[GRASS-SVN] r33285 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Fri Sep 5 18:26:09 EDT 2008
Author: martinl
Date: 2008-09-05 18:26:09 -0400 (Fri, 05 Sep 2008)
New Revision: 33285
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/vdigit/cats.cpp
wxGUI: display attributes bug fix (not found --- found)
(merge devbr6, r33283, r33284)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-09-05 22:24:34 UTC (rev 33284)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-09-05 22:26:09 UTC (rev 33285)
@@ -2805,11 +2805,15 @@
mainSizer.Fit(self)
# set min size for dialog
- self.SetMinSize(self.GetBestSize())
+ w, h = self.GetBestSize()
+ if h < 200:
+ self.SetMinSize((w, 200))
+ else:
+ self.SetMinSize(self.GetBestSize())
if self.notebook.GetPageCount() == 0:
Debug.msg(2, "DisplayAttributesDialog(): Nothing found!")
- self.mapDBInfo = None
+ ### self.mapDBInfo = None
def __SelectAttributes(self, layer):
"""Select attributes"""
@@ -2958,7 +2962,7 @@
self.mapDBInfo = VectorDBInfo(self.map)
self.line['id'] = (line, )
- self.line['cats'] = None
+ self.line['cats'] = cats
if not self.mapDBInfo:
return False
@@ -3103,9 +3107,16 @@
# for each layer END
self.Layout()
return True
+ def IsFound(self):
+ """Check if attributes found"""
+ if self.notebook.GetPageCount() > 0:
+ return True
+ return False
class VectorDBInfo(gselect.VectorDBInfo):
"""Class providing information about attribute tables
linked to the vector map"""
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-09-05 22:24:34 UTC (rev 33284)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-09-05 22:26:09 UTC (rev 33285)
@@ -1223,9 +1223,9 @@
line=line)
if self.parent.dialogs['attributes']:
- line = self.parent.dialogs['attributes'].GetLine()
- if self.parent.dialogs['attributes'].mapDBInfo and line:
+ if self.parent.dialogs['attributes'].IsFound():
# highlight feature & re-draw map
+ line = self.parent.dialogs['attributes'].GetLine()
digitClass.driver.SetSelected(line)
if not self.parent.dialogs['attributes'].IsShown():
self.parent.dialogs['attributes'].Show()
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-05 22:24:34 UTC (rev 33284)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-05 22:26:09 UTC (rev 33285)
@@ -1151,7 +1151,7 @@
@param line feature id (-1 for first selected line)
- return self.digit.GetLineCats(line)
+ return dict(self.digit.GetLineCats(line))
def SetLineCats(self, line, layer, cats, add=True):
"""Set categories for given line and layer
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-09-05 22:24:34 UTC (rev 33284)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-09-05 22:26:09 UTC (rev 33285)
@@ -158,9 +158,8 @@
std::map<int, std::vector<int> > Digit::GetLineCats(int line_id)
std::map<int, std::vector<int> > lc;
- int line, n_dblinks;
+ int line;
struct line_cats *Cats;
- struct field_info *fi;
if (!display->mapInfo) {
DisplayMsg();
@@ -189,20 +188,12 @@
ReadLineMsg(line);
return lc;
- n_dblinks = Vect_get_num_dblinks(display->mapInfo);
- for (int dblink = 0; dblink < n_dblinks; dblink++) {
- fi = Vect_get_dblink(display->mapInfo, dblink);
- if (fi == NULL) {
- DblinkMsg(dblink+1);
- continue;
- std::vector<int> cats;
- lc[fi->number] = cats;
for (int i = 0; i < Cats->n_cats; i++) {
+ if (lc.find(Cats->field[i]) == lc.end()) {
+ std::vector<int> cats;
+ lc[Cats->field[i]] = cats;
lc[Cats->field[i]].push_back(Cats->cat[i]);
