[GRASS-SVN] r33387 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Sep 10 11:28:11 EDT 2008
Author: martinl
Date: 2008-09-10 11:28:10 -0400 (Wed, 10 Sep 2008)
New Revision: 33387
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
wxGUI: fix display attributes dialog to display duplicated features
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-09-10 15:12:46 UTC (rev 33386)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-09-10 15:28:10 UTC (rev 33387)
@@ -2732,10 +2732,10 @@
self.action = action
# ids/cats of selected features
- self.line = {}
- self.line['id'] = None
- self.line['cats'] = None
+ # fid : {layer : cats}
+ self.cats = {}
+ self.fid = -1 # feature id
# get layer/table/column information
self.mapDBInfo = VectorDBInfo(self.map)
@@ -2769,8 +2769,17 @@
label=_("Close dialog on submit"))
self.closeDialog.SetValue(True)
- self.UpdateDialog(query=query, cats=cats, line=line)
+ # feature id (text/choice for duplicates)
+ self.fidMulti = wx.Choice(parent=self, id=wx.ID_ANY,
+ size=(150, -1))
+ self.fidMulti.Bind(wx.EVT_CHOICE, self.OnFeature)
+ self.fidText = wx.StaticText(parent=self, id=wx.ID_ANY)
+ self.noFoundMsg = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label=_("No attributes found"))
+ self.UpdateDialog(query=query, cats=cats)
# set title
if self.action == "update":
self.SetTitle(_("Update attributes"))
@@ -2792,7 +2801,21 @@
btnSizer.AddButton(btnSubmit)
btnSizer.Realize()
- mainSizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+ mainSizer.Add(item=self.noFoundMsg, proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=5)
+ mainSizer.Add(item=self.notebook, proportion=1,
+ fidSizer = wx.BoxSizer(wx.HORIZONTAL)
+ fidSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY,
+ label=_("Feature id:")),
+ proportion=0, border=5,
+ flag=wx.ALIGN_CENTER_VERTICAL)
+ fidSizer.Add(item=self.fidMulti, proportion=0,
+ fidSizer.Add(item=self.fidText, proportion=0,
+ mainSizer.Add(item=fidSizer, proportion=0,
+ flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
mainSizer.Add(item=self.closeDialog, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT,
border=5)
mainSizer.Add(item=btnSizer, proportion=0,
@@ -2943,17 +2966,25 @@
if self.closeDialog.IsChecked():
self.OnCancel(event)
- def GetLine(self, id=True):
+ def OnFeature(self, event):
+ self.fid = int(event.GetString())
+ self.UpdateDialog(cats=self.cats, fid=self.fid)
+ def GetCats(self):
"""Get id of selected vector object or 'None' if nothing selected
@param id if true return ids otherwise cats
- if id:
- return self.line['id']
+ if self.fid < 0:
+ return None
+ return self.cats[self.fid]
- return self.line['cats']
- def UpdateDialog(self, map=None, query=None, cats=None, line=None):
+ def GetFid(self):
+ """Get selected feature id"""
+ return self.fid
+ def UpdateDialog(self, map=None, query=None, cats=None, fid=-1):
"""Update dialog
Return True if updated otherwise False
@@ -2962,9 +2993,6 @@
self.map = map
- self.line['id'] = (line, )
- self.line['cats'] = cats
if not self.mapDBInfo:
return False
@@ -2977,36 +3005,53 @@
if query: # select by position
data = self.mapDBInfo.SelectByPoint(query[0],
query[1])
+ self.cats = {}
if data and data.has_key('Layer'):
- self.line['id'] = (-1,)
- self.line['cats'] = {}
idx = 0
- for l in data['Layer']:
- layer = int(l)
- if not self.line['cats'].has_key(layer):
- self.line['cats'][layer] = []
- self.line['cats'][layer].append(int(data['Category'][idx]))
+ for layer in data['Layer']:
+ layer = int(layer)
+ tfid = int(data['Id'][idx])
+ if not self.cats.has_key(tfid):
+ self.cats[tfid] = {}
+ if not self.cats[tfid].has_key(layer):
+ self.cats[tfid][layer] = []
+ cat = int(data['Category'][idx])
+ self.cats[tfid][layer].append(cat)
idx += 1
- nselected = len(self.line['cats'].keys())
- else:
- nselected = 0
+ else:
