[GRASS-SVN] r33238 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Wed Sep 3 12:56:18 EDT 2008
Author: martinl
Date: 2008-09-03 12:56:18 -0400 (Wed, 03 Sep 2008)
New Revision: 33238
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/line.cpp
grass/trunk/gui/wxpython/vdigit/vertex.cpp
wxGUI: break lines at intersection also works for
move vertex
move line
edit line
copy lines from background map
(merge from devbr6, r33236)
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-03 16:50:26 UTC (rev 33237)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-03 16:56:18 UTC (rev 33238)
@@ -1001,8 +1001,12 @@
snap, thresh = self.__getSnapThreshold()
- ret = self.digit.RewriteLine(lineid, listCoords,
- str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
+ try:
+ ret = self.digit.RewriteLine(lineid, listCoords,
+ str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')),
+ snap, thresh)
+ except SystemExit:
+ pass
if ret > 0:
self.toolbar.EnableUndo()
@@ -1836,7 +1840,7 @@
box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Digitize line features"))
sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- self.intersect = wx.CheckBox(parent=panel, label=_("Break lines on intersection"))
+ self.intersect = wx.CheckBox(parent=panel, label=_("Break lines at intersection"))
self.intersect.SetValue(UserSettings.Get(group='vdigit', key='breakLines', subkey='enabled'))
if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
self.intersect.Enable(False)
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-09-03 16:50:26 UTC (rev 33237)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-09-03 16:56:18 UTC (rev 33238)
@@ -17,6 +17,12 @@
int SetCategory(int, int);
struct Map_info** OpenBackgroundVectorMap(const char *);
+ int BreakLineAtIntersection(int, struct line_pnts*);
+ /* settings */
+ struct _settings {
+ bool breakLines;
+ } settings;
/* undo/redo */
enum action_type { ADD, DELETE, REWRITE };
@@ -29,11 +35,6 @@
struct line_cats *Cats;
- /* settings */
- struct _settings {
- bool breakLines;
- } settings;
std::map<int, std::vector<action_meta> > changesets;
int changesetCurrent; /* first changeset to apply */
int changesetDead; /* first dead changeset */
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-09-03 16:50:26 UTC (rev 33237)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-09-03 16:56:18 UTC (rev 33238)
@@ -133,48 +133,9 @@
return -1;
- /* break on intersection */
+ /* break at intersection */
if (settings.breakLines) {
- int lineBreak;
- BOUND_BOX lineBox;
- struct ilist *list, *listBreak, *listRef;
- struct line_pnts *points_check;
- list = Vect_new_list();
- listRef = Vect_new_list();
- listBreak = Vect_new_list();
- points_check = Vect_new_line_struct();
- /* find all relevant lines */
- Vect_get_line_box(display->mapInfo, newline, &lineBox);
- Vect_select_lines_by_box(display->mapInfo, &lineBox,
- GV_LINES, list);
- /* check for intersection */
- Vect_list_append(listBreak, newline);
- Vect_list_append(listRef, newline);
- for (int i = 0; i < list->n_values; i++) {
- lineBreak = list->value[i];
- if (lineBreak == newline)
- continue;
- type = Vect_read_line(display->mapInfo, points_check, NULL, lineBreak);
- if (!(type & GV_LINES))
- continue;
- if (Vect_line_check_intersection(Points, points_check,
- WITHOUT_Z))
- Vect_list_append(listBreak, lineBreak);
- Vect_break_lines_list(display->mapInfo, listBreak, listRef,
- GV_LINES, NULL, NULL);
- Vect_destroy_line_struct(points_check);
- Vect_destroy_list(list);
- Vect_destroy_list(listBreak);
- Vect_destroy_list(listRef);
+ BreakLineAtIntersection(newline, Points);
/* register changeset */
