[GRASS-SVN] r33268 - in grass/trunk: . general general/g.mlist
general/g.mremove include include/Make
svn_grass at osgeo.org
Thu Sep 4 19:17:54 EDT 2008
Author: glynn
Date: 2008-09-04 19:17:53 -0400 (Thu, 04 Sep 2008)
New Revision: 33268
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/general/Makefile
grass/trunk/general/g.mlist/Makefile
grass/trunk/general/g.mremove/Makefile
grass/trunk/include/Make/Platform.make.in
grass/trunk/include/config.h.in
Add configure checks for regex functions
Enable g.mlist, g.mremove
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-09-04 22:34:00 UTC (rev 33267)
+++ grass/trunk/configure 2008-09-04 23:17:53 UTC (rev 33268)
@@ -63,6 +63,8 @@
ac_help="$ac_help
--with-opendwg support openDWG functionality (default: no)"
ac_help="$ac_help
+ --with-regex support regex functionality (default: yes)"
+ac_help="$ac_help
--with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
ac_help="$ac_help
@@ -188,6 +190,11 @@
--with-opendwg-libs=DIRS
openDWG library files are in DIRS"
ac_help="$ac_help
+ --with-regex-includes=DIRS
+ regex include files are in DIRS"
+ac_help="$ac_help
+ --with-regex-libs=DIRS regex library files are in DIRS"
+ac_help="$ac_help
--with-x use the X Window System"
ac_help="$ac_help
--enable-largefile enable support for large files (LFS)"
@@ -723,7 +730,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:727: checking host system type" >&5
+echo "configure:734: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -746,7 +753,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:750: checking for $ac_word" >&5
+echo "configure:757: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -773,7 +780,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:777: checking for $ac_word" >&5
+echo "configure:784: checking for $ac_word" >&5
@@ -821,7 +828,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:825: checking for $ac_word" >&5
+echo "configure:832: checking for $ac_word" >&5
@@ -850,7 +857,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:854: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:861: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -861,12 +868,12 @@
cat > conftest.$ac_ext << EOF
-#line 865 "configure"
+#line 872 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -892,19 +899,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:896: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:903: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:901: checking whether we are using GNU C" >&5
+echo "configure:908: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:915: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -922,7 +929,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:926: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:933: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -951,10 +958,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:955: checking for Cygwin environment" >&5
+echo "configure:962: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 958 "configure"
+#line 965 "configure"
int main() {
@@ -965,7 +972,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:969: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:976: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -981,17 +988,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:985: checking for mingw32 environment" >&5
+echo "configure:992: checking for mingw32 environment" >&5
-#line 988 "configure"
+#line 995 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:995: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1002: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1009,7 +1016,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1013: checking for executable suffix" >&5
+echo "configure:1020: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1028,23 +1035,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1032: checking for full floating-point support" >&5
+echo "configure:1039: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1037: checking whether "cc -mieee" works" >&5
+echo "configure:1044: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1041 "configure"
+#line 1048 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1048: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1055: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1060,7 +1067,7 @@
else
-#line 1064 "configure"
+#line 1071 "configure"
#include <float.h>
@@ -1074,7 +1081,7 @@
EOF
-if { (eval echo configure:1078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1087,14 +1094,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1091: checking for full floating-point support with -mieee" >&5
+echo "configure:1098: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1098 "configure"
+#line 1105 "configure"
#include <float.h>
@@ -1108,7 +1115,7 @@
EOF
-if { (eval echo configure:1112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1145,7 +1152,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1149: checking for $ac_word" >&5
+echo "configure:1156: checking for $ac_word" >&5
case "$pwd" in
@@ -1183,7 +1190,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1187: checking for source directory" >&5
+echo "configure:1194: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1194,7 +1201,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1198: checking for build directory" >&5
+echo "configure:1205: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1279,7 +1286,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1283: checking for MacOSX App" >&5
+echo "configure:1290: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1302,7 +1309,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1306: checking how to build libraries" >&5
+echo "configure:1313: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1345,7 +1352,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1349: checking for $ac_word" >&5
+echo "configure:1356: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1370,7 +1377,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1374: checking how to run the C preprocessor" >&5
+echo "configure:1381: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1383,13 +1390,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1387 "configure"
+#line 1394 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1393: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1400: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1400,13 +1407,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1404 "configure"
+#line 1411 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1410: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1417,13 +1424,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1421 "configure"
+#line 1428 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1451,7 +1458,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1455: checking if 64bit support is requested" >&5
+echo "configure:1462: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1471,7 +1478,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1475: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1482: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1495,7 +1502,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1499: checking system version (for dynamic loading)" >&5
+echo "configure:1506: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1521,13 +1528,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1525: checking for dlopen in -ldl" >&5
+echo "configure:1532: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1531 "configure"
+#line 1538 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1538,7 +1545,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1585,7 +1592,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1589: checking for $ac_word" >&5
+echo "configure:1596: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1714,13 +1721,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1718: checking for gettimeofday in -lbsd" >&5
+echo "configure:1725: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1724 "configure"
+#line 1731 "configure"
@@ -1731,7 +1738,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1772,13 +1779,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1776: checking for inet_ntoa in -lbind" >&5
+echo "configure:1783: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1782 "configure"
+#line 1789 "configure"
@@ -1789,7 +1796,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1850,13 +1857,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1854: checking for shl_load in -ldld" >&5
+echo "configure:1861: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1860 "configure"
+#line 1867 "configure"
@@ -1867,7 +1874,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1932,13 +1939,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1936: checking for shl_load in -ldld" >&5
+echo "configure:1943: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1942 "configure"
+#line 1949 "configure"
@@ -1949,7 +1956,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2071,15 +2078,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2075: checking for dld.h" >&5
+echo "configure:2082: checking for dld.h" >&5
-#line 2078 "configure"
+#line 2085 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2090: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2139,15 +2146,15 @@
else
-echo "configure:2143: checking for dld.h" >&5
+echo "configure:2150: checking for dld.h" >&5
-#line 2146 "configure"
+#line 2153 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2244,9 +2251,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2248: checking for ELF" >&5
+echo "configure:2255: checking for ELF" >&5
-#line 2250 "configure"
+#line 2257 "configure"
#ifdef __ELF__
@@ -2276,15 +2283,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2280: checking for dlfcn.h" >&5
+echo "configure:2287: checking for dlfcn.h" >&5
-#line 2283 "configure"
+#line 2290 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2288: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2308,9 +2315,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2312: checking for ELF" >&5
+echo "configure:2319: checking for ELF" >&5
-#line 2314 "configure"
+#line 2321 "configure"
#ifdef __ELF__
@@ -2634,17 +2641,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2638: checking for ld accepts -Bexport flag" >&5
+echo "configure:2645: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2641 "configure"
+#line 2648 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -2972,6 +2979,16 @@
fi
+# Check whether --with-regex or --without-regex was given.
+if test "${with_regex+set}" = set; then
+ withval="$with_regex"
+else
+ with_regex=yes
+fi
# Check whether --with-python or --without-python was given.
if test "${with_python+set}" = set; then
withval="$with_python"
@@ -3376,6 +3393,23 @@
+# Check whether --with-regex-includes or --without-regex-includes was given.
+if test "${with_regex_includes+set}" = set; then
+ withval="$with_regex_includes"
+fi
+# Check whether --with-regex-libs or --without-regex-libs was given.
