[GRASS-SVN] r33420 - in grass/branches/develbranch_6: . general
include include/Make
svn_grass at osgeo.org
Sat Sep 13 02:01:33 EDT 2008
Author: neteler
Date: 2008-09-13 02:01:33 -0400 (Sat, 13 Sep 2008)
New Revision: 33420
grass/branches/develbranch_6/aclocal.m4
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
grass/branches/develbranch_6/general/Makefile
grass/branches/develbranch_6/include/Make/Platform.make.in
grass/branches/develbranch_6/include/config.h.in
glynn: Add configure checks for regex functions; Enable g.mlist, g.mremove, Use basic REs by default; add -e for extended REs (merge from trunk, r33268, r33305)
Modified: grass/branches/develbranch_6/aclocal.m4
--- grass/branches/develbranch_6/aclocal.m4 2008-09-13 06:01:12 UTC (rev 33419)
+++ grass/branches/develbranch_6/aclocal.m4 2008-09-13 06:01:33 UTC (rev 33420)
@@ -50,6 +50,24 @@
fi
+AC_DEFUN([LOC_CHECK_FRAMEWORK_PATH],[
+AC_MSG_CHECKING(for location of $2 framework)
+case "$with_$1_framework" in
+y | ye | yes | n | no)
+ AC_MSG_ERROR([*** You must supply a directory to --with-$1-framework.])
+esac
+AC_MSG_RESULT($with_$1_framework)
+if test -n "$with_$1_framework"; then
+ if test -d $with_$1_framework; then
+ $3="$$3 -F$with_$1_framework"
+ else
+ AC_MSG_ERROR([*** $2 framework directory $dir does not exist.])
+ fi
+fi
AC_DEFUN([LOC_CHECK_SHARE_PATH],[
AC_MSG_CHECKING(for location of $2 data files)
case "$with_$1_share" in
@@ -68,6 +86,17 @@
fi
+AC_DEFUN([LOC_CHECK_LDFLAGS],[
+AC_MSG_CHECKING(for $2 linking flags)
+case "$with_$1_ldflags" in
+ AC_MSG_ERROR([*** You must supply a directory to --with-$1-ldflags.])
+esac
+AC_MSG_RESULT($with_$1_ldflags)
+$3="$$3 $with_$1_ldflags"
AC_DEFUN([LOC_CHECK_INCLUDES],[
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$3 $CPPFLAGS"
@@ -151,6 +180,36 @@
LDFLAGS=${ac_save_ldflags}
+dnl $1 = function
+dnl $2 = descriptive name
+dnl $3 = result variable
+dnl $4 = LIBS initialiser (added to $3)
+dnl $5 = LDFLAGS initialiser (not added to $3)
+dnl $6 = LIBS initialiser (not added to $3)
+dnl $7 = ACTION-IF-FOUND
+dnl $8 = ACTION-IF-NOT-FOUND
+define(LOC_CHECK_FUNC,[
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS="$4 $6 $LIBS"
+LDFLAGS="$5 $LDFLAGS"
+AC_CHECK_FUNC($1,[
+ifelse($7,[],[
+ $3="$$3 $4"
+],$7)
+ifelse($8,[],[
+ifelse($2,[],
+ [AC_MSG_ERROR([*** Unable to locate $2.])],
+ [AC_MSG_ERROR([*** Unable to locate $1.])]
+],$8)
+LIBS=${ac_save_libs}
+LDFLAGS=${ac_save_ldflags}
AC_DEFUN([LOC_CHECK_VERSION_STRING],[
AC_MSG_CHECKING($3 version)
@@ -220,11 +279,21 @@
LOC_PAD([ --with-$1-libs=DIRS])[$2 library files are in DIRS])
+AC_DEFUN([LOC_ARG_WITH_LDFLAGS],[
+AC_ARG_WITH($1-ldflags,
+LOC_PAD([ --with-$1-ldflags=FLAGS])[$2 needs FLAGS when linking])
AC_DEFUN([LOC_ARG_WITH_SHARE],[
AC_ARG_WITH($1-share,
LOC_PAD([ --with-$1-share=DIR])[$2 data files are in DIR])
+AC_DEFUN([LOC_ARG_WITH_FRAMEWORK],[
+AC_ARG_WITH($1-framework,
+LOC_PAD([ --with-$1-framework=DIR])[$2 framework is in DIR])
AC_DEFUN([LOC_OPTIONAL],[
AC_MSG_CHECKING(whether to build $1)
if test -n "$USE_$2" ; then
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2008-09-13 06:01:12 UTC (rev 33419)
+++ grass/branches/develbranch_6/configure 2008-09-13 06:01:33 UTC (rev 33420)
@@ -67,6 +67,8 @@
ac_help="$ac_help
--with-curses support Curses functionality (default: yes)"
ac_help="$ac_help
+ --with-regex support regex functionality (default: yes)"
+ac_help="$ac_help
--with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
ac_help="$ac_help
@@ -186,6 +188,11 @@
--with-opendwg-libs=DIRS
openDWG library files are in DIRS"
ac_help="$ac_help
+ --with-regex-includes=DIRS
+ regex include files are in DIRS"
+ac_help="$ac_help
+ --with-regex-libs=DIRS regex library files are in DIRS"
+ac_help="$ac_help
--with-x use the X Window System"
ac_help="$ac_help
--enable-largefile enable support for large files (LFS)"
@@ -721,7 +728,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:725: checking host system type" >&5
+echo "configure:732: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -744,7 +751,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:748: checking for $ac_word" >&5
+echo "configure:755: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -771,7 +778,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:775: checking for $ac_word" >&5
+echo "configure:782: checking for $ac_word" >&5
@@ -819,7 +826,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:823: checking for $ac_word" >&5
+echo "configure:830: checking for $ac_word" >&5
@@ -848,7 +855,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:852: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:859: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -859,12 +866,12 @@
cat > conftest.$ac_ext << EOF
-#line 863 "configure"
+#line 870 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -890,19 +897,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:894: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:901: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:899: checking whether we are using GNU C" >&5
+echo "configure:906: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:906: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -920,7 +927,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:924: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:931: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -949,10 +956,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:953: checking for Cygwin environment" >&5
+echo "configure:960: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 956 "configure"
+#line 963 "configure"
int main() {
@@ -963,7 +970,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:967: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:974: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -979,17 +986,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:983: checking for mingw32 environment" >&5
+echo "configure:990: checking for mingw32 environment" >&5
-#line 986 "configure"
+#line 993 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:993: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1000: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1007,7 +1014,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1011: checking for executable suffix" >&5
+echo "configure:1018: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1026,23 +1033,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1030: checking for full floating-point support" >&5
+echo "configure:1037: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1035: checking whether "cc -mieee" works" >&5
+echo "configure:1042: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1039 "configure"
+#line 1046 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1046: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1058,7 +1065,7 @@
else
-#line 1062 "configure"
+#line 1069 "configure"
#include <float.h>
@@ -1072,7 +1079,7 @@
EOF
-if { (eval echo configure:1076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1085,14 +1092,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1089: checking for full floating-point support with -mieee" >&5
+echo "configure:1096: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1096 "configure"
+#line 1103 "configure"
#include <float.h>
@@ -1106,7 +1113,7 @@
EOF
-if { (eval echo configure:1110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1143,7 +1150,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1147: checking for $ac_word" >&5
+echo "configure:1154: checking for $ac_word" >&5
case "$pwd" in
@@ -1181,7 +1188,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1185: checking for source directory" >&5
+echo "configure:1192: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1192,7 +1199,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1196: checking for build directory" >&5
+echo "configure:1203: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1277,7 +1284,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1281: checking for MacOSX App" >&5
+echo "configure:1288: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1300,7 +1307,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1304: checking how to build libraries" >&5
+echo "configure:1311: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1343,7 +1350,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1347: checking for $ac_word" >&5
+echo "configure:1354: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1368,7 +1375,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1372: checking how to run the C preprocessor" >&5
+echo "configure:1379: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1381,13 +1388,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1385 "configure"
+#line 1392 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1398,13 +1405,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1402 "configure"
+#line 1409 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1408: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1415: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1415,13 +1422,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1419 "configure"
+#line 1426 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1425: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1449,7 +1456,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1453: checking if 64bit support is requested" >&5
+echo "configure:1460: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1469,7 +1476,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1473: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1480: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1493,7 +1500,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1497: checking system version (for dynamic loading)" >&5
+echo "configure:1504: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1519,13 +1526,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1523: checking for dlopen in -ldl" >&5
+echo "configure:1530: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1529 "configure"
+#line 1536 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1536,7 +1543,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1583,7 +1590,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1587: checking for $ac_word" >&5
+echo "configure:1594: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1712,13 +1719,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1716: checking for gettimeofday in -lbsd" >&5
+echo "configure:1723: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1722 "configure"
+#line 1729 "configure"
@@ -1729,7 +1736,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1770,13 +1777,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1774: checking for inet_ntoa in -lbind" >&5
+echo "configure:1781: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1780 "configure"
+#line 1787 "configure"
@@ -1787,7 +1794,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1848,13 +1855,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1852: checking for shl_load in -ldld" >&5
+echo "configure:1859: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1858 "configure"
+#line 1865 "configure"
@@ -1865,7 +1872,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1930,13 +1937,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1934: checking for shl_load in -ldld" >&5
+echo "configure:1941: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1940 "configure"
+#line 1947 "configure"
@@ -1947,7 +1954,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2069,15 +2076,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2073: checking for dld.h" >&5
+echo "configure:2080: checking for dld.h" >&5
-#line 2076 "configure"
+#line 2083 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2081: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2137,15 +2144,15 @@
else
-echo "configure:2141: checking for dld.h" >&5
+echo "configure:2148: checking for dld.h" >&5
-#line 2144 "configure"
+#line 2151 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2156: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2242,9 +2249,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2246: checking for ELF" >&5
+echo "configure:2253: checking for ELF" >&5
-#line 2248 "configure"
+#line 2255 "configure"
#ifdef __ELF__
@@ -2274,15 +2281,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2278: checking for dlfcn.h" >&5
+echo "configure:2285: checking for dlfcn.h" >&5
-#line 2281 "configure"
+#line 2288 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2286: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2306,9 +2313,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2310: checking for ELF" >&5
+echo "configure:2317: checking for ELF" >&5
-#line 2312 "configure"
+#line 2319 "configure"
#ifdef __ELF__
@@ -2632,17 +2639,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2636: checking for ld accepts -Bexport flag" >&5
+echo "configure:2643: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2639 "configure"
+#line 2646 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -2990,6 +2997,16 @@
fi
+# Check whether --with-regex or --without-regex was given.
