[GRASS-SVN] r33423 - grass/branches/develbranch_6
Sat Sep 13 02:32:31 EDT 2008
Author: neteler
Date: 2008-09-13 02:32:30 -0400 (Sat, 13 Sep 2008)
New Revision: 33423
   grass/branches/develbranch_6/configure
updated
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2008-09-13 06:05:16 UTC (rev 33422)
+++ grass/branches/develbranch_6/configure	2008-09-13 06:32:30 UTC (rev 33423)
@@ -7271,10 +7271,119 @@
 fi
-LOC_CHECK_FUNC(regcomp,regex functions,REGEXLIB,,,,,
-LOC_CHECK_LIBS(regex,regcomp,regex,$REGEXLIBPATH,REGEXLIB,,,)
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS="  $LIBS"
+LDFLAGS=" $LDFLAGS"
+echo $ac_n "checking for regcomp""... $ac_c" 1>&6
+echo "configure:7281: checking for regcomp" >&5
+cat > conftest.$ac_ext <<EOF
+#line 7284 "configure"
+#include "confdefs.h"
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char regcomp(); below.  */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char regcomp();
+int main() {
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_regcomp) || defined (__stub___regcomp)
+choke me
+#else
+regcomp();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:7307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_func_regcomp=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_func_regcomp=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'regcomp`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    REGEXLIB="$REGEXLIB "
+else
+  echo "$ac_t""no" 1>&6
+LDFLAGS="$REGEXLIBPATH $LDFLAGS"
+echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
+echo "configure:7334: checking for regcomp in -lregex" >&5
+ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lregex  $LIBS"
+#line 7340 "configure"
+char regcomp();
+int main() {
+regcomp()
+; return 0; }
+EOF
+if { (eval echo configure:7351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  REGEXLIB="$REGEXLIB -lregex "
+else
+LDFLAGS=${ac_save_ldflags}
+    { echo "configure: error: *** Unable to locate regex library." 1>&2; exit 1; }
+fi
+fi
+LIBS=${ac_save_libs}
 fi # $USE_REGEX
@@ -7288,7 +7397,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7292: checking whether to use Readline" >&5
+echo "configure:7401: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7309,7 +7418,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7313: checking for location of Readline includes" >&5
+echo "configure:7422: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7335,15 +7444,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7339: checking for $ac_hdr" >&5
+echo "configure:7448: checking for $ac_hdr" >&5
-#line 7342 "configure"
+#line 7451 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7347: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7456: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7379,15 +7488,15 @@
 do
-echo "configure:7383: checking for $ac_hdr" >&5
+echo "configure:7492: checking for $ac_hdr" >&5
-#line 7386 "configure"
+#line 7495 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7421,7 +7530,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7425: checking for location of Readline library" >&5
+echo "configure:7534: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7446,13 +7555,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7450: checking for readline in -lreadline" >&5
+echo "configure:7559: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7456 "configure"
+#line 7565 "configure"
@@ -7463,7 +7572,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7498,13 +7607,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7502: checking for add_history in -lhistory" >&5
+echo "configure:7611: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7508 "configure"
+#line 7617 "configure"
@@ -7515,7 +7624,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7558,7 +7667,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7562: checking whether to use JPEG" >&5
+echo "configure:7671: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7578,7 +7687,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7582: checking for location of JPEG includes" >&5
+echo "configure:7691: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7604,15 +7713,15 @@
 do
-echo "configure:7608: checking for $ac_hdr" >&5
+echo "configure:7717: checking for $ac_hdr" >&5
-#line 7611 "configure"
+#line 7720 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7725: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7646,7 +7755,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7650: checking for location of JPEG library" >&5
+echo "configure:7759: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7673,13 +7782,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7677: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7786: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7683 "configure"
+#line 7792 "configure"
@@ -7690,7 +7799,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7709,13 +7818,13 @@
-echo "configure:7713: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7822: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7719 "configure"
+#line 7828 "configure"
@@ -7726,7 +7835,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7775,7 +7884,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7779: checking whether to use GDAL" >&5
+echo "configure:7888: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7793,7 +7902,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7797: checking for $ac_word" >&5
+echo "configure:7906: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7848,14 +7957,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7852 "configure"
+#line 7961 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -7864,14 +7973,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7868 "configure"
+#line 7977 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7904,7 +8013,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7908: checking whether to use TIFF" >&5
+echo "configure:8017: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7924,7 +8033,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7928: checking for location of TIFF includes" >&5
+echo "configure:8037: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7950,15 +8059,15 @@
 do
-echo "configure:7954: checking for $ac_hdr" >&5
+echo "configure:8063: checking for $ac_hdr" >&5
-#line 7957 "configure"
+#line 8066 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7962: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7992,7 +8101,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7996: checking for location of TIFF library" >&5
+echo "configure:8105: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8023,13 +8132,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8027: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8136: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8033 "configure"
+#line 8142 "configure"
@@ -8040,7 +8149,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8059,13 +8168,13 @@
-echo "configure:8063: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8172: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8069 "configure"