+if test "${with_regex_libs+set}" = set; then
+ withval="$with_regex_libs"
+fi
# Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
# With includes option
@@ -3385,7 +3419,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3389: checking for additional include dirs" >&5
+echo "configure:3423: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3408,7 +3442,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3412: checking for additional library dirs" >&5
+echo "configure:3446: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3442,7 +3476,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3446: checking for a BSD compatible install" >&5
+echo "configure:3480: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3495,7 +3529,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3499: checking for $ac_word" >&5
+echo "configure:3533: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3526,13 +3560,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3530: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3564: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3536 "configure"
+#line 3570 "configure"
@@ -3543,7 +3577,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3568,7 +3602,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3572: checking for $ac_word" >&5
+echo "configure:3606: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3608,7 +3642,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3612: checking for $ac_word" >&5
+echo "configure:3646: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3639,7 +3673,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3643: checking for $ac_word" >&5
+echo "configure:3677: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3677,7 +3711,7 @@
-echo "configure:3681: checking for $ac_word" >&5
+echo "configure:3715: checking for $ac_word" >&5
@@ -3706,7 +3740,7 @@
-echo "configure:3710: checking for $ac_word" >&5
+echo "configure:3744: checking for $ac_word" >&5
@@ -3737,7 +3771,7 @@
-echo "configure:3741: checking for $ac_word" >&5
+echo "configure:3775: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3766,7 +3800,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3770: checking for $ac_word" >&5
+echo "configure:3804: checking for $ac_word" >&5
case "$PERL" in
@@ -3797,10 +3831,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3801: checking for ANSI C header files" >&5
+echo "configure:3835: checking for ANSI C header files" >&5
-#line 3804 "configure"
+#line 3838 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3808,7 +3842,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3812: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3846: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3825,7 +3859,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3829 "configure"
+#line 3863 "configure"
#include <string.h>
EOF
@@ -3843,7 +3877,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3847 "configure"
+#line 3881 "configure"
#include <stdlib.h>
EOF
@@ -3864,7 +3898,7 @@
else
-#line 3868 "configure"
+#line 3902 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3875,7 +3909,7 @@
exit (0); }
EOF
-if { (eval echo configure:3879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3902,15 +3936,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3906: checking for $ac_hdr" >&5
+echo "configure:3940: checking for $ac_hdr" >&5
-#line 3909 "configure"
+#line 3943 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3948: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3939,15 +3973,15 @@
do
-echo "configure:3943: checking for $ac_hdr" >&5
+echo "configure:3977: checking for $ac_hdr" >&5
-#line 3946 "configure"
+#line 3980 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3951: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3985: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3976,15 +4010,15 @@
do
-echo "configure:3980: checking for $ac_hdr" >&5
+echo "configure:4014: checking for $ac_hdr" >&5
-#line 3983 "configure"
+#line 4017 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3988: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4022: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4013,15 +4047,15 @@
do
-echo "configure:4017: checking for $ac_hdr" >&5
+echo "configure:4051: checking for $ac_hdr" >&5
-#line 4020 "configure"
+#line 4054 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4025: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4050,15 +4084,15 @@
do
-echo "configure:4054: checking for $ac_hdr" >&5
+echo "configure:4088: checking for $ac_hdr" >&5
-#line 4057 "configure"
+#line 4091 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4084,10 +4118,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4088: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4122: checking whether time.h and sys/time.h may both be included" >&5
-#line 4091 "configure"
+#line 4125 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4096,7 +4130,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4100: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4134: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4116,10 +4150,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4120: checking for off_t" >&5
+echo "configure:4154: checking for off_t" >&5
-#line 4123 "configure"
+#line 4157 "configure"
#if STDC_HEADERS
@@ -4146,10 +4180,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4150: checking for uid_t in sys/types.h" >&5
+echo "configure:4184: checking for uid_t in sys/types.h" >&5
-#line 4153 "configure"
+#line 4187 "configure"
EOF
@@ -4177,10 +4211,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4181: checking return type of signal handlers" >&5
+echo "configure:4215: checking return type of signal handlers" >&5
-#line 4184 "configure"
+#line 4218 "configure"
#include <signal.h>
@@ -4197,7 +4231,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4201: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4215,10 +4249,10 @@
-echo "configure:4219: checking for Cygwin environment" >&5
+echo "configure:4253: checking for Cygwin environment" >&5
-#line 4222 "configure"
+#line 4256 "configure"
int main() {
@@ -4229,7 +4263,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4267: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4247,10 +4281,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4251: checking for $ac_func" >&5
+echo "configure:4285: checking for $ac_func" >&5
-#line 4254 "configure"
+#line 4288 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4273,7 +4307,7 @@
; return 0; }
EOF
-if { (eval echo configure:4277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4299,10 +4333,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4303: checking for $ac_func" >&5
+echo "configure:4337: checking for $ac_func" >&5
-#line 4306 "configure"
+#line 4340 "configure"
@@ -4325,7 +4359,7 @@
; return 0; }
EOF
-if { (eval echo configure:4329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4351,10 +4385,10 @@
for ac_func in drand48
do
-echo "configure:4355: checking for $ac_func" >&5
+echo "configure:4389: checking for $ac_func" >&5
-#line 4358 "configure"
+#line 4392 "configure"
@@ -4377,7 +4411,7 @@
; return 0; }
EOF
-if { (eval echo configure:4381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4403,10 +4437,10 @@
for ac_func in putenv setenv
do
-echo "configure:4407: checking for $ac_func" >&5
+echo "configure:4441: checking for $ac_func" >&5
-#line 4410 "configure"
+#line 4444 "configure"
@@ -4429,7 +4463,7 @@
; return 0; }
EOF
-if { (eval echo configure:4433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4455,10 +4489,10 @@
for ac_func in nanosleep
do
-echo "configure:4459: checking for $ac_func" >&5
+echo "configure:4493: checking for $ac_func" >&5
-#line 4462 "configure"
+#line 4496 "configure"
@@ -4481,7 +4515,7 @@
; return 0; }
EOF
-if { (eval echo configure:4485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4506,13 +4540,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4510: checking whether setpgrp takes no argument" >&5
+echo "configure:4544: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4516 "configure"
+#line 4550 "configure"
#ifdef HAVE_UNISTD_H
@@ -4532,7 +4566,7 @@
EOF
-if { (eval echo configure:4536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4560,16 +4594,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4564: checking for long long int" >&5
+echo "configure:4598: checking for long long int" >&5
-#line 4566 "configure"
+#line 4600 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4573: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4607: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4589,7 +4623,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4593: checking for W11" >&5
+echo "configure:4627: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4617,7 +4651,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4621: checking for X" >&5
+echo "configure:4655: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4677,12 +4711,12 @@