+if test "${with_regex+set}" = set; then
+ withval="$with_regex"
+else
+ with_regex=yes
+fi
# Check whether --with-python or --without-python was given.
if test "${with_python+set}" = set; then
withval="$with_python"
@@ -3378,6 +3395,23 @@
+# Check whether --with-regex-includes or --without-regex-includes was given.
+if test "${with_regex_includes+set}" = set; then
+ withval="$with_regex_includes"
+fi
+# Check whether --with-regex-libs or --without-regex-libs was given.
+if test "${with_regex_libs+set}" = set; then
+ withval="$with_regex_libs"
+fi
# Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
# With includes option
@@ -3387,7 +3421,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3391: checking for additional include dirs" >&5
+echo "configure:3425: checking for additional include dirs" >&5
case "$with_includes" in
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3410,7 +3444,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3414: checking for additional library dirs" >&5
+echo "configure:3448: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3444,7 +3478,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3448: checking for a BSD compatible install" >&5
+echo "configure:3482: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3497,7 +3531,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3501: checking for $ac_word" >&5
+echo "configure:3535: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3528,13 +3562,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3532: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3566: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3538 "configure"
+#line 3572 "configure"
@@ -3545,7 +3579,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3570,7 +3604,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3574: checking for $ac_word" >&5
+echo "configure:3608: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3610,7 +3644,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3614: checking for $ac_word" >&5
+echo "configure:3648: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3641,7 +3675,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3645: checking for $ac_word" >&5
+echo "configure:3679: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3679,7 +3713,7 @@
-echo "configure:3683: checking for $ac_word" >&5
+echo "configure:3717: checking for $ac_word" >&5
@@ -3708,7 +3742,7 @@
-echo "configure:3712: checking for $ac_word" >&5
+echo "configure:3746: checking for $ac_word" >&5
@@ -3739,7 +3773,7 @@
-echo "configure:3743: checking for $ac_word" >&5
+echo "configure:3777: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3768,7 +3802,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3772: checking for $ac_word" >&5
+echo "configure:3806: checking for $ac_word" >&5
case "$PERL" in
@@ -3799,10 +3833,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3803: checking for ANSI C header files" >&5
+echo "configure:3837: checking for ANSI C header files" >&5
-#line 3806 "configure"
+#line 3840 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3810,7 +3844,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3848: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3827,7 +3861,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3831 "configure"
+#line 3865 "configure"
#include <string.h>
EOF
@@ -3845,7 +3879,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3849 "configure"
+#line 3883 "configure"
#include <stdlib.h>
EOF
@@ -3866,7 +3900,7 @@
else
-#line 3870 "configure"
+#line 3904 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3877,7 +3911,7 @@
exit (0); }
EOF
-if { (eval echo configure:3881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3904,15 +3938,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3908: checking for $ac_hdr" >&5
+echo "configure:3942: checking for $ac_hdr" >&5
-#line 3911 "configure"
+#line 3945 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3950: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3941,15 +3975,15 @@
do
-echo "configure:3945: checking for $ac_hdr" >&5
+echo "configure:3979: checking for $ac_hdr" >&5
-#line 3948 "configure"
+#line 3982 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3953: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3978,15 +4012,15 @@
do
-echo "configure:3982: checking for $ac_hdr" >&5
+echo "configure:4016: checking for $ac_hdr" >&5
-#line 3985 "configure"
+#line 4019 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4015,15 +4049,15 @@
do
-echo "configure:4019: checking for $ac_hdr" >&5
+echo "configure:4053: checking for $ac_hdr" >&5
-#line 4022 "configure"
+#line 4056 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4052,15 +4086,15 @@
do
-echo "configure:4056: checking for $ac_hdr" >&5
+echo "configure:4090: checking for $ac_hdr" >&5
-#line 4059 "configure"
+#line 4093 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4086,10 +4120,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4090: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4124: checking whether time.h and sys/time.h may both be included" >&5
-#line 4093 "configure"
+#line 4127 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4098,7 +4132,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4136: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4118,10 +4152,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4122: checking for off_t" >&5
+echo "configure:4156: checking for off_t" >&5
-#line 4125 "configure"
+#line 4159 "configure"
#if STDC_HEADERS
@@ -4148,10 +4182,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4152: checking for uid_t in sys/types.h" >&5
+echo "configure:4186: checking for uid_t in sys/types.h" >&5
-#line 4155 "configure"
+#line 4189 "configure"
EOF
@@ -4179,10 +4213,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4183: checking return type of signal handlers" >&5
+echo "configure:4217: checking return type of signal handlers" >&5
-#line 4186 "configure"
+#line 4220 "configure"
#include <signal.h>
@@ -4199,7 +4233,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4203: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4237: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4217,10 +4251,10 @@
-echo "configure:4221: checking for Cygwin environment" >&5
+echo "configure:4255: checking for Cygwin environment" >&5
-#line 4224 "configure"
+#line 4258 "configure"
int main() {
@@ -4231,7 +4265,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4269: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4249,10 +4283,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4253: checking for $ac_func" >&5
+echo "configure:4287: checking for $ac_func" >&5
-#line 4256 "configure"
+#line 4290 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4275,7 +4309,7 @@
; return 0; }
EOF
-if { (eval echo configure:4279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4301,10 +4335,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4305: checking for $ac_func" >&5
+echo "configure:4339: checking for $ac_func" >&5
-#line 4308 "configure"
+#line 4342 "configure"
@@ -4327,7 +4361,7 @@
; return 0; }
EOF
-if { (eval echo configure:4331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4353,10 +4387,10 @@
for ac_func in drand48
do
-echo "configure:4357: checking for $ac_func" >&5
+echo "configure:4391: checking for $ac_func" >&5
-#line 4360 "configure"
+#line 4394 "configure"
@@ -4379,7 +4413,7 @@
; return 0; }
EOF
-if { (eval echo configure:4383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4405,10 +4439,10 @@
for ac_func in putenv setenv
do
-echo "configure:4409: checking for $ac_func" >&5
+echo "configure:4443: checking for $ac_func" >&5
-#line 4412 "configure"
+#line 4446 "configure"
@@ -4431,7 +4465,7 @@
; return 0; }
EOF
-if { (eval echo configure:4435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4457,10 +4491,10 @@
for ac_func in nanosleep
do
-echo "configure:4461: checking for $ac_func" >&5
+echo "configure:4495: checking for $ac_func" >&5
-#line 4464 "configure"
+#line 4498 "configure"
@@ -4483,7 +4517,7 @@
; return 0; }
EOF
-if { (eval echo configure:4487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4508,13 +4542,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4512: checking whether setpgrp takes no argument" >&5
+echo "configure:4546: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4518 "configure"
+#line 4552 "configure"
#ifdef HAVE_UNISTD_H
@@ -4534,7 +4568,7 @@
EOF
-if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4562,16 +4596,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4566: checking for long long int" >&5
+echo "configure:4600: checking for long long int" >&5
-#line 4568 "configure"
+#line 4602 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4575: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4609: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4591,7 +4625,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4595: checking for W11" >&5
+echo "configure:4629: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4619,7 +4653,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4623: checking for X" >&5
+echo "configure:4657: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4679,12 +4713,12 @@
