[GRASS-SVN] r33383 - grass/branches/develbranch_6/scripts/r.in.wms
svn_grass at osgeo.org
Wed Sep 10 09:07:55 EDT 2008
Author: hamish
Date: 2008-09-10 09:07:54 -0400 (Wed, 10 Sep 2008)
New Revision: 33383
grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
grass/branches/develbranch_6/scripts/r.in.wms/wms.download
bugfix: missing ?; check if r.in.gdalwarp worked
Modified: grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
--- grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2008-09-10 12:27:17 UTC (rev 33382)
+++ grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2008-09-10 13:07:54 UTC (rev 33383)
@@ -368,13 +368,13 @@
if [ "$GIS_FLAG_G" -eq 1 ] ; then
g.message -v message=""
if [ "$USE_WGET" ] ; then
- wget $GIS_OPT_WGETOPTIONS "${GIS_OPT_MAPSERVER}${STRING}" \
+ wget $GIS_OPT_WGETOPTIONS "${GIS_OPT_MAPSERVER}?${STRING}" \
-O "$CAPABILITIES_FILE";
- message 1 "wget $GIS_OPT_WGETOPTIONS \"${GIS_OPT_MAPSERVER}${STRING}\" -O \"$CAPABILITIES_FILE\";"
+ message 1 "wget $GIS_OPT_WGETOPTIONS \"${GIS_OPT_MAPSERVER}?${STRING}\" -O \"$CAPABILITIES_FILE\";"
else
curl $GIS_OPT_CURLOPTIONS -o "$CAPABILITIES_FILE" \
- "${GIS_OPT_MAPSERVER}${STRING}"
- message 1 "curl $GIS_OPT_CURLOPTIONS -o \"$CAPABILITIES_FILE\" \"${GIS_OPT_MAPSERVER}${STRING}\""
+ "${GIS_OPT_MAPSERVER}?${STRING}"
+ message 1 "curl $GIS_OPT_CURLOPTIONS -o \"$CAPABILITIES_FILE\" \"${GIS_OPT_MAPSERVER}?${STRING}\""
fi
fi
@@ -560,6 +560,9 @@
message 1 "r.in.gdalwarp $GDALWARP"
eval "r.in.gdalwarp $GDALWARP"
+if [ $? -ne 0 ] ; then
+ exit 1
+fi
r.support map="$GIS_OPT_OUTPUT" title="WMS Download" history="" \
source1=`echo "$GIS_OPT_MAPSERVER" | cut -c-70` \
Modified: grass/branches/develbranch_6/scripts/r.in.wms/wms.download
--- grass/branches/develbranch_6/scripts/r.in.wms/wms.download 2008-09-10 12:27:17 UTC (rev 33382)
+++ grass/branches/develbranch_6/scripts/r.in.wms/wms.download 2008-09-10 13:07:54 UTC (rev 33383)
@@ -185,9 +185,9 @@
if [ "$POST_DATA_OK" -eq 0 ] ; then
- wget ${WGET_OPTIONS} "${SERVER}${STRING}" -O "${OUTPUT_FILE}"
+ wget ${WGET_OPTIONS} "${SERVER}?${STRING}" -O "${OUTPUT_FILE}"
else
- curl ${CURL_OPTIONS} -o "${OUTPUT_FILE}" "${SERVER}${STRING}"
+ curl ${CURL_OPTIONS} -o "${OUTPUT_FILE}" "${SERVER}?${STRING}"
fi
g.message -e "Failed while downloading the data"