# First, try using that file with no special directory specified.
-#line 4681 "configure"
+#line 4715 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4751,14 +4785,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4755 "configure"
+#line 4789 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4863,17 +4897,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4867: checking whether -R must be followed by a space" >&5
+echo "configure:4901: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4870 "configure"
+#line 4904 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4889,14 +4923,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4893 "configure"
+#line 4927 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4928,13 +4962,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4932: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4966: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4938 "configure"
+#line 4972 "configure"
@@ -4945,7 +4979,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4966,13 +5000,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4970: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5004: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4976 "configure"
+#line 5010 "configure"
@@ -4983,7 +5017,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5011,10 +5045,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5015: checking for gethostbyname" >&5
+echo "configure:5049: checking for gethostbyname" >&5
-#line 5018 "configure"
+#line 5052 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5037,7 +5071,7 @@
; return 0; }
EOF
-if { (eval echo configure:5041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5057,13 +5091,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5061: checking for gethostbyname in -lnsl" >&5
+echo "configure:5095: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5067 "configure"
+#line 5101 "configure"
@@ -5074,7 +5108,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5103,10 +5137,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5107: checking for connect" >&5
+echo "configure:5141: checking for connect" >&5
-#line 5110 "configure"
+#line 5144 "configure"
which can conflict with char connect(); below. */
@@ -5129,7 +5163,7 @@
; return 0; }
EOF
-if { (eval echo configure:5133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5149,13 +5183,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5153: checking for connect in -lsocket" >&5
+echo "configure:5187: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5159 "configure"
+#line 5193 "configure"
@@ -5166,7 +5200,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5189,10 +5223,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5193: checking for remove" >&5
+echo "configure:5227: checking for remove" >&5
-#line 5196 "configure"
+#line 5230 "configure"
which can conflict with char remove(); below. */
@@ -5215,7 +5249,7 @@
; return 0; }
EOF
-if { (eval echo configure:5219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5235,13 +5269,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5239: checking for remove in -lposix" >&5
+echo "configure:5273: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5245 "configure"
+#line 5279 "configure"
@@ -5252,7 +5286,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5275,10 +5309,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5279: checking for shmat" >&5
+echo "configure:5313: checking for shmat" >&5
-#line 5282 "configure"
+#line 5316 "configure"
which can conflict with char shmat(); below. */
@@ -5301,7 +5335,7 @@
; return 0; }
EOF
-if { (eval echo configure:5305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5321,13 +5355,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5325: checking for shmat in -lipc" >&5
+echo "configure:5359: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5331 "configure"
+#line 5365 "configure"
@@ -5338,7 +5372,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5370,13 +5404,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5374: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5408: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5380 "configure"
+#line 5414 "configure"
@@ -5387,7 +5421,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5427,12 +5461,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5431: checking for library containing cuserid" >&5
+echo "configure:5465: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5436 "configure"
+#line 5470 "configure"
@@ -5443,7 +5477,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5454,7 +5488,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5458 "configure"
+#line 5492 "configure"
@@ -5465,7 +5499,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5491,10 +5525,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5495: checking for xdrmem_create" >&5
+echo "configure:5529: checking for xdrmem_create" >&5
-#line 5498 "configure"
+#line 5532 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5517,7 +5551,7 @@
; return 0; }
EOF
-if { (eval echo configure:5521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5535,13 +5569,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5539: checking for xdrmem_create in -lsun" >&5
+echo "configure:5573: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5545 "configure"
+#line 5579 "configure"
@@ -5552,7 +5586,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5571,13 +5605,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5575: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5609: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5581 "configure"
+#line 5615 "configure"
@@ -5588,7 +5622,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5607,13 +5641,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5611: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5645: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 5617 "configure"
+#line 5651 "configure"
@@ -5624,7 +5658,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5643,13 +5677,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5647: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5681: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 5653 "configure"
+#line 5687 "configure"
@@ -5660,7 +5694,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5694,10 +5728,10 @@
for ac_func in asprintf
do
-echo "configure:5698: checking for $ac_func" >&5
+echo "configure:5732: checking for $ac_func" >&5
-#line 5701 "configure"
+#line 5735 "configure"
@@ -5720,7 +5754,7 @@
; return 0; }
EOF
-if { (eval echo configure:5724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5747,10 +5781,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5751: checking for atan" >&5
+echo "configure:5785: checking for atan" >&5
-#line 5754 "configure"
+#line 5788 "configure"
which can conflict with char atan(); below. */
@@ -5773,7 +5807,7 @@
; return 0; }
EOF
-if { (eval echo configure:5777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -5791,13 +5825,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5795: checking for atan in -lm" >&5
+echo "configure:5829: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 5801 "configure"
+#line 5835 "configure"
@@ -5808,7 +5842,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5835,10 +5869,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5839: checking for dlsym" >&5
+echo "configure:5873: checking for dlsym" >&5
-#line 5842 "configure"
+#line 5876 "configure"
which can conflict with char dlsym(); below. */
@@ -5861,7 +5895,7 @@
; return 0; }
EOF
-if { (eval echo configure:5865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -5879,13 +5913,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:5883: checking for dlsym in -ldl" >&5
+echo "configure:5917: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 5889 "configure"
+#line 5923 "configure"
@@ -5896,7 +5930,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:5900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5923,10 +5957,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:5927: checking for iconv" >&5
+echo "configure:5961: checking for iconv" >&5
-#line 5930 "configure"
+#line 5964 "configure"
which can conflict with char iconv(); below. */
@@ -5949,7 +5983,7 @@
; return 0; }
EOF
-if { (eval echo configure:5953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -5967,13 +6001,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:5971: checking for iconv in -liconv" >&5
+echo "configure:6005: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 5977 "configure"
+#line 6011 "configure"
@@ -5984,7 +6018,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:5988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6003,13 +6037,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6007: checking for iconv in -lgiconv" >&5
+echo "configure:6041: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6013 "configure"
+#line 6047 "configure"
@@ -6020,7 +6054,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6039,10 +6073,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6043: checking for libiconv" >&5
+echo "configure:6077: checking for libiconv" >&5
-#line 6046 "configure"
+#line 6080 "configure"
which can conflict with char libiconv(); below. */
@@ -6065,7 +6099,7 @@
; return 0; }
EOF
-if { (eval echo configure:6069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6083,13 +6117,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6087: checking for libiconv in -liconv" >&5
+echo "configure:6121: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6093 "configure"
+#line 6127 "configure"
@@ -6100,7 +6134,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6119,13 +6153,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6123: checking for libiconv in -lgiconv" >&5
+echo "configure:6157: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6129 "configure"
+#line 6163 "configure"
@@ -6136,7 +6170,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6173,10 +6207,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6177: checking for socket" >&5
+echo "configure:6211: checking for socket" >&5
-#line 6180 "configure"
+#line 6214 "configure"
which can conflict with char socket(); below. */
@@ -6199,7 +6233,7 @@
; return 0; }
EOF
-if { (eval echo configure:6203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6217,13 +6251,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6221: checking for socket in -lsocket" >&5
+echo "configure:6255: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6227 "configure"
+#line 6261 "configure"
@@ -6234,7 +6268,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6282,7 +6316,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6286: checking for location of zlib includes" >&5
+echo "configure:6320: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6308,15 +6342,15 @@
do
-echo "configure:6312: checking for $ac_hdr" >&5
+echo "configure:6346: checking for $ac_hdr" >&5
-#line 6315 "configure"
+#line 6349 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6354: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6350,7 +6384,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6354: checking for location of zlib library" >&5
+echo "configure:6388: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6375,13 +6409,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6379: checking for deflate in -lz" >&5
+echo "configure:6413: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6385 "configure"
+#line 6419 "configure"
@@ -6392,7 +6426,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6440,7 +6474,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6444: checking for location of External PROJ.4 includes" >&5
+echo "configure:6478: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6466,15 +6500,15 @@
do
-echo "configure:6470: checking for $ac_hdr" >&5
+echo "configure:6504: checking for $ac_hdr" >&5
-#line 6473 "configure"
