.8174E-01,
+	 0.8490E-01,0.8852E-01,0.9294E-01,0.9864E-01,0.1048E+00,0.1084E+00,
+	 0.1128E+00,0.1220E+00,0.1325E+00,0.1453E+00,0.1596E+00,0.1762E+00,
+	 0.1959E+00,0.2177E+00,0.2428E+00,0.2725E+00,0.3055E+00,0.3440E+00,
+	 0.3882E+00,0.4382E+00,0.4953E+00,0.5613E+00,0.6365E+00,0.7225E+00,
+	 0.8218E+00,0.9344E+00,0.1065E+01,0.1212E+01,0.1381E+01,0.1577E+01,
+	 0.1801E+01,0.2059E+01,0.2360E+01,0.2701E+01,0.3107E+01,0.3586E+01,
+	 0.4166E+01,0.4885E+01,0.5821E+01,0.7115E+01,0.9088E+01,0.1241E+02,
+	 0.1877E+02,0.3323E+02,0.7480E+02,0.2523E+03,0.1018E+04
+	 0.6774E+00,0.5476E+00,0.4775E+00,0.4252E+00,0.3937E+00,0.3855E+00,
+	 0.3684E+00,0.3432E+00,0.3209E+00,0.3059E+00,0.2974E+00,0.2950E+00,
+	 0.2951E+00,0.2935E+00,0.2832E+00,0.2550E+00,0.2114E+00,0.1697E+00,
+	 0.1380E+00,0.1153E+00,0.9882E-01,0.8737E-01,0.7952E-01,0.7423E-01,
+	 0.7074E-01,0.6859E-01,0.6788E-01,0.6842E-01,0.6969E-01,0.7150E-01,
+	 0.7349E-01,0.7557E-01,0.7720E-01,0.7911E-01,0.8125E-01,0.8356E-01,
+	 0.8685E-01,0.9062E-01,0.9516E-01,0.1010E+00,0.1073E+00,0.1109E+00,
+	 0.1154E+00,0.1247E+00,0.1352E+00,0.1482E+00,0.1626E+00,0.1793E+00,
+	 0.1991E+00,0.2210E+00,0.2462E+00,0.2760E+00,0.3091E+00,0.3477E+00,
+	 0.3920E+00,0.4422E+00,0.4994E+00,0.5656E+00,0.6410E+00,0.7275E+00,
+	 0.8272E+00,0.9405E+00,0.1071E+01,0.1220E+01,0.1391E+01,0.1588E+01,
+	 0.1815E+01,0.2077E+01,0.2382E+01,0.2731E+01,0.3145E+01,0.3636E+01,
+	 0.4233E+01,0.4974E+01,0.5942E+01,0.7282E+01,0.9319E+01,0.1273E+02,
+	 0.1919E+02,0.3364E+02,0.7414E+02,0.2397E+03,0.8914E+03
+	 0.6153E+00,0.5058E+00,0.4382E+00,0.3950E+00,0.3738E+00,0.3731E+00,
+	 0.3585E+00,0.3354E+00,0.3139E+00,0.2983E+00,0.2892E+00,0.2849E+00,
+	 0.2832E+00,0.2800E+00,0.2703E+00,0.2469E+00,0.2112E+00,0.1741E+00,
+	 0.1442E+00,0.1219E+00,0.1054E+00,0.9356E-01,0.8531E-01,0.7966E-01,
+	 0.7561E-01,0.7323E-01,0.7198E-01,0.7214E-01,0.7291E-01,0.7415E-01,
+	 0.7601E-01,0.7747E-01,0.7901E-01,0.8091E-01,0.8293E-01,0.8564E-01,
+	 0.8906E-01,0.9289E-01,0.9788E-01,0.1033E+00,0.1102E+00,0.1141E+00,
+	 0.1181E+00,0.1275E+00,0.1385E+00,0.1511E+00,0.1660E+00,0.1823E+00,
+	 0.2018E+00,0.2241E+00,0.2491E+00,0.2784E+00,0.3123E+00,0.3503E+00,
+	 0.3942E+00,0.4451E+00,0.5020E+00,0.5684E+00,0.6448E+00,0.7319E+00,
+	 0.8325E+00,0.9481E+00,0.1081E+01,0.1234E+01,0.1409E+01,0.1612E+01,
+	 0.1846E+01,0.2118E+01,0.2440E+01,0.2809E+01,0.3249E+01,0.3773E+01,
+	 0.4413E+01,0.5211E+01,0.6259E+01,0.7710E+01,0.9888E+01,0.1347E+02,
+	 0.2009E+02,0.3435E+02,0.7217E+02,0.2130E+03,0.6728E+03
+	 0.5916E+00,0.4877E+00,0.4171E+00,0.3786E+00,0.3632E+00,0.3654E+00,
+	 0.3546E+00,0.3335E+00,0.3124E+00,0.2967E+00,0.2869E+00,0.2822E+00,
+	 0.2792E+00,0.2744E+00,0.2635E+00,0.2413E+00,0.2085E+00,0.1740E+00,
+	 0.1459E+00,0.1244E+00,0.1084E+00,0.9682E-01,0.8822E-01,0.8243E-01,
+	 0.7835E-01,0.7606E-01,0.7463E-01,0.7441E-01,0.7473E-01,0.7609E-01,
+	 0.7739E-01,0.7905E-01,0.8078E-01,0.8256E-01,0.8474E-01,0.8745E-01,
+	 0.9082E-01,0.9490E-01,0.9996E-01,0.1057E+00,0.1127E+00,0.1166E+00,
+	 0.1207E+00,0.1301E+00,0.1412E+00,0.1539E+00,0.1686E+00,0.1858E+00,
+	 0.2048E+00,0.2270E+00,0.2528E+00,0.2818E+00,0.3154E+00,0.3545E+00,
+	 0.3980E+00,0.4487E+00,0.5067E+00,0.5728E+00,0.6491E+00,0.7374E+00,
+	 0.8386E+00,0.9547E+00,0.1090E+01,0.1244E+01,0.1423E+01,0.1630E+01,
+	 0.1870E+01,0.2149E+01,0.2477E+01,0.2862E+01,0.3316E+01,0.3862E+01,
+	 0.4527E+01,0.5365E+01,0.6458E+01,0.7974E+01,0.1023E+02,0.1390E+02,
+	 0.2058E+02,0.3459E+02,0.7042E+02,0.1961E+03,0.5608E+03
+	 0.5164E+00,0.4330E+00,0.3650E+00,0.3341E+00,0.3313E+00,0.3413E+00,
+	 0.3356E+00,0.3182E+00,0.2998E+00,0.2844E+00,0.2744E+00,0.2677E+00,
+	 0.2626E+00,0.2560E+00,0.2453E+00,0.2267E+00,0.2009E+00,0.1730E+00,
+	 0.1485E+00,0.1291E+00,0.1141E+00,0.1028E+00,0.9425E-01,0.8828E-01,
+	 0.8375E-01,0.8105E-01,0.7927E-01,0.7843E-01,0.7860E-01,0.7925E-01,
+	 0.8010E-01,0.8165E-01,0.8331E-01,0.8499E-01,0.8754E-01,0.9034E-01,
+	 0.9390E-01,0.9825E-01,0.1034E+00,0.1093E+00,0.1164E+00,0.1203E+00,
+	 0.1246E+00,0.1342E+00,0.1452E+00,0.1582E+00,0.1728E+00,0.1896E+00,
+	 0.2094E+00,0.2310E+00,0.2569E+00,0.2863E+00,0.3195E+00,0.3587E+00,
+	 0.4030E+00,0.4534E+00,0.5122E+00,0.5794E+00,0.6565E+00,0.7463E+00,
+	 0.8505E+00,0.9697E+00,0.1109E+01,0.1270E+01,0.1457E+01,0.1674E+01,
+	 0.1929E+01,0.2226E+01,0.2578E+01,0.2997E+01,0.3495E+01,0.4096E+01,
+	 0.4831E+01,0.5758E+01,0.6967E+01,0.8629E+01,0.1105E+02,0.1487E+02,
+	 0.2152E+02,0.3465E+02,0.6548E+02,0.1595E+03,0.3700E+03
+	 0.3257E+00,0.2888E+00,0.2378E+00,0.2215E+00,0.2345E+00,0.2532E+00,
+	 0.2578E+00,0.2504E+00,0.2390E+00,0.2282E+00,0.2194E+00,0.2123E+00,
+	 0.2059E+00,0.1991E+00,0.1906E+00,0.1797E+00,0.1665E+00,0.1520E+00,
+	 0.1379E+00,0.1254E+00,0.1147E+00,0.1061E+00,0.9917E-01,0.9373E-01,
+	 0.8960E-01,0.8656E-01,0.8438E-01,0.8306E-01,0.8243E-01,0.8240E-01,
+	 0.8294E-01,0.8394E-01,0.8543E-01,0.8740E-01,0.8990E-01,0.9302E-01,
+	 0.9681E-01,0.1013E+00,0.1067E+00,0.1129E+00,0.1200E+00,0.1240E+00,
+	 0.1283E+00,0.1379E+00,0.1490E+00,0.1618E+00,0.1764E+00,0.1932E+00,
+	 0.2124E+00,0.2345E+00,0.2599E+00,0.2892E+00,0.3231E+00,0.3622E+00,
+	 0.4072E+00,0.4593E+00,0.5195E+00,0.5895E+00,0.6711E+00,0.7664E+00,
+	 0.8781E+00,0.1009E+01,0.1163E+01,0.1343E+01,0.1556E+01,0.1808E+01,
+	 0.2107E+01,0.2464E+01,0.2891E+01,0.3405E+01,0.4025E+01,0.4779E+01,
+	 0.5707E+01,0.6863E+01,0.8338E+01,0.1027E+02,0.1291E+02,0.1670E+02,
+	 0.2248E+02,0.3211E+02,0.5001E+02,0.8772E+02,0.1334E+03
+	 0.2139E+00,0.1949E+00,0.1618E+00,0.1541E+00,0.1685E+00,0.1828E+00,
+	 0.1856E+00,0.1800E+00,0.1718E+00,0.1642E+00,0.1581E+00,0.1534E+00,
+	 0.1495E+00,0.1460E+00,0.1421E+00,0.1375E+00,0.1318E+00,0.1252E+00,
+	 0.1178E+00,0.1105E+00,0.1036E+00,0.9754E-01,0.9237E-01,0.8811E-01,
+	 0.8468E-01,0.8198E-01,0.7994E-01,0.7852E-01,0.7768E-01,0.7741E-01,
+	 0.7767E-01,0.7843E-01,0.7969E-01,0.8144E-01,0.8373E-01,0.8662E-01,
+	 0.9014E-01,0.9438E-01,0.9939E-01,0.1052E+00,0.1120E+00,0.1158E+00,
+	 0.1198E+00,0.1289E+00,0.1394E+00,0.1514E+00,0.1653E+00,0.1813E+00,
+	 0.1997E+00,0.2208E+00,0.2453E+00,0.2736E+00,0.3064E+00,0.3444E+00,
+	 0.3886E+00,0.4400E+00,0.5000E+00,0.5703E+00,0.6528E+00,0.7502E+00,
+	 0.8652E+00,0.1001E+01,0.1163E+01,0.1355E+01,0.1584E+01,0.1859E+01,
+	 0.2188E+01,0.2586E+01,0.3067E+01,0.3649E+01,0.4358E+01,0.5222E+01,
+	 0.6282E+01,0.7594E+01,0.9235E+01,0.1132E+02,0.1404E+02,0.1768E+02,
+	 0.2278E+02,0.3033E+02,0.4233E+02,0.6237E+02,0.7953E+02
+	 0.2110E+00,0.2025E+00,0.1832E+00,0.1730E+00,0.1773E+00,0.1912E+00,
+	 0.2055E+00,0.2138E+00,0.2152E+00,0.2113E+00,0.2040E+00,0.1946E+00,
+	 0.1842E+00,0.1734E+00,0.1627E+00,0.1524E+00,0.1429E+00,0.1344E+00,
+	 0.1268E+00,0.1203E+00,0.1149E+00,0.1104E+00,0.1068E+00,0.1040E+00,
+	 0.1019E+00,0.1006E+00,0.9982E-01,0.9972E-01,0.1003E+00,0.1014E+00,
+	 0.1031E+00,0.1054E+00,0.1084E+00,0.1119E+00,0.1162E+00,0.1212E+00,
+	 0.1271E+00,0.1338E+00,0.1415E+00,0.1503E+00,0.1603E+00,0.1658E+00,
+	 0.1717E+00,0.1847E+00,0.1995E+00,0.2163E+00,0.2354E+00,0.2571E+00,
+	 0.2818E+00,0.3100E+00,0.3422E+00,0.3792E+00,0.4216E+00,0.4702E+00,
+	 0.5261E+00,0.5903E+00,0.6644E+00,0.7500E+00,0.8493E+00,0.9645E+00,
+	 0.1098E+01,0.1254E+01,0.1436E+01,0.1649E+01,0.1897E+01,0.2189E+01,
+	 0.2531E+01,0.2934E+01,0.3408E+01,0.3968E+01,0.4630E+01,0.5415E+01,
+	 0.6348E+01,0.7463E+01,0.8805E+01,0.1044E+02,0.1244E+02,0.1495E+02,
+	 0.1816E+02,0.2237E+02,0.2799E+02,0.3517E+02,0.3934E+02
-		/* soot model */
-			0.4897E+00,0.4896E+00,0.4890E+00,0.4881E+00,0.4867E+00,0.4849E+00,
-			0.4827E+00,0.4802E+00,0.4773E+00,0.4743E+00,0.4709E+00,0.4675E+00,
-			0.4638E+00,0.4601E+00,0.4563E+00,0.4526E+00,0.4489E+00,0.4453E+00,
-			0.4419E+00,0.4388E+00,0.4359E+00,0.4334E+00,0.4312E+00,0.4296E+00,
-			0.4285E+00,0.4281E+00,0.4283E+00,0.4293E+00,0.4312E+00,0.4341E+00,
-			0.4380E+00,0.4430E+00,0.4494E+00,0.4571E+00,0.4663E+00,0.4771E+00,
-			0.4896E+00,0.5041E+00,0.5206E+00,0.5392E+00,0.5603E+00,0.5717E+00,
-			0.5838E+00,0.6101E+00,0.6392E+00,0.6714E+00,0.7069E+00,0.7459E+00,
-			0.7886E+00,0.8352E+00,0.8860E+00,0.9411E+00,0.1001E+01,0.1065E+01,
-			0.1135E+01,0.1210E+01,0.1290E+01,0.1376E+01,0.1468E+01,0.1566E+01,
-			0.1670E+01,0.1781E+01,0.1897E+01,0.2019E+01,0.2148E+01,0.2282E+01,
-			0.2421E+01,0.2565E+01,0.2713E+01,0.2865E+01,0.3019E+01,0.3173E+01,
-			0.3327E+01,0.3479E+01,0.3625E+01,0.3765E+01,0.3894E+01,0.4011E+01,
-			0.4111E+01,0.4192E+01,0.4250E+01,0.4284E+01,0.4292E+01
-			0.5620E+00,0.5618E+00,0.5611E+00,0.5599E+00,0.5582E+00,0.5560E+00,
-			0.5533E+00,0.5502E+00,0.5467E+00,0.5428E+00,0.5387E+00,0.5342E+00,
-			0.5295E+00,0.5246E+00,0.5197E+00,0.5146E+00,0.5096E+00,0.5046E+00,
-			0.4998E+00,0.4951E+00,0.4907E+00,0.4866E+00,0.4829E+00,0.4797E+00,
-			0.4771E+00,0.4751E+00,0.4738E+00,0.4734E+00,0.4738E+00,0.4753E+00,
-			0.4779E+00,0.4817E+00,0.4868E+00,0.4934E+00,0.5016E+00,0.5114E+00,
-			0.5231E+00,0.5367E+00,0.5524E+00,0.5704E+00,0.5908E+00,0.6019E+00,
-			0.6137E+00,0.6393E+00,0.6678E+00,0.6993E+00,0.7340E+00,0.7720E+00,
-			0.8136E+00,0.8589E+00,0.9081E+00,0.9613E+00,0.1019E+01,0.1080E+01,
-			0.1147E+01,0.1218E+01,0.1293E+01,0.1373E+01,0.1459E+01,0.1549E+01,
-			0.1643E+01,0.1743E+01,0.1847E+01,0.1956E+01,0.2069E+01,0.2185E+01,
-			0.2305E+01,0.2428E+01,0.2553E+01,0.2679E+01,0.2806E+01,0.2931E+01,
-			0.3055E+01,0.3174E+01,0.3289E+01,0.3396E+01,0.3495E+01,0.3582E+01,
-			0.3656E+01,0.3716E+01,0.3758E+01,0.3782E+01,0.3788E+01
+    /* soot model */
+	    0.4897E+00,0.4896E+00,0.4890E+00,0.4881E+00,0.4867E+00,0.4849E+00,
+	    0.4827E+00,0.4802E+00,0.4773E+00,0.4743E+00,0.4709E+00,0.4675E+00,
+	    0.4638E+00,0.4601E+00,0.4563E+00,0.4526E+00,0.4489E+00,0.4453E+00,
+	    0.4419E+00,0.4388E+00,0.4359E+00,0.4334E+00,0.4312E+00,0.4296E+00,
+	    0.4285E+00,0.4281E+00,0.4283E+00,0.4293E+00,0.4312E+00,0.4341E+00,
+	    0.4380E+00,0.4430E+00,0.4494E+00,0.4571E+00,0.4663E+00,0.4771E+00,
+	    0.4896E+00,0.5041E+00,0.5206E+00,0.5392E+00,0.5603E+00,0.5717E+00,
+	    0.5838E+00,0.6101E+00,0.6392E+00,0.6714E+00,0.7069E+00,0.7459E+00,
+	    0.7886E+00,0.8352E+00,0.8860E+00,0.9411E+00,0.1001E+01,0.1065E+01,
+	    0.1135E+01,0.1210E+01,0.1290E+01,0.1376E+01,0.1468E+01,0.1566E+01,
+	    0.1670E+01,0.1781E+01,0.1897E+01,0.2019E+01,0.2148E+01,0.2282E+01,
+	    0.2421E+01,0.2565E+01,0.2713E+01,0.2865E+01,0.3019E+01,0.3173E+01,
+	    0.3327E+01,0.3479E+01,0.3625E+01,0.3765E+01,0.3894E+01,0.4011E+01,
+	    0.4111E+01,0.4192E+01,0.4250E+01,0.4284E+01,0.4292E+01
+	 0.5620E+00,0.5618E+00,0.5611E+00,0.5599E+00,0.5582E+00,0.5560E+00,
+	 0.5533E+00,0.5502E+00,0.5467E+00,0.5428E+00,0.5387E+00,0.5342E+00,
+	 0.5295E+00,0.5246E+00,0.5197E+00,0.5146E+00,0.5096E+00,0.5046E+00,
+	 0.4998E+00,0.4951E+00,0.4907E+00,0.4866E+00,0.4829E+00,0.4797E+00,
+	 0.4771E+00,0.4751E+00,0.4738E+00,0.4734E+00,0.4738E+00,0.4753E+00,
+	 0.4779E+00,0.4817E+00,0.4868E+00,0.4934E+00,0.5016E+00,0.5114E+00,
+	 0.5231E+00,0.5367E+00,0.5524E+00,0.5704E+00,0.5908E+00,0.6019E+00,
+	 0.6137E+00,0.6393E+00,0.6678E+00,0.6993E+00,0.7340E+00,0.7720E+00,
+	 0.8136E+00,0.8589E+00,0.9081E+00,0.9613E+00,0.1019E+01,0.1080E+01,
+	 0.1147E+01,0.1218E+01,0.1293E+01,0.1373E+01,0.1459E+01,0.1549E+01,
+	 0.1643E+01,0.1743E+01,0.1847E+01,0.1956E+01,0.2069E+01,0.2185E+01,
+	 0.2305E+01,0.2428E+01,0.2553E+01,0.2679E+01,0.2806E+01,0.2931E+01,
+	 0.3055E+01,0.3174E+01,0.3289E+01,0.3396E+01,0.3495E+01,0.3582E+01,
+	 0.3656E+01,0.3716E+01,0.3758E+01,0.3782E+01,0.3788E+01
-			0.5834E+00,0.5832E+00,0.5825E+00,0.5813E+00,0.5795E+00,0.5771E+00,
-			0.5743E+00,0.5710E+00,0.5673E+00,0.5632E+00,0.5587E+00,0.5540E+00,
-			0.5490E+00,0.5438E+00,0.5384E+00,0.5330E+00,0.5275E+00,0.5221E+00,
-			0.5168E+00,0.5117E+00,0.5068E+00,0.5023E+00,0.4981E+00,0.4944E+00,
-			0.4913E+00,0.4889E+00,0.4871E+00,0.4862E+00,0.4862E+00,0.4872E+00,
-			0.4894E+00,0.4928E+00,0.4975E+00,0.5037E+00,0.5115E+00,0.5210E+00,
-			0.5324E+00,0.5457E+00,0.5611E+00,0.5788E+00,0.5988E+00,0.6098E+00,
-			0.6215E+00,0.6468E+00,0.6749E+00,0.7061E+00,0.7405E+00,0.7781E+00,
-			0.8193E+00,0.8641E+00,0.9127E+00,0.9652E+00,0.1022E+01,0.1083E+01,
-			0.1148E+01,0.1217E+01,0.1291E+01,0.1370E+01,0.1453E+01,0.1541E+01,
-			0.1633E+01,0.1730E+01,0.1831E+01,0.1936E+01,0.2045E+01,0.2157E+01,
-			0.2272E+01,0.2390E+01,0.2509E+01,0.2629E+01,0.2749E+01,0.2867E+01,
-			0.2984E+01,0.3096E+01,0.3203E+01,0.3304E+01,0.3395E+01,0.3476E+01,
-			0.3545E+01,0.3599E+01,0.3638E+01,0.3660E+01,0.3666E+01
-			0.6060E+00,0.6059E+00,0.6051E+00,0.6038E+00,0.6019E+00,0.5994E+00,
-			0.5964E+00,0.5929E+00,0.5889E+00,0.5846E+00,0.5798E+00,0.5747E+00,
-			0.5693E+00,0.5637E+00,0.5580E+00,0.5521E+00,0.5462E+00,0.5403E+00,
-			0.5345E+00,0.5289E+00,0.5235E+00,0.5185E+00,0.5138E+00,0.5096E+00,
-			0.5059E+00,0.5029E+00,0.5007E+00,0.4993E+00,0.4988E+00,0.4993E+00,
-			0.5010E+00,0.5040E+00,0.5083E+00,0.5142E+00,0.5216E+00,0.5307E+00,
-			0.5418E+00,0.5548E+00,0.5699E+00,0.5873E+00,0.6071E+00,0.6180E+00,
-			0.6295E+00,0.6546E+00,0.6825E+00,0.7134E+00,0.7474E+00,0.7848E+00,
-			0.8255E+00,0.8699E+00,0.9179E+00,0.9698E+00,0.1026E+01,0.1085E+01,
-			0.1150E+01,0.1218E+01,0.1290E+01,0.1367E+01,0.1448E+01,0.1534E+01,
-			0.1623E+01,0.1717E+01,0.1815E+01,0.1916E+01,0.2020E+01,0.2128E+01,
-			0.2237E+01,0.2349E+01,0.2462E+01,0.2576E+01,0.2688E+01,0.2800E+01,
-			0.2909E+01,0.3013E+01,0.3113E+01,0.3206E+01,0.3290E+01,0.3364E+01,
-			0.3427E+01,0.3477E+01,0.3512E+01,0.3532E+01,0.3537E+01
-			0.6604E+00,0.6602E+00,0.6593E+00,0.6578E+00,0.6556E+00,0.6528E+00,
-			0.6494E+00,0.6454E+00,0.6409E+00,0.6358E+00,0.6304E+00,0.6245E+00,
-			0.6182E+00,0.6117E+00,0.6050E+00,0.5981E+00,0.5911E+00,0.5841E+00,
-			0.5771E+00,0.5703E+00,0.5636E+00,0.5573E+00,0.5513E+00,0.5458E+00,
-			0.5409E+00,0.5366E+00,0.5331E+00,0.5305E+00,0.5288E+00,0.5281E+00,
-			0.5287E+00,0.5305E+00,0.5338E+00,0.5385E+00,0.5450E+00,0.5532E+00,
-			0.5633E+00,0.5754E+00,0.5897E+00,0.6062E+00,0.6252E+00,0.6356E+00,
-			0.6467E+00,0.6710E+00,0.6980E+00,0.7280E+00,0.7610E+00,0.7972E+00,
-			0.8367E+00,0.8797E+00,0.9261E+00,0.9762E+00,0.1030E+01,0.1087E+01,
-			0.1149E+01,0.1214E+01,0.1283E+01,0.1355E+01,0.1432E+01,0.1512E+01,
-			0.1595E+01,0.1682E+01,0.1772E+01,0.1865E+01,0.1961E+01,0.2058E+01,
-			0.2157E+01,0.2257E+01,0.2358E+01,0.2458E+01,0.2557E+01,0.2654E+01,
-			0.2748E+01,0.2838E+01,0.2923E+01,0.3001E+01,0.3072E+01,0.3134E+01,
-			0.3187E+01,0.3228E+01,0.3257E+01,0.3273E+01,0.3277E+01
-			0.6993E+00,0.6991E+00,0.6982E+00,0.6965E+00,0.6942E+00,0.6911E+00,
-			0.6874E+00,0.6830E+00,0.6781E+00,0.6726E+00,0.6666E+00,0.6601E+00,
-			0.6533E+00,0.6461E+00,0.6387E+00,0.6310E+00,0.6232E+00,0.6154E+00,
-			0.6076E+00,0.5998E+00,0.5923E+00,0.5851E+00,0.5782E+00,0.5717E+00,
-			0.5659E+00,0.5607E+00,0.5562E+00,0.5526E+00,0.5500E+00,0.5485E+00,
-			0.5482E+00,0.5491E+00,0.5515E+00,0.5555E+00,0.5611E+00,0.5686E+00,
-			0.5779E+00,0.5893E+00,0.6028E+00,0.6187E+00,0.6369E+00,0.6470E+00,
-			0.6577E+00,0.6812E+00,0.7074E+00,0.7366E+00,0.7687E+00,0.8040E+00,
-			0.8425E+00,0.8843E+00,0.9295E+00,0.9781E+00,0.1030E+01,0.1086E+01,
-			0.1145E+01,0.1208E+01,0.1274E+01,0.1344E+01,0.1417E+01,0.1494E+01,
-			0.1573E+01,0.1656E+01,0.1741E+01,0.1828E+01,0.1918E+01,0.2009E+01,
-			0.2101E+01,0.2194E+01,0.2287E+01,0.2380E+01,0.2470E+01,0.2559E+01,
-			0.2645E+01,0.2726E+01,0.2803E+01,0.2873E+01,0.2937E+01,0.2992E+01,
-			0.3038E+01,0.3075E+01,0.3100E+01,0.3115E+01,0.3118E+01
-			0.7916E+00,0.7914E+00,0.7903E+00,0.7883E+00,0.7855E+00,0.7818E+00,
-			0.7773E+00,0.7721E+00,0.7662E+00,0.7595E+00,0.7522E+00,0.7444E+00,
-			0.7360E+00,0.7272E+00,0.7180E+00,0.7085E+00,0.6988E+00,0.6889E+00,
-			0.6790E+00,0.6692E+00,0.6595E+00,0.6500E+00,0.6408E+00,0.6321E+00,
-			0.6239E+00,0.6164E+00,0.6097E+00,0.6038E+00,0.5989E+00,0.5952E+00,
-			0.5926E+00,0.5915E+00,0.5918E+00,0.5936E+00,0.5972E+00,0.6027E+00,
-			0.6101E+00,0.6195E+00,0.6311E+00,0.6451E+00,0.6614E+00,0.6705E+00,