+#line 8178 "configure"
@@ -8076,7 +8185,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8095,13 +8204,13 @@
-echo "configure:8099: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8208: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8105 "configure"
+#line 8214 "configure"
@@ -8112,7 +8221,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8131,13 +8240,13 @@
-echo "configure:8135: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8244: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8141 "configure"
+#line 8250 "configure"
@@ -8148,7 +8257,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8167,13 +8276,13 @@
-echo "configure:8171: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8280: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8177 "configure"
+#line 8286 "configure"
@@ -8184,7 +8293,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8203,13 +8312,13 @@
-echo "configure:8207: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8316: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8213 "configure"
+#line 8322 "configure"
@@ -8220,7 +8329,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8239,13 +8348,13 @@
-echo "configure:8243: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8352: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8249 "configure"
+#line 8358 "configure"
@@ -8256,7 +8365,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8275,13 +8384,13 @@
-echo "configure:8279: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8388: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8285 "configure"
+#line 8394 "configure"
@@ -8292,7 +8401,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8390,7 +8499,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8394: checking whether to use PNG" >&5
+echo "configure:8503: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8409,7 +8518,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8413: checking for location of PNG includes" >&5
+echo "configure:8522: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8435,15 +8544,15 @@
 do
-echo "configure:8439: checking for $ac_hdr" >&5
+echo "configure:8548: checking for $ac_hdr" >&5
-#line 8442 "configure"
+#line 8551 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8447: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8477,7 +8586,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8481: checking for location of PNG library" >&5
+echo "configure:8590: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8502,13 +8611,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8506: checking for png_read_image in -lpng" >&5
+echo "configure:8615: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8512 "configure"
+#line 8621 "configure"
@@ -8519,7 +8628,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8561,7 +8670,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8565: checking whether to use Tcl/Tk" >&5
+echo "configure:8674: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8581,7 +8690,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8585: checking for location of Tcl/Tk includes" >&5
+echo "configure:8694: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8607,15 +8716,15 @@
 do
-echo "configure:8611: checking for $ac_hdr" >&5
+echo "configure:8720: checking for $ac_hdr" >&5
-#line 8614 "configure"
+#line 8723 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8652,15 +8761,15 @@
 do
-echo "configure:8656: checking for $ac_hdr" >&5
+echo "configure:8765: checking for $ac_hdr" >&5
-#line 8659 "configure"
+#line 8768 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8664: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8694,7 +8803,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8698: checking Tcl version" >&5
+echo "configure:8807: checking Tcl version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8702,7 +8811,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8706 "configure"
+#line 8815 "configure"
 #include <stdio.h>
@@ -8714,7 +8823,7 @@
 EOF
-if { (eval echo configure:8718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8732,7 +8841,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8736: checking Tk version" >&5
+echo "configure:8845: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8740,7 +8849,7 @@
 else
-#line 8744 "configure"
+#line 8853 "configure"
 #include <stdio.h>
@@ -8752,7 +8861,7 @@
 EOF
-if { (eval echo configure:8756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8781,7 +8890,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8785: checking for location of Tcl/Tk library" >&5
+echo "configure:8894: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8811,13 +8920,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8815: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8924: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8821 "configure"
+#line 8930 "configure"
@@ -8828,7 +8937,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8847,13 +8956,13 @@
-echo "configure:8851: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8960: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8857 "configure"
+#line 8966 "configure"
@@ -8864,7 +8973,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8891,13 +9000,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8895: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9004: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8901 "configure"
+#line 9010 "configure"
@@ -8908,7 +9017,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8927,13 +9036,13 @@
-echo "configure:8931: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:9040: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8937 "configure"
+#line 9046 "configure"
@@ -8944,7 +9053,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8971,13 +9080,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8975: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9084: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8981 "configure"
+#line 9090 "configure"
@@ -8988,7 +9097,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9007,13 +9116,13 @@
-echo "configure:9011: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9120: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9017 "configure"
+#line 9126 "configure"
@@ -9024,7 +9133,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9102,13 +9211,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9106: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9215: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9112 "configure"
+#line 9221 "configure"
@@ -9119,7 +9228,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9138,13 +9247,13 @@
-echo "configure:9142: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9251: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9148 "configure"
+#line 9257 "configure"
@@ -9155,7 +9264,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9182,13 +9291,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9186: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9295: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9192 "configure"