+#line 6507 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6478: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6511,7 +6545,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6515: checking External PROJ.4 version" >&5
+echo "configure:6549: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6519,7 +6553,7 @@
else
-#line 6523 "configure"
+#line 6557 "configure"
#include <stdio.h>
@@ -6531,7 +6565,7 @@
EOF
-if { (eval echo configure:6535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6556,7 +6590,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6560: checking for location of External PROJ.4 library" >&5
+echo "configure:6594: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6581,13 +6615,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6585: checking for pj_get_def in -lproj" >&5
+echo "configure:6619: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 6591 "configure"
+#line 6625 "configure"
@@ -6598,7 +6632,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6632,7 +6666,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6636: checking for location of External PROJ.4 data files" >&5
+echo "configure:6670: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6656,14 +6690,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6660: checking for epsg" >&5
+echo "configure:6694: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6667: checking for $PROJSHARE/epsg" >&5
+echo "configure:6701: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -6695,7 +6729,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:6699: checking for $ac_word" >&5
+echo "configure:6733: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -6731,11 +6765,244 @@
# Done checking PROJ
+# Enable regex option
+echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
+echo "configure:6773: checking whether to use regex" >&5
+echo "$ac_t"""$with_regex"" 1>&6
+case "$with_regex" in
+ "no") USE_REGEX= ;;
+ "yes") USE_REGEX="1" ;;
+ *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
+esac
+REGEXINCPATH=
+REGEXLIBPATH=
+REGEXLIB=
+if test -n "$USE_REGEX"; then
+# With regex includes directory
+echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
+echo "configure:6793: checking for location of regex includes" >&5
+case "$with_regex_includes" in
+y | ye | yes | n | no)
+ { echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_regex_includes" 1>&6
+if test -n "$with_regex_includes" ; then
+ for dir in $with_regex_includes; do
+ if test -d "$dir"; then
+ REGEXINCPATH="$REGEXINCPATH -I$dir"
+ else
+ { echo "configure: error: *** regex includes directory $dir does not exist." 1>&2; exit 1; }
+ fi
+ done
+fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$REGEXINCPATH $CPPFLAGS"
+for ac_hdr in regex.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:6819: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 6822 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:6827: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=yes"
+else
+ echo "$ac_err" >&5
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+ cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+ echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate regex includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+# With regex library directory
+echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
+echo "configure:6861: checking for location of regex library" >&5
+case "$with_regex_libs" in
+ { echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_regex_libs" 1>&6
+if test -n "$with_regex_libs"; then
+ for dir in $with_regex_libs; do
+ REGEXLIBPATH="$REGEXLIBPATH -L$dir"
+ else
+ { echo "configure: error: *** regex library directory $dir does not exist." 1>&2; exit 1; }
+ fi
+ done
+fi
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS=" $LIBS"
+LDFLAGS=" $LDFLAGS"
+echo $ac_n "checking for regcomp""... $ac_c" 1>&6
+echo "configure:6886: checking for regcomp" >&5
+#line 6889 "configure"
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char regcomp(); below. */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char regcomp();
+int main() {
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined (__stub_regcomp) || defined (__stub___regcomp)
+choke me
+#else
+regcomp();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:6912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_func_regcomp=yes"
+else
+ rm -rf conftest*
+ eval "ac_cv_func_regcomp=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'regcomp`\" = yes"; then
+ REGEXLIB="$REGEXLIB "
+else
+LDFLAGS="$REGEXLIBPATH $LDFLAGS"
+echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
+echo "configure:6939: checking for regcomp in -lregex" >&5
+ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lregex $LIBS"
+#line 6945 "configure"
+char regcomp();
+int main() {
+regcomp()
+; return 0; }
+EOF
+if { (eval echo configure:6956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=yes"
+else
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+ REGEXLIB="$REGEXLIB -lregex "
+else
+LDFLAGS=${ac_save_ldflags}
+ { echo "configure: error: *** Unable to locate regex library." 1>&2; exit 1; }
+fi
+fi
+LIBS=${ac_save_libs}
+fi # $USE_REGEX
+# Done checking regex
# Enable Readline option
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:6739: checking whether to use Readline" >&5
+echo "configure:7006: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -6756,7 +7023,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6760: checking for location of Readline includes" >&5
+echo "configure:7027: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6782,15 +7049,15 @@
do
-echo "configure:6786: checking for $ac_hdr" >&5
+echo "configure:7053: checking for $ac_hdr" >&5
-#line 6789 "configure"
+#line 7056 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6826,15 +7093,15 @@
do
-echo "configure:6830: checking for $ac_hdr" >&5
+echo "configure:7097: checking for $ac_hdr" >&5
-#line 6833 "configure"
+#line 7100 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6868,7 +7135,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6872: checking for location of Readline library" >&5
+echo "configure:7139: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6893,13 +7160,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6897: checking for readline in -lreadline" >&5
+echo "configure:7164: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6903 "configure"
+#line 7170 "configure"
@@ -6910,7 +7177,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6945,13 +7212,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6949: checking for add_history in -lhistory" >&5
+echo "configure:7216: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6955 "configure"
+#line 7222 "configure"
@@ -6962,7 +7229,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7005,7 +7272,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7009: checking whether to use JPEG" >&5
+echo "configure:7276: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7025,7 +7292,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7029: checking for location of JPEG includes" >&5
+echo "configure:7296: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7051,15 +7318,15 @@
do
-echo "configure:7055: checking for $ac_hdr" >&5
+echo "configure:7322: checking for $ac_hdr" >&5
-#line 7058 "configure"
+#line 7325 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7063: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7093,7 +7360,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7097: checking for location of JPEG library" >&5
+echo "configure:7364: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7120,13 +7387,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7124: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7391: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 7130 "configure"
+#line 7397 "configure"
@@ -7137,7 +7404,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7156,13 +7423,13 @@
-echo "configure:7160: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7427: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7166 "configure"
+#line 7433 "configure"
@@ -7173,7 +7440,7 @@
; return 0; }
EOF
-if { (eval echo configure:7177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7222,7 +7489,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7226: checking whether to use GDAL" >&5
+echo "configure:7493: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -7240,7 +7507,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7244: checking for $ac_word" >&5
+echo "configure:7511: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7295,14 +7562,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7299 "configure"
+#line 7566 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -7311,14 +7578,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7315 "configure"
+#line 7582 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7351,7 +7618,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7355: checking whether to use TIFF" >&5
+echo "configure:7622: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7371,7 +7638,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7375: checking for location of TIFF includes" >&5
+echo "configure:7642: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7397,15 +7664,15 @@
do
-echo "configure:7401: checking for $ac_hdr" >&5
+echo "configure:7668: checking for $ac_hdr" >&5
-#line 7404 "configure"
+#line 7671 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7409: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7676: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7439,7 +7706,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7443: checking for location of TIFF library" >&5
+echo "configure:7710: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7470,13 +7737,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7474: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7741: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7480 "configure"
+#line 7747 "configure"
@@ -7487,7 +7754,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7506,13 +7773,13 @@
-echo "configure:7510: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7777: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7516 "configure"
+#line 7783 "configure"
@@ -7523,7 +7790,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7542,13 +7809,13 @@
-echo "configure:7546: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7813: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7552 "configure"
+#line 7819 "configure"
@@ -7559,7 +7826,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7578,13 +7845,13 @@
-echo "configure:7582: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7849: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7588 "configure"
+#line 7855 "configure"
@@ -7595,7 +7862,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7614,13 +7881,13 @@
-echo "configure:7618: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7885: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7624 "configure"
+#line 7891 "configure"
@@ -7631,7 +7898,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7650,13 +7917,13 @@
-echo "configure:7654: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7921: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7660 "configure"
+#line 7927 "configure"
@@ -7667,7 +7934,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7686,13 +7953,13 @@
-echo "configure:7690: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7957: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7696 "configure"
+#line 7963 "configure"
@@ -7703,7 +7970,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7722,13 +7989,13 @@
-echo "configure:7726: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7993: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7732 "configure"
+#line 7999 "configure"
@@ -7739,7 +8006,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7837,7 +8104,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7841: checking whether to use PNG" >&5
