[GRASS-SVN] r33342 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Sep 9 03:26:48 EDT 2008
Author: cmbarton
Date: 2008-09-09 03:26:47 -0400 (Tue, 09 Sep 2008)
New Revision: 33342
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
New classes create comboboxes for selecting vector layers, vector attribute columns, and generic data table columns.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-09-09 07:20:37 UTC (rev 33341)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-09-09 07:26:47 UTC (rev 33342)
@@ -1,21 +1,18 @@
- at package gselect
+MODULE: gselect
- at brief Custom control that selects GRASS GIS elements
CLASSES:
- - Select
- - TreeCrtlComboPopup
- - VectorDBInfo
- - LayerSelect
- - ColumnSelect
+ * Select
+ * TreeCrtlComboPopup
-(C) 2007-2008 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
+PURPOSE: Custon control that selects GRASS GIS elements
- at author Michael Barton, Martin Landa
+AUTHORS: The GRASS Development Team. Michael Barton & Martin Landa
+COPYRIGHT: (C) 2007 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
import os
@@ -301,18 +298,20 @@
linked to a vector map"""
def __init__(self, map):
self.map = map
- # {layer number : {table, database, driver})
- self.layers = {}
- # {table : {column name : type, length, values, ids}}
- self.tables = {}
- if not self.__CheckDBConnection(): # -> self.layers
+ self.layers = {} # dictionary of layer number and associated table
+ self.tables = {} # dictionary of table and associated columns
+ ## {table : {column name : type, length, values, ids}}
+ #self.tables = {}
+ if not self.__GetLayers(): # -> self.layers
return
+ self.__GetColumns() # -> self.tables
- self.__DescribeTables() # -> self.tables
- def __CheckDBConnection(self):
- """Check DB connection"""
+ def __GetLayers(self):
+ """Create layers dictionary"""
layerCommand = gcmd.Command(cmd=["v.db.connect",
"-g", "--q",
"map=%s" % self.map],
@@ -320,91 +319,39 @@
if layerCommand.returncode != 0:
return False
- # list of available layers & (table, database, driver)
+ # create dictionary of layers (as strings) and associated table names for vector
for line in layerCommand.ReadStdOutput():
lineList = line.split(' ')
layer = lineList[0]
if '/' in layer:
- layer, layer_name = lineList[0].split('/')
- else:
- layer_name = None
- # database can contain ' ' in it's path
- if len(lineList) > 5:
- database = ''.join(lineList[3:-1])
- else:
- database = lineList[3]
- self.layers[int(layer)] = {
- "name" : layer_name,
- "table" : lineList[1],
- "key" : lineList[2],
- "database" : database,
- "driver" : lineList[-1]
+ layer = layer.split('/')[0]
+ table = lineList[1]
+ self.layers[layer] = table
if (len(self.layers.keys()) == 0):
return False
return True
- def __DescribeTables(self):
- """Describe linked tables"""
+ def __GetColumns(self):
+ """Create dictionary of tables and associated columns"""
for layer in self.layers.keys():
+ columns = []
# determine column names and types
- table = self.layers[layer]["table"]
- columnsCommand = gcmd.Command (cmd=["db.describe",
- "-c", "--q",
- "table=%s" % self.layers[layer]["table"],
- "driver=%s" % self.layers[layer]["driver"],
- "database=%s" % self.layers[layer]["database"]])
- columns = {} # {name: {type, length, [values], [ids]}}
- if columnsCommand.returncode == 0:
- # skip nrows and ncols
- i = 0
- for line in columnsCommand.ReadStdOutput()[2:]:
- num, name, type, length = line.strip().split(':')
- # FIXME: support more datatypes
- if type.lower() == "integer":
- ctype = int
- elif type.lower() == "double precision":
- ctype = float
- else:
- ctype = str
- columns[name.strip()] = { 'index' : i,
- 'type' : type.lower(),
- 'ctype' : ctype,
- 'length' : int(length),
- 'values' : [],
- 'ids' : []}
- i += 1
- else:
- return False
- # check for key column
- # v.db.connect -g/p returns always key column name lowercase
- if self.layers[layer]["key"] not in columns.keys():
- for col in columns.keys():
- if col.lower() == self.layers[layer]["key"]:
- self.layers[layer]["key"] = col.upper()
- break
+ table = self.layers[layer]
+ cmd = ['v.info', '-c', 'map=%s' % table, 'layer=%s' % layer]
+ try:
+ info = gcmd.Command(cmd).ReadStdOutput()
+ for line in info:
+ col = line.split('|')[1]
+ columns.append(col)
+ except gcmd.CmdError:
+ columns = []
self.tables[table] = columns
- #print 'self tables =', self.tables[table]
return True
- def Reset(self):
- """Reset"""
- for layer in self.layers:
- table = self.layers[layer]["table"] # get table desc
- columns = self.tables[table]
- for name in self.tables[table].keys():
- self.tables[table][name]['values'] = []
- self.tables[table][name]['ids'] = []
class LayerSelect(wx.ComboBox):
Creates combo box for selecting data layers defined for vector.
