[GRASS-SVN] r33227 - grass/branches/develbranch_6/raster/r.in.bin
svn_grass at osgeo.org
Wed Sep 3 03:26:40 EDT 2008
Author: hamish
Date: 2008-09-03 03:26:39 -0400 (Wed, 03 Sep 2008)
New Revision: 33227
grass/branches/develbranch_6/raster/r.in.bin/main.c
use G_fatal_error not return 1
Modified: grass/branches/develbranch_6/raster/r.in.bin/main.c
--- grass/branches/develbranch_6/raster/r.in.bin/main.c 2008-09-02 22:10:44 UTC (rev 33226)
+++ grass/branches/develbranch_6/raster/r.in.bin/main.c 2008-09-03 07:26:39 UTC (rev 33227)
@@ -2,7 +2,7 @@
* r.in.bin
* Copyright (C) 2000 by the GRASS Development Team
- * Author: Bob Covill <bcovill at tekmap.ns.ca>
+ * Author: Bob Covill <bcovill tekmap.ns.ca>
* This program is free software under the GPL (>=v2)
* Read the file COPYING coming with GRASS for details.
@@ -239,9 +239,9 @@
else if (flag.d->answer)
bytes = 8;
else if (sscanf(parm.bytes->answer, "%d%1s", &bytes, dummy) != 1)
- return 1;
+ G_fatal_error(_("Parsing bytes per cell"));
if (bytes <= 0)
- return 1;
+ G_fatal_error(_("Bad number of bytes per cell"));
sflag = flag.s->answer;
swap = 0;
@@ -291,20 +291,18 @@
if (!parm.north->answer || !parm.south->answer ||
!parm.west->answer || !parm.east->answer)
G_fatal_error(_("You have to provide all limits of geographic region (n,s,e,w)"));
- if (!G_scan_northing
- (parm.north->answer, &cellhd.north, cellhd.proj))
- return 1;
- (parm.south->answer, &cellhd.south, cellhd.proj))
- return 1;
+ if (!G_scan_northing(parm.north->answer, &cellhd.north, cellhd.proj))
+ G_fatal_error(_("Illegal north coordinate <%s>"), parm.north->answer);
+ if (!G_scan_northing(parm.south->answer, &cellhd.south, cellhd.proj))
+ G_fatal_error(_("Illegal south coordinate <%s>"), parm.south->answer);
if (!G_scan_easting(parm.east->answer, &cellhd.east, cellhd.proj))
- return 1;
+ G_fatal_error(_("Illegal east coordinate <%s>"), parm.east->answer);
if (!G_scan_easting(parm.west->answer, &cellhd.west, cellhd.proj))
- return 1;
+ G_fatal_error(_("Illegal west coordinate <%s>"), parm.west->answer);
if (sscanf(parm.rows->answer, "%d%1s", &cellhd.rows, dummy) != 1)
- return 1;
+ G_fatal_error(_("Illegal number of rows <%s>"), parm.rows->answer);
if (sscanf(parm.cols->answer, "%d%1s", &cellhd.cols, dummy) != 1)
- return 1;
+ G_fatal_error(_("Illegal number of columns <%s>"), parm.cols->answer);
/* CASE 2 - Get only rows and columns and calculate N S E W */
@@ -312,10 +310,10 @@
if (no_dim == 0 && no_coord == 1) { /* Get rows and cols only */
|| cellhd.rows <= 0)
- return 1;
|| cellhd.cols <= 0)
- return 1;
cellhd.north = (double)cellhd.rows;
cellhd.south = 0.;
cellhd.east = (double)cellhd.cols;
@@ -331,18 +329,16 @@
if (no_coord == 0 && no_dim == 1) { /* Get n, s, e, w */
- G_fatal_error
- ("You have to provide all limits of geographic region (n,s,e,w)");
- return 1;
- return 1;
+ G_fatal_error(
+ _("You have to provide all limits of geographic region (n,s,e,w)"));
- return 1;
- return 1;
/* Calculate rows and cols */
cellhd.rows = (int)cellhd.north - cellhd.south;
@@ -498,7 +494,7 @@
cf = G_open_raster_new(output, map_type);
if (cf < 0) {
- G_fatal_error(_("Unable to create raster map %s"), output);
+ G_fatal_error(_("Unable to create raster map <%s>"), output);
exit(EXIT_FAILURE);
@@ -510,8 +506,10 @@
x_c = (char *)x_v;
if (cellhd.proj == PROJECTION_LL && cellhd.ew_res / cellhd.ns_res > 10.) /* TODO: find a reasonable value */
- G_warning
- ("East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?",
+ G_warning(
+ _("East-West (ewres: %f) and North-South (nwres: %f) "
+ "resolution differ significantly. "
+ "Did you assign east= and west= correctly?"),
cellhd.ew_res, cellhd.ns_res);
for (row = 0; row < grass_nrows; row++) {
