[GRASS-SVN] r33362 - in grass/trunk/gui/wxpython: gui_modules vdigit
Tue Sep 9 19:12:23 EDT 2008
Author: martinl
Date: 2008-09-09 19:12:23 -0400 (Tue, 09 Sep 2008)
New Revision: 33362
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/vdigit.py
   grass/trunk/gui/wxpython/vdigit/cats.cpp
   grass/trunk/gui/wxpython/vdigit/driver.h
   grass/trunk/gui/wxpython/vdigit/driver_draw.cpp
   grass/trunk/gui/wxpython/vdigit/driver_select.cpp
wxGUI/vdigit: category dialog can handle duplicated features
(merge from devbr6, r33359, r33360, r33361)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-09-09 23:10:57 UTC (rev 33361)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-09-09 23:12:23 UTC (rev 33362)
@@ -1251,21 +1251,31 @@
                     if self.parent.dialogs['category'] is None:
                         # open new dialog
                         if digitClass.type == 'vedit':
-                            self.parent.dialogs['category'] = VDigitCategoryDialog(parent=self,
-        map=map,
-        query=(coords, qdist),
-        pos=posWindow,
-        title=_("Update categories"))
+                            dlg = VDigitCategoryDialog(parent=self,
+                                                        map=map,
+                                                        query=(coords, qdist),
+                                                        pos=posWindow,
+                                                        title=_("Update categories"))
+                            self.parent.dialogs['category'] = dlg
                         else:
                             if digitClass.driver.SelectLineByPoint(coords,
        digitClass.GetSelectType()) is not None:
-        map=map,
-        cats=digitClass.GetLineCats(),
-        line=digitClass.driver.GetSelected()[0],
-        pos=posWindow,
+                                if UserSettings.Get(group='vdigit', key='checkForDupl',
+                                                    subkey='enabled'):
+                                    lines = digitClass.driver.GetSelected()
+                                else:
+                                    lines = (digitClass.driver.GetSelected()[0],) # only first found
+                                cats = {}
+                                for line in lines:
+                                    cats[line] = digitClass.GetLineCats(line)
+                                                           map=map,
+                                                           cats=cats,
+                                                           pos=posWindow,
                     else:
                         # update currently open dialog
@@ -1275,19 +1285,27 @@
                             digitClass.driver.SetSelected([])
                             # select new feature
-        digitClass.GetSelectType()) is None:
+        digitClass.GetSelectType()):
+                                else:
+                                cats = {}
+                                # upgrade dialog
+                                self.parent.dialogs['category'].UpdateDialog(cats=cats)
+                            else:
                                 line = None
-                            else:
-                                line = digitClass.driver.GetSelected()[0]
-                            # upgrade dialog
-                            self.parent.dialogs['category'].UpdateDialog(cats=digitClass.GetLineCats(),
-        line=line)
                     if self.parent.dialogs['category']:
                         line = self.parent.dialogs['category'].GetLine()
                         if line:
                             # highlight feature & re-draw map
-                            digitClass.driver.SetSelected([line])
+                            ### digitClass.driver.SetSelected(line)
                             if not self.parent.dialogs['category'].IsShown():
                                 self.parent.dialogs['category'].Show()
                         else:
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py	2008-09-09 23:10:57 UTC (rev 33361)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py	2008-09-09 23:12:23 UTC (rev 33362)
@@ -1486,7 +1486,7 @@
         @param cats if True expect categories instead of feature ids
         Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
-                  ",".join(["%d" % v for v in id]))
+                      id)
         self.__display.SetSelected(id, cats)
@@ -2279,14 +2279,13 @@
     @param parent
     @param title dialog title
-    @param query {coordinates, qdist}    - v.edit/v.what
-    @param cats  directory of categories - vdigit
-    @param line  line id                 - vdigit
+    @param query {coordinates, qdist} - used by v.edit/v.what
+    @param cats  directory of lines (layer/categories) - used by vdigit
     @param pos
     @param style
     def __init__(self, parent, title,
-                 map, query=None, cats=None, line=None,
+                 map, query=None, cats=None,
                  pos=wx.DefaultPosition,
                  style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
@@ -2296,30 +2295,29 @@
         # map name
         self.map = map
-        # line id (if not found remains 'None')
-        self.line = None
-        # {layer: [categories]}
+        # line : {layer: [categories]}
         self.cats = {}
         # do not display dialog if no line is found (-> self.cats)
         if cats is None:
             if self.__GetCategories(query[0], query[1]) == 0 or not self.line:
                 Debug.msg(3, "VDigitCategoryDialog(): nothing found!")