# First, try using that file with no special directory specified.
-#line 4683 "configure"
+#line 4717 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4753,14 +4787,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4757 "configure"
+#line 4791 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4865,17 +4899,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4869: checking whether -R must be followed by a space" >&5
+echo "configure:4903: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4872 "configure"
+#line 4906 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4891,14 +4925,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4895 "configure"
+#line 4929 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4930,13 +4964,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4934: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4968: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4940 "configure"
+#line 4974 "configure"
@@ -4947,7 +4981,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4968,13 +5002,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4972: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5006: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4978 "configure"
+#line 5012 "configure"
@@ -4985,7 +5019,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5013,10 +5047,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5017: checking for gethostbyname" >&5
+echo "configure:5051: checking for gethostbyname" >&5
-#line 5020 "configure"
+#line 5054 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5039,7 +5073,7 @@
; return 0; }
EOF
-if { (eval echo configure:5043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5059,13 +5093,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5063: checking for gethostbyname in -lnsl" >&5
+echo "configure:5097: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5069 "configure"
+#line 5103 "configure"
@@ -5076,7 +5110,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5105,10 +5139,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5109: checking for connect" >&5
+echo "configure:5143: checking for connect" >&5
-#line 5112 "configure"
+#line 5146 "configure"
which can conflict with char connect(); below. */
@@ -5131,7 +5165,7 @@
; return 0; }
EOF
-if { (eval echo configure:5135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5151,13 +5185,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5155: checking for connect in -lsocket" >&5
+echo "configure:5189: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5161 "configure"
+#line 5195 "configure"
@@ -5168,7 +5202,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5191,10 +5225,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5195: checking for remove" >&5
+echo "configure:5229: checking for remove" >&5
-#line 5198 "configure"
+#line 5232 "configure"
which can conflict with char remove(); below. */
@@ -5217,7 +5251,7 @@
; return 0; }
EOF
-if { (eval echo configure:5221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5237,13 +5271,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5241: checking for remove in -lposix" >&5
+echo "configure:5275: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5247 "configure"
+#line 5281 "configure"
@@ -5254,7 +5288,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5277,10 +5311,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5281: checking for shmat" >&5
+echo "configure:5315: checking for shmat" >&5
-#line 5284 "configure"
+#line 5318 "configure"
which can conflict with char shmat(); below. */
@@ -5303,7 +5337,7 @@
; return 0; }
EOF
-if { (eval echo configure:5307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5323,13 +5357,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5327: checking for shmat in -lipc" >&5
+echo "configure:5361: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5333 "configure"
+#line 5367 "configure"
@@ -5340,7 +5374,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5372,13 +5406,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5376: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5410: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5382 "configure"
+#line 5416 "configure"
@@ -5389,7 +5423,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5427,7 +5461,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5431: checking whether to use Curses" >&5
+echo "configure:5465: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5446,15 +5480,15 @@
do
-echo "configure:5450: checking for $ac_hdr" >&5
+echo "configure:5484: checking for $ac_hdr" >&5
-#line 5453 "configure"
+#line 5487 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5485,10 +5519,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5489: checking curses.h WINDOW structure component" >&5
+echo "configure:5523: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5492 "configure"
+#line 5526 "configure"
#include <curses.h>
@@ -5497,7 +5531,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5535: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5506,7 +5540,7 @@
fi
rm -f conftest*
-#line 5510 "configure"
+#line 5544 "configure"
#include <curses.h>
@@ -5515,7 +5549,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5519: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5553: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5531,13 +5565,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5535: checking for initscr in -lncurses" >&5
+echo "configure:5569: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5541 "configure"
+#line 5575 "configure"
@@ -5548,7 +5582,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5567,13 +5601,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5571: checking for initscr in -lcurses" >&5
+echo "configure:5605: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5577 "configure"
+#line 5611 "configure"
@@ -5584,7 +5618,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5613,13 +5647,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5617: checking for keypad in -lncurses" >&5
+echo "configure:5651: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5623 "configure"
+#line 5657 "configure"
@@ -5630,7 +5664,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5652,13 +5686,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5656: checking for keypad in -lcurses" >&5
+echo "configure:5690: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5662 "configure"
+#line 5696 "configure"
@@ -5669,7 +5703,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5699,13 +5733,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5703: checking for gtty in -lcompat" >&5
+echo "configure:5737: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5709 "configure"
+#line 5743 "configure"
@@ -5716,7 +5750,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5735,13 +5769,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5739: checking for gtty in -lbsd-compat" >&5
+echo "configure:5773: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5745 "configure"
+#line 5779 "configure"
@@ -5752,7 +5786,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5771,13 +5805,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5775: checking for gtty in -lbsd" >&5
+echo "configure:5809: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5781 "configure"
+#line 5815 "configure"
@@ -5788,7 +5822,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5822,12 +5856,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5826: checking for library containing cuserid" >&5
+echo "configure:5860: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5831 "configure"
+#line 5865 "configure"
@@ -5838,7 +5872,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5849,7 +5883,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5853 "configure"
+#line 5887 "configure"
@@ -5860,7 +5894,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5886,10 +5920,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5890: checking for xdrmem_create" >&5
+echo "configure:5924: checking for xdrmem_create" >&5
-#line 5893 "configure"
+#line 5927 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5912,7 +5946,7 @@
; return 0; }
EOF
-if { (eval echo configure:5916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5930,13 +5964,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5934: checking for xdrmem_create in -lsun" >&5
+echo "configure:5968: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5940 "configure"
+#line 5974 "configure"
@@ -5947,7 +5981,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5966,13 +6000,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5970: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6004: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5976 "configure"
+#line 6010 "configure"
@@ -5983,7 +6017,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6002,13 +6036,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6006: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6040: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6012 "configure"
+#line 6046 "configure"
@@ -6019,7 +6053,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6038,13 +6072,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6042: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6076: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6048 "configure"
+#line 6082 "configure"
@@ -6055,7 +6089,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6089,10 +6123,10 @@
for ac_func in asprintf
do
-echo "configure:6093: checking for $ac_func" >&5
+echo "configure:6127: checking for $ac_func" >&5
-#line 6096 "configure"
+#line 6130 "configure"
@@ -6115,7 +6149,7 @@
; return 0; }
EOF
-if { (eval echo configure:6119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6142,10 +6176,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6146: checking for atan" >&5
+echo "configure:6180: checking for atan" >&5
-#line 6149 "configure"
+#line 6183 "configure"
which can conflict with char atan(); below. */
@@ -6168,7 +6202,7 @@
; return 0; }
EOF
-if { (eval echo configure:6172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6186,13 +6220,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6190: checking for atan in -lm" >&5
+echo "configure:6224: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6196 "configure"
+#line 6230 "configure"
@@ -6203,7 +6237,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6230,10 +6264,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6234: checking for dlsym" >&5
+echo "configure:6268: checking for dlsym" >&5
-#line 6237 "configure"
+#line 6271 "configure"
which can conflict with char dlsym(); below. */
@@ -6256,7 +6290,7 @@
; return 0; }
EOF
-if { (eval echo configure:6260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6274,13 +6308,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6278: checking for dlsym in -ldl" >&5
+echo "configure:6312: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6284 "configure"
+#line 6318 "configure"
@@ -6291,7 +6325,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6318,10 +6352,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6322: checking for iconv" >&5
+echo "configure:6356: checking for iconv" >&5
-#line 6325 "configure"
+#line 6359 "configure"
which can conflict with char iconv(); below. */
@@ -6344,7 +6378,7 @@
; return 0; }
EOF
-if { (eval echo configure:6348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6362,13 +6396,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6366: checking for iconv in -liconv" >&5
+echo "configure:6400: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6372 "configure"
+#line 6406 "configure"
@@ -6379,7 +6413,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6398,13 +6432,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6402: checking for iconv in -lgiconv" >&5
+echo "configure:6436: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6408 "configure"
+#line 6442 "configure"
@@ -6415,7 +6449,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6434,10 +6468,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6438: checking for libiconv" >&5
+echo "configure:6472: checking for libiconv" >&5
-#line 6441 "configure"
+#line 6475 "configure"
which can conflict with char libiconv(); below. */
@@ -6460,7 +6494,7 @@
; return 0; }
EOF
-if { (eval echo configure:6464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6478,13 +6512,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6482: checking for libiconv in -liconv" >&5
+echo "configure:6516: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6488 "configure"
+#line 6522 "configure"
@@ -6495,7 +6529,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6514,13 +6548,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6518: checking for libiconv in -lgiconv" >&5
+echo "configure:6552: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6524 "configure"
+#line 6558 "configure"
