[GRASS-SVN] r33425 - in grass/branches/develbranch_6/raster/simwe:
r.sim.sediment r.sim.water
svn_grass at osgeo.org
Sat Sep 13 04:28:10 EDT 2008
Author: neteler
Date: 2008-09-13 04:28:10 -0400 (Sat, 13 Sep 2008)
New Revision: 33425
grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c
grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c
fixed code order (merge from trunk)
Modified: grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c
--- grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c 2008-09-13 06:34:14 UTC (rev 33424)
+++ grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c 2008-09-13 08:28:10 UTC (rev 33425)
@@ -51,7 +51,6 @@
/* DEFINE GLOB VAR */
-/* #define NWALK "1000000" */
#define DIFFC "0.8"
#define NITER "10"
#define ITEROUT "2"
@@ -114,54 +113,6 @@
_("Sediment transport and erosion/deposition simulation "
"using path sampling method (SIMWE)");
- if (G_get_set_window(&cellhd) == -1)
- exit(EXIT_FAILURE);
- conv = G_database_units_to_meters_factor();
- mixx = cellhd.west * conv;
- maxx = cellhd.east * conv;
- miyy = cellhd.south * conv;
- mayy = cellhd.north * conv;
- stepx = cellhd.ew_res * conv;
- stepy = cellhd.ns_res * conv;
- /* step = amin1(stepx,stepy); */
- step = (stepx + stepy) / 2.;
- mx = cellhd.cols;
- my = cellhd.rows;
- x_orig = cellhd.west * conv;
- y_orig = cellhd.south * conv; /* do we need this? */
- xmin = 0.;
- ymin = 0.;
- xp0 = xmin + stepx / 2.;
- yp0 = ymin + stepy / 2.;
- xmax = xmin + stepx * (float)mx;
- ymax = ymin + stepy * (float)my;
- hhc = hhmax = 0.;
-#if 0
- bxmi = 2093113. * conv;
- bymi = 731331. * conv;
- bxma = 2093461. * conv;
- byma = 731529. * conv;
- bresx = 2. * conv;
- bresy = 2. * conv;
- maxwab = 100000;
- mx2o = (int)((bxma - bxmi) / bresx);
- my2o = (int)((byma - bymi) / bresy);
- /* relative small box coordinates: leave 1 grid layer for overlap */
- bxmi = bxmi - mixx + stepx;
- bymi = bymi - miyy + stepy;
- bxma = bxma - mixx - stepx;
- byma = byma - miyy - stepy;
- mx2 = mx2o - 2 * ((int)(stepx / bresx));
- my2 = my2o - 2 * ((int)(stepy / bresy));
-#endif
parm.elevin = G_define_standard_option(G_OPT_R_INPUT);
parm.elevin->key = "elevin";
parm.elevin->description = _("Name of the elevation raster map [m]");
@@ -258,7 +209,6 @@
parm.nwalk = G_define_option();
parm.nwalk->key = "nwalk";
parm.nwalk->type = TYPE_INTEGER;
- /* parm.nwalk->answer = NWALK; */
parm.nwalk->required = NO;
parm.nwalk->description = _("Number of walkers");
parm.nwalk->guisection = _("Parameters");
@@ -295,22 +245,58 @@
parm.diffc->required = NO;
parm.diffc->description = _("Water diffusion constant");
parm.diffc->guisection = _("Parameters");
- flag.mscale = G_define_flag ();
- flag.mscale->key = 'm';
- flag.mscale->description = _("Multiscale simulation");
- flag.tserie = G_define_flag ();
- flag.tserie->key = 't';
- flag.tserie->description = _("Time-series output");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- /* mscale=flag.mscale->answer ? "m" : NULL;
- tserie=flag.tserie->answer ? "t" : NULL; */
+ if (G_get_set_window(&cellhd) == -1)