         else:
-            # self.cats = dict(cats)
-            for layer in cats.keys():
-                self.cats[layer] = list(cats[layer]) # TODO: tuple to list
-            self.line = line
-            Debug.msg(3, "VDigitCategoryDialog(): line=%d, cats=%s" % \
-                          (self.line, self.cats))
+            self.cats = cats
+            for line in cats.keys():
+                for layer in cats[line].keys():
+                    self.cats[line][layer] = list(cats[line][layer])
+            layers = []
+            for layer in self.parent.parent.digit.GetLayers():
+                layers.append(str(layer))
         # make copy of cats (used for 'reload')
         self.cats_orig = copy.deepcopy(self.cats)
         wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY, title=title,
-                           style=style, pos=pos)
+                          style=style, pos=pos)
         # list of categories
         box = wx.StaticBox(parent=self, id=wx.ID_ANY,
                            label=" %s " % _("List of categories - right-click to delete"))
@@ -2331,9 +2329,24 @@
                                      wx.LC_HRULES |
                                      wx.LC_VRULES)
         # sorter
-        self.itemDataMap = self.list.Populate()
+        self.fid = self.cats.keys()[0]
+        self.itemDataMap = self.list.Populate(self.cats[self.fid])
         listmix.ColumnSorterMixin.__init__(self, 2)
+        self.fidMulti = wx.Choice(parent=self, id=wx.ID_ANY,
+                                  size=(150, -1))
+        self.fidMulti.Bind(wx.EVT_CHOICE, self.OnFeature)
+        self.fidText = wx.StaticText(parent=self, id=wx.ID_ANY)
+        if len(self.cats.keys()) == 1:
+            self.fidMulti.Show(False)
+            self.fidText.SetLabel(str(self.fid))
+        else:
+            self.fidText.Show(False)
+            choices = []
+            for fid in self.cats.keys():
+                choices.append(str(fid))
+            self.fidMulti.SetItems(choices)
+            self.fidMulti.SetSelection(0)
         listSizer.Add(item=self.list, proportion=1, flag=wx.EXPAND)
         # add new category
@@ -2345,16 +2358,20 @@
         layerNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
                                  label="%s:" % _("Layer"))
-        self.layerNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(50, -1),
-                                    initial=1, min=1, max=1e9)
+        self.layerNew = wx.Choice(parent=self, id=wx.ID_ANY, size=(75, -1),
+                                  choices=layers)
+        if len(layers) > 0:
+            self.layerNew.SetSelection(0)
         catNewTxt = wx.StaticText(parent=self, id=wx.ID_ANY,
                                label="%s:" % _("Category"))
         try:
-            newCat = max(self.cats[1]) + 1
-        except:
+            newCat = max(self.cats[self.fid][1]) + 1
+        except KeyError:
             newCat = 1
         self.catNew = wx.SpinCtrl(parent=self, id=wx.ID_ANY, size=(75, -1),
-                                  initial=newCat, min=-1e9, max=1e9)
+                                  initial=newCat, min=0, max=1e9)
         btnAddCat = wx.Button(self, wx.ID_ADD)
         flexSizer.Add(item=layerNewTxt, proportion=0,
                       flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
@@ -2393,9 +2410,20 @@
         mainSizer.Add(item=addSizer, proportion=0,
                       flag=wx.EXPAND | wx.ALIGN_CENTER |
                       wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
+        fidSizer = wx.BoxSizer(wx.HORIZONTAL)
+        fidSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY,
+                                        label=_("Feature id:")),
+                     proportion=0, border=5,