+#line 9301 "configure"
@@ -9199,7 +9308,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9218,13 +9327,13 @@
-echo "configure:9222: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9331: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9228 "configure"
+#line 9337 "configure"
@@ -9235,7 +9344,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9262,13 +9371,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9266: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9375: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9272 "configure"
+#line 9381 "configure"
@@ -9279,7 +9388,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9298,13 +9407,13 @@
-echo "configure:9302: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9411: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9308 "configure"
+#line 9417 "configure"
@@ -9315,7 +9424,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9407,7 +9516,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9411: checking whether to use PostgreSQL" >&5
+echo "configure:9520: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9434,7 +9543,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9438: checking for location of PostgreSQL includes" >&5
+echo "configure:9547: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9460,15 +9569,15 @@
 do
-echo "configure:9464: checking for $ac_hdr" >&5
+echo "configure:9573: checking for $ac_hdr" >&5
-#line 9467 "configure"
+#line 9576 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9506,7 +9615,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9510: checking for location of PostgreSQL library" >&5
+echo "configure:9619: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9535,13 +9644,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9539: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9648: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9545 "configure"
+#line 9654 "configure"
@@ -9552,7 +9661,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9571,13 +9680,13 @@
-echo "configure:9575: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9684: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9581 "configure"
+#line 9690 "configure"
@@ -9588,7 +9697,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9607,13 +9716,13 @@
-echo "configure:9611: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9720: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9617 "configure"
+#line 9726 "configure"
@@ -9624,7 +9733,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9643,13 +9752,13 @@
-echo "configure:9647: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9756: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9653 "configure"
+#line 9762 "configure"
@@ -9660,7 +9769,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9717,13 +9826,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9721: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9830: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9727 "configure"
+#line 9836 "configure"
@@ -9734,7 +9843,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9756,13 +9865,13 @@
-echo "configure:9760: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9869: checking for PQcmdTuples in -lpq" >&5
-#line 9766 "configure"
+#line 9875 "configure"
@@ -9773,7 +9882,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9816,7 +9925,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9820: checking whether to use MySQL" >&5
+echo "configure:9929: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9836,7 +9945,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9840: checking for location of MySQL includes" >&5
+echo "configure:9949: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9862,15 +9971,15 @@
 do
-echo "configure:9866: checking for $ac_hdr" >&5
+echo "configure:9975: checking for $ac_hdr" >&5
-#line 9869 "configure"
+#line 9978 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9907,7 +10016,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9911: checking for location of MySQL library" >&5
+echo "configure:10020: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9938,13 +10047,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9942: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10051: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9948 "configure"
+#line 10057 "configure"
@@ -9955,7 +10064,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9974,13 +10083,13 @@
-echo "configure:9978: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10087: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9984 "configure"
+#line 10093 "configure"
@@ -9991,7 +10100,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10010,13 +10119,13 @@
-echo "configure:10014: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10123: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10020 "configure"
+#line 10129 "configure"
@@ -10027,7 +10136,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10046,13 +10155,13 @@
-echo "configure:10050: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10159: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10056 "configure"
+#line 10165 "configure"
@@ -10063,7 +10172,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10082,13 +10191,13 @@
-echo "configure:10086: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10195: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10092 "configure"
+#line 10201 "configure"
@@ -10099,7 +10208,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10118,13 +10227,13 @@
-echo "configure:10122: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10231: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10128 "configure"
+#line 10237 "configure"
@@ -10135,7 +10244,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10154,13 +10263,13 @@
-echo "configure:10158: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10267: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10164 "configure"
+#line 10273 "configure"
@@ -10171,7 +10280,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10190,13 +10299,13 @@
-echo "configure:10194: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10303: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10200 "configure"
+#line 10309 "configure"
@@ -10207,7 +10316,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10297,7 +10406,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10301: checking for $ac_word" >&5
+echo "configure:10410: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10338,10 +10447,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10342: checking for mysql_server_init" >&5
+echo "configure:10451: checking for mysql_server_init" >&5
-#line 10345 "configure"
+#line 10454 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -10364,7 +10473,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10402,7 +10511,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10406: checking whether to use SQLite" >&5