@@ -6531,7 +6565,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6568,10 +6602,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6572: checking for socket" >&5
+echo "configure:6606: checking for socket" >&5
-#line 6575 "configure"
+#line 6609 "configure"
which can conflict with char socket(); below. */
@@ -6594,7 +6628,7 @@
; return 0; }
EOF
-if { (eval echo configure:6598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6612,13 +6646,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6616: checking for socket in -lsocket" >&5
+echo "configure:6650: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6622 "configure"
+#line 6656 "configure"
@@ -6629,7 +6663,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6677,7 +6711,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6681: checking for location of zlib includes" >&5
+echo "configure:6715: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6703,15 +6737,15 @@
do
-echo "configure:6707: checking for $ac_hdr" >&5
+echo "configure:6741: checking for $ac_hdr" >&5
-#line 6710 "configure"
+#line 6744 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6745,7 +6779,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6749: checking for location of zlib library" >&5
+echo "configure:6783: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6770,13 +6804,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6774: checking for deflate in -lz" >&5
+echo "configure:6808: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6780 "configure"
+#line 6814 "configure"
@@ -6787,7 +6821,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6835,7 +6869,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6839: checking for location of External PROJ.4 includes" >&5
+echo "configure:6873: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6861,15 +6895,15 @@
do
-echo "configure:6865: checking for $ac_hdr" >&5
+echo "configure:6899: checking for $ac_hdr" >&5
-#line 6868 "configure"
+#line 6902 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6907: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6906,7 +6940,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6910: checking External PROJ.4 version" >&5
+echo "configure:6944: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6914,7 +6948,7 @@
else
-#line 6918 "configure"
+#line 6952 "configure"
#include <stdio.h>
@@ -6926,7 +6960,7 @@
EOF
-if { (eval echo configure:6930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6951,7 +6985,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6955: checking for location of External PROJ.4 library" >&5
+echo "configure:6989: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6976,13 +7010,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6980: checking for pj_get_def in -lproj" >&5
+echo "configure:7014: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 6986 "configure"
+#line 7020 "configure"
@@ -6993,7 +7027,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7027,7 +7061,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7031: checking for location of External PROJ.4 data files" >&5
+echo "configure:7065: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7051,14 +7085,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7055: checking for epsg" >&5
+echo "configure:7089: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7062: checking for $PROJSHARE/epsg" >&5
+echo "configure:7096: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7090,7 +7124,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7094: checking for $ac_word" >&5
+echo "configure:7128: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7126,11 +7160,135 @@
# Done checking PROJ
+# Enable regex option
+echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
+echo "configure:7168: checking whether to use regex" >&5
+echo "$ac_t"""$with_regex"" 1>&6
+case "$with_regex" in
+ "no") USE_REGEX= ;;
+ "yes") USE_REGEX="1" ;;
+ *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
+esac
+REGEXINCPATH=
+REGEXLIBPATH=
+REGEXLIB=
+if test -n "$USE_REGEX"; then
+# With regex includes directory
+echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
+echo "configure:7188: checking for location of regex includes" >&5
+case "$with_regex_includes" in
+y | ye | yes | n | no)
+ { echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_regex_includes" 1>&6
+if test -n "$with_regex_includes" ; then
+ for dir in $with_regex_includes; do
+ if test -d "$dir"; then
+ REGEXINCPATH="$REGEXINCPATH -I$dir"
+ else
+ { echo "configure: error: *** regex includes directory $dir does not exist." 1>&2; exit 1; }
+ fi
+ done
+fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$REGEXINCPATH $CPPFLAGS"
+for ac_hdr in regex.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:7214: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 7217 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:7222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=yes"
+else
+ echo "$ac_err" >&5
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+ cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+ echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate regex includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+# With regex library directory
+echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
+echo "configure:7256: checking for location of regex library" >&5
+case "$with_regex_libs" in
+ { echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_regex_libs" 1>&6
+if test -n "$with_regex_libs"; then
+ for dir in $with_regex_libs; do
+ REGEXLIBPATH="$REGEXLIBPATH -L$dir"
+ else
+ { echo "configure: error: *** regex library directory $dir does not exist." 1>&2; exit 1; }
+ fi
+ done
+fi
+LOC_CHECK_FUNC(regcomp,regex functions,REGEXLIB,,,,,
+LOC_CHECK_LIBS(regex,regcomp,regex,$REGEXLIBPATH,REGEXLIB,,,)
+fi # $USE_REGEX
+# Done checking regex
# Enable Readline option
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7134: checking whether to use Readline" >&5
+echo "configure:7292: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7151,7 +7309,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7155: checking for location of Readline includes" >&5
+echo "configure:7313: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7177,15 +7335,15 @@
do
-echo "configure:7181: checking for $ac_hdr" >&5
+echo "configure:7339: checking for $ac_hdr" >&5
-#line 7184 "configure"
+#line 7342 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7189: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7347: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7221,15 +7379,15 @@
do
-echo "configure:7225: checking for $ac_hdr" >&5
+echo "configure:7383: checking for $ac_hdr" >&5
-#line 7228 "configure"
+#line 7386 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7233: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7263,7 +7421,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7267: checking for location of Readline library" >&5
+echo "configure:7425: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7288,13 +7446,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7292: checking for readline in -lreadline" >&5
+echo "configure:7450: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7298 "configure"
+#line 7456 "configure"
@@ -7305,7 +7463,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7340,13 +7498,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7344: checking for add_history in -lhistory" >&5
+echo "configure:7502: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7350 "configure"
+#line 7508 "configure"
@@ -7357,7 +7515,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7400,7 +7558,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7404: checking whether to use JPEG" >&5
+echo "configure:7562: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7420,7 +7578,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7424: checking for location of JPEG includes" >&5
+echo "configure:7582: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7446,15 +7604,15 @@
do
-echo "configure:7450: checking for $ac_hdr" >&5
+echo "configure:7608: checking for $ac_hdr" >&5
-#line 7453 "configure"
+#line 7611 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7488,7 +7646,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7492: checking for location of JPEG library" >&5
+echo "configure:7650: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7515,13 +7673,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7519: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7677: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ljpeg $LIBS"
-#line 7525 "configure"
+#line 7683 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7532,7 +7690,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7551,13 +7709,13 @@
-echo "configure:7555: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7713: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7561 "configure"
+#line 7719 "configure"
@@ -7568,7 +7726,7 @@
; return 0; }
EOF
-if { (eval echo configure:7572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7617,7 +7775,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7621: checking whether to use GDAL" >&5
+echo "configure:7779: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -7635,7 +7793,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:7639: checking for $ac_word" >&5
+echo "configure:7797: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7690,14 +7848,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7694 "configure"
+#line 7852 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -7706,14 +7864,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7710 "configure"
+#line 7868 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7746,7 +7904,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7750: checking whether to use TIFF" >&5
+echo "configure:7908: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7766,7 +7924,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7770: checking for location of TIFF includes" >&5
+echo "configure:7928: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7792,15 +7950,15 @@
do
-echo "configure:7796: checking for $ac_hdr" >&5
+echo "configure:7954: checking for $ac_hdr" >&5
-#line 7799 "configure"
+#line 7957 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7804: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7962: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7834,7 +7992,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7838: checking for location of TIFF library" >&5
+echo "configure:7996: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7865,13 +8023,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7869: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8027: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7875 "configure"
+#line 8033 "configure"
@@ -7882,7 +8040,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7901,13 +8059,13 @@
-echo "configure:7905: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8063: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7911 "configure"
+#line 8069 "configure"
@@ -7918,7 +8076,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7937,13 +8095,13 @@
-echo "configure:7941: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8099: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7947 "configure"
+#line 8105 "configure"
@@ -7954,7 +8112,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7973,13 +8131,13 @@
-echo "configure:7977: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8135: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7983 "configure"
+#line 8141 "configure"
@@ -7990,7 +8148,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8009,13 +8167,13 @@
-echo "configure:8013: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8171: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8019 "configure"
+#line 8177 "configure"
@@ -8026,7 +8184,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8045,13 +8203,13 @@
-echo "configure:8049: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8207: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8055 "configure"
+#line 8213 "configure"
@@ -8062,7 +8220,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8081,13 +8239,13 @@
-echo "configure:8085: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8243: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8091 "configure"
+#line 8249 "configure"
@@ -8098,7 +8256,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8117,13 +8275,13 @@
-echo "configure:8121: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8279: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8127 "configure"
+#line 8285 "configure"
@@ -8134,7 +8292,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8232,7 +8390,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8236: checking whether to use PNG" >&5
