[GRASS-SVN] r33397 - grass/trunk/include
svn_grass at osgeo.org
Thu Sep 11 02:11:26 EDT 2008
Author: glynn
Date: 2008-09-11 02:11:22 -0400 (Thu, 11 Sep 2008)
New Revision: 33397
grass/trunk/include/gisdefs.h
Remove declarations for non-existent LZW functions
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2008-09-11 05:05:28 UTC (rev 33396)
+++ grass/trunk/include/gisdefs.h 2008-09-11 06:11:22 UTC (rev 33397)
@@ -711,24 +711,6 @@
int G_ludcmp(double **, int, int *, double *);
void G_lubksb(double **, int, int *, double[]);
-/* lzw.c */
-unsigned char *lzw_decode(unsigned char *, unsigned int);
-int lzw_expand(int (*)(), int (*)());
-int G_lzw_nof_read_bytes(void);
-int G_lzw_max_used_bits(void);
-void G_lzw_set_bits(int);
-int G_lzw_compress(unsigned char *, unsigned char *, int);
-int G_lzw_expand(unsigned char *, unsigned char *, int);
-int G_lzw_compress_count_only_array(unsigned char *, int);
-int G_lzw_compress_count_only_file(int);
-int G_lzw_write(int, unsigned char *, int);
-int G_lzw_write_noCompress(int, unsigned char *, int);
-int G_lzw_test_status(int);
-int G_lzw_read2(int, unsigned char *, int, int);
-int G_lzw_read(int, unsigned char *, int);
-int G_lzw_transfer_compress(int, int, int);
-int G_lzw_transfer_expand(int, int, int);
/* mach_name.c */
char *G__machine_name(void);