+echo "configure:10515: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10422,7 +10531,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10426: checking for location of SQLite includes" >&5
+echo "configure:10535: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10448,15 +10557,15 @@
 do
-echo "configure:10452: checking for $ac_hdr" >&5
+echo "configure:10561: checking for $ac_hdr" >&5
-#line 10455 "configure"
+#line 10564 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10499,7 +10608,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10503: checking for location of SQLite library" >&5
+echo "configure:10612: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10526,13 +10635,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10530: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10639: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10536 "configure"
+#line 10645 "configure"
@@ -10543,7 +10652,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10562,13 +10671,13 @@
-echo "configure:10566: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10675: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10572 "configure"
+#line 10681 "configure"
@@ -10579,7 +10688,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10632,7 +10741,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10636: checking whether to use FFMPEG" >&5
+echo "configure:10745: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10652,7 +10761,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10656: checking for location of FFMPEG includes" >&5
+echo "configure:10765: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10678,15 +10787,15 @@
 do
-echo "configure:10682: checking for $ac_hdr" >&5
+echo "configure:10791: checking for $ac_hdr" >&5
-#line 10685 "configure"
+#line 10794 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10690: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10799: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10722,15 +10831,15 @@
 do
-echo "configure:10726: checking for $ac_hdr" >&5
+echo "configure:10835: checking for $ac_hdr" >&5
-#line 10729 "configure"
+#line 10838 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10766,15 +10875,15 @@
 do
-echo "configure:10770: checking for $ac_hdr" >&5
+echo "configure:10879: checking for $ac_hdr" >&5
-#line 10773 "configure"
+#line 10882 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10778: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10887: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10817,7 +10926,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10821: checking for location of FFMPEG library" >&5
+echo "configure:10930: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10844,13 +10953,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10848: checking for av_free in -lavutil" >&5
+echo "configure:10957: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10854 "configure"
+#line 10963 "configure"
@@ -10861,7 +10970,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10880,13 +10989,13 @@
-echo "configure:10884: checking for av_free in -lavutil" >&5
+echo "configure:10993: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10890 "configure"
+#line 10999 "configure"
@@ -10897,7 +11006,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10942,13 +11051,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10946: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11055: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10952 "configure"
+#line 11061 "configure"
@@ -10959,7 +11068,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10978,13 +11087,13 @@
-echo "configure:10982: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11091: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10988 "configure"
+#line 11097 "configure"
@@ -10995,7 +11104,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11040,13 +11149,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11044: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11153: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 11050 "configure"
+#line 11159 "configure"
@@ -11057,7 +11166,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11076,13 +11185,13 @@
-echo "configure:11080: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11189: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11086 "configure"
+#line 11195 "configure"
@@ -11093,7 +11202,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11153,7 +11262,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11157: checking whether to use OpenGL" >&5
+echo "configure:11266: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11187,7 +11296,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11191: checking for location of OpenGL includes" >&5
+echo "configure:11300: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11213,15 +11322,15 @@
 do
-echo "configure:11217: checking for $ac_hdr" >&5
+echo "configure:11326: checking for $ac_hdr" >&5
-#line 11220 "configure"
+#line 11329 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11255,7 +11364,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11259: checking for location of OpenGL library" >&5
+echo "configure:11368: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11284,13 +11393,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11288: checking for glBegin in -lGL" >&5
+echo "configure:11397: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11294 "configure"
+#line 11403 "configure"
@@ -11301,7 +11410,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11320,13 +11429,13 @@
-echo "configure:11324: checking for glBegin in -lGL" >&5
+echo "configure:11433: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11330 "configure"
+#line 11439 "configure"
@@ -11337,7 +11446,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11356,13 +11465,13 @@
-echo "configure:11360: checking for glBegin in -lGL" >&5
+echo "configure:11469: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11366 "configure"
+#line 11475 "configure"
@@ -11373,7 +11482,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11392,13 +11501,13 @@
-echo "configure:11396: checking for glBegin in -lGL" >&5
+echo "configure:11505: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11402 "configure"
+#line 11511 "configure"
@@ -11409,7 +11518,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11471,13 +11580,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11475: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11584: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11481 "configure"
+#line 11590 "configure"
@@ -11488,7 +11597,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11507,13 +11616,13 @@
-echo "configure:11511: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11620: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11517 "configure"
+#line 11626 "configure"
@@ -11524,7 +11633,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11568,10 +11677,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11572: checking for glXCreatePbuffer" >&5
+echo "configure:11681: checking for glXCreatePbuffer" >&5
