[GRASS-SVN] r33451 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Mon Sep 15 04:34:46 EDT 2008
Author: hamish
Date: 2008-09-15 04:34:46 -0400 (Mon, 15 Sep 2008)
New Revision: 33451
grass/trunk/ps/ps.map/ps_fclrtbl.c
add label placement hint (merge from devbr6)
Modified: grass/trunk/ps/ps.map/ps_fclrtbl.c
--- grass/trunk/ps/ps.map/ps_fclrtbl.c 2008-09-15 08:34:27 UTC (rev 33450)
+++ grass/trunk/ps/ps.map/ps_fclrtbl.c 2008-09-15 08:34:46 UTC (rev 33451)
@@ -257,6 +257,13 @@
margin = 2;
fprintf(PS.fp, "/mg %.1f def\n", margin);
+ /* Hint from Glynn:
+ You can use the `stringwidth` operator to obtain the width of a string
+ (the distance that the current point will move if you `show` the string).
+ If the string is short, you can obtain the bounding box with a combination
+ of the `charpath` and `pathbbox` operators (if the string is long,
+ `charpath` may overflow the maximum path length). */
/* select label position */
label_posn = 3;
/* 1 2