+ self.cats = cats
+ if fid > 0:
+ self.fid = fid
+ elif len(self.cats.keys()) > 0:
+ self.fid = self.cats.keys()[0]
+ else:
+ self.fid = -1
+ if len(self.cats.keys()) == 1:
+ self.fidMulti.Show(False)
+ self.fidText.Show(True)
+ self.fidText.SetLabel("%d" % self.fid)
+ else:
+ self.fidMulti.Show(True)
+ self.fidText.Show(False)
+ choices = []
+ for tfid in self.cats.keys():
+ choices.append(str(tfid))
+ self.fidMulti.SetItems(choices)
+ self.fidMulti.SetStringSelection(str(self.fid))
# reset notebook
self.notebook.DeleteAllPages()
for layer in layers: # for each layer
if not query: # select by layer/cat
- if cats.has_key(layer):
- for cat in cats[layer]:
+ if self.fid > 0 and self.cats[self.fid].has_key(layer):
+ for cat in self.cats[self.fid][layer]:
nselected = self.mapDBInfo.SelectFromTable(layer,
where="%s=%d" % \
- (self.mapDBInfo.layers[layer]['key'],
- cat))
+ (self.mapDBInfo.layers[layer]['key'],
+ cat))
else:
nselected = 0
@@ -3015,13 +3060,13 @@
if self.action == "add":
if nselected <= 0:
+ if self.cats[self.fid].has_key(layer):
table = self.mapDBInfo.layers[layer]["table"]
key = self.mapDBInfo.layers[layer]["key"]
columns = self.mapDBInfo.tables[table]
for name in columns.keys():
if name == key:
self.mapDBInfo.tables[table][name]['values'].append(cat)
else:
self.mapDBInfo.tables[table][name]['values'].append(None)
@@ -3031,23 +3076,7 @@
- # value
- # if len(columns[key]['values']) == 0: # no cats
- # self.notebook.AddPage(page=panel, text=" %s %d / %s %d" % (_("Layer"), layer,
- # _("Category"), cat))
- # sizer = wx.BoxSizer(wx.VERTICAL)
- # txt = wx.StaticText(parent=panel, id=wx.ID_ANY,
- # label=_("No database record available."))
- # sizer.Add(txt, proportion=1,
- # flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER | wx.EXPAND)
- # border.Add(item=sizer, proportion=1,
- # flag=wx.ALL | wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
- # border=10)
- # panel.SetSizer(border)
- # continue
for idx in range(len(columns[key]['values'])):
if name == key:
@@ -3108,17 +3137,15 @@
# for each category END
# for each layer END
+ if self.notebook.GetPageCount() == 0:
+ self.noFoundMsg.Show(True)
+ else:
+ self.noFoundMsg.Show(False)
self.Layout()
return True
- def IsFound(self):
- """Check if attributes found"""
- if self.notebook.GetPageCount() > 0:
- return True
- return False
class VectorDBInfo(gselect.VectorDBInfo):
"""Class providing information about attribute tables
linked to the vector map"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-09-10 15:12:46 UTC (rev 33386)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-09-10 15:28:10 UTC (rev 33387)
@@ -1201,48 +1201,49 @@
elif digitToolbar.GetAction() in ["displayAttrs", "displayCats"]:
qdist = digitClass.driver.GetThreshold(type='selectThresh')
coords = (east, north)
+ if digitClass.type == 'vdigit':
+ # unselect
+ digitClass.driver.SetSelected([])
+ # select feature by point
+ cats = {}
+ if digitClass.driver.SelectLineByPoint(coords,
+ digitClass.GetSelectType()) is not None:
+ if UserSettings.Get(group='vdigit', key='checkForDupl',
+ subkey='enabled'):
+ lines = digitClass.driver.GetSelected()
+ else:
+ lines = (digitClass.driver.GetSelected()[0],) # only first found
+ for line in lines:
+ cats[line] = digitClass.GetLineCats(line)
if digitToolbar.GetAction() == "displayAttrs":
# select attributes based on coordinates (all layers)
if self.parent.dialogs['attributes'] is None:
if digitClass.type == 'vedit':
self.parent.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self, map=map,
- query=(coords, qdist),
- pos=posWindow,
- action="update")
+ query=(coords, qdist),
+ pos=posWindow,
+ action="update")
else:
- if digitClass.driver.SelectLineByPoint(coords,
- digitClass.GetSelectType()) is not None:
- self.parent.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self, map=map,