-#line 11575 "configure"
+#line 11684 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11594,7 +11703,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11616,10 +11725,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11620: checking for glXCreateGLXPixmap" >&5
+echo "configure:11729: checking for glXCreateGLXPixmap" >&5
-#line 11623 "configure"
+#line 11732 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11642,7 +11751,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11681,7 +11790,7 @@
-echo "configure:11685: checking for location of OpenGL includes" >&5
+echo "configure:11794: checking for location of OpenGL includes" >&5
@@ -11707,15 +11816,15 @@
 do
-echo "configure:11711: checking for $ac_hdr" >&5
+echo "configure:11820: checking for $ac_hdr" >&5
-#line 11714 "configure"
+#line 11823 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11828: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11750,10 +11859,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11754: checking for glBegin" >&5
+echo "configure:11863: checking for glBegin" >&5
-#line 11757 "configure"
+#line 11866 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11776,7 +11885,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11791,10 +11900,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11795: checking for gluBeginCurve" >&5
+echo "configure:11904: checking for gluBeginCurve" >&5
-#line 11798 "configure"
+#line 11907 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11817,7 +11926,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11861,7 +11970,7 @@
-echo "configure:11865: checking for location of OpenGL includes" >&5
+echo "configure:11974: checking for location of OpenGL includes" >&5
@@ -11887,15 +11996,15 @@
 do
-echo "configure:11891: checking for $ac_hdr" >&5
+echo "configure:12000: checking for $ac_hdr" >&5
-#line 11894 "configure"
+#line 12003 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11929,7 +12038,7 @@
-echo "configure:11933: checking for location of OpenGL library" >&5
+echo "configure:12042: checking for location of OpenGL library" >&5
@@ -11954,18 +12063,18 @@
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11958: checking for OpenGL library" >&5
+echo "configure:12067: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11962 "configure"
+#line 12071 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11989,18 +12098,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11993: checking for GLU library" >&5
+echo "configure:12102: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11997 "configure"
+#line 12106 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:12004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12049,7 +12158,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12053: checking whether to use ODBC" >&5
+echo "configure:12162: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12068,7 +12177,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12072: checking for location of ODBC includes" >&5
+echo "configure:12181: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12094,15 +12203,15 @@
 do
-echo "configure:12098: checking for $ac_hdr" >&5
+echo "configure:12207: checking for $ac_hdr" >&5
-#line 12101 "configure"
+#line 12210 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12106: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12136,7 +12245,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12140: checking for location of ODBC library" >&5
+echo "configure:12249: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12161,13 +12270,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12165: checking for SQLConnect in -lodbc" >&5
+echo "configure:12274: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12171 "configure"
+#line 12280 "configure"
@@ -12178,7 +12287,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12203,13 +12312,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12207: checking for SQLConnect in -liodbc" >&5
+echo "configure:12316: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12213 "configure"
+#line 12322 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12220,7 +12329,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12245,11 +12354,11 @@
 ac_save_ldflags="$LDFLAGS"
 ac_save_libs="$LIBS"
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12249: checking for ODBC library" >&5
+echo "configure:12358: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12253 "configure"
+#line 12362 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12257,7 +12366,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12306,7 +12415,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12310: checking whether to use FFTW" >&5
+echo "configure:12419: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12325,7 +12434,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12329: checking for location of FFTW includes" >&5
+echo "configure:12438: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12351,15 +12460,15 @@
 do
-echo "configure:12355: checking for $ac_hdr" >&5
+echo "configure:12464: checking for $ac_hdr" >&5
-#line 12358 "configure"
+#line 12467 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12387,15 +12496,15 @@
 do
-echo "configure:12391: checking for $ac_hdr" >&5
+echo "configure:12500: checking for $ac_hdr" >&5
-#line 12394 "configure"
+#line 12503 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12399: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12423,15 +12532,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12427: checking for $ac_hdr" >&5
+echo "configure:12536: checking for $ac_hdr" >&5
-#line 12430 "configure"
+#line 12539 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12477,7 +12586,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12481: checking for location of FFTW library" >&5
+echo "configure:12590: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12502,13 +12611,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12506: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12615: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12512 "configure"
+#line 12621 "configure"
@@ -12519,7 +12628,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12544,13 +12653,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12548: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12657: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12554 "configure"
+#line 12663 "configure"
@@ -12561,7 +12670,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12586,13 +12695,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12590: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12699: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12596 "configure"
+#line 12705 "configure"
@@ -12603,7 +12712,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12660,7 +12769,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12664: checking whether to use BLAS" >&5
+echo "configure:12773: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12681,7 +12790,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12685: checking for location of BLAS includes" >&5