+                     flag=wx.ALIGN_CENTER_VERTICAL)
+        fidSizer.Add(item=self.fidMulti, proportion=0,
+                     flag=wx.EXPAND | wx.ALL,  border=5)
+        fidSizer.Add(item=self.fidText, proportion=0,
+        mainSizer.Add(item=fidSizer, proportion=0,
         mainSizer.Add(item=btnSizer, proportion=0,
                       flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
         self.SetSizer(mainSizer)
         mainSizer.Fit(self)
         self.SetAutoLayout(True)
@@ -2410,7 +2438,7 @@
         btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
         btnAddCat.Bind(wx.EVT_BUTTON, self.OnAddCat)
         btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
         # list
         # self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected, self.list)
         # self.list.Bind(wx.EVT_RIGHT_DOWN, self.OnRightDown)
@@ -2510,7 +2538,7 @@
             layer = int (self.list.GetItem(item, 0).GetText())
             cat = int (self.list.GetItem(item, 1).GetText())
             self.list.DeleteItem(item)
-            self.cats[layer].remove(cat)
+            self.cats[self.fid][layer].remove(cat)
             item = self.list.GetFirstSelected()
@@ -2519,10 +2547,26 @@
     def OnItemDeleteAll(self, event):
         """Delete all items from the list"""
         self.list.DeleteAllItems()
-        self.cats = {}
+        self.cats[self.fid] = {}
         event.Skip()
+    def OnFeature(self, event):
+        """Feature id changed (on duplicates)"""
+        self.fid = int(event.GetString())
+        self.itemDataMap = self.list.Populate(self.cats[self.fid],
+                                              update=True)
+        try:
+        except KeyError:
+            newCat = 1
+        self.catNew.SetValue(newCat)
+        event.Skip()
     def __GetCategories(self, coords, qdist):
         """Get layer/category pairs for all available
         layers
@@ -2558,7 +2602,8 @@
         self.cats = copy.deepcopy(self.cats_orig)
         # polulate list
-        self.itemDataMap = self.list.Populate(update=True)
+                                              update=True)
         event.Skip()
@@ -2575,18 +2620,28 @@
     def OnApply(self, event):
         """Apply button pressed"""
+            newfid = self.ApplyChanges(fid)
+            if fid == self.fid:
+                self.fid = newfid
+    def ApplyChanges(self, fid):
+        cats = self.cats[fid]
+        cats_orig = self.cats_orig[fid]
         # action : (catsFrom, catsTo)
-        check = {'catadd': (self.cats,      self.cats_orig),
-                 'catdel': (self.cats_orig, self.cats)}
+        check = {'catadd': (cats,      cats_orig),
+                 'catdel': (cats_orig, cats)}
+        newfid = -1
         # add/delete new category
-        for action, cats in check.iteritems():
-            for layer in cats[0].keys():
+        for action, catsCurr in check.iteritems():
+            for layer in catsCurr[0].keys():
                 catList = []
-                for cat in cats[0][layer]:
-                    if layer not in cats[1].keys() or \
-                            cat not in cats[1][layer]:
+                for cat in catsCurr[0][layer]:
+                    if layer not in catsCurr[1].keys() or \
+                            cat not in catsCurr[1][layer]:
                         catList.append(cat)
                 if catList != []:
                     if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
@@ -2603,19 +2658,32 @@
                             add = True
                         else:
                             add = False
-                        self.line = self.parent.parent.digit.SetLineCats(-1, layer,
-        catList, add)
-                        if self.line < 0:
