[GRASS-SVN] r33474 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Sep 17 02:54:59 EDT 2008
Author: glynn
Date: 2008-09-17 02:54:59 -0400 (Wed, 17 Sep 2008)
New Revision: 33474
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
Change grass6 -> grass7
Remove PyOpenGL references
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-09-17 03:35:56 UTC (rev 33473)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-09-17 06:54:59 UTC (rev 33474)
@@ -2677,11 +2677,6 @@
"included with this build "
"of wxPython! Switching back to "
"2D display mode.\n\nDetails: %s" % nviz.errorMsg)
- if not nviz.haveOpenGL:
- msg = _("Unable to start Nviz. The OpenGL package "
- "was not found. You can get it "
- "at http://PyOpenGL.sourceforge.net. "
- "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg)
if not nviz.haveNviz:
msg = _("Unable to start Nviz. Python extension "
"for Nviz was not found or loaded properly. "
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-09-17 03:35:56 UTC (rev 33473)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-09-17 06:54:59 UTC (rev 33474)
@@ -29,18 +29,11 @@
except ImportError, e:
haveGLCanvas = False
errorMsg = e
-try:
- from OpenGL.GL import *
- from OpenGL.GLUT import *
- haveOpenGL = True
-except ImportError, e:
- haveOpenGL = False
- errorMsg = e
import globalvar
try:
sys.path.append(os.path.join(globalvar.ETCWXDIR, "nviz"))
- import grass6_wxnviz as wxnviz
+ import grass7_wxnviz as wxnviz
haveNviz = True
haveNviz = False
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2008-09-17 03:35:56 UTC (rev 33473)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2008-09-17 06:54:59 UTC (rev 33474)
@@ -37,7 +37,7 @@
from goutput import wxCmdOutput as wxCmdOutput
-import grass6_wxnviz as wxnviz
+import grass7_wxnviz as wxnviz
wxUpdateProperties, EVT_UPDATE_PROP = NewEvent()
wxUpdateView, EVT_UPDATE_VIEW = NewEvent()
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-09-17 03:35:56 UTC (rev 33473)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-09-17 06:54:59 UTC (rev 33474)
@@ -30,7 +30,7 @@
from nviz_mapdisp import wxUpdateProperties as wxUpdateProperties
class NvizToolWindow(wx.Frame):
"""Experimental window for Nviz tools
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-17 03:35:56 UTC (rev 33473)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-09-17 06:54:59 UTC (rev 33474)
@@ -1303,7 +1303,7 @@
class CDisplayDriver(AbstractDisplayDriver):
- Display driver using grass6_wxdriver module
+ Display driver using grass7_wxdriver module
def __init__(self, parent, mapwindow):
"""Initialization