-			0.6803E+00,0.7017E+00,0.7259E+00,0.7529E+00,0.7828E+00,0.8156E+00,
-			0.8514E+00,0.8903E+00,0.9323E+00,0.9774E+00,0.1026E+01,0.1077E+01,
-			0.1131E+01,0.1189E+01,0.1249E+01,0.1312E+01,0.1378E+01,0.1447E+01,
-			0.1518E+01,0.1590E+01,0.1665E+01,0.1741E+01,0.1819E+01,0.1897E+01,
-			0.1976E+01,0.2054E+01,0.2132E+01,0.2209E+01,0.2284E+01,0.2356E+01,
-			0.2426E+01,0.2491E+01,0.2552E+01,0.2607E+01,0.2657E+01,0.2700E+01,
-			0.2736E+01,0.2764E+01,0.2783E+01,0.2795E+01,0.2797E+01
-			0.1041E+01,0.1040E+01,0.1038E+01,0.1036E+01,0.1031E+01,0.1026E+01,
-			0.1019E+01,0.1011E+01,0.1002E+01,0.9924E+00,0.9814E+00,0.9694E+00,
-			0.9566E+00,0.9431E+00,0.9288E+00,0.9140E+00,0.8988E+00,0.8832E+00,
-			0.8673E+00,0.8513E+00,0.8353E+00,0.8194E+00,0.8038E+00,0.7885E+00,
-			0.7737E+00,0.7596E+00,0.7462E+00,0.7338E+00,0.7223E+00,0.7121E+00,
-			0.7031E+00,0.6955E+00,0.6895E+00,0.6852E+00,0.6827E+00,0.6820E+00,
-			0.6833E+00,0.6868E+00,0.6924E+00,0.7003E+00,0.7105E+00,0.7165E+00,
-			0.7232E+00,0.7383E+00,0.7559E+00,0.7760E+00,0.7987E+00,0.8240E+00,
-			0.8518E+00,0.8821E+00,0.9149E+00,0.9501E+00,0.9877E+00,0.1028E+01,
-			0.1069E+01,0.1113E+01,0.1159E+01,0.1207E+01,0.1256E+01,0.1306E+01,
-			0.1358E+01,0.1410E+01,0.1463E+01,0.1517E+01,0.1570E+01,0.1623E+01,
-			0.1676E+01,0.1727E+01,0.1778E+01,0.1827E+01,0.1873E+01,0.1918E+01,
-			0.1960E+01,0.1999E+01,0.2035E+01,0.2067E+01,0.2096E+01,0.2120E+01,
-			0.2140E+01,0.2156E+01,0.2167E+01,0.2173E+01,0.2174E+01
-			0.1182E+01,0.1181E+01,0.1179E+01,0.1176E+01,0.1171E+01,0.1164E+01,
-			0.1156E+01,0.1147E+01,0.1136E+01,0.1124E+01,0.1110E+01,0.1096E+01,
-			0.1080E+01,0.1064E+01,0.1046E+01,0.1028E+01,0.1009E+01,0.9903E+00,
-			0.9708E+00,0.9510E+00,0.9312E+00,0.9114E+00,0.8919E+00,0.8726E+00,
-			0.8539E+00,0.8357E+00,0.8184E+00,0.8019E+00,0.7866E+00,0.7724E+00,
-			0.7595E+00,0.7481E+00,0.7383E+00,0.7302E+00,0.7239E+00,0.7195E+00,
-			0.7171E+00,0.7168E+00,0.7188E+00,0.7229E+00,0.7294E+00,0.7335E+00,
-			0.7382E+00,0.7494E+00,0.7630E+00,0.7790E+00,0.7974E+00,0.8182E+00,
-			0.8414E+00,0.8668E+00,0.8944E+00,0.9242E+00,0.9561E+00,0.9898E+00,
-			0.1025E+01,0.1063E+01,0.1101E+01,0.1141E+01,0.1183E+01,0.1225E+01,
-			0.1268E+01,0.1311E+01,0.1355E+01,0.1399E+01,0.1442E+01,0.1485E+01,
-			0.1528E+01,0.1569E+01,0.1609E+01,0.1648E+01,0.1685E+01,0.1720E+01,
-			0.1753E+01,0.1783E+01,0.1811E+01,0.1836E+01,0.1858E+01,0.1876E+01,
-			0.1891E+01,0.1903E+01,0.1911E+01,0.1916E+01,0.1917E+01
-			0.1325E+01,0.1324E+01,0.1322E+01,0.1318E+01,0.1312E+01,0.1304E+01,
-			0.1294E+01,0.1283E+01,0.1270E+01,0.1256E+01,0.1240E+01,0.1222E+01,
-			0.1204E+01,0.1184E+01,0.1163E+01,0.1142E+01,0.1119E+01,0.1096E+01,
-			0.1073E+01,0.1049E+01,0.1025E+01,0.1001E+01,0.9776E+00,0.9541E+00,
-			0.9312E+00,0.9088E+00,0.8872E+00,0.8666E+00,0.8471E+00,0.8287E+00,
-			0.8118E+00,0.7963E+00,0.7825E+00,0.7704E+00,0.7602E+00,0.7519E+00,
-			0.7457E+00,0.7415E+00,0.7396E+00,0.7399E+00,0.7424E+00,0.7446E+00,
-			0.7473E+00,0.7545E+00,0.7640E+00,0.7758E+00,0.7899E+00,0.8063E+00,
-			0.8248E+00,0.8455E+00,0.8681E+00,0.8928E+00,0.9192E+00,0.9473E+00,
-			0.9771E+00,0.1008E+01,0.1041E+01,0.1074E+01,0.1109E+01,0.1144E+01,
-			0.1179E+01,0.1215E+01,0.1252E+01,0.1288E+01,0.1324E+01,0.1359E+01,
-			0.1393E+01,0.1427E+01,0.1460E+01,0.1491E+01,0.1521E+01,0.1549E+01,
-			0.1575E+01,0.1599E+01,0.1622E+01,0.1641E+01,0.1658E+01,0.1673E+01,
-			0.1685E+01,0.1694E+01,0.1701E+01,0.1704E+01,0.1705E+01
+	 0.5834E+00,0.5832E+00,0.5825E+00,0.5813E+00,0.5795E+00,0.5771E+00,
+	 0.5743E+00,0.5710E+00,0.5673E+00,0.5632E+00,0.5587E+00,0.5540E+00,
+	 0.5490E+00,0.5438E+00,0.5384E+00,0.5330E+00,0.5275E+00,0.5221E+00,
+	 0.5168E+00,0.5117E+00,0.5068E+00,0.5023E+00,0.4981E+00,0.4944E+00,
+	 0.4913E+00,0.4889E+00,0.4871E+00,0.4862E+00,0.4862E+00,0.4872E+00,
+	 0.4894E+00,0.4928E+00,0.4975E+00,0.5037E+00,0.5115E+00,0.5210E+00,
+	 0.5324E+00,0.5457E+00,0.5611E+00,0.5788E+00,0.5988E+00,0.6098E+00,
+	 0.6215E+00,0.6468E+00,0.6749E+00,0.7061E+00,0.7405E+00,0.7781E+00,
+	 0.8193E+00,0.8641E+00,0.9127E+00,0.9652E+00,0.1022E+01,0.1083E+01,
+	 0.1148E+01,0.1217E+01,0.1291E+01,0.1370E+01,0.1453E+01,0.1541E+01,
+	 0.1633E+01,0.1730E+01,0.1831E+01,0.1936E+01,0.2045E+01,0.2157E+01,
+	 0.2272E+01,0.2390E+01,0.2509E+01,0.2629E+01,0.2749E+01,0.2867E+01,
+	 0.2984E+01,0.3096E+01,0.3203E+01,0.3304E+01,0.3395E+01,0.3476E+01,
+	 0.3545E+01,0.3599E+01,0.3638E+01,0.3660E+01,0.3666E+01
+	 0.6060E+00,0.6059E+00,0.6051E+00,0.6038E+00,0.6019E+00,0.5994E+00,
+	 0.5964E+00,0.5929E+00,0.5889E+00,0.5846E+00,0.5798E+00,0.5747E+00,
+	 0.5693E+00,0.5637E+00,0.5580E+00,0.5521E+00,0.5462E+00,0.5403E+00,
+	 0.5345E+00,0.5289E+00,0.5235E+00,0.5185E+00,0.5138E+00,0.5096E+00,
+	 0.5059E+00,0.5029E+00,0.5007E+00,0.4993E+00,0.4988E+00,0.4993E+00,
+	 0.5010E+00,0.5040E+00,0.5083E+00,0.5142E+00,0.5216E+00,0.5307E+00,
+	 0.5418E+00,0.5548E+00,0.5699E+00,0.5873E+00,0.6071E+00,0.6180E+00,
+	 0.6295E+00,0.6546E+00,0.6825E+00,0.7134E+00,0.7474E+00,0.7848E+00,
+	 0.8255E+00,0.8699E+00,0.9179E+00,0.9698E+00,0.1026E+01,0.1085E+01,
+	 0.1150E+01,0.1218E+01,0.1290E+01,0.1367E+01,0.1448E+01,0.1534E+01,
+	 0.1623E+01,0.1717E+01,0.1815E+01,0.1916E+01,0.2020E+01,0.2128E+01,
+	 0.2237E+01,0.2349E+01,0.2462E+01,0.2576E+01,0.2688E+01,0.2800E+01,
+	 0.2909E+01,0.3013E+01,0.3113E+01,0.3206E+01,0.3290E+01,0.3364E+01,
+	 0.3427E+01,0.3477E+01,0.3512E+01,0.3532E+01,0.3537E+01
+	 0.6604E+00,0.6602E+00,0.6593E+00,0.6578E+00,0.6556E+00,0.6528E+00,
+	 0.6494E+00,0.6454E+00,0.6409E+00,0.6358E+00,0.6304E+00,0.6245E+00,
+	 0.6182E+00,0.6117E+00,0.6050E+00,0.5981E+00,0.5911E+00,0.5841E+00,
+	 0.5771E+00,0.5703E+00,0.5636E+00,0.5573E+00,0.5513E+00,0.5458E+00,
+	 0.5409E+00,0.5366E+00,0.5331E+00,0.5305E+00,0.5288E+00,0.5281E+00,
+	 0.5287E+00,0.5305E+00,0.5338E+00,0.5385E+00,0.5450E+00,0.5532E+00,
+	 0.5633E+00,0.5754E+00,0.5897E+00,0.6062E+00,0.6252E+00,0.6356E+00,
+	 0.6467E+00,0.6710E+00,0.6980E+00,0.7280E+00,0.7610E+00,0.7972E+00,
+	 0.8367E+00,0.8797E+00,0.9261E+00,0.9762E+00,0.1030E+01,0.1087E+01,
+	 0.1149E+01,0.1214E+01,0.1283E+01,0.1355E+01,0.1432E+01,0.1512E+01,
+	 0.1595E+01,0.1682E+01,0.1772E+01,0.1865E+01,0.1961E+01,0.2058E+01,
+	 0.2157E+01,0.2257E+01,0.2358E+01,0.2458E+01,0.2557E+01,0.2654E+01,
+	 0.2748E+01,0.2838E+01,0.2923E+01,0.3001E+01,0.3072E+01,0.3134E+01,
+	 0.3187E+01,0.3228E+01,0.3257E+01,0.3273E+01,0.3277E+01
+	 0.6993E+00,0.6991E+00,0.6982E+00,0.6965E+00,0.6942E+00,0.6911E+00,
+	 0.6874E+00,0.6830E+00,0.6781E+00,0.6726E+00,0.6666E+00,0.6601E+00,
+	 0.6533E+00,0.6461E+00,0.6387E+00,0.6310E+00,0.6232E+00,0.6154E+00,
+	 0.6076E+00,0.5998E+00,0.5923E+00,0.5851E+00,0.5782E+00,0.5717E+00,
+	 0.5659E+00,0.5607E+00,0.5562E+00,0.5526E+00,0.5500E+00,0.5485E+00,
+	 0.5482E+00,0.5491E+00,0.5515E+00,0.5555E+00,0.5611E+00,0.5686E+00,
+	 0.5779E+00,0.5893E+00,0.6028E+00,0.6187E+00,0.6369E+00,0.6470E+00,
+	 0.6577E+00,0.6812E+00,0.7074E+00,0.7366E+00,0.7687E+00,0.8040E+00,
+	 0.8425E+00,0.8843E+00,0.9295E+00,0.9781E+00,0.1030E+01,0.1086E+01,
+	 0.1145E+01,0.1208E+01,0.1274E+01,0.1344E+01,0.1417E+01,0.1494E+01,
+	 0.1573E+01,0.1656E+01,0.1741E+01,0.1828E+01,0.1918E+01,0.2009E+01,
+	 0.2101E+01,0.2194E+01,0.2287E+01,0.2380E+01,0.2470E+01,0.2559E+01,
+	 0.2645E+01,0.2726E+01,0.2803E+01,0.2873E+01,0.2937E+01,0.2992E+01,
+	 0.3038E+01,0.3075E+01,0.3100E+01,0.3115E+01,0.3118E+01
+	 0.7916E+00,0.7914E+00,0.7903E+00,0.7883E+00,0.7855E+00,0.7818E+00,
+	 0.7773E+00,0.7721E+00,0.7662E+00,0.7595E+00,0.7522E+00,0.7444E+00,
+	 0.7360E+00,0.7272E+00,0.7180E+00,0.7085E+00,0.6988E+00,0.6889E+00,
+	 0.6790E+00,0.6692E+00,0.6595E+00,0.6500E+00,0.6408E+00,0.6321E+00,
+	 0.6239E+00,0.6164E+00,0.6097E+00,0.6038E+00,0.5989E+00,0.5952E+00,
+	 0.5926E+00,0.5915E+00,0.5918E+00,0.5936E+00,0.5972E+00,0.6027E+00,
+	 0.6101E+00,0.6195E+00,0.6311E+00,0.6451E+00,0.6614E+00,0.6705E+00,
+	 0.6803E+00,0.7017E+00,0.7259E+00,0.7529E+00,0.7828E+00,0.8156E+00,
+	 0.8514E+00,0.8903E+00,0.9323E+00,0.9774E+00,0.1026E+01,0.1077E+01,
+	 0.1131E+01,0.1189E+01,0.1249E+01,0.1312E+01,0.1378E+01,0.1447E+01,
+	 0.1518E+01,0.1590E+01,0.1665E+01,0.1741E+01,0.1819E+01,0.1897E+01,
+	 0.1976E+01,0.2054E+01,0.2132E+01,0.2209E+01,0.2284E+01,0.2356E+01,
+	 0.2426E+01,0.2491E+01,0.2552E+01,0.2607E+01,0.2657E+01,0.2700E+01,
+	 0.2736E+01,0.2764E+01,0.2783E+01,0.2795E+01,0.2797E+01
+	 0.1041E+01,0.1040E+01,0.1038E+01,0.1036E+01,0.1031E+01,0.1026E+01,
+	 0.1019E+01,0.1011E+01,0.1002E+01,0.9924E+00,0.9814E+00,0.9694E+00,
+	 0.9566E+00,0.9431E+00,0.9288E+00,0.9140E+00,0.8988E+00,0.8832E+00,
+	 0.8673E+00,0.8513E+00,0.8353E+00,0.8194E+00,0.8038E+00,0.7885E+00,
+	 0.7737E+00,0.7596E+00,0.7462E+00,0.7338E+00,0.7223E+00,0.7121E+00,
+	 0.7031E+00,0.6955E+00,0.6895E+00,0.6852E+00,0.6827E+00,0.6820E+00,
+	 0.6833E+00,0.6868E+00,0.6924E+00,0.7003E+00,0.7105E+00,0.7165E+00,
+	 0.7232E+00,0.7383E+00,0.7559E+00,0.7760E+00,0.7987E+00,0.8240E+00,
+	 0.8518E+00,0.8821E+00,0.9149E+00,0.9501E+00,0.9877E+00,0.1028E+01,
+	 0.1069E+01,0.1113E+01,0.1159E+01,0.1207E+01,0.1256E+01,0.1306E+01,
+	 0.1358E+01,0.1410E+01,0.1463E+01,0.1517E+01,0.1570E+01,0.1623E+01,
+	 0.1676E+01,0.1727E+01,0.1778E+01,0.1827E+01,0.1873E+01,0.1918E+01,
+	 0.1960E+01,0.1999E+01,0.2035E+01,0.2067E+01,0.2096E+01,0.2120E+01,
+	 0.2140E+01,0.2156E+01,0.2167E+01,0.2173E+01,0.2174E+01
+	 0.1182E+01,0.1181E+01,0.1179E+01,0.1176E+01,0.1171E+01,0.1164E+01,
+	 0.1156E+01,0.1147E+01,0.1136E+01,0.1124E+01,0.1110E+01,0.1096E+01,
+	 0.1080E+01,0.1064E+01,0.1046E+01,0.1028E+01,0.1009E+01,0.9903E+00,
+	 0.9708E+00,0.9510E+00,0.9312E+00,0.9114E+00,0.8919E+00,0.8726E+00,
+	 0.8539E+00,0.8357E+00,0.8184E+00,0.8019E+00,0.7866E+00,0.7724E+00,
+	 0.7595E+00,0.7481E+00,0.7383E+00,0.7302E+00,0.7239E+00,0.7195E+00,
+	 0.7171E+00,0.7168E+00,0.7188E+00,0.7229E+00,0.7294E+00,0.7335E+00,
+	 0.7382E+00,0.7494E+00,0.7630E+00,0.7790E+00,0.7974E+00,0.8182E+00,
+	 0.8414E+00,0.8668E+00,0.8944E+00,0.9242E+00,0.9561E+00,0.9898E+00,
+	 0.1025E+01,0.1063E+01,0.1101E+01,0.1141E+01,0.1183E+01,0.1225E+01,
+	 0.1268E+01,0.1311E+01,0.1355E+01,0.1399E+01,0.1442E+01,0.1485E+01,
+	 0.1528E+01,0.1569E+01,0.1609E+01,0.1648E+01,0.1685E+01,0.1720E+01,
+	 0.1753E+01,0.1783E+01,0.1811E+01,0.1836E+01,0.1858E+01,0.1876E+01,
+	 0.1891E+01,0.1903E+01,0.1911E+01,0.1916E+01,0.1917E+01
+	 0.1325E+01,0.1324E+01,0.1322E+01,0.1318E+01,0.1312E+01,0.1304E+01,
+	 0.1294E+01,0.1283E+01,0.1270E+01,0.1256E+01,0.1240E+01,0.1222E+01,
+	 0.1204E+01,0.1184E+01,0.1163E+01,0.1142E+01,0.1119E+01,0.1096E+01,
+	 0.1073E+01,0.1049E+01,0.1025E+01,0.1001E+01,0.9776E+00,0.9541E+00,
+	 0.9312E+00,0.9088E+00,0.8872E+00,0.8666E+00,0.8471E+00,0.8287E+00,
+	 0.8118E+00,0.7963E+00,0.7825E+00,0.7704E+00,0.7602E+00,0.7519E+00,
+	 0.7457E+00,0.7415E+00,0.7396E+00,0.7399E+00,0.7424E+00,0.7446E+00,
+	 0.7473E+00,0.7545E+00,0.7640E+00,0.7758E+00,0.7899E+00,0.8063E+00,
+	 0.8248E+00,0.8455E+00,0.8681E+00,0.8928E+00,0.9192E+00,0.9473E+00,
+	 0.9771E+00,0.1008E+01,0.1041E+01,0.1074E+01,0.1109E+01,0.1144E+01,
+	 0.1179E+01,0.1215E+01,0.1252E+01,0.1288E+01,0.1324E+01,0.1359E+01,
+	 0.1393E+01,0.1427E+01,0.1460E+01,0.1491E+01,0.1521E+01,0.1549E+01,
+	 0.1575E+01,0.1599E+01,0.1622E+01,0.1641E+01,0.1658E+01,0.1673E+01,
+	 0.1685E+01,0.1694E+01,0.1701E+01,0.1704E+01,0.1705E+01
-		/* user defined model */
-		{{0},{0},{0},{0},{0},{0},{0},{0}},
+    /* user defined model */
+    {{0},{0},{0},{0},{0},{0},{0},{0}},
-		/* pointer to current active model */
-		0
+    /* pointer to current active model */
+    0
Modified: grass/trunk/imagery/i.atcorr/computations.cpp
--- grass/trunk/imagery/i.atcorr/computations.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/computations.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -14,197 +14,197 @@
 struct OpticalAtmosProperties
-	float rorayl, romix, roaero;
-	float ddirtr, ddiftr;
-	float ddirtt, ddiftt;
-	float ddirta, ddifta;
-	float udirtr, udiftr;
-	float udirtt, udiftt;
-	float udirta, udifta;
-	float sphalbr, sphalbt, sphalba;
+    float rorayl, romix, roaero;
+    float ddirtr, ddiftr;
+    float ddirtt, ddiftt;
+    float ddirta, ddifta;
+    float udirtr, udiftr;
+    float udirtt, udiftt;
+    float udirta, udifta;
+    float sphalbr, sphalbt, sphalba;
 /* To compute the molecular optical depth as a function of wavelength for any
- atmosphere defined by the pressure and temperature profiles. */
+   atmosphere defined by the pressure and temperature profiles. */
 float odrayl(const AtmosModel &atms, const float wl)
-	/* air refraction index edlen 1966 / metrologia,2,71-80  putting pw=0 */
-	float ak=1/wl;
+    /* air refraction index edlen 1966 / metrologia,2,71-80  putting pw=0 */
+    float ak=1/wl;
     double awl= wl*wl*wl*wl;
-	double a1 = 130 - ak * ak;
-	double a2 = 38.9 - ak * ak;
-	double a3 = 2406030 / a1;
-	double a4 = 15997 / a2;
-	double an = (8342.13 + a3 + a4) * 1.0e-08 + 1;
-	double a = (24 * M_PI * M_PI * M_PI) * ((an * an - 1) * (an * an - 1))
-			   * (6 + 3 * delta) / (6 - 7 * delta) / ((an * an + 2) * (an * an + 2));
+    double a1 = 130 - ak * ak;
+    double a2 = 38.9 - ak * ak;
+    double a3 = 2406030 / a1;
+    double a4 = 15997 / a2;
+    double an = (8342.13 + a3 + a4) * 1.0e-08 + 1;
+    double a = (24 * M_PI * M_PI * M_PI) * ((an * an - 1) * (an * an - 1))
+	* (6 + 3 * delta) / (6 - 7 * delta) / ((an * an + 2) * (an * an + 2));
-	float tray = 0;
-	for(int k = 0; k < 33; k++)
-		double dppt = (288.15 / 1013.25) * (atms.p[k] / atms.t[k] + atms.p[k+1] / atms.t[k+1]) / 2;
-		double sr = a * dppt / awl / 0.0254743;
-		tray += (float)((atms.z[k+1] - atms.z[k]) * sr);
+    float tray = 0;
+    for(int k = 0; k < 33; k++)
+	double dppt = (288.15 / 1013.25) * (atms.p[k] / atms.t[k] + atms.p[k+1] / atms.t[k+1]) / 2;
+	double sr = a * dppt / awl / 0.0254743;
+	tray += (float)((atms.z[k+1] - atms.z[k]) * sr);
-	return tray;
+    return tray;
-decompose the aerosol phase function in series of Legendre polynomial used in
-OS.f and ISO.f and compute truncation coefficient f to modify aerosol optical thickness t and single
-scattering albedo w0 according to:
-t' = (1-w0 f) t
+  decompose the aerosol phase function in series of Legendre polynomial used in
+  OS.f and ISO.f and compute truncation coefficient f to modify aerosol optical thickness t and single
+  scattering albedo w0 according to:
+  t' = (1-w0 f) t
-w0' =  w0 (1- f)
-       (1-w0 f)
+  w0' =  w0 (1- f)
+  (1-w0 f)
 float trunca()
-	float ptemp[83];
-	float cosang[80];
-	float weight[80];
-	float rmu[83];
-	float ga[83];
+    float ptemp[83];
+    float cosang[80];
+    float weight[80];
+    float rmu[83];
+    float ga[83];
-	int i;
-	for(i = 0; i < 83; i++) ptemp[i] = sixs_trunc.pha[i];
+    int i;
+    for(i = 0; i < 83; i++) ptemp[i] = sixs_trunc.pha[i];
-	Gauss::gauss(-1,1,cosang,weight,80);
+    Gauss::gauss(-1,1,cosang,weight,80);
-	for(i = 0; i < 40; i++)
-		rmu[i+1] = cosang[i];
-		ga[i+1] = weight[i];
+    for(i = 0; i < 40; i++)
+	rmu[i+1] = cosang[i];
+	ga[i+1] = weight[i];
-	rmu[0] = -1;
-	ga[0] = 0;
-	rmu[41] = 0;
-	ga[41] = 0;
+    rmu[0] = -1;
+    ga[0] = 0;
+    rmu[41] = 0;
+    ga[41] = 0;
-	for(i = 40; i < 80; i++)
-		rmu[i+2] = cosang[i];
-		ga[i+2] = weight[i];
+    for(i = 40; i < 80; i++)
+	rmu[i+2] = cosang[i];
+	ga[i+2] = weight[i];
-	rmu[82] = 1;
-	ga[82] = 0;
+    rmu[82] = 1;
+    ga[82] = 0;
-	int k = 0;
-		if(rmu[i] > 0.8) break;
-		k = i - 1;
+    int k = 0;
+	if(rmu[i] > 0.8) break;
+	k = i - 1;
-	int kk = 0;
-		if(rmu[i] > 0.94) break;
-		kk = i - 1;
+    int kk = 0;
+	if(rmu[i] > 0.94) break;
+	kk = i - 1;
     float aa = (float)((log10(sixs_trunc.pha[kk]) - log10(sixs_trunc.pha[k])) /
-					   (acos(rmu[kk]) - acos(rmu[k])));
-	float x1 = (float)(log10(sixs_trunc.pha[kk]));
-	float x2 = (float)acos(rmu[kk]);
+		       (acos(rmu[kk]) - acos(rmu[k])));
+    float x1 = (float)(log10(sixs_trunc.pha[kk]));
