[GRASS-SVN] r33347 - grass/trunk/gui/wxpython/gui_modules
Tue Sep 9 03:58:56 EDT 2008
Author: martinl
Date: 2008-09-09 03:58:56 -0400 (Tue, 09 Sep 2008)
New Revision: 33347
   grass/trunk/gui/wxpython/gui_modules/colorrules.py
cmbarton: Updated to use new gselect classes for vector layer and attribute comboboxes
(merge from devbr6, r33344)
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py	2008-09-09 07:57:21 UTC (rev 33346)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py	2008-09-09 07:58:56 UTC (rev 33347)
@@ -281,15 +281,12 @@
             except:
                 pass
         elif self.cmd == 'vcolors':
-            self.cb_vlayer.InsertLayers(self.inmap)
-            #self.mapDBInfo = dbm.VectorDBInfo(self.inmap)
-            #self.layerchoices = self.mapDBInfo.layers.keys()
-            #for n in range(len(self.layerchoices)):
-            #    self.cb_vlayer.Insert(str(self.layerchoices[n]), n)
-            # initialize column selection combox boxes for layer 1
             try:
+                # initialize layer selection combobox
+                self.cb_vlayer.InsertLayers(self.inmap)
+                # initialize attribute table for layer=1
+                self.vtable = gselect.VectorDBInfo(self.inmap).layers[str(self.vlayer)]
+                # initialize column selection comboboxes
                 self.cb_vcol.InsertColumns(vector=self.inmap, layer=self.vlayer)
                 self.cb_vrgb.InsertColumns(vector=self.inmap, layer=self.vlayer)
                 self.Update()
@@ -299,6 +296,7 @@
     def OnLayerSelection(self, event):
         # reset choices in column selection comboboxes if layer changes
         self.vlayer = int(event.GetString())
         self.Update()
@@ -403,13 +401,13 @@
     def CreateColorTable(self):
         rulestxt = ''
-        for num in self.ruleslines:
+        for num in range(len(self.ruleslines)):
             if self.ruleslines[num][0] != "":
                 if self.cmd == 'r.colors':
                     rulestxt += self.ruleslines[num][0] + ' ' + self.ruleslines[num][1] + '\n'
                     rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.vtable,
-                        self.vrgb,self.ruleslines[num][1], self.ruleslines[num][0])
+                        self.vrgb, self.ruleslines[num][1], self.ruleslines[num][0])
         if rulestxt == '': return
