[GRASS-SVN] r33300 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Sep 6 09:00:37 EDT 2008
Author: martinl
Date: 2008-09-06 09:00:37 -0400 (Sat, 06 Sep 2008)
New Revision: 33300
grass/trunk/gui/wxpython/gui_modules/histogram.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
wxGUI: bugfix - trac #291 - font settings not saved
(merge from devbr6, r33299)
Modified: grass/trunk/gui/wxpython/gui_modules/histogram.py
--- grass/trunk/gui/wxpython/gui_modules/histogram.py 2008-09-06 12:59:12 UTC (rev 33299)
+++ grass/trunk/gui/wxpython/gui_modules/histogram.py 2008-09-06 13:00:37 UTC (rev 33300)
@@ -36,7 +36,7 @@
import menuform
import disp_print
import utils
-from gui_modules.preferences import SetDefaultFont as SetDefaultFont
+from gui_modules.preferences import DefaultFontDialog as DefaultFontDialog
from debug import Debug as Debug
from icon import Icons as Icons
@@ -413,11 +413,12 @@
set, font will be default display font.
- dlg = SetDefaultFont(self, wx.ID_ANY, 'Select font for histogram text',
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_DIALOG_STYLE,
- encoding=self.encoding)
+ dlg = DefaultFontDialog(parent=self, id=wx.ID_ANY,
+ title=_('Select font for histogram text'),
+ encoding=self.encoding)
dlg.fontlb.SetStringSelection(self.font, True)
if dlg.ShowModal() == wx.ID_CANCEL:
dlg.Destroy()
return
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-09-06 12:59:12 UTC (rev 33299)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-09-06 13:00:37 UTC (rev 33300)
@@ -7,7 +7,7 @@
Classes:
- PreferencesDialog
- - SetDefaultFont
+ - DefaultFontDialog
- MapsetAccess
(C) 2007-2008 by the GRASS Development Team
@@ -84,8 +84,9 @@
# display
'display': {
- 'displayFont' : {
- 'value' : ''
+ 'font' : {
+ 'type' : '',
+ 'encoding': 'ISO-8859-1',
'driver': {
'type': 'cairo'
@@ -564,6 +565,12 @@
if self.filePath:
self.__ReadFile(self.filePath, settings)
+ # set environment variables
+ os.environ["GRASS_FONT"] = self.Get(group='display',
+ key='font', subkey='type')
+ os.environ["GRASS_ENCODING"] = self.Get(group='display',
+ key='font', subkey='encoding')
def __ReadFile(self, filename, settings=None):
"""Read settings from file to dict"""
if settings is None:
@@ -1436,30 +1443,27 @@
def OnSetFont(self, event):
"""'Set font' button pressed"""
- dlg = SetDefaultFont(parent=self, id=wx.ID_ANY,
- title=_('Select default display font'),
- encoding=self.parent.encoding)
- if dlg.ShowModal() == wx.ID_CANCEL:
- dlg.Destroy()
- return
+ title=_('Select default display font'),
+ style=wx.DEFAULT_DIALOG_STYLE)
+ if dlg.ShowModal() == wx.ID_OK:
+ # set default font and encoding environmental variables
+ if dlg.font:
+ os.environ["GRASS_FONT"] = dlg.font
+ self.settings.Set(group='display', value=dlg.font,
- # set default font type, font, and encoding to whatever selected in dialog
- if dlg.font != None:
- self.font = dlg.font
- if dlg.encoding != None:
- self.encoding = dlg.encoding
+ if dlg.encoding and \
+ dlg.encoding != "ISO-8859-1":
+ os.environ["GRASS_ENCODING"] = dlg.encoding
+ self.settings.Set(group='display', value=dlg.encoding,
dlg.Destroy()
- # set default font and encoding environmental variables
- os.environ["GRASS_FONT"] = self.font
- if self.encoding != None and self.encoding != "ISO-8859-1":
- os.environ["GRASS_ENCODING"] = self.encoding
event.Skip()
def OnSave(self, event):
"""Button 'Save' pressed"""
if self.__UpdateSettings():
@@ -1556,66 +1560,96 @@
return True
-class SetDefaultFont(wx.Dialog):
+class DefaultFontDialog(wx.Dialog):
