[GRASS-SVN] r33432 - grass/branches/develbranch_6/mswindows
svn_grass at osgeo.org
Sat Sep 13 06:33:32 EDT 2008
Author: marcopx
Date: 2008-09-13 06:33:32 -0400 (Sat, 13 Sep 2008)
New Revision: 33432
grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
Fixed bug in retrieving the UserName on OS <= XP
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2008-09-13 09:51:02 UTC (rev 33431)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2008-09-13 10:33:32 UTC (rev 33432)
@@ -2,7 +2,7 @@
;GRASS Installer for Windows
;Written by Marco Pasetti
-;Last Update: 16 July 2008
+;Last Update: 13 September 2008
;Mail to: marco.pasetti at alice.it
@@ -572,11 +572,25 @@
;Set the USERNAME variable
Var /GLOBAL USERNAME
+ Var /GLOBAL PROFILE_DRIVE
+ Var /GLOBAL PROFILE_ROOT
+ ;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
+ ;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
+ ;It first read the $PROFILE variable, to scan the OS version:
+ ;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE - "drive:\Users\"
+ ;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE - "drive:\Documents and Settings\"
${If} $USERNAME = ""
- ${StrReplace} "$USERNAME" "C:\Users\" "" "$PROFILE"
+ StrCpy $PROFILE_DRIVE "$PROFILE" 2
+ StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
+ ${If} $USERNAME = "Users"
+ ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
+ ${Else}
+ ${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
+ ${EndIf}
${EndIf}
;Create the $INSTALL_DIR\msys\home and the $INSTALL_DIR\msys\home\$USERNAME directories