+echo "configure:8108: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7856,7 +8123,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7860: checking for location of PNG includes" >&5
+echo "configure:8127: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7882,15 +8149,15 @@
do
-echo "configure:7886: checking for $ac_hdr" >&5
+echo "configure:8153: checking for $ac_hdr" >&5
-#line 7889 "configure"
+#line 8156 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8161: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7924,7 +8191,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7928: checking for location of PNG library" >&5
+echo "configure:8195: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7949,13 +8216,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7953: checking for png_read_image in -lpng" >&5
+echo "configure:8220: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7959 "configure"
+#line 8226 "configure"
@@ -7966,7 +8233,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8008,7 +8275,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8012: checking whether to use Tcl/Tk" >&5
+echo "configure:8279: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8028,7 +8295,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8032: checking for location of Tcl/Tk includes" >&5
+echo "configure:8299: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8054,15 +8321,15 @@
do
-echo "configure:8058: checking for $ac_hdr" >&5
+echo "configure:8325: checking for $ac_hdr" >&5
-#line 8061 "configure"
+#line 8328 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8066: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8099,15 +8366,15 @@
do
-echo "configure:8103: checking for $ac_hdr" >&5
+echo "configure:8370: checking for $ac_hdr" >&5
-#line 8106 "configure"
+#line 8373 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8141,7 +8408,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8145: checking Tcl version" >&5
+echo "configure:8412: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8149,7 +8416,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8153 "configure"
+#line 8420 "configure"
#include <stdio.h>
@@ -8161,7 +8428,7 @@
EOF
-if { (eval echo configure:8165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8179,7 +8446,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8183: checking Tk version" >&5
+echo "configure:8450: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8187,7 +8454,7 @@
else
-#line 8191 "configure"
+#line 8458 "configure"
#include <stdio.h>
@@ -8199,7 +8466,7 @@
EOF
-if { (eval echo configure:8203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8228,7 +8495,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8232: checking for location of Tcl/Tk library" >&5
+echo "configure:8499: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8258,13 +8525,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8262: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8529: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8268 "configure"
+#line 8535 "configure"
@@ -8275,7 +8542,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8294,13 +8561,13 @@
-echo "configure:8298: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8565: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8304 "configure"
+#line 8571 "configure"
@@ -8311,7 +8578,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8338,13 +8605,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8342: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8609: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8348 "configure"
+#line 8615 "configure"
@@ -8355,7 +8622,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8374,13 +8641,13 @@
-echo "configure:8378: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8645: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8384 "configure"
+#line 8651 "configure"
@@ -8391,7 +8658,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8418,13 +8685,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8422: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8689: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8428 "configure"
+#line 8695 "configure"
@@ -8435,7 +8702,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8454,13 +8721,13 @@
-echo "configure:8458: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8725: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8464 "configure"
+#line 8731 "configure"
@@ -8471,7 +8738,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8549,13 +8816,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8553: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8820: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8559 "configure"
+#line 8826 "configure"
@@ -8566,7 +8833,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8585,13 +8852,13 @@
-echo "configure:8589: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8856: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8595 "configure"
+#line 8862 "configure"
@@ -8602,7 +8869,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8629,13 +8896,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8633: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8900: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 8639 "configure"
+#line 8906 "configure"
@@ -8646,7 +8913,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8665,13 +8932,13 @@
-echo "configure:8669: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8936: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8675 "configure"
+#line 8942 "configure"
@@ -8682,7 +8949,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8709,13 +8976,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8713: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8980: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 8719 "configure"
+#line 8986 "configure"
@@ -8726,7 +8993,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8745,13 +9012,13 @@
-echo "configure:8749: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9016: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8755 "configure"
+#line 9022 "configure"
@@ -8762,7 +9029,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8854,7 +9121,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8858: checking whether to use PostgreSQL" >&5
+echo "configure:9125: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8881,7 +9148,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8885: checking for location of PostgreSQL includes" >&5
+echo "configure:9152: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8907,15 +9174,15 @@
do
-echo "configure:8911: checking for $ac_hdr" >&5
+echo "configure:9178: checking for $ac_hdr" >&5
-#line 8914 "configure"
+#line 9181 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8953,7 +9220,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8957: checking for location of PostgreSQL library" >&5
+echo "configure:9224: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8982,13 +9249,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8986: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9253: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8992 "configure"
+#line 9259 "configure"
@@ -8999,7 +9266,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9018,13 +9285,13 @@
-echo "configure:9022: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9289: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9028 "configure"
+#line 9295 "configure"
@@ -9035,7 +9302,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9054,13 +9321,13 @@
-echo "configure:9058: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9325: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9064 "configure"
+#line 9331 "configure"
@@ -9071,7 +9338,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9090,13 +9357,13 @@
-echo "configure:9094: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9361: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9100 "configure"
+#line 9367 "configure"
@@ -9107,7 +9374,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9164,13 +9431,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9168: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9435: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9174 "configure"
+#line 9441 "configure"
@@ -9181,7 +9448,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9203,13 +9470,13 @@
-echo "configure:9207: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9474: checking for PQcmdTuples in -lpq" >&5
-#line 9213 "configure"
+#line 9480 "configure"
@@ -9220,7 +9487,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9263,7 +9530,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9267: checking whether to use MySQL" >&5
+echo "configure:9534: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9283,7 +9550,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9287: checking for location of MySQL includes" >&5
+echo "configure:9554: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9309,15 +9576,15 @@
do
-echo "configure:9313: checking for $ac_hdr" >&5
+echo "configure:9580: checking for $ac_hdr" >&5
-#line 9316 "configure"
+#line 9583 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9354,7 +9621,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9358: checking for location of MySQL library" >&5
+echo "configure:9625: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9385,13 +9652,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9389: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9656: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9395 "configure"
+#line 9662 "configure"
@@ -9402,7 +9669,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9421,13 +9688,13 @@
-echo "configure:9425: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9692: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9431 "configure"
+#line 9698 "configure"
@@ -9438,7 +9705,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9457,13 +9724,13 @@
-echo "configure:9461: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9728: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9467 "configure"
+#line 9734 "configure"
@@ -9474,7 +9741,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9493,13 +9760,13 @@
-echo "configure:9497: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9764: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9503 "configure"
+#line 9770 "configure"
@@ -9510,7 +9777,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9529,13 +9796,13 @@
-echo "configure:9533: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9800: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9539 "configure"
+#line 9806 "configure"
@@ -9546,7 +9813,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9565,13 +9832,13 @@
-echo "configure:9569: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9836: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9575 "configure"
+#line 9842 "configure"
@@ -9582,7 +9849,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9601,13 +9868,13 @@
-echo "configure:9605: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9872: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9611 "configure"
+#line 9878 "configure"
@@ -9618,7 +9885,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9637,13 +9904,13 @@
-echo "configure:9641: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9908: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9647 "configure"
+#line 9914 "configure"
@@ -9654,7 +9921,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9744,7 +10011,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9748: checking for $ac_word" >&5
+echo "configure:10015: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9793,10 +10060,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9797: checking for mysql_server_init" >&5
+echo "configure:10064: checking for mysql_server_init" >&5
-#line 9800 "configure"
+#line 10067 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -9822,7 +10089,7 @@
; return 0; }
EOF