Opens a file selection dialog to select default font
to use in all GRASS displays
- def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_DIALOG_STYLE, encoding='ISO-8859-1'):
+ def __init__(self, parent, id, title,
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_DIALOG_STYLE,
+ settings=globalSettings):
+ self.settings = settings
wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+ panel = wx.Panel(parent=self, id=wx.ID_ANY)
if "GRASS_FONT" in os.environ:
self.font = os.environ["GRASS_FONT"]
else:
- self.font = None
+ self.font = self.settings.Get(group='display',
self.fontlist = self.GetFonts()
- self.encoding = encoding
+ self.encoding = self.settings.Get(group='display',
+ border = wx.BoxSizer(wx.VERTICAL)
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Font settings"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- sizer = wx.BoxSizer(wx.VERTICAL)
+ gridSizer = wx.GridBagSizer (hgap=5, vgap=5)
+ gridSizer.AddGrowableCol(0)
- box = wx.BoxSizer(wx.HORIZONTAL)
- label = wx.StaticText(self, -1, "Select Font:", (15, 50))
- box.Add(label, 0, wx.EXPAND|wx.GROW|wx.ALIGN_TOP|wx.RIGHT, 5)
- self.fontlb = wx.ListBox(self, wx.ID_ANY, pos=wx.DefaultPosition,
- size=(280,150), choices=self.fontlist,
+ label = wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Select font:"))
+ gridSizer.Add(item=label,
+ flag=wx.ALIGN_TOP,
+ pos=(0,0))
+ self.fontlb = wx.ListBox(parent=panel, id=wx.ID_ANY, pos=wx.DefaultPosition,
+ choices=self.fontlist,
style=wx.LB_SINGLE|wx.LB_SORT)
self.Bind(wx.EVT_LISTBOX, self.EvtListBox, self.fontlb)
self.Bind(wx.EVT_LISTBOX_DCLICK, self.EvtListBoxDClick, self.fontlb)
if self.font:
self.fontlb.SetStringSelection(self.font, True)
- box.Add(self.fontlb, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT)
- sizer.Add(box, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT|wx.ALL, 8)
- label = wx.StaticText(self, -1, "Character encoding:")
- box.Add(label, 0, wx.ALIGN_RIGHT|wx.RIGHT, 5)
- self.textentry = wx.TextCtrl(self, -1, "", size=(200,-1))
- self.textentry.SetValue(self.encoding)
- box.Add(self.textentry, 0, wx.ALIGN_LEFT)
+ gridSizer.Add(item=self.fontlb,
+ flag=wx.EXPAND, pos=(0, 1))
+ label=("Character encoding:"))
+ flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(1, 0))
+ self.textentry = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
+ value=self.encoding)
+ gridSizer.Add(item=self.textentry,
+ flag=wx.EXPAND, pos=(1, 1))
self.textentry.Bind(wx.EVT_TEXT, self.OnEncoding)
- sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 8)
- line = wx.StaticLine(self, -1, size=(20,-1), style=wx.LI_HORIZONTAL)
- sizer.Add(line, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 10)
+ sizer.Add(item=gridSizer, proportion=1,
+ flag=wx.EXPAND | wx.ALL,
+ border=5)
+ border.Add(item=sizer, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=3)
btnsizer = wx.StdDialogButtonSizer()
- btn = wx.Button(self, wx.ID_OK)
+ btn = wx.Button(parent=panel, id=wx.ID_OK)
btn.SetDefault()
btnsizer.AddButton(btn)
- btn = wx.Button(self, wx.ID_CANCEL)
+ btn = wx.Button(parent=panel, id=wx.ID_CANCEL)
btnsizer.Realize()
- sizer.Add(btnsizer, 0, wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
- self.SetSizer(sizer)
- sizer.Fit(self)
+ border.Add(item=btnsizer, proportion=0,
+ flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
+ panel.SetAutoLayout(True)
+ panel.SetSizer(border)
+ border.Fit(self)
+ self.Layout()
def EvtRadioBox(self, event):
if event.GetInt() == 0:
self.fonttype = 'grassfont'