+echo "configure:8394: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8251,7 +8409,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8255: checking for location of PNG includes" >&5
+echo "configure:8413: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8277,15 +8435,15 @@
do
-echo "configure:8281: checking for $ac_hdr" >&5
+echo "configure:8439: checking for $ac_hdr" >&5
-#line 8284 "configure"
+#line 8442 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8319,7 +8477,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8323: checking for location of PNG library" >&5
+echo "configure:8481: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8344,13 +8502,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8348: checking for png_read_image in -lpng" >&5
+echo "configure:8506: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8354 "configure"
+#line 8512 "configure"
@@ -8361,7 +8519,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8403,7 +8561,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8407: checking whether to use Tcl/Tk" >&5
+echo "configure:8565: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8423,7 +8581,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8427: checking for location of Tcl/Tk includes" >&5
+echo "configure:8585: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8449,15 +8607,15 @@
do
-echo "configure:8453: checking for $ac_hdr" >&5
+echo "configure:8611: checking for $ac_hdr" >&5
-#line 8456 "configure"
+#line 8614 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8461: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8494,15 +8652,15 @@
do
-echo "configure:8498: checking for $ac_hdr" >&5
+echo "configure:8656: checking for $ac_hdr" >&5
-#line 8501 "configure"
+#line 8659 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8506: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8664: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8536,7 +8694,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8540: checking Tcl version" >&5
+echo "configure:8698: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8544,7 +8702,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8548 "configure"
+#line 8706 "configure"
#include <stdio.h>
@@ -8556,7 +8714,7 @@
EOF
-if { (eval echo configure:8560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8574,7 +8732,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8578: checking Tk version" >&5
+echo "configure:8736: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8582,7 +8740,7 @@
else
-#line 8586 "configure"
+#line 8744 "configure"
#include <stdio.h>
@@ -8594,7 +8752,7 @@
EOF
-if { (eval echo configure:8598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8623,7 +8781,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8627: checking for location of Tcl/Tk library" >&5
+echo "configure:8785: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8653,13 +8811,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8657: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8815: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8663 "configure"
+#line 8821 "configure"
@@ -8670,7 +8828,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8689,13 +8847,13 @@
-echo "configure:8693: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8851: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8699 "configure"
+#line 8857 "configure"
@@ -8706,7 +8864,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8733,13 +8891,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8737: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8895: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8743 "configure"
+#line 8901 "configure"
@@ -8750,7 +8908,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8769,13 +8927,13 @@
-echo "configure:8773: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8931: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8779 "configure"
+#line 8937 "configure"
@@ -8786,7 +8944,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8813,13 +8971,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8817: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8975: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8823 "configure"
+#line 8981 "configure"
@@ -8830,7 +8988,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8849,13 +9007,13 @@
-echo "configure:8853: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9011: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8859 "configure"
+#line 9017 "configure"
@@ -8866,7 +9024,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8944,13 +9102,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8948: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9106: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8954 "configure"
+#line 9112 "configure"
@@ -8961,7 +9119,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8980,13 +9138,13 @@
-echo "configure:8984: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9142: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8990 "configure"
+#line 9148 "configure"
@@ -8997,7 +9155,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9024,13 +9182,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9028: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9186: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9034 "configure"
+#line 9192 "configure"
@@ -9041,7 +9199,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9060,13 +9218,13 @@
-echo "configure:9064: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9222: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9070 "configure"
+#line 9228 "configure"
@@ -9077,7 +9235,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9104,13 +9262,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9108: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9266: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9114 "configure"
+#line 9272 "configure"
@@ -9121,7 +9279,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9140,13 +9298,13 @@
-echo "configure:9144: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9302: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9150 "configure"
+#line 9308 "configure"
@@ -9157,7 +9315,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9249,7 +9407,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9253: checking whether to use PostgreSQL" >&5
+echo "configure:9411: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9276,7 +9434,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9280: checking for location of PostgreSQL includes" >&5
+echo "configure:9438: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9302,15 +9460,15 @@
do
-echo "configure:9306: checking for $ac_hdr" >&5
+echo "configure:9464: checking for $ac_hdr" >&5
-#line 9309 "configure"
+#line 9467 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9314: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9348,7 +9506,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9352: checking for location of PostgreSQL library" >&5
+echo "configure:9510: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9377,13 +9535,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9381: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9539: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9387 "configure"
+#line 9545 "configure"
@@ -9394,7 +9552,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9413,13 +9571,13 @@
-echo "configure:9417: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9575: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9423 "configure"
+#line 9581 "configure"
@@ -9430,7 +9588,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9449,13 +9607,13 @@
-echo "configure:9453: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9611: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9459 "configure"
+#line 9617 "configure"
@@ -9466,7 +9624,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9485,13 +9643,13 @@
-echo "configure:9489: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9647: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9495 "configure"
+#line 9653 "configure"
@@ -9502,7 +9660,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9559,13 +9717,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9563: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9721: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9569 "configure"
+#line 9727 "configure"
@@ -9576,7 +9734,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9598,13 +9756,13 @@
-echo "configure:9602: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9760: checking for PQcmdTuples in -lpq" >&5
-#line 9608 "configure"
+#line 9766 "configure"
@@ -9615,7 +9773,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9658,7 +9816,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9662: checking whether to use MySQL" >&5
+echo "configure:9820: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9678,7 +9836,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9682: checking for location of MySQL includes" >&5
+echo "configure:9840: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9704,15 +9862,15 @@
do
-echo "configure:9708: checking for $ac_hdr" >&5
+echo "configure:9866: checking for $ac_hdr" >&5
-#line 9711 "configure"
+#line 9869 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9716: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9749,7 +9907,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9753: checking for location of MySQL library" >&5
+echo "configure:9911: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9780,13 +9938,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9784: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9942: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9790 "configure"
+#line 9948 "configure"
@@ -9797,7 +9955,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9816,13 +9974,13 @@
-echo "configure:9820: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9978: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9826 "configure"
+#line 9984 "configure"
@@ -9833,7 +9991,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9852,13 +10010,13 @@
-echo "configure:9856: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10014: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9862 "configure"
+#line 10020 "configure"
@@ -9869,7 +10027,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9888,13 +10046,13 @@
-echo "configure:9892: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10050: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9898 "configure"
+#line 10056 "configure"
@@ -9905,7 +10063,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9924,13 +10082,13 @@
-echo "configure:9928: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10086: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9934 "configure"
+#line 10092 "configure"
@@ -9941,7 +10099,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9960,13 +10118,13 @@
-echo "configure:9964: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10122: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9970 "configure"
+#line 10128 "configure"
@@ -9977,7 +10135,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9996,13 +10154,13 @@
-echo "configure:10000: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10158: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10006 "configure"
+#line 10164 "configure"
@@ -10013,7 +10171,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10032,13 +10190,13 @@
-echo "configure:10036: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10194: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10042 "configure"
+#line 10200 "configure"
@@ -10049,7 +10207,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10139,7 +10297,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:10143: checking for $ac_word" >&5
+echo "configure:10301: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10180,10 +10338,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10184: checking for mysql_server_init" >&5
+echo "configure:10342: checking for mysql_server_init" >&5
-#line 10187 "configure"
+#line 10345 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10206,7 +10364,7 @@
; return 0; }
EOF
-if { (eval echo configure:10210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10244,7 +10402,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10248: checking whether to use SQLite" >&5
+echo "configure:10406: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10264,7 +10422,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10268: checking for location of SQLite includes" >&5
+echo "configure:10426: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10290,15 +10448,15 @@
do
-echo "configure:10294: checking for $ac_hdr" >&5
+echo "configure:10452: checking for $ac_hdr" >&5
-#line 10297 "configure"
+#line 10455 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10341,7 +10499,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10345: checking for location of SQLite library" >&5
