[GRASS-SVN] r33266 - in grass/trunk/general: . g.mlist g.mremove
svn_grass at osgeo.org
Thu Sep 4 18:24:02 EDT 2008
Author: glynn
Date: 2008-09-04 18:24:02 -0400 (Thu, 04 Sep 2008)
New Revision: 33266
Added:
grass/trunk/general/g.mlist/
grass/trunk/general/g.mremove/
Removed:
grass/trunk/general/g.mlist/gisdefs.h
grass/trunk/general/g.mlist/join.c
grass/trunk/general/g.mlist/ls.c
grass/trunk/general/g.mremove/gisdefs.h
grass/trunk/general/g.mremove/join.c
grass/trunk/general/g.mremove/ls.c
grass/trunk/general/g.mremove/sighold.c
grass/trunk/general/g.mlist/Makefile
grass/trunk/general/g.mlist/global.h
grass/trunk/general/g.mlist/main.c
grass/trunk/general/g.mlist/read_list.c
grass/trunk/general/g.mremove/Makefile
grass/trunk/general/g.mremove/do_remove.c
grass/trunk/general/g.mremove/global.h
grass/trunk/general/g.mremove/main.c
grass/trunk/general/g.mremove/read_list.c
Add g.mlist, g.mremove
Copied: grass/trunk/general/g.mlist (from rev 33262, grass-addons/general/g.xlist)
Property changes on: grass/trunk/general/g.mlist
___________________________________________________________________
+ *OBJ*
Modified: grass/trunk/general/g.mlist/Makefile
--- grass-addons/general/g.xlist/Makefile 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mlist/Makefile 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,6 +1,6 @@
-MODULE_TOPDIR = ../../../grass
+MODULE_TOPDIR = ../..
-PGM = g.xlist
+PGM = g.mlist
LIBES = $(GISLIB)
DEPENDENCIES = $(GISDEP)
Deleted: grass/trunk/general/g.mlist/gisdefs.h
--- grass-addons/general/g.xlist/gisdefs.h 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mlist/gisdefs.h 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,15 +0,0 @@
-#ifndef GISDEFS_H
-#define GISDEFS_H
-#define G_JOIN_ELEMENT_TYPE 0x1
-#define G_JOIN_ELEMENT_MAPSET 0x2
-/* join.c */
-const char *G_join_element(const char *, const char *, const char *,
- const char *, int, int *);
-/* ls.c */
-void G_set_ls_filter(int (*)(const char *, void *), void *);
-char **G__ls(const char *, int *);
-#endif
Modified: grass/trunk/general/g.mlist/global.h
--- grass-addons/general/g.xlist/global.h 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mlist/global.h 2008-09-04 22:24:02 UTC (rev 33266)
@@ -19,11 +19,5 @@
/* wc2regex.c */
char *wc2regex(const char *);
-#ifdef MAIN
-# define GLOBAL
-#else
-# define GLOBAL extern
-#endif
-GLOBAL int nlist;
-GLOBAL struct list *list;
+extern int nlist;
+extern struct list *list;
Deleted: grass/trunk/general/g.mlist/join.c
--- grass-addons/general/g.xlist/join.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mlist/join.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,158 +0,0 @@
- \file join.c
- \brief Return a string that contains elements
- \author Huidae Cho
- (C) 2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
-#include <stdlib.h>
-#include <unistd.h>
-#include <signal.h>
-#include <string.h>
-#include <sys/types.h>
-#include <dirent.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include "gisdefs.h"
-static int join_element(const char *, const char *, const char *,
- const char *, int, const char **);
- \brief General purpose join function.
- Will collect file names from all mapsets
- in the mapset list for a specified database element
- and join them into a string.
- Note: Use G_(set|get)_ls_filter functions to filter out unwanted file names.