+echo "configure:12794: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12701,7 +12810,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12705: checking for location of BLAS library" >&5
+echo "configure:12814: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12727,15 +12836,15 @@
 do
-echo "configure:12731: checking for $ac_hdr" >&5
+echo "configure:12840: checking for $ac_hdr" >&5
-#line 12734 "configure"
+#line 12843 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12848: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12770,13 +12879,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12774: checking for dnrm2_ in -lblas" >&5
+echo "configure:12883: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12780 "configure"
+#line 12889 "configure"
@@ -12787,7 +12896,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12806,13 +12915,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:12810: checking for dnrm2_ in -lblas" >&5
+echo "configure:12919: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12816 "configure"
+#line 12925 "configure"
@@ -12823,7 +12932,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12867,13 +12976,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12871: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12980: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12877 "configure"
+#line 12986 "configure"
@@ -12884,7 +12993,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12899,13 +13008,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12903: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13012: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12909 "configure"
+#line 13018 "configure"
@@ -12916,7 +13025,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12931,13 +13040,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12935: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13044: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12941 "configure"
+#line 13050 "configure"
@@ -12948,7 +13057,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12993,16 +13102,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12997: checking for sgemm in $vlib_flags" >&5
+echo "configure:13106: checking for sgemm in $vlib_flags" >&5
-#line 12999 "configure"
+#line 13108 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13020,13 +13129,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13024: checking for sgemm_ in -lblas" >&5
+echo "configure:13133: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13030 "configure"
+#line 13139 "configure"
@@ -13037,7 +13146,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13052,13 +13161,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13056: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13165: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13062 "configure"
+#line 13171 "configure"
@@ -13069,7 +13178,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13084,13 +13193,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13088: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13197: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13094 "configure"
+#line 13203 "configure"
@@ -13101,7 +13210,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13135,13 +13244,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13139: checking for acosp in -lsunmath" >&5
+echo "configure:13248: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13145 "configure"
+#line 13254 "configure"
@@ -13152,7 +13261,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13167,13 +13276,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13171: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13280: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13177 "configure"
+#line 13286 "configure"
@@ -13184,7 +13293,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13214,13 +13323,13 @@
 # Generic BLAS library
-echo "configure:13218: checking for sgemm_ in -lblas" >&5
+echo "configure:13327: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13224 "configure"
+#line 13333 "configure"
@@ -13231,7 +13340,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13270,7 +13379,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13274: checking whether to use LAPACK" >&5
+echo "configure:13383: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13295,7 +13404,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13299: checking for location of LAPACK includes" >&5
+echo "configure:13408: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13315,7 +13424,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13319: checking for location of LAPACK library" >&5
+echo "configure:13428: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13341,15 +13450,15 @@
 do
-echo "configure:13345: checking for $ac_hdr" >&5
+echo "configure:13454: checking for $ac_hdr" >&5
-#line 13348 "configure"
+#line 13457 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13381,10 +13490,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13385: checking for dsegv_" >&5
+echo "configure:13494: checking for dsegv_" >&5
-#line 13388 "configure"
+#line 13497 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char dsegv_(); below.  */
@@ -13407,7 +13516,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13434,13 +13543,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13438: checking for desgv_ in -llapack" >&5
+echo "configure:13547: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13444 "configure"
+#line 13553 "configure"
@@ -13451,7 +13560,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13483,13 +13592,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13487: checking for dgesv_ in -llapack" >&5
+echo "configure:13596: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13493 "configure"
+#line 13602 "configure"
@@ -13500,7 +13609,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13519,13 +13628,13 @@
-echo "configure:13523: checking for dgesv_ in -llapack" >&5
+echo "configure:13632: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13529 "configure"
+#line 13638 "configure"
@@ -13536,7 +13645,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13592,7 +13701,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13596: checking whether to use Motif" >&5
+echo "configure:13705: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13611,7 +13720,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13615: checking for location of Motif includes" >&5
+echo "configure:13724: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13637,15 +13746,15 @@
 do
-echo "configure:13641: checking for $ac_hdr" >&5
+echo "configure:13750: checking for $ac_hdr" >&5
-#line 13644 "configure"
+#line 13753 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13679,7 +13788,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13683: checking for location of Motif library" >&5
+echo "configure:13792: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13704,13 +13813,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13708: checking for XmStringCreate in -lXm" >&5