+    float x2 = (float)acos(rmu[kk]);
-	for(i = kk + 1; i < 83; i++)
-		double a;
-		if(fabs(rmu[i] - 1) <= 1e-08) a = x1 - aa * x2;
-		else a = x1 + aa * (acos(rmu[i]) - x2);
-		ptemp[i] = (float)pow(10,a);
+    for(i = kk + 1; i < 83; i++)
+	double a;
+	if(fabs(rmu[i] - 1) <= 1e-08) a = x1 - aa * x2;
+	else a = x1 + aa * (acos(rmu[i]) - x2);
+	ptemp[i] = (float)pow(10,a);
-	for(i = 0; i < 83; i++) sixs_trunc.pha[i] = ptemp[i];
-	for(i = 0; i < 80; i++) sixs_trunc.betal[i] = 0;
+    for(i = 0; i < 83; i++) sixs_trunc.pha[i] = ptemp[i];
+    for(i = 0; i < 80; i++) sixs_trunc.betal[i] = 0;
-	float pl[83];
+    float pl[83];
-	#define IPL(X) ((X)+1)
+#define IPL(X) ((X)+1)
+	float x = sixs_trunc.pha[i] * ga[i];
+	float rm = rmu[i];
+	pl[IPL(-1)] = 0;
+	pl[IPL(0)] = 1;
+	for(int k = 0; k <= 80; k++)
-		float x = sixs_trunc.pha[i] * ga[i];
-		float rm = rmu[i];
-		pl[IPL(-1)] = 0;
-		pl[IPL(0)] = 1;
-		for(int k = 0; k <= 80; k++)
-			pl[IPL(k+1)] = ((2 * k + 1) * rm * pl[IPL(k)] - k * pl[IPL(k-1)]) / (k + 1);
-			sixs_trunc.betal[k] += x * pl[IPL(k)];
+	    pl[IPL(k+1)] = ((2 * k + 1) * rm * pl[IPL(k)] - k * pl[IPL(k-1)]) / (k + 1);
+	    sixs_trunc.betal[k] += x * pl[IPL(k)];
-	for(i = 0; i <= 80; i++) sixs_trunc.betal[i] *= (2 * i + 1) * 0.5f;
+    for(i = 0; i <= 80; i++) sixs_trunc.betal[i] *= (2 * i + 1) * 0.5f;
-	float z1 = sixs_trunc.betal[0];
-	for(i = 0; i <= 80; i++) sixs_trunc.betal[i] /= z1;
-	if(sixs_trunc.betal[80] < 0) sixs_trunc.betal[80] = 0;
+    float z1 = sixs_trunc.betal[0];
+    for(i = 0; i <= 80; i++) sixs_trunc.betal[i] /= z1;
+    if(sixs_trunc.betal[80] < 0) sixs_trunc.betal[80] = 0;
-	return 1 - z1;
+    return 1 - z1;
-Decompose the atmosphere in a finite number of layers. For each layer, DISCRE
-provides the optical thickness, the proportion of molecules and aerosols assuming an exponential
-distribution for each constituants. Figure 1 illustrate the way molecules and aerosols are mixed in a
-realistic atmosphere. For molecules, the scale height is 8km. For aerosols it is assumed to be 2km
-unless otherwise specified by the user (using aircraft measurements).
+  Decompose the atmosphere in a finite number of layers. For each layer, DISCRE
+  provides the optical thickness, the proportion of molecules and aerosols assuming an exponential
+  distribution for each constituants. Figure 1 illustrate the way molecules and aerosols are mixed in a
+  realistic atmosphere. For molecules, the scale height is 8km. For aerosols it is assumed to be 2km
+  unless otherwise specified by the user (using aircraft measurements).
 float discre(const float ta, const float ha, const float tr, const float hr,
-	   const int it, const int nt, const float yy, const float dd,
-	   const float ppp2, const float ppp1)
+	     const int it, const int nt, const float yy, const float dd,
+	     const float ppp2, const float ppp1)
-	if( ha >= 7 )
-		fprintf(stderr, "ERROR: check aerosol measurements or plane altitude\n");
-		return 0;
+    if( ha >= 7 )
+	fprintf(stderr, "ERROR: check aerosol measurements or plane altitude\n");
+	return 0;
-	double dt;
-	if( it == 0 ) dt = 1e-17;
-	else dt = 2 * (ta + tr - yy) / (nt - it + 1);
+    double dt;
+    if( it == 0 ) dt = 1e-17;
+    else dt = 2 * (ta + tr - yy) / (nt - it + 1);
-	float zx; /* return value */
-	float ecart = 0;
-	do {
-		dt = dt / 2;
-		double ti = yy + dt;
-		float y1 = ppp2;
-		float y2;
-		float y3 = ppp1;
+    float zx; /* return value */
+    float ecart = 0;
+    do {
+	dt = dt / 2;
+	double ti = yy + dt;
+	float y1 = ppp2;
+	float y2;
+	float y3 = ppp1;
-		while(true)
-			y2 = (y1 + y3) * 0.5f;
+	while(true)
+	    y2 = (y1 + y3) * 0.5f;
-			double xx = -y2 / ha;
-			double x2;
-			if (xx < -18) x2 = tr * exp(-y2 / hr);
-			else x2 = ta * exp(xx) + tr * exp(-y2 / hr);
+	    double xx = -y2 / ha;
+	    double x2;
+	    if (xx < -18) x2 = tr * exp(-y2 / hr);
+	    else x2 = ta * exp(xx) + tr * exp(-y2 / hr);
-			if(fabs(ti - x2) < 0.00001) break;
+	    if(fabs(ti - x2) < 0.00001) break;
-			if(ti - x2 < 0) y3 = y2;
-			else y1 = y2;
+	    if(ti - x2 < 0) y3 = y2;
+	    else y1 = y2;
-		zx = y2;
-		float delta = (float)(1. / (1 + ta * hr / tr / ha * exp((zx - ppp1) * (1. / hr - 1. / ha))));
-		if(dd != 0) ecart = (float)fabs((dd - delta) / dd);
-	} while((ecart > 0.75) && (it != 0));
-	return zx;
+	zx = y2;
+	float delta = (float)(1. / (1 + ta * hr / tr / ha * exp((zx - ppp1) * (1. / hr - 1. / ha))));
+	if(dd != 0) ecart = (float)fabs((dd - delta) / dd);
+    } while((ecart > 0.75) && (it != 0));
+    return zx;
@@ -212,105 +212,105 @@
 /* indexing macro for the psl variable */
 #define PSI(X) ((X)+1)
-Compute the values of Legendre polynomials used in the successive order of
-scattering method.
+  Compute the values of Legendre polynomials used in the successive order of
+  scattering method.
 void kernel(const int is, float (&xpl)[2*mu + 1], float (&bp)[26][2*mu + 1], Gauss &gauss)
-	const double rac3 = 1.7320508075688772935274463415059;
-	#define PSI(X) ((X)+1)
-	float psl[82][2*mu + 1];
+    const double rac3 = 1.7320508075688772935274463415059;
+#define PSI(X) ((X)+1)
+    float psl[82][2*mu + 1];
-	if(is == 0)
+    if(is == 0)
+	for(int j = 0; j <= mu; j++)
-		for(int j = 0; j <= mu; j++)
-			psl[PSI(0)][STDI(-j)] = 1;
-			psl[PSI(0)][STDI(j)] = 1;
-			psl[PSI(1)][STDI(j)] = gauss.rm[STDI(j)];
-			psl[PSI(1)][STDI(-j)] = -gauss.rm[STDI(j)];
+	    psl[PSI(0)][STDI(-j)] = 1;
+	    psl[PSI(0)][STDI(j)] = 1;
+	    psl[PSI(1)][STDI(j)] = gauss.rm[STDI(j)];
+	    psl[PSI(1)][STDI(-j)] = -gauss.rm[STDI(j)];
-			double xdb = (3 * gauss.rm[STDI(j)] * gauss.rm[STDI(j)] - 1) * 0.5;
-			if(fabs(xdb) < 1e-30) xdb = 0;
-			psl[PSI(2)][STDI(-j)] = (float)xdb;
-			psl[PSI(2)][STDI(j)] = (float)xdb;
-		psl[PSI(1)][STDI(0)] = gauss.rm[STDI(0)];
+	    double xdb = (3 * gauss.rm[STDI(j)] * gauss.rm[STDI(j)] - 1) * 0.5;
+	    if(fabs(xdb) < 1e-30) xdb = 0;
+	    psl[PSI(2)][STDI(-j)] = (float)xdb;
+	    psl[PSI(2)][STDI(j)] = (float)xdb;
-	else if(is == 1)
+	psl[PSI(1)][STDI(0)] = gauss.rm[STDI(0)];
+    else if(is == 1)
-			double x = 1 - gauss.rm[STDI(j)] * gauss.rm[STDI(j)];
-			psl[PSI(0)][STDI(j)]  = 0;
-			psl[PSI(0)][STDI(-j)] = 0;
-			psl[PSI(1)][STDI(-j)] = (float)sqrt(x * 0.5);
-			psl[PSI(1)][STDI(j)]  = (float)sqrt(x * 0.5);
-			psl[PSI(2)][STDI(j)]  = (float)(gauss.rm[STDI(j)] * psl[PSI(1)][STDI(j)] * rac3);
-			psl[PSI(2)][STDI(-j)] = -psl[PSI(2)][STDI(j)];
+	    double x = 1 - gauss.rm[STDI(j)] * gauss.rm[STDI(j)];
+	    psl[PSI(0)][STDI(j)]  = 0;
+	    psl[PSI(0)][STDI(-j)] = 0;
+	    psl[PSI(1)][STDI(-j)] = (float)sqrt(x * 0.5);
+	    psl[PSI(1)][STDI(j)]  = (float)sqrt(x * 0.5);
+	    psl[PSI(2)][STDI(j)]  = (float)(gauss.rm[STDI(j)] * psl[PSI(1)][STDI(j)] * rac3);
+	    psl[PSI(2)][STDI(-j)] = -psl[PSI(2)][STDI(j)];
-		psl[PSI(2)][STDI(0)] = -psl[PSI(2)][STDI(0)];
-	else
-		double a = 1;
-		for(int i = 1; i <= is; i++) a *= sqrt((double)(i + is) / (double)i) * 0.5;
+	psl[PSI(2)][STDI(0)] = -psl[PSI(2)][STDI(0)];
+    else
+	double a = 1;
+	for(int i = 1; i <= is; i++) a *= sqrt((double)(i + is) / (double)i) * 0.5;
 /*		double b = a * sqrt((double)is / (is + 1.)) * sqrt((is - 1.) / (is + 2.));*/
-			double xx = 1 - gauss.rm[STDI(j)] * gauss.rm[STDI(j)];
-			psl[PSI(is - 1)][STDI(j)] = 0;
-			double xdb = a * pow(xx, is * 0.5);
-			psl[PSI(is)][STDI(-j)] = (float)xdb;
-			psl[PSI(is)][STDI(j)] = (float)xdb;
+	    double xx = 1 - gauss.rm[STDI(j)] * gauss.rm[STDI(j)];
+	    psl[PSI(is - 1)][STDI(j)] = 0;
+	    double xdb = a * pow(xx, is * 0.5);
+	    psl[PSI(is)][STDI(-j)] = (float)xdb;
+	    psl[PSI(is)][STDI(j)] = (float)xdb;
-	int k = 2;
-	int ip = 80;
+    int k = 2;
+    int ip = 80;
-	if(is > 2) k = is;
-	if(k != ip)
+    if(is > 2) k = is;
+    if(k != ip)
+	int ig = -1;
+	if( is == 1 ) ig = 1;
+	for(int l = k; l < ip; l++)
-		int ig = -1;
-		if( is == 1 ) ig = 1;
-		for(int l = k; l < ip; l++)
-			double a = (2 * l + 1.) / sqrt((l + is + 1.) * (l - is + 1.));
-			double b = sqrt(float((l + is) * (l - is))) / (2. * l + 1.);
+	    double a = (2 * l + 1.) / sqrt((l + is + 1.) * (l - is + 1.));
+	    double b = sqrt(float((l + is) * (l - is))) / (2. * l + 1.);
-				double xdb = a * (gauss.rm[STDI(j)] * psl[PSI(l)][STDI(j)] - b * psl[PSI(l-1)][STDI(j)]);
-				if (fabs(xdb) < 1e-30) xdb = 0;
-				psl[PSI(l+1)][STDI(j)] = (float)xdb;
-				if(j != 0) psl[PSI(l+1)][STDI(-j)] = ig * psl[PSI(l+1)][STDI(j)];
-			ig = -ig;
+		double xdb = a * (gauss.rm[STDI(j)] * psl[PSI(l)][STDI(j)] - b * psl[PSI(l-1)][STDI(j)]);
+		if (fabs(xdb) < 1e-30) xdb = 0;
+		psl[PSI(l+1)][STDI(j)] = (float)xdb;
+		if(j != 0) psl[PSI(l+1)][STDI(-j)] = ig * psl[PSI(l+1)][STDI(j)];
+	    ig = -ig;
-	int j;
-	for(j = -mu; j <= mu; j++) xpl[STDI(j)] = psl[PSI(2)][STDI(j)];
+    int j;
+    for(j = -mu; j <= mu; j++) xpl[STDI(j)] = psl[PSI(2)][STDI(j)];
-	for(j = 0; j <= mu; j++)
+    for(j = 0; j <= mu; j++)
+	for(int k = -mu; k <= mu; k++)
-		for(int k = -mu; k <= mu; k++)
-			double sbp = 0;
-			if(is <= 80)
-				for(int l = is; l <= 80; l++)
-					sbp += psl[PSI(l)][STDI(j)] * psl[PSI(l)][STDI(k)] * sixs_trunc.betal[l];
+	    double sbp = 0;
+	    if(is <= 80)
+		for(int l = is; l <= 80; l++)
+		    sbp += psl[PSI(l)][STDI(j)] * psl[PSI(l)][STDI(k)] * sixs_trunc.betal[l];
-				if(fabs(sbp) < 1e-30) sbp = 0;
-				bp[j][STDI(k)] = (float)sbp;
+		if(fabs(sbp) < 1e-30) sbp = 0;
+		bp[j][STDI(k)] = (float)sbp;
@@ -321,1278 +321,1278 @@
 #define mum1 (mu - 1)
 void os(const float tamoy, const float trmoy, const float pizmoy,
-		const float tamoyp, const float trmoyp,	float (&xl)[2*mu + 1][np],
+	const float tamoyp, const float trmoyp,	float (&xl)[2*mu + 1][np],
         Gauss &gauss, const Altitude &alt, const GeomCond &geom)
-	float trp = trmoy - trmoyp;
-	float tap = tamoy - tamoyp;
-	int iplane = 0;
+    float trp = trmoy - trmoyp;
+    float tap = tamoy - tamoyp;
+    int iplane = 0;
-	/* if plane observations recompute scale height for aerosol knowing:
-	 the aerosol optical depth as measure from the plane 	= tamoyp
-	 the rayleigh scale   height = 			= hr (8km)
-	 the rayleigh optical depth  at plane level 		= trmoyp
-	 the altitude of the plane 				= palt
-	 the rayleigh optical depth for total atmos		= trmoy
-	 the aerosol  optical depth for total atmos		= tamoy
-	 if not plane observations then ha is equal to 2.0km
-	 ntp local variable: if ntp=nt     no plane observation selected
-	                        ntp=nt-1   plane observation selected
-	    it's a mixing rayleigh+aerosol */
+    /* if plane observations recompute scale height for aerosol knowing:
+       the aerosol optical depth as measure from the plane 	= tamoyp
+       the rayleigh scale   height = 			= hr (8km)
+       the rayleigh optical depth  at plane level 		= trmoyp
+       the altitude of the plane 				= palt
+       the rayleigh optical depth for total atmos		= trmoy
+       the aerosol  optical depth for total atmos		= tamoy
+       if not plane observations then ha is equal to 2.0km
+       ntp local variable: if ntp=nt     no plane observation selected
+       ntp=nt-1   plane observation selected
+       it's a mixing rayleigh+aerosol */
-	float ha = 2;
-	int snt = nt;
-	int ntp = snt;
-	if(alt.palt <= 900 && alt.palt > 0)
-		if(tap > 1.e-03) ha = -alt.palt / (float)log(tap / tamoy);
-		ntp = snt - 1;
+    float ha = 2;
+    int snt = nt;
+    int ntp = snt;
+    if(alt.palt <= 900 && alt.palt > 0)
+	if(tap > 1.e-03) ha = -alt.palt / (float)log(tap / tamoy);
+	ntp = snt - 1;
-	float xmus = -gauss.rm[STDI(0)];
+    float xmus = -gauss.rm[STDI(0)];
-	/* compute mixing rayleigh, aerosol
-	 case 1: pure rayleigh
-	 case 2: pure aerosol
-	 case 3: mixing rayleigh-aerosol */
+    /* compute mixing rayleigh, aerosol
+       case 1: pure rayleigh
+       case 2: pure aerosol
+       case 3: mixing rayleigh-aerosol */
-	float h[31];
+    float h[31];
     memset(h, 0, sizeof(h));
-	float ch[31];
-	float ydel[31];
+    float ch[31];
+    float ydel[31];
-	float xdel[31];
-	float altc[31];
-	if( (tamoy <= accu2) && (trmoy > tamoy) )
+    float xdel[31];
+    float altc[31];
+    if( (tamoy <= accu2) && (trmoy > tamoy) )
+	for(int j = 0; j <= ntp; j++)
-		for(int j = 0; j <= ntp; j++)
-			h[j] = j * trmoy / ntp;
-			ch[j]= (float)exp(-h[j] / xmus) / 2;
-			ydel[j] = 1;
-			xdel[j] = 0;
+	    h[j] = j * trmoy / ntp;
+	    ch[j]= (float)exp(-h[j] / xmus) / 2;
+	    ydel[j] = 1;
+	    xdel[j] = 0;
-			if (j == 0) altc[j] = 300;
-		    else altc[j] = -(float)log(h[j] / trmoy) * 8;
+	    if (j == 0) altc[j] = 300;
+	    else altc[j] = -(float)log(h[j] / trmoy) * 8;
     if( (trmoy <= accu2) && (tamoy > trmoy) )
-			h[j] = j * tamoy / ntp;
-			ydel[j] = 0;
-			xdel[j] = pizmoy;
+	    h[j] = j * tamoy / ntp;
+	    ydel[j] = 0;
+	    xdel[j] = pizmoy;
-			else altc[j] = -(float)log(h[j] / tamoy) * ha;
+	    else altc[j] = -(float)log(h[j] / tamoy) * ha;
     if(trmoy > accu2 && tamoy > accu2)
+	ydel[0] = 1;
+	xdel[0] = 0;
+	h[0] = 0;
+	ch[0] = 0.5;
+	altc[0] = 300;
+	float zx = 300;
+	iplane = 0;
+	for(int it = 0; it <= ntp; it++)
-		ydel[0] = 1;
-		xdel[0] = 0;
-		h[0] = 0;
-		ch[0] = 0.5;
-		altc[0] = 300;
-		float zx = 300;
-		iplane = 0;
+	    if(it == 0) zx = discre(tamoy, ha, trmoy, 8.0, it, ntp, 0, 0, 300, 0);
+	    else zx = discre(tamoy, ha, trmoy, 8.0, it, ntp, h[it - 1], ydel[it - 1], 300, 0);
-		for(int it = 0; it <= ntp; it++)
-			if(it == 0) zx = discre(tamoy, ha, trmoy, 8.0, it, ntp, 0, 0, 300, 0);
-			else zx = discre(tamoy, ha, trmoy, 8.0, it, ntp, h[it - 1], ydel[it - 1], 300, 0);
+	    double xx = -zx / ha;
+	    float ca;
+	    if( xx <= -20 ) ca = 0;
+	    else ca = tamoy * (float)exp(xx);
-			double xx = -zx / ha;
-			float ca;
-			if( xx <= -20 ) ca = 0;
-			else ca = tamoy * (float)exp(xx);
+	    xx = -zx / 8;
+	    float cr = trmoy * (float)exp(xx);
+	    h[it] = cr + ca;
-			xx = -zx / 8;
-			float cr = trmoy * (float)exp(xx);
-			h[it] = cr + ca;
-		    altc[it] = zx;
-			ch[it] = (float)exp(-h[it] / xmus) / 2;
-			cr = cr / 8;
-			ca = ca / ha;
-			float ratio = cr / (cr + ca);
-			xdel[it] = (1 - ratio) * pizmoy;
-			ydel[it] = ratio;
+	    altc[it] = zx;
+	    ch[it] = (float)exp(-h[it] / xmus) / 2;
+	    cr = cr / 8;
+	    ca = ca / ha;
+	    float ratio = cr / (cr + ca);
+	    xdel[it] = (1 - ratio) * pizmoy;
+	    ydel[it] = ratio;
-	/* update plane layer if necessary */
-	if (ntp == (snt - 1))
-		/* compute position of the plane layer */
+    /* update plane layer if necessary */
+    if (ntp == (snt - 1))
+	/* compute position of the plane layer */
         float taup = tap + trp;
         iplane = -1;
-		for(int i = 0; i <= ntp; i++) if (taup >= h[i]) iplane = i;
+	for(int i = 0; i <= ntp; i++) if (taup >= h[i]) iplane = i;
-		/* update the layer from the end to the position to update if necessary */
-		float xt1 = (float)fabs(h[iplane] - taup);
+	/* update the layer from the end to the position to update if necessary */
+	float xt1 = (float)fabs(h[iplane] - taup);
         float xt2 = (float)fabs(h[iplane+1] - taup);
         if ((xt1 > 0.0005) && (xt2 > 0.0005))
-			for(int i = snt; i >= iplane+1; i--)
-				xdel[i] = xdel[i-1];
-				ydel[i] = ydel[i-1];
-				h[i] = h[i-1];
-				altc[i] = altc[i-1];
-				ch[i] = ch[i-1];
+	    for(int i = snt; i >= iplane+1; i--)
+		xdel[i] = xdel[i-1];
+		ydel[i] = ydel[i-1];
+		h[i] = h[i-1];
+		altc[i] = altc[i-1];
+		ch[i] = ch[i-1];
         else
-			snt = ntp;
-			if (xt2 > xt1) iplane++;
+	    snt = ntp;
+	    if (xt2 > xt1) iplane++;
-		h[iplane] = taup;
-		if ( trmoy > accu2 && tamoy > accu2 )
+	h[iplane] = taup;
+	if ( trmoy > accu2 && tamoy > accu2 )
-			float ca = tamoy * (float)exp(-alt.palt / ha);
-			float cr = trmoy * (float)exp(-alt.palt / 8);
-			h[iplane] = ca + cr;