+echo "configure:10503: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10368,13 +10526,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10372: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10530: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10378 "configure"
+#line 10536 "configure"
@@ -10385,7 +10543,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10404,13 +10562,13 @@
-echo "configure:10408: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10566: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10414 "configure"
+#line 10572 "configure"
@@ -10421,7 +10579,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10474,7 +10632,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10478: checking whether to use FFMPEG" >&5
+echo "configure:10636: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10494,7 +10652,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10498: checking for location of FFMPEG includes" >&5
+echo "configure:10656: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10520,15 +10678,15 @@
do
-echo "configure:10524: checking for $ac_hdr" >&5
+echo "configure:10682: checking for $ac_hdr" >&5
-#line 10527 "configure"
+#line 10685 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10532: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10690: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10564,15 +10722,15 @@
do
-echo "configure:10568: checking for $ac_hdr" >&5
+echo "configure:10726: checking for $ac_hdr" >&5
-#line 10571 "configure"
+#line 10729 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10608,15 +10766,15 @@
do
-echo "configure:10612: checking for $ac_hdr" >&5
+echo "configure:10770: checking for $ac_hdr" >&5
-#line 10615 "configure"
+#line 10773 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10778: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10659,7 +10817,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10663: checking for location of FFMPEG library" >&5
+echo "configure:10821: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10686,13 +10844,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10690: checking for av_free in -lavutil" >&5
+echo "configure:10848: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10696 "configure"
+#line 10854 "configure"
@@ -10703,7 +10861,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10722,13 +10880,13 @@
-echo "configure:10726: checking for av_free in -lavutil" >&5
+echo "configure:10884: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10732 "configure"
+#line 10890 "configure"
@@ -10739,7 +10897,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10784,13 +10942,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10788: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10946: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10794 "configure"
+#line 10952 "configure"
@@ -10801,7 +10959,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10820,13 +10978,13 @@
-echo "configure:10824: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10982: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10830 "configure"
+#line 10988 "configure"
@@ -10837,7 +10995,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10882,13 +11040,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10886: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11044: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10892 "configure"
+#line 11050 "configure"
@@ -10899,7 +11057,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10918,13 +11076,13 @@
-echo "configure:10922: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11080: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10928 "configure"
+#line 11086 "configure"
@@ -10935,7 +11093,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10995,7 +11153,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10999: checking whether to use OpenGL" >&5
+echo "configure:11157: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -11029,7 +11187,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11033: checking for location of OpenGL includes" >&5
+echo "configure:11191: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11055,15 +11213,15 @@
do
-echo "configure:11059: checking for $ac_hdr" >&5
+echo "configure:11217: checking for $ac_hdr" >&5
-#line 11062 "configure"
+#line 11220 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11097,7 +11255,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11101: checking for location of OpenGL library" >&5
+echo "configure:11259: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11126,13 +11284,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11130: checking for glBegin in -lGL" >&5
+echo "configure:11288: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11136 "configure"
+#line 11294 "configure"
@@ -11143,7 +11301,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11162,13 +11320,13 @@
-echo "configure:11166: checking for glBegin in -lGL" >&5
+echo "configure:11324: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11172 "configure"
+#line 11330 "configure"
@@ -11179,7 +11337,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11198,13 +11356,13 @@
-echo "configure:11202: checking for glBegin in -lGL" >&5
+echo "configure:11360: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11208 "configure"
+#line 11366 "configure"
@@ -11215,7 +11373,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11234,13 +11392,13 @@
-echo "configure:11238: checking for glBegin in -lGL" >&5
+echo "configure:11396: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11244 "configure"
+#line 11402 "configure"
@@ -11251,7 +11409,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11313,13 +11471,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11317: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11475: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11323 "configure"
+#line 11481 "configure"
@@ -11330,7 +11488,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11349,13 +11507,13 @@
-echo "configure:11353: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11511: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11359 "configure"
+#line 11517 "configure"
@@ -11366,7 +11524,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11410,10 +11568,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11414: checking for glXCreatePbuffer" >&5
+echo "configure:11572: checking for glXCreatePbuffer" >&5
-#line 11417 "configure"
+#line 11575 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11436,7 +11594,7 @@
; return 0; }
EOF
-if { (eval echo configure:11440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11458,10 +11616,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11462: checking for glXCreateGLXPixmap" >&5
+echo "configure:11620: checking for glXCreateGLXPixmap" >&5
-#line 11465 "configure"
+#line 11623 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11484,7 +11642,7 @@
; return 0; }
EOF
-if { (eval echo configure:11488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11523,7 +11681,7 @@
-echo "configure:11527: checking for location of OpenGL includes" >&5
+echo "configure:11685: checking for location of OpenGL includes" >&5
@@ -11549,15 +11707,15 @@
do
-echo "configure:11553: checking for $ac_hdr" >&5
+echo "configure:11711: checking for $ac_hdr" >&5
-#line 11556 "configure"
+#line 11714 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11561: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11592,10 +11750,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11596: checking for glBegin" >&5
+echo "configure:11754: checking for glBegin" >&5
-#line 11599 "configure"
+#line 11757 "configure"
which can conflict with char glBegin(); below. */
@@ -11618,7 +11776,7 @@
; return 0; }
EOF
-if { (eval echo configure:11622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11633,10 +11791,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11637: checking for gluBeginCurve" >&5
+echo "configure:11795: checking for gluBeginCurve" >&5
-#line 11640 "configure"
+#line 11798 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11659,7 +11817,7 @@
; return 0; }
EOF
-if { (eval echo configure:11663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11703,7 +11861,7 @@
-echo "configure:11707: checking for location of OpenGL includes" >&5
+echo "configure:11865: checking for location of OpenGL includes" >&5
@@ -11729,15 +11887,15 @@
do
-echo "configure:11733: checking for $ac_hdr" >&5
+echo "configure:11891: checking for $ac_hdr" >&5
-#line 11736 "configure"
+#line 11894 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11771,7 +11929,7 @@
-echo "configure:11775: checking for location of OpenGL library" >&5
+echo "configure:11933: checking for location of OpenGL library" >&5
@@ -11796,18 +11954,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11800: checking for OpenGL library" >&5
+echo "configure:11958: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11804 "configure"
+#line 11962 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11831,18 +11989,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11835: checking for GLU library" >&5
+echo "configure:11993: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11839 "configure"
+#line 11997 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11891,7 +12049,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11895: checking whether to use ODBC" >&5
+echo "configure:12053: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11910,7 +12068,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11914: checking for location of ODBC includes" >&5
+echo "configure:12072: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11936,15 +12094,15 @@
do
-echo "configure:11940: checking for $ac_hdr" >&5
+echo "configure:12098: checking for $ac_hdr" >&5
-#line 11943 "configure"
+#line 12101 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11948: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12106: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11978,7 +12136,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11982: checking for location of ODBC library" >&5
+echo "configure:12140: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12003,13 +12161,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12007: checking for SQLConnect in -lodbc" >&5
+echo "configure:12165: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12013 "configure"
+#line 12171 "configure"
@@ -12020,7 +12178,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12045,13 +12203,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12049: checking for SQLConnect in -liodbc" >&5
+echo "configure:12207: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12055 "configure"
+#line 12213 "configure"
@@ -12062,7 +12220,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12087,11 +12245,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12091: checking for ODBC library" >&5
+echo "configure:12249: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
cat > conftest.$ac_ext <<EOF
-#line 12095 "configure"
+#line 12253 "configure"
#include "confdefs.h"
#include <windows.h>
#include <sql.h>
@@ -12099,7 +12257,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12148,7 +12306,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12152: checking whether to use FFTW" >&5
+echo "configure:12310: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12167,7 +12325,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12171: checking for location of FFTW includes" >&5
+echo "configure:12329: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12193,15 +12351,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12197: checking for $ac_hdr" >&5
+echo "configure:12355: checking for $ac_hdr" >&5
-#line 12200 "configure"
+#line 12358 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12205: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12229,15 +12387,15 @@
do
-echo "configure:12233: checking for $ac_hdr" >&5
+echo "configure:12391: checking for $ac_hdr" >&5
-#line 12236 "configure"
+#line 12394 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12399: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12265,15 +12423,15 @@
do
-echo "configure:12269: checking for $ac_hdr" >&5
+echo "configure:12427: checking for $ac_hdr" >&5
-#line 12272 "configure"
+#line 12430 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12277: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12319,7 +12477,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12323: checking for location of FFTW library" >&5
+echo "configure:12481: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12344,13 +12502,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12348: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12506: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12354 "configure"
+#line 12512 "configure"