+echo "configure:13817: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13714 "configure"
+#line 13823 "configure"
@@ -13721,7 +13830,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13762,7 +13871,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13766: checking whether to use Cairo" >&5
+echo "configure:13875: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13788,15 +13897,15 @@
 do
-echo "configure:13792: checking for $ac_hdr" >&5
+echo "configure:13901: checking for $ac_hdr" >&5
-#line 13795 "configure"
+#line 13904 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13833,10 +13942,10 @@
 LDFLAGS="$LDFLAGS $CAIROLIB"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13837: checking for cairo_create" >&5
+echo "configure:13946: checking for cairo_create" >&5
-#line 13840 "configure"
+#line 13949 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13859,7 +13968,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13894,7 +14003,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13898: checking whether to use GLw" >&5
+echo "configure:14007: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13913,7 +14022,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13917: checking for location of GLw includes" >&5
+echo "configure:14026: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13939,15 +14048,15 @@
 do
-echo "configure:13943: checking for $ac_hdr" >&5
+echo "configure:14052: checking for $ac_hdr" >&5
-#line 13946 "configure"
+#line 14055 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13951: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13975,15 +14084,15 @@
 do
-echo "configure:13979: checking for $ac_hdr" >&5
+echo "configure:14088: checking for $ac_hdr" >&5
-#line 13982 "configure"
+#line 14091 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14023,7 +14132,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14027: checking for location of GLw library" >&5
+echo "configure:14136: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14048,13 +14157,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14052: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14161: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14058 "configure"
+#line 14167 "configure"
@@ -14065,7 +14174,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14090,13 +14199,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14094: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14203: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14100 "configure"
+#line 14209 "configure"
@@ -14107,7 +14216,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14132,13 +14241,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14136: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14245: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14142 "configure"
+#line 14251 "configure"
@@ -14149,7 +14258,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14174,13 +14283,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14178: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14287: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14184 "configure"
+#line 14293 "configure"
@@ -14191,7 +14300,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14216,13 +14325,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14220: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14329: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14226 "configure"
+#line 14335 "configure"
@@ -14233,7 +14342,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14258,13 +14367,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14262: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14371: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14268 "configure"
+#line 14377 "configure"
@@ -14275,7 +14384,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14302,13 +14411,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14306: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14415: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14312 "configure"
+#line 14421 "configure"
@@ -14319,7 +14428,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14338,13 +14447,13 @@
-echo "configure:14342: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14451: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14348 "configure"
+#line 14457 "configure"
@@ -14355,7 +14464,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14382,13 +14491,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14386: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14495: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14392 "configure"
+#line 14501 "configure"
@@ -14399,7 +14508,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14418,13 +14527,13 @@
-echo "configure:14422: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14531: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14428 "configure"
+#line 14537 "configure"
@@ -14435,7 +14544,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14548,7 +14657,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14552: checking whether to use FreeType" >&5
+echo "configure:14661: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14567,7 +14676,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14571: checking for location of FreeType includes" >&5
+echo "configure:14680: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14593,15 +14702,15 @@
 do
-echo "configure:14597: checking for $ac_hdr" >&5
+echo "configure:14706: checking for $ac_hdr" >&5
-#line 14600 "configure"
+#line 14709 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14714: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14635,7 +14744,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14639: checking for location of FreeType library" >&5
+echo "configure:14748: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14660,13 +14769,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14664: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14773: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14670 "configure"
+#line 14779 "configure"
@@ -14677,7 +14786,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14718,7 +14827,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14722: checking whether to use NLS" >&5
+echo "configure:14831: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14738,10 +14847,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14742: checking for gettext" >&5
+echo "configure:14851: checking for gettext" >&5
-#line 14745 "configure"
+#line 14854 "configure"
     which can conflict with char gettext(); below.  */
@@ -14764,7 +14873,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14782,13 +14891,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14786: checking for gettext in -lintl" >&5
+echo "configure:14895: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14792 "configure"
+#line 14901 "configure"
@@ -14799,7 +14908,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14834,7 +14943,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14838: checking whether to use C++" >&5
