[GRASS-SVN] r33247 - grass/branches/develbranch_6/vector/v.what
Thu Sep 4 09:51:59 EDT 2008
Author: martinl
Date: 2008-09-04 09:51:59 -0400 (Thu, 04 Sep 2008)
New Revision: 33247
   grass/branches/develbranch_6/vector/v.what/what.c
v.what: use same key ('type') for all features
redundant spaces removed
Modified: grass/branches/develbranch_6/vector/v.what/what.c
--- grass/branches/develbranch_6/vector/v.what/what.c	2008-09-04 13:13:48 UTC (rev 33246)
+++ grass/branches/develbranch_6/vector/v.what/what.c	2008-09-04 13:51:59 UTC (rev 33247)
@@ -55,7 +55,7 @@
 	    getz = Vect_tin_get_z(&Map[i], east, north, &z, NULL, NULL);
-	G_debug(2, "line = %d \narea = %d", line, area);
+	G_debug(2, "line = %d area = %d", line, area);
 	if (!i) {
 	    G_format_easting(east, east_buf, G_projection());
@@ -96,7 +96,6 @@
 	if (line > 0) {
-	    sprintf(buf, "Object type: ");
 	    type = Vect_read_line(&Map[i], Points, Cats, line);
 	    switch (type) {
 	    case GV_POINT:
@@ -130,10 +129,10 @@
 		float angle;
 		Vect_get_line_areas(&(Map[i]), line, &left, &right);
-		fprintf(stdout, "Looking for features within: %f \n",
+		fprintf(stdout, "Looking for features within: %f\n",
 			maxdist);
 		fprintf(stdout,
-			_("Id: %d  \nType: %s  \nLeft: %d  \nRight: %d  \n"),
+			_("Id: %d\nType: %s\nLeft: %d\nRight: %d\n"),
 			line, buf, left, right);
 		if (type & GV_LINES) {
 		    nnodes = 2;
@@ -153,7 +152,7 @@
 		    Vect_get_node_coor(&(Map[i]), node[n], &nx, &ny, &nz);
 		    fprintf(stdout,
-			    _("Node[%d]: %d  \nNumber of lines: %d  \nCoordinates: %.6f, %.6f, %.6f\n"),
+			    _("Node[%d]: %d\nNumber of lines: %d\nCoordinates: %.6f, %.6f, %.6f\n"),
 			    n, node[n], nnlines, nx, ny, nz);
 		    for (nli = 0; nli < nnlines; nli++) {
@@ -161,7 +160,7 @@
 			    Vect_get_node_line(&(Map[i]), node[n], nli);
 			angle =
 			    Vect_get_node_line_angle(&(Map[i]), node[n], nli);
-			fprintf(stdout, _("Id: %5d  \nAngle: %.8f\n"),
+			fprintf(stdout, _("Id: %5d\nAngle: %.8f\n"),
 				nodeline, angle);
@@ -195,7 +194,7 @@
 		    else {
 			fprintf(stdout,
-				_("Line height min: %f \nLine height max: %f\n"),
+				_("Line height min: %f\nLine height max: %f\n"),
 				min, max);
@@ -204,18 +203,18 @@
 	if (area > 0) {
 	    if (Map[i].head.with_z && getz) {
-		fprintf(stdout, _("Object type: Area \nArea height: %f\n"),
+		fprintf(stdout, _("Type: Area\nArea height: %f\n"),
 			z);
 	    else {
-		fprintf(stdout, _("Object type: Area\n"));
+		fprintf(stdout, _("Type: Area\n"));
 	    sq_meters = Vect_get_area_area(&Map[i], area);
 	    if (topo) {
 		int nisles, isleidx, isle, isle_area;
 		nisles = Vect_get_area_num_isles(&Map[i], area);
-		fprintf(stdout, _("Area: %d  \nNumber of isles: %d\n"), area,
+		fprintf(stdout, _("Area: %d\nNumber of isles: %d\n"), area,
 			nisles);
 		for (isleidx = 0; isleidx < nisles; isleidx++) {
@@ -232,17 +231,17 @@
 	    else {
-		fprintf(stdout, _("Sq Meters: %.3f \nHectares: %.3f\n"),
+		fprintf(stdout, _("Sq Meters: %.3f\nHectares: %.3f\n"),
 			sq_meters, (sq_meters / 10000.));
-		fprintf(stdout, _("Acres: %.3f \nSq Miles: %.4f\n"),
+		fprintf(stdout, _("Acres: %.3f\nSq Miles: %.4f\n"),
 			((sq_meters * 10.763649) / 43560.),
 			((sq_meters * 10.763649) / 43560.) / 640.);
 		if (notty) {
 		    fprintf(stderr,
-			    _("Sq Meters: %.3f \nHectares: %.3f\n"),
+			    _("Sq Meters: %.3f\nHectares: %.3f\n"),
 		    fprintf(stderr,
-			    _("Acres: %.3f \nSq Miles: %.4f\n"),
+			    _("Acres: %.3f\nSq Miles: %.4f\n"),
@@ -258,9 +257,9 @@
 	    int j;
 	    for (j = 0; j < Cats->n_cats; j++) {
-		G_debug(2, "field = %d \ncategory = %d\n", Cats->field[j],
+		G_debug(2, "field = %d  category = %d\n", Cats->field[j],
 			Cats->cat[j]);
-		fprintf(stdout, _("Layer: %d\nCategory: %d \n"),
+		fprintf(stdout, _("Layer: %d\nCategory: %d\n"),
 			Cats->field[j], Cats->cat[j]);
 		Fi = Vect_get_field(&(Map[i]), Cats->field[j]);
 		if (Fi != NULL && showextra) {