-			cr = cr / 8;
-			ca = ca / ha;
-			xdel[iplane] = (1 - ratio) * pizmoy;
-			ydel[iplane] = ratio;
-			altc[iplane] = alt.palt;
-			ch[iplane] = (float)exp(-h[iplane] / xmus) / 2;
+	    float ca = tamoy * (float)exp(-alt.palt / ha);
+	    float cr = trmoy * (float)exp(-alt.palt / 8);
+	    h[iplane] = ca + cr;
+	    cr = cr / 8;
+	    ca = ca / ha;
+	    xdel[iplane] = (1 - ratio) * pizmoy;
+	    ydel[iplane] = ratio;
+	    altc[iplane] = alt.palt;
+	    ch[iplane] = (float)exp(-h[iplane] / xmus) / 2;
-		if ( trmoy > accu2 && tamoy <= accu2 )
-			ydel[iplane] = 1;
-			xdel[iplane] = 0;
+	if ( trmoy > accu2 && tamoy <= accu2 )
+	    ydel[iplane] = 1;
+	    xdel[iplane] = 0;
-		if ( trmoy <= accu2 && tamoy > accu2 )
-			ydel[iplane] = 0;
-			xdel[iplane] = pizmoy;
+	if ( trmoy <= accu2 && tamoy > accu2 )
+	    ydel[iplane] = 0;
+	    xdel[iplane] = pizmoy;
-	float phi = (float)geom.phirad;
-	int i;
-	for(i = 0; i < np; i++) for(int m = -mu; m <= mu; m++) xl[STDI(m)][i] = 0;
+    float phi = (float)geom.phirad;
+    int i;
+    for(i = 0; i < np; i++) for(int m = -mu; m <= mu; m++) xl[STDI(m)][i] = 0;
-	/* ************ incident angle mus ******* */
+    /* ************ incident angle mus ******* */
     float aaaa = delta / (2 - delta);
     float ron = (1 - aaaa) / (1 + 2 * aaaa);
-	/* rayleigh phase function */
+    /* rayleigh phase function */
     float beta0 = 1;
-	float beta2 = 0.5f * ron;
+    float beta2 = 0.5f * ron;
-	/* fourier decomposition */
-	float i1[31][2*mu + 1];
-	float i2[31][2*mu + 1];
-	float i3[2*mu + 1];
-	float i4[2*mu + 1];
-	float in[2*mu + 1];
-	float inm1[2*mu + 1];
-	float inm2[2*mu + 1];
-	for(i = -mu; i <= mu; i++) i4[STDI(i)] = 0;
+    /* fourier decomposition */
+    float i1[31][2*mu + 1];
+    float i2[31][2*mu + 1];
+    float i3[2*mu + 1];
+    float i4[2*mu + 1];
+    float in[2*mu + 1];
+    float inm1[2*mu + 1];
+    float inm2[2*mu + 1];
+    for(i = -mu; i <= mu; i++) i4[STDI(i)] = 0;
-	int iborm = 80;
+    int iborm = 80;
     if(fabs(xmus - 1.000000) < 1e-06) iborm = 0;
-	for(int is = 0; is <= iborm; is++)
-		/* primary scattering */
-		int ig = 1;
-		float roavion0 = 0;
-		float roavion1 = 0;
-		float roavion2 = 0;
-		float roavion = 0;
+    for(int is = 0; is <= iborm; is++)
+	/* primary scattering */
+	int ig = 1;
+	float roavion0 = 0;
+	float roavion1 = 0;
+	float roavion2 = 0;
+	float roavion = 0;
-		int j;
-		for(j = -mu; j <= mu; j++) i3[STDI(j)] = 0;
+	int j;
+	for(j = -mu; j <= mu; j++) i3[STDI(j)] = 0;
-		/* kernel computations */
-		float xpl[2*mu + 1];
-		float bp[26][2*mu + 1];
-		memset(xpl, 0, sizeof(float)*(2*mu+1));
-		memset(bp, 0, sizeof(float)*26*(2*mu+1));
+	/* kernel computations */
+	float xpl[2*mu + 1];
+	float bp[26][2*mu + 1];
+	memset(xpl, 0, sizeof(float)*(2*mu+1));
+	memset(bp, 0, sizeof(float)*26*(2*mu+1));
-		kernel(is,xpl,bp,gauss);
+	kernel(is,xpl,bp,gauss);
-		if(is > 0) beta0 = 0;
+	if(is > 0) beta0 = 0;
-			float sa1;
-			float sa2;
+	    float sa1;
+	    float sa2;
-			if((is - 2) <= 0)
-				float spl = xpl[STDI(0)];
-				sa1 = beta0 + beta2 * xpl[STDI(j)] * spl;
-				sa2 = bp[0][STDI(j)];
-			else
-				sa1 = 0;
-			/* primary scattering source function at every level within the layer */
+	    if((is - 2) <= 0)
+		float spl = xpl[STDI(0)];
+		sa1 = beta0 + beta2 * xpl[STDI(j)] * spl;
+		sa2 = bp[0][STDI(j)];
+	    else
+		sa1 = 0;
+	    /* primary scattering source function at every level within the layer */
-			for(int k = 0; k <= snt; k++)
-				float c = ch[k];
-				double a = ydel[k];
-				double b = xdel[k];
-				i2[k][STDI(j)] = (float)(c * (sa2 * b + sa1 * a));
+	    for(int k = 0; k <= snt; k++)
+		float c = ch[k];
+		double a = ydel[k];
+		double b = xdel[k];
+		i2[k][STDI(j)] = (float)(c * (sa2 * b + sa1 * a));
-		int k;
-		/* vertical integration, primary upward radiation */
-		for(k = 1; k <= mu; k++)
-			i1[snt][STDI(k)] = 0;
-			float zi1 = i1[snt][STDI(k)];
+	int k;
+	/* vertical integration, primary upward radiation */
+	for(k = 1; k <= mu; k++)
+	    i1[snt][STDI(k)] = 0;
+	    float zi1 = i1[snt][STDI(k)];
-			for(int i = snt - 1; i >= 0; i--)
-				float f = h[i + 1] - h[i];
-				double a = (i2[i + 1][STDI(k)] - i2[i][STDI(k)]) / f;
-				double b = i2[i][STDI(k)] - a * h[i];
-				float c = (float)exp(-f / gauss.rm[STDI(k)]);
+	    for(int i = snt - 1; i >= 0; i--)
+		float f = h[i + 1] - h[i];
+		double a = (i2[i + 1][STDI(k)] - i2[i][STDI(k)]) / f;
+		double b = i2[i][STDI(k)] - a * h[i];
+		float c = (float)exp(-f / gauss.rm[STDI(k)]);
-				double xx = h[i] - h[i + 1] * c;
-				zi1 = (float)(c * zi1 + ((1 - c) * (b + a * gauss.rm[STDI(k)]) + a * xx) / 2);
-				i1[i][STDI(k)] = zi1;
+		double xx = h[i] - h[i + 1] * c;
+		zi1 = (float)(c * zi1 + ((1 - c) * (b + a * gauss.rm[STDI(k)]) + a * xx) / 2);
+		i1[i][STDI(k)] = zi1;
-		/* vertical integration, primary downward radiation */
-		for(k = -mu; k <= -1; k++)
-			i1[0][STDI(k)] = 0;
-			float zi1 = i1[0][STDI(k)];
+	/* vertical integration, primary downward radiation */
+	for(k = -mu; k <= -1; k++)
+	    i1[0][STDI(k)] = 0;
+	    float zi1 = i1[0][STDI(k)];
-			for(int i = 1; i <= snt; i++)
-				float f = h[i] - h[i - 1];
-				float c = (float)exp(f / gauss.rm[STDI(k)]);
-				double a = (i2[i][STDI(k)] -i2[i - 1][STDI(k)]) / f;
-				double xx = h[i] - h[i - 1] * c;
-				zi1 = (float)(c * zi1 + ((1 - c) * (b + a * gauss.rm[STDI(k)]) + a * xx)/ 2);
+	    for(int i = 1; i <= snt; i++)
+		float f = h[i] - h[i - 1];
+		float c = (float)exp(f / gauss.rm[STDI(k)]);
+		double a = (i2[i][STDI(k)] -i2[i - 1][STDI(k)]) / f;
+		double xx = h[i] - h[i - 1] * c;
+		zi1 = (float)(c * zi1 + ((1 - c) * (b + a * gauss.rm[STDI(k)]) + a * xx)/ 2);
-		/* inm2 is inialized with scattering computed at n-2
-		 i3 is inialized with primary scattering */
-		for(k = -mu; k <= mu; k++)
-			if(k < 0)
-				inm1[STDI(k)] = i1[snt][STDI(k)];
-				inm2[STDI(k)] = i1[snt][STDI(k)];
-				i3[STDI(k)] = i1[snt][STDI(k)];
-			else if(k > 0)
-				inm1[STDI(k)] = i1[0][STDI(k)];
-				inm2[STDI(k)] = i1[0][STDI(k)];
-				i3[STDI(k)] = i1[0][STDI(k)];
-		roavion2 = i1[iplane][STDI(mu)];
-		roavion = i1[iplane][STDI(mu)];
+	/* inm2 is inialized with scattering computed at n-2
+	   i3 is inialized with primary scattering */
+	for(k = -mu; k <= mu; k++)
+	    if(k < 0)
+		inm1[STDI(k)] = i1[snt][STDI(k)];
+		inm2[STDI(k)] = i1[snt][STDI(k)];
+		i3[STDI(k)] = i1[snt][STDI(k)];
+	    else if(k > 0)
+		inm1[STDI(k)] = i1[0][STDI(k)];
+		inm2[STDI(k)] = i1[0][STDI(k)];
+		i3[STDI(k)] = i1[0][STDI(k)];
+	roavion2 = i1[iplane][STDI(mu)];
+	roavion = i1[iplane][STDI(mu)];
         do
-			/* loop on successive order */
-			ig++;
+	    /* loop on successive order */
+	    ig++;
-			/* successive orders
-			 multiple scattering source function at every level within the laye
-			 if is < ou = 2 kernels are a mixing of aerosols and molecules kern
-			 if is >2 aerosols kernels only */
+	    /* successive orders
+	       multiple scattering source function at every level within the laye
+	       if is < ou = 2 kernels are a mixing of aerosols and molecules kern
+	       if is >2 aerosols kernels only */
-			if(is - 2 <= 0)
+	    if(is - 2 <= 0)
+		for(int k = 1; k <= mu; k++)
+		    for(int i = 0; i <= snt; i++)
+			double ii1 = 0;
+			double ii2 = 0;
+			for(int j = 1; j <= mu; j++)
-				for(int k = 1; k <= mu; k++)
-					for(int i = 0; i <= snt; i++)
-						double ii1 = 0;
-						double ii2 = 0;
-						for(int j = 1; j <= mu; j++)
-							double bpjk = bp[j][STDI(k)] * xdel[i] + ydel[i] * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(k)]);
-							double bpjmk = bp[j][STDI(-k)] * xdel[i] + ydel[i] * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(-k)]);
-							double xdb = gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjk + i1[i][STDI(-j)] * bpjmk);
-							ii2 += xdb;
-							xdb = gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjmk + i1[i][STDI(-j)] * bpjk);
-							ii1 += xdb;
+			    double bpjk = bp[j][STDI(k)] * xdel[i] + ydel[i] * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(k)]);
+			    double bpjmk = bp[j][STDI(-k)] * xdel[i] + ydel[i] * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(-k)]);
+			    double xdb = gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjk + i1[i][STDI(-j)] * bpjmk);
+			    ii2 += xdb;
+			    xdb = gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjmk + i1[i][STDI(-j)] * bpjk);
+			    ii1 += xdb;
-						if (ii2 < 1e-30) ii2 = 0;
-						if (ii1 < 1e-30) ii1 = 0;
-						i2[i][STDI(k)] = (float)ii2;
-						i2[i][STDI(-k)]= (float)ii1;
-			else
-					double ii1;
-					double ii2;
+			if (ii2 < 1e-30) ii2 = 0;
+			if (ii1 < 1e-30) ii1 = 0;
+			i2[i][STDI(k)] = (float)ii2;
+			i2[i][STDI(-k)]= (float)ii1;
+	    else
+		    double ii1;
+		    double ii2;
-						ii1 = 0;
-						ii2 = 0;
+			ii1 = 0;
+			ii2 = 0;
-							double bpjk = bp[j][STDI(k)] * xdel[i];
-							double bpjmk = bp[j][STDI(-k)] * xdel[i];
-							ii2 += xdb;
-							ii1 += xdb;
-						i2[i][STDI(-k)] = (float)ii1;
+			    double bpjk = bp[j][STDI(k)] * xdel[i];
+			    double bpjmk = bp[j][STDI(-k)] * xdel[i];
+			    ii2 += xdb;
+			    ii1 += xdb;
+			i2[i][STDI(-k)] = (float)ii1;
-			/* vertical integration, upward radiation */
-			int k;
+	    /* vertical integration, upward radiation */
+	    int k;
-				for(int i = snt-1; i >= 0; i--)
-					if (fabs(zi1) <= 1e-20) zi1 = 0;
+		for(int i = snt-1; i >= 0; i--)
+		    if (fabs(zi1) <= 1e-20) zi1 = 0;
-			/* vertical integration, downward radiation */
+	    /* vertical integration, downward radiation */
-					double a = (i2[i][STDI(k)] - i2[i - 1][STDI(k)]) / f;
+		    double a = (i2[i][STDI(k)] - i2[i - 1][STDI(k)]) / f;
-			/* in is the nieme scattering order */
-				if(k < 0) in[STDI(k)] = i1[snt][STDI(k)];
-				else if(k > 0) in[STDI(k)] = i1[0][STDI(k)];
-			roavion0 = i1[iplane][STDI(mu)];
+	    /* in is the nieme scattering order */
+		if(k < 0) in[STDI(k)] = i1[snt][STDI(k)];
+		else if(k > 0) in[STDI(k)] = i1[0][STDI(k)];
+	    roavion0 = i1[iplane][STDI(mu)];
-			/*  convergence test (geometrical serie) */
-			if(ig > 2)
-				float a1 = roavion2;
-				float d1 = roavion1;
+	    /*  convergence test (geometrical serie) */
+	    if(ig > 2)
+		float a1 = roavion2;
+		float d1 = roavion1;
-				float g1 = roavion0;
+		float g1 = roavion0;
-				double z = 0;
-				if(a1 >= accu && d1 >= accu && roavion >= accu)
-					double y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / roavion));
-					y = fabs(y);
-					z = y > z ? y : z;
+		double z = 0;
+		if(a1 >= accu && d1 >= accu && roavion >= accu)
+		    double y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / roavion));
+		    y = fabs(y);
+		    z = y > z ? y : z;
-				for(int l = -mu; l <= mu; l++)
-					if (l == 0) continue;
-					a1 = inm2[STDI(l)];
-					d1 = inm1[STDI(l)];
-					g1 = in[STDI(l)];
-					if(a1 <= accu) continue;
-					if(d1 <= accu) continue;
-					if(i3[STDI(l)] <= accu) continue;
+		for(int l = -mu; l <= mu; l++)
+		    if (l == 0) continue;
+		    a1 = inm2[STDI(l)];
+		    d1 = inm1[STDI(l)];
+		    g1 = in[STDI(l)];
+		    if(a1 <= accu) continue;
+		    if(d1 <= accu) continue;
+		    if(i3[STDI(l)] <= accu) continue;
-					double y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / i3[STDI(l)]));
-					y = fabs(y);
+		    double y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / i3[STDI(l)]));
+		    y = fabs(y);
-				if(z < 0.0001)
-					/* successful test (geometrical serie) */
-					float y1;
+		if(z < 0.0001)
+		    /* successful test (geometrical serie) */
+		    float y1;
-						y1 = 1;
-						g1 = in[STDI(l)];
-						y1 = 1 - g1 / d1;
-						if(fabs(g1 - d1) <= accu) continue;
-						g1 /= y1;
-						i3[STDI(l)] += g1;
+			y1 = 1;
+			g1 = in[STDI(l)];
+			y1 = 1 - g1 / d1;
+			if(fabs(g1 - d1) <= accu) continue;
+			g1 /= y1;
+			i3[STDI(l)] += g1;
-					d1 = roavion1;
-					g1 = roavion0;
-					y1 = 1;
-					if(d1 >= accu)
-						if(fabs(g1 - d1) >= accu)
-							y1 = 1 - g1 / d1;
-							g1 /= y1;
+		    d1 = roavion1;
+		    g1 = roavion0;
+		    y1 = 1;
+		    if(d1 >= accu)
+			if(fabs(g1 - d1) >= accu)
+			    y1 = 1 - g1 / d1;
+			    g1 /= y1;
-						roavion += g1;
+			roavion += g1;
-					break;	/* break out of the while loop */
+		    break;	/* break out of the while loop */
-				/* inm2 is the (n-2)ieme scattering order */
-				for(int k = -mu; k <= mu; k++) inm2[STDI(k)] = inm1[STDI(k)];
-				roavion2 = roavion1;
+		/* inm2 is the (n-2)ieme scattering order */
+		for(int k = -mu; k <= mu; k++) inm2[STDI(k)] = inm1[STDI(k)];
+		roavion2 = roavion1;
-			/* inm1 is the (n-1)ieme scattering order */
-			for(k = -mu; k <= mu; k++) inm1[STDI(k)] = in[STDI(k)];
-			roavion1 = roavion0;
+	    /* inm1 is the (n-1)ieme scattering order */
+	    for(k = -mu; k <= mu; k++) inm1[STDI(k)] = in[STDI(k)];
+	    roavion1 = roavion0;
-			/* sum of the n-1 orders */
-			for(k = -mu; k <= mu; k++) i3[STDI(k)] += in[STDI(k)];
-			roavion += roavion0;
+	    /* sum of the n-1 orders */
+	    for(k = -mu; k <= mu; k++) i3[STDI(k)] += in[STDI(k)];
+	    roavion += roavion0;
-			/* stop if order n is less than 1% of the sum */
-			double z = 0;
-				if (fabs(i3[STDI(k)]) >= accu)
-					double y = fabs(in[STDI(k)] / i3[STDI(k)]);
-					z = z >= y ? z : y;
-			if(z < 0.00001) break;
+	    /* stop if order n is less than 1% of the sum */
+	    double z = 0;
+		if (fabs(i3[STDI(k)]) >= accu)
+		    double y = fabs(in[STDI(k)] / i3[STDI(k)]);
+		    z = z >= y ? z : y;
+	    if(z < 0.00001) break;
-		} while( ig <= 20 );	/* stop if order n is greater than 20 in any case */
+	} while( ig <= 20 );	/* stop if order n is greater than 20 in any case */
-		/* sum of the fourier component s */
-		float delta0s = 1;
-		if(is != 0) delta0s = 2;
-		for(k = -mu; k <= mu; k++) i4[STDI(k)] += delta0s * i3[STDI(k)];
+	/* sum of the fourier component s */
+	float delta0s = 1;
+	if(is != 0) delta0s = 2;
+	for(k = -mu; k <= mu; k++) i4[STDI(k)] += delta0s * i3[STDI(k)];
-		/* stop of the fourier decomposition */
-		int l;
-		for(l = 0; l < np; l++)
-			phi = gauss.rp[l];
+	/* stop of the fourier decomposition */
+	int l;
+	for(l = 0; l < np; l++)
+	    phi = gauss.rp[l];
-			for(int m = -mum1; m <= mum1; m++)
-				if(m > 0) xl[STDI(m)][l] += (float)(delta0s * i3[STDI(m)] * cos(is * (phi + M_PI)));
-				else xl[STDI(m)][l] += (float)(delta0s * i3[STDI(m)] * cos(is * phi));
+	    for(int m = -mum1; m <= mum1; m++)
+		if(m > 0) xl[STDI(m)][l] += (float)(delta0s * i3[STDI(m)] * cos(is * (phi + M_PI)));
+		else xl[STDI(m)][l] += (float)(delta0s * i3[STDI(m)] * cos(is * phi));
-		if(is == 0)
-			for(int k = 1; k <= mum1; k++) xl[STDI(0)][0] += gauss.rm[STDI(k)] * gauss.gb[STDI(k)] * i3[STDI(-k)];
+	if(is == 0)
+	    for(int k = 1; k <= mum1; k++) xl[STDI(0)][0] += gauss.rm[STDI(k)] * gauss.gb[STDI(k)] * i3[STDI(-k)];
-		xl[STDI(mu)][0] += (float)(delta0s * i3[STDI(mu)] * cos(is * (geom.phirad + M_PI)));
-		xl[STDI(-mu)][0] += (float)(delta0s * roavion * cos(is * (geom.phirad + M_PI)));
+	xl[STDI(mu)][0] += (float)(delta0s * i3[STDI(mu)] * cos(is * (geom.phirad + M_PI)));
+	xl[STDI(-mu)][0] += (float)(delta0s * roavion * cos(is * (geom.phirad + M_PI)));
-		double z = 0;
-		for(l = -mu; l <= mu; l++)
+	double z = 0;
+	for(l = -mu; l <= mu; l++)
             if(l == 0) continue;
-			if (fabs(i4[STDI(l)]) > accu) continue;
-			double x = fabs(i3[STDI(l)] / i4[STDI(l)]);
-			z = z > x ? z : x;
+	    if (fabs(i4[STDI(l)]) > accu) continue;
+	    double x = fabs(i3[STDI(l)] / i4[STDI(l)]);
+	    z = z > x ? z : x;
-		if(z <= 0.001) break;
+	if(z <= 0.001) break;
-Compute the atmospheric transmission for either a satellite or aircraft observation
-as well as the spherical albedo of the atmosphere.
