[GRASS-SVN] r33445 - grass/branches/develbranch_6/ps/ps.map
svn_grass at osgeo.org
Mon Sep 15 03:31:34 EDT 2008
Author: hamish
Date: 2008-09-15 03:31:34 -0400 (Mon, 15 Sep 2008)
New Revision: 33445
grass/branches/develbranch_6/ps/ps.map/description.html
grass/branches/develbranch_6/ps/ps.map/ps_fclrtbl.c
better units label placement + adjustable (code)
Modified: grass/branches/develbranch_6/ps/ps.map/description.html
--- grass/branches/develbranch_6/ps/ps.map/description.html 2008-09-15 00:04:32 UTC (rev 33444)
+++ grass/branches/develbranch_6/ps/ps.map/description.html 2008-09-15 07:31:34 UTC (rev 33445)
@@ -239,38 +239,45 @@
</PRE>
The color table will display the colors for each raster map layer
category value and the category label.
-If <B>raster</B> is omitted, the colortable defaults to a previously registered raster layer.
+If <B>raster</B> is omitted, the colortable defaults to a previously
+registered raster layer.
The legend's <B>range</B> can be adjusted for floating point rasters, but if
set beyond the extent of the map's range be sure that you have set up color
rules with <em>r.colors</em> which cover this range.
The default location for the colortable is immediately below any other
map legend information, starting at the left margin.
The default text color is black.
Omitting the <B>colortable</B> instruction would result in
no color table. For floating point legends <B>width</B> is width of color
band only. <B>height</B> is used only for floating point legend.
Adding the <B>nodata n</B> instruction will prevent the "no data" box
from being drawn (category based legends only).
Adding the <B>tickbar y</B> instruction will change the tick mark style
so that ticks are drawn across the color table instead of protruding out
to the right (floating point legends only).
+If the map has been given a data units label with r.support then this
+label will be displayed.
+<!-- bonus prize for code explorers: you can switch the label placement by
+ editing the label_posn variable in ps.map/ps_fclrtbl.c -->
<P>
-<B>Note</B>: Be careful about asking for color tables for
+<B>Note</B>: Be careful about asking for color tables for integer
raster map layers which have many categories, such as elevation.
This could result in the printing of an extremely long color table!
<P>
Another issue is that the color table only includes categories which
have a label. If there are only a few categories, you can use
r.support to manually add labels. If there are too many categories to
-do this, you could write a script to add dummy labels to the cats file<br>
-(<gisdbase>/<location>/<mapset>/cats/<mapname>).
+do this by hand, you can supply a label rules file to the r.category
+module.
<P>
If the colortable is turned off with a "<tt>colortable n</tt>"
instruction the <B>end</B> command should not be given as the
main command will be treated as a single line instruction.
<P>
This example would print a color table immediately below any other map legend
information, starting at the left margin, with 4 columns:
<PRE>
@@ -1157,7 +1164,8 @@
This reference point specifies the text handle - what
part of the text should be placed on the location specified by the map
coordinates. Reference points can refer to:
-[lower|upper|center] [left|right|center] of the text to be printed; The default is center center, i.e the text is centered on the reference point.
+[lower|upper|center] [left|right|center] of the text to be printed;
+The default is center center, i.e the text is centered on the reference point.
<P>
<B>rotate</B>
sets the text rotation angle, measured in degrees counter-clockwise.
@@ -1256,8 +1264,8 @@
simple PostScript commands. It is similar to EPS but more limited, meaning that
while each pattern file is a true EPS file, most EPS files are not useful as pattern
files because they contain restricted commands. Color and width of patterns are set
-by <B>fcolor</B> (red, green, ..., none, R:G:B) and <B>width</B> until overwritten
-in the pattern file.
+by <B>fcolor</B> (red, green, ..., none, R:G:B) and <B>width</B> until
+overwritten in the pattern file.
Pattern may be scaled with the <b>scale</b> command. Several standard hatching
patterns are provided in <tt>$GISBASE/etc/paint/patterns/</tt>.
Demonstrative images can be found on the
Modified: grass/branches/develbranch_6/ps/ps.map/ps_fclrtbl.c
--- grass/branches/develbranch_6/ps/ps.map/ps_fclrtbl.c 2008-09-15 00:04:32 UTC (rev 33444)
+++ grass/branches/develbranch_6/ps/ps.map/ps_fclrtbl.c 2008-09-15 07:31:34 UTC (rev 33445)
@@ -26,7 +26,7 @@
int R, G, B;
DCELL dmin, dmax, val;
double t, l, r; /* legend top, left, right */
- double x1, x2, y, dy, fontsize;
+ double x1, x2, y, dy, fontsize, xu, yu;
double col_width;
double width; /* width of legend in map units */
double height; /* width of legend in map units */
@@ -40,7 +40,7 @@
double ex, cur_d, cur_ex;
int do_color;
double grey_color_val, margin;
- int max_label_length = 0;
+ int max_label_length = 0, label_posn, label_xref, label_yref;
/* let user know what's happenning */
G_message(_("Creating color table for <%s in %s>..."),
@@ -251,17 +251,66 @@
if (G_read_raster_units(ct.name, ct.mapset, units) != 0)
units[0] = '\0';
- /* TODO: nicer placement as label length changes; realign for tickbar mode */
if(strlen(units)) {
margin = 0.2 * fontsize;
if (margin < 2)
margin = 2;
fprintf(PS.fp, "/mg %.1f def\n", margin);
- text_box_path( x2 + max_label_length*(fontsize*.7),
- t - height/2,
- LEFT, CENTER, units, fontsize, 0);
+ /* select label position */
+ label_posn = 3;
+ /* 1 2
+ 3
+ 5 4 */
+ switch (label_posn) {
+ case 1:
+ /* above the tick numbers */
+ xu = x1;
+ yu = t + 0.05*72;
+ label_xref = LEFT;
+ label_yref = LOWER;
+ break;
+ case 2:
+ /* directly above the tick numbers */
+ if (ct.tickbar)
+ xu += x1 + 0.2 * fontsize;
+ else
+ xu += x2 + 0.2 * fontsize;
+ yu = t + 0.05*72;
+ break;
+ case 3:
+ /* to the right of the tick numbers */
+ xu = 0.15*72 + max_label_length*fontsize*0.5;
+ if (ct.tickbar)
+ xu += x1;
+ else
+ xu += x2;
+ yu = t - height/2;
+ label_yref = CENTER;
+ break;
+ case 4:
+ /* directly below the tick numbers */
+ if (ct.tickbar)
+ else
+ yu = t - height - 0.05*72;
+ label_yref = UPPER;
+ break;
+ case 5:
+ /* below the tick numbers */
+ xu = x1;
+ break;
+ text_box_path( xu, yu, label_xref, label_yref, units, fontsize, 0);
set_rgb_color(BLACK);
fprintf(PS.fp, "TIB\n");