-if { (eval echo configure:9826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9874,7 +10141,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9878: checking whether to use SQLite" >&5
+echo "configure:10145: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9894,7 +10161,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9898: checking for location of SQLite includes" >&5
+echo "configure:10165: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9920,15 +10187,15 @@
do
-echo "configure:9924: checking for $ac_hdr" >&5
+echo "configure:10191: checking for $ac_hdr" >&5
-#line 9927 "configure"
+#line 10194 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9932: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10199: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9971,7 +10238,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9975: checking for location of SQLite library" >&5
+echo "configure:10242: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9998,13 +10265,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10002: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10269: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10008 "configure"
+#line 10275 "configure"
@@ -10015,7 +10282,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10034,13 +10301,13 @@
-echo "configure:10038: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10305: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10044 "configure"
+#line 10311 "configure"
@@ -10051,7 +10318,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10104,7 +10371,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10108: checking whether to use FFMPEG" >&5
+echo "configure:10375: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10124,7 +10391,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10128: checking for location of FFMPEG includes" >&5
+echo "configure:10395: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10150,15 +10417,15 @@
do
-echo "configure:10154: checking for $ac_hdr" >&5
+echo "configure:10421: checking for $ac_hdr" >&5
-#line 10157 "configure"
+#line 10424 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10194,15 +10461,15 @@
do
-echo "configure:10198: checking for $ac_hdr" >&5
+echo "configure:10465: checking for $ac_hdr" >&5
-#line 10201 "configure"
+#line 10468 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10206: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10473: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10238,15 +10505,15 @@
do
-echo "configure:10242: checking for $ac_hdr" >&5
+echo "configure:10509: checking for $ac_hdr" >&5
-#line 10245 "configure"
+#line 10512 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10517: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10289,7 +10556,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10293: checking for location of FFMPEG library" >&5
+echo "configure:10560: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10316,13 +10583,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10320: checking for av_free in -lavutil" >&5
+echo "configure:10587: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10326 "configure"
+#line 10593 "configure"
@@ -10333,7 +10600,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10352,13 +10619,13 @@
-echo "configure:10356: checking for av_free in -lavutil" >&5
+echo "configure:10623: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10362 "configure"
+#line 10629 "configure"
@@ -10369,7 +10636,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10414,13 +10681,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10418: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10685: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10424 "configure"
+#line 10691 "configure"
@@ -10431,7 +10698,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10450,13 +10717,13 @@
-echo "configure:10454: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10721: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10460 "configure"
+#line 10727 "configure"
@@ -10467,7 +10734,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10512,13 +10779,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10516: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10783: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10522 "configure"
+#line 10789 "configure"
@@ -10529,7 +10796,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10548,13 +10815,13 @@
-echo "configure:10552: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10819: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10558 "configure"
+#line 10825 "configure"
@@ -10565,7 +10832,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10625,7 +10892,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10629: checking whether to use OpenGL" >&5
+echo "configure:10896: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10659,7 +10926,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10663: checking for location of OpenGL includes" >&5
+echo "configure:10930: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10685,15 +10952,15 @@
do
-echo "configure:10689: checking for $ac_hdr" >&5
+echo "configure:10956: checking for $ac_hdr" >&5
-#line 10692 "configure"
+#line 10959 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10727,7 +10994,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10731: checking for location of OpenGL library" >&5
+echo "configure:10998: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10756,13 +11023,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10760: checking for glBegin in -lGL" >&5
+echo "configure:11027: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10766 "configure"
+#line 11033 "configure"
@@ -10773,7 +11040,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10792,13 +11059,13 @@
-echo "configure:10796: checking for glBegin in -lGL" >&5
+echo "configure:11063: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10802 "configure"
+#line 11069 "configure"
@@ -10809,7 +11076,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10828,13 +11095,13 @@
-echo "configure:10832: checking for glBegin in -lGL" >&5
+echo "configure:11099: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10838 "configure"
+#line 11105 "configure"
@@ -10845,7 +11112,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10864,13 +11131,13 @@
-echo "configure:10868: checking for glBegin in -lGL" >&5
+echo "configure:11135: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10874 "configure"
+#line 11141 "configure"
@@ -10881,7 +11148,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10943,13 +11210,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10947: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11214: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10953 "configure"
+#line 11220 "configure"
@@ -10960,7 +11227,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10979,13 +11246,13 @@
-echo "configure:10983: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11250: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10989 "configure"
+#line 11256 "configure"
@@ -10996,7 +11263,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11043,10 +11310,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11047: checking for glXCreatePbuffer" >&5
+echo "configure:11314: checking for glXCreatePbuffer" >&5
-#line 11050 "configure"
+#line 11317 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11069,7 +11336,7 @@
; return 0; }
EOF
-if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11106,10 +11373,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11110: checking for glXCreateGLXPixmap" >&5
+echo "configure:11377: checking for glXCreateGLXPixmap" >&5
-#line 11113 "configure"
+#line 11380 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11132,7 +11399,7 @@
; return 0; }
EOF
-if { (eval echo configure:11136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11175,7 +11442,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11179: checking for location of OpenGL framework" >&5
+echo "configure:11446: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11199,15 +11466,15 @@
do
-echo "configure:11203: checking for $ac_hdr" >&5
+echo "configure:11470: checking for $ac_hdr" >&5
-#line 11206 "configure"
+#line 11473 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11478: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11243,10 +11510,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11247: checking for glBegin" >&5
+echo "configure:11514: checking for glBegin" >&5
-#line 11250 "configure"
+#line 11517 "configure"
which can conflict with char glBegin(); below. */
@@ -11269,7 +11536,7 @@
; return 0; }
EOF
-if { (eval echo configure:11273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11306,10 +11573,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11310: checking for gluBeginCurve" >&5
+echo "configure:11577: checking for gluBeginCurve" >&5
-#line 11313 "configure"
+#line 11580 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11332,7 +11599,7 @@
; return 0; }
EOF
-if { (eval echo configure:11336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11380,7 +11647,7 @@
-echo "configure:11384: checking for location of OpenGL includes" >&5
+echo "configure:11651: checking for location of OpenGL includes" >&5
@@ -11406,15 +11673,15 @@
do
-echo "configure:11410: checking for $ac_hdr" >&5
+echo "configure:11677: checking for $ac_hdr" >&5
-#line 11413 "configure"
+#line 11680 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11418: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11448,7 +11715,7 @@
-echo "configure:11452: checking for location of OpenGL library" >&5
+echo "configure:11719: checking for location of OpenGL library" >&5
@@ -11473,18 +11740,18 @@
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11477: checking for OpenGL library" >&5
+echo "configure:11744: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11481 "configure"
+#line 11748 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11508,18 +11775,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11512: checking for GLU library" >&5
+echo "configure:11779: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11516 "configure"
+#line 11783 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11568,7 +11835,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11572: checking whether to use ODBC" >&5
+echo "configure:11839: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11587,7 +11854,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11591: checking for location of ODBC includes" >&5
+echo "configure:11858: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11613,15 +11880,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11617: checking for $ac_hdr" >&5
+echo "configure:11884: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 11620 "configure"
+#line 11887 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11892: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -11655,7 +11922,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11659: checking for location of ODBC library" >&5
+echo "configure:11926: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11680,13 +11947,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11684: checking for SQLConnect in -lodbc" >&5
+echo "configure:11951: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11690 "configure"
+#line 11957 "configure"
@@ -11697,7 +11964,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11722,13 +11989,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11726: checking for SQLConnect in -liodbc" >&5
+echo "configure:11993: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11732 "configure"
+#line 11999 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -11739,7 +12006,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11764,11 +12031,11 @@
ac_save_ldflags="$LDFLAGS"
ac_save_libs="$LIBS"
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11768: checking for ODBC library" >&5
