[GRASS-SVN] r33241 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Thu Sep 4 04:18:42 EDT 2008
Author: martinl
Date: 2008-09-04 04:18:41 -0400 (Thu, 04 Sep 2008)
New Revision: 33241
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: new vector dialog optionally create also attribute table
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-09-04 08:11:53 UTC (rev 33240)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-09-04 08:18:41 UTC (rev 33241)
@@ -2122,6 +2122,7 @@
# list of table widgets
+ keyCol = UserSettings.Get(group='atm', key='keycolumn', subkey='value')
self.tableWidgets = {'table': (wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
label='%s:' % _("Table name")),
wx.TextCtrl(parent=self.addPanel, id=wx.ID_ANY,
@@ -2130,7 +2131,7 @@
'key': (wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
label='%s:' % _("Key column")),
- value='cat',
+ value=keyCol,
style=wx.TE_PROCESS_ENTER))}
# events
self.tableWidgets['table'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2008-09-04 08:11:53 UTC (rev 33240)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2008-09-04 08:18:41 UTC (rev 33241)
@@ -42,7 +42,7 @@
class NewVectorDialog(wx.Dialog):
"""Create new vector map layer"""
- def __init__(self, parent, id, title,
+ def __init__(self, parent, id, title, disableAdd=False,
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
wx.Dialog.__init__(self, parent, id, title, style=style)
@@ -58,7 +58,18 @@
label=_("Name for new vector map:"))
self.mapName = gselect.Select(parent=self.panel, id=wx.ID_ANY, size=globalvar.DIALOG_GSELECT_SIZE,
type='vector', mapsets=[grassenv.GetGRASSVariable('MAPSET'),])
+ self.table = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
+ label=_("Create attribute table"))
+ self.table.SetValue(True)
+ self.addbox = wx.CheckBox(parent=self.panel,
+ label=_('Add created map into layer tree'), style = wx.NO_BORDER)
+ if disableAdd:
+ self.addbox.SetValue(True)
+ self.addbox.Enable(False)
+ else:
+ self.addbox.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
self.mapName.Bind(wx.EVT_TEXT, self.OnMapName)
self.__Layout()
@@ -82,6 +93,14 @@
dataSizer.Add(self.mapName, proportion=0,
flag=wx.EXPAND | wx.ALL, border=1)
+ dataSizer.Add(self.table, proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=1)
+ dataSizer.AddSpacer(5)
+ dataSizer.Add(item=self.addbox, proportion=0,
# buttons
btnSizer = wx.StdDialogButtonSizer()
btnSizer.AddButton(self.btnCancel)
@@ -104,16 +123,17 @@
return mapName
def CreateNewVector(parent, cmdDef, title=_('Create new vector map'),
- exceptMap=None, log=None):
+ exceptMap=None, log=None, disableAdd=False):
@cmdList tuple/list (cmd list, output paramater)
- @return name of create vector map
+ @return tuple (name of create vector map, add to layer tree)
@return None of failure
cmd = cmdDef[0]
- dlg = NewVectorDialog(parent=parent, id=wx.ID_ANY, title=title)
+ dlg = NewVectorDialog(parent, wx.ID_ANY, title,
+ disableAdd)
if dlg.ShowModal() == wx.ID_OK:
outmap = dlg.GetName()
if outmap == exceptMap:
@@ -155,6 +175,24 @@
print >> sys.stderr, e
return None
+ # create attribute table
+ if dlg.table.IsChecked():
+ key = UserSettings.Get(group='atm', key='keycolumn', subkey='value')
+ sql = 'CREATE TABLE %s (%s INTEGER)' % (outmap, key)
+ gcmd.Command(['db.execute',
+ '--q'],
+ stdin=sql)
+ gcmd.Command(['v.db.connect',
+ '--q',
+ 'map=%s' % outmap,
+ 'table=%s' % outmap,
+ 'key=%s' % key,
+ 'layer=1'])
# return fully qualified map name
if '@' not in outmap:
outmap += '@' + grassenv.GetGRASSVariable('MAPSET')
@@ -162,9 +200,9 @@
if log:
log.WriteLog(_("New vector map <%s> created") % outmap)
- return outmap
+ return (outmap, dlg.addbox.IsChecked())
- return None
+ return (None, dlg.addbox.IsChecked())
class SavedRegion(wx.Dialog):