+  Compute the atmospheric transmission for either a satellite or aircraft observation
+  as well as the spherical albedo of the atmosphere.
 void iso(const float tamoy, const float trmoy, const float pizmoy,
-		 const float tamoyp, const float trmoyp, float (&xf)[3],
+	 const float tamoyp, const float trmoyp, float (&xf)[3],
          Gauss &gauss, const Altitude &alt)
-	/* molecular ratio within the layer
-	 computations are performed assuming a scale of 8km for
-	 molecules and 2km for aerosols */
+    /* molecular ratio within the layer
+       computations are performed assuming a scale of 8km for
+       molecules and 2km for aerosols */
-	/* the optical thickness above plane are recomputed to give o.t above pla */
+    /* the optical thickness above plane are recomputed to give o.t above pla */
-	 sntp local variable: if sntp=snt     no plane observation selected
-	                        sntp=snt-1   plane observation selected */
+       sntp local variable: if sntp=snt     no plane observation selected
+       sntp=snt-1   plane observation selected */
-	/* it's a mixing rayleigh+aerosol */
-	int snt = nt;
-	int iplane = 0;
-	int ntp = snt;
-	float ha = 2.0;
-	if(alt.palt <= 900. && alt.palt > 0.0)
-		if (tap > 1.e-03) ha = (float)(-alt.palt / log(tap / tamoy));
+    /* it's a mixing rayleigh+aerosol */
+    int snt = nt;
+    int iplane = 0;
+    int ntp = snt;
+    float ha = 2.0;
+    if(alt.palt <= 900. && alt.palt > 0.0)
+	if (tap > 1.e-03) ha = (float)(-alt.palt / log(tap / tamoy));
         else ha = 2.;
-		ntp = snt - 1;
+	ntp = snt - 1;
-	float h[31];
-	float ydel[31];
-	float xdel[31];
-	float altc[31];
+    float h[31];
+    float ydel[31];
+    float xdel[31];
+    float altc[31];
-	if((tamoy <= accu2) && (trmoy > tamoy))
+    if((tamoy <= accu2) && (trmoy > tamoy))
-			ydel[j] = 1.0;
-			xdel[j] = 0.0;
+	    ydel[j] = 1.0;
+	    xdel[j] = 0.0;
-	if((trmoy <= accu2) && (tamoy > trmoy))
+    if((trmoy <= accu2) && (tamoy > trmoy))
-			ydel[j] = 0.0;
-			xdel[j] = pizmoy;
+	    ydel[j] = 0.0;
+	    xdel[j] = pizmoy;
-	if(trmoy > accu2 && tamoy > accu2)
-		ydel[0] = 1.0;
-		xdel[0] = 0.0;
-		h[0] = 0;
-		altc[0] = 300;
-		float zx = 300;
-		iplane = 0;
+    if(trmoy > accu2 && tamoy > accu2)
+	ydel[0] = 1.0;
+	xdel[0] = 0.0;
+	h[0] = 0;
+	altc[0] = 300;
+	float zx = 300;
+	iplane = 0;
-			if (it == 0) zx = discre(tamoy,ha,trmoy,8.0,it,ntp,0,0,300.0,0.0);
-			else zx = discre(tamoy,ha,trmoy,8.0,it,ntp,h[it-1],ydel[it-1],300.0,0.0);
+	    if (it == 0) zx = discre(tamoy,ha,trmoy,8.0,it,ntp,0,0,300.0,0.0);
+	    else zx = discre(tamoy,ha,trmoy,8.0,it,ntp,h[it-1],ydel[it-1],300.0,0.0);
-			float ca;
-			if ((-zx / ha) < -18) ca = 0;
-			else ca = (float)(tamoy * exp(-zx / ha));
+	    float ca;
+	    if ((-zx / ha) < -18) ca = 0;
+	    else ca = (float)(tamoy * exp(-zx / ha));
-			float cr = (float)(trmoy * exp(-zx / 8.0));
-			h[it] = cr + ca;
-			altc[it] = zx;
+	    float cr = (float)(trmoy * exp(-zx / 8.0));
+	    h[it] = cr + ca;
+	    altc[it] = zx;
-			cr = cr / 8;
-			ca = ca / ha;
-			ydel[it] = ratio;
+	    cr = cr / 8;
+	    ca = ca / ha;
+	    ydel[it] = ratio;
-	if (ntp == (snt-1))
-		float taup = tap + trp;
+    if (ntp == (snt-1))
+	float taup = tap + trp;
         iplane = -1;
         float xt2 = (float)fabs(h[iplane + 1] - taup);
         if ((xt1 > 0.005) && (xt2 > 0.005))
-			for(int i = snt; i >= iplane + 1; i--)
+	    for(int i = snt; i >= iplane + 1; i--)
-				h[i] = h[i-1];
+		h[i] = h[i-1];
         else
-			snt = ntp;
-			if (xt2 < xt1) iplane = iplane + 1;
+	    snt = ntp;
+	    if (xt2 < xt1) iplane = iplane + 1;
-		h[iplane] = taup;
-		if ( trmoy > accu2 && tamoy > accu2)
-			float ca = (float)(tamoy * exp(-alt.palt / ha));
-			float cr = (float)(trmoy * exp(-alt.palt / 8.0));
-			cr = cr / 8;
-			ca = ca / ha;
+	h[iplane] = taup;
+	if ( trmoy > accu2 && tamoy > accu2)
+	    float ca = (float)(tamoy * exp(-alt.palt / ha));
+	    float cr = (float)(trmoy * exp(-alt.palt / 8.0));
+	    cr = cr / 8;
+	    ca = ca / ha;
-		if ( trmoy > accu2 && tamoy <= accu2)
-			ydel[iplane] = 1;
-			xdel[iplane] = 0;
+	if ( trmoy > accu2 && tamoy <= accu2)
+	    ydel[iplane] = 1;
+	    xdel[iplane] = 0;
-		if ( trmoy <= accu2 && tamoy > accu2)
-			ydel[iplane] = 0;
-			xdel[iplane] = 1 * pizmoy;
+	if ( trmoy <= accu2 && tamoy > accu2)
+	    ydel[iplane] = 0;
+	    xdel[iplane] = 1 * pizmoy;
-	float aaaa = delta / (2-delta);
-	float ron = (1 - aaaa) / (1 + 2 * aaaa);
+    float aaaa = delta / (2-delta);
+    float ron = (1 - aaaa) / (1 + 2 * aaaa);
-	float beta0 = 1;
+    float beta0 = 1;
-	int ig = 1;
-	float tavion0 = 0;
-	float tavion1 = 0;
-	float tavion2 = 0;
-	float tavion = 0;
+    int ig = 1;
+    float tavion0 = 0;
+    float tavion1 = 0;
+    float tavion2 = 0;
+    float tavion = 0;
-	int j;
+    int j;
-	kernel(0, xpl, bp, gauss);
+    kernel(0, xpl, bp, gauss);
-		for(int k = 0; k <= snt; k++) i2[k][STDI(j)] = 0;
+	for(int k = 0; k <= snt; k++) i2[k][STDI(j)] = 0;
-	int k;
-		i1[snt][STDI(k)] = 1.0;
-			i1[i][STDI(k)] = (float)(exp(-(tamoy + trmoy - h[i]) / gauss.rm[STDI(k)]));
+    int k;
+	i1[snt][STDI(k)] = 1.0;
+	    i1[i][STDI(k)] = (float)(exp(-(tamoy + trmoy - h[i]) / gauss.rm[STDI(k)]));
-		for(int i = 0; i <= snt; i++) i1[i][STDI(k)] = 0.0;
+	for(int i = 0; i <= snt; i++) i1[i][STDI(k)] = 0.0;
+	if(k == 0) continue;
+	if(k < 0)
-		if(k == 0) continue;
-		if(k < 0)
-		else
-	tavion = i1[iplane][STDI(mu)];
-	tavion2 = i1[iplane][STDI(mu)];
+	else
+    tavion = i1[iplane][STDI(mu)];
+    tavion2 = i1[iplane][STDI(mu)];
-	do {
-		ig = ig++;
+    do {
+	ig = ig++;
-		  multiple scattering source function at every level within the laye */
+	   multiple scattering source function at every level within the laye */
+		double ii1 = 0;
+		double ii2 = 0;
+		float x = xdel[i];
+		float y = ydel[i];
-				double ii1 = 0;
-				double ii2 = 0;
-				float x = xdel[i];
-				float y = ydel[i];
+		    float bpjk = bp[j][STDI(k)] * x + y * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(k)]);
+		    float bpjmk= bp[j][STDI(-k)] * x + y * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(-k)]);
+		    ii2 += gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjk + i1[i][STDI(-j)] * bpjmk);
+		    ii1 += gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjmk + i1[i][STDI(-j)] * bpjk);
-					float bpjk = bp[j][STDI(k)] * x + y * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(k)]);
-					float bpjmk= bp[j][STDI(-k)] * x + y * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(-k)]);
-					ii2 += gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjk + i1[i][STDI(-j)] * bpjmk);
-					ii1 += gauss.gb[STDI(j)] * (i1[i][STDI(j)] * bpjmk + i1[i][STDI(-j)] * bpjk);
-			i1[snt][STDI(k)] = 0.0;
+	    i1[snt][STDI(k)] = 0.0;
-				float f = h[i+1] - h[i];
-				float a = (i2[i+1][STDI(k)] -i2[i][STDI(k)]) / f;
-				float b = i2[i][STDI(k)] - a * h[i];
-				float xx = h[i] - h[i+1] * c;
+		float f = h[i+1] - h[i];
+		float a = (i2[i+1][STDI(k)] -i2[i][STDI(k)]) / f;
+		float b = i2[i][STDI(k)] - a * h[i];
+		float xx = h[i] - h[i+1] * c;
-				zi1 = c * zi1 + ((1 - c) * (b + a * gauss.rm[STDI(k)]) + a * xx) / 2;
+		zi1 = c * zi1 + ((1 - c) * (b + a * gauss.rm[STDI(k)]) + a * xx) / 2;
-				float f = h[i] - h[i-1];
-				float a = (i2[i][STDI(k)] - i2[i-1][STDI(k)]) / f;
-				float xx = h[i] - h[i-1] * c;
+		float f = h[i] - h[i-1];
+		float a = (i2[i][STDI(k)] - i2[i-1][STDI(k)]) / f;
+		float xx = h[i] - h[i-1] * c;
-			else in[STDI(k)] = i1[0][STDI(k)];
-		tavion0 = i1[iplane][STDI(mu)];
+	    else in[STDI(k)] = i1[0][STDI(k)];
+	tavion0 = i1[iplane][STDI(mu)];
-	    if(ig > 2)
-			float z = 0;
-			float a1 = tavion2;
-			float d1 = tavion1;
-			float g1 = tavion0;
-			if (a1 >= accu && d1 >= accu && tavion >= accu)
-				float y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / tavion));
-				y = (float)fabs(y);
+	if(ig > 2)
+	    float z = 0;
+	    float a1 = tavion2;
+	    float d1 = tavion1;
+	    float g1 = tavion0;
+	    if (a1 >= accu && d1 >= accu && tavion >= accu)
+		float y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / tavion));
+		y = (float)fabs(y);
-				g1 = in[STDI(l)];
-				if(a1 == 0) continue;
-				if(d1 == 0) continue;
-				if(i3[STDI(l)] == 0) continue;
+		g1 = in[STDI(l)];
+		if(a1 == 0) continue;
+		if(d1 == 0) continue;
+		if(i3[STDI(l)] == 0) continue;
-				float y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / i3[STDI(l)]));
+		float y = ((g1 / d1 - d1 / a1) / ((1 - g1 / d1) * (1 - g1 / d1)) * (g1 / i3[STDI(l)]));
-			if(z < 0.0001)
+	    if(z < 0.0001)
-					float y1 = 1;
-					g1 = in[STDI(l)];
-					y1 = 1 - g1 / d1;
-					g1 = g1 / y1;
+		    float y1 = 1;
+		    g1 = in[STDI(l)];
+		    y1 = 1 - g1 / d1;
+		    g1 = g1 / y1;
-				d1 = tavion1;
-				g1 = tavion0;
-				if (d1 >= accu)
-					if (fabs(g1 - d1) >= accu)
-						float y1 = 1 - g1 / d1;
-						g1 = g1 / y1;
-					tavion = tavion + g1;
+		d1 = tavion1;
+		g1 = tavion0;
+		if (d1 >= accu)
+		    if (fabs(g1 - d1) >= accu)
+			float y1 = 1 - g1 / d1;
+			g1 = g1 / y1;
+		    tavion = tavion + g1;
-				break; /* go to 505 */
+		break; /* go to 505 */
-			for(k = -mu; k <= mu; k++) inm2[STDI(k)] = inm1[STDI(k)];
-			tavion2 = tavion1;
+	    for(k = -mu; k <= mu; k++) inm2[STDI(k)] = inm1[STDI(k)];
+	    tavion2 = tavion1;
-		tavion1 = tavion0;
+	tavion1 = tavion0;
-		tavion = tavion + tavion0;
+	tavion = tavion + tavion0;
-		float z = 0;
-			if(i3[STDI(k)] != 0)
-				float y = (float)fabs(in[STDI(k)] / i3[STDI(k)]);
+	float z = 0;
+	    if(i3[STDI(k)] != 0)
+		float y = (float)fabs(in[STDI(k)] / i3[STDI(k)]);
-		/* stop if order n is greater than 20 in any case */
-	} while(ig <= 20);
+	/* stop if order n is greater than 20 in any case */
+    } while(ig <= 20);
-	/* dimension for os computation */
+    /* dimension for os computation */
     xf[0] = tavion;
-	xf[1] = 0;
-	xf[2] = 0;
+    xf[1] = 0;
+    xf[2] = 0;
-	xf[2] += i3[STDI(mu)];
-	for(k = 1; k <= mu; k++) xf[1] += gauss.rm[STDI(k)] * gauss.gb[STDI(k)] * i3[STDI(-k)];
+    xf[2] += i3[STDI(mu)];
+    for(k = 1; k <= mu; k++) xf[1] += gauss.rm[STDI(k)] * gauss.gb[STDI(k)] * i3[STDI(-k)];
-To compute the atmospheric reflectance for the molecular atmosphere in
-case of satellite observation.
+  To compute the atmospheric reflectance for the molecular atmosphere in
+  case of satellite observation.
 float chand(const float xtau, const GeomCond &geom)
-	/* input parameters: xphi,xmus,xmuv,xtau
-	 xphi: azimuthal difference between sun and observation (xphi=0,
-	 in backscattering) and expressed in degree (0.:360.)
-	 xmus: cosine of the sun zenith angle
-	 xmuv: cosine of the observation zenith angle
-	 xtau: molecular optical depth
-	 output parameter: xrray : molecular reflectance (0.:1.)
-	 constant : xdep: depolarization factor (0.0279) */
+    /* input parameters: xphi,xmus,xmuv,xtau
+       xphi: azimuthal difference between sun and observation (xphi=0,
+       in backscattering) and expressed in degree (0.:360.)
+       xmus: cosine of the sun zenith angle
+       xmuv: cosine of the observation zenith angle
+       xtau: molecular optical depth
+       output parameter: xrray : molecular reflectance (0.:1.)
+       constant : xdep: depolarization factor (0.0279) */
-	const float xdep = 0.0279;
+    const float xdep = 0.0279;
-	static const float as0[10] = {
-		.33243832,-6.777104e-02,.16285370,1.577425e-03,-.30924818,
-		-1.240906e-02,-.10324388,3.241678e-02,.11493334,-3.503695e-02
+    static const float as0[10] = {
+	.33243832,-6.777104e-02,.16285370,1.577425e-03,-.30924818,
+	-1.240906e-02,-.10324388,3.241678e-02,.11493334,-3.503695e-02
-	static const float as1[2] = { .19666292, -5.439061e-02 };
-	static const float as2[2] = { .14545937,-2.910845e-02 };
+    static const float as1[2] = { .19666292, -5.439061e-02 };
+    static const float as2[2] = { .14545937,-2.910845e-02 };
-	double phios = (180 - geom.phi);
-	double xcosf1 = 1;
-	double xcosf2 = cos(phios * M_PI / 180);
-	double xcosf3 = cos(2 * phios * M_PI / 180);
+    double phios = (180 - geom.phi);
+    double xcosf1 = 1;
+    double xcosf2 = cos(phios * M_PI / 180);
+    double xcosf3 = cos(2 * phios * M_PI / 180);
-	double xfd = xdep / (2 - xdep);
-	xfd = (1 - xfd) / (1 + 2 * xfd);
+    double xfd = xdep / (2 - xdep);
+    xfd = (1 - xfd) / (1 + 2 * xfd);
-	double xph1 = 1 + (3 * geom.xmus * geom.xmus - 1) * (3 * geom.xmuv * geom.xmuv - 1) * xfd / 8;
-	double xph2 = -geom.xmus * geom.xmuv * sqrt(1 - geom.xmus * geom.xmus) * sqrt(1 - geom.xmuv * geom.xmuv);
-	xph2 *= xfd * 0.75;
-	double xph3 = (1 - geom.xmus * geom.xmus) * (1 - geom.xmuv * geom.xmuv);
-	xph3 *= xfd * 0.1875;
+    double xph1 = 1 + (3 * geom.xmus * geom.xmus - 1) * (3 * geom.xmuv * geom.xmuv - 1) * xfd / 8;
+    double xph2 = -geom.xmus * geom.xmuv * sqrt(1 - geom.xmus * geom.xmus) * sqrt(1 - geom.xmuv * geom.xmuv);
+    xph2 *= xfd * 0.75;
+    double xph3 = (1 - geom.xmus * geom.xmus) * (1 - geom.xmuv * geom.xmuv);
+    xph3 *= xfd * 0.1875;
-	double xitm = (1 - exp(-xtau * (1 / geom.xmus + 1 / geom.xmuv))) * geom.xmus / (4 * (geom.xmus + geom.xmuv));
-	double xp1 = xph1 * xitm;
-	double xp2 = xph2 * xitm;
-	double xp3 = xph3 * xitm;
+    double xitm = (1 - exp(-xtau * (1 / geom.xmus + 1 / geom.xmuv))) * geom.xmus / (4 * (geom.xmus + geom.xmuv));
+    double xp1 = xph1 * xitm;
+    double xp2 = xph2 * xitm;
+    double xp3 = xph3 * xitm;
-	xitm = (1 - exp(-xtau / geom.xmus)) * (1 - exp(-xtau / geom.xmuv));
-	double cfonc1 = xph1 * xitm;
-	double cfonc2 = xph2 * xitm;
-	double cfonc3 = xph3 * xitm;
-	double xlntau = log(xtau);
+    xitm = (1 - exp(-xtau / geom.xmus)) * (1 - exp(-xtau / geom.xmuv));
+    double cfonc1 = xph1 * xitm;
+    double cfonc2 = xph2 * xitm;
+    double cfonc3 = xph3 * xitm;
+    double xlntau = log(xtau);
-	double pl[10];
-	pl[0] = 1;
-	pl[1] = xlntau;
-	pl[2] = geom.xmus + geom.xmuv;
-	pl[3] = xlntau * pl[2];
-	pl[4] = geom.xmus * geom.xmuv;
-	pl[5] = xlntau * pl[4];
-	pl[6] = geom.xmus * geom.xmus + geom.xmuv * geom.xmuv;
-	pl[7] = xlntau * pl[6];
-	pl[8] = geom.xmus * geom.xmus * geom.xmuv * geom.xmuv;
-	pl[9] = xlntau * pl[8];
+    double pl[10];
+    pl[0] = 1;
+    pl[1] = xlntau;
+    pl[2] = geom.xmus + geom.xmuv;
+    pl[3] = xlntau * pl[2];
+    pl[4] = geom.xmus * geom.xmuv;
+    pl[5] = xlntau * pl[4];
+    pl[6] = geom.xmus * geom.xmus + geom.xmuv * geom.xmuv;
+    pl[7] = xlntau * pl[6];
+    pl[8] = geom.xmus * geom.xmus * geom.xmuv * geom.xmuv;
+    pl[9] = xlntau * pl[8];
-	double fs0 = 0;
-	for(int i = 0; i < 10; i++) fs0 += pl[i] * as0[i];
+    double fs0 = 0;
+    for(int i = 0; i < 10; i++) fs0 += pl[i] * as0[i];
-	double fs1 = pl[0] * as1[0] + pl[1] * as1[1];
-	double fs2 = pl[0] * as2[0] + pl[1] * as2[1];
-	double xitot1 = xp1 + cfonc1 * fs0 * geom.xmus;
-	double xitot2 = xp2 + cfonc2 * fs1 * geom.xmus;
-	double xitot3 = xp3 + cfonc3 * fs2 * geom.xmus;
+    double fs1 = pl[0] * as1[0] + pl[1] * as1[1];
+    double fs2 = pl[0] * as2[0] + pl[1] * as2[1];
+    double xitot1 = xp1 + cfonc1 * fs0 * geom.xmus;
+    double xitot2 = xp2 + cfonc2 * fs1 * geom.xmus;
+    double xitot3 = xp3 + cfonc3 * fs2 * geom.xmus;
-	float xrray = (float)(xitot1 * xcosf1);
-	xrray += (float)(xitot2 * xcosf2 * 2);
+    float xrray = (float)(xitot1 * xcosf1);
+    xrray += (float)(xitot2 * xcosf2 * 2);
-	xrray += (float)(xitot3 * xcosf3 * 2);
-	xrray /= (float)geom.xmus;
+    xrray += (float)(xitot3 * xcosf3 * 2);
+    xrray /= (float)geom.xmus;
-	return xrray;
+    return xrray;
-To compute the atmospheric reflectance for the molecular and aerosol atmospheres
-and the mixed atmosphere. In 6S instead of an approximation as in 5S, we use the scalar Successive
-Order of Scattering method (subroutine OS.f). The polarization terms of aerosol or rayleigh phase
-are not accounted for in the computation of the aerosol reflectance and the mixed Rayleigh-aerosol
-reflectance. The polarization is addressed in computing the Rayleigh reflectance (Subroutine
-CHAND.f) by semi-empirical fitting of the vectorized Successive Orders of Scattering method
-(Deuzé et al, 1989).