@@ -416,20 +363,17 @@
super(LayerSelect, self).__init__(parent, id, value, pos, size, choices)
- self.vector = kargs['vector'] # vector map to check for attribute tables
+ lsvector = kargs['vector'] # vector map to check for attribute tables
- if self.vector == '':
+ if lsvector == '':
return
else:
- self.InsertLayers(self.vector)
+ self.InsertLayers(lsvector)
def InsertLayers(self, vector):
"""insert layers for a vector into the layer combobox"""
layerchoices = VectorDBInfo(vector).layers.keys()
- self.Clear()
- for n in range(len(layerchoices)):
- self.Insert(str(layerchoices[n]), n)
+ self.SetItems(layerchoices)
self.SetSelection(0)
self.SetValue('1') # all vectors have a layer 1 by default
@@ -444,24 +388,53 @@
super(ColumnSelect, self).__init__(parent, id, value, pos, size, choices)
- self.layer = kargs['layer'] # data layer connected to attribute table
+ csvector = kargs['vector'] # vector map to check for attribute tables
+ cslayer = kargs['layer'] # data layer connected to attribute table
- if self.vector == '' or self.layer == '':
+ if csvector == '' or cslayer == '':
return
else:
- self.InsertColumns(self.vector, self.layer)
+ self.InsertColumns(csvector, cslayer)
def InsertColumns(self, vector, layer):
- """Return list of columns names for a vector layer"""
+ """insert columns for a vector attribute table into the columns combobox"""
if vector == '' or layer == '': return
+ table = VectorDBInfo(vector).layers[str(layer)]
+ columnchoices = VectorDBInfo(vector).tables[table]
+ #columnchoices.sort()
+ self.SetItems(columnchoices)
+class DbColumnSelect(wx.ComboBox):
+ Creates combo box for selecting columns from any table.
+ def __init__(self, parent,
+ id=wx.ID_ANY, value='', pos=wx.DefaultPosition,
+ size=wx.DefaultSize, choices=[''], **kargs):
+ super(ColumnSelect, self).__init__(parent, id, value, pos, size, choices)
+ dbtable = kargs['table'] # table to check for columns
+ dbdriver = kargs['driver'] # driver for table
+ dbdatabase = kargs['database'] # database for table
+ if dbtable == '':
+ return
+ else:
+ self.InsertColumns(dbtable)
+ def InsertColumns(self, table):
+ """insert columns for a table into the columns combobox"""
+ if table == '' : return
- table = VectorDBInfo(vector).layers[layer]["table"]
- columnchoices = VectorDBInfo(vector).tables[table].keys()
- columnchoices.sort()
- self.Clear()
- for n in range(len(columnchoices)):
- self.Insert(columnchoices[n], n)
- self.SetSelection(0)
- self.SetValue(columnchoices[0]) #set the combobox to the first column
+ cmd = ['db.columns','table=%s' % table]
+ if dbdriver != '': cmd.append('driver=%s' % dbdriver)
+ if dbdatabase != '': cmd.append('database=%s' % dbdatabase)
+ try:
+ columnchoices = gcmd.Command(cmd).ReadStdOutput()
+ columnchoices = []