@@ -12361,7 +12519,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12386,13 +12544,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12390: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12548: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12396 "configure"
+#line 12554 "configure"
@@ -12403,7 +12561,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12428,13 +12586,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12432: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12590: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12438 "configure"
+#line 12596 "configure"
@@ -12445,7 +12603,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12502,7 +12660,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12506: checking whether to use BLAS" >&5
+echo "configure:12664: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12523,7 +12681,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12527: checking for location of BLAS includes" >&5
+echo "configure:12685: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12543,7 +12701,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12547: checking for location of BLAS library" >&5
+echo "configure:12705: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12569,15 +12727,15 @@
do
-echo "configure:12573: checking for $ac_hdr" >&5
+echo "configure:12731: checking for $ac_hdr" >&5
-#line 12576 "configure"
+#line 12734 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12612,13 +12770,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12616: checking for dnrm2_ in -lblas" >&5
+echo "configure:12774: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $MATHLIB $LIBS"
-#line 12622 "configure"
+#line 12780 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12629,7 +12787,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12648,13 +12806,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:12652: checking for dnrm2_ in -lblas" >&5
+echo "configure:12810: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12658 "configure"
+#line 12816 "configure"
@@ -12665,7 +12823,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12709,13 +12867,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12713: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12871: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12719 "configure"
+#line 12877 "configure"
@@ -12726,7 +12884,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12741,13 +12899,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12745: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12903: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12751 "configure"
+#line 12909 "configure"
@@ -12758,7 +12916,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12773,13 +12931,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12777: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12935: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12783 "configure"
+#line 12941 "configure"
@@ -12790,7 +12948,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12835,16 +12993,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12839: checking for sgemm in $vlib_flags" >&5
+echo "configure:12997: checking for sgemm in $vlib_flags" >&5
-#line 12841 "configure"
+#line 12999 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12862,13 +13020,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12866: checking for sgemm_ in -lblas" >&5
+echo "configure:13024: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12872 "configure"
+#line 13030 "configure"
@@ -12879,7 +13037,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12894,13 +13052,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12898: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13056: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12904 "configure"
+#line 13062 "configure"
@@ -12911,7 +13069,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12926,13 +13084,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12930: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13088: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12936 "configure"
+#line 13094 "configure"
@@ -12943,7 +13101,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12977,13 +13135,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12981: checking for acosp in -lsunmath" >&5
+echo "configure:13139: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12987 "configure"
+#line 13145 "configure"
@@ -12994,7 +13152,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13009,13 +13167,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13013: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13171: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13019 "configure"
+#line 13177 "configure"
@@ -13026,7 +13184,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13056,13 +13214,13 @@
# Generic BLAS library
-echo "configure:13060: checking for sgemm_ in -lblas" >&5
+echo "configure:13218: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13066 "configure"
+#line 13224 "configure"
@@ -13073,7 +13231,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13112,7 +13270,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13116: checking whether to use LAPACK" >&5
+echo "configure:13274: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13137,7 +13295,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13141: checking for location of LAPACK includes" >&5
+echo "configure:13299: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13157,7 +13315,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13161: checking for location of LAPACK library" >&5
+echo "configure:13319: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13183,15 +13341,15 @@
do
-echo "configure:13187: checking for $ac_hdr" >&5
+echo "configure:13345: checking for $ac_hdr" >&5
-#line 13190 "configure"
+#line 13348 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13195: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13223,10 +13381,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13227: checking for dsegv_" >&5
+echo "configure:13385: checking for dsegv_" >&5
-#line 13230 "configure"
+#line 13388 "configure"
which can conflict with char dsegv_(); below. */
@@ -13249,7 +13407,7 @@
; return 0; }
EOF
-if { (eval echo configure:13253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13276,13 +13434,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13280: checking for desgv_ in -llapack" >&5
+echo "configure:13438: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13286 "configure"
+#line 13444 "configure"
@@ -13293,7 +13451,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13325,13 +13483,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13329: checking for dgesv_ in -llapack" >&5
+echo "configure:13487: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13335 "configure"
+#line 13493 "configure"
@@ -13342,7 +13500,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13361,13 +13519,13 @@
-echo "configure:13365: checking for dgesv_ in -llapack" >&5
+echo "configure:13523: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13371 "configure"
+#line 13529 "configure"
@@ -13378,7 +13536,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13434,7 +13592,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13438: checking whether to use Motif" >&5
+echo "configure:13596: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13453,7 +13611,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13457: checking for location of Motif includes" >&5
+echo "configure:13615: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13479,15 +13637,15 @@
do
-echo "configure:13483: checking for $ac_hdr" >&5
+echo "configure:13641: checking for $ac_hdr" >&5
-#line 13486 "configure"
+#line 13644 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13491: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13521,7 +13679,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13525: checking for location of Motif library" >&5
+echo "configure:13683: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13546,13 +13704,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13550: checking for XmStringCreate in -lXm" >&5
+echo "configure:13708: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13556 "configure"
+#line 13714 "configure"
@@ -13563,7 +13721,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13604,7 +13762,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13608: checking whether to use Cairo" >&5
+echo "configure:13766: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13630,15 +13788,15 @@
do
-echo "configure:13634: checking for $ac_hdr" >&5
+echo "configure:13792: checking for $ac_hdr" >&5
-#line 13637 "configure"
+#line 13795 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13642: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13675,10 +13833,10 @@
LDFLAGS="$LDFLAGS $CAIROLIB"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13679: checking for cairo_create" >&5
+echo "configure:13837: checking for cairo_create" >&5
-#line 13682 "configure"
+#line 13840 "configure"
which can conflict with char cairo_create(); below. */
@@ -13701,7 +13859,7 @@
; return 0; }
EOF
-if { (eval echo configure:13705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13736,7 +13894,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13740: checking whether to use GLw" >&5
+echo "configure:13898: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13755,7 +13913,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13759: checking for location of GLw includes" >&5
+echo "configure:13917: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13781,15 +13939,15 @@
do
-echo "configure:13785: checking for $ac_hdr" >&5
+echo "configure:13943: checking for $ac_hdr" >&5
-#line 13788 "configure"
+#line 13946 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13951: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13817,15 +13975,15 @@
do
-echo "configure:13821: checking for $ac_hdr" >&5
+echo "configure:13979: checking for $ac_hdr" >&5
-#line 13824 "configure"
+#line 13982 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13829: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13865,7 +14023,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13869: checking for location of GLw library" >&5
+echo "configure:14027: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13890,13 +14048,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13894: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14052: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13900 "configure"
+#line 14058 "configure"
@@ -13907,7 +14065,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13932,13 +14090,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13936: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14094: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13942 "configure"
+#line 14100 "configure"
@@ -13949,7 +14107,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13974,13 +14132,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13978: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14136: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13984 "configure"
+#line 14142 "configure"
@@ -13991,7 +14149,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14016,13 +14174,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14020: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14178: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14026 "configure"
+#line 14184 "configure"
@@ -14033,7 +14191,7 @@
; return 0; }
EOF
-if { (eval echo configure:14037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14058,13 +14216,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14062: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14220: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14068 "configure"
+#line 14226 "configure"
@@ -14075,7 +14233,7 @@
; return 0; }
EOF
-if { (eval echo configure:14079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14100,13 +14258,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14104: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14262: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14110 "configure"
+#line 14268 "configure"
@@ -14117,7 +14275,7 @@
; return 0; }
EOF
-if { (eval echo configure:14121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14144,13 +14302,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14148: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14306: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14154 "configure"
+#line 14312 "configure"
@@ -14161,7 +14319,7 @@
; return 0; }
EOF
-if { (eval echo configure:14165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14180,13 +14338,13 @@
-echo "configure:14184: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14342: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14190 "configure"
+#line 14348 "configure"
@@ -14197,7 +14355,7 @@