+echo "configure:12035: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11772 "configure"
+#line 12039 "configure"
#include <windows.h>
#include <sql.h>
@@ -11776,7 +12043,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11825,7 +12092,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11829: checking whether to use FFTW" >&5
+echo "configure:12096: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11844,7 +12111,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11848: checking for location of FFTW includes" >&5
+echo "configure:12115: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11870,15 +12137,15 @@
do
-echo "configure:11874: checking for $ac_hdr" >&5
+echo "configure:12141: checking for $ac_hdr" >&5
-#line 11877 "configure"
+#line 12144 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11906,15 +12173,15 @@
do
-echo "configure:11910: checking for $ac_hdr" >&5
+echo "configure:12177: checking for $ac_hdr" >&5
-#line 11913 "configure"
+#line 12180 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12185: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11942,15 +12209,15 @@
do
-echo "configure:11946: checking for $ac_hdr" >&5
+echo "configure:12213: checking for $ac_hdr" >&5
-#line 11949 "configure"
+#line 12216 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11954: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11996,7 +12263,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12000: checking for location of FFTW library" >&5
+echo "configure:12267: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12021,13 +12288,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12025: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12292: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12031 "configure"
+#line 12298 "configure"
@@ -12038,7 +12305,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12063,13 +12330,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12067: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12334: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12073 "configure"
+#line 12340 "configure"
@@ -12080,7 +12347,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12105,13 +12372,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12109: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12376: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12115 "configure"
+#line 12382 "configure"
@@ -12122,7 +12389,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12179,7 +12446,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12183: checking whether to use BLAS" >&5
+echo "configure:12450: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12200,7 +12467,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12204: checking for location of BLAS includes" >&5
+echo "configure:12471: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12220,7 +12487,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12224: checking for location of BLAS library" >&5
+echo "configure:12491: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12246,15 +12513,15 @@
do
-echo "configure:12250: checking for $ac_hdr" >&5
+echo "configure:12517: checking for $ac_hdr" >&5
-#line 12253 "configure"
+#line 12520 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12525: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12289,13 +12556,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12293: checking for dnrm2_ in -lblas" >&5
+echo "configure:12560: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12299 "configure"
+#line 12566 "configure"
@@ -12306,7 +12573,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12325,13 +12592,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:12329: checking for dnrm2_ in -lblas" >&5
+echo "configure:12596: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12335 "configure"
+#line 12602 "configure"
@@ -12342,7 +12609,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12386,13 +12653,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12390: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12657: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12396 "configure"
+#line 12663 "configure"
@@ -12403,7 +12670,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12418,13 +12685,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12422: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12689: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12428 "configure"
+#line 12695 "configure"
@@ -12435,7 +12702,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12450,13 +12717,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12454: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12721: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12460 "configure"
+#line 12727 "configure"
@@ -12467,7 +12734,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12512,16 +12779,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12516: checking for sgemm in $vlib_flags" >&5
+echo "configure:12783: checking for sgemm in $vlib_flags" >&5
-#line 12518 "configure"
+#line 12785 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12539,13 +12806,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12543: checking for sgemm_ in -lblas" >&5
+echo "configure:12810: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12549 "configure"
+#line 12816 "configure"
@@ -12556,7 +12823,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12571,13 +12838,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12575: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12842: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12581 "configure"
+#line 12848 "configure"
@@ -12588,7 +12855,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12603,13 +12870,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12607: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12874: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12613 "configure"
+#line 12880 "configure"
@@ -12620,7 +12887,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12654,13 +12921,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12658: checking for acosp in -lsunmath" >&5
+echo "configure:12925: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12664 "configure"
+#line 12931 "configure"
@@ -12671,7 +12938,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12686,13 +12953,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12690: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12957: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12696 "configure"
+#line 12963 "configure"
@@ -12703,7 +12970,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12733,13 +13000,13 @@
# Generic BLAS library
-echo "configure:12737: checking for sgemm_ in -lblas" >&5
+echo "configure:13004: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12743 "configure"
+#line 13010 "configure"
@@ -12750,7 +13017,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12789,7 +13056,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12793: checking whether to use LAPACK" >&5
+echo "configure:13060: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12814,7 +13081,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12818: checking for location of LAPACK includes" >&5
+echo "configure:13085: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12834,7 +13101,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12838: checking for location of LAPACK library" >&5
+echo "configure:13105: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12860,15 +13127,15 @@
do
-echo "configure:12864: checking for $ac_hdr" >&5
+echo "configure:13131: checking for $ac_hdr" >&5
-#line 12867 "configure"
+#line 13134 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12900,10 +13167,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12904: checking for dsegv_" >&5
+echo "configure:13171: checking for dsegv_" >&5
-#line 12907 "configure"
+#line 13174 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char dsegv_(); below. */
@@ -12926,7 +13193,7 @@
; return 0; }
EOF
-if { (eval echo configure:12930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12953,13 +13220,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12957: checking for desgv_ in -llapack" >&5
+echo "configure:13224: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12963 "configure"
+#line 13230 "configure"
@@ -12970,7 +13237,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13002,13 +13269,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13006: checking for dgesv_ in -llapack" >&5
+echo "configure:13273: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13012 "configure"
+#line 13279 "configure"
@@ -13019,7 +13286,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13038,13 +13305,13 @@
-echo "configure:13042: checking for dgesv_ in -llapack" >&5
+echo "configure:13309: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13048 "configure"
+#line 13315 "configure"
@@ -13055,7 +13322,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13111,7 +13378,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13115: checking whether to use Motif" >&5
+echo "configure:13382: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13130,7 +13397,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13134: checking for location of Motif includes" >&5
+echo "configure:13401: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13156,15 +13423,15 @@
do
-echo "configure:13160: checking for $ac_hdr" >&5
+echo "configure:13427: checking for $ac_hdr" >&5
-#line 13163 "configure"
+#line 13430 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13198,7 +13465,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13202: checking for location of Motif library" >&5
+echo "configure:13469: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13223,13 +13490,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13227: checking for XmStringCreate in -lXm" >&5
+echo "configure:13494: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13233 "configure"
+#line 13500 "configure"
@@ -13240,7 +13507,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13281,7 +13548,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13285: checking whether to use Cairo" >&5
+echo "configure:13552: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13302,7 +13569,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13306: checking for location of cairo includes" >&5
+echo "configure:13573: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13328,15 +13595,15 @@
do
-echo "configure:13332: checking for $ac_hdr" >&5
+echo "configure:13599: checking for $ac_hdr" >&5
-#line 13335 "configure"
+#line 13602 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13372,7 +13639,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13376: checking for location of cairo library" >&5
+echo "configure:13643: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13392,7 +13659,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13396: checking for cairo linking flags" >&5
+echo "configure:13663: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13408,10 +13675,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13412: checking for cairo_create" >&5
+echo "configure:13679: checking for cairo_create" >&5
-#line 13415 "configure"
+#line 13682 "configure"
which can conflict with char cairo_create(); below. */
@@ -13434,7 +13701,7 @@
; return 0; }
EOF
-if { (eval echo configure:13438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13477,7 +13744,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13481: checking whether to use FreeType" >&5
+echo "configure:13748: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13496,7 +13763,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13500: checking for location of FreeType includes" >&5
+echo "configure:13767: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13522,15 +13789,15 @@
do
-echo "configure:13526: checking for $ac_hdr" >&5
+echo "configure:13793: checking for $ac_hdr" >&5
-#line 13529 "configure"
