[GRASS-SVN] r33345 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Sep 9 03:54:43 EDT 2008
Author: martinl
Date: 2008-09-09 03:54:43 -0400 (Tue, 09 Sep 2008)
New Revision: 33345
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
wxGUI: changes in VectorDBInfo class reverted (r33342) -- it breaks dbm.py completely
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-09-09 07:28:43 UTC (rev 33344)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-09-09 07:54:43 UTC (rev 33345)
@@ -299,19 +299,18 @@
def __init__(self, map):
self.map = map
- self.layers = {} # dictionary of layer number and associated table
- self.tables = {} # dictionary of table and associated columns
+ # dictionary of layer number and associated (driver, database, table)
+ self.layers = {}
+ # dictionary of table and associated columns (type, length, values, ids)
+ self.tables = {}
- ## {table : {column name : type, length, values, ids}}
- #self.tables = {}
- if not self.__GetLayers(): # -> self.layers
+ if not self.__CheckDBConnection(): # -> self.layers
return
- self.__GetColumns() # -> self.tables
- def __GetLayers(self):
- """Create layers dictionary"""
+ self.__DescribeTables() # -> self.tables
+ def __CheckDBConnection(self):
+ """Check DB connection"""
layerCommand = gcmd.Command(cmd=["v.db.connect",
"-g", "--q",
"map=%s" % self.map],
@@ -319,39 +318,91 @@
if layerCommand.returncode != 0:
return False
- # create dictionary of layers (as strings) and associated table names for vector
+ # list of available layers & (table, database, driver)
for line in layerCommand.ReadStdOutput():
lineList = line.split(' ')
layer = lineList[0]
if '/' in layer:
- layer = layer.split('/')[0]
- table = lineList[1]
- self.layers[layer] = table
+ layer, layer_name = lineList[0].split('/')
+ else:
+ layer_name = None
+ # database can contain ' ' in it's path
+ if len(lineList) > 5:
+ database = ''.join(lineList[3:-1])
+ else:
+ database = lineList[3]
+ self.layers[int(layer)] = {
+ "name" : layer_name,
+ "table" : lineList[1],
+ "key" : lineList[2],
+ "database" : database,
+ "driver" : lineList[-1]
if (len(self.layers.keys()) == 0):
return False
return True
- def __GetColumns(self):
- """Create dictionary of tables and associated columns"""
+ def __DescribeTables(self):
+ """Describe linked tables"""
for layer in self.layers.keys():
- columns = []
# determine column names and types
- table = self.layers[layer]
- cmd = ['v.info', '-c', 'map=%s' % table, 'layer=%s' % layer]
- try:
- info = gcmd.Command(cmd).ReadStdOutput()
- for line in info:
- col = line.split('|')[1]
- columns.append(col)
- except gcmd.CmdError:
- columns = []
+ table = self.layers[layer]["table"]
+ columnsCommand = gcmd.Command (cmd=["db.describe",
+ "-c", "--q",
+ "table=%s" % self.layers[layer]["table"],
+ "driver=%s" % self.layers[layer]["driver"],
+ "database=%s" % self.layers[layer]["database"]])
+ columns = {} # {name: {type, length, [values], [ids]}}
+ if columnsCommand.returncode == 0:
+ # skip nrows and ncols
+ i = 0
+ for line in columnsCommand.ReadStdOutput()[2:]:
+ num, name, type, length = line.strip().split(':')
+ # FIXME: support more datatypes
+ if type.lower() == "integer":
+ ctype = int
+ elif type.lower() == "double precision":
+ ctype = float
+ else:
+ ctype = str
+ columns[name.strip()] = { 'index' : i,
+ 'type' : type.lower(),
+ 'ctype' : ctype,
+ 'length' : int(length),
+ 'values' : [],
+ 'ids' : []}
+ i += 1
+ else:
+ return False
+ # check for key column
+ # v.db.connect -g/p returns always key column name lowercase
+ if self.layers[layer]["key"] not in columns.keys():
+ for col in columns.keys():
+ if col.lower() == self.layers[layer]["key"]:
+ self.layers[layer]["key"] = col.upper()
+ break
self.tables[table] = columns
+ #print 'self tables =', self.tables[table]
return True
+ def Reset(self):
+ """Reset"""
+ for layer in self.layers:
+ table = self.layers[layer]["table"] # get table desc
+ columns = self.tables[table]
+ for name in self.tables[table].keys():
+ self.tables[table][name]['values'] = []
+ self.tables[table][name]['ids'] = []
class LayerSelect(wx.ComboBox):
Creates combo box for selecting data layers defined for vector.