; return 0; }
EOF
-if { (eval echo configure:14201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14224,13 +14382,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14228: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14386: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14234 "configure"
+#line 14392 "configure"
@@ -14241,7 +14399,7 @@
; return 0; }
EOF
-if { (eval echo configure:14245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14260,13 +14418,13 @@
-echo "configure:14264: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14422: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14270 "configure"
+#line 14428 "configure"
@@ -14277,7 +14435,7 @@
; return 0; }
EOF
-if { (eval echo configure:14281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14390,7 +14548,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14394: checking whether to use FreeType" >&5
+echo "configure:14552: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14409,7 +14567,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14413: checking for location of FreeType includes" >&5
+echo "configure:14571: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14435,15 +14593,15 @@
do
-echo "configure:14439: checking for $ac_hdr" >&5
+echo "configure:14597: checking for $ac_hdr" >&5
-#line 14442 "configure"
+#line 14600 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14477,7 +14635,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14481: checking for location of FreeType library" >&5
+echo "configure:14639: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14502,13 +14660,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14506: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14664: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14512 "configure"
+#line 14670 "configure"
@@ -14519,7 +14677,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14560,7 +14718,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14564: checking whether to use NLS" >&5
+echo "configure:14722: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14580,10 +14738,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14584: checking for gettext" >&5
+echo "configure:14742: checking for gettext" >&5
-#line 14587 "configure"
+#line 14745 "configure"
which can conflict with char gettext(); below. */
@@ -14606,7 +14764,7 @@
; return 0; }
EOF
-if { (eval echo configure:14610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14624,13 +14782,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14628: checking for gettext in -lintl" >&5
+echo "configure:14786: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14634 "configure"
+#line 14792 "configure"
@@ -14641,7 +14799,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14676,7 +14834,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14680: checking whether to use C++" >&5
+echo "configure:14838: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14692,7 +14850,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14696: checking for $ac_word" >&5
+echo "configure:14854: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14721,7 +14879,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14725: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14883: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14732,12 +14890,12 @@
cat > conftest.$ac_ext << EOF
-#line 14736 "configure"
+#line 14894 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14763,19 +14921,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14767: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14925: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14772: checking whether we are using GNU C++" >&5
+echo "configure:14930: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14793,7 +14951,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14797: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14955: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14834,7 +14992,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14838: checking whether to use openDWG" >&5
+echo "configure:14996: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14854,7 +15012,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14858: checking for location of openDGW includes" >&5
+echo "configure:15016: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14880,15 +15038,15 @@
do
-echo "configure:14884: checking for $ac_hdr" >&5
+echo "configure:15042: checking for $ac_hdr" >&5
-#line 14887 "configure"
+#line 15045 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14892: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14922,7 +15080,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14926: checking for location of openDWG library" >&5
+echo "configure:15084: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14969,7 +15127,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14973: checking for special C compiler options needed for large files" >&5
+echo "configure:15131: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14977,7 +15135,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14981 "configure"
+#line 15139 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14993,7 +15151,7 @@
; return 0; }
EOF
-if { (eval echo configure:14997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15155: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15002,7 +15160,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15006 "configure"
+#line 15164 "configure"
@@ -15018,7 +15176,7 @@
; return 0; }
EOF
-if { (eval echo configure:15022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15180: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15038,11 +15196,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15042: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15200: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15046 "configure"
+#line 15204 "configure"
@@ -15058,14 +15216,14 @@
; return 0; }
EOF
-if { (eval echo configure:15062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15220: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15069 "configure"
+#line 15227 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15083,7 +15241,7 @@
; return 0; }
EOF
-if { (eval echo configure:15087: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15245: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15102,11 +15260,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15106: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15264: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15110 "configure"
+#line 15268 "configure"
@@ -15122,14 +15280,14 @@
; return 0; }
EOF
-if { (eval echo configure:15126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15133 "configure"
+#line 15291 "configure"
#define _LARGE_FILES 1
@@ -15147,7 +15305,7 @@
; return 0; }
EOF
-if { (eval echo configure:15151: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15309: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15166,25 +15324,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15170: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15328: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15174 "configure"
+#line 15332 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15181: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15339: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15188 "configure"
+#line 15346 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15193,7 +15351,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15197: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15214,10 +15372,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15218: checking if system supports Large Files at all" >&5
+echo "configure:15376: checking if system supports Large Files at all" >&5
-#line 15221 "configure"
+#line 15379 "configure"
#include <stdio.h>
@@ -15249,7 +15407,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15253: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15411: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15278,7 +15436,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15282: checking whether to use Python" >&5
+echo "configure:15440: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15298,7 +15456,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:15302: checking for $ac_word" >&5
+echo "configure:15460: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15343,15 +15501,15 @@
do
-echo "configure:15347: checking for $ac_hdr" >&5
+echo "configure:15505: checking for $ac_hdr" >&5
-#line 15350 "configure"
+#line 15508 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15391,7 +15549,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15395: checking for $ac_word" >&5
+echo "configure:15553: checking for $ac_word" >&5
case "$SWIG" in
@@ -15437,7 +15595,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15441: checking whether to use wxWidgets" >&5
+echo "configure:15599: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15457,7 +15615,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15461: checking for $ac_word" >&5
+echo "configure:15619: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15505,7 +15663,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15509: checking wxWidgets version" >&5
+echo "configure:15667: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15528,15 +15686,15 @@
do
-echo "configure:15532: checking for $ac_hdr" >&5
+echo "configure:15690: checking for $ac_hdr" >&5
-#line 15535 "configure"
+#line 15693 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15540: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15572,15 +15730,15 @@
do
-echo "configure:15576: checking for $ac_hdr" >&5
+echo "configure:15734: checking for $ac_hdr" >&5
-#line 15579 "configure"
+#line 15737 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15742: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15810,6 +15968,10 @@
s%@PROJLIB@%$PROJLIB%g
s%@PROJSHARE@%$PROJSHARE%g
s%@NAD2BIN@%$NAD2BIN%g
+s%@REGEXINCPATH@%$REGEXINCPATH%g
+s%@REGEXLIBPATH@%$REGEXLIBPATH%g
+s%@REGEXLIB@%$REGEXLIB%g
+s%@USE_REGEX@%$USE_REGEX%g
s%@READLINEINCPATH@%$READLINEINCPATH%g
s%@READLINELIBPATH@%$READLINELIBPATH%g
s%@READLINELIB@%$READLINELIB%g
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2008-09-13 06:01:12 UTC (rev 33419)
+++ grass/branches/develbranch_6/configure.in 2008-09-13 06:01:33 UTC (rev 33420)
@@ -197,6 +197,7 @@
LOC_ARG_WITH(readline, Readline, no)
LOC_ARG_WITH(opendwg, openDWG, no)
LOC_ARG_WITH(curses, Curses, yes)
+LOC_ARG_WITH(regex, regex)
AC_ARG_WITH(python,
[ --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
e.g. '--with-python=/usr/bin/python2.5-config', default: no)],, with_python="no")
@@ -277,6 +278,9 @@
LOC_ARG_WITH_INC(opendwg, openDWG)
LOC_ARG_WITH_LIB(opendwg, openDWG)
+LOC_ARG_WITH_INC(regex, regex)
+LOC_ARG_WITH_LIB(regex, regex)
# Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
# With includes option
@@ -611,6 +615,39 @@
# Done checking PROJ
+# Enable regex option
+LOC_CHECK_USE(regex,regex,USE_REGEX)
+REGEXINCPATH=
+REGEXLIBPATH=
+REGEXLIB=
+if test -n "$USE_REGEX"; then
+# With regex includes directory
+LOC_CHECK_INC_PATH(regex,regex,REGEXINCPATH)
+LOC_CHECK_INCLUDES(regex.h,regex,$REGEXINCPATH)
+# With regex library directory
+LOC_CHECK_LIB_PATH(regex,regex,REGEXLIBPATH)
+LOC_CHECK_FUNC(regcomp,regex functions,REGEXLIB,,,,,[
+LOC_CHECK_LIBS(regex,regcomp,regex,$REGEXLIBPATH,REGEXLIB,,,)
+fi # $USE_REGEX
+AC_SUBST(REGEXINCPATH)
+AC_SUBST(REGEXLIBPATH)
+AC_SUBST(REGEXLIB)
+AC_SUBST(USE_REGEX)
+# Done checking regex
# Enable Readline option
LOC_CHECK_USE(readline,Readline,USE_READLINE)
Modified: grass/branches/develbranch_6/general/Makefile
--- grass/branches/develbranch_6/general/Makefile 2008-09-13 06:01:12 UTC (rev 33419)
+++ grass/branches/develbranch_6/general/Makefile 2008-09-13 06:01:33 UTC (rev 33420)
@@ -14,6 +14,8 @@
g.mapsets \
g.message \
g.mkfontcap \
+ g.mlist \
+ g.mremove \
g.parser \
g.proj \
g.pnmcomp \
Modified: grass/branches/develbranch_6/include/Make/Platform.make.in
--- grass/branches/develbranch_6/include/Make/Platform.make.in 2008-09-13 06:01:12 UTC (rev 33419)
+++ grass/branches/develbranch_6/include/Make/Platform.make.in 2008-09-13 06:01:33 UTC (rev 33420)
@@ -222,6 +222,12 @@
WXWIDGETSLIB = @WXWIDGETSLIB@
USE_WXWIDGETS = @USE_WXWIDGETS@
+#regex
+REGEXINCPATH = @REGEXINCPATH@
+REGEXLIBPATH = @REGEXLIBPATH@
+REGEXLIB = @REGEXLIB@
+USE_REGEX = @USE_REGEX@
#i18N
HAVE_NLS = @HAVE_NLS@
Modified: grass/branches/develbranch_6/include/config.h.in
--- grass/branches/develbranch_6/include/config.h.in 2008-09-13 06:01:12 UTC (rev 33419)
+++ grass/branches/develbranch_6/include/config.h.in 2008-09-13 06:01:33 UTC (rev 33420)
@@ -248,6 +248,9 @@
/* define if OpenGL uses Windows */
#undef OPENGL_WINDOWS
+/* define if regex.h exists */
+#undef HAVE_REGEX_H
* configuration information solely dependent on the above
* nothing below this point should need changing