+echo "configure:14947: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14850,7 +14959,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14854: checking for $ac_word" >&5
+echo "configure:14963: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14879,7 +14988,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14883: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14992: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14890,12 +14999,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14894 "configure"
+#line 15003 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14921,19 +15030,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14925: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15034: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14930: checking whether we are using GNU C++" >&5
+echo "configure:15039: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14951,7 +15060,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14955: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15064: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14992,7 +15101,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14996: checking whether to use openDWG" >&5
+echo "configure:15105: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15012,7 +15121,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15016: checking for location of openDGW includes" >&5
+echo "configure:15125: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15038,15 +15147,15 @@
 do
-echo "configure:15042: checking for $ac_hdr" >&5
+echo "configure:15151: checking for $ac_hdr" >&5
-#line 15045 "configure"
+#line 15154 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15080,7 +15189,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15084: checking for location of openDWG library" >&5
+echo "configure:15193: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15127,7 +15236,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15131: checking for special C compiler options needed for large files" >&5
+echo "configure:15240: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15135,7 +15244,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15139 "configure"
+#line 15248 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15151,7 +15260,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15155: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15264: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -15160,7 +15269,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15164 "configure"
+#line 15273 "configure"
@@ -15176,7 +15285,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15180: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15289: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15196,11 +15305,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15200: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15309: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15204 "configure"
+#line 15313 "configure"
@@ -15216,14 +15325,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15220: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15329: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15227 "configure"
+#line 15336 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15241,7 +15350,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15245: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15354: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15260,11 +15369,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15264: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15373: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15268 "configure"
+#line 15377 "configure"
@@ -15280,14 +15389,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15393: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15291 "configure"
+#line 15400 "configure"
 #define _LARGE_FILES 1
@@ -15305,7 +15414,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15309: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15418: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15324,25 +15433,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15328: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15437: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15332 "configure"
+#line 15441 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15339: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15448: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15346 "configure"
+#line 15455 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15351,7 +15460,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15464: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15372,10 +15481,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15376: checking if system supports Large Files at all" >&5
+echo "configure:15485: checking if system supports Large Files at all" >&5
-#line 15379 "configure"
+#line 15488 "configure"
 #include <stdio.h>
@@ -15407,7 +15516,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15411: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15520: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15436,7 +15545,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15440: checking whether to use Python" >&5
+echo "configure:15549: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15456,7 +15565,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15460: checking for $ac_word" >&5
+echo "configure:15569: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15501,15 +15610,15 @@
 do
-echo "configure:15505: checking for $ac_hdr" >&5
+echo "configure:15614: checking for $ac_hdr" >&5
-#line 15508 "configure"
+#line 15617 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15549,7 +15658,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15553: checking for $ac_word" >&5
+echo "configure:15662: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15595,7 +15704,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15599: checking whether to use wxWidgets" >&5
+echo "configure:15708: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15615,7 +15724,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15619: checking for $ac_word" >&5
+echo "configure:15728: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15663,7 +15772,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15667: checking wxWidgets version" >&5
+echo "configure:15776: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15686,15 +15795,15 @@
 do
-echo "configure:15690: checking for $ac_hdr" >&5
+echo "configure:15799: checking for $ac_hdr" >&5
-#line 15693 "configure"
+#line 15802 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15807: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15730,15 +15839,15 @@
 do
-echo "configure:15734: checking for $ac_hdr" >&5
+echo "configure:15843: checking for $ac_hdr" >&5
-#line 15737 "configure"
+#line 15846 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15742: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
