[GRASS-SVN] r33379 -
grass/branches/develbranch_6/raster/wildfire/r.spread
svn_grass at osgeo.org
Wed Sep 10 07:37:31 EDT 2008
Author: hamish
Date: 2008-09-10 07:37:31 -0400 (Wed, 10 Sep 2008)
New Revision: 33379
grass/branches/develbranch_6/raster/wildfire/r.spread/main.c
simplify G_fatal_error()
Modified: grass/branches/develbranch_6/raster/wildfire/r.spread/main.c
--- grass/branches/develbranch_6/raster/wildfire/r.spread/main.c 2008-09-10 11:11:39 UTC (rev 33378)
+++ grass/branches/develbranch_6/raster/wildfire/r.spread/main.c 2008-09-10 11:37:31 UTC (rev 33379)
@@ -334,11 +334,8 @@
/* Get database window parameters */
- if (G_get_window(&window) < 0) {
- sprintf(buf, "can't read current window parameters");
- G_fatal_error(buf);
- exit(EXIT_FAILURE);
+ if (G_get_window(&window) < 0)
+ G_fatal_error(_("Unable to read current window parameters"));
/* find number of rows and columns in window */
@@ -355,139 +352,86 @@
display_init();
/* Check if input layers exists in data base */
+ if (G_find_cell2(max_layer, "") == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), max_layer);
- if (G_find_cell2(max_layer, "") == NULL) {
- sprintf(buf, "Raster map <%s> not found", max_layer);
+ if (G_find_cell2(dir_layer, "") == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), dir_layer);
- if (G_find_cell2(dir_layer, "") == NULL) {
- sprintf(buf, _("Raster map <%s> not found"), dir_layer);
+ if (G_find_cell2(base_layer, "") == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), base_layer);
- if (G_find_cell2(base_layer, "") == NULL) {
- sprintf(buf, _("Raster map <%s> not found"), base_layer);
+ if (G_find_cell2(start_layer, "") == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), start_layer);
- if (G_find_cell2(start_layer, "") == NULL) {
- sprintf(buf, _("Raster map <%s> not found"), start_layer);
if (spotting) {
- if (G_find_cell2(spotdist_layer, "") == NULL) {
- sprintf(buf, _("Raster map <%s> not found"), spotdist_layer);
- if (G_find_cell2(velocity_layer, "") == NULL) {
- sprintf(buf, _("Raster map <%s> not found"), velocity_layer);
- if (G_find_cell2(mois_layer, "") == NULL) {
- sprintf(buf, _("Raster map <%s> not found"), mois_layer);
+ if (G_find_cell2(spotdist_layer, "") == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), spotdist_layer);
+ if (G_find_cell2(velocity_layer, "") == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), velocity_layer);
+ if (G_find_cell2(mois_layer, "") == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), mois_layer);
/* Check if specified output layer names ARE LEGAL or EXISTS */
+ if (G_legal_filename(out_layer) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), out_layer);
- if (G_legal_filename(out_layer) < 0) {
- sprintf(buf, _("<%s> is an illegal file name"), out_layer);
- if (G_find_cell2(out_layer, G_mapset())) {
- sprintf(buf,
- _("Raster map <%s> already exists in mapset <%s>, select another name"),
+ if (G_find_cell2(out_layer, G_mapset()))
+ G_fatal_error(
+ _("Raster map <%s> already exists in mapset <%s>, select another name"),
out_layer, G_mapset());
if (x_out) {
- if (G_legal_filename(x_out_layer) < 0) {
- sprintf(buf, _("<%s> is an illegal file name"), x_out_layer);
- if (G_find_cell2(x_out_layer, G_mapset())) {
- sprintf(buf,
+ if (G_legal_filename(x_out_layer) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), x_out_layer);
+ if (G_find_cell2(x_out_layer, G_mapset()))
+ G_fatal_error(
x_out_layer, G_mapset());
if (y_out) {
- if (G_legal_filename(y_out_layer) < 0) {
- sprintf(buf, _("<%s> is an illegal file name"), y_out_layer);
- if (G_find_cell2(y_out_layer, G_mapset())) {
- sprintf(buf,
+ if (G_legal_filename(y_out_layer) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), y_out_layer);
+ if (G_find_cell2(y_out_layer, G_mapset()))
+ G_fatal_error(
y_out_layer, G_mapset());
/* Open input cell layers for reading */
max_fd = G_open_cell_old(max_layer, G_find_cell2(max_layer, ""));
- if (max_fd < 0) {
- sprintf(buf, _("Unable to open raster map <%s>"), max_layer);
+ if (max_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), max_layer);
dir_fd = G_open_cell_old(dir_layer, G_find_cell2(dir_layer, ""));
- if (dir_fd < 0) {
- sprintf(buf, _("Unable to open raster map <%s>"), dir_layer);
+ if (dir_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), dir_layer);
base_fd = G_open_cell_old(base_layer, G_find_cell2(base_layer, ""));
- if (base_fd < 0) {
- sprintf(buf, _("Unable to open raster map <%s>"), base_layer);
+ if (base_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), base_layer);
if (spotting) {
spotdist_fd =
G_open_cell_old(spotdist_layer, G_find_cell2(spotdist_layer, ""));
- if (spotdist_fd < 0) {
- sprintf(buf, _("Unable to open raster map <%s>"), spotdist_layer);
+ if (spotdist_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), spotdist_layer);
velocity_fd =
G_open_cell_old(velocity_layer, G_find_cell2(velocity_layer, ""));
- if (velocity_fd < 0) {
- sprintf(buf, _("Unable to open raster map <%s>"), velocity_layer);
+ if (velocity_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), velocity_layer);
mois_fd = G_open_cell_old(mois_layer, G_find_cell2(mois_layer, ""));
- if (mois_fd < 0) {
- sprintf(buf, _("Unable to open raster map <%s>"), mois_layer);
+ if (mois_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), mois_layer);
/* Allocate memories for a row */
@@ -555,12 +499,10 @@
start_fd = G_open_cell_old(start_layer, G_find_cell2(start_layer, ""));
- if (start_fd < 0) {
- sprintf(buf, _("Unable to open raster map <%s>"), start_layer);
+ if (start_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), start_layer);
G_read_range(start_layer, G_find_file("cell", start_layer, ""), &range);
G_get_range_min_max(&range, &range_min, &range_max);
