[GRASS-SVN] r33312 -
grass/branches/develbranch_6/visualization/nviz2/cmd
svn_grass at osgeo.org
Sun Sep 7 07:50:38 EDT 2008
Author: martinl
Date: 2008-09-07 07:50:38 -0400 (Sun, 07 Sep 2008)
New Revision: 33312
grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h
grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c
grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c
nviz_cmd: options for position (surface, vlines, vpoints)
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/args.c 2008-09-07 11:49:01 UTC (rev 33311)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/args.c 2008-09-07 11:50:38 UTC (rev 33312)
@@ -279,6 +279,17 @@
params->shade->answer = "gouraud";
params->shade->guisection = _("Draw");
+ /* position */
+ params->surface_pos = G_define_option();
+ params->surface_pos->key = "position";
+ params->surface_pos->key_desc = "x,y,z";
+ params->surface_pos->type = TYPE_INTEGER;
+ params->surface_pos->required = YES;
+ params->surface_pos->multiple = YES;
+ params->surface_pos->description = _("Position");
+ params->surface_pos->guisection = _("Draw");
+ params->surface_pos->answer = "0,0,0";
return;
@@ -336,6 +347,17 @@
params->vline_height->options = "0-1000";
params->vline_height->answer = "0";
+ /* position */
+ params->vline_pos = G_define_option();
+ params->vline_pos->key = "vline_position";
+ params->vline_pos->key_desc = "x,y,z";
+ params->vline_pos->type = TYPE_INTEGER;
+ params->vline_pos->required = YES;
+ params->vline_pos->multiple = YES;
+ params->vline_pos->description = _("Position");
+ params->vline_pos->guisection = _("Vector lines");
+ params->vline_pos->answer = "0,0,0";
return;
@@ -394,6 +416,17 @@
params->vpoint_marker->answer = "sphere";
params->vpoint_marker->guisection = _("Vector points");
+ /* position */
+ params->vpoint_pos = G_define_option();
+ params->vpoint_pos->key = "vpoint_position";
+ params->vpoint_pos->key_desc = "x,y,z";
+ params->vpoint_pos->type = TYPE_INTEGER;
+ params->vpoint_pos->required = YES;
+ params->vpoint_pos->multiple = YES;
+ params->vpoint_pos->description = _("Position");
+ params->vpoint_pos->guisection = _("Vector points");
+ params->vpoint_pos->answer = "0,0,0";
return;
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h
--- grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h 2008-09-07 11:49:01 UTC (rev 33311)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/local_proto.h 2008-09-07 11:50:38 UTC (rev 33312)
@@ -14,11 +14,11 @@
*mask_map, *transp_map, *transp_const, *shine_map, *shine_const,
*emit_map, *emit_const,
/* surface draw mode */
- *mode, *res_fine, *res_coarse, *style, *shade, *wire_color,
+ *mode, *res_fine, *res_coarse, *style, *shade, *wire_color, *surface_pos,
/* vector lines */
- *vlines, *vline_width, *vline_color, *vline_mode, *vline_height,
+ *vlines, *vline_width, *vline_color, *vline_mode, *vline_height, *vline_pos,
/* vector points */
- *vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width,
+ *vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width, *vpoint_pos,
/* volumes */
*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
/* misc */
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c 2008-09-07 11:49:01 UTC (rev 33311)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/surface.c 2008-09-07 11:50:38 UTC (rev 33312)
@@ -37,6 +37,8 @@
int *surf_list, nsurfs;
int id;
+ double x, y, z;
nelev_map = opt_get_num_answers(params->elev_map);
nelev_const = opt_get_num_answers(params->elev_const);
@@ -72,6 +74,13 @@
i + 1);
+ /* set position */
+ x = atof(params->surface_pos->answers[i]);
+ y = atof(params->surface_pos->answers[i+1]);
+ z = atof(params->surface_pos->answers[i+2]);
+ GS_set_trans(id, x, y, z);
/* set surface attributes */
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c 2008-09-07 11:49:01 UTC (rev 33311)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/vector.c 2008-09-07 11:50:38 UTC (rev 33312)
@@ -22,7 +22,7 @@
#include "local_proto.h"
static int load_vectors(const struct Option *, const struct Option *,
- const struct Option *, int, nv_data *);
+ const struct Option *, const struct Option *, int, nv_data *);
\brief Load vector maps (lines)
@@ -35,7 +35,8 @@
int load_vlines(const struct GParams *params, nv_data * data)
return load_vectors(params->elev_map, params->elev_const,
- params->vlines, MAP_OBJ_VECT, data);
+ params->vlines, params->vline_pos,
+ MAP_OBJ_VECT, data);
@@ -49,18 +50,22 @@
int load_vpoints(const struct GParams *params, nv_data * data)
- params->vpoints, MAP_OBJ_SITE, data);
+ params->vpoints, params->vpoint_pos,
+ MAP_OBJ_SITE, data);
int load_vectors(const struct Option *elev_map,
const struct Option *elev_const, const struct Option *vect,
+ const struct Option *position,
int map_obj_type, nv_data * data)
- int i;
+ int i, id;
int nvects;
char *mapset;
+ double x, y, z;
if ((!elev_map->answer || elev_const->answer) && GS_num_surfs() == 0) { /* load base surface if no loaded */
int *surf_list, nsurf;
@@ -77,10 +82,20 @@
if (mapset == NULL) {
G_fatal_error(_("Vector map <%s> not found"), vect->answers[i]);
- Nviz_new_map_obj(map_obj_type,
- G_fully_qualified_name(vect->answers[i], mapset),
- 0.0, data);
+ id = Nviz_new_map_obj(map_obj_type,
+ G_fully_qualified_name(vect->answers[i], mapset),
+ 0.0, data);
+ x = atof(position->answers[i]);
+ y = atof(position->answers[i+1]);
+ z = atof(position->answers[i+2]);
+ if (map_obj_type == MAP_OBJ_VECT)
+ GV_set_trans(id, x, y, z);
+ else
+ GP_set_trans(id, x, y, z);
nvects++;