- \param element Database element (eg, "cell", "cellhd", etc)
- \param alias Alias for element (if NULL, element is used)
- \param mapset Mapset to be listed "" to list all mapsets in mapset search list
- "." will list current mapset
- \param separator Map name separator
- \param flags G_JOIN_ELEMENT_TYPE Include alias
- G_JOIN_ELEMENT_MAPSET Include mapset name
- \param count Return the number of elements (if NULL, ignored)
- \return String pointer
-const char *G_join_element(const char *element,
- const char *alias,
- const char *mapset,
- const char *separator, int flags, int *count)
- int c, n;
- const char *buf;
- c = 0;
- if (alias == 0 || *alias == 0)
- alias = element;
- * if no specific mapset is requested, list the mapsets
- * from the mapset search list
- * otherwise just list the specified mapset
- buf = G_strdup("");
- if (mapset == 0 || *mapset == 0)
- for (n = 0; (mapset = G__mapset_name(n)); n++)
- c += join_element(element, alias, mapset, separator, flags, &buf);
- else
- c = join_element(element, alias, mapset, separator, flags, &buf);
- if (count)
- *count = c;
- return buf;
-static int join_element(const char *element,
- const char *separator, int flags, const char **buf)
- char path[GPATH_MAX], *p;
- int i, count = 0;
- int buf_len, alias_len, list_len, sep_len = strlen(separator), mapset_len;
- char **list;
- * convert . to current mapset
- if (strcmp(mapset, ".") == 0)
- mapset = G_mapset();
- mapset_len = strlen(mapset);
- * get the full name of the GIS directory within the mapset
- * and list its contents (if it exists)
- G__file_name(path, element, "", mapset);
- if (access(path, 0) != 0)
- return count;
- list = G__ls(path, &count);
- alias_len = strlen(alias);
- for (i = 0; i < count; i++) {
- buf_len = strlen(*buf);
- list_len = strlen(list[i]);
- *buf = (char *)G_realloc((char *)*buf,
- (buf_len ? buf_len + sep_len : 0) +
- (flags & G_JOIN_ELEMENT_TYPE ? alias_len +
- 1 : 0) + list_len +
- (flags & G_JOIN_ELEMENT_MAPSET ? mapset_len +
- 1 : 0) + 1);
- p = (char *)*buf + buf_len;
- /* looks dirty but fast! */
- if (buf_len) {
- if (flags & G_JOIN_ELEMENT_TYPE) {
- if (flags & G_JOIN_ELEMENT_MAPSET)
- sprintf(p, "%s%s/%s@%s", separator, alias, list[i],
- mapset);
- else
- sprintf(p, "%s%s/%s", separator, alias, list[i]);
- else {
- sprintf(p, "%s%s@%s", separator, list[i], mapset);
- else
- sprintf(p, "%s%s", separator, list[i]);
- else {
- sprintf(p, "%s/%s@%s", alias, list[i], mapset);
- else
- sprintf(p, "%s/%s", alias, list[i]);
- else {
- sprintf(p, "%s@%s", list[i], mapset);
- else
- sprintf(p, "%s", list[i]);
- G_free((char *)list[i]);
- if (list)
- G_free(list);
- return count;
Deleted: grass/trunk/general/g.mlist/ls.c
--- grass-addons/general/g.xlist/ls.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mlist/ls.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,105 +0,0 @@
- \file ls.c
- \brief Functions to list the files in a directory.
- \author Paul Kelly, Huidae Cho
- (C) 2007, 2008 by the GRASS Development Team
- for details.
-#include <stdio.h>
-#include <grass/config.h>
-#ifdef HAVE_SYS_IOCTL_H
-# include <sys/ioctl.h>
-#endif
-typedef int ls_filter_func(const char * /*filename */ , void * /*closure */ );
-static ls_filter_func *ls_filter = NULL;
-static void *ls_closure = NULL;
-static int cmp_names(const void *aa, const void *bb)
- char *const *a = (char *const *)aa;
- char *const *b = (char *const *)bb;
- return strcmp(*a, *b);
- * \brief Sets a function and its complementary data for G__ls filtering.
- * Defines a filter function and its rule data that allow G__ls to filter out
- * unwanted file names. Call this function before G__ls.
- * \param func Filter callback function to compare a file name and closure
- * pattern (if NULL, no filter will be used).
- * func(filename, closure) should return 1 on success, 0 on
- * failure.
- * \param closure Data used to determine if a file name matches the rule.
-void G_set_ls_filter(ls_filter_func * func, void *closure)
- ls_filter = func;
- ls_closure = closure;
- return;
- * \brief Stores a sorted directory listing in an array
- * The filenames in the specified directory are stored in an array of
- * strings, then sorted alphabetically. Each filename has space allocated
- * using G_store(), which can be freed using G_free() if necessary. The
- * same goes for the array itself.