@@ -205,7 +166,7 @@
int Digit::RewriteLine(int line, std::vector<double> coords,
const char *bgmap, int snap, double threshold)
- int ret, type, dim;
+ int newline, type, dim;
struct line_pnts *points;
struct line_cats *cats;
@@ -236,16 +197,23 @@
- ret = 0;
- points = Vect_new_line_struct();
cats = Vect_new_cats_struct();
/* read line */
type = Vect_read_line(display->mapInfo, NULL, cats, line);
if (type < 0) {
- ret = -1;
+ Vect_destroy_cats_struct(cats);
+ if (BgMap && BgMap[0]) {
+ Vect_close(BgMap[0]);
+ ReadLineMsg(line);
+ return -1;
+ points = Vect_new_line_struct();
/* define line geometry */
if (Vect_is_3d(display->mapInfo)) {
dim = 3;
@@ -272,10 +240,14 @@
// AddActionToChangeset(changesets.size(), REWRITE, line);
/* rewrite line */
- if (ret == 0) {
- ret = Vect_rewrite_line(display->mapInfo, line, type, points, cats);
+ newline = Vect_rewrite_line(display->mapInfo, line, type, points, cats);
+ if (newline > 0 && settings.breakLines) {
+ BreakLineAtIntersection(newline, points);
+ if (newline < 0)
+ WriteLineMsg();
/* TODO
if (ret > 0) {
changesets[changesets.size()-1][0].line = Vect_get_num_lines(display->mapInfo);
@@ -287,12 +259,12 @@
Vect_destroy_line_struct(points);
- return ret;
+ return newline;
@@ -530,6 +502,11 @@
move_x, move_y, move_z,
snap, thresh);
+ if (ret > 0 && settings.breakLines) {
+ for(int i = 1; i <= ret; i++)
+ BreakLineAtIntersection(nlines+i, NULL);
/* TODO
if (ret > 0) {
for (int i = 0; i < display->selected.values->n_values; i++) {
@@ -821,6 +798,11 @@
ret = Vedit_copy_lines (display->mapInfo, bgMap,
list);
+ if (ret > 0 && bgMap && settings.breakLines) {
if (ret > 0) {
changeset = changesets.size();
@@ -938,3 +920,70 @@
return ret;
+ \brief Break given line at intersection
+ \param line line id
+ \return number of modified lines
+int Digit::BreakLineAtIntersection(int line, struct line_pnts* points_line)
+ int ret, type;
+ int lineBreak;
+ BOUND_BOX lineBox;
+ struct ilist *list, *listBreak, *listRef;
+ struct line_pnts *points_check, *points;
+ if (!points_line) {
+ if (Vect_read_line(display->mapInfo, points, NULL, line) < 0) {
+ return -1;
+ else {
+ points = points_line;
+ list = Vect_new_list();
+ listRef = Vect_new_list();
+ listBreak = Vect_new_list();
+ points_check = Vect_new_line_struct();
+ /* find all relevant lines */
+ Vect_get_line_box(display->mapInfo, line, &lineBox);
+ Vect_select_lines_by_box(display->mapInfo, &lineBox,
+ GV_LINES, list);
+ /* check for intersection */
+ Vect_list_append(listBreak, line);
+ Vect_list_append(listRef, line);
+ for (int i = 0; i < list->n_values; i++) {
+ lineBreak = list->value[i];
+ if (lineBreak == line)
+ continue;
+ type = Vect_read_line(display->mapInfo, points_check, NULL, lineBreak);
+ if (!(type & GV_LINES))
+ continue;
+ if (Vect_line_check_intersection(points, points_check,
+ WITHOUT_Z))
+ Vect_list_append(listBreak, lineBreak);
+ ret = Vect_break_lines_list(display->mapInfo, listBreak, listRef,
+ GV_LINES, NULL, NULL);
+ Vect_destroy_line_struct(points_check);
+ if (points != points_line)
+ Vect_destroy_line_struct(points);
+ Vect_destroy_list(list);
+ Vect_destroy_list(listBreak);
+ Vect_destroy_list(listRef);
+ return ret;
Modified: grass/trunk/gui/wxpython/vdigit/vertex.cpp
--- grass/trunk/gui/wxpython/vdigit/vertex.cpp 2008-09-03 16:50:26 UTC (rev 33237)
+++ grass/trunk/gui/wxpython/vdigit/vertex.cpp 2008-09-03 16:56:18 UTC (rev 33238)
@@ -76,8 +76,12 @@
display->selected.values,
point, thresh_coords, thresh_snap,
- 1, snap);
+ 1, snap);
+ if (settings.breakLines && ret > 0) {
+ BreakLineAtIntersection(Vect_get_num_lines(display->mapInfo), NULL);
/* TODO
if (ret > 0) {