+#line 13796 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13564,7 +13831,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13568: checking for location of FreeType library" >&5
+echo "configure:13835: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13589,13 +13856,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13593: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13860: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 13599 "configure"
+#line 13866 "configure"
@@ -13606,7 +13873,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13647,7 +13914,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13651: checking whether to use NLS" >&5
+echo "configure:13918: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13667,10 +13934,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13671: checking for gettext" >&5
+echo "configure:13938: checking for gettext" >&5
-#line 13674 "configure"
+#line 13941 "configure"
which can conflict with char gettext(); below. */
@@ -13693,7 +13960,7 @@
; return 0; }
EOF
-if { (eval echo configure:13697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13711,13 +13978,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13715: checking for gettext in -lintl" >&5
+echo "configure:13982: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13721 "configure"
+#line 13988 "configure"
@@ -13728,7 +13995,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13763,7 +14030,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13767: checking whether to use C++" >&5
+echo "configure:14034: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13779,7 +14046,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13783: checking for $ac_word" >&5
+echo "configure:14050: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13808,7 +14075,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13812: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14079: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13819,12 +14086,12 @@
cat > conftest.$ac_ext << EOF
-#line 13823 "configure"
+#line 14090 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13850,19 +14117,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13854: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14121: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13859: checking whether we are using GNU C++" >&5
+echo "configure:14126: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13866: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13880,7 +14147,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13884: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14151: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13921,7 +14188,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13925: checking whether to use openDWG" >&5
+echo "configure:14192: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13941,7 +14208,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13945: checking for location of openDGW includes" >&5
+echo "configure:14212: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13967,15 +14234,15 @@
do
-echo "configure:13971: checking for $ac_hdr" >&5
+echo "configure:14238: checking for $ac_hdr" >&5
-#line 13974 "configure"
+#line 14241 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13979: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14009,7 +14276,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14013: checking for location of openDWG library" >&5
+echo "configure:14280: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14056,7 +14323,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14060: checking for special C compiler options needed for large files" >&5
+echo "configure:14327: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14064,7 +14331,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14068 "configure"
+#line 14335 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14080,7 +14347,7 @@
; return 0; }
EOF
-if { (eval echo configure:14084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14351: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14089,7 +14356,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14093 "configure"
+#line 14360 "configure"
@@ -14105,7 +14372,7 @@
; return 0; }
EOF
-if { (eval echo configure:14109: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14376: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14125,11 +14392,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14129: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14396: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14133 "configure"
+#line 14400 "configure"
@@ -14145,14 +14412,14 @@
; return 0; }
EOF
-if { (eval echo configure:14149: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14416: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14156 "configure"
+#line 14423 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14170,7 +14437,7 @@
; return 0; }
EOF
-if { (eval echo configure:14174: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14441: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14189,11 +14456,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14193: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14460: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14197 "configure"
+#line 14464 "configure"
@@ -14209,14 +14476,14 @@
; return 0; }
EOF
-if { (eval echo configure:14213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14480: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14220 "configure"
+#line 14487 "configure"
#define _LARGE_FILES 1
@@ -14234,7 +14501,7 @@
; return 0; }
EOF
-if { (eval echo configure:14238: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14505: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14253,25 +14520,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14257: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14524: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14261 "configure"
+#line 14528 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14268: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14535: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14275 "configure"
+#line 14542 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14280,7 +14547,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14551: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14301,10 +14568,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14305: checking if system supports Large Files at all" >&5
+echo "configure:14572: checking if system supports Large Files at all" >&5
-#line 14308 "configure"
+#line 14575 "configure"
#include <stdio.h>
@@ -14336,7 +14603,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14340: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14607: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14365,7 +14632,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14369: checking whether to use Python" >&5
+echo "configure:14636: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -14385,7 +14652,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:14389: checking for $ac_word" >&5
+echo "configure:14656: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -14430,15 +14697,15 @@
do
-echo "configure:14434: checking for $ac_hdr" >&5
+echo "configure:14701: checking for $ac_hdr" >&5
-#line 14437 "configure"
+#line 14704 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14709: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14478,7 +14745,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:14482: checking for $ac_word" >&5
+echo "configure:14749: checking for $ac_word" >&5
case "$SWIG" in
@@ -14524,7 +14791,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14528: checking whether to use wxWidgets" >&5
+echo "configure:14795: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14544,7 +14811,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14548: checking for $ac_word" >&5
+echo "configure:14815: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14592,7 +14859,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14596: checking wxWidgets version" >&5
+echo "configure:14863: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14615,15 +14882,15 @@
do
-echo "configure:14619: checking for $ac_hdr" >&5
+echo "configure:14886: checking for $ac_hdr" >&5
-#line 14622 "configure"
+#line 14889 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14659,15 +14926,15 @@
do
-echo "configure:14663: checking for $ac_hdr" >&5
+echo "configure:14930: checking for $ac_hdr" >&5
-#line 14666 "configure"
+#line 14933 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14938: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14893,6 +15160,10 @@
s%@PROJLIB@%$PROJLIB%g
s%@PROJSHARE@%$PROJSHARE%g
s%@NAD2BIN@%$NAD2BIN%g
+s%@REGEXINCPATH@%$REGEXINCPATH%g
+s%@REGEXLIBPATH@%$REGEXLIBPATH%g
+s%@REGEXLIB@%$REGEXLIB%g
+s%@USE_REGEX@%$USE_REGEX%g
s%@READLINEINCPATH@%$READLINEINCPATH%g
s%@READLINELIBPATH@%$READLINELIBPATH%g
s%@READLINELIB@%$READLINELIB%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-09-04 22:34:00 UTC (rev 33267)
+++ grass/trunk/configure.in 2008-09-04 23:17:53 UTC (rev 33268)
@@ -195,6 +195,7 @@
LOC_ARG_WITH(nls, NLS, no)
LOC_ARG_WITH(readline, Readline, no)
LOC_ARG_WITH(opendwg, openDWG, no)
+LOC_ARG_WITH(regex, regex)
AC_ARG_WITH(python,
[ --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
e.g. '--with-python=/usr/bin/python2.5-config', default: no)],, with_python="no")
@@ -277,6 +278,9 @@
LOC_ARG_WITH_INC(opendwg, openDWG)
LOC_ARG_WITH_LIB(opendwg, openDWG)
+LOC_ARG_WITH_INC(regex, regex)
+LOC_ARG_WITH_LIB(regex, regex)
# Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
# With includes option
@@ -568,6 +572,39 @@
# Done checking PROJ
+# Enable regex option
+LOC_CHECK_USE(regex,regex,USE_REGEX)
+REGEXINCPATH=
+REGEXLIBPATH=
+REGEXLIB=
+if test -n "$USE_REGEX"; then
+# With regex includes directory
+LOC_CHECK_INC_PATH(regex,regex,REGEXINCPATH)
+LOC_CHECK_INCLUDES(regex.h,regex,$REGEXINCPATH)
+# With regex library directory
+LOC_CHECK_LIB_PATH(regex,regex,REGEXLIBPATH)
+LOC_CHECK_FUNC(regcomp,regex functions,REGEXLIB,,,,,[
+LOC_CHECK_LIBS(regex,regcomp,regex,$REGEXLIBPATH,REGEXLIB,,,)
+fi # $USE_REGEX
+AC_SUBST(REGEXINCPATH)
+AC_SUBST(REGEXLIBPATH)
+AC_SUBST(REGEXLIB)
+AC_SUBST(USE_REGEX)
+# Done checking regex
# Enable Readline option
LOC_CHECK_USE(readline,Readline,USE_READLINE)
Modified: grass/trunk/general/Makefile
--- grass/trunk/general/Makefile 2008-09-04 22:34:00 UTC (rev 33267)
+++ grass/trunk/general/Makefile 2008-09-04 23:17:53 UTC (rev 33268)
@@ -13,6 +13,8 @@
g.mapsets \
g.message \
g.mkfontcap \
+ g.mlist \
+ g.mremove \
g.parser \
g.proj \
g.pnmcomp \
Modified: grass/trunk/general/g.mlist/Makefile
--- grass/trunk/general/g.mlist/Makefile 2008-09-04 22:34:00 UTC (rev 33267)
+++ grass/trunk/general/g.mlist/Makefile 2008-09-04 23:17:53 UTC (rev 33268)
@@ -7,4 +7,8 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_REGEX),)
default: cmd
+else
+default:
+endif
Modified: grass/trunk/general/g.mremove/Makefile
--- grass/trunk/general/g.mremove/Makefile 2008-09-04 22:34:00 UTC (rev 33267)
+++ grass/trunk/general/g.mremove/Makefile 2008-09-04 23:17:53 UTC (rev 33268)
@@ -7,4 +7,8 @@
default: cmd
+else
+default:
+endif
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2008-09-04 22:34:00 UTC (rev 33267)
+++ grass/trunk/include/Make/Platform.make.in 2008-09-04 23:17:53 UTC (rev 33268)
@@ -228,6 +228,12 @@
WXWIDGETSLIB = @WXWIDGETSLIB@
USE_WXWIDGETS = @USE_WXWIDGETS@
+#regex
+REGEXINCPATH = @REGEXINCPATH@
+REGEXLIBPATH = @REGEXLIBPATH@
+REGEXLIB = @REGEXLIB@
+USE_REGEX = @USE_REGEX@
#i18N
HAVE_NLS = @HAVE_NLS@
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in 2008-09-04 22:34:00 UTC (rev 33267)
+++ grass/trunk/include/config.h.in 2008-09-04 23:17:53 UTC (rev 33268)
@@ -233,6 +233,9 @@
/* define if OpenGL uses Windows */
#undef OPENGL_WINDOWS
+/* define if regex.h exists */
+#undef HAVE_REGEX_H
* configuration information solely dependent on the above
* nothing below this point should need changing