- * \param dir Directory to list
- * \param num_files Pointer to an integer in which the total number of
- * files listed will be stored
- * \return Pointer to array of strings containing the listing
-char **G__ls(const char *dir, int *num_files)
- struct dirent *dp;
- DIR *dfd;
- char **dir_listing = NULL;
- int n = 0;
- if ((dfd = opendir(dir)) == NULL)
- G_fatal_error(_("Unable to open directory %s"), dir);
- while ((dp = readdir(dfd)) != NULL) {
- if ((dp->d_name[0] == '.' && dp->d_name[1] == 0) ||
- (dp->d_name[0] == '.' && dp->d_name[1] == '.' &&
- dp->d_name[2] == 0) || (ls_filter &&
- !(*ls_filter) (dp->d_name, ls_closure)))
- continue;
- dir_listing = (char **)G_realloc(dir_listing, (1 + n) * sizeof(char *));
- dir_listing[n] = G_store(dp->d_name);
- n++;
- /* Sort list of filenames alphabetically */
- qsort(dir_listing, n, sizeof(char *), cmp_names);
- *num_files = n;
- return dir_listing;
Modified: grass/trunk/general/g.mlist/main.c
--- grass-addons/general/g.xlist/main.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mlist/main.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -17,16 +17,21 @@
-#define MAIN
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <regex.h>
#include <grass/spawn.h>
#include "global.h"
-static int do_list(int, const char *, const char *, int, const char *, int);
+int nlist;
+struct list *list;
+static int any;
+static void do_list(const struct list *,
+ const char *, const char *, const char *,
+ int, int, int);
static int parse(const char *);
static int ls_filter(const char *, void *);
@@ -48,7 +53,7 @@
struct Flag *pretty;
struct Flag *full;
} flag;
- int i, n, all, num_types, any, flags = 0;
+ int i, n, all, num_types;
char *pattern = NULL, separator[2], *buf;
regex_t regex;
@@ -76,10 +81,10 @@
buf[0] = 0;
for (n = 0; n < nlist; n++) {
- G_strcat(buf, list[n].alias);
- G_strcat(buf, ",");
+ strcat(buf, list[n].alias);
+ strcat(buf, ",");
- G_strcat(buf, "all");
+ strcat(buf, "all");
opt.type->options = buf;
opt.pattern = G_define_option();
@@ -171,32 +176,28 @@
num_types = i;
- if (flag.type->answer)
- flags |= G_JOIN_ELEMENT_TYPE;
- if (flag.mapset->answer)
- flags |= G_JOIN_ELEMENT_MAPSET;
for (i = 0; i < num_types; i++) {
n = all ? i : parse(opt.type->answers[i]);
if (flag.full->answer) {
- char lister[300];
+ char lister[GPATH_MAX];
sprintf(lister, "%s/etc/lister/%s", G_gisbase(),
list[n].element[0]);
G_debug(3, "lister CMD: %s", lister);
- if (access(lister, 1) == 0) /* execute permission? */
+ if (access(lister, 1) == 0) { /* execute permission? */
G_spawn(lister, lister, opt.mapset->answer, NULL);
- else
- any =
- do_list(n, pattern, opt.mapset->answer,
- flag.pretty->answer, separator, flags);
+ continue;
else
- any =
- do_list(n, pattern, opt.mapset->answer, flag.pretty->answer,
- separator, flags);
+ do_list(&list[n], pattern, opt.mapset->answer, separator,
+ flag.pretty->answer, flag.type->answer,
+ flag.mapset->answer);
if (!flag.pretty->answer && any)
fprintf(stdout, "\n");
@@ -208,32 +209,59 @@
exit(EXIT_SUCCESS);
-static int do_list(int n, const char *pattern, const char *mapset,
- int pretty, const char *separator, int flags)
+ const struct list *elem,
+ const char *pattern, const char *mapset, const char *separator,
+ int pretty, int add_type, int add_mapset)
- static int any = 0;
- const char *buf;
- int len;
+ char path[GPATH_MAX];
+ const char *element = elem->element[0];
+ const char *alias = elem->alias;
+ char **list;
+ int count;
+ int i;
if (pretty) {
- G_list_element(list[n].element[0], list[n].alias, mapset,
- (int (*)())0);
- return 1;
+ G_list_element(element, alias, mapset, NULL);
+ return;
- buf =
- G_join_element(list[n].element[0], list[n].alias, mapset, separator,
- flags, NULL);
- len = strlen(buf);
- if (any && len)
- fprintf(stdout, "%s", separator);
- if (len)
- fprintf(stdout, "%s", buf);
- G_free((char *)buf);
+ if (!mapset || !*mapset) {
+ int n;
+ for (n = 0; mapset = G__mapset_name(n), mapset; n++)
+ do_list(elem, pattern, mapset, separator,
+ pretty, add_type, add_mapset);
+ return;
- any += len > 0;
+ G__file_name(path, element, "", mapset);
+ if (access(path, 0) != 0)
+ return;
- return any;
+ list = G__ls(path, &count);
+ if (!list)
+ return;
+ for (i = 0; i < count; i++) {
+ char *name = list[i];
+ if (any)
+ fprintf(stdout, "%s", separator);
+ if (add_type)
+ fprintf(stdout, "%s/", alias);
+ fprintf(stdout, "%s", name);
+ if (add_mapset)
+ fprintf(stdout, "@%s", mapset);