+ exit(EXIT_FAILURE);
+ conv = G_database_units_to_meters_factor();
+ mixx = cellhd.west * conv;
+ maxx = cellhd.east * conv;
+ miyy = cellhd.south * conv;
+ mayy = cellhd.north * conv;
+ stepx = cellhd.ew_res * conv;
+ stepy = cellhd.ns_res * conv;
+ /* step = amin1(stepx,stepy); */
+ step = (stepx + stepy) / 2.;
+ mx = cellhd.cols;
+ my = cellhd.rows;
+ x_orig = cellhd.west * conv;
+ y_orig = cellhd.south * conv; /* do we need this? */
+ xmin = 0.;
+ ymin = 0.;
+ xp0 = xmin + stepx / 2.;
+ yp0 = ymin + stepy / 2.;
+ xmax = xmin + stepx * (float)mx;
+ ymax = ymin + stepy * (float)my;
+ hhc = hhmax = 0.;
+#if 0
+ bxmi = 2093113. * conv;
+ bymi = 731331. * conv;
+ bxma = 2093461. * conv;
+ byma = 731529. * conv;
+ bresx = 2. * conv;
+ bresy = 2. * conv;
+ maxwab = 100000;
+ mx2o = (int)((bxma - bxmi) / bresx);
+ my2o = (int)((byma - bymi) / bresy);
+ /* relative small box coordinates: leave 1 grid layer for overlap */
+ bxmi = bxmi - mixx + stepx;
+ bymi = bymi - miyy + stepy;
+ bxma = bxma - mixx - stepx;
+ byma = byma - miyy - stepy;
+ mx2 = mx2o - 2 * ((int)(stepx / bresx));
+ my2 = my2o - 2 * ((int)(stepy / bresy));
+#endif
elevin = parm.elevin->answer;
wdepth = parm.wdepth->answer;
dxin = parm.dxin->answer;
Modified: grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c
--- grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c 2008-09-13 06:34:14 UTC (rev 33424)
+++ grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c 2008-09-13 08:28:10 UTC (rev 33425)
@@ -119,51 +119,6 @@
_("Overland flow hydrologic simulation using "
"path sampling method (SIMWE)");
- mixx = conv * cellhd.west;
- maxx = conv * cellhd.east;
- miyy = conv * cellhd.south;
- mayy = conv * cellhd.north;
- mx = cellhd.cols;
- my = cellhd.rows;
- xmin = 0.;
- ymin = 0.;
- bxmi=2093113. * conv;
- bymi=731331. * conv;
- bxma=2093461. * conv;
- byma=731529. * conv;
- bresx=2. * conv;
- bresy=2. * conv;
- maxwab=100000;
- mx2o= (int)((bxma-bxmi)/bresx);
- my2o= (int)((byma-bymi)/bresy);
- mx2 = mx2o - 2*((int) (stepx / bresx));
- my2 = my2o - 2*((int) (stepy / bresy));
@@ -232,7 +187,6 @@
_("Name of the flow controls raster map (permeability ratio 0-1)");
parm.traps->guisection = _("Input_options");
- /* needs to be updated to GRASS 6 vector format !! */
parm.sfile = G_define_standard_option(G_OPT_V_INPUT);
parm.sfile->key = "vector";
parm.sfile->required = NO;
@@ -268,7 +222,6 @@
_("Number of walkers, default is twice the no. of cells");
@@ -332,11 +285,7 @@
parm.hbeta->description =
_("Weighting factor for water flow velocity vector");
parm.hbeta->guisection = _("Parameters");
flag.tserie = G_define_flag();
@@ -345,13 +294,36 @@
exit(EXIT_FAILURE);
- /* mscale=flag.mscale->answer; */
+ mixx = conv * cellhd.west;
+ maxx = conv * cellhd.east;
+ miyy = conv * cellhd.south;
+ mayy = conv * cellhd.north;
+ mx = cellhd.cols;
+ my = cellhd.rows;
+ xmin = 0.;
+ ymin = 0.;
ts = flag.tserie->answer;
dyin = parm.dyin->answer;
- /* maskmap = parm.maskmap->answer; */
rain = parm.rain->answer;
infil = parm.infil->answer;
traps = parm.traps->answer;