+  To compute the atmospheric reflectance for the molecular and aerosol atmospheres
+  and the mixed atmosphere. In 6S instead of an approximation as in 5S, we use the scalar Successive
+  Order of Scattering method (subroutine OS.f). The polarization terms of aerosol or rayleigh phase
+  are not accounted for in the computation of the aerosol reflectance and the mixed Rayleigh-aerosol
+  reflectance. The polarization is addressed in computing the Rayleigh reflectance (Subroutine
+  CHAND.f) by semi-empirical fitting of the vectorized Successive Orders of Scattering method
+  (Deuzé et al, 1989).
 void atmref(const float tamoy, const float trmoy, const float pizmoy,
-			const float tamoyp, const float trmoyp, OpticalAtmosProperties &oap,
+	    const float tamoyp, const float trmoyp, OpticalAtmosProperties &oap,
             Gauss &gauss, const GeomCond &geom, const AerosolModel &aero,
     float xlm1[2 * mu + 1][np];
     float xlm2[2 * mu + 1][np];
-	/* atmospheric reflectances */
-	oap.rorayl = 0;
-	oap.roaero = 0;
+    /* atmospheric reflectances */
+    oap.rorayl = 0;
+    oap.roaero = 0;
-	/* rayleigh reflectance 3 cases (satellite,plane,ground) */
-	if(alt.palt < 900 && alt.palt > 0)
-		gauss.rm[STDI(-mu)] = -(float)geom.xmuv;
-		gauss.rm[STDI(mu)] = (float)geom.xmuv;
-		gauss.rm[STDI(0)] = -(float)geom.xmus;
+    /* rayleigh reflectance 3 cases (satellite,plane,ground) */
+    if(alt.palt < 900 && alt.palt > 0)
+	gauss.rm[STDI(-mu)] = -(float)geom.xmuv;
+	gauss.rm[STDI(mu)] = (float)geom.xmuv;
+	gauss.rm[STDI(0)] = -(float)geom.xmus;
-		os(0, trmoy, pizmoy, 0, trmoyp, xlm1, gauss, alt, geom);
+	os(0, trmoy, pizmoy, 0, trmoyp, xlm1, gauss, alt, geom);
-		oap.rorayl = (float)(xlm1[STDI(-mu)][0] / geom.xmus);
-	else if(alt.palt <= 0) oap.rorayl = 0;
-	else oap.rorayl = chand(trmoy, geom);
+	oap.rorayl = (float)(xlm1[STDI(-mu)][0] / geom.xmus);
+    else if(alt.palt <= 0) oap.rorayl = 0;
+    else oap.rorayl = chand(trmoy, geom);
-	if (aero.iaer == 0)
-		oap.romix = oap.rorayl;
-		return;
+    if (aero.iaer == 0)
+	oap.romix = oap.rorayl;
+	return;
-	/* rayleigh+aerosol=romix,aerosol=roaero reflectance computed
-	 using sucessive order of scattering method
-	 3 cases: satellite,plane,ground */
-	if (alt.palt > 0)
+    /* rayleigh+aerosol=romix,aerosol=roaero reflectance computed
+       using sucessive order of scattering method
+       3 cases: satellite,plane,ground */
+    if (alt.palt > 0)
-		os(tamoy, trmoy, pizmoy, tamoyp, trmoyp, xlm2, gauss, alt, geom);
-		oap.romix = (float)(xlm2[STDI(-mu)][0] / geom.xmus);
+	os(tamoy, trmoy, pizmoy, tamoyp, trmoyp, xlm2, gauss, alt, geom);
+	oap.romix = (float)(xlm2[STDI(-mu)][0] / geom.xmus);
-		os(tamoy, 0, pizmoy, tamoyp, 0, xlm2, gauss, alt, geom);
-		oap.roaero = (float)(xlm2[STDI(-mu)][0] / geom.xmus);
-	else
-		oap.roaero = 0;
-		oap.romix = 0;
+	os(tamoy, 0, pizmoy, tamoyp, 0, xlm2, gauss, alt, geom);
+	oap.roaero = (float)(xlm2[STDI(-mu)][0] / geom.xmus);
+    else
+	oap.roaero = 0;
+	oap.romix = 0;
 float fintexp1(const float xtau)
-	/* accuracy 2e-07... for 0<xtau<1 */
-	float a[6] = { -.57721566,0.99999193,-0.24991055,0.05519968,-0.00976004,0.00107857 };
-	float xftau = 1;
-	float xx = a[0];
-	for(int i = 1; i <= 5; i++)
-      xftau *= xtau;
-      xx += a[i] * xftau;
-	return (float)(xx - log(xtau));
+    /* accuracy 2e-07... for 0<xtau<1 */
+    float a[6] = { -.57721566,0.99999193,-0.24991055,0.05519968,-0.00976004,0.00107857 };
+    float xftau = 1;
+    float xx = a[0];
+    for(int i = 1; i <= 5; i++)
+	xftau *= xtau;
+	xx += a[i] * xftau;
+    return (float)(xx - log(xtau));
 float fintexp3(const float xtau)
-	return (float)((exp(-xtau) * (1. - xtau) + xtau * xtau * fintexp1(xtau)) / 2.);
+    return (float)((exp(-xtau) * (1. - xtau) + xtau * xtau * fintexp1(xtau)) / 2.);
 /* To compute the spherical albedo of the molecular layer. */
 void csalbr(const float xtau, float& xalb)
-	xalb = (float)((3. * xtau - fintexp3(xtau) * (4. + 2. * xtau) + 2. * exp(-xtau)));
-	xalb = (float)(xalb / (4. + 3. * xtau));
+    xalb = (float)((3. * xtau - fintexp3(xtau) * (4. + 2. * xtau) + 2. * exp(-xtau)));
+    xalb = (float)(xalb / (4. + 3. * xtau));
 void scatra(const float taer, const float taerp,
-			const float tray, const float trayp,
-			const float piza, OpticalAtmosProperties& oap,
+	    const float tray, const float trayp,
+	    const float piza, OpticalAtmosProperties& oap,
             Gauss &gauss, const GeomCond &geom, const Altitude &alt)
-	/* computations of the direct and diffuse transmittances
-	 for downward and upward paths , and spherical albedo */
-	float tamol,tamolp;
-	float xtrans[3];
+    /* computations of the direct and diffuse transmittances
+       for downward and upward paths , and spherical albedo */
+    float tamol,tamolp;
+    float xtrans[3];
-	oap.ddirtt = 1;	oap.ddiftt = 0;
-	oap.udirtt = 1;	oap.udiftt = 0;
-	oap.ddirtr = 1;	oap.ddiftr = 0;
-	oap.udirtr = 1;	oap.udiftr = 0;
-	oap.ddirta = 1;	oap.ddifta = 0;
-	oap.udirta = 1;	oap.udifta = 0;
-	oap.sphalbt = 0;
-	oap.sphalbr = 0;
-	oap.sphalba = 0;
+    oap.ddirtt = 1;	oap.ddiftt = 0;
+    oap.udirtt = 1;	oap.udiftt = 0;
+    oap.ddirtr = 1;	oap.ddiftr = 0;
+    oap.udirtr = 1;	oap.udiftr = 0;
+    oap.ddirta = 1;	oap.ddifta = 0;
+    oap.udirta = 1;	oap.udifta = 0;
+    oap.sphalbt = 0;
+    oap.sphalbr = 0;
+    oap.sphalba = 0;
-	for(int it = 1; it <= 3; it++)
+    for(int it = 1; it <= 3; it++)
+	/* it=1 rayleigh only, it=2 aerosol only, it=3 rayleigh+aerosol */
+	if (it == 2 && taer <= 0) continue;
+	/* compute upward,downward diffuse transmittance for rayleigh,aerosol */
+	if (it == 1)
-		/* it=1 rayleigh only, it=2 aerosol only, it=3 rayleigh+aerosol */
-		if (it == 2 && taer <= 0) continue;
+	    if (alt.palt > 900)
+		oap.udiftt = (float)((2. / 3. + geom.xmuv) + (2. / 3. - geom.xmuv) * exp(-tray / geom.xmuv));
-		/* compute upward,downward diffuse transmittance for rayleigh,aerosol */
-		if (it == 1)
-			if (alt.palt > 900)
-				oap.udiftt = (float)((2. / 3. + geom.xmuv) + (2. / 3. - geom.xmuv) * exp(-tray / geom.xmuv));
+		oap.udiftt = (float)(oap.udiftt / ((4. / 3.) + tray) - exp(-tray / geom.xmuv));
+		oap.ddiftt = (float)((2. / 3. + geom.xmus) + (2. / 3. - geom.xmus) * exp(-tray / geom.xmus));
+		oap.ddiftt = (float)(oap.ddiftt / ((4. / 3.) + tray) - exp(-tray / geom.xmus));
+		oap.ddirtt = (float)exp(-tray / geom.xmus);
+		oap.udirtt = (float)exp(-tray / geom.xmuv);
-				oap.udiftt = (float)(oap.udiftt / ((4. / 3.) + tray) - exp(-tray / geom.xmuv));
-				oap.ddiftt = (float)((2. / 3. + geom.xmus) + (2. / 3. - geom.xmus) * exp(-tray / geom.xmus));
-				oap.ddiftt = (float)(oap.ddiftt / ((4. / 3.) + tray) - exp(-tray / geom.xmus));
-				oap.ddirtt = (float)exp(-tray / geom.xmus);
-				oap.udirtt = (float)exp(-tray / geom.xmuv);
+		csalbr(tray, oap.sphalbt);
+	    else if (alt.palt > 0 && alt.palt <= 900)
+		tamol = 0;
+		tamolp= 0;
+		gauss.rm[STDI(0)] = (float)geom.xmus;
-				csalbr(tray, oap.sphalbt);
-			else if (alt.palt > 0 && alt.palt <= 900)
-				tamol = 0;
-				tamolp= 0;
-				gauss.rm[STDI(0)] = (float)geom.xmus;
-				iso(tamol, tray, piza, tamolp, trayp, xtrans, gauss, alt);
+		iso(tamol, tray, piza, tamolp, trayp, xtrans, gauss, alt);
-				oap.udiftt = (float)(xtrans[0] - exp(-trayp / geom.xmuv));
-				oap.udirtt = (float)exp(-trayp / geom.xmuv);
-				gauss.rm[STDI(-mu)] = -(float)geom.xmus;
-				gauss.rm[STDI(mu)] = (float)geom.xmus;
+		oap.udiftt = (float)(xtrans[0] - exp(-trayp / geom.xmuv));
+		oap.udirtt = (float)exp(-trayp / geom.xmuv);
+		gauss.rm[STDI(-mu)] = -(float)geom.xmus;
+		gauss.rm[STDI(mu)] = (float)geom.xmus;
-			else if (alt.palt <= 0.)
-				oap.udiftt = 0;
-				oap.udirtt = 1;
+	    else if (alt.palt <= 0.)
+		oap.udiftt = 0;
+		oap.udirtt = 1;
-			oap.ddirtr = oap.ddirtt;
-			oap.ddiftr = oap.ddiftt;
-			oap.udirtr = oap.udirtt;
-			oap.udiftr = oap.udiftt;
-			oap.sphalbr = oap.sphalbt;
+	    oap.ddirtr = oap.ddirtt;
+	    oap.ddiftr = oap.ddiftt;
+	    oap.udirtr = oap.udirtt;
+	    oap.udiftr = oap.udiftt;
+	    oap.sphalbr = oap.sphalbt;
-		else if (it == 2)
-			tamol = 0;
-			tamolp= 0;
+	else if (it == 2)
+	    tamol = 0;
+	    tamolp= 0;
-			iso(taer, tamol, piza, taerp, tamolp, xtrans, gauss, alt);
+	    iso(taer, tamol, piza, taerp, tamolp, xtrans, gauss, alt);
-			oap.udiftt = (float)(xtrans[0] - exp(-taerp / geom.xmuv));
-			oap.udirtt = (float)exp(-taerp / geom.xmuv);
+	    oap.udiftt = (float)(xtrans[0] - exp(-taerp / geom.xmuv));
+	    oap.udirtt = (float)exp(-taerp / geom.xmuv);
-			float tmp_alt = alt.palt;
-			alt.palt = 999;
-			alt.palt = tmp_alt;
+	    float tmp_alt = alt.palt;
+	    alt.palt = 999;
+	    alt.palt = tmp_alt;
-			oap.ddirtt = (float)exp(-taer / geom.xmus);
-			oap.ddiftt = (float)(xtrans[2] - exp(-taer / geom.xmus));
-			oap.sphalbt= (float)(xtrans[1] * 2);
+	    oap.ddirtt = (float)exp(-taer / geom.xmus);
+	    oap.ddiftt = (float)(xtrans[2] - exp(-taer / geom.xmus));
+	    oap.sphalbt= (float)(xtrans[1] * 2);
-			if(alt.palt <= 0)
-				oap.udiftt = 0;
-				oap.udirtt = 1;
+	    if(alt.palt <= 0)
+		oap.udiftt = 0;
+		oap.udirtt = 1;
-			oap.ddirta = oap.ddirtt;
-			oap.ddifta = oap.ddiftt;
-			oap.udirta = oap.udirtt;
-			oap.udifta = oap.udiftt;
-			oap.sphalba = oap.sphalbt;
-		else if(it == 3)
+	    oap.ddirta = oap.ddirtt;
+	    oap.ddifta = oap.ddiftt;
+	    oap.udirta = oap.udirtt;
+	    oap.udifta = oap.udiftt;
+	    oap.sphalba = oap.sphalbt;
+	else if(it == 3)
-			iso(taer, tray, piza, taerp, trayp, xtrans, gauss, alt);
+	    iso(taer, tray, piza, taerp, trayp, xtrans, gauss, alt);
-			oap.udirtt = (float)exp(-(taerp + trayp) / geom.xmuv);
-			oap.udiftt = (float)(xtrans[0] - exp(-(taerp + trayp) / geom.xmuv));
+	    oap.udirtt = (float)exp(-(taerp + trayp) / geom.xmuv);
+	    oap.udiftt = (float)(xtrans[0] - exp(-(taerp + trayp) / geom.xmuv));
-			alt.palt = 999;
+	    alt.palt = 999;
-			oap.ddiftt = (float)(xtrans[2] - exp(-(taer + tray) / geom.xmus));
-			oap.ddirtt = (float)exp(-(taer + tray) / geom.xmus);
+	    oap.ddiftt = (float)(xtrans[2] - exp(-(taer + tray) / geom.xmus));
+	    oap.ddirtt = (float)exp(-(taer + tray) / geom.xmus);
-			if (alt.palt <= 0)
-				oap.udiftt = 0;
-				oap.udirtt = 1;
+	    if (alt.palt <= 0)
+		oap.udiftt = 0;
+		oap.udirtt = 1;
 /* To compute the optical properties of the atmosphere at the 10 discrete
-wavelengths. */
+   wavelengths. */
 void discom(const GeomCond &geom, const AtmosModel &atms,
             const AerosolModel &aero, const AerosolConcentration &aerocon,
             const Altitude &alt, const IWave &iwave)
-	OpticalAtmosProperties oap;
+    OpticalAtmosProperties oap;
     memset(&oap, 0, sizeof(oap));
     Gauss gauss;
@@ -1600,117 +1600,117 @@
     memset(&sixs_trunc, 0, sizeof(sixs_trunc));  /* clear this to keep preconditions the same and output consistent */
 /*    computation of all scattering parameters at wavelength
-    discrete values,so we
-    can interpolate at any wavelength */
-	int i;
-	for(i = 0; i < 10; i++)
-		if(!((((i < 2) && iwave.ffu.wlsup < sixs_disc.wldis[0])) || ((iwave.ffu.wlinf > sixs_disc.wldis[9]) && (i >= 8))))
-			if (((i < 9) && (sixs_disc.wldis[i] < iwave.ffu.wlinf) && (sixs_disc.wldis[i+1] < iwave.ffu.wlinf)) ||
-			    ((i > 0) && (sixs_disc.wldis[i] > iwave.ffu.wlsup) && (sixs_disc.wldis[i-1] > iwave.ffu.wlsup))) continue;
+      discrete values,so we
+      can interpolate at any wavelength */
+    int i;
+    for(i = 0; i < 10; i++)
+	if(!((((i < 2) && iwave.ffu.wlsup < sixs_disc.wldis[0])) || ((iwave.ffu.wlinf > sixs_disc.wldis[9]) && (i >= 8))))
+	    if (((i < 9) && (sixs_disc.wldis[i] < iwave.ffu.wlinf) && (sixs_disc.wldis[i+1] < iwave.ffu.wlinf)) ||
+		((i > 0) && (sixs_disc.wldis[i] > iwave.ffu.wlsup) && (sixs_disc.wldis[i-1] > iwave.ffu.wlsup))) continue;
-		float wl = sixs_disc.wldis[i];
-		/* computation of rayleigh optical depth at wl */
-		float tray = odrayl(atms, wl);
-		float trayp;
+	float wl = sixs_disc.wldis[i];
+	/* computation of rayleigh optical depth at wl */
+	float tray = odrayl(atms, wl);
+	float trayp;
-		/* plane case discussed here above */
-		if (alt.idatmp == 0) trayp = 0;
-		else if (alt.idatmp == 4) trayp = tray;
-		else trayp = tray * alt.ftray;
+	/* plane case discussed here above */
+	if (alt.idatmp == 0) trayp = 0;
+	else if (alt.idatmp == 4) trayp = tray;
+	else trayp = tray * alt.ftray;
-		sixs_disc.trayl[i] = tray;
-		sixs_disc.traypl[i] = trayp;
+	sixs_disc.trayl[i] = tray;
+	sixs_disc.traypl[i] = trayp;
-		/* computation of aerosol optical properties at wl */
+	/* computation of aerosol optical properties at wl */
-		float taer = aerocon.taer55 * sixs_aer.ext[i] / sixs_aer.ext[3];
-		float taerp = alt.taer55p * sixs_aer.ext[i] / sixs_aer.ext[3];
-		float piza = sixs_aer.ome[i];
+	float taer = aerocon.taer55 * sixs_aer.ext[i] / sixs_aer.ext[3];
+	float taerp = alt.taer55p * sixs_aer.ext[i] / sixs_aer.ext[3];
+	float piza = sixs_aer.ome[i];
-		/* computation of atmospheric reflectances
+	/* computation of atmospheric reflectances
-		            rorayl is rayleigh ref
-		            roaero is aerosol ref
-		 call plegen to decompose aerosol phase function in Betal */
+	rorayl is rayleigh ref
+	roaero is aerosol ref
+	call plegen to decompose aerosol phase function in Betal */
-		float coeff = 0;
-		if(aero.iaer != 0)
-			for(int k = 0; k < 83; k++) sixs_trunc.pha[k] = sixs_sos.phasel[i][k];
-			coeff = trunca();
+	float coeff = 0;
+	if(aero.iaer != 0)
+	    for(int k = 0; k < 83; k++) sixs_trunc.pha[k] = sixs_sos.phasel[i][k];
+	    coeff = trunca();
-		float tamoy = taer * (1 - piza * coeff);
-		float tamoyp = taerp * (1 - piza * coeff);
-		float pizmoy = piza * (1 - coeff) / (1 - piza * coeff);
+	float tamoy = taer * (1 - piza * coeff);
+	float tamoyp = taerp * (1 - piza * coeff);
+	float pizmoy = piza * (1 - coeff) / (1 - piza * coeff);
-		atmref(tamoy, tray, pizmoy, tamoyp, trayp, oap, gauss, geom, aero, alt);
+	atmref(tamoy, tray, pizmoy, tamoyp, trayp, oap, gauss, geom, aero, alt);
-		/* computation of scattering transmitances (direct and diffuse)
-		 first time for rayleigh ,next total (rayleigh+aerosols) */
+	/* computation of scattering transmitances (direct and diffuse)
+	   first time for rayleigh ,next total (rayleigh+aerosols) */
-		scatra(tamoy, tamoyp, tray, trayp, pizmoy, oap, gauss, geom, alt);
+	scatra(tamoy, tamoyp, tray, trayp, pizmoy, oap, gauss, geom, alt);
-		sixs_disc.roatm[0][i] = oap.rorayl;
-		sixs_disc.roatm[1][i] = oap.romix;
-		sixs_disc.roatm[2][i] = oap.roaero;
-		sixs_disc.dtdir[0][i] = oap.ddirtr;
-		sixs_disc.dtdif[0][i] = oap.ddiftr;
-		sixs_disc.dtdir[1][i] = oap.ddirtt;
-		sixs_disc.dtdif[1][i] = oap.ddiftt;
-		sixs_disc.dtdir[2][i] = oap.ddirta;
-		sixs_disc.dtdif[2][i] = oap.ddifta;
-		sixs_disc.utdir[0][i] = oap.udirtr;
-		sixs_disc.utdif[0][i] = oap.udiftr;
-		sixs_disc.utdir[1][i] = oap.udirtt;
-		sixs_disc.utdif[1][i] = oap.udiftt;
-		sixs_disc.utdir[2][i] = oap.udirta;
-		sixs_disc.utdif[2][i] = oap.udifta;
-		sixs_disc.sphal[0][i] = oap.sphalbr;
-		sixs_disc.sphal[1][i] = oap.sphalbt;
-		sixs_disc.sphal[2][i] = oap.sphalba;
+	sixs_disc.roatm[0][i] = oap.rorayl;
+	sixs_disc.roatm[1][i] = oap.romix;
+	sixs_disc.roatm[2][i] = oap.roaero;
+	sixs_disc.dtdir[0][i] = oap.ddirtr;
+	sixs_disc.dtdif[0][i] = oap.ddiftr;
+	sixs_disc.dtdir[1][i] = oap.ddirtt;
+	sixs_disc.dtdif[1][i] = oap.ddiftt;
+	sixs_disc.dtdir[2][i] = oap.ddirta;
+	sixs_disc.dtdif[2][i] = oap.ddifta;
+	sixs_disc.utdir[0][i] = oap.udirtr;
+	sixs_disc.utdif[0][i] = oap.udiftr;
+	sixs_disc.utdir[1][i] = oap.udirtt;
+	sixs_disc.utdif[1][i] = oap.udiftt;
+	sixs_disc.utdir[2][i] = oap.udirta;
+	sixs_disc.utdif[2][i] = oap.udifta;
+	sixs_disc.sphal[0][i] = oap.sphalbr;
+	sixs_disc.sphal[1][i] = oap.sphalbt;
+	sixs_disc.sphal[2][i] = oap.sphalba;
-To compute the atmospheric properties at the equivalent wavelength (see
-EQUIVWL.f) needed for the calculation of the downward radiation field used
-in the computation of the non lambertian target contribution (main.f).