+ G_free(name);
+ any++;
+ G_free(list);
static int parse(const char *data_type)
Modified: grass/trunk/general/g.mlist/read_list.c
--- grass-addons/general/g.xlist/read_list.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mlist/read_list.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -36,7 +36,7 @@
any = 0;
if ((env = G__getenv("ELEMENT_LIST")))
- G_strcpy(element_list, env);
+ strcpy(element_list, env);
else
sprintf(element_list, "%s/etc/element_list", G_gisbase());
fd = fopen(element_list, "r");
Copied: grass/trunk/general/g.mremove (from rev 33262, grass-addons/general/g.xremove)
Property changes on: grass/trunk/general/g.mremove
+ *OBJ*
Modified: grass/trunk/general/g.mremove/Makefile
--- grass-addons/general/g.xremove/Makefile 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/Makefile 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,6 +1,6 @@
-PGM = g.xremove
+PGM = g.mremove
LIBES = $(GISLIB) $(VECTLIB) $(G3DLIB)
DEPENDENCIES = $(GISDEP) $(VECTDEP) $(G3DDEP)
Modified: grass/trunk/general/g.mremove/do_remove.c
--- grass-addons/general/g.xremove/do_remove.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/do_remove.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -21,8 +21,6 @@
/* len = get_description_len(n); */
- hold_signals(1);
if (G__name_is_fully_qualified(old, xname, xmapset)) {
if (strcmp(xmapset, G_mapset()) != 0)
G_fatal_error("%s is not in the current mapset (%s)", old,
@@ -77,7 +75,7 @@
if (G_strcasecmp(list[n].element[0], "cell") == 0) {
- char colr2[50];
+ char colr2[GMAPSET_MAX + 6];
sprintf(colr2, "colr2/%s", G_mapset());
switch (G_remove(colr2, old)) {
@@ -97,8 +95,6 @@
- hold_signals(0);
if (!removed)
G_warning(_("<%s> nothing removed"), old);
Deleted: grass/trunk/general/g.mremove/gisdefs.h
--- grass-addons/general/g.xremove/gisdefs.h 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/gisdefs.h 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,15 +0,0 @@
-#ifndef GISDEFS_H
-#define GISDEFS_H
-/* join.c */
-/* ls.c */
-#endif
Modified: grass/trunk/general/g.mremove/global.h
--- grass-addons/general/g.xremove/global.h 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/global.h 2008-09-04 22:24:02 UTC (rev 33266)
@@ -22,17 +22,8 @@
/* check_reclass.c */
int check_reclass(const char *, const char *, int);
-/* sighold.c */
-int hold_signals(int);
/* do_remove.c */
int do_remove(int, char *);
-#ifdef MAIN
-# define GLOBAL
-#else
-#endif
-GLOBAL int nlist;
+extern int nlist;
Deleted: grass/trunk/general/g.mremove/join.c
--- grass-addons/general/g.xremove/join.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/join.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,158 +0,0 @@
- \file join.c
- for details.
- int c, n;
- const char *buf;
- c = 0;
- alias = element;
- else
- if (count)
- *count = c;
- return buf;
- int i, count = 0;
- char **list;
- return count;
- 1 : 0) + 1);
- if (buf_len) {
- mapset);
- else
- else {
- else
- else {
- else
- else {
- else
- if (list)
- G_free(list);
- return count;
Deleted: grass/trunk/general/g.mremove/ls.c
--- grass-addons/general/g.xremove/ls.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/ls.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,105 +0,0 @@
- \file ls.c
- for details.
-#include <stdio.h>
-#endif
- * failure.
- ls_filter = func;
- return;
- DIR *dfd;
- int n = 0;
- continue;
- n++;
- *num_files = n;
Modified: grass/trunk/general/g.mremove/main.c
--- grass-addons/general/g.xremove/main.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/main.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -25,11 +25,14 @@
-#define MAIN
#include <stdlib.h>
+#include <unistd.h>
#include <regex.h>
#include "global.h"
+int nlist;
+struct list *list;
int main(int argc, char *argv[])
Modified: grass/trunk/general/g.mremove/read_list.c
--- grass-addons/general/g.xremove/read_list.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/read_list.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -36,7 +36,7 @@
any = 0;
else
Deleted: grass/trunk/general/g.mremove/sighold.c
--- grass-addons/general/g.xremove/sighold.c 2008-09-04 20:02:47 UTC (rev 33262)
+++ grass/trunk/general/g.mremove/sighold.c 2008-09-04 22:24:02 UTC (rev 33266)
@@ -1,21 +0,0 @@
-void (*sig) ();
-int hold_signals(int hold)
- sig = hold ? SIG_IGN : SIG_DFL;
- signal(SIGINT, sig);
-#ifndef __MINGW32__
- signal(SIGQUIT, sig);
-#endif
-#ifdef SIGTSTP
- signal(SIGTSTP, sig);
-#endif
- return 0;
