[GRASS-SVN] r33399 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Thu Sep 11 02:46:24 EDT 2008
Author: martinl
Date: 2008-09-11 02:46:24 -0400 (Thu, 11 Sep 2008)
New Revision: 33399
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI: attribute dialog fixes
vdigit: start with category 1
(merge from devbr6, r33398)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-09-11 06:36:13 UTC (rev 33398)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-09-11 06:46:24 UTC (rev 33399)
@@ -3189,7 +3189,10 @@
name, value = item.split(':')
name = name.strip()
# append value to the column
- value = self.tables[table][name]['ctype'] (value.strip())
+ if len(value) < 1:
+ value = None
+ else:
+ value = self.tables[table][name]['ctype'] (value.strip())
self.tables[table][name]['values'].append(value)
else:
if not data.has_key(key):
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-09-11 06:36:13 UTC (rev 33398)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-09-11 06:46:24 UTC (rev 33399)
@@ -1140,7 +1140,8 @@
else:
point = False
- if digitClass.AddPoint(map, point, east, north) < 0:
+ fid = digitClass.AddPoint(map, point, east, north)
+ if fid < 0:
return
self.UpdateMap(render=False) # redraw map
@@ -1148,9 +1149,10 @@
# add new record into atribute table
if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') is True:
# select attributes based on layer and category
- cats = {}
- cats[UserSettings.Get(group='vdigit', key="layer", subkey='value')] = \
- (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
+ cats = { fid : {
+ UserSettings.Get(group='vdigit', key="layer", subkey='value') :
+ (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
addRecordDlg = dbm.DisplayAttributesDialog(parent=self, map=map,
cats=cats,
pos=posWindow,
@@ -1763,7 +1765,8 @@
if len(self.polycoords) < 2: # ignore 'one-point' lines
return
- if digitClass.AddLine(map, line, self.polycoords) < 0:
+ fid = digitClass.AddLine(map, line, self.polycoords)
+ if fid < 0:
return
position = self.Cell2Pixel(self.polycoords[-1])
@@ -1776,9 +1779,11 @@
position[1] + self.dialogOffset))
- cats = {}
+ cats = { fid : {
cats=cats,
pos=posWindow,
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-11 06:36:13 UTC (rev 33398)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-11 06:46:24 UTC (rev 33399)
@@ -124,8 +124,9 @@
return True
else:
cat = self.digit.GetCategory(UserSettings.Get(group='vdigit', key='layer', subkey='value'))
+ cat += 1
UserSettings.Set(group='vdigit', key='category', subkey='value',
- value=cat + 1)
+ value=cat)
def SetCategory(self):
"""Return category number to use (according Settings)"""
@@ -820,7 +821,7 @@
else:
layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
cat = self.SetCategory()
if point:
type = wxvdigit.GV_POINT
else:
@@ -1281,9 +1282,12 @@
if units is None:
units = UserSettings.Get(group='vdigit', key=type, subkey='units')
+ reg = self.mapwindow.Map.region
+ if value < 0:
+ value = (reg['nsres'] + reg['ewres']) / 2.
if units == "screen pixels":
# pixel -> cell
- reg = self.mapwindow.Map.region
if reg['nsres'] > reg['ewres']:
res = reg['nsres']
else:
@@ -1740,6 +1744,7 @@
initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
min=-1, max=1e6)
self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
+ self.snappingValue.Bind(wx.EVT_TEXT, self.OnChangeSnappingValue)
self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
choices=["screen pixels", "map units"])
self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
@@ -2103,7 +2108,7 @@
self.snappingInfo.SetLabel(_("Snapping disabled"))
elif value < 0:
self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s "
- "(based on computation resolution)") %
+ "(based on comp. resolution)") %
{'value' : threshold,
'units' : self.mapUnits.lower()})
else:
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-09-11 06:36:13 UTC (rev 33398)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-09-11 06:46:24 UTC (rev 33399)
@@ -75,7 +75,7 @@
for(std::map<int, int>::const_iterator b = cats.begin(), e = cats.end();
b != e; ++b ) {
if (b->second == PORT_INT_MIN) {
- cats[b->first] = 0;
+ cats[b->first] = 0; /* first category 1 */
G_debug(3, "wxDigit.InitCats(): layer=%d, cat=%d", b->first, cats[b->first]);
@@ -89,7 +89,7 @@
\param layer layer number
- \return category number (1 if no category found)
+ \return category number (0 if no category found)
\return -1 on error
int Digit::GetCategory(int layer)
@@ -99,7 +99,7 @@
return cats[layer];
- return -1;
+ return 0;
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-09-11 06:36:13 UTC (rev 33398)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-09-11 06:46:24 UTC (rev 33399)
@@ -32,7 +32,7 @@
\param snap snapping mode (see vedit.h)
\param thresh threshold value for snapping
- \return 0 on success
+ \return fid on success
\return -1 on failure
int Digit::AddLine(int type, std::vector<double> coords, int layer, int cat,
@@ -148,7 +148,7 @@
Vect_close(BgMap[0]);
- return 0;
+ return newline;