+                        newfid = self.parent.parent.digit.SetLineCats(fid, layer,
+        catList, add)
+                            self.fidText.SetLabel("%d" % newfid)
+                        else:
+                            choices = self.fidMulti.GetItems()
+                            choices[choices.index(str(fid))] = str(newfid)
+                            self.fidMulti.SetStringSelection(str(newfid))
+                        self.cats[newfid] = self.cats[fid]
+                        del self.cats[fid]
+                        fid = newfid
+                        if self.fid < 0:
                             wx.MessageBox(parent=self, message=_("Unable to update vector map."),
                                           caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
             # reload map (needed for v.edit)
             self.parent.parent.digit.driver.ReloadMap()
-        self.cats_orig = copy.deepcopy(self.cats)
+        self.cats_orig[fid] = copy.deepcopy(cats)
+        return newfid
-        event.Skip()
     def OnOK(self, event):
         """OK button pressed"""
         self.OnApply(event)
@@ -2624,7 +2692,7 @@
     def OnAddCat(self, event):
         """Button 'Add' new category pressed"""
         try:
-            layer = int(self.layerNew.GetValue())
+            layer = int(self.layerNew.GetStringSelection())
             cat   = int(self.catNew.GetValue())
             if layer <= 0:
                 raise ValueError
@@ -2639,13 +2707,14 @@
             dlg.Destroy()
             return False
-        if layer not in self.cats.keys():
-            self.cats[layer] = []
+        if layer not in self.cats[self.fid].keys():
+            self.cats[self.fid][layer] = []
-        self.cats[layer].append(cat)
+        self.cats[self.fid][layer].append(cat)
         # reload list
+                                              update=True)
         # update category number for add
         self.catNew.SetValue(cat + 1)
@@ -2656,32 +2725,27 @@
     def GetLine(self):
         """Get id of selected line of 'None' if no line is selected"""
-        return self.line
+        return self.cats.keys()
-    def UpdateDialog(self, query=None, cats=None, line=None):
+    def UpdateDialog(self, query=None, cats=None):
         """Update dialog
         @param query {coordinates, distance} - v.edit/v.what
         @param cats  directory layer/cats    - vdigit
         Return True if updated otherwise False
-        self.line = None
+        # line: {layer: [categories]}
         self.cats = {}
         if cats is None:
             ret = self.__GetCategories(query[0], query[1])
         else:
-            self.line = line
+            self.cats = cats
             ret = 1
-        if ret == 0 or not self.line:
+        if ret == 0 or len(self.cats.keys()) < 1:
             return False
@@ -2689,14 +2753,31 @@
         # polulate list
+                                              update=True)
         try:
-        except:
+        except KeyError:
             newCat = 1
+            self.fidText.Show(True)
+            self.fidText.SetLabel("%d" % self.fid)
+        else:
+            self.fidMulti.Show(True)
+            choices = []
+        self.Layout()
         return True
 class CategoryListCtrl(wx.ListCtrl,
@@ -2714,7 +2795,7 @@
         listmix.ListCtrlAutoWidthMixin.__init__(self)
         listmix.TextEditMixin.__init__(self)
-    def Populate(self, update=False):
+    def Populate(self, cats, update=False):
         """Populate the list"""
         itemData = {} # requested by sorter
@@ -2726,8 +2807,8 @@
             self.DeleteAllItems()
         i = 1
-        for layer in self.parent.cats.keys():
-            catsList = self.parent.cats[layer]
+        for layer in cats.keys():
+            catsList = cats[layer]