+  To compute the atmospheric properties at the equivalent wavelength (see
+  EQUIVWL.f) needed for the calculation of the downward radiation field used
+  in the computation of the non lambertian target contribution (main.f).
 void specinterp(const float wl, float& tamoy, float& tamoyp, float& pizmoy, float& pizmoyp,
                 const AerosolConcentration &aerocon, const Altitude &alt)
-	int linf = 0;
-	for(int i = 0; i < 9; i++)
-		if(wl >= sixs_disc.wldis[i] && wl <= sixs_disc.wldis[i+1]) linf = i;
-	if(wl > sixs_disc.wldis[9]) linf = 8;
+    int linf = 0;
+    for(int i = 0; i < 9; i++)
+	if(wl >= sixs_disc.wldis[i] && wl <= sixs_disc.wldis[i+1]) linf = i;
+    if(wl > sixs_disc.wldis[9]) linf = 8;
     int lsup = linf + 1;
-	float coef = (float)log(sixs_disc.wldis[lsup] / sixs_disc.wldis[linf]);
+    float coef = (float)log(sixs_disc.wldis[lsup] / sixs_disc.wldis[linf]);
     float wlinf = sixs_disc.wldis[linf];
     float alphaa = (float)(log(sixs_aer.ext[lsup] * sixs_aer.ome[lsup] /
-				   (sixs_aer.ext[linf] * sixs_aer.ome[linf])) / coef);
-	float betaa = (float)(sixs_aer.ext[linf] * sixs_aer.ome[linf] / pow(wlinf,alphaa));
+			       (sixs_aer.ext[linf] * sixs_aer.ome[linf])) / coef);
+    float betaa = (float)(sixs_aer.ext[linf] * sixs_aer.ome[linf] / pow(wlinf,alphaa));
     float tsca = (float)(aerocon.taer55 * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
-	alphaa = (float)(log(sixs_aer.ext[lsup] / sixs_aer.ext[linf]) / coef);
+    alphaa = (float)(log(sixs_aer.ext[lsup] / sixs_aer.ext[linf]) / coef);
     betaa = (float)(sixs_aer.ext[linf] / pow(wlinf,alphaa));
     tamoy = (float)(aerocon.taer55 * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
     tamoyp= (float)(alt.taer55p * betaa * pow(wl,alphaa) / sixs_aer.ext[3]);
     pizmoy= tsca / tamoy;
     pizmoyp = pizmoy;
-		alphaa = (float)log(sixs_sos.phasel[lsup][k] / sixs_sos.phasel[linf][k]) / coef;
-		betaa = (float)(sixs_sos.phasel[linf][k] / pow(wlinf,alphaa));
-		sixs_trunc.pha[k] = (float)(betaa * pow(wl,alphaa));
+	alphaa = (float)log(sixs_sos.phasel[lsup][k] / sixs_sos.phasel[linf][k]) / coef;
+	betaa = (float)(sixs_sos.phasel[linf][k] / pow(wlinf,alphaa));
+	sixs_trunc.pha[k] = (float)(betaa * pow(wl,alphaa));
-	float coeff = trunca();
+    float coeff = trunca();
     tamoy *= 1 - pizmoy * coeff;
     tamoyp *= 1 - pizmoyp * coeff;
@@ -1724,97 +1724,97 @@
 c**********************************************************************/
-To compute the environment functions F(r) which allows us to account for an
-inhomogeneous ground.
+  To compute the environment functions F(r) which allows us to account for an
+  inhomogeneous ground.
 void enviro (const float difr, const float difa, const float r, const float palt,
-			 const float xmuv, float& fra, float& fae, float& fr)
+	     const float xmuv, float& fra, float& fae, float& fr)
-	float fae0, fra0, xlnv;
-	static const float alt[16] = {
-		0.5,1.0,2.0,3.0,4.0,5.0,6.0,7.0,8.0,
-		10.0,12.0,14.0,16.0,18.0,20.0,60.0
+    float fae0, fra0, xlnv;
+    static const float alt[16] = {
+	0.5,1.0,2.0,3.0,4.0,5.0,6.0,7.0,8.0,
+	10.0,12.0,14.0,16.0,18.0,20.0,60.0
-	static const float cfr1[16] = {
-		0.730,0.710,0.656,0.606,0.560,0.516,0.473,
-		0.433,0.395,0.323,0.258,0.209,0.171,0.142,0.122,0.070
+    static const float cfr1[16] = {
+	0.730,0.710,0.656,0.606,0.560,0.516,0.473,
+	0.433,0.395,0.323,0.258,0.209,0.171,0.142,0.122,0.070
-	static const float cfr2[16] = {
-		2.8,1.51,0.845,0.634,0.524,0.465,0.429,
-		0.405,0.390,0.386,0.409,0.445,0.488,0.545,0.608,0.868
+    static const float cfr2[16] = {
+	2.8,1.51,0.845,0.634,0.524,0.465,0.429,
+	0.405,0.390,0.386,0.409,0.445,0.488,0.545,0.608,0.868
     static const float cfa1[16] = {
-		0.239,0.396,0.588,0.626,0.612,0.505,0.454,
-		0.448,0.444,0.445,0.444,0.448,0.448,0.448,0.448,0.448
+	0.239,0.396,0.588,0.626,0.612,0.505,0.454,
+	0.448,0.444,0.445,0.444,0.448,0.448,0.448,0.448,0.448
-	static const float cfa2[16] = {
-		1.40,1.20,1.02,0.86,0.74,0.56,0.46,0.42,
-		0.38,0.34,0.3,0.28,0.27,0.27,0.27,0.27
+    static const float cfa2[16] = {
+	1.40,1.20,1.02,0.86,0.74,0.56,0.46,0.42,
+	0.38,0.34,0.3,0.28,0.27,0.27,0.27,0.27
-	static const float cfa3[16] = {
-		9.17,6.26,5.48,5.16,4.74,3.65,3.24,3.15,
-		3.07,2.97,2.88,2.83,2.83,2.83,2.83,2.83
+    static const float cfa3[16] = {
+	9.17,6.26,5.48,5.16,4.74,3.65,3.24,3.15,
+	3.07,2.97,2.88,2.83,2.83,2.83,2.83,2.83
 /*     calculation of the environmental function for
-     rayleigh and aerosols contribution.
+       rayleigh and aerosols contribution.
-     this calculation have been done for nadir observation
-    and are corrected of the effect of the view zenith angle. */
+       this calculation have been done for nadir observation
+       and are corrected of the effect of the view zenith angle. */
-	const float a0 = 1.3347;
-	const float b0 = 0.57757;
-	const float a1 = -1.479;
-	const float b1 = -1.5275;
+    const float a0 = 1.3347;
+    const float b0 = 0.57757;
+    const float a1 = -1.479;
+    const float b1 = -1.5275;
-	if (palt >= 60)
+    if (palt >= 60)
+	fae0 = (float)(1. - 0.448 * exp( -r * 0.27) - 0.552 * exp( -r * 2.83));
+	fra0 = (float)(1. - 0.930 * exp( -r * 0.080) - 0.070 * exp( -r * 1.100));
+    else
+	int i;
+	for(i = 0; palt >= alt[i]; i++);
+	float xcfr1 = 0, xcfr2 = 0, xcfa1 = 0, xcfa2 = 0, xcfa3 = 0;
+	if ((i > 0) && (i < 16))
-		fae0 = (float)(1. - 0.448 * exp( -r * 0.27) - 0.552 * exp( -r * 2.83));
-		fra0 = (float)(1. - 0.930 * exp( -r * 0.080) - 0.070 * exp( -r * 1.100));
+	    float zmin = alt[i - 1];
+	    float zmax = alt[i];
+	    xcfr1 = cfr1[i - 1] + (cfr1[i] - cfr1[i - 1]) * (palt - zmin) / (zmax - zmin);
+	    xcfr2 = cfr2[i - 1] + (cfr2[i] - cfr2[i - 1]) * (palt - zmin) / (zmax - zmin);
+	    xcfa1 = cfa1[i - 1] + (cfa1[i] - cfa1[i - 1]) * (palt - zmin) / (zmax - zmin);
+	    xcfa2 = cfa2[i - 1] + (cfa2[i] - cfa2[i - 1]) * (palt - zmin) / (zmax - zmin);
+	    xcfa3 = cfa3[i - 1] + (cfa3[i] - cfa3[i - 1]) * (palt - zmin) / (zmax - zmin);
-    else
+	if (i == 0)
-		int i;
-		for(i = 0; palt >= alt[i]; i++);
-	    float xcfr1 = 0, xcfr2 = 0, xcfa1 = 0, xcfa2 = 0, xcfa3 = 0;
+	    xcfr1 = cfr1[0];
+	    xcfr2 = cfr2[0];
+	    xcfa1 = cfa1[0];
+	    xcfa2 = cfa2[0];
+	    xcfa3 = cfa3[0];
-		if ((i > 0) && (i < 16))
-			float zmin = alt[i - 1];
-			float zmax = alt[i];
-			xcfr1 = cfr1[i - 1] + (cfr1[i] - cfr1[i - 1]) * (palt - zmin) / (zmax - zmin);
-			xcfr2 = cfr2[i - 1] + (cfr2[i] - cfr2[i - 1]) * (palt - zmin) / (zmax - zmin);
-			xcfa1 = cfa1[i - 1] + (cfa1[i] - cfa1[i - 1]) * (palt - zmin) / (zmax - zmin);
-			xcfa2 = cfa2[i - 1] + (cfa2[i] - cfa2[i - 1]) * (palt - zmin) / (zmax - zmin);
-			xcfa3 = cfa3[i - 1] + (cfa3[i] - cfa3[i - 1]) * (palt - zmin) / (zmax - zmin);
+	fra0 = (float)(1. - xcfr1 * exp(-r * xcfr2) - (1. - xcfr1) * exp(-r * 0.08));
+	fae0 = (float)(1. - xcfa1 * exp(-r * xcfa2) - (1. - xcfa1) * exp(-r * xcfa3));
-		if (i == 0)
-			xcfr1 = cfr1[0];
-			xcfr2 = cfr2[0];
-			xcfa1 = cfa1[0];
-			xcfa2 = cfa2[0];
-			xcfa3 = cfa3[0];
+    /* correction of the effect of the view zenith angle */
+    xlnv = (float)log(xmuv);
+    fra = (float)(fra0 * (xlnv * (1 - fra0) + 1));
+    fae = (float)(fae0 * ((1 + a0 * xlnv + b0 * xlnv * xlnv) + fae0 * (a1 * xlnv + b1 * xlnv * xlnv) +
+			  fae0 * fae0 * ((-a1 - a0) * xlnv + ( - b1 - b0) * xlnv * xlnv)));
-		fra0 = (float)(1. - xcfr1 * exp(-r * xcfr2) - (1. - xcfr1) * exp(-r * 0.08));
-		fae0 = (float)(1. - xcfa1 * exp(-r * xcfa2) - (1. - xcfa1) * exp(-r * xcfa3));
-	/* correction of the effect of the view zenith angle */
-	xlnv = (float)log(xmuv);
-	fra = (float)(fra0 * (xlnv * (1 - fra0) + 1));
-	fae = (float)(fae0 * ((1 + a0 * xlnv + b0 * xlnv * xlnv) + fae0 * (a1 * xlnv + b1 * xlnv * xlnv) +
-		  fae0 * fae0 * ((-a1 - a0) * xlnv + ( - b1 - b0) * xlnv * xlnv)));
-	if ((difa + difr) > 1e-03) fr = (fae * difa + fra * difr) / (difa + difr);
+    if ((difa + difr) > 1e-03) fr = (fae * difa + fra * difr) / (difa + difr);
     else fr = 1;
Modified: grass/trunk/imagery/i.atcorr/gauss.cpp
--- grass/trunk/imagery/i.atcorr/gauss.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/gauss.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -10,17 +10,17 @@
 /*  preliminary computations for gauss integration */
 void Gauss::init()
-	int j;
+    int j;
-	/* convert angphi and angmu to radians */
-	for (j = 0; j < 13; ++j) angphi[j] = (float)(angphi[j] * M_PI / 180.f);
-	for (j = 0; j < 10; ++j) angmu[j] =	 (float)cos(angmu[j] * M_PI / 180.f);
+    /* convert angphi and angmu to radians */
+    for (j = 0; j < 13; ++j) angphi[j] = (float)(angphi[j] * M_PI / 180.f);
+    for (j = 0; j < 10; ++j) angmu[j] =	 (float)cos(angmu[j] * M_PI / 180.f);
-	/* calculate rm & gb */
+    /* calculate rm & gb */
-	float anglem[mu2];
-	float weightm[mu2];
-	gauss (-1.f, 1.f, anglem, weightm, mu2);
+    float anglem[mu2];
+    float weightm[mu2];
+    gauss (-1.f, 1.f, anglem, weightm, mu2);
     gb[STDI(-mu)]   = 0;
     gb[STDI(0)]     = 0;
@@ -28,60 +28,60 @@
     rm[STDI(-mu)]   = 0;
     rm[STDI(0)]     = 0;
     rm[STDI(mu)]    = 0;
-	/* do shift into rm & gb */
-	for (j = -mu+1; j <= -1; ++j)
+    /* do shift into rm & gb */
+    for (j = -mu+1; j <= -1; ++j)
-      rm[-j] = anglem[mu + j - 1];
-      gb[-j] = weightm[mu + j - 1];
+	rm[-j] = anglem[mu + j - 1];
+	gb[-j] = weightm[mu + j - 1];
-	for (j = 1; j <= mu-1; ++j)
+    for (j = 1; j <= mu-1; ++j)
-      rm[2*mu - j] = anglem[mu + j - 2];
-      gb[2*mu - j] = weightm[mu + j - 2];
+	rm[2*mu - j] = anglem[mu + j - 2];
+	gb[2*mu - j] = weightm[mu + j - 2];
-	/* calculate rp & gp */
-	gauss (0.f, (float)2 * M_PI, rp, gp, np);
+    /* calculate rp & gp */
+    gauss (0.f, (float)2 * M_PI, rp, gp, np);
 /*	Compute for a given n, the gaussian quadrature (the n gaussian angles and the
-	their respective weights). The gaussian quadrature is used in numerical integration involving the
-	cosine of emergent or incident direction zenith angle. */
+  their respective weights). The gaussian quadrature is used in numerical integration involving the
+  cosine of emergent or incident direction zenith angle. */
 void Gauss::gauss (float a, float b, float *x, float *w, long int n)
-	int m = (n + 1) / 2;
-	double xm = (b + a) / 2;
-	double xl = (b - a) / 2;
+    int m = (n + 1) / 2;
+    double xm = (b + a) / 2;
+    double xl = (b - a) / 2;
-	for(int i = 0; i < m; i++)
-		double
-			z1,
-			pp,
-			z = cos(M_PI * (i + 0.75) / (n + 0.5));
+    for(int i = 0; i < m; i++)
+	double
+	    z1,
+	    pp,
+	    z = cos(M_PI * (i + 0.75) / (n + 0.5));
-		do {
-			double p1 = 1;
-			double p2 = 0;
+	do {
+	    double p1 = 1;
+	    double p2 = 0;
-			for(int j = 0; j < n; j++)
-				double p3 = p2;
-				p2 = p1;
-				p1 = ((2 * j + 1) * z * p2 - j * p3) / (j+1);
+	    for(int j = 0; j < n; j++)
+		double p3 = p2;
+		p2 = p1;
+		p1 = ((2 * j + 1) * z * p2 - j * p3) / (j+1);
-			pp = n * (z * p1 - p2) / (z * z - 1);
-			z1 = z;
-			z = z1 - p1 / pp;
-		} while(fabs(z - z1) > 3e-14);
+	    pp = n * (z * p1 - p2) / (z * z - 1);
+	    z1 = z;
+	    z = z1 - p1 / pp;
+	} while(fabs(z - z1) > 3e-14);
-		if (fabs(z) < 3e-14) z = 0;
-		x[i] = (float)(xm - xl * z);
+	if (fabs(z) < 3e-14) z = 0;
+	x[i] = (float)(xm - xl * z);
         x[n - 1 - i] = (float)(xm + xl * z);
-		w[i] = (float)(2 * xl / ((1 - z * z) * pp * pp));
-		w[n - 1 - i] = w[i];
+	w[i] = (float)(2 * xl / ((1 - z * z) * pp * pp));
+	w[n - 1 - i] = w[i];
Modified: grass/trunk/imagery/i.atcorr/main.cpp
--- grass/trunk/imagery/i.atcorr/main.cpp	2008-09-02 10:25:37 UTC (rev 33216)
+++ grass/trunk/imagery/i.atcorr/main.cpp	2008-09-02 10:28:01 UTC (rev 33217)
@@ -22,7 +22,7 @@
     supplying an elevation map has not been run to completion, because it
     takes to long and no sensible data for the test data was at hand.
     Testing would be welcomed. :)
 #include <stdlib.h>
 #include <math.h>
@@ -41,19 +41,19 @@
 struct Options
     /* options */
-	struct Option *iimg;    /* input satelite image */
-	struct Option *iscl;    /* input data is scaled to this range */
-	struct Option *ialt;    /* an input elevation map in km used to increase */
+    struct Option *iimg;    /* input satelite image */
+    struct Option *iscl;    /* input data is scaled to this range */
+    struct Option *ialt;    /* an input elevation map in km used to increase */
                             /* atmospheric correction accuracy, including this */
                             /* will make computations take much, much longer */
     struct Option *ivis;    /* an input visibility map in km (same purpose and effect as ialt) */
-	struct Option *icnd;    /* the input conditions file */
-	struct Option *oimg;    /* output image name */
-	struct Option *oscl;    /* scale the output data (reflectance values) to this range */
+    struct Option *icnd;    /* the input conditions file */
+    struct Option *oimg;    /* output image name */
+    struct Option *oscl;    /* scale the output data (reflectance values) to this range */
     /* flags */
-	struct Flag *oflt;      /* output data as floating point and do not round */
-	struct Flag *irad;      /* treat input values as reflectance instead of radiance values */
+    struct Flag *oflt;      /* output data as floating point and do not round */
+    struct Flag *irad;      /* treat input values as reflectance instead of radiance values */
     struct Flag *etmafter;  /* treat input data as a satelite image of type etm+ taken after July 1, 2000 */
     struct Flag *etmbefore; /* treat input data as a satelite image of type etm+ taken before July 1, 2000 */
     struct Flag *optimize;
@@ -81,42 +81,42 @@
- Adjust the region to that of the input raster.
- Atmospheric corrections should be done on the whole
- satelite image, not just portions.
+   Adjust the region to that of the input raster.
+   Atmospheric corrections should be done on the whole
+   satelite image, not just portions.
 static void adjust_region (char *name, char *mapset)
-	struct Cell_head iimg_head;	/* the input image header file */
+    struct Cell_head iimg_head;	/* the input image header file */
-	if(G_get_cellhd(name, mapset, &iimg_head) < 0)
-		G_fatal_error ("Unable to retreive header dat for input image");
+    if(G_get_cellhd(name, mapset, &iimg_head) < 0)
+	G_fatal_error ("Unable to retreive header dat for input image");
-	if(G_set_window(&iimg_head) < 0)
-		G_fatal_error ("Invalid graphics region coordinates");
+    if(G_set_window(&iimg_head) < 0)
+	G_fatal_error ("Invalid graphics region coordinates");
 /* Rounds a floating point cell value */
 static CELL round_c (FCELL x)
-	if (x >= 0.0)
-		return (CELL)(x + .5);
+    if (x >= 0.0)
+	return (CELL)(x + .5);
-	return (CELL)(-(-x + .5));
+    return (CELL)(-(-x + .5));
 /* Converts the buffer to cell and write it to disk */
 static void write_fp_to_cell (int ofd, FCELL* buf)
-	CELL* cbuf;
-	int col;
+    CELL* cbuf;
+    int col;
-	cbuf = (CELL*)G_allocate_raster_buf(CELL_TYPE);
+    cbuf = (CELL*)G_allocate_raster_buf(CELL_TYPE);
-	for(col = 0; col < G_window_cols(); col++) cbuf[col] = round_c(buf[col]);
-	G_put_raster_row(ofd, cbuf, CELL_TYPE);
+    for(col = 0; col < G_window_cols(); col++) cbuf[col] = round_c(buf[col]);
+    G_put_raster_row(ofd, cbuf, CELL_TYPE);
@@ -133,85 +133,85 @@
 public:
     TICache() { p = 0; for(int i = 0; i < MAX_TIs; i++) alts[i] = -1; }
     int search(float alt) {
-	    for(int i = 0; i < MAX_TIs; i++)
-		    if(alt == alts[i])
-			    hit++;
-			    return i;
-	    mis++;
-	    return -1;
+	for(int i = 0; i < MAX_TIs; i++)
+	    if(alt == alts[i])
+		hit++;
+		return i;
+	mis++;
+	return -1;
     TransformInput get(int i) { return tis[i]; }
     void add(TransformInput ti, float alt) {
-	    tis[p] = ti;
-	    alts[p] = alt;
-	    p++;
-	    if(p >= MAX_TIs) p = 0;
+	tis[p] = ti;
+	alts[p] = alt;
+	p++;
+	if(p >= MAX_TIs) p = 0;
 /* the transform input map, is a array of ticaches.
- The first key is the visibility which matches to a TICache for the altitudes.
- This code is horrible, i just spent 20min writing and 5min debugging it. */
+   The first key is the visibility which matches to a TICache for the altitudes.
