[GRASS-SVN] r33468 - grass/trunk/include
svn_grass at osgeo.org
Tue Sep 16 04:51:15 EDT 2008
Author: glynn
Date: 2008-09-16 04:51:15 -0400 (Tue, 16 Sep 2008)
New Revision: 33468
grass/trunk/include/Vect.h
grass/trunk/include/gisdefs.h
Remove/disable declarations for non-existent functions
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h 2008-09-16 08:20:24 UTC (rev 33467)
+++ grass/trunk/include/Vect.h 2008-09-16 08:51:15 UTC (rev 33468)
@@ -323,6 +323,10 @@
int Vect_overlay(struct Map_info *, int, struct ilist *, struct ilist *,
int, struct Map_info *);
+int Vect_overlay_and(struct Map_info *, int, struct ilist *,
+ struct ilist *, struct Map_info *, int,
+ struct ilist *, struct ilist *,
+ struct Map_info *);
/* Graph */
void Vect_graph_init(GRAPH *, int);
@@ -403,8 +407,6 @@
/* Read/write lines */
int V1_read_line_nat(struct Map_info *, struct line_pnts *,
struct line_cats *, long);
-int V1_read_next_line(struct Map_info *, struct line_pnts *,
- struct line_cats *);
int V1_read_next_line_nat(struct Map_info *, struct line_pnts *,
int V1_read_next_line_ogr(struct Map_info *, struct line_pnts *,
@@ -413,30 +415,28 @@
struct line_cats *, int);
int V2_read_line_ogr(struct Map_info *, struct line_pnts *,
-int V2_read_next_line(struct Map_info *, struct line_pnts *,
int V2_read_next_line_nat(struct Map_info *, struct line_pnts *,
int V2_read_next_line_ogr(struct Map_info *, struct line_pnts *,
-int V1_delete_line(struct Map_info *, long);
-int V2_delete_line(struct Map_info *, int);
int V1_delete_line_nat(struct Map_info *, long);
int V2_delete_line_nat(struct Map_info *, int);
long V1_write_line_nat(struct Map_info *, int type, struct line_pnts *,
long V2_write_line_nat(struct Map_info *, int type, struct line_pnts *,
+#if 0
long V1_write_line_ogr(struct Map_info *, int type, struct line_pnts *,
-long V1_rewrite_line(struct Map_info *, long offset, int type,
- struct line_pnts *, struct line_cats *);
+#endif
long V1_rewrite_line_nat(struct Map_info *, long offset, int type,
int V2_rewrite_line_nat(struct Map_info *, int line, int type,
+#if 0
long V1_rewrite_line_ogr(struct Map_info *, long offset, int type,
+#endif
/* Miscellaneous */
int Vect_build_nat(struct Map_info *, int, FILE *);
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2008-09-16 08:20:24 UTC (rev 33467)
+++ grass/trunk/include/gisdefs.h 2008-09-16 08:51:15 UTC (rev 33468)
@@ -640,9 +640,6 @@
double, double, double *, double *, double *,
double *);
-/* intr_char.c */
-char G_intr_char(void);
/* is.c */
int G_is_gisbase(const char *);
int G_is_location(const char *);
@@ -768,7 +765,6 @@
void G_newlines_to_spaces(char *);
/* nme_in_mps.c */
-int G__name_in_mapset(const char *, char *, char *);
int G__name_is_fully_qualified(const char *, char *, char *);
char *G_fully_qualified_name(const char *, const char *);
int G__unqualified_name(const char *, const char *, char *, char *);
