[GRASS-SVN] r33305 - in grass/trunk/general: g.mlist g.mremove
svn_grass at osgeo.org
Sat Sep 6 13:31:46 EDT 2008
Author: glynn
Date: 2008-09-06 13:31:46 -0400 (Sat, 06 Sep 2008)
New Revision: 33305
grass/trunk/general/g.mlist/main.c
grass/trunk/general/g.mremove/main.c
Use basic REs by default; add -e for extended REs
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2008-09-06 17:23:43 UTC (rev 33304)
+++ grass/trunk/general/g.mlist/main.c 2008-09-06 17:31:46 UTC (rev 33305)
@@ -48,6 +48,7 @@
struct
struct Flag *regex;
+ struct Flag *extended;
struct Flag *type;
struct Flag *mapset;
struct Flag *pretty;
@@ -115,6 +116,11 @@
flag.regex = G_define_flag();
flag.regex->key = 'r';
flag.regex->description =
+ _("Use basic regular expressions instead of wildcards");
+ flag.extended = G_define_flag();
+ flag.extended->key = 'e';
+ flag.extended->description =
_("Use extended regular expressions instead of wildcards");
flag.type = G_define_flag();
@@ -138,12 +144,15 @@
G_free(buf);
- if (flag.regex->answer)
+ if (flag.regex->answer && flag.extended->answer)
+ G_fatal_error(_("-r and -e are mutually exclusive"));
+ if (flag.regex->answer || flag.extended->answer)
pattern = opt.pattern->answer;
else
pattern = wc2regex(opt.pattern->answer);
- if (regcomp(®ex, pattern, REG_EXTENDED | REG_NOSUB))
+ if (regcomp(®ex, pattern, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
G_fatal_error(_("Unable to compile regular expression %s"), pattern);
G_set_ls_filter(ls_filter, ®ex);
Modified: grass/trunk/general/g.mremove/main.c
--- grass/trunk/general/g.mremove/main.c 2008-09-06 17:23:43 UTC (rev 33304)
+++ grass/trunk/general/g.mremove/main.c 2008-09-06 17:31:46 UTC (rev 33305)
@@ -42,6 +42,7 @@
struct
struct Flag *regex;
struct Flag *force;
struct Flag *basemap;
} flag;
@@ -62,6 +63,11 @@
flag.force = G_define_flag();
@@ -94,6 +100,9 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
for (n = 0; n < nlist; n++) {
o = opt[n];
G_free((char *)o->gisprompt);
@@ -110,13 +119,14 @@
continue;
rast = !G_strcasecmp(list[n].alias, "rast");
for (i = 0; (name = opt[n]->answers[i]); i++) {
- if (!flag.regex->answer)
+ if (!flag.regex->answer && !flag.extended->answer)
name = wc2regex(name);
- if (regcomp(®ex, name, REG_EXTENDED | REG_NOSUB))
+ if (regcomp(®ex, name,
+ (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
G_fatal_error(_
name);
G_free(name);