- cats=digitClass.GetLineCats(),
- line=digitClass.driver.GetSelected()[0],
- action="update")
+ self.parent.dialogs['attributes'] = dbm.DisplayAttributesDialog(parent=self, map=map,
+ cats=cats,
+ action="update")
else:
# update currently open dialog
self.parent.dialogs['attributes'].UpdateDialog(query=(coords, qdist))
else:
- # unselect
- digitClass.driver.SetSelected([])
- # select new feature
- digitClass.GetSelectType()) is None:
- line = None
- else:
- line = digitClass.driver.GetSelected()[0]
# upgrade dialog
- self.parent.dialogs['attributes'].UpdateDialog(cats=digitClass.GetLineCats(),
- line=line)
+ self.parent.dialogs['attributes'].UpdateDialog(cats=cats)
if self.parent.dialogs['attributes']:
- if self.parent.dialogs['attributes'].IsFound():
+ if len(cats.keys()) > 0:
# highlight feature & re-draw map
- line = self.parent.dialogs['attributes'].GetLine()
- digitClass.driver.SetSelected(line)
if not self.parent.dialogs['attributes'].IsShown():
self.parent.dialogs['attributes'].Show()
else:
if self.parent.dialogs['attributes'] and \
self.parent.dialogs['attributes'].Hide()
@@ -1258,61 +1259,30 @@
title=_("Update categories"))
self.parent.dialogs['category'] = dlg
else:
- if UserSettings.Get(group='vdigit', key='checkForDupl',
- subkey='enabled'):
- lines = digitClass.driver.GetSelected()
- else:
- lines = (digitClass.driver.GetSelected()[0],) # only first found
- cats = {}
- for line in lines:
- cats[line] = digitClass.GetLineCats(line)
- dlg = VDigitCategoryDialog(parent=self,
- map=map,
- cats=cats,
- pos=posWindow,
- title=_("Update categories"))
- self.parent.dialogs['category'] = dlg
+ dlg = VDigitCategoryDialog(parent=self,
+ map=map,
+ cats=cats,
+ pos=posWindow,
+ title=_("Update categories"))
+ self.parent.dialogs['category'] = dlg
else:
self.parent.dialogs['category'].UpdateDialog(query=(coords, qdist))
else:
- # unselect
- digitClass.GetSelectType()):
- else:
- cats = {}
- # upgrade dialog
- self.parent.dialogs['category'].UpdateDialog(cats=cats)
- else:
- line = None
+ # upgrade dialog
+ self.parent.dialogs['category'].UpdateDialog(cats=cats)
if self.parent.dialogs['category']:
- line = self.parent.dialogs['category'].GetLine()
- if line:
### digitClass.driver.SetSelected(line)
if not self.parent.dialogs['category'].IsShown():
self.parent.dialogs['category'].Show()
else:
if self.parent.dialogs['category'].IsShown():
self.parent.dialogs['category'].Hide()
self.UpdateMap(render=False)
elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
@@ -3459,7 +3429,7 @@
else:
self.dialogs['attributes'].UpdateDialog(query=((east, north), qdist))
- cats = self.dialogs['attributes'].GetLine(id=False)
+ cats = self.dialogs['attributes'].GetCats()
try:
qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)[0]
except IndexError:
@@ -3475,7 +3445,6 @@
self.AddTmpVectorMapLayer(mapName, cats, useId=False)
self.MapWindow.UpdateMap(render=False, renderVector=False)
- # digitClass.driver.SetSelected([line])
if not self.dialogs['attributes'].IsShown():
self.dialogs['attributes'].Show()
else:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-09-10 15:12:46 UTC (rev 33386)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-09-10 15:28:10 UTC (rev 33387)
@@ -2474,7 +2474,7 @@
catNew = int(event.GetLabel())
try:
- if layerNew not in self.cats.keys():
+ if layerNew not in self.cats[self.fid].keys():
self.cats[layerNew] = []
self.cats[layerNew].append(catNew)
self.cats[layerOld].remove(catOld)
@@ -2485,7 +2485,7 @@
dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
"Layer and category number must be integer.\n"
"Layer number must be greater then zero.") %
- { 'layer': str(self.layerNew.GetValue()),
+ { 'layer': self.layerNew.GetStringSelection(),
'category' : str(self.catNew.GetValue()) },
_("Error"), wx.OK | wx.ICON_ERROR)
dlg.ShowModal()