def __init__(self, parent, id, title="", pos=wx.DefaultPosition, size=wx.DefaultSize,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-09-04 08:11:53 UTC (rev 33240)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-09-04 08:18:41 UTC (rev 33241)
@@ -128,6 +128,9 @@
'askOnDeleteRec' : {
'enabled' : True
+ 'keycolumn' : {
+ 'value' : 'cat'
# Command
@@ -1253,6 +1256,36 @@
flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
border=3)
+ # create table
+ createTableBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
+ label=" %s " % _("Create table"))
+ createTableSizer = wx.StaticBoxSizer(createTableBox, wx.VERTICAL)
+ flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+ flexSizer.AddGrowableCol(0)
+ label = wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Key column"))
+ keyColumn = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
+ size=(250, -1))
+ keyColumn.SetValue(self.settings.Get(group='atm', key='keycolumn', subkey='value'))
+ self.winId['atm:keycolumn:value'] = keyColumn.GetId()
+ flexSizer.Add(label, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(keyColumn, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ createTableSizer.Add(item=flexSizer,
+ proportion=0,
+ flag=wx.ALL | wx.EXPAND,
+ border=5)
+ pageSizer.Add(item=createTableSizer,
+ proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
+ border=3)
panel.SetSizer(pageSizer)
return panel
@@ -1438,15 +1471,15 @@
def OnSave(self, event):
"""Button 'Save' pressed"""
- self.__UpdateSettings()
- file = self.settings.SaveToFile()
- self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % file)
- self.Close()
+ if self.__UpdateSettings():
+ file = self.settings.SaveToFile()
+ self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % file)
+ self.Close()
def OnApply(self, event):
"""Button 'Apply' pressed"""
- self.Close()
+ self.Close()
def OnCancel(self, event):
"""Button 'Cancel' pressed"""
@@ -1474,7 +1507,6 @@
else:
value = win.SetValue(value)
def __UpdateSettings(self):
"""Update user settings"""
for item in self.winId.keys():
@@ -1498,7 +1530,14 @@
value = tuple(win.GetValue())
else:
value = win.GetValue()
+ if key == 'keycolumn' and value == '':
+ wx.MessageBox(parent=self,
+ message=_("Key column cannot be empty string."),
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
+ win.SetValue(self.settings.Get(group='atm', key='keycolumn', subkey='value'))
+ return False
if subkey1:
self.settings.Set(group, value, key, [subkey, subkey1])
else:
@@ -1524,6 +1563,8 @@
else:
self.settings.Set(group='general', key='defWindowPos', subkey='dim', value='')
+ return True
class SetDefaultFont(wx.Dialog):
Opens a file selection dialog to select default font
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2008-09-04 08:11:53 UTC (rev 33240)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2008-09-04 08:18:41 UTC (rev 33241)
@@ -980,7 +980,8 @@
openVectorMap = None
mapName = gdialogs.CreateNewVector(self.parent,
exceptMap=openVectorMap, log=self.log,
- cmdDef=(['v.edit', 'tool=create'], "map"))
+ cmdDef=(['v.edit', 'tool=create'], "map"),
+ disableAdd=True)[0]
if mapName:
# add layer to map layer tree
if self.layerTree:
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-09-04 08:11:53 UTC (rev 33240)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-09-04 08:18:41 UTC (rev 33241)
@@ -465,8 +465,16 @@
def OnNewVector(self, event):
- name = gdialogs.CreateNewVector(self, log=self.goutput,
+ name, add = gdialogs.CreateNewVector(self, log=self.goutput,
+ cmdDef=(['v.edit', 'tool=create'], "map"))
+ if name and add:
+ # add layer to map layer tree
+ self.curr_page.maptree.AddLayer(ltype='vector',
+ lname=name,
+ lchecked=True,
+ lopacity=1.0,
+ lcmd=['d.vect', 'map=%s' % name])
def OnAboutGRASS(self, event):
"""Display 'About GRASS' dialog"""