+   This code is horrible, i just spent 20min writing and 5min debugging it. */
 class TIMap
-	enum TIMapSize
-		MAX_TICs = 128 /* this value is a guess. It means that 1024 TI's will be the max combinations of vis/alt pairs */
+    enum TIMapSize
+	MAX_TICs = 128 /* this value is a guess. It means that 1024 TI's will be the max combinations of vis/alt pairs */
-	TICache tic[MAX_TICs]; /* array of TICaches */
-	float visi[MAX_TICs];
-	int p;
+    TICache tic[MAX_TICs]; /* array of TICaches */
+    float visi[MAX_TICs];
+    int p;
 public:
-	struct Position
-		int i, j;
-		Position() : i(-1), j(-1) {}
-		Position(int x, int y) : i(x), j(y) {}
-		bool valid() { return i != -1 && j != -1; }
+    struct Position
+	int i, j;
+	Position() : i(-1), j(-1) {}
+	Position(int x, int y) : i(x), j(y) {}
+	bool valid() { return i != -1 && j != -1; }
-	TIMap() { p = 0; for(int i = 0; i < MAX_TICs; i++) visi[i] = -1; }
-	Position search(float vis, float alt) {
-		for(int i = 0; i < MAX_TICs; i++)
-			if(vis == visi[i]) {
-				Position pos;
-				pos.i = i;
-				pos.j = tic[i].search(alt);
-				return pos;
-		return Position();
+    TIMap() { p = 0; for(int i = 0; i < MAX_TICs; i++) visi[i] = -1; }
+    Position search(float vis, float alt) {
+	for(int i = 0; i < MAX_TICs; i++)
+	    if(vis == visi[i]) {
+		Position pos;
+		pos.i = i;
+		pos.j = tic[i].search(alt);
+		return pos;
+	return Position();
-	TransformInput get(Position pos) { return tic[pos.i].get(pos.j); }
+    TransformInput get(Position pos) { return tic[pos.i].get(pos.j); }
-	void add(TransformInput ti, float vis, float alt) {
-		tic[p].add(ti, alt);
-		visi[p] = vis;
-		p++;
-		if(p >= MAX_TICs) p = 0;
+    void add(TransformInput ti, float vis, float alt) {
+	tic[p].add(ti, alt);
+	visi[p] = vis;
+	p++;
+	if(p >= MAX_TICs) p = 0;
 struct IntPair
-	FCELL x;
-	FCELL y;
+    FCELL x;
+    FCELL y;
-	IntPair(FCELL i, FCELL j) : x(i), y(j) {}
+    IntPair(FCELL i, FCELL j) : x(i), y(j) {}
-	bool operator<(const IntPair& b) const
+    bool operator<(const IntPair& b) const
-		if(x < b.x) return true;
-		else if(x > b.x) return false;
-		else if(y < b.y) return true;
-		return false;
+	    if(x < b.x) return true;
+	    else if(x > b.x) return false;
+	    else if(y < b.y) return true;
+	    return false;
@@ -221,51 +221,51 @@
 const TransformInput& optimize_va (const FCELL& vis, const FCELL& alt)
-	static CacheMap timap;
-	static TransformInput ti;
+    static CacheMap timap;
+    static TransformInput ti;
-	IntPair key(vis, alt);
-	CacheMap::iterator it = timap.find(key);
+    IntPair key(vis, alt);
+    CacheMap::iterator it = timap.find(key);
-	if(it != timap.end()) /* search found key */
-		ti = (*it).second;
-	else
-		pre_compute_hv(alt, vis);
-		ti = compute();
-		timap.insert(std::make_pair(key, ti));
+    if(it != timap.end()) /* search found key */
+	ti = (*it).second;
+    else
+	pre_compute_hv(alt, vis);
+	ti = compute();
+	timap.insert(std::make_pair(key, ti));
-	return ti;
+    return ti;
 /* Process the raster and do atmospheric corrections.
-Params:
- * INPUT FILE
- ifd: input file descriptor
- iref: input file has radiance values (default is reflectance) ?
- iscale: input file's range (default is min = 0, max = 255)
- ialt_fd: height map file descriptor, negative if global value is used
- ivis_fd: visibility map file descriptor, negative if global value is used
+   Params:
+   * INPUT FILE
+   ifd: input file descriptor
+   iref: input file has radiance values (default is reflectance) ?
+   iscale: input file's range (default is min = 0, max = 255)
+   ialt_fd: height map file descriptor, negative if global value is used
+   ivis_fd: visibility map file descriptor, negative if global value is used
- * OUTPUT FILE
- ofd: output file descriptor
- oflt: if true use FCELL_TYPE for output
- oscale: output file's range (default is min = 0, max = 255)
+   * OUTPUT FILE
+   ofd: output file descriptor
+   oflt: if true use FCELL_TYPE for output
+   oscale: output file's range (default is min = 0, max = 255)
 static void process_raster (int ifd, InputMask imask, ScaleRange iscale,
-                int ialt_fd, int ivis_fd, int ofd, bool oflt,
-                ScaleRange oscale, bool optimize)
+			    int ialt_fd, int ivis_fd, int ofd, bool oflt,
+			    ScaleRange oscale, bool optimize)
-	FCELL* buf;         /* buffer for the input values */
+    FCELL* buf;         /* buffer for the input values */
     FCELL* alt = NULL;         /* buffer for the elevation values */
     FCELL* vis = NULL;         /* buffer for the visibility values */
     FCELL  prev_alt = -1.f;
     FCELL  prev_vis = -1.f;
-	int row, col;
+    int row, col;
     /* do initial computation with global elevation and visibility values */
     TransformInput ti;
@@ -274,36 +274,36 @@
     TICache ticache;    /* use this to increase computation speed when an elevation map with categories are given */
     /* allocate memory for buffers */
-	buf = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
+    buf = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
     if(ialt_fd >= 0) alt = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
     if(ivis_fd >= 0) vis = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
     fprintf(stderr, "Percent complete: ");
-	for(row = 0; row < G_window_rows(); row++)
-        	G_percent(row, G_window_rows(), 1);     /* keep the user informed of our progress */
+    for(row = 0; row < G_window_rows(); row++)
+	G_percent(row, G_window_rows(), 1);     /* keep the user informed of our progress */
         /* read the next row */
-		if(G_get_raster_row(ifd, buf, row, FCELL_TYPE) < 0)
-			G_fatal_error ("Unable to read from input file");
+	if(G_get_raster_row(ifd, buf, row, FCELL_TYPE) < 0)
+	    G_fatal_error ("Unable to read from input file");
         /* read the next row of elevation values */
         if(ialt_fd >= 0)
-    		if(G_get_raster_row(ialt_fd, alt, row, FCELL_TYPE) < 0)
-	    		G_fatal_error ("Unable to read from elevation raster");
+	    if(G_get_raster_row(ialt_fd, alt, row, FCELL_TYPE) < 0)
+		G_fatal_error ("Unable to read from elevation raster");
         if(ivis_fd >= 0)
-    		if(G_get_raster_row(ivis_fd, vis, row, FCELL_TYPE) < 0)
-	    		G_fatal_error ("Unable to read from visibility raster");
+	    if(G_get_raster_row(ivis_fd, vis, row, FCELL_TYPE) < 0)
+		G_fatal_error ("Unable to read from visibility raster");
         /* loop over all the values in the row */
 /* TODO: use G_set_f_null_value()?? */
-		if(vis && isnan(vis[col]) || alt && isnan(alt[col]) || isnan(buf[col])) {buf[col] = FP_NAN; continue;}
-      		alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
+	    if(vis && isnan(vis[col]) || alt && isnan(alt[col]) || isnan(buf[col])) {buf[col] = FP_NAN; continue;}
+	    alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
             /* check if both maps are active and if whether any value has changed */
             if((ialt_fd >= 0) && (ivis_fd >= 0) && ((prev_vis != vis[col]) || (prev_alt != alt[col])))
@@ -312,8 +312,8 @@
                	prev_vis = vis[col];
  		if(optimize) ti = optimize_va(vis[col], alt[col]); /* try to optimize? */
 		else { /* no optimizations */
-		   pre_compute_hv(alt[col], vis[col]);
-               	   ti = compute();
+		    pre_compute_hv(alt[col], vis[col]);
+		    ti = compute();
             else    /* only one of the maps is being used */
@@ -372,16 +372,16 @@
             buf[col] = buf[col] * ((float)oscale.max - (float)oscale.min) + oscale.min;
             if(~oflt && (buf[col] > (float)oscale.max))
-              G_warning ("The output data will overflow. Reflectance > 100%%");
+		G_warning ("The output data will overflow. Reflectance > 100%%");
         /* write output */
-		if(oflt) G_put_raster_row(ofd, buf, FCELL_TYPE);
-		else write_fp_to_cell(ofd, buf);
+	if(oflt) G_put_raster_row(ofd, buf, FCELL_TYPE);
+	else write_fp_to_cell(ofd, buf);
     /* free allocated memory */
-	G_free(buf);
+    G_free(buf);
     if(ialt_fd >= 0) G_free(alt);
     if(ivis_fd >= 0) G_free(vis);
@@ -391,111 +391,111 @@
 /* Copy the colors from map named iname to the map named oname */
 static void copy_colors (char *iname, char *imapset, char *oname)
-	struct Colors colors;
+    struct Colors colors;
-	G_read_colors(iname, imapset, &colors);
-	G_write_colors(oname, G_mapset(), &colors);
+    G_read_colors(iname, imapset, &colors);
+    G_write_colors(oname, G_mapset(), &colors);
 /* Define our module so that Grass can print it if the user wants to know more. */
 static void define_module (void)
-	struct GModule *module;
+    struct GModule *module;
-	module = G_define_module();
-	module->label = _("Performs atmospheric correction using the 6S algorithm.");
-	module->description =
-	 _("6S - Second Simulation of Satellite Signal in the Solar Spectrum.");
-	 " Incorporated into Grass by Christo A. Zietsman, January 2003.\n"
-	 " Converted from Fortran to C by Christo A. Zietsman, November 2002.\n\n"
-	 " Adapted by Mauro A. Homem Antunes for atmopheric corrections of\n"
-	 " remotely sensed images in raw format (.RAW) of 8 bits.\n"
-	 " April 4, 2001.\n\n"
-	 " Please refer to the following paper and acknowledge the authors of\n"
-	 " the model:\n"
-	 " Vermote, E.F., Tanre, D., Deuze, J.L., Herman, M., and Morcrette,\n"
-	 "    J.J., (1997), Second simulation of the satellite signal in\n"
-	 "    the solar spectrum, 6S: An overview., IEEE Trans. Geosc.\n"
-	 "    and Remote Sens. 35(3):675-686.\n"
-	 " The code is provided as is and is not to be sold. See notes on\n"
-	 " http://loasys.univ-lille1.fr/informatique/sixs_gb.html\n"
-	 " http://www.ltid.inpe.br/dsr/mauro/6s/index.html\n"
-	 " and on http://www.cs.sun.ac.za/~caz/index.html\n";*/
+    module = G_define_module();
+    module->label = _("Performs atmospheric correction using the 6S algorithm.");
+    module->description =
+	_("6S - Second Simulation of Satellite Signal in the Solar Spectrum.");
+       " Incorporated into Grass by Christo A. Zietsman, January 2003.\n"
+       " Converted from Fortran to C by Christo A. Zietsman, November 2002.\n\n"
+       " Adapted by Mauro A. Homem Antunes for atmopheric corrections of\n"
+       " remotely sensed images in raw format (.RAW) of 8 bits.\n"
+       " April 4, 2001.\n\n"
+       " Please refer to the following paper and acknowledge the authors of\n"
+       " the model:\n"
+       " Vermote, E.F., Tanre, D., Deuze, J.L., Herman, M., and Morcrette,\n"
+       "    J.J., (1997), Second simulation of the satellite signal in\n"
+       "    the solar spectrum, 6S: An overview., IEEE Trans. Geosc.\n"
+       "    and Remote Sens. 35(3):675-686.\n"
+       " The code is provided as is and is not to be sold. See notes on\n"
+       " http://loasys.univ-lille1.fr/informatique/sixs_gb.html\n"
+       " http://www.ltid.inpe.br/dsr/mauro/6s/index.html\n"
+       " and on http://www.cs.sun.ac.za/~caz/index.html\n";*/
 /* Define the options and flags */
 static struct Options define_options (void)
-	struct Options opts;
+    struct Options opts;
-	opts.iimg = G_define_standard_option (G_OPT_R_INPUT);
-	opts.iimg->key		= "iimg";
-	opts.iimg->description	= "Input imagery map to be corrected";
+    opts.iimg = G_define_standard_option (G_OPT_R_INPUT);
+    opts.iimg->key		= "iimg";
+    opts.iimg->description	= "Input imagery map to be corrected";
 /*	opts.iimg->answer	= "ETM4_400x400.raw"; */
-	opts.iscl = G_define_option();
-	opts.iscl->key          = "iscl";
-	opts.iscl->type         = TYPE_INTEGER;
-	opts.iscl->key_desc     = "Input scale range";
-	opts.iscl->required     = NO;
-	opts.iscl->answer       = "0,255";
-	opts.iscl->description  = "Input imagery range [0,255]";
+    opts.iscl = G_define_option();
+    opts.iscl->key          = "iscl";
+    opts.iscl->type         = TYPE_INTEGER;
+    opts.iscl->key_desc     = "Input scale range";
+    opts.iscl->required     = NO;
+    opts.iscl->answer       = "0,255";
+    opts.iscl->description  = "Input imagery range [0,255]";
-	opts.ialt = G_define_standard_option (G_OPT_R_INPUT);
-	opts.ialt->key		= "ialt";
-	opts.ialt->required	= NO;
-	opts.ialt->answer	= "dem_float";
-	opts.ialt->description	= "Input altitude map in m (optional)";
+    opts.ialt = G_define_standard_option (G_OPT_R_INPUT);
+    opts.ialt->key		= "ialt";
+    opts.ialt->required	= NO;
+    opts.ialt->answer	= "dem_float";
+    opts.ialt->description	= "Input altitude map in m (optional)";
-	opts.ivis = G_define_standard_option (G_OPT_R_INPUT);
-	opts.ivis->key		= "ivis";
-	opts.ivis->required	= NO;
+    opts.ivis = G_define_standard_option (G_OPT_R_INPUT);
+    opts.ivis->key		= "ivis";
+    opts.ivis->required	= NO;
 /*	opts.ivis->answer	= "visibility"; */
-	opts.ivis->description	= "Input visibility map in km (optional)";
+    opts.ivis->description	= "Input visibility map in km (optional)";
-	opts.icnd = G_define_standard_option (G_OPT_F_INPUT);
-	opts.icnd->key		= "icnd";
-	opts.icnd->required	= YES;
+    opts.icnd = G_define_standard_option (G_OPT_F_INPUT);
+    opts.icnd->key		= "icnd";
+    opts.icnd->required	= YES;
 /*	opts.icnd->answer	= "ETM4_atmospheric_input_GRASS.txt"; */
-	opts.icnd->description	= "6S input text file";
+    opts.icnd->description	= "6S input text file";
-	opts.oimg = G_define_standard_option (G_OPT_R_OUTPUT);
-	opts.oimg->key		= "oimg";
+    opts.oimg = G_define_standard_option (G_OPT_R_OUTPUT);
+    opts.oimg->key		= "oimg";
 /*	opts.oimg->answer	= "6s_output_file"; */
-	opts.oimg->description	= "6S output imagery map";
+    opts.oimg->description	= "6S output imagery map";
-	opts.oscl = G_define_option();
-	opts.oscl->key          = "oscl";
-	opts.oscl->type         = TYPE_INTEGER;
-	opts.oscl->key_desc     = "Output scale range";
-	opts.oscl->required     = YES;
-	opts.oscl->answer       = "0,255";
-	opts.oscl->description  = "Rescale output imagery map [0,255]";
+    opts.oscl = G_define_option();
+    opts.oscl->key          = "oscl";
+    opts.oscl->type         = TYPE_INTEGER;
+    opts.oscl->key_desc     = "Output scale range";
+    opts.oscl->required     = YES;
+    opts.oscl->answer       = "0,255";
+    opts.oscl->description  = "Rescale output imagery map [0,255]";
-	opts.oflt = G_define_flag();
-	opts.oflt->key = 'f';
-	opts.oflt->description = "Output raster is floating point";
+    opts.oflt = G_define_flag();
+    opts.oflt->key = 'f';
+    opts.oflt->description = "Output raster is floating point";
-	opts.irad = G_define_flag();
-	opts.irad->key = 'r';
-	opts.irad->description = "Input map converted to reflectance (default is radiance)";
+    opts.irad = G_define_flag();
+    opts.irad->key = 'r';
+    opts.irad->description = "Input map converted to reflectance (default is radiance)";
-	opts.etmafter = G_define_flag();
-	opts.etmafter->key = 'a';
-	opts.etmafter->description = "Input from ETM+ image taken after July 1, 2000";
+    opts.etmafter = G_define_flag();
+    opts.etmafter->key = 'a';
+    opts.etmafter->description = "Input from ETM+ image taken after July 1, 2000";
-	opts.etmbefore = G_define_flag();
-	opts.etmbefore->key = 'b';
-	opts.etmbefore->description = "Input from ETM+ image taken before July 1, 2000";
+    opts.etmbefore = G_define_flag();
+    opts.etmbefore->key = 'b';
+    opts.etmbefore->description = "Input from ETM+ image taken before July 1, 2000";
-	opts.optimize = G_define_flag();
-	opts.optimize->key = 'o';
-	opts.optimize->description = "Try to increase computation speed when categorized altitude or/and visibility map is used.";
+    opts.optimize = G_define_flag();
+    opts.optimize->key = 'o';
+    opts.optimize->description = "Try to increase computation speed when categorized altitude or/and visibility map is used.";
-	return opts;
+    return opts;
 /* Read the min and max values from the iscl and oscl options */
@@ -532,88 +532,88 @@
 int main(int argc, char* argv[])
     struct ScaleRange iscale;   /* input file's data is scaled to this interval */
     struct ScaleRange oscale;   /* output file's scale */
-	int iimg_fd;	        /* input image's file descriptor */
-	int oimg_fd;	        /* output image's file descriptor */
-	int ialt_fd = -1;       /* input elevation map's file descriptor */
+    int iimg_fd;	        /* input image's file descriptor */
+    int oimg_fd;	        /* output image's file descriptor */
+    int ialt_fd = -1;       /* input elevation map's file descriptor */
     int ivis_fd = -1;       /* input visibility map's file descriptor */
     char *iimg_mapset, *ialt_mapset, *iviz_mapset;
-	/* Define module */
-	define_module();
+    /* Define module */
+    define_module();
     /* Define the different input options */
-	opts = define_options();
+    opts = define_options();
-	/**** Start ****/
-	G_gisinit(argv[0]);
-	if (G_parser(argc, argv) < 0)
-		exit (EXIT_FAILURE);
+    /**** Start ****/
+    G_gisinit(argv[0]);
+    if (G_parser(argc, argv) < 0)
+	exit (EXIT_FAILURE);
-	/* open input raster */
-	if ( (iimg_mapset = G_find_cell2 ( opts.iimg->answer, "") ) == NULL )
-	     G_fatal_error ( _("Raster map <%s> not found"), opts.iimg->answer);
-	if((iimg_fd = G_open_cell_old(opts.iimg->answer, iimg_mapset)) < 0)
-		G_fatal_error ("Unable to open input raster");
+    /* open input raster */
+    if ( (iimg_mapset = G_find_cell2 ( opts.iimg->answer, "") ) == NULL )
+	G_fatal_error ( _("Raster map <%s> not found"), opts.iimg->answer);
+    if((iimg_fd = G_open_cell_old(opts.iimg->answer, iimg_mapset)) < 0)
+	G_fatal_error ("Unable to open input raster");
-	adjust_region(opts.iimg->answer, iimg_mapset);
+    adjust_region(opts.iimg->answer, iimg_mapset);
-        if(opts.ialt->answer) {
-	  if ( (ialt_mapset = G_find_cell2 ( opts.ialt->answer, "") ) == NULL )
+    if(opts.ialt->answer) {
+	if ( (ialt_mapset = G_find_cell2 ( opts.ialt->answer, "") ) == NULL )
 	    G_fatal_error ( _("Raster map <%s> not found"), opts.ialt->answer);
-	  if((ialt_fd = G_open_cell_old(opts.ialt->answer, ialt_mapset)) < 0)
+	if((ialt_fd = G_open_cell_old(opts.ialt->answer, ialt_mapset)) < 0)
             G_warning ("Unable to open DEM raster");
-	if(opts.ivis->answer) {
-	  if ( (iviz_mapset = G_find_cell2 ( opts.ivis->answer, "") ) == NULL )
-	       G_fatal_error ( _("Raster map <%s> not found"), opts.ivis->answer);
-          if((ivis_fd = G_open_cell_old(opts.ivis->answer, iviz_mapset)) < 0)
+    if(opts.ivis->answer) {
+	if ( (iviz_mapset = G_find_cell2 ( opts.ivis->answer, "") ) == NULL )
+	    G_fatal_error ( _("Raster map <%s> not found"), opts.ivis->answer);
+	if((ivis_fd = G_open_cell_old(opts.ivis->answer, iviz_mapset)) < 0)
             G_warning ("Unable to open visibility raster");
-	/* open a floating point raster or not? */
-	if(opts.oflt->answer)
-		if((oimg_fd = G_open_fp_cell_new(opts.oimg->answer)) < 0)
-			G_fatal_error ("Unable to create output raster");
-	else
-		if((oimg_fd = G_open_raster_new(opts.oimg->answer, CELL_TYPE)) < 0)
+    /* open a floating point raster or not? */
+    if(opts.oflt->answer)
+	if((oimg_fd = G_open_fp_cell_new(opts.oimg->answer)) < 0)
+	    G_fatal_error ("Unable to create output raster");
+    else
+	if((oimg_fd = G_open_raster_new(opts.oimg->answer, CELL_TYPE)) < 0)
     /* read the scale parameters */
     read_scale(opts.iscl, iscale);
     read_scale(opts.oscl, oscale);
     /* initialize this 6s computation and parse the input conditions file */
-	init_6S(opts.icnd->answer);
+    init_6S(opts.icnd->answer);
     InputMask imask = RADIANCE;         /* the input mask tells us what transformations if any
-                                         needs to be done to make our input values, reflectance
-                                         values scaled between 0 and 1 */
+					   needs to be done to make our input values, reflectance
+					   values scaled between 0 and 1 */
     if(opts.irad->answer) imask = REFLECTANCE;
     if(opts.etmbefore->answer) imask = (InputMask)(imask | ETM_BEFORE);
     if(opts.etmafter->answer) imask = (InputMask)(imask | ETM_AFTER);
     /* process the input raster and produce our atmospheric corrected output raster. */
-	process_raster(iimg_fd, imask, iscale, ialt_fd, ivis_fd,
+    process_raster(iimg_fd, imask, iscale, ialt_fd, ivis_fd,
                    oimg_fd, opts.oflt->answer, oscale, opts.optimize->answer);
     /* Close the input and output file descriptors */
-	G_close_cell(iimg_fd);
+    G_close_cell(iimg_fd);
     if(opts.ialt->answer) G_close_cell(ialt_fd);
     if(opts.ivis->answer) G_close_cell(ivis_fd);
-	G_close_cell(oimg_fd);
+    G_close_cell(oimg_fd);
     /* Copy the colors of the input raster to the output raster.
        Scaling is ignored and color ranges might not be correct. */
-	copy_colors(opts.iimg->answer, iimg_mapset, opts.oimg->answer);
+    copy_colors(opts.iimg->answer, iimg_mapset, opts.oimg->answer);
-	exit (EXIT_SUCCESS);
+    exit (EXIT_SUCCESS);