             for cat in catsList:
                 index = self.InsertStringItem(sys.maxint, str(catsList[0]))
                 self.SetStringItem(index, 0, str(layer))
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp	2008-09-09 23:10:57 UTC (rev 33361)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp	2008-09-09 23:12:23 UTC (rev 33362)
@@ -229,10 +229,12 @@
 	return -1;
-    line = -1;
     if (line_id == -1) {
 	line = display->selected.values->value[0];
+    else {
+	line = line_id;
     if (!Vect_line_alive(display->mapInfo, line)) {
 	DeadLineMsg(line);
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h	2008-09-09 23:10:57 UTC (rev 33361)
+++ grass/trunk/gui/wxpython/vdigit/driver.h	2008-09-09 23:12:23 UTC (rev 33362)
@@ -174,7 +174,7 @@
     std::vector<int> GetSelected(bool);
     std::map<int, std::vector <int> > GetDuplicates();
-    std::vector<int> GetRegionSelected();
+    std::vector<double> GetRegionSelected();
     int SetSelected(std::vector<int>, bool);
     int UnSelect(std::vector<int>);
     std::vector<int> GetSelectedVertex(double, double, double);
Modified: grass/trunk/gui/wxpython/vdigit/driver_draw.cpp
--- grass/trunk/gui/wxpython/vdigit/driver_draw.cpp	2008-09-09 23:10:57 UTC (rev 33361)
+++ grass/trunk/gui/wxpython/vdigit/driver_draw.cpp	2008-09-09 23:12:23 UTC (rev 33362)
@@ -64,7 +64,8 @@
 	wxBrush *fillArea, *fillAreaSelected, *fillIsle;
-	fillArea = new wxBrush(settings.area.color);
+	// fillArea = new wxBrush(settings.area.color);
+	fillArea = new wxBrush(wxColour(100,100,100,0));
 	fillAreaSelected = new wxBrush(settings.highlight);
 	fillIsle = new wxBrush(*wxWHITE_BRUSH);
Modified: grass/trunk/gui/wxpython/vdigit/driver_select.cpp
--- grass/trunk/gui/wxpython/vdigit/driver_select.cpp	2008-09-09 23:10:57 UTC (rev 33361)
+++ grass/trunk/gui/wxpython/vdigit/driver_select.cpp	2008-09-09 23:12:23 UTC (rev 33362)
@@ -112,27 +112,31 @@
 std::vector<double> DisplayDriver::SelectLineByPoint(double x, double y, double z,
 						     double thresh, int type, int with_z)
-    long int line;
+  long int line, line_nearest;
     double px, py, pz;
     std::vector<double> p;
+    struct ilist *found;
+    found = Vect_new_list();
     drawSelected = true;
     selected.isId = true;
-    line = Vect_find_line(mapInfo, x, y, z,
-			  type, thresh, with_z, 0);
+    line_nearest = Vect_find_line_list(mapInfo, x, y, z,
+				       type, thresh, with_z,
+				       NULL, found);
-    if (line > 0) {
-	if (!IsSelected(line)) {
-	    Vect_list_append(selected.values, line);
+    if (line_nearest > 0) {
+	if (!IsSelected(line_nearest)) {
+	    Vect_list_append(selected.values, line_nearest);
 	else {
-	    Vect_list_delete(selected.values, line);
+	    Vect_list_delete(selected.values, line_nearest);
-	type = Vect_read_line (mapInfo, points, cats, line);
+	type = Vect_read_line (mapInfo, points, cats, line_nearest);
 	Vect_line_distance (points, x, y, z, with_z,
 			    &px, &py, &pz,
 			    NULL, NULL, NULL);
@@ -141,8 +145,29 @@
 	if (with_z) {
 	    p.push_back(pz);
+	/* check for duplicates */
+	if (settings.highlightDupl.enabled) {
+	    for (int i = 0; i < found->n_values; i++) {
+		line = found->value[i];
+		if (line != line_nearest) {
+		    Vect_list_append(selected.values, found->value[i]);
+	    GetDuplicates();
+		if (line != line_nearest && !IsDuplicated(line)) {
+		    Vect_list_delete(selected.values, line);
+    Vect_destroy_list(found);
     drawSegments = true;
     return p;
@@ -413,11 +438,11 @@
   \return n,s,w,e
-std::vector<int> DisplayDriver::GetRegionSelected()
+std::vector<double> DisplayDriver::GetRegionSelected()
     int line, area, nareas;
-    std::vector<int> region;
+    std::vector<double> region;
     BOUND_BOX region_box, line_box;
     struct ilist *list, *list_tmp;
